TDA4VM: How to add the number of CAN channels
Part Number: TDA4VM
Hi Team,
1. The ti-processor-sdk-rtos-j721e-evm-09_00_00_02 supports only four CAN channels, namely MCU_MCAN0 and MCU_MCAN1 in the MCU domain and MCAN0 and MCAN1 in the main domain.
2. Due to development requirements, we need to enable MCAN2, MCAN3 and MCAN4 in the main domain. May I ask how to open these three can channels.
Yousheng Liu
    All CAN channels are enabled to use , are you saying in example we didn't use so you are thinking channels are disabled?
    Tarun MUkesh
  • It's possible that I have expressed it incorrectly.
    MCAN2, MCAN3, and MCAN4 have already been enabled, but I noticed that these 3 CAN channels are still forbidden. Where can I activate them?
    Yousheng Liu
  • Hi
    It's possible that I have expressed it incorrectly before.
    MCAN2, MCAN3, and MCAN4 have already been enabled in rtos, but I noticed that these 3 CAN channels are still forbidden. Where can I activate them?
    CanApp_Startup.c as follows
    * Copyright (c) 2023-2020 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file     CanApp_Startup.c
     *  \brief    This file contains the pinmux, interrupt and clock configuration.
    /*                             Include Files                                  */
    #include "CanApp_Startup.h"
    #include "can_profile.h"
    #include <ti/csl/csl_types.h>
    /*                            Global Variables                                */
    uint32                      CanApp_IntNumbers[CAN_MAX_CONTROLLER];
    /**< Store the interrupt numbers for all enabled CAN instances */
    uint32                      CanApp_InstanceSrcId[CAN_MAX_CONTROLLER];
    /**< Store the interrupt source id for all enabled CAN instances */
    CanApp_IsrType              CanApp_Isr[CAN_MAX_CONTROLLER];
    /**< Associated ISR */
    uint32                      CanApp_RoutIntNumbers[CAN_MAX_CONTROLLER];
    /**< Store the output interrupt number routed */
    extern Can_PduType          CanApp_Pdu, CanApp_Pdu1;
    /**< Variable used for copying protocol data unit */
    extern uint8                CanApp_InputData[64U];
    /**< Variables which contains Can PDU data used in Can transmission */
    extern const Can_PduType    *CanApp_PduInfo;
    /**< Variable which contains Can PDU data passed during Transmission */
    /*                          Function Definitions                              */
    /** \brief Start up sequence : Program the interrupt muxes / priorities */
    void CanApp_Startup(void)
        /* Build Interrupt list for the enabled Can Instances */
        CanApp_BuildIntList();
        Intc_Init();    /* Interrupt handler initialized, here as other functions
                         * can use API's to clear pending interrupts if any
        /* Interrupt configuration for the enabled Can Instances */
        CanApp_InterruptConfig();
        /* Initialize counters, that would be required for profiling operations */
        AppUtils_ProfileInit(0);
        /* Initialize memory sections, which is used to check memory corruption */
    	AppUtils_CanSectionInit();
    void CanApp_BuildIntList(void)
        uint32 idx, flag, intNum;
        const Can_ConfigType *Can_ConfigPtr;
        CanApp_IsrType pIsrHandler = NULL;
        uint32 canMaxControllerCnt = 0U;
        uint32 canDevId, routIntNum = 0U;//20230419
         * 1. Determine the number of Can Instances used
         * 2. Build valid Can Instances list
         * 3. Build isr and interrupt number for enabled Can Instances only
        /* Do Can Init */
    #if (STD_ON == CAN_VARIANT_PRE_COMPILE)
        Can_ConfigPtr = &CAN_INIT_CONFIG_PC;
        Can_Init((const Can_ConfigType *) NULL_PTR);
    #if (CAN_INITIAL_PRINT_DISABLE_BEFORE_CAN_RESPONSE == STD_OFF)
        /*AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME
                        "Variant - Pre Compile being used !!!\n");*/
    #endif
    #else
        Can_ConfigPtr = &CanConfigSet;
        Can_Init(Can_ConfigPtr);
                        "Variant - Post Build being used !!!\n");
    #endif
    #endif
        /* Enable SCI Client */
        Sciclient_init(NULL_PTR);
        canMaxControllerCnt = Can_ConfigPtr->CanMaxControllerCount;
        for (idx = 0U; idx < canMaxControllerCnt; idx++)
            CanApp_IntNumbers[idx] = 0U;
            CanApp_InstanceSrcId[idx] = 0U;
            CanApp_RoutIntNumbers[idx] = 0U;
            flag = 0U;
            if (CAN_CONTROLLER_INSTANCE_MCU_MCAN0 ==
                CanConfigSet_CanController_List_PC[idx]->CanControllerInst)
                intNum = APP_MCU_MCAN_0_INT0;
                pIsrHandler = Can_0_Int0ISR;
                canDevId = TISCI_DEV_MCU_MCAN0;//20230419
                flag = 1U;
            if (CAN_CONTROLLER_INSTANCE_MCU_MCAN1 ==
                intNum = APP_MCU_MCAN_1_INT0;
                pIsrHandler = Can_1_Int0ISR;
                canDevId = TISCI_DEV_MCU_MCAN1;//20230419
                flag = 1U;
            //20230419
            if (CAN_CONTROLLER_INSTANCE_MCAN0 ==
                intNum = APP_MCAN_0_INT0;//16U
                pIsrHandler = Can_2_Int0ISR;
                routIntNum = INTRTR_CFG_MAIN_DOMAIN_MCAN_0_OUT_INT_NO +
                    INTRTR_CFG_START_LEVEL_INT_NUMBER;//28+160
                canDevId = TISCI_DEV_MCAN0;
                flag = 1U;
            //20230505 Add Main_MCAN1
            if (CAN_CONTROLLER_INSTANCE_MCAN1 ==
                intNum = APP_MCAN_1_INT0;//19U
                pIsrHandler = Can_3_Int0ISR;
                routIntNum = INTRTR_CFG_MAIN_DOMAIN_MCAN_1_OUT_INT_NO +
                    INTRTR_CFG_START_LEVEL_INT_NUMBER;//29+160
                canDevId = TISCI_DEV_MCAN1;
                flag = 1U;
            //20230508 Add Main_MCAN2
            if (CAN_CONTROLLER_INSTANCE_MCAN2 ==
                intNum = APP_MCAN_2_INT0;//22U
                pIsrHandler = Can_4_Int0ISR;
                routIntNum = INTRTR_CFG_MAIN_DOMAIN_MCAN_2_OUT_INT_NO +
                    INTRTR_CFG_START_LEVEL_INT_NUMBER;//30+160
                canDevId = TISCI_DEV_MCAN2;
                flag = 1U;
            //20230508 Add Main_MCAN3
            if (CAN_CONTROLLER_INSTANCE_MCAN3 ==
                intNum = APP_MCAN_3_INT0;//25U
                pIsrHandler = Can_5_Int0ISR;
                routIntNum = INTRTR_CFG_MAIN_DOMAIN_MCAN_3_OUT_INT_NO +
                    INTRTR_CFG_START_LEVEL_INT_NUMBER;//31+160
                canDevId = TISCI_DEV_MCAN3;
                flag = 1U;
            //20230508 Add Main_MCAN4
            if (CAN_CONTROLLER_INSTANCE_MCAN4 ==
                intNum = APP_MCAN_4_INT0;//278U
                pIsrHandler = Can_6_Int0ISR;
                routIntNum = INTRTR_CFG_MAIN_DOMAIN_MCAN_4_OUT_INT_NO +
                    INTRTR_CFG_START_LEVEL_INT_NUMBER;//32+160
                canDevId = TISCI_DEV_MCAN4;
                flag = 1U;
            if (0U != flag)
                CanApp_IntNumbers[idx] = intNum;
                CanApp_Isr[idx] = pIsrHandler;
                CanApp_InstanceSrcId[idx] = canDevId;//20230419
                CanApp_RoutIntNumbers[idx] = routIntNum;//20230419
                flag = 0U;
        return;
    void CanApp_PlatformInit()
        uint32 regVal = 0U;
        /* Unlock lock key registers for Partition 7: IO PAD
           configuration registers in MAIN_CTRL_MMR */
        /* write Partition 7 Lock Key 0 Register */
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1D008, 0x68EF3490);
        /* write Partition 7 Lock Key 1 Register */
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1D00C, 0xD172BC5A);
        /* Check for unlock */
        regVal = CSL_REG32_RD(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1D008);
        while ((regVal & 0x1) != 0x1U)
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1D008, 0x68EF3490);
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1D00C, 0xD172BC5A);
        regVal = CSL_REG32_RD(CSL_CTRL_MMR0_CFG0_BASE + 0x1D008);
        /* Unlocking done */
        /* Below code will be replaced by Port module in further releases */
        /* MCU MCAN 0 Tx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1C0A8U, regVal);
        /* MCU MCAN 0 Rx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1C0ACU, regVal);
        /* MCU MCAN 1 Tx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1C0C0U, regVal);
        /* MCU MCAN 1 Rx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + 0x1C0C4U, regVal);
        /* MAIN MCAN 0 Tx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C20CU, regVal);
        /* MAIN MCAN 0 Rx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C208U, regVal);
        /* MAIN MCAN 1 Tx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C214U, regVal);
        /* MAIN MCAN 1 Rx PAD configuration */
        regVal = 0x60000U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C210U, regVal);
        /* MAIN MCAN 2 Tx PAD configuration */
        regVal = 0x60003U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C21CU, regVal);
        /* MAIN MCAN 2 Rx PAD configuration */
        regVal = 0x60003U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C218U, regVal);
        /* MAIN MCAN 3 Tx PAD configuration */
        regVal = 0x60001U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C204U, regVal);
        /* MAIN MCAN 3 Rx PAD configuration */
        regVal = 0x60001U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C200U, regVal);
        /* MAIN MCAN 4 Tx PAD configuration */
        regVal = 0x60006U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C020U, regVal);
        /* MAIN MCAN 4 Rx PAD configuration */
        regVal = 0x60006U;
        CSL_REG32_WR(CSL_CTRL_MMR0_CFG0_BASE + 0x1C024U, regVal);
        /* Take MCAN transceivers out of STB mode i.e NORMAL Mode */
        CanApp_EnableTransceivers();
    void CanApp_EnableTransceivers(void)
        uint32 regVal = 0U;
        Dio_LevelType dioPinLevel[2U];
        /* Take MCAN transceiver out of STB mode for MCU MCAN0 */
        /* Pin mux configuration of Dio Pin 15(MCU_MCAN0_EN J27 WKUP_GPIO0_15) */
        regVal = 0x08050007U;
        CSL_REG32_WR(CSL_WKUP_CTRL_MMR0_CFG0_BASE + CSL_WKUP_CTRL_MMR_CFG0_PADCONFIG59, regVal);
        /* Set Pin direction to output */
        regVal = CSL_REG32_RD(CSL_WKUP_GPIO0_BASE + 0x10U);
        regVal &= (~(1U << 0x0FU));
        CSL_REG32_WR(CSL_WKUP_GPIO0_BASE + 0x10U, regVal);
        /* Drive Pin to High */
        Dio_WriteChannel(15U, STD_HIGH);
         /* Read Pin level */
        dioPinLevel[1U] = Dio_ReadChannel(15U);
        /*Read back the pin levels to ensure transceiver is enabled*/
        if (STD_HIGH != dioPinLevel[1U])
            " Error in Enabling CAN Transceiver MCU MCAN0!!!\n");
        else
            /* Pin mux configuration of Dio Pin 51(MCU_CAN0_STBZ F23 WKUP_GPIO0_51) */
                CSL_WKUP_CTRL_MMR_CFG0_PADCONFIG35, regVal);
            regVal = CSL_REG32_RD(CSL_WKUP_GPIO0_BASE + 0x38U);
            regVal &= (~(1U << 0x13U));
            CSL_REG32_WR(CSL_WKUP_GPIO0_BASE + 0x38U, regVal);
            Dio_WriteChannel(51U, STD_HIGH);
            dioPinLevel[1U] = Dio_ReadChannel(51U);
            else
                " Successfully Enabled CAN Transceiver MCU MCAN0!!!\n");*/
        return;
    void CanApp_InterruptConfig(void)
        uint32 idx;
        OsalRegisterIntrParams_t    intrPrms;
        OsalInterruptRetCode_e      osalRetVal;
        HwiP_Handle hwiHandle;
        struct tisci_msg_rm_irq_set_req     rmIrqReq;//20230504
        struct tisci_msg_rm_irq_set_resp    rmIrqResp;//20230504
        Int32 retVal;//20230504
        uint32 AddressOffset,regVal = 0;
    #else
    #endif
        /*set MAIN2MCU_LVL_INTRTR0_MUXCNTL_n n= 0 ~ 63*/
        regVal |= (1U << 16U);//INT_ENABLE
        regVal |= APP_MCAN_4_INT0;//MAIN2MCU_LVL_INTRTR0_IN_278
        AddressOffset = (4 + 32*4);//
        CSL_REG32_WR(CSL_MAIN2MCU_LVL_INTRTR0_CFG_BASE + AddressOffset, regVal);//Page13473 MAIN2MCU_LVL_INTRTR0_MUXCNTL_n Register
        AddressOffset = 0;
        for (idx = 0U; idx < Can_ConfigPtr->CanMaxControllerCount; idx++)
            /* If the CAN instance is not in MCU domain, the interrupt router will
                have to be configured */
            /* Set the destination interrupt */
            if ((CAN_CONTROLLER_INSTANCE_MCU_MCAN0 !=
                CanConfigSet_CanController_List_PC[idx]->CanControllerInst) &&
               (CAN_CONTROLLER_INSTANCE_MCU_MCAN1 !=
                CanConfigSet_CanController_List_PC[idx]->CanControllerInst))
                CanApp_IntNumbers[idx] = CanApp_RoutIntNumbers[idx];
                rmIrqReq.valid_params           = TISCI_MSG_VALUE_RM_DST_ID_VALID;
                rmIrqReq.valid_params          |= TISCI_MSG_VALUE_RM_DST_HOST_IRQ_VALID;
                rmIrqReq.src_id                 = CanApp_InstanceSrcId[idx];
                rmIrqReq.global_event           = 0U;
                /* Src Index 0 - mcanss_ext_ts_rollover_lvl_int,
                   Src Index 1 - mcanss_mcan_lvl_int Line 0,
                   Src Index 2 - mcanss_mcan_lvl_int Line 1 */
                rmIrqReq.src_index              = 1U;
                rmIrqReq.dst_id                 = TISCI_DEV_MCU_R5FSS0_CORE0;
                rmIrqReq.dst_host_irq           = CanApp_RoutIntNumbers[idx];
                rmIrqReq.ia_id                  = 0U;
                rmIrqReq.vint                   = 0U;
                rmIrqReq.vint_status_bit_index  = 0U;
                rmIrqReq.secondary_host         = TISCI_MSG_VALUE_RM_UNUSED_SECONDARY_HOST;
                retVal = Sciclient_rmIrqSet(
                             &rmIrqReq, &rmIrqResp, APP_SCICLIENT_TIMEOUT);
                if(CSL_PASS != retVal)
                    "CAN_APP: Error in SciClient Interrupt Params Configuration %d !!!\n",idx);
            Osal_RegisterInterrupt_initParams(&intrPrms);
            intrPrms.corepacConfig.arg          = (uintptr_t)CanApp_Isr[idx];
            intrPrms.corepacConfig.isrRoutine   = &CanApp_CanXIsr;
            intrPrms.corepacConfig.priority     = 1U;
            intrPrms.corepacConfig.corepacEventNum = 0U; /* NOT USED ? */
            intrPrms.corepacConfig.intVecNum        = CanApp_IntNumbers[idx];
            osalRetVal = Osal_RegisterInterrupt(&intrPrms, &hwiHandle);
            if(OSAL_INT_SUCCESS != osalRetVal)
                                "CAN_APP: Error %d !!!\n",idx);
                break;
        for (idx = 0U; idx < 64; idx++)
            AddressOffset = 4 + idx*4;
            regVal = CSL_REG32_RD(CSL_MAIN2MCU_LVL_INTRTR0_CFG_BASE + AddressOffset);
            //MAIN2MCU_LVL_INTRTR0 0~27 and 50~62 have no value
            AppUtils_Printf(MSG_NORMAL,"CAN_APP_RouteNo MAIN2MCU_LVL_INTRTR0: %d, %0x\n",idx,regVal);
        return;
    /** \brief None, SBL/GEL powers up the timers and clock sources */
    void CanApp_PowerAndClkSrc(void)
        /* Mcu module, when included will replace this operation */
        return;
    void CanApp_SetupCanFrame(uint32 ctlr_cnt, uint8 *hth, uint32 *mask)
    #if (CAN_TX_ONLY_MODE == STD_ON)
                CanConfigSet_CanController_List_PC[ctlr_cnt]->CanControllerInst)
                /* CAN Protocol Data Unit */
                CanApp_PduInfo = &CanApp_Pdu;
                /* Hardware Transmit Handle assigned to MCAN0 */
                *hth     = CAN_HTRH_0;
                /* mask is need for checking id of received message with
                 * sent message as 30th bit the of sent message will be set
                 * for CAN FD frame */
    #if (CAN_LOOPBACK_ENABLE == STD_ON) || (CAN_EXT_LOOPBACK == STD_ON)
                *mask    = 0xC0000000U;
    #endif
                CanApp_PduInfo = &CanApp_Pdu1;
                /* Hardware Transmit Handle assigned to MCAN1 */
                *hth     = CAN_HTRH_2;
    #endif
    #endif
    #if (CAN_EXT_LOOPBACK == STD_ON)
    Std_ReturnType CanApp_SetupControllersExternalLoopback(uint32 CanControllerTransition)
        Std_ReturnType      statusTxCan, statusRxCan;
        Std_ReturnType      status = E_OK;
        if (CanControllerTransition == CAN_CS_STARTED)
            statusTxCan = Can_SetControllerMode(
            CanConfigSet_CanController_List_PC[APP_MCU_MCAN0_IDX]->ControllerId, CAN_CS_STARTED);
            statusRxCan = Can_SetControllerMode(
            CanConfigSet_CanController_List_PC[APP_MCU_MCAN1_IDX]->ControllerId, CAN_CS_STARTED);
            if ((statusTxCan != E_OK) && (statusRxCan != E_OK))
                status = E_NOT_OK;
        if (CanControllerTransition == CAN_CS_STOPPED)
            CanConfigSet_CanController_List_PC[APP_MCU_MCAN0_IDX]->ControllerId, CAN_CS_STOPPED);
            CanConfigSet_CanController_List_PC[APP_MCU_MCAN1_IDX]->ControllerId, CAN_CS_STOPPED);
                status = E_NOT_OK;
        return status;
    void CanApp_SetupCanFrameExternalLoopback(uint8 *hth, uint32 *mask)
        /* Setup Can frame, reception happens on MCAN9 */
        /* Hardware Transmit Handle assigned to MCAN4 */
        *hth     = CAN_HTRH_0;
    #endif
    Yousheng Liu
    Let me check your application.
    Few instances are on GESI board you need to use I2C to write into those.
    Tarun Mukesh
    1.We are utilizing MCAN0, MCAN1, MCAN2, MCAN3, MCAN4 and routing the interrupt to MCU_R5F1_0. The interrupt route numbers are 160+28, 160+29, 160+30, 160+31, 160+32 respectively.
    2.MCAN0 and MCAN1 can send and receive messages normally
    3.MCAN2 and MCAN3 can route successfully but cannot send or receive messages.
    4.MCAN4 routing failed,  and the return value of calling Sciclient_rmIrqSet is always CSL_FAIL.
    Yousheng Liu
    MCAN2,MCAN3,MCAN4 all are not pinned out on TI EVM.Are you testing it with any custom board ?
    Please check with internal loop back test to ensure the problem is not in CAN transceiver configuration.
    Tarun Mukesh
    1.We use boards of our own design for development.
    2.Check that the TXD and RXD pin configurations of the can transceiver are correct.
    3.CAN transceivers TXD and RXD have been maintained around 2.5v by multimeter measurement.
    Yousheng Liu
    I suspect pin mux/transceiver configuration is not matching your custom board.Please run internal loop back test on MCAN2/3/4 so that we can further debug this based on result.
    Interrupt routing numbers are correct.
    Tarun Mukesh
