Hi team,
Here's an issue from the customer may need your help:
When App is running, and one gate link(on ipu) is turned on, the log printed as below:
SYSTEM: IPC: [DSP1] Notify recvfrom failed (Link has been severed, 67) !!!
Dose that mean the ipc link issue? And what dose the error "link has been severed" indicate? Is there any documents could help elaborate on the ipc issue?
Environment: TDA2SX, 2G DDR, VSDK, customer made use case;
Usecase txt:
Select_xxx_only -> Gate_xxx -> Alg_FrameCopy (A15) -> Dup_xxx(A15) -> Alg_Arcxxx (DSP2) -> Merge_dsp (DSP1)
Dup_xxx(A15) -> Alg_Arcxxx2 (DSP1) -> Merge_dsp (DSP1)
log as below :
Could you help resolve this case? Thanks.
Cherry
