Hi expert,
I meet a weird issue, the root cause can't be found by now, maybe related hardware issues. So we are trying to run keywriter on EVM board(SOC is replaced by HS PRIME). Is it possible to try it?
Hi expert,
Hi Henry,
Are you able to see any hex characters on the MCU UART? Also is the issue with: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1119578/tda4vm-tda4vm-which-boot-mode-should-i-set-to-run-keywriter
fixed?
- Keerthy
Hi Keerthy,
[A] what's the meaning?
[A] This issue isn't fixed yet.
If we don't enable VPP, there are no any error log in UART. UART log shows burned successfully, but not in fact.
We want to eliminate hardware impact, so want to try it on TI EVM board.
BR
Can you share the logs from the keywriter? On both MCU UART & WKUP UART?
Please use UART boot mode to boot the keywriter binary.
- Keerthy
