Hii SIr,
Can You tell me ,How to load SPI flash Memory DTB file through Linux ?
Niraj Kumar
Hii SIr,
Niraj Kumar
Thanks sir,
I am working on SPI flash memory(w25q64) and I build DTS file for this through SDK and I want to load dts file into board through linux commad . Any command for this?
we can load file through another way but they will take more time.
Here I am putting dts file.
/* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /* * AM335x Starter Kit * http://www.ti.com/tool/tmdssk3358 */ /dts-v1/; #include "am33xx.dtsi" #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/interrupt-controller/irq.h> / { model = "TI AM335x EVM-SK"; compatible = "ti,am335x-evmsk", "ti,am33xx"; chosen { stdout-path = &uart0; tick-timer = &timer2; }; cpus { cpu@0 { cpu0-supply = <&vdd1_reg>; }; }; memory { device_type = "memory"; reg = <0x80000000 0x10000000>; /* 256 MB */ }; vbat: fixedregulator@0 { compatible = "regulator-fixed"; regulator-name = "vbat"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; regulator-boot-on; }; lis3_reg: fixedregulator@1 { compatible = "regulator-fixed"; regulator-name = "lis3_reg"; regulator-boot-on; }; wl12xx_vmmc: fixedregulator@2 { pinctrl-names = "default"; pinctrl-0 = <&wl12xx_gpio>; compatible = "regulator-fixed"; regulator-name = "vwl1271"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; gpio = <&gpio1 29 0>; startup-delay-us = <70000>; enable-active-high; }; vtt_fixed: fixedregulator@3 { compatible = "regulator-fixed"; regulator-name = "vtt"; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; gpio = <&gpio0 7 GPIO_ACTIVE_HIGH>; regulator-always-on; regulator-boot-on; enable-active-high; }; leds { pinctrl-names = "default"; pinctrl-0 = <&user_leds_s0>; compatible = "gpio-leds"; led@1 { label = "evmsk:green:usr0"; gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led@2 { label = "evmsk:green:usr1"; gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led@3 { label = "evmsk:green:mmc0"; gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc0"; default-state = "off"; }; led@4 { label = "evmsk:green:heartbeat"; gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; default-state = "off"; }; }; gpio_buttons: gpio_buttons@0 { compatible = "gpio-keys"; switch@1 { label = "button0"; linux,code = <0x100>; gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; }; switch@2 { label = "button1"; linux,code = <0x101>; gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; }; switch@3 { label = "button2"; linux,code = <0x102>; gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>; wakeup-source; }; switch@4 { label = "button3"; linux,code = <0x103>; gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>; }; }; backlight { compatible = "pwm-backlight"; pwms = <&ecap2 0 50000 PWM_POLARITY_INVERTED>; brightness-levels = <0 58 61 66 75 90 125 170 255>; default-brightness-level = <8>; }; sound { compatible = "simple-audio-card"; simple-audio-card,name = "AM335x-EVMSK"; simple-audio-card,widgets = "Headphone", "Headphone Jack"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound_master>; simple-audio-card,frame-master = <&sound_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp1>; }; sound_master: simple-audio-card,codec { sound-dai = <&tlv320aic3106>; system-clock-frequency = <24000000>; }; }; panel { compatible = "ti,tilcdc,panel"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&lcd_pins_default>; pinctrl-1 = <&lcd_pins_sleep>; status = "okay"; panel-info { ac-bias = <255>; ac-bias-intrpt = <0>; dma-burst-sz = <16>; bpp = <32>; fdd = <0x80>; sync-edge = <0>; sync-ctrl = <1>; raster-order = <0>; fifo-th = <0>; }; display-timings { 480x272 { hactive = <480>; vactive = <272>; hback-porch = <43>; hfront-porch = <8>; hsync-len = <4>; vback-porch = <12>; vfront-porch = <4>; vsync-len = <10>; clock-frequency = <9000000>; hsync-active = <0>; vsync-active = <0>; }; }; }; }; &am33xx_pinmux { pinctrl-names = "default"; pinctrl-0 = <&gpio_keys_s0 &clkout2_pin>; lcd_pins_default: lcd_pins_default { pinctrl-single,pins = < AM33XX_IOPAD(0x820, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad8.lcd_data23 */ AM33XX_IOPAD(0x824, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad9.lcd_data22 */ AM33XX_IOPAD(0x828, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad10.lcd_data21 */ AM33XX_IOPAD(0x82c, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad11.lcd_data20 */ AM33XX_IOPAD(0x830, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad12.lcd_data19 */ AM33XX_IOPAD(0x834, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad13.lcd_data18 */ AM33XX_IOPAD(0x838, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad14.lcd_data17 */ AM33XX_IOPAD(0x83c, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad15.lcd_data16 */ AM33XX_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE0) /* lcd_data0.lcd_data0 */ AM33XX_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE0) /* lcd_data1.lcd_data1 */ AM33XX_IOPAD(0x8a8, PIN_OUTPUT | MUX_MODE0) /* lcd_data2.lcd_data2 */ AM33XX_IOPAD(0x8ac, PIN_OUTPUT | MUX_MODE0) /* lcd_data3.lcd_data3 */ AM33XX_IOPAD(0x8b0, PIN_OUTPUT | MUX_MODE0) /* lcd_data4.lcd_data4 */ AM33XX_IOPAD(0x8b4, PIN_OUTPUT | MUX_MODE0) /* lcd_data5.lcd_data5 */ AM33XX_IOPAD(0x8b8, PIN_OUTPUT | MUX_MODE0) /* lcd_data6.lcd_data6 */ AM33XX_IOPAD(0x8bc, PIN_OUTPUT | MUX_MODE0) /* lcd_data7.lcd_data7 */ AM33XX_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE0) /* lcd_data8.lcd_data8 */ AM33XX_IOPAD(0x8c4, PIN_OUTPUT | MUX_MODE0) /* lcd_data9.lcd_data9 */ AM33XX_IOPAD(0x8c8, PIN_OUTPUT | MUX_MODE0) /* lcd_data10.lcd_data10 */ AM33XX_IOPAD(0x8cc, PIN_OUTPUT | MUX_MODE0) /* lcd_data11.lcd_data11 */ AM33XX_IOPAD(0x8d0, PIN_OUTPUT | MUX_MODE0) /* lcd_data12.lcd_data12 */ AM33XX_IOPAD(0x8d4, PIN_OUTPUT | MUX_MODE0) /* lcd_data13.lcd_data13 */ AM33XX_IOPAD(0x8d8, PIN_OUTPUT | MUX_MODE0) /* lcd_data14.lcd_data14 */ AM33XX_IOPAD(0x8dc, PIN_OUTPUT | MUX_MODE0) /* lcd_data15.lcd_data15 */ AM33XX_IOPAD(0x8e0, PIN_OUTPUT | MUX_MODE0) /* lcd_vsync.lcd_vsync */ AM33XX_IOPAD(0x8e4, PIN_OUTPUT | MUX_MODE0) /* lcd_hsync.lcd_hsync */ AM33XX_IOPAD(0x8e8, PIN_OUTPUT | MUX_MODE0) /* lcd_pclk.lcd_pclk */ AM33XX_IOPAD(0x8ec, PIN_OUTPUT | MUX_MODE0) /* lcd_ac_bias_en.lcd_ac_bias_en */ >; }; lcd_pins_sleep: lcd_pins_sleep { pinctrl-single,pins = < AM33XX_IOPAD(0x820, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad8.lcd_data23 */ AM33XX_IOPAD(0x824, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad9.lcd_data22 */ AM33XX_IOPAD(0x828, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad10.lcd_data21 */ AM33XX_IOPAD(0x82c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad11.lcd_data20 */ AM33XX_IOPAD(0x830, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad12.lcd_data19 */ AM33XX_IOPAD(0x834, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad13.lcd_data18 */ AM33XX_IOPAD(0x838, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad14.lcd_data17 */ AM33XX_IOPAD(0x83c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad15.lcd_data16 */ AM33XX_IOPAD(0x8a0, PULL_DISABLE | MUX_MODE7) /* lcd_data0.lcd_data0 */ AM33XX_IOPAD(0x8a4, PULL_DISABLE | MUX_MODE7) /* lcd_data1.lcd_data1 */ AM33XX_IOPAD(0x8a8, PULL_DISABLE | MUX_MODE7) /* lcd_data2.lcd_data2 */ AM33XX_IOPAD(0x8ac, PULL_DISABLE | MUX_MODE7) /* lcd_data3.lcd_data3 */ AM33XX_IOPAD(0x8b0, PULL_DISABLE | MUX_MODE7) /* lcd_data4.lcd_data4 */ AM33XX_IOPAD(0x8b4, PULL_DISABLE | MUX_MODE7) /* lcd_data5.lcd_data5 */ AM33XX_IOPAD(0x8b8, PULL_DISABLE | MUX_MODE7) /* lcd_data6.lcd_data6 */ AM33XX_IOPAD(0x8bc, PULL_DISABLE | MUX_MODE7) /* lcd_data7.lcd_data7 */ AM33XX_IOPAD(0x8c0, PULL_DISABLE | MUX_MODE7) /* lcd_data8.lcd_data8 */ AM33XX_IOPAD(0x8c4, PULL_DISABLE | MUX_MODE7) /* lcd_data9.lcd_data9 */ AM33XX_IOPAD(0x8c8, PULL_DISABLE | MUX_MODE7) /* lcd_data10.lcd_data10 */ AM33XX_IOPAD(0x8cc, PULL_DISABLE | MUX_MODE7) /* lcd_data11.lcd_data11 */ AM33XX_IOPAD(0x8d0, PULL_DISABLE | MUX_MODE7) /* lcd_data12.lcd_data12 */ AM33XX_IOPAD(0x8d4, PULL_DISABLE | MUX_MODE7) /* lcd_data13.lcd_data13 */ AM33XX_IOPAD(0x8d8, PULL_DISABLE | MUX_MODE7) /* lcd_data14.lcd_data14 */ AM33XX_IOPAD(0x8dc, PULL_DISABLE | MUX_MODE7) /* lcd_data15.lcd_data15 */ AM33XX_IOPAD(0x8e0, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_vsync.lcd_vsync */ AM33XX_IOPAD(0x8e4, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_hsync.lcd_hsync */ AM33XX_IOPAD(0x8e8, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_pclk.lcd_pclk */ AM33XX_IOPAD(0x8ec, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_ac_bias_en.lcd_ac_bias_en */ >; }; user_leds_s0: user_leds_s0 { pinctrl-single,pins = < AM33XX_IOPAD(0x810, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */ AM33XX_IOPAD(0x814, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */ AM33XX_IOPAD(0x818, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */ AM33XX_IOPAD(0x81c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */ >; }; gpio_keys_s0: gpio_keys_s0 { pinctrl-single,pins = < AM33XX_IOPAD(0x894, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_oen_ren.gpio2_3 */ AM33XX_IOPAD(0x890, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_advn_ale.gpio2_2 */ AM33XX_IOPAD(0x870, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wait0.gpio0_30 */ AM33XX_IOPAD(0x89c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ben0_cle.gpio2_5 */ >; }; i2c0_pins: pinmux_i2c0_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x988, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_sda.i2c0_sda */ AM33XX_IOPAD(0x98c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_scl.i2c0_scl */ >; }; spi0_pins_default: spi0_pins_default { pinctrl-single,pins = < AM33XX_IOPAD(0x950, PIN_INPUT_PULLUP | MUX_MODE0) /* (A17) spi0_sclk.spi0_sclk */ AM33XX_IOPAD(0x954, PIN_INPUT_PULLUP | MUX_MODE0) /* (B17) spi0_d0.spi0_d0 */ AM33XX_IOPAD(0x958, PIN_INPUT_PULLUP | MUX_MODE0) /* (B16) spi0_d1.spi0_d1 */ AM33XX_IOPAD(0x95c, PIN_INPUT_PULLUP | MUX_MODE0) /* (A16) spi0_cs0.spi0_cs0 */ AM33XX_IOPAD(0x960, PIN_INPUT_PULLUP | MUX_MODE0) /* (C15) spi0_cs0.spi0_cs1 */ >; }; uart0_pins: pinmux_uart0_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */ AM33XX_IOPAD(0x974, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */ >; }; clkout2_pin: pinmux_clkout2_pin { pinctrl-single,pins = < AM33XX_IOPAD(0x9b4, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* xdma_event_intr1.clkout2 */ >; }; ecap2_pins: backlight_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x99c, MUX_MODE4) /* mcasp0_ahclkr.ecap2_in_pwm2_out */ >; }; cpsw_default: cpsw_default { pinctrl-single,pins = < /* Slave 1 */ AM33XX_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txen.rgmii1_tctl */ AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxdv.rgmii1_rctl */ AM33XX_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd3.rgmii1_td3 */ AM33XX_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd2.rgmii1_td2 */ AM33XX_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_td1 */ AM33XX_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_td0 */ AM33XX_IOPAD(0x92c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txclk.rgmii1_tclk */ AM33XX_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxclk.rgmii1_rclk */ AM33XX_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd3.rgmii1_rd3 */ AM33XX_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd2.rgmii1_rd2 */ AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rd1 */ AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rd0 */ /* Slave 2 */ AM33XX_IOPAD(0x840, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a0.rgmii2_tctl */ AM33XX_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a1.rgmii2_rctl */ AM33XX_IOPAD(0x848, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a2.rgmii2_td3 */ AM33XX_IOPAD(0x84c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a3.rgmii2_td2 */ AM33XX_IOPAD(0x850, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a4.rgmii2_td1 */ AM33XX_IOPAD(0x854, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a5.rgmii2_td0 */ AM33XX_IOPAD(0x858, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a6.rgmii2_tclk */ AM33XX_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a7.rgmii2_rclk */ AM33XX_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a8.rgmii2_rd3 */ AM33XX_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a9.rgmii2_rd2 */ AM33XX_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a10.rgmii2_rd1 */ AM33XX_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a11.rgmii2_rd0 */ >; }; cpsw_sleep: cpsw_sleep { pinctrl-single,pins = < /* Slave 1 reset value */ AM33XX_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x91c, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x920, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x92c, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7) /* Slave 2 reset value*/ AM33XX_IOPAD(0x840, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x848, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x84c, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x850, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x854, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < /* MDIO */ AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < /* MDIO reset value */ AM33XX_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x960, PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */ >; }; mcasp1_pins: mcasp1_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_crs.mcasp1_aclkx */ AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rxerr.mcasp1_fsx */ AM33XX_IOPAD(0x908, PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 */ AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 */ >; }; mcasp1_pins_sleep: mcasp1_pins_sleep { pinctrl-single,pins = < AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x908, PIN_INPUT_PULLDOWN | MUX_MODE7) AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; mmc2_pins: pinmux_mmc2_pins { pinctrl-single,pins = < AM33XX_IOPAD(0x874, PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpio0_31 */ AM33XX_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */ AM33XX_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */ AM33XX_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */ AM33XX_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */ AM33XX_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */ AM33XX_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */ >; }; wl12xx_gpio: pinmux_wl12xx_gpio { pinctrl-single,pins = < AM33XX_IOPAD(0x87c, PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_csn0.gpio1_29 */ >; }; }; &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins>; status = "okay"; }; &i2c0 { pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; status = "okay"; clock-frequency = <400000>; tps: tps@2d { reg = <0x2d>; }; lis331dlh: lis331dlh@18 { compatible = "st,lis331dlh", "st,lis3lv02d"; reg = <0x18>; Vdd-supply = <&lis3_reg>; Vdd_IO-supply = <&lis3_reg>; st,click-single-x; st,click-single-y; st,click-single-z; st,click-thresh-x = <10>; st,click-thresh-y = <10>; st,click-thresh-z = <10>; st,irq1-click; st,irq2-click; st,wakeup-x-lo; st,wakeup-x-hi; st,wakeup-y-lo; st,wakeup-y-hi; st,wakeup-z-lo; st,wakeup-z-hi; st,min-limit-x = <120>; st,min-limit-y = <120>; st,min-limit-z = <140>; st,max-limit-x = <550>; st,max-limit-y = <550>; st,max-limit-z = <750>; }; tlv320aic3106: tlv320aic3106@1b { #sound-dai-cells = <0>; compatible = "ti,tlv320aic3106"; reg = <0x1b>; status = "okay"; /* Regulators */ AVDD-supply = <&vaux2_reg>; IOVDD-supply = <&vaux2_reg>; DRVDD-supply = <&vaux2_reg>; DVDD-supply = <&vbat>; }; }; &spi0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi0_pins_default>; /*sn65hvs882@1 { compatible = "pisosr-gpio"; gpio-controller; #gpio-cells = <2>; load-gpios = <&gpio3 18 GPIO_ACTIVE_LOW>; reg = <1>; spi-max-frequency = <1000000>; spi-cpol; };*/ spi_nor: flash@0 { #address-cells = <1>; #size-cells = <1>; /*compatible = "linux,spidev"; */ compatible = "winbond,w25q64","jedec,spi-nor"; spi-max-frequency = <20000000>; /* 20 mhz */ m25p,fast-read; reg = <0>; partition@0 { label = "u-boot-spl"; reg = <0x0 0x80000>; read-only; }; partition@1 { label = "u-boot"; reg = <0x80000 0x100000>; read-only; }; partition@2 { label = "u-boot-env"; reg = <0x180000 0x20000>; read-only; }; partition@3 { label = "misc"; reg = <0x1A0000 0x660000>; }; }; }; &usb { status = "okay"; }; &usb_ctrl_mod { status = "okay"; }; &usb0_phy { status = "okay"; }; &usb1_phy { status = "okay"; }; &usb0 { status = "okay"; }; &usb1 { status = "okay"; dr_mode = "host"; }; &cppi41dma { status = "okay"; }; &epwmss2 { status = "okay"; ecap2: ecap@48304100 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ecap2_pins>; }; }; #include "tps65910.dtsi" &tps { vcc1-supply = <&vbat>; vcc2-supply = <&vbat>; vcc3-supply = <&vbat>; vcc4-supply = <&vbat>; vcc5-supply = <&vbat>; vcc6-supply = <&vbat>; vcc7-supply = <&vbat>; vccio-supply = <&vbat>; regulators { vrtc_reg: regulator@0 { regulator-always-on; }; vio_reg: regulator@1 { regulator-always-on; }; vdd1_reg: regulator@2 { /* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */ regulator-name = "vdd_mpu"; regulator-min-microvolt = <912500>; regulator-max-microvolt = <1312500>; regulator-boot-on; regulator-always-on; }; vdd2_reg: regulator@3 { /* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */ regulator-name = "vdd_core"; regulator-min-microvolt = <912500>; regulator-max-microvolt = <1150000>; regulator-boot-on; regulator-always-on; }; vdd3_reg: regulator@4 { regulator-always-on; }; vdig1_reg: regulator@5 { regulator-always-on; }; vdig2_reg: regulator@6 { regulator-always-on; }; vpll_reg: regulator@7 { regulator-always-on; }; vdac_reg: regulator@8 { regulator-always-on; }; vaux1_reg: regulator@9 { regulator-always-on; }; vaux2_reg: regulator@10 { regulator-always-on; }; vaux33_reg: regulator@11 { regulator-always-on; }; vmmc_reg: regulator@12 { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-always-on; }; }; }; &mac { pinctrl-names = "default", "sleep"; pinctrl-0 = <&cpsw_default>; pinctrl-1 = <&cpsw_sleep>; dual_emac = <1>; status = "okay"; }; &davinci_mdio { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; status = "okay"; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "rgmii-txid"; dual_emac_res_vlan = <1>; }; &cpsw_emac1 { phy_id = <&davinci_mdio>, <1>; phy-mode = "rgmii-txid"; dual_emac_res_vlan = <2>; }; &mmc1 { status = "okay"; vmmc-supply = <&vmmc_reg>; bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; }; &sham { status = "okay"; }; &aes { status = "okay"; }; &gpio0 { ti,no-reset-on-init; }; &mmc2 { status = "okay"; vmmc-supply = <&wl12xx_vmmc>; ti,non-removable; bus-width = <4>; cap-power-off-card; pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; #address-cells = <1>; #size-cells = <0>; wlcore: wlcore@2 { compatible = "ti,wl1271"; reg = <2>; interrupt-parent = <&gpio0>; interrupts = <31 IRQ_TYPE_LEVEL_HIGH>; /* gpio 31 */ ref-clock-frequency = <38400000>; }; }; &mcasp1 { #sound-dai-cells = <0>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mcasp1_pins>; pinctrl-1 = <&mcasp1_pins_sleep>; status = "okay"; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; /* 4 serializers */ serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 0 0 1 2 >; tx-num-evt = <32>; rx-num-evt = <32>; }; &tscadc { status = "okay"; tsc { ti,wires = <4>; ti,x-plate-resistance = <200>; ti,coordinate-readouts = <5>; ti,wire-config = <0x00 0x11 0x22 0x33>; }; }; &lcdc { status = "okay"; };
Niraj Kumar
I understand you are trying to get your custom DTB file over to your board to run/test it, so you can access the SPI Flash memory device you have. There's a near endless list of ways how to do that, and it really depends on your board/setup. For example you could...
Also you'd want to make sure the new DTB file gets loaded/used during the boot process. If your DTB file simply replaces an existing DTB file (meaning same file name) in the /boot folder, then U-Boot should pick it up automatically. If your DTB file has a different/custom name you'd need to update your U-Boot environment variables (and do an 'env save' afterwards) to specifically load your custom DTB file.
Regards, Andreas
Thanks Sir,
I am running in linux and scp command is used for copy the file .
Sir, Then How we can load the dts file through scp command?
Niraj Kumar
Define "load"?
Regards, Andreas
Thanks sir,
I understood.First we will copy the file into board through scp commad.
Niraj Kumar
Hii sir,
After loading the DTB file, where We execute the spidev_test.c(https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/tools/spi/spidev_test.c).
Niraj Kumar
