I have followed file:///home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/docs/user_guide/BUILD_INSTRUCTIONS.html , trying to build mmalib_02_01_00_07 from source inside installed psdk which name is ti-processor-sdk-rtos-j721e-evm-08_00_00_12. The script I'm using is
#!/bin/sh
PSDK_RTOS_PATH=$HOME/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12
MMALIB_PATH=${PSDK_RTOS_PATH}/mmalib_02_01_00_07
MMALIB_CGT7X_COMPILER_DIR=${PSDK_RTOS_PATH}/ti-cgt-c7000_1.4.2.LTS
# Setup needed the compiler for CGT7x
export CGT7X_ROOT=${MMALIB_CGT7X_COMPILER_DIR}
# Setup for HOST EMULATION
export C7X_HOST_EMULATION_PATH=${CGT7X_ROOT}/host_emulation
# Path setup
export PATH=${CGT7X_ROOT}/bin:${PATH}
cd $MMALIB_PATH
echo
echo 'Compile the code from the MMALIB_xx_xx_xx_xx folder'
echo
echo 'Compile the libraries for target'
echo
make -j$(nproc) mmalib mmalib_cn common test TARGET_CPU=C7100 TARGET_BUILD=debug CHECKPARAMS=1
But got following errors, which folder path following c71 and c7100 can not fould:
--mma------------------------------------start ------------------
TARGET_CPU=C7100
TARGET_BUILD=debug
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/test/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolve_row_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_row_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnected_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_tensor_convert_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_pixelShuffle_row_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_fir_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/dsp_c7xmma/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_firSmall_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftLarge_ixX_cxX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftSmall_ixX_cxX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_fft_ixX_cxX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_highRadixDecompositions_ixX_cxX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_pointwiseMatrixMatrixMultiply_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiplyAccumulate_ixX_ixX_ixX_oxX/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i32fc_c32fc_o32fc/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i16sc_c16sc_o16sc/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i16sc_c16sc_o16sc/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i32fc_c32fc_o32fc/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/c71’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolve_row_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_row_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnected_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_tensor_convert_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_pixelShuffle_row_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_fir_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/dsp_c7xmma/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_firSmall_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftLarge_ixX_cxX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftSmall_ixX_cxX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_fft_ixX_cxX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_highRadixDecompositions_ixX_cxX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_pointwiseMatrixMatrixMultiply_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiplyAccumulate_ixX_ixX_ixX_oxX/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i32fc_c32fc_o32fc/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i16sc_c16sc_o16sc/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i16sc_c16sc_o16sc/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i32fc_c32fc_o32fc/c7100’: No such file or directory
find: ‘/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/ti/mmalib/src/fft_c7x/c7100’: No such file or directory
HOST_ROOT=/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07
HOST_COMPILER=CGT7X
HOST_OS=LINUX
HOST_CPU=x86_64
HOST_ARCH=64
TARGET_OS=NO_OS
TARGET_CPU=C7100
MMA_IMPLEMENTATION=HARDWARE
TEST_ENV=LOKI
TARGET_PLATFORM=
TARGET_BUILD=debug
TARGET_OUT=/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug
TARGET_DOC=/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/docs
MODULES= common test mmalib mmalib_cn mmalib_d linker_cmd regress_linker_cmd regress mma_self_test
SCM_ROOT=
SCM_VERSION=
Linking /home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/mmalib_C7100.lib
make: Nothing to be done for 'common'.
Linking /home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/mmalib_cn_C7100.lib
==> building archive '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/mmalib_C7100.lib'
==> building archive '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/mmalib_cn_C7100.lib'
Linking /home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/test_C7100.lib
--> error: '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/module/test/test/TI_profile.obj' not found
--> error: '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/module/test/test/TI_test.obj' not found
--> error: '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/module/test/test/TI_memory.obj' not found
--> error: '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/module/test/test/c71/TI_cache.obj' not found
==> new archive '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/test_C7100.lib'
==> building archive '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/test_C7100.lib'
make: [concerto/finale.mak:120: /home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/mmalib_02_01_00_07/out/C7100/debug/test_C7100.lib] Error 1 (ignored)
