Other Parts Discussed in Thread: TPS65218, AM4372, BQ25890, TPS51632, TAS2764, TPS65090, DP83869, TPS65912, TPA6130A2, TPS65910, ADS7950, CDCE925, LM95241, TVP7002, ADC161S626, SN65DSI83, LM95245, ADS7846, ADC108S102, PCM5102A, TMP117, LP8727, INA238, TMP006, LM63, LMP91000, PCM1681, AMC6821, TLC4541, LM93, LM3639, TLV320AIC23B, TAS5805M, TPD12S015, LM8333, ADS8688, DAC5571, HDC2010, BQ24190, TAS2552, PCM3168A, TMP464, TPS65219, SN65DSI86, DAC7612, AFE4404, TPS65217, ADS131E08, DRV2665, DRV2667, TMP513, DAC082S085, ADS7828, TPS65010, LP3972, LP3971, LM8323, ADC128S052, BQ24257, LM3642, TPS23861, CDCE706, ADS1015, TAS2562, TCA6507, INA3221, LM83, TAS6424, TPS62360, LM80, LM87, THS7303, TLV320AIC23, DAC7311, TPS65086, DAC124S085, DP83TC811, THS8200, TAS2770, TPS65023, LP3943, LM95234, TFP410, TVP5150, TSC2004, TSC2005, OPT3001, TMP401, LM77, LM70, LP3944, LM73, LM3530, INA209, ADS8344, TAS2780, PCF8574, ADC084S021, ADS7871, PCM3060, TSC2046, LMK04832, LM3532, LM3533, BQ24735, TSC2007, TCA8418, PMP, DLPC3433, TWL6040, TAS5086, AFE4403, TMP102, TMP103, ADC128D818, TS3A227E, TMP421, ADS124S08, TMP108, TPIC2810, LM3560, PCM1789, TMP007, BQ25980, TPS65132, LM92, TCA6416, LM90
Hi Expert!
Facing issue for am437x custom HW.
Please find below logs.
U-Boot SPL 2023.04-g999 (Jul 01 2024 - 06:27:59 +0000)
Trying to boot from USB
Bus usb@483d0000: Register 2000440 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@483d0000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
U-Boot 2023.04-g999 (Jul 01 2024 - 06:27:59 +0000)
CPU : AM437X-GP rev 1.2
Model: Carrier Corporation PIC-6.1 V-01
DRAM: 512 MiB
Core: 38 devices, 18 uclasses, devicetree: separate
PMIC: TPS65218
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
Loading Environment from FAT... OK
Net: Could not get PHY for ethernet@4a100000: addr 1602051762
eth2: ethernet@4a100000
Hit any key to stop autoboot: 0
starting USB...
USB XHCI 1.00
Can't set block device
zimage: Bad magic!
=> usb start
=> run usbboot
Device 0: Vendor: SanDisk Rev: 1.00 Prod: Ultra
Type: Removable Hard Disk
Capacity: 58656.0 MB = 57.2 GB (120127488 x 512)
... is now current device
## Error: "loadbootenv" not defined
5218816 bytes read in 149 ms (33.4 MiB/s)
116123 bytes read in 5 ms (22.1 MiB/s)
Booting from USB 0 ***********
Kernel image @ 0x82000000 [ 0x000000 - 0x4fa200 ]
Working FDT set to 88000000
Loading Device Tree to 8ffe0000, end 8ffff59a ... OK
Working FDT set to 8ffe0000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 6.1.33-g40c32565ca (oe-user@oe-host) (arm-oe-linux-gnueabi-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 PREEMPT Thu
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM437x PIC6.1 Default 25-06-2024
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9d000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM437x ES1.2 (sgx neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS4,115200n8 root=/dev/sda2 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 453316K/524288K available (10240K kernel code, 683K rwdata, 3144K rodata, 1024K init, 243K bss, 21820K reserved, 49152K cma-reserved,
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] OMAP L2C310: ROM does not support power control setting
[ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000001] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000023] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000148] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000156] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000465] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000
[ 0.002200] Console: colour dummy device 80x30
[ 0.002276] Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
[ 0.087356] pid_max: default: 32768 minimum: 301
[ 0.087608] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.087632] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.088609] CPU: Testing write buffer coherency: ok
[ 0.088663] CPU0: Spectre v2: using BPIALL workaround
[ 0.089921] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.090111] rcu: Hierarchical SRCU implementation.
[ 0.090119] rcu: Max phase no-delay instances is 1000.
[ 0.090264] EFI services will not be available.
[ 0.090798] devtmpfs: initialized
[ 0.107005] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.107291] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.107319] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.112053] pinctrl core: initialized pinctrl subsystem
[ 0.113033] DMI not present or invalid.
[ 0.113875] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.116519] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.117769] thermal_sys: Registered thermal governor 'fair_share'
[ 0.117783] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.117789] thermal_sys: Registered thermal governor 'step_wise'
[ 0.117793] thermal_sys: Registered thermal governor 'user_space'
[ 0.117887] cpuidle: using governor ladder
[ 0.117915] cpuidle: using governor menu
[ 0.137430] platform display: Fixed dependency cycle(s) with /ocp@44000000/interconnect@48000000/segment@300000/target-module@2a000/dss@0
[ 0.138043] No ATAGs?
[ 0.138062] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.138072] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.152128] iommu: Default domain type: Translated
[ 0.152137] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.154050] SCSI subsystem initialized
[ 0.154297] usbcore: registered new interface driver usbfs
[ 0.154359] usbcore: registered new interface driver hub
[ 0.154411] usbcore: registered new device driver usb
[ 0.154693] mc: Linux media interface: v0.10
[ 0.154729] videodev: Linux video capture interface: v2.00
[ 0.154841] pps_core: LinuxPPS API ver. 1 registered
[ 0.154849] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.154870] PTP clock support registered
[ 0.155166] Advanced Linux Sound Architecture Driver Initialized.
[ 0.156470] clocksource: Switched to clocksource dmtimer
[ 0.165953] NET: Registered PF_INET protocol family
[ 0.166318] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.168040] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.168091] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.168110] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.168152] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.168244] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.168380] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.168417] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.168602] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.169205] RPC: Registered named UNIX socket transport module.
[ 0.169218] RPC: Registered udp transport module.
[ 0.169224] RPC: Registered tcp transport module.
[ 0.169228] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.169242] PCI: CLS 0 bytes, default 64
[ 0.170389] Initialise system trusted keyrings
[ 0.170857] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.175433] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.176620] NFS: Registering the id_resolver key type
[ 0.176699] Key type id_resolver registered
[ 0.176705] Key type id_legacy registered
[ 0.176760] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.177469] Key type asymmetric registered
[ 0.177483] Asymmetric key parser 'x509' registered
[ 0.177614] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.177625] io scheduler mq-deadline registered
[ 0.177633] io scheduler kyber registered
[ 0.234667] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.239354] panel_simple_v1
[ 0.253505] brd: module loaded
[ 0.260435] loop: module loaded
[ 0.263925] CAN device driver interface
[ 0.265750] Warning! fotg210_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 0.265824] SPI driver max3421-hcd has no spi_device_id for maxim,max3421
[ 0.265914] usbcore: registered new interface driver cdc_acm
[ 0.265922] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.265957] usbcore: registered new interface driver usbtmc
[ 0.266016] usbcore: registered new interface driver usb-storage
[ 0.266143] usbcore: registered new interface driver usbtest
[ 0.266296] usbcore: registered new interface driver sisusb
[ 0.266799] i2c_dev: i2c /dev entries driver
[ 0.268321] cpuidle: enable-method property 'ti,am4372' found operations
[ 0.268683] sdhci: Secure Digital Host Controller Interface driver
[ 0.268691] sdhci: Copyright(c) Pierre Ossman
[ 0.268958] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.269446] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.271728] NET: Registered PF_INET6 protocol family
[ 0.273234] Segment Routing with IPv6
[ 0.273306] In-situ OAM (IOAM) with IPv6
[ 0.273410] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.274159] NET: Registered PF_PACKET protocol family
[ 0.274173] can: controller area network core
[ 0.274391] NET: Registered PF_CAN protocol family
[ 0.274661] Key type dns_resolver registered
[ 0.275579] omap_voltage_late_init: Voltage driver support not added
[ 0.276618] Loading compiled-in X.509 certificates
[ 0.312526] pinctrl-single 44e10800.pinmux: 199 pins, size 796
[ 0.316002] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 0.329753] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.332782] ti-sysc: probe of 48040000.target-module failed with error -16
[ 0.343712] gpio gpiochip0: (gpio-0-31): not an immutable chip, please consider fixing it!
[ 0.344162] OMAP GPIO hardware version 0.1
[ 0.347490] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[ 0.347916] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 0.364573] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
[ 0.366016] printk: console [ttyS4] disabled
[ 0.366220] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 61, base_baud = 3000000) is a 8250
[ 1.273405] printk: console [ttyS4] enabled
[ 1.280972] gpio-33 (LCD_PDB): hogged as output/high
[ 1.286012] gpio gpiochip1: (gpio-32-63): not an immutable chip, please consider fixing it!
[ 1.297117] gpio-81 (ADC Enable): hogged as output/high
[ 1.302415] gpio gpiochip2: (gpio-64-95): not an immutable chip, please consider fixing it!
[ 1.323255] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.329679] random: crng init done
[ 1.335385] gpio gpiochip3: (gpio-96-127): not an immutable chip, please consider fixing it!
[ 1.346856] gpio gpiochip4: (gpio-128-159): not an immutable chip, please consider fixing it!
[ 1.360022] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 1.390703] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 1.398777] edma 49000000.dma: TI EDMA DMA engine driver
[ 1.447578] tps65218-pwrbutton: Failed to locate of_node [id: -2]
[ 1.454033] tps65218-gpio: Failed to locate of_node [id: -2]
[ 1.466093] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.473673] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[ 1.481903] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 1.490518] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 1.501313] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 1.527019] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 1.550116] ALSA device list:
[ 1.553125] No soundcards found.
[ 1.606530] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 1.615284] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 1.624937] Waiting for root device /dev/sda2...
[ 1.692847] mmc0: new high speed MMC card at address 0001
[ 1.699768] mmcblk0: mmc0:0001 S0J35A 3.57 GiB
[ 1.713529] mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 >
[ 1.723939] mmcblk0boot0: mmc0:0001 S0J35A 31.5 MiB
[ 1.731172] mmcblk0boot1: mmc0:0001 S0J35A 31.5 MiB
[ 1.738001] mmcblk0rpmb: mmc0:0001 S0J35A 4.00 MiB, chardev (244:0)
[ 1.745080] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 12.007610] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
[ 12.020753] panel-simple display: supply power not found, using dummy regulator
[ 12.028669] panel-simple display: Specify missing connector_type
[ 12.035252] platform 4832a000.dss: deferred probe pending
[ 12.040848] platform 48390000.usb: deferred probe pending
[ 12.046283] platform 483d0000.usb: deferred probe pending
[ 12.051858] platform display: deferred probe pending
After this logs nothing is comming on console.
FYI.. Using 6.1 kernel and U-boot 2023 from SDK 9 version.
Please find DTS and and Defconfig.
Trying USB boot for custom HW.
/dts-v1/; #include "am4372.dtsi" #include <dt-bindings/pinctrl/am43xx.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> / { /* |-R is for release DTS to be used with prod releases */ /* | dd-nn *//*dd - Date & nn-number*/ model = "TI AM437x Default"; compatible = "ti,am437x-pic61","ti,am4372","ti,am43"; chosen { stdout-path = &uart4; }; aliases { display0 = &lcd0; gpio0 = &gpio0; gpio1 = &gpio1; gpio2 = &gpio2; gpio3 = &gpio3; gpio4 = &gpio4; gpio5 = &gpio5; }; memory@80000000 { device_type = "memory"; reg = <0x80000000 0x20000000>; }; evm_v3_3d: fixedregulator-v3_3d { compatible = "regulator-fixed"; regulator-name = "evm_v3_3d"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; enable-active-high; }; pwm7: dmtimer-pwm@7 { compatible = "ti,omap-dmtimer-pwm"; pinctrl-names = "default"; pinctrl-0 = <&timer7_pins>; ti,timers = <&timer7>; #pwm-cells = <3>; }; lcd_bl: backlight { compatible = "pwm-backlight"; pwms = <&pwm7 0 10000 0>; brightness-levels = <0 51 53 56 62 75 101 152 255>; default-brightness-level = <8>; }; panel_reg: panel-regulator { compatible = "regulator-fixed"; regulator-name = "panel-VCC"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; }; lcd0: display { compatible = "carrier,pic6-1-30", "panel-dpi"; label = "lcd"; backlight = <&lcd_bl>; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&leds_pins>; led0 { label = "am437x-pic61:red:heartbeat"; gpios = <&gpio5 4 GPIO_ACTIVE_LOW>; /* Bank 5, pin 4 */ linux,default-trigger = "heartbeat"; default-state = "on"; }; led1 { label = "am437x-pic61:green:stat1"; gpios = <&gpio5 5 GPIO_ACTIVE_LOW>; /* Bank 5, pin 5 */ linux,default-trigger = "none"; default-state = "off"; }; led2 { label = "am437x-pic61:blue:stat1"; gpios = <&gpio5 6 GPIO_ACTIVE_LOW>; /* Bank 5, pin 6 */ linux,default-trigger = "none"; default-state = "off"; }; }; /* fixed 24MHz oscillator */ refclk: oscillator { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; }; /* fixed 32k external oscillator clock */ clk_32k_rtc: clk_32k_rtc { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; }; }; &am43xx_pinmux { pinctrl-names = "default"; //pinctrl-0 = <&adc_pins_default &wlan_pins_default &debugss_pins_default>; // pinctrl-0 = <&wlan_pins_default &debugss_pins_default>; i2c0_pins: i2c0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x988, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */ AM4372_IOPAD(0x98c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */ >; }; cpsw1_default: cpsw1_default { pinctrl-single,pins = < /* Slave 1 */ AM4372_IOPAD(0x90c, PIN_INPUT | MUX_MODE1) /* (B14) mii1_crs.rmii1_crs_dv */ AM4372_IOPAD(0x910, PIN_INPUT | MUX_MODE1) /* (B13) mii1_rx_er.rmii1_rxer */ AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE1) /* (A13) mii1_tx_en.rmii1_txen */ AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE1) /* (B15) mii1_txd0.rmii1_txd0 */ AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE1) /* (A14) mii1_txd1.rmii1_txd1 */ AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE1) /* (F17) mii1_rxd0.rmii1_rxd0 */ AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE1) /* (B16) mii1_rxd1.rmii1_rxd1 */ AM4372_IOPAD(0x944, PIN_INPUT | MUX_MODE0) /* (A16) rmii1_ref_clk.rmii1_refclk */ >; }; cpsw2_default: cpsw2_default { pinctrl-single,pins = < /* Slave 2*/ AM4372_IOPAD(0x864, PIN_INPUT | MUX_MODE8) /* (B4) gpmc_a9.rmii2_crs_dv */ AM4372_IOPAD(0x874, PIN_INPUT | MUX_MODE3) /* (B3) gpmc_wpn.rmii2_rxer */ AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE3) /* (C3) gpmc_a0.rmii2_txen */ AM4372_IOPAD(0x854, PIN_OUTPUT | MUX_MODE3) /* (E7) gpmc_a5.rmii2_txd0 */ AM4372_IOPAD(0x850, PIN_OUTPUT | MUX_MODE3) /* (D7) gpmc_a4.rmii2_txd1 */ AM4372_IOPAD(0x86c, PIN_INPUT | MUX_MODE3) /* (D8) gpmc_a11.rmii2_rxd0 */ AM4372_IOPAD(0x868, PIN_INPUT | MUX_MODE3) /* (G8) gpmc_a10.rmii2_rxd1 */ AM4372_IOPAD(0x908, PIN_INPUT | MUX_MODE1) /* (D16) mii1_col.rmii2_refclk */ >; }; cpsw_sleep: cpsw_sleep { pinctrl-single,pins = < /* Slave 1 reset value */ AM4372_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (B14) mii1_crs.rmii1_crs_dv */ AM4372_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (B13) mii1_rx_er.rmii1_rxer */ AM4372_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A13) mii1_tx_en.rmii1_txen */ AM4372_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (B15) mii1_txd0.rmii1_txd0 */ AM4372_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A14) mii1_txd1.rmii1_txd1 */ AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (F17) mii1_rxd0.rmii1_rxd0 */ AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (B16) mii1_rxd1.rmii1_rxd1 */ AM4372_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A16) rmii1_ref_clk.rmii1_refclk */ /* Slave 2 reset value */ AM4372_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (B4) gpmc_a9.rmii2_crs_dv */ AM4372_IOPAD(0x874, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (B3) gpmc_wpn.rmii2_rxer */ AM4372_IOPAD(0x840, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (C3) gpmc_a0.rmii2_txen */ AM4372_IOPAD(0x854, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (E7) gpmc_a5.rmii2_txd0 */ AM4372_IOPAD(0x850, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (D7) gpmc_a4.rmii2_txd1 */ AM4372_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (D8) gpmc_a11.rmii2_rxd0 */ AM4372_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (G8) gpmc_a10.rmii2_rxd1 */ AM4372_IOPAD(0x908, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (D16) mii1_col.rmii2_refclk */ >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < /* MDIO */ AM4372_IOPAD(0x948, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ AM4372_IOPAD(0x94c, PIN_OUTPUT | MUX_MODE0) /* mdio_clk.mdio_clk */ >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < /* MDIO reset value */ AM4372_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7) AM4372_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; pixcir_ts_pins: pixcir_ts_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa64, PIN_INPUT_PULLUP | MUX_MODE7) /* spi2_d0.gpio3_22 */ >; }; dss_pins: dss_pins { pinctrl-single,pins = < AM4372_IOPAD(0x820, PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 8 -> DSS DATA 23 */ AM4372_IOPAD(0x824, PIN_OUTPUT_PULLUP | MUX_MODE1) AM4372_IOPAD(0x828, PIN_OUTPUT_PULLUP | MUX_MODE1) AM4372_IOPAD(0x82c, PIN_OUTPUT_PULLUP | MUX_MODE1) AM4372_IOPAD(0x830, PIN_OUTPUT_PULLUP | MUX_MODE1) AM4372_IOPAD(0x834, PIN_OUTPUT_PULLUP | MUX_MODE1) AM4372_IOPAD(0x838, PIN_OUTPUT_PULLUP | MUX_MODE1) AM4372_IOPAD(0x83c, PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 15 -> DSS DATA 16 */ AM4372_IOPAD(0x8a0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 0 */ AM4372_IOPAD(0x8a4, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8a8, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8ac, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8b0, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8b4, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8b8, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8bc, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8c0, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8c4, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8c8, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8cc, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8d0, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8d4, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8d8, PIN_OUTPUT_PULLUP | MUX_MODE0) AM4372_IOPAD(0x8dc, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 15 */ AM4372_IOPAD(0x8e0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS VSYNC */ AM4372_IOPAD(0x8e4, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS HSYNC */ AM4372_IOPAD(0x8e8, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS PCLK */ AM4372_IOPAD(0x8ec, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS AC BIAS EN */ >; }; console_pins_default: console_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x91c, PIN_INPUT | MUX_MODE3) /* (C16) mii1_txd3.uart4_rxd */ AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE3) /* (C13) mii1_txd2.uart4_txd */ >; }; console_pins_sleep: console_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0x91c, PIN_INPUT | MUX_MODE7) /* (C16) mii1_txd3.uart4_rxd */ AM4372_IOPAD(0x920, PIN_INPUT | MUX_MODE7) /* (C13) mii1_txd2.uart4_txd */ >; }; uart0_pins_default: uart0_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x970, PIN_INPUT | MUX_MODE0) /* (K25) uart0_rxd.uart0_rxd */ AM4372_IOPAD(0x974, PIN_OUTPUT | MUX_MODE0) /* (J24) uart0_txd.uart0_txd */ AM4372_IOPAD(0x9d0, PIN_OUTPUT | MUX_MODE7) /* (AD24) cam1_data8.uart0_rtsn.gpio4_8 */ //AM4372_IOPAD(0x9d0, PIN_OUTPUT_PULLUP | MUX_MODE8) /* (AD24) cam1_data8.uart0_rtsn */ >; }; uart0_pins_sleep: uart0_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0x970, PIN_INPUT | MUX_MODE7) /* (K25) uart0_rxd.uart0_rxd */ AM4372_IOPAD(0x974, PIN_INPUT | MUX_MODE7) /* (J24) uart0_txd.uart0_txd */ AM4372_IOPAD(0x9d0, PIN_INPUT | MUX_MODE7) /* (AD24) cam1_data8.uart0_rtsn.gpio4_8 */ >; }; uart1_pins_default: uart1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x9e8, PIN_INPUT | MUX_MODE1) /* (AB20) cam1_data0.uart1_rxd */ AM4372_IOPAD(0x9ec, PIN_OUTPUT | MUX_MODE1) /* (AC21) cam1_data1.uart1_txd */ AM4372_IOPAD(0x9f4, PIN_OUTPUT | MUX_MODE7) /* (AE22) cam1_data3.uart1_rtsn.gpio4_17 */ //AM4372_IOPAD(0x9f4, PIN_OUTPUT_PULLUP | MUX_MODE1) /* (AE22) cam1_data3.uart1_rtsn */ >; }; uart1_pins_sleep: uart1_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0x9e8, PIN_INPUT | MUX_MODE7) /* (AB20) cam1_data0.uart1_rxd */ AM4372_IOPAD(0x9ec, PIN_INPUT | MUX_MODE7) /* (AC21) cam1_data1.uart1_txd */ AM4372_IOPAD(0x9f4, PIN_INPUT | MUX_MODE7) /* (AE22) cam1_data3.uart1_rtsn.gpio4_17 */ >; }; uart2_pins_default: uart2_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x9f8, PIN_INPUT | MUX_MODE2) /* (AD22) cam1_data4.uart2_rxd */ AM4372_IOPAD(0x9fc, PIN_OUTPUT | MUX_MODE2) /* (AE23) cam1_data5.uart2_txd */ AM4372_IOPAD(0xa04, PIN_OUTPUT | MUX_MODE7) /* (AE24) cam1_data7.uart2_rtsn.gpio4_21 */ //AM4372_IOPAD(0xa04, PIN_OUTPUT_PULLUP | MUX_MODE2) /* (AE24) cam1_data7.uart2_rtsn */ >; }; uart2_pins_sleep: uart2_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0x9f8, PIN_INPUT | MUX_MODE7) /* (AD22) cam1_data4.uart2_rxd */ AM4372_IOPAD(0x9fc, PIN_INPUT | MUX_MODE7) /* (AE23) cam1_data5.uart2_txd */ AM4372_IOPAD(0xa04, PIN_INPUT | MUX_MODE7) /* (AE24) cam1_data7.uart2_rtsn.gpio4_21 */ >; }; uart3_pins_default: uart3_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0xa28, PIN_INPUT | MUX_MODE0) /* (H25) uart3_rxd.uart3_rxd */ AM4372_IOPAD(0xa2c, PIN_OUTPUT | MUX_MODE0) /* (H24) uart3_txd.uart3_txd */ AM4372_IOPAD(0xa34, PIN_OUTPUT | MUX_MODE7) /* (K24) uart3_rtsn.uart3_rtsn.gpio5_1 */ //AM4372_IOPAD(0xa34, PIN_OUTPUT_PULLUP | MUX_MODE0) /* (K24) uart3_rtsn.uart3_rtsn */ >; }; uart3_pins_sleep: uart3_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0xa28, PIN_INPUT | MUX_MODE7) /* (H25) uart3_rxd.uart3_rxd */ AM4372_IOPAD(0xa2c, PIN_INPUT | MUX_MODE7) /* (H24) uart3_txd.uart3_txd */ AM4372_IOPAD(0xa34, PIN_INPUT | MUX_MODE7) /* (K24) uart3_rtsn.uart3_rtsn.gpio5_1 */ >; }; gpio4_pins_default: gpio4_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x9cc, PIN_INPUT | MUX_MODE7) /* (AC24) cam1_data9.gpio4[7] */ AM4372_IOPAD(0x9d4, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD25) cam1_hd.gpio4[9] */ AM4372_IOPAD(0x9d8, PIN_INPUT | MUX_MODE7) /* (AC23) cam1_vd.gpio4[10] */ AM4372_IOPAD(0x9dc, PIN_INPUT | MUX_MODE7) /* (AE21) cam1_pclk.gpio4[11] */ AM4372_IOPAD(0x9e0, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AC25) cam1_field.gpio4[12] */ AM4372_IOPAD(0x9e4, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AB25) cam1_wen.gpio4[13] */ AM4372_IOPAD(0x9f0, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD21) cam1_data2.gpio4[16] */ AM4372_IOPAD(0xa00, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD23) cam1_data6.gpio4[20] */ AM4372_IOPAD(0xa10, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (Y18) cam0_data2.gpio4[24] */ AM4372_IOPAD(0xa14, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AA18) cam0_data3.gpio4[25] */ AM4372_IOPAD(0xa18, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE19) cam0_data4.gpio4[26] */ AM4372_IOPAD(0xa1c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD19) cam0_data5.gpio4[27] */ AM4372_IOPAD(0xa20, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE20) cam0_data6.gpio4[28] */ AM4372_IOPAD(0xa24, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD20) cam0_data7.gpio4[29] */ >; }; gpio5_pins_default: gpio5_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0xa30, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (H22) uart3_ctsn.gpio5[0] */ //AM4372_IOPAD(0xa50, PIN_INPUT | MUX_MODE7) /* (P25) spi4_sclk.gpio5[4] */ //AM4372_IOPAD(0xa54, PIN_INPUT | MUX_MODE7) /* (R24) spi4_d0.gpio5[5] */ //AM4372_IOPAD(0xa58, PIN_INPUT | MUX_MODE7) /* (P24) spi4_d1.gpio5[6] */ AM4372_IOPAD(0xa5c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (N25) spi4_cs0.gpio5[7] */ AM4372_IOPAD(0xa38, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (D25) gpio5_8.gpio5[8] */ AM4372_IOPAD(0xa3c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (F24) gpio5_9.gpio5[9] */ AM4372_IOPAD(0xa40, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (G20) gpio5_10.gpio5[10] */ AM4372_IOPAD(0xa44, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (F23) gpio5_11.gpio5[11] */ AM4372_IOPAD(0xa48, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (E25) gpio5_12.gpio5[12] */ AM4372_IOPAD(0xa4c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (E24) gpio5_13.gpio5[13] */ AM4372_IOPAD(0xa08, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE18) cam0_data0.gpio5[19] */ AM4372_IOPAD(0xa0c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AB18) cam0_data1.gpio5[20] */ AM4372_IOPAD(0x870, PIN_INPUT_PULLDOWN | MUX_MODE9) /* (A2) gpmc_wait0.gpio5[30] */ >; }; gpio1_pins_default: gpio1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (C5) gpmc_a1.gpio1[17] */ AM4372_IOPAD(0x848, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (C6) gpmc_a2.gpio1[18] */ AM4372_IOPAD(0x84c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A4) gpmc_a3.gpio1[19] */ AM4372_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (E8) gpmc_a6.gpio1[22] */ AM4372_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (F6) gpmc_a7.gpio1[23] */ AM4372_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (F7) gpmc_a8.gpio1[24] */ AM4372_IOPAD(0x878, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A3) gpmc_be1n.gpio1[28] */ //AM4372_IOPAD(0x87c, PIN_INPUT | MUX_MODE7) /* (A8) gpmc_csn0.gpio1[29] */ >; }; gpio2_2_ctp_pins:gpio2_2_ctp_pins { pinctrl-single,pins = < AM4372_IOPAD(0x890, PIN_OUTPUT | MUX_MODE7) /* (A9) gpmc_advn_ale.gpio2[2] CTP_RSTn*/ >; }; gpio2_pins_default: gpio2_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x888, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (B12) gpmc_csn3.gpio2[0] */ AM4372_IOPAD(0x88c, PIN_OUTPUT | MUX_MODE7) /* (A12) gpmc_clk.gpio2[1] */ /* AM4372_IOPAD(0x890, PIN_INPUT | MUX_MODE7) (A9) gpmc_advn_ale.gpio2[2] */ >; }; gpio3_pins_default: gpio3_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x918, PIN_OUTPUT | MUX_MODE7) /* (A15) mii1_rx_dv.gpio3[4] LCD_STANDBY*/ AM4372_IOPAD(0x990, PIN_INPUT | MUX_MODE7) /* (N24) mcasp0_aclkx.gpio3[14] */ AM4372_IOPAD(0x994, PIN_INPUT | MUX_MODE7) /* (N22) mcasp0_fsx.gpio3[15] */ AM4372_IOPAD(0x998, PIN_INPUT | MUX_MODE7) /* (H23) mcasp0_axr0.gpio3[16] */ AM4372_IOPAD(0x99c, PIN_INPUT | MUX_MODE7) /* (M24) mcasp0_ahclkr.gpio3[17] */ AM4372_IOPAD(0x9a0, PIN_INPUT | MUX_MODE7) /* (L23) mcasp0_aclkr.gpio3[18] */ AM4372_IOPAD(0x9a4, PIN_INPUT | MUX_MODE7) /* (K23) mcasp0_fsr.gpio3[19] */ AM4372_IOPAD(0x9a8, PIN_INPUT | MUX_MODE7) /* (M25) mcasp0_axr1.gpio3[20] */ AM4372_IOPAD(0x9ac, PIN_INPUT | MUX_MODE7) /* (L24) mcasp0_ahclkx.gpio3[21] */ //AM4372_IOPAD(0xa68, PIN_INPUT | MUX_MODE7) /* (P20) spi2_d1.gpio3[23] */ //Used by RTC INT AM4372_IOPAD(0xa60, PIN_INPUT | MUX_MODE7) /* (N20) spi2_sclk.gpio3[24] */ AM4372_IOPAD(0xa6c, PIN_INPUT | MUX_MODE7) /* (T23) spi2_cs0.gpio3[25] */ >; }; i2c1_pins: i2c1_pins { pinctrl-single,pins = < AM4372_IOPAD(0x984, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE3) /* uart1_txd.i2c1_scl */ AM4372_IOPAD(0x980, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE3) /* uart1_rxd.i2c1_sda */ >; }; emmc_pins_default: emmc_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x900, PIN_INPUT | MUX_MODE0) /* (D1) mmc0_clk.mmc0_clk */ AM4372_IOPAD(0x904, PIN_INPUT | MUX_MODE0) /* (D2) mmc0_cmd.mmc0_cmd */ AM4372_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) /* (C1) mmc0_dat0.mmc0_dat0 */ AM4372_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) /* (C2) mmc0_dat1.mmc0_dat1 */ AM4372_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) /* (B2) mmc0_dat2.mmc0_dat2 */ AM4372_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) /* (B1) mmc0_dat3.mmc0_dat3 */ AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE3) /* (E16) mii1_rxd2.mmc0_dat4 */ AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE3) /* (C14) mii1_rxd3.mmc0_dat5 */ AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE3) /* (D13) mii1_rx_clk.mmc0_dat6 */ AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE3) /* (D14) mii1_tx_clk.mmc0_dat7 */ >; }; osc1_pins_default: osc1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0xa88, PIN_INPUT | MUX_MODE0) /* (C25) XTALIN.OSC0_IN */ AM4372_IOPAD(0xa8c, PIN_OUTPUT | MUX_MODE0) /* (B25) XTALOUT.OSC0_OUT */ >; }; leds_pins: leds_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa50, PIN_INPUT | MUX_MODE7) /* (P25) spi4_sclk.gpio5[4] */ AM4372_IOPAD(0xa54, PIN_INPUT | MUX_MODE7) /* (R24) spi4_d0.gpio5[5] */ AM4372_IOPAD(0xa58, PIN_INPUT | MUX_MODE7) /* (P24) spi4_d1.gpio5[6] */ >; }; rtc_irq_pin: rtc_irq_pin { pinctrl-single,pins = < AM4372_IOPAD(0xa68, PIN_INPUT | MUX_MODE9) /* (P20) spi2_d1.gpio3[23].gpio0_21 */ >; }; timer7_pins: backlight_pins { pinctrl-single,pins = < AM4372_IOPAD(0x894, PIN_OUTPUT | MUX_MODE2) /* gpmc_oen_ren.gpio2_3 MODE2 */ >; }; wlan_pins_default: wlan_pins_default { pinctrl-single,pins = < //AM4372_IOPAD(0x87c, PIN_INPUT | MUX_MODE7) /* (A8) gpmc_csn0.gpio1[29] Wifi_3_3_EnH*/ AM4372_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE7) /* (A8) gpmc_csn0.gpio1[29] Wifi_3_3_EnH*/ >; }; #if 0 adc_pins_default: adc_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x99c, PIN_OUTPUT_PULLUP | MUX_MODE7) /* (M24) mcasp0_ahclkr.gpio3[17] */ >; }; #endif }; &uart4 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&console_pins_default>; pinctrl-1 = <&console_pins_sleep>; }; &i2c0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; clock-frequency = <400000>; tps65218: tps65218@24 { reg = <0x24>; compatible = "ti,tps65218"; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; dcdc1: regulator-dcdc1 { regulator-name = "vdd_core"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1144000>; regulator-boot-on; regulator-always-on; }; dcdc2: regulator-dcdc2 { regulator-name = "vdd_mpu"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; }; dcdc3: regulator-dcdc3 { regulator-name = "vdcdc3"; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; regulator-state-disk { regulator-off-in-suspend; }; }; dcdc5: regulator-dcdc5 { regulator-name = "v1_0bat"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; dcdc6: regulator-dcdc6 { regulator-name = "v1_8bat"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; ldo1: regulator-ldo1 { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; }; rtc@51 { pinctrl-names = "default"; pinctrl-0 = <&rtc_irq_pin>; compatible = "nxp,pcf85263"; reg = <0x51>; interrupt-names = "INTA"; //quartz-load-capacitance = <PCF85263_QUARTZCAP_12p5pF>; //quartz-drive-strength = <PCF85263_QUARTZDRIVE_HIGH>; status = "okay"; }; }; &i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; clock-frequency = <400000>; core_ee: eeprom@50 { compatible = "atmel,24c256"; reg = <0x50>; pagesize = <0x40>; }; focaltech: focaltech@38 { compatible = "focaltech,fts"; reg = <0x38>; pinctrl-names = "default"; /*vcc_i2c-supply = <&evm_v3_3d>;*/ vdd-supply = <&evm_v3_3d>; pinctrl-0 = <&pixcir_ts_pins>; interrupt-parent = <&gpio3>; /* INT PIN */ interrupts = <22 IRQ_TYPE_EDGE_FALLING>; focaltech,reset-gpio = <&gpio2 2 GPIO_ACTIVE_LOW>; /* RST pin */ focaltech,irq-gpio = <&gpio3 22 IRQ_TYPE_EDGE_FALLING>; /* INT pin */ focaltech,max-touch-number = <5>; focaltech,display-coords = <0 0 1024 600>; /* RESOLUTION */ touchscreen-size-x = <1024>; touchscreen-size-y = <600>; }; }; &gpio1 { pinctrl-names = "default"; pinctrl-0 = <&gpio1_pins_default>; status = "okay"; }; &gpio2 { pinctrl-names = "default"; pinctrl-1 = <&gpio2_pins_default>; status = "okay"; P1 { gpio-hog; gpios = <1 GPIO_ACTIVE_HIGH>; output-high; line-name = "LCD_PDB"; }; }; &gpio3 { pinctrl-names = "default"; pinctrl-1 = <&gpio3_pins_default>; status = "okay"; p17 { gpio-hog; gpios = <17 GPIO_ACTIVE_HIGH>; output-high; line-name = "ADC Enable"; }; }; &gpio4 { pinctrl-names = "default"; pinctrl-0 = <&gpio4_pins_default>; status = "okay"; }; &gpio5 { pinctrl-names = "default"; pinctrl-0 = <&gpio5_pins_default>; status = "okay"; }; &mmc1 { status = "okay"; vmmc-supply = <&evm_v3_3d>; bus-width = <8>; pinctrl-names = "default"; pinctrl-0 = <&emmc_pins_default>; /*cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;*/ }; &usb2_phy1 { status = "okay"; }; &usb1 { dr_mode = "host"; status = "okay"; }; &usb2_phy2 { status = "okay"; }; &usb2 { dr_mode = "host"; status = "okay"; }; &uart0 { compatible = "ti,omap2-uart-pic61"; pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_default>; rs485-rts-delay = <1 1>; rts-gpio = <&gpio4 8 GPIO_ACTIVE_HIGH>; rs485-rts-active-high; linux,rs485-enabled-at-boot-time; clocks = <&dpll_per_m2_div4_ck>; clock-names = "fck"; status = "okay"; }; &uart1 { //compatible = "ti,omap2-uart-pic61"; // this compatibility option is selected for manufacturing compatible = "carrier,ccn0"; // this compatibility option is selected for release - enabled CCN Port driver pinctrl-names = "default"; pinctrl-0 = <&uart1_pins_default>; //rs485-rts-delay = <2 2>; // this compatibility option is selected for manufacturing rs485-rts-delay = <1 1>; // this compatibility option is selected for release - enabled CCN Port driver rts-gpio = <&gpio4 17 GPIO_ACTIVE_HIGH>; rs485-rts-active-high; //linux,rs485-enabled-at-boot-time; // Remove when enabling CCN clocks = <&dpll_per_m2_div4_ck>; clock-names = "fck"; status = "okay"; }; &uart2 { //compatible = "ti,omap2-uart-pic61"; // this compatibility option is selected for manufacturing compatible = "carrier,ccn1"; // this compatibility option is selected for release - enabled LEN Port driver status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart2_pins_default>; //rs485-rts-delay = <2 2>; // this compatibility option is selected for manufacturing rs485-rts-delay = <1 1>; // this compatibility option is selected for release - enabled LEN Port driver rts-gpio = <&gpio4 21 GPIO_ACTIVE_HIGH>; rs485-rts-active-high; //linux,rs485-enabled-at-boot-time; //Remove when enabling LEN clocks = <&dpll_per_m2_div4_ck>; clock-names = "fck"; status = "okay"; }; &uart3 { //compatible = "ti,omap2-uart-pic61"; // this compatibility option is selected for manufacturing compatible = "alc,mstp-cmnet", "alc,mstp-tpi", "ti,omap3-uart-tpi"; // this compatibility option is selected for release - enabled MSTP Port driver pinctrl-names = "default"; pinctrl-0 = <&uart3_pins_default>; //rs485-rts-delay = <2 2>; // this compatibility option is selected for manufacturing rs485-rts-delay = <1 1>; // this compatibility option is selected for release - enabled MSTP Port driver rts-gpio = <&gpio5 1 GPIO_ACTIVE_HIGH>; rs485-rts-active-high; //linux,rs485-enabled-at-boot-time; //Remove when enabling MSTP clocks = <&dpll_per_m2_div4_ck>; clock-names = "fck"; status = "okay"; }; /* Analog inputs */ &tscadc { status = "okay"; adc { compatible = "ti,am3359-adc"; ti,adc-channels = <0 1 2 3>; }; }; &elm { status = "okay"; }; &dss { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&dss_pins>; port { dpi_out: endpoint { remote-endpoint = <&lcd_in>; data-lines = <24>; }; }; }; &cpu { cpu0-supply = <&dcdc2>; }; &timer3 { status = "okay"; }; &timer4 { status = "okay"; }; &timer5 { status = "okay"; }; &timer6 { status = "okay"; }; &timer7 { status = "okay"; }; &timer8 { status = "okay"; };
# # Automatically generated file; DO NOT EDIT. # Linux/arm 6.1.33 Kernel Configuration # CONFIG_CC_VERSION_TEXT="arm-oe-linux-gnueabi-gcc (GCC) 11.3.0" CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=110300 CONFIG_CLANG_VERSION=0 CONFIG_AS_IS_GNU=y CONFIG_AS_VERSION=20244508 CONFIG_LD_IS_BFD=y CONFIG_LD_VERSION=20244508 CONFIG_LLD_VERSION=0 CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y CONFIG_CC_HAS_ASM_INLINE=y CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y CONFIG_PAHOLE_VERSION=0 CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_TABLE_SORT=y CONFIG_THREAD_INFO_IN_TASK=y # # General setup # CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set # CONFIG_WERROR is not set CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_BUILD_SALT="" CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y # CONFIG_KERNEL_GZIP is not set CONFIG_KERNEL_LZMA=y # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_INIT="" CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_WATCH_QUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_GENERIC_MSI_IRQ=y CONFIG_GENERIC_MSI_IRQ_DOMAIN=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set # end of IRQ subsystem CONFIG_GENERIC_IRQ_MULTI_HANDLER=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y CONFIG_CONTEXT_TRACKING=y CONFIG_CONTEXT_TRACKING_IDLE=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y # end of Timers subsystem CONFIG_BPF=y CONFIG_HAVE_EBPF_JIT=y # # BPF subsystem # # CONFIG_BPF_SYSCALL is not set # CONFIG_BPF_JIT is not set # end of BPF subsystem CONFIG_PREEMPT_BUILD=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set CONFIG_BSD_PROCESS_ACCT=y # CONFIG_BSD_PROCESS_ACCT_V3 is not set # CONFIG_TASKSTATS is not set # CONFIG_PSI is not set # end of CPU/Task time and stats accounting # # RCU Subsystem # CONFIG_TREE_RCU=y CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y # end of RCU Subsystem CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_IKHEADERS is not set CONFIG_LOG_BUF_SHIFT=17 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 # CONFIG_PRINTK_INDEX is not set CONFIG_GENERIC_SCHED_CLOCK=y # # Scheduler features # # end of Scheduler features CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5" CONFIG_GCC11_NO_ARRAY_BOUNDS=y CONFIG_CC_NO_ARRAY_BOUNDS=y CONFIG_CGROUPS=y CONFIG_PAGE_COUNTER=y # CONFIG_CGROUP_FAVOR_DYNMODS is not set CONFIG_MEMCG=y CONFIG_MEMCG_KMEM=y CONFIG_BLK_CGROUP=y CONFIG_CGROUP_WRITEBACK=y CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y CONFIG_CFS_BANDWIDTH=y # CONFIG_RT_GROUP_SCHED is not set CONFIG_CGROUP_PIDS=y # CONFIG_CGROUP_RDMA is not set CONFIG_CGROUP_FREEZER=y CONFIG_CGROUP_DEVICE=y CONFIG_CGROUP_CPUACCT=y CONFIG_CGROUP_PERF=y # CONFIG_CGROUP_MISC is not set # CONFIG_CGROUP_DEBUG is not set CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_IPC_NS=y # CONFIG_USER_NS is not set CONFIG_PID_NS=y CONFIG_NET_NS=y CONFIG_CHECKPOINT_RESTORE=y # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_RD_ZSTD=y # CONFIG_BOOT_CONFIG is not set CONFIG_INITRAMFS_PRESERVE_MTIME=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_LD_ORPHAN_WARN=y CONFIG_SYSCTL=y CONFIG_HAVE_UID16=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y CONFIG_FHANDLE=y CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y CONFIG_KCMP=y CONFIG_RSEQ=y # CONFIG_DEBUG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set # end of Kernel Performance Events And Counters CONFIG_SYSTEM_DATA_VERIFICATION=y # CONFIG_PROFILING is not set # end of General setup CONFIG_ARM=y CONFIG_ARM_HAS_GROUP_RELOCS=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_ARCH_HAS_BANDGAP=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 # # System Type # CONFIG_MMU=y CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARCH_MULTIPLATFORM=y # # Platform selection # # # CPU Core family selection # # CONFIG_ARCH_MULTI_V6 is not set CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # end of Platform selection # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_AIROHA is not set # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_ARTPEC is not set # CONFIG_ARCH_ASPEED is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_DIGICOLOR is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_HPE is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MILBEAUT is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_MSTARV7 is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_NPCM is not set CONFIG_ARCH_OMAP=y CONFIG_MACH_OMAP_GENERIC=y # # TI OMAP/AM/DM/DRA Family # # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set # CONFIG_SOC_OMAP5 is not set CONFIG_SOC_AM33XX=y CONFIG_SOC_AM43XX=y # CONFIG_SOC_DRA7XX is not set CONFIG_ARCH_OMAP2PLUS=y # # TI OMAP2/3/4 Specific Features # CONFIG_ARCH_OMAP2PLUS_TYPICAL=y # CONFIG_SOC_HAS_OMAP2_SDRC is not set # # OMAP Legacy Platform Data Board Type # # end of TI OMAP2/3/4 Specific Features # end of TI OMAP/AM/DM/DRA Family # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_RDA is not set # CONFIG_ARCH_REALTEK is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_INTEL_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_STM32 is not set # CONFIG_ARCH_SUNPLUS is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_THUMB_CAPABLE=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set CONFIG_ARM_THUMB=y # CONFIG_ARM_THUMBEE is not set CONFIG_ARM_VIRT_EXT=y # CONFIG_SWP_EMULATE is not set CONFIG_CPU_LITTLE_ENDIAN=y # CONFIG_CPU_BIG_ENDIAN is not set # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_CPU_SPECTRE=y CONFIG_HARDEN_BRANCH_PREDICTOR=y CONFIG_HARDEN_BRANCH_HISTORY=y CONFIG_KUSER_HELPERS=y # CONFIG_VDSO is not set CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y # CONFIG_CACHE_L2X0_PMU is not set # CONFIG_PL310_ERRATA_588369 is not set # CONFIG_PL310_ERRATA_727915 is not set # CONFIG_PL310_ERRATA_753970 is not set # CONFIG_PL310_ERRATA_769419 is not set CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_HEAVY_MB=y CONFIG_DEBUG_ALIGN_RODATA=y # CONFIG_ARM_ERRATA_430973 is not set # CONFIG_ARM_ERRATA_720789 is not set CONFIG_ARM_ERRATA_754322=y # CONFIG_ARM_ERRATA_764319 is not set CONFIG_ARM_ERRATA_775420=y # CONFIG_ARM_ERRATA_773022 is not set # CONFIG_ARM_ERRATA_818325_852422 is not set # CONFIG_ARM_ERRATA_821420 is not set # CONFIG_ARM_ERRATA_825619 is not set # CONFIG_ARM_ERRATA_857271 is not set # CONFIG_ARM_ERRATA_852421 is not set # CONFIG_ARM_ERRATA_852423 is not set # CONFIG_ARM_ERRATA_857272 is not set # end of System Type # # Bus support # # CONFIG_ARM_ERRATA_814220 is not set # end of Bus support # # Kernel Features # CONFIG_HAVE_SMP=y # CONFIG_SMP is not set CONFIG_CURRENT_POINTER_IN_TPIDRURO=y CONFIG_IRQSTACKS=y CONFIG_HAVE_ARM_SCU=y # CONFIG_HAVE_ARM_ARCH_TIMER is not set CONFIG_HAVE_ARM_TWD=y CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_3G_OPT is not set # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 # CONFIG_ARM_PSCI is not set CONFIG_ARCH_NR_GPIO=0 CONFIG_HZ_FIXED=0 CONFIG_HZ_100=y # CONFIG_HZ_200 is not set # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=100 CONFIG_SCHED_HRTICK=y # CONFIG_THUMB2_KERNEL is not set CONFIG_ARM_PATCH_IDIV=y CONFIG_AEABI=y # CONFIG_OABI_COMPAT is not set CONFIG_ARCH_SELECT_MEMORY_MODEL=y CONFIG_ARCH_FLATMEM_ENABLE=y CONFIG_ARCH_SPARSEMEM_ENABLE=y CONFIG_HIGHMEM=y CONFIG_HIGHPTE=y CONFIG_CPU_SW_DOMAIN_PAN=y CONFIG_HW_PERF_EVENTS=y CONFIG_ARM_MODULE_PLTS=y CONFIG_ARCH_FORCE_MAX_ORDER=12 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # CONFIG_XEN is not set CONFIG_STACKPROTECTOR_PER_TASK=y # end of Kernel Features # # Boot options # CONFIG_USE_OF=y CONFIG_ATAGS=y # CONFIG_UNUSED_BOARD_FILES is not set # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_ARM_APPENDED_DTB=y CONFIG_ARM_ATAG_DTB_COMPAT=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set CONFIG_CMDLINE="" CONFIG_KEXEC=y CONFIG_ATAGS_PROC=y # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y CONFIG_EFI_STUB=y CONFIG_EFI=y CONFIG_DMI=y # end of Boot options # # CPU Power Management # # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_ATTR_SET=y CONFIG_CPU_FREQ_GOV_COMMON=y CONFIG_CPU_FREQ_STAT=y # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=y CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y # CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set CONFIG_ARM_TI_CPUFREQ=y # end of CPU Frequency scaling # # CPU Idle # CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y CONFIG_CPU_IDLE_GOV_LADDER=y CONFIG_CPU_IDLE_GOV_MENU=y # CONFIG_CPU_IDLE_GOV_TEO is not set CONFIG_DT_IDLE_STATES=y # # ARM CPU Idle Drivers # CONFIG_ARM_CPUIDLE=y # end of ARM CPU Idle Drivers # end of CPU Idle # end of CPU Power Management # # Floating point emulation # # # At least one emulation must be selected # CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y CONFIG_KERNEL_MODE_NEON=y # end of Floating point emulation # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set # CONFIG_HIBERNATION is not set CONFIG_PM_SLEEP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_USERSPACE_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y CONFIG_PM_DEBUG=y # CONFIG_PM_ADVANCED_DEBUG is not set # CONFIG_PM_TEST_SUSPEND is not set CONFIG_PM_SLEEP_DEBUG=y # CONFIG_DPM_WATCHDOG is not set # CONFIG_APM_EMULATION is not set CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y # end of Power management options CONFIG_AS_VFP_VMRS_FPINST=y # # General architecture-dependent options # CONFIG_CRASH_CORE=y CONFIG_KEXEC_CORE=y # CONFIG_KPROBES is not set CONFIG_JUMP_LABEL=y # CONFIG_STATIC_KEYS_SELFTEST is not set CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_OPTPROBES=y CONFIG_HAVE_NMI=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_KEEPINITRD=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_32BIT_OFF_T=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP=y CONFIG_SECCOMP_FILTER=y # CONFIG_SECCOMP_CACHE_DEBUG is not set CONFIG_HAVE_STACKPROTECTOR=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_LTO_NONE=y CONFIG_HAVE_CONTEXT_TRACKING_USER=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_HAVE_IRQ_EXIT_ON_IRQ_STACK=y CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y CONFIG_SOFTIRQ_ON_OWN_STACK=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_ARCH_MMAP_RND_BITS=8 CONFIG_PAGE_SIZE_LESS_THAN_64KB=y CONFIG_PAGE_SIZE_LESS_THAN_256KB=y CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_HAVE_ARCH_VMAP_STACK=y CONFIG_VMAP_STACK=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y # CONFIG_LOCK_EVENT_COUNTS is not set CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y CONFIG_HAVE_ARCH_PFN_VALID=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y # end of GCOV-based kernel profiling CONFIG_HAVE_GCC_PLUGINS=y CONFIG_GCC_PLUGINS=y # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set CONFIG_GCC_PLUGIN_ARM_SSP_PER_TASK=y # end of General architecture-dependent options CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y # CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set CONFIG_MODVERSIONS=y CONFIG_MODULE_SRCVERSION_ALL=y # CONFIG_MODULE_SIG is not set CONFIG_MODULE_COMPRESS_NONE=y # CONFIG_MODULE_COMPRESS_GZIP is not set # CONFIG_MODULE_COMPRESS_XZ is not set # CONFIG_MODULE_COMPRESS_ZSTD is not set # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set CONFIG_MODPROBE_PATH="/sbin/modprobe" # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_BLOCK_LEGACY_AUTOLOAD=y CONFIG_BLK_DEV_BSG_COMMON=y # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set # CONFIG_BLK_DEV_THROTTLING is not set # CONFIG_BLK_WBT is not set # CONFIG_BLK_CGROUP_IOLATENCY is not set # CONFIG_BLK_CGROUP_IOCOST is not set # CONFIG_BLK_CGROUP_IOPRIO is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # CONFIG_BLK_INLINE_ENCRYPTION is not set # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_AIX_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_ATARI_PARTITION is not set # CONFIG_MAC_PARTITION is not set CONFIG_MSDOS_PARTITION=y # CONFIG_BSD_DISKLABEL is not set # CONFIG_MINIX_SUBPARTITION is not set # CONFIG_SOLARIS_X86_PARTITION is not set # CONFIG_UNIXWARE_DISKLABEL is not set # CONFIG_LDM_PARTITION is not set # CONFIG_SGI_PARTITION is not set # CONFIG_ULTRIX_PARTITION is not set # CONFIG_SUN_PARTITION is not set # CONFIG_KARMA_PARTITION is not set CONFIG_EFI_PARTITION=y # CONFIG_SYSV68_PARTITION is not set CONFIG_CMDLINE_PARTITION=y # end of Partition Types CONFIG_BLK_MQ_PCI=y CONFIG_BLK_MQ_VIRTIO=y CONFIG_BLK_PM=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set # end of IO Schedulers CONFIG_ASN1=y CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y CONFIG_FREEZER=y # # Executable file formats # CONFIG_BINFMT_ELF=y # CONFIG_BINFMT_ELF_FDPIC is not set CONFIG_ELFCORE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y CONFIG_ARCH_HAS_BINFMT_FLAT=y # CONFIG_BINFMT_FLAT is not set CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # end of Executable file formats # # Memory Management options # CONFIG_SWAP=y # CONFIG_ZSWAP is not set # # SLAB allocator options # # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set # CONFIG_SLUB_STATS is not set # end of SLAB allocator options # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set CONFIG_COMPAT_BRK=y CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y # CONFIG_SPARSEMEM_MANUAL is not set CONFIG_FLATMEM=y CONFIG_ARCH_KEEP_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1 # CONFIG_PAGE_REPORTING is not set CONFIG_MIGRATION=y CONFIG_CONTIG_ALLOC=y CONFIG_BOUNCE=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_ARCH_WANT_GENERAL_HUGETLB=y CONFIG_NEED_PER_CPU_KM=y CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set # CONFIG_CMA_SYSFS is not set CONFIG_CMA_AREAS=7 CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y CONFIG_VM_EVENT_COUNTERS=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_TEST is not set CONFIG_KMAP_LOCAL=y CONFIG_KMAP_LOCAL_NON_LINEAR_PTE_ARRAY=y # CONFIG_ANON_VMA_NAME is not set # CONFIG_USERFAULTFD is not set # CONFIG_LRU_GEN is not set # # Data Access Monitoring # # CONFIG_DAMON is not set # end of Data Access Monitoring # end of Memory Management options CONFIG_NET=y CONFIG_NET_INGRESS=y CONFIG_NET_EGRESS=y CONFIG_SKB_EXTENSIONS=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y CONFIG_UNIX_SCM=y CONFIG_AF_UNIX_OOB=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set CONFIG_XFRM=y CONFIG_XFRM_ALGO=m CONFIG_XFRM_USER=m # CONFIG_XFRM_INTERFACE is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_XFRM_AH=m CONFIG_XFRM_ESP=m CONFIG_XFRM_IPCOMP=m CONFIG_NET_KEY=m # CONFIG_NET_KEY_MIGRATE is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_ROUTE_CLASSID=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_NET_IP_TUNNEL=y # CONFIG_IP_MROUTE is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set CONFIG_NET_UDP_TUNNEL=m # CONFIG_NET_FOU is not set # CONFIG_NET_FOU_IP_TUNNELS is not set CONFIG_INET_AH=m CONFIG_INET_ESP=m # CONFIG_INET_ESP_OFFLOAD is not set # CONFIG_INET_ESPINTCP is not set CONFIG_INET_IPCOMP=m CONFIG_INET_TABLE_PERTURB_ORDER=16 CONFIG_INET_XFRM_TUNNEL=m CONFIG_INET_TUNNEL=y CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=y CONFIG_IPV6_ROUTER_PREF=y # CONFIG_IPV6_ROUTE_INFO is not set CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_AH=m CONFIG_INET6_ESP=m # CONFIG_INET6_ESP_OFFLOAD is not set # CONFIG_INET6_ESPINTCP is not set CONFIG_INET6_IPCOMP=m CONFIG_IPV6_MIP6=m # CONFIG_IPV6_ILA is not set CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m # CONFIG_IPV6_VTI is not set CONFIG_IPV6_SIT=y # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y CONFIG_IPV6_TUNNEL=m CONFIG_IPV6_MULTIPLE_TABLES=y # CONFIG_IPV6_SUBTREES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_IPV6_RPL_LWTUNNEL is not set # CONFIG_IPV6_IOAM6_LWTUNNEL is not set # CONFIG_MPTCP is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set CONFIG_NETFILTER=y CONFIG_NETFILTER_ADVANCED=y # CONFIG_BRIDGE_NETFILTER is not set # # Core Netfilter Configuration # CONFIG_NETFILTER_INGRESS=y CONFIG_NETFILTER_EGRESS=y CONFIG_NETFILTER_SKIP_EGRESS=y CONFIG_NETFILTER_FAMILY_BRIDGE=y CONFIG_NETFILTER_FAMILY_ARP=y # CONFIG_NETFILTER_NETLINK_ACCT is not set # CONFIG_NETFILTER_NETLINK_QUEUE is not set # CONFIG_NETFILTER_NETLINK_LOG is not set # CONFIG_NETFILTER_NETLINK_OSF is not set CONFIG_NF_CONNTRACK=m # CONFIG_NF_LOG_SYSLOG is not set # CONFIG_NF_CONNTRACK_MARK is not set # CONFIG_NF_CONNTRACK_ZONES is not set # CONFIG_NF_CONNTRACK_PROCFS is not set # CONFIG_NF_CONNTRACK_EVENTS is not set # CONFIG_NF_CONNTRACK_TIMEOUT is not set # CONFIG_NF_CONNTRACK_TIMESTAMP is not set # CONFIG_NF_CONNTRACK_LABELS is not set CONFIG_NF_CT_PROTO_DCCP=y CONFIG_NF_CT_PROTO_SCTP=y CONFIG_NF_CT_PROTO_UDPLITE=y # CONFIG_NF_CONNTRACK_AMANDA is not set # CONFIG_NF_CONNTRACK_FTP is not set # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set # CONFIG_NF_CONNTRACK_SIP is not set # CONFIG_NF_CONNTRACK_TFTP is not set # CONFIG_NF_CT_NETLINK is not set CONFIG_NF_NAT=m CONFIG_NF_NAT_MASQUERADE=y # CONFIG_NF_TABLES is not set CONFIG_NETFILTER_XTABLES=m # # Xtables combined modules # CONFIG_NETFILTER_XT_MARK=m # CONFIG_NETFILTER_XT_CONNMARK is not set # # Xtables targets # CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set # CONFIG_NETFILTER_XT_TARGET_HMARK is not set CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m # CONFIG_NETFILTER_XT_TARGET_LED is not set # CONFIG_NETFILTER_XT_TARGET_LOG is not set CONFIG_NETFILTER_XT_TARGET_MARK=m CONFIG_NETFILTER_XT_NAT=m # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set # CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m # CONFIG_NETFILTER_XT_TARGET_TEE is not set # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set # # Xtables matches # # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set # CONFIG_NETFILTER_XT_MATCH_BPF is not set # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set CONFIG_NETFILTER_XT_MATCH_COMMENT=m # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set CONFIG_NETFILTER_XT_MATCH_CPU=m # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set # CONFIG_NETFILTER_XT_MATCH_DSCP is not set # CONFIG_NETFILTER_XT_MATCH_ECN is not set # CONFIG_NETFILTER_XT_MATCH_ESP is not set # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_HELPER is not set # CONFIG_NETFILTER_XT_MATCH_HL is not set # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set CONFIG_NETFILTER_XT_MATCH_IPRANGE=m # CONFIG_NETFILTER_XT_MATCH_L2TP is not set CONFIG_NETFILTER_XT_MATCH_LENGTH=m CONFIG_NETFILTER_XT_MATCH_LIMIT=m CONFIG_NETFILTER_XT_MATCH_MAC=m CONFIG_NETFILTER_XT_MATCH_MARK=m CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set # CONFIG_NETFILTER_XT_MATCH_OSF is not set # CONFIG_NETFILTER_XT_MATCH_OWNER is not set CONFIG_NETFILTER_XT_MATCH_POLICY=m CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set # CONFIG_NETFILTER_XT_MATCH_REALM is not set # CONFIG_NETFILTER_XT_MATCH_RECENT is not set CONFIG_NETFILTER_XT_MATCH_SCTP=m # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set # CONFIG_NETFILTER_XT_MATCH_STATE is not set # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set # CONFIG_NETFILTER_XT_MATCH_STRING is not set # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set # CONFIG_NETFILTER_XT_MATCH_TIME is not set # CONFIG_NETFILTER_XT_MATCH_U32 is not set # end of Core Netfilter Configuration # CONFIG_IP_SET is not set # CONFIG_IP_VS is not set # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m # CONFIG_NF_SOCKET_IPV4 is not set # CONFIG_NF_TPROXY_IPV4 is not set # CONFIG_NF_DUP_IPV4 is not set # CONFIG_NF_LOG_ARP is not set # CONFIG_NF_LOG_IPV4 is not set # CONFIG_NF_REJECT_IPV4 is not set CONFIG_IP_NF_IPTABLES=m # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_TTL is not set CONFIG_IP_NF_FILTER=m # CONFIG_IP_NF_TARGET_REJECT is not set # CONFIG_IP_NF_TARGET_SYNPROXY is not set CONFIG_IP_NF_NAT=m CONFIG_IP_NF_TARGET_MASQUERADE=m # CONFIG_IP_NF_TARGET_NETMAP is not set # CONFIG_IP_NF_TARGET_REDIRECT is not set # CONFIG_IP_NF_MANGLE is not set # CONFIG_IP_NF_RAW is not set CONFIG_IP_NF_ARPTABLES=m CONFIG_IP_NF_ARPFILTER=m CONFIG_IP_NF_ARP_MANGLE=m # end of IP: Netfilter Configuration # # IPv6: Netfilter Configuration # # CONFIG_NF_SOCKET_IPV6 is not set # CONFIG_NF_TPROXY_IPV6 is not set # CONFIG_NF_DUP_IPV6 is not set # CONFIG_NF_REJECT_IPV6 is not set # CONFIG_NF_LOG_IPV6 is not set # CONFIG_IP6_NF_IPTABLES is not set # end of IPv6: Netfilter Configuration CONFIG_NF_DEFRAG_IPV6=m # CONFIG_NF_CONNTRACK_BRIDGE is not set CONFIG_BRIDGE_NF_EBTABLES=m CONFIG_BRIDGE_EBT_BROUTE=m CONFIG_BRIDGE_EBT_T_FILTER=m CONFIG_BRIDGE_EBT_T_NAT=m CONFIG_BRIDGE_EBT_802_3=m CONFIG_BRIDGE_EBT_AMONG=m CONFIG_BRIDGE_EBT_ARP=m CONFIG_BRIDGE_EBT_IP=m CONFIG_BRIDGE_EBT_IP6=m CONFIG_BRIDGE_EBT_LIMIT=m CONFIG_BRIDGE_EBT_MARK=m CONFIG_BRIDGE_EBT_PKTTYPE=m CONFIG_BRIDGE_EBT_STP=m CONFIG_BRIDGE_EBT_VLAN=m CONFIG_BRIDGE_EBT_ARPREPLY=m CONFIG_BRIDGE_EBT_DNAT=m CONFIG_BRIDGE_EBT_MARK_T=m CONFIG_BRIDGE_EBT_REDIRECT=m CONFIG_BRIDGE_EBT_SNAT=m CONFIG_BRIDGE_EBT_LOG=m CONFIG_BRIDGE_EBT_NFLOG=m # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set CONFIG_IP_SCTP=m # CONFIG_SCTP_DBG_OBJCNT is not set CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set CONFIG_SCTP_COOKIE_HMAC_MD5=y # CONFIG_SCTP_COOKIE_HMAC_SHA1 is not set CONFIG_INET_SCTP_DIAG=m # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set CONFIG_STP=m CONFIG_BRIDGE=m CONFIG_BRIDGE_IGMP_SNOOPING=y # CONFIG_BRIDGE_VLAN_FILTERING is not set # CONFIG_BRIDGE_MRP is not set # CONFIG_BRIDGE_CFM is not set CONFIG_NET_DSA=m # CONFIG_NET_DSA_TAG_AR9331 is not set # CONFIG_NET_DSA_TAG_BRCM is not set # CONFIG_NET_DSA_TAG_BRCM_LEGACY is not set # CONFIG_NET_DSA_TAG_BRCM_PREPEND is not set # CONFIG_NET_DSA_TAG_HELLCREEK is not set # CONFIG_NET_DSA_TAG_GSWIP is not set # CONFIG_NET_DSA_TAG_DSA is not set # CONFIG_NET_DSA_TAG_EDSA is not set # CONFIG_NET_DSA_TAG_MTK is not set # CONFIG_NET_DSA_TAG_KSZ is not set # CONFIG_NET_DSA_TAG_OCELOT is not set # CONFIG_NET_DSA_TAG_OCELOT_8021Q is not set # CONFIG_NET_DSA_TAG_QCA is not set # CONFIG_NET_DSA_TAG_RTL4_A is not set # CONFIG_NET_DSA_TAG_RTL8_4 is not set # CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set # CONFIG_NET_DSA_TAG_LAN9303 is not set # CONFIG_NET_DSA_TAG_SJA1105 is not set # CONFIG_NET_DSA_TAG_TRAILER is not set # CONFIG_NET_DSA_TAG_XRS700X is not set CONFIG_VLAN_8021Q=m # CONFIG_VLAN_8021Q_GVRP is not set # CONFIG_VLAN_8021Q_MVRP is not set CONFIG_LLC=m # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set CONFIG_NET_SCHED=y # # Queueing/Scheduling # CONFIG_NET_SCH_CBQ=m CONFIG_NET_SCH_HTB=m CONFIG_NET_SCH_HFSC=m CONFIG_NET_SCH_PRIO=m CONFIG_NET_SCH_MULTIQ=m CONFIG_NET_SCH_RED=m CONFIG_NET_SCH_SFB=m CONFIG_NET_SCH_SFQ=m CONFIG_NET_SCH_TEQL=m CONFIG_NET_SCH_TBF=m # CONFIG_NET_SCH_CBS is not set # CONFIG_NET_SCH_ETF is not set # CONFIG_NET_SCH_TAPRIO is not set CONFIG_NET_SCH_GRED=m CONFIG_NET_SCH_DSMARK=m CONFIG_NET_SCH_NETEM=m CONFIG_NET_SCH_DRR=m CONFIG_NET_SCH_MQPRIO=m # CONFIG_NET_SCH_SKBPRIO is not set CONFIG_NET_SCH_CHOKE=m CONFIG_NET_SCH_QFQ=m CONFIG_NET_SCH_CODEL=m CONFIG_NET_SCH_FQ_CODEL=m # CONFIG_NET_SCH_CAKE is not set # CONFIG_NET_SCH_FQ is not set # CONFIG_NET_SCH_HHF is not set # CONFIG_NET_SCH_PIE is not set CONFIG_NET_SCH_INGRESS=m # CONFIG_NET_SCH_PLUG is not set # CONFIG_NET_SCH_ETS is not set # CONFIG_NET_SCH_DEFAULT is not set # # Classification # CONFIG_NET_CLS=y CONFIG_NET_CLS_BASIC=m CONFIG_NET_CLS_ROUTE4=m CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m # CONFIG_CLS_U32_PERF is not set CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_RSVP=m CONFIG_NET_CLS_RSVP6=m CONFIG_NET_CLS_FLOW=m # CONFIG_NET_CLS_CGROUP is not set # CONFIG_NET_CLS_BPF is not set # CONFIG_NET_CLS_FLOWER is not set # CONFIG_NET_CLS_MATCHALL is not set CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_STACK=32 CONFIG_NET_EMATCH_CMP=m CONFIG_NET_EMATCH_NBYTE=m CONFIG_NET_EMATCH_U32=m CONFIG_NET_EMATCH_META=m CONFIG_NET_EMATCH_TEXT=m # CONFIG_NET_EMATCH_CANID is not set # CONFIG_NET_EMATCH_IPT is not set CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=m CONFIG_NET_ACT_GACT=m CONFIG_GACT_PROB=y CONFIG_NET_ACT_MIRRED=m # CONFIG_NET_ACT_SAMPLE is not set CONFIG_NET_ACT_IPT=m CONFIG_NET_ACT_NAT=m CONFIG_NET_ACT_PEDIT=m CONFIG_NET_ACT_SIMP=m CONFIG_NET_ACT_SKBEDIT=m CONFIG_NET_ACT_CSUM=m # CONFIG_NET_ACT_MPLS is not set # CONFIG_NET_ACT_VLAN is not set # CONFIG_NET_ACT_BPF is not set # CONFIG_NET_ACT_SKBMOD is not set # CONFIG_NET_ACT_IFE is not set # CONFIG_NET_ACT_TUNNEL_KEY is not set # CONFIG_NET_ACT_GATE is not set # CONFIG_NET_TC_SKB_EXT is not set CONFIG_NET_SCH_FIFO=y # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set # CONFIG_HSR is not set CONFIG_NET_SWITCHDEV=y # CONFIG_NET_L3_MASTER_DEV is not set # CONFIG_QRTR is not set # CONFIG_NET_NCSI is not set # CONFIG_CGROUP_NET_PRIO is not set # CONFIG_CGROUP_NET_CLASSID is not set CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # # Network testing # # CONFIG_NET_PKTGEN is not set # end of Network testing # end of Networking options # CONFIG_HAMRADIO is not set CONFIG_CAN=y CONFIG_CAN_RAW=m CONFIG_CAN_BCM=m CONFIG_CAN_GW=m # CONFIG_CAN_J1939 is not set # CONFIG_CAN_ISOTP is not set CONFIG_BT=m CONFIG_BT_BREDR=y # CONFIG_BT_RFCOMM is not set # CONFIG_BT_BNEP is not set # CONFIG_BT_HIDP is not set # CONFIG_BT_HS is not set CONFIG_BT_LE=y # CONFIG_BT_LEDS is not set # CONFIG_BT_MSFTEXT is not set # CONFIG_BT_AOSPEXT is not set CONFIG_BT_DEBUGFS=y # CONFIG_BT_SELFTEST is not set # CONFIG_BT_FEATURE_DEBUG is not set # # Bluetooth device drivers # CONFIG_BT_BCM=m # CONFIG_BT_HCIBTUSB is not set # CONFIG_BT_HCIBTSDIO is not set CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_SERDEV=y CONFIG_BT_HCIUART_H4=y # CONFIG_BT_HCIUART_NOKIA is not set # CONFIG_BT_HCIUART_BCSP is not set # CONFIG_BT_HCIUART_ATH3K is not set # CONFIG_BT_HCIUART_LL is not set # CONFIG_BT_HCIUART_3WIRE is not set # CONFIG_BT_HCIUART_INTEL is not set CONFIG_BT_HCIUART_BCM=y # CONFIG_BT_HCIUART_RTL is not set # CONFIG_BT_HCIUART_QCA is not set # CONFIG_BT_HCIUART_AG6XX is not set # CONFIG_BT_HCIUART_MRVL is not set # CONFIG_BT_HCIBCM203X is not set # CONFIG_BT_HCIBPA10X is not set # CONFIG_BT_HCIBFUSB is not set # CONFIG_BT_HCIVHCI is not set CONFIG_BT_MRVL=m CONFIG_BT_MRVL_SDIO=m # CONFIG_BT_MTKSDIO is not set # CONFIG_BT_MTKUART is not set # CONFIG_BT_VIRTIO is not set # end of Bluetooth device drivers # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set # CONFIG_MCTP is not set CONFIG_FIB_RULES=y CONFIG_WIRELESS=y CONFIG_CFG80211=m CONFIG_NL80211_TESTMODE=y # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set # CONFIG_CFG80211_CERTIFICATION_ONUS is not set CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set CONFIG_MAC80211=m CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" # CONFIG_MAC80211_MESH is not set CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 CONFIG_RFKILL=y CONFIG_RFKILL_LEDS=y CONFIG_RFKILL_INPUT=y CONFIG_RFKILL_GPIO=y # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y CONFIG_NET_SELFTESTS=y CONFIG_NET_DEVLINK=y CONFIG_PAGE_POOL=y # CONFIG_PAGE_POOL_STATS is not set CONFIG_FAILOVER=y CONFIG_ETHTOOL_NETLINK=y # # Device Drivers # CONFIG_HAVE_PCI=y CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_DOMAINS_GENERIC=y CONFIG_PCI_SYSCALL=y CONFIG_PCIEPORTBUS=y # CONFIG_PCIEAER is not set CONFIG_PCIEASPM=y CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_POWER_SUPERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCIE_PTM is not set CONFIG_PCI_MSI=y CONFIG_PCI_MSI_IRQ_DOMAIN=y CONFIG_PCI_QUIRKS=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_STUB is not set # CONFIG_PCI_IOV is not set # CONFIG_PCI_PRI is not set # CONFIG_PCI_PASID is not set CONFIG_PCI_LABEL=y # CONFIG_PCIE_BUS_TUNE_OFF is not set CONFIG_PCIE_BUS_DEFAULT=y # CONFIG_PCIE_BUS_SAFE is not set # CONFIG_PCIE_BUS_PERFORMANCE is not set # CONFIG_PCIE_BUS_PEER2PEER is not set # CONFIG_VGA_ARB is not set # CONFIG_HOTPLUG_PCI is not set # # PCI controller drivers # # CONFIG_PCI_FTPCI100 is not set # CONFIG_PCI_HOST_GENERIC is not set # CONFIG_PCIE_XILINX is not set # CONFIG_PCI_V3_SEMI is not set # CONFIG_PCIE_ALTERA is not set # CONFIG_PCIE_MICROCHIP_HOST is not set # # DesignWare PCI Core Support # # CONFIG_PCIE_DW_PLAT_HOST is not set # CONFIG_PCIE_DW_PLAT_EP is not set # CONFIG_PCI_LAYERSCAPE is not set # CONFIG_PCI_LAYERSCAPE_EP is not set # CONFIG_PCI_MESON is not set # end of DesignWare PCI Core Support # # Mobiveil PCIe Core Support # # end of Mobiveil PCIe Core Support # # Cadence PCIe controllers support # # CONFIG_PCIE_CADENCE_PLAT_HOST is not set # CONFIG_PCIE_CADENCE_PLAT_EP is not set # CONFIG_PCI_J721E_HOST is not set # CONFIG_PCI_J721E_EP is not set # end of Cadence PCIe controllers support # end of PCI controller drivers # # PCI Endpoint # CONFIG_PCI_ENDPOINT=y CONFIG_PCI_ENDPOINT_CONFIGFS=y CONFIG_PCI_EPF_TEST=y # CONFIG_PCI_EPF_NTB is not set # end of PCI Endpoint # # PCI switch controller drivers # # CONFIG_PCI_SW_SWITCHTEC is not set # end of PCI switch controller drivers # CONFIG_CXL_BUS is not set # CONFIG_PCCARD is not set # CONFIG_RAPIDIO is not set # # Generic Driver Options # # CONFIG_UEVENT_HELPER is not set CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y # CONFIG_DEVTMPFS_SAFE is not set CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER is not set # CONFIG_FW_LOADER_COMPRESS is not set CONFIG_FW_CACHE=y # CONFIG_FW_UPLOAD is not set # end of Firmware loader CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_GENERIC_CPU_VULNERABILITIES=y CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set # end of Generic Driver Options # # Bus devices # # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_MOXTET is not set CONFIG_OMAP_INTERCONNECT=y CONFIG_OMAP_OCP2SCP=y CONFIG_TI_SYSC=y # CONFIG_VEXPRESS_CONFIG is not set # CONFIG_MHI_BUS is not set # CONFIG_MHI_BUS_EP is not set # end of Bus devices # CONFIG_CONNECTOR is not set # # Firmware Drivers # # # ARM System Control and Management Interface Protocol # # CONFIG_ARM_SCMI_PROTOCOL is not set # end of ARM System Control and Management Interface Protocol # CONFIG_FIRMWARE_MEMMAP is not set # CONFIG_DMIID is not set # CONFIG_DMI_SYSFS is not set # CONFIG_FW_CFG_SYSFS is not set # CONFIG_SYSFB_SIMPLEFB is not set # CONFIG_TRUSTED_FOUNDATIONS is not set # CONFIG_GOOGLE_FIRMWARE is not set # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_ESRT=y CONFIG_EFI_VARS_PSTORE=y # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_GENERIC_STUB=y CONFIG_EFI_ARMSTUB_DTB_LOADER=y # CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set # CONFIG_EFI_BOOTLOADER_CONTROL is not set CONFIG_EFI_CAPSULE_LOADER=m # CONFIG_EFI_TEST is not set # CONFIG_RESET_ATTACK_MITIGATION is not set # CONFIG_EFI_DISABLE_PCI_DMA is not set # CONFIG_EFI_DISABLE_RUNTIME is not set # CONFIG_EFI_COCO_SECRET is not set # end of EFI (Extensible Firmware Interface) Support CONFIG_HAVE_ARM_SMCCC=y # # Tegra firmware driver # # end of Tegra firmware driver # end of Firmware Drivers # CONFIG_GNSS is not set CONFIG_MTD=y CONFIG_MTD_TESTS=m # # Partition parsers # # CONFIG_MTD_AR7_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set # end of Partition parsers # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # # Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK. # # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # end of RAM/ROM/Flash chip drivers # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # end of Mapping drivers for chip access # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_DATAFLASH is not set # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_MCHP48L640 is not set # CONFIG_MTD_SST25L is not set # CONFIG_MTD_BCM47XXSFLASH is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # end of Self-contained MTD device drivers # # NAND # # CONFIG_MTD_ONENAND is not set # CONFIG_MTD_RAW_NAND is not set # CONFIG_MTD_SPI_NAND is not set # # ECC engine support # # CONFIG_MTD_NAND_ECC_SW_HAMMING is not set # CONFIG_MTD_NAND_ECC_SW_BCH is not set # CONFIG_MTD_NAND_ECC_MXIC is not set # end of ECC engine support # end of NAND # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # CONFIG_MTD_LPDDR2_NVM is not set # end of LPDDR & LPDDR2 PCM memory drivers CONFIG_MTD_SPI_NOR=y # CONFIG_MTD_SPI_NOR_USE_4K_SECTORS is not set # CONFIG_MTD_SPI_NOR_SWP_DISABLE is not set CONFIG_MTD_SPI_NOR_SWP_DISABLE_ON_VOLATILE=y # CONFIG_MTD_SPI_NOR_SWP_KEEP is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set # CONFIG_MTD_UBI_BLOCK is not set # CONFIG_MTD_HYPERBUS is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_DYNAMIC=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set CONFIG_CDROM=m # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set # CONFIG_ZRAM is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_DRBD is not set # CONFIG_BLK_DEV_NBD is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=65536 # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set CONFIG_VIRTIO_BLK=y # CONFIG_BLK_DEV_RBD is not set # CONFIG_BLK_DEV_UBLK is not set # # NVME Support # # CONFIG_BLK_DEV_NVME is not set # CONFIG_NVME_FC is not set # CONFIG_NVME_TCP is not set # CONFIG_NVME_TARGET is not set # end of NVME Support # # Misc devices # CONFIG_AD525X_DPOT=y CONFIG_AD525X_DPOT_I2C=y # CONFIG_AD525X_DPOT_SPI is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_PHANTOM is not set # CONFIG_TIFM_CORE is not set CONFIG_ICS932S401=y # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HI6421V600_IRQ is not set # CONFIG_HP_ILO is not set CONFIG_APDS9802ALS=y CONFIG_ISL29003=y # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set CONFIG_SRAM=y CONFIG_SRAM_EXEC=y # CONFIG_DW_XDATA_PCIE is not set CONFIG_PCI_ENDPOINT_TEST=m # CONFIG_XILINX_SDFEC is not set # CONFIG_HISI_HIKEY_USB is not set # CONFIG_OPEN_DICE is not set # CONFIG_VCPU_STALL_DETECTOR is not set CONFIG_DMA_BUF_PHYS=y # CONFIG_C2PORT is not set # # EEPROM support # CONFIG_EEPROM_AT24=m # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set CONFIG_EEPROM_93CX6=y # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # end of EEPROM support # CONFIG_CB710_CORE is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # end of Texas Instruments shared transport line discipline # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # CONFIG_ECHO is not set # CONFIG_BCM_VK is not set # CONFIG_MISC_ALCOR_PCI is not set # CONFIG_MISC_RTSX_PCI is not set # CONFIG_MISC_RTSX_USB is not set # CONFIG_HABANA_AI is not set # CONFIG_UACCE is not set # CONFIG_PVPANIC is not set # CONFIG_GP_PCI1XXXX is not set # end of Misc devices # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI_COMMON=y CONFIG_SCSI=y CONFIG_SCSI_DMA=y CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set CONFIG_BLK_DEV_SR=m CONFIG_CHR_DEV_SG=y CONFIG_BLK_DEV_BSG=y # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # end of SCSI Transports CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_CXGB3_ISCSI is not set # CONFIG_SCSI_CXGB4_ISCSI is not set # CONFIG_SCSI_BNX2_ISCSI is not set # CONFIG_BE2ISCSI is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_HPSA is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_3W_SAS is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_AIC94XX is not set # CONFIG_SCSI_MVSAS is not set # CONFIG_SCSI_MVUMI is not set # CONFIG_SCSI_ADVANSYS is not set # CONFIG_SCSI_ARCMSR is not set # CONFIG_SCSI_ESAS2R is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set # CONFIG_MEGARAID_SAS is not set # CONFIG_SCSI_MPT3SAS is not set # CONFIG_SCSI_MPT2SAS is not set # CONFIG_SCSI_MPI3MR is not set # CONFIG_SCSI_SMARTPQI is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_SCSI_BUSLOGIC is not set # CONFIG_SCSI_MYRB is not set # CONFIG_SCSI_MYRS is not set # CONFIG_SCSI_SNIC is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_FDOMAIN_PCI is not set # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_STEX is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_ISCSI is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_AM53C974 is not set # CONFIG_SCSI_NSP32 is not set # CONFIG_SCSI_WD719X is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_PMCRAID is not set # CONFIG_SCSI_PM8001 is not set # CONFIG_SCSI_VIRTIO is not set # CONFIG_SCSI_DH is not set # end of SCSI device support CONFIG_ATA=m CONFIG_SATA_HOST=y CONFIG_ATA_VERBOSE_ERROR=y CONFIG_ATA_FORCE=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # CONFIG_SATA_AHCI=m CONFIG_SATA_MOBILE_LPM_POLICY=0 CONFIG_SATA_AHCI_PLATFORM=m CONFIG_AHCI_DM816=m # CONFIG_AHCI_DWC is not set # CONFIG_AHCI_CEVA is not set # CONFIG_AHCI_QORIQ is not set # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set # CONFIG_SATA_SIL24 is not set CONFIG_ATA_SFF=y # # SFF controllers with custom DMA interface # # CONFIG_PDC_ADMA is not set # CONFIG_SATA_QSTOR is not set # CONFIG_SATA_SX4 is not set CONFIG_ATA_BMDMA=y # # SATA SFF controllers with BMDMA # # CONFIG_ATA_PIIX is not set # CONFIG_SATA_DWC is not set CONFIG_SATA_MV=m # CONFIG_SATA_NV is not set # CONFIG_SATA_PROMISE is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIS is not set # CONFIG_SATA_SVW is not set # CONFIG_SATA_ULI is not set # CONFIG_SATA_VIA is not set # CONFIG_SATA_VITESSE is not set # # PATA SFF controllers with BMDMA # # CONFIG_PATA_ALI is not set # CONFIG_PATA_AMD is not set # CONFIG_PATA_ARTOP is not set # CONFIG_PATA_ATIIXP is not set # CONFIG_PATA_ATP867X is not set # CONFIG_PATA_CMD64X is not set # CONFIG_PATA_CYPRESS is not set # CONFIG_PATA_EFAR is not set # CONFIG_PATA_HPT366 is not set # CONFIG_PATA_HPT37X is not set # CONFIG_PATA_HPT3X2N is not set # CONFIG_PATA_HPT3X3 is not set # CONFIG_PATA_IT8213 is not set # CONFIG_PATA_IT821X is not set # CONFIG_PATA_JMICRON is not set # CONFIG_PATA_MARVELL is not set # CONFIG_PATA_NETCELL is not set # CONFIG_PATA_NINJA32 is not set # CONFIG_PATA_NS87415 is not set # CONFIG_PATA_OLDPIIX is not set # CONFIG_PATA_OPTIDMA is not set # CONFIG_PATA_PDC2027X is not set # CONFIG_PATA_PDC_OLD is not set # CONFIG_PATA_RADISYS is not set # CONFIG_PATA_RDC is not set # CONFIG_PATA_SCH is not set # CONFIG_PATA_SERVERWORKS is not set # CONFIG_PATA_SIL680 is not set # CONFIG_PATA_SIS is not set # CONFIG_PATA_TOSHIBA is not set # CONFIG_PATA_TRIFLEX is not set # CONFIG_PATA_VIA is not set # CONFIG_PATA_WINBOND is not set # # PIO-only SFF controllers # # CONFIG_PATA_CMD640_PCI is not set # CONFIG_PATA_MPIIX is not set # CONFIG_PATA_NS87410 is not set # CONFIG_PATA_OPTI is not set # CONFIG_PATA_OF_PLATFORM is not set # CONFIG_PATA_RZ1000 is not set # # Generic fallback / legacy drivers # # CONFIG_ATA_GENERIC is not set # CONFIG_PATA_LEGACY is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set # end of IEEE 1394 (FireWire) support CONFIG_NETDEVICES=y CONFIG_MII=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_WIREGUARD is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_FC is not set # CONFIG_IFB is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_IPVLAN is not set # CONFIG_VXLAN is not set # CONFIG_GENEVE is not set # CONFIG_BAREUDP is not set # CONFIG_GTP is not set # CONFIG_AMT is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set # CONFIG_TUN is not set # CONFIG_TUN_VNET_CROSS_LE is not set # CONFIG_VETH is not set CONFIG_VIRTIO_NET=y # CONFIG_NLMON is not set # CONFIG_ARCNET is not set # # Distributed Switch Architecture drivers # # CONFIG_B53 is not set # CONFIG_NET_DSA_BCM_SF2 is not set # CONFIG_NET_DSA_LOOP is not set # CONFIG_NET_DSA_LANTIQ_GSWIP is not set # CONFIG_NET_DSA_MT7530 is not set # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON is not set # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_MSCC_SEVILLE is not set # CONFIG_NET_DSA_AR9331 is not set # CONFIG_NET_DSA_QCA8K is not set # CONFIG_NET_DSA_SJA1105 is not set # CONFIG_NET_DSA_XRS700X_I2C is not set # CONFIG_NET_DSA_XRS700X_MDIO is not set # CONFIG_NET_DSA_REALTEK is not set # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set # end of Distributed Switch Architecture drivers CONFIG_ETHERNET=y # CONFIG_NET_VENDOR_3COM is not set # CONFIG_NET_VENDOR_ADAPTEC is not set # CONFIG_NET_VENDOR_AGERE is not set CONFIG_NET_VENDOR_ALACRITECH=y # CONFIG_SLICOSS is not set # CONFIG_NET_VENDOR_ALTEON is not set # CONFIG_ALTERA_TSE is not set # CONFIG_NET_VENDOR_AMAZON is not set # CONFIG_NET_VENDOR_AMD is not set CONFIG_NET_VENDOR_AQUANTIA=y # CONFIG_AQTION is not set # CONFIG_NET_VENDOR_ARC is not set CONFIG_NET_VENDOR_ASIX=y # CONFIG_SPI_AX88796C is not set # CONFIG_NET_VENDOR_ATHEROS is not set CONFIG_NET_VENDOR_BROADCOM=y # CONFIG_B44 is not set # CONFIG_BCMGENET is not set # CONFIG_BNX2 is not set # CONFIG_CNIC is not set CONFIG_TIGON3=m CONFIG_TIGON3_HWMON=y # CONFIG_BNX2X is not set # CONFIG_SYSTEMPORT is not set # CONFIG_BNXT is not set CONFIG_NET_VENDOR_CADENCE=y CONFIG_MACB=y CONFIG_MACB_USE_HWSTAMP=y # CONFIG_MACB_PCI is not set # CONFIG_NET_VENDOR_CAVIUM is not set # CONFIG_NET_VENDOR_CHELSIO is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_NET_VENDOR_CISCO is not set CONFIG_NET_VENDOR_CORTINA=y # CONFIG_GEMINI_ETHERNET is not set CONFIG_NET_VENDOR_DAVICOM=y # CONFIG_DM9000 is not set # CONFIG_DM9051 is not set # CONFIG_DNET is not set # CONFIG_NET_VENDOR_DEC is not set # CONFIG_NET_VENDOR_DLINK is not set # CONFIG_NET_VENDOR_EMULEX is not set CONFIG_NET_VENDOR_ENGLEDER=y # CONFIG_TSNEP is not set # CONFIG_NET_VENDOR_EZCHIP is not set # CONFIG_NET_VENDOR_FARADAY is not set CONFIG_NET_VENDOR_FUNGIBLE=y # CONFIG_FUN_ETH is not set CONFIG_NET_VENDOR_GOOGLE=y # CONFIG_GVE is not set # CONFIG_NET_VENDOR_HISILICON is not set CONFIG_NET_VENDOR_HUAWEI=y # CONFIG_NET_VENDOR_I825XX is not set CONFIG_NET_VENDOR_INTEL=y # CONFIG_E100 is not set CONFIG_E1000=m CONFIG_E1000E=m # CONFIG_IGB is not set # CONFIG_IGBVF is not set # CONFIG_IXGB is not set # CONFIG_IXGBE is not set # CONFIG_IXGBEVF is not set # CONFIG_I40E is not set # CONFIG_I40EVF is not set # CONFIG_ICE is not set # CONFIG_FM10K is not set # CONFIG_IGC is not set CONFIG_NET_VENDOR_WANGXUN=y # CONFIG_NGBE is not set # CONFIG_TXGBE is not set # CONFIG_JME is not set CONFIG_NET_VENDOR_ADI=y # CONFIG_ADIN1110 is not set CONFIG_NET_VENDOR_LITEX=y # CONFIG_LITEX_LITEETH is not set CONFIG_NET_VENDOR_MARVELL=y # CONFIG_MVMDIO is not set CONFIG_SKGE=m # CONFIG_SKGE_DEBUG is not set # CONFIG_SKGE_GENESIS is not set # CONFIG_SKY2 is not set # CONFIG_PRESTERA is not set # CONFIG_NET_VENDOR_MELLANOX is not set CONFIG_NET_VENDOR_MICREL=y # CONFIG_KS8842 is not set CONFIG_KS8851=y # CONFIG_KS8851_MLL is not set # CONFIG_KSZ884X_PCI is not set # CONFIG_NET_VENDOR_MICROCHIP is not set CONFIG_NET_VENDOR_MICROSEMI=y # CONFIG_MSCC_OCELOT_SWITCH is not set CONFIG_NET_VENDOR_MICROSOFT=y # CONFIG_NET_VENDOR_MYRI is not set # CONFIG_FEALNX is not set CONFIG_NET_VENDOR_NI=y # CONFIG_NI_XGE_MANAGEMENT_ENET is not set # CONFIG_NET_VENDOR_NATSEMI is not set CONFIG_NET_VENDOR_NETERION=y # CONFIG_S2IO is not set # CONFIG_NET_VENDOR_NETRONOME is not set # CONFIG_NET_VENDOR_NVIDIA is not set # CONFIG_NET_VENDOR_OKI is not set # CONFIG_ETHOC is not set CONFIG_NET_VENDOR_PACKET_ENGINES=y # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set CONFIG_NET_VENDOR_PENSANDO=y # CONFIG_NET_VENDOR_QLOGIC is not set # CONFIG_NET_VENDOR_BROCADE is not set # CONFIG_NET_VENDOR_QUALCOMM is not set # CONFIG_NET_VENDOR_RDC is not set # CONFIG_NET_VENDOR_REALTEK is not set # CONFIG_NET_VENDOR_RENESAS is not set # CONFIG_NET_VENDOR_ROCKER is not set # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set # CONFIG_NET_VENDOR_SILAN is not set # CONFIG_NET_VENDOR_SIS is not set CONFIG_NET_VENDOR_SOLARFLARE=y # CONFIG_SFC is not set # CONFIG_SFC_FALCON is not set # CONFIG_SFC_SIENA is not set CONFIG_NET_VENDOR_SMSC=y # CONFIG_SMC91X is not set # CONFIG_EPIC100 is not set # CONFIG_SMC911X is not set CONFIG_SMSC911X=y # CONFIG_SMSC9420 is not set CONFIG_NET_VENDOR_SOCIONEXT=y # CONFIG_NET_VENDOR_STMICRO is not set # CONFIG_NET_VENDOR_SUN is not set # CONFIG_NET_VENDOR_SYNOPSYS is not set # CONFIG_NET_VENDOR_TEHUTI is not set CONFIG_NET_VENDOR_TI=y CONFIG_TI_DAVINCI_MDIO=y # CONFIG_TI_CPSW_PHY_SEL is not set CONFIG_TI_CPSW=y # CONFIG_TI_CPSW_SWITCHDEV is not set CONFIG_TI_CPTS=y # CONFIG_TLAN is not set CONFIG_TI_ICSS_IEP=m CONFIG_NET_VENDOR_VERTEXCOM=y # CONFIG_MSE102X is not set # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WIZNET is not set CONFIG_NET_VENDOR_XILINX=y # CONFIG_XILINX_EMACLITE is not set # CONFIG_XILINX_AXI_EMAC is not set # CONFIG_XILINX_LL_TEMAC is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set CONFIG_PHYLINK=y CONFIG_PHYLIB=y CONFIG_SWPHY=y # CONFIG_LED_TRIGGER_PHY is not set CONFIG_FIXED_PHY=y # CONFIG_SFP is not set # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_ADIN_PHY is not set # CONFIG_ADIN1100_PHY is not set # CONFIG_AQUANTIA_PHY is not set CONFIG_AX88796B_PHY=m # CONFIG_BROADCOM_PHY is not set # CONFIG_BCM54140_PHY is not set # CONFIG_BCM7XXX_PHY is not set # CONFIG_BCM84881_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set CONFIG_MARVELL_PHY=y # CONFIG_MARVELL_10G_PHY is not set # CONFIG_MARVELL_88X2222_PHY is not set # CONFIG_MAXLINEAR_GPHY is not set # CONFIG_MEDIATEK_GE_PHY is not set CONFIG_MICREL_PHY=y CONFIG_MICROCHIP_PHY=m # CONFIG_MICROCHIP_T1_PHY is not set # CONFIG_MICROSEMI_PHY is not set # CONFIG_MOTORCOMM_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_NXP_C45_TJA11XX_PHY is not set # CONFIG_NXP_TJA11XX_PHY is not set CONFIG_AT803X_PHY=y # CONFIG_QSEMI_PHY is not set CONFIG_REALTEK_PHY=y # CONFIG_RENESAS_PHY is not set CONFIG_ROCKCHIP_PHY=y CONFIG_SMSC_PHY=y # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_DP83822_PHY is not set # CONFIG_DP83TC811_PHY is not set CONFIG_DP83848_PHY=y CONFIG_DP83867_PHY=y # CONFIG_DP83869_PHY is not set # CONFIG_DP83TD510_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PSE_CONTROLLER is not set CONFIG_CAN_DEV=y # CONFIG_CAN_VCAN is not set # CONFIG_CAN_VXCAN is not set CONFIG_CAN_NETLINK=y CONFIG_CAN_CALC_BITTIMING=y CONFIG_CAN_RX_OFFLOAD=y # CONFIG_CAN_CAN327 is not set CONFIG_CAN_FLEXCAN=m # CONFIG_CAN_GRCAN is not set # CONFIG_CAN_KVASER_PCIEFD is not set # CONFIG_CAN_SLCAN is not set # CONFIG_CAN_TI_HECC is not set CONFIG_CAN_C_CAN=y CONFIG_CAN_C_CAN_PLATFORM=y # CONFIG_CAN_C_CAN_PCI is not set # CONFIG_CAN_CC770 is not set # CONFIG_CAN_CTUCANFD_PCI is not set # CONFIG_CAN_CTUCANFD_PLATFORM is not set # CONFIG_CAN_IFI_CANFD is not set CONFIG_CAN_M_CAN=m # CONFIG_CAN_M_CAN_PCI is not set # CONFIG_CAN_M_CAN_PLATFORM is not set # CONFIG_CAN_M_CAN_TCAN4X5X is not set # CONFIG_CAN_PEAK_PCIEFD is not set # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_SOFTING is not set # # CAN SPI interfaces # # CONFIG_CAN_HI311X is not set CONFIG_CAN_MCP251X=m # CONFIG_CAN_MCP251XFD is not set # end of CAN SPI interfaces # # CAN USB interfaces # # CONFIG_CAN_8DEV_USB is not set # CONFIG_CAN_EMS_USB is not set # CONFIG_CAN_ESD_USB is not set # CONFIG_CAN_ETAS_ES58X is not set # CONFIG_CAN_GS_USB is not set # CONFIG_CAN_KVASER_USB is not set # CONFIG_CAN_MCBA_USB is not set # CONFIG_CAN_PEAK_USB is not set # CONFIG_CAN_UCAN is not set # end of CAN USB interfaces # CONFIG_CAN_DEBUG_DEVICES is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y CONFIG_FWNODE_MDIO=y CONFIG_OF_MDIO=y CONFIG_MDIO_DEVRES=y CONFIG_MDIO_BITBANG=y # CONFIG_MDIO_BCM_UNIMAC is not set # CONFIG_MDIO_GPIO is not set # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_MVUSB is not set # CONFIG_MDIO_MSCC_MIIM is not set # CONFIG_MDIO_IPQ4019 is not set # CONFIG_MDIO_IPQ8064 is not set # # MDIO Multiplexers # # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # # PCS device drivers # # end of PCS device drivers # CONFIG_PPP is not set # CONFIG_SLIP is not set CONFIG_USB_NET_DRIVERS=m # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set CONFIG_USB_PEGASUS=m # CONFIG_USB_RTL8150 is not set CONFIG_USB_RTL8152=m CONFIG_USB_LAN78XX=m CONFIG_USB_USBNET=m CONFIG_USB_NET_AX8817X=m CONFIG_USB_NET_AX88179_178A=m CONFIG_USB_NET_CDCETHER=m # CONFIG_USB_NET_CDC_EEM is not set CONFIG_USB_NET_CDC_NCM=m # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set # CONFIG_USB_NET_CDC_MBIM is not set # CONFIG_USB_NET_DM9601 is not set # CONFIG_USB_NET_SR9700 is not set # CONFIG_USB_NET_SR9800 is not set CONFIG_USB_NET_SMSC75XX=m CONFIG_USB_NET_SMSC95XX=m # CONFIG_USB_NET_GL620A is not set CONFIG_USB_NET_NET1080=m # CONFIG_USB_NET_PLUSB is not set # CONFIG_USB_NET_MCS7830 is not set # CONFIG_USB_NET_RNDIS_HOST is not set CONFIG_USB_NET_CDC_SUBSET_ENABLE=m CONFIG_USB_NET_CDC_SUBSET=m # CONFIG_USB_ALI_M5632 is not set # CONFIG_USB_AN2720 is not set CONFIG_USB_BELKIN=y CONFIG_USB_ARMLINUX=y # CONFIG_USB_EPSON2888 is not set # CONFIG_USB_KC2190 is not set CONFIG_USB_NET_ZAURUS=m # CONFIG_USB_NET_CX82310_ETH is not set # CONFIG_USB_NET_KALMIA is not set # CONFIG_USB_NET_QMI_WWAN is not set # CONFIG_USB_HSO is not set # CONFIG_USB_NET_INT51X1 is not set # CONFIG_USB_IPHETH is not set # CONFIG_USB_SIERRA_NET is not set # CONFIG_USB_VL600 is not set # CONFIG_USB_NET_CH9200 is not set # CONFIG_USB_NET_AQC111 is not set CONFIG_USB_RTL8153_ECM=m CONFIG_WLAN=y CONFIG_WLAN_VENDOR_ADMTEK=y # CONFIG_ADM8211 is not set CONFIG_WLAN_VENDOR_ATH=y # CONFIG_ATH_DEBUG is not set # CONFIG_ATH5K is not set # CONFIG_ATH5K_PCI is not set # CONFIG_ATH9K is not set # CONFIG_ATH9K_HTC is not set # CONFIG_CARL9170 is not set # CONFIG_ATH6KL is not set # CONFIG_AR5523 is not set # CONFIG_WIL6210 is not set # CONFIG_ATH10K is not set # CONFIG_WCN36XX is not set CONFIG_WLAN_VENDOR_ATMEL=y # CONFIG_ATMEL is not set # CONFIG_AT76C50X_USB is not set CONFIG_WLAN_VENDOR_BROADCOM=y CONFIG_B43=m CONFIG_B43_BCMA=y CONFIG_B43_SSB=y CONFIG_B43_BUSES_BCMA_AND_SSB=y # CONFIG_B43_BUSES_BCMA is not set # CONFIG_B43_BUSES_SSB is not set CONFIG_B43_PCI_AUTOSELECT=y CONFIG_B43_PCICORE_AUTOSELECT=y # CONFIG_B43_SDIO is not set CONFIG_B43_BCMA_PIO=y CONFIG_B43_PIO=y CONFIG_B43_PHY_G=y CONFIG_B43_PHY_N=y CONFIG_B43_PHY_LP=y CONFIG_B43_PHY_HT=y CONFIG_B43_LEDS=y CONFIG_B43_HWRNG=y # CONFIG_B43_DEBUG is not set # CONFIG_B43LEGACY is not set CONFIG_BRCMUTIL=m # CONFIG_BRCMSMAC is not set CONFIG_BRCMFMAC=m CONFIG_BRCMFMAC_PROTO_BCDC=y CONFIG_BRCMFMAC_SDIO=y # CONFIG_BRCMFMAC_USB is not set # CONFIG_BRCMFMAC_PCIE is not set # CONFIG_BRCM_TRACING is not set # CONFIG_BRCMDBG is not set CONFIG_WLAN_VENDOR_CISCO=y CONFIG_WLAN_VENDOR_INTEL=y # CONFIG_IPW2100 is not set # CONFIG_IPW2200 is not set # CONFIG_IWL4965 is not set # CONFIG_IWL3945 is not set CONFIG_IWLWIFI=m CONFIG_IWLWIFI_LEDS=y CONFIG_IWLDVM=m CONFIG_IWLMVM=m CONFIG_IWLWIFI_OPMODE_MODULAR=y # # Debugging Options # # CONFIG_IWLWIFI_DEBUG is not set # end of Debugging Options CONFIG_WLAN_VENDOR_INTERSIL=y # CONFIG_HOSTAP is not set # CONFIG_HERMES is not set # CONFIG_P54_COMMON is not set CONFIG_WLAN_VENDOR_MARVELL=y # CONFIG_LIBERTAS is not set # CONFIG_LIBERTAS_THINFIRM is not set CONFIG_MWIFIEX=m CONFIG_MWIFIEX_SDIO=m # CONFIG_MWIFIEX_PCIE is not set # CONFIG_MWIFIEX_USB is not set # CONFIG_MWL8K is not set CONFIG_WLAN_VENDOR_MEDIATEK=y # CONFIG_MT7601U is not set # CONFIG_MT76x0U is not set # CONFIG_MT76x0E is not set # CONFIG_MT76x2E is not set # CONFIG_MT76x2U is not set # CONFIG_MT7603E is not set # CONFIG_MT7615E is not set # CONFIG_MT7663U is not set # CONFIG_MT7663S is not set # CONFIG_MT7915E is not set # CONFIG_MT7921E is not set # CONFIG_MT7921S is not set # CONFIG_MT7921U is not set CONFIG_WLAN_VENDOR_MICROCHIP=y # CONFIG_WILC1000_SDIO is not set # CONFIG_WILC1000_SPI is not set CONFIG_WLAN_VENDOR_PURELIFI=y # CONFIG_PLFXLC is not set CONFIG_WLAN_VENDOR_RALINK=y CONFIG_RT2X00=m # CONFIG_RT2400PCI is not set # CONFIG_RT2500PCI is not set # CONFIG_RT61PCI is not set # CONFIG_RT2800PCI is not set # CONFIG_RT2500USB is not set # CONFIG_RT73USB is not set CONFIG_RT2800USB=m CONFIG_RT2800USB_RT33XX=y CONFIG_RT2800USB_RT35XX=y # CONFIG_RT2800USB_RT3573 is not set # CONFIG_RT2800USB_RT53XX is not set # CONFIG_RT2800USB_RT55XX is not set # CONFIG_RT2800USB_UNKNOWN is not set CONFIG_RT2800_LIB=m CONFIG_RT2X00_LIB_USB=m CONFIG_RT2X00_LIB=m CONFIG_RT2X00_LIB_FIRMWARE=y CONFIG_RT2X00_LIB_CRYPTO=y CONFIG_RT2X00_LIB_LEDS=y # CONFIG_RT2X00_DEBUG is not set CONFIG_WLAN_VENDOR_REALTEK=y # CONFIG_RTL8180 is not set # CONFIG_RTL8187 is not set CONFIG_RTL_CARDS=m # CONFIG_RTL8192CE is not set # CONFIG_RTL8192SE is not set # CONFIG_RTL8192DE is not set # CONFIG_RTL8723AE is not set # CONFIG_RTL8723BE is not set # CONFIG_RTL8188EE is not set # CONFIG_RTL8192EE is not set # CONFIG_RTL8821AE is not set # CONFIG_RTL8192CU is not set # CONFIG_RTL8XXXU is not set # CONFIG_RTW88 is not set # CONFIG_RTW89 is not set CONFIG_WLAN_VENDOR_RSI=y # CONFIG_RSI_91X is not set CONFIG_WLAN_VENDOR_SILABS=y # CONFIG_WFX is not set CONFIG_WLAN_VENDOR_ST=y # CONFIG_CW1200 is not set CONFIG_WLAN_VENDOR_TI=y # CONFIG_WL1251 is not set # CONFIG_WL12XX is not set CONFIG_WL18XX=m CONFIG_WLCORE=m # CONFIG_WLCORE_SPI is not set CONFIG_WLCORE_SDIO=m CONFIG_WILINK_PLATFORM_DATA=y CONFIG_WLAN_VENDOR_ZYDAS=y # CONFIG_USB_ZD1201 is not set # CONFIG_ZD1211RW is not set CONFIG_WLAN_VENDOR_QUANTENNA=y # CONFIG_QTNFMAC_PCIE is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # CONFIG_VIRT_WIFI is not set # CONFIG_WAN is not set # # Wireless WAN # # CONFIG_WWAN is not set # end of Wireless WAN # CONFIG_VMXNET3 is not set # CONFIG_NETDEVSIM is not set CONFIG_NET_FAILOVER=y # CONFIG_ISDN is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_SPARSEKMAP is not set CONFIG_INPUT_MATRIXKMAP=m CONFIG_INPUT_VIVALDIFMAP=y # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set CONFIG_INPUT_JOYDEV=y CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADC is not set # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_QT1050 is not set CONFIG_KEYBOARD_QT1070=m # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=y # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set CONFIG_KEYBOARD_MATRIX=m # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_PINEPHONE is not set CONFIG_KEYBOARD_SAMSUNG=m # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_KEYBOARD_CYPRESS_SF is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_BYD=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y CONFIG_MOUSE_PS2_CYPRESS=y CONFIG_MOUSE_PS2_TRACKPOINT=y CONFIG_MOUSE_PS2_ELANTECH=y CONFIG_MOUSE_PS2_ELANTECH_SMBUS=y # CONFIG_MOUSE_PS2_SENTELIC is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set CONFIG_MOUSE_PS2_FOCALTECH=y CONFIG_MOUSE_PS2_SMBUS=y # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set CONFIG_MOUSE_CYAPA=m CONFIG_MOUSE_ELAN_I2C=y CONFIG_MOUSE_ELAN_I2C_I2C=y # CONFIG_MOUSE_ELAN_I2C_SMBUS is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_MOUSE_GPIO is not set # CONFIG_MOUSE_SYNAPTICS_I2C is not set # CONFIG_MOUSE_SYNAPTICS_USB is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_ADC is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set CONFIG_TOUCHSCREEN_ATMEL_MXT=m # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_BU21029 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_EXC3000 is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set CONFIG_TOUCHSCREEN_GOODIX=m # CONFIG_TOUCHSCREEN_HIDEEP is not set # CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set # CONFIG_TOUCHSCREEN_ILI210X is not set # CONFIG_TOUCHSCREEN_ILITEK is not set # CONFIG_TOUCHSCREEN_S6SY761 is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set CONFIG_TOUCHSCREEN_MMS114=m # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MSG2638 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMAGIS is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set CONFIG_TOUCHSCREEN_EDT_FT5X06=m # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m CONFIG_TOUCHSCREEN_PIXCIR=m # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set CONFIG_TOUCHSCREEN_ST1232=m # CONFIG_TOUCHSCREEN_STMFTS is not set # CONFIG_TOUCHSCREEN_SUR40 is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZET6223 is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set # CONFIG_TOUCHSCREEN_IQS5XX is not set # CONFIG_TOUCHSCREEN_ZINITIX is not set CONFIG_TOUCHSCREEN_FTS=y CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_GPIO_BEEPER is not set CONFIG_INPUT_GPIO_DECODER=m # CONFIG_INPUT_GPIO_VIBRA is not set CONFIG_INPUT_CPCAP_PWRBUTTON=m # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set # CONFIG_INPUT_TPS65218_PWRBUTTON is not set # CONFIG_INPUT_TWL6040_VIBRA is not set # CONFIG_INPUT_UINPUT is not set # CONFIG_INPUT_PALMAS_PWRBUTTON is not set # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_DA7280_HAPTICS is not set CONFIG_INPUT_ADXL34X=m CONFIG_INPUT_ADXL34X_I2C=m CONFIG_INPUT_ADXL34X_SPI=m # CONFIG_INPUT_IBM_PANEL is not set # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_IQS269A is not set # CONFIG_INPUT_IQS626A is not set # CONFIG_INPUT_IQS7222 is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_GPIO_PS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # end of Hardware I/O ports # end of Input device support # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y # CONFIG_VT_HW_CONSOLE_BINDING is not set CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=256 CONFIG_LDISC_AUTOLOAD=y # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y CONFIG_SERIAL_8250_16550A_VARIANTS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_EXAR=y CONFIG_SERIAL_8250_NR_UARTS=10 CONFIG_SERIAL_8250_RUNTIME_UARTS=10 CONFIG_SERIAL_8250_EXTENDED=y # CONFIG_SERIAL_8250_MANY_PORTS is not set CONFIG_SERIAL_8250_SHARE_IRQ=y # CONFIG_SERIAL_8250_DETECT_IRQ is not set # CONFIG_SERIAL_8250_RSA is not set CONFIG_SERIAL_8250_FSL=y # CONFIG_SERIAL_8250_DW is not set # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_8250_OMAP=y CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y CONFIG_SERIAL_8250_PERICOM=y CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set # CONFIG_SERIAL_SIFIVE is not set # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_RP2 is not set # CONFIG_SERIAL_FSL_LPUART is not set # CONFIG_SERIAL_FSL_LINFLEXUART is not set # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_ST_ASC is not set # CONFIG_SERIAL_SPRD is not set # end of Serial drivers CONFIG_SERIAL_MCTRL_GPIO=y # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_NOZOMI is not set # CONFIG_NULL_TTY is not set CONFIG_HVC_DRIVER=y # CONFIG_HVC_DCC is not set # CONFIG_RPMSG_TTY is not set CONFIG_SERIAL_DEV_BUS=y CONFIG_SERIAL_DEV_CTRL_TTYPORT=y # CONFIG_TTY_PRINTK is not set CONFIG_VIRTIO_CONSOLE=y # CONFIG_IPMI_HANDLER is not set # CONFIG_IPMB_DEVICE_INTERFACE is not set CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_BA431 is not set CONFIG_HW_RANDOM_OMAP=y # CONFIG_HW_RANDOM_VIRTIO is not set CONFIG_HW_RANDOM_OPTEE=y # CONFIG_HW_RANDOM_CCTRNG is not set # CONFIG_HW_RANDOM_XIPHERA is not set # CONFIG_APPLICOM is not set CONFIG_DEVMEM=y CONFIG_DEVPORT=y # CONFIG_TCG_TPM is not set # CONFIG_XILLYBUS is not set # CONFIG_XILLYUSB is not set CONFIG_RANDOM_TRUST_CPU=y CONFIG_RANDOM_TRUST_BOOTLOADER=y # end of Character devices # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_MUX=y # # Multiplexer I2C Chip support # CONFIG_I2C_ARB_GPIO_CHALLENGE=m # CONFIG_I2C_MUX_GPIO is not set # CONFIG_I2C_MUX_GPMUX is not set # CONFIG_I2C_MUX_LTC4306 is not set # CONFIG_I2C_MUX_PCA9541 is not set CONFIG_I2C_MUX_PCA954x=y CONFIG_I2C_MUX_PINCTRL=y # CONFIG_I2C_MUX_REG is not set CONFIG_I2C_DEMUX_PINCTRL=y # CONFIG_I2C_MUX_MLXCPLD is not set # end of Multiplexer I2C Chip support # CONFIG_I2C_ATR is not set CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_NVIDIA_GPU is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_DESIGNWARE_PCI is not set CONFIG_I2C_EMEV2=m # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_CP2615 is not set # CONFIG_I2C_PCI1XXXX is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_VIRTIO is not set # end of I2C Hardware Bus support # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y CONFIG_I2C_SLAVE_EEPROM=y # CONFIG_I2C_SLAVE_TESTUNIT is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # end of I2C support # CONFIG_I3C is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y CONFIG_SPI_MEM=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set CONFIG_SPI_BITBANG=m # CONFIG_SPI_CADENCE is not set CONFIG_SPI_CADENCE_QUADSPI=y # CONFIG_SPI_CADENCE_XSPI is not set # CONFIG_SPI_DESIGNWARE is not set # CONFIG_SPI_NXP_FLEXSPI is not set CONFIG_SPI_GPIO=m # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_MICROCHIP_CORE is not set # CONFIG_SPI_MICROCHIP_CORE_QSPI is not set # CONFIG_SPI_OC_TINY is not set CONFIG_SPI_OMAP24XX=y CONFIG_SPI_TI_QSPI=y # CONFIG_SPI_PXA2XX is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SPI_MXIC is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # CONFIG_SPI_AMD is not set # # SPI Multiplexer support # # CONFIG_SPI_MUX is not set # # SPI Protocol Masters # # CONFIG_SPI_SPIDEV is not set # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set # CONFIG_SPI_SLAVE is not set CONFIG_SPI_DYNAMIC=y CONFIG_SPMI=y # CONFIG_SPMI_HISI3670 is not set # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y CONFIG_PTP_1588_CLOCK_OPTIONAL=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set # CONFIG_PTP_1588_CLOCK_IDTCM is not set # CONFIG_PTP_1588_CLOCK_OCP is not set # end of PTP clock support CONFIG_PINCTRL=y CONFIG_GENERIC_PINCTRL_GROUPS=y CONFIG_PINMUX=y CONFIG_GENERIC_PINMUX_FUNCTIONS=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_CY8C95X0 is not set # CONFIG_PINCTRL_MCP23S08 is not set # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set # CONFIG_PINCTRL_OCELOT is not set CONFIG_PINCTRL_PALMAS=y CONFIG_PINCTRL_SINGLE=y # CONFIG_PINCTRL_STMFX is not set # CONFIG_PINCTRL_SX150X is not set # # Renesas pinctrl drivers # # end of Renesas pinctrl drivers CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y CONFIG_DEBUG_GPIO=y CONFIG_GPIO_SYSFS=y CONFIG_GPIO_CDEV=y CONFIG_GPIO_CDEV_V1=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_CADENCE is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_EXAR is not set # CONFIG_GPIO_FTGPIO010 is not set # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_LOGICVC is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_MPC8XXX is not set CONFIG_GPIO_OMAP=y # CONFIG_GPIO_SIFIVE is not set CONFIG_GPIO_SYSCON=y # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # CONFIG_GPIO_AMD_FCH is not set # end of Memory mapped GPIO drivers # # I2C GPIO expanders # # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set CONFIG_GPIO_PCA953X=y CONFIG_GPIO_PCA953X_IRQ=y # CONFIG_GPIO_PCA9570 is not set CONFIG_GPIO_PCF857X=y CONFIG_GPIO_TPIC2810=m # end of I2C GPIO expanders # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # CONFIG_GPIO_LP873X is not set # CONFIG_GPIO_LP87565 is not set CONFIG_GPIO_PALMAS=y # CONFIG_GPIO_TPS65218 is not set # CONFIG_GPIO_TPS6586X is not set CONFIG_GPIO_TPS65910=y # CONFIG_GPIO_TWL6040 is not set # end of MFD GPIO expanders # # PCI GPIO expanders # # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_PCI_IDIO_16 is not set # CONFIG_GPIO_PCIE_IDIO_24 is not set # CONFIG_GPIO_RDC321X is not set # end of PCI GPIO expanders # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX3191X is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set CONFIG_GPIO_PISOSR=m # CONFIG_GPIO_XRA1403 is not set # end of SPI GPIO expanders # # USB GPIO expanders # # end of USB GPIO expanders # # Virtual GPIO drivers # # CONFIG_GPIO_AGGREGATOR is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_VIRTIO is not set # CONFIG_GPIO_SIM is not set # end of Virtual GPIO drivers CONFIG_W1=m # # 1-wire Bus Masters # # CONFIG_W1_MASTER_MATROX is not set # CONFIG_W1_MASTER_DS2490 is not set # CONFIG_W1_MASTER_DS2482 is not set # CONFIG_W1_MASTER_DS1WM is not set # CONFIG_W1_MASTER_GPIO is not set CONFIG_HDQ_MASTER_OMAP=m # CONFIG_W1_MASTER_SGI is not set # end of 1-wire Bus Masters # # 1-wire Slaves # # CONFIG_W1_SLAVE_THERM is not set # CONFIG_W1_SLAVE_SMEM is not set # CONFIG_W1_SLAVE_DS2405 is not set # CONFIG_W1_SLAVE_DS2408 is not set # CONFIG_W1_SLAVE_DS2413 is not set # CONFIG_W1_SLAVE_DS2406 is not set # CONFIG_W1_SLAVE_DS2423 is not set # CONFIG_W1_SLAVE_DS2805 is not set # CONFIG_W1_SLAVE_DS2430 is not set # CONFIG_W1_SLAVE_DS2431 is not set # CONFIG_W1_SLAVE_DS2433 is not set # CONFIG_W1_SLAVE_DS2438 is not set # CONFIG_W1_SLAVE_DS250X is not set # CONFIG_W1_SLAVE_DS2780 is not set # CONFIG_W1_SLAVE_DS2781 is not set # CONFIG_W1_SLAVE_DS28E04 is not set # CONFIG_W1_SLAVE_DS28E17 is not set # end of 1-wire Slaves CONFIG_POWER_RESET=y # CONFIG_POWER_RESET_BRCMKONA is not set # CONFIG_POWER_RESET_BRCMSTB is not set CONFIG_POWER_RESET_GPIO=y CONFIG_POWER_RESET_GPIO_RESTART=y # CONFIG_POWER_RESET_LTC2952 is not set # CONFIG_POWER_RESET_REGULATOR is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_RESET_VERSATILE is not set # CONFIG_POWER_RESET_SYSCON is not set # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set # CONFIG_SYSCON_REBOOT_MODE is not set # CONFIG_NVMEM_REBOOT_MODE is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set CONFIG_POWER_SUPPLY_HWMON=y # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_IP5XXX_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_CHARGER_ADP5061 is not set CONFIG_BATTERY_ACT8945A=y CONFIG_BATTERY_CPCAP=m # CONFIG_BATTERY_CW2015 is not set # CONFIG_BATTERY_DS2760 is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SAMSUNG_SDI is not set CONFIG_BATTERY_SBS=y # CONFIG_CHARGER_SBS is not set # CONFIG_MANAGER_SBS is not set # CONFIG_BATTERY_BQ27XXX is not set CONFIG_BATTERY_MAX17040=m CONFIG_BATTERY_MAX17042=m # CONFIG_BATTERY_MAX1721X is not set CONFIG_CHARGER_CPCAP=m # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LT3651 is not set # CONFIG_CHARGER_LTC4162L is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_MAX77976 is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ2515X is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_BQ25980 is not set # CONFIG_CHARGER_BQ256XX is not set # CONFIG_CHARGER_SMB347 is not set CONFIG_CHARGER_TPS65090=y # CONFIG_CHARGER_TPS65217 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_BATTERY_GOLDFISH is not set # CONFIG_BATTERY_RT5033 is not set # CONFIG_CHARGER_RT9455 is not set # CONFIG_CHARGER_UCS1002 is not set # CONFIG_CHARGER_BD99954 is not set # CONFIG_BATTERY_UG3105 is not set CONFIG_HWMON=y # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM1177 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_AHT10 is not set # CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set # CONFIG_SENSORS_AS370 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_AXI_FAN_CONTROL is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_CORSAIR_CPRO is not set # CONFIG_SENSORS_CORSAIR_PSU is not set # CONFIG_SENSORS_DRIVETEMP is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_I5K_AMB is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_FTSTEUTATES is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set CONFIG_SENSORS_GPIO_FAN=y # CONFIG_SENSORS_HIH6130 is not set CONFIG_SENSORS_IIO_HWMON=y # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_JC42 is not set # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2947_I2C is not set # CONFIG_SENSORS_LTC2947_SPI is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC2992 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX127 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31722 is not set # CONFIG_SENSORS_MAX31730 is not set # CONFIG_SENSORS_MAX31760 is not set # CONFIG_SENSORS_MAX6620 is not set # CONFIG_SENSORS_MAX6621 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_TC654 is not set # CONFIG_SENSORS_TPS23861 is not set # CONFIG_SENSORS_MR75203 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set # CONFIG_SENSORS_LM75 is not set # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set CONFIG_SENSORS_LM90=y # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set CONFIG_SENSORS_LM95245=y # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set CONFIG_SENSORS_NTC_THERMISTOR=m # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775_I2C is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_NPCM7XX is not set # CONFIG_SENSORS_NZXT_KRAKEN2 is not set # CONFIG_SENSORS_NZXT_SMART2 is not set # CONFIG_SENSORS_OCC_P8_I2C is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set # CONFIG_SENSORS_SBTSI is not set # CONFIG_SENSORS_SBRMI is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHT4x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_SIS5595 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC2305 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_STTS751 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set CONFIG_SENSORS_INA2XX=m # CONFIG_SENSORS_INA238 is not set # CONFIG_SENSORS_INA3221 is not set # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set CONFIG_SENSORS_TMP102=y # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP108 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_TMP464 is not set # CONFIG_SENSORS_TMP513 is not set # CONFIG_SENSORS_VIA686A is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_VT8231 is not set # CONFIG_SENSORS_W83773G is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set CONFIG_THERMAL=y # CONFIG_THERMAL_NETLINK is not set # CONFIG_THERMAL_STATISTICS is not set CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_OF=y CONFIG_THERMAL_WRITABLE_TRIPS=y CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set CONFIG_THERMAL_GOV_FAIR_SHARE=y CONFIG_THERMAL_GOV_STEP_WISE=y CONFIG_THERMAL_GOV_BANG_BANG=y CONFIG_THERMAL_GOV_USER_SPACE=y CONFIG_CPU_THERMAL=y CONFIG_CPU_FREQ_THERMAL=y CONFIG_THERMAL_EMULATION=y # CONFIG_THERMAL_MMIO is not set # # Texas Instruments thermal drivers # CONFIG_TI_SOC_THERMAL=y CONFIG_TI_THERMAL=y # end of Texas Instruments thermal drivers # CONFIG_GENERIC_ADC_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=m # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y CONFIG_WATCHDOG_OPEN_TIMEOUT=0 # CONFIG_WATCHDOG_SYSFS is not set # CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set # CONFIG_FTWDT010_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set CONFIG_OMAP_WATCHDOG=m # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_ARM_SMC_WATCHDOG is not set # CONFIG_ALIM7101_WDT is not set # CONFIG_I6300ESB_WDT is not set # CONFIG_MEN_A21_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y CONFIG_SSB=m CONFIG_SSB_SPROM=y CONFIG_SSB_BLOCKIO=y CONFIG_SSB_PCIHOST_POSSIBLE=y CONFIG_SSB_PCIHOST=y CONFIG_SSB_B43_PCI_BRIDGE=y CONFIG_SSB_SDIOHOST_POSSIBLE=y # CONFIG_SSB_SDIOHOST is not set CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y CONFIG_SSB_DRIVER_PCICORE=y # CONFIG_SSB_DRIVER_GPIO is not set CONFIG_BCMA_POSSIBLE=y CONFIG_BCMA=m CONFIG_BCMA_BLOCKIO=y CONFIG_BCMA_HOST_PCI_POSSIBLE=y CONFIG_BCMA_HOST_PCI=y CONFIG_BCMA_HOST_SOC=y CONFIG_BCMA_DRIVER_PCI=y CONFIG_BCMA_SFLASH=y CONFIG_BCMA_DRIVER_GMAC_CMN=y CONFIG_BCMA_DRIVER_GPIO=y # CONFIG_BCMA_DEBUG is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y CONFIG_MFD_ACT8945A=y # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set # CONFIG_MFD_BD9571MWV is not set # CONFIG_MFD_AXP20X_I2C is not set # CONFIG_MFD_MADERA is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_GATEWORKS_GSC is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_MP2629 is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_MFD_HI6421_SPMI is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_LPC_ICH is not set # CONFIG_LPC_SCH is not set # CONFIG_MFD_IQS62X is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77650 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77714 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_MT6360 is not set # CONFIG_MFD_MT6370 is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_MENF21BMC is not set # CONFIG_MFD_OCELOT is not set # CONFIG_EZX_PCAP is not set CONFIG_MFD_CPCAP=y # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_NTXEC is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_PM8XXX is not set # CONFIG_MFD_SY7636A is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_RT4831 is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RT5120 is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y CONFIG_MFD_TI_AM335X_TSCADC=m # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set CONFIG_MFD_OMAP_USB_HOST=y CONFIG_MFD_PALMAS=y # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set CONFIG_MFD_TPS65090=y CONFIG_MFD_TPS65217=y CONFIG_MFD_TI_LP873X=y CONFIG_MFD_TI_LP87565=y CONFIG_MFD_TPS65218=y # CONFIG_MFD_TPS65219 is not set CONFIG_MFD_TPS6586X=y CONFIG_MFD_TPS65910=y # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS6594_I2C is not set # CONFIG_MFD_TPS6594_SPI is not set # CONFIG_TWL4030_CORE is not set CONFIG_TWL6040_CORE=y # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_ROHM_BD718XX is not set # CONFIG_MFD_ROHM_BD71828 is not set # CONFIG_MFD_ROHM_BD957XMUF is not set # CONFIG_MFD_STPMIC1 is not set # CONFIG_MFD_STMFX is not set # CONFIG_MFD_ATC260X_I2C is not set # CONFIG_MFD_QCOM_PM8008 is not set # CONFIG_RAVE_SP_CORE is not set # CONFIG_MFD_INTEL_M10_BMC is not set # CONFIG_MFD_RSMU_I2C is not set # CONFIG_MFD_RSMU_SPI is not set # end of Multifunction device drivers CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_88PG86X is not set # CONFIG_REGULATOR_ACT8865 is not set CONFIG_REGULATOR_ACT8945A=y # CONFIG_REGULATOR_AD5398 is not set CONFIG_REGULATOR_CPCAP=y # CONFIG_REGULATOR_DA9121 is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set # CONFIG_REGULATOR_FAN53555 is not set # CONFIG_REGULATOR_FAN53880 is not set CONFIG_REGULATOR_GPIO=y # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set CONFIG_REGULATOR_LP873X=y # CONFIG_REGULATOR_LP8755 is not set CONFIG_REGULATOR_LP87565=y # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8893 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MAX8973 is not set # CONFIG_REGULATOR_MAX20086 is not set # CONFIG_REGULATOR_MAX77826 is not set # CONFIG_REGULATOR_MCP16502 is not set # CONFIG_REGULATOR_MP5416 is not set # CONFIG_REGULATOR_MP8859 is not set # CONFIG_REGULATOR_MP886X is not set # CONFIG_REGULATOR_MPQ7920 is not set # CONFIG_REGULATOR_MT6311 is not set # CONFIG_REGULATOR_MT6315 is not set CONFIG_REGULATOR_PALMAS=y CONFIG_REGULATOR_PBIAS=y # CONFIG_REGULATOR_PCA9450 is not set # CONFIG_REGULATOR_PF8X00 is not set # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set # CONFIG_REGULATOR_QCOM_SPMI is not set # CONFIG_REGULATOR_QCOM_USB_VBUS is not set # CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set # CONFIG_REGULATOR_RT4801 is not set # CONFIG_REGULATOR_RT5190A is not set # CONFIG_REGULATOR_RT5759 is not set # CONFIG_REGULATOR_RT6160 is not set # CONFIG_REGULATOR_RT6245 is not set # CONFIG_REGULATOR_RTQ2134 is not set # CONFIG_REGULATOR_RTMV20 is not set # CONFIG_REGULATOR_RTQ6752 is not set # CONFIG_REGULATOR_SLG51000 is not set CONFIG_REGULATOR_TI_ABB=y # CONFIG_REGULATOR_SY8106A is not set # CONFIG_REGULATOR_SY8824X is not set # CONFIG_REGULATOR_SY8827N is not set # CONFIG_REGULATOR_TPS51632 is not set CONFIG_REGULATOR_TPS62360=y # CONFIG_REGULATOR_TPS6286X is not set CONFIG_REGULATOR_TPS65023=y CONFIG_REGULATOR_TPS6507X=y CONFIG_REGULATOR_TPS65090=y # CONFIG_REGULATOR_TPS65132 is not set CONFIG_REGULATOR_TPS65217=y CONFIG_REGULATOR_TPS65218=y CONFIG_REGULATOR_TPS6524X=y CONFIG_REGULATOR_TPS6586X=y CONFIG_REGULATOR_TPS65910=y # CONFIG_REGULATOR_VCTRL is not set # CONFIG_REGULATOR_QCOM_LABIBB is not set # CONFIG_RC_CORE is not set CONFIG_CEC_CORE=y # # CEC support # CONFIG_MEDIA_CEC_SUPPORT=y # CONFIG_CEC_CH7322 is not set # CONFIG_CEC_GPIO is not set # CONFIG_USB_PULSE8_CEC is not set # CONFIG_USB_RAINSHADOW_CEC is not set # end of CEC support CONFIG_MEDIA_SUPPORT=y # CONFIG_MEDIA_SUPPORT_FILTER is not set # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # # Media device types # CONFIG_MEDIA_CAMERA_SUPPORT=y CONFIG_MEDIA_ANALOG_TV_SUPPORT=y CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y CONFIG_MEDIA_RADIO_SUPPORT=y CONFIG_MEDIA_SDR_SUPPORT=y CONFIG_MEDIA_PLATFORM_SUPPORT=y CONFIG_MEDIA_TEST_SUPPORT=y # end of Media device types # # Media core support # CONFIG_VIDEO_DEV=y CONFIG_MEDIA_CONTROLLER=y CONFIG_DVB_CORE=y # end of Media core support # # Video4Linux options # CONFIG_VIDEO_V4L2_I2C=y CONFIG_VIDEO_V4L2_SUBDEV_API=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set # CONFIG_V4L2_FLASH_LED_CLASS is not set CONFIG_V4L2_FWNODE=m CONFIG_V4L2_ASYNC=m # end of Video4Linux options # # Media controller options # # CONFIG_MEDIA_CONTROLLER_DVB is not set # end of Media controller options # # Digital TV options # # CONFIG_DVB_MMAP is not set CONFIG_DVB_NET=y CONFIG_DVB_MAX_ADAPTERS=16 CONFIG_DVB_DYNAMIC_MINORS=y # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set # CONFIG_DVB_ULE_DEBUG is not set # end of Digital TV options # # Media drivers # # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # # CONFIG_USB_GSPCA is not set # CONFIG_USB_PWC is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set CONFIG_USB_VIDEO_CLASS=m CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # # Analog TV USB devices # # CONFIG_VIDEO_GO7007 is not set # CONFIG_VIDEO_HDPVR is not set # CONFIG_VIDEO_PVRUSB2 is not set # CONFIG_VIDEO_STK1160_COMMON is not set # # Analog/digital TV USB devices # # CONFIG_VIDEO_AU0828 is not set # CONFIG_VIDEO_CX231XX is not set # # Digital TV USB devices # # CONFIG_DVB_AS102 is not set # CONFIG_DVB_B2C2_FLEXCOP_USB is not set # CONFIG_DVB_USB_V2 is not set # CONFIG_SMS_USB_DRV is not set # CONFIG_DVB_TTUSB_BUDGET is not set # CONFIG_DVB_TTUSB_DEC is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set # # Software defined radio USB devices # # CONFIG_USB_AIRSPY is not set # CONFIG_USB_HACKRF is not set # CONFIG_USB_MSI2500 is not set # CONFIG_MEDIA_PCI_SUPPORT is not set CONFIG_RADIO_ADAPTERS=y # CONFIG_RADIO_MAXIRADIO is not set # CONFIG_RADIO_SAA7706H is not set # CONFIG_RADIO_SHARK is not set # CONFIG_RADIO_SHARK2 is not set # CONFIG_RADIO_SI4713 is not set # CONFIG_RADIO_TEA5764 is not set # CONFIG_RADIO_TEF6862 is not set # CONFIG_RADIO_WL1273 is not set # CONFIG_USB_DSBR is not set # CONFIG_USB_KEENE is not set # CONFIG_USB_MA901 is not set # CONFIG_USB_MR800 is not set # CONFIG_USB_RAREMONO is not set # CONFIG_RADIO_SI470X is not set CONFIG_MEDIA_PLATFORM_DRIVERS=y CONFIG_V4L_PLATFORM_DRIVERS=y # CONFIG_SDR_PLATFORM_DRIVERS is not set # CONFIG_DVB_PLATFORM_DRIVERS is not set CONFIG_V4L_MEM2MEM_DRIVERS=y # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set # CONFIG_VIDEO_MUX is not set # # Allegro DVT media platform drivers # # # Amlogic media platform drivers # # # Amphion drivers # # # Aspeed media platform drivers # # CONFIG_VIDEO_ASPEED is not set # # Atmel media platform drivers # # # Cadence media platform drivers # # CONFIG_VIDEO_CADENCE_CSI2RX is not set # CONFIG_VIDEO_CADENCE_CSI2TX is not set # # Chips&Media media platform drivers # # CONFIG_VIDEO_WAVE_VPU is not set # # IMG media platform drivers # # # Intel media platform drivers # # # Marvell media platform drivers # # CONFIG_VIDEO_CAFE_CCIC is not set # # Mediatek media platform drivers # # # NVidia media platform drivers # # # NXP media platform drivers # # # Qualcomm media platform drivers # # # Renesas media platform drivers # # # Rockchip media platform drivers # # # Samsung media platform drivers # # # STMicroelectronics media platform drivers # # # Sunxi media platform drivers # # # Texas Instruments drivers # # CONFIG_VIDEO_AM437X_VPFE is not set # # Verisilicon media platform drivers # # # VIA media platform drivers # # # Xilinx media platform drivers # # CONFIG_VIDEO_XILINX is not set # # MMC/SDIO DVB adapters # # CONFIG_SMS_SDIO_DRV is not set CONFIG_V4L_TEST_DRIVERS=y # CONFIG_VIDEO_VIM2M is not set # CONFIG_VIDEO_VICODEC is not set # CONFIG_VIDEO_VIMC is not set # CONFIG_DVB_TEST_DRIVERS is not set CONFIG_VIDEOBUF2_CORE=m CONFIG_VIDEOBUF2_V4L2=m CONFIG_VIDEOBUF2_MEMOPS=m CONFIG_VIDEOBUF2_VMALLOC=m CONFIG_VIDEOBUF2_DMA_SG=m # end of Media drivers # # Media ancillary drivers # CONFIG_MEDIA_ATTACH=y # # Camera sensor devices # # CONFIG_VIDEO_AR0521 is not set # CONFIG_VIDEO_HI556 is not set # CONFIG_VIDEO_HI846 is not set # CONFIG_VIDEO_HI847 is not set # CONFIG_VIDEO_IMX208 is not set # CONFIG_VIDEO_IMX214 is not set # CONFIG_VIDEO_IMX219 is not set # CONFIG_VIDEO_IMX258 is not set # CONFIG_VIDEO_IMX274 is not set # CONFIG_VIDEO_IMX290 is not set # CONFIG_VIDEO_IMX319 is not set # CONFIG_VIDEO_IMX334 is not set # CONFIG_VIDEO_IMX335 is not set # CONFIG_VIDEO_IMX355 is not set # CONFIG_VIDEO_IMX390 is not set # CONFIG_VIDEO_IMX412 is not set # CONFIG_VIDEO_MT9M001 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9T112 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set # CONFIG_VIDEO_MT9V111 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_OG01A1B is not set # CONFIG_VIDEO_OV02A10 is not set # CONFIG_VIDEO_OV08D10 is not set # CONFIG_VIDEO_OV13858 is not set # CONFIG_VIDEO_OV13B10 is not set # CONFIG_VIDEO_OV2312 is not set # CONFIG_VIDEO_OV2640 is not set CONFIG_VIDEO_OV2659=m # CONFIG_VIDEO_OV2680 is not set # CONFIG_VIDEO_OV2685 is not set # CONFIG_VIDEO_OV5640 is not set # CONFIG_VIDEO_OV5645 is not set # CONFIG_VIDEO_OV5647 is not set # CONFIG_VIDEO_OV5648 is not set # CONFIG_VIDEO_OV5670 is not set # CONFIG_VIDEO_OV5675 is not set # CONFIG_VIDEO_OV5693 is not set # CONFIG_VIDEO_OV5695 is not set # CONFIG_VIDEO_OV6650 is not set # CONFIG_VIDEO_OV7251 is not set # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV772X is not set # CONFIG_VIDEO_OV7740 is not set # CONFIG_VIDEO_OV8856 is not set # CONFIG_VIDEO_OV8865 is not set # CONFIG_VIDEO_OV9282 is not set # CONFIG_VIDEO_OV9640 is not set # CONFIG_VIDEO_OV9650 is not set # CONFIG_VIDEO_RDACM20 is not set # CONFIG_VIDEO_RDACM21 is not set # CONFIG_VIDEO_RJ54N1 is not set # CONFIG_VIDEO_S5C73M3 is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_S5K5BAF is not set # CONFIG_VIDEO_S5K6A3 is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_CCS is not set # CONFIG_VIDEO_ET8EK8 is not set # CONFIG_VIDEO_M5MOLS is not set # end of Camera sensor devices # # Lens drivers # # CONFIG_VIDEO_AD5820 is not set # CONFIG_VIDEO_AK7375 is not set # CONFIG_VIDEO_DW9714 is not set # CONFIG_VIDEO_DW9768 is not set # CONFIG_VIDEO_DW9807_VCM is not set # end of Lens drivers # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_LM3560 is not set # CONFIG_VIDEO_LM3646 is not set # end of Flash devices # # Audio decoders, processors and mixers # # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # CONFIG_VIDEO_TDA1997X is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_WM8775 is not set # end of Audio decoders, processors and mixers # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # end of RDS decoders # # Video decoders # CONFIG_VIDEO_ADV7180=m # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV748X is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_ISL7998X is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_MAX9286 is not set CONFIG_VIDEO_ML86V7667=m # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TC358743 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_TW9910 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # end of Video decoders # # Video encoders # # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_THS8200 is not set # end of Video encoders # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # end of Video improvement chips # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # end of Audio/Video compression chips # # SDR tuner chips # # CONFIG_SDR_MAX2175 is not set # end of SDR tuner chips # # Miscellaneous helper chips # # CONFIG_VIDEO_I2C is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_ST_MIPID02 is not set # CONFIG_VIDEO_THS7303 is not set # end of Miscellaneous helper chips # # Video serializers and deserializers # # CONFIG_VIDEO_DS90UB913 is not set # CONFIG_VIDEO_DS90UB953 is not set # CONFIG_VIDEO_DS90UB960 is not set # end of Video serializers and deserializers # # Media SPI Adapters # CONFIG_CXD2880_SPI_DRV=m # CONFIG_VIDEO_GS1662 is not set # end of Media SPI Adapters CONFIG_MEDIA_TUNER=y # # Customize TV tuners # CONFIG_MEDIA_TUNER_E4000=m CONFIG_MEDIA_TUNER_FC0011=m CONFIG_MEDIA_TUNER_FC0012=m CONFIG_MEDIA_TUNER_FC0013=m CONFIG_MEDIA_TUNER_FC2580=m CONFIG_MEDIA_TUNER_IT913X=m CONFIG_MEDIA_TUNER_M88RS6000T=m CONFIG_MEDIA_TUNER_MAX2165=m CONFIG_MEDIA_TUNER_MC44S803=m CONFIG_MEDIA_TUNER_MSI001=m CONFIG_MEDIA_TUNER_MT2060=m CONFIG_MEDIA_TUNER_MT2063=m CONFIG_MEDIA_TUNER_MT20XX=m CONFIG_MEDIA_TUNER_MT2131=m CONFIG_MEDIA_TUNER_MT2266=m CONFIG_MEDIA_TUNER_MXL301RF=m CONFIG_MEDIA_TUNER_MXL5005S=m CONFIG_MEDIA_TUNER_MXL5007T=m CONFIG_MEDIA_TUNER_QM1D1B0004=m CONFIG_MEDIA_TUNER_QM1D1C0042=m CONFIG_MEDIA_TUNER_QT1010=m CONFIG_MEDIA_TUNER_R820T=m CONFIG_MEDIA_TUNER_SI2157=m CONFIG_MEDIA_TUNER_SIMPLE=m CONFIG_MEDIA_TUNER_TDA18212=m CONFIG_MEDIA_TUNER_TDA18218=m CONFIG_MEDIA_TUNER_TDA18250=m CONFIG_MEDIA_TUNER_TDA18271=m CONFIG_MEDIA_TUNER_TDA827X=m CONFIG_MEDIA_TUNER_TDA8290=m CONFIG_MEDIA_TUNER_TDA9887=m CONFIG_MEDIA_TUNER_TEA5761=m CONFIG_MEDIA_TUNER_TEA5767=m CONFIG_MEDIA_TUNER_TUA9001=m CONFIG_MEDIA_TUNER_XC2028=m CONFIG_MEDIA_TUNER_XC4000=m CONFIG_MEDIA_TUNER_XC5000=m # end of Customize TV tuners # # Customise DVB Frontends # # # Multistandard (satellite) frontends # CONFIG_DVB_M88DS3103=m CONFIG_DVB_MXL5XX=m CONFIG_DVB_STB0899=m CONFIG_DVB_STB6100=m CONFIG_DVB_STV090x=m CONFIG_DVB_STV0910=m CONFIG_DVB_STV6110x=m CONFIG_DVB_STV6111=m # # Multistandard (cable + terrestrial) frontends # CONFIG_DVB_DRXK=m CONFIG_DVB_MN88472=m CONFIG_DVB_MN88473=m CONFIG_DVB_SI2165=m CONFIG_DVB_TDA18271C2DD=m # # DVB-S (satellite) frontends # CONFIG_DVB_CX24110=m CONFIG_DVB_CX24116=m CONFIG_DVB_CX24117=m CONFIG_DVB_CX24120=m CONFIG_DVB_CX24123=m CONFIG_DVB_DS3000=m CONFIG_DVB_MB86A16=m CONFIG_DVB_MT312=m CONFIG_DVB_S5H1420=m CONFIG_DVB_SI21XX=m CONFIG_DVB_STB6000=m CONFIG_DVB_STV0288=m CONFIG_DVB_STV0299=m CONFIG_DVB_STV0900=m CONFIG_DVB_STV6110=m CONFIG_DVB_TDA10071=m CONFIG_DVB_TDA10086=m CONFIG_DVB_TDA8083=m CONFIG_DVB_TDA8261=m CONFIG_DVB_TDA826X=m CONFIG_DVB_TS2020=m CONFIG_DVB_TUA6100=m CONFIG_DVB_TUNER_CX24113=m CONFIG_DVB_TUNER_ITD1000=m CONFIG_DVB_VES1X93=m CONFIG_DVB_ZL10036=m CONFIG_DVB_ZL10039=m # # DVB-T (terrestrial) frontends # CONFIG_DVB_AF9013=m CONFIG_DVB_CX22700=m CONFIG_DVB_CX22702=m CONFIG_DVB_CXD2820R=m CONFIG_DVB_CXD2841ER=m CONFIG_DVB_DIB3000MB=m CONFIG_DVB_DIB3000MC=m CONFIG_DVB_DIB7000M=m CONFIG_DVB_DIB7000P=m CONFIG_DVB_DIB9000=m CONFIG_DVB_DRXD=m CONFIG_DVB_EC100=m CONFIG_DVB_L64781=m CONFIG_DVB_MT352=m CONFIG_DVB_NXT6000=m CONFIG_DVB_RTL2830=m CONFIG_DVB_RTL2832=m CONFIG_DVB_RTL2832_SDR=m CONFIG_DVB_S5H1432=m CONFIG_DVB_SI2168=m CONFIG_DVB_SP887X=m CONFIG_DVB_STV0367=m CONFIG_DVB_TDA10048=m CONFIG_DVB_TDA1004X=m CONFIG_DVB_ZD1301_DEMOD=m CONFIG_DVB_ZL10353=m CONFIG_DVB_CXD2880=m # # DVB-C (cable) frontends # CONFIG_DVB_STV0297=m CONFIG_DVB_TDA10021=m CONFIG_DVB_TDA10023=m CONFIG_DVB_VES1820=m # # ATSC (North American/Korean Terrestrial/Cable DTV) frontends # CONFIG_DVB_AU8522=m CONFIG_DVB_AU8522_DTV=m CONFIG_DVB_AU8522_V4L=m CONFIG_DVB_BCM3510=m CONFIG_DVB_LG2160=m CONFIG_DVB_LGDT3305=m CONFIG_DVB_LGDT3306A=m CONFIG_DVB_LGDT330X=m CONFIG_DVB_MXL692=m CONFIG_DVB_NXT200X=m CONFIG_DVB_OR51132=m CONFIG_DVB_OR51211=m CONFIG_DVB_S5H1409=m CONFIG_DVB_S5H1411=m # # ISDB-T (terrestrial) frontends # CONFIG_DVB_DIB8000=m CONFIG_DVB_MB86A20S=m CONFIG_DVB_S921=m # # ISDB-S (satellite) & ISDB-T (terrestrial) frontends # CONFIG_DVB_MN88443X=m CONFIG_DVB_TC90522=m # # Digital terrestrial only tuners/PLL # CONFIG_DVB_PLL=m CONFIG_DVB_TUNER_DIB0070=m CONFIG_DVB_TUNER_DIB0090=m # # SEC control devices for DVB-S # CONFIG_DVB_A8293=m CONFIG_DVB_AF9033=m CONFIG_DVB_ASCOT2E=m CONFIG_DVB_ATBM8830=m CONFIG_DVB_HELENE=m CONFIG_DVB_HORUS3A=m CONFIG_DVB_ISL6405=m CONFIG_DVB_ISL6421=m CONFIG_DVB_ISL6423=m CONFIG_DVB_IX2505V=m CONFIG_DVB_LGS8GL5=m CONFIG_DVB_LGS8GXX=m CONFIG_DVB_LNBH25=m CONFIG_DVB_LNBH29=m CONFIG_DVB_LNBP21=m CONFIG_DVB_LNBP22=m CONFIG_DVB_M88RS2000=m CONFIG_DVB_TDA665x=m CONFIG_DVB_DRX39XYJ=m # # Common Interface (EN50221) controller drivers # CONFIG_DVB_CXD2099=m CONFIG_DVB_SP2=m # end of Customise DVB Frontends # # Tools to develop new frontends # # CONFIG_DVB_DUMMY_FE is not set # end of Media ancillary drivers # # Graphics support # # CONFIG_IMX_IPUV3_CORE is not set CONFIG_DRM=y CONFIG_DRM_MIPI_DSI=y # CONFIG_DRM_DEBUG_MM is not set CONFIG_DRM_KMS_HELPER=y # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set # CONFIG_DRM_DEBUG_MODESET_LOCK is not set # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set CONFIG_DRM_DISPLAY_HELPER=y CONFIG_DRM_DISPLAY_DP_HELPER=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DP_CEC is not set CONFIG_DRM_GEM_DMA_HELPER=y # # I2C encoder or helper chips # # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set CONFIG_DRM_I2C_NXP_TDA998X=y # CONFIG_DRM_I2C_NXP_TDA9950 is not set # end of I2C encoder or helper chips # # ARM devices # # CONFIG_DRM_HDLCD is not set # CONFIG_DRM_MALI_DISPLAY is not set # CONFIG_DRM_KOMEDA is not set # end of ARM devices # CONFIG_DRM_RADEON is not set # CONFIG_DRM_AMDGPU is not set # CONFIG_DRM_NOUVEAU is not set # CONFIG_DRM_VGEM is not set # CONFIG_DRM_VKMS is not set # CONFIG_DRM_EXYNOS is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_AST is not set # CONFIG_DRM_MGAG200 is not set # CONFIG_DRM_ARMADA is not set # CONFIG_DRM_RCAR_DW_HDMI is not set # CONFIG_DRM_RCAR_USE_LVDS is not set # CONFIG_DRM_RCAR_USE_MIPI_DSI is not set CONFIG_DRM_OMAP=y # CONFIG_OMAP2_DSS_DEBUG is not set CONFIG_OMAP2_DSS_DEBUGFS=y # CONFIG_OMAP2_DSS_COLLECT_IRQ_STATS is not set CONFIG_OMAP2_DSS_DPI=y # CONFIG_OMAP2_DSS_VENC is not set CONFIG_OMAP2_DSS_HDMI_COMMON=y CONFIG_OMAP4_DSS_HDMI=y CONFIG_OMAP4_DSS_HDMI_CEC=y CONFIG_OMAP5_DSS_HDMI=y # CONFIG_OMAP2_DSS_SDI is not set # CONFIG_OMAP2_DSS_DSI is not set CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0 CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y CONFIG_DRM_TILCDC=y # CONFIG_DRM_QXL is not set # CONFIG_DRM_VIRTIO_GPU is not set # CONFIG_DRM_FSL_DCU is not set # CONFIG_DRM_STM is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_ABT_Y030XX067A is not set # CONFIG_DRM_PANEL_ARM_VERSATILE is not set # CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set # CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set # CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set # CONFIG_DRM_PANEL_BOE_TV101WUM_NL6 is not set # CONFIG_DRM_PANEL_DSI_CM is not set # CONFIG_DRM_PANEL_LVDS is not set CONFIG_DRM_PANEL_SIMPLE=y # CONFIG_DRM_PANEL_EDP is not set # CONFIG_DRM_PANEL_EBBG_FT8719 is not set # CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set # CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set # CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set # CONFIG_DRM_PANEL_JDI_R63452 is not set # CONFIG_DRM_PANEL_KHADAS_TS050 is not set # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set # CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set # CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set # CONFIG_DRM_PANEL_LG_LB035Q02 is not set # CONFIG_DRM_PANEL_LG_LG4573 is not set # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set # CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set # CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set # CONFIG_DRM_PANEL_NOVATEK_NT35560 is not set # CONFIG_DRM_PANEL_NOVATEK_NT35950 is not set # CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set # CONFIG_DRM_PANEL_MANTIX_MLAF057WE51 is not set # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS=y # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set # CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set # CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set # CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set # CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7703 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set # CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set # CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set # CONFIG_DRM_PANEL_TPO_TPG110 is not set # CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set # CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set # CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set # CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set # end of Display Panels CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_CHIPONE_ICN6211 is not set # CONFIG_DRM_CHRONTEL_CH7033 is not set # CONFIG_DRM_DISPLAY_CONNECTOR is not set # CONFIG_DRM_ITE_IT6505 is not set # CONFIG_DRM_LONTIUM_LT8912B is not set # CONFIG_DRM_LONTIUM_LT9211 is not set # CONFIG_DRM_LONTIUM_LT9611 is not set # CONFIG_DRM_LONTIUM_LT9611UXC is not set # CONFIG_DRM_ITE_IT66121 is not set # CONFIG_DRM_LVDS_CODEC is not set # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set # CONFIG_DRM_NWL_MIPI_DSI is not set # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set # CONFIG_DRM_PARADE_PS8640 is not set # CONFIG_DRM_SIL_SII8620 is not set CONFIG_DRM_SII902X=y # CONFIG_DRM_SII9234 is not set # CONFIG_DRM_SIMPLE_BRIDGE is not set # CONFIG_DRM_THINE_THC63LVD1024 is not set # CONFIG_DRM_TOSHIBA_TC358762 is not set # CONFIG_DRM_TOSHIBA_TC358764 is not set CONFIG_DRM_TOSHIBA_TC358767=y CONFIG_DRM_TOSHIBA_TC358768=y # CONFIG_DRM_TOSHIBA_TC358775 is not set # CONFIG_DRM_TI_DLPC3433 is not set CONFIG_DRM_TI_TFP410=y # CONFIG_DRM_TI_SN65DSI83 is not set # CONFIG_DRM_TI_SN65DSI86 is not set # CONFIG_DRM_TI_TPD12S015 is not set # CONFIG_DRM_ANALOGIX_ANX6345 is not set # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_ANALOGIX_ANX7625 is not set # CONFIG_DRM_I2C_ADV7511 is not set # CONFIG_DRM_CDNS_DSI is not set # CONFIG_DRM_CDNS_MHDP8546 is not set # end of Display Interface Bridges # CONFIG_DRM_STI is not set # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_LOGICVC is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_BOCHS is not set # CONFIG_DRM_CIRRUS_QEMU is not set # CONFIG_DRM_GM12U320 is not set # CONFIG_DRM_PANEL_MIPI_DBI is not set # CONFIG_DRM_SIMPLEDRM is not set # CONFIG_TINYDRM_HX8357D is not set # CONFIG_TINYDRM_ILI9163 is not set # CONFIG_TINYDRM_ILI9225 is not set # CONFIG_TINYDRM_ILI9341 is not set # CONFIG_TINYDRM_ILI9486 is not set # CONFIG_TINYDRM_MI0283QT is not set # CONFIG_TINYDRM_REPAPER is not set # CONFIG_TINYDRM_ST7586 is not set # CONFIG_TINYDRM_ST7735R is not set # CONFIG_DRM_PL111 is not set # CONFIG_DRM_TVE200 is not set # CONFIG_DRM_LIMA is not set # CONFIG_DRM_PANFROST is not set # CONFIG_DRM_MCDE is not set CONFIG_DRM_TIDSS=y # CONFIG_DRM_GUD is not set # CONFIG_DRM_SSD130X is not set CONFIG_DRM_LEGACY=y # CONFIG_DRM_TDFX is not set # CONFIG_DRM_R128 is not set # CONFIG_DRM_MGA is not set # CONFIG_DRM_VIA is not set # CONFIG_DRM_SAVAGE is not set CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y CONFIG_DRM_NOMODESET=y # # Frame buffer Devices # CONFIG_FB_CMDLINE=y # CONFIG_FB is not set # end of Frame buffer Devices # # Backlight & LCD device support # # CONFIG_LCD_CLASS_DEVICE is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y # CONFIG_BACKLIGHT_KTD253 is not set # CONFIG_BACKLIGHT_QCOM_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3639 is not set # CONFIG_BACKLIGHT_TPS65217 is not set CONFIG_BACKLIGHT_GPIO=y # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set # CONFIG_BACKLIGHT_ARCXCNN is not set CONFIG_BACKLIGHT_LED=y # end of Backlight & LCD device support CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y # end of Console display driver support # end of Graphics support CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_PCM_ELD=y CONFIG_SND_PCM_IEC958=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set CONFIG_SND_CTL_FAST_LOOKUP=y # CONFIG_SND_DEBUG is not set # CONFIG_SND_CTL_INPUT_VALIDATION is not set # CONFIG_SND_SEQUENCER is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_SERIAL_GENERIC is not set # CONFIG_SND_MPU401 is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LOLA is not set # CONFIG_SND_LX6464ES is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SE6X is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # # HD-Audio # # CONFIG_SND_HDA_INTEL is not set # end of HD-Audio CONFIG_SND_HDA_PREALLOC_SIZE=64 # CONFIG_SND_ARM is not set # CONFIG_SND_SPI is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=m CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_ADI is not set # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_AMD_ACP_CONFIG is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set # CONFIG_SND_SOC_FSL_SAI is not set # CONFIG_SND_SOC_FSL_AUDMIX is not set # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_FSL_MICFIL is not set # CONFIG_SND_SOC_FSL_XCVR is not set # CONFIG_SND_SOC_FSL_RPMSG is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # end of SoC Audio for Freescale CPUs # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set # CONFIG_SND_SOC_SOF_TOPLEVEL is not set # # STMicroelectronics STM32 SOC audio support # # end of STMicroelectronics STM32 SOC audio support # # Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_TI_EDMA_PCM=y CONFIG_SND_SOC_TI_SDMA_PCM=y CONFIG_SND_SOC_TI_UDMA_PCM=y # # Texas Instruments DAI support for: # CONFIG_SND_SOC_DAVINCI_MCASP=y # CONFIG_SND_SOC_OMAP_MCBSP is not set # # Audio support for boards with Texas Instruments SoCs # CONFIG_SND_SOC_OMAP_HDMI=m # end of Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1372_I2C is not set # CONFIG_SND_SOC_ADAU1372_SPI is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_ADAU7118_HW is not set # CONFIG_SND_SOC_ADAU7118_I2C is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4375 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_AW8738 is not set # CONFIG_SND_SOC_BD28623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CPCAP is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS35L41_SPI is not set # CONFIG_SND_SOC_CS35L41_I2C is not set # CONFIG_SND_SOC_CS35L45_SPI is not set # CONFIG_SND_SOC_CS35L45_I2C is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS42L83 is not set # CONFIG_SND_SOC_CS4234 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_CX2072X is not set # CONFIG_SND_SOC_DA7213 is not set # CONFIG_SND_SOC_DMIC is not set CONFIG_SND_SOC_HDMI_CODEC=y # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8326 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_HDA is not set # CONFIG_SND_SOC_ICS43432 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set # CONFIG_SND_SOC_MAX98357A is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set # CONFIG_SND_SOC_MAX98927 is not set # CONFIG_SND_SOC_MAX98520 is not set # CONFIG_SND_SOC_MAX98373_I2C is not set # CONFIG_SND_SOC_MAX98390 is not set # CONFIG_SND_SOC_MAX98396 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_MSM8916_WCD_ANALOG is not set # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM186X_SPI is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3060_SPI is not set CONFIG_SND_SOC_PCM3168A=m CONFIG_SND_SOC_PCM3168A_I2C=m # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM5102A is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_RT5640 is not set # CONFIG_SND_SOC_RT5659 is not set # CONFIG_SND_SOC_RT9120 is not set # CONFIG_SND_SOC_SGTL5000 is not set # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set # CONFIG_SND_SOC_SIMPLE_MUX is not set CONFIG_SND_SOC_SPDIF=m # CONFIG_SND_SOC_SRC4XXX_I2C is not set # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2518 is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS2562 is not set # CONFIG_SND_SOC_TAS2764 is not set # CONFIG_SND_SOC_TAS2770 is not set # CONFIG_SND_SOC_TAS2780 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS5805M is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TFA989X is not set # CONFIG_SND_SOC_TLV320ADC3XXX is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set CONFIG_SND_SOC_TLV320AIC31XX=m # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set # CONFIG_SND_SOC_TLV320AIC3X_I2C is not set # CONFIG_SND_SOC_TLV320AIC3X_SPI is not set # CONFIG_SND_SOC_TLV320ADCX140 is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_UDA1334 is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8524 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731_I2C is not set # CONFIG_SND_SOC_WM8731_SPI is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set # CONFIG_SND_SOC_WM8904 is not set # CONFIG_SND_SOC_WM8940 is not set # CONFIG_SND_SOC_WM8960 is not set # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set # CONFIG_SND_SOC_WM8978 is not set # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_ZL38060 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_MT6660 is not set # CONFIG_SND_SOC_NAU8315 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8821 is not set # CONFIG_SND_SOC_NAU8822 is not set # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set # CONFIG_SND_SOC_LPASS_WSA_MACRO is not set # CONFIG_SND_SOC_LPASS_VA_MACRO is not set # CONFIG_SND_SOC_LPASS_RX_MACRO is not set # CONFIG_SND_SOC_LPASS_TX_MACRO is not set # end of CODEC drivers CONFIG_SND_SIMPLE_CARD_UTILS=m CONFIG_SND_SIMPLE_CARD=m CONFIG_SND_AUDIO_GRAPH_CARD=m # CONFIG_SND_AUDIO_GRAPH_CARD2 is not set # CONFIG_SND_TEST_COMPONENT is not set # CONFIG_SND_VIRTIO is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACCUTOUCH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_ASUS is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_BETOP_FF is not set # CONFIG_HID_BIGBEN_FF is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CORSAIR is not set # CONFIG_HID_COUGAR is not set # CONFIG_HID_MACALLY is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set # CONFIG_HID_CREATIVE_SB0540 is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELAN is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_GLORIOUS is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_VIVALDI is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_VIEWSONIC is not set # CONFIG_HID_VRC2 is not set # CONFIG_HID_XIAOMI is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_ITE is not set # CONFIG_HID_JABRA is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_LETSKETCH is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MALTRON is not set # CONFIG_HID_MAYFLASH is not set # CONFIG_HID_MEGAWORLD_FF is not set # CONFIG_HID_REDRAGON is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set CONFIG_HID_MULTITOUCH=m # CONFIG_HID_NINTENDO is not set # CONFIG_HID_NTI is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PXRC is not set # CONFIG_HID_RAZER is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_RETRODE is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SEMITEK is not set # CONFIG_HID_SIGMAMICRO is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEAM is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_TOPRE is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_U2FZERO is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # CONFIG_HID_MCP2221 is not set # end of Special HID drivers # # USB HID support # CONFIG_USB_HID=m # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # # USB HID Boot Protocol drivers # # CONFIG_USB_KBD is not set # CONFIG_USB_MOUSE is not set # end of USB HID Boot Protocol drivers # end of USB HID support # # I2C HID support # # CONFIG_I2C_HID_OF is not set # CONFIG_I2C_HID_OF_ELAN is not set # CONFIG_I2C_HID_OF_GOODIX is not set # end of I2C HID support # end of HID support CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y # CONFIG_USB_LED_TRIG is not set # CONFIG_USB_ULPI_BUS is not set # CONFIG_USB_CONN_GPIO is not set CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y CONFIG_USB_PCI=y CONFIG_USB_ANNOUNCE_NEW_DEVICES=y # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y CONFIG_USB_FEW_INIT_RETRIES=y CONFIG_USB_DYNAMIC_MINORS=y CONFIG_USB_OTG=y # CONFIG_USB_OTG_PRODUCTLIST is not set # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set CONFIG_USB_OTG_FSM=y # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set CONFIG_USB_AUTOSUSPEND_DELAY=2 # CONFIG_USB_MON is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DBGCAP=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_XHCI_PCI_RENESAS=y CONFIG_USB_XHCI_PLATFORM=y CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_ROOT_HUB_TT is not set CONFIG_USB_EHCI_TT_NEWSCHED=y CONFIG_USB_EHCI_PCI=y # CONFIG_USB_EHCI_FSL is not set CONFIG_USB_EHCI_HCD_OMAP=m CONFIG_USB_EHCI_HCD_PLATFORM=y CONFIG_USB_OXU210HP_HCD=y CONFIG_USB_ISP116X_HCD=y CONFIG_USB_FOTG210_HCD=y CONFIG_USB_MAX3421_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_HCD_PCI=y CONFIG_USB_OHCI_HCD_PLATFORM=y CONFIG_USB_UHCI_HCD=y CONFIG_USB_SL811_HCD=y # CONFIG_USB_SL811_HCD_ISO is not set CONFIG_USB_R8A66597_HCD=y # CONFIG_USB_HCD_BCMA is not set CONFIG_USB_HCD_SSB=m # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=y # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set CONFIG_USB_TMC=y # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y CONFIG_USB_STORAGE_DEBUG=y # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set CONFIG_USB_UAS=m # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set # CONFIG_USB_CDNS_SUPPORT is not set CONFIG_USB_MUSB_HDRC=y CONFIG_USB_MUSB_HOST=y # CONFIG_USB_MUSB_GADGET is not set # CONFIG_USB_MUSB_DUAL_ROLE is not set # # Platform Glue Layer # CONFIG_USB_MUSB_OMAP2PLUS=y CONFIG_USB_MUSB_AM35X=m CONFIG_USB_MUSB_DSPS=y # # MUSB DMA mode # # CONFIG_MUSB_PIO_ONLY is not set CONFIG_USB_INVENTRA_DMA=y CONFIG_USB_TI_CPPI41_DMA=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_HOST=y # CONFIG_USB_DWC3_GADGET is not set # CONFIG_USB_DWC3_DUAL_ROLE is not set # # Platform Glue Driver Support # CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_HAPS=y CONFIG_USB_DWC3_OF_SIMPLE=y CONFIG_USB_DWC2=y # CONFIG_USB_DWC2_HOST is not set # # Gadget/Dual-role mode requires USB Gadget support to be enabled # # CONFIG_USB_DWC2_PERIPHERAL is not set CONFIG_USB_DWC2_DUAL_ROLE=y # CONFIG_USB_DWC2_PCI is not set # CONFIG_USB_DWC2_DEBUG is not set # CONFIG_USB_DWC2_TRACK_MISSED_SOFS is not set # CONFIG_USB_CHIPIDEA is not set CONFIG_USB_ISP1760=m CONFIG_USB_ISP1760_HCD=y CONFIG_USB_ISP1761_UDC=y # CONFIG_USB_ISP1760_HOST_ROLE is not set # CONFIG_USB_ISP1760_GADGET_ROLE is not set CONFIG_USB_ISP1760_DUAL_ROLE=y # # USB port drivers # CONFIG_USB_SERIAL=y # CONFIG_USB_SERIAL_CONSOLE is not set # CONFIG_USB_SERIAL_GENERIC is not set # CONFIG_USB_SERIAL_SIMPLE is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set CONFIG_USB_SERIAL_CP210X=m # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set CONFIG_USB_SERIAL_FTDI_SIO=m # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_F8153X is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set CONFIG_USB_SERIAL_PL2303=m # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set CONFIG_USB_SERIAL_WWAN=m CONFIG_USB_SERIAL_OPTION=m # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_UPD78F0730 is not set # CONFIG_USB_SERIAL_XR is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_APPLE_MFI_FASTCHARGE is not set CONFIG_USB_SISUSBVGA=y # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set CONFIG_USB_TEST=y # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HUB_USB251XB is not set CONFIG_USB_HSIC_USB3503=y # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # CONFIG_USB_CHAOSKEY is not set # CONFIG_USB_ONBOARD_HUB is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=m CONFIG_AM335X_CONTROL_USB=m CONFIG_AM335X_PHY_USB=m CONFIG_USB_GPIO_VBUS=m CONFIG_USB_ISP1301=m # CONFIG_USB_ULPI is not set # end of USB Physical Layer drivers CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32 # CONFIG_U_SERIAL_CONSOLE is not set # # USB Peripheral Controller # # CONFIG_USB_FUSB300 is not set # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set # CONFIG_USB_SNP_UDC_PLAT is not set # CONFIG_USB_M66592 is not set # CONFIG_USB_BDC_UDC is not set # CONFIG_USB_AMD5536UDC is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_NET2280 is not set # CONFIG_USB_GOKU is not set # CONFIG_USB_EG20T is not set # CONFIG_USB_GADGET_XILINX is not set # CONFIG_USB_MAX3420_UDC is not set # CONFIG_USB_DUMMY_HCD is not set # end of USB Peripheral Controller CONFIG_USB_LIBCOMPOSITE=m CONFIG_USB_F_ACM=m CONFIG_USB_F_SS_LB=m CONFIG_USB_U_SERIAL=m CONFIG_USB_U_ETHER=m CONFIG_USB_U_AUDIO=m CONFIG_USB_F_SERIAL=m CONFIG_USB_F_OBEX=m CONFIG_USB_F_NCM=m CONFIG_USB_F_ECM=m CONFIG_USB_F_EEM=m CONFIG_USB_F_SUBSET=m CONFIG_USB_F_RNDIS=m CONFIG_USB_F_MASS_STORAGE=m CONFIG_USB_F_FS=m CONFIG_USB_F_UAC1=m CONFIG_USB_F_UAC1_LEGACY=m CONFIG_USB_F_UAC2=m CONFIG_USB_F_UVC=m CONFIG_USB_F_MIDI=m CONFIG_USB_F_HID=m CONFIG_USB_F_PRINTER=m CONFIG_USB_CONFIGFS=m CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_OBEX=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_ECM_SUBSET=y CONFIG_USB_CONFIGFS_RNDIS=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y CONFIG_USB_CONFIGFS_F_LB_SS=y CONFIG_USB_CONFIGFS_F_FS=y CONFIG_USB_CONFIGFS_F_UAC1=y CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y CONFIG_USB_CONFIGFS_F_UAC2=y CONFIG_USB_CONFIGFS_F_MIDI=y CONFIG_USB_CONFIGFS_F_HID=y CONFIG_USB_CONFIGFS_F_UVC=y CONFIG_USB_CONFIGFS_F_PRINTER=y # # USB Gadget precomposed configurations # CONFIG_USB_ZERO=m # CONFIG_USB_ZERO_HNPTEST is not set CONFIG_USB_AUDIO=m # CONFIG_GADGET_UAC1 is not set CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set CONFIG_USB_G_NCM=m CONFIG_USB_GADGETFS=m CONFIG_USB_FUNCTIONFS=m CONFIG_USB_FUNCTIONFS_ETH=y CONFIG_USB_FUNCTIONFS_RNDIS=y CONFIG_USB_FUNCTIONFS_GENERIC=y CONFIG_USB_MASS_STORAGE=m CONFIG_USB_G_SERIAL=m CONFIG_USB_MIDI_GADGET=m CONFIG_USB_G_PRINTER=m CONFIG_USB_CDC_COMPOSITE=m CONFIG_USB_G_ACM_MS=m CONFIG_USB_G_MULTI=m CONFIG_USB_G_MULTI_RNDIS=y CONFIG_USB_G_MULTI_CDC=y CONFIG_USB_G_HID=m CONFIG_USB_G_DBGP=m # CONFIG_USB_G_DBGP_PRINTK is not set CONFIG_USB_G_DBGP_SERIAL=y CONFIG_USB_G_WEBCAM=m # CONFIG_USB_RAW_GADGET is not set # end of USB Gadget precomposed configurations # CONFIG_TYPEC is not set CONFIG_USB_ROLE_SWITCH=y CONFIG_MMC=y CONFIG_PWRSEQ_EMMC=y # CONFIG_PWRSEQ_SD8787 is not set CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=16 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_DEBUG is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_IO_ACCESSORS=y # CONFIG_MMC_SDHCI_PCI is not set CONFIG_MMC_SDHCI_PLTFM=y CONFIG_MMC_SDHCI_OF_ARASAN=y CONFIG_MMC_SDHCI_OF_AT91=y # CONFIG_MMC_SDHCI_OF_DWCMSHC is not set # CONFIG_MMC_SDHCI_CADENCE is not set # CONFIG_MMC_SDHCI_F_SDH30 is not set # CONFIG_MMC_SDHCI_MILBEAUT is not set CONFIG_MMC_OMAP=y CONFIG_MMC_OMAP_HS=y # CONFIG_MMC_TIFM_SD is not set # CONFIG_MMC_SPI is not set # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set CONFIG_MMC_CQHCI=y # CONFIG_MMC_HSQ is not set # CONFIG_MMC_TOSHIBA_PCI is not set # CONFIG_MMC_MTK is not set # CONFIG_MMC_SDHCI_XENON is not set CONFIG_MMC_SDHCI_OMAP=y CONFIG_MMC_SDHCI_AM654=y CONFIG_MMC_SDHCI_EXTERNAL_DMA=y # CONFIG_SCSI_UFSHCD is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y CONFIG_LEDS_CLASS_FLASH=m # CONFIG_LEDS_CLASS_MULTICOLOR is not set # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_AN30259A is not set # CONFIG_LEDS_AW2013 is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set CONFIG_LEDS_CPCAP=m # CONFIG_LEDS_CR0014114 is not set # CONFIG_LEDS_EL15203000 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3532 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_LM3692X is not set # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP50XX is not set # CONFIG_LEDS_LP55XX_COMMON is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set CONFIG_LEDS_TLC591XX=y # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set # CONFIG_LEDS_SYSCON is not set # CONFIG_LEDS_MLXREG is not set # CONFIG_LEDS_USER is not set # CONFIG_LEDS_SPI_BYTE is not set # CONFIG_LEDS_TI_LMU_COMMON is not set # # Flash and Torch LED drivers # # CONFIG_LEDS_AAT1290 is not set # CONFIG_LEDS_AS3645A is not set # CONFIG_LEDS_KTD2692 is not set # CONFIG_LEDS_LM3601X is not set # CONFIG_LEDS_RT4505 is not set # CONFIG_LEDS_RT8515 is not set # CONFIG_LEDS_SGM3140 is not set # # RGB LED drivers # # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_ONESHOT=y # CONFIG_LEDS_TRIGGER_DISK is not set # CONFIG_LEDS_TRIGGER_MTD is not set CONFIG_LEDS_TRIGGER_HEARTBEAT=y CONFIG_LEDS_TRIGGER_BACKLIGHT=y CONFIG_LEDS_TRIGGER_CPU=y # CONFIG_LEDS_TRIGGER_ACTIVITY is not set CONFIG_LEDS_TRIGGER_GPIO=y CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # CONFIG_LEDS_TRIGGER_TRANSIENT=y CONFIG_LEDS_TRIGGER_CAMERA=y # CONFIG_LEDS_TRIGGER_PANIC is not set # CONFIG_LEDS_TRIGGER_NETDEV is not set # CONFIG_LEDS_TRIGGER_PATTERN is not set # CONFIG_LEDS_TRIGGER_AUDIO is not set # CONFIG_LEDS_TRIGGER_TTY is not set # # Simple LED drivers # # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" CONFIG_RTC_DEBUG=y CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set CONFIG_RTC_DRV_DS1307=m # CONFIG_RTC_DRV_DS1307_CENTURY is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_NCT3018Y is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_ISL12026 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF85363 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set CONFIG_RTC_DRV_PALMAS=m CONFIG_RTC_DRV_TPS6586X=m CONFIG_RTC_DRV_TPS65910=m # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV3028 is not set # CONFIG_RTC_DRV_RV3032 is not set # CONFIG_RTC_DRV_RV8803 is not set # CONFIG_RTC_DRV_SD3078 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # CONFIG_RTC_DRV_RX6110 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set CONFIG_RTC_DRV_EFI=m # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_OPTEE is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_OMAP=m # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set # CONFIG_RTC_DRV_R7301 is not set CONFIG_RTC_DRV_CPCAP=m # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_GOLDFISH is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set # CONFIG_DW_AXI_DMAC is not set CONFIG_FSL_EDMA=y # CONFIG_FSL_QDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_NBPFAXI_DMA is not set # CONFIG_PLX_DMA is not set # CONFIG_XILINX_ZYNQMP_DPDMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set CONFIG_DW_DMAC_CORE=y CONFIG_DW_DMAC=y # CONFIG_DW_DMAC_PCI is not set # CONFIG_DW_EDMA is not set # CONFIG_DW_EDMA_PCIE is not set # CONFIG_SF_PDMA is not set CONFIG_TI_CPPI41=y CONFIG_TI_EDMA=y CONFIG_DMA_OMAP=y CONFIG_TI_DMA_CROSSBAR=y # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_UDMABUF is not set # CONFIG_DMABUF_MOVE_NOTIFY is not set # CONFIG_DMABUF_DEBUG is not set # CONFIG_DMABUF_SELFTESTS is not set # CONFIG_DMABUF_HEAPS is not set # CONFIG_DMABUF_SYSFS_STATS is not set # end of DMABUF options # CONFIG_AUXDISPLAY is not set CONFIG_UIO=m # CONFIG_UIO_CIF is not set # CONFIG_UIO_PDRV_GENIRQ is not set # CONFIG_UIO_DMEM_GENIRQ is not set # CONFIG_UIO_AEC is not set # CONFIG_UIO_SERCOS3 is not set # CONFIG_UIO_PCI_GENERIC is not set # CONFIG_UIO_NETX is not set # CONFIG_UIO_PRUSS is not set # CONFIG_UIO_MF624 is not set # CONFIG_VFIO is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO_ANCHOR=y CONFIG_VIRTIO=y CONFIG_VIRTIO_PCI_LIB=y CONFIG_VIRTIO_PCI_LIB_LEGACY=y CONFIG_VIRTIO_MENU=y CONFIG_VIRTIO_PCI=y CONFIG_VIRTIO_PCI_LEGACY=y # CONFIG_VIRTIO_BALLOON is not set # CONFIG_VIRTIO_INPUT is not set CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # CONFIG_VDPA is not set CONFIG_VHOST_MENU=y # CONFIG_VHOST_NET is not set # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set # # Microsoft Hyper-V guest support # # end of Microsoft Hyper-V guest support # CONFIG_GREYBUS is not set # CONFIG_COMEDI is not set # CONFIG_STAGING is not set # CONFIG_GOLDFISH is not set # CONFIG_CHROME_PLATFORMS is not set # CONFIG_MELLANOX_PLATFORM is not set CONFIG_HAVE_CLK=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Clock driver for ARM Reference designs # # CONFIG_CLK_ICST is not set # CONFIG_CLK_SP810 is not set # end of Clock driver for ARM Reference designs # CONFIG_LMK04832 is not set # CONFIG_COMMON_CLK_MAX9485 is not set # CONFIG_COMMON_CLK_SI5341 is not set # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_CLK_TWL6040 is not set # CONFIG_COMMON_CLK_AXI_CLKGEN is not set CONFIG_COMMON_CLK_PALMAS=y # CONFIG_COMMON_CLK_RS9_PCIE is not set # CONFIG_COMMON_CLK_VC5 is not set # CONFIG_COMMON_CLK_VC7 is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set # CONFIG_COMMON_CLK_TI_ADPLL is not set # CONFIG_XILINX_VCU is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set CONFIG_HWSPINLOCK=y CONFIG_HWSPINLOCK_OMAP=y # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_OMAP_DM_SYSTIMER=y CONFIG_CLKSRC_MMIO=y CONFIG_OMAP_DM_TIMER=y CONFIG_CLKSRC_TI_32K=y # CONFIG_MICROCHIP_PIT64B is not set # end of Clock Source drivers # CONFIG_MAILBOX is not set CONFIG_IOMMU_API=y CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set # end of Generic IOMMU Pagetable Support # CONFIG_IOMMU_DEBUGFS is not set CONFIG_IOMMU_DEFAULT_DMA_STRICT=y # CONFIG_IOMMU_DEFAULT_DMA_LAZY is not set # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set CONFIG_OF_IOMMU=y CONFIG_OMAP_IOMMU=y CONFIG_OMAP_IOMMU_DEBUG=y # CONFIG_ARM_SMMU is not set # # Remoteproc drivers # # CONFIG_REMOTEPROC is not set # end of Remoteproc drivers # # Rpmsg drivers # CONFIG_RPMSG=m # CONFIG_RPMSG_CHAR is not set # CONFIG_RPMSG_CTRL is not set CONFIG_RPMSG_NS=m CONFIG_RPMSG_VIRTIO=m # end of Rpmsg drivers # # Rpmsg virtual device drivers # CONFIG_RPMSG_KDRV=m # CONFIG_RPMSG_KDRV_DEMO is not set # CONFIG_RPMSG_KDRV_DISPLAY is not set CONFIG_RPMSG_KDRV_ETH_SWITCH=m # end of Rpmsg virtual device drivers # CONFIG_SOUNDWIRE is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # end of Amlogic SoC drivers # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # end of Broadcom SoC drivers # # NXP/Freescale QorIQ SoC drivers # # CONFIG_QUICC_ENGINE is not set # CONFIG_FSL_RCPM is not set # end of NXP/Freescale QorIQ SoC drivers # # fujitsu SoC drivers # # end of fujitsu SoC drivers # # i.MX SoC drivers # # end of i.MX SoC drivers # # Enable LiteX SoC Builder specific drivers # # CONFIG_LITEX_SOC_CONTROLLER is not set # end of Enable LiteX SoC Builder specific drivers # # Qualcomm SoC drivers # # end of Qualcomm SoC drivers CONFIG_SOC_TI=y CONFIG_TI_PRUSS=m # # Xilinx SoC drivers # # end of Xilinx SoC drivers # end of SOC (System On Chip) specific Drivers # CONFIG_PM_DEVFREQ is not set CONFIG_EXTCON=y # # Extcon Device Drivers # # CONFIG_EXTCON_ADC_JACK is not set # CONFIG_EXTCON_FSA9480 is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set CONFIG_EXTCON_PALMAS=m # CONFIG_EXTCON_PTN5150 is not set # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set CONFIG_EXTCON_USB_GPIO=y CONFIG_MEMORY=y # CONFIG_TI_EMIF is not set CONFIG_OMAP_GPMC=y # CONFIG_OMAP_GPMC_DEBUG is not set CONFIG_TI_EMIF_SRAM=m CONFIG_IIO=y CONFIG_IIO_BUFFER=y # CONFIG_IIO_BUFFER_CB is not set # CONFIG_IIO_BUFFER_DMA is not set # CONFIG_IIO_BUFFER_DMAENGINE is not set # CONFIG_IIO_BUFFER_HW_CONSUMER is not set CONFIG_IIO_KFIFO_BUF=y CONFIG_IIO_TRIGGERED_BUFFER=y CONFIG_IIO_CONFIGFS=y CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 # CONFIG_IIO_SW_DEVICE is not set CONFIG_IIO_SW_TRIGGER=y # CONFIG_IIO_TRIGGERED_EVENT is not set # # Accelerometers # # CONFIG_ADIS16201 is not set # CONFIG_ADIS16209 is not set # CONFIG_ADXL313_I2C is not set # CONFIG_ADXL313_SPI is not set # CONFIG_ADXL355_I2C is not set # CONFIG_ADXL355_SPI is not set # CONFIG_ADXL367_SPI is not set # CONFIG_ADXL367_I2C is not set # CONFIG_ADXL372_SPI is not set # CONFIG_ADXL372_I2C is not set # CONFIG_BMA180 is not set # CONFIG_BMA220 is not set # CONFIG_BMA400 is not set # CONFIG_BMC150_ACCEL is not set # CONFIG_BMI088_ACCEL is not set # CONFIG_DA280 is not set # CONFIG_DA311 is not set # CONFIG_DMARD06 is not set # CONFIG_DMARD09 is not set # CONFIG_DMARD10 is not set # CONFIG_FXLS8962AF_I2C is not set # CONFIG_FXLS8962AF_SPI is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # CONFIG_KXCJK1013 is not set # CONFIG_MC3230 is not set # CONFIG_MMA7455_I2C is not set # CONFIG_MMA7455_SPI is not set # CONFIG_MMA7660 is not set # CONFIG_MMA8452 is not set # CONFIG_MMA9551 is not set # CONFIG_MMA9553 is not set # CONFIG_MSA311 is not set # CONFIG_MXC4005 is not set # CONFIG_MXC6255 is not set # CONFIG_SCA3000 is not set # CONFIG_SCA3300 is not set # CONFIG_STK8312 is not set # CONFIG_STK8BA50 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7091R5 is not set # CONFIG_AD7124 is not set # CONFIG_AD7192 is not set # CONFIG_AD7266 is not set # CONFIG_AD7280 is not set # CONFIG_AD7291 is not set # CONFIG_AD7292 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7606_IFACE_PARALLEL is not set # CONFIG_AD7606_IFACE_SPI is not set # CONFIG_AD7766 is not set # CONFIG_AD7768_1 is not set # CONFIG_AD7780 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_AD7949 is not set # CONFIG_AD799X is not set # CONFIG_ADI_AXI_ADC is not set # CONFIG_CC10001_ADC is not set CONFIG_CPCAP_ADC=m # CONFIG_ENVELOPE_DETECTOR is not set # CONFIG_HI8435 is not set # CONFIG_HX711 is not set # CONFIG_INA2XX_ADC is not set # CONFIG_LTC2471 is not set # CONFIG_LTC2485 is not set # CONFIG_LTC2496 is not set # CONFIG_LTC2497 is not set # CONFIG_MAX1027 is not set # CONFIG_MAX11100 is not set # CONFIG_MAX1118 is not set # CONFIG_MAX11205 is not set # CONFIG_MAX1241 is not set # CONFIG_MAX1363 is not set # CONFIG_MAX9611 is not set # CONFIG_MCP320X is not set # CONFIG_MCP3422 is not set # CONFIG_MCP3911 is not set # CONFIG_NAU7802 is not set # CONFIG_PALMAS_GPADC is not set # CONFIG_QCOM_SPMI_IADC is not set # CONFIG_QCOM_SPMI_VADC is not set # CONFIG_QCOM_SPMI_ADC5 is not set # CONFIG_RICHTEK_RTQ6056 is not set # CONFIG_SD_ADC_MODULATOR is not set # CONFIG_TI_ADC081C is not set # CONFIG_TI_ADC0832 is not set # CONFIG_TI_ADC084S021 is not set # CONFIG_TI_ADC12138 is not set # CONFIG_TI_ADC108S102 is not set # CONFIG_TI_ADC128S052 is not set # CONFIG_TI_ADC161S626 is not set # CONFIG_TI_ADS1015 is not set # CONFIG_TI_ADS7950 is not set # CONFIG_TI_ADS8344 is not set # CONFIG_TI_ADS8688 is not set # CONFIG_TI_ADS124S08 is not set # CONFIG_TI_ADS131E08 is not set CONFIG_TI_AM335X_ADC=m # CONFIG_TI_TLC4541 is not set # CONFIG_TI_TSC2046 is not set CONFIG_VF610_ADC=m # CONFIG_XILINX_XADC is not set # end of Analog to digital converters # # Analog to digital and digital to analog converters # # CONFIG_AD74413R is not set # end of Analog to digital and digital to analog converters # # Analog Front Ends # # CONFIG_IIO_RESCALE is not set # end of Analog Front Ends # # Amplifiers # # CONFIG_AD8366 is not set # CONFIG_ADA4250 is not set # CONFIG_HMC425 is not set # end of Amplifiers # # Capacitance to digital converters # # CONFIG_AD7150 is not set # CONFIG_AD7746 is not set # end of Capacitance to digital converters # # Chemical Sensors # # CONFIG_ATLAS_PH_SENSOR is not set # CONFIG_ATLAS_EZO_SENSOR is not set # CONFIG_BME680 is not set # CONFIG_CCS811 is not set # CONFIG_IAQCORE is not set # CONFIG_PMS7003 is not set # CONFIG_SCD30_CORE is not set # CONFIG_SCD4X is not set # CONFIG_SENSIRION_SGP30 is not set # CONFIG_SENSIRION_SGP40 is not set # CONFIG_SPS30_I2C is not set # CONFIG_SPS30_SERIAL is not set # CONFIG_SENSEAIR_SUNRISE_CO2 is not set # CONFIG_VZ89X is not set # end of Chemical Sensors # # Hid Sensor IIO Common # # end of Hid Sensor IIO Common # # IIO SCMI Sensors # # end of IIO SCMI Sensors # # SSP Sensor Common # # CONFIG_IIO_SSP_SENSORHUB is not set # end of SSP Sensor Common # # Digital to analog converters # # CONFIG_AD3552R is not set # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5592R is not set # CONFIG_AD5593R is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_LTC2688 is not set # CONFIG_AD5686_SPI is not set # CONFIG_AD5696_I2C is not set # CONFIG_AD5755 is not set # CONFIG_AD5758 is not set # CONFIG_AD5761 is not set # CONFIG_AD5764 is not set # CONFIG_AD5766 is not set # CONFIG_AD5770R is not set # CONFIG_AD5791 is not set # CONFIG_AD7293 is not set # CONFIG_AD7303 is not set # CONFIG_AD8801 is not set # CONFIG_DPOT_DAC is not set # CONFIG_DS4424 is not set # CONFIG_LTC1660 is not set # CONFIG_LTC2632 is not set # CONFIG_M62332 is not set # CONFIG_MAX517 is not set # CONFIG_MAX5821 is not set # CONFIG_MCP4725 is not set # CONFIG_MCP4922 is not set # CONFIG_TI_DAC082S085 is not set # CONFIG_TI_DAC5571 is not set # CONFIG_TI_DAC7311 is not set # CONFIG_TI_DAC7612 is not set # CONFIG_VF610_DAC is not set # end of Digital to analog converters # # IIO dummy driver # # end of IIO dummy driver # # Filters # # end of Filters # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # end of Clock Generator/Distribution # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # CONFIG_ADF4371 is not set # CONFIG_ADMV1013 is not set # CONFIG_ADMV4420 is not set # CONFIG_ADRF6780 is not set # end of Phase-Locked Loop (PLL) frequency synthesizers # end of Frequency Synthesizers DDS/PLL # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS290 is not set # CONFIG_ADXRS450 is not set # CONFIG_BMG160 is not set # CONFIG_FXAS21002C is not set CONFIG_MPU3050=y CONFIG_MPU3050_I2C=y # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # end of Digital gyroscope sensors # # Health Sensors # # # Heart Rate Monitors # # CONFIG_AFE4403 is not set # CONFIG_AFE4404 is not set # CONFIG_MAX30100 is not set # CONFIG_MAX30102 is not set # end of Heart Rate Monitors # end of Health Sensors # # Humidity sensors # # CONFIG_AM2315 is not set # CONFIG_DHT11 is not set # CONFIG_HDC100X is not set # CONFIG_HDC2010 is not set # CONFIG_HTS221 is not set # CONFIG_HTU21 is not set # CONFIG_SI7005 is not set # CONFIG_SI7020 is not set # end of Humidity sensors # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16460 is not set # CONFIG_ADIS16475 is not set # CONFIG_ADIS16480 is not set # CONFIG_BMI160_I2C is not set # CONFIG_BMI160_SPI is not set # CONFIG_BOSCH_BNO055_SERIAL is not set # CONFIG_BOSCH_BNO055_I2C is not set # CONFIG_FXOS8700_I2C is not set # CONFIG_FXOS8700_SPI is not set # CONFIG_KMX61 is not set # CONFIG_INV_ICM42600_I2C is not set # CONFIG_INV_ICM42600_SPI is not set # CONFIG_INV_MPU6050_I2C is not set # CONFIG_INV_MPU6050_SPI is not set # CONFIG_IIO_ST_LSM6DSX is not set # CONFIG_IIO_ST_LSM9DS0 is not set # end of Inertial measurement units # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_ADUX1020 is not set # CONFIG_AL3010 is not set # CONFIG_AL3320A is not set # CONFIG_APDS9300 is not set # CONFIG_APDS9960 is not set # CONFIG_AS73211 is not set # CONFIG_BH1750 is not set # CONFIG_BH1780 is not set # CONFIG_CM32181 is not set # CONFIG_CM3232 is not set # CONFIG_CM3323 is not set # CONFIG_CM3605 is not set CONFIG_CM36651=m # CONFIG_GP2AP002 is not set # CONFIG_GP2AP020A00F is not set CONFIG_SENSORS_ISL29018=y CONFIG_SENSORS_ISL29028=y # CONFIG_ISL29125 is not set # CONFIG_JSA1212 is not set # CONFIG_RPR0521 is not set # CONFIG_LTR501 is not set # CONFIG_LTRF216A is not set # CONFIG_LV0104CS is not set # CONFIG_MAX44000 is not set # CONFIG_MAX44009 is not set # CONFIG_NOA1305 is not set # CONFIG_OPT3001 is not set # CONFIG_PA12203001 is not set # CONFIG_SI1133 is not set # CONFIG_SI1145 is not set # CONFIG_STK3310 is not set # CONFIG_ST_UVIS25 is not set # CONFIG_TCS3414 is not set # CONFIG_TCS3472 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_TSL2583 is not set # CONFIG_TSL2591 is not set # CONFIG_TSL2772 is not set # CONFIG_TSL4531 is not set # CONFIG_US5182D is not set # CONFIG_VCNL4000 is not set # CONFIG_VCNL4035 is not set # CONFIG_VEML6030 is not set # CONFIG_VEML6070 is not set # CONFIG_VL6180 is not set # CONFIG_ZOPT2201 is not set # end of Light sensors # # Magnetometer sensors # # CONFIG_AK8974 is not set CONFIG_AK8975=y # CONFIG_AK09911 is not set # CONFIG_BMC150_MAGN_I2C is not set # CONFIG_BMC150_MAGN_SPI is not set # CONFIG_MAG3110 is not set # CONFIG_MMC35240 is not set # CONFIG_IIO_ST_MAGN_3AXIS is not set # CONFIG_SENSORS_HMC5843_I2C is not set # CONFIG_SENSORS_HMC5843_SPI is not set # CONFIG_SENSORS_RM3100_I2C is not set # CONFIG_SENSORS_RM3100_SPI is not set # CONFIG_YAMAHA_YAS530 is not set # end of Magnetometer sensors # # Multiplexers # # CONFIG_IIO_MUX is not set # end of Multiplexers # # Inclinometer sensors # # end of Inclinometer sensors # # Triggers - standalone # CONFIG_IIO_HRTIMER_TRIGGER=y # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_TIGHTLOOP_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # end of Triggers - standalone # # Linear and angular position sensors # # end of Linear and angular position sensors # # Digital potentiometers # # CONFIG_AD5110 is not set # CONFIG_AD5272 is not set # CONFIG_DS1803 is not set # CONFIG_MAX5432 is not set # CONFIG_MAX5481 is not set # CONFIG_MAX5487 is not set # CONFIG_MCP4018 is not set # CONFIG_MCP4131 is not set # CONFIG_MCP4531 is not set # CONFIG_MCP41010 is not set # CONFIG_TPL0102 is not set # end of Digital potentiometers # # Digital potentiostats # # CONFIG_LMP91000 is not set # end of Digital potentiostats # # Pressure sensors # # CONFIG_ABP060MG is not set # CONFIG_BMP280 is not set # CONFIG_DLHL60D is not set # CONFIG_DPS310 is not set # CONFIG_HP03 is not set # CONFIG_ICP10100 is not set # CONFIG_MPL115_I2C is not set # CONFIG_MPL115_SPI is not set # CONFIG_MPL3115 is not set # CONFIG_MS5611 is not set # CONFIG_MS5637 is not set # CONFIG_IIO_ST_PRESS is not set # CONFIG_T5403 is not set # CONFIG_HP206C is not set # CONFIG_ZPA2326 is not set # end of Pressure sensors # # Lightning sensors # # CONFIG_AS3935 is not set # end of Lightning sensors # # Proximity and distance sensors # # CONFIG_ISL29501 is not set # CONFIG_LIDAR_LITE_V2 is not set # CONFIG_MB1232 is not set # CONFIG_PING is not set # CONFIG_RFD77402 is not set # CONFIG_SRF04 is not set # CONFIG_SX9310 is not set # CONFIG_SX9324 is not set # CONFIG_SX9360 is not set # CONFIG_SX9500 is not set # CONFIG_SRF08 is not set # CONFIG_VCNL3020 is not set # CONFIG_VL53L0X_I2C is not set # end of Proximity and distance sensors # # Resolver to digital converters # # CONFIG_AD2S90 is not set # CONFIG_AD2S1200 is not set # end of Resolver to digital converters # # Temperature sensors # # CONFIG_LTC2983 is not set # CONFIG_MAXIM_THERMOCOUPLE is not set # CONFIG_MLX90614 is not set # CONFIG_MLX90632 is not set # CONFIG_TMP006 is not set # CONFIG_TMP007 is not set # CONFIG_TMP117 is not set # CONFIG_TSYS01 is not set # CONFIG_TSYS02D is not set # CONFIG_MAX31856 is not set # CONFIG_MAX31865 is not set # end of Temperature sensors # CONFIG_NTB is not set # CONFIG_PWM is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 # CONFIG_AL_FIC is not set CONFIG_OMAP_IRQCHIP=y # CONFIG_XILINX_INTC is not set CONFIG_TI_PRUSS_INTC=m # end of IRQ chip support # CONFIG_IPACK_BUS is not set CONFIG_ARCH_HAS_RESET_CONTROLLER=y CONFIG_RESET_CONTROLLER=y # CONFIG_RESET_SIMPLE is not set CONFIG_RESET_TI_SYSCON=y # CONFIG_RESET_TI_TPS380X is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y # CONFIG_PHY_CAN_TRANSCEIVER is not set # # PHY drivers for Broadcom platforms # # CONFIG_BCM_KONA_USB2_PHY is not set # end of PHY drivers for Broadcom platforms # CONFIG_PHY_CADENCE_TORRENT is not set # CONFIG_PHY_CADENCE_DPHY is not set # CONFIG_PHY_CADENCE_DPHY_RX is not set # CONFIG_PHY_CADENCE_SIERRA is not set # CONFIG_PHY_CADENCE_SALVO is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_LAN966X_SERDES is not set CONFIG_PHY_CPCAP_USB=m # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_PHY_OCELOT_SERDES is not set # CONFIG_PHY_SAMSUNG_USB2 is not set CONFIG_PHY_DM816X_USB=m CONFIG_OMAP_CONTROL_PHY=y CONFIG_OMAP_USB2=m CONFIG_TI_PIPE3=y CONFIG_PHY_TI_GMII_SEL=y # end of PHY Subsystem # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # # CONFIG_ARM_CCI_PMU is not set # CONFIG_ARM_CCN is not set CONFIG_ARM_PMU=y # end of Performance monitor support # CONFIG_RAS is not set # CONFIG_USB4 is not set # # Android # # CONFIG_ANDROID_BINDER_IPC is not set # end of Android # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_NVMEM_SYSFS=y # CONFIG_NVMEM_RMEM is not set # CONFIG_NVMEM_SPMI_SDAM is not set # CONFIG_NVMEM_U_BOOT_ENV is not set # # HW tracing support # # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # end of HW tracing support # CONFIG_FPGA is not set # CONFIG_FSI is not set CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_PM_OPP=y # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set # CONFIG_INTERCONNECT is not set # CONFIG_COUNTER is not set # CONFIG_MOST is not set # CONFIG_PECI is not set # CONFIG_HTE is not set # end of Device Drivers # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_VALIDATE_FS_PARSER is not set CONFIG_FS_IOMAP=y # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set CONFIG_EXT4_FS=y CONFIG_EXT4_USE_FOR_EXT2=y CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set # CONFIG_FS_VERITY is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set CONFIG_AUTOFS4_FS=y CONFIG_AUTOFS_FS=y # CONFIG_FUSE_FS is not set # CONFIG_OVERLAY_FS is not set # # Caches # # CONFIG_FSCACHE is not set # end of Caches # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # end of CD-ROM/DVD Filesystems # # DOS/FAT/EXFAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set # CONFIG_EXFAT_FS is not set CONFIG_NTFS_FS=y # CONFIG_NTFS_DEBUG is not set # CONFIG_NTFS_RW is not set # CONFIG_NTFS3_FS is not set # end of DOS/FAT/EXFAT/NT Filesystems # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_PROC_CHILDREN=y CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y CONFIG_MEMFD_CREATE=y CONFIG_CONFIGFS_FS=y CONFIG_EFIVAR_FS=m # end of Pseudo filesystems CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y CONFIG_UBIFS_FS_ZSTD=y # CONFIG_UBIFS_ATIME_SUPPORT is not set CONFIG_UBIFS_FS_XATTR=y CONFIG_UBIFS_FS_SECURITY=y # CONFIG_UBIFS_FS_AUTHENTICATION is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y CONFIG_SQUASHFS_FILE_CACHE=y # CONFIG_SQUASHFS_FILE_DIRECT is not set CONFIG_SQUASHFS_DECOMP_SINGLE=y # CONFIG_SQUASHFS_DECOMP_MULTI is not set # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set CONFIG_SQUASHFS_LZO=y CONFIG_SQUASHFS_XZ=y # CONFIG_SQUASHFS_ZSTD is not set # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set CONFIG_PSTORE=y CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240 CONFIG_PSTORE_DEFLATE_COMPRESS=y # CONFIG_PSTORE_LZO_COMPRESS is not set # CONFIG_PSTORE_LZ4_COMPRESS is not set # CONFIG_PSTORE_LZ4HC_COMPRESS is not set # CONFIG_PSTORE_842_COMPRESS is not set # CONFIG_PSTORE_ZSTD_COMPRESS is not set CONFIG_PSTORE_COMPRESS=y CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y CONFIG_PSTORE_COMPRESS_DEFAULT="deflate" CONFIG_PSTORE_CONSOLE=y CONFIG_PSTORE_PMSG=y CONFIG_PSTORE_RAM=y # CONFIG_PSTORE_BLK is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_EROFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y # CONFIG_NFS_SWAP is not set # CONFIG_NFS_V4_1 is not set CONFIG_ROOT_NFS=y # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y CONFIG_NFS_DISABLE_UDP_SUPPORT=y # CONFIG_NFSD is not set CONFIG_GRACE_PERIOD=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set CONFIG_CIFS=m CONFIG_CIFS_STATS2=y CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y # CONFIG_CIFS_UPCALL is not set CONFIG_CIFS_XATTR=y CONFIG_CIFS_POSIX=y CONFIG_CIFS_DEBUG=y # CONFIG_CIFS_DEBUG2 is not set # CONFIG_CIFS_DEBUG_DUMP_KEYS is not set # CONFIG_CIFS_DFS_UPCALL is not set # CONFIG_CIFS_SWN_UPCALL is not set # CONFIG_SMB_SERVER is not set CONFIG_SMBFS_COMMON=m # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # CONFIG_UNICODE is not set CONFIG_IO_WQ=y # end of File systems # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_REQUEST_CACHE is not set # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_TRUSTED_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf" # # Kernel hardening options # # # Memory initialization # CONFIG_INIT_STACK_NONE=y # CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y # CONFIG_ZERO_CALL_USED_REGS is not set # end of Memory initialization CONFIG_RANDSTRUCT_NONE=y # CONFIG_RANDSTRUCT_FULL is not set # CONFIG_RANDSTRUCT_PERFORMANCE is not set # end of Kernel hardening options # end of Security options CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=m CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_SKCIPHER=m CONFIG_CRYPTO_SKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=m CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=m CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=m CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y CONFIG_CRYPTO_USER=m CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=m CONFIG_CRYPTO_NULL=m CONFIG_CRYPTO_NULL2=y CONFIG_CRYPTO_CRYPTD=m CONFIG_CRYPTO_AUTHENC=m CONFIG_CRYPTO_TEST=m CONFIG_CRYPTO_SIMD=m CONFIG_CRYPTO_ENGINE=m # end of Crypto core or helper # # Public-key cryptography # CONFIG_CRYPTO_RSA=y # CONFIG_CRYPTO_DH is not set CONFIG_CRYPTO_ECC=m CONFIG_CRYPTO_ECDH=m # CONFIG_CRYPTO_ECDSA is not set # CONFIG_CRYPTO_ECRDSA is not set # CONFIG_CRYPTO_SM2 is not set # CONFIG_CRYPTO_CURVE25519 is not set # end of Public-key cryptography # # Block ciphers # CONFIG_CRYPTO_AES=m # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARIA is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_SM4_GENERIC is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # end of Block ciphers # # Length-preserving ciphers and modes # # CONFIG_CRYPTO_ADIANTUM is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_CHACHA20 is not set CONFIG_CRYPTO_CBC=m # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=m # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=m # CONFIG_CRYPTO_HCTR2 is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # end of Length-preserving ciphers and modes # # AEAD (authenticated encryption with associated data) ciphers # # CONFIG_CRYPTO_AEGIS128 is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_CCM=m CONFIG_CRYPTO_GCM=m CONFIG_CRYPTO_SEQIV=m CONFIG_CRYPTO_ECHAINIV=m # CONFIG_CRYPTO_ESSIV is not set # end of AEAD (authenticated encryption with associated data) ciphers # # Hashes, digests, and MACs # # CONFIG_CRYPTO_BLAKE2B is not set CONFIG_CRYPTO_CMAC=m CONFIG_CRYPTO_GHASH=m CONFIG_CRYPTO_HMAC=m # CONFIG_CRYPTO_MD4 is not set CONFIG_CRYPTO_MD5=m # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_RMD160 is not set CONFIG_CRYPTO_SHA1=y CONFIG_CRYPTO_SHA256=m CONFIG_CRYPTO_SHA512=m # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_SM3_GENERIC is not set # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_VMAC is not set # CONFIG_CRYPTO_WP512 is not set # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_XXHASH is not set # end of Hashes, digests, and MACs # # CRCs (cyclic redundancy checks) # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_CRCT10DIF is not set # end of CRCs (cyclic redundancy checks) # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set CONFIG_CRYPTO_ZSTD=y # end of Compression # # Random number generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=m CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=m CONFIG_CRYPTO_JITTERENTROPY=m # end of Random number generation # # Userspace interface # CONFIG_CRYPTO_USER_API=m CONFIG_CRYPTO_USER_API_HASH=m CONFIG_CRYPTO_USER_API_SKCIPHER=m CONFIG_CRYPTO_USER_API_RNG=m # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set CONFIG_CRYPTO_USER_API_AEAD=m CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y # CONFIG_CRYPTO_STATS is not set # end of Userspace interface CONFIG_CRYPTO_HASH_INFO=y # # Accelerated Cryptographic Algorithms for CPU (arm) # # CONFIG_CRYPTO_CURVE25519_NEON is not set CONFIG_CRYPTO_GHASH_ARM_CE=m # CONFIG_CRYPTO_NHPOLY1305_NEON is not set # CONFIG_CRYPTO_POLY1305_ARM is not set # CONFIG_CRYPTO_BLAKE2S_ARM is not set # CONFIG_CRYPTO_BLAKE2B_NEON is not set CONFIG_CRYPTO_SHA1_ARM=m CONFIG_CRYPTO_SHA1_ARM_NEON=m CONFIG_CRYPTO_SHA1_ARM_CE=m CONFIG_CRYPTO_SHA2_ARM_CE=m CONFIG_CRYPTO_SHA256_ARM=m CONFIG_CRYPTO_SHA512_ARM=m CONFIG_CRYPTO_AES_ARM=m CONFIG_CRYPTO_AES_ARM_BS=m CONFIG_CRYPTO_AES_ARM_CE=m CONFIG_CRYPTO_CHACHA20_NEON=m CONFIG_CRYPTO_CRC32_ARM_CE=m # end of Accelerated Cryptographic Algorithms for CPU (arm) CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_HIFN_795X is not set CONFIG_CRYPTO_DEV_OMAP=m CONFIG_CRYPTO_DEV_OMAP_SHAM=m CONFIG_CRYPTO_DEV_OMAP_AES=m CONFIG_CRYPTO_DEV_OMAP_DES=m # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set # CONFIG_CRYPTO_DEV_QAT_DH895xCC is not set # CONFIG_CRYPTO_DEV_QAT_C3XXX is not set # CONFIG_CRYPTO_DEV_QAT_C62X is not set # CONFIG_CRYPTO_DEV_QAT_4XXX is not set # CONFIG_CRYPTO_DEV_QAT_DH895xCCVF is not set # CONFIG_CRYPTO_DEV_QAT_C3XXXVF is not set # CONFIG_CRYPTO_DEV_QAT_C62XVF is not set # CONFIG_CRYPTO_DEV_VIRTIO is not set # CONFIG_CRYPTO_DEV_SAFEXCEL is not set # CONFIG_CRYPTO_DEV_CCREE is not set # CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # CONFIG_PKCS7_TEST_KEY is not set # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set # CONFIG_FIPS_SIGNATURE_SELFTEST is not set # # Certificates for signature checking # CONFIG_SYSTEM_TRUSTED_KEYRING=y CONFIG_SYSTEM_TRUSTED_KEYS="" # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set # CONFIG_SECONDARY_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # end of Certificates for signature checking # # Library routines # CONFIG_LINEAR_RANGES=y # CONFIG_PACKING is not set CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y CONFIG_CORDIC=m # CONFIG_PRIME_NUMBERS is not set CONFIG_RATIONAL=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y # # Crypto library routines # CONFIG_CRYPTO_LIB_UTILS=y CONFIG_CRYPTO_LIB_AES=m CONFIG_CRYPTO_LIB_ARC4=m CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m # CONFIG_CRYPTO_LIB_CHACHA is not set # CONFIG_CRYPTO_LIB_CURVE25519 is not set CONFIG_CRYPTO_LIB_DES=m CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9 # CONFIG_CRYPTO_LIB_POLY1305 is not set # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set CONFIG_CRYPTO_LIB_SHA1=y CONFIG_CRYPTO_LIB_SHA256=m # end of Crypto library routines CONFIG_CRC_CCITT=m CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set # CONFIG_CRC64_ROCKSOFT is not set CONFIG_CRC_ITU_T=m CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC64 is not set # CONFIG_CRC4 is not set # CONFIG_CRC7 is not set CONFIG_LIBCRC32C=m # CONFIG_CRC8 is not set CONFIG_XXHASH=y # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_ZSTD_COMMON=y CONFIG_ZSTD_COMPRESS=y CONFIG_ZSTD_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y # CONFIG_XZ_DEC_MICROLZMA is not set CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_DECOMPRESS_ZSTD=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_REED_SOLOMON=y CONFIG_REED_SOLOMON_ENC8=y CONFIG_REED_SOLOMON_DEC8=y CONFIG_TEXTSEARCH=y CONFIG_TEXTSEARCH_KMP=m CONFIG_TEXTSEARCH_BM=m CONFIG_TEXTSEARCH_FSM=m CONFIG_XARRAY_MULTI=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_DMA_OPS=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y CONFIG_DMA_NONCOHERENT_MMAP=y CONFIG_DMA_CMA=y # CONFIG_DMA_PERNUMA_CMA is not set # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=48 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # CONFIG_DMA_API_DEBUG is not set # CONFIG_DMA_MAP_BENCHMARK is not set CONFIG_SGL_ALLOC=y CONFIG_DQL=y CONFIG_GLOB=y # CONFIG_GLOB_SELFTEST is not set CONFIG_NLATTR=y CONFIG_CLZ_TAB=y # CONFIG_IRQ_POLL is not set CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_SG_SPLIT=y CONFIG_SG_POOL=y CONFIG_SBITMAP=y # end of Library routines CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set # CONFIG_STACKTRACE_BUILD_ID is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_DYNAMIC_DEBUG_CORE is not set CONFIG_SYMBOLIC_ERRNAME=y # CONFIG_DEBUG_BUGVERBOSE is not set # end of printk and dmesg options CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y # # Compile-time checks and compiler options # CONFIG_AS_HAS_NON_CONST_LEB128=y CONFIG_DEBUG_INFO_NONE=y # CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT is not set # CONFIG_DEBUG_INFO_DWARF4 is not set # CONFIG_DEBUG_INFO_DWARF5 is not set CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_HEADERS_INSTALL is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_VMLINUX_MAP is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # end of Compile-time checks and compiler options # # Generic Kernel Debugging Instruments # CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_MAGIC_SYSRQ_SERIAL=y CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE="" CONFIG_DEBUG_FS=y CONFIG_DEBUG_FS_ALLOW_ALL=y # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set # CONFIG_DEBUG_FS_ALLOW_NONE is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_UBSAN is not set CONFIG_HAVE_KCSAN_COMPILER=y # end of Generic Kernel Debugging Instruments # # Networking Debugging # # CONFIG_NET_DEV_REFCNT_TRACKER is not set # CONFIG_NET_NS_REFCNT_TRACKER is not set # CONFIG_DEBUG_NET is not set # end of Networking Debugging # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_SLUB_DEBUG is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_RODATA_TEST is not set # CONFIG_DEBUG_WX is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SHRINKER_DEBUG is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_VM is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_KMAP_LOCAL is not set # CONFIG_DEBUG_HIGHMEM is not set CONFIG_HAVE_ARCH_KASAN=y CONFIG_HAVE_ARCH_KASAN_VMALLOC=y CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y # CONFIG_KASAN is not set CONFIG_HAVE_ARCH_KFENCE=y # CONFIG_KFENCE is not set # end of Memory Debugging # CONFIG_DEBUG_SHIRQ is not set # # Debug Oops, Lockups and Hangs # # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_TEST_LOCKUP is not set # end of Debug Oops, Lockups and Hangs # # Scheduler Debugging # CONFIG_SCHED_DEBUG=y CONFIG_SCHED_INFO=y CONFIG_SCHEDSTATS=y # end of Scheduler Debugging # CONFIG_DEBUG_TIMEKEEPING is not set # CONFIG_DEBUG_PREEMPT is not set # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # CONFIG_SCF_TORTURE_TEST is not set # end of Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_DEBUG_IRQFLAGS is not set # CONFIG_STACKTRACE is not set # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set # # Debug kernel data structures # # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PLIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_DEBUG_MAPLE_TREE is not set # end of Debug kernel data structures # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_SCALE_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_RCU_REF_SCALE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0 CONFIG_RCU_TRACE=y # CONFIG_RCU_EQS_DEBUG is not set # end of RCU Debugging # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_HAVE_BUILDTIME_MCOUNT_SORT=y CONFIG_TRACE_CLOCK=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # CONFIG_SAMPLES is not set # CONFIG_STRICT_DEVMEM is not set # # arm Debugging # # CONFIG_ARM_PTDUMP_DEBUGFS is not set # CONFIG_UNWINDER_FRAME_POINTER is not set CONFIG_UNWINDER_ARM=y CONFIG_ARM_UNWIND=y # CONFIG_BACKTRACE_VERBOSE is not set # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_LL is not set CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S" CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_CORESIGHT is not set # end of arm Debugging # # Kernel Testing and Coverage # # CONFIG_KUNIT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y # CONFIG_KCOV is not set CONFIG_RUNTIME_TESTING_MENU=y # CONFIG_LKDTM is not set # CONFIG_TEST_MIN_HEAP is not set # CONFIG_TEST_DIV64 is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_TEST_REF_TRACKER is not set # CONFIG_RBTREE_TEST is not set # CONFIG_REED_SOLOMON_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_STRING_SELFTEST is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_STRSCPY is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_SCANF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_XARRAY is not set # CONFIG_TEST_MAPLE_TREE is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_SIPHASH is not set # CONFIG_TEST_IDA is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_BITOPS is not set # CONFIG_TEST_VMALLOC is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_TEST_BLACKHOLE_DEV is not set # CONFIG_FIND_BIT_BENCHMARK is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_SYSCTL is not set # CONFIG_TEST_UDELAY is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_TEST_KMOD is not set # CONFIG_TEST_MEMCAT_P is not set # CONFIG_TEST_MEMINIT is not set # CONFIG_TEST_FREE_PAGES is not set CONFIG_ARCH_USE_MEMTEST=y # CONFIG_MEMTEST is not set # end of Kernel Testing and Coverage # # Rust hacking # # end of Rust hacking # end of Kernel hacking
