HI sir,
I am using AM5728 board with ti-processor-sdk-linux-am57xx-evm-06.01.00.08 sdk version using?
Actually my input is YUV format and output also YUV required but it's generating RGB only in GFX mode?
Anything required for changing plane from GFX to VID1 from where we want to change could you give me some suggestions thanking you?
[ 48.494115] omapdrm omapdrm.0: omap_plane_atomic_check:ovl_color_mode_supported 34325852
[ 48.506671] DISPC: omapdss DISPC error: dispc_ovl_color_mode_supported plane:0, fourcc=34325852
[ 48.518132] DISPC: omapdss DISPC error: dispc_ovl_color_mode_supported true
[ 48.525171] DISPC: omapdss DISPC error: dispc_ovl_setup 0, pa 0x000000007f790000, pa_uv 0x0000000000000000, sw 2048, 0,0, 1920x1080 -> 1920x1080, cmode 34325852, rot 1, chan 0 repl 1
[ 48.541751] DISPC: omapdss DISPC error: dispc_ovl_setup else i734_sel=0
[ 48.541768] DISPC: omapdss DISPC error: dispc_ovl_setup_common plane:0, fourcc=34325852
[ 48.556572] DISPC: omapdss DISPC error: dispc_ovl_setup_common format=34325852, depth=24, numplanes=1, hsub=1, vsub=1
[ 48.567287] DISPC: omapdss DISPC error: dispc_ovl_color_mode_supported plane:0, fourcc=34325852
[ 48.576021] DISPC: omapdss DISPC error: dispc_ovl_color_mode_supported true
[ 48.583046] DISPC: omapdss DISPC error: dispc_ovl_calc_scaling plane:0, fourcc=34325852
[ 48.591187] DISPC: omapdss DISPC error: calc_offset fourcc: 34325852
[ 48.597617] DISPC: omapdss DISPC error: color_mode_to_bpp fourcc: 34325852
[ 48.604539] DISPC: omapdss DISPC error: dispc_ovl_set_color_mode plane:0, fourcc=34325852
[ 48.612797] DISPC: omapdss DISPC error: dispc_ovl_set_rotation_attrs plane:0, fourcc=34325852
[ 48.621646] DISPC: omapdss DISPC error: dispc_ovl_color_mode_supported plane:0, fourcc=3231564e
[ 48.630488] DISPC: omapdss DISPC error: dispc_enable_plane 0, 1
[ 48.636444] DISPC: omapdss DISPC error: dispc_ovl_enable end
[ 48.642302] DISPC: omapdss DISPC error: dispc_enable_plane 1, 0
[ 48.648311] DISPC: omapdss DISPC error: dispc_ovl_enable end
[ 48.654040] DISPC: omapdss DISPC error: dispc_mgr_setup start
[ 48.659910] DISPC: omapdss DISPC error: dispc_mgr_setup end
we are changing to yuv pattern dispc but not working could you give me some suggestions?
Thanking you,
regards,
Ramachandra,
