TDA4VH-Q1: How can we setup two Phy devices which can be regarded to use as the virtual mac driver's device's MAC address?
Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TMP75, INA226
Hi TI Support  friends,
Here we can setup a example  RTOS Enet driver running for R5F chip and then A-Core Linux OS can identify one of the two network phy devices connected to the SGMII port.  But another phy devices can not be used so the Linux can only one eth1 driver working.
We want to use another phy devices too so we can have two Linux ethX devices.
We attached the debugging records in a cloud storaging link  debug record url
Expecting to get the answer and please help give us a solution.
    We are not able to access the debug records directly, requesting for login.
    Can you please share logs over E2E.
    By default one MAC Port is mapped to A72 as Virtual MAC interface, and one switch interface also mapped to A72.
    Which are by default eth2 (Switch interface) eth3 (MAC Port-1 virtual interface).
    If you want to add more MAC only ports, Please refer to FAQ [How to add/map MAC only Ports to A72]. But, there were some limitations due to resource availability so you can add up to 5Ports.
    If you want all 8 Ports of CPSW9G then you can go for Native Linux Driver, Please refer to FAQ [How to move to Native Linux Driver] and update Port configuration as required in device tree overlays.
    Sudheer
  • Our flag is very simple, please see below:
    Starting kernel ...
    [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [ 0.000000] Linux version 5.10.120-marsiii-1.2-g411a1ad87e (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon May 22 11:32:44 UTC 2023
    [ 0.000000] Machine model: Texas Instruments J784S4 EVM
    [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [ 0.000000] printk: bootconsole [ns16550a0] enabled
    [ 0.000000] efi: UEFI not found.
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@ab000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 51 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@ab100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ae400000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@ae400000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ae500000, size 51 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@ae500000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b1800000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@b1800000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b1900000, size 51 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@b1900000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4c00000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@b4c00000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4d00000, size 51 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@b4d00000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 48 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@b8000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bb000000, size 96 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@bb000000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e1000000, size 336 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e1000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000f6000000, size 8 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@f6000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000f6800000, size 24 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@f6800000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 768 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [ 0.000000] Zone ranges:
    [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
    [ 0.000000] DMA32 empty
    [ 0.000000] Normal [mem 0x0000000100000000-0x0000000fffffefff]
    [ 0.000000] Movable zone start for each node
    [ 0.000000] Early memory node ranges
    [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
    [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000c0ffffff]
    [ 0.000000] node 0: [mem 0x00000000c1000000-0x00000000e0ffffff]
    [ 0.000000] node 0: [mem 0x00000000e1000000-0x00000000f7ffffff]
    [ 0.000000] node 0: [mem 0x00000000f8000000-0x00000000ffffefff]
    [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008afffffff]
    [ 0.000000] node 0: [mem 0x00000008b0000000-0x0000000fffffefff]
    [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
    [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [ 0.000000] cma: Reserved 144 MiB at 0x0000000095800000
    [ 0.000000] psci: probing for conduit method from DT.
    [ 0.000000] psci: PSCIv1.1 detected in firmware.
    [ 0.000000] psci: Using standard PSCI v0.2 function IDs
    [ 0.000000] psci: Trusted OS migration not required
    [ 0.000000] psci: SMC Calling Convention v1.2
    [ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [ 0.000000] Detected PIPT I-cache on CPU0
    [ 0.000000] CPU features: detected: GIC system register CPU interface
    [ 0.000000] CPU features: detected: EL2 vector hardening
    [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [ 0.000000] CPU features: detected: Spectre-BHB
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8257534
    [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=39f37672-02 rw rootfstype=ext4 rootwait
    [ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
    [ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [ 0.000000] Memory: 30432624K/33554424K available (10880K kernel code, 1130K rwdata, 4208K rodata, 1792K init, 431K bss, 2974344K reserved, 147456K cma-reserved)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    [ 0.000000] rcu: RCU event tracing is enabled.
    [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
    [ 0.000000] Trampoline variant of Tasks RCU enabled.
    [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [ 0.000000] GICv3: 960 SPIs implemented
    [ 0.000000] GICv3: 0 Extended SPIs implemented
    [ 0.000000] GICv3: Distributor has no Range Selector support
    [ 0.000000] GICv3: 16 PPIs implemented
    [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [ 0.000000] ITS [mem 0x01820000-0x0182ffff]
    [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8b0800000 (flat, esz 8, psz 64K, shr 0)
    [ 0.000000] ITS: using cache flushing for cmd queue
    [ 0.000000] GICv3: using LPI property table @0x00000008b0050000
    [ 0.000000] GIC: using cache flushing for LPI property table
    [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008b0060000
    [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [ 0.008513] Console: colour dummy device 80x25
    [ 0.013090] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [ 0.023769] pid_max: default: 32768 minimum: 301
    [ 0.028548] LSM: Security Framework initializing
    [ 0.033459] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [ 0.041363] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [ 0.051052] rcu: Hierarchical SRCU implementation.
    [ 0.056257] Platform MSI: msi-controller@1820000 domain created
    [ 0.062533] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [ 0.071914] EFI services will not be available.
    [ 0.077021] smp: Bringing up secondary CPUs ...
    [ 0.082407] Detected PIPT I-cache on CPU1
    [ 0.082430] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [ 0.082443] GICv3: CPU1: using allocated LPI pending table @0x00000008b0070000
    [ 0.082485] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [ 0.083368] Detected PIPT I-cache on CPU2
    [ 0.083393] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [ 0.083408] GICv3: CPU2: using allocated LPI pending table @0x00000008b0080000
    [ 0.083448] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [ 0.084278] Detected PIPT I-cache on CPU3
    [ 0.084305] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [ 0.084319] GICv3: CPU3: using allocated LPI pending table @0x00000008b0090000
    [ 0.084360] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [ 0.085193] Detected PIPT I-cache on CPU4
    [ 0.085220] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [ 0.085235] GICv3: CPU4: using allocated LPI pending table @0x00000008b00a0000
    [ 0.085277] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [ 0.086149] Detected PIPT I-cache on CPU5
    [ 0.086180] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [ 0.086194] GICv3: CPU5: using allocated LPI pending table @0x00000008b00b0000
    [ 0.086235] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [ 0.087076] Detected PIPT I-cache on CPU6
    [ 0.087106] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [ 0.087121] GICv3: CPU6: using allocated LPI pending table @0x00000008b00c0000
    [ 0.087163] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [ 0.087988] Detected PIPT I-cache on CPU7
    [ 0.088020] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [ 0.088036] GICv3: CPU7: using allocated LPI pending table @0x00000008b00d0000
    [ 0.088078] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [ 0.088212] smp: Brought up 1 node, 8 CPUs
    [ 0.269325] SMP: Total of 8 processors activated.
    [ 0.274145] CPU features: detected: 32-bit EL0 Support
    [ 0.279416] CPU features: detected: CRC32 instructions
    [ 0.295440] CPU: All CPU(s) started at EL2
    [ 0.299676] alternatives: patching kernel code
    [ 0.305045] devtmpfs: initialized
    [ 0.315542] KASLR disabled due to lack of seed
    [ 0.320227] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.330206] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [ 0.338955] pinctrl core: initialized pinctrl subsystem
    [ 0.344647] DMI not present or invalid.
    [ 0.348963] NET: Registered protocol family 16
    [ 0.354779] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [ 0.362901] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [ 0.371747] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [ 0.380308] thermal_sys: Registered thermal governor 'step_wise'
    [ 0.380313] thermal_sys: Registered thermal governor 'power_allocator'
    [ 0.387019] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [ 0.400812] ASID allocator initialised with 65536 entries
    [ 0.429870] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [ 0.436742] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [ 0.443600] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [ 0.450455] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [ 0.458909] cryptd: max_cpu_qlen set to 1000
    [ 0.467351] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [ 0.476538]
    [ 0.491374] iommu: Default domain type: Translated
    [ 0.496614] SCSI subsystem initialized
    [ 0.500805] mc: Linux media interface: v0.10
    [ 0.505214] videodev: Linux video capture interface: v2.00
    [ 0.510898] pps_core: LinuxPPS API ver. 1 registered
    [ 0.515981] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.525338] PTP clock support registered
    [ 0.529376] EDAC MC: Ver: 3.0.0
    [ 0.533853] FPGA manager framework
    [ 0.537434] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.544366] clocksource: Switched to clocksource arch_sys_counter
    [ 0.550778] VFS: Disk quotas dquot_6.6.0
    [ 0.554851] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [ 0.569355] Carveout Heap: Exported 512 MiB at 0x00000000c1000000
    [ 0.575699] NET: Registered protocol family 2
    [ 0.580835] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [ 0.592003] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [ 0.601158] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [ 0.610259] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [ 0.618279] TCP: Hash tables configured (established 262144 bind 65536)
    [ 0.625208] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [ 0.632591] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [ 0.640559] NET: Registered protocol family 1
    [ 0.645663] RPC: Registered named UNIX socket transport module.
    [ 0.651741] RPC: Registered udp transport module.
    [ 0.656553] RPC: Registered tcp transport module.
    [ 0.661362] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.667954] PCI: CLS 0 bytes, default 64
    [ 0.672992] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [ 0.686678] Initialise system trusted keyrings
    [ 0.691445] workingset: timestamp_bits=46 max_order=23 bucket_order=0
    [ 0.700636] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.707070] NFS: Registering the id_resolver key type
    [ 0.712289] Key type id_resolver registered
    [ 0.716582] Key type id_legacy registered
    [ 0.720739] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [ 0.727602] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [ 0.735315] 9p: Installing v9fs 9p2000 file system support
    [ 0.760692] Key type asymmetric registered
    [ 0.764897] Asymmetric key parser 'x509' registered
    [ 0.769921] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [ 0.777489] io scheduler mq-deadline registered
    [ 0.782121] io scheduler kyber registered
    [ 0.788921] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [ 0.795142] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [ 0.806401] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.812772] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.823376] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [ 0.844452] brd: module loaded
    [ 0.854106] loop: module loaded
    [ 0.857784] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
    [ 0.865731] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 5.10.120-marsiii-1.2-g411a1ad87e #1
    [ 0.874087] Hardware name: Texas Instruments J784S4 EVM (DT)
    [ 0.879865] Call trace:
    [ 0.882365] dump_backtrace+0x0/0x1a0
    [ 0.886103] show_stack+0x18/0x68
    [ 0.889485] dump_stack+0xd0/0x12c
    [ 0.892956] sysfs_warn_dup+0x60/0x80
    [ 0.896691] sysfs_create_dir_ns+0xe0/0xf8
    [ 0.900872] kobject_add_internal+0x98/0x288
    [ 0.905229] kobject_add+0x94/0x100
    [ 0.908787] device_add+0xe0/0x740
    [ 0.912258] platform_device_add+0x100/0x238
    [ 0.916617] platform_device_register_full+0xcc/0x150
    [ 0.921775] dma_buf_phys_init+0x6c/0x9c
    [ 0.925777] do_one_initcall+0x54/0x1b8
    [ 0.929692] kernel_init_freeable+0x220/0x2a0
    [ 0.934139] kernel_init+0x14/0x114
    [ 0.937698] ret_from_fork+0x10/0x34
    [ 0.941364] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
    [ 0.955182] megasas: 07.714.04.00-rc1
    [ 0.962772] tun: Universal TUN/TAP device driver, 1.6
    [ 0.968452] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [ 0.974881] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [ 0.980985] sky2: driver version 1.30
    [ 0.985937] VFIO - User Level meta-driver version: 0.3
    [ 0.992269] i2c /dev entries driver
    [ 0.997837] sdhci: Secure Digital Host Controller Interface driver
    [ 1.004168] sdhci: Copyright(c) Pierre Ossman
    [ 1.009087] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 1.016352] ledtrig-cpu: registered to indicate activity on CPUs
    [ 1.022883] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [ 1.031008] optee: probing for conduit method.
    [ 1.035591] optee: revision 3.12 (3d47a131)
    [ 1.035977] optee: initialized driver
    [ 1.044583] mmio-mux 104000.scm-conf:mux-controller0: mux-reg-masks property missing or invalid: -22
    [ 1.053963] mmio-mux: probe of 104000.scm-conf:mux-controller0 failed with error -22
    [ 1.063358] NET: Registered protocol family 17
    [ 1.068012] 9pnet: Installing 9P2000 support
    [ 1.072442] Key type dns_resolver registered
    [ 1.076957] Loading compiled-in X.509 certificates
    [ 1.087304] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 1.093785] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 1.105165] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.5--v08.04.05 (Jolly Jellyfi')
    [ 1.163301] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [ 1.170073] lm75 1-0048: supply vs not found, using dummy regulator
    [ 1.200750] hwmon hwmon0: temp1_input not attached to any thermal zone
    [ 1.207448] lm75 1-0048: hwmon0: sensor 'tmp75'
    [ 1.212390] lm75 1-0049: supply vs not found, using dummy regulator
    [ 1.219334] hwmon hwmon1: temp1_input not attached to any thermal zone
    [ 1.226037] lm75 1-0049: hwmon1: sensor 'tmp75'
    [ 1.230931] lm75 1-004a: supply vs not found, using dummy regulator
    [ 1.237878] hwmon hwmon2: temp1_input not attached to any thermal zone
    [ 1.244583] lm75 1-004a: hwmon2: sensor 'tmp75'
    [ 1.249508] lm75 1-004b: supply vs not found, using dummy regulator
    [ 1.256485] hwmon hwmon3: temp1_input not attached to any thermal zone
    [ 1.263185] lm75 1-004b: hwmon3: sensor 'tmp75'
    [ 1.268078] lm75 1-004c: supply vs not found, using dummy regulator
    [ 1.275030] hwmon hwmon4: temp1_input not attached to any thermal zone
    [ 1.281731] lm75 1-004c: hwmon4: sensor 'tmp75'
    [ 1.286626] lm75 1-004d: supply vs not found, using dummy regulator
    [ 1.293564] hwmon hwmon5: temp1_input not attached to any thermal zone
    [ 1.300266] lm75 1-004d: hwmon5: sensor 'tmp75'
    [ 1.305534] ina2xx 1-0040: power monitor ina226 (Rshunt = 3000 uOhm)
    [ 1.312318] at24 1-0050: supply vcc not found, using dummy regulator
    [ 1.319269] at24 1-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [ 1.326719] pca953x 1-0074: supply vcc not found, using dummy regulator
    [ 1.333596] pca953x 1-0074: using no AI
    [ 1.338381] pca953x 1-0075: supply vcc not found, using dummy regulator
    [ 1.345258] pca953x 1-0075: using no AI
    [ 1.349876] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 400 kHz
    [ 1.357398] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [ 1.366048] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [ 1.375405] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [ 1.384134] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [ 1.400012] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [ 1.409923] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [ 1.416692] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [ 1.426379] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [ 1.436550] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [ 1.443317] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [ 1.451448] 42300000.serial: ttyS0 at MMIO 0x42300000 (irq = 15, base_baud = 6000000) is a 8250
    [ 1.461419] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 16, base_baud = 6000000) is a 8250
    [ 1.471337] 2820000.serial: ttyS3 at MMIO 0x2820000 (irq = 29, base_baud = 3000000) is a 8250
    [ 1.481089] 2860000.serial: ttyS4 at MMIO 0x2860000 (irq = 30, base_baud = 3000000) is a 8250
    [ 1.490781] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 31, base_baud = 3000000) is a 8250
    [ 1.499566] printk: console [ttyS2] enabled
    [ 1.508017] printk: bootconsole [ns16550a0] disabled
    [ 1.519025] 2890000.serial: ttyS5 at MMIO 0x2890000 (irq = 32, base_baud = 3000000) is a 8250
    [ 1.533977] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [ 1.544504] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [ 1.554675] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [ 1.564923] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [ 1.576173] scsi host0: ufshcd
    [ 1.596477] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [ 1.624379] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [ 1.630863] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [ 1.632270] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [ 1.643905] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [ 1.650453] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [ 1.664182] scsi 0:0:0:49488: Well-known LUN WDC SDINDDH6-32G 1746 PQ: 0 ANSI: 6
    [ 1.675821] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
    [ 1.685717] scsi 0:0:0:49476: Well-known LUN WDC SDINDDH6-32G 1746 PQ: 0 ANSI: 6
    [ 1.701132] scsi 0:0:0:49456: Well-known LUN WDC SDINDDH6-32G 1746 PQ: 0 ANSI: 6
    [ 1.712200] scsi 0:0:0:0: Direct-Access WDC SDINDDH6-32G 1746 PQ: 0 ANSI: 6
    [ 1.721968] sd 0:0:0:0: Power-on or device reset occurred
    [ 1.729253] scsi 0:0:0:1: Direct-Access WDC SDINDDH6-32G 1746 PQ: 0 ANSI: 6
    [ 1.729749] sd 0:0:0:0: [sda] 7808000 4096-byte logical blocks: (32.0 GB/29.8 GiB)
    [ 1.739243] sd 0:0:0:1: Power-on or device reset occurred
    [ 1.739599] scsi 0:0:0:2: Direct-Access WDC SDINDDH6-32G 1746 PQ: 0 ANSI: 6
    [ 1.741595] sd 0:0:0:2: Power-on or device reset occurred
    [ 1.743414] sd 0:0:0:2: [sdc] 1024 4096-byte logical blocks: (4.19 MB/4.00 MiB)
    [ 1.743879] sd 0:0:0:2: [sdc] Write Protect is off
    [ 1.744402] sd 0:0:0:2: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [ 1.745204] sd 0:0:0:0: [sda] Write Protect is off
    [ 1.752830] sd 0:0:0:1: [sdb] 1024 4096-byte logical blocks: (4.19 MB/4.00 MiB)
    [ 1.757551] sd 0:0:0:2: [sdc] Attached SCSI disk
    [ 1.764411] sd 0:0:0:1: [sdb] Write Protect is off
    [ 1.771637] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [ 1.792985] mmc0: CQHCI version 5.10
    [ 1.806041] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [ 1.820167] sd 0:0:0:0: [sda] Attached SCSI disk
    [ 1.820221] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [ 1.820808] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [ 1.821320] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [ 1.821783] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [ 1.822251] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [ 1.822704] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [ 1.823621] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [ 1.826091] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [ 1.835567] spi-nor spi3.0: s28hs512t (65536 Kbytes)
    [ 1.844807] sd 0:0:0:1: [sdb] Attached SCSI disk
    [ 1.850878] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [ 1.852980] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [ 1.911149] Creating 7 MTD partitions on "47040000.spi.0":
    [ 1.916631] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [ 1.923111] 0x000000080000-0x000000280000 : "ospi.tispl"
    [ 1.929385] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [ 1.934973] mmc0: Command Queue Engine enabled
    [ 1.935812] 0x000000680000-0x0000006c0000 : "ospi.env"
    [ 1.939449] mmc0: new high speed MMC card at address 0001
    [ 1.945544] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [ 1.950410] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
    [ 1.956780] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [ 1.960471] mmcblk0boot0: mmc0:0001 G1M15M partition 1 31.5 MiB
    [ 1.966748] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [ 1.971751] mmcblk0boot1: mmc0:0001 G1M15M partition 2 31.5 MiB
    [ 1.983464] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (237:0)
    [ 2.020376] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [ 2.028269] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [ 2.035061] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [ 2.048644] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [ 2.055554] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [ 2.062788] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [ 2.069366] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [ 2.080742] mmc1: CQHCI version 5.10
    [ 2.081733] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [ 2.091585] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [ 2.099325] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
    [ 2.106693] debugfs: Directory 'pd:334' with parent 'pm_genpd' already present!
    [ 2.114048] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [ 2.121384] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [ 2.135579] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [ 2.138439] ALSA device list:
    [ 2.146052] No soundcards found.
    [ 2.149824] Waiting for root device PARTUUID=39f37672-02...
    [ 2.178385] mmc1: new high speed SDHC card at address aaaa
    [ 2.184406] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
    [ 2.190303] mmcblk1: p1 p2
    [ 2.244599] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 2.252740] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [ 2.266273] devtmpfs: mounted
    [ 2.270012] Freeing unused kernel memory: 1792K
    [ 2.274651] Run /sbin/init as init process
    [ 2.618002] systemd[1]: System time before build time, advancing clock.
    [ 2.702657] NET: Registered protocol family 10
    [ 2.707951] Segment Routing with IPv6
    [ 2.750067] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [ 2.772218] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [ 2.813600] systemd[1]: Set hostname to <j784s4-evm>.
    [ 3.132572] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock 仺 /run/docker.sock; please update the unit file accordingly.
    [ 3.236401] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.243220] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [ 3.255575] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [ 3.267643] systemd[1]: Created slice system-getty.slice.
    [ OK ] Created slice system-getty.slice.
    [ 3.288566] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.296968] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ OK ] Created slice system-serial\x2dgetty.slice.
    [ 3.320528] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.328763] systemd[1]: Created slice User and Session Slice.
    [ OK ] Created slice User and Session Slice.
    [ 3.348818] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ OK ] Started Dispatch Password 乧ts to Console Directory Watch.
    [ 3.372746] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ OK ] Started Forward Password R乧uests to Wall Directory Watch.
    [ 3.396628] systemd[1]: Reached target Paths.
    [ OK ] Reached target Paths.
    [ 3.416575] systemd[1]: Reached target Remote File Systems.
    [ OK ] Reached target Remote File Systems.
    [ 3.436562] systemd[1]: Reached target Slices.
    [ OK ] Reached target Slices.
    [ 3.456571] systemd[1]: Reached target Swap.
    [ OK ] Reached target Swap.
    [ 3.486757] systemd[1]: Listening on RPCbind Server Activation Socket.
    [ OK ] Listening on RPCbind Server Activation Socket.
    [ 3.508574] systemd[1]: Reached target RPC Port Mapper.
    [ OK ] Reached target RPC Port Mapper.
    [ 3.531898] systemd[1]: Listening on Process Core Dump Socket.
    [ OK ] Listening on Process Core Dump Socket.
    [ 3.552831] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [ OK ] Listening on initctl Compatibility Named Pipe.
    [ 3.591208] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [ 3.599858] systemd[1]: Listening on Journal Socket (/dev/log).
    [ OK ] Listening on Journal Socket (/dev/log).
    [ 3.621108] systemd[1]: Listening on Journal Socket.
    [ OK ] Listening on Journal Socket.
    [ 3.637242] systemd[1]: Listening on Network Service Netlink Socket.
    [ OK ] Listening on Network Service Netlink Socket.
    [ 3.661034] systemd[1]: Listening on udev Control Socket.
    [ OK ] Listening on udev Control Socket.
    [ 3.680865] systemd[1]: Listening on udev Kernel Socket.
    [ OK ] Listening on udev Kernel Socket.
    [ 3.705712] systemd[1]: Mounting Huge Pages File System...
    [ 3.725433] systemd[1]: Mounting POSIX Message Queue File System...
    [ 3.753388] systemd[1]: Mounting Kernel Debug File System...
    [ 3.776139] systemd[1]: Mounting Temporary Directory (/tmp)...
    [ 3.797702] systemd[1]: Starting Create list of static device nodes for the current kernel...
    Starting Create list of st乧odes for the current kernel...
    [ 3.825217] systemd[1]: Starting Start psplash boot splash screen...
    [ 3.859595] systemd[1]: Starting RPC Bind...
    [ 3.872628] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [ 3.890259] systemd[1]: Starting Journal Service...
    [ 3.924275] systemd[1]: Starting Load Kernel Modules...
    [ 3.949258] cryptodev: loading out-of-tree module taints kernel.
    [ 3.950103] systemd[1]: Starting Remount Root and Kernel File Systems...
    Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
    [0m...
    [ 3.973633] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [ 3.990680] systemd[1]: Starting udev Coldplug all Devices...
    [ 3.996722] simple_module_init::++++++++++
    Starting udev Coldplug all Devices...[ 4.001470] simple_module_probe::++++++++++
    [ 4.010501] major = 236
    [ 4.013240] minor = 0
    [ 4.015938] simple_module_probe::----------
    [ 4.021749] simple_init_module OK!
    [ 4.025184] simple_module_init::----------
    [ 4.027821] systemd[1]: Started RPC Bind.
    [ OK ] Started RPC Bind.
    [ 4.049573] systemd[1]: Mounted Huge Pages File System.
    [ OK ] Mounted Huge Pages File System.
    [ 4.077005] systemd[1]: Started Journal Service.
    [ OK ] Started Journal Service.
    [ OK ] Mounted POSIX Message Queue File System.
    [ OK ] Mounted Kernel Debug File System.
    [ OK ] Mounted Temporary Directory (/tmp).
    [ OK ] Started Create list of sta乧 nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star乧progress communication helper.
    [ OK ] Started Load Kernel Modules.
    [ OK ] Started Remount Root and Kernel File Systems.
    [ 4.268251] urandom_read_iter: 38 callbacks suppressed
    [ 4.268257] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [ 4.270329] random: systemd: uninitialized urandom read (16 bytes read)
    Mounting Kernel Configuration File System.[ 4.295120] random: systemd-journal: uninitialized urandom read (16 bytes read)
    Starting Flush Journal to Persistent Storage...
    [ 4.341456] systemd-journald[217]: Received client request to flush runtime journal.
    Starting Apply Kernel Variables...
    Starting Create Static Device Nodes in /dev...
    [ OK ] Mounted Kernel Configuration File System.
    [ OK ] Started Flush Journal to Persistent Storage.
    [ OK ] Started Apply Kernel Variables.
    [ OK ] Started Create Static Device Nodes in /dev.
    [ OK ] Reached target Local File Systems (Pre).
    Mounting /media/ram...
    Mounting /var/volatile...
    Starting udev Kernel Device Manager...
    [ OK ] Mounted /media/ram.
    [ OK ] Mounted /var/volatile.
    Starting Load/Save Random Seed...
    [ OK ] Reached target Local File Systems.
    Starting Create Volatile Files and Directories...
    [ OK ] Started Create Volatile Files and Directories.
    [ OK ] Started udev Coldplug all Devices.
    [FAILED] Failed to start Network Time Synchronization.
    See 'systemctl status systemd-timesyncd.service' for details.
    [ OK ] Reached target System Time Set.
    [ OK ] Reached target System Time Synchronized.
    Starting udev Wait for Complete Device Initialization...
    Starting Update UTMP about System Boot/Shutdown...
    [ OK ] Started udev Kernel Device Manager.
    [ OK ] Stopped Network Time Synchronization.
    [ OK ] Started Update UTMP about System Bo[ 5.051859] CAN device driver interface
    ot/Shutdown.
    [ 5.092506] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
    [FAILED] Failed to start Network Time Sync[ 5.127534] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@ab000000
    hronization.
    [ 5.149811] m_can_platform 40568000.can: m_can device registered (irq=21, version=32)
    [ 5.157981] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [ 5.168003] remoteproc remoteproc0: 64800000.dsp is available
    [ 5.170170] m_can_platform 2721000.can: m_can device registered (irq=39, version=32)
    [ 5.177761] remoteproc remoteproc0: attaching to 64800000.dsp
    [ OK ] Stopped Network Time Synchronizatio[ 5.192254] remoteproc remoteproc0: unsupported resource 65538
    n.
    [ 5.197747] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.203240] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [ 5.216189] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@ab000000
    [ 5.226609] wave5: module is from the staging directory, the quality is unknown, you have been warned.
    [ 5.243801] wave5: module is from the staging directory, the quality is unknown, you have been warned.
    [ 5.248151] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.251677] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 5.251759] remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [ 5.251767] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [ 5.256572] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [ 5.273197] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@ae400000
    [ 5.280133] vdec 4210000.video-codec: sram daddr: 0x70020000, size: 0x1f800
    [ 5.302942] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.314858] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [ 5.324160] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.326916] urandom_read_iter: 35 callbacks suppressed
    [ 5.326922] random: systemd: uninitialized urandom read (16 bytes read)
    [ 5.342949] random: systemd: uninitialized urandom read (16 bytes read)
    [ 5.343716] remoteproc remoteproc1: 65800000.dsp is available
    [ 5.354743] random: systemd: uninitialized urandom read (16 bytes read)
    [ 5.360768] remoteproc remoteproc1: attaching to 65800000.dsp
    [ 5.368697] remoteproc remoteproc1: unsupported resource 65538
    [ 5.368818] PVR_K: 266: Read BVNC 36.53.104.796 from HW device registers
    [ 5.369043] m_can_platform 2751000.can: m_can device registered (irq=41, version=32)
    [ 5.374771] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [ 5.386556] PVR_K: 266: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [ 5.389612] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@ae400000
    [ 5.392870] vdec 4210000.video-codec: enum product_id : 00000000
    [ 5.392880] vdec 4210000.video-codec: fw_version : 00000000(r284060)
    [ 5.399726] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [ 5.405231] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 5.440093] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [ 5.440841] m_can_platform 27a1000.can: m_can device registered (irq=43, version=32)
    [ OK ] Stopped Network Time Synchronizatio[ 5.441515] remoteproc1#vdev0buffer: registered virtio1 (type 7)
    n.
    [ 5.441524] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [ 5.456600] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@b1800000
    [ 5.467357] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.480415] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
    [ 5.497455] remoteproc remoteproc2: 66800000.dsp is available
    [ 5.498476] vdec 4220000.video-codec: sram daddr: 0x7003f800, size: 0x1f800
    [FAILED] Failed to start Network Time Sync[ 5.503425] remoteproc remoteproc2: attaching to 66800000.dsp
    [ 5.510416] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    hronization.
    [ 5.521826] remoteproc remoteproc2: unsupported resource 65538
    [ 5.535380] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
    [ 5.547741] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71_2-dma-memory@b1800000
    [ 5.553432] vdec 4220000.video-codec: enum product_id : 00000000
    [ 5.558317] virtio_rpmsg_bus virtio2: rpmsg host is online
    [ 5.565466] vdec 4220000.video-codec: fw_version : 00000000(r284060)
    [ 5.569096] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [ 5.583042] remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [ 5.589297] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
    [ 5.597035] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.605012] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@b4c00000
    [ 5.615036] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.623034] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
    [ 5.630184] remoteproc remoteproc3: 67800000.dsp is available
    [ 5.636382] remoteproc remoteproc3: attaching to 67800000.dsp
    [ 5.636495] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.644018] remoteproc remoteproc3: unsupported resource 65538
    [ 5.646750] m_can_platform 27c1000.can: m_can device registered (irq=45, version=32)
    [ 5.651153] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.654145] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
    [ 5.665282] m_can_platform 26a1000.can: m_can device registered (irq=47, version=32)
    [ 5.667799] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71_3-dma-memory@b4c00000
    [ 5.683394] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.692295] virtio_rpmsg_bus virtio3: rpmsg host is online
    [ 5.700933] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [ 5.703605] remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [ 5.717493] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
    [ 5.725186] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.733480] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.877965] platform 5c00000.r5f: configured R5F for IPC-only mode
    [ 5.884639] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [ 5.901154] remoteproc remoteproc4: 5c00000.r5f is available
    [ 5.907042] remoteproc remoteproc4: attaching to 5c00000.r5f
    [ 5.913058] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [ 5.920462] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [ 5.930512] virtio_rpmsg_bus virtio4: rpmsg host is online
    [ 5.942792] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 5.948851] remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [ 5.952899] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [ 5.955039] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
    [ 5.977538] platform 5d00000.r5f: configured R5F for IPC-only mode
    [ 5.990202] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [ 6.002137] remoteproc remoteproc5: 5d00000.r5f is available
    [ 6.007930] remoteproc remoteproc5: attaching to 5d00000.r5f
    [ 6.013942] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [ 6.020679] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [ 6.035754] virtio_rpmsg_bus virtio5: rpmsg host is online
    [ 6.043338] remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [ 6.050901] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
    [ 6.057573] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [ 6.058503] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.074040] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.074760] platform 5e00000.r5f: configured R5F for IPC-only mode
    [ 6.086709] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [ 6.097442] remoteproc remoteproc6: 5e00000.r5f is available
    [ 6.103302] remoteproc remoteproc6: attaching to 5e00000.r5f
    [ 6.114431] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [ 6.121174] remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [ 6.131184] virtio_rpmsg_bus virtio6: rpmsg host is online
    [ 6.138153] remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [ 6.146179] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.153125] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [ 6.155771] remoteproc remoteproc6: remote processor 5e00000.r5f is now attached
    [ 6.174842] platform 5f00000.r5f: configured R5F for IPC-only mode
    [ 6.181433] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [ 6.192808] remoteproc remoteproc7: 5f00000.r5f is available
    [ 6.198700] remoteproc remoteproc7: attaching to 5f00000.r5f
    [ 6.204815] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [ 6.211906] remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [ 6.222096] virtio_rpmsg_bus virtio7: rpmsg host is online
    [ 6.231123] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.237356] remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [ 6.243610] remoteproc remoteproc7: remote processor 5f00000.r5f is now attached
    [ 6.251200] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [ 6.263538] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.282896] platform 5900000.r5f: configured R5F for IPC-only mode
    [ 6.311447] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [ 6.312425] random: crng init done
    [ 6.323936] random: 35 urandom warning(s) missed due to ratelimiting
    [ 6.354171] remoteproc remoteproc8: 5900000.r5f is available
    [ 6.359961] remoteproc remoteproc8: attaching to 5900000.r5f
    [ 6.365861] platform 5900000.r5f: R5F core initialized in IPC-only mode
    [ 6.372515] remoteproc8#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [ 6.398272] virtio_rpmsg_bus virtio8: rpmsg host is online
    [ 6.406383] remoteproc8#vdev0buffer: registered virtio8 (type 7)
    [ 6.407043] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.412703] remoteproc remoteproc8: remote processor 5900000.r5f is now attached
    [ 6.420179] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
    [ 6.433258] platform 5a00000.r5f: configured R5F for IPC-only mode
    [ OK ] Started Load/Save Random Seed.
    [ 6.451808] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
    [ 6.487621] remoteproc remoteproc9: 5a00000.r5f is available
    [ 6.509760] remoteproc remoteproc9: attaching to 5a00000.r5f
    [ 6.515942] platform 5a00000.r5f: R5F core initialized in IPC-only mode
    [ 6.522658] remoteproc9#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
    [ 6.532754] virtio_rpmsg_bus virtio9: rpmsg host is online
    [ 6.546085] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.554965] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
    [ 6.557258] remoteproc9#vdev0buffer: registered virtio9 (type 7)
    [ 6.562768] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
    [ 6.568892] remoteproc remoteproc9: remote processor 5a00000.r5f is now attached
    [ 6.576138] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.592617] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.596587] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [ 6.606097] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.613855] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [ 6.621242] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.629040] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [ 6.636493] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.644211] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [ 6.651582] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.659398] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [ 6.666792] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [ 6.674932] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [ 6.682341] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.690095] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [ 6.697525] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.705532] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [ 6.713043] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
    [ 6.720608] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.728504] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
    [ 6.735834] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
    [ 6.747896] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [ 6.758889] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 31/May/2023 SHA:f2e96942
    [ 6.771670] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.778575] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [ 6.805640] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [ 6.813678] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:114 tx_psil_dst_id:4A00 mac_only:0
    [ 6.826341] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [ 6.840639] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.884750] usbcore: registered new interface driver usbfs
    [ 6.890468] usbcore: registered new interface driver hub
    [ 6.896003] usbcore: registered new device driver usb
    [ 6.899007] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.911888] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.920725] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 6.989756] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 7.130421] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [ 7.141799] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [ 7.152434] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [ 7.168845] xhci-hcd xhci-hcd.2.auto: irq 468, io mem 0x06010000
    [ 7.175545] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [ 7.184228] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 7.191704] usb usb1: Product: xHCI Host Controller
    [ 7.196621] usb usb1: Manufacturer: Linux 5.10.120-marsiii-1.2-g411a1ad87e xhci-hcd
    [ 7.204326] usb usb1: SerialNumber: xhci-hcd.2.auto
    [ 7.209727] hub 1-0:1.0: USB hub found
    [ 7.213603] hub 1-0:1.0: 1 port detected
    [ 7.218103] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 7.219455] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [ 7.225787] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 7.229467] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [ 7.242983] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [ 7.249608] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 7.257851] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [ 7.266156] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 7.273403] usb usb2: Product: xHCI Host Controller
    [ 7.278296] usb usb2: Manufacturer: Linux 5.10.120-marsiii-1.2-g411a1ad87e xhci-hcd
    [ 7.285963] usb usb2: SerialNumber: xhci-hcd.2.auto
    [ 7.291335] hub 2-0:1.0: USB hub found
    [ 7.295172] hub 2-0:1.0: 1 port detected
    [ 7.300774] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ 7.308517] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    [ OK ] Created slice system-systemd\x2dfsck.slice.
    [ OK ] Found device /dev/mmcblk1p1.
    [ OK ] Started udev Wait for Complete Device Initialization.
    [ OK ] Started Hardware RNG Entropy Gatherer Daemon.
    [ OK ] Reached target System Initialization.
    [ OK ] Started Daily rotation of log files.
    [ OK ] Started Daily Cleanup of Temporary Directories.
    [ OK ] Reached target Timers.
    [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [ OK ] Listening on D-Bus System Message Bus Socket.
    Starting Docker Socket for the API.
    [ OK ] Listening on dropbear.socket.
    Starting Reboot and dump vmcore via kexec...
    Starting File System Check on /dev/mmcblk1p1...
    [ OK ] Listening on Docker Socket for the API.
    [ OK ] Started Reboot and dump vmcore via kexec.
    [ OK ] Reached target Sockets.
    [ OK ] Reached target Basic System.
    [ OK ] Started Job spooling tools.
    [ OK ] Started Periodic Command Scheduler.
    [ OK ] Started D-Bus System Message Bus.
    Starting Print notice about GPLv3 packages...
    Starting IPv6 Packet Filtering Framework...
    Starting IPv4 Packet Filtering Framework...
    [ OK ] Started irqbalance daemon.
    Starting Telephony service...
    Starting rc.pvr.service...
    [FAILED] Failed to start Login Service.
    See 'systemctl status systemd-logind.service' for details.
    [ OK ] Started TEE Supplicant.
    [ OK ] Stopped Login Service.
    [ OK ] Started File System Check on /dev/mmcblk1p1.
    [ OK ] Started IPv6 Packet Filtering Framework.
    [ OK ] Started IPv4 Packet Filtering Framework.
    [ OK ] Started Telephony service.
    [ OK ] Reached target Network (Pre).
    Mounting /run/media/mmcblk1p1...
    Starting Network Service...
    [ OK ] Started rc.pvr.service.
    Starting weston.service...
    [ OK ] Listening on Load/Save RF 乧itch Status /dev/rfkill Watch.
    [ 8.427297] Bluetooth: Core ver 2.22
    [ 8.431032] NET: Registered protocol family 31
    [ 8.435647] Bluetooth: HCI device and connection manager initialized
    [ 8.442066] Bluetooth: HCI socket layer initialized
    [ OK ] Mounted /run/media/mmcblk1p1.
    [ 8.447328] Bluetooth: L2CAP socket layer initialized
    [ 8.457680] Bluetooth: SCO socket layer initialized
    [ OK ] Started Network Service.
    Starting Wait for Network to be Configured...
    [FAILED] Failed to start Network Name Reso[ 8.508444] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    lution.
    See 'systemctl status systemd-resolved.service' for details.
    [ OK ] Reached target Network.
    [ OK ] Reached target Host and Network Name Lookups.
    Starting Avahi mDNS/DNS-SD Stack...
    Starting Enable and configure wl18xx bluetooth stack...
    [ OK ] Started 8.548866] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on slave 1
    ;39mNFS status monitor for NFSv2/3 locking..
    Starting /etc/rc.local Compatibility...
    Starting Simple Network Ma乧ent Protocol (SNMP) Daemon....
    Starting Permit User Sessions...
    [ OK ] Started Enable and configure wl18xx bluetooth stack.
    [ OK ] Stopped Network Name Resolution.
    [FAILED] Failed to start Network Name Reso[ 8.603075] export_store: invalid GPIO 272
    lution.
    [ OK ] Started Permit User Sess[ 8.615193] export_store: invalid GPIO 282
    ions.
    [ OK ] Started Avahi mDNS/DNS-SD Stack.
    [FAILED] Failed to start Network Name Resolution.
    [FAILED] Failed to s[ 8.657064] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [ OK ] Started Simple Network Man乧ement Protocol (SNMP) Daemon..
    [ OK ] Started /etc/rc.local Compatibility.
    [ OK ] Started Getty on tty1.
    [ OK ] Started Serial Getty on ttyS2.
    [ OK ] Reached target Login Prompts.
    Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [ 10.655673] export_store: invalid GPIO 311
    NOTICE: This file system contains the following GPLv3 packages:
    autoconf
    bash-dev
    bash
    bc
    binutils
    cifs-utils
    coreutils-stdbuf
    coreutils
    cpio
    cpp-symlinks
    cpp
    dosfstools
    elfutils
    g++-symlinks
    g++
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbserver
    gettext
    glmark2
    gstreamer1.0-libav-dev
    gstreamer1.0-libav
    gzip
    less
    libasm1
    libbfd
    libdw1
    libelf1
    libgdbm-compat4
    libgdbm-dev
    libgdbm6
    libgettextlib
    libgettextsrc
    libgmp-dev
    libgmp10
    libgmpxx4
    libidn2-0
    libidn2-dev
    libmpc3
    libmpfr6
    libreadline-dev
    libreadline8
    libunistring-dev
    libunistring2
    m4-dev
    m4
    make
    nettle-dev
    nettle
    parted
    python3-docutils
    python3-rfc3987
    python3-strict-rfc3339
    tar
    which
    zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution. This can be done using
    the opkg remove command. i.e.:
    opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
    will be notified of the dependent packages. You should
    use the --force-removal-of-dependent-packages option to
    also remove the dependent packages as well
    [ OK ] Started Print notice about GPLv3 packages.
    [ OK ] Started weston.service.
    Starting telnetd.service...
    [ OK ] Started telnetd.service.
    _____ _____ _ _
    | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    | | _| .'| . | . | | __| _| . | | | -_| _| _|
    |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    |___| |___|
    Arago Project http://arago-project.org j784s4-evm ttyS2
    Arago 2021.09 j784s4-evm ttyS2
    j784s4-evm login: root
    root@j784s4-evm:~# ifconfig
    eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 metric 1
    inet6 fe80::72ff:76ff:fe1d:92c1 prefixlen 64 scopeid 0x20<link>
    ether 70:ff:76:1d:92:c1 txqueuelen 1000 (Ethernet)
    RX packets 0 bytes 0 (0.0 B)
    RX errors 0 dropped 0 overruns 0 frame 0
    TX packets 18 bytes 3288 (3.2 KiB)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 metric 1
    inet 127.0.0.1 netmask 255.0.0.0
    inet6 ::1 prefixlen 128 scopeid 0x10<host>
    loop txqueuelen 1000 (Local Loopback)
    RX packets 2 bytes 140 (140.0 B)
    TX packets 2 bytes 140 (140.0 B)
  • The  RTOS output console log is below, we can see the two phy chip 88Q2110 can be found in the rtos flow :
    [MCU2_0] 16.793258 s: DqenetDetected is true
    [MCU2_0] 16.793302 s: EthFwBoard_configQenet is used
    [MCU2_0] 16.793329 s: gEthFwBoard.serdesAllowed is true
    [MCU2_0] 16.800240 s: EthFwBoard_configCpswClocks is used
    [MCU2_0] 16.801243 s: instId for Enet_initCfg = 0
    [MCU2_0] 16.801294 s: Warning: Using 6 MAC address(es) from static pool
    [MCU2_0] 16.801366 s: ETHFW: Shared multicasts (software fanout):
    [MCU2_0] 16.801397 s: ETHFW: Reserved multicasts:
    [MCU2_0] 16.801421 s: 01:80:c2:00:00:0e
    [MCU2_0] 16.801468 s: 01:1b:19:00:00:00
    [MCU2_0] 16.801680 s: EnetMcm: CPSW_9G on MAIN NAVSS
    [MCU2_0] 16.816244 s: PHY 1 is alive
    [MCU2_0] 16.816300 s: PHY 2 is alive
    [MCU2_0] 16.816401 s: EnetSoc_getMacPortMii: EnetSoc_getMacPortMii use enetType = 6
    [MCU2_0] 16.816441 s: EnetSoc_getMacPortMii: EnetSoc_getMacPortMii use instId = 0
    [MCU2_0] 16.816477 s: EnetSoc_getMainCpsw9gEnetControl: ENET_MAC_PORT5 information is get for modeSel
    [MCU2_0] 16.816520 s: EnetSoc_getMainCpsw9gEnetControl: *modeSel value is 3
    [MCU2_0]
    [MCU2_0] 16.816557 s: EnetSoc_getMacPortMii: EnetSoc_getMacPortMii use modeSel = 3
    [MCU2_0] 16.816593 s: CpswMacPort_checkSocCfg: status in 1st EnetSoc_getMacPortMii
    [MCU2_0] 16.816627 s: CpswMacPort_checkSocCfg: status in 3rd EnetSoc_getMacPortMii
    [MCU2_0] 16.816661 s: CpswMacPort_checkSocCfg: status in 5th EnetSoc_getMacPortMii
    [MCU2_0] 16.817342 s: gEnetPhyDrvs i 0: PHY 2: OUI:000ac2 Model:32 Ver:01 <-> 'vsc8514'
    [MCU2_0] 16.817390 s: PHY addr 2: hDriv->name 'vsc8514
    [MCU2_0] , hDrv = 0xa3bf9bac
    [MCU2_0] 16.817437 s: Vsc8514 verison->oui: 2754, version->model = 50, version->revision =1:
    [MCU2_0] 16.817494 s: gEnetPhyDrvs i 1: PHY 2: OUI:000ac2 Model:32 Ver:01 <-> 'dp83822'
    [MCU2_0] 16.817536 s: PHY addr 2: hDriv->name 'dp83822
    [MCU2_0] , hDrv = 0xa3bf9ae4
    [MCU2_0] 16.817582 s: Dp83822 verison->oui: 2754, version->model = 50, version->revision =1:
    [MCU2_0] 16.817640 s: gEnetPhyDrvs i 2: PHY 2: OUI:000ac2 Model:32 Ver:01 <-> 'dp83867'
    [MCU2_0] 16.817682 s: PHY addr 2: hDriv->name 'dp83867
    [MCU2_0] , hDrv = 0xa3bf9b0c
    [MCU2_0] 16.817728 s: Dp83867 verison->oui: 2754, version->model = 50, version->revision =1:
    [MCU2_0] 16.817786 s: gEnetPhyDrvs i 3: PHY 2: OUI:000ac2 Model:32 Ver:01 <-> '88Q2221'
    [MCU2_0] 16.817828 s: PHY addr 2: hDriv->name '88Q2221
    [MCU2_0] , hDrv = 0xa3bf9b84
    [MCU2_0] 16.817863 s: M88Q2221_isMacModeSupported: M88Q2221_isMacModeSupported::----------
    [MCU2_0] 16.817919 s: EnetPhy_bindDriver: ENETTRACE_INFO_IF hPhy->hDrv !=NULL,PHY 2: OUI:000ac2 Model:32 Ver:01 <-> '88Q2221' : OK
    [MCU2_0] 16.817991 s: EnetSoc_getMacPortMii: EnetSoc_getMacPortMii use enetType = 6
    [MCU2_0] 16.818029 s: EnetSoc_getMacPortMii: EnetSoc_getMacPortMii use instId = 0
    [MCU2_0] 16.818064 s: EnetSoc_getMainCpsw9gEnetControl: ENET_MAC_PORT6 information is get for modeSel
    [MCU2_0] 16.818106 s: EnetSoc_getMainCpsw9gEnetControl: *modeSel value is 3
    [MCU2_0]
    [MCU2_0] 16.818142 s: EnetSoc_getMacPortMii: EnetSoc_getMacPortMii use modeSel = 3
    [MCU2_0] 16.818176 s: CpswMacPort_checkSocCfg: status in 1st EnetSoc_getMacPortMii
    [MCU2_0] 16.818209 s: CpswMacPort_checkSocCfg: status in 3rd EnetSoc_getMacPortMii
    [MCU2_0] 16.818243 s: CpswMacPort_checkSocCfg: status in 5th EnetSoc_getMacPortMii
    [MCU2_0] 16.818817 s: gEnetPhyDrvs i 0: PHY 1: OUI:000ac2 Model:32 Ver:01 <-> 'vsc8514'
    [MCU2_0] 16.818865 s: PHY addr 1: hDriv->name 'vsc8514
    [MCU2_0] 16.818910 s: Vsc8514 verison->oui: 2754, version->model = 50, version->revision =1:
    [MCU2_0] 16.818971 s: gEnetPhyDrvs i 1: PHY 1: OUI:000ac2 Model:32 Ver:01 <-> 'dp83822'
    [MCU2_0] 16.819014 s: PHY addr 1: hDriv->name 'dp83822
    [MCU2_0] 16.819059 s: Dp83822 verison->oui: 2754, version->model = 50, version->revision =1:
    [MCU2_0] 16.819116 s: gEnetPhyDrvs i 2: PHY 1: OUI:000ac2 Model:32 Ver:01 <-> 'dp83867'
    [MCU2_0] 16.819159 s: PHY addr 1: hDriv->name 'dp83867
    [MCU2_0] 16.819203 s: Dp83867 verison->oui: 2754, version->model = 50, version->revision =1:
    [MCU2_0] 16.819259 s: gEnetPhyDrvs i 3: PHY 1: OUI:000ac2 Model:32 Ver:01 <-> '88Q2221'
    [MCU2_0] 16.819301 s: PHY addr 1: hDriv->name '88Q2221
    [MCU2_0] 16.819333 s: M88Q2221_isMacModeSupported: M88Q2221_isMacModeSupported::----------
    [MCU2_0] 16.819387 s: EnetPhy_bindDriver: ENETTRACE_INFO_IF hPhy->hDrv !=NULL,PHY 1: OUI:000ac2 Model:32 Ver:01 <-> '88Q2221' : OK
    [MCU2_0] 16.822302 s:
    [MCU2_0] ETHFW Version : 0.02.00
    [MCU2_0] 16.822349 s: ETHFW Build Date: May 31, 2023
    [MCU2_0] 16.822374 s: ETHFW Build Time: 10:06:59
    [MCU2_0] 16.822397 s: ETHFW Commit SHA: 5459b1a1
    [MCU2_0] 16.822547 s: ETHFW: Init ... DONE !!!
    [MCU2_0] 16.822573 s: ETHFW: Remove server Init ... !!!
    [MCU2_0] 16.822737 s: CpswProxyServer: Virtual port configuration:
    [MCU2_0] 16.822780 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
    [MCU2_0] 16.822820 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
    [MCU2_0] 16.823650 s: CpswProxyServer: initialization completed (core: mcu2_0)
    [MCU2_0] 16.823690 s: ETHFW: Remove server Init ... DONE !!!
    [MCU2_0] 16.824633 s: Starting lwIP, local interface IP is dhcp-enabled
    [MCU2_0] 16.830827 s: Host MAC address: 70:ff:76:1d:92:c2
    [MCU2_0] 16.834104 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
    [MCU2_0] 16.834166 s: Added interface 'ti1', IP is 0.0.0.0
    [MCU2_0] 16.874948 s: FVID2: Init ... !!!
    [MCU2_0] 16.875022 s: FVID2: Init ... Done !!!
    [MCU2_0] 16.875048 s: SCICLIENT: Sciclient_pmSetModuleState module=275 state=2
    [MCU2_0] 16.875174 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875216 s: DSS: Init ... !!!
    [MCU2_0] 16.875238 s: DSS: Display type is eDP !!!
    [MCU2_0] 16.875261 s: DSS: SoC init ... !!!
    [MCU2_0] 16.875282 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0
    [MCU2_0] 16.875352 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875379 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2
    [MCU2_0] 16.875486 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875512 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
    [MCU2_0] 16.875604 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875631 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2
    [MCU2_0] 16.875701 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875727 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
    [MCU2_0] 16.875787 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875813 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0
    [MCU2_0] 16.875873 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.875899 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=218 clk=3 freq=148500000
    [MCU2_0] 16.877289 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
    [MCU2_0] 16.877320 s: SCICLIENT: Sciclient_pmModuleClkRequest module=218 clk=3 state=2 flag=2
    [MCU2_0] 16.877470 s: SCICLIENT: Sciclient_pmModuleClkRequest success
    [MCU2_0] 16.877497 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=2
    [MCU2_0] 16.877629 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.877654 s: DSS: SoC init ... Done !!!
    [MCU2_0] 16.877677 s: DSS: Board init ... !!!
    [MCU2_0] 16.877697 s: DSS: Board init ... Done !!!
    [MCU2_0] 16.896686 s: DSS: Init ... Done !!!
    [MCU2_0] 16.896732 s: VHWA: VPAC Init ... !!!
    [MCU2_0] 16.896754 s: SCICLIENT: Sciclient_pmSetModuleState module=399 state=2
    [MCU2_0] 16.896889 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.896916 s: VHWA: LDC Init ... !!!
    [MCU2_0] 16.899088 s: VHWA: LDC Init ... Done !!!
    [MCU2_0] 16.899130 s: VHWA: MSC Init ... !!!
    [MCU2_0] 16.907671 s: VHWA: MSC Init ... Done !!!
    [MCU2_0] 16.907712 s: VHWA: NF Init ... !!!
    [MCU2_0] 16.908736 s: VHWA: NF Init ... Done !!!
    [MCU2_0] 16.908769 s: VHWA: VISS Init ... !!!
    [MCU2_0] 16.916134 s: VHWA: VISS Init ... Done !!!
    [MCU2_0] 16.916178 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0] 16.916211 s: VX_ZONE_INIT:Enabled
    [MCU2_0] 16.916235 s: VX_ZONE_ERROR:Enabled
    [MCU2_0] 16.916257 s: VX_ZONE_WARNING:Enabled
    [MCU2_0] 16.917679 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
    [MCU2_0] 16.917868 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
    [MCU2_0] 16.918133 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
    [MCU2_0] 16.918330 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
    [MCU2_0] 16.918513 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
    [MCU2_0] 16.918727 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
    [MCU2_0] 16.918918 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
    [MCU2_0] 16.919187 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
    [MCU2_0] 16.919388 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
    [MCU2_0] 16.919582 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
    [MCU2_0] 16.919755 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
    [MCU2_0] 16.920007 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
    [MCU2_0] 16.920221 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
    [MCU2_0] 16.920420 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
    [MCU2_0] 16.920622 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
    [MCU2_0] 16.920816 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
    [MCU2_0] 16.921072 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
    [MCU2_0] 16.921270 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
    [MCU2_0] 16.921458 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
    [MCU2_0] 16.921637 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
    [MCU2_0] 16.921818 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
    [MCU2_0] 16.922090 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX2
    [MCU2_0] 16.922304 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE9
    [MCU2_0] 16.922489 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE10
    [MCU2_0] 16.922672 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE11
    [MCU2_0] 16.922872 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE12
    [MCU2_0] 16.922917 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_0] 16.923000 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0] 16.950153 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0] 16.950195 s: CSI2RX: Init ... !!!
    [MCU2_0] 16.950216 s: SCICLIENT: Sciclient_pmSetModuleState module=189 state=2
    [MCU2_0] 16.950323 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.950351 s: SCICLIENT: Sciclient_pmSetModuleState module=72 state=2
    [MCU2_0] 16.950471 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.950497 s: SCICLIENT: Sciclient_pmSetModuleState module=73 state=2
    [MCU2_0] 16.950586 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.950612 s: SCICLIENT: Sciclient_pmSetModuleState module=74 state=2
    [MCU2_0] 16.950695 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.950721 s: SCICLIENT: Sciclient_pmSetModuleState module=212 state=2
    [MCU2_0] 16.950795 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.950821 s: SCICLIENT: Sciclient_pmSetModuleState module=213 state=2
    [MCU2_0] 16.950889 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.950915 s: SCICLIENT: Sciclient_pmSetModuleState module=214 state=2
    [MCU2_0] 16.951026 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.951257 s: CSI2RX: Init ... Done !!!
    [MCU2_0] 16.951286 s: CSI2TX: Init ... !!!
    [MCU2_0] 16.951309 s: SCICLIENT: Sciclient_pmSetModuleState module=189 state=2
    [MCU2_0] 16.951377 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.951405 s: SCICLIENT: Sciclient_pmSetModuleState module=75 state=2
    [MCU2_0] 16.951486 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.951512 s: SCICLIENT: Sciclient_pmSetModuleState module=76 state=2
    [MCU2_0] 16.951596 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 16.951622 s: SCICLIENT: Sciclient_pmSetModuleState module=402 state=2
    [MCU2_0] 16.951687 s: SCICLIENT: Sciclient_pmSetModuleState success
    From log we see only one Switch port is mapped to A72 (MPU1_0).
    Can you please confirm, have you disabled CPSW2G's from Device trees.
    Also, can you confirm eth1 interface is working with one PHY connected to CPSW9G?
    If you want to add more MAC only ports, Please refer to FAQ [How to add/map MAC only Ports to A72]. But, there were some limitations due to resource availability so you can add up to 5Ports.
    As pointed above please refer to FAQ and add/map ports to A72.
    Sudheer
