DRA821U-Q1: Rebooting error in room temperature environment(25 degrees Celsius)
Part Number: DRA821U-Q1
My customer tested the reboot behavior of the DRA821U-Q1 in room temperature environment(25 degrees Celsius) with a board they designed.
When the device was repeatedly rebooted using the reboot command, a symptom of stopping while loading the kernel occurred.
Please review the log file below.
AVS_0.9V_REBOOT_LOG.zip
Please advise on the cause of this symptom and a solution to resolve the issue.
Thank you.
JH
    In the U-Boot prompt please try the below commands:
    setenv dorprocboot 1
    saveenv
    Basically the R5F core 1 is being loaded before core0 which is causing a hang.
    If you are using 9.x SDK then you will need to add that as part of uenv.txt in the boot partition.
    - Keerthy
  • Hi Keerthy,
    The customer repeatedly rebooted the DRA821U-Q1 using the commands you provided, but the symptom was the same.
    A freeze occurred during booting about 1-2 times out of 500.
    The SDK currently in use is 8.04.
    JH
  • Hi Shin,
    Please provide the failure logs with the above change done. We need to make sure if that is the same issue or a different one.
    - Keerthy
  • Hi Keerthy,
    Here is the log file.
    REBOOT_LOG_ADD_COMMAND.zip
    BR,
    JH
  • Hi Shin,
    Can you confirm if the failing points are consistent or they fail at different points. I want to make sure if this is the same failure or we have different ones. Also what's your boot flow?
    Keerthy
  • Hi Keerthy,
    Referring to the log file above, when reboot is executed, a freeze occurs at the line below.
    [    4.581932] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 83820
    [    4.586551] remoteproc remoteproc1: Booting fw image j7200-main-r5f0_0-fw, size 617812
    or
    [    4.644864] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 83820
    They say that the boot flow is the same as EVM as there is no special modification.
    Additionally, the H/W boots with eMMC without using any other storage devices.
    JH
  • Hi Shin,
    Can you please check if the environment variable dorprocboot is actually set to 1 in U-boot prompt?
    Use the command:
    printenv dorprocboot
    Also which SDK version is being used?
    Keerthy
  • Dear Keerthy
    After checking the provided commands, it appears as follows:
    => printenv dorprocboot
    dorprocboot=1
    I also tested it with SDK version 9.01, but it still hangs at the same point.
  • Hi MyoungBong,
    I do not think U-Boot is booting the remoteprocs if you continue to see above traces.
    The current Linux driver does not ensure the boot ordering, but U-Boot allows the proper core loading order between Core0 and Core1.
    The kernel traces should not show the processors to be in 'remoteproc' mode, they should show up as 'IPC-only' mode. If you do not see the latter, then U-Boot has not booted the processors.
    regards
    Suman
  • HI Suman
    We control sgmii through ethfw. Therefore, we need to use remoteproc to use automotive ethernet.
    Why don't we need a solution to why we stop using remoteproc?
    regards
    dongseuk.kim
  • Hi Kim,
    Yes, the usage of EthFW is failrly standard. EthFW is on MCU2_0 and needs to be booted at U-Boot prompt.
    I am not sure what you are saying here. We always need a loader code to load firmware and boot a remote-processor. So, you always need a remoteproc driver for this either at U-Boot or in Linux.
    regards
    Suman
  • Hi Suman
    It's also mentioned in the previous logs, but after IPC-ONLY, it loads the remoteproc firmware
    [    4.160859] platform 41000000.r5f: R5F core initialized in IPC-only mode
             Mounting /mnt/nvlog...
             Mounting /opt4...
             Mounting /opt5...
    [    4.261387]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
             Mounting /opt6...
             Mounting /opt-aws/greengrass/v2/packages...
    [    4.318382] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
    [    4.328527] ext4 filesystem being mounted at /mnt/nvlog supports timestamps until 2038 (0x7fffffff)
    [    4.329195] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /usr/local...
    [    4.381089] random: crng init done
    [    4.382817] random: 38 urandom warning(s) missed due to ratelimiting
    [    4.386446]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    4.391274] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: (null)
    [    4.429719] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [    4.441543] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started Load/Save Random Seed.
    [    4.457956] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
    [    4.465343] ext4 filesystem being mounted at /opt6 supports timestamps until 2038 (0x7fffffff)
    [  OK  ] Mounted /mnt/nvlog.
    [  OK  ] Mounted /opt4.
    [    4.511172] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [  OK  ] Mounted /opt5.
    [  OK  ] Mounted /opt6.
    [    4.533591] platform 5c00000.r5f: configured R5F for remoteproc mode
    [  OK  ] Mounted /opt-aws/greengrass/v2/packages.
    [    4.542561] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [  OK  ] Mounted /usr/local.
    [    4.554201] remoteproc remoteproc1: 5c00000.r5f is available
    [    4.563402] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    4.567475] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    4.572285] remoteproc remoteproc2: 5d00000.r5f is available
    [    4.572500] remoteproc remoteproc1: powering up 5c00000.r5f
    [    4.579107] remoteproc remoteproc2: powering up 5d00000.r5f
    Are there any additional improvements that can be made beyond the initial attempt with U-Boot commands?
    Best Regards
  • Hi MyoungBong,
    I only see MCU1_0 booted in IPC-only mode (as expected, since this is the DM firmware that R5 SPL branches off to). All the MAIN R5Fs are in remoteproc mode only, meaning they have not been booted at U-Boot.
    You haven't provided the complete log, so I cannot see the relevant traces from U-Boot that shows that these processors are indeed booted at U-Boot. Please provide the complete log.
    regards
    Suman
  • Hi Suman
    I had previously attached the entire log, but I'm attaching it again
    REBOOT_LOG_ADD_COMMAND.txt
    root@test:~# --- success at loopNo:  466 ok
    -sh: ---: command not found
    root@test:~#
    root@test:~# reboot
             Stopping Session c1 of user root.
    [  OK  ] Stopped target Multi-User System.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target Network (Pre).
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Timers.
    [  OK  ] Stopped Daily rotation of log files.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Enable and configure 5G modem module...
             Stopping Enable and configure CAN1 interface...
             Stopping Enable and configure CAN2 interface...
             Stopping Enable and configure CAN3 interface...
             Stopping Enable and configure CAN4 interface...
             Stopping Enable and configure CAN5 interface...
             Stopping Enable and configure CAN6 interface...
             Stopping DNS forwarder and DHCP server...
             Stopping Getty on tty1...
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
             Stopping managing ISO-TP s…sage for in vehicle network...
             Stopping NFS status monitor for NFSv2/3 locking....
             Stopping Serial Getty on ttyS2...
    [  OK  ] Stopped ETH0 MAC ADDRESS configure interface.
    [  OK  ] Stopped ETH1 MAC ADDRESS configure interface.
    [  OK  ] Stopped WIFI MAC ADDRESS configure interface.
             Stopping Load/Save Random Seed...
             Stopping TEE Supplicant...
             Stopping thermal-zone-init.service...
             Stopping save redis db abo…y input, gps, cell info etc...
    [  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
    [  OK  ] Stopped TEE Supplicant.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Enable and configure 5G modem module.
    [  OK  ] Stopped save redis db abou…key input, gps, cell info etc.
    [  OK  ] Stopped managing ISO-TP so…essage for in vehicle network.
    [  OK  ] Stopped Enable and configure CAN1 interface.
    [  OK  ] Stopped Enable and configure CAN2 interface.
    [  OK  ] Stopped Enable and configure CAN3 interface.
    [  OK  ] Stopped Enable and configure CAN4 interface.
    [  OK  ] Stopped Enable and configure CAN5 interface.
    [  OK  ] Stopped Enable and configure CAN6 interface.
    [  OK  ] Stopped DNS forwarder and DHCP server.
    [  OK  ] Stopped Load/Save Random Seed.
    [  OK  ] Stopped thermal-zone-init.service.
    [  OK  ] Stopped Session c1 of user root.
    [  OK  ] Removed slice system-getty.slice.
    [  OK  ] Removed slice system-serial\x2dgetty.slice.
             Stopping managing CAN sock…sage for in vehicle network...
             Stopping LSB: network benchmark...
             Stopping System Logger Daemon "default" instance...
             Stopping syslog.service...
             Stopping Login Service...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped managing CAN socke…assage for in vehicle network.
    [  OK  ] Stopped User Manager for UID 0.
    [  OK  ] Stopped System Logger Daemon "default" instance.
    [  OK  ] Stopped LSB: network benchmark.
    [  OK  ] Stopped syslog.service.
    [  OK  ] Removed slice system-syslog\x2dng.slice.
    [  OK  ] Stopped target Network is Online.
    [  OK  ] Stopped target Host and Network Name Lookups.
    [  OK  ] Stopped target System Time Synchronized.
    [  OK  ] Stopped target System Time Set.
             Stopping Redis In-Memory Data Store for J1939 Manager...
             Stopping Redis In-Memory Data Store...
             Stopping Network Name Resolution...
             Stopping telnetd.service...
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped Login Service.
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Stopped Redis In-Memory Data Store for J1939 Manager.
    [  OK  ] Stopped Redis In-Memory Data Store.
    [  OK  ] Stopped telnetd.service.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Removed slice User Slice of UID 0.
             Stopping D-Bus System Message Bus...
             Stopping Permit User Sessions...
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Paths.
    [  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
    [  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
    [  OK  ] Stopped target Remote File Systems.
    [  OK  ] Stopped target Slices.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Sockets.
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Stopped target System Initialization.
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Stopped Load Kernel Modules.
             Stopping Network Time Synchronization...
             Stopping Update UTMP about System Boot/Shutdown...
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Stopped Update UTMP about System Boot/Shutdown.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /media/ram...
             Unmounting /mnt/nvlog...
             Unmounting /opt...
             Unmounting /opt4...
             Unmounting /opt5...
             Unmounting /opt6...
             Unmounting /opt-aws/greengrass/v2/packages...
             Unmounting Temporary Directory (/tmp)...
             Unmounting /usr/local...
             Unmounting /var/volatile...
    [  OK  ] Unmounted /media/ram.
    [  OK  ] Unmounted /mnt/nvlog.
    [  OK  ] Unmounted /opt.
    [  OK  ] Unmounted /opt4.
    [  OK  ] Unmounted /opt5.
    [  OK  ] Unmounted /opt6.
    [  OK  ] Unmounted /opt-aws/greengrass/v2/packages.
    [  OK  ] Unmounted Temporary Directory (/tmp).
    [  OK  ] Unmounted /usr/local.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Swap.
             Unmounting /opt-aws...
    [  OK  ] Stopped File System Check on /dev/mmcblk0p10.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p11.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p13.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p14.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p15.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p16.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p5.
    [  OK  ] Unmounted /opt-aws.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p12.
    [  OK  ] Removed slice system-systemd\x2dfsck.slice.
    [  OK  ] Stopped target Local File Systems (Pre).
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Reached target Shutdown.
    [  OK  ] Reached target Final Step.
    [  OK  ] Started Reboot.
    [  OK  ] Reached target Reboot.
    [   41.165512] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   41.169032] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   41.172468] watchdog: watchdog0: watchdog did not stop!
    [   41.183435] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   41.188875] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   41.198771] systemd-journald[99]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   41.214634] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   41.222311] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
    [   41.227468] systemd-shutdown[1]: Unmounting file systems.
    [   41.231763] [776]: Remounting '/' read-only in with options '(null)'.
    [   41.241450] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
    [   41.245733] systemd-shutdown[1]: All filesystems unmounted.
    [   41.248527] systemd-shutdown[1]: Deactivating swaps.
    [   41.251187] systemd-shutdown[1]: All swaps deactivated.
    [   41.253864] systemd-shutdown[1]: Detaching loop devices.
    [   41.258526] systemd-shutdown[1]: All loop devices detached.
    [   41.261355] systemd-shutdown[1]: Detaching DM devices.
    [   41.264125] systemd-shutdown[1]: All DM devices detached.
    [   41.266844] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
    [   41.273832] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   41.277516] systemd-shutdown[1]: Rebooting.
    [   41.291905] gpio-keys gpio_keys: failed to configure IRQ 402 as wakeup source: -6
    [   41.295664] gpio-keys gpio_keys: failed to shutdown
    [   41.298196] reboot: Restarting system
    [    0.034000] U-Boot SPL 2021.01 (Nov 10 2023 - 11:32:22 +0900)
    [    0.088000] Trying to boot from MMC1
    [    0.288000] Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.7(release):v2.7.0-391-g9dedc1ab2-dirty
    NOTICE:  BL31: Built : 10:55:33, Sep 16 2022
    ti_dm6441_gpio gpio@42110000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
    [21411.521000] Trying to boot from MMC1
    [21412.422000] U-Boot 2021.01 (Nov 10 2023 - 11:32:05 +0900)
    [21412.425000] SoC:   J7200 SR2.0 GP
    [21412.427000] DRAM:  4 GiB
    [21412.462000] wifi get node 10796
    [21412.465000] test: wifipower enable
    [21412.468000] MCU reset get node 27600
    [21412.469000] MCU reset
    [21412.471000] PHY reset get node 27324
    [21412.473000] PHY reset
    [21412.975000] CELL reset get node 27416
    [21412.976000] CELL reset
    [21413.478000] SPI reset get node 27508
    [21413.480000] SPI reset
    Flash: 0 Bytes
    [21413.982000] MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    [env_relocate] env load
    Loading Environment from MMC... OK
    read_env size : 0x00020000 , offset:  0x01800000
    blk start : 0x0000C000 , blk_cnt : 0x00000100, rcnt : 0x00000100
    crc : 0x40496360 crc32 0x40496360
    Create Hash Table: N=1024
    INSERT: table 00000000fffc5358, filled 1/1031 rv 00000000fdef5fb0 ==> name="APN" value="apn.hdi.test"
    INSERT: table 00000000fffc5358, filled 2/1031 rv 00000000fdef9930 ==> name="ETH1ADDR" value="02:D0:20:00:00:02"
    INSERT: table 00000000fffc5358, filled 3/1031 rv 00000000fdef6fa0 ==> name="ETHADDR" value="02:D0:20:00:00:01"
    INSERT: table 00000000fffc5358, filled 4/1031 rv 00000000fdef4e58 ==> name="HW-REVISION" value="B1"
    INSERT: table 00000000fffc5358, filled 5/1031 rv 00000000fdef1e60 ==> name="OEM" value="HDI"
    INSERT: table 00000000fffc5358, filled 6/1031 rv 00000000fdef6a28 ==> name="TSN" value="test000000000000"
    INSERT: table 00000000fffc5358, filled 7/1031 rv 00000000fdef6c08 ==> name="USIM" value="0"
    INSERT: table 00000000fffc5358, filled 8/1031 rv 00000000fdef33c8 ==> name="WATCHDOG" value="1"
    INSERT: table 00000000fffc5358, filled 9/1031 rv 00000000fdef6820 ==> name="WIFI-SUPPORT" value="0"
    INSERT: table 00000000fffc5358, filled 10/1031 rv 00000000fdef6898 ==> name="WIFIADDR" value="02:D0:20:F1:00:01"
    INSERT: free(data = 00000000fdec73b0)
    INSERT: done
    env import success
    watchdog 1
    WATCHDOG enable
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    [21414.267000] Net:   [21414.271000] eth0: ethernet@46000000port@1
    Saving Environment to MMC... Writing to MMC(0)... OK
    [21414.281000] Hit any key to stop autoboot:  0
    [21414.492000] switch to partitions #0, OK
    [21414.494000] mmc0(part 0) is current device
    SD/MMC found on device 0
    ** Unrecognized filesystem type **
    i2c_write: error waiting for data ACK (status=0x116)
    pca953x gpio@21: Error reading output register
    GPIO: 'gpio@22_17' not found
    Command 'gpio' failed: Error -121
    GPIO: 'gpio@22_16' not found
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    Failed to load '/lib/firmware/j7200-main-r5f0_0-fw'
    Failed to load '/lib/firmware/j7200-main-r5f0_1-fw'
    [21414.790000] 13734400 bytes read in 42 ms (311.9 MiB/s)
    [21414.795000] 54103 bytes read in 1 ms (51.6 MiB/s)
    [21414.798000] ## Flattened Device Tree blob at 88000000
    [21414.800000]    Booting using the fdt blob at 0x88000000
    [21414.806000]    Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
    [21414.814000] Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.120 (test.support@auto-dev131) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Nov 10 11:28:38 KST 2023
    [    0.000000] Machine model: Texas Instruments K3 J7200 SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@a5200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
    [    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000a4ffffff]
    [    0.000000]   node   0: [mem 0x00000000a5000000-0x00000000a6ffffff]
    [    0.000000]   node   0: [mem 0x00000000a7000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s49368 r8192 d32552 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,230400n8 earlycon=ns16550a,mmio32,0x02800000 earlycon=ns16550a,mmio32,0x02800000 ethaddr=34:08:e1:71:bc:b9 eth1addr= wifiaddr= root=PARTUUID=c7f6d00b-60f0-a340-9fd8-d84c3a7ca9ae rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3379104K/4194304K available (7936K kernel code, 932K rwdata, 3044K rodata, 1408K init, 355K bss, 290912K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.004271] Console: colour dummy device 80x25
    [    0.006587] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.011986] pid_max: default: 32768 minimum: 301
    [    0.014447] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.018300] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.023346] rcu: Hierarchical SRCU implementation.
    [    0.026002] Platform MSI: msi-controller@1820000 domain created
    [    0.029208] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.033944] EFI services will not be available.
    [    0.036441] smp: Bringing up secondary CPUs ...
    [    0.039437] Detected PIPT I-cache on CPU1
    [    0.039462] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.039476] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.039516] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.039591] smp: Brought up 1 node, 2 CPUs
    [    0.054435] SMP: Total of 2 processors activated.
    [    0.056868] CPU features: detected: 32-bit EL0 Support
    [    0.059519] CPU features: detected: CRC32 instructions
    [    0.068669] CPU: All CPU(s) started at EL2
    [    0.070811] alternatives: patching kernel code
    [    0.073605] devtmpfs: initialized
    [    0.078522] KASLR disabled due to lack of seed
    [    0.080953] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.085997] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.101202] pinctrl core: initialized pinctrl subsystem
    [    0.104272] DMI not present or invalid.
    [    0.106604] NET: Registered protocol family 16
    [    0.109566] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.113328] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.117470] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.121801] thermal_sys: Registered thermal governor 'step_wise'
    [    0.121806] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.125206] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.132135] ASID allocator initialised with 65536 entries
    [    0.146063] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.149535] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.152993] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.156452] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.523172] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
    [    0.527961] iommu: Default domain type: Translated
    [    0.530917] pps_core: LinuxPPS API ver. 1 registered
    [    0.533531] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.538276] EDAC MC: Ver: 3.0.0
    [    0.541046] clocksource: Switched to clocksource arch_sys_counter
    [    0.547263] NET: Registered protocol family 2
    [    0.549956] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.555128] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.559594] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.563812] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.568073] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.571671] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.575208] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.579087] NET: Registered protocol family 1
    [    0.581397] PCI: CLS 0 bytes, default 64
    [    0.583763] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.588653] Initialise system trusted keyrings
    [    0.591115] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.596377] Key type asymmetric registered
    [    0.598514] Asymmetric key parser 'x509' registered
    [    0.601061] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    0.604882] io scheduler mq-deadline registered
    [    0.607227] io scheduler kyber registered
    [    0.611320] pinctrl-single 4301c000.pinctrl: 120 pins, size 480
    [    0.614715] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.619787] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.623015] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.627696] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.637201] brd: module loaded
    [    0.642493] loop: module loaded
    [    0.645852] tun: Universal TUN/TAP device driver, 1.6
    [    0.648773] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.652034] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.655121] sky2: driver version 1.30
    [    0.657685] i2c /dev entries driver
    [    0.660045] sdhci: Secure Digital Host Controller Interface driver
    [    0.663264] sdhci: Copyright(c) Pierre Ossman
    [    0.665721] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.669131] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.672458] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.676268] optee: probing for conduit method.
    [    0.678592] optee: revision 3.17 (f9e55014)
    [    0.678870] optee: initialized driver
    [    0.683772] NET: Registered protocol family 17
    [    0.686131] Key type dns_resolver registered
    [    0.688416] Loading compiled-in X.509 certificates
    [    0.693142] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.696396] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.701560] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.727234] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.730698] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.734136] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.737776] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.741295] pca953x 3-0021: using no AI
    [    0.765098] pca953x 3-0021: failed writing register
    [    0.767690] pca953x: probe of 3-0021 failed with error -121
    [    0.770772] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.774269] pca953x 3-0022: using AI
    [    0.776181] pca953x 3-0022: failed writing register
    [    0.778784] pca953x: probe of 3-0022 failed with error -121
    [    0.781715] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.785189] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
    [    0.788564] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    [    0.791953] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.795370] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.798746] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    0.802132] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
    [    0.805460] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.810584] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.815097] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [    0.820250] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    0.827999] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    0.833021] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.836444] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.842440] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    0.847594] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.851017] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.855375] 42300000.serial: ttyS0 at MMIO 0x42300000 (irq = 15, base_baud = 3000000) is a 8250
    [    0.860647] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 16, base_baud = 6000000) is a 8250
    [    0.865823] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    0.870272] printk: console [ttyS2] enabled
    [    0.874520] printk: bootconsole [ns16550a0] disabled
    [    0.880233] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    0.885187] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 24, base_baud = 3000000) is a 8250
    [    0.890107] 2830000.serial: ttyS5 at MMIO 0x2830000 (irq = 25, base_baud = 3000000) is a 8250
    [    0.895066] 2850000.serial: ttyS7 at MMIO 0x2850000 (irq = 26, base_baud = 3000000) is a 8250
    [    0.900007] 2860000.serial: ttyS8 at MMIO 0x2860000 (irq = 27, base_baud = 3000000) is a 8250
    [    0.904961] 2890000.serial: ttyS9 at MMIO 0x2890000 (irq = 28, base_baud = 3000000) is a 8250
    [    0.910733] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.081055] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    1.085729] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.089813] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.197809] mmc0: CQHCI version 5.10
    [    1.199759] mmc1: CQHCI version 5.10
    [    1.205463] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
    [    1.209110] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
    [    1.213039] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.218801] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
    [    1.224653] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.235224] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.238999] invalid of gpio : -2
    [    1.241068] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.244824] Wi-Fi enable with gpio
    [    1.292326] mmc1: new ultra high speed SDR104 SDIO card at address 0001
    [    1.318031] mmc0: Command Queue Engine enabled
    [    1.320258] mmc0: new HS400 MMC card at address 0001
    [    1.323096] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
    [    1.325500] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
    [    1.328561] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
    [    1.331648] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (242:0)
    [    1.337213]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
    [    1.393065] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    1.397768] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.401857] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.409134] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.412875] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.416498] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.421962] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    1.432521] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [    1.436616] VFS: Mounted root (ext4 filesystem) on device 179:7.
    [    1.440427] devtmpfs: mounted
    [    1.443053] Freeing unused kernel memory: 1408K
    [    1.453102] Run /sbin/init as init process
    [    1.499386] systemd[1]: System time before build time, advancing clock.
    [    1.517774] NET: Registered protocol family 10
    [    1.520620] Segment Routing with IPv6
    [    1.529397] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    1.540428] systemd[1]: Detected architecture arm64.
    Welcome to test 2021.09!
    [    1.565385] systemd[1]: Set hostname to <test>.
    [    1.681450] systemd[1]: vehicle-manager.service: Failed to open /usr/local/systemd/system/vehicle-manager.service: No such file or directory
    [    1.698638] systemd[1]: redis.service: Failed to open /usr/local/systemd/system/redis.service: No such file or directory
    [    1.711464] systemd[1]: j1939manager-db.service: Failed to open /usr/local/systemd/system/j1939manager-db.service: No such file or directory
    [    1.717870] systemd[1]: isotp-manager.service: Failed to open /usr/local/systemd/system/isotp-manager.service: No such file or directory
    [    1.732135] systemd[1]: data-collector.service: Failed to open /usr/local/systemd/system/data-collector.service: No such file or directory
    [    1.793009] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.796516] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    1.802706] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    1.808620] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    1.825173] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.829267] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    1.845163] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.849209] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    1.866025] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [    1.881826] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    1.897368] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    1.913333] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    1.929327] systemd[1]: Reached target Network is Online.
    [  OK  ] Reached target Network is Online.
    [    1.945197] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    1.957182] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    1.973175] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    1.985236] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    2.002015] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    2.017224] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    2.035189] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    2.053357] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    2.073017] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    2.077524] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    2.093532] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    2.109559] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    2.125414] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    2.143693] systemd[1]: Mounting Huge Pages File System...
    [    2.163580] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.183671] systemd[1]: Mounting Kernel Debug File System...
    [    2.203715] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    2.224123] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    2.243888] systemd[1]: Starting RPC Bind...
    [    2.261330] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    2.269034] systemd[1]: Starting Journal Service...
    [    2.288751] systemd[1]: Starting Load Kernel Modules...
    [    2.307944] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    2.326313] systemd[1]: Starting udev Coldplug all Devices...
    [    2.331474] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
    [    2.335168] ext4 filesystem being remounted at / supports timestamps until 2038 (0x7fffffff)
    [    2.344306] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    2.357581] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    2.520973] systemd-journald[99]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [    2.834935] urandom_read_iter: 56 callbacks suppressed
    [    2.834939] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.915284] CAN device driver interface
    [    3.063440] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.066873] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.085397] m_can_platform 2701000.can: m_can device registered (irq=39, version=32)
    [    3.112153] m_can_platform 2741000.can: m_can device registered (irq=41, version=32)
    [    3.225967] m_can_platform 27a1000.can: m_can device registered (irq=43, version=32)
    [    3.278820] m_can_platform 27c1000.can: m_can device registered (irq=45, version=32)
    [    3.379230] m_can_platform 27d1000.can: m_can device registered (irq=47, version=32)
    [    3.435369] m_can_platform 2691000.can: m_can device registered (irq=49, version=32)
    [  OK  ] Found device /dev/mmcblk0p11.
    [  OK  ] Found device /dev/mmcblk0p14.
    [  OK  ] Found device /dev/mmcblk0p12.
    [  OK  ] Found device /dev/mmcblk0p10.
    [  OK  ] Found device /dev/mmcblk0p13.
    [  OK  ] Found device /dev/mmcblk0p15.
    [  OK  ] Found device /dev/mmcblk0p16.
    [    3.755938] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [  OK  ] Found device /dev/mmcblk0p5.
             Starting File System Check on /dev/mmcblk0p10...
             Starting File System Check on /dev/mmcblk0p11...
             Starting File System Check on /dev/mmcblk0p12...
             Starting File System Check on /dev/mmcblk0p13 urandom_read_iter: 119 callbacks suppressed
    [0m...
    [    3.873774] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.883834] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    3.899472] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    3.909404] platform 41000000.r5f: configured R5F for IPC-only mode
    [    3.912670] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
             Starting File System Check on /dev/mmcblk0p14...
             Starting File System Check on /dev/mmcblk0p15...
             Starting File System Check on /dev/mmcblk0p16...
    [    3.956343] remoteproc remoteproc0: 41000000.r5f is available
             Starting File System Check on /dev/mmcblk0p5...
    [  OK  ] Started File System Check on /dev/mmcblk0p10.
             Mounting /opt...
    [  OK  ] Started File System Check on /dev/mmcblk0p12.
             Mounting /opt-aws...
    [    4.028345] remoteproc remoteproc0: attaching to 41000000.r5f
    [  OK  ] Started File System Check on /dev/mmcblk0p11.
    [  OK  ] Started File System Check on /dev/mmcblk0p13.
    [  OK  ] Started File System Check on /dev/mmcblk0p5.
    [  OK  ] Started File System Check on /dev/mmcblk0p14.
    [  OK  ] Started File System Check on /dev/mmcblk0p15.
    [    4.118489] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
    [    4.122738] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk0p16.
    [  OK  ] Mounted /opt.
    [  OK  ] Mounted /opt-aws.
             Mounting /opt4...
             Mounting /opt5...
             Mounting /opt6...
    According to what you're saying, it seems like the R5F cores need to be pre-booted in U-BOOT.
    Is it correct that the 'setenv dorprocboot 1' command in U-BOOT boots the MAIN R5F cores?
    What should be done if this method doesn't work properly?
    Best Regards
  • Hi MyoungBong,
    The MAIN R5FSS Core0 and Core1 failed to boot from U-Boot as per the below lines from your log. Also, you are attempting to boot MCU1_0, which should not even be attempted. U-Boot fails these gracefully, so you are able to proceed further.
    Correct.
    This is a helper variable to control the boot of the relevant cores. This does not automatically boot the MAIN R5F cores. This depends on the variables set in the rproc_fw_binaries variable.
    The overall sequence is part of the bootcmd.
    Please inspect all the various commands part of your bootcmd, and how they play around the above variables. IIRC, the commands are effective only for MMC interface in the TI SDK, and not if you are using other peripheral boots.
    regards
    Suman
  • Hi suman
    We loaded the firmware from U-BOOT and booted up, and it also shows IPC Mode in the Kernel.
    Please refer to the attached file.
    uboot_firmware_load.txt
    load mmc 0:7 0x880000000 /lib/firmware/ethfw/app_remoteswitchcfg_server_strip.xer5f
    [   48.851000] 617812 bytes read in 40 ms (14.7 MiB/s)
    => rproc load 2 0x880000000 0x${filesize}
    Load Remote Processor 2 with data@addr=0x880000000 617812 bytes: Success!
    => rproc start 2
    => load mmc 0:7 0x880000000 /lib/firmware/pdk-ipc/ipc_echo_test_mcu2_1_release_strip.xer5f
    [   65.992000] 83820 bytes read in 42 ms (1.9 MiB/s)
    => rproc load 3 0x880000000 0x${filesize}
    Load Remote Processor 3 with data@addr=0x880000000 83820 bytes: Success!
    => rproc start 3
    => boot
    [   78.129000] switch to partitions #0, OK
    [   78.131000] mmc0(part 0) is current device
    [   78.691000] 13734400 bytes read in 86 ms (152.3 MiB/s)
    [   78.758000] 54103 bytes read in 15 ms (3.4 MiB/s)
    [   78.761000] ## Flattened Device Tree blob at 88000000
    [   78.763000]    Booting using the fdt blob at 0x88000000
    [   78.769000]    Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
    [   78.777000] Starting kernel ...
    [    0.000000] Kernel command line: console=ttyS2,230400n8 earlycon=ns16550a,mmio32,0x02800000 earlycon=ns16550a,mmio32,0x02800000 ethaddr=34:08:e1:71:99:e4 eth1addr= wifiaddr= root=PARTUUID=10bd1158-4a73-e04f-9bf1-342b18a8fe15 rw rootfstype=ext4 rootwait
    [    0.004274] Console: colour dummy device 80x25
    [    0.006589] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.011990] pid_max: default: 32768 minimum: 301
    [    0.014451] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.018304] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.023355] rcu: Hierarchical SRCU implementation.
    [    0.026015] Platform MSI: msi-controller@1820000 domain created
    [    0.029224] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.033962] EFI services will not be available.
    [    0.036457] smp: Bringing up secondary CPUs ...
    [    0.039445] Detected PIPT I-cache on CPU1
    [    0.039469] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.039483] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.039524] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.039593] smp: Brought up 1 node, 2 CPUs
    [    0.054445] SMP: Total of 2 processors activated.
    [    0.056880] CPU features: detected: 32-bit EL0 Support
    [    0.059532] CPU features: detected: CRC32 instructions
    [    0.068668] CPU: All CPU(s) started at EL2
    [    0.073608] devtmpfs: initialized
    [    0.078519] KASLR disabled due to lack of seed
    [    0.080951] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.085998] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.101176] pinctrl core: initialized pinctrl subsystem
    [    0.104251] DMI not present or invalid.
    [    0.106581] NET: Registered protocol family 16
    [    0.109542] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.113307] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.117456] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.121784] thermal_sys: Registered thermal governor 'step_wise'
    [    0.121788] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.125187] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.132124] ASID allocator initialised with 65536 entries
    [    0.146006] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.149481] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.152942] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.156405] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.523127] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
    [    0.527919] iommu: Default domain type: Translated
    [    0.530864] pps_core: LinuxPPS API ver. 1 registered
    [    0.533476] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.538219] EDAC MC: Ver: 3.0.0
    [    0.541007] clocksource: Switched to clocksource arch_sys_counter
    [    0.547218] NET: Registered protocol family 2
    [    0.549914] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.555068] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.559531] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.563750] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.568013] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.571605] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.575138] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.579006] NET: Registered protocol family 1
    [    0.581320] PCI: CLS 0 bytes, default 64
    [    0.583692] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.588573] Initialise system trusted keyrings
    [    0.591032] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.596297] Key type asymmetric registered
    [    0.598430] Asymmetric key parser 'x509' registered
    [    0.600967] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    0.604791] io scheduler mq-deadline registered
    [    0.607131] io scheduler kyber registered
    [    0.611207] pinctrl-single 4301c000.pinctrl: 120 pins, size 480
    [    0.614601] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.619705] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.622927] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.627606] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.636975] brd: module loaded
    [    0.642283] loop: module loaded
    [    0.645647] tun: Universal TUN/TAP device driver, 1.6
    [    0.648562] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.651817] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.654902] sky2: driver version 1.30
    [    0.657456] i2c /dev entries driver
    [    0.659818] sdhci: Secure Digital Host Controller Interface driver
    [    0.663033] sdhci: Copyright(c) Pierre Ossman
    [    0.665482] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.668870] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.672213] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.676011] optee: probing for conduit method.
    [    0.678333] optee: revision 3.17 (f9e55014)
    [    0.678610] optee: initialized driver
    [    0.683492] NET: Registered protocol family 17
    [    0.685850] Key type dns_resolver registered
    [    0.688144] Loading compiled-in X.509 certificates
    [    0.692808] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.696102] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.701243] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.726916] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.730376] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.733809] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.737435] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.740926] pca953x 3-0021: using no AI
    [    0.765056] pca953x 3-0021: failed writing register
    [    0.767646] pca953x: probe of 3-0021 failed with error -121
    [    0.770727] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.774225] pca953x 3-0022: using AI
    [    0.776133] pca953x 3-0022: failed writing register
    [    0.778732] pca953x: probe of 3-0022 failed with error -121
    [    0.781660] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.785129] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
    [    0.788505] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    [    0.791893] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.795294] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.798671] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    0.802054] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
    [    0.805391] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.810508] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.815014] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [    0.820167] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    0.828017] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    0.833035] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.836451] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.842434] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    0.847587] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.851007] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.855371] 42300000.serial: ttyS0 at MMIO 0x42300000 (irq = 15, base_baud = 3000000) is a 8250
    [    0.860633] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 16, base_baud = 6000000) is a 8250
    [    0.865799] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    0.870249] printk: console [ttyS2] enabled
    [    0.874497] printk: bootconsole [ns16550a0] disabled
    [    0.880184] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    0.885125] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 24, base_baud = 3000000) is a 8250
    [    0.890061] 2830000.serial: ttyS5 at MMIO 0x2830000 (irq = 25, base_baud = 3000000) is a 8250
    [    0.895002] 2850000.serial: ttyS7 at MMIO 0x2850000 (irq = 26, base_baud = 3000000) is a 8250
    [    0.899922] 2860000.serial: ttyS8 at MMIO 0x2860000 (irq = 27, base_baud = 3000000) is a 8250
    [    0.904859] 2890000.serial: ttyS9 at MMIO 0x2890000 (irq = 28, base_baud = 3000000) is a 8250
    [    0.910619] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.081016] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    1.085687] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.089770] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.197987] mmc0: CQHCI version 5.10
    [    1.200059] mmc1: CQHCI version 5.10
    [    1.205608] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
    [    1.209293] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
    [    1.213237] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.218971] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
    [    1.224816] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.234151] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.237921] invalid of gpio : -2
    [    1.241730] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.245502] Wi-Fi enable with gpio
    [    1.316938] mmc0: Command Queue Engine enabled
    [    1.319186] mmc0: new HS400 MMC card at address 0001
    [    1.322016] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
    [    1.324388] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
    [    1.327484] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
    [    1.330564] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (242:0)
    [    1.336008]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
    [    1.393017] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    1.397695] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    1.401803] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.409100] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.412886] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.416532] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.422014] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    1.475137] EXT4-fs (mmcblk0p7): 1 orphan inode deleted
    [    1.477785] EXT4-fs (mmcblk0p7): recovery complete
    [    1.485037] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [    1.489130] VFS: Mounted root (ext4 filesystem) on device 179:7.
    [    1.492358] devtmpfs: mounted
    [    1.494981] Freeing unused kernel memory: 1408K
    [    1.497345] Run /sbin/init as init process
    [    1.541475] systemd[1]: System time before build time, advancing clock.
    [    1.559850] NET: Registered protocol family 10
    [    1.562724] Segment Routing with IPv6
    [    1.571244] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    1.582281] systemd[1]: Detected architecture arm64.
    [    1.621367] systemd[1]: Set hostname to <test>.
    [    1.740815] systemd[1]: vehicle-manager.service: Failed to open /usr/local/systemd/system/vehicle-manager.service: No such file or directory
    [    1.758210] systemd[1]: redis.service: Failed to open /usr/local/systemd/system/redis.service: No such file or directory
    [    1.771220] systemd[1]: j1939manager-db.service: Failed to open /usr/local/systemd/system/j1939manager-db.service: No such file or directory
    [    1.777623] systemd[1]: isotp-manager.service: Failed to open /usr/local/systemd/system/isotp-manager.service: No such file or directory
    [    1.792012] systemd[1]: data-collector.service: Failed to open /usr/local/systemd/system/data-collector.service: No such file or directory
    [    1.853342] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.856794] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    1.863057] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    1.868924] systemd[1]: Created slice system-getty.slice.
    [    1.885130] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.889204] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    1.905121] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.909196] systemd[1]: Created slice system-syslog\x2dng.slice.
    [    1.925945] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    1.941778] systemd[1]: Created slice User and Session Slice.
    [    1.957324] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password ��ts to Console Directory Watch.
    [    1.973275] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R��uests to Wall Directory Watch.
    [    1.989275] systemd[1]: Reached target Network is Online.
    [    2.005153] systemd[1]: Reached target Paths.
    [    2.017139] systemd[1]: Reached target Remote File Systems.
    [    2.033198] systemd[1]: Reached target Slices.
    [    2.049175] systemd[1]: Reached target Swap.
    [    2.065988] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    2.081177] systemd[1]: Reached target RPC Port Mapper.
    [    2.100229] systemd[1]: Listening on Process Core Dump Socket.
    [    2.117332] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    2.136810] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    2.141308] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.157493] systemd[1]: Listening on Journal Socket.
    [    2.169529] systemd[1]: Listening on udev Control Socket.
    [    2.185351] systemd[1]: Listening on udev Kernel Socket.
    [    2.203633] systemd[1]: Mounting Huge Pages File System...
    [    2.219531] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.239656] systemd[1]: Mounting Kernel Debug File System...
    [    2.255699] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    2.280042] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st��odes for the current kernel...
    [    2.303823] systemd[1]: Starting RPC Bind...
    [    2.317287] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    2.324941] systemd[1]: Starting Journal Service...
    [    2.345329] systemd[1]: Starting Load Kernel Modules...
    [    2.363943] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    2.377790] systemd[1]: Starting udev Coldplug all Devices...
    [    2.385471] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
    [    2.388191] ext4 filesystem being remounted at / supports timestamps until 2038 (0x7fffffff)
    [    2.397909] systemd[1]: Started RPC Bind.
    [    2.410764] systemd[1]: Started Journal Service.
    [  OK  ] Started Create list of sta�� nodes for the current kernel.
    [    2.565135] systemd-journald[100]: Received client request to flush runtime journal.
    [    2.895673] urandom_read_iter: 56 callbacks suppressed
    [    2.895677] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.974015] CAN device driver interface
    [    3.138190] m_can_platform 2701000.can: m_can device registered (irq=39, version=32)
    [    3.151314] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.154766] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.203401] m_can_platform 2741000.can: m_can device registered (irq=41, version=32)
    [    3.331690] m_can_platform 27a1000.can: m_can device registered (irq=43, version=32)
    [    3.419659] m_can_platform 27c1000.can: m_can device registered (irq=45, version=32)
    [    3.454436] m_can_platform 27d1000.can: m_can device registered (irq=47, version=32)
    [    3.511871] m_can_platform 2691000.can: m_can device registered (irq=49, version=32)
    [    3.574845] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    3.648791] platform 41000000.r5f: configured R5F for IPC-only mode
    [    3.689216] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    3.899250] urandom_read_iter: 71 callbacks suppressed
    [    3.899254] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.915990] random: systemd: uninitialized urandom read (16 bytes read)
             Starting File System Check on /dev/mmcblk0p10 random: systemd-journal: uninitialized urandom read (16 bytes read)
    [0m...
    [    3.968445] remoteproc remoteproc0: 41000000.r5f is available
             Starting File System Check on /dev/mmcblk0p13...
    [    4.047712] remoteproc remoteproc0: attaching to 41000000.r5f
    [    4.181387] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    4.184753]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    4.230405]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    4.233495] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [  OK  ] Started File System Check on /dev/m[    4.245683] platform 5c00000.r5f: configured R5F for IPC-only mode
    mcblk0p16.
    [    4.248932] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    4.268950] remoteproc remoteproc1: 5c00000.r5f is available
    [    4.305097] remoteproc remoteproc1: attaching to 5c00000.r5f
    [    4.308119] platform 5c00000.r5f: R5F core initialized in IPC-only mode
             Mounting /opt...
             Mounting /opt4...
    [    4.378022]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    4.393137]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    4.396185] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
             Mounting /opt5...
    [    4.406997] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /opt6...
    [    4.430288] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: (null)
    [    4.440695] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    4.494234] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: (null)
    [    4.505495] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
    [    4.513186] ext4 filesystem being mounted at /opt6 supports timestamps until 2038 (0x7fffffff)
    [    4.549051] random: crng init done
    [    4.550757] random: 84 urandom warning(s) missed due to ratelimiting
    [    4.558004] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    4.568356] remoteproc remoteproc2: 5d00000.r5f is available
    [    4.569883] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    4.571371] remoteproc remoteproc2: attaching to 5d00000.r5f
    [    4.578564] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    4.581972]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    4.586298]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    4.589754] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached
    [  OK  ] Started Load/Save Random Seed.
    [    4.642048] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /opt4.
    [  OK  ] Mounted /opt5.
    [  OK  ] Mounted /opt6.
    [    4.759540] usbcore: registered new interface driver usbfs
    [    4.793123] usbcore: registered new interface driver hub
             Mounting /mnt/nvlog...
    [    4.817146] usbcore: registered new device driver usb
             Mounting /opt-aws/greengrass/v2/packages...
    [    4.862639] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
    [    4.869686] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
    [    4.873060] ext4 filesystem being mounted at /mnt/nvlog supports timestamps until 2038 (0x7fffffff)
    [  OK  ] Mounted /opt-aws/greengrass/v2/packages.
    [  OK  ] Mounted /mnt/nvlog.
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [    4.947192] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    4.958721] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    4.962596] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    4.978116] virtio_rpmsg_bus virtio1: rpmsg host is online
    [  OK  ] Started Create Volatile Files and D[    4.988594] virtio_rpmsg_bus virtio2: rpmsg host is online
    irectories.
    [    4.993563] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
             Starting Network Name Resolution...
    [    5.009276] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [    5.134309] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    5.149599] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    5.173209] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [    5.179748] xhci-hcd xhci-hcd.1.auto: irq 527, io mem 0x06010000
    [    5.183632] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    5.216910] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    5.241112] usb usb1: Product: xHCI Host Controller
    [    5.243557] usb usb1: Manufacturer: Linux 5.10.120 xhci-hcd
    [    5.261240] usb usb1: SerialNumber: xhci-hcd.1.auto
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initializatio[    5.270862] hub 1-0:1.0: USB hub found
    n.
    [    5.273965] hub 1-0:1.0: 1 port detected
    [    5.276964] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    5.281719] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [  OK  ] Started Daily Cleanup of Temporary [    5.286215] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    Directories.
    [    5.292249] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    5.297168] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    5.301327] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    5.304934] usb usb2: Product: xHCI Host Controller
    [    5.307403] usb usb2: Manufacturer: Linux 5.10.120 xhci-hcd
    [    5.310221] usb usb2: SerialNumber: xhci-hcd.1.auto
    [  OK  ] Reached target System Time Set.[    5.313103] hub 2-0:1.0: USB hub found
    [    5.317407] hub 2-0:1.0: 1 port detected
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting u-boot bootount reset...
             Starting Enable and configure CAN1 interface...
             Starting Enable and configure CAN2 interface...
             Starting Enable and configure CAN3 interface...
             Starting Enable and configure CAN4 interface...
             Starting Enable and configure CAN5 interface...
             Starting Enable and configure CAN6 interface...
    [  OK  ] Started D-Bus System Message Bus.
    [    5.549659] IPv6: ADDRCONF(NETDEV_CHANGE): can2: link becomes ready
    [    5.555314] IPv6: ADDRCONF(NETDEV_CHANGE): can1: link becomes ready
             Starting DNS forwarder and DHCP server...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
             Starting Insmod kernel moudule...
             Starting ETH0 MAC ADDRESS configure interface...
             Starting ETH1 MAC ADDRESS configure interface...
             Starting WIFI MAC ADDRESS configure interface...
    [    5.673820] mhi_init Quectel_Linux_PCIE_MHI_Driver_V1.3.1
             Starting System Logger Daemon "default" instance...
    grep: /var/lib/opkg/info/*.control: No such file or directory
             Starting Login Service...
             Starting Permit User Sessions...
    [    5.762744] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Started TEE Supplicant.
             Starting telnetd.service...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started u-boot bootount reset.
    [  OK  ] Started Enable and configure CAN1 interface.
    [    5.883199] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [Generic PHY] (irq=POLL)
    [    5.888294] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rmii link mode
    [  OK  ] Started Enable and configure CAN2 interface.
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Started Enable and configure CAN3 interface.
    [  OK  ] Started Enable and configure CAN4 interface.
    [    5.946608] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [  OK  ] Started Enable and configure CAN5 interface.
    [  OK  ] Started Enable and configure CAN6 interface.
    [    5.980162] wlan: Loading MWLAN driver
    [    5.982642] wlan: Register to Bus Driver...
    [    5.984841] wlan: Register to Bus Driver Done
    [    5.988145] wlan: Driver loaded successfully
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started Insmod kernel moudule.
    [  OK  ] Started ETH0 MAC ADDRESS configure interface.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started DNS forwarder and DHCP server.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Listening on Load/Save RF ��itch Status /dev/rfkill Watch.
             Starting Enable and configure 5G modem module...
             Starting Enable coredump...
    [  OK  ] Started Getty on tty1.
             Starting LSB: network benchmark...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting redis service and opt package set path...
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting syslog.service...
    [  OK  ] Started Enable coredump.
    [  OK  ] Started LSB: network benchmark.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started syslog.service.
    [  OK  ] Started Login Service.
             Starting thermal-zone-init.service...
    [  OK  ] Started thermal-zone-init.service.
    [    6.569088] IPv6: ADDRCONF(NETDEV_CHANGE): can3: link becomes ready
    [    6.572587] IPv6: ADDRCONF(NETDEV_CHANGE): can5: link becomes ready
    [    6.584498] IPv6: ADDRCONF(NETDEV_CHANGE): can4: link becomes ready
    [    6.588818] IPv6: ADDRCONF(NETDEV_CHANGE): can6: link becomes ready
    [  OK  ] Started Redis In-Memory Data Store.
    [  OK  ] Started Redis In-Memory Data Store for J1939 Manager.
    [  OK  ] Started save redis db abou��key input, gps, cell info etc.
    [  OK  ] Started managing CAN socke��assage for in vehicle network.
             Starting Rotate log files...
    [  OK  ] Started Enable and configure 5G modem module.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project test ttyS2
    test 2021.09 test ttyS2
    test login: [  OK  ] Started managing ISO-TP so��essage for in vehicle network.
    [  OK  ] Started redis service and opt package set path.
    [  OK  ] Reached target Multi-User System.
             Starting Update UTMP about System Runlevel Changes...
    [  OK  ] Started Update UTMP about System Runlevel Changes.
    root
    [  OK  ] Created slice User Slice of UID 0.
             Starting User Runtime Directory /run/user/0...
    [  OK  ] Started User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [  OK  ] Started User Manager for UID 0.
    [  OK  ] Started Session c1 of user root.
    root@test:~#
    root@test:~# [   17.891762] can: controller area network core
    [   17.894033] NET: Registered protocol family 29
    [   17.901506] can: raw protocol
    [FAILED] Failed to start WIFI MAC ADDRESS configure interface.
    See 'systemctl status set_wifi_macaddress.service' for details.
    [FAILED] Failed to start ETH1 MAC ADDRESS configure interface.
    See 'systemctl status set_eth1_macaddress.service' for details.
    root@test:~#
    However, when loading the firmware from U-BOOT, ethfw does not operate properly in the kernel.
    Is there any additional configuration needed?
  • Hi MyoungBong,
    Your latest log clearly shows the processors booted in U-Boot, and the kernel detecting these properly and configuring the R5Fs to be in IPC-only mode.
    Your earlier reboot logs though did not showcase this.
    Let's concentrate on the original topic of this thread - reboot frozen. Please do not fork this thread into a completely different topic.
    regards
    Suman
  • Hi Suman.
    OK. I will inquire separately about the issue with ethfw not functioning properly.
    I have confirmed that loading the F/W in U-BOOT does not cause the system to hang during repeated tests.
    Thank you for your support
