Other Parts Discussed in Thread: TMS320C6202B
The TMS320C6414T datasheet claims the following: Fully Software-Compatible With C62x
I currently have a software application running on a TMS320C6202B, where code side in 0x00000000 to 0x0003FFFF range and software data memory reside internal in 0x800xxxx range. Memory MAP1. No external memory required.
The new hardware design is a TMS320C6414T with no external memory, and no internal data memory at 0x8000xxxx (data and program memory locate at 0x000xxxxx).
Given the TMS320C6414T is Fully Software-Compatible With C62x, how can I port my TMS320C6202B software application to the TMS320C6414T without any modification ?
or do I have to modify my link command file to locate my data memory section to internal 0x0004xxx and re-link my C62x software application to be able to run as is in a C64x?
Any other software porting considerations a should I should take care ?
Regards and thank you for your support
