TDA4AH-Q1: start weston service failed
Part Number: TDA4AH-Q1
when I flash the follow version, and the weston could not work, please help to check.
I download the bin ti-processor-sdk-linux-adas-j784s4-evm-09_02_00_05-Linux-x86-Install.bin
I follow the tutorial create-sd-card-with-custom-images to build the SD card.
This is boot log:
U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
ti_i2c_eeprom_am6_get: Ignoring record id 255
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
SPL initial stack usage: 13456 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
I/TC:
I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
SoC:   J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
Board: J784S4X-EVM rev E3
DRAM:  2 GiB (effective 32 GiB)
idle-statesCore:  91 devices, 33 uclasses, devicetree: separate
Flash: spi_nand nand@0: Winbond SPI NAND was found.
spi_nand nand@0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
In:    serial@2880000
Out:   serial@2880000
Err:   serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1534 bytes read in 23 ms (64.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
gpio: pin gpio@22_17 (gpio 188) value is 1
gpio: pin gpio@22_16 (gpio 187) value is 0
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
Failed to load '/lib/firmware/j784s4-mcu-r5f0_1-fw'
1597000 bytes read in 43 ms (35.4 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1597000 bytes: Success!
322804 bytes read in 30 ms (10.3 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 322804 bytes: Success!
150752 bytes read in 27 ms (5.3 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 150752 bytes: Success!
150752 bytes read in 28 ms (5.1 MiB/s)
Load Remote Processor 5 with data@addr=0x82000000 150752 bytes: Success!
478460 bytes read in 31 ms (14.7 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 478460 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 150752 bytes: Success!
15470920 bytes read in 186 ms (79.3 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 15470920 bytes: Success!
15864024 bytes read in 190 ms (79.6 MiB/s)
Load Remote Processor 9 with data@addr=0x82000000 15864024 bytes: Success!
15475016 bytes read in 186 ms (79.3 MiB/s)
Load Remote Processor 10 with data@addr=0x82000000 15475016 bytes: Success!
15475016 bytes read in 187 ms (78.9 MiB/s)
Load Remote Processor 11 with data@addr=0x82000000 15475016 bytes: Success!
19376640 bytes read in 224 ms (82.5 MiB/s)
114029 bytes read in 27 ms (4 MiB/s)
Working FDT set to 88000000
3943 bytes read in 26 ms (147.5 KiB/s)
14601 bytes read in 25 ms (570.3 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=80000000 flags=4)
   Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
Working FDT set to 8fee1000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024
[    0.000000] Machine model: Texas Instruments J784S4 EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 48 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@b6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@b6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@b8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@b8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@ba000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000be000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@be000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000be800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@be800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 2048 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 1792 MiB
[    0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000b2603fff]
[    0.000000]   node   0: [mem 0x00000000b2604000-0x00000000b3ffffff]
[    0.000000]   node   0: [mem 0x00000000b4000000-0x00000000b4603fff]
[    0.000000]   node   0: [mem 0x00000000b4604000-0x00000000b5ffffff]
[    0.000000]   node   0: [mem 0x00000000b6000000-0x00000000b6603fff]
[    0.000000]   node   0: [mem 0x00000000b6604000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000b8603fff]
[    0.000000]   node   0: [mem 0x00000000b8604000-0x00000000b9ffffff]
[    0.000000]   node   0: [mem 0x00000000ba000000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000]   node   0: [mem 0x0000000900000000-0x0000000fffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8257536
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=01e2bc61-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 27524696K/33554432K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 4194728K reserved, 1835008K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @93c800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x000000093c050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000093c060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008455] Console: colour dummy device 80x25
[    0.013027] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023698] pid_max: default: 32768 minimum: 301
[    0.028436] LSM: Security Framework initializing
[    0.033251] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.041049] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.050130] cblist_init_generic: Setting adjustable number of callback queues.
[    0.057526] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.063787] cblist_init_generic: Setting adjustable number of callback queues.
[    0.071173] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.077475] rcu: Hierarchical SRCU implementation.
[    0.082373] rcu:     Max phase no-delay instances is 1000.
[    0.087856] Platform MSI: msi-controller@1820000 domain created
[    0.094050] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.103520] EFI services will not be available.
[    0.108346] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[    0.121412] Detected PIPT I-cache on CPU1
[    0.121464] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.121477] GICv3: CPU1: using allocated LPI pending table @0x000000093c070000
[    0.121506] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.129952] Detected PIPT I-cache on CPU2
[    0.129994] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[    0.130007] GICv3: CPU2: using allocated LPI pending table @0x000000093c080000
[    0.130029] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[    0.138432] Detected PIPT I-cache on CPU3
[    0.138473] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[    0.138487] GICv3: CPU3: using allocated LPI pending table @0x000000093c090000
[    0.138510] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[    0.146964] Detected PIPT I-cache on CPU4
[    0.147044] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[    0.147058] GICv3: CPU4: using allocated LPI pending table @0x000000093c0a0000
[    0.147090] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[    0.155549] Detected PIPT I-cache on CPU5
[    0.155602] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[    0.155614] GICv3: CPU5: using allocated LPI pending table @0x000000093c0b0000
[    0.155637] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[    0.164067] Detected PIPT I-cache on CPU6
[    0.164120] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[    0.164132] GICv3: CPU6: using allocated LPI pending table @0x000000093c0c0000
[    0.164156] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[    0.172578] Detected PIPT I-cache on CPU7
[    0.172630] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[    0.172643] GICv3: CPU7: using allocated LPI pending table @0x000000093c0d0000
[    0.172666] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[    0.172711] smp: Brought up 1 node, 8 CPUs
[    0.353683] SMP: Total of 8 processors activated.
[    0.358489] CPU features: detected: 32-bit EL0 Support
[    0.363744] CPU features: detected: CRC32 instructions
[    0.369037] CPU: All CPU(s) started at EL2
[    0.373226] alternatives: applying system-wide alternatives
[    0.379866] devtmpfs: initialized
[    0.393279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.403257] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.432389] pinctrl core: initialized pinctrl subsystem
[    0.438034] DMI not present or invalid.
[    0.442281] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.449591] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.457612] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.466333] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.474565] audit: initializing netlink subsys (disabled)
[    0.480182] audit: type=2000 audit(0.340:1): state=initialized audit_enabled=0 res=1
[    0.480376] thermal_sys: Registered thermal governor 'step_wise'
[    0.488100] thermal_sys: Registered thermal governor 'power_allocator'
[    0.494315] cpuidle: using governor menu
[    0.505049] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.512072] ASID allocator initialised with 65536 entries
[    0.525569] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[    0.537665] KASLR disabled due to lack of seed
[    0.544953] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.551902] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.558307] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.565241] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.571644] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.578578] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.584980] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.591914] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.598988] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[    0.608506] iommu: Default domain type: Translated
[    0.613493] iommu: DMA domain TLB invalidation policy: strict mode
[    0.620006] SCSI subsystem initialized
[    0.623981] usbcore: registered new interface driver usbfs
[    0.629600] usbcore: registered new interface driver hub
[    0.635039] usbcore: registered new device driver usb
[    0.640389] pps_core: LinuxPPS API ver. 1 registered
[    0.645461] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.654797] PTP clock support registered
[    0.658879] EDAC MC: Ver: 3.0.0
[    0.662556] FPGA manager framework
[    0.666061] Advanced Linux Sound Architecture Driver Initialized.
[    0.672679] clocksource: Switched to clocksource arch_sys_counter
[    0.679020] VFS: Disk quotas dquot_6.6.0
[    0.683046] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.692960] Carveout Heap: Exported 960 MiB at 0x0000000900000000
[    0.699240] NET: Registered PF_INET protocol family
[    0.704631] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.717500] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.726523] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.734452] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.743538] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.751938] TCP: Hash tables configured (established 262144 bind 65536)
[    0.758810] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.766159] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.774025] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.780089] RPC: Registered named UNIX socket transport module.
[    0.786146] RPC: Registered udp transport module.
[    0.790949] RPC: Registered tcp transport module.
[    0.795752] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.802333] NET: Registered PF_XDP protocol family
[    0.807240] PCI: CLS 0 bytes, default 64
[    0.811898] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.821166] Initialise system trusted keyrings
[    0.825828] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.834375] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.840576] NFS: Registering the id_resolver key type
[    0.845750] Key type id_resolver registered
[    0.850022] Key type id_legacy registered
[    0.854141] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.860990] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.887854] Key type asymmetric registered
[    0.892037] Asymmetric key parser 'x509' registered
[    0.897041] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.904678] io scheduler mq-deadline registered
[    0.909306] io scheduler kyber registered
[    0.915601] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.921577] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[    0.927599] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[    0.933798] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[    0.939624] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[    0.945970] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.955400] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.967053] loop: module loaded
[    0.970913] megasas: 07.719.03.00-rc1
[    0.976219] tun: Universal TUN/TAP device driver, 1.6
[    0.981767] VFIO - User Level meta-driver version: 0.3
[    0.987403] usbcore: registered new interface driver usb-storage
[    0.993858] i2c_dev: i2c /dev entries driver
[    0.998794] sdhci: Secure Digital Host Controller Interface driver
[    1.005111] sdhci: Copyright(c) Pierre Ossman
[    1.009684] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.015894] ledtrig-cpu: registered to indicate activity on CPUs
[    1.022131] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.028885] usbcore: registered new interface driver usbhid
[    1.034579] usbhid: USB HID core driver
[    1.039073] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    1.043632] optee: revision 4.1 (012cdca4)
[    1.060027] optee: dynamic shared memory is enabled
[    1.069409] optee: initialized driver
[    1.074157] Initializing XFRM netlink socket
[    1.078538] NET: Registered PF_PACKET protocol family
[    1.083735] Key type dns_resolver registered
[    1.088274] registered taskstats version 1
[    1.092475] Loading compiled-in X.509 certificates
[    1.103174] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
[    1.150859] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz
[    1.157169] pca953x 0-0020: supply vcc not found, using dummy regulator
[    1.163982] pca953x 0-0020: using no AI
[    1.189314] pca953x 0-0022: supply vcc not found, using dummy regulator
[    1.196127] pca953x 0-0022: using AI
[    1.200420] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.206202] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[    1.214735] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[    1.223981] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[    1.232628] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[    1.244635] ti-udma 311a0000.dma-controller: Number of rings: 48
[    1.251853] ti-udma 311a0000.dma-controller: Channels: 48 (bchan: 0, tchan: 16, rchan: 32)
[    1.261498] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[    1.271376] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.278135] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.287035] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[    1.297181] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.303940] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.311793] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 262, base_baud = 6000000) is a 8250
[    1.321196] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 263, base_baud = 3000000) is a 8250
[    1.330046] printk: console [ttyS2] enabled
[    1.338487] printk: bootconsole [ns16550a0] disabled
[    1.388685] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.397918] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.406184] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.419032] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.426240] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.432399] pps pps0: new PPS source ptp0
[    1.436531] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    1.484683] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.493682] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    1.501773] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.514508] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    1.520762] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    1.527880] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[    1.533982] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[    1.544093] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[    1.552829] mmc0: CQHCI version 5.10
[    1.597334] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.688956] mmc0: Command Queue Engine enabled
[    1.693396] mmc0: new HS200 MMC card at address 0001
[    1.698679] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.704253] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    1.709841] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    1.715323] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[    1.843890] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    1.849850] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
[    1.858103] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[    1.864893] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[    1.871660] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[    1.878435] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[    1.885212] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[    1.891982] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[    1.900447] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[    1.910354] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[    1.922086] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.927392] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[    1.935712] 7 fixed-partitions partitions found on MTD device spi0.0
[    1.942056] Creating 7 MTD partitions on "spi0.0":
[    1.946840] 0x000000000000-0x000000100000 : "ospi_nand.tiboot3"
[    1.953754] 0x000000100000-0x000000300000 : "ospi_nand.tispl"
[    1.960715] 0x000000300000-0x000000700000 : "ospi_nand.u-boot"
[    1.968376] 0x000000700000-0x000000740000 : "ospi_nand.env"
[    1.974559] 0x000000740000-0x000000780000 : "ospi_nand.env.backup"
[    1.981324] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[    2.018990] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[    2.027760] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[    2.032851] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[    2.039886] Creating 7 MTD partitions on "47050000.spi.0":
[    2.045357] 0x000000000000-0x000000100000 : "qspi.tiboot3"
[    2.051362] 0x000000100000-0x000000300000 : "qspi.tispl"
[    2.057205] 0x000000300000-0x000000700000 : "qspi.u-boot"
[    2.063093] 0x000000700000-0x000000740000 : "qspi.env"
[    2.068756] 0x000000740000-0x000000780000 : "qspi.env.backup"
[    2.074994] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[    2.080889] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[    2.124687] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.133922] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.142188] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.155039] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.162247] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    2.168389] pps pps0: new PPS source ptp1
[    2.172528] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    2.182407] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    2.228686] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.237769] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    2.245860] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.258605] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    2.264859] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    2.271977] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[    2.278084] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    2.287863] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[    2.295832] mmc1: CQHCI version 5.10
[    2.296131] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present!
[    2.306660] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[    2.313883] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[    2.321580] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[    2.328891] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[    2.336206] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[    2.340268] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.352530] ALSA device list:
[    2.355498]   No soundcards found.
[    2.359086] Waiting for root device PARTUUID=01e2bc61-02...
[    2.415532] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    2.422508] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[    2.431266]  mmcblk1: p1 p2
[    2.870993] EXT4-fs (mmcblk1p2): recovery complete
[    2.876499] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[    2.885043] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    2.899473] devtmpfs: mounted
[    2.903107] Freeing unused kernel memory: 1984K
[    2.907728] Run /sbin/init as init process
[    3.051835] systemd[1]: System time before build time, advancing clock.
[    3.088005] NET: Registered PF_INET6 protocol family
[    3.093547] Segment Routing with IPv6
[    3.097225] In-situ OAM (IOAM) with IPv6
[    3.120186] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    3.151743] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    3.207312] systemd[1]: Hostname set to <j784s4-evm>.
[    3.272391] systemd-sysv-generator[194]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    3.402174] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.445966] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.495709] systemd[1]: Queued start job for default target Graphical Interface.
[    3.540473] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    3.561937] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    3.585734] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    3.609558] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.632838] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    3.656787] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    3.680839] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    3.696745] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.716728] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    3.732744] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    3.778418] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    3.804793] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    3.830479] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.852842] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.876988] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.896899] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.916916] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.932956] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.956958] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.976847] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.996892] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    4.036926] systemd[1]: Mounting Huge Pages File System...
[    4.055051] systemd[1]: Mounting POSIX Message Queue File System...
[    4.078896] systemd[1]: Mounting Kernel Debug File System...
[    4.096914] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.114493] systemd[1]: Mounting Temporary Directory /tmp...
[    4.131447] systemd[1]: Starting Create List of Static Device Nodes...
[    4.154745] systemd[1]: Starting Load Kernel Module configfs...
[    4.174843] systemd[1]: Starting Load Kernel Module drm...
[    4.190979] systemd[1]: Starting Load Kernel Module fuse...
[    4.199506] fuse: init (API version 7.37)
[    4.214776] systemd[1]: Starting Start psplash boot splash screen...
[    4.241963] systemd[1]: Starting RPC Bind...
[    4.256873] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    4.272512] systemd[1]: Starting Journal Service...
[    4.295040] systemd[1]: Starting Load Kernel Modules...
[    4.306455] cryptodev: loading out-of-tree module taints kernel.
[    4.313262] cryptodev: driver 1.12 loaded.
[    4.315263] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[    4.343284] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.355865] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[    4.367470] systemd[1]: Starting Coldplug All udev Devices...
[    4.389157] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    4.405063] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    4.759328] systemd-journald[215]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /media/ram...
         Mounting /var/volatile...
[    4.995018] audit: type=1334 audit(1651167746.940:2): prog-id=5 op=LOAD
[    5.001755] audit: type=1334 audit(1651167746.948:3): prog-id=6 op=LOAD
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[    5.169273] random: crng init done
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Load/Save Random Seed.[    5.199221] CAN device driver interface
[  OK  ] Finished Create Volatile Files and Directories.
[    5.232555] mc: Linux media interface: v0.10
[  OK  ] Found device /dev/ttyS2.[    5.242946] PVR_K:  280: Device: 4e20000000.gpu
[    5.250332] PVR_K:  280: Read BVNC 36.53.104.796 from HW device registers
[    5.257222] PVR_K:  280: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[    5.260764] videodev: Linux video capture interface: v2.00
[    5.266109] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.274145] [drm] Initialized pvr 23.3.6512818 20170530 for 4e20000000.gpu on minor 0
[    5.279060] j721e-pcie-host 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.291382] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[    5.293687] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[    5.293942] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[    5.295451] j721e-pcie-host 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.299589] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[    5.305380] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[    5.308071] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[    5.310216] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[    5.315657] j721e-pcie-host 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.317794] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    5.318079] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    5.318135] remoteproc remoteproc0: 64800000.dsp is available
[    5.318182] remoteproc remoteproc0: attaching to 64800000.dsp
[    5.318345] remoteproc remoteproc0: unsupported resource 65538
[    5.318434] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    5.318444] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    5.318773] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.318786] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
[    5.318790] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[    5.318794] k3-dsp-rproc 64800000.dsp: register pm nitifiers in remoteproc mode
[    5.319444] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
[    5.319799] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[    5.319848] remoteproc remoteproc1: 65800000.dsp is available
[    5.319887] remoteproc remoteproc1: attaching to 65800000.dsp
[    5.320024] remoteproc remoteproc1: unsupported resource 65538
[    5.320071] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[    5.320079] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
[    5.320375] virtio_rpmsg_bus virtio1: rpmsg host is online
[    5.320388] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
[    5.320392] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
[    5.320395] k3-dsp-rproc 65800000.dsp: register pm nitifiers in remoteproc mode
[    5.322520] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    5.322834] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
[    5.323468] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
[    5.323518] remoteproc remoteproc2: 66800000.dsp is available
[    5.323558] remoteproc remoteproc2: attaching to 66800000.dsp
[    5.323714] remoteproc remoteproc2: unsupported resource 65538
[    5.323770] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
[    5.323777] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
[    5.324088] virtio_rpmsg_bus virtio2: rpmsg host is online
[    5.324104] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
[    5.324108] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
[    5.324111] k3-dsp-rproc 66800000.dsp: register pm nitifiers in remoteproc mode
[    5.324184] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    5.324661] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
[    5.325447] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
[    5.476302] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.482138] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    5.482184] remoteproc remoteproc3: 67800000.dsp is available
[    5.482235] remoteproc remoteproc3: attaching to 67800000.dsp
[    5.482485] remoteproc remoteproc3: unsupported resource 65538
[    5.482589] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
[    5.482602] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
[    5.482910] virtio_rpmsg_bus virtio3: rpmsg host is online
[    5.482931] rproc-virtio rproc-virtio.10.auto: registered virtio3 (type 7)
[    5.482935] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
[    5.482939] k3-dsp-rproc 67800000.dsp: register pm nitifiers in remoteproc mode
[    5.487771] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.487796] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.493694] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    5.516199] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.522929] platform 41000000.r5f: configured R5F for IPC-only mode
[    5.523425] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    5.530408] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.539274] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    5.545673] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.557217] remoteproc remoteproc4: 41000000.r5f is available
[    5.562596] m_can_platform 40528000.can: m_can device registered (irq=634, version=32)
[    5.566954] remoteproc remoteproc4: attaching to 41000000.r5f
[    5.573972] m_can_platform 40568000.can: m_can device registered (irq=635, version=32)
[    5.578999] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    5.586401] m_can_platform 26a1000.can: m_can device registered (irq=637, version=32)
[    5.595482] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    5.602424] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.608158] virtio_rpmsg_bus virtio4: rpmsg host is online
[    5.615165] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.615202] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.622578] rproc-virtio rproc-virtio.11.auto: registered virtio4 (type 7)
[    5.626827] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
[    5.627115] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
[    5.632997] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.640765] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
[    5.647147] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.656746] platform 41400000.r5f: configured R5F for remoteproc mode
[    5.658715] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.670395] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
[    5.680780] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.686397] remoteproc remoteproc5: 41400000.r5f is available
[    5.693097] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.707688] remoteproc remoteproc5: loading /lib/firmware/j784s4-mcu-r5f0_1-fw failed with error -22
[    5.712916] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.826259] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    5.832297] remoteproc remoteproc5: Direct firmware load for j784s4-mcu-r5f0_1-fw failed with error -22
[    5.844183] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    5.847728] remoteproc remoteproc5: powering up 41400000.r5f
[    5.847773] remoteproc remoteproc5: loading /lib/firmware/j784s4-mcu-r5f0_1-fw failed with error -22
[    5.849750] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    5.853245] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    5.854275] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.854283] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.854301] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.858078] m_can_platform 40528000.can mcu_mcan0: renamed from can0
[    5.862280] remoteproc remoteproc5: Direct firmware load for j784s4-mcu-r5f0_1-fw failed with error -22
[    5.862299] remoteproc remoteproc5: request_firmware failed: -22
[    5.864120] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.868155] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    5.875037] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.924768] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[    5.935197] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.935351] scsi host0: ufshcd
[    5.954821] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[    5.964933] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.965972] m_can_platform 40568000.can mcu_mcan1: renamed from can1
[    5.969070] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1
[    5.971994] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.972870] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.973743] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    5.979549] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.979576] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.989124] xhci-hcd xhci-hcd.12.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
[    6.000100] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.001855] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[    6.005265] xhci-hcd xhci-hcd.12.auto: irq 641, io mem 0x06010000
[    6.013907] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.013922] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    6.020569] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[    6.037792] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[    6.045492] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2
[    6.052827] m_can_platform 26a1000.can main_mcan16: renamed from can2
[    6.057686] xhci-hcd xhci-hcd.12.auto: Host supports USB 3.0 SuperSpeed
[    6.058074] hub 1-0:1.0: USB hub found
[    6.094523] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[    6.098255] hub 1-0:1.0: 1 port detected
[    6.149663] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[    6.151337] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.152124] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.152129] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.152143] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
         Starting Network Time Synchronization...
[    6.320554] hub 2-0:1.0: USB hub found
[    6.329706] hub 2-0:1.0: 1 port detected
[    6.334739] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.340501] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.349570] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Network Time Synchronization.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[    6.536872] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00
[    6.543582] pci_bus 0000:00: root bus resource [bus 00-ff]
[    6.549068] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    6.558629] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[    6.565540] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[    6.568372] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[    6.571544] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    6.571656] pci 0000:00:00.0: supports D1
[    6.594839] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    6.597009] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[  OK  ] Reached target System Initializatio[    6.608710] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
n.
[    6.609710] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[    6.620757] pci 0000:00:00.0: PCI bridge to [bus 01]
[  OK  ] Started Daily Cleanup of Temporary [    6.636531] pcieport 0000:00:00.0: PME: Signaling with IRQ 649
Directories.[    6.648131] pcieport 0000:00:00.0: AER: enabled with IRQ 649
[    6.648830] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.660830] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.660868] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.669875] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    6.677774] j721e-pcie-host 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.684310] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.692089] j721e-pcie-host 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.692100] j721e-pcie-host 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.697825] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.697834] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[  OK  ] Reached target System Time Set.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
         Starting Weston socket...
         Starting D-Bus System Message Bus...
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Listening on Weston socket.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Finished Reboot and dump vmcore via kexec.
[  OK  ] Created slice Slice /system/systemd-fsck.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
         Starting DEMO...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
   [    7.198731] audit: type=1334 audit(1651174221.544:4): prog-id=7 op=LOAD
      Starting Expand the rootfs…ll size of the boot [    7.206926] audit: type=1334 audit(1651174221.552:5): prog-id=8 op=LOAD
device....
[  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
         Starting User Login Management...
[  OK  ] Started TEE Supplicant.
         Starting Telnet Server...
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Found device /dev/mmcblk1p1.
[  OK  ] Started DEMO.
[  OK  ] Reached target Preparation for Network.
         Starting File System Check on /dev/mmcblk1p1...
         Starting Network Configuration...
[  OK  ] Started Telephony service.
[  OK  ] Started User Login Management.
[    7.534546] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.546764] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.553601] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  OK  ] Finished Expand the rootfs…full size of the boot device..
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[    7.590452] Bluetooth: Core ver 2.22
[    7.594148] NET: Registered PF_BLUETOOTH protocol family
[    7.599488] Bluetooth: HCI device and connection manager initialized
[    7.605855] Bluetooth: HCI socket layer initialized
[    7.610735] Bluetooth: L2CAP socket layer initialized
[    7.615799] Bluetooth: SCO socket layer initialized
[  OK  ] Finished File System Check on /dev/mmcblk1p1.
[    7.704875] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0001:00
[    7.711987] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.717492] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    7.727154] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
         Mounting /run/media/BOOT-mmcblk1p1...
[    7.728705] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: Timed out waiting for 41400000.r5f core to power up!
[    7.734063] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
[    7.734070] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    7.734227] pci 0001:00:00.0: supports D1
[    7.738103] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    7.738120] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[    7.751253] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    7.751432] platform 5c00000.r5f: configured R5F for IPC-only mode
[    7.751631] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    7.752474] remoteproc remoteproc6: 5c00000.r5f is available
[    7.752527] remoteproc remoteproc6: attaching to 5c00000.r5f
[    7.752794] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    7.752802] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    7.753279] virtio_rpmsg_bus virtio5: rpmsg host is online
[    7.753292] rproc-virtio rproc-virtio.13.auto: registered virtio5 (type 7)
[    7.753296] remoteproc remoteproc6: remote processor 5c00000.r5f is now attached
[    7.753460] platform 5d00000.r5f: configured R5F for IPC-only mode
[    7.753548] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.753969] remoteproc remoteproc7: 5d00000.r5f is available
[    7.754003] remoteproc remoteproc7: attaching to 5d00000.r5f
[    7.754156] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    7.754162] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.754540] virtio_rpmsg_bus virtio6: rpmsg host is online
[    7.754562] rproc-virtio rproc-virtio.14.auto: registered virtio6 (type 7)
[    7.754565] remoteproc remoteproc7: remote processor 5d00000.r5f is now attached
[    7.755851] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[    7.756437] platform 5e00000.r5f: configured R5F for IPC-only mode
[    7.756655] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
[    7.757622] remoteproc remoteproc8: 5e00000.r5f is available
[    7.757666] remoteproc remoteproc8: attaching to 5e00000.r5f
[    7.757922] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[    7.757930] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
[    7.758364] virtio_rpmsg_bus virtio7: rpmsg host is online
[    7.758378] rproc-virtio rproc-virtio.15.auto: registered virtio7 (type 7)
[    7.758381] remoteproc remoteproc8: remote processor 5e00000.r5f is now attached
[    7.758544] platform 5f00000.r5f: configured R5F for IPC-only mode
[    7.758643] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[    7.758992] remoteproc remoteproc9: 5f00000.r5f is available
[    7.759038] remoteproc remoteproc9: attaching to 5f00000.r5f
[    7.759179] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[    7.759184] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[    7.759612] virtio_rpmsg_bus virtio8: rpmsg host is online
[    7.759626] rproc-virtio rproc-virtio.16.auto: registered virtio8 (type 7)
[    7.759629] remoteproc remoteproc9: remote processor 5f00000.r5f is now attached
[    7.760051] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[    7.761365] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[    7.761849] platform 5900000.r5f: configured R5F for IPC-only mode
[    7.762075] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[    7.762682] remoteproc remoteproc10: 5900000.r5f is available
[    7.762726] remoteproc remoteproc10: attaching to 5900000.r5f
[    7.763004] platform 5900000.r5f: R5F core initialized in IPC-only mode
[    7.763011] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[    7.763492] virtio_rpmsg_bus virtio9: rpmsg host is online
[    7.763511] rproc-virtio rproc-virtio.17.auto: registered virtio9 (type 7)
[    7.763515] remoteproc remoteproc10: remote processor 5900000.r5f is now attached
[    7.763691] platform 5a00000.r5f: configured R5F for IPC-only mode
[    7.763816] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[    7.764323] remoteproc remoteproc11: 5a00000.r5f is available
[    7.764366] remoteproc remoteproc11: attaching to 5a00000.r5f
[    7.764602] platform 5a00000.r5f: R5F core initialized in IPC-only mode
[    7.764609] rproc-virtio rproc-virtio.18.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[    7.764842] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[    7.765339] virtio_rpmsg_bus virtio10: rpmsg host is online
[    7.765355] rproc-virtio rproc-virtio.18.auto: registered virtio10 (type 7)
[    7.765359] remoteproc remoteproc11: remote processor 5a00000.r5f is now attached
[    7.765495] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    7.765518] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    7.765998] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
[    7.767473] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    7.767489] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    7.769549] pci 0001:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[    7.769621] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
[    7.771342] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
[    7.771583] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    7.771856] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    7.772091] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    7.772253] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
[    7.772372] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    7.772586] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[    7.772740] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
[    7.772917] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[    7.773137] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
[    7.773306] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[    7.773560] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    7.773693] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
[    7.773751] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
[    7.773973] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[    7.775660] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[    7.775860] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    7.776519] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    7.782647] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[    7.787094] pci 0001:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[    7.791531] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    7.792991] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    7.799504] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    7.799885] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
[    7.808481] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    7.814155] pci 0001:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[    7.820005] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    7.826513] pci 0001:00:00.0: PCI bridge to [bus 01]
[    7.982382] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x72
[    7.988307] pcieport 0001:00:00.0: PME: Signaling with IRQ 653
[    7.994109] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.ethdevice addr 0x71
[    8.003319] pcieport 0001:00:00.0: AER: enabled with IRQ 653
[    8.008899] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    8.110350] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[    8.113907] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    8.504210] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    8.511108] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    8.521408] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    8.530469] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[  OK  ] Mounted /run/media/BOOT-mmcblk1p1    8.540811] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
0m.
[    8.552714] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: Virt Port: 0, Type: Switch Port, Iface: eth2, Num TX: 2, Num RX: 1, Token: 0
[    8.566049] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: Virt Port: 4, Type: MAC Port, Iface: eth3, Num TX: 1, Num RX: 1, Token: 400
[    8.579881] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    8.585637] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    8.594696] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    8.618186] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: started virt port: 4 on interface eth3
         Starting Network Name Resolution...
[    8.641628] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: started virt port: 0 on interface eth2
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston, a Wayland…ositor, as a system service...
[    9.016328] audit: type=1334 audit(1651174223.360:6): prog-id=9 op=LOAD
[    9.022984] audit: type=1334 audit(1651174223.368:7): prog-id=10 op=LOAD
         Starting User Database Manager...
[  OK  ] Started User Database Manager.
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[    9.264744] audit: type=1006 audit(1651174223.612:8): pid=795 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[    9.277291] audit: type=1300 audit(1651174223.612:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc4fb1778 a2=4 a3=ffffada6a020 items=0 ppid=1 pid=795 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[    9.303779] audit: type=1327 audit(1651174223.612:8): proctitle="(systemd)"
[  OK  ] Finished Synchronize System and HW clocks.
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User wes[    9.757324] audit: type=1006 audit(1651174224.104:9): pid=788 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
ton.
[    9.774183] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
[    9.774219] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[    9.789950] audit: type=1300 audit(1651174224.104:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc4fb1778 a2=4 a3=ffffada6a020 items=0 ppid=1 pid=788 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[    9.816192] audit: type=1327 audit(1651174224.104:9): proctitle="(weston)"
[FAILED] Failed to start Weston, a …mpositor, as a system service.
See 'systemctl status weston.service' for details.
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libeigen-dev
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5sensors-plugins
        libqt5sensors-qmlplugins
        libqt5sensors5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libqt5webchannel-plugins
        libqt5webchannel-qmlplugins
        libqt5webchannel5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started containerd container runtime.
[  OK  ] Finished Print notice about GPLv3 packages.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project j784s4-evm -
Arago 2023.10 j784s4-evm -
j784s4-evm login: [   18.605708] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[   18.611474] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[   18.620523] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[   18.626416] platform main-r5fss-cpsw9g-virt-mac1: deferred probe pending
[   18.633111] platform main-r5fss-cpsw9g-virt-mac0: deferred probe pending
[   18.639801] platform regulator-dp1-prw: deferred probe pending
[   18.645621] platform regulator-dp0-prw: deferred probe pending
[   18.651440] platform dp0-connector: deferred probe pending
[   18.656913] platform a000000.dp-bridge: deferred probe pending
weston service log:
root@j784s4-evm:~# systemctl status weston
x weston.service - Weston, a Wayland compositor, as a system service
     Loaded: loaded (/lib/systemd/system/weston.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Thu 2022-04-28 19:30:24 UTC; 2min 22s ago
TriggeredBy: * weston.socket
       Docs: man:weston(1)
             man:weston.ini(5)
             http://wayland.freedesktop.org/
    Process: 788 ExecStart=/usr/bin/weston --modules=systemd-notify.so (code=exited, status=1/FAILURE)
   Main PID: 788 (code=exited, status=1/FAILURE)
Apr 28 19:30:23 j784s4-evm systemd[1]: Starting Weston, a Wayland compositor, as a system service...
Apr 28 19:30:23 j784s4-evm systemd[788]: pam_unix(weston-autologin:session): session opened for user weston(uid=1000) by weston(uid=0)
Apr 28 19:30:24 j784s4-evm systemd[1]: weston.service: Main process exited, code=exited, status=1/FAILURE
Apr 28 19:30:24 j784s4-evm systemd[1]: weston.service: Failed with result 'exit-code'.
Apr 28 19:30:24 j784s4-evm systemd[1]: Failed to start Weston, a Wayland compositor, as a system service.
no tidss device:
root@j784s4-evm:~# ls /dev | grep -i tidss
root@j784s4-evm:~#
lsmod info:
root@j784s4-evm:~# lsmod
Module                  Size  Used by
overlay               122880  0
pci_endpoint_test      20480  0
ti_cpsw_proxy_client    36864  0
bluetooth             512000  2
ecdh_generic           16384  1 bluetooth
ecc                    36864  1 ecdh_generic
cfg80211              389120  0
rfkill                 24576  3 bluetooth,cfg80211
xhci_plat_hcd          16384  0
rpmsg_ctrl             16384  0
rpmsg_char             16384  1 rpmsg_ctrl
ti_am335x_adc          20480  0
cdns3                  45056  0
kfifo_buf              16384  1 ti_am335x_adc
omap_rng               16384  0
cdns_pltfrm            16384  0
cdns_usb_common        20480  1 cdns3
crct10dif_ce           16384  1
ti_j721e_cpsw_virt_mac    32768  0
wave5                  94208  0
display_connector      16384  0
phy_can_transceiver    16384  3
videobuf2_dma_contig    20480  1 wave5
ti_k3_r5_remoteproc    28672  0
cdns_mhdp8546          40960  0
cdns_dsi               20480  0
videobuf2_memops       16384  1 videobuf2_dma_contig
v4l2_mem2mem           36864  1 wave5
drm_display_helper    139264  1 cdns_mhdp8546
videobuf2_v4l2         32768  2 v4l2_mem2mem,wave5
ti_k3_dsp_remoteproc    16384  0
drm_kms_helper        184320  4 display_connector,cdns_mhdp8546,drm_display_helper,cdns_dsi
videobuf2_common       57344  5 videobuf2_dma_contig,videobuf2_v4l2,v4l2_mem2mem,wave5,videobuf2_memops
syscopyarea            16384  1 drm_kms_helper
virtio_rpmsg_bus       20480  0
m_can_platform         16384  0
pci_j721e_host         16384  0
videodev              245760  4 videobuf2_v4l2,videobuf2_common,v4l2_mem2mem,wave5
sysfillrect            16384  1 drm_kms_helper
rpmsg_ns               16384  1 virtio_rpmsg_bus
ti_am335x_tscadc       16384  1 ti_am335x_adc
k3_j72xx_bandgap       20480  0
ti_k3_common           16384  1 ti_k3_dsp_remoteproc
mc                     57344  4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
sysimgblt              16384  1 drm_kms_helper
pci_j721e              16384  1 pci_j721e_host
ti_j721e_ufs           16384  0
pvrsrvkm             1273856  0
m_can                  24576  1 m_can_platform
fb_sys_fops            16384  1 drm_kms_helper
pcie_cadence_host      16384  1 pci_j721e_host
cdns_dphy              16384  0
cdns_dphy_rx           16384  0
sa2ul                  36864  0
can_dev                36864  1 m_can
pcie_cadence           16384  2 pcie_cadence_host,pci_j721e_host
cdns3_ti               16384  0
optee_rng              16384  0
rng_core               20480  2 optee_rng,omap_rng
rti_wdt                16384  0
cryptodev              53248  0
fuse                  131072  1
drm                   561152  7 drm_kms_helper,display_connector,pvrsrvkm,cdns_mhdp8546,drm_display_helper,cdns_dsi
drm_panel_orientation_quirks    28672  1 drm
ipv6                  479232  56
dmesg:
root@j784s4-evm:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024
[    0.000000] Machine model: Texas Instruments J784S4 EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 48 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@b6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@b6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@b8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8100000, size 5 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@b8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@ba000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000be000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@be000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000be800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@be800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 2048 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 1792 MiB
[    0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000b2603fff]
[    0.000000]   node   0: [mem 0x00000000b2604000-0x00000000b3ffffff]
[    0.000000]   node   0: [mem 0x00000000b4000000-0x00000000b4603fff]
[    0.000000]   node   0: [mem 0x00000000b4604000-0x00000000b5ffffff]
[    0.000000]   node   0: [mem 0x00000000b6000000-0x00000000b6603fff]
[    0.000000]   node   0: [mem 0x00000000b6604000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000b8603fff]
[    0.000000]   node   0: [mem 0x00000000b8604000-0x00000000b9ffffff]
[    0.000000]   node   0: [mem 0x00000000ba000000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000]   node   0: [mem 0x0000000900000000-0x0000000fffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
[    0.000000] pcpu-alloc: s41064 r8192 d32664 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8257536
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=01e2bc61-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 27524696K/33554432K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 4194728K reserved, 1835008K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @93c800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x000000093c050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000093c060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008455] Console: colour dummy device 80x25
[    0.013027] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023698] pid_max: default: 32768 minimum: 301
[    0.028436] LSM: Security Framework initializing
[    0.033251] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.041049] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.050130] cblist_init_generic: Setting adjustable number of callback queues.
[    0.057526] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.063787] cblist_init_generic: Setting adjustable number of callback queues.
[    0.071173] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.077475] rcu: Hierarchical SRCU implementation.
[    0.082373] rcu:     Max phase no-delay instances is 1000.
[    0.087856] Platform MSI: msi-controller@1820000 domain created
[    0.094050] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.103520] EFI services will not be available.
[    0.108346] smp: Bringing up secondary CPUs ...
[    0.121412] Detected PIPT I-cache on CPU1
[    0.121464] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.121477] GICv3: CPU1: using allocated LPI pending table @0x000000093c070000
[    0.121506] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.129952] Detected PIPT I-cache on CPU2
[    0.129994] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[    0.130007] GICv3: CPU2: using allocated LPI pending table @0x000000093c080000
[    0.130029] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[    0.138432] Detected PIPT I-cache on CPU3
[    0.138473] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[    0.138487] GICv3: CPU3: using allocated LPI pending table @0x000000093c090000
[    0.138510] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[    0.146964] Detected PIPT I-cache on CPU4
[    0.147044] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[    0.147058] GICv3: CPU4: using allocated LPI pending table @0x000000093c0a0000
[    0.147090] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[    0.155549] Detected PIPT I-cache on CPU5
[    0.155602] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[    0.155614] GICv3: CPU5: using allocated LPI pending table @0x000000093c0b0000
[    0.155637] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[    0.164067] Detected PIPT I-cache on CPU6
[    0.164120] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[    0.164132] GICv3: CPU6: using allocated LPI pending table @0x000000093c0c0000
[    0.164156] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[    0.172578] Detected PIPT I-cache on CPU7
[    0.172630] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[    0.172643] GICv3: CPU7: using allocated LPI pending table @0x000000093c0d0000
[    0.172666] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[    0.172711] smp: Brought up 1 node, 8 CPUs
[    0.353683] SMP: Total of 8 processors activated.
[    0.358489] CPU features: detected: 32-bit EL0 Support
[    0.363744] CPU features: detected: CRC32 instructions
[    0.369037] CPU: All CPU(s) started at EL2
[    0.373226] alternatives: applying system-wide alternatives
[    0.379866] devtmpfs: initialized
[    0.393279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.403257] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.432389] pinctrl core: initialized pinctrl subsystem
[    0.438034] DMI not present or invalid.
[    0.442281] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.449591] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.457612] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.466333] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.474565] audit: initializing netlink subsys (disabled)
[    0.480182] audit: type=2000 audit(0.340:1): state=initialized audit_enabled=0 res=1
[    0.480376] thermal_sys: Registered thermal governor 'step_wise'
[    0.488100] thermal_sys: Registered thermal governor 'power_allocator'
[    0.494315] cpuidle: using governor menu
[    0.505049] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.512072] ASID allocator initialised with 65536 entries
[    0.525569] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[    0.537665] KASLR disabled due to lack of seed
[    0.544953] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.551902] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.558307] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.565241] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.571644] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.578578] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.584980] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.591914] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.598988] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[    0.608506] iommu: Default domain type: Translated
[    0.613493] iommu: DMA domain TLB invalidation policy: strict mode
[    0.620006] SCSI subsystem initialized
[    0.623906] libata version 3.00 loaded.
[    0.623981] usbcore: registered new interface driver usbfs
[    0.629600] usbcore: registered new interface driver hub
[    0.635039] usbcore: registered new device driver usb
[    0.640389] pps_core: LinuxPPS API ver. 1 registered
[    0.645461] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.654797] PTP clock support registered
[    0.658879] EDAC MC: Ver: 3.0.0
[    0.662556] FPGA manager framework
[    0.666061] Advanced Linux Sound Architecture Driver Initialized.
[    0.672679] clocksource: Switched to clocksource arch_sys_counter
[    0.679020] VFS: Disk quotas dquot_6.6.0
[    0.683046] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.692960] Carveout Heap: Exported 960 MiB at 0x0000000900000000
[    0.699240] NET: Registered PF_INET protocol family
[    0.704631] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.717500] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.726523] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.734452] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.743538] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.751938] TCP: Hash tables configured (established 262144 bind 65536)
[    0.758810] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.766159] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.774025] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.780089] RPC: Registered named UNIX socket transport module.
[    0.786146] RPC: Registered udp transport module.
[    0.790949] RPC: Registered tcp transport module.
[    0.795752] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.802333] NET: Registered PF_XDP protocol family
[    0.807240] PCI: CLS 0 bytes, default 64
[    0.811898] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.821166] Initialise system trusted keyrings
[    0.825828] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.834375] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.840576] NFS: Registering the id_resolver key type
[    0.845750] Key type id_resolver registered
[    0.850022] Key type id_legacy registered
[    0.854141] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.860990] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.887854] Key type asymmetric registered
[    0.892037] Asymmetric key parser 'x509' registered
[    0.897041] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.904678] io scheduler mq-deadline registered
[    0.909306] io scheduler kyber registered
[    0.915601] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.921577] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[    0.927599] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[    0.933798] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[    0.939624] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[    0.945970] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.955400] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.967053] loop: module loaded
[    0.970913] megasas: 07.719.03.00-rc1
[    0.976219] tun: Universal TUN/TAP device driver, 1.6
[    0.981767] VFIO - User Level meta-driver version: 0.3
[    0.987403] usbcore: registered new interface driver usb-storage
[    0.993858] i2c_dev: i2c /dev entries driver
[    0.998794] sdhci: Secure Digital Host Controller Interface driver
[    1.005111] sdhci: Copyright(c) Pierre Ossman
[    1.009684] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.015894] ledtrig-cpu: registered to indicate activity on CPUs
[    1.022131] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.028885] usbcore: registered new interface driver usbhid
[    1.034579] usbhid: USB HID core driver
[    1.039073] optee: probing for conduit method.
[    1.043632] optee: revision 4.1 (012cdca4)
[    1.060027] optee: dynamic shared memory is enabled
[    1.069409] optee: initialized driver
[    1.074157] Initializing XFRM netlink socket
[    1.078538] NET: Registered PF_PACKET protocol family
[    1.083735] Key type dns_resolver registered
[    1.088274] registered taskstats version 1
[    1.092475] Loading compiled-in X.509 certificates
[    1.103174] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
[    1.150859] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz
[    1.157169] pca953x 0-0020: supply vcc not found, using dummy regulator
[    1.163982] pca953x 0-0020: using no AI
[    1.189314] pca953x 0-0022: supply vcc not found, using dummy regulator
[    1.196127] pca953x 0-0022: using AI
[    1.200420] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.206202] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[    1.214735] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[    1.223981] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[    1.232628] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[    1.244635] ti-udma 311a0000.dma-controller: Number of rings: 48
[    1.251853] ti-udma 311a0000.dma-controller: Channels: 48 (bchan: 0, tchan: 16, rchan: 32)
[    1.261498] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[    1.271376] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.278135] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.287035] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[    1.297181] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.303940] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.311793] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 262, base_baud = 6000000) is a 8250
[    1.321196] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 263, base_baud = 3000000) is a 8250
[    1.330046] printk: console [ttyS2] enabled
[    1.338487] printk: bootconsole [ns16550a0] disabled
[    1.388685] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.397918] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.406184] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.419032] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.426240] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.432399] pps pps0: new PPS source ptp0
[    1.436531] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    1.484683] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.493682] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    1.501773] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.514508] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    1.520762] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    1.527880] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[    1.533982] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[    1.544093] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[    1.552829] mmc0: CQHCI version 5.10
[    1.597334] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.688956] mmc0: Command Queue Engine enabled
[    1.693396] mmc0: new HS200 MMC card at address 0001
[    1.698679] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.704253] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    1.709841] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    1.715323] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[    1.843890] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    1.849850] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
[    1.858103] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[    1.864893] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[    1.871660] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[    1.878435] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[    1.885212] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[    1.891982] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[    1.900447] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[    1.910354] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[    1.922086] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.927392] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[    1.935712] 7 fixed-partitions partitions found on MTD device spi0.0
[    1.942056] Creating 7 MTD partitions on "spi0.0":
[    1.946840] 0x000000000000-0x000000100000 : "ospi_nand.tiboot3"
[    1.953754] 0x000000100000-0x000000300000 : "ospi_nand.tispl"
[    1.960715] 0x000000300000-0x000000700000 : "ospi_nand.u-boot"
[    1.968376] 0x000000700000-0x000000740000 : "ospi_nand.env"
[    1.974559] 0x000000740000-0x000000780000 : "ospi_nand.env.backup"
[    1.981324] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[    2.018990] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[    2.027760] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[    2.032851] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[    2.039886] Creating 7 MTD partitions on "47050000.spi.0":
[    2.045357] 0x000000000000-0x000000100000 : "qspi.tiboot3"
[    2.051362] 0x000000100000-0x000000300000 : "qspi.tispl"
[    2.057205] 0x000000300000-0x000000700000 : "qspi.u-boot"
[    2.063093] 0x000000700000-0x000000740000 : "qspi.env"
[    2.068756] 0x000000740000-0x000000780000 : "qspi.env.backup"
[    2.074994] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[    2.080889] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[    2.124687] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.133922] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.142188] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.155039] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.162247] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    2.168389] pps pps0: new PPS source ptp1
[    2.172528] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    2.182407] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    2.228686] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.237769] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    2.245860] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.258605] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    2.264859] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    2.271977] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[    2.278084] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    2.287863] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[    2.295832] mmc1: CQHCI version 5.10
[    2.296131] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present!
[    2.306660] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[    2.313883] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[    2.321580] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[    2.328891] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[    2.336206] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[    2.340268] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.352530] ALSA device list:
[    2.355498]   No soundcards found.
[    2.359086] Waiting for root device PARTUUID=01e2bc61-02...
[    2.415532] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    2.422508] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[    2.431266]  mmcblk1: p1 p2
[    2.870993] EXT4-fs (mmcblk1p2): recovery complete
[    2.876499] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[    2.885043] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    2.899473] devtmpfs: mounted
[    2.903107] Freeing unused kernel memory: 1984K
[    2.907728] Run /sbin/init as init process
[    2.911815]   with arguments:
[    2.911817]     /sbin/init
[    2.911819]   with environment:
[    2.911820]     HOME=/
[    2.911822]     TERM=linux
[    3.051835] systemd[1]: System time before build time, advancing clock.
[    3.088005] NET: Registered PF_INET6 protocol family
[    3.093547] Segment Routing with IPv6
[    3.097225] In-situ OAM (IOAM) with IPv6
[    3.120186] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    3.151743] systemd[1]: Detected architecture arm64.
[    3.207312] systemd[1]: Hostname set to <j784s4-evm>.
[    3.272391] systemd-sysv-generator[194]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    3.402174] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.445966] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.495709] systemd[1]: Queued start job for default target Graphical Interface.
[    3.540473] systemd[1]: Created slice Slice /system/getty.
[    3.561937] systemd[1]: Created slice Slice /system/modprobe.
[    3.585734] systemd[1]: Created slice Slice /system/serial-getty.
[    3.609558] systemd[1]: Created slice User and Session Slice.
[    3.632838] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.656787] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.680839] systemd[1]: Reached target Path Units.
[    3.696745] systemd[1]: Reached target Remote File Systems.
[    3.716728] systemd[1]: Reached target Slice Units.
[    3.732744] systemd[1]: Reached target Swaps.
[    3.778418] systemd[1]: Listening on RPCbind Server Activation Socket.
[    3.804793] systemd[1]: Reached target RPC Port Mapper.
[    3.830479] systemd[1]: Listening on Process Core Dump Socket.
[    3.852842] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.876988] systemd[1]: Listening on Journal Audit Socket.
[    3.896899] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.916916] systemd[1]: Listening on Journal Socket.
[    3.932956] systemd[1]: Listening on Network Service Netlink Socket.
[    3.956958] systemd[1]: Listening on udev Control Socket.
[    3.976847] systemd[1]: Listening on udev Kernel Socket.
[    3.996892] systemd[1]: Listening on User Database Manager Socket.
[    4.036926] systemd[1]: Mounting Huge Pages File System...
[    4.055051] systemd[1]: Mounting POSIX Message Queue File System...
[    4.078896] systemd[1]: Mounting Kernel Debug File System...
[    4.096914] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.114493] systemd[1]: Mounting Temporary Directory /tmp...
[    4.131447] systemd[1]: Starting Create List of Static Device Nodes...
[    4.154745] systemd[1]: Starting Load Kernel Module configfs...
[    4.174843] systemd[1]: Starting Load Kernel Module drm...
[    4.190979] systemd[1]: Starting Load Kernel Module fuse...
[    4.199506] fuse: init (API version 7.37)
[    4.214776] systemd[1]: Starting Start psplash boot splash screen...
[    4.241963] systemd[1]: Starting RPC Bind...
[    4.256873] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    4.272512] systemd[1]: Starting Journal Service...
[    4.295040] systemd[1]: Starting Load Kernel Modules...
[    4.306455] cryptodev: loading out-of-tree module taints kernel.
[    4.313262] cryptodev: driver 1.12 loaded.
[    4.315263] systemd[1]: Starting Generate network units from Kernel command line...
[    4.343284] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.355865] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[    4.367470] systemd[1]: Starting Coldplug All udev Devices...
[    4.389157] systemd[1]: Started RPC Bind.
[    4.405063] systemd[1]: Started Journal Service.
[    4.759328] systemd-journald[215]: Received client request to flush runtime journal.
[    4.995018] audit: type=1334 audit(1651167746.940:2): prog-id=5 op=LOAD
[    5.001755] audit: type=1334 audit(1651167746.948:3): prog-id=6 op=LOAD
[    5.169273] random: crng init done
[    5.199221] CAN device driver interface
[    5.232555] mc: Linux media interface: v0.10
[    5.242946] PVR_K:  280: Device: 4e20000000.gpu
[    5.250332] PVR_K:  280: Read BVNC 36.53.104.796 from HW device registers
[    5.257222] PVR_K:  280: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[    5.260764] videodev: Linux video capture interface: v2.00
[    5.266109] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.274145] [drm] Initialized pvr 23.3.6512818 20170530 for 4e20000000.gpu on minor 0
[    5.279060] j721e-pcie-host 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.291382] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[    5.293687] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[    5.293942] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[    5.295451] j721e-pcie-host 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.299589] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[    5.305380] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[    5.308071] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[    5.310216] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[    5.315657] j721e-pcie-host 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.317794] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    5.318079] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    5.318135] remoteproc remoteproc0: 64800000.dsp is available
[    5.318182] remoteproc remoteproc0: attaching to 64800000.dsp
[    5.318345] remoteproc remoteproc0: unsupported resource 65538
[    5.318434] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    5.318444] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    5.318773] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.318786] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
[    5.318790] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[    5.318794] k3-dsp-rproc 64800000.dsp: register pm nitifiers in remoteproc mode
[    5.319444] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
[    5.319799] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[    5.319848] remoteproc remoteproc1: 65800000.dsp is available
[    5.319887] remoteproc remoteproc1: attaching to 65800000.dsp
[    5.320024] remoteproc remoteproc1: unsupported resource 65538
[    5.320071] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[    5.320079] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
[    5.320375] virtio_rpmsg_bus virtio1: rpmsg host is online
[    5.320388] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
[    5.320392] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
[    5.320395] k3-dsp-rproc 65800000.dsp: register pm nitifiers in remoteproc mode
[    5.322520] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    5.322834] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
[    5.323468] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
[    5.323518] remoteproc remoteproc2: 66800000.dsp is available
[    5.323558] remoteproc remoteproc2: attaching to 66800000.dsp
[    5.323714] remoteproc remoteproc2: unsupported resource 65538
[    5.323770] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
[    5.323777] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
[    5.324088] virtio_rpmsg_bus virtio2: rpmsg host is online
[    5.324104] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
[    5.324108] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
[    5.324111] k3-dsp-rproc 66800000.dsp: register pm nitifiers in remoteproc mode
[    5.324184] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    5.324661] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
[    5.325447] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
[    5.476302] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.482138] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    5.482184] remoteproc remoteproc3: 67800000.dsp is available
[    5.482235] remoteproc remoteproc3: attaching to 67800000.dsp
[    5.482485] remoteproc remoteproc3: unsupported resource 65538
[    5.482589] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
[    5.482602] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
[    5.482910] virtio_rpmsg_bus virtio3: rpmsg host is online
[    5.482931] rproc-virtio rproc-virtio.10.auto: registered virtio3 (type 7)
[    5.482935] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
[    5.482939] k3-dsp-rproc 67800000.dsp: register pm nitifiers in remoteproc mode
[    5.487771] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.487796] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.493694] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    5.516199] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.522929] platform 41000000.r5f: configured R5F for IPC-only mode
[    5.523425] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    5.530408] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.539274] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    5.545673] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.557217] remoteproc remoteproc4: 41000000.r5f is available
[    5.562596] m_can_platform 40528000.can: m_can device registered (irq=634, version=32)
[    5.566954] remoteproc remoteproc4: attaching to 41000000.r5f
[    5.573972] m_can_platform 40568000.can: m_can device registered (irq=635, version=32)
[    5.578999] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    5.586401] m_can_platform 26a1000.can: m_can device registered (irq=637, version=32)
[    5.595482] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    5.602424] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.608158] virtio_rpmsg_bus virtio4: rpmsg host is online
[    5.615165] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.615202] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.622578] rproc-virtio rproc-virtio.11.auto: registered virtio4 (type 7)
[    5.626827] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
[    5.627115] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
[    5.632997] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.640765] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
[    5.647147] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.656746] platform 41400000.r5f: configured R5F for remoteproc mode
[    5.658715] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.670395] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
[    5.680780] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.686397] remoteproc remoteproc5: 41400000.r5f is available
[    5.693097] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.707688] remoteproc remoteproc5: loading /lib/firmware/j784s4-mcu-r5f0_1-fw failed with error -22
[    5.712916] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.826259] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    5.832297] remoteproc remoteproc5: Direct firmware load for j784s4-mcu-r5f0_1-fw failed with error -22
[    5.844183] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    5.847728] remoteproc remoteproc5: powering up 41400000.r5f
[    5.847773] remoteproc remoteproc5: loading /lib/firmware/j784s4-mcu-r5f0_1-fw failed with error -22
[    5.849750] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    5.853245] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    5.854275] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.854283] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.854301] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.858078] m_can_platform 40528000.can mcu_mcan0: renamed from can0
[    5.862280] remoteproc remoteproc5: Direct firmware load for j784s4-mcu-r5f0_1-fw failed with error -22
[    5.862299] remoteproc remoteproc5: request_firmware failed: -22
[    5.864120] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.868155] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    5.875037] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.924768] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[    5.935197] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.935351] scsi host0: ufshcd
[    5.954821] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[    5.964933] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    5.965972] m_can_platform 40568000.can mcu_mcan1: renamed from can1
[    5.969070] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1
[    5.971994] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.972870] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.973743] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    5.979549] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    5.979576] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    5.989124] xhci-hcd xhci-hcd.12.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
[    6.000100] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.001855] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[    6.005265] xhci-hcd xhci-hcd.12.auto: irq 641, io mem 0x06010000
[    6.013907] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.013922] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    6.020569] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[    6.037792] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[    6.045492] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2
[    6.052827] m_can_platform 26a1000.can main_mcan16: renamed from can2
[    6.057686] xhci-hcd xhci-hcd.12.auto: Host supports USB 3.0 SuperSpeed
[    6.058074] hub 1-0:1.0: USB hub found
[    6.094523] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[    6.098255] hub 1-0:1.0: 1 port detected
[    6.149663] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[    6.151337] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.152124] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.152129] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.152143] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    6.320554] hub 2-0:1.0: USB hub found
[    6.329706] hub 2-0:1.0: 1 port detected
[    6.334739] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.340501] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.349570] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    6.536872] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00
[    6.543582] pci_bus 0000:00: root bus resource [bus 00-ff]
[    6.549068] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    6.558629] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[    6.565540] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[    6.568372] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[    6.571544] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    6.571656] pci 0000:00:00.0: supports D1
[    6.594839] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    6.597009] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    6.608710] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    6.609710] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[    6.620757] pci 0000:00:00.0: PCI bridge to [bus 01]
[    6.636531] pcieport 0000:00:00.0: PME: Signaling with IRQ 649
[    6.648131] pcieport 0000:00:00.0: AER: enabled with IRQ 649
[    6.648830] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.660830] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.660868] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.669875] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    6.677774] j721e-pcie-host 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.684310] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    6.692089] j721e-pcie-host 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.692100] j721e-pcie-host 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.697825] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    6.697834] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    7.198731] audit: type=1334 audit(1651174221.544:4): prog-id=7 op=LOAD
[    7.206926] audit: type=1334 audit(1651174221.552:5): prog-id=8 op=LOAD
[    7.534546] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.546764] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.553601] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    7.590452] Bluetooth: Core ver 2.22
[    7.594148] NET: Registered PF_BLUETOOTH protocol family
[    7.599488] Bluetooth: HCI device and connection manager initialized
[    7.605855] Bluetooth: HCI socket layer initialized
[    7.610735] Bluetooth: L2CAP socket layer initialized
[    7.615799] Bluetooth: SCO socket layer initialized
[    7.704875] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0001:00
[    7.711987] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.717492] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    7.727154] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[    7.728705] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: Timed out waiting for 41400000.r5f core to power up!
[    7.734063] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
[    7.734070] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    7.734227] pci 0001:00:00.0: supports D1
[    7.738103] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    7.738120] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[    7.751253] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    7.751432] platform 5c00000.r5f: configured R5F for IPC-only mode
[    7.751631] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    7.752474] remoteproc remoteproc6: 5c00000.r5f is available
[    7.752527] remoteproc remoteproc6: attaching to 5c00000.r5f
[    7.752794] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    7.752802] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    7.753279] virtio_rpmsg_bus virtio5: rpmsg host is online
[    7.753292] rproc-virtio rproc-virtio.13.auto: registered virtio5 (type 7)
[    7.753296] remoteproc remoteproc6: remote processor 5c00000.r5f is now attached
[    7.753460] platform 5d00000.r5f: configured R5F for IPC-only mode
[    7.753548] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.753969] remoteproc remoteproc7: 5d00000.r5f is available
[    7.754003] remoteproc remoteproc7: attaching to 5d00000.r5f
[    7.754156] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    7.754162] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.754540] virtio_rpmsg_bus virtio6: rpmsg host is online
[    7.754562] rproc-virtio rproc-virtio.14.auto: registered virtio6 (type 7)
[    7.754565] remoteproc remoteproc7: remote processor 5d00000.r5f is now attached
[    7.755851] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[    7.756437] platform 5e00000.r5f: configured R5F for IPC-only mode
[    7.756655] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
[    7.757622] remoteproc remoteproc8: 5e00000.r5f is available
[    7.757666] remoteproc remoteproc8: attaching to 5e00000.r5f
[    7.757922] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[    7.757930] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
[    7.758364] virtio_rpmsg_bus virtio7: rpmsg host is online
[    7.758378] rproc-virtio rproc-virtio.15.auto: registered virtio7 (type 7)
[    7.758381] remoteproc remoteproc8: remote processor 5e00000.r5f is now attached
[    7.758544] platform 5f00000.r5f: configured R5F for IPC-only mode
[    7.758643] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[    7.758992] remoteproc remoteproc9: 5f00000.r5f is available
[    7.759038] remoteproc remoteproc9: attaching to 5f00000.r5f
[    7.759179] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[    7.759184] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[    7.759612] virtio_rpmsg_bus virtio8: rpmsg host is online
[    7.759626] rproc-virtio rproc-virtio.16.auto: registered virtio8 (type 7)
[    7.759629] remoteproc remoteproc9: remote processor 5f00000.r5f is now attached
[    7.760051] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[    7.761365] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[    7.761849] platform 5900000.r5f: configured R5F for IPC-only mode
[    7.762075] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[    7.762682] remoteproc remoteproc10: 5900000.r5f is available
[    7.762726] remoteproc remoteproc10: attaching to 5900000.r5f
[    7.763004] platform 5900000.r5f: R5F core initialized in IPC-only mode
[    7.763011] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[    7.763492] virtio_rpmsg_bus virtio9: rpmsg host is online
[    7.763511] rproc-virtio rproc-virtio.17.auto: registered virtio9 (type 7)
[    7.763515] remoteproc remoteproc10: remote processor 5900000.r5f is now attached
[    7.763691] platform 5a00000.r5f: configured R5F for IPC-only mode
[    7.763816] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[    7.764323] remoteproc remoteproc11: 5a00000.r5f is available
[    7.764366] remoteproc remoteproc11: attaching to 5a00000.r5f
[    7.764602] platform 5a00000.r5f: R5F core initialized in IPC-only mode
[    7.764609] rproc-virtio rproc-virtio.18.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[    7.764842] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[    7.765339] virtio_rpmsg_bus virtio10: rpmsg host is online
[    7.765355] rproc-virtio rproc-virtio.18.auto: registered virtio10 (type 7)
[    7.765359] remoteproc remoteproc11: remote processor 5a00000.r5f is now attached
[    7.765495] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    7.765518] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    7.765998] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
[    7.767473] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    7.767489] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    7.769549] pci 0001:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[    7.769621] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
[    7.771342] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
[    7.771583] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    7.771856] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    7.772091] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    7.772253] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
[    7.772372] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    7.772586] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[    7.772740] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
[    7.772917] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[    7.773137] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
[    7.773306] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[    7.773560] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    7.773693] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
[    7.773751] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
[    7.773973] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[    7.775660] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[    7.775860] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    7.776519] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    7.782647] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[    7.787094] pci 0001:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[    7.791531] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    7.792991] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    7.799504] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    7.799885] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
[    7.808481] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    7.814155] pci 0001:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[    7.820005] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    7.826513] pci 0001:00:00.0: PCI bridge to [bus 01]
[    7.982382] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x72
[    7.988307] pcieport 0001:00:00.0: PME: Signaling with IRQ 653
[    7.994109] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.ethdevice addr 0x71
[    8.003319] pcieport 0001:00:00.0: AER: enabled with IRQ 653
[    8.008899] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    8.110350] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[    8.113907] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    8.504210] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    8.511108] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    8.521408] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    8.530469] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    8.540811] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
[    8.552714] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: Virt Port: 0, Type: Switch Port, Iface: eth2, Num TX: 2, Num RX: 1, Token: 0
[    8.566049] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: Virt Port: 4, Type: MAC Port, Iface: eth3, Num TX: 1, Num RX: 1, Token: 400
[    8.579881] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[    8.585637] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[    8.594696] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[    8.618186] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: started virt port: 4 on interface eth3
[    8.641628] ti_cpsw_proxy_client virtio5.ti.ethfw.ethdevice.-1.113: started virt port: 0 on interface eth2
[    9.016328] audit: type=1334 audit(1651174223.360:6): prog-id=9 op=LOAD
[    9.022984] audit: type=1334 audit(1651174223.368:7): prog-id=10 op=LOAD
[    9.264744] audit: type=1006 audit(1651174223.612:8): pid=795 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[    9.277291] audit: type=1300 audit(1651174223.612:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc4fb1778 a2=4 a3=ffffada6a020 items=0 ppid=1 pid=795 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[    9.303779] audit: type=1327 audit(1651174223.612:8): proctitle="(systemd)"
[    9.757324] audit: type=1006 audit(1651174224.104:9): pid=788 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[    9.774183] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
[    9.774219] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[    9.789950] audit: type=1300 audit(1651174224.104:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc4fb1778 a2=4 a3=ffffada6a020 items=0 ppid=1 pid=788 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[    9.816192] audit: type=1327 audit(1651174224.104:9): proctitle="(weston)"
[   18.605708] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[   18.611474] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[   18.620523] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[   18.626416] platform main-r5fss-cpsw9g-virt-mac1: deferred probe pending
[   18.633111] platform main-r5fss-cpsw9g-virt-mac0: deferred probe pending
[   18.639801] platform regulator-dp1-prw: deferred probe pending
[   18.645621] platform regulator-dp0-prw: deferred probe pending
[   18.651440] platform dp0-connector: deferred probe pending
[   18.656913] platform a000000.dp-bridge: deferred probe pending
[  115.401787] audit: type=1006 audit(1651174329.748:10): pid=1180 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[  115.414240] audit: type=1300 audit(1651174329.748:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc4fb1778 a2=1 a3=ffffada6a020 items=0 ppid=1 pid=1180 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[  115.440629] audit: type=1327 audit(1651174329.748:10): proctitle="(systemd)"
[  115.447699] audit: type=1334 audit(1651174329.756:11): prog-id=11 op=LOAD
[  115.454492] audit: type=1300 audit(1651174329.756:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffee1b8bc0 a2=78 a3=0 items=0 ppid=1 pid=1180 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[  115.479917] audit: type=1327 audit(1651174329.756:11): proctitle="(systemd)"
[  115.486958] audit: type=1334 audit(1651174329.760:12): prog-id=11 op=UNLOAD
[  115.493909] audit: type=1334 audit(1651174329.760:13): prog-id=12 op=LOAD
[  115.500686] audit: type=1300 audit(1651174329.760:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffee1b8c60 a2=78 a3=0 items=0 ppid=1 pid=1180 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[  115.526099] audit: type=1327 audit(1651174329.760:13): proctitle="(systemd)"
drm:
root@j784s4-evm:~# ls /dev/dri/
by-path  card0  renderD128
pvr:
root@j784s4-evm:~# pvrdebug
----------------------- Start -----------------------
Connecting to first (0) default pvr device
[  584.496382] PVR_K:  1225: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[  584.513356] PVR_K:  1225: Shader binary image 'rgx.sh.36.53.104.796' loaded
------------------------ End ------------------------
root@j784s4-evm:~#
root@j784s4-evm:~#
root@j784s4-evm:~#
root@j784s4-evm:~# pvr_memory_test
Profiling 4MB block-size transfer (512 times, 2048MB) using 4K-aligned (12) buffer
-------------------- Start tests (+ Memcpy) --------------------
Loop count = 512
CPU(ZeroPg)         -> CPU(ZeroPg)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.292935 seconds = 6991.3Mbytes/sec
CPU(ZeroPg)         -> CPU(Cached)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.290787 seconds = 7043.0Mbytes/sec
CPU(Cached)         -> CPU(Cached)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.491094 seconds = 4170.3Mbytes/sec
CPU(Cached)         -> DEV(Cached)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.496992 seconds = 4120.8Mbytes/sec
CPU(Cached)         -> DEV(Cached) + Flush  started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.834173 seconds = 2455.1Mbytes/sec
DEV(Cached)         -> CPU(Cached)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.488704 seconds = 4190.7Mbytes/sec
CPU(Cached)         -> DEV(Uncached)        started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.494999 seconds = 4137.4Mbytes/sec
DEV(Uncached)       -> CPU(Cached)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.495086 seconds = 4136.7Mbytes/sec
CPU(Cached)         -> DEV(Write-Combined)  started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.509644 seconds = 4018.5Mbytes/sec
DEV(Write-Combined) -> CPU(Cached)          started: Moving 512 blocks of 4194304 bytes = 2048Mbytes per test
                                                took 0.564898 seconds = 3625.4Mbytes/sec
--------------------- End tests ---------------------
Profiling 4MB block-size transfer (16 times, 64MB) using 4K-aligned (12) buffer
Loop count = 16
CPU(ZeroPg)         -> CPU(ZeroPg)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.012435 seconds = 5146.6Mbytes/sec
CPU(ZeroPg)         -> CPU(Cached)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.009407 seconds = 6803.4Mbytes/sec
CPU(Cached)         -> CPU(Cached)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.016210 seconds = 3948.2Mbytes/sec
CPU(Cached)         -> DEV(Cached)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.018285 seconds = 3500.1Mbytes/sec
CPU(Cached)         -> DEV(Cached) + Flush  started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.026284 seconds = 2435.0Mbytes/sec
DEV(Cached)         -> CPU(Cached)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.015926 seconds = 4018.7Mbytes/sec
CPU(Cached)         -> DEV(Uncached)        started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.017807 seconds = 3594.0Mbytes/sec
DEV(Uncached)       -> CPU(Cached)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.015836 seconds = 4041.5Mbytes/sec
CPU(Cached)         -> DEV(Write-Combined)  started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.017897 seconds = 3576.1Mbytes/sec
DEV(Write-Combined) -> CPU(Cached)          started: Moving 16 blocks of 4194304 bytes = 64Mbytes per test
                                                took 0.015788 seconds = 4053.7Mbytes/sec
root@j784s4-evm:~# pvrlogdump
Checking driver state ............... initialised
Checking for debugfs ................ found
Checking for lockdep ................ not found
Checking for ftrace ................. not found
Checking for firmware log groups .... not found
    There are no AppHints enabled in /etc/powervr.ini or in debugfs
    for any of the firmware log groups. Unless 'pvrdebug' tool
    was used for that purpose there will be no information in
    firmware log.
    Please consider enabling some of the firmware log groups
    before the problem occurs.
Dumping data ........................ [  663.116876] PVR_K:  1264: User requested PVR debug info
[  663.122114] PVR_K:  1264: ------------[ PVR DBG: START (High) ]------------
[  663.129069] PVR_K:  1264: OS kernel info: Linux 6.1.80-ti-g2e423244f8c0 #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024 aarch64
[  663.140183] PVR_K:  1264: DDK info: Rogue_DDK_Linux_WS rogueddk 23.3@6512818 (release) j784s4_linux
[  663.149211] PVR_K:  1264: Time now: 663149210us
[  663.153734] PVR_K:  1264: Services State: OK
[  663.157995] PVR_K:  1264: Server Errors: 0
[  663.162086] PVR_K:  1264: Connections Device ID:0(128) P1264-V1264-T1264-pvrdebug
[  663.169554] PVR_K:  1264: ------[ Driver Info ]------
[  663.174595] PVR_K:  1264: Comparison of UM/KM components: MATCHING
[  663.180763] PVR_K:  1264: KM Arch: 64 Bit
[  663.184765] PVR_K:  1264: Driver Mode: Native
[  663.189113] PVR_K:  1264: UM Connected Clients: 64 Bit
[  663.194242] PVR_K:  1264: UM info: 23.3 @  6512818 (release) build options: 0x80000810
[  663.202145] PVR_K:  1264: KM info: 23.3 @  6512818 (release) build options: 0x00000810
[  663.210047] PVR_K:  1264: Window system: lws-generic
[  663.215003] PVR_K:  1264: ------[ Server Thread Summary ]------
[  663.220913] PVR_K:  1264:   pvr_defer_free : Running
[  663.225872] PVR_K:  1264:     Number of deferred cleanup items: QUEUED: 00000  CONNECTION : 00000 MMU : 00000 OSMEM : 00000 PMR : 00000
[  663.238022] PVR_K:  1264:     Number of deferred cleanup items dropped after retry limit reached : 0
[  663.247142] PVR_K:  1264:   pvr_device_wdg : Running
[  663.252127] PVR_K:  1264: Active Threads (UM/KM): 1 / 2
[  663.257345] PVR_K:  1264: Suspended Threads: 0
[  663.261781] PVR_K:  1264: ------[ RGX Device ID:0 Start ]------
[  663.267690] PVR_K:  1264: ------[ RGX Info ]------
[  663.272474] PVR_K:  1264: Device Node (Info): 000000009922bde0 (00000000b51fd110)
[  663.279943] PVR_K:  1264:     DevmemHistoryRecordStats - None
[  663.285680] PVR_K:  1264: RGX BVNC: 36.53.104.796 (rogue)
[  663.291069] PVR_K:  1264: RGX Device State: ACTIVE
[  663.295851] PVR_K:  1264: RGX Power State: OFF
[  663.300286] PVR_K:  1264: RGX Health Status: OK, Reason: NONE
[  663.306021] PVR_K:  1264: FW info: 23.3 @  6512818 (release) build options: 0x80000810
[  663.313922] PVR_K:  1264: TRP: HW support - Yes; SW disabled
[  663.319570] PVR_K:  1264: WGP: HW support - Yes; SW disabled
[  663.325220] PVR_K:  1264: RGX HWR State 0x00000001: HWR OK;
[  663.330784] PVR_K:  1264: RGX FW Power State: RGXFWIF_POW_OFF (APM enabled: 3 ok, 0 denied, 0 non-idle, 1 retry, 0 other, 4 total. Latency: 100 ms)
[  663.343974] PVR_K:  1264: RGX DVFS: 0 frequency changes. Current frequency: 799.997 MHz (sampled at 608283150250 ns). FW frequency: 800.000 MHz.
[  663.356905] PVR_K:  1264: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; Isolation group: 0;  Time Slice*: 0% (0ms); MTS off;
[  663.369063] PVR_K:  1264: RGX Kernel CCB WO:0x8 RO:0x8
[  663.374196] PVR_K:  1264: RGX Firmware CCB WO:0x0 RO:0x0
[  663.379501] PVR_K:  1264: RGX Kernel CCB commands executed = 8
[  663.385323] PVR_K:  1264: RGX SLR: Forced UFO updates requested = 0
[  663.391580] PVR_K:  1264: RGX Errors: WGP:0, TRP:0
[  663.396361] PVR_K:  1264: Thread0: FW IRQ count = 6
[  663.401228] PVR_K:  1264: Last sampled IRQ count in LISR = 6
[  663.406879] PVR_K:  1264: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile;)
[  663.416257] PVR_K:  1264: FW OS config flags = 0x0000000F (Ctx switch: TDM; GEOM; 3D; CDM;)
[  663.424594] PVR_K:  1264:  (!) RGX power is down. No registers dumped
[  663.431023] PVR_K:  1264: ------[ RGX FW Trace Info ]------
[  663.436585] PVR_K:  1264: Debug log type: none
[  663.441019] PVR_K:  1264: RGX FW thread 0: Trace buffer not yet allocated
[  663.447794] PVR_K:  1264: ------[ Full CCB Status ]------
[  663.453187] PVR_K:  1264: ------[ RGX Device ID:0 End ]------
[  663.458922] PVR_K:  1264: ------[ Device ID: 128 - Phys Heaps ]------
[  663.465360] PVR_K:  1264: 0x00000000800819db -> PdMs: SYSMEM, Type: UMA, default, Usage Flags: 0x00000004 (GPU_LOCAL), Refs: 11, Free Size: 29714448384B, Total Size: 30066368512B
[  663.481237] PVR_K:  1264: PMR Zombie Count: 0, PMR Zombie Count In Cleanup: 0
[  663.488362] PVR_K:  1264: PMR Live Count: 21
[  663.492625] PVR_K:  1264: ------[ System Summary Device ID:0 ]------
[  663.498969] PVR_K:  1264: Device System Power State: ON
[  663.504185] PVR_K:  1264: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
[  663.513216] PVR_K:  1264: ------[ AppHint Settings ]------
[  663.518690] PVR_K:  1264:   Build Vars
[  663.522433] PVR_K:  1264:     EnableTrustedDeviceAceConfig: N
[  663.528168] PVR_K:  1264:     CleanupThreadPriority: 0x00000005
[  663.534077] PVR_K:  1264:     WatchdogThreadPriority: 0x00000000
[  663.540073] PVR_K:  1264:     HWPerfClientBufferSize: 0x000c0000
[  663.546068] PVR_K:  1264:     DevmemHistoryBufSizeLog2: 0x0000000b
[  663.552237] PVR_K:  1264:     DevmemHistoryMaxEntries: 0x00002710
[  663.558317] PVR_K:  1264:   Module Params
[  663.562327] PVR_K:  1264:     none
[  663.565720] PVR_K:  1264:   Debug Info Params
[  663.570070] PVR_K:  1264:     none
[  663.573463] PVR_K:  1264:   Debug Info Params Device ID: 0
[  663.578940] PVR_K:  1264:     none
[  663.582336] PVR_K:  1264: ------[ Active Sync Checkpoints ]------
[  663.588420] PVR_K:  1264: (SyncCP Counts: InUse:0 Max:0)
[  663.593723] PVR_K:  1264: ------[ Native Fence Sync: timelines ]------
[  663.600242] PVR_K:  1264: foreign_sync: @0 ctx=1 refs=1
[  663.605457] PVR_K:  1264: ------------[ PVR DBG: END ]------------
done
Archiving data ...................... done
File /tmp/pvrlogdump_j784s4-evm_2204281941.txt.gz was created.
    It seems during your initial boot, there was no GPU drivers loaded. Later, you ran pvr_memory_test successfully, so perhaps weston was waiting on those drivers. Did you try restarting weston?
    systemctl restart weston
    You could also run it from the command line so we can see the logs on the console, and please share those.
    weston &
    Erick
  • Can you also give some details about the rootfs and bootfs that you are using? How was it created?
    Erick
  • Hello
    I have retry restarting weston and use different backend, and it also could not work.
    The result is as follow, please help.
    root@j784s4-evm:~# weston &
    [1] 1195
    root@j784s4-evm:~# Date: 2022-04-28 UTC
    [22:40:00.670] weston 10.0.2
                   https://wayland.freedesktop.org
                   Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
                   Build: 10.0.2
    [22:40:00.670] Command line: weston
    [22:40:00.670] OS: Linux, 6.1.80-ti-g2e423244f8c0, #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024, aarch64
    [22:40:00.670] Flight recorder: enabled
    [22:40:00.671] Starting with no config file.
    [22:40:00.671] Output repaint window is 7 ms maximum.
    [22:40:00.674] Loading module '/usr/lib/libweston-10/wayland-backend.so'
    [22:40:01.360] Error: Failed to retrieve wl_shm from parent Wayland compositor
    [22:40:01.360] fatal: failed to create compositor backend
    [1]+  Done(1)                 weston
    root@j784s4-evm:~# weston --backend=drm-backend.so
    [22:41:08.870] weston 10.0.2
                   Build: 10.0.2
    [22:41:08.870] Command line: weston --backend=drm-backend.so
    [22:41:08.870] OS: Linux, 6.1.80-ti-g2e423244f8c0, #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024, aarch64
    [22:41:08.870] Flight recorder: enabled
    [22:41:08.870] Starting with no config file.
    [22:41:08.871] Output repaint window is 7 ms maximum.
    [22:41:08.871] Loading module '/usr/lib/libweston-10/drm-backend.so'
    [22:41:08.873] initializing drm backend
    [22:41:08.873] Trying logind launcher...
    [22:41:08.874] logind: failed to get session seat
    [22:41:08.874] logind: cannot setup systemd-logind helper error: (No data available), using legacy fallback
    [22:41:08.874] Trying weston_launch launcher...
    [22:41:08.874] could not get launcher fd from env
    [22:41:08.874] Trying direct launcher...
    [22:41:08.874] failed to get VT mode: Inappropriate ioctl for device
    [22:41:08.874] fatal: drm backend should be run using weston-launch binary, or your system should provide the logind D-Bus API.
    [22:41:08.874] fatal: failed to create compositor backend
    Internal warning: debug scope 'drm-backend' has not been destroyed.
    Dean
    I just download ti-processor-sdk-linux-adas-j784s4-evm-09_02_00_05 SDK, and use the ./bin/create-sdcard.sh script to make SD card. And I selected the tisdk-adas-image-j784s4-evm.tar.xz
    u20@DLDZ46LR3:~/ti/ti-processor-sdk-linux-adas-j784s4-evm-09_02_00_05$ ./bin/create-sdcard.sh
    u20@DLDZ46LR3:~/ti/ti-processor-sdk-linux-adas-j784s4-evm-09_02_00_05$ ls filesystem/* -l
    -rw-r--r-- 1 u20 u20 1030943532 Mar 19 21:33 filesystem/tisdk-adas-image-j784s4-evm.tar.xz
    -rw-r--r-- 1 u20 u20   25274840 Apr  4 03:09 filesystem/tisdk-tiny-image-j784s4-evm.tar.xz
  • Zhu,
    Weston should start up automatically if the SD card was correctly created and you have a display connected. Do you have a valid display connected to the EVM? Can you send the output of the following command:
    modetest -M tidss
    Erick
  • Hello Erick
    I run this test and it print no such file or directory. I tried DP0 and DP1, and didn't work, which connected a DELL monitor that resolution is 1920x1080.
    And what is 'valid display'? Could you supply valid display list?
    root@j784s4-evm:~# modetest -M tidss
    failed to open device 'tidss': No such file or directory
    root@j784s4-evm:~#
    Dean
  • Hello Erick
    I found a case that your answered faq-tda4vm-sample-wayland-application-of-opengl-to-run-on-ti-board.
    So I flash this version image ti-processor-sdk-linux-j784s4-evm-08_06_01_02-Linux-x86-Install.bin, and weston could work well with this version, which display a develop board as background.
    I think that my DELL monitor is ok, please check what's the 'bug' with ti-processor-sdk-linux-adas-j784s4-evm-09_02_00_05-Linux-x86-Install.bin.
    Dean
  • Hello Erick
    This version ti-processor-sdk-linux-adas-j784s4-evm-09_01_00_06-Linux-x86-Install.bin also could work well , which display a gray background.
    Please help check what's the 'bug' with ti-processor-sdk-linux-adas-j784s4-evm-09_02_00_05-Linux-x86-Install.bin.
    Dean
  • Zhu,
    Let me run this on my board and see what the issue could be.
    Erick
  • Hello Erick
    Any updates?
    Dean
  • Dean,
    Apologies, I've been trying to acquire the J784S4 EVM to test this, I've got one recently so I'll be giving it a try.
    Erick
    It seems the DisplayPort is not coming up, I see both in your logs as well as mine the issue with the display port bridge:
    [ 18.347146] cdns-mhdp8546 a000000.dp-bridge: invalid resource
    [ 18.352903] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
    [ 18.361947] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
    Let me check with our display team on this issue. It does not seem related to weston, but rather the display port bridge coming up.
    Erick
  • Hi all,
    Most likely, the issue is the same as this thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1355675/processor-sdk-j721e-dp0-crtc0-sync-lost/5182755
    Please refer to the thread for the reason for why weston is not working with adas image, and solution for the issue.
    Takuma
  • Hi
    I am not a BSP engineer. It need modify driver configuration and code, and rebuild BSP code, which is not easy for me. I will use old version.
    Thank Takuma & Erick.
    Dean
