We are running into the same issue as this post on an AM5718 board. All software is based on latest PSDK v06_03_00_106. Looking at kernel source, the dra7xx-clocks.dtsi file has the encoder clock DPLL still set to 388MHz:
From "arch/arm/boot/dts/dra7xx-clocks.dtsi":
dpll_iva_m2_ck: dpll_iva_m2_ck@1b0 {
#clock-cells = <0>;
compatible = "ti,divider-clock";
clocks = <&dpll_iva_ck>;
ti,max-div = <31>;
ti,autoidle-shift = <8>;
reg = <0x01b0>;
ti,index-starts-at-one;
ti,invert-autoidle-bit;
assigned-clocks = <&dpll_iva_m2_ck>;
assigned-clock-rates = <388333334>;
which results in ~18ms or 19ms of encoding per frame, see gstreamer debug output below:
0:00:04.506654937 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18438267ns (18 ms)
0:00:04.507213371 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e92b8
0:00:04.521476961 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.541183539 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 19629149ns (19 ms)
0:00:04.541911310 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e59a0
0:00:04.556856310 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.575660414 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18727488ns (18 ms)
0:00:04.576434707 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e5a40
0:00:04.588280582 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.606655083 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18293819ns (18 ms)
0:00:04.607092494 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e5860
0:00:04.621428632 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.639654782 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18148395ns (18 ms)
0:00:04.641217846 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e5900
0:00:04.656764224 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.675680406 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18839240ns (18 ms)
0:00:04.676444776 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e93f8
0:00:04.688566045 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.706682395 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18037944ns (18 ms)
0:00:04.707250915 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e92b8
0:00:04.721298483 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.739654603 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18277064ns (18 ms)
0:00:04.740164725 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e59a0
0:00:04.756789421 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.775659731 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18794181ns (18 ms)
0:00:04.776250699 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e5a40
0:00:04.788346755 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.806658629 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18230379ns (18 ms)
0:00:04.807222106 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e5860
0:00:04.821186064 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:873:gst_ducati_videnc_handle_frame: Calling VIDENC2_process
0:00:04.839654912 3976 0x59c2c0 DEBUG ducati gstducatividenc.c:879:gst_ducati_videnc_handle_frame:<ducatih264enc0> VIDENC2_process took 18391907ns (18 ms)
0:00:04.840170402 3976 0x59c2c0 LOG ducati gstducatividenc.c:948:gst_ducati_videnc_handle_frame:<ducatih264enc0> free buffer: 0x5e5900
These encoding times prevent achieving 60fps for 1080p video. Changing the "assigned-clock-rates" parameter has no effect on the encoding times. Could someone provide a patch that fixes this? We are uncertain of the required changeset.
