According to TI multi camera demo, refer to captureNode,
A new kernel (bydCameraTransferNode (vx_graph graph, vx_object_array output)) has been written,
The Process function on the target side mainly obtains the images of four cameras from the interface provided by the third-party camera service,
The third party service provides an interface for acquiring images: autoCameraManager getOpenvxImage(image_type, isWait, &outType);
Where isWait: whether to wait for a new frame.
We have written a flow chart, which only includes the bydCameraTransferNode node. Then, we add the start time before entering the queue and the end time after leaving the queue to count the time from entering the queue to leaving the queue. At the same time, we count the number of frames executed within one second.
At the same time, we also add the start time at the TI multi camera demo queue entry point, and add the end time at the queue exit point. Similarly, we only retain the captureNode node to count the time from a queue entry to a queue exit, and count the number of frames executed within one second.
Then, we compared the data between the two, and found that the time spent from queue entry to queue exit of TI multi camera demo is about 33ms, while the time spent from queue entry to queue exit of nodes written by ourselves is not uniform.
In addition, the CPU usage of our graph during operation is 15%, much higher than that of TI multi-camera demo. For pipeline scheduling, what logical strategies should be done inside the node to reduce the CPU usage?
We are confused about this. What mechanism is used to control the time uniformity of captureNode? How do we control the time uniformity of the nodes we write?
#include <unistd.h> #include <stdlib.h> #include <stdio.h> #include <sys/stat.h> #include <sys/time.h> #include "VX/vx.h" #include "TI/tivx.h" #include "TI/tivx_target_kernel.h" #include <TI/tivx_task.h> #include "tivx_kernels_target_utils.h" #include "byd/byd_camera_transfer.h" #include "byd_camera_transfer_kernels_priv.h" #include "byd_camera_transfer_host.h" #include <utils/mem/include/app_mem.h> #include "camera_client.h" #include <common_log.h> // #include <TI/tivx_mutex.h> // #include <inttypes.h> #define NUM_CHANNELS (4U) #define TIVX_FILEIO_FILE_PATH_LENGTH (512U) #define MAX_FNAME (256u) static tivx_target_kernel byd_camera_transfer_target_kernel = NULL; // static pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER; struct timeval now_tv3 = {0}; struct timeval pre_tv3 = {0}; uint32_t tv_ms3; struct timeval now_tv4 = {0}; struct timeval pre_tv4 = {0}; uint32_t tv_ms4; struct timeval now_tv0 = {0}; struct timeval pre_tv0 = {0}; uint32_t tv_ms0; static int kernel_process_cnt = 0; static uint64_t kernel_process_id = 0; #if 0 static int file_index = 0; struct timeval now_tv8 = {0}; struct timeval pre_tv8 = {0}; uint32_t tv_ms6; static char *app_get_test_file_path() { char *tivxPlatformGetEnv(char *env_var); #if defined(SYSBIOS) return tivxPlatformGetEnv("VX_TEST_DATA_PATH"); #else return getenv("VX_TEST_DATA_PATH"); #endif } #endif int get_time_diff2(struct timeval *pT1, struct timeval *pT2) { int t_ms; if (pT1->tv_sec >= pT2->tv_sec) { t_ms = (pT1->tv_sec * 1000000 + pT1->tv_usec) - (pT2->tv_sec * 1000000 + pT2->tv_usec); } else { t_ms = (pT2->tv_sec * 1000000 + pT2->tv_usec) - (pT1->tv_sec * 1000000 + pT1->tv_usec); } return t_ms; } vx_status ptkdemo_load_vximage_from_yuvfile(vx_image image, char *filename) { vx_status vxStatus = (vx_status)VX_SUCCESS; vx_rectangle_t rect; vx_imagepatch_addressing_t image_addr; vx_map_id map_id; void * data_ptr; vx_uint32 img_width; vx_uint32 img_height; vx_df_image img_format; vx_int32 j; FILE *fp= fopen(filename, "rb"); if(fp==NULL) { VX_PRINT(VX_ZONE_ERROR, "# ERROR: Unable to open input file [%s]\n", filename); return(VX_FAILURE); } vxQueryImage(image, VX_IMAGE_WIDTH, &img_width, sizeof(vx_uint32)); vxQueryImage(image, VX_IMAGE_HEIGHT, &img_height, sizeof(vx_uint32)); vxQueryImage(image, VX_IMAGE_FORMAT, &img_format, sizeof(vx_df_image)); rect.start_x = 0; rect.start_y = 0; rect.end_x = img_width; rect.end_y = img_height; // Copy Luma or Luma+Chroma vxStatus = vxMapImagePatch(image, &rect, 0, &map_id, &image_addr, &data_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST, VX_NOGAP_X); for (j = 0; j < image_addr.dim_y; j++) { fread(data_ptr, 1, image_addr.dim_x*image_addr.stride_x, fp); data_ptr += image_addr.stride_y; } vxUnmapImagePatch(image, map_id); // Copy Chroma for NV12 if (img_format == VX_DF_IMAGE_NV12) { vxStatus = vxMapImagePatch(image, &rect, 1, &map_id, &image_addr, &data_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST, VX_NOGAP_X); for (j = 0; j < img_height/2; j++) { fread(data_ptr, 1, image_addr.dim_x, fp); data_ptr += image_addr.stride_y; } vxUnmapImagePatch(image, map_id); } fclose(fp); return vxStatus; } static vx_status VX_CALLBACK bydCameraTransferProcess( tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[], uint16_t num_params, void *priv_arg); static vx_status VX_CALLBACK bydCameraTransferCreate( tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[], uint16_t num_params, void *priv_arg); static vx_status VX_CALLBACK bydCameraTransferDelete( tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[], uint16_t num_params, void *priv_arg); static vx_status VX_CALLBACK bydCameraTransferProcess( tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[], uint16_t num_params, void *priv_arg) { gettimeofday(&now_tv3, NULL); pre_tv3.tv_sec = now_tv3.tv_sec; pre_tv3.tv_usec = now_tv3.tv_usec; LOGD("%s -------------------pre_tv3.tv_sec %ld, pre_tv3.tv_usec %ld \n", __FUNCTION__, pre_tv3.tv_sec, pre_tv3.tv_usec); kernel_process_id++; gettimeofday(&now_tv0, NULL); if (pre_tv0.tv_sec == 0 && pre_tv0.tv_usec == 0) { pre_tv0.tv_sec = now_tv0.tv_sec; pre_tv0.tv_usec = now_tv0.tv_usec; // LOGD("pre_tv0.tv_sec %ld \n", pre_tv0.tv_sec); // LOGD("pre_tv0.tv_usec %ld \n", pre_tv0.tv_usec); } tv_ms0 = get_time_diff2(&now_tv0, &pre_tv0) / 1000; // LOGD("tv_ms0 %d \n", tv_ms0); if (tv_ms0 > 1000) { LOGD("==================1s kernel process cnt: %d \n", kernel_process_cnt); pre_tv0.tv_sec = now_tv0.tv_sec; pre_tv0.tv_usec = now_tv0.tv_usec; kernel_process_cnt = 0; } else { if (kernel_process_id >= 0 && kernel_process_id <= 3000) { LOGD("==================current kernel_process_id: %ld \n", kernel_process_id); } } kernel_process_cnt++; vx_status status = (vx_status)VX_SUCCESS; tivx_obj_desc_object_array_t *out_object_array_desc; tivx_obj_desc_image_t *out_image_desc[4]; tivx_obj_desc_image_t *image_out_object_array_desc[TIVX_OBJECT_ARRAY_MAX_ITEMS]; uint32_t i; vx_enum state; if ( (num_params != BYD_KERNEL_CAMERA_TRANSFER_MAX_PARAMS) || (NULL == obj_desc[BYD_KERNEL_CAMERA_TRANSFER_OUTPUT_IDX]) ) { status = (vx_status)VX_FAILURE; } if (VX_SUCCESS == status) { out_object_array_desc = (tivx_obj_desc_object_array_t *)obj_desc[BYD_KERNEL_CAMERA_TRANSFER_OUTPUT_IDX]; } if (VX_SUCCESS == status) { tivxGetObjDescList(out_object_array_desc->obj_desc_id, (tivx_obj_desc_t**)image_out_object_array_desc, out_object_array_desc->num_items); for (i = 0; i < NUM_CHANNELS; i++) { out_image_desc[i] = image_out_object_array_desc[i]; } if (VX_SUCCESS == status) { status = tivxGetTargetKernelInstanceState(kernel, &state); if (VX_SUCCESS == status) { if (VX_NODE_STATE_STEADY == state) { gettimeofday(&now_tv4, NULL); pre_tv4.tv_sec = now_tv4.tv_sec; pre_tv4.tv_usec = now_tv4.tv_usec; LOGD("%s -------------------pre_tv4.tv_sec %ld, pre_tv4.tv_usec %ld \n", __FUNCTION__, pre_tv4.tv_sec, pre_tv4.tv_usec); // camera_image_dequeue(out_image_desc, NUM_CHANNELS); // pthread_mutex_lock(&mutex); // pthread_t actual_tid = pthread_self(); // uint64_t current_id = 0; // memcpy(¤t_id, &actual_tid, sizeof(actual_tid)); // LOGD("%s syncronized camera_image_dequeue ================================ Thread id = ", __FUNCTION__); // LOGD("%" PRIu64 "\n", current_id); camera_image_dequeue(out_image_desc, NUM_CHANNELS); // pthread_mutex_unlock(&mutex); for (i = 0; i < NUM_CHANNELS; i++) { LOGD("%s ------------------------out_image_desc[%d]->base.timestamp %ld \n", __FUNCTION__, i, out_image_desc[i]->base.timestamp); } #if 0 gettimeofday(&now_tv8, NULL); if (pre_tv8.tv_sec == 0 && pre_tv8.tv_usec == 0) { pre_tv8.tv_sec = now_tv8.tv_sec; pre_tv8.tv_usec = now_tv8.tv_usec; // LOGD("pre_tv8.tv_sec %ld \n", pre_tv8.tv_sec); // LOGD("pre_tv8.tv_usec %ld \n", pre_tv8.tv_usec); } tv_ms6 = get_time_diff2(&now_tv8, &pre_tv8) / 1000; // LOGD("tv_ms6 %d \n", tv_ms6); if (tv_ms6 > 2000) { char file_name[TIVX_FILEIO_FILE_PATH_LENGTH * 2]; char failsafe_test_data_path[3] = "./"; char * test_data_path = app_get_test_file_path(); struct stat s; if (NULL == test_data_path) { LOGD("Test data path is NULL. Defaulting to current folder \n"); test_data_path = failsafe_test_data_path; } if (stat(test_data_path, &s)) { LOGD("Test data path %s does not exist. Defaulting to current folder \n", test_data_path); test_data_path = failsafe_test_data_path; } if (out_image_desc[0]->format == VX_DF_IMAGE_NV12) { strcat(file_name, ".yuv"); } else if (out_image_desc[0]->format == VX_DF_IMAGE_RGB) { strcat(file_name, ".rgb"); } else { strcat(file_name, ".bin"); } snprintf(file_name, MAX_FNAME, "%s/%s_%04d.yuv", test_data_path, "cap_img_uyvy", file_index); LOGD("Writing %s ..\n", file_name); void* in_img_target_ptr[2]; in_img_target_ptr[0] = tivxMemShared2TargetPtr(&out_image_desc[0]->mem_ptr[0]); tivxMemBufferMap(in_img_target_ptr[0], out_image_desc[0]->mem_size[0], VX_MEMORY_TYPE_HOST, VX_READ_ONLY); in_img_target_ptr[1] = NULL; if (out_image_desc[0]->mem_ptr[1].shared_ptr != 0) { in_img_target_ptr[1] = tivxMemShared2TargetPtr(&out_image_desc[0]->mem_ptr[1]); tivxMemBufferMap(in_img_target_ptr[1], out_image_desc[0]->mem_size[1], VX_MEMORY_TYPE_HOST, VX_READ_ONLY); } FILE *fp = fopen(file_name, "wb"); if (fp == NULL) { LOGD("Unable to write file %s\n", file_name); } else { uint32_t width = out_image_desc[0]->imagepatch_addr[0].dim_x; uint32_t height = out_image_desc[0]->imagepatch_addr[0].dim_y; uint32_t stride = out_image_desc[0]->imagepatch_addr[0].stride_y; uint8_t *pData = in_img_target_ptr[0]; int32_t i; for (i = 0; i < height; i++) { fwrite(pData, 1, width, fp); pData += stride; } if (in_img_target_ptr[1] != NULL) { pData = in_img_target_ptr[1]; height = height / 2; for (i = 0; i < height; i++) { fwrite(pData, 1, width, fp); pData += stride; } } fflush(fp); fclose(fp); } LOGD("Done!\n"); tivxMemBufferUnmap(in_img_target_ptr[0], out_image_desc[0]->mem_size[0], VX_MEMORY_TYPE_HOST, VX_READ_ONLY); if (in_img_target_ptr[1] != NULL){ tivxMemBufferUnmap(in_img_target_ptr[1], out_image_desc[0]->mem_size[1], VX_MEMORY_TYPE_HOST, VX_READ_ONLY); } pre_tv8.tv_sec = now_tv8.tv_sec; pre_tv8.tv_usec = now_tv8.tv_usec; file_index++; if (file_index > 9999) { file_index = 0; } } #endif gettimeofday(&now_tv4, NULL); LOGD("%s =======================now_tv4.tv_sec %ld, now_tv4.tv_usec %ld \n", __FUNCTION__, now_tv4.tv_sec, now_tv4.tv_usec); // tv_ms4 = get_time_diff2(&now_tv4, &pre_tv4) / 1000; tv_ms4 = get_time_diff2(&now_tv4, &pre_tv4); LOGD("%s **************************** tv_us4 %d \n", __FUNCTION__, tv_ms4); // LOGD("sleep 5ms state: %d \n", state); // tivxTaskWaitMsecs(5); } else { // LOGD("sleep 10ms state: %d \n", state); // tivxTaskWaitMsecs(10); } } } } gettimeofday(&now_tv3, NULL); LOGD("%s =======================now_tv3.tv_sec %ld, now_tv3.tv_usec %ld \n", __FUNCTION__, now_tv3.tv_sec, now_tv3.tv_usec); // tv_ms3 = get_time_diff2(&now_tv3, &pre_tv3) / 1000; tv_ms3 = get_time_diff2(&now_tv3, &pre_tv3); LOGD("%s **************************** tv_us3 %d \n", __FUNCTION__, tv_ms3); return status; } static vx_status VX_CALLBACK bydCameraTransferCreate( tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[], uint16_t num_params, void *priv_arg) { vx_status status = (vx_status)VX_SUCCESS; if ( (num_params != BYD_KERNEL_CAMERA_TRANSFER_MAX_PARAMS) || (NULL == obj_desc[BYD_KERNEL_CAMERA_TRANSFER_OUTPUT_IDX]) ) { status = (vx_status)VX_FAILURE; } else { camera_client_start(); } return status; } static vx_status VX_CALLBACK bydCameraTransferDelete( tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[], uint16_t num_params, void *priv_arg) { vx_status status = (vx_status)VX_SUCCESS; if ( (num_params != BYD_KERNEL_CAMERA_TRANSFER_MAX_PARAMS) || (NULL == obj_desc[BYD_KERNEL_CAMERA_TRANSFER_OUTPUT_IDX]) ) { status = (vx_status)VX_FAILURE; } camera_client_stop(); return status; } void bydAddTargetKernelCameraTransfer(void) { vx_status status = VX_FAILURE; char target_name[TIVX_TARGET_MAX_NAME]; vx_enum self_cpu; self_cpu = tivxGetSelfCpuId(); if (self_cpu == TIVX_CPU_ID_A72_0) { strncpy(target_name, TIVX_TARGET_A72_0, TIVX_TARGET_MAX_NAME); status = VX_SUCCESS; } else { status = VX_FAILURE; } if (status == VX_SUCCESS) { byd_camera_transfer_target_kernel = tivxAddTargetKernelByName( BYD_CAMERA_TRANSFER, target_name, bydCameraTransferProcess, bydCameraTransferCreate, bydCameraTransferDelete, NULL, NULL); } } void bydRemoveTargetKernelCameraTransfer(void) { vx_status status = VX_SUCCESS; status = tivxRemoveTargetKernel(byd_camera_transfer_target_kernel); if (status == VX_SUCCESS) { byd_camera_transfer_target_kernel = NULL; } }
