Hello TI experts,
We want to change the external Infineon Flash from S28HS512TGABHM013 (1.8V version) to S28HL512TGABHM013 (3.3V version), does the SDK support?
Background is the MCU Bootmode pins multiples with Flash OSPI pins while the Flash is supplied with 1.8V and Bootmode is supplied with 3.3V.
So a dedicated buffer with level shift function is needed. However, if the Flash is supplied with 3.3V then a common buffer could be used.
We need confirm the SDK support such changing. And is there any other conerning?
Currently in our design, the external Flash is connected to VDDSHV1_M power group. And no other periphery is connected to VDDSHV1_M.
Thanks a lot.
