Other Parts Discussed in Thread: TDA4VM
Hi expert,
I'm try use the NFS on TDA4VM but failed. I also have try some method on E2E but it not work for me.
https://e2e.ti.com/support/processors/f/791/t/984034
Could you help give some comments? Thanks~
(base) test@test:~/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11$ sudo minicom -S ./bin/setupBoard.minicom [sudo] password for test: Welcome to minicom 2.7.1 OPTIONS: I18n Compiled on Aug 13 2017, 15:25:34. Port /dev/ttyUSB0, 18:03:18 Press CTRL-A Z for help on special keys U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 09:35:44 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.6(release):v2.7-rc0-dirty NOTICE: BL31: Built : 09:18:58, Aug 30 2022 I/TC: I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 09:20:07 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2021.01-ga169f42610 (Aug 30 2022 - 09:20:07 +0000) SoC: J721E SR1.0 GP Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 cdns,sierra serdes@5000000: sierra probed Net: eth0: ethernet@46000000port@1 Hit any key to stop autobo 0 =>env default -f -a ## Resetting to default environment =>saveenv Saving Environment to FAT... OK =>reset resetting ... U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 09:35:44 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.6(release):v2.7-rc0-dirty NOTICE: BL31: Built : 09:18:58, Aug 30 2022 I/TC: I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 09:20:07 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2021.01-ga169f42610 (Aug 30 2022 - 09:20:07 +0000) SoC: J721E SR1.0 GP Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 cdns,sierra serdes@5000000: sierra probed Net: eth0: ethernet@46000000port@1 Hit any key to stop autobo 0 =>setenv serverip 192.168.1.1 =>setenv nfs_root /home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS =>setenv name_kern Image =>setenv overlay_files k3-j721e-vision-apps.dtbo =>setenv bootcmd 'run findfdt; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern' =>setenv init_net 'run args_all args_net; setenv autoload no; dhcp' =>setenv args_net 'setenv bootargs console=${console} ${optargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp' =>setenv get_kern_net 'tftp ${loadaddr} ${name_kern}' =>setenv get_fdt_net 'tftp ${fdtaddr} ${name_fdt}' =>setenv get_overlay_net 'fdt address ${fdtaddr};fdt resize 0x100000;for overlay in ${overlay_files};do;tftp ${overlayaddr} ${overlay_files};fdt apply ${overlayaddr}; done' =>setenv nfs_options 'nolock,v3,tcp,rsize=4096,wsize=4096' =>setenv setup_mmc '' =>setenv setup_net 'setenv autoload no; dhcp' =>setenv kern_boot net =>setenv rootfs_boot net =>saveenv Saving Environment to FAT... OK =>boot switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 7 ms (67.4 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 12 ms (0 Bytes/s) Already setup. k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 Abort am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 Abort am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! => ping 192.168.1.1 am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set ping failed; host 192.168.1.1 is not alive => am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set ping failed; host 192.168.1.1 is not alive => U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 09:35:44 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.6(release):v2.7-rc0-dirty NOTICE: BL31: Built : 09:18:58, Aug 30 2022 I/TC: I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 09:20:07 +0000) Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2021.01-ga169f42610 (Aug 30 2022 - 09:20:07 +0000) SoC: J721E SR1.0 GP Model: Texas Instruments K3 J721E SoC Board: J721EX-PM1-SOM rev E2 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 cdns,sierra serdes@5000000: sierra probed Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 12 ms (0 Bytes/s) Already setup. k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 ethernet@46000000port@1 Waiting for PHY auto negotiation to complete. done link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! => setenv rootfs_boot net => set ipaddr 192.168.1.2 => boot switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 9 ms (51.8 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 13 ms (0 Bytes/s) Already setup. am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 Abort am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 Abort am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! => setenv serverip 192.168.1.1 => setenv nfs_root /home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS => setenv name_kern Image => setenv overlay_files k3-j721e-vision-apps.dtbo => setenv bootcmd 'run findfdt; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern' => setenv init_net 'run args_all args_net; setenv autoload no; dhcp' => setenv args_net 'setenv bootargs console=${console} ${optargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp' => setenv get_kern_net 'tftp ${loadaddr} ${name_kern}' => setenv get_fdt_net 'tftp ${fdtaddr} ${name_fdt}' => setenv get_overlay_net 'fdt address ${fdtaddr};fdt resize 0x100000;for overlay in ${overlay_files};do;tftp ${overlayaddr} ${overlay_files};fdt apply ${overlayaddr}; done' => setenv nfs_options 'nolock,v3,tcp,rsize=4096,wsize=4096' => setenv setup_mmc '' => setenv setup_net 'setenv autoload no; dhcp' => setenv kern_boot net => setenv rootfs_boot net => boot switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 9 ms (51.8 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 10 ms (0 Bytes/s) Already setup. am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 Abort am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 Abort am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! => set ipaddr 192.168.1.2 => setenv serverip 192.168.1.1 => setenv nfs_root /home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS => setenv name_kern /boot/Image => setenv overlay_files /boot/k3-j721e-vision-apps.dtbo => setenv bootcmd 'run findfdt; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern' => setenv init_net 'run args_all args_net; setenv autoload no; dhcp' => setenv args_net 'setenv bootargs console=${console} ${optargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp' => setenv get_kern_net 'tftp ${loadaddr} ${name_kern}' => setenv get_fdt_net 'tftp ${fdtaddr} ${name_fdt}' => setenv get_overlay_net 'fdt address ${fdtaddr};fdt resize 0x100000;for overlay in ${overlay_files};do;tftp ${overlayaddr} ${overlay_files};fdt apply ${overlayaddr}; done' => setenv nfs_options 'nolock,v3,tcp,rsize=4096,wsize=4096' => setenv setup_mmc '' => setenv setup_net 'setenv autoload no; dhcp' => setenv kern_boot net => setenv rootfs_boot net => boot switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 13 ms (0 Bytes/s) Already setup. am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! => ping 192.168.1.1 am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set ping failed; host 192.168.1.1 is not alive => ping 192.168.1.1 am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set ping failed; host 192.168.1.1 is not alive => set ipaddr 192.168.1.2 => ping 192.168.1.1 am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex Using ethernet@46000000port@1 device host 192.168.1.1 is alive => boot switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 12 ms (0 Bytes/s) Already setup. am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! => nfs 0x82000000 192.168.1.1:/home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS/boot/Image am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set => set ipaddr 192.168.1.2 => nfs 0x82000000 192.168.1.1:/home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS/boot/Image am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex Using ethernet@46000000port@1 device File transfer via NFS from server 192.168.1.1; our IP address is 192.168.1.2 Filename '/home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS/boot/Image'. Load address: 0x82000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ########################################### done Bytes transferred = 18520576 (11a9a00 hex) => nfs 0x81200000 192.168.1.1:/home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS/boot/k3-j721e-common-proc-board.dtb am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex Using ethernet@46000000port@1 device File transfer via NFS from server 192.168.1.1; our IP address is 192.168.1.2 Filename '/home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS/boot/k3-j721e-common-proc-board.dtb'. Load address: 0x81200000 Loading: ##################### done Bytes transferred = 107508 (1a3f4 hex) => am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex Using ethernet@46000000port@1 device File transfer via NFS from server 192.168.1.1; our IP address is 192.168.1.2 Filename '/home/test/Desktop/pc_disk/ti_sdk/TDA4VM/ti-8.4/ti-processor-sdk-linux-j7-evm-08_04_00_11/targetNFS/boot/k3-j721e-common-proc-board.dtb'. Load address: 0x81200000 Loading: ##################### done Bytes transferred = 107508 (1a3f4 hex) => boot switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 13 ms (0 Bytes/s) Already setup. am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2 link up on port 1, speed 1000, full duplex *** ERROR: `ipaddr' not set No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! =>
