The customer is considering to use 5Gb QSGMII and 2.5Gb SGMII on DRA829V.
They’re looking for 5Gbps and 2.5Gbps Ethernet PHY.
Could you tell them which Ethernet PHY you used on 5Gb or 2.5Gb Ethernet validation or test ?
Hideaki
Hideaki
The DRA829V EVM includes MicroSemi's VSC8514 for implementing 5Gbps QSGMII. The EVM does not have a PHY supporting 2.5Gbps SGMII.
Hi Robert,
Thank you for your response. Yes, the EVM does not have a PHY supporting 2.5Gbps SGMII, so the customer wants to know what your recommendation is.
Did you TI test or validate the 2.5Gbps Ethernet of DRA829V by using a PHY ?
If you used, could you tell them its vender and part number ?
Thanks and regards,
Hideaki
For testing of 2.5Gbps and higher, TI did not use a PHY to validate. Validation was done using processor to processor communication.
