AM1808: 3.3V does not drop when power is turned off
Part Number: AM1808
In AM1808, I have a 3.3V power line with about 1.4V left in it even though I have power-off.
AM1808 has provisions for power-on, but no detailed provisions for power-off.
Is there a correct sequence of power lines to power-off?
I found a similar question, but it does not seem to have been resolved.
e2e.ti.com/.../am1802-when-1-2v-power-up-there-is-a-1-3v-on-3-3v-power-pin
    I have assigned your query to our expert. Since the team is out for holidays, expect a response post New year.
    Apologies for the delay.
    Suren
  • Hello Kishimoto Kazuma
    Thank you for the query.
    Can you please verify if there are any input applied (voltage level) that is higher than the supply rail that is causing leakage,
    Sreenivasa
    Checking if you have had a chance to review the errata.
    2.3.7
    https://www.ti.com/product/AM1808
    Sreenivasa
  • Hello Kallikuppa Sreenivasa-san,
    Thank you for your reply.
    I have already checked Errata 2.3.7 and I believe it is about power ON.
    I was talking about the 3.3V power supply not going to 0V and leaving 1.4V when powered OFF, do you think this phenomenon leads to errata 2.3.7?
    Kazuma
    Thank you.
    Can you please verify the above.
    regards,
    Sreenivasa
    When the 3.3V power supply of AM1808 is turned OFF, it kills everyone above 3.3V.
    Kazuma
    Thank you.
    This is not the on-board supply.
    Please check if there are any external inputs connected to the AM1808 that have a signal when the AM1808 is off.
    Sreenivasa
    Sorry, my information was incorrect.
    C4, D1 and D4, E1~E3 are pulled up to another 3.3V (3.3V_AL) even while the 3.3V supply (3.3V_IDL) of AM1808 is turned off.
    Also, 5V (VDC_5V) on N19 slowly drops in voltage toward 0V over a long period of time (more than 10 seconds).
    Kazuma
    Thank you.
    You will have to review the implementation to see who is causing the leakage and make the required changes. (Since you have the design files and also the familiarity)
    general note is - the inputs should not be available before power supply ramps.
    Sreenivasa
    The voltage remaining when trying to turn off the AM1808 power supply (3.3V_IDL) is as reported the other day.
    Could you provide any comments?
    AM1808 uses 1.2V and 1.8V in addition to 3.3V.
    When turning off the AM1808, I try to drop 3.3V first, then 1.8V and 1.2V, but 3.3V does not drop. It is maybe caused by the leakage.
    The reason the order in which power is turned off is as it is now is because the datasheet has a provision for power ON, but not for power OFF.
    Going back to my first question, is there any provision for the order in which power is turned off?
    Should I really drop the smaller power supplies first?
    Kazuma
    Thank you.
    Do you see any of these signals causing leakage. Since you have the design information, i guess you are in a better position to review.
    If this is something that could be tested, i would recommend trying.
    Sreenivasa
