SK-AM62-LP: Configuring pinmux for CPSW3G AM62LP
Part Number: SK-AM62-LP
I am trying to configure a pinmux for AM62LP using SysConfig 1.20.0+3587. I am based on MCU PLUS SDK for AM62 09_02_01_06.
I have selected the desired configuration:
Configuration file looks like that:
 * These arguments were used when this file was generated. They will be automatically applied on subsequent loads
 * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
 * @cliArgs --device "AM62x" --package "AMC" --part "Default" --context "a53ss0-0" --product "MCU_PLUS_SDK_AM62x@09.02.01"
 * @versions {"tool":"1.20.0+3587"}
 * Import the modules used in this configuration.
const udma       = scripting.addModule("/drivers/udma/udma", {}, false);
const udma1      = udma.addInstance();
const debug_log  = scripting.addModule("/kernel/dpl/debug_log");
const mmu_armv8  = scripting.addModule("/kernel/dpl/mmu_armv8", {}, false);
const mmu_armv81 = mmu_armv8.addInstance();
const mmu_armv82 = mmu_armv8.addInstance();
 * Write custom configuration values to the imported modules.
udma1.$name = "CONFIG_UDMA0";
debug_log.enableUartLog        = true;
debug_log.uartLog.$name        = "CONFIG_UART_CONSOLE";
debug_log.uartLog.UART.$assign = "USART0";
mmu_armv81.size  = 0x80000000;
mmu_armv81.$name = "SOC_MEM_REGION";
mmu_armv82.vAddr     = 0x80000000;
mmu_armv82.pAddr     = 0x80000000;
mmu_armv82.size      = 0x80000000;
mmu_armv82.attribute = "MAIR7";
mmu_armv82.$name     = "DDR_REGION";
 * These are the reserved peripherals and settings in this configuration
const iCPSW3G1             = scripting.addPeripheral("CPSW3G");
iCPSW3G1.$name             = "MyCPSW3G1";
iCPSW3G1.$assign           = "CP_GEMAC_CPTS0";
iCPSW3G1.HW1TSPUSH.$assign = "SPI0_D0";
iCPSW3G1.HW2TSPUSH.$assign = "SPI0_D1";
iCPSW3G1.RFT_CLK.$assign   = "EXT_REFCLK1";
iCPSW3G1.TS_COMP.$assign   = "SPI0_CS1";
iCPSW3G1.TS_SYNC.$assign   = "SPI0_CLK";
const iMDIO1               = scripting.addPeripheral("MDIO");
iMDIO1.$name               = "MyMDIO1";
iMDIO1.$assign             = "MDIO0";
iMDIO1.MDC.$assign         = "MDIO0_MDC";
iMDIO1.MDIO.$assign        = "MDIO0_MDIO";
const iRGMII1              = scripting.addPeripheral("RGMII");
iRGMII1.$name              = "MyRGMII1";
iRGMII1.RD0.$assign        = "RGMII1_RD0";
iRGMII1.RD1.$assign        = "RGMII1_RD1";
iRGMII1.RD2.$assign        = "RGMII1_RD2";
iRGMII1.RD3.$assign        = "RGMII1_RD3";
iRGMII1.RXC.$assign        = "RGMII1_RXC";
iRGMII1.RX_CTL.$assign     = "RGMII1_RX_CTL";
iRGMII1.TD0.$assign        = "RGMII1_TD0";
iRGMII1.TD1.$assign        = "RGMII1_TD1";
iRGMII1.TD2.$assign        = "RGMII1_TD2";
iRGMII1.TD3.$assign        = "RGMII1_TD3";
iRGMII1.TXC.$assign        = "RGMII1_TXC";
iRGMII1.TX_CTL.$assign     = "RGMII1_TX_CTL";
 * Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
 * version of the tool will not impact the pinmux you originally saw.  These lines can be completely deleted in order to
 * re-solve from scratch.
debug_log.uartLog.UART.RXD.$suggestSolution = "UART0_RXD";
debug_log.uartLog.UART.TXD.$suggestSolution = "UART0_TXD";
iRGMII1.$suggestSolution                    = "RGMII1";
However, generated ti_pinmux_config.c does not reflect my changes:
 *  Copyright (C) 2021 Texas Instruments Incorporated
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * Auto generated file
#include "ti_drivers_config.h"
#include <drivers/pinmux.h>
static Pinmux_PerCfg_t gPinMuxMainDomainCfg[] = {
            /* USART0 pin config */
    /* UART0_RXD -> UART0_RXD (A13) */
        PIN_UART0_RXD,
        ( PIN_MODE(0) | PIN_INPUT_ENABLE | PIN_PULL_DISABLE )
    /* UART0_TXD -> UART0_TXD (E11) */
        PIN_UART0_TXD,
        ( PIN_MODE(0) | PIN_PULL_DISABLE )
    {PINMUX_END, PINMUX_END}
static Pinmux_PerCfg_t gPinMuxMcuDomainCfg[] = {
 * Pinmux
void Pinmux_init(void)
    Pinmux_config(gPinMuxMainDomainCfg, PINMUX_DOMAIN_ID_MAIN);
    Pinmux_config(gPinMuxMcuDomainCfg, PINMUX_DOMAIN_ID_MCU);
What am I missing?
BR
Wojciech Jaśko
