TDA4VM: SDK J721E board start up basic driver can not be started correctly
Part Number: TDA4VM
i follow the the documentation software-dl.ti.com/.../build_steps_j721e.html
the tisci-mgr, tiipc-mgr:.... basic driver can not be started.
U-Boot 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
SoC:   J721E SR1.1
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev A
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
cdns,sierra serdes@5000000: sierra probed
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
556 bytes read in 12 ms (44.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
gpio: pin gpio@22_17 (gpio 281) value is 1
gpio: pin gpio@22_16 (gpio 280) value is 0
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
4787436 bytes read in 215 ms (21.2 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 4787436 bytes: Success!
3043076 bytes read in 139 ms (20.9 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 3043076 bytes: Success!
Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
Failed to load '/lib/firmware/j7-c66_0-fw'
Failed to load '/lib/firmware/j7-c66_1-fw'
Failed to load '/lib/firmware/j7-c71_0-fw'
8283972 bytes read in 361 ms (21.9 MiB/s)
## Starting application at 0x80080000 ...
MMU: 16-bit ASID 44-bit PA TCR_EL1=b5183519
ARM GIC-500 r1p1, arch v3.0 detected
gic_v3_lpi_add_entry for vectors 8192 -> 8447, Ok
gic_v3_lpi_add_entry for vectors 8448 -> 65535, Ok
No SPI intrinfo. Add default entry for 32 -> 991 vectors, Ok
LPI config table #1 @ 000000008000f000, callout vaddr: ffffff8040251000
cpu0: MPIDR=80000000
cpu0: MIDR=411fd080 Cortex-A72 r1p0
cpu0: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
cpu0: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
cpu0: L1 Icache 48K linesz=64 set/way=256/3
cpu0: L1 Dcache 32K linesz=64 set/way=256/2
cpu0: L2 Unified 1024K linesz=64 set/way=1024/16
Enabling ITS 0
ITS queue at 0000000080020000, num slots: 256
Issue MAPC/SYNC/INVALL commands for ICID 0
update CWRITER to 0x00000060
Waiting for all commands to be processed ... Done in 1 tries
Enable LPIs in GICR_CTLR @ 0000000001900000 for CPU0
Display set to R5
TI: Not configuring pcie to avoid serdes conflict with EthFw using QSGMII board
Total Available L3 cache (MSMC SRAM): 0 bytes
Loading IFS...decompressing...done
cpu1: MPIDR=80000001
cpu1: MIDR=411fd080 Cortex-A72 r1p0
cpu1: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
cpu1: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
cpu1: L1 Icache 48K linesz=64 set/way=256/3
cpu1: L1 Dcache 32K linesz=64 set/way=256/2
cpu1: L2 Unified 1024K linesz=64 set/way=1024/16
ITS 0 already Enabled
Issue MAPC/SYNC/INVALL commands for ICID 1
update CWRITER to 0x000000c0
Enable LPIs in GICR_CTLR @ 0000000001920000 for CPU1
System page at phys:0000000080023000 user:ffffff8040275000 kern:ffffff8040272000
Starting next program at vffffff80600983c0
All ClockCycles offsets within tolerance
Welcome to QNX Neutrino 7.1.0 on the TI J721E EVM Board!!
Starting random service ...
start serial driver
Setting OS clock from RTC
Starting MMC/SD memory card driver... eMMC
Starting MMC/SD memory card driver... SD
Starting XHCI driver on USB3SS0 and USB3SS1
Path=0 - am65x
 target=0 lun=0     Direct-Access(0) - SDMMC: S0J56X Rev: 1.0
Setting environment variables...
done..
Mounting the sd ..
Looking for user script to run: /ti_fs/scripts/user.sh
Running user script...
user.sh called...
Setting additional environment variables...
Starting tisci-mgr..
/proc/boot/.console_ti.sh: /ti_fs/scripts/user.sh[10]: tisci-mgr: Bad file descriptor
Unable to access /dev/tisci
Starting shmemallocator..
/proc/boot/.console_ti.sh: /ti_fs/scripts/user.sh[14]: shmemallocator: Bad file descriptor
Starting tiipc-mgr..
/proc/boot/.console_ti.sh: /ti_fs/scripts/user.sh[17]: tiipc-mgr: Bad file descriptor
Starting tiudma-mgr..
/proc/boot/.console_ti.sh: /ti_fs/scripts/user.sh[20]: tiudma-mgr: Bad file descriptor
Start screen..
/proc/boot/.console_ti.sh: /ti_fs/scripts/user.sh[23]: screen: Bad file descriptor
screen started with dss_on_r5 configuration..
done...
after call of ifconfig am0 up
open(/dev/tisci): No such file or directory
ifconfig: SIOCSIFFLAGS: No such process
the boot/   und bootfs/ folder is copied the all files which mentioned in link. If we only use the command
cp -fv ${PSDK_QNX_PATH}/bootfs/*                                  <path_to_SD_card_mount_dir>/boot
only qnx-ifs will be copied, the rest folder will be ignored, i added the -r to copy the all the files to the /boot
in /bootfs, lib/firmware also created and copied.
    From the errors being seen it appears the content on the SD card, DOS partition is not correct.
    The linux partition which contains the remote core images, also is indicating that images are note present:
    Which steps are being followed at https://software-dl.ti.com/jacinto7/esd/processor-sdk-qnx-jacinto7/08_02_00_03/exports/docs/build_steps_j721e.html ?
    Please be aware that 2a, 2b, 2c and 2d are options, only one of them should be run.
    When running the commands for one of 2a, 2b, 2c and 2d, make sure to check for any errors being seen when copying.
    kb
    for us only the ETH firmware image is used , also 2a, 2c is our option.
    the partition of sd card is made by .sh file, /boot (FAT32) and /rootfs (EXT4) are created.
    /dev/sdc1  12GB    /boot
    /dev/sdc2   17GB   /rootfs
    ~$ ls -ls /media/user/boot
    total 10936
       8 drwxr-xr-x 2 user user  8192 Aug  1 19:30  bin
       8 drwxr-xr-x 2 user user   8192 Aug  1 19:30  boot
       8 drwxr-xr-x 3 user user    8192 Aug  1 19:30  etc
       8 drwxr-xr-x 3 user user 8192 Aug  1 19:30  lib
    8096 -rw-r--r-- 1 user user 8284508 Aug  8 17:40  qnx-ifs
       8 drwxr-xr-x 2 t user user    8192 Aug  1 19:30  sbin
       8 drwxr-xr-x 2 user user    8192 Aug  1 20:29  scripts
     264 -rw-r--r-- 1 user user  268990 Aug  8 17:24  sysfw.itb
       8 drwxr-xr-x 2 user user    8192 Aug  8 20:25 'System Volume Information'
       8 drwxr-xr-x 2 user user   8192 Aug  1 20:29  tibin
     288 -rw-r--r-- 1 user user 288988 Aug  8 17:09  tiboot3.bin
       8 drwxr-xr-x 2 user user    8192 Aug  1 20:29  tilib
     960 -rw-r--r-- 1 user user  978704 Aug  8 17:09  tispl.bin
    1240 -rw-r--r-- 1 user user 1263792 Aug  8 17:09  u-boot.img
       8 -rw-r--r-- 1 user user 556 Mär 25 17:24  uEnv.txt
       8 drwxr-xr-x 5 user user  8192 Aug  8 17:44  usr
    ~$ ls -ls /media/user/rootfs/lib/firmware/
    total 7644
    4672 -rw-r--r-- 1 root root 4787436 Aug  6 19:48 j7-main-r5f0_0-fw
    2972 -rw-r--r-- 1 root root 3043076 Aug  6 19:48 j7-main-r5f0_1-fw
    if we use the copy command from TI Guide
    cd ${PSDK_QNX_PATH}
    ## Remove existing files on bootfs
    rm -rf <path_to_SD_card_mount_dir>/boot/*
    ## Copy PSDK QNX binaries + QNX FS
    ## Copy SPL-Uboot
    cp -fv ${PSDK_QNX_PATH}/qnx/scripts/u-boot/uEnv.txt         <path_to_SD_card_mount_dir>/boot/uEnv.txt
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/tiboot3.bin                 <path_to_SD_card_mount_dir>/boot
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/tispl.bin                   <path_to_SD_card_mount_dir>/boot
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/u-boot.img                  <path_to_SD_card_mount_dir>/boot
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/sysfw.itb                   <path_to_SD_card_mount_dir>/boot
    ## Remove existing files on rootfs
    sudo rm -rf <path_to_SD_card_mount_dir>/rootfs/*
    ## Copy remote proc images
    sudo mkdir -p <path_to_SD_card_mount_dir>/rootfs/lib/firmware
    sudo cp -fv ${PSDK_QNX_PATH}/ethfw_firmware/j7-main-r5f0_0-fw  <path_to_SD_card_mount_dir>/rootfs/lib/firmware
    sudo cp -fv ${PSDK_QNX_PATH}/ethfw_firmware/j7-main-r5f0_1-fw  <path_to_SD_card_mount_dir>/rootfs/lib/firmware
    only copied the qnx-ifs, other folder will be omitted. i copied with option -r so that to copy the other folders to /boot.
  • Thanks,
    After you reach the QNX prompt, please run below commands and provide the output, to get a feel for what is running, and perhaps some additional error logs.
    • pidin ar
    • slog2info
    As a test once you get to the QNX prompt, if tisci-mgr is not running, try launching it manually to see if it works when launched a 2nd time.
    /ti_fs/tibin/tisci-mgr
    Another thought is that the DOS partition is read only, or perhaps the SD card has a write protect on it.  Try copying a file when on the QNX prompt see if that works.
    cp /ti_fs/tiboot3.bin /ti_fs/asdf.delme
    I was not able to follow the statement above on the "qnx-ifs".  Is the default qnx-ifs (j721e-evm-ti.build) in use, or has there been modifications to the BSP?
    kb
    here is some info. from target Board:
    # pidin ar
    /# pidin ar
         pid Arguments
           1 procnto-smp-instr -v
           2 slogger2
           3 pipe
           4 dumper -d /tmp
           5 random -t
       16390 devc-seromap -e -F 0x02800000,224
       16391 i2c-omap35xx -p0x2000000 -i232 -d
       16392 i2c-omap35xx -p0x2010000 -i233 -d
       20489 devb-sdmmc-am65x blk cache=1m sdio addr=0x4f80000,irq=35,timing=~hs400,emmc,bs=sscfg=0x8000 disk name=emmc
       20490 devb-sdmmc-am65x blk cache=1m sdio addr=0x04fb0000,irq=36,bs=sscfg=0x8000:ldo=0x600000^117:pwrdev=/dev/i2c0 cam pnp disk name=sd
       20491 io-pkt-v6-hc -d cpsw2g
       61452 io-usb-otg -d cdns3-xhci ioport=0x6010000,irq=128,iosize=65536,ioport=0x6410000,irq=136,iosize=65536,nousb3
       61453 ksh /proc/boot/.console_ti.sh
      139278 ksh ksh
      147471 pidin ar
    #slog2info
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:34:29 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 21:03:57, Mar 23 2022
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    556 bytes read in 13 ms (41 KiB/s)
    Running uenvcmd ...
    4787436 bytes read in 217 ms (21 MiB/s)
    3043076 bytes read in 141 ms (20.6 MiB/s)
    8284508 bytes read in 361 ms (21.9 MiB/s)
    Enabling ITS 0
    Display set to R5
    Starting TI services ...
    Unable to start "tisci-mgr" (2)
    Unable to access "/dev/tisci" (2)
    Unable to start "shmemallocator" (2)
    Unable to access "/dev/shmemallocator" (2)
    Unable to start "tiipc-mgr" (2)
    Unable to access "/dev/tiipc" (2)
    Unable to start "tiudma-mgr" (2)
    Unable to access "/dev/tiudma" (2)
    start serial driver
    Starting Network driver...
    Path=0 - am65x
    if_up: retries exhausted
    ifconfig: SIOCGIFFLAGS am0: No such device or address
    done..
    Mounting the sd ..
    user.sh called...
    Start screen..
    done...
    J7EVM@QNX:/# pidin ar
         pid Arguments
           2 slogger2
           3 pipe
           4 dumper -d /tmp
           5 random -t
      139278 ksh ksh
      147471 pidin ar
    J7EVM@QNX:/# slog2info
    Jan 01 00:00:00.016                       random.5                  low*     0  qcrypto: loading configuration file '/etc/qcrypto.conf' [qcrypto_common.c(190)]
    Jan 01 00:00:00.016                    random.5..0                 slog*   700  Random is using the Fortuna PRNG
    Jan 01 00:00:00.021                       random.5                  low      0  qcrypto: 'openssl' plugin loaded [qcrypto_plugins.c(354)]
    Jan 01 00:00:00.021                    random.5..0                 slog    700  Selecting timer as an entropy source
    Jan 01 00:00:00.021                    random.5..0                 slog    700  Registered path names
    Jan 01 00:00:00.021                    random.5..0                 slog    700  random: starting resmgr
    Jan 01 00:00:00.021                    random.5..0                 slog    700  random: Daemonizing the process
    Jan 01 00:00:00.002         devb_sdmmc_am65x.20489                 slog*  1800  devb-sdmmc-am65x 1.00A (Aug  1 2022 19:29:25)
    Jan 01 00:00:00.002         devb_sdmmc_am65x.20489                 slog      0  libcam.so (Sep  3 2021 11:57:38) bver 7010004
    Jan 01 00:00:00.003         devb_sdmmc_am65x.20489                 slog   1800  sdio_cd:  insertion path 0, cd state 0x1
    Jan 01 00:00:00.004         devb_sdmmc_am65x.20490                 slog*  1800  devb-sdmmc-am65x 1.00A (Aug  1 2022 19:29:25)
    Jan 01 00:00:00.005         devb_sdmmc_am65x.20490                 slog      0  libcam.so (Sep  3 2021 11:57:38) bver 7010004
    Jan 01 00:00:00.005         devb_sdmmc_am65x.20490                 slog   1800  sdio_cd:  insertion path 0, cd state 0x1
    Jan 01 00:00:00.007                    iopkt.20491          main_buffer*     0  tcpip starting
    Jan 01 00:00:00.008                    iopkt.20491          main_buffer      0  smmu support is disabled
    Jan 01 00:00:00.009                    iopkt.20491          main_buffer      0  initializing IPsec...
    Jan 01 00:00:00.009                    iopkt.20491          main_buffer      0   done
    Jan 01 00:00:00.009                    iopkt.20491          main_buffer      0  IPsec: Initialized Security Association Processing.
    Jan 01 00:00:00.010                    iopkt.20491          main_buffer      0  Unable to load devnp-cpsw2g.so: (null)
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800  MMC CID:
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    MID 0x13, OID 0x4e, PNM S0J56X
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    PRV 0x10, PSN 0x2936a2fa, MDT 7-2021
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800  MMC CSD:
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    CSD_STRUCTURE 3, SPEC_VERS 4, CCC 0x8f5
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    TAAC 127, NSAC 1, TRAN_SPEED 50
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    C_SIZE 4095, C_SIZE_MULT 7
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    READ_BL_LEN 9, WRITE_BL_LEN 9
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    ERASE GRP_SIZE 31, GRP_MULT 31, SIZE 0
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    blksz 512, sectors 2097152, dtr 25000000
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800  MMC EXT CSD:
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    DEVICE_TYPE 0x57, EXT_CSD_REV 8
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    SEC_COUNT 31080448, dtr 200000000
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    HC_ERASE_GRP_SIZE 1, HC_WP_GRP_SIZE 16
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    STROBE 0x0, BKOPS_EN 0x0
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800    Driver type: 0x0
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog   1800  CFG:  Timing HS200, DTR 200000000, Bus Width 8 bit
    Jan 01 00:00:00.089         devb_sdmmc_am65x.20489                 slog    100  cam-disk.so (Sep  3 2021 11:57:42)
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800  SD CID:
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    MID 0x9f, OID 0x5449, PNM ASTC
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    PRV 0x0, PSN 0x536, MDT 4-2022
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800  SD CSD:
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    CSD_STRUCTURE 1, SPEC_VERS 0, CCC 0x5b5
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    TAAC 14, NSAC 0, TRAN_SPEED 50
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    C_SIZE 59635, C_SIZE_MULT 0
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    READ_BL_LEN 9, WRITE_BL_LEN 9
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    ERASE GRP_SIZE 0, GRP_MULT 0, SIZE 127
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    blksz 512, sectors 61067264, dtr 25000000
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800  SD SW CAPS:
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    bus mode 0x3, cmd sys 0x1
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    drv type 0x1, curr limit 0x1
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800    dtr 50000000
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog   1800  CFG:  Timing HS, DTR 50000000, Bus Width 4 bit
    Jan 01 00:00:00.177         devb_sdmmc_am65x.20490                 slog    100  cam-disk.so (Sep  3 2021 11:57:42)
    Jan 01 00:00:04.035               io_usb_otg.61452                 slog*     0  main(453)[tid:1]: io-usb-otg (Jul 26 2021 16:07:38) args: -d cdns3-xhci ioport=0x6010000,irq=128,iosize=65536,ioport=0x6410000,irq=136,iosize=65536,nousb3
    Jan 01 00:00:04.038               io_usb_otg.61452                 slog      0  xhci_init: Initialiaing with sever version: 2
    Jan 01 00:00:04.038               io_usb_otg.61452                 slog      0  xhci_controller_init(2661): devu-hcd-cdns3-xhci.so (Jan 20 2022 16:08:39):  args
    Jan 01 00:00:04.039               io_usb_otg.61452                 slog      0  cdns3_usb_port_info(308)[tid:1]: cdns3: chipset j721e xhci_irq=128 serdes_addr=0x5030000
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog      8  usb_enum_port(94)[tid:1]: busno 0, parent -1, port 0, Super speed
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 8)
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog     12  usb_device_set_address(245)[tid:1]: b:0 devno 0
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18)
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9)
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25)
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog      8  usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 0, devno 0:0)
    Jan 01 00:00:04.043               io_usb_otg.61452                 slog     11  hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0
    Jan 01 00:00:04.044               io_usb_otg.61452                 slog     13  hub_configuration_enable(263)[tid:1]: 1
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog      0  xhci_init: Initialiaing with sever version: 2
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog      0  xhci_controller_init(2661): devu-hcd-cdns3-xhci.so (Jan 20 2022 16:08:39):  args nousb3
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog      0  cdns3_usb_port_info(308)[tid:1]: cdns3: chipset j721e xhci_irq=136 serdes_addr=0x0
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog      8  usb_enum_port(94)[tid:1]: busno 1, parent -1, port 0, High speed
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 8)
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog     12  usb_device_set_address(245)[tid:1]: b:1 devno 0
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18)
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9)
    Jan 01 00:00:04.145               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25)
    Jan 01 00:00:04.146               io_usb_otg.61452                 slog      8  usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 1, devno 0:1)
    Jan 01 00:00:04.146               io_usb_otg.61452                 slog     11  hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0
    Jan 01 00:00:04.146               io_usb_otg.61452                 slog     13  hub_configuration_enable(263)[tid:1]: 1
    Jan 01 00:00:04.248               io_usb_otg.61452                 slog      0  usbh_timeout_init(203)[tid:1]: Complete
    Jan 01 00:00:04.307               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 0, pdevno 0, portno 1)
    Jan 01 00:00:04.307               io_usb_otg.61452                 slog      8  usb_enum_port_extract(192)[tid:8]: status (2)
    Jan 01 00:00:04.307               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 0, pdevno 0, portno 2)
    Jan 01 00:00:04.313               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 0, portno 1)
    Jan 01 00:00:04.313               io_usb_otg.61452                 slog      8  usb_enum_port_extract(192)[tid:8]: status (2)
    Jan 01 00:00:04.328               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 0, portno 1)
    Jan 01 00:00:04.328               io_usb_otg.61452                 slog      8  usb_enum_port_extract(192)[tid:8]: status (2)
    Jan 01 00:00:04.586               io_usb_otg.61452                 slog      0  xhci_get_root_device_speed: port 0 is HIGH speed, psts e03
    Jan 01 00:00:04.586               io_usb_otg.61452                 slog      8  usb_enum_port(94)[tid:8]: busno 1, parent 0, port 1, High speed
    Jan 01 00:00:04.586               io_usb_otg.61452                 slog      0  xring_create: ep->mbuf = 0x892c77c0
    Jan 01 00:00:04.592               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:8]: (type 1, index 0, length 8)
    Jan 01 00:00:04.592               io_usb_otg.61452                 slog     12  usb_device_set_address(245)[tid:8]: b:1 devno 1
    Jan 01 00:00:04.592               io_usb_otg.61452                 slog      0  xHCI: Internal Device Addr 1
    Jan 01 00:00:04.613               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:8]: (type 1, index 0, length 18)
    Jan 01 00:00:04.613               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:8]: (type 2, index 0, length 9)
    Jan 01 00:00:04.613               io_usb_otg.61452                 slog     11  usb_client_descriptor_get(198)[tid:8]: (type 2, index 0, length 41)
    Jan 01 00:00:04.613               io_usb_otg.61452                 slog      8  usb_enum_port(141)[tid:8]: vid 0x0451, did 0x8142 enumerated(busno 1, devno 1:2)
    Jan 01 00:00:04.613               io_usb_otg.61452                 slog     11  hub_state_inserted(569)[tid:8]: bdentry 1, dentry 1 0
    Jan 01 00:00:04.614               io_usb_otg.61452                 slog      0  xring_create: ep->mbuf = 0x892c7950
    Jan 01 00:00:04.614               io_usb_otg.61452                 slog     13  hub_configuration_enable(263)[tid:2]: 1
    Jan 01 00:00:04.614               io_usb_otg.61452                 slog      0  process_xfer_complete: No Outstanding Transfer, slotid = 1 devaddr = 0x1 epnum = 0x1 epdir = 0x80 xring->enq_idx = 0 xring->deq_idx = 0
    Jan 01 00:00:04.614               io_usb_otg.61452                 slog      0  process_xfer_complete: evt->w0 = 0x8002e000 evt->w1 = 0x0 evt->w2 = 0x1b000000 evt->w3 = 0x1038001
    Jan 01 00:00:04.614               io_usb_otg.61452                 slog     16  hub_notification_disable(353)[tid:2]:
    Jan 01 00:00:04.715               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 1)
    Jan 01 00:00:04.715               io_usb_otg.61452                 slog      8  usb_enum_port_extract(192)[tid:8]: status (2)
    Jan 01 00:00:04.715               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 2)
    Jan 01 00:00:04.715               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 3)
    Jan 01 00:00:04.715               io_usb_otg.61452                 slog      8  usb_enum_port_extract(172)[tid:8]: (busno 1, pdevno 1, portno 4)
    Jan 01 00:00:04.924         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:04.924         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:04.924         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:05.071         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:05.071         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:05.071         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:05.222         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:05.222         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:05.222         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:05.369         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:05.369         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:05.369         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:05.527         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:05.527         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:05.527         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:05.689         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:05.689         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:05.689         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:05.847         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:05.847         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:05.847         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:06.005         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:06.005         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:06.005         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:06.167         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:06.167         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:06.167         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:06.325         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:06.325         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:06.325         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:07.158         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:07.158         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:07.158         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:07.320         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:07.320         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:07.320         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:07.478         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:07.478         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:07.478         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:07.636         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:07.636         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:07.636         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:07.798         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:07.798         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:07.798         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:07.956         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:07.956         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:07.956         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:08.114         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:08.114         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:08.114         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:08.276         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:08.276         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:08.276         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:08.434         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:08.434         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:08.434         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:08.592         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:08.592         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:08.592         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:08.759         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:08.759         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:08.759         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:08.917         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:08.917         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:08.917         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:09.075         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:09.075         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:09.075         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:09.237         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:09.237         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:09.237         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:09.395         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:09.395         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:09.395         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:09.553         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:09.553         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:09.553         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:09.715         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:09.715         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:09.715         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:09.873         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:09.873         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:09.873         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:10.031         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.031         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.031         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:10.193         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.193         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.193         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:10.357         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.357         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.357         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:10.515         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.515         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.515         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:10.677         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.677         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.677         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:10.835         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.835         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.835         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:10.993         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:10.993         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:10.993         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:11.155         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:11.155         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:11.155         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:11.313         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:11.313         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:11.313         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:11.471         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:11.471         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:11.471         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:11.633         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:11.633         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:11.633         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:11.791         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:11.791         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:11.791         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:11.949         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:11.949         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:11.949         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:12.111         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:12.111         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:12.111         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:12.269         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:12.269         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:12.269         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:12.427         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:12.427         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:12.427         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:12.589         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:12.589         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:12.589         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:12.747         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:12.747         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:12.747         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:12.905         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:12.905         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:12.905         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:13.067         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:13.067         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:13.067         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:13.225         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:13.225         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:13.225         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:13.383         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:13.383         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:13.383         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:13.545         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:13.545         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:13.545         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:13.706         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:13.706         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:13.706         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:13.867         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:13.867         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:13.867         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:14.029         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.029         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.029         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:14.187         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.187         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.187         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:14.345         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.345         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.345         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:14.507         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.507         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.507         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:14.665         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.665         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.665         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:14.823         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.823         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.823         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:14.985         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:14.985         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:14.985         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:15.143         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:15.143         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:15.143         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:15.301         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:15.301         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:15.301         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:15.463         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:15.463         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:15.463         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:15.621         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:15.621         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:15.621         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:15.779         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:15.779         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:15.779         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:15.941         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:15.941         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:15.941         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:16.099         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:16.099         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:16.099         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:16.257         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:16.257         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:16.257         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:16.419         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:16.419         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:16.419         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:16.577         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:16.577         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:16.577         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:16.741         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:16.741         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:16.741         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:16.903         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:16.903         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:16.903         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:17.061         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:17.061         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:17.061         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:17.219         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:17.219         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:17.219         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:17.381         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:17.381         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:17.381         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:17.539         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:17.539         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:17.539         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:17.697         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:17.697         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:17.697         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:17.859         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:17.859         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:17.859         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:18.017         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:18.017         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:18.017         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:18.175         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:18.175         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:18.175         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1512448 (1512448 - 1512448), nlba 1, resid 1
    Jan 01 00:00:18.348         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:18.348         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:18.348         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:18.517         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:18.517         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:18.517         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:18.686         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:18.686         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:18.686         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:18.859         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:18.859         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:18.859         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:19.028         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:19.028         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:19.028         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:19.197         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:19.197         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:19.197         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:19.370         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:19.370         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:19.370         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:19.539         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:19.539         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:19.539         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:19.708         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:19.708         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:19.708         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:19.881         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:19.881         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:19.881         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:20.050         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:20.050         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:20.050         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:20.219         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:20.219         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:20.219         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:20.392         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:20.392         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:20.392         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:20.561         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:20.561         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:20.561         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:20.730         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:20.730         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:20.730         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:20.903         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:20.903         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:20.903         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:21.072         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:21.072         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:21.072         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:21.241         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:21.241         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:21.241         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:21.414         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514160, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:21.414         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:21.414         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514160 (1514160 - 1514160), nlba 1, resid 1
    Jan 01 00:00:21.583         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1514064, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:21.583         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:21.583         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1514064 (1514064 - 1514064), nlba 1, resid 1
    Jan 01 00:00:21.752         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:21.752         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x00000080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:21.752         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 1
    Jan 01 00:00:21.925         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:21.925         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:21.925         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 2
    Jan 01 00:00:22.094         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:22.094         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:22.094         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 3
    Jan 01 00:00:22.263         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:22.263         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:22.263         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 4
    Jan 01 00:00:22.436         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:22.436         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:22.436         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 5
    Jan 01 00:00:22.605         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:22.605         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:22.605         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 6
    Jan 01 00:00:22.774         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:22.774         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:22.774         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 7
    Jan 01 00:00:22.947         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:22.947         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:22.947         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 8
    Jan 01 00:00:23.116         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:23.116         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:23.116         devb_sdmmc_am65x.20490                 slog      0  _scsi_io_cbf:  status b, retry 9
    Jan 01 00:00:23.285         devb_sdmmc_am65x.20490                 slog   1800  sdmmc_rw:  flgs 0x400, lba 1512448, len 512, status 0x104, cstatus 0x9, rsp[0] 0x400e00
    Jan 01 00:00:23.285         devb_sdmmc_am65x.20490                 slog      0  scsi_error (sdmmc ptl-0:0:0):  cam_status=0x4b, scsi_status=0x0, flag=0x0000a080, vuflag=0x0001, cmd=0x2a
    Jan 01 00:00:23.285         devb_sdmmc_am65x.20490                 slog      0  scsi_io_done ptl-0:0:0:  I/O error 5 lba 1512448 (1512448 - 1512448), nlba 1, resid 1
    Other terminal port R5
    Enabling clocks!
                CPSW Ethernet Firmware
    ETHFW: Shared multicasts (software fanout):
    ETHFW: Reserved multicasts:
      01:80:c2:00:00:0e
      01:1b:19:00:00:00
    EnetMcm: CPSW_9G on MAIN NAVSS
    PHY 16 is alive
    PHY 17 is alive
    PHY 18 is alive
    PHY 19 is alive
    EnetPhy_bindDriver: PHY 16: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 17: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 18: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 19: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    ETHFW Version   : 0.02.00
    ETHFW Build Date: Aug  1, 2022
    ETHFW Build Time: 21:11:13
    ETHFW Commit SHA:
    Starting lwIP, local interface IP is dhcp-enabled
    Host MAC address: 70:ff:76:1d:92:c2
    [LWIPIF_LWIP] Enet LLD netif initialized successfully
    Added interface 'ti1', IP is 0.0.0.0
    Skipping Ipc_loadResourceTable for QNX (core : mcu2_0) .....
    CpswProxyServer: Virtual port configuration:
      mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
      mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
    CpswProxyServer: initialization completed (core: mcu2_0)
    REMOTE_SERVICE: Init ... !!!
    Function:CpswProxyServer_attachExtHandlerCb,HostId:4,CpswType:6
    [IPC] Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a7b384,CoreKey:3            8acb976, Cmd:1010401,InArgsLen:0, OutArgsLen:4
    Virtio_kick: Ipc_mailboxSend failed
    Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a7b384,CoreKey:38acb97            6, Cmd:1010201,InArgsLen:24, OutArgsLen:4
    REMOTE_SERVICE: Init ... Done !!!
    Function:CpswProxyServer_registerMacHandlerCb,HostId:4,Handle:a2a7b384,CoreKey:3            8acb976, MacAddress:70:ff:76:1d:92:c3, FlowIdx:178, FlowIdxOffset:6
    Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:5, Policer Entry:1
    Function:CpswProxyServer_registerRemoteTimerHandlerCb,HostId:4,Handle:a2a7b384,C            oreKey:38acb976, Name:mcu_2_1_ethswitch-device-1, Timer:1, PushNum:2
    if i want to change the path to the ti_fs/bin or ti_fs/tibin some error happened
    J7EVM@QNX:/ti_fs# ls
    =boot          lib            sysfw.itb      tispl.bin
    bin            qnx-ifs        tibin          u-boot.img
    boot           sbin           tiboot3.bin    uEnv.txt
    etc            scripts        tilib          usr
    J7EVM@QNX:/ti_fs# cd tibin
    ksh: cd: /ti_fs/tibin - Input/output error
    J7EVM@QNX:/ti_fs# cd scripts/
    J7EVM@QNX:/ti_fs/scripts# ls
    start_qconn_with_devnp-cpsw2g.sh       user__dss_on_a72.sh
    start_qconn_with_usb-asix.sh           user__dss_on_r5.sh
    user.sh
    J7EVM@QNX:/ti_fs/scripts# cd ..
    J7EVM@QNX:/ti_fs# cd etc
    J7EVM@QNX:/ti_fs/etc# ls
    system
    J7EVM@QNX:/ti_fs/etc# cd
    J7EVM@QNX:/# cd ti_fs/tilib/
    J7EVM@QNX:/ti_fs/tilib# ls
    devnp-cpsw2g.so                        libti-sciclient.so
    devnp-cpsw9g.so                        libti-sciclient.so.1
    libsharedmemallocator.so               libti-udmalld.so
    libsharedmemallocator.so.1             libti-udmalld.so.1
    libti-enetlld.so                       libtiipc-usr.so
    libti-enetlld.so.1                     libtiipc-usr.so.1
    libti-ipclld.so                        libtiudma-usr.so
    libti-ipclld.so.1                      libtiudma-usr.so.1
    libti-pdk.so
    libti-pdk.so.1
    cp operation
    J7EVM@QNX:/ti_fs/tilib# cp /ti_fs/tiboot3.bin /ti_fs/asdf.delme
    cp: Can't open destination file.  (/ti_fs/asdf.delme): Permission denied
    so basically, i have set the enviroment of RTOS SDK, then put QNX SDK under that Path,  then follow the QNX SDK Guild to make all and create the ifs image, the output qnx-ifs has the same size as ifs-j721e-evm-ti.raw, which is auto generated in psdkqa/bootfs/.
    ~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/psdkqa/bootfs$ ls -ls
    total 8128
       4 drwxrwxr-x 2 -  4096 Aug  1 19:30 bin
       4 drwxrwxr-x 2 -    4096 Aug  1 19:30 boot
       4 drwxrwxr-x 3 -4096 Aug  1 19:30 etc
       4 drwxrwxr-x 3 -096 Aug  1 19:30 lib
    8092 -rw-rw-r-- 1 - 8284508 Aug  8 17:40 qnx-ifs
       4 drwxrwxr-x 2 -    4096 Aug  1 19:30 sbin
       4 drwxrwxr-x 2 -  4096 Aug  1 20:29 scripts
       4 drwxrwxr-x 2 -  4096 Aug  1 20:29 tibin
       4 drwxrwxr-x 2 -    4096 Aug  1 20:29 tilib
       4 drwxrwxr-x 5 -  4096 Aug  1 19:30 usr
    i copied all the files into sd card /boot/   although the command from guide only copied the qnx-ifs file , the folder like bin/ etc/ can not be copied with the guide command.
    cp -fv ${PSDK_QNX_PATH}/bootfs/*                            <path_to_SD_card_mount_dir>/boot
    i think if i follow the guide from TI, use the ti provided build script , i just incommented the ETH part in build script , but from start up log. you can see, it was also not successfully.
    here is the built image: i think the raw file would be renamed and copied to the /bootfs/ folder?
    here is my local psdkqa/qnx/bsp/images/
    ~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/psdkqa/qnx/bsp/images$ ls -ls -a
    total 99724
        4 drwxr-xr-x 3      4096 Aug  8 17:39 .
        4 drwxrwxr-x 7      4096 Aug  3 10:12 ..
    60076 -rw-r--r-- 1   61513984 Jan 20  2022 ifs-j721e-evm-graphics.raw
     8056 -rw-r--r-- 1   8245932 Jan 20  2022 ifs-j721e-evm.raw
     8092 -rw-rw-r-- 1    8283972 Aug  3 10:17 ifs-j721e-evm-ti-emmc.raw
     8092 -rw-rw-r-- 1    8284508 Aug  8 17:39 ifs-j721e-evm-ti.raw
       20 -rw-r--r-- 1     16693 Jan 20  2022 j721e-evm.build
       24 -rw-r--r-- 1     23754 Jan 20  2022 j721e-evm-graphics.build
       20 -rw-r--r-- 1      16631 Jan 20  2022 j721e-evm-smmu.build
       20 -rw-r--r-- 1    17355 Jan 20  2022 j721e-evm-static.build
       24 -rw-r--r-- 1      21271 Aug  8 17:37 j721e-evm-ti.build
       24 -rw-r--r-- 1      21288 Aug  3 10:12 j721e-evm-ti-emmc.build
        4 -rw-r--r-- 1       1512 Aug  3 10:12 Makefile
    15048 -rwxrwxr-x 1  15425312 Aug  8 17:39 procnto-smp-instr.sym
      212 -rwxrwxr-x 1   269568 Aug  8 17:39 startup-j721e-evm.sym
        4 drwxr-xr-x 3     4096 Jan 20  2022 target-extra
  • Hi
    It appears an issue is occurring with SD card driver, as indicated by the slog2info logs, which are not expected.
    For details on these logs, please see the SD driver in the QNX BSP, and/or reach out to QNX  / Blackberry for support.
    Some tests that could be tried:
    • Try a different SD card.  If the 16GB SD card that came with the J721E EVM is available, those are known to work.
    • When on the host, can you run the same copy command, that was run on the target, on the SD card have it succeed?
    kb
  • i have use the steps 1 to make the partition for the 32GB SD card. i just tested in linux , all file can be copy to other fold in boot partition.
    • Insert SD card onto your PC SD card slot and format SD card in two partitions. At-least 16GB SD card recommended.
      • FAT32 partition: for boot loader, 12GB size recommended
      • ext4 partition: for root filesystem, rest of SD card. (Used only for SPL+Uboot boot to store firmware images)
    SD card is bought new and was also used for basic qnx build before, it works fine from qnx guide for 7.1. I think sd card has no issue. But my feeling is maybe the guide from TI sth. is wrong or some steps are missing in the documentation. like RTOS set enviroment step....
    I have a question, as in Guide from TI looks a little strange,
    as ext4 is for rootfs (root file system) why only copy 2 eth_firmware into this partition. The file system image will never be there?  partition 2 (rootfs) has only lib/firmware/... , but in FAT32 partition 1 (boot) so much folder (like file system) needs to be copied into boot partition?
    my file list is followed, in /boot and /rootfs
    /boot$ ls -a
    . boot qnx-ifs sysfw.itb tilib u-boot.img
    .. etc sbin tibin tispl.bin uEnv.txt
    bin lib scripts tiboot3.bin .Trash-1000 usr
    /rootfs$ ls
    lib
    Guide copy command from TI:
    cd ${PSDK_QNX_PATH}
    ## Remove existing files on bootfs
    rm -rf <path_to_SD_card_mount_dir>/boot/*
    ## Copy PSDK QNX binaries + QNX FS
    ## Copy SPL-Uboot
    cp -fv ${PSDK_QNX_PATH}/qnx/scripts/u-boot/uEnv.txt         <path_to_SD_card_mount_dir>/boot/uEnv.txt
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/tiboot3.bin                 <path_to_SD_card_mount_dir>/boot
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/tispl.bin                   <path_to_SD_card_mount_dir>/boot
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/u-boot.img                  <path_to_SD_card_mount_dir>/boot
    cp -fv ${PSDK_LINUX_UBOOT_PATH}/sysfw.itb                   <path_to_SD_card_mount_dir>/boot
    ## Remove existing files on rootfs
    sudo rm -rf <path_to_SD_card_mount_dir>/rootfs/*
    ## Copy remote proc images
    sudo mkdir -p <path_to_SD_card_mount_dir>/rootfs/lib/firmware
    sudo cp -fv ${PSDK_QNX_PATH}/ethfw_firmware/j7-main-r5f0_0-fw  <path_to_SD_card_mount_dir>/rootfs/lib/firmware
    sudo cp -fv ${PSDK_QNX_PATH}/ethfw_firmware/j7-main-r5f0_1-fw  <path_to_SD_card_mount_dir>/rootfs/lib/firmware
  • Regarding "why only copy 2 eth_firmware into this partition", the steps being followed 2(a) and 2(c) for a basic ethernet test, and only those two images are required.   Having the ext4 partition on the SD card, allows the same Uboot used for PSDK Linux, to function for PSDK QNX.   Once QNX starts it requires the filesystem to be on a DOS partition, for which the boot partition was re-used.
    If further content is desired on the SD card, please reference the Vision Apps User Guide: Vision Apps Introduction, which support many different demos, making use of the additional cores on the TDA4VM.   This uses a different set of build commands which may be worth trying.
    kb
  • thanks for the info.
    i have changed the orig. 16GB Scandisk SD card, after start up  phase, call the user.sh file from TI , it can run the app correctly, (the 32GB sd card before is from Intenso). But in the ti-build script file, i activate those apps (maybe FileSystem from sd card is still no loaded?) , it can not activate the tisci-mgr, tisci...... , only after mount of sd card file system, and user.sh is called, then it can run correctly, see "start log".
    Welcome to QNX Neutrino 7.1.0 on the TI J721E EVM Board!!
    Starting random service ...
    Starting TI services ...
    Unable to start "tisci-mgr" (2)
    Unable to access "/dev/tisci" (2)
    Unable to start "shmemallocator" (2)
    Unable to access "/dev/shmemallocator" (2)
    Unable to start "tiipc-mgr" (2)
    Unable to access "/dev/tiipc" (2)
    Unable to start "tiudma-mgr" (2)
    Unable to access "/dev/tiudma" (2)
    start serial driver
    start log:
    U-Boot 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
    SoC:   J721E SR1.1
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev A
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA8                                                       0100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    cdns,sierra serdes@5000000: sierra probed
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    556 bytes read in 9 ms (59.6 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    gpio: pin gpio@22_17 (gpio 281) value is 1
    gpio: pin gpio@22_16 (gpio 280) value is 0
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    4787436 bytes read in 209 ms (21.8 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 4787436 bytes: Success!
    3043076 bytes read in 136 ms (21.3 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 3043076 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    Failed to load '/lib/firmware/j7-c66_0-fw'
    Failed to load '/lib/firmware/j7-c66_1-fw'
    Failed to load '/lib/firmware/j7-c71_0-fw'
    8284508 bytes read in 353 ms (22.4 MiB/s)
    ## Starting application at 0x80080000 ...
    MMU: 16-bit ASID 44-bit PA TCR_EL1=b5183519
    ARM GIC-500 r1p1, arch v3.0 detected
    gic_v3_lpi_add_entry for vectors 8192 -> 8447, Ok
    gic_v3_lpi_add_entry for vectors 8448 -> 65535, Ok
    No SPI intrinfo. Add default entry for 32 -> 991 vectors, Ok
    LPI config table #1 @ 000000008000f000, callout vaddr: ffffff8040251000
    cpu0: MPIDR=80000000
    cpu0: MIDR=411fd080 Cortex-A72 r1p0
    cpu0: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
    cpu0: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
    cpu0: L1 Icache 48K linesz=64 set/way=256/3
    cpu0: L1 Dcache 32K linesz=64 set/way=256/2
    cpu0: L2 Unified 1024K linesz=64 set/way=1024/16
    Enabling ITS 0
    ITS queue at 0000000080020000, num slots: 256
    Issue MAPC/SYNC/INVALL commands for ICID 0
    update CWRITER to 0x00000060
    Waiting for all commands to be processed ... Done in 1 tries
    Enable LPIs in GICR_CTLR @ 0000000001900000 for CPU0
    Display set to R5
    TI: Not configuring pcie to avoid serdes conflict with EthFw using QSGMII board
    Total Available L3 cache (MSMC SRAM): 0 bytes
    Loading IFS...decompressing...done
    cpu1: MPIDR=80000001
    cpu1: MIDR=411fd080 Cortex-A72 r1p0
    cpu1: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
    cpu1: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
    cpu1: L1 Icache 48K linesz=64 set/way=256/3
    cpu1: L1 Dcache 32K linesz=64 set/way=256/2
    cpu1: L2 Unified 1024K linesz=64 set/way=1024/16
    ITS 0 already Enabled
    Issue MAPC/SYNC/INVALL commands for ICID 1
    update CWRITER to 0x000000c0
    Enable LPIs in GICR_CTLR @ 0000000001920000 for CPU1
    System page at phys:0000000080023000 user:ffffff8040275000 kern:ffffff8040272000
    Starting next program at vffffff80600983c0
    All ClockCycles offsets within tolerance
    start serial driver
    Setting OS clock from RTC
    Starting MMC/SD memory card driver... eMMC
    Starting MMC/SD memory card driver... SD
    Starting Network driver...
    Path=0 - am65x
     target=0 lun=0     Direct-Access(0) - SDMMC: S0J56X Rev: 1.0
    if_up: retries exhausted
    ifconfig: SIOCGIFFLAGS am0: No such device or address
    Starting XHCI driver on USB3SS0 and USB3SS1
    Setting environment variables...
    done..
    Mounting the sd ..
    Looking for user script to run: /ti_fs/scripts/user.sh
    Running user script...
    user.sh called...
    Setting additional environment variables...
    Starting tisci-mgr..
    Starting shmemallocator..
    Starting tiipc-mgr..
    Starting TI IPC Resmgr
    Starting tiudma-mgr..
    Start screen..
    screen started with dss_on_r5 configuration..
    done...
    J7EVM@QNX:/# ifconfig
    lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33136
            inet 127.0.0.1 netmask 0xff000000
            inet6 ::1 prefixlen 128
            inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    J7EVM@QNX:/# io-pkt-v6-hc -d cpsw2g
    J7EVM@QNX:/# dhclient -nw am0
    am0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
            address: 24:76:25:a2:5c:fb
            media: Ethernet none
            status: no carrier
            inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
            inet6 fe80::2676:25ff:fea2:5cfb%am0 prefixlen 64 scopeid 0x11
    J7EVM@QNX:/# ifconfig am0 192.168.111.20
            status: no carrier
            inet 192.168.111.20 netmask 0xffffff00 broadcast 192.168.111.255
    J7EVM@QNX:/# qconn
    i have still some question :
    1. is it possible to mount the file system before? so that those Ti file is already got access, as i activate those TI SCI / IPC Resource Managers part in begin of QNX build script file (j721e-evm-ti.build) ?
    2. ssh in qnx with putty still get connect refused. qconn for prot 8000 works fine. momentic can sync with target. How to activate the ssh ? still any binary missing in image file? maybe the qnx710 target lib must also add into build script but i found lots of ssh related binary
  • Hi
    Regarding (1), yes the TI binaries can be included in the IFS and launched from the build file if that is desired.  They must be launched after the SD card is started and the filesystem has been mounted.
    Regarding (2), please contact QNX / Blackberry for SSH support, or reference online documentation at - ssh (qnx.com).   There are multiple su=blinks from this link for related configuration files.
    kb
