Tried building C++ demo apps on target SK-TDA4 VM Evaluation Board. Followed steps from - software-dl.ti.com/.../running_simple_demos.html
Also Verified the given header file is present at that location
can you please help ?
Hi Saurabh,
Could you manually try setting the time using "date -s <current date/time>". You can check to see if the date of the system was updated by running just "date".
The error "Clock skew detected" indicates the system time is not set correctly, which could be the reason why the build does not complete. On boot, a script named init_script.sh automatically gets executed and sets the time when there is internet connection. But if internet is not connected at boot or some the init_script.sh fails to execute the date does not get set.
Takuma
