SK-AM68: port imx477 to SK-AM68
Part Number: SK-AM68
make all log:
make_all.log
  I need to port imx477 to SK-AM68 platform,
  I follow this
https://dev.ti.com/tirex/explore/content/am62ax_academy_9_02_00_00_v1/_build_am62ax_academy_9_02_00_00_v1/source/linux/ch-develop/dev-use-camera.html#enable-a-new-csi-2-sensor
Enable A New CSI-2 Sensor
The Processor SDK supports a few sensors out-of-box. Both the driver modules and the device tree overlays for the supported sensors are pre-built and included in the SDK. To enable a new CSI-2 sensor, the following listed steps are needed. Some steps can be skipped if the driver is already included in the SDK.
  1. Add the sensor driver source code to drivers/media/i2c/<sensor_name>.c (path is relative to <sdk root>/board-support/ti-linux-kernel).
  2. Add the sensor configuration in drivers/media/i2c/Kconfig. For example:
    config VIDEO_<SENSOR_NAME>
            tristate "<sensor_name> support"
            depends on VIDEO_DEV && I2C
            depends on ACPI || COMPILE_TEST
            select MEDIA_CONTROLLER
            select VIDEO_V4L2_SUBDEV_API
            select V4L2_FWNODE
            help
              This is a Video4Linux2 sensor driver for the <sensor_name>
  3. Enable the compilation of the sensor driver in drivers/media/i2c/Makefile:
    obj-$(CONFIG_VIDEO_<SENSOR_NAME>) += <sensor_name>.o
  4. Enable the kernel module for the sensor in arch/arm64/configs/defconfig:
    CONFIG_VIDEO_<SENSOR_NAME>=m
  5. Create a device tree overlay for the sensor and add it to arch/arm64/boot/dts/ti:
    arch/arm64/boot/dts/ti/<device_tree_overlay_name>.dtso
  6. Add the device tree overlay to arch/arm64/boot/dts/ti/Makefile:
    dtb-$(CONFIG_ARCH_K3) += <device_tree_overlay_name>.dtso
  7. Rebuild and install Linux kernel according to the instructions given in section Build Kernel.
  8. Boot the EVM with the updated kernel. Apply the device tree overlay according to instructions given in the Camera Evaluation section.
  9. Verify the sensor is probed according to Camera Evaluation.
    the kernel module(imx477.ko) has been updated to the target board, and enable it by dtb overlay file in /run/media/BOOT-mmcblk1p1/uEnv.txt as below,
    name_overlays=k3-j721s2-edgeai-apps.dtbo k3-am68-sk-bb-rpi-cam-imx477.dtbo
    but i cann't see the imx477 log during the booting the EVM, did I miss any steps? thanks
    What was the result of the camera verification? Could you share the output of dmesg | grep -i imx and dmesg | grep -i csi ? If you haven't already, I recommend adding imx477 to the setup_cameras.sh script located in the /opt/edgeai-gst-apps/scripts directory.
    Thank you,
    Fabiana
  • the output log:
    root@am68a-sk:/opt/edgeai-gst-apps# dmesg | grep imx
    [ 4.811001] imx477 4-0010: supply dovdd not found, using dummy regulator
    [ 4.822631] imx477 4-0010: supply avdd not found, using dummy regulator
    [ 4.830100] imx477 4-0010: supply dvdd not found, using dummy regulator
    [ 4.863887] imx477 4-0010: failed to find sensor: -5
    [ 4.880402] imx477: probe of 4-0010 failed with error -5
    [ 4.971633] imx477 5-0010: supply dovdd not found, using dummy regulator
    [ 5.069309] imx477 5-0010: supply avdd not found, using dummy regulator
    [ 5.133913] imx477 5-0010: supply dvdd not found, using dummy regulator
    [ 5.171249] imx477 5-0010: before read reg
    [ 5.183112] imx477 5-0010: client->addr is 16
    [ 5.192762] imx477 5-0010: failed to find sensor: -5
    [ 5.273839] imx477: probe of 5-0010 failed with error -5
    and in imx477.c
    /* Chip ID */
    #define IMX477_REG_ID 0x0016
    #define IMX477_ID 0x477
    the k3-am68-sk-bb-rpi-cam-imx477.dtso
    /dts-v1/;
    /plugin/;
    #include <dt-bindings/gpio/gpio.h>
    #include "k3-pinctrl.h"
    	clk_imx477_fixed: imx477-xclk {
    		compatible = "fixed-clock";
    		#clock-cells = <0>;
    		clock-frequency = <24000000>;
    &exp3 {
    	p01-hog {
    		/* CSI_MUX_SEL_2 */
    		gpio-hog;
    		gpios = <1 GPIO_ACTIVE_HIGH>;
    		output-high;
    		line-name = "CSI_MUX_SEL_2";
    &main_i2c1 {
    	status = "okay";
    	#address-cells = <1>;
    	#size-cells = <0>;
    	i2c-switch@70 {
    		compatible = "nxp,pca9543";
    		#size-cells = <0>;
    		reg = <0x70>;
    		i2c-alias-pool = /bits/ 16 <0x10 0x11>;
    		/* CAM0 I2C */
    		cam0_i2c: i2c@0 {
    			#size-cells = <0>;
    			reg = <0>;
    			imx477_0: imx477_0@10 {
    				compatible = "sony,imx477";
    				reg = <0x10>;
    				clocks = <&clk_imx477_fixed>;
    				clock-names = "xclk";
    				port {
    					csi2_cam0: endpoint {
    						remote-endpoint = <&csi2rx0_in_sensor>;
    						link-frequencies = /bits/ 64 <456000000>;
    						clock-lanes = <0>;
    						data-lanes = <1 2>;
    		/* CAM1 I2C */
    		cam1_i2c: i2c@1 {
    			#size-cells = <0>;
    			reg = <1>;
    			imx477_1: imx477_1@10 {
    				reg = <0x10>;
    				port {
    					csi2_cam1: endpoint {
    						remote-endpoint = <&csi2rx1_in_sensor>;
    						clock-lanes = <0>;
    						data-lanes = <1 2>;
    &csi0_port0 {
    	status = "okay";
    	csi2rx0_in_sensor: endpoint {
    		remote-endpoint = <&csi2_cam0>;
    		bus-type = <4>; /* CSI2 DPHY. */
    		clock-lanes = <0>;
    		data-lanes = <1 2>;
    &csi1_port0 {
    	status = "okay";
    	csi2rx1_in_sensor: endpoint {
    		remote-endpoint = <&csi2_cam1>;
    		clock-lanes = <0>;
    		data-lanes = <1 2>;
    Could you help me confirm which step is wrong or what is missing? thanks
    in k3-am68-sk-bb-rpi-cam-imx477.dtso  the device reg addr is 0x10 or 0x1A?
    Thank you for the data. Due to a US holiday, there will a delay in my response. Thanks for understanding.
    -Fabiana
  • root@am68a-sk:/opt/edgeai-gst-apps# dmesg | grep -i csi
    [ 0.428166] SCSI subsystem initialized
    [ 0.712024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [ 1.137471] i2c 4-001a: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4500000/csi-bridge@4504000
    [ 1.152089] i2c 5-001a: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4510000/csi-bridge@4514000
    [ 1.185712] gpio-481 (CSI_MUX_SEL_2): hogged as output/high
    [ 4.931977] imx477 4-001a: gpio info: CSI0_B_GPIO1
    [ 6.379594] imx477 5-001a: gpio info: CSI0_B_GPIO1
    [ 7.021885] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
    [ 7.090799] cdns-csi2rx 4514000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
    Please expect a delay in response as I am out of office.
    Thank you,
    Fabiana
  • i checked the hardware configutation and now imx477 works.
      CSI Camera 0 detected
        device = /dev/video-rpi-cam0
        name = imx477
        format = [fmt:SRGGB12_1X12/2028x1080]
        subdev_id = /dev/v4l-rpi-subdev0
        isp_required = yes
    [   15.576636] sh (986): drop_caches: 1
    and check imx477 camera:
    root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-mbus-codes pad=0
    ioctl: VIDIOC_SUBDEV_ENUM_MBUS_CODE (pad=0,stream=0)
       0x3012: MEDIA_BUS_FMT_SRGGB12_1X12
       0x300f: MEDIA_BUS_FMT_SRGGB10_1X10
    root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-framesizes pad=0,code=0x300f
    ioctl: VIDIOC_SUBDEV_ENUM_FRAME_SIZE (pad=0,stream=0)
       Size Range: 1332x990 - 1332x990
       root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-framesizes pad=0,code=0x3012
       Size Range: 4056x3040 - 4056x3040
       Size Range: 2028x1520 - 2028x1520
       Size Range: 2028x1080 - 2028x1080
    Modify the /opt/edgeai-gst-apps/scripts/setup_cameras.sh
    setup_imx477(){
        IMX477_CAM_FMT='[fmt:SRGGB12_1X12/2028x1080]'
    if runs the edgeai-gst-app, select camera it will crash
    the crash log:
    [   32.371914] ------------[ cut here ]------------
    [   32.376529] WARNING: CPU: 1 PID: 1235 at drivers/media/common/videobuf2/videobuf2-core.c:1647 vb2_start_streaming+0xd8/0x15c [videobuf2_common]
    [   32.389388] Modules linked in: xt_conntrack xt_MASQUERADE iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter ip_tables x_tables br_netfilter bridge stp )
    [   32.389507]  fuse drm drm_panel_orientation_quirks ipv6
    [   32.481655] CPU: 1 PID: 1235 Comm: v4l2src0:src Tainted: G           O       6.1.46 #1
    [   32.489552] Hardware name: Texas Instruments AM68 SK (DT)
    [   32.494933] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [   32.501876] pc : vb2_start_streaming+0xd8/0x15c [videobuf2_common]
    [   32.508047] lr : vb2_start_streaming+0x68/0x15c [videobuf2_common]
    [   32.514214] sp : ffff80000b4cbb60
    [   32.517514] x29: ffff80000b4cbb60 x28: ffff000832059400 x27: ffff000830ea14b8
    [   32.524632] x26: 0000000000000000 x25: 0000000040045612 x24: 0000000000000000
    [   32.531750] x23: ffff80000b4cbcc8 x22: ffff00082f479700 x21: ffff000830ea1438
    [   32.538868] x20: ffff000830ea1450 x19: 00000000ffffffa1 x18: 00000000002feac5
    [   32.545986] x17: 0000000000000020 x16: fffffc002405f808 x15: 0000000000000000
    [   32.553104] x14: 000000000000025d x13: 0000000000000000 x12: 0000000000000000
    [   32.560222] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000b4cba30
    [   32.567339] x8 : ffff00084204df90 x7 : ffff000b7e1b3340 x6 : 0000000000000000
    [   32.574457] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff00082eddaa48
    [   32.581574] x2 : 0000000000000000 x1 : ffff800000e6d000 x0 : ffff00084213c9f0
    [   32.588693] Call trace:
    [   32.591127]  vb2_start_streaming+0xd8/0x15c [videobuf2_common]
    [   32.596951]  vb2_core_streamon+0x90/0x190 [videobuf2_common]
    [   32.602598]  vb2_ioctl_streamon+0x5c/0xb0 [videobuf2_v4l2]
    [   32.608078]  v4l_streamon+0x24/0x30 [videodev]
    [   32.612534]  __video_do_ioctl+0x18c/0x3dc [videodev]
    [   32.617504]  video_usercopy+0x21c/0x6d0 [videodev]
    [   32.622307]  video_ioctl2+0x18/0x30 [videodev]
    [   32.626758]  v4l2_ioctl+0x40/0x60 [videodev]
    [   32.631034]  __arm64_sys_ioctl+0xa8/0xf0
    [   32.634948]  invoke_syscall+0x48/0x114
    [   32.638687]  el0_svc_common.constprop.0+0xd4/0xfc
    [   32.643377]  do_el0_svc+0x30/0xd0
    [   32.646680]  el0_svc+0x2c/0x84
    [   32.649725]  el0t_64_sync_handler+0xbc/0x140
    [   32.653981]  el0t_64_sync+0x18c/0x190
    [   32.657631] ---[ end trace 0000000000000000 ]---
    [   34.119055] cdns-csi2rx 4504000.csi-bridge: Failed to start streams 0x1 on subdev
    [   34.136691] cdns-csi2rx 4504000.csi-bridge: Failed to stop stream0
    [   34.152889] cdns-csi2rx 4504000.csi-bridge: Failed to stop stream1
    [   34.169118] cdns-csi2rx 4504000.csi-bridge: Failed to stop stream2
    [   34.185300] cdns-csi2rx 4504000.csi-bridge: Failed to stop stream3
    [   34.196974] ------------[ cut here ]------------
    [   34.201593] WARNING: CPU: 1 PID: 1248 at drivers/media/common/videobuf2/videobuf2-core.c:1647 vb2_start_streaming+0xd8/0x15c [videobuf2_common]
    [   34.214455] Modules linked in: xt_conntrack xt_MASQUERADE iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter ip_tables x_tables br_netfilter bridge stp )
    [   34.214582]  fuse drm drm_panel_orientation_quirks ipv6
    [   34.306733] CPU: 1 PID: 1248 Comm: v4l2src0:src Tainted: G        W  O       6.1.46 #1
    [   34.314631] Hardware name: Texas Instruments AM68 SK (DT)
    [   34.320011] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [   34.326954] pc : vb2_start_streaming+0xd8/0x15c [videobuf2_common]
    [   34.333125] lr : vb2_start_streaming+0x68/0x15c [videobuf2_common]
    [   34.339294] sp : ffff80000b7a3b60
    [   34.342594] x29: ffff80000b7a3b60 x28: ffff000830ca4900 x27: ffff000830ea14b8
    [   34.349713] x26: 0000000000000000 x25: 0000000040045612 x24: 0000000000000000
    [   34.356831] x23: ffff80000b7a3cc8 x22: ffff000833959f00 x21: ffff000830ea1438
    [   34.363949] x20: ffff000830ea1450 x19: 00000000ffffffa1 x18: 00000000002fb867
    [   34.371067] x17: 0000000000000020 x16: fffffc002405f808 x15: 0000003deadedbfe
    [   34.378185] x14: 0000000000000322 x13: 0000000000000000 x12: 0000000000000000
    [   34.385302] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000b7a3a30
    [   34.392420] x8 : ffff00082d78a690 x7 : ffff000b7e1b3340 x6 : 0000000000000000
    [   34.399537] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff00082edda348
    [   34.406655] x2 : 0000000000000000 x1 : ffff800000e6d000 x0 : ffff00084214b9f0
    [   34.413773] Call trace:
    [   34.416207]  vb2_start_streaming+0xd8/0x15c [videobuf2_common]
    [   34.422030]  vb2_core_streamon+0x90/0x190 [videobuf2_common]
    [   34.427677]  vb2_ioctl_streamon+0x5c/0xb0 [videobuf2_v4l2]
    [   34.433155]  v4l_streamon+0x24/0x30 [videodev]
    [   34.437612]  __video_do_ioctl+0x18c/0x3dc [videodev]
    [   34.442584]  video_usercopy+0x21c/0x6d0 [videodev]
    [   34.447380]  video_ioctl2+0x18/0x30 [videodev]
    [   34.451830]  v4l2_ioctl+0x40/0x60 [videodev]
    [   34.456106]  __arm64_sys_ioctl+0xa8/0xf0
    [   34.460020]  invoke_syscall+0x48/0x114
    [   34.463759]  el0_svc_common.constprop.0+0xd4/0xfc
    [   34.468450]  do_el0_svc+0x30/0xd0
    [   34.471754]  el0_svc+0x2c/0x84
    [   34.474799]  el0t_64_sync_handler+0xbc/0x140
    [   34.479057]  el0t_64_sync+0x18c/0x190
    [   34.482707] ---[ end trace 0000000000000000 ]---
    Could you help me confirm which step is wrong or what steps are still missing? thanks
  • Our expert handling this topic is currently out of the office; please expect a 1-2 day delay in response.
    Thanks.
    Try running the below command to grab a frame and share the output:
    v4l2-ctl --verbose --device /dev/video-rpi-cam0  --set-fmt-video=width=2028,height=1080 --stream-mmap --stream-to=test-frame.raw --stream-count=1
    Fabiana
  • I used SDK version: ti-processor-sdk-linux-edgeai-j721s2-evm-09_02_00_05
    port imx477.c from raspberrypi
    and connected two cameras(imx219 and imx477),
    The driver is probed and I2C communication works,
    see the log:
    root@am68a-sk:/opt/edgeai-gst-apps# dmesg | grep -i imx
    [    4.575593] imx219 5-0010: supply VANA not found, using dummy regulator
    [    4.592375] imx219 5-0010: supply VDIG not found, using dummy regulator
    [    4.592410] imx477 4-001a: supply dovdd not found, using dummy regulator
    [    4.607551] imx219 5-0010: supply VDDL not found, using dummy regulator
    [    4.614484] imx477 4-001a: supply avdd not found, using dummy regulator
    [    4.621566] imx477 4-001a: supply dvdd not found, using dummy regulator
    [    7.145908] imx477 4-001a: Consider updating driver imx477 to match on endpoints
    [    7.506788] imx219 5-0010: Consider updating driver imx219 to match on endpoints
    IMX219 Camera 1 detected
        device = /dev/video-imx219-cam0
        name = imx219
        format = [fmt:SRGGB8_1X8/1920x1080]
        subdev_id = /dev/v4l-imx219-subdev0
        isp_required = yes
    IMX477 Camera 0 detected
        device = /dev/video-imx477-cam0
        name = imx477
        format = [fmt:SRGGB10_1X10/1332x990]
        subdev_id = /dev/v4l-imx477-subdev0
        isp_required = yes
    imx219 camera can work,
    but when i select IMX477 camera,there is no display and no incorrect log output
    if I use v4l2-ctl command to grab a frame,they will stuck and can not return, Also including imx219
    imx477:
    root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl --verbose --device /dev/video-imx477-cam0  --set-fmt-video=width=1332,height=990 --stream-mmap --stream-to=test-frame.raw --stream-count=1
    VIDIOC_QUERYCAP: ok
    VIDIOC_G_FMT: ok
    VIDIOC_S_FMT: ok
    Format Video Capture:
       Width/Height      : 1328/990
       Pixel Format      : 'UYVY' (UYVY 4:2:2)
       Field             : None
       Bytes per Line    : 2656
       Size Image        : 2629440
       Colorspace        : sRGB
       Transfer Function : Default (maps to sRGB)
       YCbCr/HSV Encoding: Default (maps to ITU-R 601)
       Quantization      : Default (maps to Limited Range)
       Flags             :
            VIDIOC_REQBUFS returned 0 (Success)
            VIDIOC_QUERYBUF returned 0 (Success)
            VIDIOC_QBUF returned 0 (Success)
            VIDIOC_STREAMON returned 0 (Success)
        Stuck here!!!!
        imx219:
        root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl --verbose --device /dev/video-imx219-cam0  --set-fmt-video=width=2028,height=1080 --stream-mmap --stream-to=test-frame.raw --stream-count=1
    VIDIOC_QUERYCAP: ok
    VIDIOC_G_FMT: ok
    VIDIOC_S_FMT: ok
       Width/Height      : 2024/1080
       Field             : None
       Bytes per Line    : 4048
       Size[  244.125984] imx219 5-0010: imx219_start_streaming
     Image        : 4371840
       Colorspace        : sRGB
       Flags             :
        stuck here
    Do you know the reason why imx477 doesn't work and how to debug this issue
    and does TI have plan to support IMX477 in the subsequent versions?
    If the camera only produces raw RGB or RGBD images, then further ISP processing is required which can be handled by the Vision Imaging Sub System (VISS) hardware accelerator. For more on ISP tuning, please see the following application note: https://www.ti.com/lit/an/sprad86a/sprad86a.pdf
    We are still discussing internally about looking into IMX477 or another similar sensor and if it is something we can support soon.
    Thank you,
    Fabiana
  • Thank you for your reply.
    followed the ISP tuning guide,
    I have copied the generated DCC binary files to the target board,
    /opt/imaging/imx477/linear/dcc_2a.bin
    /opt/imaging/imx477/linear/dcc_ldc.bin
    /opt/imaging/imx477/linear/dcc_viss.bin
    if select the IMX477 camera via the below edgeAI GUI,
    Do I need to set the path of the DCC file, that is,how can the GUI find the newly added DCC file of imx477
     If it is needed, where to config it?
    The way the custom gui application works is by generating a yaml/configuration file to generate and run a GStreamer pipeline using the provided inputs. Because IMX477 is not supported out of box, the sensor id for this sensor is missing so the format cannot be set to rggb. When enabling a new sensor, you should test functionality by running GStreamer pipelines in the command line. Here is an example for IMX219:
    gst-launch-1.0 v4l2src device=/dev/video-imx219-cam0 io-mode=5 ! queue leaky=2 ! \
    video/x-bayer, width=1920, height=1080, framerate=30/1, format=rggb ! \
    tiovxisp sink_0::device=/dev/v4l-subdev2 sensor-name="SENSOR_SONY_IMX219_RPI" \
    dcc-isp-file=/opt/imaging/imx219/dcc_viss.bin \
    sink_0::dcc-2a-file=/opt/imaging/imx219/dcc_2a.bin format-msb=7 ! \
    tiovxmultiscaler ! \
    video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! \
    kmssink driver-name=tidss sync=false
    Thank you,
    Fabiana
  • These are my two camera devices(media0 is IMX477, media1 is IMX219)
    root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl --list-devices
    j721e-csi2rx (platform:4500000.ticsi2rx):
            /dev/video2
            /dev/video3
            /dev/video4
            /dev/video5
            /dev/video6
            /dev/video7
            /dev/video8
            /dev/video9
            /dev/media0
    j721e-csi2rx (platform:4510000.ticsi2rx):
            /dev/video10
            /dev/video11
            /dev/video12
            /dev/video13
            /dev/video14
            /dev/video15
            /dev/video16
            /dev/video17
            /dev/media1
    wave5-dec (platform:wave5-dec):
            /dev/video0
    wave5-enc (platform:wave5-enc):
            /dev/video1
    check the media0 device topology,
    root@am68a-sk:/opt/edgeai-gst-apps# media-ctl -p -d /dev/media0
    Media controller API version 6.1.80
    Media device information
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:4500000.ticsi2rx
    hw revision     0x1
    driver version  6.1.80
    Device topology
    - entity 1: 4500000.ticsi2rx (9 pads, 9 links, 1 route)
                type V4L2 subdev subtype Unknown flags 0
                device node name /dev/v4l-subdev0
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
                    <- "cdns_csi2rx.4504000.csi-bridge":1 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4500000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
            pad2: Source
                    -> "4500000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
            pad3: Source
                    -> "4500000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
            pad4: Source
                    -> "4500000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
            pad5: Source
                    -> "4500000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
            pad6: Source
                    -> "4500000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
            pad7: Source
                    -> "4500000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE]
            pad8: Source
                    -> "4500000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE]
    - entity 11: cdns_csi2rx.4504000.csi-bridge (5 pads, 2 links, 1 route)
                 device node name /dev/v4l-subdev1
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:SRGGB10_1X10/4056x3040 field:none colorspace:raw xfer:none]
                    <- "imx477 4-001a":0 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4500000.ticsi2rx":0 [ENABLED,IMMUTABLE]
            pad2: Source
            pad3: Source
            pad4: Source
    - entity 17: imx477 4-001a (1 pad, 1 link, 0 route)
                 type V4L2 subdev subtype Sensor flags 0
                 device node name /dev/v4l-subdev2
            pad0: Source
                    -> "cdns_csi2rx.4504000.csi-bridge":0 [ENABLED,IMMUTABLE]
    - entity 23: 4500000.ticsi2rx context 0 (1 pad, 1 link, 0 route)
                 type Node subtype V4L flags 0
                 device node name /dev/video2
            pad0: Sink
                    <- "4500000.ticsi2rx":1 [ENABLED,IMMUTABLE]
    - entity 29: 4500000.ticsi2rx context 1 (1 pad, 1 link, 0 route)
                 device node name /dev/video3
            pad0: Sink
                    <- "4500000.ticsi2rx":2 [ENABLED,IMMUTABLE]
    - entity 35: 4500000.ticsi2rx context 2 (1 pad, 1 link, 0 route)
                 device node name /dev/video4
            pad0: Sink
                    <- "4500000.ticsi2rx":3 [ENABLED,IMMUTABLE]
    - entity 41: 4500000.ticsi2rx context 3 (1 pad, 1 link, 0 route)
                 device node name /dev/video5
            pad0: Sink
                    <- "4500000.ticsi2rx":4 [ENABLED,IMMUTABLE]
    - entity 47: 4500000.ticsi2rx context 4 (1 pad, 1 link, 0 route)
                 device node name /dev/video6
            pad0: Sink
                    <- "4500000.ticsi2rx":5 [ENABLED,IMMUTABLE]
    - entity 53: 4500000.ticsi2rx context 5 (1 pad, 1 link, 0 route)
                 device node name /dev/video7
            pad0: Sink
                    <- "4500000.ticsi2rx":6 [ENABLED,IMMUTABLE]
    - entity 59: 4500000.ticsi2rx context 6 (1 pad, 1 link, 0 route)
                 device node name /dev/video8
            pad0: Sink
                    <- "4500000.ticsi2rx":7 [ENABLED,IMMUTABLE]
    - entity 65: 4500000.ticsi2rx context 7 (1 pad, 1 link, 0 route)
                 device node name /dev/video9
            pad0: Sink
                    <- "4500000.ticsi2rx":8 [ENABLED,IMMUTABLE]
    check the media1 device topology,
    root@am68a-sk:/opt/edgeai-gst-apps# media-ctl -p -d /dev/media1
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:4510000.ticsi2rx
    hw revision     0x1
    Device topology
    - entity 1: 4510000.ticsi2rx (9 pads, 9 links, 1 route)
                device node name /dev/v4l-subdev3
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    <- "cdns_csi2rx.4514000.csi-bridge":1 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4510000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
            pad2: Source
                    -> "4510000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
            pad3: Source
                    -> "4510000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
            pad4: Source
                    -> "4510000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
            pad5: Source
                    -> "4510000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
            pad6: Source
                    -> "4510000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
            pad7: Source
                    -> "4510000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE]
            pad8: Source
                    -> "4510000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE]
    - entity 11: cdns_csi2rx.4514000.csi-bridge (5 pads, 2 links, 1 route)
                 device node name /dev/v4l-subdev4
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:SRGGB8_1X8/1920x1080 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:full-range]
                    <- "imx219 5-0010":0 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4510000.ticsi2rx":0 [ENABLED,IMMUTABLE]
            pad2: Source
            pad3: Source
            pad4: Source
    - entity 17: imx219 5-0010 (1 pad, 1 link, 0 route)
                 device node name /dev/v4l-subdev5
            pad0: Source
                     crop.bounds:(8,8)/3280x2464
                     crop:(688,700)/1920x1080]
                    -> "cdns_csi2rx.4514000.csi-bridge":0 [ENABLED,IMMUTABLE]
    - entity 23: 4510000.ticsi2rx context 0 (1 pad, 1 link, 0 route)
                 device node name /dev/video10
            pad0: Sink
                    <- "4510000.ticsi2rx":1 [ENABLED,IMMUTABLE]
    - entity 29: 4510000.ticsi2rx context 1 (1 pad, 1 link, 0 route)
                 device node name /dev/video11
            pad0: Sink
                    <- "4510000.ticsi2rx":2 [ENABLED,IMMUTABLE]
    - entity 35: 4510000.ticsi2rx context 2 (1 pad, 1 link, 0 route)
                 device node name /dev/video12
            pad0: Sink
                    <- "4510000.ticsi2rx":3 [ENABLED,IMMUTABLE]
    - entity 41: 4510000.ticsi2rx context 3 (1 pad, 1 link, 0 route)
                 device node name /dev/video13
            pad0: Sink
                    <- "4510000.ticsi2rx":4 [ENABLED,IMMUTABLE]
    - entity 47: 4510000.ticsi2rx context 4 (1 pad, 1 link, 0 route)
                 device node name /dev/video14
            pad0: Sink
                    <- "4510000.ticsi2rx":5 [ENABLED,IMMUTABLE]
    - entity 53: 4510000.ticsi2rx context 5 (1 pad, 1 link, 0 route)
                 device node name /dev/video15
            pad0: Sink
                    <- "4510000.ticsi2rx":6 [ENABLED,IMMUTABLE]
    - entity 59: 4510000.ticsi2rx context 6 (1 pad, 1 link, 0 route)
                 device node name /dev/video16
            pad0: Sink
                    <- "4510000.ticsi2rx":7 [ENABLED,IMMUTABLE]
    - entity 65: 4510000.ticsi2rx context 7 (1 pad, 1 link, 0 route)
                 device node name /dev/video17
            pad0: Sink
                    <- "4510000.ticsi2rx":8 [ENABLED,IMMUTABLE]
    for IMX219, the following command works,
    tiovxisp sink_0::device=/dev/v4l-subdev4 sensor-name="SENSOR_SONY_IMX219_RPI" \
    dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss.bin \
    sink_0::dcc-2a-file=/opt/imaging/imx219/linear/dcc_2a.bin format-msb=7 ! \
    for IMX477, I made the software changes followed the ISP tuning guide, and use the following command, it does't work,
    could you help check this command, "tiovxisp sink_0::device=/dev/v4l-subdev1" it is correct accoring to
    the above device tolopoly?
    gst-launch-1.0  v4l2src device=/dev/video-imx477-cam0 io-mode=5 ! queue leaky=2 ! \
    tiovxisp sink_0::device=/dev/v4l-subdev1 sensor-name="SENSOR_SONY_IMX477_RPI" \
    dcc-isp-file=/opt/imaging/imx477/linear/dcc_viss.bin \
    sink_0::dcc-2a-file=/opt/imaging/imx477/linear/dcc_2a.bin format-msb=7 ! \
    I enabled the gst-debug log and added some logs in gsttivoxisp.c and gsttiovxmiso.c,
    compared the logs between IMX219 and IMX477,
    for IMX477,  the initialization function(gst_tiovx_isp_init_module) was not called,and it will stuck there
    Could you help me check whether there are still any missing or wrong configurations?  thanks.
    Could you try running the following configuration and share the output?
    video/x-bayer, width=1332, height=990, framerate=30/1, format=rggb10 ! \
    tiovxisp sink_0::device=/dev/v4l-imx477-subdev0 sensor-name="SENSOR_SONY_IMX477_RPI" \
    Thank you,
    Fabiana
  • I run the above command, now it will not stuck, and the screen displays as follows,
    I use this configuration for ISP tuning,
    SENSOR_ID 477
    PRJ_DIR ../imx477_output
    SENSOR_NAME imx477
    SENSOR_DCC_NAME IMX477-UB953_D3
    SENSOR_WIDTH 1920
    SENSOR_HEIGHT 1080
    # 0=RGGB; 1=GRBG; 2=GBRG; 3=BGGR, 4=MONO
    COLOR_PATTERN 0
    # sensor mode: 0 for linear (no decompanding), 1 for WDR (decompanding)
    WDR_MODE 0
    # raw sensor image BIT_DEPTH: it may be 8, 10, or 12 for linear sensors; typically 12 for WDR mode because of companding
    BIT_DEPTH 10
    # WDR BIT_DEPTH: WDR raw sensor image bitdepth after decompanding, typically 20 or 24
    WDR_BIT_DEPTH 20
    # WDR decompanding knee points (comma separated without spaces in between)
    WDR_KNEE_X 0,512,1408,2176,4095,65535
    WDR_KNEE_Y 0,2048,16384,65536,1048063,1048063
    # Sensor black level to subtract before decompanding (for linear sensors only and some Sony WDR sensors)
    BLACK_PRE  0
    # Sensor black level to subtract after decompanding (for most WDR sensors and all linear sensors)
    BLACK_POST  0
    # GAMMA value for compressing 20/24-bit WDR raw to 16-bit ISP internal
    # typically around 50 (0.5) for 24-bit WDR sensors and 70 (0.7) for 20-bit sensors
    GAMMA_PRE 70
    # LSB location for H3A input bit range (from bit-H3A_INPUT_LSB to bit-H3A_INPUT_LSB+9)
    H3A_INPUT_LSB 2
    and same with IMX219 for the exposure setting in gsttiovxisp.c,
    check the imx477 camera configuration as this,
    root@am68a-sk:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/v4l-imx477-subdev0 --list-ctrls
    User Controls
                           exposure 0x00980911 (int)    : min=4 max=1028 step=1 default=1028 value=1028
                    horizontal_flip 0x00980914 (bool)   : default=0 value=0 flags=modify-layout
                      vertical_flip 0x00980915 (bool)   : default=0 value=0 flags=modify-layout
    Image Source Controls
                  vertical_blanking 0x009e0901 (int)    : min=60 max=8383010 step=1 default=60 value=60
                horizontal_blanking 0x009e0902 (int)    : min=5332 max=65520 step=1 default=5332 value=5332
                      analogue_gain 0x009e0903 (int)    : min=0 max=978 step=1 default=0 value=224
                    red_pixel_value 0x009e0904 (int)    : min=0 max=4095 step=1 default=4095 value=4095
              green_red_pixel_value 0x009e0905 (int)    : min=0 max=4095 step=1 default=4095 value=4095
                   blue_pixel_value 0x009e0906 (int)    : min=0 max=4095 step=1 default=4095 value=4095
             green_blue_pixel_value 0x009e0907 (int)    : min=0 max=4095 step=1 default=4095 value=4095
    Image Processing Controls
                     link_frequency 0x009f0901 (intmenu): min=0 max=0 default=0 value=0 (456000000 0x1b2e0200) flags=read-only
                         pixel_rate 0x009f0902 (int64)  : min=840000000 max=840000000 step=1 default=840000000 value=840000000 flags=read-only
                       test_pattern 0x009f0903 (menu)   : min=0 max=4 default=0 value=0 (Disabled)
                       digital_gain 0x009f0905 (int)    : min=256 max=65535 step=1 default=256 value=256
    Could you help me check which configurations are incorrect?
    I have looped in our ISP tuning expert. Please expect a response from them soon.
    Fabiana
  • Hi csscyt,
    The configuration file looks good to me.
    Before ISP processing, we need to verify the raw image from sensor.
    Are you able to capture some valid raw image frames from the sensor?
  • I used these commands,
    media-ctl -V '"imx477 4-001a":0 [fmt:SRGGB10_1X10/1920x1080 field:none]'
    gst-launch-1.0 -v v4l2src num-buffers=5 device=/dev/video-imx477-cam0 io-mode=dmabuf ! \
    video/x-bayer, width=1920, height=1080, framerate=30/1, format=rggb10 ! \
    multifilesink location="imx477-image-%d.raw"
    imx477_raw.tar.gz
  • Hi csscyt,
    Thanks for sharing!
    These raw images do not look correct.
    The pixels on top ~686 lines are around 0x40 and the rest are all 0s.
    That is the same as what you see on the monitor.
    There might be something wrong in the sensor driver.
    I have verified that the IMX477 camera hardware is normal on other platforms,
    I tried different modes(10/12bit with different resolutions) to capture the raw image frames from the sensor,
    The raw image data is always similar to that in the previous post,
    Do you know which configurations in the sensor driver might lead to this phenomenon, or what other configurations there could be?
  • Hi csscyt,
    I am not familiar with IMX477.
    Is there a test pattern you may turn on in IMX477?
    Fabiana may have some past experience with that sensor.
  • @Fabiana
    Do you have any suggestions? thanks
  • Hi csscyt,
    IMX477 is not currently supported and I have not worked with it before, but I could review the sensor driver. Could you share it so I could take a look?
    Thank you,
    Fabiana
    I used this code (https://github.com/raspberrypi/linux/blob/rpi-6.6.y/drivers/media/i2c/imx477.c)
    and tried the following configurations with different modes(10/12bit + different resolutions)
    1)
    #define IMX477_DEFAULT_LINK_FREQ 450000000
    #define IMX477_PIXEL_RATE 840000000
    2)
    #define IMX477_DEFAULT_LINK_FREQ 900000000
    3)
    #define IMX477_PIXEL_RATE 420000000
    Please ensure that the link and clock frequencies match between the driver and dtso.
    Thank you,
    Fabiana
  • Yes, they are matched.since there would be a hardware check error if they weren't.
  • Is the dtso you previously shared in this thread the one you are currently using?
    Thank you,
    Fabiana
  • // SPDX-License-Identifier: GPL-2.0
     * DT Overlay for RPi Camera V2.1 (Sony imx477) interfaced with CSI2 on AM68-SK board.
     * https://datasheets.raspberrypi.org/camera/camera-v2-schematic.pdf
     * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/
    /dts-v1/;
    /plugin/;
    		#clock-cells = <0>;
    	clk_imx219_fixed: imx219-xclk {
    		#clock-cells = <0>;
    &exp3 {
    	p01-hog {
    		/* CSI_MUX_SEL_2 */
    		gpio-hog;
    		output-high;
    	p00-hog {
    		 /* I2C voltage - set to 3.3V */
    		 gpio-hog;
    		 gpios = <0 GPIO_ACTIVE_HIGH>;
    		 output-high;
    		 line-name = "CSI_VIO_SELCSI_VIO_SEL";
    &main_i2c1 {
    	status = "okay";
    	#size-cells = <0>;
    	i2c-switch@70 {
    		#size-cells = <0>;
    		reg = <0x70>;
    		i3c-alias-pool = /bits/ 17 <0x10 0x11>;
    		/* CAM0 I2C */
    		cam0_i2c: i2c@0 {
    			#size-cells = <0>;
    			reg = <0>;
    				reg = <0x1a>;
    				reset-gpios = <&exp3 3 GPIO_ACTIVE_HIGH>;
    				port {
    						link-frequencies = /bits/ 64 <450000000>;
    						clock-lanes = <0>;
    						data-lanes = <1 2>;
    		/* CAM1 I2C */
    		cam1_i2c: i2c@1 {
    			#size-cells = <0>;
    			reg = <1>;
    			imx219_1: imx219_1@10 {
    				compatible = "sony,imx219";
    				reg = <0x10>;
    				clocks = <&clk_imx219_fixed>;
    				reset-gpios = <&exp3 4 GPIO_ACTIVE_HIGH>;
    				port {
    						clock-lanes = <0>;
    						data-lanes = <1 2>;
    &csi0_port0 {
    	status = "okay";
    		clock-lanes = <0>;
    		data-lanes = <1 2>;
    &csi1_port0 {
    	status = "okay";
    		clock-lanes = <0>;
    		data-lanes = <1 2>;
    It supports RAW10/12 formats for imx477 sensor driver,
    now i use this format ( fmt:SRGGB12_1X12/2028x1520)
    check the configuration by media-ctl
    root@am68a-sk:/opt/edgeai-gst-apps# media-ctl -d /dev/media0 -p
    Media controller API version 6.1.80[   48.543307]
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    hw revision     0x1
    Device topology
    	routes:
    		0/0 -> 1/0 [ACTIVE]
    	pad0: Sink
    		[stream:0 fmt:SRGGB12_1X12/2280x1520 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
    	pad1: Source
    	pad2: Source
    	pad3: Source
    	pad4: Source
    	pad5: Source
    	pad6: Source
    	pad7: Source
    	pad8: Source
    	routes:
    		0/0 -> 1/0 [ACTIVE]
    	pad0: Sink
    		[stream:0 fmt:SRGGB12_1X12/2028x1520 field:none colorspace:raw xfer:none ycbcr:601 quantization:full-range]
    	pad1: Source
    	pad2: Source
    	pad3: Source
    	pad4: Source
    	pad0: Source
    		 crop.bounds:(8,16)/4056x3040
    		 crop:(8,16)/4056x3040]
    	pad0: Sink
    	pad0: Sink
    	pad0: Sink
    	pad0: Sink
    	pad0: Sink
    	pad0: Sink
    	pad0: Sink
    	pad0: Sink
    but Only 8 and 16 bit bpp in the format array of j721e-csi2rx.c,
    static const struct ti_csi2rx_fmt formats[] = {
    		.fourcc			= V4L2_PIX_FMT_YUYV,
    		.code			= MEDIA_BUS_FMT_YUYV8_1X16,
    		.csi_dt			= MIPI_CSI2_DT_YUV422_8B,
    		.bpp			= 16,
    		.size			= SHIM_DMACNTX_SIZE_8,
    		.fourcc			= V4L2_PIX_FMT_UYVY,
    		.code			= MEDIA_BUS_FMT_UYVY8_1X16,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_YVYU,
    		.code			= MEDIA_BUS_FMT_YVYU8_1X16,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_VYUY,
    		.code			= MEDIA_BUS_FMT_VYUY8_1X16,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SBGGR8,
    		.code			= MEDIA_BUS_FMT_SBGGR8_1X8,
    		.csi_dt			= MIPI_CSI2_DT_RAW8,
    		.bpp			= 8,
    		.fourcc			= V4L2_PIX_FMT_SGBRG8,
    		.code			= MEDIA_BUS_FMT_SGBRG8_1X8,
    		.bpp			= 8,
    		.fourcc			= V4L2_PIX_FMT_SGRBG8,
    		.code			= MEDIA_BUS_FMT_SGRBG8_1X8,
    		.bpp			= 8,
    		.fourcc			= V4L2_PIX_FMT_SRGGB8,
    		.code			= MEDIA_BUS_FMT_SRGGB8_1X8,
    		.bpp			= 8,
    		.fourcc			= V4L2_PIX_FMT_SBGGR10,
    		.code			= MEDIA_BUS_FMT_SBGGR10_1X10,
    		.csi_dt			= MIPI_CSI2_DT_RAW10,
    		.bpp			= 16,
    		.size			= SHIM_DMACNTX_SIZE_16,
    		.fourcc			= V4L2_PIX_FMT_SGBRG10,
    		.code			= MEDIA_BUS_FMT_SGBRG10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGRBG10,
    		.code			= MEDIA_BUS_FMT_SGRBG10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SRGGB10,
    		.code			= MEDIA_BUS_FMT_SRGGB10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SBGGR12,
    		.code			= MEDIA_BUS_FMT_SBGGR12_1X12,
    		.csi_dt			= MIPI_CSI2_DT_RAW12,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGBRG12,
    		.code			= MEDIA_BUS_FMT_SGBRG12_1X12,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGRBG12,
    		.code			= MEDIA_BUS_FMT_SGRBG12_1X12,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SRGGB12,
    		.code			= MEDIA_BUS_FMT_SRGGB12_1X12,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SRGGI10,
    		.code			= MEDIA_BUS_FMT_SRGGI10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGRIG10,
    		.code			= MEDIA_BUS_FMT_SGRIG10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SBGGI10,
    		.code			= MEDIA_BUS_FMT_SBGGI10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGBIG10,
    		.code			= MEDIA_BUS_FMT_SGBIG10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGIRG10,
    		.code			= MEDIA_BUS_FMT_SGIRG10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SIGGR10,
    		.code			= MEDIA_BUS_FMT_SIGGR10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SGIBG10,
    		.code			= MEDIA_BUS_FMT_SGIBG10_1X10,
    		.bpp			= 16,
    		.fourcc			= V4L2_PIX_FMT_SIGGB10,
    		.code			= MEDIA_BUS_FMT_SIGGB10_1X10,
    		.bpp			= 16,
    	/* More formats can be supported but they are not listed for now. */
    Does the bpp in the CSI2RX driver need to match the raw12 of the sensor driver?
    If need to modify it, how can we do? Simply changing it to 12 doesn't seem to work.
    from this guide  https://dev.ti.com/tirex/explore/content/am62ax_academy_9_02_00_00_v1/_build_am62ax_academy_9_02_00_00_v1/source/linux/ch-develop/dev-use-camera.html#enable-a-new-csi-2-sensor,if enable a new CSI-2 sensor,there is no indication that the CSI2RX driver needs to be modified,
    could you help to confirm if need to modify csi2rx and v4l2 driver and how to do it? thanks.
    Could you configure your sensor format to fmt:SRGGB10_1X10/1920x1080 and run the below pipeline?
    Thank you,
    Fabiana
