PROCESSOR-SDK-AM335X: Configuration File with respect to SDK 09_01_00_001 for AM3352
Part Number: PROCESSOR-SDK-AM335X
Other Parts Discussed in Thread: AM3352
Hi All,
i was referring 1.2. Building the SDK with Yocto — Processor SDK Linux for AM335X Documentation in this they have mentioned
./oe-layertool-setup.sh -f configs/processor-sdk/<oeconfig-file> which oe-config file that we need to update?
is it processor-sdk-09.01.00-am65xx-config.txt or processor-sdk-09.01.00-config.txt or processor-sdk-09.01.00-legacy-config.txt
As it was mentioned 09_01_00_001 i have used processor-sdk-09.01.00-legacy-config.txt(when i open file i saw this meta-processor-sdk,git.ti.com/.../meta-processor-sdk.git,kirkstone,09.01.00.001,layers=)
please correct me if i am wrong.
Please let me know?
  • Hi Manu,
    actually the layer config file to use is on the page you linked, but unfortunately it is easy to miss. What you need to do is to click on this hyperlink:
    ...which will take you to a new page that has the actual file on it:
    https://software-dl.ti.com/processor-sdk-linux/esd/AM335X/09_01_00_001/exports/docs/linux/Release_Specific_Yocto_layer_Configuration.html#yocto-layer-configuration
    Since this question has come up before a few times let me go back and check if there's an improvement request already filed to get this updated to make it more obvious, and if not file one.
    Regards, Andreas
  • Thanks Andreas,
    waiting for your valuable reply
    As you suggested i have gone through the link which you have provided and observed that it is supported to am335x-evm,am335x-evm i hope it will support am335x-evmsk
  • Thanks Andreas,
    Also 1 more query
    we tried to install sudo apt install repo(as mentioned in steps which i have attached) how to resolve this.. is it a mandatory for further build process? can we continue without that.
    thanks
  • As you suggested i have gone through the link which you have provided and observed that it is supported to am335x-evm,am335x-evm i hope it will support am335x-evmsk
    Yes the AM335x SK board (amongst other AM335x boards like the BeagleBoard Black) are all supported through the same MACHINE=am335x-evm build variable specification. This is done by way of DTB files, for example am335x-evmsk.dtb in case of the AM335x SK board.
  • Hi Manu,
    Try building without installing it, it may or may not be needed in all cases and/or what you are doing.
    Also, `repo` is a standard package on Ubuntu 22.04, which is the recommended distro to be used for AM335x SDK v9.1. If you are using something else I'd strongly consider switching to Ubuntu 22.04.
    Regards, Andreas
  • i am using ubuntu22.04 below is the log
    lsb_release -a
    No LSB modules are available.
    Distributor ID: Ubuntu
    Description: Ubuntu 20.04.6 LTS
    Release: 20.04
    Codename: focal
    sudo apt-get install repo
    [sudo] password for sem3user:
    Sorry, try again.
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    E: Unable to locate package repo
    sem3user@INBLRSH0365LNPR:~$
    You say 22.04.... but your log shows 20.04....
    Release: 20.04
  • Thanks Andreas for poining out will check and get back... if further issues
    request to please not to close the ticket..
  • Hello Andreas,
    My machine was initally umask as 0027 as i was getting oe-build failed error.
    later i fixed by changing umask 0002 and build continues and
    i am getting below  error,
    | HASH[link cmd/vet]: "packagefile internal/fmtsort=qEjl0-nXZkWFUHU02IZX\n"
    | HASH[link cmd/vet]: "packagefile math=7qgDsR4c_TOVbVMNr_5_\n"
    | HASH[link cmd/vet]: "packagefile io/fs=KhKl4_P-PPIynRvKsrX-\n"
    | HASH[link cmd/vet]: "packagefile internal/itoa=PwyN1qih0sNMf5YyV21e\n"
    | HASH[link cmd/vet]: "packagefile internal/oserror=IMYptYTqKDUUNRuKSkAL\n"
    | HASH[link cmd/vet]: "packagefile internal/poll=ltB36XROmeMIgyDCJspa\n"
    | HASH[link cmd/vet]: "packagefile internal/safefilepath=m2AcSdzybq-1KO-021ew\n"
    | HASH[link cmd/vet]: "packagefile internal/syscall/execenv=uAQW4kfQOcGVt8t50N0e\n"
    | HASH[link cmd/vet]: "packagefile internal/syscall/unix=48-N0gECuRj48B8d3UYy\n"
    | HASH[link cmd/vet]: "packagefile internal/testlog=PV5l6YelH5XAm7BpAMun\n"
    | HASH[link cmd/vet]: "packagefile internal/unsafeheader=WbU-wG2vdekb44sQGpE1\n"
    | HASH[link cmd/vet]: "packagefile sync/atomic=qYXI4BpI9KqHykjxp1WI\n"
    | HASH[link cmd/vet]: "packagefile syscall=x-kWoqttNVtdHmB_jqKa\n"
    | HASH[link cmd/vet]: "packagefile math/bits=Rv9a2-yQT6LlJhnT9vxt\n"
    | HASH[link cmd/vet]: "packagefile go/scanner=P_QZY_HWCCmlp3hNIJac\n"
    | HASH[link cmd/vet]: "packagefile bufio=DtlERhXkawr1BEc6H1rn\n"
    | HASH[link cmd/vet]: "packagefile go/doc=d1yPY5gNxnN_58HAREnd\n"
    | HASH[link cmd/vet]: "packagefile internal/execabs=QcUm0-fcokWdERv-B2CD\n"
    | HASH[link cmd/vet]: "packagefile internal/goroot=Z4rTDLjwLjqS-YcSmjZ9\n"
    | HASH[link cmd/vet]: "packagefile internal/goversion=t0XDnkYczb0MjM8GD5ip\n"
    | HASH[link cmd/vet]: "packagefile path=Ubzp8zQUa5A8KZj9C0Hw\n"
    | HASH[link cmd/vet]: "packagefile container/heap=w05lh3xpFKHfQi2NuImV\n"
    | HASH[link cmd/vet]: "packagefile go/internal/typeparams=u_-HUZSqnNSEYZBff0pg\n"
    | HASH[link cmd/vet]: "packagefile cmd/vendor/golang.org/x/tools/internal/analysisinternal=y8oaVIx8zrkToQEfgavV\n"
    | HASH[link cmd/vet]: "packagefile go/printer=_d8P6hRx-kYivtYbW5Gu\n"
    | HASH[link cmd/vet]: "packagefile regexp/syntax=dyhfN-qTnTdB8f8ZkFso\n"
    | HASH[link cmd/vet]: "packagefile cmd/vendor/golang.org/x/tools/go/ast/astutil=YFWXxP4rW5mnWGqceEOa\n"
    | HASH[link cmd/vet]: "packagefile math/big=v9sUVLtJ1Vgqx9peX7sV\n"
    | HASH[link cmd/vet]: "packagefile internal/reflectlite=W4p5bayzXQSM9V5XVusX\n"
    | HASH[link cmd/vet]: "packagefile encoding=-ZsBrYAbqgm_YA1eVRwB\n"
    | HASH[link cmd/vet]: "packagefile encoding/binary=0TPzFfBPEpl2SJmhpuhd\n"
    | HASH[link cmd/vet]: "packagefile encoding/base64=mgH1VUN2zivZEAzSNCm1\n"
    | HASH[link cmd/vet]: "packagefile unicode/utf16=dSeZY9TADVgMX3mKXleP\n"
    | HASH[link cmd/vet]: "packagefile go/internal/gccgoimporter=KhtvPBBcx452dTwFOqL4\n"
    | HASH[link cmd/vet]: "packagefile go/internal/gcimporter=J89UsEyYMcgOyVtxlOC3\n"
    | HASH[link cmd/vet]: "packagefile go/internal/srcimporter=VCU92ovKl9yugQyDkfuQ\n"
    | HASH[link cmd/vet]: "packagefile crypto/sha256=amq9J4yL_Jo38R9G8wSR\n"
    | HASH[link cmd/vet]: "packagefile cmd/vendor/golang.org/x/tools/go/types/objectpath=7mVB2N1zH_iQy_1B_8A4\n"
    | HASH[link cmd/vet]: "packagefile internal/race=ce5o7Mbk4_AMAVCl7SOX\n"
    | HASH[link cmd/vet]: "packagefile internal/lazyregexp=11ZD38vEesP1SS8z3PT6\n"
    | HASH[link cmd/vet]: "packagefile text/template=5FflO6MR2AWX7D_N7qTp\n"
    | HASH[link cmd/vet]: "packagefile context=HXgkXK9Ty_J9-XYNKtYr\n"
    | HASH[link cmd/vet]: "packagefile os/exec=C4g4KDoSUo4dqLLvsTSj\n"
    | HASH[link cmd/vet]: "packagefile cmd/vendor/golang.org/x/tools/internal/lsp/fuzzy=g4BnTBwmd7xf1QXR88QJ\n"
    | HASH[link cmd/vet]: "packagefile text/tabwriter=EGwfD47a7bHjRKigkHsp\n"
    | HASH[link cmd/vet]: "packagefile math/rand=ULUu8pMVjfEVSh-4n0PP\n"
    | HASH[link cmd/vet]: "packagefile debug/elf=BSh2_GXczp1Q4FN-wDvO\n"
    | HASH[link cmd/vet]: "packagefile internal/xcoff=7qs-zoDuqVrGNi5AEheJ\n"
    | HASH[link cmd/vet]: "packagefile text/scanner=cePg69xkGychuWOEGW1U\n"
    | HASH[link cmd/vet]: "packagefile crypto=grXGJ7xEQdi7oxuX3FbR\n"
    | HASH[link cmd/vet]: "packagefile hash=t4LBI8uJjL1HqFMOHRs6\n"
    | HASH[link cmd/vet]: "packagefile net/url=90PCfeLEJ98QKy1P4m7T\n"
    | HASH[link cmd/vet]: "packagefile text/template/parse=rmI0QZdIZbuOp9p5-5yi\n"
    | HASH[link cmd/vet]: "packagefile compress/zlib=r1bbQO3fB9ah2jwDWxHz\n"
    | HASH[link cmd/vet]: "packagefile debug/dwarf=wJQuu71g9VWlJD7OBVj4\n"
    | HASH[link cmd/vet]: "packagefile compress/flate=lh4ShsEhfNGuObMdAanH\n"
    | HASH[link cmd/vet]: "packagefile hash/adler32=bwg5w45yvewlFtlcA1JV\n"
    | HASH[link cmd/vet]: 9d2e9c396ac0861a461212fb9456e5dcaf25c081e081c6e739fe2cf0c718fa5a
    | HASH subkey 76813d8a8f97931a272427ed6522d4c614a26501df018e525fa7726f24bd4dd3 "link-stdout" = dbb69085f9054c7ce5361f35807b1e957f5bf3801ecea9419dc82c6615b070c0
    | go tool dist: FAILED: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/go-cross-armv7at2hf-neon/1.17.13-r0/go/pkg/tool/native_native/go_bootstrap install -gcflags=all= -ldflags=all= std cmd: exit status 2
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/go-cross-armv7at2hf-neon/1.17.13-r0/temp/run.do_compile.549660:160 exit 2 from './make.bash --host-only --no-banner'
    | WARNING: Backtrace (BB generated script):
    | #1: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/go-cross-armv7at2hf-neon/1.17.13-r0/temp/run.do_compile.549660, line 160
    | #2: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/go-cross-armv7at2hf-neon/1.17.13-r0/temp/run.do_compile.549660, line 165
    ERROR: Task (/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-devtools/go/go-cross_1.17.13.bb:do_compile) failed with exit code '1'
    WARNING: netkit-ftp-0.17-r0 do_fetch: Failed to fetch URL ftp.debian.org/.../netkit-ftp_0.17-31.debian.tar.xz;name=patch31, attempting MIRRORS if available
    WARNING: wpantund-stable-r0 do_fetch: URL: git://github.com/openthread/wpantund.git;protocol=git uses git protocol which is no longer supported by github. Please change to ;protocol=https in the url.
    WARNING: wpantund-stable-r0 do_fetch: URL: git://github.com/openthread/wpantund.git;protocol=git does not set any branch parameter. The future default branch used by tools and repositories is uncertain and we will therefore soon require this is set in all git urls.
    WARNING: wpantund-stable-r0 do_unpack: URL: git://github.com/openthread/wpantund.git;protocol=git uses git protocol which is no longer supported by github. Please change to ;protocol=https in the url.
    WARNING: wpantund-stable-r0 do_unpack: URL: git://github.com/openthread/wpantund.git;protocol=git does not set any branch parameter. The future default branch used by tools and repositories is uncertain and we will therefore soon require this is set in all git urls.
    ERROR: zip-native-3.0-r2 do_compile: oe_runmake failed
    ERROR: zip-native-3.0-r2 do_compile: ExecutionError('/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885', 1, None, None)
    ERROR: Logfile of failure stored in: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/log.do_compile.573885
    Log data follows:
    | DEBUG: Executing shell function do_compile
    | NOTE: make -j 8 CC=gcc BIND=gcc AS=gcc -c CPP=gcc -E CFLAGS=-I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe CFLAGS_NOOPT=-I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe INSTALL=install INSTALL_D=install -d BINFLAGS=0755 -f unix/Makefile flags IZ_BZIP2=no_such_directory
    | sh unix/configure "gcc " "-I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe" "no_such_directory"
    | Check C compiler type (optimization options)
    | Other-unknown C (-O)
    | Check bzip2 support
    | Check for bzip2 compiled library in IZ_BZIP2 (no_such_directory)
    | no_such_directory/libbz2.a not found
    | -- Since IZ_BZIP2 defined, skipping OS and bzip2 checks - no bzip2
    | Check for the C preprocessor
    | Check if we can use asm code
    | Check for ANSI options
    | Check for prototypes
    | Check the handling of const
    | Check for time_t
    | Check for size_t
    | Check for off_t
    | Check size of UIDs and GIDs
    | (Now zip stores variable size UIDs/GIDs using a new extra field. This
    | tests if this OS uses 16-bit UIDs/GIDs and so if the old 16-bit storage
    | should also be used for backward compatibility.)
    | -- UID/GID test failed on compile - disabling old 16-bit UID/GID support
    | Check for Large File Support
    | -- yes we have Large File Support!
    | Check for wide char support
    | -- no Unicode support
    | Check for gcc no-builtin flag
    | Check for rmdir
    | Check for strchr
    | Check for strrchr
    | Check for rename
    | Check for mktemp
    | Check for mktime
    | Check for mkstemp
    | Check for memset
    | Check for memmove
    | Check for strerror
    | Check for errno declaration
    | Check for directory libraries
    | Check for readlink
    | Check for directory include file
    | Check for nonexistent include files
    | Check for term I/O include file
    | Check for valloc
    | Check for /usr/local/bin and /usr/local/man
    | Check for OS-specific flags
    | Check for symbolic links
    | NOTE: make -j 8 CC=gcc BIND=gcc AS=gcc -c CPP=gcc -E CFLAGS=-I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe CFLAGS_NOOPT=-I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe INSTALL=install INSTALL_D=install -d BINFLAGS=0755 -f unix/Makefile generic IZ_BZIP2=no_such_directory
    | eval make -f unix/Makefile zips `cat flags`
    | make[1]: Entering directory '/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/zip30'
    | gcc -c -I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe -O -DNO_PROTO -DNO_CONST -DNO_TIME_T -DNO_SIZE_T -DNO_OFF_T -DUIDGID_NOT_16BIT -DLARGE_FILE_SUPPORT -DNO_RMDIR -DNO_STRCHR -DNO_STRRCHR -DNO_RENAME -DNO_MKTEMP -DNO_MKTIME -DNO_MKSTEMP -DZMEM -DNEED_MEMMOVE -DNEED_STRERROR -DNO_ERRNO -DNO_DIR -DNO_STDLIB_H -DNO_STDDEF_H -DNO_UNISTD_H -DNO_FCNTL_H -DNO_STRING_H -DNO_VALLOC zip.c
    | gcc -c -I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe -O -DNO_PROTO -DNO_CONST -DNO_TIME_T -DNO_SIZE_T -DNO_OFF_T -DUIDGID_NOT_16BIT -DLARGE_FILE_SUPPORT -DNO_RMDIR -DNO_STRCHR -DNO_STRRCHR -DNO_RENAME -DNO_MKTEMP -DNO_MKTIME -DNO_MKSTEMP -DZMEM -DNEED_MEMMOVE -DNEED_STRERROR -DNO_ERRNO -DNO_DIR -DNO_STDLIB_H -DNO_STDDEF_H -DNO_UNISTD_H -DNO_FCNTL_H -DNO_STRING_H -DNO_VALLOC zipfile.c
    | gcc -c -I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe -O -DNO_PROTO -DNO_CONST -DNO_TIME_T -DNO_SIZE_T -DNO_OFF_T -DUIDGID_NOT_16BIT -DLARGE_FILE_SUPPORT -DNO_RMDIR -DNO_STRCHR -DNO_STRRCHR -DNO_RENAME -DNO_MKTEMP -DNO_MKTIME -DNO_MKSTEMP -DZMEM -DNEED_MEMMOVE -DNEED_STRERROR -DNO_ERRNO -DNO_DIR -DNO_STDLIB_H -DNO_STDDEF_H -DNO_UNISTD_H -DNO_FCNTL_H -DNO_STRING_H -DNO_VALLOC zipup.c
    | gcc -c -I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe -O -DNO_PROTO -DNO_CONST -DNO_TIME_T -DNO_SIZE_T -DNO_OFF_T -DUIDGID_NOT_16BIT -DLARGE_FILE_SUPPORT -DNO_RMDIR -DNO_STRCHR -DNO_STRRCHR -DNO_RENAME -DNO_MKTEMP -DNO_MKTIME -DNO_MKSTEMP -DZMEM -DNEED_MEMMOVE -DNEED_STRERROR -DNO_ERRNO -DNO_DIR -DNO_STDLIB_H -DNO_STDDEF_H -DNO_UNISTD_H -DNO_FCNTL_H -DNO_STRING_H -DNO_VALLOC fileio.c
    | cc1: error: /usr/local/include/x86_64-linux-gnu: Permission denied
    | gcc -c -I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe -O -DNO_PROTO -DNO_CONST -DNO_TIME_T -DNO_SIZE_T -DNO_OFF_T -DUIDGID_NOT_16BIT -DLARGE_FILE_SUPPORT -DNO_RMDIR -DNO_STRCHR -DNO_STRRCHR -DNO_RENAME -DNO_MKTEMP -DNO_MKTIME -DNO_MKSTEMP -DZMEM -DNEED_MEMMOVE -DNEED_STRERROR -DNO_ERRNO -DNO_DIR -DNO_STDLIB_H -DNO_STDDEF_H -DNO_UNISTD_H -DNO_FCNTL_H -DNO_STRING_H -DNO_VALLOC util.c
    | gcc -c -I. -DUNIX -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/recipe-sysroot-native/usr/include -O2 -pipe -O -DNO_PROTO -DNO_CONST -DNO_TIME_T -DNO_SIZE_T -DNO_OFF_T -DUIDGID_NOT_16BIT -DLARGE_FILE_SUPPORT -DNO_RMDIR -DNO_STRCHR -DNO_STRRCHR -DNO_RENAME -DNO_MKTEMP -DNO_MKTIME -DNO_MKSTEMP -DZMEM -DNEED_MEMMOVE -DNEED_STRERROR -DNO_ERRNO -DNO_DIR -DNO_STDLIB_H -DNO_STDDEF_H -DNO_UNISTD_H -DNO_FCNTL_H -DNO_STRING_H -DNO_VALLOC globals.c
    | make[1]: *** [unix/Makefile:86: zipup.o] Error 1
    | make[1]: *** Waiting for unfinished jobs....
    | make[1]: *** [unix/Makefile:86: fileio.o] Error 1
    | make[1]: *** [unix/Makefile:86: zip.o] Error 1
    | make[1]: *** [unix/Makefile:86: zipfile.o] Error 1
    | make[1]: *** [unix/Makefile:86: util.o] Error 1
    | make[1]: Leaving directory '/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/zip30'
    | make[1]: *** [unix/Makefile:86: globals.o] Error 1
    | make: *** [unix/Makefile:202: generic] Error 2
    | ERROR: oe_runmake failed
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885:171 exit 1 from 'exit 1'
    | #1: bbfatal_log, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885, line 171
    | #2: die, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885, line 155
    | #3: oe_runmake, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885, line 150
    | #4: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885, line 145
    | #5: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/zip-native/3.0-r2/temp/run.do_compile.573885, line 184
    ERROR: Task (virtual:native:/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-extended/zip/zip_3.0.bb:do_compile) failed with exit code '1'
    ERROR: lemon-native-3.7.3-r0 do_compile: ExecutionError('/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lemon-native/3.7.3-r0/temp/run.do_compile.574426', 1, None, None)
    ERROR: Logfile of failure stored in: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lemon-native/3.7.3-r0/temp/log.do_compile.574426
    Log data follows:
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lemon-native/3.7.3-r0/temp/run.do_compile.574426:143 exit 1 from 'gcc -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lemon-native/3.7.3-r0/recipe-sysroot-native/usr/include -O2 -pipe lemon.c -c -o lemon.o'
    | #1: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lemon-native/3.7.3-r0/temp/run.do_compile.574426, line 143
    | #2: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lemon-native/3.7.3-r0/temp/run.do_compile.574426, line 148
    ERROR: Task (virtual:native:/home/sem3user/SDK_91/tisdk/sources/meta-openembedded/meta-oe/recipes-devtools/lemon/lemon_3.7.3.bb:do_compile) failed with exit code '1'
    ERROR: lz4-native-1_1.9.4-r0 do_compile: oe_runmake failed
    ERROR: lz4-native-1_1.9.4-r0 do_compile: ExecutionError('/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729', 1, None, None)
    ERROR: Logfile of failure stored in: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/log.do_compile.576729
    Log data follows:
    | NOTE: make -j 8 PREFIX=/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/recipe-sysroot-native/usr CC=gcc CFLAGS=-isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/recipe-sysroot-native/usr/include -O2 -pipe DESTDIR=/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/image LIBDIR=/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/recipe-sysroot-native/usr/lib INCLUDEDIR=/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/recipe-sysroot-native/usr/include BUILD_STATIC=no
    | make[1]: Entering directory '/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/git/lib'
    | compiling dynamic library 1.9.4
    | make[1]: *** [Makefile:122: liblz4.so.1.9.4] Error 1
    | make[1]: Leaving directory '/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/git/lib'
    | make: *** [Makefile:57: lib-release] Error 2
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729:181 exit 1 from 'exit 1'
    | #1: bbfatal_log, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729, line 181
    | #2: die, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729, line 166
    | #3: oe_runmake, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729, line 171
    | #4: base_do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729, line 149
    | #5: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729, line 143
    | #6: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/lz4-native/1_1.9.4-r0/temp/run.do_compile.576729, line 191
    ERROR: Task (virtual:native:/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-support/lz4/lz4_1.9.4.bb:do_compile) failed with exit code '1'
    ERROR: ldconfig-native-2.12.1-r2 do_compile: ExecutionError('/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/ldconfig-native/2.12.1-r2/temp/run.do_compile.585302', 1, None, None)
    ERROR: Logfile of failure stored in: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/ldconfig-native/2.12.1-r2/temp/log.do_compile.585302
    Log data follows:
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/ldconfig-native/2.12.1-r2/temp/run.do_compile.585302:143 exit 1 from '$CC ldconfig.c -std=gnu99 chroot_canon.c xmalloc.c xstrdup.c cache.c readlib.c -I. dl-cache.c -o ldconfig'
    | #1: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/ldconfig-native/2.12.1-r2/temp/run.do_compile.585302, line 143
    | #2: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/ldconfig-native/2.12.1-r2/temp/run.do_compile.585302, line 147
    ERROR: Task (/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_compile) failed with exit code '1'
    ERROR: makedevs-native-1.0.1-r0 do_compile: ExecutionError('/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/temp/run.do_compile.585330', 1, None, None)
    ERROR: Logfile of failure stored in: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/temp/log.do_compile.585330
    Log data follows:
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/temp/run.do_compile.585330:143 exit 1 from 'gcc -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/usr/lib -L/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/recipe-sysroot-native/lib -Wl,-O1 -o /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/makedevs /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/makedevs.c'
    | #1: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/temp/run.do_compile.585330, line 143
    | #2: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/makedevs-native/1.0.1-r0/temp/run.do_compile.585330, line 147
    ERROR: Task (virtual:native:/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_compile) failed with exit code '1'
    ERROR: cdrtools-native-3.01-r0 do_compile: oe_runmake failed
    ERROR: cdrtools-native-3.01-r0 do_compile: ExecutionError('/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267', 1, None, None)
    ERROR: Logfile of failure stored in: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/log.do_compile.585267
    Log data follows:
    | NOTE: make -j 8 -e MAKEFLAGS=
    | W A R N I N G Messages like:
    | gmake[2]: Entering directory `/tmp/cdrtools-2.01/libschily'
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/cvmod.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/dat.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/fcons.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/fdown.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/fdup.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/ffileread.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/ffilewrite.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/fgetline.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/fgetstr.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/file_raise.d: No such file or directory
    | ../RULES/r-gmake.dep:76: OBJ/<arch-dir>/fileclose.d: No such file or directory
    | are caused by a GNU make bug and not by the Schily makefile system.
    | The related bug has been reported to the GNU make maintainers in 1998 but
    | as the bug has not yet been fixed, it seems that GNU make is unmaintained :-(
    | A working highly portable make program is at
    | sourceforge.net/.../
    | You may switch off this warning by calling "gmake GMAKE_NOWARN=true ..."
    | ==> MAKING DIRECTORY "incs/x86_64-linux-cc/Inull"
    | sh conf/cc-config.sh cc cc incs/Dcc.x86_64-linux
    | ==> MAKING SYMLINKS in ./RULES/
    | Trying to find cc
    | ==> CONFIGURING RULES "incs/x86_64-linux-cc/rules.cnf"
    | Trying to find GCC
    | loading site script /home/sem3user/SDK_91/tisdk/sources/oe-core/meta/site/native
    | creating cache ./config.cache
    | cc is gcc
    | Found gcc
    | Making gcc the default compiler in 'incs/Dcc.x86_64-linux'
    | checking host system type... Invalid configuration `unknownCPU-unknownMFR-unknownOS': machine `unknownCPU-unknownMFR' not recognized
    | checking if sh is bash... yes
    | checking if /bin/sh is bash... yes
    | checking whether sh -ce is broken... no
    | checking whether /bin/sh -ce is broken... no
    | checking whether /bin/bosh is a working shell... no
    | checking whether /opt/schily/bin/bosh is a working shell... no
    | checking for cc... (cached) gcc
    | checking for gcc... (cached) gcc
    | checking whether the C compiler (gcc -isystem/home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/recipe-sysroot-native/usr/include -O2 -pipe ) works... no
    | configure: error: installation or configuration problem: C compiler cannot create executables.
    | RULES/rules.top:47: RULES/ldummy.lnk: No such file or directory
    | make: *** [RULES/rules.cnf:59: incs/x86_64-linux-cc/rules.cnf] Error 1
    | make: *** Waiting for unfinished jobs....
    | ==> MAKING SYMLINKS in ./TEMPLATES/
    | WARNING: /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267:182 exit 1 from 'exit 1'
    | #1: bbfatal_log, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267, line 182
    | #2: die, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267, line 167
    | #3: oe_runmake, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267, line 172
    | #4: base_do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267, line 150
    | #5: do_compile, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267, line 144
    | #6: main, /home/sem3user/SDK_91/tisdk/build/arago-tmp-default-glibc/work/x86_64-linux/cdrtools-native/3.01-r0/temp/run.do_compile.585267, line 192
    ERROR: Task (/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-devtools/cdrtools/cdrtools-native_3.01.bb:do_compile) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 2174 tasks of which 0 didn't need to be rerun and 11 failed.
    NOTE: Writing buildhistory
    NOTE: Writing buildhistory took: 7 seconds
    Summary: 11 tasks failed:
    /home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-devtools/m4/m4-native_1.4.19.bb:do_configure
    virtual:native:/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-extended/zstd/zstd_1.5.2.bb:do_compile
    virtual:native:/home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-extended/unzip/unzip_6.0.bb:do_compile
    /home/sem3user/SDK_91/tisdk/sources/oe-core/meta/recipes-support/boost/boost-build-native_4.4.1.bb:do_compile
    Summary: There were 15 WARNING messages.
    Summary: There were 17 ERROR messages, returning a non-zero exit cod
  • From the logs it looks like you have some serious setup issues there with your system, not sure how you ended up with all that. At this point I recommend you to backup any important files, and then completely erase(!)/re-install Ubuntu 22.04, setup the SDK from scratch, and then it should all work.
    Regards, Andreas
  • Hi Andreas,
    I followed as you suggested with ubuntu 22.04..
    I am facing below fetch error but build is continuing further is that fine? i hope for AM3352 this may not effect.
    WARNING: gnutls-3.7.4-r0.arago0 do_package: QA Issue: Excluding gnutls-bin from packaging as it has incompatible license(s): GPL-3.0-or-later [incompatible-license]
    WARNING: vulkan-loader-1.3.204.1-r0 do_package: vulkan-loader: NOT adding alternative provide /usr/lib/libvulkan.so: libvulkan.so.1 does not exist
    WARNING: amx3-cm3-1.9.2-r0 do_fetch: Failed to fetch URL git://git.ti.com/git/processor-firmware/ti-amx3-cm3-pm-firmware.git;protocol=https;branch=ti-v4.1.y, attempting MIRRORS if available
    ERROR: amx3-cm3-1.9.2-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/home/sem3user/tisdk/sources/oe-core/scripts:/home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/recipe-sysroot-native/usr/bin/arm-oe-linux-gnueabi:/home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/recipe-sysroot/usr/bin/crossscripts:/home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/recipe-sysroot-native/usr/sbin:/home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/recipe-sysroot-native/usr/bin:/home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/recipe-sysroot-native/sbin:/home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/recipe-sysroot-native/bin:/home/sem3user/tisdk/sources/bitbake/bin:/home/sem3user/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/sem3user"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror git.ti.com/.../ti-amx3-cm3-pm-firmware.git /home/sem3user/tisdk/downloads/git2/git.ti.com.git.processor-firmware.ti-amx3-cm3-pm-firmware.git --progress failed with exit code 128, no output
    ERROR: amx3-cm3-1.9.2-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://git.ti.com/git/processor-firmware/ti-amx3-cm3-pm-firmware.git;protocol=https;branch=ti-v4.1.y')
    ERROR: Logfile of failure stored in: /home/sem3user/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/amx3-cm3/1.9.2-r0/temp/log.do_fetch.3928411
    ERROR: Task (/home/sem3user/tisdk/sources/meta-ti/meta-ti-bsp/recipes-bsp/cm3-pm-firmware/amx3-cm3_git.bb:do_fetch) failed with exit code '1'
    WARNING: wpantund-stable-r0 do_patch: URL: git://github.com/openthread/wpantund.git;protocol=git uses git protocol which is no longer supported by github. Please change to ;protocol=https in the url.
    WARNING: wpantund-stable-r0 do_patch: URL: git://github.com/openthread/wpantund.git;protocol=git does not set any branch parameter. The future default branch used by tools and repositories is uncertain and we will therefore soon require this is set in all git urls.
    Setscene tasks: 4081 of 4081
    Currently 5 running tasks (5569 of 10121)
  • ERROR: amx3-cm3-1.9.2-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://git.ti.com/git/processor-firmware/ti-amx3-cm3-pm-firmware.git;protocol=https;branch=ti-v4.1.y')
    I'd suggest to just let the build finish, and then re-start it. With this fetch error it won't complete successfully but often such issues are transient, and just re-starting the build helps.
    Also I'd highly recommend to keep a permanent archive of your downloads folder (which can also be shared amongst projects, and even developers), so that in the future you minimize any external build dependencies (and it'll be faster too).
    a0797059@dasso:~/tisdk/am62xx-evm/build (dev)
    $ grep -B 5 DL_DIR conf/local.conf
    # Where to place downloads
    # During a first build the system will download many different source code
    # tarballs from various upstream projects. This can take a while, particularly
    # if your network connection is slow. These are all stored in DL_DIR. When
    # wiping and rebuilding you can preserve this directory to speed up this part
    # of subsequent builds. This directory is safe to share between multiple builds
    # on the same machine too.
    DL_DIR = "/home/a0797059/tisdk/downloads"
    Regards, Andreas
  • Thanks,
    May i know in which path toolchain  is present?
    in building 8.2.0.24 we have downloaded tool chain sepeartly.. in new version we are not doing that. hence i am asking
    need to check what are the changes is done from 8.2.0.24 to 9.1.0.001
  • in building 8.2.0.24 we have downloaded tool chain sepeartly.. in new version we are not doing that. hence i am asking
    Just follow the Yocto build instructions if you want to do a Yocto build for a given SDK version. For other differences, those should be documented in the release notes section of the SDK User Guide,.
    Regards, Andreas
