For the MCAL ti-processor-sdk-rtos-j721e-evm-07_03_00_07,
In Icu module, the Icu_Irq.c at line no. 162, the code present is
{code:java}
#define PWM_STOP_SEC_ISR_CODE
#include "Pwm_MemMap.h"
{code}
Since it's an Icu module and further the START_SEC is being assigned as
{code:java}
#define ICU_START_SEC_ISR_CODE
#include "Icu_MemMap.h"
{code}
Due to the presence of incorrect STOP_SEC and memmap file inclusion it results in compilation failure.
Refer the updated EB_update file after which there is no issue in compilation .
/* * * Copyright (c) 2020 Texas Instruments Incorporated * * All rights reserved not granted herein. * * Limited License. * * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive * license under copyrights and patents it now or hereafter owns or controls to make, * have made, use, import, offer to sell and sell ("Utilize") this software subject to the * terms herein. With respect to the foregoing patent license, such license is granted * solely to the extent that any such patent is necessary to Utilize the software alone. * The patent license shall not apply to any combinations which include this software, * other than combinations with devices manufactured by or for TI ("TI Devices"). * No hardware patent is licensed hereunder. * * Redistributions must preserve existing copyright notices and reproduce this license * (including the above copyright notice and the disclaimer and (if applicable) source * code license limitations below) in the documentation and/or other materials provided * with the distribution * * Redistribution and use in binary form, without modification, are permitted provided * that the following conditions are met: * * * No reverse engineering, decompilation, or disassembly of this software is * permitted with respect to any software provided in binary form. * * * any redistribution and use are licensed by TI for use only with TI Devices. * * * Nothing shall obligate TI to provide you with source code for the software * licensed and provided to you in object code. * * If software source code is provided to you, modification and redistribution of the * source code are permitted provided that the following conditions are met: * * * any redistribution and use of the source code, including any resulting derivative * works, are licensed by TI for use only with TI Devices. * * * any redistribution and use of any object code compiled from the source code * and any resulting derivative works, are licensed by TI for use only with TI Devices. * * Neither the name of Texas Instruments Incorporated nor the names of its suppliers * * may be used to endorse or promote products derived from this software without * specific prior written permission. * * DISCLAIMER. * * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED * OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** * \file Icu_Irq.c * * \brief This file contains the ISR implementation of ICU MCAL driver * */ /* ========================================================================== */ /* Include Files */ /* ========================================================================== */ #include "Icu_Priv.h" #include "Icu_Irq.h" /* ========================================================================== */ /* Macros & Typedefs */ /* ========================================================================== */ /* None */ /* ========================================================================== */ /* Structures and Enums */ /* ========================================================================== */ /* None */ /* ========================================================================== */ /* Internal Function Declarations */ /* ========================================================================== */ /* None */ /* ========================================================================== */ /* Global Variables */ /* ========================================================================== */ /* None */ /* ========================================================================== */ /* Function Definitions */ /* ========================================================================== */ #define ICU_START_SEC_ISR_CODE #include "Icu_MemMap.h" ICU_ISR_TEXT_SECTION void Icu_ch0Notify(void) { #if (STD_ON == ICU_DEV_ERROR_DETECT) uint32 baseAddr = Icu_GetBaseAddr(ICU_CHANNEL0); if (ICU_STATUS_INIT != Icu_DrvStatus) { /* Disable and Clear Interrupt */ ECAPIntDisable(baseAddr, ECAP_INT_ALL); ECAPIntStatusClear(baseAddr, ECAP_INT_ALL); } else #endif { Icu_ChannelISR(ICU_CHANNEL0); } } ICU_ISR_TEXT_SECTION void Icu_ch1Notify(void) { #if (STD_ON == ICU_DEV_ERROR_DETECT) uint32 baseAddr = Icu_GetBaseAddr(ICU_CHANNEL1); if (ICU_STATUS_INIT != Icu_DrvStatus) { /* Disable and Clear Interrupt */ ECAPIntDisable(baseAddr, ECAP_INT_ALL); ECAPIntStatusClear(baseAddr, ECAP_INT_ALL); } else #endif { Icu_ChannelISR(ICU_CHANNEL1); } } ICU_ISR_TEXT_SECTION void Icu_ch2Notify(void) { #if (STD_ON == ICU_DEV_ERROR_DETECT) uint32 baseAddr = Icu_GetBaseAddr(ICU_CHANNEL2); if (ICU_STATUS_INIT != Icu_DrvStatus) { /* Disable and Clear Interrupt */ ECAPIntDisable(baseAddr, ECAP_INT_ALL); ECAPIntStatusClear(baseAddr, ECAP_INT_ALL); } else #endif { Icu_ChannelISR(ICU_CHANNEL2); } } #define ICU_STOP_SEC_ISR_CODE #include "Icu_MemMap.h"
Update :
{code:java}
{code}
*ICU_STOP section and Icu memmap.h file inclusion.*
Please let us know regarding this issue since its a blocker for our release.
Kamia
