AM625: Enable USB0 in UBOOT
Part Number: AM625
How to enable USB0 in UBOOT?
no matter with default .dts, or copy usb0 configuration from Kernel to UBOOT dts. same result as below I got on AM62-SK-P1
Customer target to use USB0 in UBOOT as Host to support USB-MSC.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0042.k3_2D00_am625_2D00_sk.dts
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0042.k3_2D00_am62_2D00_main.dtsi
U-Boot SPL 2023.04-dirty (Jun 05 2024 - 12:41:56 +0800)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
SPL initial stack usage: 13408 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE: BL31: Built : 16:09:05, Feb 9 2024
U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
SPL initial stack usage: 1856 bytes
U-Boot 2023.04-dirty (Jun 05 2024 - 12:42:42 +0800)
SoC: AM62X SR1.0 HS-FS
Model: Texas Instruments AM625 SK
EEPROM not available at 80, trying to read at 81
Board: AM62B-SKEVM-P1 rev A
DRAM: 2 GiB
Core: 72 devices, 32 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@8000000port@1
=> usb start
starting USB...
Bus usb@31100000: generic_phy_get_bulk : no phys property
Register 1000840 NbrPorts 1
Starting the controller
USB XHCI 1.10
#2. UBOOT dts did not update USB configuration, but it is updated in Kernel dts.
usbss0: dwc3-usb@f900000 {
    compatible = "ti,am62-usb";
     reg = <0x00 0x0f900000 0x00 0x800>,
+   <0x00 0x0f908000 0x00 0x400>;
#3. Insert U flash and power again, found 2 USB devices on usb@31100000, why have 2 on USB1?
=> usb start
starting USB...
Bus usb@31100000: Register 1000840 NbrPorts 1
USB XHCI 1.10
scanning bus usb@31100000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
  • Hi Tony,
    No, please don't touch k3-am62-main.dtsi file.
    why have 2 on USB1?
    '2' means virtual root hub and the usb device.
    Here is the SDK9.2 U-Boot device tree patch for USB0 to be in host mode.
    diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts
    index 823e4320c3c4..4f559dbc2f4d 100644
    --- a/arch/arm/dts/k3-am625-sk.dts
    +++ b/arch/arm/dts/k3-am625-sk.dts
    @@ -569,7 +569,7 @@
     &usb0 {
    -       dr_mode = "peripheral";
    +       dr_mode = "host";
     &usb1 {
    diff --git a/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi b/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi
    index 4265b434168b..9db329975f06 100644
    --- a/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi
    +++ b/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi
    @@ -122,7 +122,7 @@
     &usb0 {
    +       dr_mode = "host";
            /* Since role switching is not supported in U-Boot */
            /delete-property/ extcon;
            bootph-pre-ram;
    Here is the U-Boot boot log in USB MSC boot.
    U-Boot SPL 2023.04-00001-g0f287d63fb2d-dirty (Jun 05 2024 - 11:13:00 -0500)
    Trying to boot from USB
    Bus usb@31000000: Register 1000840 NbrPorts 1
    USB XHCI 1.10
    USB XHCI 1.10
    scanning bus usb@31000000 for devices... 2 USB Device(s) found
    scanning bus usb@31100000 for devices... 1 USB Device(s) found
    U-Boot SPL 2023.04-00001-g0f287d63fb2d-dirty (Jun 05 2024 - 11:13:06 -0500)
    MMC: no card present
    ** Bad device specification mmc 1 **
    Couldn't find partition mmc 1:1
    Error: could not access storage.
    USB XHCI 1.10
    USB XHCI 1.10
    U-Boot 2023.04-00001-g0f287d63fb2d-dirty (Jun 05 2024 - 11:13:06 -0500)
    Board: AM62B-SKEVM rev A
    DRAM:  no bloblist found!2 GiB
    Core:  72 devices, 31 uclasses, devicetree: separate
    In:    serial
    Out:   serial
    Err:   serial
    Hit any key to stop autoboot:  0
  • Bin,
    we don't use USB-MSC boot, just want to use USB-MSC in UBOOT.
    With the patch, same result
    U-Boot 2023.04-dirty (Jun 06 2024 - 11:33:01 +0800)
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    => usb start
    starting USB...
    USB XHCI 1.10
           scanning usb for storage devices... 0 Storage Device(s) found
  • Tony,
    This U-Boot patch makes USB0 in host mode for SD card boot too:
    U-Boot SPL 2023.04-00001-g0f287d63fb2d-dirty (Jun 06 2024 - 10:49:43 -0500)
    U-Boot SPL 2023.04-00001-g0f287d63fb2d-dirty (Jun 06 2024 - 10:49:49 -0500)
    U-Boot 2023.04-00001-g0f287d63fb2d-dirty (Jun 06 2024 - 10:49:49 -0500)
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    => usb start
    starting USB...
    Bus usb@31000000: generic_phy_get_bulk : no phys property
    USB XHCI 1.10
    USB XHCI 1.10
    => usb storage
      Device 0: Vendor: SanDisk  Rev: 1.10 Prod: Cruzer
                Type: Removable Hard Disk
                Capacity: 7633.5 MB = 7.4 GB (15633408 x 512)
    The following commands show USB0 device tree configures it to host mode:
    => fdt addr $fdtcontroladdr
    Working FDT set to fd5e7840
    => fdt print usb0
    usb@31000000 {
            compatible = "snps,dwc3";
            reg = <0x00000000 0x31000000 0x00000000 0x00050000>;
            interrupts = <0x00000000 0x000000bc 0x00000004 0x00000000 0x000000bc 0x00000004>;
            interrupt-names = "host", "peripheral";
            maximum-speed = "high-speed";
            dr_mode = "host";
            bootph-pre-ram;
            phandle = <0x00000071>;
  • Hi Bin,
    My mistake, I modified the k3-am62x-sk-common.dtsi other than k3-am62x-sk-common-u-boot.dtsi file, it works now.
    But I did not find where included the k3-am62x-sk-common-u-boot.dtsi to k3-am625-sk.dts
