J721EXSOMXEVM: A driver of crypto hardware accelerator for J721E DRA829 supports AES-GCM or not
Part Number: J721EXSOMXEVM
Other Parts Discussed in Thread: DRA829
Hello!
We have some questions about crypto hardware accelerator for J721E DRA829.
1) Crypto API Driver for Linux SDK
Does the following crypto API driver for Linux SDK support AES-GCM ?
We would like to ask this driver can work AES-GCM correctly or not.
https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/08_01_00_07/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Crypto.html
Note: I have gotten cryptodev source code by following steps.
https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/08_06_01_02/exports/docs/linux/Overview_Building_the_SDK.html#build-options
2) A driver in J721E SDK
Does a drive in following J721E SDK support AES-GCM ?
SDK file name:
ti-processor-sdk-rtos-j721e-evm-08_05_00_11.tar.gz
Driver directory Name:
ti-processor-sdk-rtos-j721e-evm-08_05_00_11/pdk_jacinto_08_05_00_36/packages/ti/drv/sa
Thank you very much in advance.
Regards, S.Saito
    https://elixir.bootlin.com/linux/latest/source/drivers/crypto/sa2ul.c
    The Linux driver doesn't support aes-gcm.
    The same is true with rtos.
    Keerthy
  • Hi Keerthy san
    Thank you for your quick response.
    We have just implemented sa2ul driver for hardware acceleration. This driver owns APIs in below URL.
    https://software-dl.ti.com/mcu-plus-sdk/esd/AM64X/09_00_00_35/exports/docs/api_guide_am64x/SECURITY_SA2UL_MODULE_PAGE.html#autotoc_md1912
    Since this driver does not support AES-GCM, we tried to customize it based on SPRUIL3B.pdf, section[3.2.3 GCM Encryption].
    But it looks AES-GCM encryption and decryption does not work as expected.
    Could you answer below questions and let me know ?
    [Questions]
    1) About transfer data to hardware:
    What is correct data our driver must transfer to hardware in AES-GCM case ?
    2) About authentication tag:
    Our driver cannot receive the authentication tag produced by AES-GCM from hardware.
    What do we need to receive it ?
    Details is as below:
    [Steps]
    1)Encrypt input data using AES-GCM
    2)Decrypt ciphertext using AES-GCM
    3)Compare input data with decryption data
    [Result]
    Input data and decryption data do mismatch.
    [ENC]result[0]:53
    [ENC]result[1]:0f
    [ENC]result[2]:8a
    [ENC]result[3]:fb
    [ENC]result[4]:c7
    [ENC]result[5]:45
    [ENC]result[6]:36
    [ENC]result[7]:b9
    [ENC]result[8]:a9
    [ENC]result[9]:63
    [ENC]result[10]:b4
    [ENC]result[11]:f1
    [ENC]result[12]:c4
    [ENC]result[13]:cb
    [ENC]result[14]:73
    [ENC]result[15]:8b
    [Security context data using DMA transfer]
    The following data is transferred from our driver to hardware.
    - start of encryption context
    our driver :0x14610044
    SPRUIL3B.pdf :0x0c610044
    Note:
    Difference!!. When we set 0x0c610044 to this field based on SPRUIL3B.pdf, our driver cannot receive ciphertext from hardware.
    - MCE instructions for GCM
    [0]:88a9fe83
    [1]:997e582e
    [2]:8a907141
    [3]:839d63aa
    [4]:0b7e9a78
    [5]:3aa38b1e
    => same as "Addr N+64B" in section[3.2.3 GCM Encryption] in [SPRUIL3B.pdf]
    - encryption key
    [0]:00000000
    [1]:00000000
    [2]:00000000
    [3]:00000000
    [4]:00000000
    [5]:00000000
    [6]:00000000
    [7]:00000000
    => same as "Addr N+96B:" in above section
    - Aux1
    [0]:dc95c078
    [1]:a2408989
    [2]:ad48a214
    [3]:92842087
    [4]:00000000
    [5]:00000080
    [6]:00000000
    [7]:00000080
    => same as "Addr N+128B:" in above section
    [TX descriptor data]
    Could you please confirm if below data correct or not ?
    [PS Info]
    ps1:02e90000
    ps2:14300010
    ps3:00596272
    [SW info]
    word 0:45000000
    word 1:c048f240
    word 2:10000000
    option[0]:00000000
    option[1]:00000000
    option[2]:00000000
    option[3]:00000080
    option[4]:00000000
    option[5]:00000000
    option[6]:00000000
    option[7]:00000000
    option[8]:00000000
    option[9]:00000000
    option[10]:00000000
    option[11]:00000001
    Regards, S.Saito
  • Hi Saito-san,
    I checked with our team and unfortunately, we do not have the bandwidth from our experts to support addition of new encryption modes, so support will be very limited from TI-side.
    Looking through our Linux driver, I see the following algorithms supported:
    enum sa_algo_id {
    SA_ALG_CBC_AES = 0,
    SA_ALG_EBC_AES,
    SA_ALG_CBC_DES3,
    SA_ALG_ECB_DES3,
    SA_ALG_SHA1,
    SA_ALG_SHA256,
    SA_ALG_SHA512,
    SA_ALG_AUTHENC_SHA1_AES,
    SA_ALG_AUTHENC_SHA256_AES,
    Is it possible to use any of these other encryption methods for your purpose?
    Takuma
