J722SXH01EVM: LVDS configuration single lane
Part Number: J722SXH01EVM
We are booting skipping u-boot, so do not have access to device tree overlays.
I'd like to configure the LVDS port on J722S channel 1 on J39.
I tried overwriting the dss section of the device tree and adding a "display" node in the root.
So far, the HDMI is still working, and the LVDS does not seem to be getting registered.
Attaching k3-j722s-evm.dts
Perhaps I need to remove the dss_port section first and then recreate it?
I started with the microtips overlay first, and it also didn't work correctly, causing the OS to crash and reboot. (but it did output on the LVDS connector for a split second)
// SPDX-License-Identifier: GPL-2.0
 * Device Tree file for the J722S-EVM
 * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/
 * Schematics: https://www.ti.com/lit/zip/sprr495
/dts-v1/;
#include <dt-bindings/leds/common.h>
#include "k3-j722s.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/mux/ti-serdes.h>
#include <dt-bindings/phy/phy.h>
	compatible = "ti,j722s-evm", "ti,j722s";
	model = "Texas Instruments J722S EVM";
	aliases {
		serial0 = &wkup_uart0;
		serial2 = &main_uart0;
		mmc0 = &sdhci0;
		mmc1 = &sdhci1;
		usb0 = &usb0;
		usb1 = &usb1;
	chosen {
		stdout-path = &main_uart0;
		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait loglevel=8 init=/sbin/hlio-init.sh";
	memory@80000000 {
		/* 8G RAM */
		reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
		      <0x00000008 0x80000000 0x00000001 0x80000000>;
		device_type = "memory";
		bootph-pre-ram;
	reserved_memory: reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		/* global cma region */
		linux,cma {
			compatible = "shared-dma-pool";
			reusable;
			size = <0x00 0x38000000>;
			linux,cma-default;
		secure_tfa_ddr: tfa@9e780000 {
			reg = <0x00 0x9e780000 0x00 0x80000>;
			no-map;
		secure_ddr: optee@9e800000 {
			reg = <0x00 0x9e800000 0x00 0x01800000>;
			no-map;
		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
			reg = <0x00 0xa0000000 0x00 0x100000>;
			no-map;
		wkup_r5fss0_core0_memory_region: r5f-memory@a0100000 {
			reg = <0x00 0xa0100000 0x00 0xf00000>;
			no-map;
		mcu_r5fss0_core0_dma_memory_region: mcu-r5fss-dma-memory-region@a1000000 {
			reg = <0x00 0xa1000000 0x00 0x100000>;
			no-map;
		mcu_r5fss0_core0_memory_region: mcu-r5fss-memory-region@a1100000 {
			reg = <0x00 0xa1100000 0x00 0xf00000>;
			no-map;
		main_r5fss0_core0_dma_memory_region: main-r5fss-dma-memory-region@a2000000 {
			reg = <0x00 0xa2000000 0x00 0x100000>;
			no-map;
		main_r5fss0_core0_memory_region: main-r5fss-memory-region@a2100000 {
			reg = <0x00 0xa2100000 0x00 0xf00000>;
			no-map;
		c7x_0_dma_memory_region: c7x-dma-memory@a3000000 {
			reg = <0x00 0xa3000000 0x00 0x100000>;
			no-map;
		c7x_0_memory_region: c7x-memory@a3100000 {
			reg = <0x00 0xa3100000 0x00 0xf00000>;
			no-map;
		c7x_1_dma_memory_region: c7x-dma-memory@a4000000 {
			reg = <0x00 0xa4000000 0x00 0x100000>;
			no-map;
		c7x_1_memory_region: c7x-memory@a4100000 {
			reg = <0x00 0xa4100000 0x00 0xf00000>;
			no-map;
		rtos_ipc_memory_region: ipc-memories@a5000000 {
			reg = <0x00 0xa5000000 0x00 0x1c00000>;
			alignment = <0x1000>;
			no-map;
	vmain_pd: regulator-0 {
		/* TPS65988 PD CONTROLLER OUTPUT */
		compatible = "regulator-fixed";
		regulator-name = "vmain_pd";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-always-on;
		regulator-boot-on;
		bootph-all;
	vsys_5v0: regulator-vsys5v0 {
		/* Output of LM5140 */
		regulator-name = "vsys_5v0";
		vin-supply = <&vmain_pd>;
		regulator-boot-on;
	vdd_mmc1: regulator-mmc1 {
		/* TPS22918DBVR */
		regulator-name = "vdd_mmc1";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&exp1 15 GPIO_ACTIVE_HIGH>;
		bootph-all;
	vdd_sd_dv: regulator-TLV71033 {
		compatible = "regulator-gpio";
		regulator-name = "tlv71033";
		pinctrl-names = "default";
		pinctrl-0 = <&vdd_sd_dv_pins_default>;
		regulator-min-microvolt = <1800000>;
		regulator-boot-on;
		vin-supply = <&vsys_5v0>;
		gpios = <&main_gpio0 70 GPIO_ACTIVE_HIGH>;
		states = <1800000 0x0>,
			 <3300000 0x1>;
	vsys_io_1v8: regulator-vsys-io-1v8 {
		regulator-name = "vsys_io_1v8";
		regulator-max-microvolt = <1800000>;
		regulator-boot-on;
	vsys_io_1v2: regulator-vsys-io-1v2 {
		regulator-name = "vsys_io_1v2";
		regulator-min-microvolt = <1200000>;
		regulator-max-microvolt = <1200000>;
		regulator-boot-on;
	leds {
		compatible = "gpio-leds";
		pinctrl-0 = <&led_pins_default>;
		led-0 {
			label = "j722s-evm:red:heartbeat";
			gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
			function = LED_FUNCTION_HEARTBEAT;
			linux,default-trigger = "heartbeat";
		led-1 {
			label = "j722s-evm:green:disk-activity";
			gpios = <&exp1 16 GPIO_ACTIVE_HIGH>;
			function = LED_FUNCTION_DISK_ACTIVITY;
			linux,default-trigger = "mmc1";
			default-state = "off";
	hdmi0: connector-hdmi {
		compatible = "hdmi-connector";
		label = "hdmi";
		type = "a";
		port {
			hdmi_connector_in: endpoint {
				remote-endpoint = <&sii9022_out>;
	display {
		compatible = "tianma,tm070rvhg71";
		power-supply = <&display_reg>;
		backlight = <&display_reg>;
		port@0 {
			lcd_in0: endpoint {
				remote-endpoint = <&oldi_out0>;
&main_pmx0 {
	/delete-property/ interrupts;
	main_i2c0_pins_default: main-i2c0-default-pins {
		pinctrl-single,pins = <
			J722S_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (D23) I2C0_SCL */
			J722S_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (B22) I2C0_SDA */
		bootph-all;
	main_i2c1_pins_default: main-i2c1-default-pins {
			J722S_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (C24) I2C1_SCL */
			J722S_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A22) I2C1_SDA */
		bootph-all;
	main_uart0_pins_default: main-uart0-default-pins {
			J722S_IOPAD(0x01c8, PIN_INPUT, 0)	/* (F19) UART0_RXD */
			J722S_IOPAD(0x01cc, PIN_OUTPUT, 0)	/* (F20) UART0_TXD */
			J722S_IOPAD(0x01d4, PIN_OUTPUT, 0)	/* (B21) UART0_RTSn */
			J722S_IOPAD(0x01d0, PIN_INPUT, 0)	/* (E22) UART0_CTSn */
		bootph-all;
	vdd_sd_dv_pins_default: vdd-sd-dv-default-pins {
			J722S_IOPAD(0x0120, PIN_INPUT, 7) /* (F27) MMC2_CMD.GPIO0_70 */
		bootph-all;
	main_mmc1_pins_default: main-mmc1-default-pins {
			J722S_IOPAD(0x023c, PIN_INPUT, 0) /* (H22) MMC1_CMD */
			J722S_IOPAD(0x0234, PIN_OUTPUT, 0) /* (H24) MMC1_CLK */
			J722S_IOPAD(0x0230, PIN_INPUT, 0) /* (H23) MMC1_DAT0 */
			J722S_IOPAD(0x022c, PIN_INPUT_PULLUP, 0) /* (H20) MMC1_DAT1 */
			J722S_IOPAD(0x0228, PIN_INPUT_PULLUP, 0) /* (J23) MMC1_DAT2 */
			J722S_IOPAD(0x0224, PIN_INPUT_PULLUP, 0) /* (H25) MMC1_DAT3 */
			J722S_IOPAD(0x0240, PIN_INPUT, 0) /* (B24) MMC1_SDCD */
		bootph-all;
	ospi0_pins_default: ospi0-default-pins {
			J722S_IOPAD(0x0000, PIN_OUTPUT, 0) /* (P23) OSPI0_CLK */
			J722S_IOPAD(0x002c, PIN_OUTPUT, 0) /* (M25) OSPI0_CSn0 */
			J722S_IOPAD(0x000c, PIN_INPUT, 0) /* (L25) OSPI0_D0 */
			J722S_IOPAD(0x0010, PIN_INPUT, 0) /* (N24) OSPI0_D1 */
			J722S_IOPAD(0x0014, PIN_INPUT, 0) /* (N25) OSPI0_D2 */
			J722S_IOPAD(0x0018, PIN_INPUT, 0) /* (M24) OSPI0_D3 */
			J722S_IOPAD(0x001c, PIN_INPUT, 0) /* (N21) OSPI0_D4 */
			J722S_IOPAD(0x0020, PIN_INPUT, 0) /* (N22) OSPI0_D5 */
			J722S_IOPAD(0x0024, PIN_INPUT, 0) /* (P21) OSPI0_D6 */
			J722S_IOPAD(0x0028, PIN_INPUT, 0) /* (N20) OSPI0_D7 */
			J722S_IOPAD(0x0008, PIN_INPUT, 0) /* (P22) OSPI0_DQS */
		bootph-all;
	main_i2c2_pins_default: main-i2c2-default-pins {
			J722S_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (P22) GPMC0_CSn2.I2C2_SCL */
			J722S_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (P23) GPMC0_CSn3.I2C2_SDA */
	mdio_pins_default: mdio-default-pins {
			J722S_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AC24) MDIO0_MDC */
			J722S_IOPAD(0x015c, PIN_INPUT, 0) /* (AD25) MDIO0_MDIO */
	rgmii1_pins_default: rgmii1-default-pins {
			J722S_IOPAD(0x014c, PIN_INPUT, 0) /* (AC25) RGMII1_RD0 */
			J722S_IOPAD(0x0150, PIN_INPUT, 0) /* (AD27) RGMII1_RD1 */
			J722S_IOPAD(0x0154, PIN_INPUT, 0) /* (AE24) RGMII1_RD2 */
			J722S_IOPAD(0x0158, PIN_INPUT, 0) /* (AE26) RGMII1_RD3 */
			J722S_IOPAD(0x0148, PIN_INPUT, 0) /* (AE27) RGMII1_RXC */
			J722S_IOPAD(0x0144, PIN_INPUT, 0) /* (AD23) RGMII1_RX_CTL */
			J722S_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AF27) RGMII1_TD0 */
			J722S_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AE23) RGMII1_TD1 */
			J722S_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AG25) RGMII1_TD2 */
			J722S_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AF24) RGMII1_TD3 */
			J722S_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AG26) RGMII1_TXC */
			J722S_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AF25) RGMII1_TX_CTL */
	led_pins_default: led-default-pins {
			J722S_IOPAD(0x0244, PIN_INPUT, 7) /* (A24) MMC1_SDWP */
	main_usb1_pins_default: main-usb1-default-pins {
			J722S_IOPAD(0x0258, PIN_INPUT, 0) /* (B27) USB1_DRVVBUS */
	main_gpio0_ioexp_intr_pins_default: main-gpio0-ioexp-intr-default-pins {
			J722S_IOPAD(0x0110, PIN_INPUT, 7) /* (G27) MMC2_DAT1.GPIO0_67 */
	main_dpi_pins_default: main-dpi-default-pins {
			J722S_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AB23) VOUT0_VSYNC */
			J722S_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
			J722S_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC26) VOUT0_PCLK */
			J722S_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (AC27) VOUT0_DE */
			J722S_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (W27) VOUT0_DATA0 */
			J722S_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA1 */
			J722S_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA2 */
			J722S_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W23) VOUT0_DATA3 */
			J722S_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA4 */
			J722S_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA5 */
			J722S_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y26) VOUT0_DATA6 */
			J722S_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (Y27) VOUT0_DATA7 */
			J722S_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA8 */
			J722S_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (AA27) VOUT0_DATA9 */
			J722S_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA10 */
			J722S_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA11 */
			J722S_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA12 */
			J722S_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA22) VOUT0_DATA13 */
			J722S_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (AB26) VOUT0_DATA14 */
			J722S_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AB27) VOUT0_DATA15 */
			J722S_IOPAD(0x005c, PIN_OUTPUT, 1) /* (U27) GPMC0_AD8.VOUT0_DATA16 */
			J722S_IOPAD(0x0060, PIN_OUTPUT, 1) /* (U26) GPMC0_AD9.VOUT0_DATA17 */
			J722S_IOPAD(0x0064, PIN_OUTPUT, 1) /* (V27) GPMC0_AD10.VOUT0_DATA18 */
			J722S_IOPAD(0x0068, PIN_OUTPUT, 1) /* (V25) GPMC0_AD11.VOUT0_DATA19 */
			J722S_IOPAD(0x006c, PIN_OUTPUT, 1) /* (V26) GPMC0_AD12.VOUT0_DATA20 */
			J722S_IOPAD(0x0070, PIN_OUTPUT, 1) /* (V24) GPMC0_AD13.VOUT0_DATA21 */
			J722S_IOPAD(0x0074, PIN_OUTPUT, 1) /* (V22) GPMC0_AD14.VOUT0_DATA22 */
			J722S_IOPAD(0x0078, PIN_OUTPUT, 1) /* (V23) GPMC0_AD15.VOUT0_DATA23 */
			J722S_IOPAD(0x009c, PIN_OUTPUT, 1) /* (W26) GPMC0_WAIT1.VOUT0_EXTPCLKIN */
&main_gpio1 {
	status = "okay";
&main_uart0 {
	pinctrl-0 = <&main_uart0_pins_default>;
	status = "okay";
	bootph-all;
&mcu_pmx0 {
	wkup_uart0_pins_default: wkup-uart0-default-pins {
			J722S_MCU_IOPAD(0x02c, PIN_INPUT, 0)	/* (C7) WKUP_UART0_CTSn */
			J722S_MCU_IOPAD(0x030, PIN_OUTPUT, 0)	/* (C6) WKUP_UART0_RTSn */
			J722S_MCU_IOPAD(0x024, PIN_INPUT, 0)	/* (D8) WKUP_UART0_RXD */
			J722S_MCU_IOPAD(0x028, PIN_OUTPUT, 0)	/* (D7) WKUP_UART0_TXD */
		bootph-all;
	wkup_i2c0_pins_default: wkup-i2c0-default-pins {
			J722S_MCU_IOPAD(0x04c, PIN_INPUT_PULLUP, 0)	/* (C7) WKUP_I2C0_SCL */
			J722S_MCU_IOPAD(0x050, PIN_INPUT_PULLUP, 0)	/* (C6) WKUP_I2C1_SDA */
		bootph-all;
&wkup_uart0 {
	/* WKUP UART0 is used by DM firmware */
	pinctrl-0 = <&wkup_uart0_pins_default>;
	status = "reserved";
	bootph-all;
&wkup_i2c0 {
	status = "okay";
	pinctrl-0 = <&wkup_i2c0_pins_default>;
	clock-frequency = <400000>;
	bootph-all;
&main_i2c0 {
	status = "okay";
	pinctrl-0 = <&main_i2c0_pins_default>;
	bootph-all;
	exp1: gpio@23 {
		compatible = "ti,tca6424";
		reg = <0x23>;
		gpio-controller;
		#gpio-cells = <2>;
		gpio-line-names = "TRC_MUX_SEL", "OSPI/ONAND_MUX_SEL",
				  "MCASP1_FET_SEL", "CTRL_PM_I2C_OE#",
				  "CSI_VIO_SEL", "USB2.0_MUX_SEL",
				  "CSI01_MUX_SEL_2", "CSI23_MUX_SEL_2",
				  "LMK1_OE1", "LMK1_OE0",
				  "LMK2_OE0", "LMK2_OE1",
				  "GPIO_RGMII1_RST#", "GPIO_AUD_RSTn",
				  "GPIO_eMMC_RSTn", "GPIO_uSD_PWR_EN",
				  "USER_LED2", "MCAN0_STB",
				  "PCIe0_1L_RC_RSTz", "PCIe0_1L_PRSNT#",
				  "ENET1_EXP_SPARE2", "ENET1_EXP_PWRDN",
				  "PD_I2ENET1_I2CMUX_SELC_IRQ", "ENET1_EXP_RESETZ";
		p01-hog {
			/* P01 - TRC_MUX_SEL */
			gpio-hog;
			gpios = <0 GPIO_ACTIVE_HIGH>;
			output-low;
			line-name = "TRC_MUX_SEL";
&main_i2c2 {
	status = "okay";
	pinctrl-0 = <&main_i2c2_pins_default>;
	pca9543_0: i2c-mux@70 {
		compatible = "nxp,pca9543";
		#address-cells = <1>;
		#size-cells = <0>;
		reg = <0x70>;
	pca9543_1: i2c-mux@71 {
		#size-cells = <0>;
		reg = <0x71>;
&main_i2c1 {
	status = "okay";
	pinctrl-0 = <&main_i2c1_pins_default>;
	clock-frequency = <100000>;
	exp2: gpio@20 {
		compatible = "ti,tca6416";
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
		gpio-line-names = "DSI_Mux_SEL_2", "GPIO_eDP_ENABLE",
				  "DP0_PWR_SW_EN", "GPIO_OLDI_RSTn",
				  "GPIO_HDMI_RSTn", "HDMI_LS_OE",
				  "DSI_GPIO0", "DSI_GPIO1",
				  "DSI_EDID", "IO_eDP_IRQ",
				  "OLDI_INT#", "HDMI_INTn",
		interrupt-parent = <&main_gpio0>;
		interrupts = <67 IRQ_TYPE_EDGE_FALLING>;
		interrupt-controller;
		#interrupt-cells = <2>;
		pinctrl-0 = <&main_gpio0_ioexp_intr_pins_default>;
		bootph-all;
		p04-hog {
			/* P04 - GPIO_HDMI_RSTn */
			gpio-hog;
			gpios = <4 GPIO_ACTIVE_LOW>;
			output-low;
			line-name = "GPIO_HDMI_RSTn";
		p03-hog {
			/* P03 - GPIO_OLDI_RSTn */
			gpio-hog;
			gpios = <3 GPIO_ACTIVE_LOW>;
			output-low;
			line-name = "GPIO_OLDI_RSTn";
		p05-hog {
			/* P05 - HDMI_LS_OE */
			gpio-hog;
			gpios = <5 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "HDMI_LS_OE";
	sii9022: bridge-hdmi@3b {
		compatible = "sil,sii9022";
		reg = <0x3b>;
		interrupt-parent = <&exp2>;
		interrupts = <13 IRQ_TYPE_EDGE_FALLING>;
		#sound-dai-cells = <0>;
		sil,i2s-data-lanes = < 0 >;
		hdmi_tx_ports: ports {
			#size-cells = <0>;
			 * HDMI can be serviced with 3 potential VPs -
			 * (DSS0 VP1 / DSS1 VP0 / DSS1 VP1).
			 * For now, we will service it with DSS1 VP0.
			port@0 {
				reg = <0>;
				sii9022_in: endpoint {
					remote-endpoint = <&dss1_dpi0_out>;
			port@1 {
				reg = <1>;
				sii9022_out: endpoint {
					remote-endpoint = <&hdmi_connector_in>;
&sdhci0 {
	/*eMMC*/
	status = "okay";
	ti,driver-strength-ohm = <50>;
	disable-wp;
	bootph-all;
&sdhci1 {
	/* SD/MMC */
	status = "okay";
	vmmc-supply = <&vdd_mmc1>;
	vqmmc-supply = <&vdd_sd_dv>;
	pinctrl-0 = <&main_mmc1_pins_default>;
	disable-wp;
	bootph-all;
&ospi0 {
	status = "okay";
	pinctrl-0 = <&ospi0_pins_default>;
	bootph-all;
	flash@0{
		compatible = "jedec,spi-nor";
		reg = <0x0>;
		spi-tx-bus-width = <8>;
		spi-rx-bus-width = <8>;
		spi-max-frequency = <25000000>;
		cdns,tshsl-ns = <60>;
		cdns,tsd2d-ns = <60>;
		cdns,tchsh-ns = <60>;
		cdns,tslch-ns = <60>;
		cdns,read-delay = <4>;
		bootph-all;
		partitions {
			compatible = "fixed-partitions";
			#size-cells = <1>;
			bootph-all;
			partition@0 {
				label = "ospi.tiboot3";
				reg = <0x00 0x80000>;
			partition@80000 {
				label = "ospi.tispl";
				reg = <0x80000 0x200000>;
			partition@280000 {
				label = "ospi.u-boot";
				reg = <0x280000 0x400000>;
			partition@680000 {
				label = "ospi.env";
				reg = <0x680000 0x40000>;
			partition@6c0000 {
				label = "ospi.env.backup";
				reg = <0x6c0000 0x40000>;
			partition@800000 {
				label = "ospi.rootfs";
				reg = <0x800000 0x37c0000>;
			partition@3fc0000 {
				label = "ospi.phypattern";
				reg = <0x3fc0000 0x40000>;
				bootph-all;
	ospi0_nand: nand@0 {
		compatible = "spi-nand";
		reg = <0x0>;
		cdns,read-delay = <2>;
		#size-cells = <1>;
		status = "disabled";
		partitions {
			#size-cells = <1>;
			partition@0 {
				label = "ospi_nand.tiboot3";
				reg = <0x0 0x80000>;
			partition@80000 {
				label = "ospi_nand.tispl";
			partition@280000 {
				label = "ospi_nand.u-boot";
			partition@680000 {
				label = "ospi_nand.env";
			partition@6c0000 {
				label = "ospi_nand.env.backup";
			partition@2000000 {
				label = "ospi_nand.rootfs";
				reg = <0x2000000 0x5fc0000>;
			partition@7fc0000 {
				label = "ospi_nand.phypattern";
				reg = <0x7fc0000 0x40000>;
&cpsw3g {
	status = "okay";
	pinctrl-0 = <&rgmii1_pins_default>;
&cpsw3g_mdio {
	status = "okay";
	pinctrl-0 = <&mdio_pins_default>;
	cpsw3g_phy0: ethernet-phy@0 {
		reg = <0>;
		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
		ti,min-output-impedance;
&cpsw_port1 {
	phy-mode = "rgmii-rxid";
	phy-handle = <&cpsw3g_phy0>;
&cpsw_port2 {
&mailbox0_cluster0 {
	status = "okay";
	mbox_r5_0: mbox-r5-0 {
		ti,mbox-rx = <0 0 0>;
		ti,mbox-tx = <1 0 0>;
&mailbox0_cluster1 {
	status = "okay";
	mbox_mcu_r5_0: mbox-mcu-r5-0 {
&mailbox0_cluster2 {
	status = "okay";
	mbox_c7x_0: mbox-c7x-0 {
&mailbox0_cluster3 {
	status = "okay";
	mbox_main_r5_0: mbox-main-r5-0 {
	mbox_c7x_1: mbox-c7x-1 {
		ti,mbox-rx = <2 0 0>;
		ti,mbox-tx = <3 0 0>;
&wkup_r5fss0 {
	status = "okay";
&wkup_r5fss0_core0 {
	mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
	memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
			<&wkup_r5fss0_core0_memory_region>;
&mcu_r5fss0 {
	status = "okay";
&mcu_r5fss0_core0 {
	mboxes = <&mailbox0_cluster1 &mbox_mcu_r5_0>;
	memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
			<&mcu_r5fss0_core0_memory_region>;
&main_r5fss0 {
	status = "okay";
&main_r5fss0_core0 {
	mboxes = <&mailbox0_cluster3 &mbox_main_r5_0>;
	memory-region = <&main_r5fss0_core0_dma_memory_region>,
			<&main_r5fss0_core0_memory_region>;
&c7x_0 {
	status = "okay";
	mboxes = <&mailbox0_cluster2 &mbox_c7x_0>;
	memory-region = <&c7x_0_dma_memory_region>,
			<&c7x_0_memory_region>;
&c7x_1 {
	status = "okay";
	mboxes = <&mailbox0_cluster3 &mbox_c7x_1>;
	memory-region = <&c7x_1_dma_memory_region>,
			<&c7x_1_memory_region>;
&serdes_ln_ctrl {
	idle-states = <J722S_SERDES0_LANE0_USB>,
		      <J722S_SERDES1_LANE0_PCIE0_LANE0>;
&serdes0 {
	status = "okay";
	serdes0_usb_link: phy@0 {
		reg = <0>;
		cdns,num-lanes = <1>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_USB3>;
		resets = <&serdes_wiz0 1>;
&serdes1 {
	serdes1_pcie_link: phy@0 {
		reg = <0>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_PCIE>;
		resets = <&serdes_wiz1 1>;
&usbss0 {
	status = "okay";
	ti,vbus-divider;
&usb0 {
	dr_mode = "otg";
	usb-role-switch;
&usbss1 {
	status = "okay";
	pinctrl-0 = <&main_usb1_pins_default>;
	ti,vbus-divider;
&usb1 {
	dr_mode = "host";
	maximum-speed = "super-speed";
	phys = <&serdes0_usb_link>;
	phy-names = "cdns3,usb3-phy";
&pcie0_rc {
	status = "okay";
	reset-gpios = <&exp1 18 GPIO_ACTIVE_HIGH>;
	phys = <&serdes1_pcie_link>;
	phy-names = "pcie-phy";
&dss1 {
	status = "okay";
	pinctrl-0 = <&main_dpi_pins_default>;
	assigned-clocks = <&k3_clks 241 0>,	/* DSS1-VP0 */
			  <&k3_clks 240 0>,	/* DSS1-VP1 */
			  <&k3_clks 245 0>;	/* DPI Output */
	assigned-clock-parents = <&k3_clks 241 2>,	/* PLL 17 HDMI */
				 <&k3_clks 240 1>,	/* PLL 18 DSI */
				 <&k3_clks 245 2>;	/* DSS1-DPI0 */
&dss1_ports {
	/* DSS1-VP0: DPI/HDMI Output */
	port@0 {
		reg = <0>;
		dss1_dpi0_out: endpoint {
			remote-endpoint = <&sii9022_in>;
&dss0 {
	status = "okay";
&dss0_ports {
	#size-cells = <0>;
	/* VP1: LVDS Output (OLDI TX 0) */
	port@0 {
		reg = <0>;
		oldi_out0: endpoint {
			remote-endpoint = <&lcd_in0>;
&main_i2c1 {
	#size-cells = <0>;
	display_reg: regulator@45 {
		compatible = "raspberrypi,7inch-touchscreen-panel-regulator";
		reg = <0x45>;
		gpio-controller;
		#gpio-cells = <2>;
Here's the patch I applied for testing the dual LVDS output:
From fdff488f989a805275b007666ea49d7edba256e3 Mon Sep 17 00:00:00 2001
From: Evan Williams <evan.williams@enovationcontrols.com>
Date: Wed, 24 Jul 2024 11:29:04 -0500
Subject: [PATCH] Adding LVDS output.
 arch/arm64/boot/dts/ti/k3-j722s-evm.dts | 55 +++++++++++++++++++++++++
 1 file changed, 55 insertions(+)
diff --git a/arch/arm64/boot/dts/ti/k3-j722s-evm.dts b/arch/arm64/boot/dts/ti/k3-j722s-evm.dts
index 26257e7989f4..53665db57335 100644
--- a/arch/arm64/boot/dts/ti/k3-j722s-evm.dts
+++ b/arch/arm64/boot/dts/ti/k3-j722s-evm.dts
@@ -227,6 +227,34 @@ hdmi_connector_in: endpoint {
+	display {
+		compatible = "microtips,mf-101hiebcaf0";
+		* Note that the OLDI TX 0 transmits the odd set of pixels
+		* while the OLDI TX 1 transmits the even set. This is a
+		* fixed configuration in the IP integration and is not
+		* changeable. The properties, "dual-lvds-odd-pixels" and
+		* "dual-lvds-even-pixels" have been used to merely
+		* identify if a Dual Link configuration is required.
+		* Swapping them will not make any difference.
+		port@0 {
+			dual-lvds-odd-pixels;
+			lcd_in0: endpoint {
+				remote-endpoint = <&oldi_out0>;
+		port@1 {
+			dual-lvds-even-pixels;
+			lcd_in1: endpoint {
+				remote-endpoint = <&oldi_out1>;
 &main_pmx0 {
@@ -903,3 +931,33 @@ dss1_dpi0_out: endpoint {
+&dss0 {
+	status = "okay";
+&dss0_ports {
+	#address-cells = <1>;
+	#size-cells = <0>;
+	/* VP1: LVDS Output (OLDI TX 0) */
+	port@0 {
+		reg = <0>;
+		oldi_out0: endpoint {
+			remote-endpoint = <&lcd_in0>;
+	/* VP1: LVDS Output (OLDI TX 1) */
+	port@2 {
+		reg = <2>;
+		oldi_out1: endpoint {
+			remote-endpoint = <&lcd_in1>;
I think I've found there's an issue with the tidss driver.
I'll attach some debug information once I have it.
  • Hi Evan,
    Yes, please do so.
    Otherwise, you mention that testing the dual LVDS output using microtips worked briefly. I see main difference being backlight/power-supply properties, and usage of dual channel vs single channel, and of course, timing/mode coded in the driver is different between microtip and tianma display.
    One theory I have is that there are issues with how backlight/power-supply properties are populated when using the tianma display. Reasoning for this is that I see the "raspberrypi,7inch-touchscreen-panel-regulator" is used in your device tree. Reading through devicetree bindings, this seems to interface with a ATTiny that is integrated on to the Raspberry Pi display itself (details here: https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel/tree/Documentation/devicetree/bindings/regulator/raspberrypi,7inch-touchscreen-panel-regulator.yaml?h=ti-linux-6.1.y)
    We are using a different display, so this power-supply node will most likely not function correctly. This could explain why the microtip overlay works briefly, since it does not have power-supply node, and since it is the wrong timing as tianma display, that explains why it would fail.
    Takuma
  • Hi Takuma,
    Please see attached.
    I've since removed the raspi regulators and am only initializing the dss0 module with the LVDS port as simply as possible, like in the patch for dual LVDS.
    U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
    SPL initial stack usage: 17064 bytes
    Trying to boot from SPI
    Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices
    Starting ATF on ARM64 core...
    bl31_early_platform_setup2[86]: PRELOADED_BL33_BASE=0x80200000New Print!
    NOTICE:  New Print!
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b8-dirty
    NOTICE:  BL31: Built : 20:29:25, Jun 20 2024
    NOTICE:  Upgrade Firmwares for Power off functionality
    ERROR:   Failed to get response (-19)
    ERROR:   Transfer send failed (-19)
    ERROR:   Unable to query firmware capabilities (-19)
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024
    [    0.000000] Machine model: Texas Instruments J722S EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009c8000000, size 896 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node main-r5fss-dma-memory-region@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node main-r5fss-memory-region@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a6bfffff]
    [    0.000000]   node   0: [mem 0x00000000a6c00000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41128 r8192 d32600 u81920
    [    0.000000] pcpu-alloc: s41128 r8192 d32600 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064384
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait loglevel=8 init=/sbin/init
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 7089488K/8388608K available (11712K kernel code, 1260K rwdata, 3816K rodata, 1984K init, 440K bss, 381616K reserved, 917504K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008514] Console: colour dummy device 80x25
    [    0.013098] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023767] pid_max: default: 32768 minimum: 301
    [    0.028525] LSM: Security Framework initializing
    [    0.033361] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.041120] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.050828] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.058254] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.064536] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.071923] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.078290] rcu: Hierarchical SRCU implementation.
    [    0.083190] rcu:     Max phase no-delay instances is 1000.
    [    0.088753] Platform MSI: msi-controller@1820000 domain created
    [    0.095048] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.104458] EFI services will not be available.
    [    0.109328] smp: Bringing up secondary CPUs ...
    [    0.114570] Detected VIPT I-cache on CPU1
    [    0.114668] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.114685] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.114734] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.115356] Detected VIPT I-cache on CPU2
    [    0.115423] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.115437] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.115468] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.116026] Detected VIPT I-cache on CPU3
    [    0.116103] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.116114] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.116143] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.116203] smp: Brought up 1 node, 4 CPUs
    [    0.195841] SMP: Total of 4 processors activated.
    [    0.200647] CPU features: detected: 32-bit EL0 Support
    [    0.205912] CPU features: detected: CRC32 instructions
    [    0.211215] CPU: All CPU(s) started at EL2
    [    0.215407] alternatives: applying system-wide alternatives
    [    0.222681] devtmpfs: initialized
    [    0.236279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.246279] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.280229] pinctrl core: initialized pinctrl subsystem
    [    0.286170] DMI not present or invalid.
    [    0.290653] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.297716] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.305151] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.313269] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.321553] audit: initializing netlink subsys (disabled)
    [    0.327262] audit: type=2000 audit(0.224:1): state=initialized audit_enabled=0 res=1
    [    0.327690] thermal_sys: Registered thermal governor 'step_wise'
    [    0.335179] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.341462] cpuidle: using governor menu
    [    0.352282] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.359291] ASID allocator initialised with 65536 entries
    [    0.378121] KASLR disabled due to lack of seed
    [    0.388899] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.395857] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.402260] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.409191] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.415591] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.422521] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.428922] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.435852] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.443525] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
    [    0.453541] iommu: Default domain type: Translated
    [    0.458545] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.465200] SCSI subsystem initialized
    [    0.469170] libata version 3.00 loaded.
    [    0.473261] usbcore: registered new interface driver usbfs
    [    0.478893] usbcore: registered new interface driver hub
    [    0.484340] usbcore: registered new device driver usb
    [    0.489918] pps_core: LinuxPPS API ver. 1 registered
    [    0.494992] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.504329] PTP clock support registered
    [    0.508455] EDAC MC: Ver: 3.0.0
    [    0.512454] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.519272] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.526082] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.532907] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
    [    0.539924] FPGA manager framework
    [    0.543474] Advanced Linux Sound Architecture Driver Initialized.
    [    0.550550] clocksource: Switched to clocksource arch_sys_counter
    [    0.556999] VFS: Disk quotas dquot_6.6.0
    [    0.561041] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.573638] NET: Registered PF_INET protocol family
    [    0.578973] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.591946] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.600782] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.608718] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.617233] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.626628] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.633478] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.640574] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.648251] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.654463] RPC: Registered named UNIX socket transport module.
    [    0.660537] RPC: Registered udp transport module.
    [    0.665341] RPC: Registered tcp transport module.
    [    0.670144] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.676728] NET: Registered PF_XDP protocol family
    [    0.681632] PCI: CLS 0 bytes, default 64
    [    0.686324] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.696251] Initialise system trusted keyrings
    [    0.701019] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.711706] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.718207] NFS: Registering the id_resolver key type
    [    0.723417] Key type id_resolver registered
    [    0.727688] Key type id_legacy registered
    [    0.731832] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.738679] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.780790] Key type asymmetric registered
    [    0.784979] Asymmetric key parser 'x509' registered
    [    0.790003] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.797699] io scheduler mq-deadline registered
    [    0.802339] io scheduler kyber registered
    [    0.809661] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.816081] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.828160] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.843363] loop: module loaded
    [    0.847613] megasas: 07.719.03.00-rc1
    [    0.854198] tun: Universal TUN/TAP device driver, 1.6
    [    0.860058] VFIO - User Level meta-driver version: 0.3
    [    0.866039] usbcore: registered new interface driver usb-storage
    [    0.872719] i2c_dev: i2c /dev entries driver
    [    0.878211] sdhci: Secure Digital Host Controller Interface driver
    [    0.884555] sdhci: Copyright(c) Pierre Ossman
    [    0.889205] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.895707] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.902026] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.908955] usbcore: registered new interface driver usbhid
    [    0.914653] usbhid: USB HID core driver
    [    0.919396] optee: probing for conduit method.
    [    0.923975] optee: revision 4.1 (012cdca4)
    [    0.924249] optee: dynamic shared memory is enabled
    [    0.933648] optee: initialized driver
    [    0.939144] Initializing XFRM netlink socket
    [    0.943558] NET: Registered PF_PACKET protocol family
    [    0.948784] Key type dns_resolver registered
    [    0.953530] registered taskstats version 1
    [    0.957740] Loading compiled-in X.509 certificates
    [    0.970415] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
    [    1.025846] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.032642] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.039533] pca953x 1-0023: using AI
    [    1.067205] gpio-488 (TRC_MUX_SEL): hogged as output/low
    [    1.073131] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.079786] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.106793] i2c i2c-3: Added multiplexed i2c bus 4
    [    1.111846] i2c i2c-3: Added multiplexed i2c bus 5
    [    1.116750] pca954x 3-0070: registered 2 multiplexed busses for I2C switch pca9543
    [    1.124893] i2c i2c-3: Added multiplexed i2c bus 6
    [    1.129936] i2c i2c-3: Added multiplexed i2c bus 7
    [    1.134844] pca954x 3-0071: registered 2 multiplexed busses for I2C switch pca9543
    [    1.142611] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.148511] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.156823] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.166026] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.174993] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.188785] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.196721] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
    [    1.207348] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.217074] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.226446] ti-udma 4e230000.dma-controller: Number of rings: 40
    [    1.233655] ti-udma 4e230000.dma-controller: Channels: 20 (bchan: 0, tchan: 8, rchan: 12)
    [    1.243703] printk: console [ttyS2] disabled
    [    1.248143] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 276, base_baud = 3000000) is a 8250
    [    1.257004] printk: console [ttyS2] enabled
    [    1.265455] printk: bootconsole [ns16550a0] disabled
    [    1.278371] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.283447] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.290405] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.295796] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.302372] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.308697] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.315121] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.321254] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.328026] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.334399] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.382570] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.392187] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.400323] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.413173] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.419443] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.426567] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.433096] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.443458] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.451270] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
    [    1.457070] cpu cpu0: OPP table can't be empty
    [    1.462843] mmc0: CQHCI version 5.10
    [    1.469301] pca953x 2-0020: supply vcc not found, using dummy regulator
    [    1.476041] pca953x 2-0020: using no AI
    [    1.506297] gpio-308 (GPIO_HDMI_RSTn): hogged as output/low
    [    1.507851] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.512528] gpio-307 (GPIO_OLDI_RSTn): hogged as output/low
    [    1.525561] gpio-309 (HDMI_LS_OE): hogged as output/high
    [    1.536567] debugfs: Directory 'pd:249' with parent 'pm_genpd' already present!
    [    1.536567] mmc1: CQHCI version 5.10
    [    1.536612] debugfs: Directory 'pd:248' with parent 'pm_genpd' already present!
    [    1.554819] debugfs: Directory 'pd:247' with parent 'pm_genpd' already present!
    [    1.562298] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.569650] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present!
    [    1.578315] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.585658] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.600410] ALSA device list:
    [    1.603399]   No soundcards found.
    [    1.606918] mmc0: Command Queue Engine enabled
    [    1.611376] mmc0: new HS400 MMC card at address 0001
    [    1.617000] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.624204]  mmcblk0: p1
    [    1.627327] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.633264] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.639058] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
    [    3.062693] sdhci-am654 fa00000.mmc: Power on failed
    [    3.098271] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    3.121835] EXT4-fs (mmcblk0p1): recovery complete
    [    3.127280] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
    [    3.135865] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    3.142276] devtmpfs: mounted
    [    3.145826] Freeing unused kernel memory: 1984K
    [    3.150437] Run /sbin/init as init process
    [    3.154528]   with arguments:
    [    3.157489]     /sbin/init
    [    3.160190]   with environment:
    [    3.163323]     HOME=/
    [    3.165672]     TERM=linux
    [    3.239624] systemd[1]: System time before build time, advancing clock.
    [    3.267171] NET: Registered PF_INET6 protocol family
    [    3.273109] Segment Routing with IPv6
    [    3.276827] In-situ OAM (IOAM) with IPv6
    [    3.296563] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    3.328378] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    3.395221] systemd[1]: Hostname set to <openviewpro>.
    [    3.466456] systemd-sysv-generator[156]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    3.661859] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.716183] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.791720] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.858426] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.881454] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.905434] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.928806] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.950995] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.974866] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.998960] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    4.014707] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.034667] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    4.050692] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    4.107827] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.130810] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.156817] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.179052] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.203541] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    4.227274] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.251239] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.267446] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.291317] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.311114] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.331181] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    4.379026] systemd[1]: Mounting Huge Pages File System...
    [    4.399384] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.447071] systemd[1]: Mounting Kernel Debug File System...
    [    4.463132] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.481165] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.504440] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.531255] systemd[1]: Starting Load Kernel Module configfs...
    [    4.551309] systemd[1]: Starting Load Kernel Module drm...
    [    4.571935] systemd[1]: Starting Load Kernel Module fuse...
    [    4.582222] fuse: init (API version 7.37)
    [    4.594885] systemd[1]: Starting Start psplash boot splash screen...
    [    4.624501] systemd[1]: Starting RPC Bind...
    [    4.647941] systemd[1]: Started Boot Process Profiler.
    [  OK  ] Started Boot Process Profiler.
    [    4.671102] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    4.690470] systemd[1]: Starting Journal Service...
    [    4.714383] systemd[1]: Starting Load Kernel Modules...
    [    4.731295] cryptodev: loading out-of-tree module taints kernel.
    [    4.736126] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network …ts from Kernel co[    4.750862] cryptodev: driver 1.12 loaded.
    mmand line...
    [    4.791365] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.811339] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
    [    4.823442] systemd[1]: Starting Coldplug All udev Devices...
    [    4.848535] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.863404] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting NFSD configuration filesystem...
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    5.245226] systemd-journald[172]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [FAILED] Failed to mount NFSD configuration filesystem.
    See 'systemctl status proc-fs-nfsd.mount' for details.
    [DEPEND] Dependency failed for NFS Mount Daemon.
    [DEPEND] Dependency failed for NFS server and services.
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
    [    5.519505] audit: type=1334 audit(1651167747.276:2): prog-id=5 op=LOAD
    [    5.526196] audit: type=1334 audit(1651167747.280:3): prog-id=6 op=LOAD
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Create Volatile Files and Directories.
    [    5.758585] random: crng init done
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Found device /dev/ttyS2.
    [    6.047866] mc: Linux media interface: v0.10
    [    6.073588] videodev: Linux video capture interface: v2.00
    [    6.117299] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@a3000000
    [    6.132002] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    6.139089] remoteproc remoteproc0: 7e000000.dsp is available
    [    6.143100] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.145079] k3-dsp-rproc 7e000000.dsp: register pm nitifiers in remoteproc mode
    [    6.157524] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@a1000000
    [    6.159524] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2
    [  OK  ] Started Network Time Synchronizatio[    6.177231] remoteproc remoteproc0: powering up 7e000000.dsp
    n.
    [    6.177699] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node c7x-dma-memory@a4000000
    [    6.188839] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2
    [    6.200048] k3-dsp-rproc 7e200000.dsp: configured DSP for remoteproc mode
    [    6.206526] remoteproc remoteproc1: 79000000.r5f is available
    [    6.217185] remoteproc remoteproc0: request_firmware failed: -2
    [    6.219493] remoteproc remoteproc1: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2
    [    6.229864] remoteproc remoteproc2: 7e200000.dsp is available
    [    6.235294] remoteproc remoteproc1: powering up 79000000.r5f
    [    6.240416] k3-dsp-rproc 7e200000.dsp: register pm nitifiers in remoteproc mode
    [    6.246012] remoteproc remoteproc1: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2
    [    6.253255] remoteproc remoteproc2: Direct firmware load for j722s-c71_1-fw failed with error -2
    [    6.253282] remoteproc remoteproc2: powering up 7e200000.dsp
    [    6.253310] remoteproc remoteproc2: Direct firmware load for j722s-c71_1-fw failed with error -2
    [    6.271373] remoteproc remoteproc1: request_firmware failed: -2
    [    6.277168] remoteproc remoteproc2: request_firmware failed: -2
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary [    6.318944] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    Directories.
    [    6.338827] tidss 30200000.dss: tidss_probe
    [  OK  ] Reached target System Time Set.[    6.348948] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.355883] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [  OK  ] Reached target Timer Units.[    6.372045] remoteproc remoteproc3: 78000000.r5f is available
    [    6.382736] remoteproc remoteproc3: attaching to 78000000.r5f
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [    6.402250] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    6.406078] tidss 30200000.dss: dispc_init
    [    6.409191] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [    6.413435] tidss 30200000.dss: DSS fclk 320000000 Hz
    [  OK  ] Listening on D-Bus System Message B[    6.428153] tidss 30200000.dss: tidss_modeset_init
    us Socket.
    [    6.439515] tidss 30200000.dss: port 0 probe returned -517
    [    6.443260] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.443517] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.443640] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
             Starting Docker Socket for the API...
    [    6.470283] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    6.477514] remoteproc remoteproc3: remote processor 78000000.r5f is now attached
    [    6.478944] e5010 fd20000.e5010: Device registered as /dev/video2
    [    6.495966] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
    [  OK  ] Listening on dropbear.socket.
    [    6.505511] platform 78400000.r5f: configured R5F for remoteproc mode
    [    6.519590] tidss 30200000.dss: tidss_probe
    [    6.525544] platform 78400000.r5f: assigned reserved memory node main-r5fss-dma-memory-region@a2000000
    [    6.548206] tidss 30200000.dss: dispc_init
    [    6.552564] tidss 30200000.dss: DSS fclk 320000000 Hz
    [    6.558891] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    6.559305] remoteproc remoteproc4: 78400000.r5f is available
    [    6.565009] tidss 30200000.dss: tidss_modeset_init
    [  OK  ] Listening on PC/SC Smart Card Daemo[    6.575313] tidss 30200000.dss: port 0 probe returned -517
    n Activation Socket.
    [    6.575606] remoteproc remoteproc4: Direct firmware load for j722s-main-r5f0_0-fw failed with error -2
    [    6.589711] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10)
    [    6.590492] tidss 30200000.dss: tidss_probe
    [    6.602245] remoteproc remoteproc4: powering up 78400000.r5f
    [    6.616256] remoteproc remoteproc4: Direct firmware load for j722s-main-r5f0_0-fw failed with error -2
    [    6.625652] remoteproc remoteproc4: request_firmware failed: -2
    [    6.625895] tidss 30200000.dss: dispc_init
    [    6.631862] PVR_K:  207: Device: fd80000.gpu
    [    6.636577] tidss 30200000.dss: DSS fclk 320000000 Hz
    [    6.641501] PVR_K:  207: Read BVNC 36.53.104.796 from HW device registers
    [    6.645867] tidss 30200000.dss: tidss_modeset_init
    [    6.653142] PVR_K:  207: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.657051] tidss 30200000.dss: port 0 probe returned -517
    [    6.660026] systemd-journald[172]: Time jumped backwards, rotating.
    [    6.688114] tidss 30200000.dss: tidss_probe
    [    6.712857] tidss 30200000.dss: dispc_init
    [    6.717243] tidss 30200000.dss: DSS fclk 320000000 Hz
    [    6.726718] tidss 30200000.dss: tidss_modeset_init
    [    6.731764] tidss 30200000.dss: port 0 probe returned -517
    [    6.742075] [drm] Initialized pvr 23.3.6512818 20170530 for fd80000.gpu on minor 1
    [    6.762386] tidss 30200000.dss: tidss_probe
    [    6.799310] panel-simple panel: supply power not found, using dummy regulator
    [    6.893434] j721e-pcie-host f102000.pcie: host bridge /pcie@f102000 ranges:
    [    6.900521] j721e-pcie-host f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    6.910217] j721e-pcie-host f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    6.918946] j721e-pcie-host f102000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.923412] tidss 30200000.dss: dispc_init
    [    6.932058] tidss 30200000.dss: DSS fclk 320000000 Hz
             Starting Weston socket...[    6.938159] tidss 30200000.dss: tidss_modeset_init
    [    6.949244] tidss 30200000.dss: Setting up panel for port 0
    [    6.955243] tidss 30200000.dss: no panel/bridge for port 1
    [    6.960827] tidss 30200000.dss: no panel/bridge for port 2
    [    6.966521] tidss 30200000.dss: tidss_crtc_create: tidss->shared_mode: 0 tidss->shared_mode_owned_vps[0] = 0
    [    6.976465] tidss 30200000.dss: Encoder create done
             Starting D-Bus System Message Bus...
    [    6.988034] tidss 30200000.dss: tidss_modeset_init done
    [    6.997831] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [  OK  ] Listening on Docker Socket for the API.
    [    7.018319] tidss 30200000.dss: tidss_encoder_atomic_check
    [    7.018346] tidss 30200000.dss: tidss_plane_atomic_check
    [    7.018361] tidss 30200000.dss: tidss_plane_atomic_check
    [    7.018366] tidss 30200000.dss: tidss_crtc_atomic_check
    [    7.018394] tidss 30200000.dss: tidss_atomic_commit_tail
    [    7.018399] tidss 30200000.dss: tidss_runtime_get
    [    7.018748] tidss 30200000.dss: tidss_pm_runtime_resume
    [    7.018766] tidss 30200000.dss: resume
    [    7.018819] tidss 30200000.dss: OMAP DSS7 rev 0x64040901
    [    7.018827] tidss 30200000.dss: VP RESETDONE 1,1,0
    [    7.018834] tidss 30200000.dss: OLDI RESETDONE 0,0,0
    [    7.018840] tidss 30200000.dss: DISPC IDLE 1
    [    7.018844] tidss 30200000.dss: dispc_k3_plane_init()
    [    7.018851] tidss 30200000.dss: vid: bufsize 2560, buf_threshold 2559/1280, mflag threshold 1706/853 preload 1280
    [    7.018862] tidss 30200000.dss: vidl1: bufsize 2560, buf_threshold 2559/1280, mflag threshold 1706/853 preload 1280
    [    7.018871] tidss 30200000.dss: dispc_vp_init()
    [    7.018899] tidss 30200000.dss: tidss_plane_atomic_update
    [    7.018913] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, needs modeset, event 0000000077d9cd8b
    [    7.018926] tidss 30200000.dss: tidss_crtc_atomic_enable, event 0000000077d9cd8b
    [    7.018932] tidss 30200000.dss: tidss_runtime_get
    [    7.019076] tidss 30200000.dss: vp0: new rate 210000000 Hz (requested 204400000 Hz)
    [    7.019151] tidss 30200000.dss: dispc_vp_set_gamma: vp_idx 0, lut len 0, hw len 256
    [    7.019168] tidss 30200000.dss: dispc_am65x_vp_write_gamma_table: vp_idx 0
    [    7.019278] tidss 30200000.dss: tidss_runtime_put
    [    7.019321] Console: switching to colour frame buffer device 100x30
    [    7.019399] tidss 30200000.dss: tidss_encoder_atomic_check
    [    7.019407] tidss 30200000.dss: tidss_plane_atomic_check
    [    7.019419] tidss 30200000.dss: tidss_plane_atomic_check
    [    7.019424] tidss 30200000.dss: tidss_crtc_atomic_check
    [    7.019451] tidss 30200000.dss: tidss_atomic_commit_tail
    [    7.019456] tidss 30200000.dss: tidss_runtime_get
    [    7.019466] tidss 30200000.dss: tidss_plane_atomic_update
    [    7.019477] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, doesn't need modeset, event 00000000a3bec537
    [    7.019490] tidss 30200000.dss: tidss_crtc_enable_vblank
    [    7.019495] tidss 30200000.dss: tidss_runtime_get
    [    7.035648] tidss 30200000.dss: tidss_runtime_put
    [    7.266499] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
    [  OK  ] Listening on Weston socket.
    [  OK  ] Started D-Bus System Message Bus.
    [    7.306631] tidss 30200000.dss: tidss_probe done
    [    7.306786] tidss 30200000.dss: tidss_encoder_atomic_check
    [    7.317456] tidss 30200000.dss: tidss_plane_atomic_check
    [    7.322854] tidss 30200000.dss: tidss_plane_atomic_check
    [    7.328967] tidss 30200000.dss: tidss_crtc_atomic_check
    [    7.342644] tidss 30200000.dss: tidss_atomic_commit_tail
    [    7.348077] tidss 30200000.dss: tidss_runtime_get
    [    7.352865] tidss 30200000.dss: tidss_plane_atomic_update
    [    7.358708] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, doesn't need modeset, event 00000000cf71b279
    [    7.377691] tidss 30200000.dss: tidss_runtime_put
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [    7.562137] audit: type=1334 audit(11.468:4): prog-id=7 op=LOAD
    [    7.570117] audit: type=1334 audit(11.476:5): prog-id=8 op=LOAD
             Starting User Login Management...
    [  OK  ] Started TEE Supplicant.
             Starting Telnet Server...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [    7.888834] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [    7.920139] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [    7.953397] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [    7.953484] xhci-hcd xhci-hcd.2.auto: irq 475, io mem 0x31210000
    [    7.953696] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [    7.953806] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [    7.953835] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [    7.969621] hub 1-0:1.0: USB hub found
    [    7.971743] j721e-pcie-host f102000.pcie: PCI host bridge to bus 0000:00
    [    7.971764] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    7.971776] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    7.971783] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    7.972094] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    7.972426] pci 0000:00:00.0: supports D1
    [    7.972436] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    7.993930] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    7.998999] hub 1-0:1.0: 1 port detected
    [    8.006376] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    8.007973] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    8.015503] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    8.020556] hub 2-0:1.0: USB hub found
    [    8.031970] pcieport 0000:00:00.0: PME: Signaling with IRQ 479
    [    8.036364] hub 2-0:1.0: 1 port detected
    [    8.046371] pcieport 0000:00:00.0: AER: enabled with IRQ 479
    [    8.067655] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [    8.127099] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.139113] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Started Network Configuration.
             Starting Network Name Resolution...[    8.216107] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.226852] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    8.266632] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    8.420302] hub 1-1:1.0: USB hub found
    [    8.424382] hub 1-1:1.0: 4 ports detected
    [    8.546701] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    [    8.572038] hub 2-1:1.0: USB hub found
    [    8.575990] hub 2-1:1.0: 4 ports detected
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland…ositor, as a system service...
    [    8.838614] audit: type=1334 audit(12.744:6): prog-id=9 op=LOAD
    [    8.844680] audit: type=1334 audit(12.752:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    NOTICE: This file system contains the following GPL-3.0 packages:
            bash
            cifs-utils
            dosfstools
            gdb
            gdbserver
            glmark2
            grub-common
            grub-editenv
            grub-efi
            less
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm6
            libgmp10
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libreadline8
            libstdc++-dev
            libstdc++6
            parted
            python3-can
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative
            qtpdf-plugins
            qtpdf-qmlplugins
            qtpdf
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquics-plugins.control
            qtquics-qmlplugins.control
            qtquics.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            zeromq-dev
            zeromq
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started User Database Manager.
    [  OK  ] Finished Print notice about GPLv3 packages.
    [  OK  ] Finished Synchronize System and HW clocks.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [    9.316382] audit: type=1006 audit(13.224:8): pid=647 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    9.334802] audit: type=1300 audit(13.224:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffffa48d38 a2=4 a3=ffffbee7b020 items=0 ppid=1 pid=647 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    9.361256] audit: type=1327 audit(13.224:8): proctitle="(systemd)"
    [  OK  ] Started containerd container runtime.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston.
    [    9.842316] audit: type=1006 audit(13.748:9): pid=581 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [   10.033371] PVR_K:  581: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   10.044321] PVR_K:  581: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [  OK  ] Started Weston, a Wayland …mpositor, as a system service.
    [  OK  ] Reached target Graphical Interface.
    [   10.212271] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.218062] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.223640] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.223657] tidss 30200000.dss: tidss_crtc_atomic_check
             Starting Record Runlevel Change in UTMP...[   10.223743] tidss 30200000.dss: tidss_atomic_commit_tail
    [   10.223752] tidss 30200000.dss: tidss_runtime_get
    [   10.223769] tidss 30200000.dss: tidss_plane_atomic_update
    [   10.223782] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, doesn't need modeset, event 00000000f8e98e40
    [   10.228177] tidss 30200000.dss: tidss_runtime_put
    [  OK  ] Finished Record Runlevel Change in UTMP.
    [   10.354828] using random self ethernet address
    [   10.359342] using random host ethernet address
    [   10.410447] using random self ethernet address
    [   10.415265] using random host ethernet address
    [   10.429426] usb0: HOST MAC 02:24:6d:95:c3:7a
    [   10.433883] usb0: MAC 6e:f2:64:36:4f:a5
    [   10.438733] usb1: HOST MAC f6:2a:f2:eb:f8:9c
    [   10.443233] usb1: MAC d2:fc:fa:da:e8:a0
    [   10.482015] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.487588] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.492920] tidss 30200000.dss: tidss_crtc_atomic_check
    [   10.549356] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.554918] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.560311] tidss 30200000.dss: tidss_crtc_atomic_check
    [   10.565657] tidss 30200000.dss: tidss_atomic_commit_tail
    [   10.571282] tidss 30200000.dss: tidss_runtime_get
    [   10.576068] tidss 30200000.dss: tidss_plane_atomic_update
    [   10.581619] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, doesn't need modeset, event 000000007aec5272
    [   10.602756] tidss 30200000.dss: tidss_runtime_put
    [   10.612244] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.618015] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.623358] tidss 30200000.dss: tidss_crtc_atomic_check
    [   10.630290] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.635859] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.641220] tidss 30200000.dss: tidss_crtc_atomic_check
    [   10.646509] tidss 30200000.dss: tidss_atomic_commit_tail
    [   10.651929] tidss 30200000.dss: tidss_runtime_get
    [   10.656702] tidss 30200000.dss: tidss_plane_atomic_update
    [   10.662199] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, doesn't need modeset, event 000000004f3a85bf
    [   10.684219] tidss 30200000.dss: tidss_runtime_put
    [   10.693858] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.699460] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.705205] tidss 30200000.dss: tidss_crtc_atomic_check
    [   10.712426] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.718181] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.723594] tidss 30200000.dss: tidss_crtc_atomic_check
    [   10.728952] tidss 30200000.dss: tidss_atomic_commit_tail
    [   10.734320] tidss 30200000.dss: tidss_runtime_get
    [   10.741217] tidss 30200000.dss: tidss_plane_atomic_update
    [   10.748091] tidss 30200000.dss: tidss_crtc_atomic_flush: crtc-0 is active, doesn't need modeset, event 0000000013bc8feb
    [   10.765696] tidss 30200000.dss: tidss_runtime_put
    [   10.775227] tidss 30200000.dss: tidss_encoder_atomic_check
    [   10.780757] tidss 30200000.dss: tidss_plane_atomic_check
    [   10.786110] tidss 30200000.dss: tidss_crtc_atomic_check
    Here's the current dts:
    // SPDX-License-Identifier: GPL-2.0
     * Device Tree file for the J722S-EVM
     * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/
     * Schematics: https://www.ti.com/lit/zip/sprr495
    /dts-v1/;
    #include <dt-bindings/leds/common.h>
    #include "k3-j722s.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/net/ti-dp83867.h>
    #include <dt-bindings/mux/ti-serdes.h>
    #include <dt-bindings/phy/phy.h>
    	compatible = "ti,j722s-evm", "ti,j722s";
    	model = "Texas Instruments J722S EVM";
    	aliases {
    		serial0 = &wkup_uart0;
    		serial2 = &main_uart0;
    		mmc0 = &sdhci0;
    		mmc1 = &sdhci1;
    		usb0 = &usb0;
    		usb1 = &usb1;
    	chosen {
    		stdout-path = &main_uart0;
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait loglevel=8 init=/sbin/init";
    	memory@80000000 {
    		/* 8G RAM */
    		reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
    		      <0x00000008 0x80000000 0x00000001 0x80000000>;
    		device_type = "memory";
    		bootph-pre-ram;
    	reserved_memory: reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		/* global cma region */
    		linux,cma {
    			compatible = "shared-dma-pool";
    			reusable;
    			size = <0x00 0x38000000>;
    			linux,cma-default;
    		secure_tfa_ddr: tfa@9e780000 {
    			reg = <0x00 0x9e780000 0x00 0x80000>;
    			no-map;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>;
    			no-map;
    		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
    			reg = <0x00 0xa0000000 0x00 0x100000>;
    			no-map;
    		wkup_r5fss0_core0_memory_region: r5f-memory@a0100000 {
    			reg = <0x00 0xa0100000 0x00 0xf00000>;
    			no-map;
    		mcu_r5fss0_core0_dma_memory_region: mcu-r5fss-dma-memory-region@a1000000 {
    			reg = <0x00 0xa1000000 0x00 0x100000>;
    			no-map;
    		mcu_r5fss0_core0_memory_region: mcu-r5fss-memory-region@a1100000 {
    			reg = <0x00 0xa1100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss0_core0_dma_memory_region: main-r5fss-dma-memory-region@a2000000 {
    			reg = <0x00 0xa2000000 0x00 0x100000>;
    			no-map;
    		main_r5fss0_core0_memory_region: main-r5fss-memory-region@a2100000 {
    			reg = <0x00 0xa2100000 0x00 0xf00000>;
    			no-map;
    		c7x_0_dma_memory_region: c7x-dma-memory@a3000000 {
    			reg = <0x00 0xa3000000 0x00 0x100000>;
    			no-map;
    		c7x_0_memory_region: c7x-memory@a3100000 {
    			reg = <0x00 0xa3100000 0x00 0xf00000>;
    			no-map;
    		c7x_1_dma_memory_region: c7x-dma-memory@a4000000 {
    			reg = <0x00 0xa4000000 0x00 0x100000>;
    			no-map;
    		c7x_1_memory_region: c7x-memory@a4100000 {
    			reg = <0x00 0xa4100000 0x00 0xf00000>;
    			no-map;
    		rtos_ipc_memory_region: ipc-memories@a5000000 {
    			reg = <0x00 0xa5000000 0x00 0x1c00000>;
    			alignment = <0x1000>;
    			no-map;
    	vmain_pd: regulator-0 {
    		/* TPS65988 PD CONTROLLER OUTPUT */
    		compatible = "regulator-fixed";
    		regulator-name = "vmain_pd";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-always-on;
    		regulator-boot-on;
    		bootph-all;
    	vsys_5v0: regulator-vsys5v0 {
    		/* Output of LM5140 */
    		regulator-name = "vsys_5v0";
    		vin-supply = <&vmain_pd>;
    		regulator-boot-on;
    	vdd_mmc1: regulator-mmc1 {
    		/* TPS22918DBVR */
    		regulator-name = "vdd_mmc1";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-boot-on;
    		enable-active-high;
    		gpio = <&exp1 15 GPIO_ACTIVE_HIGH>;
    		bootph-all;
    	vdd_sd_dv: regulator-TLV71033 {
    		compatible = "regulator-gpio";
    		regulator-name = "tlv71033";
    		pinctrl-names = "default";
    		pinctrl-0 = <&vdd_sd_dv_pins_default>;
    		regulator-min-microvolt = <1800000>;
    		regulator-boot-on;
    		vin-supply = <&vsys_5v0>;
    		gpios = <&main_gpio0 70 GPIO_ACTIVE_HIGH>;
    		states = <1800000 0x0>,
    			 <3300000 0x1>;
    	vsys_io_1v8: regulator-vsys-io-1v8 {
    		regulator-name = "vsys_io_1v8";
    		regulator-max-microvolt = <1800000>;
    		regulator-boot-on;
    	vsys_io_1v2: regulator-vsys-io-1v2 {
    		regulator-name = "vsys_io_1v2";
    		regulator-min-microvolt = <1200000>;
    		regulator-max-microvolt = <1200000>;
    		regulator-boot-on;
    	leds {
    		compatible = "gpio-leds";
    		pinctrl-0 = <&led_pins_default>;
    		led-0 {
    			label = "j722s-evm:red:heartbeat";
    			gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
    			function = LED_FUNCTION_HEARTBEAT;
    			linux,default-trigger = "heartbeat";
    		led-1 {
    			label = "j722s-evm:green:disk-activity";
    			gpios = <&exp1 16 GPIO_ACTIVE_HIGH>;
    			function = LED_FUNCTION_DISK_ACTIVITY;
    			linux,default-trigger = "mmc1";
    			default-state = "off";
    	panel {
    		compatible = "tianma,tm070rvhg71";
    		port@0 {
    			lcd_in0: endpoint {
    &main_pmx0 {
    	/delete-property/ interrupts;
    	main_i2c0_pins_default: main-i2c0-default-pins {
    		pinctrl-single,pins = <
    			J722S_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (D23) I2C0_SCL */
    			J722S_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (B22) I2C0_SDA */
    		bootph-all;
    	main_i2c1_pins_default: main-i2c1-default-pins {
    			J722S_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (C24) I2C1_SCL */
    			J722S_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A22) I2C1_SDA */
    		bootph-all;
    	main_uart0_pins_default: main-uart0-default-pins {
    			J722S_IOPAD(0x01c8, PIN_INPUT, 0)	/* (F19) UART0_RXD */
    			J722S_IOPAD(0x01cc, PIN_OUTPUT, 0)	/* (F20) UART0_TXD */
    			J722S_IOPAD(0x01d4, PIN_OUTPUT, 0)	/* (B21) UART0_RTSn */
    			J722S_IOPAD(0x01d0, PIN_INPUT, 0)	/* (E22) UART0_CTSn */
    		bootph-all;
    	vdd_sd_dv_pins_default: vdd-sd-dv-default-pins {
    			J722S_IOPAD(0x0120, PIN_INPUT, 7) /* (F27) MMC2_CMD.GPIO0_70 */
    		bootph-all;
    	main_mmc1_pins_default: main-mmc1-default-pins {
    			J722S_IOPAD(0x023c, PIN_INPUT, 0) /* (H22) MMC1_CMD */
    			J722S_IOPAD(0x0234, PIN_OUTPUT, 0) /* (H24) MMC1_CLK */
    			J722S_IOPAD(0x0230, PIN_INPUT, 0) /* (H23) MMC1_DAT0 */
    			J722S_IOPAD(0x022c, PIN_INPUT_PULLUP, 0) /* (H20) MMC1_DAT1 */
    			J722S_IOPAD(0x0228, PIN_INPUT_PULLUP, 0) /* (J23) MMC1_DAT2 */
    			J722S_IOPAD(0x0224, PIN_INPUT_PULLUP, 0) /* (H25) MMC1_DAT3 */
    			J722S_IOPAD(0x0240, PIN_INPUT, 0) /* (B24) MMC1_SDCD */
    		bootph-all;
    	ospi0_pins_default: ospi0-default-pins {
    			J722S_IOPAD(0x0000, PIN_OUTPUT, 0) /* (P23) OSPI0_CLK */
    			J722S_IOPAD(0x002c, PIN_OUTPUT, 0) /* (M25) OSPI0_CSn0 */
    			J722S_IOPAD(0x000c, PIN_INPUT, 0) /* (L25) OSPI0_D0 */
    			J722S_IOPAD(0x0010, PIN_INPUT, 0) /* (N24) OSPI0_D1 */
    			J722S_IOPAD(0x0014, PIN_INPUT, 0) /* (N25) OSPI0_D2 */
    			J722S_IOPAD(0x0018, PIN_INPUT, 0) /* (M24) OSPI0_D3 */
    			J722S_IOPAD(0x001c, PIN_INPUT, 0) /* (N21) OSPI0_D4 */
    			J722S_IOPAD(0x0020, PIN_INPUT, 0) /* (N22) OSPI0_D5 */
    			J722S_IOPAD(0x0024, PIN_INPUT, 0) /* (P21) OSPI0_D6 */
    			J722S_IOPAD(0x0028, PIN_INPUT, 0) /* (N20) OSPI0_D7 */
    			J722S_IOPAD(0x0008, PIN_INPUT, 0) /* (P22) OSPI0_DQS */
    		bootph-all;
    	main_i2c2_pins_default: main-i2c2-default-pins {
    			J722S_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (P22) GPMC0_CSn2.I2C2_SCL */
    			J722S_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (P23) GPMC0_CSn3.I2C2_SDA */
    	mdio_pins_default: mdio-default-pins {
    			J722S_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AC24) MDIO0_MDC */
    			J722S_IOPAD(0x015c, PIN_INPUT, 0) /* (AD25) MDIO0_MDIO */
    	rgmii1_pins_default: rgmii1-default-pins {
    			J722S_IOPAD(0x014c, PIN_INPUT, 0) /* (AC25) RGMII1_RD0 */
    			J722S_IOPAD(0x0150, PIN_INPUT, 0) /* (AD27) RGMII1_RD1 */
    			J722S_IOPAD(0x0154, PIN_INPUT, 0) /* (AE24) RGMII1_RD2 */
    			J722S_IOPAD(0x0158, PIN_INPUT, 0) /* (AE26) RGMII1_RD3 */
    			J722S_IOPAD(0x0148, PIN_INPUT, 0) /* (AE27) RGMII1_RXC */
    			J722S_IOPAD(0x0144, PIN_INPUT, 0) /* (AD23) RGMII1_RX_CTL */
    			J722S_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AF27) RGMII1_TD0 */
    			J722S_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AE23) RGMII1_TD1 */
    			J722S_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AG25) RGMII1_TD2 */
    			J722S_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AF24) RGMII1_TD3 */
    			J722S_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AG26) RGMII1_TXC */
    			J722S_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AF25) RGMII1_TX_CTL */
    	led_pins_default: led-default-pins {
    			J722S_IOPAD(0x0244, PIN_INPUT, 7) /* (A24) MMC1_SDWP */
    	main_usb1_pins_default: main-usb1-default-pins {
    			J722S_IOPAD(0x0258, PIN_INPUT, 0) /* (B27) USB1_DRVVBUS */
    	main_gpio0_ioexp_intr_pins_default: main-gpio0-ioexp-intr-default-pins {
    			J722S_IOPAD(0x0110, PIN_INPUT, 7) /* (G27) MMC2_DAT1.GPIO0_67 */
    	main_dpi_pins_default: main-dpi-default-pins {
    			J722S_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AB23) VOUT0_VSYNC */
    			J722S_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
    			J722S_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC26) VOUT0_PCLK */
    			J722S_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (AC27) VOUT0_DE */
    			J722S_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (W27) VOUT0_DATA0 */
    			J722S_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA1 */
    			J722S_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA2 */
    			J722S_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W23) VOUT0_DATA3 */
    			J722S_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA4 */
    			J722S_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA5 */
    			J722S_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y26) VOUT0_DATA6 */
    			J722S_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (Y27) VOUT0_DATA7 */
    			J722S_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA8 */
    			J722S_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (AA27) VOUT0_DATA9 */
    			J722S_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA10 */
    			J722S_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA11 */
    			J722S_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA12 */
    			J722S_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA22) VOUT0_DATA13 */
    			J722S_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (AB26) VOUT0_DATA14 */
    			J722S_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AB27) VOUT0_DATA15 */
    			J722S_IOPAD(0x005c, PIN_OUTPUT, 1) /* (U27) GPMC0_AD8.VOUT0_DATA16 */
    			J722S_IOPAD(0x0060, PIN_OUTPUT, 1) /* (U26) GPMC0_AD9.VOUT0_DATA17 */
    			J722S_IOPAD(0x0064, PIN_OUTPUT, 1) /* (V27) GPMC0_AD10.VOUT0_DATA18 */
    			J722S_IOPAD(0x0068, PIN_OUTPUT, 1) /* (V25) GPMC0_AD11.VOUT0_DATA19 */
    			J722S_IOPAD(0x006c, PIN_OUTPUT, 1) /* (V26) GPMC0_AD12.VOUT0_DATA20 */
    			J722S_IOPAD(0x0070, PIN_OUTPUT, 1) /* (V24) GPMC0_AD13.VOUT0_DATA21 */
    			J722S_IOPAD(0x0074, PIN_OUTPUT, 1) /* (V22) GPMC0_AD14.VOUT0_DATA22 */
    			J722S_IOPAD(0x0078, PIN_OUTPUT, 1) /* (V23) GPMC0_AD15.VOUT0_DATA23 */
    			J722S_IOPAD(0x009c, PIN_OUTPUT, 1) /* (W26) GPMC0_WAIT1.VOUT0_EXTPCLKIN */
    &main_gpio1 {
    	status = "okay";
    &main_uart0 {
    	pinctrl-0 = <&main_uart0_pins_default>;
    	status = "okay";
    	bootph-all;
    &mcu_pmx0 {
    	wkup_uart0_pins_default: wkup-uart0-default-pins {
    			J722S_MCU_IOPAD(0x02c, PIN_INPUT, 0)	/* (C7) WKUP_UART0_CTSn */
    			J722S_MCU_IOPAD(0x030, PIN_OUTPUT, 0)	/* (C6) WKUP_UART0_RTSn */
    			J722S_MCU_IOPAD(0x024, PIN_INPUT, 0)	/* (D8) WKUP_UART0_RXD */
    			J722S_MCU_IOPAD(0x028, PIN_OUTPUT, 0)	/* (D7) WKUP_UART0_TXD */
    		bootph-all;
    	wkup_i2c0_pins_default: wkup-i2c0-default-pins {
    			J722S_MCU_IOPAD(0x04c, PIN_INPUT_PULLUP, 0)	/* (C7) WKUP_I2C0_SCL */
    			J722S_MCU_IOPAD(0x050, PIN_INPUT_PULLUP, 0)	/* (C6) WKUP_I2C1_SDA */
    		bootph-all;
    &wkup_uart0 {
    	/* WKUP UART0 is used by DM firmware */
    	pinctrl-0 = <&wkup_uart0_pins_default>;
    	status = "reserved";
    	bootph-all;
    &wkup_i2c0 {
    	status = "okay";
    	pinctrl-0 = <&wkup_i2c0_pins_default>;
    	clock-frequency = <400000>;
    	bootph-all;
    &main_i2c0 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c0_pins_default>;
    	bootph-all;
    	exp1: gpio@23 {
    		compatible = "ti,tca6424";
    		reg = <0x23>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "TRC_MUX_SEL", "OSPI/ONAND_MUX_SEL",
    				  "MCASP1_FET_SEL", "CTRL_PM_I2C_OE#",
    				  "CSI_VIO_SEL", "USB2.0_MUX_SEL",
    				  "CSI01_MUX_SEL_2", "CSI23_MUX_SEL_2",
    				  "LMK1_OE1", "LMK1_OE0",
    				  "LMK2_OE0", "LMK2_OE1",
    				  "GPIO_RGMII1_RST#", "GPIO_AUD_RSTn",
    				  "GPIO_eMMC_RSTn", "GPIO_uSD_PWR_EN",
    				  "USER_LED2", "MCAN0_STB",
    				  "PCIe0_1L_RC_RSTz", "PCIe0_1L_PRSNT#",
    				  "ENET1_EXP_SPARE2", "ENET1_EXP_PWRDN",
    				  "PD_I2ENET1_I2CMUX_SELC_IRQ", "ENET1_EXP_RESETZ";
    		p01-hog {
    			/* P01 - TRC_MUX_SEL */
    			gpio-hog;
    			gpios = <0 GPIO_ACTIVE_HIGH>;
    			output-low;
    			line-name = "TRC_MUX_SEL";
    &main_i2c2 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c2_pins_default>;
    	pca9543_0: i2c-mux@70 {
    		compatible = "nxp,pca9543";
    		#address-cells = <1>;
    		#size-cells = <0>;
    		reg = <0x70>;
    	pca9543_1: i2c-mux@71 {
    		#size-cells = <0>;
    		reg = <0x71>;
    &main_i2c1 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c1_pins_default>;
    	clock-frequency = <100000>;
    	exp2: gpio@20 {
    		compatible = "ti,tca6416";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "DSI_Mux_SEL_2", "GPIO_eDP_ENABLE",
    				  "DP0_PWR_SW_EN", "GPIO_OLDI_RSTn",
    				  "GPIO_HDMI_RSTn", "HDMI_LS_OE",
    				  "DSI_GPIO0", "DSI_GPIO1",
    				  "DSI_EDID", "IO_eDP_IRQ",
    				  "OLDI_INT#", "HDMI_INTn",
    		interrupt-parent = <&main_gpio0>;
    		interrupts = <67 IRQ_TYPE_EDGE_FALLING>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		pinctrl-0 = <&main_gpio0_ioexp_intr_pins_default>;
    		bootph-all;
    		p04-hog {
    			/* P04 - GPIO_HDMI_RSTn */
    			gpio-hog;
    			gpios = <4 GPIO_ACTIVE_LOW>;
    			output-low;
    			line-name = "GPIO_HDMI_RSTn";
    		p03-hog {
    			/* P03 - GPIO_OLDI_RSTn */
    			gpio-hog;
    			gpios = <3 GPIO_ACTIVE_LOW>;
    			output-low;
    			line-name = "GPIO_OLDI_RSTn";
    		p05-hog {
    			/* P05 - HDMI_LS_OE */
    			gpio-hog;
    			gpios = <5 GPIO_ACTIVE_HIGH>;
    			output-high;
    			line-name = "HDMI_LS_OE";
    &sdhci0 {
    	/*eMMC*/
    	status = "okay";
    	ti,driver-strength-ohm = <50>;
    	disable-wp;
    	bootph-all;
    &sdhci1 {
    	/* SD/MMC */
    	status = "okay";
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vdd_sd_dv>;
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    	bootph-all;
    &ospi0 {
    	status = "okay";
    	pinctrl-0 = <&ospi0_pins_default>;
    	bootph-all;
    	flash@0{
    		compatible = "jedec,spi-nor";
    		reg = <0x0>;
    		spi-tx-bus-width = <8>;
    		spi-rx-bus-width = <8>;
    		spi-max-frequency = <25000000>;
    		cdns,tshsl-ns = <60>;
    		cdns,tsd2d-ns = <60>;
    		cdns,tchsh-ns = <60>;
    		cdns,tslch-ns = <60>;
    		cdns,read-delay = <4>;
    		bootph-all;
    		partitions {
    			compatible = "fixed-partitions";
    			#size-cells = <1>;
    			bootph-all;
    			partition@0 {
    				label = "ospi.tiboot3";
    				reg = <0x00 0x80000>;
    			partition@80000 {
    				label = "ospi.tispl";
    				reg = <0x80000 0x200000>;
    			partition@280000 {
    				label = "ospi.u-boot";
    				reg = <0x280000 0x400000>;
    			partition@680000 {
    				label = "ospi.env";
    				reg = <0x680000 0x40000>;
    			partition@6c0000 {
    				label = "ospi.env.backup";
    				reg = <0x6c0000 0x40000>;
    			partition@800000 {
    				label = "ospi.rootfs";
    				reg = <0x800000 0x37c0000>;
    			partition@3fc0000 {
    				label = "ospi.phypattern";
    				reg = <0x3fc0000 0x40000>;
    				bootph-all;
    	ospi0_nand: nand@0 {
    		compatible = "spi-nand";
    		reg = <0x0>;
    		cdns,read-delay = <2>;
    		#size-cells = <1>;
    		status = "disabled";
    		partitions {
    			#size-cells = <1>;
    			partition@0 {
    				label = "ospi_nand.tiboot3";
    				reg = <0x0 0x80000>;
    			partition@80000 {
    				label = "ospi_nand.tispl";
    			partition@280000 {
    				label = "ospi_nand.u-boot";
    			partition@680000 {
    				label = "ospi_nand.env";
    			partition@6c0000 {
    				label = "ospi_nand.env.backup";
    			partition@2000000 {
    				label = "ospi_nand.rootfs";
    				reg = <0x2000000 0x5fc0000>;
    			partition@7fc0000 {
    				label = "ospi_nand.phypattern";
    				reg = <0x7fc0000 0x40000>;
    &cpsw3g {
    	status = "okay";
    	pinctrl-0 = <&rgmii1_pins_default>;
    &cpsw3g_mdio {
    	status = "okay";
    	pinctrl-0 = <&mdio_pins_default>;
    	cpsw3g_phy0: ethernet-phy@0 {
    		reg = <0>;
    		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
    		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
    		ti,min-output-impedance;
    &cpsw_port1 {
    	phy-mode = "rgmii-rxid";
    	phy-handle = <&cpsw3g_phy0>;
    &cpsw_port2 {
    &mailbox0_cluster0 {
    	status = "okay";
    	mbox_r5_0: mbox-r5-0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    &mailbox0_cluster1 {
    	status = "okay";
    	mbox_mcu_r5_0: mbox-mcu-r5-0 {
    &mailbox0_cluster2 {
    	status = "okay";
    	mbox_c7x_0: mbox-c7x-0 {
    &mailbox0_cluster3 {
    	status = "okay";
    	mbox_main_r5_0: mbox-main-r5-0 {
    	mbox_c7x_1: mbox-c7x-1 {
    		ti,mbox-rx = <2 0 0>;
    		ti,mbox-tx = <3 0 0>;
    &wkup_r5fss0 {
    	status = "okay";
    &wkup_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
    	memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
    			<&wkup_r5fss0_core0_memory_region>;
    &mcu_r5fss0 {
    	status = "okay";
    &mcu_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster1 &mbox_mcu_r5_0>;
    	memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
    			<&mcu_r5fss0_core0_memory_region>;
    &main_r5fss0 {
    	status = "okay";
    &main_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster3 &mbox_main_r5_0>;
    	memory-region = <&main_r5fss0_core0_dma_memory_region>,
    			<&main_r5fss0_core0_memory_region>;
    &c7x_0 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster2 &mbox_c7x_0>;
    	memory-region = <&c7x_0_dma_memory_region>,
    			<&c7x_0_memory_region>;
    &c7x_1 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster3 &mbox_c7x_1>;
    	memory-region = <&c7x_1_dma_memory_region>,
    			<&c7x_1_memory_region>;
    &serdes_ln_ctrl {
    	idle-states = <J722S_SERDES0_LANE0_USB>,
    		      <J722S_SERDES1_LANE0_PCIE0_LANE0>;
    &serdes0 {
    	status = "okay";
    	serdes0_usb_link: phy@0 {
    		reg = <0>;
    		cdns,num-lanes = <1>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_USB3>;
    		resets = <&serdes_wiz0 1>;
    &serdes1 {
    	serdes1_pcie_link: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_PCIE>;
    		resets = <&serdes_wiz1 1>;
    &usbss0 {
    	status = "okay";
    	ti,vbus-divider;
    &usb0 {
    	dr_mode = "otg";
    	usb-role-switch;
    &usbss1 {
    	status = "okay";
    	pinctrl-0 = <&main_usb1_pins_default>;
    	ti,vbus-divider;
    &usb1 {
    	dr_mode = "host";
    	maximum-speed = "super-speed";
    	phys = <&serdes0_usb_link>;
    	phy-names = "cdns3,usb3-phy";
    &pcie0_rc {
    	status = "okay";
    	reset-gpios = <&exp1 18 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes1_pcie_link>;
    	phy-names = "pcie-phy";
    &dss0 {
    	status = "okay";
    &dss0_ports {
    	#size-cells = <0>;
    	/* VP1: LVDS Output (OLDI TX 0) */
    	port@0 {
    		reg = <0>;
    		oldi_out0: endpoint {
    			remote-endpoint = <&lcd_in0>;
    I can grab more driver logs if you can think of something I should capture.
    The reboot failure happens even if I don't have an LVDS display attached and use the dual LVDS configuration.
  • Hi Evan,
    Most common issue for reboot is power supply issues (aka, using a power supply that has a little too less wattage). If not using a 60W USB-C power supply, could you try to obtain one and use that? EVM userguide has some recommendation for power supplies if you ctrl+f in it: https://www.ti.com/lit/ug/sprujb5/sprujb5.pdf.
    We should fix the reboot issue first, since that will make the debug a bit more complicated for display.
    On the other hand, for display, I think power-supply property is needed (even though dual LVDS display node does not have it). I say this because the panel-simple devicetree bindings used by tianma calls out that "compatible" and "power-supply" are necessary properties (details here: https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel/tree/Documentation/devicetree/bindings/display/panel/panel-simple.yaml?h=ti-linux-6.1.y
    If you have a data sheet on hand for the tianma display, it would also be good to check if there is a backlight or enable-gpio pin that needs to be triggered.
    Takuma
  • Hi Takuma,
    Yes, the issue was with the power supply.
    Thanks!
  • Hi Evan,
    Awesome to hear we fixed the reboot issue!
    Display is still an issue, correct? Or did the power supply change also fix it?
    Takuma
  • Hi Takuma,
    I need to update the timings to correct the image, but I think it's an issue I will be able to solve.
    My main problem was the reboot issue.
  • Hi Evan,
    Alright, sounds good. Let us know on this E2E if you need help, or if you are able to resolve.
    Takuma
  • Hi Takuma,
    I updated the timings and it's working now.
    Thanks again!
  • Hi Evan,
    Glad to hear that you were able to get it working!
    Takuma
