Hello TI Teams:
I am building the can_boot_app_mcu_rtos , it's didn't work on my side. i hadn't modify the makefiles, and i tried to set CANFUNC ?= none , but it still has the same error. Please help to check . Thanks.
$ make -s -j can_boot_app_mcu_rtos BOARD=j721e_evm SOC=j721e BUILD_PROFILE=release CORE=mcu1_0 BUILD_OS_TYPE=freertos Nothing to be done for j721e i2c_profile Nothing to be done for j721e i2c_indp Nothing to be done for j721e i2c_icss0 Nothing to be done for j721e i2c_profile_indp # Check and update: src/version/rmpmhal_version.h Nothing to be done for j721e fatfs_multi_indp fatal: 没有附注标签能描述 '7a5bc0fed9f28f3a929f3a641835b1558819fa97'。 然而,存在未附注标签:尝试 --tags。 # Check and update: src/version/sciserver_version.h fatal: 没有附注标签能描述 '7a5bc0fed9f28f3a929f3a641835b1558819fa97'。 然而,存在未附注标签:尝试 --tags。 Building MCUSW CAN Boot App with BISTFUNC=disabled, BOOTFUNC=enabled, HLOSBOOT=none, BOOTMODE=ospi, CANFUNC=can_fast_response, DEVICETYPE=GP, BUILD_OS_TYPE=freertos, ENABLE_OSPI_DMA=no and MCUONLYFUNC=disabled Building MCUSW CAN Boot App with BISTFUNC=disabled, BOOTFUNC=enabled, HLOSBOOT=none, BOOTMODE=ospi, CANFUNC=can_fast_response, DEVICETYPE=GP, BUILD_OS_TYPE=freertos, ENABLE_OSPI_DMA=no and MCUONLYFUNC=disabled # Compiling j721e_evm:j721e:mcu1_0:release:app_utils:src/app_utils.c # Compiling j721e_evm:j721e:mcu1_0:release:app_utils:src/app_r5f_Pmu.c # Compiling j721e:mcu1_0:release:can:src/Can.c # Compiling j721e:mcu1_0:release:can:src/Can_Priv.c # Compiling j721e:mcu1_0:release:can:src/Can_Irq.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Det/src/Det.c # Compiling j721e:mcu1_0:release:dio:src/Dio.c # Compiling j721e_evm:j721e:mcu1_0:release:demo_utils:src/utils_prf_rtos.c # Compiling j721e:mcu1_0:release:can:src/Can_Mcan.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Dem/src/Dem.c # Compiling j721e:mcu1_0:release:dio:src/Dio_PlatformJ721e.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Os/src/Os.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_Spi.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_Can.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_Dio.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_Eth.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_EthTrcv.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_Gpt.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:EcuM/src/EcuM_Cbk.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:Rte/src/SchM_Cdd_Ipc.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:CanIf/src/CanIf.c # Compiling j721e:mcu1_0:release:bsw_stubs_rtos:CanIf/src/CanIf_Cbk.c # # Archiving j721e_evm:j721e:mcu1_0:release:app_utils into /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/mcal/examples/utils/lib/j721e_evm/mcu1_0/release/app_utils.aer5f ... # # # # Archiving j721e_evm:j721e:mcu1_0:release:demo_utils into /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/mcuss_demos/demo_utils/lib/j721e_evm/r5f/release/demo_utils.aer5f ... # Archiving j721e:mcu1_0:release:dio into /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/mcal/Dio/lib/j721e/mcu1_0/release/dio.aer5f ... # # # # Archiving j721e:mcu1_0:release:bsw_stubs_rtos into /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/mcuss_demos/Bsw_Stubs/lib/j721e/r5f/release/bsw_stubs_rtos.aer5f ... # # # Archiving j721e:mcu1_0:release:can into /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/mcal/Can/lib/j721e/mcu1_0/release/can.aer5f ... # Building MCUSW CAN Boot App with BISTFUNC=disabled, BOOTFUNC=enabled, HLOSBOOT=none, BOOTMODE=ospi, CANFUNC=can_fast_response, DEVICETYPE=GP, BUILD_OS_TYPE=freertos, ENABLE_OSPI_DMA=no and MCUONLYFUNC=disabled # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos: /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/mcal_drv/mcal/examples/utils/src/utilsCopyVecs2ATcm.asm # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:main_tirtos.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:soc/j721e/boot_core_defs.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:overrides/j721e/mcu1_0/r5_mpu_freertos.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:mcu_timer_multicore.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:can_resp.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:can_utils.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:boot.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/mcuss_demos/mcal_config/Can_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Can_Cfg.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/mcuss_demos/mcal_config/Can_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Can_PBcfg.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/mcuss_demos/mcal_config/Dio_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Dio_Lcfg.c # Compiling j721e_evm:j721e:mcu1_0:release:can_boot_app_mcu_rtos:/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/mcal_drv/mcal/examples/utils/src/app_utils_can.c # Linking into /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/can_boot_app_mcu_rtos/bin/j721e_evm/can_boot_app_mcu_rtos_mcu1_0_release.xer5f... # "/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/mcuss_demos/boot_app_mcu_rtos/overrides/j721e/mcu1_0/linker_r5_freertos.lds", line 121: error #10099-D: program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment fails for section ".cinit" size 0x2b2e. Available memory ranges: OCMC_RAM_SCISERVER size: 0x60000 unused: 0xe36 max hole: 0x7d0 error #10010: errors encountered during linking; "/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/can_boot_app_mcu_rtos/bin /j721e_evm/can_boot_app_mcu_rtos_mcu1_0_release.xer5f" not built tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation) /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/pdk_jacinto_08_02_00_21/packages/ti/build/makerules/rules_ti_cgt_arm.mk:349: recipe for target '/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/can_boot_app_mcu_rtos/bin/j721e_evm/can_boot_app_mcu_rtos_mcu1_0_release.xer5f' failed make[2]: *** [/home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/mcusw/binary/can_boot_app_mcu_rtos/bin/j721e_evm/can_boot_app_mcu_rtos_mcu1_0_release.xer5f] Error 1 /home/tda4/SDK_8_2/sdk8_2_qnx/PSDKRA/pdk_jacinto_08_02_00_21/packages/ti/build/makerules/common.mk:410: recipe for target 'mcu1_0' failed make[1]: *** [mcu1_0] Error 2 makefile:148: recipe for target 'can_boot_app_mcu_rtos' failed make: *** [can_boot_app_mcu_rtos] Error 2
