Customer wants to implement MCSPI to trigger EDMA. He modified based on processor_sdk_rtos_am57xx_06_03_02_08\pdk_am57xx_1_0_18\packages\ti\csl\example\mcspi\mcspiMasterSlave\mcspiMasterSlave_spi1_spi2.c
MCSPI1 can transmit successfully in loopback mode, However, when using EDMA, the interrupt cannot be triggered. Below is spi code:
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/Diags.h>
#include <xdc/runtime/Log.h>
#include <xdc/runtime/Assert.h>
#include <xdc/runtime/Registry.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/hal/Hwi.h>
#include <ti/ipc/Ipc.h>
#include <ti/ipc/MessageQ.h>
#include <ti/ipc/MultiProc.h>
#include <stdio.h>
#include <ti/csl/example/utils/common/inc/app_utils.h>
#include <ti/csl/soc.h>
#include <ti/csl/hw_types.h>
#include <ti/csl/csl_edma.h>
#include <ti/csl/arch/csl_arch.h>
#include <ti/drv/spi/SPI.h>
#include <ti/csl/csl_mcspi.h>
#include <ti/drv/spi/soc/SPI_soc.h>
#include <ti/drv/spi/src/SPI_osal.h>
//#include "bsp_spi.h"
//#include "edma_test.h"
#include <ti/osal/HwiP.h>
#include <ti/csl/csl_types.h>
#include <ti/csl/arch/c66x/interrupt.h>
#include <ti/csl/soc/am571x/src/cslr_soc_dsp_baseaddress.h>
#include <ti/csl/src/ip/edma/V1/edma.h>
#include <ti/csl/src/ip/edma/V1/hw_edma_tpcc.h>
/* Macros */
//#define McSPI_DATA_COUNT 50U // Data Count Transaction
#define MCSPI_INSTANCE 0//0-spi1 1-spi2 2-spi3
#define MCSPI_POLLED_MODE 0
#define HSI2C_EN_SPI2 ((uint8_t) 0x40U)
#define HSI2C_ZERO ((uint8_t) 0x00U)
#define MCSPI_OUT_FREQ (48000000U)
#define MCSPI_IN_CLK (48000000U)
#define McSPI_DATA_COUNT 256U // Data Count Transaction
#define MCSPI1_BASE_ADDRESS (CSL_MPU_MCSPI1_REGS)
#define MCSPI2_BASE_ADDRESS (CSL_MPU_MCSPI2_REGS)
/** \brief EDMA3 channel for SPI1 Channel 0 Tx and Rx*/
#define MCSPI1_TX_EVENT (34U)
#define MCSPI1_RX_EVENT (35U)
/** \brief EDMA3 channel for SPI2 Channel 0 Tx and Rx*/
#define MCSPI2_TX_EVENT (42U)
#define MCSPI2_RX_EVENT (43U)
/** \brief MCSPI Tx/Rx buffer base address */
#define MCSPI1_TX0_REG (SOC_MCSPI1_BASE + (0x138U))
#define MCSPI1_RX0_REG (SOC_MCSPI1_BASE + (0x13CU))
#define MCSPI2_TX0_REG (SOC_MCSPI2_BASE + (0x138U))
#define MCSPI2_RX0_REG (SOC_MCSPI2_BASE + (0x13CU))
/** \brief MCSPI Channel number*/
#define MCSPI_CH_NUM (0U)
#define EVT_QUEQUE_NUM (0U)
#define DUMMY_CH_NUM (5U)
#define EDMA_TDA2XX_U_BASE (CSL_DSP_DSP_EDMA_CC_REGS)
#define EDMA3CC_PaRAM_BASE (0x4000)
#define EDMA3CC_OPT(n) (EDMA3CC_PaRAM_BASE + 0x0 + (0x20 * n))
#define EDMA3_CC_XFER_COMPLETION_INT_A15 (12U)
#define EDMA3_CC_XFER_COMPLETION_INT_M4 (35U)
/* DSP1 EDMA3 transfer event number */
#define DSP1_EDMA3_CC_XFER_COMPLETION_INT 19
#define DSP1_EDMA3_CC_ERROR_INT 27
/* DSP1 EDAM3 region number */
#define DSP1_EDMA3_REGION 2
/* DSP1 EDMA3 channel number */
#define DSP1_EDMA3_CHANNEL 0
/* DSP1 EDMA3 tcc number */
#define DSP1_EDMA3_TCC 0
/* DSP1 EDMA3 evtq number */
#define DSP1_EDMA3_EVTQ 0
/* OPT Field specific defines */
#define OPT_SYNCDIM_SHIFT (0x00000002u)
#define OPT_TCC_MASK (0x0003F000u)
#define OPT_TCC_SHIFT (0x0000000Cu)
#define OPT_ITCINTEN_SHIFT (0x00000015u)
#define OPT_TCINTEN_SHIFT (0x00000014u)
#define OPT_TCCMOD_SHIFT (0x0000000Bu)
#define EDMA3_ERROR_INT_A15 (14)
#define EDMA3_ERROR_INT_A15_1 (15)
#define EDMA3_ERROR_INT_M4 (36)
#define EDMA3_ERROR_INT_M4_1 (37)
#define EDMA3_CC_REGION_A15 (0U)
#define EDMA3_CC_REGION_M4 (1U)
#define MCSPI_MASTERSLAVE_POLLED_MODE_TEST ('1')
#define MCSPI_MASTERSLAVE_DMA_MODE_TEST ('2')
#define EXIT(opt) (('x' == opt) || ('X' == opt))
************************** Global Variables **************************
uint32_t dataToSlave;
uint32_t gChNum = 0;
uint32_t length = 0;
uint8_t dataFromSlave;
uint8_t rxBuffer[McSPI_DATA_COUNT + 10];
uint8_t txBuffer[McSPI_DATA_COUNT + 10];
uint8_t txSlvBuffer[McSPI_DATA_COUNT + 10];
uint8_t rxSlvBuffer[McSPI_DATA_COUNT + 10];
uint8_t gRxBuffer[McSPI_DATA_COUNT];
uint8_t gTxBuffer[McSPI_DATA_COUNT];
static void(*cb_Fxn[EDMA3_NUM_TCC]) (uint32_t tcc,
uint32_t status);
volatile uint8_t flagTx = 0;
volatile uint8_t flagRx = 0;
volatile uint8_t flagSlvTx = 0;
volatile uint8_t flagSlvRx = 0;
/* Function Declarations */
/* ========================================================================== *//* clock callback function */
void SPI_callback(SPI_Handle handle, SPI_Transaction *transaction);
static void McSPI1SetUp(void);
static void McSPIMSTransfer(uint16_t length);
static void McSPIVerifyData(void);
static void McSPIInitializeBuffers(void);
void McSPIMasterSlaveAppTest(void);
static void McSPIConfigureDma(uint32_t length);
static void McSpi1TxEdmaParamSet(uint32_t tccNum, uint32_t chNum,
volatile uint8_t *buffer,
uint16_t buffLength);
static void McSpi1RxEdmaParamSet(uint32_t tccNum, uint32_t chNum,
uint16_t buffLength,
uint32_t destBidxFlag);
static void CallBack_McSPI1(uint32_t tccNum, uint32_t status);
static void TxDummyPaRAMConfEnable(void);
static void RequestEDMA3Channels(void);
static void EDMA3Initialize(void);
static void spiedma_cb_isr(UInt32 event_id);
static int EDMA3IntConfigure(void);
/* Function Definitions */
/* Do the necessary set up configurations for McSPI.*/
// EDMA3Init(EDMA_TDA2XX_U_BASE, 0);
/* Initialize the EDMA3 instance.*/
EDMA3Initialize();
/* Request EDMA3CC for Tx and Rx channels for SPI0. */
RequestEDMA3Channels();
McSPI1SetUp();
McSPIInitializeBuffers();
McSPIConfigureDma(McSPI_DATA_COUNT);
McSPIMSTransfer(McSPI_DATA_COUNT);
Task_sleep(1000);
/* Verify whether the data written by Master and the one read by
* Slave are Equal */
McSPIVerifyData();
/* Configuring the AINTC to receive EDMA3 Interrupts */
EDMA3IntConfigure();
** This function configures the AINTC to receive EDMA3 interrupts.
#ifdef _TMS320C6X
/* Initialize DSP interrupt controller and enable interrupts */
Hwi_Params hwiParams;
Error_Block eb;
EDMAsetRegion(DSP1_EDMA3_REGION);
EDMA3Init(CSL_DSP_DSP_EDMA_CC_REGS, 0);
Hwi_Params_init(&hwiParams);
Error_init(&eb);
/* set the event id of the peripheral assigned to this interrupt */
hwiParams.eventId = DSP1_EDMA3_CC_XFER_COMPLETION_INT;
/* set the argument passed to ISR function */
hwiParams.arg = DSP1_EDMA3_CC_XFER_COMPLETION_INT;
hwiParams.maskSetting = Hwi_MaskingOption_SELF;
Hwi_create(12, spiedma_cb_isr, &hwiParams, &eb);
if (Error_check(&eb)) {
Log_print0(Diags_INFO, "Hwi create failed \n");
return -1;
hwiParams.eventId = DSP1_EDMA3_CC_ERROR_INT;
hwiParams.arg = DSP1_EDMA3_CC_ERROR_INT;
Hwi_create(13, spiedma_cb_isr, &hwiParams, &eb);
return -1;
Hwi_enable();
#endif
System_printf("spiedma_cb_isr...\r\n");
switch(event_id) {
case DSP1_EDMA3_CC_XFER_COMPLETION_INT:
/* Transfer completed successfully */
// (*cb_Fxn[indexl])(indexl, EDMA3_XFER_COMPLETE);
break;
case DSP1_EDMA3_CC_ERROR_INT:
/* Transfer resulted in error. */
break;
default:
break;
EDMA3ClrIntr(CSL_DSP_DSP_EDMA_CC_REGS, DSP1_EDMA3_TCC);
** This function allocates EDMA3 channels to McSPI0 for trasmisssion and
** reception purposes.
/* Request DMA Channel and TCC for SPI Transmit*/
EDMA3RequestChannel(EDMA_TDA2XX_U_BASE, EDMA3_CHANNEL_TYPE_DMA, \
MCSPI1_TX_EVENT, MCSPI1_TX_EVENT, EVT_QUEQUE_NUM);
EDMA3EnableEvtIntr(EDMA_TDA2XX_U_BASE, MCSPI1_TX_EVENT);
/* Request DMA Channel and TCC for SPI Receive*/
MCSPI1_RX_EVENT, MCSPI1_RX_EVENT, EVT_QUEQUE_NUM);
EDMA3EnableEvtIntr(EDMA_TDA2XX_U_BASE, MCSPI1_RX_EVENT);
** This function will call the necessary McSPI APIs which will configure the
** McSPI controller.
uint32_t status = 1U; // FALSE
/* Reset the McSPI instance.*/
McSPIReset(MCSPI1_BASE_ADDRESS);
/* CLOCKACTIVITY bit - OCP and Functional clocks are maintained */
/* SIDLEMODE bit - Ignore the idle request and configure in normal mode
/* AUTOIDLE bit - Disable (OCP clock is running free, no gating) */
MCSPISysConfigSetup(MCSPI1_BASE_ADDRESS, MCSPI_CLOCKS_OCP_ON_FUNC_ON,
MCSPI_SIDLEMODE_NO, MCSPI_WAKEUP_DISABLE,
MCSPI_AUTOIDLE_OFF);
/* Enable chip select pin.*/
McSPICSEnable(MCSPI1_BASE_ADDRESS);
/* Enable master mode of operation.*/
McSPIMasterModeEnable(MCSPI1_BASE_ADDRESS);
/* Perform the necessary configuration for master mode. */
status = McSPIMasterModeConfig(MCSPI1_BASE_ADDRESS, MCSPI_SINGLE_CH,
MCSPI_TX_RX_MODE,
MCSPI_DATA_LINE_COMM_MODE_6,
gChNum);
if (0 == status)
//UARTConfigPuts(uartBaseAddr,"\nMcSPI1 - Communication not supported by SPIDAT[1:0]",-1);
/* Configure the McSPI bus clock depending on clock mode. */
McSPIClkConfig(MCSPI1_BASE_ADDRESS, MCSPI_IN_CLK, MCSPI_OUT_FREQ, gChNum,
MCSPI_CLK_MODE_0);
/* Configure the word length.*/
McSPIWordLengthSet(MCSPI1_BASE_ADDRESS, MCSPI_WORD_LENGTH(8), gChNum);
/* Set polarity of SPIEN to low.*/
McSPICSPolarityConfig(MCSPI1_BASE_ADDRESS,
(MCSPI_CH0CONF_EPOL_ACTIVELOW <<
MCSPI_CH0CONF_EPOL_SHIFT), gChNum);
/* Enable the transmitter FIFO of McSPI peripheral.*/
McSPITxFIFOConfig(MCSPI1_BASE_ADDRESS, MCSPI_TX_FIFO_ENABLE, gChNum);
/* Enable the receiver FIFO of McSPI peripheral.*/
McSPIRxFIFOConfig(MCSPI1_BASE_ADDRESS, MCSPI_RX_FIFO_ENABLE, gChNum);
uint32_t index = 0;
static int cnt = 0;
char msg[McSPI_DATA_COUNT] = {"Initialize the txBuffer McSPI1 with a known pattern of data:"};
for (index = 0; index < McSPI_DATA_COUNT; index++)
/* Initialize the txBuffer McSPI1 with a known pattern of data */
// txBuffer[index] = (uint8_t) index;
/* Initialize the rxBuffer McSPI1 with 0 */
rxBuffer[index] = (uint8_t) 0;
sprintf(txBuffer,"%s%d",msg,cnt++);
txSlvBuffer[index] = (uint8_t) index;
rxSlvBuffer[index] = 0;
/* DMA PaRAM Configuration for McSPI1 */
/* Configure the read data parameters of McSPI for Edma transmit.*/
McSpi1TxEdmaParamSet(MCSPI1_TX_EVENT, MCSPI1_TX_EVENT, txBuffer,
length);
/* Configure the read data parameters of McSPI for Edma receive.*/
McSpi1RxEdmaParamSet(MCSPI1_RX_EVENT, MCSPI1_RX_EVENT, rxBuffer,
length, TRUE);
/* Register the call-back function for Tx/Rx edma events of McSPI.*/
cb_Fxn[MCSPI1_TX_EVENT] = &CallBack_McSPI1;
cb_Fxn[MCSPI1_RX_EVENT] = &CallBack_McSPI1;
/* Set the word count field with the data length to be transferred.*/
McSPIWordCountSet(MCSPI1_BASE_ADDRESS, length);
/* Enable the Tx/Rx DMA events for McSPI. */
McSPIDMAEnable(MCSPI1_BASE_ADDRESS,
(MCSPI_DMA_RX_EVENT | MCSPI_DMA_TX_EVENT),
MCSPI_CH_NUM);
** Call back function. Here we disable the Tx/Rx DMA events of McSPI
** peripheral.
System_printf("CallBack_McSPI1...\r\n");
if (tccNum == MCSPI1_TX_EVENT)
flagTx = 1;
System_printf("MCSPI1_TX_EVENT\r\n");
/* Disable McSPI Transmit event */
McSPIDMADisable(MCSPI1_BASE_ADDRESS, MCSPI_CH0CONF_DMAW_MASK,
MCSPI_CH_NUM);
if (tccNum == MCSPI1_RX_EVENT)
flagRx = 1;
System_printf("MCSPI1_RX_EVENT\r\n");
/* Disable McSPI Receive event */
McSPIDMADisable(MCSPI1_BASE_ADDRESS, MCSPI_CH0CONF_DMAR_MASK,
MCSPI_CH_NUM);
** This function is used to set the PaRAM entries of EDMA3 for the Receive
** event of channel 0 of McSPI1 instance. The corresponding EDMA3 channel
** is also enabled for reception.
EDMA3CCPaRAMEntry paramSet = {0};
/* Fill the PaRAM Set with Receive specific information.*/
/* srcAddr holds address of SPI Rx FIFO.*/
paramSet.srcAddr = (uint32_t) (MCSPI1_RX0_REG);
/* destAddr is address of memory location named buffer.*/
paramSet.destAddr = (uint32_t) buffer;
/* aCnt holds the number of bytes in an array.*/
paramSet.aCnt = 1;
/* bCnt holds the number of such arrays to be transferred.*/
paramSet.bCnt = buffLength;
/* cCnt holds the number of frames of aCnt*bBcnt bytes to be transferred.*/
paramSet.cCnt = 1;
/* The srcBidx should not be incremented since it is a h/w register.*/
paramSet.srcBIdx = 0;
if (TRUE == destBidxFlag)
/* The destBidx should be incremented for every byte.*/
paramSet.destBIdx = 1;
else
/* The destBidx should not be incremented.*/
paramSet.destBIdx = 0;
/* A sync Transfer Mode. */
/* srCIdx and destCIdx set to zero since ASYNC Mode is used.*/
paramSet.srcCIdx = 0;
paramSet.destCIdx = 0;
/* Linking transfers in EDMA3 are not used.*/
paramSet.linkAddr = 0xFFFF;
paramSet.bCntReload = 0;
paramSet.opt = 0x00000000;
/* Set TCC field in OPT with the tccNum.*/
paramSet.opt |= ((tccNum << EDMA_TPCC_OPT_TCC_SHIFT) &
EDMA_TPCC_OPT_TCC_MASK);
/* EDMA3 Interrupt is enabled and Intermediate Interrupt Disabled.*/
paramSet.opt |= (1 << EDMA_TPCC_OPT_TCINTEN_SHIFT);
/* Now write the PaRam Set to EDMA3.*/
EDMA3SetPaRAM(EDMA_TDA2XX_U_BASE, chNum, ¶mSet);
/* EDMA3 Transfer is Enabled.*/
EDMA3EnableTransfer(EDMA_TDA2XX_U_BASE, chNum, EDMA3_TRIG_MODE_EVENT);
** This function is used to set the PaRAM entries of EDMA3 for the Transmit
** Channel 0 of SPI1 instance. The corresponding EDMA3 channel is also enabled
** for transmission.
/* Fill the PaRAM Set with transfer specific information. */
/* srcAddr holds address of memory location buffer. */
paramSet.srcAddr = (uint32_t) buffer;
/* destAddr holds address of McSPI_TX register. */
paramSet.destAddr = (uint32_t) (MCSPI1_TX0_REG);
/* aCnt holds the number of bytes in an array. */
paramSet.aCnt = 1;
/* bCnt holds the number of such arrays to be transferred. */
/* cCnt holds the number of frames of aCnt*bBcnt bytes to be transferred. */
paramSet.cCnt = 1;
** The srcBidx should be incremented by aCnt number of bytes since the
** source used here is memory.
paramSet.srcBIdx = 1;
/* Async Transfer Mode is set in OPT.*/
/* srCIdx and destCIdx set to zero since ASYNC Mode is used. */
/* Linking transfers in EDMA3 are not used. */
paramSet.linkAddr = (EDMA3CC_OPT(DUMMY_CH_NUM));
/* SAM and DAM fields both are set to 0 */
/* Set TCC field in OPT with the tccNum. */
/* Dummy param set is enabled */
TxDummyPaRAMConfEnable();
/* EDMA3 Transfer is Enabled. */
** This configures the PaRAM set for the Dummy Transfer.
EDMA3CCPaRAMEntry dummyPaRAMSet;
EDMA3GetPaRAM(EDMA_TDA2XX_U_BASE, DUMMY_CH_NUM, &dummyPaRAMSet);
dummyPaRAMSet.aCnt = 1;
dummyPaRAMSet.bCnt = 0;
dummyPaRAMSet.cCnt = 0;
dummyPaRAMSet.srcAddr = 0;
dummyPaRAMSet.destAddr = 0;
dummyPaRAMSet.srcBIdx = 0;
dummyPaRAMSet.destBIdx = 0;
dummyPaRAMSet.srcCIdx = 0;
dummyPaRAMSet.destCIdx = 0;
dummyPaRAMSet.linkAddr = 0xFFFFU;
dummyPaRAMSet.bCntReload = 0;
dummyPaRAMSet.opt = 0;
EDMA3SetPaRAM(EDMA_TDA2XX_U_BASE, DUMMY_CH_NUM, &dummyPaRAMSet);
/* Enable the McSPI channel for communication.*/
McSPIChannelEnable(MCSPI1_BASE_ADDRESS, gChNum);
/* SPIEN line is forced to low state.*/
McSPICSAssert(MCSPI1_BASE_ADDRESS, gChNum);
Task_sleep(1000);
/* Force SPIEN line to the inactive state.*/
McSPICSDeAssert(MCSPI1_BASE_ADDRESS, gChNum);
/* Disable the McSPI channel.*/
McSPIChannelDisable(MCSPI1_BASE_ADDRESS, gChNum);
** This function will verify the data written to and read from flash and print
** the appropriate message.
uint32_t index = 0;
uint32_t error = 0;
// for (index = 0; index < McSPI_DATA_COUNT; index++)
// if ((rxSlvBuffer[index] != txBuffer[index]) ||
// (txSlvBuffer[index] != rxBuffer[index]))
// //UARTConfigPuts(uartBaseAddr,"\nData Mismatch found at index : \r",-1);
// error = 1;
// break;
System_printf("txBuffer:%s\r\n",txBuffer);
System_printf("rxBuffer:%s\r\n",rxBuffer);
memset(txBuffer,0,McSPI_DATA_COUNT);
// memset(rxBuffer,0,McSPI_DATA_COUNT);
if (error == 0)
//UARTConfigPuts(uartBaseAddr,"\nThe data written by Master and the one read by Slave are Equal",-1);
Modified part:
SOC_EDMA_TPCC_BASE_VIRT is replaced by CSL_DSP_DSP_EDMA_CC_REGS
Is there a related demo?
