TMS320C6657: [TMS320C6657] how to configure cfg file to enable inter-core communication between 2 cores using shared region and message Q
Part Number: TMS320C6657
Hi.
as the title said, I'd like to know how to configure both cfg file to make share region and message Q available.
and my plan is to get two cores share data vwith message Q via shared memory.
Could you give me any example that I can adjust my application?
especially I have been looking up the configuration example of shared region. however I am quite confused same configuration should be included in both cfg file of two cores.
for example, I am not sure that I have to include the below configuration in each cfg file
sharedRegion.setEntryMeta(0,{
Please show me the best practice for enabling the modules. I need your help so much.
ysshim
  • Dear Customer,
    By any chance, have you practiced the example, that I have answered to your previous e2e query below?? Please practice that example. Because, that example has the configuration file which enables the shared memory region and the message Q.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1057109/tms320c6657-tms320c6657
    In the IPC-SRC example, you will find the configuration file, located at C:\ti\pdk_c665x_2_0_16\packages\ti\transport\ipc\c66\srio\example\c6657\c66\bios\bench_srio.cfg
    In this cfg file, you can observe the initialization of sharedmemory and the message Q.
    IPC_SRIO - This is the " Example application that uses the SRIO IPC transport to send* MessageQ messages between two DSP cores. "
    Shankari G
  • Dear, Shankari G
    what I am curious about is the both cfg file of two cores use the same 'bench_srio.cfg' ?
    I am guessing configuring cfg file would be different based on which core.
    I understand there are tons of example and materials talking about IPC module usage
    but it is quite hard for me as a beginner to find the correct examples that meet my need and how to run those.
    I am still working on it following the instructions and examples described in this document ''SYS/BIOS IPC 1.25" and studying the example you showed me.
    but I am facing unexpected issue such as getting stuck into 'IPC_start' function after I include Multiproc module initialization in cfg files.
    and I still don't know why.
    Thank you so much for your sincere help. I want to solve it for my project team.
    ysshim
  • Dear, Shankari G
    when I run the SRIO example.
    message on my console window is different from a footage you showed me before.
    core 0 and core 1 MessageQ_create failed.
    what happen?
    and what i notice is that when 'IPC_Start' function run on both cores only with ipc and sharedregion configuration on cfg file.
    I got a 'success' message from 'IPC_Start' function on both core. however when I add Multiproc configuration on both cfg files
    codes are stuck into IPC_start function.
    i just copied Multiproc configuration from SRIO example to my applications.
    I don't know why...
    ysshim
  • Dear Customer,
    Please post your error messages and the screenshot of CCS. Let us solve them.
    It worked for me. So it should directly work for you too.
    Shankari G
  • Dear Shankari G
    I have created new projects for simple test on IPC configuration.
    the issue I have had on Maltiproc doesn't happen with new projec, which makes me examine my previous application.
    the test of running the SRIO example failed yesterday was carried out with a hardware module that my team developed.
    so I changed it to 6678 EVM and I tried the example again. and I verified it worked fine as you showed me before.
    It seems to be ok with me to go next step.
    you are the best.
    ysshim
  • Dear ysshim,
    That's a great news. You made it man!.
    By the way, you are best too!.
    As it now works for you, with your permission,  shall I close this thread ?
    Shankari G
  • Yeah good to close
    ysshim
