J7200XSOMXEVM: Auto reboot issue
Part Number: J7200XSOMXEVM
Other Parts Discussed in Thread: SK-TDA4VM, TDA4VM
Hi team,
We are enaging our DRAM product on J7 series platform, but we met some problem.
We found 2 EVM, J7200 and SK-TDA4VM will auto reboot after idle for a while.
This is based on default WIC image and Micron chip, and without error log related to auto reboot.
We've also tried to cool down the SoC but no improvement.
What should we do next?
Thanks.
Maurice
  • Hi Maurice,
    Couple of requests:
    • Please share the logs as a text file attachment.
    • Which SDK version are you using?
    • How long does it take before the reboot happens?
    • How about other EVMs? Are they working without any reboot issues?
    Keerthy
  • Hi Keerthy,
      I am unable to upload files from our site, can I send logs through the mail directly?
      SDK version 9.2.0.5, but the original image in SD card can also duplicate.
      Within 30mins when idle, 2-10 mins when running memtester.
      J721S2 EVM is fine, no reboot issue.
      Thanks a lot,
      Maurice
  • I am unable to upload files from our site, can I send logs through the mail directly?
    You can paste the logs here if text file attachment is not possible.
    - Keerthy
  • J7200
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.09.30 16:13:31 =~=~=~=~=~=~=~=~=~=~=~=
    U-Boot SPL 2021.01-g15769936a5 (Dec 21 2021 - 15:57:07 +0000)
    Model: Texas Instruments K3 J7200 SoC
    Board: J7200X-PM2-SOM rev E8
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 15:41:50, Dec 21 2021
    U-Boot SPL 2021.01-g15769936a5 (Dec 21 2021 - 15:43:01 +0000)
    Detected: J7X-BASE-CPB rev A
    Detected: J7X-VSC8514-ETH rev E2
    am654_sdhci sdhci@4fb0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
    U-Boot 2021.01-g15769936a5 (Dec 21 2021 - 15:43:01 +0000)
    SoC:   J7200 SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    eth0: ethernet@46000000
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    0 bytes read in 0 ms
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    19270144 bytes read in 202 ms (91 MiB/s)
    46143 bytes read in 3 ms (14.7 MiB/s)
       Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.65-gdcc6bedb2c (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Dec 21 15:45:03 UTC 2021
    [    0.000000] Machine model: Texas Instruments K3 J7200 SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@a5200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
    [    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000a4ffffff]
    [    0.000000]   node   0: [mem 0x00000000a5000000-0x00000000a6ffffff]
    [    0.000000]   node   0: [mem 0x00000000a7000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:1m(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=96d5e2f2-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3441792K/4194304K available (10880K kernel code, 1346K rwdata, 4288K rodata, 1856K init, 757K bss, 228224K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008291] Console: colour dummy device 80x25
    [    0.012854] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023527] pid_max: default: 32768 minimum: 301
    [    0.028274] LSM: Security Framework initializing
    [    0.033027] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040600] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.050171] rcu: Hierarchical SRCU implementation.
    [    0.055348] Platform MSI: msi-controller@1820000 domain created
    [    0.061531] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070819] EFI services will not be available.
    [    0.075657] smp: Bringing up secondary CPUs ...
    [    0.081059] Detected PIPT I-cache on CPU1
    [    0.081083] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.081097] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.081135] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.081220] smp: Brought up 1 node, 2 CPUs
    [    0.110582] SMP: Total of 2 processors activated.
    [    0.115390] CPU features: detected: 32-bit EL0 Support
    [    0.120648] CPU features: detected: CRC32 instructions
    [    0.134253] CPU: All CPU(s) started at EL2
    [    0.138460] alternatives: patching kernel code
    [    0.143623] devtmpfs: initialized
    [    0.149861] KASLR disabled due to lack of seed
    [    0.154599] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.164573] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.172431] pinctrl core: initialized pinctrl subsystem
    [    0.178081] DMI not present or invalid.
    [    0.182390] NET: Registered protocol family 16
    [    0.190423] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197804] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205858] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214231] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214234] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220614] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.234282] ASID allocator initialised with 65536 entries
    [    0.250971] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.257833] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.264593] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.274111] cryptd: max_cpu_qlen set to 1000
    [    0.281604] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR1.0 JTAGID[0x0bb6d02f] Detected
    [    0.290482] vsys_3v3: supplied by evm_12v0
    [    0.294971] vsys_5v0: supplied by evm_12v0
    [    0.299764] iommu: Default domain type: Translated
    [    0.304930] SCSI subsystem initialized
    [    0.309115] mc: Linux media interface: v0.10
    [    0.313511] videodev: Linux video capture interface: v2.00
    [    0.319157] pps_core: LinuxPPS API ver. 1 registered
    [    0.324230] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.333571] PTP clock support registered
    [    0.337594] EDAC MC: Ver: 3.0.0
    [    0.341513] FPGA manager framework
    [    0.345059] Advanced Linux Sound Architecture Driver Initialized.
    [    0.351830] clocksource: Switched to clocksource arch_sys_counter
    [    0.358288] VFS: Disk quotas dquot_6.6.0
    [    0.362392] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.372683] NET: Registered protocol family 2
    [    0.377451] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.386335] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.395151] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.403368] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.411348] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.418196] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.425104] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.432546] NET: Registered protocol family 1
    [    0.437451] RPC: Registered named UNIX socket transport module.
    [    0.443529] RPC: Registered udp transport module.
    [    0.448353] RPC: Registered tcp transport module.
    [    0.453160] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.459745] PCI: CLS 0 bytes, default 64
    [    0.464141] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.476004] Initialise system trusted keyrings
    [    0.480688] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.489220] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.495575] NFS: Registering the id_resolver key type
    [    0.500769] Key type id_resolver registered
    [    0.505048] Key type id_legacy registered
    [    0.509212] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.516065] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.523746] 9p: Installing v9fs 9p2000 file system support
    [    0.548554] Key type asymmetric registered
    [    0.552754] Asymmetric key parser 'x509' registered
    [    0.557768] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.565328] io scheduler mq-deadline registered
    [    0.569954] io scheduler kyber registered
    [    0.575142] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.581360] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.589613] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.595922] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.604101] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.618419] brd: module loaded
    [    0.626084] loop: module loaded
    [    0.629729] megasas: 07.714.04.00-rc1
    [    0.634750] libphy: Fixed MDIO Bus: probed
    [    0.639448] tun: Universal TUN/TAP device driver, 1.6
    [    0.644904] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.651325] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.657408] sky2: driver version 1.30
    [    0.661741] VFIO - User Level meta-driver version: 0.3
    [    0.667522] i2c /dev entries driver
    [    0.671659] sdhci: Secure Digital Host Controller Interface driver
    [    0.677998] sdhci: Copyright(c) Pierre Ossman
    [    0.682750] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.689065] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.695433] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.702677] optee: probing for conduit method.
    [    0.707250] optee: revision 3.12 (3d47a131)
    [    0.707590] optee: initialized driver
    [    0.716975] NET: Registered protocol family 17
    [    0.721608] 9pnet: Installing 9P2000 support
    [    0.726014] Key type dns_resolver registered
    [    0.730465] Loading compiled-in X.509 certificates
    [    0.740487] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.746885] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.754767] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.779694] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.786033] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.792342] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.798805] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.805654] pca953x 3-0021: using no AI
    [    0.832391] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.839227] pca953x 3-0020: using no AI
    [    0.843878] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.850703] pca953x 3-0022: using AI
    [    0.854791] random: fast init done
    [    0.858561] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.865010] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    0.871873] pca953x 4-0020: using no AI
    [    0.896232] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.902478] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    [    0.908717] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.914930] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.921153] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    0.927361] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
    [    0.933599] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.943617] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.952449] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [    0.962490] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    0.972334] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.980022] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.988303] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.996581] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.016113] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
    [    2.022545] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    2.028155] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
    [    2.037845] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.044898] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
    [    2.051141] pci 0000:00:00.0: supports D1
    [    2.055237] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.061965] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.070911] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.077688] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.083022] pcieport 0000:00:00.0: PME: Signaling with IRQ 36
    [    2.090163] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    2.100077] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    2.106843] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.116637] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    2.126796] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    2.133557] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.141619] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    2.151255] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    2.160016] printk: console [ttyS2] enabled
    [    2.168455] printk: bootconsole [ns16550a0] disabled
    [    2.179147] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    2.355838] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    2.363321] libphy: 46000f00.mdio: probed
    [    2.392489] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.400822] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.416205] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.425744] mmc1: CQHCI version 5.10
    [    2.433394] vdd_mmc1: supplied by vsys_3v3
    [    2.438440] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
    [    2.445382] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
    [    2.452585] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    2.462588] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
    [    2.466500] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.474912] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.483666] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.490338] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.495840] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    2.502234] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    2.508453] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    2.514773] 0x000000700000-0x000000740000 : "ospi.env"
    [    2.520551] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    2.527000] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.533091] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.598952] mmc1: Command Queue Engine enabled
    [    2.603411] mmc1: new HS400 MMC card at address 0001
    [    2.608791] mmcblk1: mmc1:0001 G1M15L 29.6 GiB
    [    2.613535] mmcblk1boot0: mmc1:0001 G1M15L partition 1 31.5 MiB
    [    2.619661] mmcblk1boot1: mmc1:0001 G1M15L partition 2 31.5 MiB
    [    2.625749] mmcblk1rpmb: mmc1:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    2.707853] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    2.715340] libphy: 46000f00.mdio: probed
    [    2.743878] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.752213] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.765752] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.772808] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.780028] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.786462] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    2.796851] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.797138] mmc0: CQHCI version 5.10
    [    2.810486] ALSA device list:
    [    2.813461]   No soundcards found.
    [    2.847766] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.855671] Waiting for root device PARTUUID=96d5e2f2-02...
    [    2.907453] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.914519] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    [    2.924164]  mmcblk0: p1 p2
    [    3.022815] EXT4-fs (mmcblk0p2): recovery complete
    [    3.028532] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.036655] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.048366] devtmpfs: mounted
    [    3.052554] Freeing unused kernel memory: 1856K
    [    3.057131] Run /sbin/init as init process
    [    3.164719] systemd[1]: System time before build time, advancing clock.
    [    3.207242] NET: Registered protocol family 10
    [    3.212280] Segment Routing with IPv6
    [    3.230322] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.252237] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    3.294532] systemd[1]: Set hostname to <j7200-evm>.
    [    3.491088] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    3.572138] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.578876] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.591218] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.601709] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.623952] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.631539] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.651951] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.659519] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    3.680943] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.704130] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.728076] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.752030] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.771957] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.791955] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.811955] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.838503] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.859984] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.884319] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.908123] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.940491] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.948956] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.972355] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.988356] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.012297] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.032153] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.055667] systemd[1]: Mounting Huge Pages File System...
    [    4.075787] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.103779] systemd[1]: Mounting Kernel Debug File System...
    [    4.130274] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.152208] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    4.186397] systemd[1]: Starting RPC Bind...
    [    4.204038] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.217579] systemd[1]: Starting Journal Service...
    [    4.247680] systemd[1]: Starting Load Kernel Modules...
    [    4.268348] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.290499] cryptodev: loading out-of-tree module taints kernel.
    [    4.297263] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.300225] systemd[1]: Starting udev Coldplug all Devices...
    [    4.309588] cryptodev: driver 1.10 loaded.
    [    4.331397] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.344396] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev[0[    4.541056] systemd-journald[157]: Received client request to flush runtime journal.
    m...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    5.374289] ti-udma 285c0000.dma-controller: chan1: is running!
    [    5.518524] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.639140] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.671722] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    5.768023] remoteproc remoteproc0: 41000000.r5f is available
    [    5.841102] remoteproc remoteproc0: attaching to 41000000.r5f
    [    5.916079] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    6.025241]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    6.187610] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.207888] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.215470] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.310550]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    6.390891] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [    6.416583] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    6.478515] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    6.589855] remoteproc remoteproc1: 5c00000.r5f is available
    [    6.706798] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    6.715095] remoteproc remoteproc1: powering up 5c00000.r5f
    [    6.720706] remoteproc remoteproc1: Booting fw image j7200-main-r5f0_0-fw, size 634196
    [    6.735070]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    6.747009] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.756010]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    6.762143] remoteproc remoteproc1: remote processor 5c00000.r5f is now up
    [    6.881684] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e
    [    6.891736] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
    [    6.900111] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    6.908767] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 3
    [    6.919683] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
    [    6.933883] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 3
    [    6.950375] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
    [    6.963298] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:84 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [    6.991636] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac loaded
    [    7.000851] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:84 tx_psil_dst_id:4A00 mac_only:0
    [    7.014098] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [    7.028062] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:85 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [    7.046053] remoteproc remoteproc2: 5d00000.r5f is available
    [    7.056647] remoteproc remoteproc2: powering up 5d00000.r5f
    [    7.062838] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 83148
    [    7.070936] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [    7.082114] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:85 tx_psil_dst_id:4A01 mac_only:1
    [    7.096806]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    7.107967] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [    7.122191] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.129556]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    7.139598] remoteproc remoteproc2: remote processor 5d00000.r5f is now up
    [    7.180505] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.191958] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    7.611857] random: crng init done
    [    7.615259] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    7.797869] usbcore: registered new interface driver usbfs
    [    7.807658] usbcore: registered new interface driver hub
    [    7.839154] omap_rng 40910000.rng: Random Number Generator ver. 241b34c
    [    7.854424] usbcore: registered new device driver usb
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting System Logger Daemon "default" instance...
             Starting Login Service...
             Starting telnetd.service...
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [  OK  ] Started telnetd.service.
             Starting syslog.service...
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [    8.933740] Bluetooth: Core ver 2.22
    [    8.940688] NET: Registered protocol family 31
    [    8.948693] Bluetooth: HCI device and connection manager initialized
    [    8.962467] Bluetooth: HCI socket layer initialized
    [    8.968820] Bluetooth: L2CAP socket layer initialized
    [    8.978418] Bluetooth: SCO socket layer initialized
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [    9.156128] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [    9.205601] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac started
    [  OK  ] Started syslog.service.
    [  OK  ] Started Login Service.
    [    9.571299] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [    9.678749] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Vsftpd ftp daemon.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	gstreamer1.0-libav-dev
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline8
    	libunistring-dev
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	python3-rfc3987
    	python3-strict-rfc3339
    	tar
    	which
    	zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7200-evm ttyS2
    Arago 2021.09 j7200-evm ttyS2
    j7200-evm login:
    j7200-evm login:
    j7200-evm login: root
    78root@j7200-evm:~# memtester 100M
    memtester version 4.3.0 (64-bit)
    Copyright (C) 2001-2012 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 65536
    pagesizemask is 0xffffffffffff0000
    want 100MB (104857600 bytes)
    got  100MB (104857600 bytes), trying mlock ...locked.
    Loop 1:
      Stuck Address       :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15           ok
      Random Value        :  \|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/- ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Sequential Increment: ok
      Solid Bits          :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63           ok
      Block Sequential    :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127setting 128testing 128setting 129testing 129setting 130testing 130setting 131testing 131setting 132testing 132setting 133testing 133setting 134testing 134setting 135testing 135setting 136testing 136setting 137testing 137setting 138testing 138setting 139testing 139setting 140testing 140setting 141testing 141setting 142testing 142setting 143testing 143setting 144testing 144setting 145testing 145setting 146testing 146setting 147testing 147setting 148testing 148setting 149testing 149setting 150testing 150setting 151testing 151setting 152testing 152setting 153testing 153setting 154testing 154setting 155testing 155setting 156testing 156setting 157testing 157setting 158testing 158setting 159testing 159setting 160testing 160setting 161testing 161setting 162testing 162setting 163testing 163setting 164testing 164setting 165testing 165setting 166testing 166setting 167testing 167setting 168testing 168setting 169testing 169setting 170testing 170setting 171testing 171setting 172testing 172setting 173testing 173setting 174testing 174setting 175testing 175setting 176testing 176setting 177testing 177setting 178testing 178setting 179testing 179setting 180testing 180setting 181testing 181setting 182testing 182setting 183testing 183setting 184testing 184setting 185testing 185setting 186testing 186setting 187testing 187setting 188testing 188setting 189testing 189setting 190testing 190setting 191testing 191setting 192testing 192setting 193testing 193setting 194testing 194setting 195testing 195setting 196testing 196setting 197testing 197setting 198testing 198setting 199testing 199setting 200testing 200setting 201testing 201setting 202testing 202setting 203testing 203setting 204testing 204setting 205testing 205setting 206testing 206setting 207testing 207setting 208testing 208setting 209testing 209setting 210testing 210setting 211testing 211setting 212testing 212setting 213testing 213setting 214testing 214setting 215testing 215setting 216testing 216setting 217testing 217setting 218testing 218setting 219testing 219setting 220testing 220setting 221testing 221setting 222testing 222setting 223testing 223setting 224testing 224setting 225testing 225setting 226testing 226setting 227testing 227setting 228testing 228setting 229testing 229setting 230testing 230setting 231testing 231setting 232testing 232setting 233testing 233setting 234testing 234setting 235testing 235setting 236testing 236setting 237testing 237setting 238testing 238setting 239testing 239setting 240testing 240setting 241testing 241setting 242testing 242setting 243testing 243setting 244testing 244setting 245testing 245setting 246testing 246setting 247testing 247setting 248testing 248setting 249testing 249setting 250testing 250setting 251testing 251setting 252testing 252setting 253testing 253setting 254testing 254setting 255testing 255           ok
      Checkerboard        :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63           ok
      Bit Spread          :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127           ok
      Bit Flip            :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127setting 128testing 128setting 129testing 129setting 130testing 130setting 131testing 131setting 132testing 132setting 133testing 133setting 134testing 134setting 135testing 135setting 136testing 136setting 137testing 137setting 138testing 138setting 139testing 139setting 140testing 140setting 141testing 141setting 142testing 142setting 143testing 143setting 144testing 144setting 145testing 145setting 146testing 146setting 147testing 147setting 148testing 148setting 149testing 149setting 150testing 150setting 151testing 151setting 152testing 152setting 153testing 153setting 154testing 154setting 155testing 155setting 156testing 156setting 157testing 157setting 158testing 158setting 159testing 159setting 160testing 160setting 161testing 161setting 162testing 162setting 163testing 163setting 164testing 164setting 165testing 165setting 166testing 166setting 167testing 167setting 168testing 168setting 169testing 169setting 170testing 170setting 171testing 171setting 172testing 172setting 173testing 173setting 174testing 174setting 175testing 175setting 176testing 176setting 177testing 177setting 178testing 178setting 179testing 179setting 180testing 180setting 181testing 181setting 182testing 182setting 183testing 183setting 184testing 184setting 185testing 185setting 186testing 186setting 187testing 187setting 188testing 188setting 189testing 189setting 190testing 190setting 191testing 191setting 192testing 192setting 193testing 193setting 194testing 194setting 195testing 195setting 196testing 196setting 197testing 197setting 198testing 198setting 199testing 199setting 200testing 200setting 201testing 201setting 202testing 202setting 203testing 203setting 204testing 204setting 205testing 205setting 206testing 206setting 207testing 207setting 208testing 208setting 209testing 209setting 210testing 210setting 211testing 211setting 212testing 212setting 213testing 213setting 214testing 214setting 215testing 215setting 216testing 216setting 217testing 217setting 218testing 218setting 219testing 219setting 220testing 220setting 221testing 221setting 222testing 222setting 223testing 223setting 224testing 224setting 225testing 225setting 226testing 226setting 227testing 227setting 228testing 228setting 229testing 229setting 230testing 230setting 231testing 231setting 232testing 232setting 233testing 233setting 234testing 234setting 235testing 235setting 236testing 236setting 237testing 237setting 238testing 238setting 239testing 239setting 240testing 240setting 241testing 241setting 242testing 242setting 243testing 243setting 244testing 244setting 245testing 245setting 246testing 246setting 247testing 247setting 248testing 248setting 249testing 249setting 250testing 250setting 251testing 251setting 252testing 252setting 253testing 253setting 254testing 254setting 255testing 255setting 256testing 256setting 257testing 257setting 258testing 258setting 259testing 259setting 260testing 260setting 261testing 261setting 262testing 262setting 263testing 263setting 264testing 264setting 265testing 265setting 266testing 266setting 267testing 267setting 268testing 268setting 269testing 269setting 270testing 270setting 271testing 271setting 272testing 272setting 273testing 273setting 274testing 274setting 275testing 275setting 276testing 276setting 277testing 277setting 278testing 278setting 279testing 279setting 280testing 280setting 281testing 281setting 282testing 282setting 283testing 283setting 284testing 284setting 285testing 285setting 286testing 286setting 287testing 287setting 288testing 288setting 289testing 289setting 290testing 290setting 291testing 291setting 292testing 292setting 293testing 293setting 294testing 294setting 295testing 295setting 296testing 296setting 297testing 297setting 298testing 298setting 299testing 299setting 300testing 300setting 301testing 301setting 302testing 302setting 303testing 303setting 304testing 304setting 305testing 305setting 306testing 306setting 307testing 307setting 308testing 308setting 309testing 309setting 310testing 310setting 311testing 311setting 312testing 312setting 313testing 313setting 314testing 314setting 315testing 315setting 316testing 316setting 317testing 317setting 318testing 318setting 319testing 319setting 320testing 320setting 321testing 321setting 322testing 322setting 323testing 323setting 324testing 324setting 325testing 325setting 326testing 326setting 327testing 327setting 328testing 328setting 329testing 329setting 330testing 330setting 331testing 331setting 332testing 332setting 333testing 333setting 334testing 334setting 335testing 335setting 336testing 336setting 337testing 337setting 338testing 338setting 339testing 339setting 340testing 340setting 341testing 341setting 342testing 342setting 343testing 343setting 344testing 344setting 345testing 345setting 346testing 346setting 347testing 347setting 348testing 348setting 349testing 349setting 350testing 350setting 351testing 351setting 352testing 352setting 353testing 353setting 354testing 354setting 355testing 355setting 356testing 356setting 357testing 357setting 358testing 358setting 359testing 359setting 360testing 360setting 361testing 361setting 362testing 362setting 363testing 363setting 364testing 364setting 365testing 365setting 366testing 366setting 367testing 367setting 368testing 368setting 369testing 369setting 370testing 370setting 371testing 371setting 372testing 372setting 373testing 373setting 374testing 374setting 375testing 375setting 376testing 376setting 377testing 377setting 378testing 378setting 379testing 379setting 380testing 380setting 381testing 381setting 382testing 382setting 383testing 383setting 384testing 384setting 385testing 385setting 386testing 386setting 387testing 387setting 388testing 388setting 389testing 389setting 390testing 390setting 391testing 391setting 392testing 392setting 393testing 393setting 394testing 394setting 395testing 395setting 396testing 396setting 397testing 397setting 398testing 398setting 399testing 399setting 400testing 400setting 401testing 401setting 402testing 402setting 403testing 403setting 404testing 404setting 405testing 405setting 406testing 406setting 407testing 407setting 408testing 408setting 409testing 409setting 410testing 410setting 411testing 411setting 412testing 412setting 413testing 413setting 414testing 414setting 415testing 415setting 416testing 416setting 417testing 417setting 418testing 418setting 419testing 419setting 420testing 420setting 421testing 421setting 422testing 422setting 423testing 423setting 424testing 424setting 425testing 425setting 426testing 426setting 427testing 427setting 428testing 428setting 429testing 429setting 430testing 430setting 431testing 431setting 432testing 432setting 433testing 433setting 434testing 434setting 435testing 435setting 436testing 436setting 437testing 437setting 438testing 438setting 439testing 439setting 440testing 440setting 441testing 441setting 442testing 442setting 443testing 443setting 444testing 444setting 445testing 445setting 446testing 446setting 447testing 447setting 448testing 448setting 449testing 449setting 450testing 450setting 451testing 451setting 452testing 452setting 453testing 453setting 454testing 454setting 455testing 455setting 456testing 456setting 457testing 457setting 458testing 458setting 459testing 459setting 460testing 460setting 461testing 461setting 462testing 462setting 463testing 463setting 464testing 464setting 465testing 465setting 466testing 466setting 467testing 467setting 468testing 468setting 469testing 469setting 470testing 470setting 471testing 471setting 472testing 472setting 473testing 473setting 474testing 474setting 475testing 475setting 476testing 476setting 477testing 477setting 478testing 478setting 479testing 479setting 480testing 480setting 481testing 481setting 482testing 482setting 483testing 483setting 484testing 484setting 485testing 485setting 486testing 486setting 487testing 487setting 488testing 488setting 489testing 489setting 490testing 490setting 491testing 491setting 492testing 492setting 493testing 493setting 494testing 494setting 495testing 495setting 496testing 496setting 497testing 497setting 498testing 498setting 499testing 499setting 500testing 500setting 501testing 501setting 502testing 502setting 503testing 503setting 504testing 504setting 505testing 505setting 506testing 506setting 507testing 507setting 508testing 508setting 509testing 509setting 510testing 510setting 511testing 511           ok
      Walking Ones        :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127           ok
      Walking Zeroes      :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63[  130.737936] Initializing XFRM netlink socket
    Loop 2:
      Stuck Address       :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7[  137.623146] process 'docker/tmp/qemu-check731142680/check' started with executable stack
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Walking Zeroes      :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127           ok
    Loop 3:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 4:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 5:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 6:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 7:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    U-Boot SPL 2021.01-g15769936a5 (Dec 21 2021 - 15:57:07 +0000)
    Model: Texas Instruments K3 J7200 SoC
    Board: J7200X-PM2-SOM rev E8
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 15:41:50, Dec 21 2021
    U-Boot SPL 2021.01-g15769936a5 (Dec 21 2021 - 15:43:01 +0000)
    Detected: J7X-BASE-CPB rev A
    Detected: J7X-VSC8514-ETH rev E2
    am654_sdhci sdhci@4fb0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
    U-Boot 2021.01-g15769936a5 (Dec 21 2021 - 15:43:01 +0000)
    SoC:   J7200 SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    eth0: ethernet@46000000
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    0 bytes read in 1 ms (0 Bytes/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    19270144 bytes read in 201 ms (91.4 MiB/s)
    46143 bytes read in 3 ms (14.7 MiB/s)
       Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.65-gdcc6bedb2c (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Dec 21 15:45:03 UTC 2021
    [    0.000000] Machine model: Texas Instruments K3 J7200 SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@a5200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
    [    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000a4ffffff]
    [    0.000000]   node   0: [mem 0x00000000a5000000-0x00000000a6ffffff]
    [    0.000000]   node   0: [mem 0x00000000a7000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:1m(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=96d5e2f2-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3441792K/4194304K available (10880K kernel code, 1346K rwdata, 4288K rodata, 1856K init, 757K bss, 228224K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008294] Console: colour dummy device 80x25
    [    0.012856] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023527] pid_max: default: 32768 minimum: 301
    [    0.028276] LSM: Security Framework initializing
    [    0.033028] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040605] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.050174] rcu: Hierarchical SRCU implementation.
    [    0.055362] Platform MSI: msi-controller@1820000 domain created
    [    0.061550] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070839] EFI services will not be available.
    [    0.075675] smp: Bringing up secondary CPUs ...
    [    0.081069] Detected PIPT I-cache on CPU1
    [    0.081093] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.081107] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.081147] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.081229] smp: Brought up 1 node, 2 CPUs
    [    0.110591] SMP: Total of 2 processors activated.
    [    0.115399] CPU features: detected: 32-bit EL0 Support
    [    0.120657] CPU features: detected: CRC32 instructions
    [    0.134183] CPU: All CPU(s) started at EL2
    [    0.138390] alternatives: patching kernel code
    [    0.143538] devtmpfs: initialized
    [    0.149797] KASLR disabled due to lack of seed
    [    0.154529] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.164505] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.172320] pinctrl core: initialized pinctrl subsystem
    [    0.177967] DMI not present or invalid.
    [    0.182281] NET: Registered protocol family 16
    [    0.190335] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197720] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205773] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214142] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214145] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220527] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.234193] ASID allocator initialised with 65536 entries
    [    0.251077] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.257938] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.264697] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.274206] cryptd: max_cpu_qlen set to 1000
    [    0.281689] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR1.0 JTAGID[0x0bb6d02f] Detected
    [    0.290554] vsys_3v3: supplied by evm_12v0
    [    0.295034] vsys_5v0: supplied by evm_12v0
    [    0.299816] iommu: Default domain type: Translated
    [    0.304978] SCSI subsystem initialized
    [    0.309170] mc: Linux media interface: v0.10
    [    0.313565] videodev: Linux video capture interface: v2.00
    [    0.319209] pps_core: LinuxPPS API ver. 1 registered
    [    0.324282] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.333621] PTP clock support registered
    [    0.337645] EDAC MC: Ver: 3.0.0
    [    0.341546] FPGA manager framework
    [    0.345094] Advanced Linux Sound Architecture Driver Initialized.
    [    0.351848] clocksource: Switched to clocksource arch_sys_counter
    [    0.358302] VFS: Disk quotas dquot_6.6.0
    [    0.362402] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.372626] NET: Registered protocol family 2
    [    0.377402] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.386297] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.395117] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.403333] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.411318] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.418168] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.425076] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.432522] NET: Registered protocol family 1
    [    0.437442] RPC: Registered named UNIX socket transport module.
    [    0.443509] RPC: Registered udp transport module.
    [    0.448316] RPC: Registered tcp transport module.
    [    0.453123] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.459708] PCI: CLS 0 bytes, default 64
    [    0.464092] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.476085] Initialise system trusted keyrings
    [    0.480774] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.489280] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.495637] NFS: Registering the id_resolver key type
    [    0.500826] Key type id_resolver registered
    [    0.505102] Key type id_legacy registered
    [    0.509236] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.516089] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.523763] 9p: Installing v9fs 9p2000 file system support
    [    0.548877] Key type asymmetric registered
    [    0.553073] Asymmetric key parser 'x509' registered
    [    0.558085] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.565647] io scheduler mq-deadline registered
    [    0.570272] io scheduler kyber registered
    [    0.575426] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.581674] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.589930] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.596235] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.604311] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.618585] brd: module loaded
    [    0.626269] loop: module loaded
    [    0.629902] megasas: 07.714.04.00-rc1
    [    0.634900] libphy: Fixed MDIO Bus: probed
    [    0.639608] tun: Universal TUN/TAP device driver, 1.6
    [    0.645060] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.651479] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.657564] sky2: driver version 1.30
    [    0.661925] VFIO - User Level meta-driver version: 0.3
    [    0.667699] i2c /dev entries driver
    [    0.671866] sdhci: Secure Digital Host Controller Interface driver
    [    0.678186] sdhci: Copyright(c) Pierre Ossman
    [    0.682948] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.689256] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.695620] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.702861] optee: probing for conduit method.
    [    0.707434] optee: revision 3.12 (3d47a131)
    [    0.707767] optee: initialized driver
    [    0.717118] NET: Registered protocol family 17
    [    0.721747] 9pnet: Installing 9P2000 support
    [    0.726148] Key type dns_resolver registered
    [    0.730594] Loading compiled-in X.509 certificates
    [    0.740550] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.746945] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.754800] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.779785] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.786117] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.792407] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.798861] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.805711] pca953x 3-0021: using no AI
    [    0.832406] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.839241] pca953x 3-0020: using no AI
    [    0.843886] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.850706] pca953x 3-0022: using AI
    [    0.854795] random: fast init done
    [    0.858559] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.864995] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    0.871854] pca953x 4-0020: using no AI
    [    0.896248] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.902487] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    [    0.908681] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.914893] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.921080] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    0.927268] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
    [    0.933520] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.943537] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.952366] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [    0.962398] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    0.972221] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.979907] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.988188] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.996466] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.016003] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
    [    2.022417] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    2.028024] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
    [    2.037714] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.044766] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
    [    2.050984] pci 0000:00:00.0: supports D1
    [    2.055080] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.061810] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.070750] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.077534] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.082856] pcieport 0000:00:00.0: PME: Signaling with IRQ 36
    [    2.089989] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    2.099901] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    2.106666] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.116479] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    2.126637] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    2.133398] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.141463] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    2.151086] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    2.159852] printk: console [ttyS2] enabled
    [    2.168289] printk: bootconsole [ns16550a0] disabled
    [    2.178977] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    2.355859] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    2.363340] libphy: 46000f00.mdio: probed
    [    2.390940] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.399271] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.414672] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.424254] mmc1: CQHCI version 5.10
    [    2.431456] vdd_mmc1: supplied by vsys_3v3
    [    2.436521] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
    [    2.443456] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
    [    2.450651] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    2.460658] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
    [    2.468947] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.472970] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.481720] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.488394] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.493880] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    2.500243] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    2.506474] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    2.512719] 0x000000700000-0x000000740000 : "ospi.env"
    [    2.518466] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    2.524867] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.530931] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.596879] mmc1: Command Queue Engine enabled
    [    2.601339] mmc1: new HS400 MMC card at address 0001
    [    2.606719] mmcblk1: mmc1:0001 G1M15L 29.6 GiB
    [    2.611457] mmcblk1boot0: mmc1:0001 G1M15L partition 1 31.5 MiB
    [    2.617588] mmcblk1boot1: mmc1:0001 G1M15L partition 2 31.5 MiB
    [    2.623697] mmcblk1rpmb: mmc1:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    2.707863] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    2.715346] libphy: 46000f00.mdio: probed
    [    2.744914] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.753260] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.766791] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.773857] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.781107] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.787553] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    2.797922] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.798203] mmc0: CQHCI version 5.10
    [    2.811517] ALSA device list:
    [    2.814500]   No soundcards found.
    [    2.849890] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.857819] Waiting for root device PARTUUID=96d5e2f2-02...
    [    2.915203] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.922276] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    [    2.931829]  mmcblk0: p1 p2
    [    3.266767] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
    [    3.272019] EXT4-fs (mmcblk0p2): recovery complete
    [    3.294471] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.302598] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.311772] devtmpfs: mounted
    [    3.315974] Freeing unused kernel memory: 1856K
    [    3.320538] Run /sbin/init as init process
    [    3.424649] systemd[1]: System time before build time, advancing clock.
    [    3.465368] NET: Registered protocol family 10
    [    3.470383] Segment Routing with IPv6
    [    3.486156] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.508097] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    3.546576] systemd[1]: Set hostname to <j7200-evm>.
    [    3.749390] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    3.827292] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.834068] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.846410] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.856915] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.879967] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.887560] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.907973] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.915507] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    3.936993] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.960148] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.984097] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    4.008052] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    4.023981] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.043973] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    4.059980] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    4.079475] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.099998] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.124341] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.148144] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.180600] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.189044] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.212313] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.228363] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.252308] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.272176] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.295474] systemd[1]: Mounting Huge Pages File System...
    [    4.315333] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.339933] systemd[1]: Mounting Kernel Debug File System...
    [    4.362400] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.383774] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    4.414481] systemd[1]: Starting RPC Bind...
    [    4.428068] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.441289] systemd[1]: Starting Journal Service...
    [    4.461312] systemd[1]: Starting Load Kernel Modules...
    [    4.484573] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.495557] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
             Starting Remount Root and Kernel File Systems[    4.505935] cryptodev: loading out-of-tree module taints kernel.
    [0m...
    [    4.516583] cryptodev: driver 1.10 loaded.
    [    4.528557] systemd[1]: Starting udev Coldplug all Devices...
    [    4.547289] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.560406] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    4.744097] systemd-journald[156]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    5.529728] ti-udma 285c0000.dma-controller: chan1: is running!
    [    5.707197] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.726592] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.735350] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    5.761044] remoteproc remoteproc0: 41000000.r5f is available
    [    5.767657] remoteproc remoteproc0: attaching to 41000000.r5f
    [    5.774324] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.782126]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    5.792939] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.799409]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    5.818963] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.830680] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    5.870798] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [    5.962409] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    6.106630] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    6.258332] remoteproc remoteproc1: 5c00000.r5f is available
    [    6.408908] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    6.415504] remoteproc remoteproc1: powering up 5c00000.r5f
    [    6.421116] remoteproc remoteproc1: Booting fw image j7200-main-r5f0_0-fw, size 634196
    [    6.441224]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    6.449906] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.455429]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    6.463917] remoteproc remoteproc1: remote processor 5c00000.r5f is now up
    [    6.505288] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    6.576038] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e
    [    6.584145] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
    [    6.599923] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 3
    [    6.620606] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
    [    6.638867] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 3
    [    6.655771] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
    [    6.672556] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:84 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [    6.704867] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac loaded
    [    6.712908] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:84 tx_psil_dst_id:4A00 mac_only:0
    [    6.720053] remoteproc remoteproc2: 5d00000.r5f is available
    [    6.739975] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [    6.761166] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:85 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [    6.794006] remoteproc remoteproc2: powering up 5d00000.r5f
    [    6.799769] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 83148
    [    6.804603] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [    6.815592] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:85 tx_psil_dst_id:4A01 mac_only:1
    [    6.828814]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    6.830535] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [    6.842493] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.863159]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    6.879862] remoteproc remoteproc2: remote processor 5d00000.r5f is now up
    [    6.906755] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.914358] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    7.539889] random: crng init done
    [    7.543293] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    8.008084] usbcore: registered new interface driver usbfs
    [    8.014223] omap_rng 40910000.rng: Random Number Generator ver. 241b34c
    [    8.048244] usbcore: registered new interface driver hub
    [    8.055564] usbcore: registered new device driver usb
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk0p1.
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting System Logger Daemon "default" instance...
             Starting Login Service...
             Starting telnetd.service...
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
    [  OK  ] Started Telephony service.
    [  OK  ] Reached target Network (Pre).
             Mounting /run/media/mmcblk0p1...
             Starting syslog.service...
             Starting Network Service...
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Listening on Load/Save RF …itch S[    8.964103] Bluetooth: Core ver 2.22
    tatus /dev/rfkill Watch.
    [    8.975517] NET: Registered protocol family 31
    [    8.982587] Bluetooth: HCI device and connection manager initialized
    [    8.994707] Bluetooth: HCI socket layer initialized
    [    9.004294] Bluetooth: L2CAP socket layer initialized
    [    9.015963] Bluetooth: SCO socket layer initialized
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [    9.187757] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [  OK  ] Started Login Service.
    [    9.255157] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac started
    [  OK  ] Started syslog.service.
    [    9.614187] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
    [    9.708828] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Vsftpd ftp daemon.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	gstreamer1.0-libav-dev
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline8
    	libunistring-dev
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	python3-rfc3987
    	python3-strict-rfc3339
    	tar
    	which
    	zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7200-evm ttyS2
    Arago 2021.09 j7200-evm ttyS2
    j7200-evm login:
  • TDA4VM
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.09.30 15:38:05 =~=~=~=~=~=~=~=~=~=~=~=
    U-Boot SPL 2023.04-dirty (Sep 12 2024 - 15:36:37 +0800)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Loading Environment from nowhere... OK
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    I/TC:
    I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2023.04-dirty (Sep 12 2024 - 15:36:30 +0800)
    U-Boot 2023.04-dirty (Sep 12 2024 - 15:36:30 +0800)
    SoC:   J721E SR1.1 GP
    Model: Texas Instruments J721E SK A72
    Board: J721EX-EAIK rev A1
    DRAM:  2 GiB
    Core:  121 devices, 34 uclasses, devicetree: separate
    Flash: 0 Bytes
    MMC:   mmc@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    1432 bytes read in 25 ms (55.7 KiB/s)
    Running uenvcmd ...
    1 bytes read in 25 ms (0 Bytes/s)
    Already setup.
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    Failed to load '/lib/firmware/j7-mcu-r5f0_1-fw'
    450240 bytes read in 37 ms (11.6 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 450240 bytes: Success!
    322804 bytes read in 35 ms (8.8 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 322804 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    998192 bytes read in 49 ms (19.4 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 998192 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 998192 bytes: Success!
    13504656 bytes read in 140 ms (92 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 13504656 bytes: Success!
    19376640 bytes read in 413 ms (44.7 MiB/s)
    103777 bytes read in 30 ms (3.3 MiB/s)
    Working FDT set to 88000000
    10434 bytes read in 28 ms (363.3 KiB/s)
       Loading Device Tree to 000000008fee3000, end 000000008fffffff ... OK
    Working FDT set to 8fee3000
    Starting kernel ...
    [    0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024
    [    0.000000] Machine model: Texas Instruments J721E SK
    [    0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma': size 512 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000]   Normal   empty
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fbc00000
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 systemd.hostname=tda4vm-sk root=PARTUUID=a8f772c7-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Memory: 834104K/2097152K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 1230280K reserved, 32768K cma-reserved)
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008436] Console: colour dummy device 80x25
    [    0.013002] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023672] pid_max: default: 32768 minimum: 301
    [    0.028408] LSM: Security Framework initializing
    [    0.033184] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.040752] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.049601] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.057003] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.063264] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.070649] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.076964] rcu: Hierarchical SRCU implementation.
    [    0.081861] rcu: 	Max phase no-delay instances is 1000.
    [    0.087365] Platform MSI: msi-controller@1820000 domain created
    [    0.093641] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.103074] EFI services will not be available.
    [    0.107818] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.121043] Detected PIPT I-cache on CPU1
    [    0.121105] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.121118] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.121154] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.121205] smp: Brought up 1 node, 2 CPUs
    [    0.150553] SMP: Total of 2 processors activated.
    [    0.155357] CPU features: detected: 32-bit EL0 Support
    [    0.160609] CPU features: detected: CRC32 instructions
    [    0.165886] CPU: All CPU(s) started at EL2
    [    0.170067] alternatives: applying system-wide alternatives
    [    0.176700] devtmpfs: initialized
    [    0.186361] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.196354] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.203995] pinctrl core: initialized pinctrl subsystem
    [    0.209618] DMI not present or invalid.
    [    0.213862] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.220493] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.227758] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.235726] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.243854] audit: initializing netlink subsys (disabled)
    [    0.249483] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.249719] thermal_sys: Registered thermal governor 'step_wise'
    [    0.257402] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.263613] cpuidle: using governor menu
    [    0.274370] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.281333] ASID allocator initialised with 65536 entries
    [    0.296068] KASLR disabled due to lack of seed
    [    0.303479] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.310420] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.316822] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.323756] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.330157] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.337090] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.343490] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.350423] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.357547] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.366756] iommu: Default domain type: Translated
    [    0.371743] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.378268] SCSI subsystem initialized
    [    0.382257] usbcore: registered new interface driver usbfs
    [    0.387877] usbcore: registered new interface driver hub
    [    0.393312] usbcore: registered new device driver usb
    [    0.398685] pps_core: LinuxPPS API ver. 1 registered
    [    0.403756] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.413093] PTP clock support registered
    [    0.417170] EDAC MC: Ver: 3.0.0
    [    0.420871] FPGA manager framework
    [    0.424383] Advanced Linux Sound Architecture Driver Initialized.
    [    0.431025] clocksource: Switched to clocksource arch_sys_counter
    [    0.437365] VFS: Disk quotas dquot_6.6.0
    [    0.441397] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.451411] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.457708] NET: Registered PF_INET protocol family
    [    0.462832] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.471260] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.480011] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.487933] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.496082] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.504136] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.510885] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.517765] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.525186] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.531244] RPC: Registered named UNIX socket transport module.
    [    0.537299] RPC: Registered udp transport module.
    [    0.542102] RPC: Registered tcp transport module.
    [    0.546905] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.553487] NET: Registered PF_XDP protocol family
    [    0.558388] PCI: CLS 0 bytes, default 64
    [    0.562730] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.571877] Initialise system trusted keyrings
    [    0.576532] workingset: timestamp_bits=46 max_order=18 bucket_order=0
    [    0.585074] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.591331] NFS: Registering the id_resolver key type
    [    0.596509] Key type id_resolver registered
    [    0.600780] Key type id_legacy registered
    [    0.604898] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.611747] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.638657] Key type asymmetric registered
    [    0.642842] Asymmetric key parser 'x509' registered
    [    0.647849] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.655482] io scheduler mq-deadline registered
    [    0.660112] io scheduler kyber registered
    [    0.666424] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.672778] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.682407] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.690777] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.699048] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.706209] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.714268] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.725354] loop: module loaded
    [    0.729296] megasas: 07.719.03.00-rc1
    [    0.734582] tun: Universal TUN/TAP device driver, 1.6
    [    0.740165] VFIO - User Level meta-driver version: 0.3
    [    0.745825] usbcore: registered new interface driver usb-storage
    [    0.752284] i2c_dev: i2c /dev entries driver
    [    0.757201] sdhci: Secure Digital Host Controller Interface driver
    [    0.763522] sdhci: Copyright(c) Pierre Ossman
    [    0.768089] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.774199] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.780427] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.787168] usbcore: registered new interface driver usbhid
    [    0.792862] usbhid: USB HID core driver
    [    0.797267] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.801825] optee: revision 4.1 (012cdca4)
    [    0.818255] optee: dynamic shared memory is enabled
    [    0.827638] optee: initialized driver
    [    0.832632] Initializing XFRM netlink socket
    [    0.837022] NET: Registered PF_PACKET protocol family
    [    0.842222] Key type dns_resolver registered
    [    0.846770] registered taskstats version 1
    [    0.850969] Loading compiled-in X.509 certificates
    [    0.861796] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    [    0.916819] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.947183] i2c i2c-1: Added multiplexed i2c bus 2
    [    0.952164] i2c i2c-1: Added multiplexed i2c bus 3
    [    0.957063] pca954x 1-0071: registered 2 multiplexed busses for I2C switch pca9543
    [    0.964852] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.970875] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
    [    0.999182] i2c i2c-5: Added multiplexed i2c bus 6
    [    1.004163] i2c i2c-5: Added multiplexed i2c bus 7
    [    1.009062] pca954x 5-0070: registered 2 multiplexed busses for I2C switch pca9543
    [    1.016819] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.022873] omap_i2c 2050000.i2c: bus 8 rev0.12 at 400 kHz
    [    1.028674] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    1.037219] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    1.046558] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    1.055163] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.072456] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.082352] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.089111] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.098240] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.108403] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.115162] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.123129] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 193, base_baud = 6000000) is a 8250
    [    1.132593] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 194, base_baud = 3000000) is a 8250
    [    1.141446] printk: console [ttyS2] enabled
    [    1.149887] printk: bootconsole [ns16550a0] disabled
    [    1.160295] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 195, base_baud = 3000000) is a 8250
    [    1.170263] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.215033] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.223704] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.231975] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.244785] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.251992] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.258276] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.268599] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.282626] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.289467] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.296263] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.303062] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.309833] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.323904] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.334663] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.349129] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.354162] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
    [    1.361198] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.366671] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.372769] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.378524] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.384369] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.389956] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.395757] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    1.401976] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.407829] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.418248] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.463031] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.471701] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.479973] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.492782] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.499990] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.506235] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.516668] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.525232] mmc1: CQHCI version 5.10
    [    1.539612] ALSA device list:
    [    1.542579]   No soundcards found.
    [    1.569834] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.577429] Waiting for root device PARTUUID=a8f772c7-02...
    [    1.629523] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.636499] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
    [    1.645528]  mmcblk1: p1 p2
    [    1.686912] EXT4-fs (mmcblk1p2): recovery complete
    [    1.691711] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.700251] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.709946] devtmpfs: mounted
    [    1.714004] Freeing unused kernel memory: 1984K
    [    1.718632] Run /sbin/init as init process
    [    1.940798] systemd[1]: System time before build time, advancing clock.
    [    1.991114] NET: Registered PF_INET6 protocol family
    [    1.996648] Segment Routing with IPv6
    [    2.000331] In-situ OAM (IOAM) with IPv6
    [    2.029422] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    2.060818] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    2.123170] systemd[1]: Hostname set to <tda4vm-sk>.
    [    2.217933] systemd-sysv-generator[142]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.242940] systemd-sysv-generator[142]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.382957] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.426686] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.478126] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.516127] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    2.540444] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    2.564398] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    2.588096] systemd[1]: Created slice User and Session Slice.
    [    2.611253] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password ?宇s to Console Directory Watch.
    [    2.635174] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R?守ests to Wall Directory Watch.
    [    2.659206] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    2.675089] systemd[1]: Reached target Remote File Systems.
    [    2.695080] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    2.711086] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    2.758123] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    2.779177] systemd[1]: Reached target RPC Port Mapper.
    [    2.803932] systemd[1]: Listening on Process Core Dump Socket.
    [    2.827265] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    2.851436] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    2.871334] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.891355] systemd[1]: Listening on Journal Socket.
    [    2.907417] systemd[1]: Listening on Network Service Netlink Socket.
    [    2.931393] systemd[1]: Listening on udev Control Socket.
    [    2.951263] systemd[1]: Listening on udev Kernel Socket.
    [    2.971324] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.011541] systemd[1]: Mounting Huge Pages File System...
    [    3.029647] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.053872] systemd[1]: Mounting Kernel Debug File System...
    [    3.071328] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.089300] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.110182] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.147468] systemd[1]: Starting Load Kernel Module configfs...
    [    3.165716] systemd[1]: Starting Load Kernel Module drm...
    [    3.185707] systemd[1]: Starting Load Kernel Module fuse...
    [    3.199662] fuse: init (API version 7.37)
    [    3.216069] systemd[1]: Starting Start psplash boot splash screen...
    [    3.271711] systemd[1]: Starting RPC Bind...
    [    3.295266] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    3.327734] systemd[1]: Starting Journal Service...
    [    3.355738] systemd[1]: Starting Load Kernel Modules...
    [    3.372542] cryptodev: loading out-of-tree module taints kernel.
    [    3.382129] cryptodev: driver 1.12 loaded.
    [    3.384238] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network ?宇s from Kernel command line...
    [    3.404604] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.428155] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    3.459647] systemd[1]: Starting Coldplug All udev Devices...
    [    3.483808] systemd[1]: Started RPC Bind.
    [    3.503584] systemd[1]: Started Journal Service.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star?如rogress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
    [    3.844395] systemd-journald[158]: Received client request to flush runtime journal.
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
    [    4.037508] audit: type=1334 audit(1651167747.096:2): prog-id=5 op=LOAD
    [    4.044434] audit: type=1334 audit(1651167747.104:3): prog-id=6 op=LOAD
             Starting Rule-based Manage?圩or Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [    4.534639] random: crng init done
    [  OK  ] Reached target Timer Units.
    [    4.591662] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [  OK  ] Listening on D-Bus System Message B[    4.599969] mc: Linux media interface: v0.10
    us Socket.
    [    4.601063] j721e-pcie-host 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
             Starting Docker Socket for the API...
    [    4.625621] j721e-pcie-host 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    4.637645] j721e-pcie-host 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.649304] videodev: Linux video capture interface: v2.00
    [  OK  ] Listening on PC/SC Smart Card Daemo[    4.673383] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    n Activation Socket.
    [    4.693049] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    4.704039] remoteproc remoteproc0: 4d80800000.dsp is available
             Starting Weston socket...
    [    4.714121] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    4.725556] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    4.734176] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
             Starting D-Bus System Message Bus...[    4.748820] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    4.750098] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    4.757770] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    4.763239] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    4.777177] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    4.784868] k3-dsp-rproc 4d80800000.dsp: register pm nitifiers in remoteproc mode
    [    4.805468] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [  OK  ] Finished Load/Save Random Seed.[    4.820359] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    4.833639] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [  OK  ] Listening on Docker Socket for the [    4.847723] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    API.
    [    4.856771] remoteproc remoteproc1: 4d81800000.dsp is available
    [    4.863338] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [  OK  ] Listening on Weston socket.
    [    4.870494] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    4.882482] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    4.894306] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    4.899943] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [  OK  ] Found device /dev/ttyS2.[    4.909007] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [  OK  ] Reached target Socket Units.[    4.924736] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
    [    4.929199] PVR_K:  184: Device: 4e20000000.gpu
    [    4.936972] k3-dsp-rproc 4d81800000.dsp: register pm nitifiers in remoteproc mode
    [    4.942721] PVR_K:  184: Read BVNC 22.104.208.318 from HW device registers
    [    4.956638] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    4.966259] PVR_K:  184: RGX Device registered with BVNC 22.104.208.318
    [    4.973370] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    4.980575] [drm] Initialized pvr 23.3.6512818 20170530 for 4e20000000.gpu on minor 0
    [    4.982498] remoteproc remoteproc2: 64800000.dsp is available
    [    4.998347] remoteproc remoteproc2: attaching to 64800000.dsp
    [    5.004473] remoteproc remoteproc2: unsupported resource 65538
    [    5.010447] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    5.017273] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    5.027929] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.029966] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    5.034302] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [    5.047402] remoteproc remoteproc2: remote processor 64800000.dsp is now attached
    [    5.054916] k3-dsp-rproc 64800000.dsp: register pm nitifiers in remoteproc mode
    [    5.079646] cdns-mhdp8546 a000000.dp-bridge: invalid resource
    [    5.086137] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
    [  OK  ] Finished Reboot and dump vmcore via kexec.
             Starting DEMO...
             Starting Update pmic regis?圩ety feature on power rails...
             Starting Expand the rootfs?奸l size of the boot device....
    [  OK  ] Started strongSwan IPsec I?匈KEv2 daemon using ipsec.conf.
    [    5.399533] audit: type=1334 audit(1651170771.564:4): prog-id=7 op=LOAD
    [    5.409817] audit: type=1334 audit(1651170771.572:5): prog-id=8 op=LOAD
             Starting User Login Management...
    [  OK  ] Started TEE Supplicant.
             Starting Telnet Server...
    [  OK  ] Started DEMO.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [    5.592793] Bluetooth: Core ver 2.22
    [    5.600145] NET: Registered PF_BLUETOOTH protocol family
    [    5.611062] Bluetooth: HCI device and connection manager initialized
    [    5.622775] Bluetooth: HCI socket layer initialized
    [    5.634110] Bluetooth: L2CAP socket layer initialized
    [    5.639257] Bluetooth: SCO socket layer initialized
    [    5.664142] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00
    [    5.697805] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    5.737471] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    5.749112] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    5.756115] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    5.762599] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    5.773351] pci 0000:00:00.0: supports D1
    [    5.777447] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [  OK  ] Finished Update pmic regis?存afety[    5.788110] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [  OK  ] Finished Expand the rootfs?圩ull size of the boot device..
    [    5.825040] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    5.831732] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    5.837552] pcieport 0000:00:00.0: PME: Signaling with IRQ 629
    [    5.846278] pcieport 0000:00:00.0: AER: enabled with IRQ 629
    [    5.852525] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.862316] j721e-pcie-host 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.871124] j721e-pcie-host 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.879856] j721e-pcie-host 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [  OK  ] Started User Login Management.
    [    5.936473] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.013423] platform 41000000.r5f: configured R5F for IPC-only mode
    [    6.022221] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.033167] remoteproc remoteproc3: 41000000.r5f is available
    [    6.039631] remoteproc remoteproc3: attaching to 41000000.r5f
    [    6.048201] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    6.055252] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.068106] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.074321] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [    6.081832] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [    6.083725] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.097274] platform 41400000.r5f: configured R5F for remoteproc mode
    [    6.103984] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    6.111500] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [    6.122814] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.125490] remoteproc remoteproc4: 41400000.r5f is available
    [    6.145568] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.157231] remoteproc remoteproc4: loading /lib/firmware/j7-mcu-r5f0_1-fw failed with error -22
    [    6.158278] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    6.168498] remoteproc remoteproc4: Direct firmware load for j7-mcu-r5f0_1-fw failed with error -22
    [    6.189694] remoteproc remoteproc4: powering up 41400000.r5f
    [    6.199085] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [    6.206280] remoteproc remoteproc4: loading /lib/firmware/j7-mcu-r5f0_1-fw failed with error -22
    [    6.215270] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    6.224786] remoteproc remoteproc4: Direct firmware load for j7-mcu-r5f0_1-fw failed with error -22
    [    6.234960] remoteproc remoteproc4: request_firmware failed: -22
    [    6.244566] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [  OK  ] Started Network Configuration.
    [    6.305848] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    6.315715] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Ma?圯nt Protocol (SNMP) Daemon....
    [  OK  ] Finished Permit User Sessions.
             Starting Weston, a Wayland?她sitor, as a system service...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [    6.899281] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0001:00
    [    6.908424] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    6.914022] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    6.923763] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    6.930815] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    6.936923] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    6.947245] pci 0001:00:00.0: supports D1
    [    6.951275] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    6.959306] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    6.967727] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    6.974462] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    6.980050] pcieport 0001:00:00.0: PME: Signaling with IRQ 634
    [    6.989655] pcieport 0001:00:00.0: AER: enabled with IRQ 634
    [    7.044239] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    7.139335] audit: type=1334 audit(1651170773.304:6): prog-id=9 op=LOAD
    [    7.146255] audit: type=1334 audit(1651170773.312:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    [    7.163603] remoteproc remoteproc5: b034000.pru is available
    [    7.172654] remoteproc remoteproc6: b004000.rtu is available
    [    7.184878] remoteproc remoteproc7: b00a000.txpru is available
    [    7.193926] remoteproc remoteproc8: b038000.pru is available
    [    7.200914] remoteproc remoteproc9: b006000.rtu is available
    [    7.209632] remoteproc remoteproc10: b00c000.txpru is available
    [    7.217524] remoteproc remoteproc11: b134000.pru is available
    [    7.225586] remoteproc remoteproc12: b104000.rtu is available
    [    7.232925] remoteproc remoteproc13: b10a000.txpru is available
    [    7.240447] remoteproc remoteproc14: b138000.pru is available
    [    7.247549] remoteproc remoteproc15: b106000.rtu is available
    [    7.255248] remoteproc remoteproc16: b10c000.txpru is available
    [  OK  ] Started User Database Manager.
    [    7.320878] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [    7.388580] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [  OK  ] Created slice User Slice of UID 1000.
    [  OK  ] Listening on Load/Save RF ?夷tch Status /dev/rfkill Watch.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [    7.517622] audit: type=1006 audit(1651170773.680:8): pid=555 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    7.530290] audit: type=1300 audit(1651170773.680:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc6fc6558 a2=4 a3=ffffae5d3020 items=0 ppid=1 pid=555 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    7.557452] audit: type=1327 audit(1651170773.680:8): proctitle="(systemd)"
    [    7.887674] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    7.893214] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [    7.901012] xhci-hcd xhci-hcd.4.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [    7.910475] xhci-hcd xhci-hcd.4.auto: irq 657, io mem 0x06410000
    [    7.916698] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    7.922213] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
    [    7.929895] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
    [    7.936905] hub 1-0:1.0: USB hub found
    [    7.940727] hub 1-0:1.0: 1 port detected
    [    7.945961] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.955132] hub 2-0:1.0: USB hub found
    [    7.959165] hub 2-0:1.0: 1 port detected
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston[[    8.017260] audit: type=1006 audit(1651170774.180:9): pid=530 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    0m.
    [    8.030304] audit: type=1300 audit(1651170774.180:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc6fc6558 a2=4 a3=ffffae5d3020 items=0 ppid=1 pid=530 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [    8.056847] audit: type=1327 audit(1651170774.180:9): proctitle="(weston)"
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [    8.159087] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: Timed out waiting for 41400000.r5f core to power up!
    [    8.177922] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    8.184465] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    8.195275] remoteproc remoteproc17: 5c00000.r5f is available
    [    8.199077] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    8.201089] remoteproc remoteproc17: attaching to 5c00000.r5f
    [    8.214198] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    8.220895] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    8.234445] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    8.238806] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    8.240283] rproc-virtio rproc-virtio.5.auto: registered virtio4 (type 7)
    [  OK  ] Found device /dev/mmcblk1p1.[    8.254074] remoteproc remoteproc17: remote processor 5c00000.r5f is now attached
    [    8.267516] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    8.274093] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
             Starting File System Check on /dev/mmcblk1p1[[    8.286010] remoteproc remoteproc18: 5d00000.r5f is available
    0m...
    [    8.295998] remoteproc remoteproc18: attaching to 5d00000.r5f
    [    8.302613] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    8.309564] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    8.320332] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    8.324635] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    8.325981] rproc-virtio rproc-virtio.6.auto: registered virtio5 (type 7)
    [    8.335268] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    8.339695] remoteproc remoteproc18: remote processor 5d00000.r5f is now attached
    [    8.349319] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.362124] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    8.369700] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.377443] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    8.385058] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    8.386499] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.399061] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    8.406444] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    8.406826] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.415988] remoteproc remoteproc19: 5e00000.r5f is available
    [    8.426714] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    8.430187] remoteproc remoteproc19: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [    8.445051] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [    8.446237] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.454900] remoteproc remoteproc19: powering up 5e00000.r5f
    [    8.467641] remoteproc remoteproc19: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [    8.476646] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [    8.485937] remoteproc remoteproc19: request_firmware failed: -22
    [  OK  ] Started Simple Network Man?圯ment Protocol (SNMP) Daemon..
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/BOOT-mmcblk1p1...
    [    8.855974] hub 1-1:1.0: USB hub found
    [    8.859856] hub 1-1:1.0: 4 ports detected
    [    8.983078] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [    9.007937] hub 2-1:1.0: USB hub found
    [    9.012029] hub 2-1:1.0: 4 ports detected
    [  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
    [    9.100036] PVR_K:  530: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [    9.118406] PVR_K:  530: Shader binary image 'rgx.sh.22.104.208.318' loaded
    [  OK  ] Started Weston, a Wayland ?妃positor, as a system service.
             Starting EdgeAI OOB demos...
             Stopping Weston, a Wayland?她sitor, as a system service...
             Stopping Session c1 of User weston...
    [  OK  ] Stopped Session c1 of User weston.
    [  OK  ] Stopped Weston, a Wayland ?妃positor, as a system service.
    [  OK  ] Started containerd container runtime.
    [  OK  ] Started EdgeAI OOB demos.
    [   10.467067] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
    [   11.203464] audit: type=1701 audit(1651170777.368:10): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=727 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
    [  OK  ] Created slice Slice /system/systemd[   11.239629] audit: type=1334 audit(1651170777.404:11): prog-id=11 op=LOAD
    -coredump.
    [   11.251217] audit: type=1334 audit(1651170777.416:12): prog-id=12 op=LOAD
    [  OK  ] Started Process Core Dump (PID 819/UID 0).
    [   11.739142] audit: type=1334 audit(1651170777.904:13): prog-id=12 op=UNLOAD
    [   11.746764] audit: type=1334 audit(1651170777.904:14): prog-id=11 op=UNLOAD
    NOTICE: This file system contains the following GPL-3.0 packages:
    	adwaita-icon-theme-symbolic
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gnu-config
    	grub-common
    	grub-editenv
    	grub-efi
    	gzip
    	hidapi
    	less
    	libasm1
    	libatomic-dev
    	libatomic1
    	libbfd
    	libdebuginfod1
    	libdw1
    	libeigen-dev
    	libelf1
    	libgcc-s-dev
    	libgcc1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libopcodes
    	libqt5charts-examples
    	libqt5charts-plugins
    	libqt5charts-qmlplugins
    	libqt5charts5
    	libqt5sensors-plugins
    	libqt5sensors-qmlplugins
    	libqt5sensors5
    	libqt5serialport-examples
    	libqt5serialport-plugins
    	libqt5serialport-qmlplugins
    	libqt5serialport5
    	libqt5svg-examples
    	libqt5svg-plugins
    	libqt5svg-qmlplugins
    	libqt5svg5
    	libqt5virtualkeyboard-plugins
    	libqt5virtualkeyboard-qmlplugins
    	libqt5virtualkeyboard5
    	libqt5webchannel-plugins
    	libqt5webchannel-qmlplugins
    	libqt5webchannel5
    	libreadline-dev
    	libreadline8
    	libstdc++-dev
    	libstdc++6
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle
    	parted
    	piglit
    	qt3d-plugins
    	qt3d-qmlplugins
    	qt3d
    	qtbase-examples
    	qtbase-plugins
    	qtbase-qmlplugins
    	qtbase
    	qtconnectivity-plugins
    	qtconnectivity-qmlplugins
    	qtconnectivity
    	qtdeclarative-plugins
    	qtdeclarative-qmlplugins
    	qtdeclarative-tools
    	qtdeclarative
    	qtgraphicaleffects-qmlplugins
    	qtlocation-examples
    	qtlocation-plugins
    	qtlocation-qmlplugins
    	qtlocation
    	qtmultimedia-examples
    	qtmultimedia-plugins
    	qtmultimedia-qmlplugins
    	qtmultimedia
    	qtquick3d-plugins
    	qtquick3d-qmlplugins
    	qtquick3d
    	qtquics-qmlplugins.control
    	qtquics2-plugins.control
    	qtquics2-qmlplugins.control
    	qtquics2.control
    	qtscript-examples
    	qtscript-plugins
    	qtscript-qmlplugins
    	qtscript
    	qtwayland-examples
    	qtwayland-plugins
    	qtwayland-qmlplugins
    	qtwayland
    	tar
    	which
    If you do not wish to distribute GPL-3.0 components please remove
     _____                    _____           _         _
                  |___|                    |___|
    Arago Project tda4vm-sk -
    Arago 2023.10 tda4vm-sk -
    tda4vm-sk login: root
    [   16.211342] audit: type=1006 audit(1651170782.376:15): pid=1314 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   16.224120] audit: type=1300 audit(1651170782.376:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc6fc6558 a2=1 a3=0 items=0 ppid=1 pid=1314 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   16.250002] audit: type=1327 audit(1651170782.376:15): proctitle="(systemd)"
    [   16.257338] audit: type=1334 audit(1651170782.376:16): prog-id=13 op=LOAD
    [   16.264538] audit: type=1300 audit(1651170782.376:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff5c05610 a2=78 a3=0 items=0 ppid=1 pid=1314 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   16.290172] audit: type=1327 audit(1651170782.376:16): proctitle="(systemd)"
    [   16.297379] audit: type=1334 audit(1651170782.388:17): prog-id=13 op=UNLOAD
    [   16.304466] audit: type=1334 audit(1651170782.388:18): prog-id=14 op=LOAD
    [   16.311471] audit: type=1300 audit(1651170782.388:18): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff5c056b0 a2=78 a3=0 items=0 ppid=1 pid=1314 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   16.337011] audit: type=1327 audit(1651170782.388:18): proctitle="(systemd)"
    78root@tda4vm-sk:/opt/edgeai-gst-apps#
    root@tda4vm-sk:/opt/edgeai-gst-apps# memter ster 10M
    memtester version 4.5.1 (64-bit)
    Copyright (C) 2001-2020 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 4096
    pagesizemask is 0xfffffffffffff000
    want 10MB (10485760 bytes)
    got  10MB (10485760 bytes), trying mlock ...locked.
    Loop 1:
      Stuck Address       :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15           ok
      Random Value        :  \|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\| ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Sequential Increment: ok
      Solid Bits          :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63           ok
      Block Sequential    :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127setting 128testing 128setting 129testing 129setting 130testing 130setting 131testing 131setting 132testing 132setting 133testing 133setting 134testing 134setting 135testing 135setting 136testing 136setting 137testing 137setting 138testing 138setting 139testing 139setting 140testing 140setting 141testing 141setting 142testing 142setting 143testing 143setting 144testing 144setting 145testing 145setting 146testing 146setting 147testing 147setting 148testing 148setting 149testing 149setting 150testing 150setting 151testing 151setting 152testing 152setting 153testing 153setting 154testing 154setting 155testing 155setting 156testing 156setting 157testing 157setting 158testing 158setting 159testing 159setting 160testing 160setting 161testing 161setting 162testing 162setting 163testing 163setting 164testing 164setting 165testing 165setting 166testing 166setting 167testing 167setting 168testing 168setting 169testing 169setting 170testing 170setting 171testing 171setting 172testing 172setting 173testing 173setting 174testing 174setting 175testing 175setting 176testing 176setting 177testing 177setting 178testing 178setting 179testing 179setting 180testing 180setting 181testing 181setting 182testing 182setting 183testing 183setting 184testing 184setting 185testing 185setting 186testing 186setting 187testing 187setting 188testing 188setting 189testing 189setting 190testing 190setting 191testing 191setting 192testing 192setting 193testing 193setting 194testing 194setting 195testing 195setting 196testing 196setting 197testing 197setting 198testing 198setting 199testing 199setting 200testing 200setting 201testing 201setting 202testing 202setting 203testing 203setting 204testing 204setting 205testing 205setting 206testing 206setting 207testing 207setting 208testing 208setting 209testing 209setting 210testing 210setting 211testing 211setting 212testing 212setting 213testing 213setting 214testing 214setting 215testing 215setting 216testing 216setting 217testing 217setting 218testing 218setting 219testing 219setting 220testing 220setting 221testing 221setting 222testing 222setting 223testing 223setting 224testing 224setting 225testing 225setting 226testing 226setting 227testing 227setting 228testing 228setting 229testing 229setting 230testing 230setting 231testing 231setting 232testing 232setting 233testing 233setting 234testing 234setting 235testing 235setting 236testing 236setting 237testing 237setting 238testing 238setting 239testing 239setting 240testing 240setting 241testing 241setting 242testing 242setting 243testing 243setting 244testing 244setting 245testing 245setting 246testing 246setting 247testing 247setting 248testing 248setting 249testing 249setting 250testing 250setting 251testing 251setting 252testing 252setting 253testing 253setting 254testing 254setting 255testing 255           ok
      Checkerboard        :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63           ok
      Bit Spread          :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127           ok
      Bit Flip            :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127setting 128testing 128setting 129testing 129setting 130testing 130setting 131testing 131setting 132testing 132setting 133testing 133setting 134testing 134setting 135testing 135setting 136testing 136setting 137testing 137setting 138testing 138setting 139testing 139setting 140testing 140setting 141testing 141setting 142testing 142setting 143testing 143setting 144testing 144setting 145testing 145setting 146testing 146setting 147testing 147setting 148testing 148setting 149testing 149setting 150testing 150setting 151testing 151setting 152testing 152setting 153testing 153setting 154testing 154setting 155testing 155setting 156testing 156setting 157testing 157setting 158testing 158setting 159testing 159setting 160testing 160setting 161testing 161setting 162testing 162setting 163testing 163setting 164testing 164setting 165testing 165setting 166testing 166setting 167testing 167setting 168testing 168setting 169testing 169setting 170testing 170setting 171testing 171setting 172testing 172setting 173testing 173setting 174testing 174setting 175testing 175setting 176testing 176setting 177testing 177setting 178testing 178setting 179testing 179setting 180testing 180setting 181testing 181setting 182testing 182setting 183testing 183setting 184testing 184setting 185testing 185setting 186testing 186setting 187testing 187setting 188testing 188setting 189testing 189setting 190testing 190setting 191testing 191setting 192testing 192setting 193testing 193setting 194testing 194setting 195testing 195setting 196testing 196setting 197testing 197setting 198testing 198setting 199testing 199setting 200testing 200setting 201testing 201setting 202testing 202setting 203testing 203setting 204testing 204setting 205testing 205setting 206testing 206setting 207testing 207setting 208testing 208setting 209testing 209setting 210testing 210setting 211testing 211setting 212testing 212setting 213testing 213setting 214testing 214setting 215testing 215setting 216testing 216setting 217testing 217setting 218testing 218setting 219testing 219setting 220testing 220setting 221testing 221setting 222testing 222setting 223testing 223setting 224testing 224setting 225testing 225setting 226testing 226setting 227testing 227setting 228testing 228setting 229testing 229setting 230testing 230setting 231testing 231setting 232testing 232setting 233testing 233setting 234testing 234setting 235testing 235setting 236testing 236setting 237testing 237setting 238testing 238setting 239testing 239setting 240testing 240setting 241testing 241setting 242testing 242setting 243testing 243setting 244testing 244setting 245testing 245setting 246testing 246setting 247testing 247setting 248testing 248setting 249testing 249setting 250testing 250setting 251testing 251setting 252testing 252setting 253testing 253setting 254testing 254setting 255testing 255setting 256testing 256setting 257testing 257setting 258testing 258setting 259testing 259setting 260testing 260setting 261testing 261setting 262testing 262setting 263testing 263setting 264testing 264setting 265testing 265setting 266testing 266setting 267testing 267setting 268testing 268setting 269testing 269setting 270testing 270setting 271testing 271setting 272testing 272setting 273testing 273setting 274testing 274setting 275testing 275setting 276testing 276setting 277testing 277setting 278testing 278setting 279testing 279setting 280testing 280setting 281testing 281setting 282testing 282setting 283testing 283setting 284testing 284setting 285testing 285setting 286testing 286setting 287testing 287setting 288testing 288setting 289testing 289setting 290testing 290setting 291testing 291setting 292testing 292setting 293testing 293setting 294testing 294setting 295testing 295setting 296testing 296setting 297testing 297setting 298testing 298setting 299testing 299setting 300testing 300setting 301testing 301setting 302testing 302setting 303testing 303setting 304testing 304setting 305testing 305setting 306testing 306setting 307testing 307setting 308testing 308setting 309testing 309setting 310testing 310setting 311testing 311setting 312testing 312setting 313testing 313setting 314testing 314setting 315testing 315setting 316testing 316setting 317testing 317setting 318testing 318setting 319testing 319setting 320testing 320setting 321testing 321setting 322testing 322setting 323testing 323setting 324testing 324setting 325testing 325setting 326testing 326setting 327testing 327setting 328testing 328setting 329testing 329setting 330testing 330setting 331testing 331setting 332testing 332setting 333testing 333setting 334testing 334setting 335testing 335setting 336testing 336setting 337testing 337setting 338testing 338setting 339testing 339setting 340testing 340setting 341testing 341setting 342testing 342setting 343testing 343setting 344testing 344setting 345testing 345setting 346testing 346setting 347testing 347setting 348testing 348setting 349testing 349setting 350testing 350setting 351testing 351setting 352testing 352setting 353testing 353setting 354testing 354setting 355testing 355setting 356testing 356setting 357testing 357setting 358testing 358setting 359testing 359setting 360testing 360setting 361testing 361setting 362testing 362setting 363testing 363setting 364testing 364setting 365testing 365setting 366testing 366setting 367testing 367setting 368testing 368setting 369testing 369setting 370testing 370setting 371testing 371setting 372testing 372setting 373testing 373setting 374testing 374setting 375testing 375setting 376testing 376setting 377testing 377setting 378testing 378setting 379testing 379setting 380testing 380setting 381testing 381setting 382testing 382setting 383testing 383setting 384testing 384setting 385testing 385setting 386testing 386setting 387testing 387setting 388testing 388setting 389testing 389setting 390testing 390setting 391testing 391setting 392testing 392setting 393testing 393setting 394testing 394setting 395testing 395setting 396testing 396setting 397testing 397setting 398testing 398setting 399testing 399setting 400testing 400setting 401testing 401setting 402testing 402setting 403testing 403setting 404testing 404setting 405testing 405setting 406testing 406setting 407testing 407setting 408testing 408setting 409testing 409setting 410testing 410setting 411testing 411setting 412testing 412setting 413testing 413setting 414testing 414setting 415testing 415setting 416testing 416setting 417testing 417setting 418testing 418setting 419testing 419setting 420testing 420setting 421testing 421setting 422testing 422setting 423testing 423setting 424testing 424setting 425testing 425setting 426testing 426setting 427testing 427setting 428testing 428setting 429testing 429setting 430testing 430setting 431testing 431setting 432testing 432setting 433testing 433setting 434testing 434setting 435testing 435setting 436testing 436setting 437testing 437setting 438testing 438setting 439testing 439setting 440testing 440setting 441testing 441setting 442testing 442setting 443testing 443setting 444testing 444setting 445testing 445setting 446testing 446setting 447testing 447setting 448testing 448setting 449testing 449setting 450testing 450setting 451testing 451setting 452testing 452setting 453testing 453setting 454testing 454setting 455testing 455setting 456testing 456setting 457testing 457setting 458testing 458setting 459testing 459setting 460testing 460setting 461testing 461setting 462testing 462setting 463testing 463setting 464testing 464setting 465testing 465setting 466testing 466setting 467testing 467setting 468testing 468setting 469testing 469setting 470testing 470setting 471testing 471setting 472testing 472setting 473testing 473setting 474testing 474setting 475testing 475setting 476testing 476setting 477testing 477setting 478testing 478setting 479testing 479setting 480testing 480setting 481testing 481setting 482testing 482setting 483testing 483setting 484testing 484setting 485testing 485setting 486testing 486setting 487testing 487setting 488testing 488setting 489testing 489setting 490testing 490setting 491testing 491setting 492testing 492setting 493testing 493setting 494testing 494setting 495testing 495setting 496testing 496setting 497testing 497setting 498testing 498setting 499testing 499setting 500testing 500setting 501testing 501setting 502testing 502setting 503testing 503setting 504testing 504setting 505testing 505setting 506testing 506setting 507testing 507setting 508testing 508setting 509testing 509setting 510testing 510setting 511testing 511           ok
      Walking Ones        :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127           ok
      Walking Zeroes      :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112testing 112setting 113testing 113setting 114testing 114setting 115testing 115setting 116testing 116setting 117testing 117setting 118testing 118setting 119testing 119setting 120testing 120setting 121testing 121setting 122testing 122setting 123testing 123setting 124testing 124setting 125testing 125setting 126testing 126setting 127testing 127           ok
    Loop 2:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 3:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 4:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 5:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 6:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 7:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 8:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 9:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 10:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 11:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 12:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 13:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 14:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 15:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 16:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 17:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
    Loop 18:
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Bit Spread          :            setting   0testing   0setting   1testing   1setting   2testing   2setting   3testing   3setting   4testing   4setting   5testing   5setting   6testing   6setting   7testing   7setting   8testing   8setting   9testing   9setting  10testing  10setting  11testing  11setting  12testing  12setting  13testing  13setting  14testing  14setting  15testing  15setting  16testing  16setting  17testing  17setting  18testing  18setting  19testing  19setting  20testing  20setting  21testing  21setting  22testing  22setting  23testing  23setting  24testing  24setting  25testing  25setting  26testing  26setting  27testing  27setting  28testing  28setting  29testing  29setting  30testing  30setting  31testing  31setting  32testing  32setting  33testing  33setting  34testing  34setting  35testing  35setting  36testing  36setting  37testing  37setting  38testing  38setting  39testing  39setting  40testing  40setting  41testing  41setting  42testing  42setting  43testing  43setting  44testing  44setting  45testing  45setting  46testing  46setting  47testing  47setting  48testing  48setting  49testing  49setting  50testing  50setting  51testing  51setting  52testing  52setting  53testing  53setting  54testing  54setting  55testing  55setting  56testing  56setting  57testing  57setting  58testing  58setting  59testing  59setting  60testing  60setting  61testing  61setting  62testing  62setting  63testing  63setting  64testing  64setting  65testing  65setting  66testing  66setting  67testing  67setting  68testing  68setting  69testing  69setting  70testing  70setting  71testing  71setting  72testing  72setting  73testing  73setting  74testing  74setting  75testing  75setting  76testing  76setting  77testing  77setting  78testing  78setting  79testing  79setting  80testing  80setting  81testing  81setting  82testing  82setting  83testing  83setting  84testing  84setting  85testing  85setting  86testing  86setting  87testing  87setting  88testing  88setting  89testing  89setting  90testing  90setting  91testing  91setting  92testing  92setting  93testing  93setting  94testing  94setting  95testing  95setting  96testing  96setting  97testing  97setting  98testing  98setting  99testing  99setting 100testing 100setting 101testing 101setting 102testing 102setting 103testing 103setting 104testing 104setting 105testing 105setting 106testing 106setting 107testing 107setting 108testing 108setting 109testing 109setting 110testing 110setting 111testing 111setting 112test?
    U-Boot SPL 2023.04-dirty (Sep 12 2024 - 15:36:37 +0800)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    Trying to boot from MMC2
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Loading Environment from nowhere... OK
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    I/TC:
    I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2023.04-dirty (Sep 12 2024 - 15:36:30 +0800)
    U-Boot 2023.04-dirty (Sep 12 2024 - 15:36:30 +0800)
    SoC:   J721E SR1.1 GP
    Model: Texas Instruments J721E SK A72
    Board: J721EX-EAIK rev A1
    DRAM:  2 GiB
    Core:  121 devices, 34 uclasses, devicetree: separate
    Flash: 0 Bytes
    MMC:   mmc@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    1432 bytes read in 22 ms (63.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 21 ms (0 Bytes/s)
    Already setup.
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    Failed to load '/lib/firmware/j7-mcu-r5f0_1-fw'
    450240 bytes read in 35 ms (12.3 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 450240 bytes: Success!
    322804 bytes read in 31 ms (9.9 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 322804 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    998192 bytes read in 46 ms (20.7 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 998192 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 998192 bytes: Success!
    13504656 bytes read in 136 ms (94.7 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 13504656 bytes: Success!
    19376640 bytes read in 410 ms (45.1 MiB/s)
    103777 bytes read in 26 ms (3.8 MiB/s)
    Working FDT set to 88000000
    10434 bytes read in 24 ms (423.8 KiB/s)
       Loading Device Tree to 000000008fee3000, end 000000008fffffff ... OK
    Working FDT set to 8fee3000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024
    [    0.000000] Machine model: Texas Instruments J721E SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma': size 512 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fbc00000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 systemd.hostname=tda4vm-sk root=PARTUUID=a8f772c7-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 834104K/2097152K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 1230280K reserved, 32768K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008436] Console: colour dummy device 80x25
    [    0.013006] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023676] pid_max: default: 32768 minimum: 301
    [    0.028413] LSM: Security Framework initializing
    [    0.033190] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.040760] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.049607] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.057010] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.063271] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.070657] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.076970] rcu: Hierarchical SRCU implementation.
    [    0.081867] rcu: 	Max phase no-delay instances is 1000.
    [    0.087373] Platform MSI: msi-controller@1820000 domain created
    [    0.093659] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.103104] EFI services will not be available.
    [    0.107844] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.121074] Detected PIPT I-cache on CPU1
    [    0.121139] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.121153] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.121190] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.121246] smp: Brought up 1 node, 2 CPUs
    [    0.150591] SMP: Total of 2 processors activated.
    [    0.155396] CPU features: detected: 32-bit EL0 Support
    [    0.160650] CPU features: detected: CRC32 instructions
    [    0.165925] CPU: All CPU(s) started at EL2
    [    0.170107] alternatives: applying system-wide alternatives
    [    0.176733] devtmpfs: initialized
    [    0.186446] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.196435] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.204087] pinctrl core: initialized pinctrl subsystem
    [    0.209728] DMI not present or invalid.
    [    0.213975] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.220615] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.227876] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.235843] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.243969] audit: initializing netlink subsys (disabled)
    [    0.249599] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.249826] thermal_sys: Registered thermal governor 'step_wise'
    [    0.257519] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.263731] cpuidle: using governor menu
    [    0.274486] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.281451] ASID allocator initialised with 65536 entries
    [    0.296219] KASLR disabled due to lack of seed
    [    0.303623] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.310565] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.316967] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.323901] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.330302] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.337235] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.343635] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.350568] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.357684] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.366881] iommu: Default domain type: Translated
    [    0.371868] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.378390] SCSI subsystem initialized
    [    0.382386] usbcore: registered new interface driver usbfs
    [    0.388008] usbcore: registered new interface driver hub
    [    0.393442] usbcore: registered new device driver usb
    [    0.398810] pps_core: LinuxPPS API ver. 1 registered
    [    0.403882] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.413219] PTP clock support registered
    [    0.417294] EDAC MC: Ver: 3.0.0
    [    0.420991] FPGA manager framework
    [    0.424500] Advanced Linux Sound Architecture Driver Initialized.
    [    0.431137] clocksource: Switched to clocksource arch_sys_counter
    [    0.437477] VFS: Disk quotas dquot_6.6.0
    [    0.441508] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.451525] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.457822] NET: Registered PF_INET protocol family
    [    0.462947] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.471372] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.480118] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.488041] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.496192] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.504238] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.510986] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.517868] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.525286] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.531356] RPC: Registered named UNIX socket transport module.
    [    0.537408] RPC: Registered udp transport module.
    [    0.542211] RPC: Registered tcp transport module.
    [    0.547013] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.553597] NET: Registered PF_XDP protocol family
    [    0.558498] PCI: CLS 0 bytes, default 64
    [    0.562852] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.571967] Initialise system trusted keyrings
    [    0.576632] workingset: timestamp_bits=46 max_order=18 bucket_order=0
    [    0.585222] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.591479] NFS: Registering the id_resolver key type
    [    0.596665] Key type id_resolver registered
    [    0.600936] Key type id_legacy registered
    [    0.605051] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.611900] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.638914] Key type asymmetric registered
    [    0.643100] Asymmetric key parser 'x509' registered
    [    0.648111] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.655751] io scheduler mq-deadline registered
    [    0.660383] io scheduler kyber registered
    [    0.666637] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.673015] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.682570] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.690915] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.699178] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.706328] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.714359] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.725468] loop: module loaded
    [    0.729409] megasas: 07.719.03.00-rc1
    [    0.734628] tun: Universal TUN/TAP device driver, 1.6
    [    0.740173] VFIO - User Level meta-driver version: 0.3
    [    0.745834] usbcore: registered new interface driver usb-storage
    [    0.752288] i2c_dev: i2c /dev entries driver
    [    0.757204] sdhci: Secure Digital Host Controller Interface driver
    [    0.763530] sdhci: Copyright(c) Pierre Ossman
    [    0.768080] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.774175] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.780397] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.787130] usbcore: registered new interface driver usbhid
    [    0.792827] usbhid: USB HID core driver
    [    0.797239] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.801796] optee: revision 4.1 (012cdca4)
    [    0.818214] optee: dynamic shared memory is enabled
    [    0.827599] optee: initialized driver
    [    0.832545] Initializing XFRM netlink socket
    [    0.836933] NET: Registered PF_PACKET protocol family
    [    0.842134] Key type dns_resolver registered
    [    0.846672] registered taskstats version 1
    [    0.850873] Loading compiled-in X.509 certificates
    [    0.861705] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    [    0.917840] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.947296] i2c i2c-1: Added multiplexed i2c bus 2
    [    0.952281] i2c i2c-1: Added multiplexed i2c bus 3
    [    0.957179] pca954x 1-0071: registered 2 multiplexed busses for I2C switch pca9543
    [    0.964937] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.970933] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
    [    0.999293] i2c i2c-5: Added multiplexed i2c bus 6
    [    1.004271] i2c i2c-5: Added multiplexed i2c bus 7
    [    1.009169] pca954x 5-0070: registered 2 multiplexed busses for I2C switch pca9543
    [    1.016924] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.022964] omap_i2c 2050000.i2c: bus 8 rev0.12 at 400 kHz
    [    1.028770] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    1.037313] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    1.046649] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    1.055252] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.071997] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.081889] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.088648] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.097801] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.107964] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.114722] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.122693] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 193, base_baud = 6000000) is a 8250
    [    1.132160] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 194, base_baud = 3000000) is a 8250
    [    1.141009] printk: console [ttyS2] enabled
    [    1.149452] printk: bootconsole [ns16550a0] disabled
    [    1.159883] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 195, base_baud = 3000000) is a 8250
    [    1.169776] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.215145] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.223825] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.232096] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.244904] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.252109] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.258411] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.268801] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.282913] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.289745] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.296544] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.303344] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.310121] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.324227] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.334923] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.349317] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.354348] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
    [    1.361385] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.366856] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.372922] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.378686] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.384534] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.390115] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.395879] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    1.402072] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.407928] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.418518] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.463143] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.471824] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.480097] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.492902] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.500110] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.506350] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.516787] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.525336] mmc1: CQHCI version 5.10
    [    1.536811] ALSA device list:
    [    1.539783]   No soundcards found.
    [    1.567680] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.575259] Waiting for root device PARTUUID=a8f772c7-02...
    [    1.627390] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.634337] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
    [    1.643276]  mmcblk1: p1 p2
    [    1.722923] EXT4-fs (mmcblk1p2): recovery complete
    [    1.728601] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.737153] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.747167] devtmpfs: mounted
    [    1.751239] Freeing unused kernel memory: 1984K
    [    1.755844] Run /sbin/init as init process
    [    1.975878] systemd[1]: System time before build time, advancing clock.
    [    2.028357] NET: Registered PF_INET6 protocol family
    [    2.033896] Segment Routing with IPv6
    [    2.037576] In-situ OAM (IOAM) with IPv6
    [    2.066764] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    2.098162] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    2.159273] systemd[1]: Hostname set to <tda4vm-sk>.
    [    2.251689] systemd-sysv-generator[143]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.276436] systemd-sysv-generator[143]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.434630] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.478413] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.529874] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.568470] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    2.592580] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    2.616506] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    2.640238] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    2.663371] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password ?宇s to Console Directory Watch.
    [    2.687280] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R?守ests to Wall Directory Watch.
    [    2.711338] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    2.727222] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    2.747192] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    2.763199] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    2.809845] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    2.831299] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    2.856058] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    2.879404] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    2.903559] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    2.923455] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    2.943470] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    2.963538] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    2.987514] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.007384] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.027431] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.071592] systemd[1]: Mounting Huge Pages File System...
    [    3.093827] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.139441] systemd[1]: Mounting Kernel Debug File System...
    [    3.159408] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.177328] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.215595] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.241837] systemd[1]: Starting Load Kernel Module configfs...
    [    3.265930] systemd[1]: Starting Load Kernel Module drm...
    [    3.290139] systemd[1]: Starting Load Kernel Module fuse...
    [    3.303933] fuse: init (API version 7.37)
    [    3.339779] systemd[1]: Starting Start psplash boot splash screen...
    [    3.373246] systemd[1]: Starting RPC Bind...
    [    3.391387] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    3.407655] systemd[1]: Starting Journal Service...
    [    3.434406] systemd[1]: Starting Load Kernel Modules...
    [    3.454239] cryptodev: loading out-of-tree module taints kernel.
    [    3.461189] cryptodev: driver 1.12 loaded.
    [    3.475823] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network ?宇s from Kernel command line...
    [    3.502442] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.518836] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    3.528403] systemd[1]: Starting Coldplug All udev Devices...
    [    3.556221] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.575683] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star?如rogress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...[    3.928804] systemd-journald[158]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
    [    4.149600] audit: type=1334 audit(1651167747.172:2): prog-id=5 op=LOAD
    [    4.156536] audit: type=1334 audit(1651167747.180:3): prog-id=6 op=LOAD
             Starting Rule-based Manage?圩or Device Events and Files...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [    4.642906] random: crng init done
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [    4.697839] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    4.708688] j721e-pcie-host 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [  OK  ] Listening on D-Bus System Message B[    4.719084] j721e-pcie-host 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    us Socket.
    [    4.732816] j721e-pcie-host 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
             Starting Docker Socket for the API...
    [    4.755056] mc: Linux media interface: v0.10
    [    4.772220] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [  OK  ] Listening on dropbear.socket.
    [    4.786516] videodev: Linux video capture interface: v2.00
    [    4.793931] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [  OK  ] Listening on PC/SC Smart Card Daemo[    4.801228] remoteproc remoteproc0: 4d80800000.dsp is available
    n Activation Socket.
    [    4.813064] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    4.821472] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    4.828950] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    4.840622] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    4.846237] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    4.853431] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    4.861471] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    4.869271] k3-dsp-rproc 4d80800000.dsp: register pm nitifiers in remoteproc mode
             Starting Weston socket...
    [    4.880179] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    4.895384] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    4.903440] remoteproc remoteproc1: 4d81800000.dsp is available
             Starting D-Bus System Message Bus...[    4.910062] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [    4.920911] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    4.927732] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    4.938476] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    4.942029] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    4.944090] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [    4.958696] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
    [    4.966467] k3-dsp-rproc 4d81800000.dsp: register pm nitifiers in remoteproc mode
    [    4.975304] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
             Starting Reboot and dump vmcore via kexec.[    4.989464] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    4.997322] remoteproc remoteproc2: 64800000.dsp is available
    [    5.003306] remoteproc remoteproc2: attaching to 64800000.dsp
    [    5.009308] remoteproc remoteproc2: unsupported resource 65538
    [    5.015263] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    5.021938] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [  OK  ] Finished Load/Save Random Seed.[    5.033110] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.034971] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    5.044426] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [    5.057147] remoteproc remoteproc2: remote processor 64800000.dsp is now attached
    [    5.066757] k3-dsp-rproc 64800000.dsp: register pm nitifiers in remoteproc mode
    [  OK  ] Listening on Docker Socket for the API.
    [    5.088023] PVR_K:  187: Device: 4e20000000.gpu
    [  OK  ] Listening on Weston socket.[    5.098486] PVR_K:  187: Read BVNC 22.104.208.318 from HW device registers
    [    5.107940] PVR_K:  187: RGX Device registered with BVNC 22.104.208.318
    [    5.116002] [drm] Initialized pvr 23.3.6512818 20170530 for 4e20000000.gpu on minor 0
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [    5.131258] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [  OK  ] Found device /dev/ttyS2.[    5.144544] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    5.149495] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [  OK  ] Reached target Socket Units.
    [    5.179841] cdns-mhdp8546 a000000.dp-bridge: invalid resource
    [    5.188324] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
             Starting DEMO...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Update pmic regis?圩ety feature on power rails...
             Starting Expand the rootfs?奸l size of the boot device....
    [  OK  ] Started strongSwan IPsec I?匈KEv2 daemon using ipsec.conf.
    [    5.399323] audit: type=1334 audit(1651170831.512:4): prog-id=7 op=LOAD
             Starting User Login Management...
    [    5.412607] audit: type=1334 audit(1651170831.512:5): prog-id=8 op=LOAD
    [  OK  ] Started TEE Supplicant.
             Starting Telnet Server...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [  OK  ] Finished Telnet Server.
    [  OK  ] Started DEMO.
    [  OK  ] Started Telephony service.
    [    5.660365] Bluetooth: Core ver 2.22
    [    5.664049] NET: Registered PF_BLUETOOTH protocol family
    [    5.675230] Bluetooth: HCI device and connection manager initialized
    [    5.687351] Bluetooth: HCI socket layer initialized
    [    5.698417] Bluetooth: L2CAP socket layer initialized
    [    5.706767] Bluetooth: SCO socket layer initialized
    [    5.725109] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Finished Update pmic regis?存afety feature on power rails.
    [    5.788886] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00
    [    5.796172] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.803183] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    5.805688] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    5.828617] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    5.838744] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    5.846047] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    5.860375] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    5.870474] pci 0000:00:00.0: supports D1
    [    5.874984] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [  OK  ] Finished Expand the rootfs?圩ull size of the boot device..
    [    5.944506] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [  OK  ] Started User Login Management.
    [    5.967207] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    6.006201] pci 0000:00:00.0: PCI bridge to [bus 01]
    [  OK  ] Started Network Configuration.
    [    6.012336] pcieport 0000:00:00.0: PME: Signaling with IRQ 630
             Starting Network Name Resolution...
    [    6.051847] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    6.075656] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    6.092390] pcieport 0000:00:00.0: AER: enabled with IRQ 630
    [    6.099377] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.120020] platform 41000000.r5f: configured R5F for IPC-only mode
    [    6.130193] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.142221] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.150871] j721e-pcie-host 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.159752] j721e-pcie-host 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.168640] j721e-pcie-host 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.200827] remoteproc remoteproc3: 41000000.r5f is available
    [    6.210114] remoteproc remoteproc3: attaching to 41000000.r5f
    [    6.217542] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    6.269873] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.293265] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.309301] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.318532] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    6.326564] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [    6.337161] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [    6.345885] platform 41400000.r5f: configured R5F for remoteproc mode
    [    6.353137] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [    6.366849] remoteproc remoteproc4: 41400000.r5f is available
    [    6.377997] remoteproc remoteproc4: loading /lib/firmware/j7-mcu-r5f0_1-fw failed with error -22
    [    6.388081] remoteproc remoteproc4: Direct firmware load for j7-mcu-r5f0_1-fw failed with error -22
    [  OK  ] Started Network Name Resolution[    6.400538] remoteproc remoteproc4: powering up 41400000.r5f
    [  OK  ] Reached target Network.
    [[[    6.408742] remoteproc remoteproc4: loading /lib/firmware/j7-mcu-r5f0_1-fw failed with error -22
    0;32m  OK  ] Reached target Host and Network Name L[    6.424261] remoteproc remoteproc4: Direct firmware load for j7-mcu-r5f0_1-fw failed with error -22
    ookups.
             Starting Avahi mDNS/DNS-SD Stack...
    [    6.439748] remoteproc remoteproc4: request_firmware failed: -22
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma?圯nt Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland?她sitor, as a system service...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Start[    6.629516] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    ed Avahi mDNS/DNS-SD Stack.
    [    6.646261] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    6.659293] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    6.665722] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    6.843117] audit: type=1334 audit(1651170832.956:6): prog-id=9 op=LOAD
    [    6.852931] audit: type=1334 audit(1651170832.968:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    [  OK  ] Started User Database Manager.
    [    7.159862] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [  OK  ] Created slice User Slice of UID 1000.
    [    7.183293] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0001:00
    [    7.190380] pci_bus 0001:00: root bus resource [bus 00-ff]
             Starting User Runtime Directory /run/user/1000[    7.196359] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    7.211857] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    7.218982] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    7.225315] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    7.235715] pci 0001:00:00.0: supports D1
    [    7.241297] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    7.250839] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [  OK  ] Finished User Runtime Directory /ru[    7.259756] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    n/user/1000.
    [    7.274433] pci 0001:00:00.0: PCI bridge to [bus 01]
             Starting User Manager for UID 1000...
    [    7.281831] pcieport 0001:00:00.0: PME: Signaling with IRQ 640
    [    7.291079] pcieport 0001:00:00.0: AER: enabled with IRQ 640
    [    7.321708] audit: type=1006 audit(1651170833.436:8): pid=555 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    7.344521] remoteproc remoteproc5: b034000.pru is available
    [    7.349983] audit: type=1300 audit(1651170833.436:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd1dfc708 a2=4 a3=ffffb1d21020 items=0 ppid=1 pid=555 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    7.353842] remoteproc remoteproc6: b004000.rtu is available
    [    7.378657] audit: type=1327 audit(1651170833.436:8): proctitle="(systemd)"
    [    7.385570] remoteproc remoteproc7: b00a000.txpru is available
    [    7.395634] remoteproc remoteproc8: b038000.pru is available
    [    7.401988] remoteproc remoteproc9: b006000.rtu is available
    [    7.408541] remoteproc remoteproc10: b00c000.txpru is available
    [    7.415548] remoteproc remoteproc11: b134000.pru is available
    [    7.421887] remoteproc remoteproc12: b104000.rtu is available
    [    7.428495] remoteproc remoteproc13: b10a000.txpru is available
    [    7.435291] remoteproc remoteproc14: b138000.pru is available
    [    7.441965] remoteproc remoteproc15: b106000.rtu is available
    [    7.448948] remoteproc remoteproc16: b10c000.txpru is available
    [  OK  ] Listening on Load/Save RF ?夷tch Status /dev/rfkill Watch.
    [    7.613546] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [    7.677616] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User wes[    7.864405] audit: type=1006 audit(1651170833.980:9): pid=452 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    ton.
    [    7.880105] audit: type=1300 audit(1651170833.980:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd1dfc708 a2=4 a3=ffffb1d21020 items=0 ppid=1 pid=452 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [    7.907030] audit: type=1327 audit(1651170833.980:9): proctitle="(weston)"
    [    8.011341] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    8.016907] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [    8.024727] xhci-hcd xhci-hcd.4.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [    8.034250] xhci-hcd xhci-hcd.4.auto: irq 657, io mem 0x06410000
    [    8.040419] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    8.045937] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
    [    8.053611] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
    [    8.061144] hub 1-0:1.0: USB hub found
    [    8.064969] hub 1-0:1.0: 1 port detected
    [    8.069781] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [  OK  ] Created slice Slice /system/systemd[    8.078980] hub 2-0:1.0: USB hub found
    -fsck.
    [    8.087375] hub 2-0:1.0: 1 port detected
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Started Simple Network Man?圯ment Protocol (SNMP) Daemon..
    [    8.383177] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: Timed out waiting for 41400000.r5f core to power up!
    [    8.397157] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    8.404076] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    8.414342] remoteproc remoteproc17: 5c00000.r5f is available
    [    8.420833] remoteproc remoteproc17: attaching to 5c00000.r5f
    [    8.428137] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    8.434876] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    8.446264] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    8.450620] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    8.451850] rproc-virtio rproc-virtio.5.auto: registered virtio4 (type 7)
    [    8.465624] remoteproc remoteproc17: remote processor 5c00000.r5f is now attached
    [    8.473383] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    8.479889] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    8.490157] remoteproc remoteproc18: 5d00000.r5f is available
    [    8.495981] remoteproc remoteproc18: attaching to 5d00000.r5f
    [    8.502633] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    8.509355] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    8.520198] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    8.524527] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    8.525830] rproc-virtio rproc-virtio.6.auto: registered virtio5 (type 7)
    [    8.539596] remoteproc remoteproc18: remote processor 5d00000.r5f is now attached
    [    8.539917] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    8.556335] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    8.564242] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.572084] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    8.573101] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.586411] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    8.586710] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    8.596792] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.607686] remoteproc remoteproc19: 5e00000.r5f is available
    [    8.611865] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    8.616452] remoteproc remoteproc19: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [    8.627038] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.632297] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [    8.645172] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    8.649153] remoteproc remoteproc19: powering up 5e00000.r5f
    [    8.658305] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.662020] remoteproc remoteproc19: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [    8.678280] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [    8.687710] remoteproc remoteproc19: request_firmware failed: -22
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/BOOT-mmcblk1p1...
    [    8.827180] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    8.972278] PVR_K:  452: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [    8.980080] hub 1-1:1.0: USB hub found
    [    8.984548] hub 1-1:1.0: 4 ports detected
    [    8.999452] PVR_K:  452: Shader binary image 'rgx.sh.22.104.208.318' loaded
    [  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
    [    9.107267] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [    9.132038] hub 2-1:1.0: USB hub found
    [    9.135911] hub 2-1:1.0: 4 ports detected
    [  OK  ] Started Weston, a Wayland ?妃positor, as a system service.
             Starting EdgeAI OOB demos...
             Stopping Weston, a Wayland?她sitor, as a system service...
    [  OK  ] Stopped Weston, a Wayland ?妃positor, as a system service.
    [  OK  ] Started containerd container runtime.
    [  OK  ] Started EdgeAI OOB demos.
    [   10.655173] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
    [   11.048454] audit: type=1701 audit(1651170837.164:10): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=733 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
    [  OK  ] Created slice Slice /system/systemd[   11.071754] audit: type=1334 audit(1651170837.184:11): prog-id=11 op=LOAD
    -coredump.
    [   11.081202] audit: type=1334 audit(1651170837.184:12): prog-id=12 op=LOAD
    [  OK  ] Started Process Core Dump (PID 825/UID 0).
    [   11.559453] audit: type=1334 audit(1651170837.676:13): prog-id=12 op=UNLOAD
    [   11.567566] audit: type=1334 audit(1651170837.676:14): prog-id=11 op=UNLOAD
    NOTICE: This file system contains the following GPL-3.0 packages:
    	adwaita-icon-theme-symbolic
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gnu-config
    	grub-common
    	grub-editenv
    	grub-efi
    	gzip
    	hidapi
    	less
    	libasm1
    	libatomic-dev
    	libatomic1
    	libbfd
    	libdebuginfod1
    	libdw1
    	libeigen-dev
    	libelf1
    	libgcc-s-dev
    	libgcc1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libopcodes
    	libqt5charts-examples
    	libqt5charts-plugins
    	libqt5charts-qmlplugins
    	libqt5charts5
    	libqt5sensors-plugins
    	libqt5sensors-qmlplugins
    	libqt5sensors5
    	libqt5serialport-examples
    	libqt5serialport-plugins
    	libqt5serialport-qmlplugins
    	libqt5serialport5
    	libqt5svg-examples
    	libqt5svg-plugins
    	libqt5svg-qmlplugins
    	libqt5svg5
    	libqt5virtualkeyboard-plugins
    	libqt5virtualkeyboard-qmlplugins
    	libqt5virtualkeyboard5
    	libqt5webchannel-plugins
    	libqt5webchannel-qmlplugins
    	libqt5webchannel5
    	libreadline-dev
    	libreadline8
    	libstdc++-dev
    	libstdc++6
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle
    	parted
    	piglit
    	qt3d-plugins
    	qt3d-qmlplugins
    	qt3d
    	qtbase-examples
    	qtbase-plugins
    	qtbase-qmlplugins
    	qtbase
    	qtconnectivity-plugins
    	qtconnectivity-qmlplugins
    	qtconnectivity
    	qtdeclarative-plugins
    	qtdeclarative-qmlplugins
    	qtdeclarative-tools
    	qtdeclarative
    	qtgraphicaleffects-qmlplugins
    	qtlocation-examples
    	qtlocation-plugins
    	qtlocation-qmlplugins
    	qtlocation
    	qtmultimedia-examples
    	qtmultimedia-plugins
    	qtmultimedia-qmlplugins
    	qtmultimedia
    	qtquick3d-plugins
    	qtquick3d-qmlplugins
    	qtquick3d
    	qtquics-qmlplugins.control
    	qtquics2-plugins.control
    	qtquics2-qmlplugins.control
    	qtquics2.control
    	qtscript-examples
    	qtscript-plugins
    	qtscript-qmlplugins
    	qtscript
    	qtwayland-examples
    	qtwayland-plugins
    	qtwayland-qmlplugins
    	qtwayland
    	tar
    	which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project tda4vm-sk -
    Arago 2023.10 tda4vm-sk -
    tda4vm-sk login:
  • We are enaging our DRAM product on J7 series platform, but we met some problem.
    Are you using a different DRAM? If yes which DDR part is being used?
    Have you changed the DDR config accordingly.
    - Keerthy
  • Hi Keerthy,
    I haven't changed to other DRAM, just using Micron part and default DDR setting.
    As you can see in log, there's no error meeage when system auto reboot.
    Thanks.
    Maurice
  • Hello Maurice,
    I haven't observed this on the EVM. Just want to confirm if there was any other changes in the software or default WIC images from 9.2 SDK were used?
    Keerthy
  • Hi Keerthy,
    No we didn't change anything.
    Should we send the EVM to you to help us check again?
    Thanks.
    Maurice
