SK-TDA4VM: How to see the datatype of mipi data at the application layer
Part Number: SK-TDA4VM
Hi Team,
Is there a way to check the datatype of mipi data at the application layer? I have a sensor that sends corresponding mipi data. I want to check whether the type it sends is correct. How should I do it?
I want to see the data before the development board accepts it, because my problem is that I set the raw16 reception on the development board now and it cannot be received normally.
So what I'm trying to see now is the data before the data matches.
Could I view the datatype of the mipi data before being checked by the CRC?
Kind regards,
Katherine
  • Hi Katherine,
    CSIRX will capture the image only if there is a matching datatype.. So if there is no capture, one of the reason could be datatype..
    No, application cannot know the datatype in the incoming stream.. The capture and comparison is done way before it is captured. Also there is no way in CSIRX to store received datatype.
    Brijesh
