AM625: Delay in calling IIO_Trigger_Handler function for shared-edge triggered interrupts
Part Number: AM625
Other Parts Discussed in Thread: PMP, DP83TC811, DP83869, TCA6416, TCA8418, LM8323, LM8333, ADS7846, TSC2004, TSC2005, TSC2007, TPS65219, PCF8574, DRV2665, DRV2667, TPIC2810, LP8727, BQ24190, BQ24257, BQ24735, BQ25890, BQ25980, TPS23861, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95234, LM95241, LM95245, ADC128D818, ADS7828, ADS7871, AMC6821, INA209, INA238, INA3221, TMP102, TMP103, TMP108, TMP401, TMP421, TMP464, TMP513, LP3943, TPS65010, TPS65086, TPS65090, TPS65217, TPS65218, TPS65910, TPS65912, TWL6040, LM3533, LP3971, LP3972, TPS51632, TPS62360, TPS65023, TPS65132, LM3560, TLV320AIC23B, TVP5150, TVP7002, THS8200, THS7303, DLPC3433, TFP410, SN65DSI83, SN65DSI86, TPD12S015, LM3630A, LM3639, PCM1681, PCM1789, PCM3060, PCM3168A, PCM5102A, TAS2552, TAS2562, TAS2764, TAS2770, TAS2780, TAS5086, TAS5805M, TAS6424, TLV320AIC23, TS3A227E, TPA6130A2, HD3SS3220, LM3530, LM3532, LM3642, LP3944, DAC124S085, TCA6507, LMK04832, CDCE706, CDCE925, TUSB320, ADC084S021, ADC108S102, ADC128S052, ADC161S626, ADS1015, ADS7950, ADS8344, ADS8688, ADS124S08, ADS131E08, TLC4541, TSC2046, DAC082S085, DAC5571, DAC7311, DAC7612, AFE4403, AFE4404, HDC2010, OPT3001, LMP91000, TMP006, TMP007, TMP117, TUSB1210, CSD
Hi Team,
We are interfacing 2 ADCs(ADAS1000 chips) to Main SPI channel of AM625 using different chip select lines. We have modified the adas1000 driver for edge trigger and the chip configurations are fine.
We see that the IIO_Handler is getting called after 4ms delay. Attached is the kernel configuration of AM625 processor.
Request to verify the kernel config for fast IIO_Handler response and provide suggestion to reduce the delay to 20-30 us.
  • Hi Akshay, sending this to one of our experts. In the meantime, could you please re-attach kernel configuration? I don't see it. Also, which Linux SDK version are you using?
    thank you,
    Paula
  • Hi ,
    Thanks for your quick response.
    Would like to provide more info on hardware, we are using toradex Verdin SOM, which uses Am625 processor. The SDK version is 6.1.80-6.7.0-devel+git.79fe3839eaae
    Sorry, our IT team has blocked any file upload.
    Please find the configuration below -
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm64 6.1.80 Kernel Configuration
    CONFIG_CC_VERSION_TEXT="aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 12.3.Rel1 (Build arm-12.35)) 12.3.1 20230626"
    CONFIG_CC_IS_GCC=y
    CONFIG_GCC_VERSION=120301
    CONFIG_CLANG_VERSION=0
    CONFIG_AS_IS_GNU=y
    CONFIG_AS_VERSION=24000
    CONFIG_LD_IS_BFD=y
    CONFIG_LD_VERSION=24000
    CONFIG_LLD_VERSION=0
    CONFIG_CC_CAN_LINK=y
    CONFIG_CC_CAN_LINK_STATIC=y
    CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
    CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
    CONFIG_GCC_ASM_GOTO_OUTPUT_WORKAROUND=y
    CONFIG_CC_HAS_ASM_INLINE=y
    CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
    CONFIG_PAHOLE_VERSION=0
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_TABLE_SORT=y
    CONFIG_THREAD_INFO_IN_TASK=y
    # General setup
    CONFIG_INIT_ENV_ARG_LIMIT=32
    # CONFIG_COMPILE_TEST is not set
    # CONFIG_WERROR is not set
    CONFIG_LOCALVERSION="-6.7.0-devel"
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_BUILD_SALT=""
    CONFIG_DEFAULT_INIT=""
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_SYSVIPC_COMPAT=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    # CONFIG_WATCH_QUEUE is not set
    CONFIG_CROSS_MEMORY_ATTACH=y
    # CONFIG_USELIB is not set
    CONFIG_AUDIT=y
    CONFIG_HAVE_ARCH_AUDITSYSCALL=y
    CONFIG_AUDITSYSCALL=y
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
    CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
    CONFIG_GENERIC_IRQ_MIGRATION=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_IRQ_DOMAIN=y
    CONFIG_IRQ_DOMAIN_HIERARCHY=y
    CONFIG_GENERIC_IRQ_IPI=y
    CONFIG_GENERIC_MSI_IRQ=y
    CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
    CONFIG_IRQ_MSI_IOMMU=y
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    # CONFIG_GENERIC_IRQ_DEBUGFS is not set
    # end of IRQ subsystem
    CONFIG_GENERIC_TIME_VSYSCALL=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_ARCH_HAS_TICK_BROADCAST=y
    CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
    CONFIG_HAVE_POSIX_CPU_TIMERS_TASK_WORK=y
    CONFIG_POSIX_CPU_TIMERS_TASK_WORK=y
    CONFIG_CONTEXT_TRACKING=y
    CONFIG_CONTEXT_TRACKING_IDLE=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    # CONFIG_NO_HZ_FULL is not set
    # CONFIG_NO_HZ is not set
    CONFIG_HIGH_RES_TIMERS=y
    # end of Timers subsystem
    CONFIG_BPF=y
    CONFIG_HAVE_EBPF_JIT=y
    CONFIG_ARCH_WANT_DEFAULT_BPF_JIT=y
    # BPF subsystem
    CONFIG_BPF_SYSCALL=y
    CONFIG_BPF_JIT=y
    # CONFIG_BPF_JIT_ALWAYS_ON is not set
    CONFIG_BPF_JIT_DEFAULT_ON=y
    CONFIG_BPF_UNPRIV_DEFAULT_OFF=y
    # CONFIG_BPF_PRELOAD is not set
    # end of BPF subsystem
    CONFIG_PREEMPT_BUILD=y
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_PREEMPT_COUNT=y
    CONFIG_PREEMPTION=y
    # CONFIG_PREEMPT_DYNAMIC is not set
    # CONFIG_SCHED_CORE is not set
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
    CONFIG_IRQ_TIME_ACCOUNTING=y
    CONFIG_HAVE_SCHED_AVG_IRQ=y
    CONFIG_SCHED_THERMAL_PRESSURE=y
    CONFIG_BSD_PROCESS_ACCT=y
    CONFIG_BSD_PROCESS_ACCT_V3=y
    CONFIG_TASKSTATS=y
    # CONFIG_TASK_DELAY_ACCT is not set
    CONFIG_TASK_XACCT=y
    CONFIG_TASK_IO_ACCOUNTING=y
    # CONFIG_PSI is not set
    # end of CPU/Task time and stats accounting
    CONFIG_CPU_ISOLATION=y
    # RCU Subsystem
    CONFIG_TREE_RCU=y
    CONFIG_PREEMPT_RCU=y
    # CONFIG_RCU_EXPERT is not set
    CONFIG_SRCU=y
    CONFIG_TREE_SRCU=y
    CONFIG_TASKS_RCU_GENERIC=y
    CONFIG_TASKS_RCU=y
    CONFIG_TASKS_TRACE_RCU=y
    CONFIG_RCU_STALL_COMMON=y
    CONFIG_RCU_NEED_SEGCBLIST=y
    # end of RCU Subsystem
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    # CONFIG_IKHEADERS is not set
    CONFIG_LOG_BUF_SHIFT=17
    CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
    CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
    # CONFIG_PRINTK_INDEX is not set
    CONFIG_GENERIC_SCHED_CLOCK=y
    # Scheduler features
    # CONFIG_UCLAMP_TASK is not set
    # end of Scheduler features
    CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y
    CONFIG_CC_HAS_INT128=y
    CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5"
    CONFIG_GCC11_NO_ARRAY_BOUNDS=y
    CONFIG_CC_NO_ARRAY_BOUNDS=y
    CONFIG_ARCH_SUPPORTS_INT128=y
    CONFIG_CGROUPS=y
    CONFIG_PAGE_COUNTER=y
    # CONFIG_CGROUP_FAVOR_DYNMODS is not set
    CONFIG_MEMCG=y
    CONFIG_MEMCG_KMEM=y
    CONFIG_BLK_CGROUP=y
    CONFIG_CGROUP_WRITEBACK=y
    CONFIG_CGROUP_SCHED=y
    CONFIG_FAIR_GROUP_SCHED=y
    CONFIG_CFS_BANDWIDTH=y
    # CONFIG_RT_GROUP_SCHED is not set
    CONFIG_CGROUP_PIDS=y
    # CONFIG_CGROUP_RDMA is not set
    CONFIG_CGROUP_FREEZER=y
    CONFIG_CGROUP_HUGETLB=y
    CONFIG_CPUSETS=y
    CONFIG_PROC_PID_CPUSET=y
    CONFIG_CGROUP_DEVICE=y
    CONFIG_CGROUP_CPUACCT=y
    CONFIG_CGROUP_PERF=y
    CONFIG_CGROUP_BPF=y
    # CONFIG_CGROUP_MISC is not set
    # CONFIG_CGROUP_DEBUG is not set
    CONFIG_SOCK_CGROUP_DATA=y
    CONFIG_NAMESPACES=y
    CONFIG_UTS_NS=y
    CONFIG_TIME_NS=y
    CONFIG_IPC_NS=y
    CONFIG_USER_NS=y
    CONFIG_PID_NS=y
    CONFIG_NET_NS=y
    # CONFIG_CHECKPOINT_RESTORE is not set
    CONFIG_SCHED_AUTOGROUP=y
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    CONFIG_RD_BZIP2=y
    CONFIG_RD_LZMA=y
    CONFIG_RD_XZ=y
    CONFIG_RD_LZO=y
    CONFIG_RD_LZ4=y
    CONFIG_RD_ZSTD=y
    # CONFIG_BOOT_CONFIG is not set
    CONFIG_INITRAMFS_PRESERVE_MTIME=y
    CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
    # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
    CONFIG_LD_ORPHAN_WARN=y
    CONFIG_SYSCTL=y
    CONFIG_HAVE_UID16=y
    CONFIG_SYSCTL_EXCEPTION_TRACE=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    CONFIG_MULTIUSER=y
    # CONFIG_SGETMASK_SYSCALL is not set
    CONFIG_SYSFS_SYSCALL=y
    CONFIG_FHANDLE=y
    CONFIG_POSIX_TIMERS=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_FUTEX_PI=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_IO_URING=y
    CONFIG_ADVISE_SYSCALLS=y
    CONFIG_MEMBARRIER=y
    CONFIG_KALLSYMS=y
    CONFIG_KALLSYMS_ALL=y
    CONFIG_KALLSYMS_BASE_RELATIVE=y
    CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
    CONFIG_KCMP=y
    CONFIG_RSEQ=y
    # CONFIG_DEBUG_RSEQ is not set
    CONFIG_EMBEDDED=y
    CONFIG_HAVE_PERF_EVENTS=y
    # CONFIG_PC104 is not set
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    # end of Kernel Performance Events And Counters
    CONFIG_SYSTEM_DATA_VERIFICATION=y
    CONFIG_PROFILING=y
    # end of General setup
    CONFIG_ARM64=y
    CONFIG_GCC_SUPPORTS_DYNAMIC_FTRACE_WITH_REGS=y
    CONFIG_64BIT=y
    CONFIG_MMU=y
    CONFIG_ARM64_PAGE_SHIFT=12
    CONFIG_ARM64_CONT_PTE_SHIFT=4
    CONFIG_ARM64_CONT_PMD_SHIFT=4
    CONFIG_ARCH_MMAP_RND_BITS_MIN=18
    CONFIG_ARCH_MMAP_RND_BITS_MAX=33
    CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11
    CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16
    CONFIG_NO_IOPORT_MAP=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CSUM=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_ARCH_MHP_MEMMAP_ON_MEMORY_ENABLE=y
    CONFIG_SMP=y
    CONFIG_KERNEL_MODE_NEON=y
    CONFIG_FIX_EARLYCON_MEM=y
    CONFIG_PGTABLE_LEVELS=4
    CONFIG_ARCH_SUPPORTS_UPROBES=y
    CONFIG_ARCH_PROC_KCORE_TEXT=y
    # Platform selection
    # CONFIG_ARCH_ACTIONS is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_ALPINE is not set
    # CONFIG_ARCH_APPLE is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_ARCH_BERLIN is not set
    # CONFIG_ARCH_BITMAIN is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_SPARX5 is not set
    CONFIG_ARCH_K3=y
    # CONFIG_ARCH_LG1K is not set
    # CONFIG_ARCH_HISI is not set
    # CONFIG_ARCH_KEEMBAY is not set
    # CONFIG_ARCH_MEDIATEK is not set
    # CONFIG_ARCH_MESON is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_NXP is not set
    # CONFIG_ARCH_NPCM is not set
    # CONFIG_ARCH_QCOM is not set
    # CONFIG_ARCH_REALTEK is not set
    # CONFIG_ARCH_RENESAS is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_SEATTLE is not set
    # CONFIG_ARCH_INTEL_SOCFPGA is not set
    # CONFIG_ARCH_SYNQUACER is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_SPRD is not set
    # CONFIG_ARCH_THUNDER is not set
    # CONFIG_ARCH_THUNDER2 is not set
    # CONFIG_ARCH_UNIPHIER is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_VISCONTI is not set
    # CONFIG_ARCH_XGENE is not set
    # CONFIG_ARCH_ZYNQMP is not set
    # end of Platform selection
    # Kernel Features
    # ARM errata workarounds via the alternatives framework
    # CONFIG_AMPERE_ERRATUM_AC03_CPU_38 is not set
    CONFIG_ARM64_WORKAROUND_CLEAN_CACHE=y
    CONFIG_ARM64_ERRATUM_826319=y
    CONFIG_ARM64_ERRATUM_827319=y
    CONFIG_ARM64_ERRATUM_824069=y
    CONFIG_ARM64_ERRATUM_819472=y
    # CONFIG_ARM64_ERRATUM_832075 is not set
    CONFIG_ARM64_ERRATUM_1742098=y
    CONFIG_ARM64_ERRATUM_845719=y
    CONFIG_ARM64_ERRATUM_843419=y
    CONFIG_ARM64_LD_HAS_FIX_ERRATUM_843419=y
    # CONFIG_ARM64_ERRATUM_1024718 is not set
    # CONFIG_ARM64_ERRATUM_1418040 is not set
    CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT=y
    # CONFIG_ARM64_ERRATUM_1165522 is not set
    CONFIG_ARM64_ERRATUM_1319367=y
    # CONFIG_ARM64_ERRATUM_1530923 is not set
    # CONFIG_ARM64_ERRATUM_2441007 is not set
    # CONFIG_ARM64_ERRATUM_1286807 is not set
    # CONFIG_ARM64_ERRATUM_1463225 is not set
    # CONFIG_ARM64_ERRATUM_1542419 is not set
    # CONFIG_ARM64_ERRATUM_1508412 is not set
    # CONFIG_ARM64_ERRATUM_2051678 is not set
    # CONFIG_ARM64_ERRATUM_2077057 is not set
    # CONFIG_ARM64_ERRATUM_2658417 is not set
    # CONFIG_ARM64_ERRATUM_2054223 is not set
    # CONFIG_ARM64_ERRATUM_2067961 is not set
    # CONFIG_ARM64_ERRATUM_2441009 is not set
    CONFIG_ARM64_ERRATUM_2457168=y
    CONFIG_ARM64_WORKAROUND_SPECULATIVE_UNPRIV_LOAD=y
    CONFIG_ARM64_ERRATUM_2966298=y
    # CONFIG_CAVIUM_ERRATUM_22375 is not set
    # CONFIG_CAVIUM_ERRATUM_23154 is not set
    # CONFIG_CAVIUM_ERRATUM_27456 is not set
    # CONFIG_CAVIUM_ERRATUM_30115 is not set
    # CONFIG_CAVIUM_TX2_ERRATUM_219 is not set
    # CONFIG_FUJITSU_ERRATUM_010001 is not set
    # CONFIG_HISILICON_ERRATUM_161600802 is not set
    # CONFIG_QCOM_FALKOR_ERRATUM_1003 is not set
    # CONFIG_QCOM_FALKOR_ERRATUM_1009 is not set
    # CONFIG_QCOM_QDF2400_ERRATUM_0065 is not set
    # CONFIG_QCOM_FALKOR_ERRATUM_E1041 is not set
    # CONFIG_NVIDIA_CARMEL_CNP_ERRATUM is not set
    CONFIG_SOCIONEXT_SYNQUACER_PREITS=y
    # end of ARM errata workarounds via the alternatives framework
    CONFIG_ARM64_4K_PAGES=y
    # CONFIG_ARM64_16K_PAGES is not set
    # CONFIG_ARM64_64K_PAGES is not set
    # CONFIG_ARM64_VA_BITS_39 is not set
    CONFIG_ARM64_VA_BITS_48=y
    CONFIG_ARM64_VA_BITS=48
    CONFIG_ARM64_PA_BITS_48=y
    CONFIG_ARM64_PA_BITS=48
    # CONFIG_CPU_BIG_ENDIAN is not set
    CONFIG_CPU_LITTLE_ENDIAN=y
    CONFIG_SCHED_MC=y
    # CONFIG_SCHED_CLUSTER is not set
    CONFIG_SCHED_SMT=y
    CONFIG_NR_CPUS=256
    CONFIG_HOTPLUG_CPU=y
    # CONFIG_NUMA is not set
    # CONFIG_HZ_100 is not set
    CONFIG_HZ_250=y
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_1000 is not set
    CONFIG_HZ=250
    CONFIG_SCHED_HRTICK=y
    CONFIG_ARCH_SPARSEMEM_ENABLE=y
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_CC_HAVE_SHADOW_CALL_STACK=y
    CONFIG_PARAVIRT=y
    # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
    CONFIG_KEXEC=y
    CONFIG_KEXEC_FILE=y
    # CONFIG_KEXEC_SIG is not set
    # CONFIG_CRASH_DUMP is not set
    CONFIG_TRANS_TABLE=y
    # CONFIG_XEN is not set
    CONFIG_ARCH_FORCE_MAX_ORDER=11
    CONFIG_UNMAP_KERNEL_AT_EL0=y
    CONFIG_MITIGATE_SPECTRE_BRANCH_HISTORY=y
    CONFIG_RODATA_FULL_DEFAULT_ENABLED=y
    # CONFIG_ARM64_SW_TTBR0_PAN is not set
    CONFIG_ARM64_TAGGED_ADDR_ABI=y
    CONFIG_COMPAT=y
    CONFIG_KUSER_HELPERS=y
    # CONFIG_COMPAT_ALIGNMENT_FIXUPS is not set
    # CONFIG_ARMV8_DEPRECATED is not set
    # ARMv8.1 architectural features
    CONFIG_ARM64_HW_AFDBM=y
    CONFIG_ARM64_PAN=y
    CONFIG_AS_HAS_LDAPR=y
    CONFIG_AS_HAS_LSE_ATOMICS=y
    CONFIG_ARM64_LSE_ATOMICS=y
    CONFIG_ARM64_USE_LSE_ATOMICS=y
    # end of ARMv8.1 architectural features
    # ARMv8.2 architectural features
    CONFIG_AS_HAS_ARMV8_2=y
    CONFIG_AS_HAS_SHA3=y
    # CONFIG_ARM64_PMEM is not set
    CONFIG_ARM64_RAS_EXTN=y
    CONFIG_ARM64_CNP=y
    # end of ARMv8.2 architectural features
    # ARMv8.3 architectural features
    CONFIG_ARM64_PTR_AUTH=y
    CONFIG_ARM64_PTR_AUTH_KERNEL=y
    CONFIG_CC_HAS_BRANCH_PROT_PAC_RET=y
    CONFIG_CC_HAS_SIGN_RETURN_ADDRESS=y
    CONFIG_AS_HAS_PAC=y
    CONFIG_AS_HAS_CFI_NEGATE_RA_STATE=y
    # end of ARMv8.3 architectural features
    # ARMv8.4 architectural features
    CONFIG_ARM64_AMU_EXTN=y
    CONFIG_AS_HAS_ARMV8_4=y
    CONFIG_ARM64_TLB_RANGE=y
    # end of ARMv8.4 architectural features
    # ARMv8.5 architectural features
    CONFIG_AS_HAS_ARMV8_5=y
    CONFIG_ARM64_BTI=y
    CONFIG_CC_HAS_BRANCH_PROT_PAC_RET_BTI=y
    CONFIG_ARM64_E0PD=y
    CONFIG_ARM64_AS_HAS_MTE=y
    CONFIG_ARM64_MTE=y
    # end of ARMv8.5 architectural features
    # ARMv8.7 architectural features
    CONFIG_ARM64_EPAN=y
    # end of ARMv8.7 architectural features
    # CONFIG_ARM64_SVE is not set
    CONFIG_ARM64_MODULE_PLTS=y
    # CONFIG_ARM64_PSEUDO_NMI is not set
    CONFIG_RELOCATABLE=y
    CONFIG_RANDOMIZE_BASE=y
    CONFIG_RANDOMIZE_MODULE_REGION_FULL=y
    CONFIG_CC_HAVE_STACKPROTECTOR_SYSREG=y
    CONFIG_STACKPROTECTOR_PER_TASK=y
    CONFIG_ARCH_NR_GPIO=0
    # end of Kernel Features
    # Boot options
    CONFIG_CMDLINE=""
    CONFIG_EFI_STUB=y
    CONFIG_EFI=y
    CONFIG_DMI=y
    # end of Boot options
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    # CONFIG_SUSPEND_SKIP_SYNC is not set
    CONFIG_HIBERNATE_CALLBACKS=y
    CONFIG_HIBERNATION=y
    CONFIG_HIBERNATION_SNAPSHOT_DEV=y
    CONFIG_PM_STD_PARTITION=""
    CONFIG_PM_SLEEP=y
    CONFIG_PM_SLEEP_SMP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_USERSPACE_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_ADVANCED_DEBUG is not set
    # CONFIG_PM_TEST_SUSPEND is not set
    CONFIG_PM_SLEEP_DEBUG=y
    # CONFIG_DPM_WATCHDOG is not set
    CONFIG_PM_CLK=y
    CONFIG_PM_GENERIC_DOMAINS=y
    CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
    CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
    CONFIG_PM_GENERIC_DOMAINS_OF=y
    CONFIG_CPU_PM=y
    CONFIG_ENERGY_MODEL=y
    CONFIG_ARCH_HIBERNATION_POSSIBLE=y
    CONFIG_ARCH_HIBERNATION_HEADER=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    # end of Power management options
    # CPU Power Management
    # CPU Idle
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
    # CONFIG_CPU_IDLE_GOV_LADDER is not set
    CONFIG_CPU_IDLE_GOV_MENU=y
    # CONFIG_CPU_IDLE_GOV_TEO is not set
    CONFIG_DT_IDLE_STATES=y
    CONFIG_DT_IDLE_GENPD=y
    # ARM CPU Idle Drivers
    CONFIG_ARM_PSCI_CPUIDLE=y
    CONFIG_ARM_PSCI_CPUIDLE_DOMAIN=y
    # end of ARM CPU Idle Drivers
    # end of CPU Idle
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_GOV_ATTR_SET=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=m
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
    CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
    # CPU frequency scaling drivers
    CONFIG_CPUFREQ_DT=y
    CONFIG_CPUFREQ_DT_PLATDEV=y
    CONFIG_ARM_SCMI_CPUFREQ=y
    CONFIG_ARM_TI_CPUFREQ=y
    # end of CPU Frequency scaling
    # end of CPU Power Management
    CONFIG_ARCH_SUPPORTS_ACPI=y
    # CONFIG_ACPI is not set
    CONFIG_HAVE_KVM=y
    CONFIG_VIRTUALIZATION=y
    # CONFIG_KVM is not set
    # General architecture-dependent options
    CONFIG_CRASH_CORE=y
    CONFIG_KEXEC_CORE=y
    CONFIG_ARCH_HAS_SUBPAGE_FAULTS=y
    # CONFIG_KPROBES is not set
    CONFIG_JUMP_LABEL=y
    # CONFIG_STATIC_KEYS_SELFTEST is not set
    CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
    CONFIG_HAVE_IOREMAP_PROT=y
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_ARCH_CORRECT_STACKTRACE_ON_KRETPROBE=y
    CONFIG_HAVE_FUNCTION_ERROR_INJECTION=y
    CONFIG_HAVE_NMI=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_NMI_SUPPORT=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
    CONFIG_ARCH_HAS_KEEPINITRD=y
    CONFIG_ARCH_HAS_SET_MEMORY=y
    CONFIG_ARCH_HAS_SET_DIRECT_MAP=y
    CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
    CONFIG_ARCH_WANTS_NO_INSTR=y
    CONFIG_HAVE_ASM_MODVERSIONS=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_RSEQ=y
    CONFIG_HAVE_FUNCTION_ARG_ACCESS_API=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_PERF_REGS=y
    CONFIG_HAVE_PERF_USER_STACK_DUMP=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_HAVE_ARCH_JUMP_LABEL_RELATIVE=y
    CONFIG_MMU_GATHER_TABLE_FREE=y
    CONFIG_MMU_GATHER_RCU_TABLE_FREE=y
    CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y
    CONFIG_HAVE_ALIGNED_STRUCT_PAGE=y
    CONFIG_HAVE_CMPXCHG_LOCAL=y
    CONFIG_HAVE_CMPXCHG_DOUBLE=y
    CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_ARCH_SECCOMP=y
    CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
    CONFIG_SECCOMP=y
    CONFIG_SECCOMP_FILTER=y
    # CONFIG_SECCOMP_CACHE_DEBUG is not set
    CONFIG_HAVE_ARCH_STACKLEAK=y
    CONFIG_HAVE_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR_STRONG=y
    CONFIG_ARCH_SUPPORTS_SHADOW_CALL_STACK=y
    # CONFIG_SHADOW_CALL_STACK is not set
    CONFIG_ARCH_SUPPORTS_LTO_CLANG=y
    CONFIG_ARCH_SUPPORTS_LTO_CLANG_THIN=y
    CONFIG_LTO_NONE=y
    CONFIG_ARCH_SUPPORTS_CFI_CLANG=y
    CONFIG_HAVE_CONTEXT_TRACKING_USER=y
    CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_HAVE_MOVE_PUD=y
    CONFIG_HAVE_MOVE_PMD=y
    CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y
    CONFIG_HAVE_ARCH_HUGE_VMAP=y
    CONFIG_HAVE_ARCH_HUGE_VMALLOC=y
    CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y
    CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
    CONFIG_MODULES_USE_ELF_RELA=y
    CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y
    CONFIG_SOFTIRQ_ON_OWN_STACK=y
    CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
    CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
    CONFIG_ARCH_MMAP_RND_BITS=18
    CONFIG_HAVE_ARCH_MMAP_RND_COMPAT_BITS=y
    CONFIG_ARCH_MMAP_RND_COMPAT_BITS=11
    CONFIG_PAGE_SIZE_LESS_THAN_64KB=y
    CONFIG_PAGE_SIZE_LESS_THAN_256KB=y
    CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_COMPAT_OLD_SIGACTION=y
    CONFIG_COMPAT_32BIT_TIME=y
    CONFIG_HAVE_ARCH_VMAP_STACK=y
    CONFIG_VMAP_STACK=y
    CONFIG_HAVE_ARCH_RANDOMIZE_KSTACK_OFFSET=y
    CONFIG_RANDOMIZE_KSTACK_OFFSET=y
    # CONFIG_RANDOMIZE_KSTACK_OFFSET_DEFAULT is not set
    CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
    CONFIG_STRICT_KERNEL_RWX=y
    CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
    CONFIG_STRICT_MODULE_RWX=y
    CONFIG_HAVE_ARCH_COMPILER_H=y
    CONFIG_HAVE_ARCH_PREL32_RELOCATIONS=y
    CONFIG_ARCH_USE_MEMREMAP_PROT=y
    # CONFIG_LOCK_EVENT_COUNTS is not set
    CONFIG_ARCH_HAS_RELR=y
    CONFIG_HAVE_PREEMPT_DYNAMIC=y
    CONFIG_HAVE_PREEMPT_DYNAMIC_KEY=y
    CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
    CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y
    CONFIG_ARCH_SUPPORTS_PAGE_TABLE_CHECK=y
    CONFIG_ARCH_HAVE_TRACE_MMIO_ACCESS=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
    # end of GCOV-based kernel profiling
    CONFIG_HAVE_GCC_PLUGINS=y
    CONFIG_GCC_PLUGINS=y
    # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
    # end of General architecture-dependent options
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    # CONFIG_MODULE_FORCE_LOAD is not set
    CONFIG_MODULE_UNLOAD=y
    # CONFIG_MODULE_FORCE_UNLOAD is not set
    # CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set
    # CONFIG_MODVERSIONS is not set
    # CONFIG_MODULE_SRCVERSION_ALL is not set
    # CONFIG_MODULE_SIG is not set
    CONFIG_MODULE_COMPRESS_NONE=y
    # CONFIG_MODULE_COMPRESS_GZIP is not set
    # CONFIG_MODULE_COMPRESS_XZ is not set
    # CONFIG_MODULE_COMPRESS_ZSTD is not set
    # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
    CONFIG_MODPROBE_PATH="/sbin/modprobe"
    # CONFIG_TRIM_UNUSED_KSYMS is not set
    CONFIG_MODULES_TREE_LOOKUP=y
    CONFIG_BLOCK=y
    CONFIG_BLOCK_LEGACY_AUTOLOAD=y
    CONFIG_BLK_CGROUP_RWSTAT=y
    CONFIG_BLK_DEV_BSG_COMMON=y
    CONFIG_BLK_DEV_BSGLIB=y
    CONFIG_BLK_DEV_INTEGRITY=y
    CONFIG_BLK_DEV_INTEGRITY_T10=y
    # CONFIG_BLK_DEV_ZONED is not set
    CONFIG_BLK_DEV_THROTTLING=y
    # CONFIG_BLK_DEV_THROTTLING_LOW is not set
    # CONFIG_BLK_WBT is not set
    # CONFIG_BLK_CGROUP_IOLATENCY is not set
    # CONFIG_BLK_CGROUP_IOCOST is not set
    # CONFIG_BLK_CGROUP_IOPRIO is not set
    CONFIG_BLK_DEBUG_FS=y
    # CONFIG_BLK_SED_OPAL is not set
    # CONFIG_BLK_INLINE_ENCRYPTION is not set
    # Partition Types
    # CONFIG_PARTITION_ADVANCED is not set
    CONFIG_MSDOS_PARTITION=y
    CONFIG_EFI_PARTITION=y
    # end of Partition Types
    CONFIG_BLOCK_COMPAT=y
    CONFIG_BLK_MQ_VIRTIO=y
    CONFIG_BLK_PM=y
    CONFIG_BLOCK_HOLDER_DEPRECATED=y
    CONFIG_BLK_MQ_STACKING=y
    # IO Schedulers
    CONFIG_MQ_IOSCHED_DEADLINE=y
    CONFIG_MQ_IOSCHED_KYBER=y
    # CONFIG_IOSCHED_BFQ is not set
    # end of IO Schedulers
    CONFIG_ASN1=y
    CONFIG_UNINLINE_SPIN_UNLOCK=y
    CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
    CONFIG_MUTEX_SPIN_ON_OWNER=y
    CONFIG_RWSEM_SPIN_ON_OWNER=y
    CONFIG_LOCK_SPIN_ON_OWNER=y
    CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y
    CONFIG_QUEUED_SPINLOCKS=y
    CONFIG_ARCH_USE_QUEUED_RWLOCKS=y
    CONFIG_QUEUED_RWLOCKS=y
    CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
    CONFIG_ARCH_HAS_SYSCALL_WRAPPER=y
    CONFIG_FREEZER=y
    # Executable file formats
    CONFIG_BINFMT_ELF=y
    CONFIG_COMPAT_BINFMT_ELF=y
    CONFIG_ARCH_BINFMT_ELF_STATE=y
    CONFIG_ARCH_BINFMT_ELF_EXTRA_PHDRS=y
    CONFIG_ARCH_HAVE_ELF_PROT=y
    CONFIG_ARCH_USE_GNU_PROPERTY=y
    CONFIG_ELFCORE=y
    # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
    CONFIG_BINFMT_SCRIPT=y
    # CONFIG_BINFMT_MISC is not set
    CONFIG_COREDUMP=y
    # end of Executable file formats
    # Memory Management options
    CONFIG_SWAP=y
    # CONFIG_ZSWAP is not set
    # SLAB allocator options
    # CONFIG_SLAB is not set
    CONFIG_SLUB=y
    # CONFIG_SLOB is not set
    CONFIG_SLAB_MERGE_DEFAULT=y
    # CONFIG_SLAB_FREELIST_RANDOM is not set
    # CONFIG_SLAB_FREELIST_HARDENED is not set
    # CONFIG_SLUB_STATS is not set
    CONFIG_SLUB_CPU_PARTIAL=y
    # end of SLAB allocator options
    # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
    # CONFIG_COMPAT_BRK is not set
    CONFIG_SPARSEMEM=y
    CONFIG_SPARSEMEM_EXTREME=y
    CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y
    CONFIG_SPARSEMEM_VMEMMAP=y
    CONFIG_HAVE_FAST_GUP=y
    CONFIG_ARCH_KEEP_MEMBLOCK=y
    CONFIG_MEMORY_ISOLATION=y
    CONFIG_EXCLUSIVE_SYSTEM_RAM=y
    CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
    CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y
    CONFIG_MEMORY_HOTPLUG=y
    # CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE is not set
    CONFIG_MEMORY_HOTREMOVE=y
    CONFIG_MHP_MEMMAP_ON_MEMORY=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    CONFIG_ARCH_ENABLE_SPLIT_PMD_PTLOCK=y
    CONFIG_MEMORY_BALLOON=y
    CONFIG_BALLOON_COMPACTION=y
    CONFIG_COMPACTION=y
    CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1
    CONFIG_PAGE_REPORTING=y
    CONFIG_MIGRATION=y
    CONFIG_ARCH_ENABLE_HUGEPAGE_MIGRATION=y
    CONFIG_ARCH_ENABLE_THP_MIGRATION=y
    CONFIG_CONTIG_ALLOC=y
    CONFIG_PHYS_ADDR_T_64BIT=y
    CONFIG_KSM=y
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_ARCH_SUPPORTS_MEMORY_FAILURE=y
    CONFIG_MEMORY_FAILURE=y
    # CONFIG_HWPOISON_INJECT is not set
    CONFIG_ARCH_WANTS_THP_SWAP=y
    CONFIG_TRANSPARENT_HUGEPAGE=y
    CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y
    # CONFIG_TRANSPARENT_HUGEPAGE_MADVISE is not set
    CONFIG_THP_SWAP=y
    # CONFIG_READ_ONLY_THP_FOR_FS is not set
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_CMA_DEBUGFS is not set
    # CONFIG_CMA_SYSFS is not set
    CONFIG_CMA_AREAS=19
    CONFIG_GENERIC_EARLY_IOREMAP=y
    # CONFIG_DEFERRED_STRUCT_PAGE_INIT is not set
    # CONFIG_IDLE_PAGE_TRACKING is not set
    CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y
    CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y
    CONFIG_ARCH_HAS_PTE_DEVMAP=y
    CONFIG_ARCH_HAS_ZONE_DMA_SET=y
    CONFIG_ZONE_DMA=y
    CONFIG_ZONE_DMA32=y
    # CONFIG_ZONE_DEVICE is not set
    CONFIG_ARCH_USES_HIGH_VMA_FLAGS=y
    CONFIG_VM_EVENT_COUNTERS=y
    # CONFIG_PERCPU_STATS is not set
    # CONFIG_GUP_TEST is not set
    CONFIG_ARCH_HAS_PTE_SPECIAL=y
    # CONFIG_ANON_VMA_NAME is not set
    # CONFIG_USERFAULTFD is not set
    # CONFIG_LRU_GEN is not set
    CONFIG_LOCK_MM_AND_FIND_VMA=y
    # Data Access Monitoring
    # CONFIG_DAMON is not set
    # end of Data Access Monitoring
    # end of Memory Management options
    CONFIG_NET=y
    CONFIG_COMPAT_NETLINK_MESSAGES=y
    CONFIG_NET_INGRESS=y
    CONFIG_NET_EGRESS=y
    CONFIG_SKB_EXTENSIONS=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    CONFIG_UNIX_SCM=y
    CONFIG_AF_UNIX_OOB=y
    # CONFIG_UNIX_DIAG is not set
    # CONFIG_TLS is not set
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=y
    CONFIG_XFRM_USER=y
    # CONFIG_XFRM_INTERFACE is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_ESP=y
    # CONFIG_NET_KEY is not set
    CONFIG_XDP_SOCKETS=y
    # CONFIG_XDP_SOCKETS_DIAG is not set
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_ROUTE_CLASSID=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    # CONFIG_IP_PNP_RARP is not set
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    CONFIG_NET_IP_TUNNEL=m
    # CONFIG_IP_MROUTE is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    CONFIG_NET_UDP_TUNNEL=m
    # CONFIG_NET_FOU is not set
    # CONFIG_NET_FOU_IP_TUNNELS is not set
    # CONFIG_INET_AH is not set
    CONFIG_INET_ESP=y
    # CONFIG_INET_ESP_OFFLOAD is not set
    # CONFIG_INET_ESPINTCP is not set
    # CONFIG_INET_IPCOMP is not set
    CONFIG_INET_TABLE_PERTURB_ORDER=16
    CONFIG_INET_TUNNEL=m
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_INET_RAW_DIAG is not set
    # CONFIG_INET_DIAG_DESTROY is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=m
    # CONFIG_IPV6_ROUTER_PREF is not set
    # CONFIG_IPV6_OPTIMISTIC_DAD is not set
    # CONFIG_INET6_AH is not set
    # CONFIG_INET6_ESP is not set
    # CONFIG_INET6_IPCOMP is not set
    # CONFIG_IPV6_MIP6 is not set
    # CONFIG_IPV6_ILA is not set
    # CONFIG_IPV6_VTI is not set
    CONFIG_IPV6_SIT=m
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    # CONFIG_IPV6_TUNNEL is not set
    # CONFIG_IPV6_MULTIPLE_TABLES is not set
    # CONFIG_IPV6_MROUTE is not set
    # CONFIG_IPV6_SEG6_LWTUNNEL is not set
    # CONFIG_IPV6_SEG6_HMAC is not set
    # CONFIG_IPV6_RPL_LWTUNNEL is not set
    # CONFIG_IPV6_IOAM6_LWTUNNEL is not set
    # CONFIG_NETLABEL is not set
    # CONFIG_MPTCP is not set
    # CONFIG_NETWORK_SECMARK is not set
    CONFIG_NET_PTP_CLASSIFY=y
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    CONFIG_NETFILTER_ADVANCED=y
    CONFIG_BRIDGE_NETFILTER=m
    # Core Netfilter Configuration
    CONFIG_NETFILTER_INGRESS=y
    CONFIG_NETFILTER_EGRESS=y
    CONFIG_NETFILTER_SKIP_EGRESS=y
    CONFIG_NETFILTER_FAMILY_BRIDGE=y
    # CONFIG_NETFILTER_NETLINK_ACCT is not set
    # CONFIG_NETFILTER_NETLINK_QUEUE is not set
    # CONFIG_NETFILTER_NETLINK_LOG is not set
    # CONFIG_NETFILTER_NETLINK_OSF is not set
    CONFIG_NF_CONNTRACK=m
    CONFIG_NF_LOG_SYSLOG=m
    # CONFIG_NF_CONNTRACK_MARK is not set
    # CONFIG_NF_CONNTRACK_ZONES is not set
    # CONFIG_NF_CONNTRACK_PROCFS is not set
    CONFIG_NF_CONNTRACK_EVENTS=y
    # CONFIG_NF_CONNTRACK_TIMEOUT is not set
    # CONFIG_NF_CONNTRACK_TIMESTAMP is not set
    # CONFIG_NF_CONNTRACK_LABELS is not set
    CONFIG_NF_CT_PROTO_DCCP=y
    CONFIG_NF_CT_PROTO_SCTP=y
    CONFIG_NF_CT_PROTO_UDPLITE=y
    # CONFIG_NF_CONNTRACK_AMANDA is not set
    CONFIG_NF_CONNTRACK_FTP=m
    # CONFIG_NF_CONNTRACK_H323 is not set
    # CONFIG_NF_CONNTRACK_IRC is not set
    # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
    # CONFIG_NF_CONNTRACK_SNMP is not set
    # CONFIG_NF_CONNTRACK_PPTP is not set
    # CONFIG_NF_CONNTRACK_SANE is not set
    # CONFIG_NF_CONNTRACK_SIP is not set
    CONFIG_NF_CONNTRACK_TFTP=m
    # CONFIG_NF_CT_NETLINK is not set
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_FTP=m
    CONFIG_NF_NAT_TFTP=m
    CONFIG_NF_NAT_REDIRECT=y
    CONFIG_NF_NAT_MASQUERADE=y
    # CONFIG_NF_TABLES is not set
    CONFIG_NETFILTER_XTABLES=m
    CONFIG_NETFILTER_XTABLES_COMPAT=y
    # Xtables combined modules
    CONFIG_NETFILTER_XT_MARK=m
    # CONFIG_NETFILTER_XT_CONNMARK is not set
    # Xtables targets
    # CONFIG_NETFILTER_XT_TARGET_AUDIT is not set
    CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
    # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
    # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_DSCP is not set
    # CONFIG_NETFILTER_XT_TARGET_HL is not set
    # CONFIG_NETFILTER_XT_TARGET_HMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
    # CONFIG_NETFILTER_XT_TARGET_LED is not set
    CONFIG_NETFILTER_XT_TARGET_LOG=m
    # CONFIG_NETFILTER_XT_TARGET_MARK is not set
    CONFIG_NETFILTER_XT_NAT=m
    # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
    # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
    # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
    # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
    CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
    CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
    # CONFIG_NETFILTER_XT_TARGET_TEE is not set
    # CONFIG_NETFILTER_XT_TARGET_TPROXY is not set
    # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
    # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
    # Xtables matches
    CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
    # CONFIG_NETFILTER_XT_MATCH_BPF is not set
    # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
    CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
    # CONFIG_NETFILTER_XT_MATCH_CPU is not set
    # CONFIG_NETFILTER_XT_MATCH_DCCP is not set
    # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_DSCP is not set
    # CONFIG_NETFILTER_XT_MATCH_ECN is not set
    # CONFIG_NETFILTER_XT_MATCH_ESP is not set
    # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_HELPER is not set
    # CONFIG_NETFILTER_XT_MATCH_HL is not set
    # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
    # CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
    CONFIG_NETFILTER_XT_MATCH_IPVS=m
    # CONFIG_NETFILTER_XT_MATCH_L2TP is not set
    # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
    # CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_MAC is not set
    # CONFIG_NETFILTER_XT_MATCH_MARK is not set
    # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
    # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
    # CONFIG_NETFILTER_XT_MATCH_OSF is not set
    # CONFIG_NETFILTER_XT_MATCH_OWNER is not set
    # CONFIG_NETFILTER_XT_MATCH_POLICY is not set
    # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
    # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
    # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
    # CONFIG_NETFILTER_XT_MATCH_REALM is not set
    # CONFIG_NETFILTER_XT_MATCH_RECENT is not set
    # CONFIG_NETFILTER_XT_MATCH_SCTP is not set
    # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
    # CONFIG_NETFILTER_XT_MATCH_STATE is not set
    # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
    # CONFIG_NETFILTER_XT_MATCH_STRING is not set
    # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
    # CONFIG_NETFILTER_XT_MATCH_TIME is not set
    # CONFIG_NETFILTER_XT_MATCH_U32 is not set
    # end of Core Netfilter Configuration
    # CONFIG_IP_SET is not set
    CONFIG_IP_VS=m
    # CONFIG_IP_VS_IPV6 is not set
    # CONFIG_IP_VS_DEBUG is not set
    CONFIG_IP_VS_TAB_BITS=12
    # IPVS transport protocol load balancing support
    CONFIG_IP_VS_PROTO_TCP=y
    CONFIG_IP_VS_PROTO_UDP=y
    # CONFIG_IP_VS_PROTO_ESP is not set
    # CONFIG_IP_VS_PROTO_AH is not set
    # CONFIG_IP_VS_PROTO_SCTP is not set
    # IPVS scheduler
    CONFIG_IP_VS_RR=m
    # CONFIG_IP_VS_WRR is not set
    # CONFIG_IP_VS_LC is not set
    # CONFIG_IP_VS_WLC is not set
    # CONFIG_IP_VS_FO is not set
    # CONFIG_IP_VS_OVF is not set
    # CONFIG_IP_VS_LBLC is not set
    # CONFIG_IP_VS_LBLCR is not set
    # CONFIG_IP_VS_DH is not set
    # CONFIG_IP_VS_SH is not set
    # CONFIG_IP_VS_MH is not set
    # CONFIG_IP_VS_SED is not set
    # CONFIG_IP_VS_NQ is not set
    # CONFIG_IP_VS_TWOS is not set
    # IPVS SH scheduler
    CONFIG_IP_VS_SH_TAB_BITS=8
    # IPVS MH scheduler
    CONFIG_IP_VS_MH_TAB_INDEX=12
    # IPVS application helper
    # CONFIG_IP_VS_FTP is not set
    CONFIG_IP_VS_NFCT=y
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    # CONFIG_NF_SOCKET_IPV4 is not set
    # CONFIG_NF_TPROXY_IPV4 is not set
    # CONFIG_NF_DUP_IPV4 is not set
    # CONFIG_NF_LOG_ARP is not set
    # CONFIG_NF_LOG_IPV4 is not set
    CONFIG_NF_REJECT_IPV4=m
    CONFIG_IP_NF_IPTABLES=m
    # CONFIG_IP_NF_MATCH_AH is not set
    # CONFIG_IP_NF_MATCH_ECN is not set
    # CONFIG_IP_NF_MATCH_RPFILTER is not set
    # CONFIG_IP_NF_MATCH_TTL is not set
    CONFIG_IP_NF_FILTER=m
    CONFIG_IP_NF_TARGET_REJECT=m
    # CONFIG_IP_NF_TARGET_SYNPROXY is not set
    CONFIG_IP_NF_NAT=m
    CONFIG_IP_NF_TARGET_MASQUERADE=m
    # CONFIG_IP_NF_TARGET_NETMAP is not set
    CONFIG_IP_NF_TARGET_REDIRECT=m
    CONFIG_IP_NF_MANGLE=m
    # CONFIG_IP_NF_TARGET_CLUSTERIP is not set
    # CONFIG_IP_NF_TARGET_ECN is not set
    # CONFIG_IP_NF_TARGET_TTL is not set
    # CONFIG_IP_NF_RAW is not set
    # CONFIG_IP_NF_SECURITY is not set
    # CONFIG_IP_NF_ARPTABLES is not set
    # end of IP: Netfilter Configuration
    # IPv6: Netfilter Configuration
    # CONFIG_NF_SOCKET_IPV6 is not set
    # CONFIG_NF_TPROXY_IPV6 is not set
    # CONFIG_NF_DUP_IPV6 is not set
    CONFIG_NF_REJECT_IPV6=m
    CONFIG_NF_LOG_IPV6=m
    CONFIG_IP6_NF_IPTABLES=m
    # CONFIG_IP6_NF_MATCH_AH is not set
    # CONFIG_IP6_NF_MATCH_EUI64 is not set
    # CONFIG_IP6_NF_MATCH_FRAG is not set
    # CONFIG_IP6_NF_MATCH_OPTS is not set
    # CONFIG_IP6_NF_MATCH_HL is not set
    # CONFIG_IP6_NF_MATCH_IPV6HEADER is not set
    # CONFIG_IP6_NF_MATCH_MH is not set
    # CONFIG_IP6_NF_MATCH_RPFILTER is not set
    # CONFIG_IP6_NF_MATCH_RT is not set
    # CONFIG_IP6_NF_MATCH_SRH is not set
    # CONFIG_IP6_NF_TARGET_HL is not set
    CONFIG_IP6_NF_FILTER=m
    CONFIG_IP6_NF_TARGET_REJECT=m
    # CONFIG_IP6_NF_TARGET_SYNPROXY is not set
    CONFIG_IP6_NF_MANGLE=m
    # CONFIG_IP6_NF_RAW is not set
    # CONFIG_IP6_NF_SECURITY is not set
    CONFIG_IP6_NF_NAT=m
    CONFIG_IP6_NF_TARGET_MASQUERADE=m
    # CONFIG_IP6_NF_TARGET_NPT is not set
    # end of IPv6: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV6=m
    # CONFIG_NF_CONNTRACK_BRIDGE is not set
    # CONFIG_BRIDGE_NF_EBTABLES is not set
    # CONFIG_BPFILTER is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    CONFIG_STP=m
    CONFIG_GARP=m
    CONFIG_MRP=m
    CONFIG_BRIDGE=m
    CONFIG_BRIDGE_IGMP_SNOOPING=y
    CONFIG_BRIDGE_VLAN_FILTERING=y
    # CONFIG_BRIDGE_MRP is not set
    # CONFIG_BRIDGE_CFM is not set
    # CONFIG_NET_DSA is not set
    CONFIG_VLAN_8021Q=m
    CONFIG_VLAN_8021Q_GVRP=y
    CONFIG_VLAN_8021Q_MVRP=y
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_PHONET is not set
    # CONFIG_6LOWPAN is not set
    # CONFIG_IEEE802154 is not set
    CONFIG_NET_SCHED=y
    # Queueing/Scheduling
    # CONFIG_NET_SCH_HTB is not set
    # CONFIG_NET_SCH_HFSC is not set
    # CONFIG_NET_SCH_PRIO is not set
    # CONFIG_NET_SCH_MULTIQ is not set
    # CONFIG_NET_SCH_RED is not set
    # CONFIG_NET_SCH_SFB is not set
    # CONFIG_NET_SCH_SFQ is not set
    # CONFIG_NET_SCH_TEQL is not set
    # CONFIG_NET_SCH_TBF is not set
    CONFIG_NET_SCH_CBS=m
    CONFIG_NET_SCH_ETF=m
    CONFIG_NET_SCH_TAPRIO=m
    # CONFIG_NET_SCH_GRED is not set
    # CONFIG_NET_SCH_NETEM is not set
    # CONFIG_NET_SCH_DRR is not set
    CONFIG_NET_SCH_MQPRIO=m
    # CONFIG_NET_SCH_SKBPRIO is not set
    # CONFIG_NET_SCH_CHOKE is not set
    # CONFIG_NET_SCH_QFQ is not set
    # CONFIG_NET_SCH_CODEL is not set
    # CONFIG_NET_SCH_FQ_CODEL is not set
    # CONFIG_NET_SCH_CAKE is not set
    # CONFIG_NET_SCH_FQ is not set
    # CONFIG_NET_SCH_HHF is not set
    # CONFIG_NET_SCH_PIE is not set
    CONFIG_NET_SCH_INGRESS=m
    # CONFIG_NET_SCH_PLUG is not set
    # CONFIG_NET_SCH_ETS is not set
    # CONFIG_NET_SCH_DEFAULT is not set
    # Classification
    CONFIG_NET_CLS=y
    CONFIG_NET_CLS_BASIC=m
    CONFIG_NET_CLS_ROUTE4=m
    CONFIG_NET_CLS_FW=m
    CONFIG_NET_CLS_U32=m
    # CONFIG_CLS_U32_PERF is not set
    CONFIG_CLS_U32_MARK=y
    CONFIG_NET_CLS_FLOW=m
    CONFIG_NET_CLS_CGROUP=m
    # CONFIG_NET_CLS_BPF is not set
    CONFIG_NET_CLS_FLOWER=m
    # CONFIG_NET_CLS_MATCHALL is not set
    CONFIG_NET_EMATCH=y
    CONFIG_NET_EMATCH_STACK=32
    CONFIG_NET_EMATCH_CMP=m
    CONFIG_NET_EMATCH_NBYTE=m
    CONFIG_NET_EMATCH_U32=m
    CONFIG_NET_EMATCH_META=m
    CONFIG_NET_EMATCH_TEXT=m
    # CONFIG_NET_EMATCH_CANID is not set
    # CONFIG_NET_EMATCH_IPT is not set
    CONFIG_NET_CLS_ACT=y
    CONFIG_NET_ACT_POLICE=m
    CONFIG_NET_ACT_GACT=m
    CONFIG_GACT_PROB=y
    CONFIG_NET_ACT_MIRRED=m
    # CONFIG_NET_ACT_SAMPLE is not set
    CONFIG_NET_ACT_IPT=m
    CONFIG_NET_ACT_NAT=m
    CONFIG_NET_ACT_PEDIT=m
    CONFIG_NET_ACT_SIMP=m
    CONFIG_NET_ACT_SKBEDIT=m
    CONFIG_NET_ACT_CSUM=m
    # CONFIG_NET_ACT_MPLS is not set
    # CONFIG_NET_ACT_VLAN is not set
    # CONFIG_NET_ACT_BPF is not set
    # CONFIG_NET_ACT_SKBMOD is not set
    # CONFIG_NET_ACT_IFE is not set
    # CONFIG_NET_ACT_TUNNEL_KEY is not set
    CONFIG_NET_ACT_GATE=m
    # CONFIG_NET_TC_SKB_EXT is not set
    CONFIG_NET_SCH_FIFO=y
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_MPLS is not set
    # CONFIG_NET_NSH is not set
    CONFIG_HSR=m
    CONFIG_NET_SWITCHDEV=y
    CONFIG_NET_L3_MASTER_DEV=y
    # CONFIG_QRTR is not set
    # CONFIG_NET_NCSI is not set
    CONFIG_PCPU_DEV_REFCNT=y
    CONFIG_RPS=y
    CONFIG_RFS_ACCEL=y
    CONFIG_SOCK_RX_QUEUE_MAPPING=y
    CONFIG_XPS=y
    CONFIG_CGROUP_NET_PRIO=y
    CONFIG_CGROUP_NET_CLASSID=y
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    # CONFIG_BPF_STREAM_PARSER is not set
    CONFIG_NET_FLOW_LIMIT=y
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # end of Network testing
    # end of Networking options
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    CONFIG_CAN_GW=m
    CONFIG_CAN_J1939=m
    # CONFIG_CAN_ISOTP is not set
    CONFIG_BT=m
    CONFIG_BT_BREDR=y
    CONFIG_BT_RFCOMM=m
    # CONFIG_BT_RFCOMM_TTY is not set
    # CONFIG_BT_BNEP is not set
    CONFIG_BT_HIDP=m
    # CONFIG_BT_HS is not set
    # CONFIG_BT_LE is not set
    CONFIG_BT_LEDS=y
    # CONFIG_BT_MSFTEXT is not set
    # CONFIG_BT_AOSPEXT is not set
    # CONFIG_BT_DEBUGFS is not set
    # CONFIG_BT_SELFTEST is not set
    # Bluetooth device drivers
    CONFIG_BT_INTEL=m
    CONFIG_BT_BCM=m
    CONFIG_BT_RTL=m
    CONFIG_BT_QCA=m
    CONFIG_BT_HCIBTUSB=m
    # CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set
    CONFIG_BT_HCIBTUSB_BCM=y
    # CONFIG_BT_HCIBTUSB_MTK is not set
    CONFIG_BT_HCIBTUSB_RTL=y
    CONFIG_BT_HCIBTSDIO=m
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_SERDEV=y
    CONFIG_BT_HCIUART_H4=y
    # CONFIG_BT_HCIUART_NOKIA is not set
    # CONFIG_BT_HCIUART_BCSP is not set
    # CONFIG_BT_HCIUART_ATH3K is not set
    CONFIG_BT_HCIUART_LL=y
    # CONFIG_BT_HCIUART_3WIRE is not set
    # CONFIG_BT_HCIUART_INTEL is not set
    CONFIG_BT_HCIUART_BCM=y
    # CONFIG_BT_HCIUART_RTL is not set
    CONFIG_BT_HCIUART_QCA=y
    # CONFIG_BT_HCIUART_AG6XX is not set
    CONFIG_BT_HCIUART_MRVL=y
    # CONFIG_BT_HCIBCM203X is not set
    # CONFIG_BT_HCIBPA10X is not set
    # CONFIG_BT_HCIBFUSB is not set
    CONFIG_BT_HCIVHCI=m
    CONFIG_BT_MRVL=m
    CONFIG_BT_MRVL_SDIO=m
    # CONFIG_BT_ATH3K is not set
    # CONFIG_BT_MTKSDIO is not set
    # CONFIG_BT_MTKUART is not set
    # CONFIG_BT_VIRTIO is not set
    CONFIG_BT_NXPUART=m
    # end of Bluetooth device drivers
    # CONFIG_AF_RXRPC is not set
    # CONFIG_AF_KCM is not set
    # CONFIG_MCTP is not set
    CONFIG_WIRELESS=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WEXT_CORE=y
    CONFIG_WEXT_PROC=y
    CONFIG_WEXT_PRIV=y
    CONFIG_CFG80211=m
    # CONFIG_NL80211_TESTMODE is not set
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_CERTIFICATION_ONUS is not set
    CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
    CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
    CONFIG_CFG80211_DEFAULT_PS=y
    # CONFIG_CFG80211_DEBUGFS is not set
    CONFIG_CFG80211_CRDA_SUPPORT=y
    # CONFIG_CFG80211_WEXT is not set
    CONFIG_LIB80211=m
    CONFIG_LIB80211_CRYPT_WEP=m
    CONFIG_LIB80211_CRYPT_CCMP=m
    # CONFIG_LIB80211_DEBUG is not set
    CONFIG_MAC80211=m
    CONFIG_MAC80211_HAS_RC=y
    CONFIG_MAC80211_RC_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
    # CONFIG_MAC80211_MESH is not set
    CONFIG_MAC80211_LEDS=y
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_MESSAGE_TRACING is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
    CONFIG_RFKILL=m
    CONFIG_RFKILL_LEDS=y
    # CONFIG_RFKILL_INPUT is not set
    CONFIG_RFKILL_GPIO=m
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # CONFIG_NFC is not set
    # CONFIG_PSAMPLE is not set
    # CONFIG_NET_IFE is not set
    # CONFIG_LWTUNNEL is not set
    CONFIG_DST_CACHE=y
    CONFIG_GRO_CELLS=y
    CONFIG_NET_SELFTESTS=y
    CONFIG_NET_SOCK_MSG=y
    CONFIG_NET_DEVLINK=y
    CONFIG_PAGE_POOL=y
    CONFIG_PAGE_POOL_STATS=y
    CONFIG_FAILOVER=y
    CONFIG_ETHTOOL_NETLINK=y
    # Device Drivers
    CONFIG_ARM_AMBA=y
    CONFIG_HAVE_PCI=y
    # CONFIG_PCI is not set
    # CONFIG_PCCARD is not set
    # Generic Driver Options
    CONFIG_AUXILIARY_BUS=y
    # CONFIG_UEVENT_HELPER is not set
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    # CONFIG_DEVTMPFS_SAFE is not set
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    # Firmware loader
    CONFIG_FW_LOADER=y
    CONFIG_EXTRA_FIRMWARE=""
    # CONFIG_FW_LOADER_USER_HELPER is not set
    # CONFIG_FW_LOADER_COMPRESS is not set
    CONFIG_FW_CACHE=y
    # CONFIG_FW_UPLOAD is not set
    # end of Firmware loader
    CONFIG_WANT_DEV_COREDUMP=y
    CONFIG_ALLOW_DEV_COREDUMP=y
    CONFIG_DEV_COREDUMP=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
    # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
    CONFIG_GENERIC_CPU_AUTOPROBE=y
    CONFIG_GENERIC_CPU_VULNERABILITIES=y
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=y
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_SHARED_BUFFER=y
    # CONFIG_DMA_FENCE_TRACE is not set
    CONFIG_GENERIC_ARCH_TOPOLOGY=y
    # end of Generic Driver Options
    # Bus devices
    CONFIG_ARM_CCI=y
    CONFIG_ARM_CCI400_COMMON=y
    # CONFIG_BRCMSTB_GISB_ARB is not set
    # CONFIG_MOXTET is not set
    CONFIG_TI_SYSC=y
    # CONFIG_VEXPRESS_CONFIG is not set
    CONFIG_MHI_BUS=m
    # CONFIG_MHI_BUS_DEBUG is not set
    # CONFIG_MHI_BUS_EP is not set
    # end of Bus devices
    # CONFIG_CONNECTOR is not set
    # Firmware Drivers
    # ARM System Control and Management Interface Protocol
    CONFIG_ARM_SCMI_PROTOCOL=y
    CONFIG_ARM_SCMI_HAVE_TRANSPORT=y
    CONFIG_ARM_SCMI_HAVE_SHMEM=y
    CONFIG_ARM_SCMI_HAVE_MSG=y
    CONFIG_ARM_SCMI_TRANSPORT_MAILBOX=y
    CONFIG_ARM_SCMI_TRANSPORT_OPTEE=y
    CONFIG_ARM_SCMI_TRANSPORT_SMC=y
    # CONFIG_ARM_SCMI_TRANSPORT_SMC_ATOMIC_ENABLE is not set
    # CONFIG_ARM_SCMI_TRANSPORT_VIRTIO is not set
    CONFIG_ARM_SCMI_POWER_DOMAIN=y
    # CONFIG_ARM_SCMI_POWER_CONTROL is not set
    # end of ARM System Control and Management Interface Protocol
    # CONFIG_ARM_SCPI_PROTOCOL is not set
    # CONFIG_FIRMWARE_MEMMAP is not set
    CONFIG_DMIID=y
    # CONFIG_DMI_SYSFS is not set
    # CONFIG_SYSFB_SIMPLEFB is not set
    CONFIG_TI_SCI_PROTOCOL=y
    # CONFIG_ARM_FFA_TRANSPORT is not set
    # CONFIG_GOOGLE_FIRMWARE is not set
    # EFI (Extensible Firmware Interface) Support
    CONFIG_EFI_ESRT=y
    CONFIG_EFI_VARS_PSTORE=y
    # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set
    CONFIG_EFI_PARAMS_FROM_FDT=y
    CONFIG_EFI_RUNTIME_WRAPPERS=y
    CONFIG_EFI_GENERIC_STUB=y
    # CONFIG_EFI_ZBOOT is not set
    CONFIG_EFI_ARMSTUB_DTB_LOADER=y
    # CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set
    # CONFIG_EFI_BOOTLOADER_CONTROL is not set
    CONFIG_EFI_CAPSULE_LOADER=y
    # CONFIG_EFI_TEST is not set
    # CONFIG_RESET_ATTACK_MITIGATION is not set
    # CONFIG_EFI_DISABLE_PCI_DMA is not set
    CONFIG_EFI_EARLYCON=y
    # CONFIG_EFI_DISABLE_RUNTIME is not set
    # CONFIG_EFI_COCO_SECRET is not set
    # end of EFI (Extensible Firmware Interface) Support
    CONFIG_ARM_PSCI_FW=y
    # CONFIG_ARM_PSCI_CHECKER is not set
    CONFIG_HAVE_ARM_SMCCC=y
    CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y
    CONFIG_ARM_SMCCC_SOC_ID=y
    # Tegra firmware driver
    # end of Tegra firmware driver
    # end of Firmware Drivers
    CONFIG_GNSS=m
    CONFIG_GNSS_SERIAL=m
    CONFIG_GNSS_MTK_SERIAL=m
    # CONFIG_GNSS_SIRF_SERIAL is not set
    # CONFIG_GNSS_UBX_SERIAL is not set
    # CONFIG_GNSS_USB is not set
    # CONFIG_MTD is not set
    CONFIG_DTC=y
    CONFIG_OF=y
    # CONFIG_OF_UNITTEST is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_KOBJ=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_RESERVED_MEM=y
    # CONFIG_OF_OVERLAY is not set
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_NULL_BLK is not set
    # CONFIG_ZRAM is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_DRBD is not set
    CONFIG_BLK_DEV_NBD=m
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=65536
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    CONFIG_VIRTIO_BLK=y
    # CONFIG_BLK_DEV_RBD is not set
    # CONFIG_BLK_DEV_UBLK is not set
    # NVME Support
    # CONFIG_NVME_FC is not set
    # CONFIG_NVME_TCP is not set
    # CONFIG_NVME_TARGET is not set
    # end of NVME Support
    # Misc devices
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    CONFIG_SRAM=y
    CONFIG_SRAM_DMA_HEAP=y
    # CONFIG_XILINX_SDFEC is not set
    # CONFIG_HISI_HIKEY_USB is not set
    # CONFIG_OPEN_DICE is not set
    # CONFIG_VCPU_STALL_DETECTOR is not set
    CONFIG_DMA_BUF_PHYS=y
    CONFIG_TPS6594_ESM=y
    CONFIG_TPS6594_PFSM=y
    # CONFIG_C2PORT is not set
    # EEPROM support
    CONFIG_EEPROM_AT24=y
    CONFIG_EEPROM_AT25=m
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    # CONFIG_EEPROM_93CX6 is not set
    # CONFIG_EEPROM_93XX46 is not set
    # CONFIG_EEPROM_IDT_89HPESX is not set
    # CONFIG_EEPROM_EE1004 is not set
    # end of EEPROM support
    # Texas Instruments shared transport line discipline
    # CONFIG_TI_ST is not set
    # end of Texas Instruments shared transport line discipline
    # CONFIG_SENSORS_LIS3_SPI is not set
    # CONFIG_SENSORS_LIS3_I2C is not set
    # CONFIG_ALTERA_STAPL is not set
    # CONFIG_ECHO is not set
    # CONFIG_MISC_RTSX_USB is not set
    CONFIG_UACCE=m
    # CONFIG_PVPANIC is not set
    # end of Misc devices
    # SCSI device support
    CONFIG_SCSI_MOD=y
    CONFIG_RAID_ATTRS=m
    CONFIG_SCSI_COMMON=y
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_PROC_FS is not set
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_BLK_DEV_SR is not set
    # CONFIG_CHR_DEV_SG is not set
    CONFIG_BLK_DEV_BSG=y
    # CONFIG_CHR_DEV_SCH is not set
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    CONFIG_SCSI_SAS_ATTRS=y
    CONFIG_SCSI_SAS_LIBSAS=y
    CONFIG_SCSI_SAS_ATA=y
    CONFIG_SCSI_SAS_HOST_SMP=y
    # CONFIG_SCSI_SRP_ATTRS is not set
    # end of SCSI Transports
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_HISI_SAS is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_VIRTIO is not set
    # CONFIG_SCSI_DH is not set
    # end of SCSI device support
    CONFIG_ATA=y
    CONFIG_SATA_HOST=y
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_ATA_FORCE=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    CONFIG_SATA_AHCI_PLATFORM=y
    # CONFIG_AHCI_DWC is not set
    # CONFIG_AHCI_CEVA is not set
    # CONFIG_AHCI_XGENE is not set
    # CONFIG_AHCI_QORIQ is not set
    CONFIG_ATA_SFF=y
    # SFF controllers with custom DMA interface
    CONFIG_ATA_BMDMA=y
    # SATA SFF controllers with BMDMA
    # CONFIG_SATA_DWC is not set
    # PATA SFF controllers with BMDMA
    # PIO-only SFF controllers
    CONFIG_PATA_PLATFORM=y
    CONFIG_PATA_OF_PLATFORM=y
    # Generic fallback / legacy drivers
    CONFIG_MD=y
    CONFIG_BLK_DEV_MD=m
    # CONFIG_MD_LINEAR is not set
    # CONFIG_MD_RAID0 is not set
    # CONFIG_MD_RAID1 is not set
    # CONFIG_MD_RAID10 is not set
    # CONFIG_MD_RAID456 is not set
    # CONFIG_MD_MULTIPATH is not set
    # CONFIG_MD_FAULTY is not set
    # CONFIG_BCACHE is not set
    CONFIG_BLK_DEV_DM_BUILTIN=y
    CONFIG_BLK_DEV_DM=m
    # CONFIG_DM_DEBUG is not set
    CONFIG_DM_BUFIO=m
    # CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
    CONFIG_DM_BIO_PRISON=m
    CONFIG_DM_PERSISTENT_DATA=m
    # CONFIG_DM_UNSTRIPED is not set
    # CONFIG_DM_CRYPT is not set
    # CONFIG_DM_SNAPSHOT is not set
    CONFIG_DM_THIN_PROVISIONING=m
    # CONFIG_DM_CACHE is not set
    # CONFIG_DM_WRITECACHE is not set
    # CONFIG_DM_EBS is not set
    # CONFIG_DM_ERA is not set
    # CONFIG_DM_CLONE is not set
    CONFIG_DM_MIRROR=m
    # CONFIG_DM_LOG_USERSPACE is not set
    # CONFIG_DM_RAID is not set
    CONFIG_DM_ZERO=m
    # CONFIG_DM_MULTIPATH is not set
    # CONFIG_DM_DELAY is not set
    # CONFIG_DM_DUST is not set
    # CONFIG_DM_UEVENT is not set
    # CONFIG_DM_FLAKEY is not set
    # CONFIG_DM_VERITY is not set
    # CONFIG_DM_SWITCH is not set
    # CONFIG_DM_LOG_WRITES is not set
    # CONFIG_DM_INTEGRITY is not set
    # CONFIG_DM_AUDIT is not set
    # CONFIG_TARGET_CORE is not set
    CONFIG_NETDEVICES=y
    CONFIG_MII=m
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    CONFIG_DUMMY=m
    # CONFIG_WIREGUARD is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_IFB is not set
    # CONFIG_NET_TEAM is not set
    CONFIG_MACVLAN=m
    CONFIG_MACVTAP=m
    CONFIG_IPVLAN_L3S=y
    CONFIG_IPVLAN=m
    # CONFIG_IPVTAP is not set
    CONFIG_VXLAN=m
    # CONFIG_GENEVE is not set
    # CONFIG_BAREUDP is not set
    # CONFIG_GTP is not set
    # CONFIG_AMT is not set
    # CONFIG_MACSEC is not set
    # CONFIG_NETCONSOLE is not set
    CONFIG_TUN=y
    CONFIG_TAP=m
    # CONFIG_TUN_VNET_CROSS_LE is not set
    CONFIG_VETH=m
    CONFIG_VIRTIO_NET=y
    # CONFIG_NLMON is not set
    # CONFIG_MHI_NET is not set
    CONFIG_ETHERNET=y
    # CONFIG_NET_VENDOR_ALACRITECH is not set
    # CONFIG_ALTERA_TSE is not set
    # CONFIG_NET_VENDOR_AMAZON is not set
    # CONFIG_NET_VENDOR_AMD is not set
    # CONFIG_NET_VENDOR_AQUANTIA is not set
    # CONFIG_NET_VENDOR_ARC is not set
    # CONFIG_NET_VENDOR_ASIX is not set
    # CONFIG_NET_VENDOR_BROADCOM is not set
    # CONFIG_NET_VENDOR_CADENCE is not set
    # CONFIG_NET_VENDOR_CAVIUM is not set
    # CONFIG_NET_VENDOR_CORTINA is not set
    # CONFIG_NET_VENDOR_DAVICOM is not set
    # CONFIG_DNET is not set
    # CONFIG_NET_VENDOR_ENGLEDER is not set
    # CONFIG_NET_VENDOR_EZCHIP is not set
    # CONFIG_NET_VENDOR_FUNGIBLE is not set
    # CONFIG_NET_VENDOR_GOOGLE is not set
    # CONFIG_NET_VENDOR_HISILICON is not set
    # CONFIG_NET_VENDOR_HUAWEI is not set
    # CONFIG_NET_VENDOR_INTEL is not set
    # CONFIG_NET_VENDOR_WANGXUN is not set
    CONFIG_NET_VENDOR_ADI=y
    # CONFIG_ADIN1110 is not set
    # CONFIG_NET_VENDOR_LITEX is not set
    # CONFIG_NET_VENDOR_MARVELL is not set
    # CONFIG_NET_VENDOR_MELLANOX is not set
    # CONFIG_NET_VENDOR_MICREL is not set
    # CONFIG_NET_VENDOR_MICROCHIP is not set
    # CONFIG_NET_VENDOR_MICROSEMI is not set
    # CONFIG_NET_VENDOR_MICROSOFT is not set
    # CONFIG_NET_VENDOR_NI is not set
    # CONFIG_NET_VENDOR_NATSEMI is not set
    # CONFIG_NET_VENDOR_NETRONOME is not set
    # CONFIG_ETHOC is not set
    # CONFIG_NET_VENDOR_PENSANDO is not set
    # CONFIG_NET_VENDOR_QUALCOMM is not set
    # CONFIG_NET_VENDOR_RENESAS is not set
    # CONFIG_NET_VENDOR_ROCKER is not set
    # CONFIG_NET_VENDOR_SAMSUNG is not set
    # CONFIG_NET_VENDOR_SEEQ is not set
    # CONFIG_NET_VENDOR_SOLARFLARE is not set
    # CONFIG_NET_VENDOR_SMSC is not set
    # CONFIG_NET_VENDOR_SOCIONEXT is not set
    # CONFIG_NET_VENDOR_STMICRO is not set
    # CONFIG_NET_VENDOR_SYNOPSYS is not set
    CONFIG_NET_VENDOR_TI=y
    CONFIG_TI_DAVINCI_MDIO=y
    # CONFIG_TI_CPSW_PHY_SEL is not set
    CONFIG_TI_CPSW_PROXY_CLIENT=m
    CONFIG_TI_K3_AM65_CPSW_NUSS=y
    CONFIG_TI_K3_AM65_CPSW_SWITCHDEV=y
    CONFIG_TI_K3_AM65_CPTS=y
    CONFIG_TI_AM65_CPSW_TAS=y
    CONFIG_TI_RDEV_ETH_SWITCH_VIRT_EMAC=m
    CONFIG_TI_ICSSG_PRUETH=m
    CONFIG_TI_ICSS_IEP=m
    # CONFIG_NET_VENDOR_VERTEXCOM is not set
    # CONFIG_NET_VENDOR_VIA is not set
    # CONFIG_NET_VENDOR_WIZNET is not set
    # CONFIG_NET_VENDOR_XILINX is not set
    CONFIG_PHYLINK=y
    CONFIG_PHYLIB=y
    CONFIG_SWPHY=y
    # CONFIG_LED_TRIGGER_PHY is not set
    CONFIG_FIXED_PHY=y
    # CONFIG_SFP is not set
    # MII PHY device drivers
    # CONFIG_AMD_PHY is not set
    # CONFIG_ADIN_PHY is not set
    # CONFIG_ADIN1100_PHY is not set
    CONFIG_AQUANTIA_PHY=y
    CONFIG_AX88796B_PHY=m
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM54140_PHY is not set
    CONFIG_BCM7XXX_PHY=m
    # CONFIG_BCM84881_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    CONFIG_BCM_NET_PHYLIB=m
    # CONFIG_CICADA_PHY is not set
    # CONFIG_CORTINA_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_INTEL_XWAY_PHY is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    CONFIG_MARVELL_PHY=m
    CONFIG_MARVELL_10G_PHY=m
    # CONFIG_MARVELL_88X2222_PHY is not set
    # CONFIG_MAXLINEAR_GPHY is not set
    # CONFIG_MEDIATEK_GE_PHY is not set
    CONFIG_MICREL_PHY=y
    CONFIG_MICROCHIP_PHY=m
    # CONFIG_MICROCHIP_T1_PHY is not set
    CONFIG_MICROSEMI_PHY=y
    # CONFIG_MOTORCOMM_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_NXP_C45_TJA11XX_PHY is not set
    # CONFIG_NXP_TJA11XX_PHY is not set
    CONFIG_AT803X_PHY=y
    # CONFIG_QSEMI_PHY is not set
    CONFIG_REALTEK_PHY=y
    # CONFIG_RENESAS_PHY is not set
    # CONFIG_ROCKCHIP_PHY is not set
    CONFIG_SMSC_PHY=m
    # CONFIG_STE10XP is not set
    # CONFIG_TERANETICS_PHY is not set
    # CONFIG_DP83822_PHY is not set
    # CONFIG_DP83TC811_PHY is not set
    # CONFIG_DP83848_PHY is not set
    CONFIG_DP83867_PHY=y
    CONFIG_DP83869_PHY=y
    CONFIG_DP83TD510_PHY=y
    CONFIG_VITESSE_PHY=y
    # CONFIG_XILINX_GMII2RGMII is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PSE_CONTROLLER is not set
    CONFIG_CAN_DEV=m
    CONFIG_CAN_VCAN=m
    # CONFIG_CAN_VXCAN is not set
    CONFIG_CAN_NETLINK=y
    CONFIG_CAN_CALC_BITTIMING=y
    CONFIG_CAN_RX_OFFLOAD=y
    # CONFIG_CAN_CAN327 is not set
    # CONFIG_CAN_FLEXCAN is not set
    # CONFIG_CAN_GRCAN is not set
    # CONFIG_CAN_SLCAN is not set
    # CONFIG_CAN_XILINXCAN is not set
    # CONFIG_CAN_C_CAN is not set
    # CONFIG_CAN_CC770 is not set
    # CONFIG_CAN_CTUCANFD_PLATFORM is not set
    # CONFIG_CAN_IFI_CANFD is not set
    CONFIG_CAN_M_CAN=m
    CONFIG_CAN_M_CAN_PLATFORM=m
    # CONFIG_CAN_M_CAN_TCAN4X5X is not set
    # CONFIG_CAN_SJA1000 is not set
    # CONFIG_CAN_SOFTING is not set
    # CAN SPI interfaces
    # CONFIG_CAN_HI311X is not set
    # CONFIG_CAN_MCP251X is not set
    CONFIG_CAN_MCP251XFD=m
    # CONFIG_CAN_MCP251XFD_SANITY is not set
    # end of CAN SPI interfaces
    # CAN USB interfaces
    # CONFIG_CAN_8DEV_USB is not set
    # CONFIG_CAN_EMS_USB is not set
    # CONFIG_CAN_ESD_USB is not set
    # CONFIG_CAN_ETAS_ES58X is not set
    # CONFIG_CAN_GS_USB is not set
    # CONFIG_CAN_KVASER_USB is not set
    # CONFIG_CAN_MCBA_USB is not set
    # CONFIG_CAN_PEAK_USB is not set
    # CONFIG_CAN_UCAN is not set
    # end of CAN USB interfaces
    # CONFIG_CAN_DEBUG_DEVICES is not set
    CONFIG_MDIO_DEVICE=y
    CONFIG_MDIO_BUS=y
    CONFIG_FWNODE_MDIO=y
    CONFIG_OF_MDIO=y
    CONFIG_MDIO_DEVRES=y
    CONFIG_MDIO_BITBANG=y
    CONFIG_MDIO_BCM_UNIMAC=m
    CONFIG_MDIO_GPIO=y
    # CONFIG_MDIO_HISI_FEMAC is not set
    # CONFIG_MDIO_MVUSB is not set
    # CONFIG_MDIO_MSCC_MIIM is not set
    # CONFIG_MDIO_OCTEON is not set
    # CONFIG_MDIO_IPQ4019 is not set
    # CONFIG_MDIO_IPQ8064 is not set
    # MDIO Multiplexers
    CONFIG_MDIO_BUS_MUX=y
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
    CONFIG_MDIO_BUS_MUX_MMIOREG=y
    # PCS device drivers
    # end of PCS device drivers
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    CONFIG_USB_NET_DRIVERS=y
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    CONFIG_USB_PEGASUS=m
    CONFIG_USB_RTL8150=m
    CONFIG_USB_RTL8152=m
    CONFIG_USB_LAN78XX=m
    CONFIG_USB_USBNET=m
    CONFIG_USB_NET_AX8817X=m
    CONFIG_USB_NET_AX88179_178A=m
    CONFIG_USB_NET_CDCETHER=m
    # CONFIG_USB_NET_CDC_EEM is not set
    CONFIG_USB_NET_CDC_NCM=m
    # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
    # CONFIG_USB_NET_CDC_MBIM is not set
    CONFIG_USB_NET_DM9601=m
    # CONFIG_USB_NET_SR9700 is not set
    CONFIG_USB_NET_SR9800=m
    CONFIG_USB_NET_SMSC75XX=m
    CONFIG_USB_NET_SMSC95XX=m
    # CONFIG_USB_NET_GL620A is not set
    CONFIG_USB_NET_NET1080=m
    CONFIG_USB_NET_PLUSB=m
    CONFIG_USB_NET_MCS7830=m
    # CONFIG_USB_NET_RNDIS_HOST is not set
    CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
    CONFIG_USB_NET_CDC_SUBSET=m
    # CONFIG_USB_ALI_M5632 is not set
    # CONFIG_USB_AN2720 is not set
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    # CONFIG_USB_EPSON2888 is not set
    # CONFIG_USB_KC2190 is not set
    CONFIG_USB_NET_ZAURUS=m
    # CONFIG_USB_NET_CX82310_ETH is not set
    # CONFIG_USB_NET_KALMIA is not set
    # CONFIG_USB_NET_QMI_WWAN is not set
    # CONFIG_USB_HSO is not set
    # CONFIG_USB_NET_INT51X1 is not set
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_USB_VL600 is not set
    # CONFIG_USB_NET_CH9200 is not set
    # CONFIG_USB_NET_AQC111 is not set
    CONFIG_USB_RTL8153_ECM=m
    CONFIG_WLAN=y
    # CONFIG_WLAN_VENDOR_ADMTEK is not set
    # CONFIG_WLAN_VENDOR_ATH is not set
    # CONFIG_WLAN_VENDOR_ATMEL is not set
    # CONFIG_WLAN_VENDOR_BROADCOM is not set
    # CONFIG_WLAN_VENDOR_CISCO is not set
    # CONFIG_WLAN_VENDOR_INTEL is not set
    # CONFIG_WLAN_VENDOR_INTERSIL is not set
    CONFIG_WLAN_VENDOR_MARVELL=y
    # CONFIG_LIBERTAS is not set
    # CONFIG_LIBERTAS_THINFIRM is not set
    CONFIG_MWIFIEX=m
    CONFIG_MWIFIEX_SDIO=m
    CONFIG_MWIFIEX_USB=m
    # CONFIG_WLAN_VENDOR_MEDIATEK is not set
    CONFIG_WLAN_VENDOR_MICROCHIP=y
    # CONFIG_WILC1000_SDIO is not set
    # CONFIG_WILC1000_SPI is not set
    CONFIG_WLAN_VENDOR_PURELIFI=y
    # CONFIG_PLFXLC is not set
    # CONFIG_WLAN_VENDOR_RALINK is not set
    CONFIG_WLAN_VENDOR_REALTEK=y
    # CONFIG_RTL8187 is not set
    CONFIG_RTL_CARDS=m
    # CONFIG_RTL8192CU is not set
    # CONFIG_RTL8XXXU is not set
    # CONFIG_RTW88 is not set
    # CONFIG_RTW89 is not set
    # CONFIG_WLAN_VENDOR_RSI is not set
    CONFIG_WLAN_VENDOR_SILABS=y
    # CONFIG_WFX is not set
    # CONFIG_WLAN_VENDOR_ST is not set
    # CONFIG_WLAN_VENDOR_TI is not set
    # CONFIG_WLAN_VENDOR_ZYDAS is not set
    # CONFIG_WLAN_VENDOR_QUANTENNA is not set
    # CONFIG_MAC80211_HWSIM is not set
    # CONFIG_USB_NET_RNDIS_WLAN is not set
    # CONFIG_VIRT_WIFI is not set
    # CONFIG_WAN is not set
    # Wireless WAN
    # CONFIG_WWAN is not set
    # end of Wireless WAN
    # CONFIG_NETDEVSIM is not set
    CONFIG_NET_FAILOVER=y
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    CONFIG_INPUT_LEDS=y
    CONFIG_INPUT_FF_MEMLESS=m
    # CONFIG_INPUT_SPARSEKMAP is not set
    CONFIG_INPUT_MATRIXKMAP=y
    CONFIG_INPUT_VIVALDIFMAP=y
    # Userland interfaces
    # CONFIG_INPUT_MOUSEDEV is not set
    # CONFIG_INPUT_JOYDEV is not set
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    CONFIG_KEYBOARD_ADC=m
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=y
    # CONFIG_KEYBOARD_QT1050 is not set
    # CONFIG_KEYBOARD_QT1070 is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_DLINK_DIR685 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    # CONFIG_KEYBOARD_MATRIX is not set
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_PINEPHONE is not set
    # CONFIG_KEYBOARD_SAMSUNG is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_OMAP4 is not set
    # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
    # CONFIG_KEYBOARD_XTKBD is not set
    # CONFIG_KEYBOARD_CAP11XX is not set
    # CONFIG_KEYBOARD_BCM is not set
    # CONFIG_KEYBOARD_MTK_PMIC is not set
    # CONFIG_KEYBOARD_CYPRESS_SF is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_BYD=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y
    CONFIG_MOUSE_PS2_CYPRESS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    # CONFIG_MOUSE_PS2_ELANTECH is not set
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    CONFIG_MOUSE_PS2_FOCALTECH=y
    CONFIG_MOUSE_PS2_SMBUS=y
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_CYAPA is not set
    # CONFIG_MOUSE_ELAN_I2C is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_MOUSE_SYNAPTICS_USB is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    # CONFIG_TOUCHSCREEN_ADS7846 is not set
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    CONFIG_TOUCHSCREEN_AD7879=m
    CONFIG_TOUCHSCREEN_AD7879_I2C=m
    # CONFIG_TOUCHSCREEN_AD7879_SPI is not set
    # CONFIG_TOUCHSCREEN_ADC is not set
    # CONFIG_TOUCHSCREEN_AR1021_I2C is not set
    CONFIG_TOUCHSCREEN_ATMEL_MXT=m
    # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_BU21029 is not set
    # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
    # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
    # CONFIG_TOUCHSCREEN_EXC3000 is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    CONFIG_TOUCHSCREEN_GOODIX=m
    # CONFIG_TOUCHSCREEN_HIDEEP is not set
    # CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set
    CONFIG_TOUCHSCREEN_ILI210X=m
    CONFIG_TOUCHSCREEN_ILITEK=m
    # CONFIG_TOUCHSCREEN_S6SY761 is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_EKTF2127 is not set
    # CONFIG_TOUCHSCREEN_ELAN is not set
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    # CONFIG_TOUCHSCREEN_MMS114 is not set
    # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
    # CONFIG_TOUCHSCREEN_MSG2638 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_IMAGIS is not set
    # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    CONFIG_TOUCHSCREEN_EDT_FT5X06=m
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    # CONFIG_TOUCHSCREEN_TI_AM335X_TSC is not set
    # CONFIG_TOUCHSCREEN_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    # CONFIG_TOUCHSCREEN_TSC2004 is not set
    # CONFIG_TOUCHSCREEN_TSC2005 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    # CONFIG_TOUCHSCREEN_RM_TS is not set
    # CONFIG_TOUCHSCREEN_SILEAD is not set
    # CONFIG_TOUCHSCREEN_SIS_I2C is not set
    # CONFIG_TOUCHSCREEN_ST1232 is not set
    # CONFIG_TOUCHSCREEN_STMFTS is not set
    # CONFIG_TOUCHSCREEN_SUR40 is not set
    # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
    # CONFIG_TOUCHSCREEN_SX8654 is not set
    # CONFIG_TOUCHSCREEN_TPS6507X is not set
    # CONFIG_TOUCHSCREEN_ZET6223 is not set
    # CONFIG_TOUCHSCREEN_ZFORCE is not set
    # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set
    # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
    # CONFIG_TOUCHSCREEN_IQS5XX is not set
    # CONFIG_TOUCHSCREEN_ZINITIX is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_ATMEL_CAPTOUCH is not set
    # CONFIG_INPUT_BMA150 is not set
    # CONFIG_INPUT_E3X0_BUTTON is not set
    # CONFIG_INPUT_MMA8450 is not set
    # CONFIG_INPUT_GPIO_BEEPER is not set
    # CONFIG_INPUT_GPIO_DECODER is not set
    # CONFIG_INPUT_GPIO_VIBRA is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_KXTJ9 is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    # CONFIG_INPUT_REGULATOR_HAPTIC is not set
    CONFIG_INPUT_TPS65219_PWRBUTTON=y
    # CONFIG_INPUT_AXP20X_PEK is not set
    # CONFIG_INPUT_UINPUT is not set
    # CONFIG_INPUT_PCF8574 is not set
    CONFIG_INPUT_PWM_BEEPER=m
    CONFIG_INPUT_PWM_VIBRA=m
    # CONFIG_INPUT_RK805_PWRKEY is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    # CONFIG_INPUT_DA7280_HAPTICS is not set
    # CONFIG_INPUT_ADXL34X is not set
    # CONFIG_INPUT_IBM_PANEL is not set
    # CONFIG_INPUT_IMS_PCU is not set
    # CONFIG_INPUT_IQS269A is not set
    # CONFIG_INPUT_IQS626A is not set
    # CONFIG_INPUT_IQS7222 is not set
    # CONFIG_INPUT_CMA3000 is not set
    # CONFIG_INPUT_DRV260X_HAPTICS is not set
    # CONFIG_INPUT_DRV2665_HAPTICS is not set
    # CONFIG_INPUT_DRV2667_HAPTICS is not set
    # CONFIG_RMI4_CORE is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    # CONFIG_SERIO_SERPORT is not set
    CONFIG_SERIO_AMBAKMI=y
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_SERIO_GPIO_PS2 is not set
    # CONFIG_USERIO is not set
    # CONFIG_GAMEPORT is not set
    # end of Hardware I/O ports
    # end of Input device support
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    CONFIG_LEGACY_PTYS=y
    CONFIG_LEGACY_PTY_COUNT=16
    CONFIG_LDISC_AUTOLOAD=y
    # Serial drivers
    CONFIG_SERIAL_EARLYCON=y
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
    CONFIG_SERIAL_8250_16550A_VARIANTS=y
    # CONFIG_SERIAL_8250_FINTEK is not set
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_DMA=y
    CONFIG_SERIAL_8250_NR_UARTS=6
    CONFIG_SERIAL_8250_RUNTIME_UARTS=6
    CONFIG_SERIAL_8250_EXTENDED=y
    # CONFIG_SERIAL_8250_MANY_PORTS is not set
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    # CONFIG_SERIAL_8250_DETECT_IRQ is not set
    # CONFIG_SERIAL_8250_RSA is not set
    CONFIG_SERIAL_8250_FSL=y
    # CONFIG_SERIAL_8250_DW is not set
    # CONFIG_SERIAL_8250_RT288X is not set
    CONFIG_SERIAL_8250_OMAP=y
    CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
    CONFIG_SERIAL_8250_PRUSS=m
    CONFIG_SERIAL_OF_PLATFORM=y
    # Non-8250 serial port support
    # CONFIG_SERIAL_AMBA_PL010 is not set
    # CONFIG_SERIAL_AMBA_PL011 is not set
    # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    # CONFIG_SERIAL_UARTLITE is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_SIFIVE is not set
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_SC16IS7XX is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_XILINX_PS_UART is not set
    # CONFIG_SERIAL_ARC is not set
    CONFIG_SERIAL_FSL_LPUART=y
    CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
    CONFIG_SERIAL_FSL_LINFLEXUART=y
    CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y
    # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
    # CONFIG_SERIAL_SPRD is not set
    # end of Serial drivers
    CONFIG_SERIAL_MCTRL_GPIO=y
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_N_GSM is not set
    # CONFIG_NULL_TTY is not set
    CONFIG_HVC_DRIVER=y
    # CONFIG_HVC_DCC is not set
    # CONFIG_RPMSG_TTY is not set
    CONFIG_SERIAL_DEV_BUS=y
    CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
    # CONFIG_TTY_PRINTK is not set
    CONFIG_VIRTIO_CONSOLE=y
    CONFIG_IPMI_HANDLER=m
    CONFIG_IPMI_DMI_DECODE=y
    CONFIG_IPMI_PLAT_DATA=y
    # CONFIG_IPMI_PANIC_EVENT is not set
    CONFIG_IPMI_DEVICE_INTERFACE=m
    CONFIG_IPMI_SI=m
    # CONFIG_IPMI_SSIF is not set
    # CONFIG_IPMI_IPMB is not set
    # CONFIG_IPMI_WATCHDOG is not set
    # CONFIG_IPMI_POWEROFF is not set
    # CONFIG_IPMB_DEVICE_INTERFACE is not set
    CONFIG_HW_RANDOM=m
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    # CONFIG_HW_RANDOM_BA431 is not set
    CONFIG_HW_RANDOM_OMAP=m
    # CONFIG_HW_RANDOM_VIRTIO is not set
    CONFIG_HW_RANDOM_OPTEE=m
    # CONFIG_HW_RANDOM_CCTRNG is not set
    # CONFIG_HW_RANDOM_XIPHERA is not set
    # CONFIG_HW_RANDOM_ARM_SMCCC_TRNG is not set
    CONFIG_DEVMEM=y
    CONFIG_TCG_TPM=y
    CONFIG_TCG_TIS_CORE=m
    # CONFIG_TCG_TIS is not set
    CONFIG_TCG_TIS_SPI=m
    # CONFIG_TCG_TIS_SPI_CR50 is not set
    # CONFIG_TCG_TIS_I2C is not set
    # CONFIG_TCG_TIS_I2C_CR50 is not set
    # CONFIG_TCG_TIS_I2C_ATMEL is not set
    CONFIG_TCG_TIS_I2C_INFINEON=y
    # CONFIG_TCG_TIS_I2C_NUVOTON is not set
    # CONFIG_TCG_VTPM_PROXY is not set
    # CONFIG_TCG_FTPM_TEE is not set
    # CONFIG_TCG_TIS_ST33ZP24_I2C is not set
    # CONFIG_TCG_TIS_ST33ZP24_SPI is not set
    # CONFIG_XILLYBUS is not set
    # CONFIG_XILLYUSB is not set
    CONFIG_RANDOM_TRUST_CPU=y
    CONFIG_RANDOM_TRUST_BOOTLOADER=y
    # end of Character devices
    # I2C support
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_MUX=y
    # Multiplexer I2C Chip support
    # CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
    # CONFIG_I2C_MUX_GPIO is not set
    # CONFIG_I2C_MUX_GPMUX is not set
    # CONFIG_I2C_MUX_LTC4306 is not set
    # CONFIG_I2C_MUX_PCA9541 is not set
    CONFIG_I2C_MUX_PCA954x=y
    # CONFIG_I2C_MUX_PINCTRL is not set
    # CONFIG_I2C_MUX_REG is not set
    # CONFIG_I2C_DEMUX_PINCTRL is not set
    # CONFIG_I2C_MUX_MLXCPLD is not set
    # end of Multiplexer I2C Chip support
    CONFIG_I2C_ATR=m
    CONFIG_I2C_HELPER_AUTO=y
    CONFIG_I2C_ALGOBIT=m
    # I2C Hardware Bus support
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_CADENCE is not set
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    # CONFIG_I2C_EMEV2 is not set
    CONFIG_I2C_GPIO=m
    # CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
    # CONFIG_I2C_NOMADIK is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_RK3X is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_CP2615 is not set
    # CONFIG_I2C_ROBOTFUZZ_OSIF is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_VIRTIO is not set
    # end of I2C Hardware Bus support
    # CONFIG_I2C_STUB is not set
    CONFIG_I2C_SLAVE=y
    # CONFIG_I2C_SLAVE_EEPROM is not set
    # CONFIG_I2C_SLAVE_TESTUNIT is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    # end of I2C support
    # CONFIG_I3C is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    CONFIG_SPI_MEM=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    # CONFIG_SPI_AXI_SPI_ENGINE is not set
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_CADENCE is not set
    CONFIG_SPI_CADENCE_QUADSPI=y
    # CONFIG_SPI_CADENCE_XSPI is not set
    CONFIG_SPI_DESIGNWARE=y
    CONFIG_SPI_DW_DMA=y
    # CONFIG_SPI_DW_MMIO is not set
    # CONFIG_SPI_NXP_FLEXSPI is not set
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_MICROCHIP_CORE is not set
    # CONFIG_SPI_MICROCHIP_CORE_QSPI is not set
    # CONFIG_SPI_OC_TINY is not set
    CONFIG_SPI_OMAP24XX=m
    # CONFIG_SPI_PL022 is not set
    # CONFIG_SPI_ROCKCHIP is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_SIFIVE is not set
    # CONFIG_SPI_MXIC is not set
    # CONFIG_SPI_XCOMM is not set
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_ZYNQMP_GQSPI is not set
    # CONFIG_SPI_AMD is not set
    # SPI Multiplexer support
    # CONFIG_SPI_MUX is not set
    # SPI Protocol Masters
    CONFIG_SPI_SPIDEV=y
    # CONFIG_SPI_LOOPBACK_TEST is not set
    # CONFIG_SPI_TLE62X0 is not set
    CONFIG_SPI_SLAVE=y
    # CONFIG_SPI_SLAVE_TIME is not set
    # CONFIG_SPI_SLAVE_SYSTEM_CONTROL is not set
    CONFIG_SPI_DYNAMIC=y
    # CONFIG_SPMI is not set
    # CONFIG_HSI is not set
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    CONFIG_PPS_CLIENT_LDISC=m
    CONFIG_PPS_CLIENT_GPIO=m
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    CONFIG_PTP_1588_CLOCK_OPTIONAL=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    CONFIG_PTP_1588_CLOCK_KVM=y
    # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
    # CONFIG_PTP_1588_CLOCK_IDTCM is not set
    # end of PTP clock support
    CONFIG_PINCTRL=y
    CONFIG_GENERIC_PINCTRL_GROUPS=y
    CONFIG_PINMUX=y
    CONFIG_GENERIC_PINMUX_FUNCTIONS=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    # CONFIG_DEBUG_PINCTRL is not set
    # CONFIG_PINCTRL_AXP209 is not set
    # CONFIG_PINCTRL_CY8C95X0 is not set
    # CONFIG_PINCTRL_MAX77620 is not set
    # CONFIG_PINCTRL_MCP23S08 is not set
    # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
    # CONFIG_PINCTRL_OCELOT is not set
    # CONFIG_PINCTRL_RK805 is not set
    CONFIG_PINCTRL_SINGLE=y
    # CONFIG_PINCTRL_STMFX is not set
    # CONFIG_PINCTRL_SX150X is not set
    CONFIG_PINCTRL_TPS6594=y
    # Renesas pinctrl drivers
    # end of Renesas pinctrl drivers
    CONFIG_GPIOLIB=y
    CONFIG_GPIOLIB_FASTPATH_LIMIT=512
    CONFIG_OF_GPIO=y
    CONFIG_GPIOLIB_IRQCHIP=y
    # CONFIG_DEBUG_GPIO is not set
    CONFIG_GPIO_SYSFS=y
    CONFIG_GPIO_CDEV=y
    CONFIG_GPIO_CDEV_V1=y
    CONFIG_GPIO_GENERIC=y
    # Memory mapped GPIO drivers
    # CONFIG_GPIO_74XX_MMIO is not set
    # CONFIG_GPIO_ALTERA is not set
    # CONFIG_GPIO_CADENCE is not set
    CONFIG_GPIO_DAVINCI=y
    # CONFIG_GPIO_DWAPB is not set
    # CONFIG_GPIO_FTGPIO010 is not set
    CONFIG_GPIO_GENERIC_PLATFORM=y
    # CONFIG_GPIO_GRGPIO is not set
    # CONFIG_GPIO_HLWD is not set
    # CONFIG_GPIO_LOGICVC is not set
    # CONFIG_GPIO_MB86S7X is not set
    # CONFIG_GPIO_PL061 is not set
    # CONFIG_GPIO_SIFIVE is not set
    # CONFIG_GPIO_SYSCON is not set
    # CONFIG_GPIO_XGENE is not set
    # CONFIG_GPIO_XILINX is not set
    # CONFIG_GPIO_AMD_FCH is not set
    # end of Memory mapped GPIO drivers
    # I2C GPIO expanders
    # CONFIG_GPIO_ADNP is not set
    # CONFIG_GPIO_GW_PLD is not set
    # CONFIG_GPIO_MAX7300 is not set
    CONFIG_GPIO_MAX732X=y
    # CONFIG_GPIO_MAX732X_IRQ is not set
    CONFIG_GPIO_PCA953X=y
    CONFIG_GPIO_PCA953X_IRQ=y
    # CONFIG_GPIO_PCA9570 is not set
    # CONFIG_GPIO_PCF857X is not set
    # CONFIG_GPIO_TPIC2810 is not set
    # end of I2C GPIO expanders
    # MFD GPIO expanders
    CONFIG_GPIO_BD9571MWV=m
    CONFIG_GPIO_MAX77620=y
    # CONFIG_GPIO_WM8994 is not set
    # end of MFD GPIO expanders
    # SPI GPIO expanders
    # CONFIG_GPIO_74X164 is not set
    # CONFIG_GPIO_MAX3191X is not set
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_PISOSR is not set
    # CONFIG_GPIO_XRA1403 is not set
    # end of SPI GPIO expanders
    # USB GPIO expanders
    # end of USB GPIO expanders
    # Virtual GPIO drivers
    # CONFIG_GPIO_AGGREGATOR is not set
    # CONFIG_GPIO_MOCKUP is not set
    # CONFIG_GPIO_VIRTIO is not set
    # CONFIG_GPIO_SIM is not set
    # end of Virtual GPIO drivers
    # CONFIG_W1 is not set
    CONFIG_POWER_RESET=y
    CONFIG_POWER_RESET_BRCMSTB=y
    # CONFIG_POWER_RESET_GPIO is not set
    # CONFIG_POWER_RESET_GPIO_RESTART is not set
    # CONFIG_POWER_RESET_LTC2952 is not set
    # CONFIG_POWER_RESET_MT6323 is not set
    # CONFIG_POWER_RESET_REGULATOR is not set
    # CONFIG_POWER_RESET_RESTART is not set
    # CONFIG_POWER_RESET_XGENE is not set
    CONFIG_POWER_RESET_SYSCON=y
    # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
    CONFIG_REBOOT_MODE=y
    CONFIG_SYSCON_REBOOT_MODE=y
    # CONFIG_NVMEM_REBOOT_MODE is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    CONFIG_POWER_SUPPLY_HWMON=y
    # CONFIG_PDA_POWER is not set
    # CONFIG_GENERIC_ADC_BATTERY is not set
    # CONFIG_IP5XXX_POWER is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_CHARGER_ADP5061 is not set
    # CONFIG_BATTERY_CW2015 is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_SAMSUNG_SDI is not set
    CONFIG_BATTERY_SBS=m
    # CONFIG_CHARGER_SBS is not set
    # CONFIG_MANAGER_SBS is not set
    CONFIG_BATTERY_BQ27XXX=y
    CONFIG_BATTERY_BQ27XXX_I2C=y
    # CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set
    # CONFIG_AXP20X_POWER is not set
    # CONFIG_BATTERY_MAX17040 is not set
    CONFIG_BATTERY_MAX17042=m
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_MAX8903 is not set
    # CONFIG_CHARGER_LP8727 is not set
    # CONFIG_CHARGER_GPIO is not set
    # CONFIG_CHARGER_MANAGER is not set
    # CONFIG_CHARGER_LT3651 is not set
    # CONFIG_CHARGER_LTC4162L is not set
    # CONFIG_CHARGER_DETECTOR_MAX14656 is not set
    # CONFIG_CHARGER_MAX77976 is not set
    CONFIG_CHARGER_MT6360=m
    # CONFIG_CHARGER_BQ2415X is not set
    # CONFIG_CHARGER_BQ24190 is not set
    # CONFIG_CHARGER_BQ24257 is not set
    # CONFIG_CHARGER_BQ24735 is not set
    # CONFIG_CHARGER_BQ2515X is not set
    CONFIG_CHARGER_BQ25890=m
    CONFIG_CHARGER_BQ25980=m
    # CONFIG_CHARGER_BQ256XX is not set
    # CONFIG_CHARGER_RK817 is not set
    # CONFIG_CHARGER_SMB347 is not set
    # CONFIG_BATTERY_GAUGE_LTC2941 is not set
    # CONFIG_BATTERY_GOLDFISH is not set
    # CONFIG_BATTERY_RT5033 is not set
    # CONFIG_CHARGER_RT9455 is not set
    # CONFIG_CHARGER_UCS1002 is not set
    # CONFIG_CHARGER_BD99954 is not set
    # CONFIG_BATTERY_UG3105 is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM1177 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_AHT10 is not set
    # CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set
    # CONFIG_SENSORS_AS370 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_AXI_FAN_CONTROL is not set
    CONFIG_SENSORS_ARM_SCMI=y
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_CORSAIR_CPRO is not set
    # CONFIG_SENSORS_CORSAIR_PSU is not set
    # CONFIG_SENSORS_DRIVETEMP is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_FTSTEUTATES is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    CONFIG_SENSORS_GPIO_FAN=y
    # CONFIG_SENSORS_HIH6130 is not set
    # CONFIG_SENSORS_IBMAEM is not set
    # CONFIG_SENSORS_IBMPEX is not set
    # CONFIG_SENSORS_IIO_HWMON is not set
    # CONFIG_SENSORS_IT87 is not set
    CONFIG_SENSORS_JC42=m
    # CONFIG_SENSORS_POWR1220 is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LTC2945 is not set
    # CONFIG_SENSORS_LTC2947_I2C is not set
    # CONFIG_SENSORS_LTC2947_SPI is not set
    # CONFIG_SENSORS_LTC2990 is not set
    # CONFIG_SENSORS_LTC2992 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4222 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4260 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX127 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX31722 is not set
    # CONFIG_SENSORS_MAX31730 is not set
    # CONFIG_SENSORS_MAX31760 is not set
    # CONFIG_SENSORS_MAX6620 is not set
    # CONFIG_SENSORS_MAX6621 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_MAX31790 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_TC654 is not set
    # CONFIG_SENSORS_TPS23861 is not set
    # CONFIG_SENSORS_MR75203 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    CONFIG_SENSORS_LM75=m
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    CONFIG_SENSORS_LM90=m
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    # CONFIG_SENSORS_LM95245 is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_NTC_THERMISTOR is not set
    # CONFIG_SENSORS_NCT6683 is not set
    # CONFIG_SENSORS_NCT6775 is not set
    # CONFIG_SENSORS_NCT6775_I2C is not set
    # CONFIG_SENSORS_NCT7802 is not set
    # CONFIG_SENSORS_NCT7904 is not set
    # CONFIG_SENSORS_NPCM7XX is not set
    # CONFIG_SENSORS_NZXT_KRAKEN2 is not set
    # CONFIG_SENSORS_NZXT_SMART2 is not set
    # CONFIG_SENSORS_OCC_P8_I2C is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    CONFIG_SENSORS_PWM_FAN=m
    # CONFIG_SENSORS_SBTSI is not set
    # CONFIG_SENSORS_SBRMI is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SHT3x is not set
    # CONFIG_SENSORS_SHT4x is not set
    # CONFIG_SENSORS_SHTC1 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC2305 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_STTS751 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_ADC128D818 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    CONFIG_SENSORS_INA2XX=m
    # CONFIG_SENSORS_INA238 is not set
    CONFIG_SENSORS_INA3221=m
    # CONFIG_SENSORS_TC74 is not set
    # CONFIG_SENSORS_THMC50 is not set
    CONFIG_SENSORS_TMP102=m
    # CONFIG_SENSORS_TMP103 is not set
    # CONFIG_SENSORS_TMP108 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_TMP464 is not set
    # CONFIG_SENSORS_TMP513 is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_W83773G is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_THERMAL=y
    # CONFIG_THERMAL_NETLINK is not set
    CONFIG_THERMAL_STATISTICS=y
    CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=10000
    CONFIG_THERMAL_HWMON=y
    CONFIG_THERMAL_OF=y
    # CONFIG_THERMAL_WRITABLE_TRIPS is not set
    CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
    # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
    # CONFIG_THERMAL_GOV_FAIR_SHARE is not set
    CONFIG_THERMAL_GOV_STEP_WISE=y
    # CONFIG_THERMAL_GOV_BANG_BANG is not set
    # CONFIG_THERMAL_GOV_USER_SPACE is not set
    CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
    CONFIG_CPU_THERMAL=y
    CONFIG_CPU_FREQ_THERMAL=y
    CONFIG_DEVFREQ_THERMAL=y
    CONFIG_THERMAL_EMULATION=y
    # CONFIG_THERMAL_MMIO is not set
    CONFIG_K3_THERMAL=y
    # CONFIG_MAX77620_THERMAL is not set
    # CONFIG_GENERIC_ADC_THERMAL is not set
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
    CONFIG_WATCHDOG_OPEN_TIMEOUT=0
    # CONFIG_WATCHDOG_SYSFS is not set
    # CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
    # Watchdog Pretimeout Governors
    # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_GPIO_WATCHDOG is not set
    # CONFIG_XILINX_WATCHDOG is not set
    # CONFIG_ZIIRAVE_WATCHDOG is not set
    # CONFIG_ARM_SP805_WATCHDOG is not set
    # CONFIG_ARM_SBSA_WATCHDOG is not set
    # CONFIG_CADENCE_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_K3_RTI_WATCHDOG=y
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_MAX77620_WATCHDOG is not set
    CONFIG_ARM_SMC_WATCHDOG=y
    # CONFIG_MEN_A21_WDT is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    # CONFIG_BCMA is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_ACT8945A is not set
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_MFD_AS3722 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_ATMEL_FLEXCOM is not set
    # CONFIG_MFD_ATMEL_HLCDC is not set
    # CONFIG_MFD_BCM590XX is not set
    CONFIG_MFD_BD9571MWV=y
    CONFIG_MFD_AXP20X=y
    CONFIG_MFD_AXP20X_I2C=y
    # CONFIG_MFD_MADERA is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9062 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_DA9150 is not set
    # CONFIG_MFD_DLN2 is not set
    # CONFIG_MFD_GATEWORKS_GSC is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_MFD_MP2629 is not set
    CONFIG_MFD_HI6421_PMIC=y
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_MFD_IQS62X is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX14577 is not set
    CONFIG_MFD_MAX77620=y
    # CONFIG_MFD_MAX77650 is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX77714 is not set
    # CONFIG_MFD_MAX77843 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    CONFIG_MFD_MT6360=y
    # CONFIG_MFD_MT6370 is not set
    CONFIG_MFD_MT6397=y
    # CONFIG_MFD_MENF21BMC is not set
    # CONFIG_MFD_OCELOT is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_CPCAP is not set
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_NTXEC is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_SY7636A is not set
    # CONFIG_MFD_RT4831 is not set
    # CONFIG_MFD_RT5033 is not set
    # CONFIG_MFD_RT5120 is not set
    # CONFIG_MFD_RC5T583 is not set
    CONFIG_MFD_RK808=y
    # CONFIG_MFD_RN5T618 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SKY81452 is not set
    # CONFIG_MFD_STMPE is not set
    CONFIG_MFD_SYSCON=y
    CONFIG_MFD_TI_AM335X_TSCADC=m
    # CONFIG_MFD_LP3943 is not set
    # CONFIG_MFD_LP8788 is not set
    # CONFIG_MFD_TI_LMU is not set
    # CONFIG_MFD_PALMAS is not set
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65086 is not set
    # CONFIG_MFD_TPS65090 is not set
    # CONFIG_MFD_TPS65217 is not set
    # CONFIG_MFD_TI_LP873X is not set
    # CONFIG_MFD_TI_LP87565 is not set
    # CONFIG_MFD_TPS65218 is not set
    CONFIG_MFD_TPS65219=y
    # CONFIG_MFD_TPS6586X is not set
    # CONFIG_MFD_TPS65910 is not set
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    CONFIG_MFD_TPS6594=y
    CONFIG_MFD_TPS6594_I2C=y
    # CONFIG_MFD_TPS6594_SPI is not set
    # CONFIG_TWL4030_CORE is not set
    # CONFIG_TWL6040_CORE is not set
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_TQMX86 is not set
    # CONFIG_MFD_LOCHNAGAR is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    CONFIG_MFD_WM8994=m
    CONFIG_MFD_ROHM_BD718XX=y
    # CONFIG_MFD_ROHM_BD71828 is not set
    # CONFIG_MFD_ROHM_BD957XMUF is not set
    # CONFIG_MFD_STPMIC1 is not set
    # CONFIG_MFD_STMFX is not set
    # CONFIG_MFD_ATC260X_I2C is not set
    # CONFIG_MFD_QCOM_PM8008 is not set
    # CONFIG_RAVE_SP_CORE is not set
    # CONFIG_MFD_INTEL_M10_BMC is not set
    # CONFIG_MFD_RSMU_I2C is not set
    # CONFIG_MFD_RSMU_SPI is not set
    # end of Multifunction device drivers
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    CONFIG_REGULATOR_FIXED_VOLTAGE=y
    CONFIG_REGULATOR_VIRTUAL_CONSUMER=y
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_88PG86X is not set
    # CONFIG_REGULATOR_ACT8865 is not set
    # CONFIG_REGULATOR_AD5398 is not set
    # CONFIG_REGULATOR_ARM_SCMI is not set
    CONFIG_REGULATOR_AXP20X=y
    CONFIG_REGULATOR_BD718XX=y
    CONFIG_REGULATOR_BD9571MWV=y
    # CONFIG_REGULATOR_DA9121 is not set
    # CONFIG_REGULATOR_DA9210 is not set
    # CONFIG_REGULATOR_DA9211 is not set
    CONFIG_REGULATOR_FAN53555=y
    # CONFIG_REGULATOR_FAN53880 is not set
    CONFIG_REGULATOR_GPIO=y
    # CONFIG_REGULATOR_HI6421 is not set
    CONFIG_REGULATOR_HI6421V530=y
    # CONFIG_REGULATOR_ISL9305 is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_LP872X is not set
    # CONFIG_REGULATOR_LP8755 is not set
    # CONFIG_REGULATOR_LTC3589 is not set
    # CONFIG_REGULATOR_LTC3676 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    CONFIG_REGULATOR_MAX77620=y
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8893 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    CONFIG_REGULATOR_MAX8973=y
    # CONFIG_REGULATOR_MAX20086 is not set
    # CONFIG_REGULATOR_MAX77826 is not set
    # CONFIG_REGULATOR_MCP16502 is not set
    # CONFIG_REGULATOR_MP5416 is not set
    CONFIG_REGULATOR_MP8859=y
    # CONFIG_REGULATOR_MP886X is not set
    # CONFIG_REGULATOR_MPQ7920 is not set
    # CONFIG_REGULATOR_MT6311 is not set
    # CONFIG_REGULATOR_MT6323 is not set
    # CONFIG_REGULATOR_MT6331 is not set
    # CONFIG_REGULATOR_MT6332 is not set
    CONFIG_REGULATOR_MT6358=y
    CONFIG_REGULATOR_MT6359=y
    CONFIG_REGULATOR_MT6360=y
    CONFIG_REGULATOR_MT6397=y
    CONFIG_REGULATOR_PCA9450=y
    CONFIG_REGULATOR_PF8X00=y
    CONFIG_REGULATOR_PFUZE100=y
    # CONFIG_REGULATOR_PV88060 is not set
    # CONFIG_REGULATOR_PV88080 is not set
    # CONFIG_REGULATOR_PV88090 is not set
    CONFIG_REGULATOR_PWM=y
    CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY=m
    CONFIG_REGULATOR_RK808=y
    CONFIG_REGULATOR_ROHM=y
    # CONFIG_REGULATOR_RT4801 is not set
    # CONFIG_REGULATOR_RT5190A is not set
    # CONFIG_REGULATOR_RT5759 is not set
    # CONFIG_REGULATOR_RT6160 is not set
    # CONFIG_REGULATOR_RT6245 is not set
    # CONFIG_REGULATOR_RTQ2134 is not set
    # CONFIG_REGULATOR_RTMV20 is not set
    # CONFIG_REGULATOR_RTQ6752 is not set
    # CONFIG_REGULATOR_SLG51000 is not set
    # CONFIG_REGULATOR_SY8106A is not set
    # CONFIG_REGULATOR_SY8824X is not set
    # CONFIG_REGULATOR_SY8827N is not set
    # CONFIG_REGULATOR_TPS51632 is not set
    # CONFIG_REGULATOR_TPS62360 is not set
    # CONFIG_REGULATOR_TPS6286X is not set
    # CONFIG_REGULATOR_TPS65023 is not set
    # CONFIG_REGULATOR_TPS6507X is not set
    CONFIG_REGULATOR_TPS65132=m
    CONFIG_REGULATOR_TPS65219=y
    CONFIG_REGULATOR_TPS6594=y
    # CONFIG_REGULATOR_TPS6524X is not set
    CONFIG_REGULATOR_VCTRL=m
    # CONFIG_REGULATOR_WM8994 is not set
    # CONFIG_RC_CORE is not set
    # CEC support
    CONFIG_MEDIA_CEC_SUPPORT=y
    # CONFIG_CEC_CH7322 is not set
    # CONFIG_CEC_GPIO is not set
    # CONFIG_USB_PULSE8_CEC is not set
    # CONFIG_USB_RAINSHADOW_CEC is not set
    # end of CEC support
    CONFIG_MEDIA_SUPPORT=m
    # CONFIG_MEDIA_SUPPORT_FILTER is not set
    # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
    # Media device types
    CONFIG_MEDIA_CAMERA_SUPPORT=y
    CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
    CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
    CONFIG_MEDIA_RADIO_SUPPORT=y
    CONFIG_MEDIA_SDR_SUPPORT=y
    CONFIG_MEDIA_PLATFORM_SUPPORT=y
    CONFIG_MEDIA_TEST_SUPPORT=y
    # end of Media device types
    # Media core support
    CONFIG_VIDEO_DEV=m
    CONFIG_MEDIA_CONTROLLER=y
    CONFIG_DVB_CORE=m
    # end of Media core support
    # Video4Linux options
    CONFIG_VIDEO_V4L2_I2C=y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_V4L2_MEM2MEM_DEV=m
    CONFIG_V4L2_FWNODE=m
    CONFIG_V4L2_ASYNC=m
    # end of Video4Linux options
    # Media controller options
    # CONFIG_MEDIA_CONTROLLER_DVB is not set
    # end of Media controller options
    # Digital TV options
    # CONFIG_DVB_MMAP is not set
    # CONFIG_DVB_NET is not set
    CONFIG_DVB_MAX_ADAPTERS=16
    CONFIG_DVB_DYNAMIC_MINORS=y
    # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
    # CONFIG_DVB_ULE_DEBUG is not set
    # end of Digital TV options
    # Media drivers
    # Media drivers
    CONFIG_MEDIA_USB_SUPPORT=y
    # Webcam devices
    # CONFIG_USB_GSPCA is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_USB_S2255 is not set
    # CONFIG_VIDEO_USBTV is not set
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    # Analog TV USB devices
    # CONFIG_VIDEO_GO7007 is not set
    # CONFIG_VIDEO_HDPVR is not set
    # CONFIG_VIDEO_PVRUSB2 is not set
    # CONFIG_VIDEO_STK1160_COMMON is not set
    # Analog/digital TV USB devices
    # CONFIG_VIDEO_AU0828 is not set
    # CONFIG_VIDEO_CX231XX is not set
    # Digital TV USB devices
    # CONFIG_DVB_AS102 is not set
    # CONFIG_DVB_B2C2_FLEXCOP_USB is not set
    # CONFIG_DVB_USB_V2 is not set
    # CONFIG_SMS_USB_DRV is not set
    # Webcam, TV (analog/digital) USB devices
    # CONFIG_VIDEO_EM28XX is not set
    # Software defined radio USB devices
    # CONFIG_USB_AIRSPY is not set
    # CONFIG_USB_HACKRF is not set
    # CONFIG_USB_MSI2500 is not set
    CONFIG_RADIO_ADAPTERS=m
    # CONFIG_RADIO_SAA7706H is not set
    # CONFIG_RADIO_SHARK is not set
    # CONFIG_RADIO_SHARK2 is not set
    # CONFIG_RADIO_SI4713 is not set
    # CONFIG_RADIO_TEA5764 is not set
    # CONFIG_RADIO_TEF6862 is not set
    # CONFIG_RADIO_WL1273 is not set
    # CONFIG_USB_DSBR is not set
    # CONFIG_USB_KEENE is not set
    # CONFIG_USB_MA901 is not set
    # CONFIG_USB_MR800 is not set
    # CONFIG_USB_RAREMONO is not set
    # CONFIG_RADIO_SI470X is not set
    CONFIG_MEDIA_PLATFORM_DRIVERS=y
    CONFIG_V4L_PLATFORM_DRIVERS=y
    CONFIG_SDR_PLATFORM_DRIVERS=y
    # CONFIG_DVB_PLATFORM_DRIVERS is not set
    CONFIG_V4L_MEM2MEM_DRIVERS=y
    # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
    # CONFIG_VIDEO_MUX is not set
    # Allegro DVT media platform drivers
    # Amlogic media platform drivers
    # Amphion drivers
    # Aspeed media platform drivers
    # CONFIG_VIDEO_ASPEED is not set
    # Atmel media platform drivers
    # Cadence media platform drivers
    CONFIG_VIDEO_CADENCE_CSI2RX=m
    # CONFIG_VIDEO_CADENCE_CSI2TX is not set
    # Chips&Media media platform drivers
    CONFIG_VIDEO_WAVE_VPU=m
    # IMG media platform drivers
    CONFIG_VIDEO_IMG_VXD_DEC=m
    CONFIG_VIDEO_IMG_VXE_ENC=m
    CONFIG_VIDEO_E5010_JPEG_ENC=m
    # Intel media platform drivers
    # Marvell media platform drivers
    # Mediatek media platform drivers
    # NVidia media platform drivers
    # NXP media platform drivers
    # Qualcomm media platform drivers
    # Renesas media platform drivers
    # Rockchip media platform drivers
    # Samsung media platform drivers
    # STMicroelectronics media platform drivers
    # Sunxi media platform drivers
    # Texas Instruments drivers
    # CONFIG_VIDEO_TI_CAL is not set
    CONFIG_VIDEO_TI_J721E_CSI2RX=m
    # Verisilicon media platform drivers
    # VIA media platform drivers
    # Xilinx media platform drivers
    # CONFIG_VIDEO_XILINX is not set
    # MMC/SDIO DVB adapters
    # CONFIG_SMS_SDIO_DRV is not set
    # CONFIG_V4L_TEST_DRIVERS is not set
    # CONFIG_DVB_TEST_DRIVERS is not set
    CONFIG_VIDEOBUF2_CORE=m
    CONFIG_VIDEOBUF2_V4L2=m
    CONFIG_VIDEOBUF2_MEMOPS=m
    CONFIG_VIDEOBUF2_DMA_CONTIG=m
    CONFIG_VIDEOBUF2_VMALLOC=m
    CONFIG_VIDEOBUF2_DMA_SG=m
    # end of Media drivers
    # Media ancillary drivers
    CONFIG_MEDIA_ATTACH=y
    CONFIG_VIDEO_CAMERA_SENSOR=y
    # CONFIG_VIDEO_AR0521 is not set
    # CONFIG_VIDEO_HI556 is not set
    # CONFIG_VIDEO_HI846 is not set
    # CONFIG_VIDEO_HI847 is not set
    # CONFIG_VIDEO_IMX208 is not set
    # CONFIG_VIDEO_IMX214 is not set
    CONFIG_VIDEO_IMX219=m
    # CONFIG_VIDEO_IMX258 is not set
    # CONFIG_VIDEO_IMX274 is not set
    # CONFIG_VIDEO_IMX290 is not set
    # CONFIG_VIDEO_IMX319 is not set
    # CONFIG_VIDEO_IMX334 is not set
    # CONFIG_VIDEO_IMX335 is not set
    # CONFIG_VIDEO_IMX355 is not set
    CONFIG_VIDEO_IMX390=m
    # CONFIG_VIDEO_IMX412 is not set
    # CONFIG_VIDEO_MT9M001 is not set
    # CONFIG_VIDEO_MT9M032 is not set
    # CONFIG_VIDEO_MT9M111 is not set
    # CONFIG_VIDEO_MT9P031 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    # CONFIG_VIDEO_MT9T112 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_MT9V032 is not set
    # CONFIG_VIDEO_MT9V111 is not set
    # CONFIG_VIDEO_NOON010PC30 is not set
    # CONFIG_VIDEO_OG01A1B is not set
    # CONFIG_VIDEO_OV02A10 is not set
    # CONFIG_VIDEO_OV08D10 is not set
    # CONFIG_VIDEO_OV1063X is not set
    # CONFIG_VIDEO_OV13858 is not set
    # CONFIG_VIDEO_OV13B10 is not set
    CONFIG_VIDEO_OV2312=m
    # CONFIG_VIDEO_OV2640 is not set
    # CONFIG_VIDEO_OV2659 is not set
    # CONFIG_VIDEO_OV2680 is not set
    # CONFIG_VIDEO_OV2685 is not set
    CONFIG_VIDEO_OV5640=m
    CONFIG_VIDEO_OV5645=m
    # CONFIG_VIDEO_OV5647 is not set
    # CONFIG_VIDEO_OV5648 is not set
    # CONFIG_VIDEO_OV5670 is not set
    # CONFIG_VIDEO_OV5675 is not set
    # CONFIG_VIDEO_OV5693 is not set
    # CONFIG_VIDEO_OV5695 is not set
    # CONFIG_VIDEO_OV6650 is not set
    # CONFIG_VIDEO_OV7251 is not set
    # CONFIG_VIDEO_OV7640 is not set
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_OV772X is not set
    # CONFIG_VIDEO_OV7740 is not set
    # CONFIG_VIDEO_OV8856 is not set
    # CONFIG_VIDEO_OV8865 is not set
    # CONFIG_VIDEO_OV9282 is not set
    # CONFIG_VIDEO_OV9640 is not set
    # CONFIG_VIDEO_OV9650 is not set
    CONFIG_VIDEO_OX05B1S=m
    # CONFIG_VIDEO_RDACM20 is not set
    # CONFIG_VIDEO_RDACM21 is not set
    # CONFIG_VIDEO_RJ54N1 is not set
    # CONFIG_VIDEO_S5C73M3 is not set
    # CONFIG_VIDEO_S5K4ECGX is not set
    # CONFIG_VIDEO_S5K5BAF is not set
    # CONFIG_VIDEO_S5K6A3 is not set
    # CONFIG_VIDEO_S5K6AA is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_VIDEO_VS6624 is not set
    # CONFIG_VIDEO_CCS is not set
    # CONFIG_VIDEO_ET8EK8 is not set
    # CONFIG_VIDEO_M5MOLS is not set
    # Lens drivers
    # CONFIG_VIDEO_AD5820 is not set
    # CONFIG_VIDEO_AK7375 is not set
    # CONFIG_VIDEO_DW9714 is not set
    # CONFIG_VIDEO_DW9768 is not set
    # CONFIG_VIDEO_DW9807_VCM is not set
    # end of Lens drivers
    # Flash devices
    # CONFIG_VIDEO_ADP1653 is not set
    # CONFIG_VIDEO_LM3560 is not set
    # CONFIG_VIDEO_LM3646 is not set
    # end of Flash devices
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_CS3308 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_SONY_BTF_MPX is not set
    # CONFIG_VIDEO_TDA1997X is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_UDA1342 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_WM8775 is not set
    # end of Audio decoders, processors and mixers
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # end of RDS decoders
    # Video decoders
    # CONFIG_VIDEO_ADV7180 is not set
    # CONFIG_VIDEO_ADV7183 is not set
    # CONFIG_VIDEO_ADV748X is not set
    # CONFIG_VIDEO_ADV7604 is not set
    # CONFIG_VIDEO_ADV7842 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_ISL7998X is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_MAX9286 is not set
    # CONFIG_VIDEO_ML86V7667 is not set
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_TC358743 is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_TW2804 is not set
    # CONFIG_VIDEO_TW9903 is not set
    # CONFIG_VIDEO_TW9906 is not set
    # CONFIG_VIDEO_TW9910 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # end of Video decoders
    # Video encoders
    # CONFIG_VIDEO_AD9389B is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_ADV7393 is not set
    # CONFIG_VIDEO_ADV7511 is not set
    # CONFIG_VIDEO_AK881X is not set
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_THS8200 is not set
    # end of Video encoders
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # end of Video improvement chips
    # Audio/Video compression chips
    # CONFIG_VIDEO_SAA6752HS is not set
    # end of Audio/Video compression chips
    # SDR tuner chips
    # CONFIG_SDR_MAX2175 is not set
    # end of SDR tuner chips
    # Miscellaneous helper chips
    # CONFIG_VIDEO_I2C is not set
    # CONFIG_VIDEO_M52790 is not set
    # CONFIG_VIDEO_ST_MIPID02 is not set
    # CONFIG_VIDEO_THS7303 is not set
    # end of Miscellaneous helper chips
    # Video serializers and deserializers
    # CONFIG_VIDEO_DS90UB913 is not set
    CONFIG_VIDEO_DS90UB953=m
    CONFIG_VIDEO_DS90UB960=m
    # end of Video serializers and deserializers
    # Media SPI Adapters
    # CONFIG_CXD2880_SPI_DRV is not set
    # CONFIG_VIDEO_GS1662 is not set
    # end of Media SPI Adapters
    CONFIG_MEDIA_TUNER=m
    # Customize TV tuners
    # CONFIG_MEDIA_TUNER_E4000 is not set
    # CONFIG_MEDIA_TUNER_FC0011 is not set
    # CONFIG_MEDIA_TUNER_FC0012 is not set
    # CONFIG_MEDIA_TUNER_FC0013 is not set
    # CONFIG_MEDIA_TUNER_FC2580 is not set
    # CONFIG_MEDIA_TUNER_IT913X is not set
    # CONFIG_MEDIA_TUNER_M88RS6000T is not set
    # CONFIG_MEDIA_TUNER_MAX2165 is not set
    # CONFIG_MEDIA_TUNER_MC44S803 is not set
    # CONFIG_MEDIA_TUNER_MSI001 is not set
    # CONFIG_MEDIA_TUNER_MT2060 is not set
    # CONFIG_MEDIA_TUNER_MT2063 is not set
    # CONFIG_MEDIA_TUNER_MT20XX is not set
    # CONFIG_MEDIA_TUNER_MT2131 is not set
    # CONFIG_MEDIA_TUNER_MT2266 is not set
    # CONFIG_MEDIA_TUNER_MXL301RF is not set
    # CONFIG_MEDIA_TUNER_MXL5005S is not set
    # CONFIG_MEDIA_TUNER_MXL5007T is not set
    # CONFIG_MEDIA_TUNER_QM1D1B0004 is not set
    # CONFIG_MEDIA_TUNER_QM1D1C0042 is not set
    # CONFIG_MEDIA_TUNER_QT1010 is not set
    # CONFIG_MEDIA_TUNER_R820T is not set
    # CONFIG_MEDIA_TUNER_SI2157 is not set
    # CONFIG_MEDIA_TUNER_SIMPLE is not set
    # CONFIG_MEDIA_TUNER_TDA18212 is not set
    # CONFIG_MEDIA_TUNER_TDA18218 is not set
    # CONFIG_MEDIA_TUNER_TDA18250 is not set
    # CONFIG_MEDIA_TUNER_TDA18271 is not set
    # CONFIG_MEDIA_TUNER_TDA827X is not set
    # CONFIG_MEDIA_TUNER_TDA8290 is not set
    # CONFIG_MEDIA_TUNER_TDA9887 is not set
    # CONFIG_MEDIA_TUNER_TEA5761 is not set
    # CONFIG_MEDIA_TUNER_TEA5767 is not set
    # CONFIG_MEDIA_TUNER_TUA9001 is not set
    # CONFIG_MEDIA_TUNER_XC2028 is not set
    # CONFIG_MEDIA_TUNER_XC4000 is not set
    # CONFIG_MEDIA_TUNER_XC5000 is not set
    # end of Customize TV tuners
    # Customise DVB Frontends
    # Multistandard (satellite) frontends
    # CONFIG_DVB_M88DS3103 is not set
    # CONFIG_DVB_MXL5XX is not set
    # CONFIG_DVB_STB0899 is not set
    # CONFIG_DVB_STB6100 is not set
    # CONFIG_DVB_STV090x is not set
    # CONFIG_DVB_STV0910 is not set
    # CONFIG_DVB_STV6110x is not set
    # CONFIG_DVB_STV6111 is not set
    # Multistandard (cable + terrestrial) frontends
    # CONFIG_DVB_DRXK is not set
    # CONFIG_DVB_MN88472 is not set
    # CONFIG_DVB_MN88473 is not set
    # CONFIG_DVB_SI2165 is not set
    # CONFIG_DVB_TDA18271C2DD is not set
    # DVB-S (satellite) frontends
    # CONFIG_DVB_CX24110 is not set
    # CONFIG_DVB_CX24116 is not set
    # CONFIG_DVB_CX24117 is not set
    # CONFIG_DVB_CX24120 is not set
    # CONFIG_DVB_CX24123 is not set
    # CONFIG_DVB_DS3000 is not set
    # CONFIG_DVB_MB86A16 is not set
    # CONFIG_DVB_MT312 is not set
    # CONFIG_DVB_S5H1420 is not set
    # CONFIG_DVB_SI21XX is not set
    # CONFIG_DVB_STB6000 is not set
    # CONFIG_DVB_STV0288 is not set
    # CONFIG_DVB_STV0299 is not set
    # CONFIG_DVB_STV0900 is not set
    # CONFIG_DVB_STV6110 is not set
    # CONFIG_DVB_TDA10071 is not set
    # CONFIG_DVB_TDA10086 is not set
    # CONFIG_DVB_TDA8083 is not set
    # CONFIG_DVB_TDA8261 is not set
    # CONFIG_DVB_TDA826X is not set
    # CONFIG_DVB_TS2020 is not set
    # CONFIG_DVB_TUA6100 is not set
    # CONFIG_DVB_TUNER_CX24113 is not set
    # CONFIG_DVB_TUNER_ITD1000 is not set
    # CONFIG_DVB_VES1X93 is not set
    # CONFIG_DVB_ZL10036 is not set
    # CONFIG_DVB_ZL10039 is not set
    # DVB-T (terrestrial) frontends
    # CONFIG_DVB_AF9013 is not set
    # CONFIG_DVB_CX22700 is not set
    # CONFIG_DVB_CX22702 is not set
    # CONFIG_DVB_CXD2820R is not set
    # CONFIG_DVB_CXD2841ER is not set
    # CONFIG_DVB_DIB3000MB is not set
    # CONFIG_DVB_DIB3000MC is not set
    # CONFIG_DVB_DIB7000M is not set
    # CONFIG_DVB_DIB7000P is not set
    # CONFIG_DVB_DIB9000 is not set
    # CONFIG_DVB_DRXD is not set
    # CONFIG_DVB_EC100 is not set
    # CONFIG_DVB_L64781 is not set
    # CONFIG_DVB_MT352 is not set
    # CONFIG_DVB_NXT6000 is not set
    # CONFIG_DVB_RTL2830 is not set
    # CONFIG_DVB_RTL2832 is not set
    # CONFIG_DVB_RTL2832_SDR is not set
    # CONFIG_DVB_S5H1432 is not set
    # CONFIG_DVB_SI2168 is not set
    # CONFIG_DVB_SP887X is not set
    # CONFIG_DVB_STV0367 is not set
    # CONFIG_DVB_TDA10048 is not set
    # CONFIG_DVB_TDA1004X is not set
    # CONFIG_DVB_ZD1301_DEMOD is not set
    # CONFIG_DVB_ZL10353 is not set
    # CONFIG_DVB_CXD2880 is not set
    # DVB-C (cable) frontends
    # CONFIG_DVB_STV0297 is not set
    # CONFIG_DVB_TDA10021 is not set
    # CONFIG_DVB_TDA10023 is not set
    # CONFIG_DVB_VES1820 is not set
    # ATSC (North American/Korean Terrestrial/Cable DTV) frontends
    # CONFIG_DVB_AU8522_DTV is not set
    # CONFIG_DVB_AU8522_V4L is not set
    # CONFIG_DVB_BCM3510 is not set
    # CONFIG_DVB_LG2160 is not set
    # CONFIG_DVB_LGDT3305 is not set
    # CONFIG_DVB_LGDT3306A is not set
    # CONFIG_DVB_LGDT330X is not set
    # CONFIG_DVB_MXL692 is not set
    # CONFIG_DVB_NXT200X is not set
    # CONFIG_DVB_OR51132 is not set
    # CONFIG_DVB_OR51211 is not set
    # CONFIG_DVB_S5H1409 is not set
    # CONFIG_DVB_S5H1411 is not set
    # ISDB-T (terrestrial) frontends
    # CONFIG_DVB_DIB8000 is not set
    # CONFIG_DVB_MB86A20S is not set
    # CONFIG_DVB_S921 is not set
    # ISDB-S (satellite) & ISDB-T (terrestrial) frontends
    # CONFIG_DVB_MN88443X is not set
    # CONFIG_DVB_TC90522 is not set
    # Digital terrestrial only tuners/PLL
    # CONFIG_DVB_PLL is not set
    # CONFIG_DVB_TUNER_DIB0070 is not set
    # CONFIG_DVB_TUNER_DIB0090 is not set
    # SEC control devices for DVB-S
    # CONFIG_DVB_A8293 is not set
    # CONFIG_DVB_AF9033 is not set
    # CONFIG_DVB_ASCOT2E is not set
    # CONFIG_DVB_ATBM8830 is not set
    # CONFIG_DVB_HELENE is not set
    # CONFIG_DVB_HORUS3A is not set
    # CONFIG_DVB_ISL6405 is not set
    # CONFIG_DVB_ISL6421 is not set
    # CONFIG_DVB_ISL6423 is not set
    # CONFIG_DVB_IX2505V is not set
    # CONFIG_DVB_LGS8GL5 is not set
    # CONFIG_DVB_LGS8GXX is not set
    # CONFIG_DVB_LNBH25 is not set
    # CONFIG_DVB_LNBH29 is not set
    # CONFIG_DVB_LNBP21 is not set
    # CONFIG_DVB_LNBP22 is not set
    # CONFIG_DVB_M88RS2000 is not set
    # CONFIG_DVB_TDA665x is not set
    # CONFIG_DVB_DRX39XYJ is not set
    # Common Interface (EN50221) controller drivers
    # CONFIG_DVB_CXD2099 is not set
    # CONFIG_DVB_SP2 is not set
    # end of Customise DVB Frontends
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # end of Media ancillary drivers
    # Graphics support
    CONFIG_APERTURE_HELPERS=y
    CONFIG_DRM=m
    CONFIG_DRM_MIPI_DSI=y
    CONFIG_DRM_KMS_HELPER=m
    # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
    # CONFIG_DRM_DEBUG_MODESET_LOCK is not set
    CONFIG_DRM_FBDEV_EMULATION=y
    CONFIG_DRM_FBDEV_OVERALLOC=100
    # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
    # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
    CONFIG_DRM_DP_AUX_BUS=m
    CONFIG_DRM_DISPLAY_HELPER=m
    CONFIG_DRM_DISPLAY_DP_HELPER=y
    CONFIG_DRM_DISPLAY_HDCP_HELPER=y
    # CONFIG_DRM_DP_AUX_CHARDEV is not set
    # CONFIG_DRM_DP_CEC is not set
    CONFIG_DRM_GEM_DMA_HELPER=m
    # I2C encoder or helper chips
    CONFIG_DRM_I2C_CH7006=m
    CONFIG_DRM_I2C_SIL164=m
    CONFIG_DRM_I2C_NXP_TDA998X=m
    # CONFIG_DRM_I2C_NXP_TDA9950 is not set
    # end of I2C encoder or helper chips
    # ARM devices
    # CONFIG_DRM_HDLCD is not set
    # CONFIG_DRM_MALI_DISPLAY is not set
    # CONFIG_DRM_KOMEDA is not set
    # end of ARM devices
    # CONFIG_DRM_VGEM is not set
    # CONFIG_DRM_VKMS is not set
    # CONFIG_DRM_UDL is not set
    # CONFIG_DRM_RCAR_DW_HDMI is not set
    # CONFIG_DRM_RCAR_USE_LVDS is not set
    # CONFIG_DRM_RCAR_USE_MIPI_DSI is not set
    # CONFIG_DRM_VIRTIO_GPU is not set
    CONFIG_DRM_PANEL=y
    # Display Panels
    # CONFIG_DRM_PANEL_ABT_Y030XX067A is not set
    # CONFIG_DRM_PANEL_ARM_VERSATILE is not set
    # CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set
    # CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set
    # CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
    CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m
    # CONFIG_DRM_PANEL_DSI_CM is not set
    CONFIG_DRM_PANEL_LVDS=m
    CONFIG_DRM_PANEL_SIMPLE=m
    CONFIG_DRM_PANEL_EDP=m
    # CONFIG_DRM_PANEL_EBBG_FT8719 is not set
    # CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
    # CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set
    # CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
    # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
    # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set
    # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
    # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
    # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
    # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
    # CONFIG_DRM_PANEL_JDI_R63452 is not set
    # CONFIG_DRM_PANEL_KHADAS_TS050 is not set
    # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
    # CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
    # CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
    # CONFIG_DRM_PANEL_LG_LB035Q02 is not set
    # CONFIG_DRM_PANEL_LG_LG4573 is not set
    # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
    # CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35560 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35950 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
    CONFIG_DRM_PANEL_MANTIX_MLAF057WE51=m
    # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
    # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
    # CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
    # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
    # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
    CONFIG_DRM_PANEL_RAYDIUM_RM67191=m
    # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
    # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set
    # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
    # CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
    CONFIG_DRM_PANEL_SITRONIX_ST7703=m
    # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
    # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
    # CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set
    # CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set
    # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
    # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
    # CONFIG_DRM_PANEL_TPO_TPG110 is not set
    CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
    # CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
    # CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set
    # CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set
    # end of Display Panels
    CONFIG_DRM_BRIDGE=y
    CONFIG_DRM_PANEL_BRIDGE=y
    # Display Interface Bridges
    # CONFIG_DRM_CHIPONE_ICN6211 is not set
    # CONFIG_DRM_CHRONTEL_CH7033 is not set
    CONFIG_DRM_DISPLAY_CONNECTOR=m
    # CONFIG_DRM_ITE_IT6505 is not set
    CONFIG_DRM_LONTIUM_LT8912B=m
    # CONFIG_DRM_LONTIUM_LT9211 is not set
    CONFIG_DRM_LONTIUM_LT9611=m
    CONFIG_DRM_LONTIUM_LT9611UXC=m
    CONFIG_DRM_ITE_IT66121=m
    # CONFIG_DRM_LVDS_CODEC is not set
    # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
    CONFIG_DRM_NWL_MIPI_DSI=m
    # CONFIG_DRM_NXP_PTN3460 is not set
    # CONFIG_DRM_PARADE_PS8622 is not set
    CONFIG_DRM_PARADE_PS8640=m
    # CONFIG_DRM_SIL_SII8620 is not set
    CONFIG_DRM_SII902X=m
    # CONFIG_DRM_SII9234 is not set
    CONFIG_DRM_SIMPLE_BRIDGE=m
    CONFIG_DRM_THINE_THC63LVD1024=m
    CONFIG_DRM_TOSHIBA_TC358762=m
    # CONFIG_DRM_TOSHIBA_TC358764 is not set
    # CONFIG_DRM_TOSHIBA_TC358767 is not set
    CONFIG_DRM_TOSHIBA_TC358768=m
    # CONFIG_DRM_TOSHIBA_TC358775 is not set
    # CONFIG_DRM_TI_DLPC3433 is not set
    CONFIG_DRM_TI_TFP410=m
    CONFIG_DRM_TI_SN65DSI83=m
    CONFIG_DRM_TI_SN65DSI86=m
    # CONFIG_DRM_TI_TPD12S015 is not set
    # CONFIG_DRM_ANALOGIX_ANX6345 is not set
    # CONFIG_DRM_ANALOGIX_ANX78XX is not set
    # CONFIG_DRM_ANALOGIX_ANX7625 is not set
    # CONFIG_DRM_I2C_ADV7511 is not set
    CONFIG_DRM_CDNS_DSI=m
    CONFIG_DRM_CDNS_DSI_J721E=y
    CONFIG_DRM_CDNS_MHDP8546=m
    CONFIG_DRM_CDNS_MHDP8546_J721E=y
    # end of Display Interface Bridges
    # CONFIG_DRM_ETNAVIV is not set
    # CONFIG_DRM_HISI_KIRIN is not set
    # CONFIG_DRM_LOGICVC is not set
    # CONFIG_DRM_ARCPGU is not set
    # CONFIG_DRM_GM12U320 is not set
    # CONFIG_DRM_PANEL_MIPI_DBI is not set
    # CONFIG_DRM_SIMPLEDRM is not set
    # CONFIG_TINYDRM_HX8357D is not set
    # CONFIG_TINYDRM_ILI9163 is not set
    # CONFIG_TINYDRM_ILI9225 is not set
    # CONFIG_TINYDRM_ILI9341 is not set
    # CONFIG_TINYDRM_ILI9486 is not set
    # CONFIG_TINYDRM_MI0283QT is not set
    # CONFIG_TINYDRM_REPAPER is not set
    # CONFIG_TINYDRM_ST7586 is not set
    # CONFIG_TINYDRM_ST7735R is not set
    # CONFIG_DRM_PL111 is not set
    # CONFIG_DRM_LIMA is not set
    # CONFIG_DRM_PANFROST is not set
    CONFIG_DRM_TIDSS=m
    # CONFIG_DRM_GUD is not set
    # CONFIG_DRM_SSD130X is not set
    CONFIG_DRM_LEGACY=y
    CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m
    CONFIG_DRM_NOMODESET=y
    # Frame buffer Devices
    CONFIG_FB_CMDLINE=y
    CONFIG_FB_NOTIFY=y
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    CONFIG_FB_SYS_FILLRECT=m
    CONFIG_FB_SYS_COPYAREA=m
    CONFIG_FB_SYS_IMAGEBLIT=m
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    CONFIG_FB_SYS_FOPS=m
    CONFIG_FB_DEFERRED_IO=y
    CONFIG_FB_MODE_HELPERS=y
    # CONFIG_FB_TILEBLITTING is not set
    # Frame buffer hardware drivers
    # CONFIG_FB_ARMCLCD is not set
    # CONFIG_FB_EFI is not set
    # CONFIG_FB_OPENCORES is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_IBM_GXT4500 is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    CONFIG_FB_SIMPLE=y
    # CONFIG_FB_SSD1307 is not set
    # end of Frame buffer Devices
    # Backlight & LCD device support
    # CONFIG_LCD_CLASS_DEVICE is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    # CONFIG_BACKLIGHT_KTD253 is not set
    CONFIG_BACKLIGHT_PWM=m
    # CONFIG_BACKLIGHT_QCOM_WLED is not set
    # CONFIG_BACKLIGHT_ADP8860 is not set
    # CONFIG_BACKLIGHT_ADP8870 is not set
    # CONFIG_BACKLIGHT_LM3630A is not set
    # CONFIG_BACKLIGHT_LM3639 is not set
    CONFIG_BACKLIGHT_LP855X=m
    CONFIG_BACKLIGHT_GPIO=y
    # CONFIG_BACKLIGHT_LV5207LP is not set
    # CONFIG_BACKLIGHT_BD6107 is not set
    # CONFIG_BACKLIGHT_ARCXCNN is not set
    # CONFIG_BACKLIGHT_LED is not set
    # end of Backlight & LCD device support
    CONFIG_VIDEOMODE_HELPERS=y
    CONFIG_HDMI=y
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_DUMMY_CONSOLE_COLUMNS=80
    CONFIG_DUMMY_CONSOLE_ROWS=25
    CONFIG_FRAMEBUFFER_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION=y
    CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
    # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
    # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
    # end of Console display driver support
    CONFIG_LOGO=y
    # CONFIG_LOGO_LINUX_MONO is not set
    # CONFIG_LOGO_LINUX_VGA16 is not set
    CONFIG_LOGO_LINUX_CLUT224=y
    # end of Graphics support
    CONFIG_SOUND=y
    CONFIG_SND=y
    CONFIG_SND_TIMER=y
    CONFIG_SND_PCM=y
    CONFIG_SND_PCM_ELD=y
    CONFIG_SND_PCM_IEC958=y
    CONFIG_SND_DMAENGINE_PCM=y
    CONFIG_SND_HWDEP=m
    CONFIG_SND_RAWMIDI=m
    CONFIG_SND_JACK=y
    CONFIG_SND_JACK_INPUT_DEV=y
    # CONFIG_SND_OSSEMUL is not set
    CONFIG_SND_PCM_TIMER=y
    # CONFIG_SND_HRTIMER is not set
    CONFIG_SND_DYNAMIC_MINORS=y
    CONFIG_SND_MAX_CARDS=32
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_PROC_FS=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    CONFIG_SND_CTL_FAST_LOOKUP=y
    # CONFIG_SND_DEBUG is not set
    # CONFIG_SND_CTL_INPUT_VALIDATION is not set
    # CONFIG_SND_SEQUENCER is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_SERIAL_GENERIC is not set
    # CONFIG_SND_MPU401 is not set
    # HD-Audio
    # end of HD-Audio
    CONFIG_SND_HDA_PREALLOC_SIZE=64
    # CONFIG_SND_SPI is not set
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=m
    CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_6FIRE is not set
    # CONFIG_SND_USB_HIFACE is not set
    # CONFIG_SND_BCD2000 is not set
    # CONFIG_SND_USB_POD is not set
    # CONFIG_SND_USB_PODHD is not set
    # CONFIG_SND_USB_TONEPORT is not set
    # CONFIG_SND_USB_VARIAX is not set
    CONFIG_SND_SOC=y
    CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
    # CONFIG_SND_SOC_ADI is not set
    # CONFIG_SND_SOC_AMD_ACP is not set
    # CONFIG_SND_AMD_ACP_CONFIG is not set
    # CONFIG_SND_ATMEL_SOC is not set
    # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
    # CONFIG_SND_DESIGNWARE_I2S is not set
    # SoC Audio for Freescale CPUs
    # Common SoC Audio options for Freescale CPUs:
    # CONFIG_SND_SOC_FSL_ASRC is not set
    # CONFIG_SND_SOC_FSL_SAI is not set
    # CONFIG_SND_SOC_FSL_AUDMIX is not set
    # CONFIG_SND_SOC_FSL_SSI is not set
    # CONFIG_SND_SOC_FSL_SPDIF is not set
    # CONFIG_SND_SOC_FSL_ESAI is not set
    # CONFIG_SND_SOC_FSL_MICFIL is not set
    # CONFIG_SND_SOC_FSL_XCVR is not set
    # CONFIG_SND_SOC_FSL_RPMSG is not set
    # CONFIG_SND_SOC_IMX_AUDMUX is not set
    # end of SoC Audio for Freescale CPUs
    # CONFIG_SND_I2S_HI6210_I2S is not set
    # CONFIG_SND_SOC_IMG is not set
    # CONFIG_SND_SOC_MTK_BTCVSD is not set
    # CONFIG_SND_SOC_SOF_TOPLEVEL is not set
    # STMicroelectronics STM32 SOC audio support
    # end of STMicroelectronics STM32 SOC audio support
    # Audio support for Texas Instruments SoCs
    CONFIG_SND_SOC_TI_EDMA_PCM=m
    CONFIG_SND_SOC_TI_SDMA_PCM=m
    CONFIG_SND_SOC_TI_UDMA_PCM=m
    # Texas Instruments DAI support for:
    CONFIG_SND_SOC_DAVINCI_MCASP=m
    # Audio support for boards with Texas Instruments SoCs
    CONFIG_SND_SOC_J721E_EVM=m
    # end of Audio support for Texas Instruments SoCs
    # CONFIG_SND_SOC_XILINX_I2S is not set
    # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
    # CONFIG_SND_SOC_XILINX_SPDIF is not set
    # CONFIG_SND_SOC_XTFPGA_I2S is not set
    CONFIG_SND_SOC_I2C_AND_SPI=y
    # CODEC drivers
    # CONFIG_SND_SOC_AC97_CODEC is not set
    # CONFIG_SND_SOC_ADAU1372_I2C is not set
    # CONFIG_SND_SOC_ADAU1372_SPI is not set
    # CONFIG_SND_SOC_ADAU1701 is not set
    # CONFIG_SND_SOC_ADAU1761_I2C is not set
    # CONFIG_SND_SOC_ADAU1761_SPI is not set
    CONFIG_SND_SOC_ADAU7002=m
    # CONFIG_SND_SOC_ADAU7118_HW is not set
    # CONFIG_SND_SOC_ADAU7118_I2C is not set
    # CONFIG_SND_SOC_AK4104 is not set
    # CONFIG_SND_SOC_AK4118 is not set
    # CONFIG_SND_SOC_AK4375 is not set
    # CONFIG_SND_SOC_AK4458 is not set
    # CONFIG_SND_SOC_AK4554 is not set
    # CONFIG_SND_SOC_AK4613 is not set
    # CONFIG_SND_SOC_AK4642 is not set
    # CONFIG_SND_SOC_AK5386 is not set
    # CONFIG_SND_SOC_AK5558 is not set
    # CONFIG_SND_SOC_ALC5623 is not set
    # CONFIG_SND_SOC_AW8738 is not set
    # CONFIG_SND_SOC_BD28623 is not set
    # CONFIG_SND_SOC_BT_SCO is not set
    # CONFIG_SND_SOC_CS35L32 is not set
    # CONFIG_SND_SOC_CS35L33 is not set
    # CONFIG_SND_SOC_CS35L34 is not set
    # CONFIG_SND_SOC_CS35L35 is not set
    # CONFIG_SND_SOC_CS35L36 is not set
    # CONFIG_SND_SOC_CS35L41_SPI is not set
    # CONFIG_SND_SOC_CS35L41_I2C is not set
    # CONFIG_SND_SOC_CS35L45_SPI is not set
    # CONFIG_SND_SOC_CS35L45_I2C is not set
    # CONFIG_SND_SOC_CS42L42 is not set
    # CONFIG_SND_SOC_CS42L51_I2C is not set
    # CONFIG_SND_SOC_CS42L52 is not set
    # CONFIG_SND_SOC_CS42L56 is not set
    # CONFIG_SND_SOC_CS42L73 is not set
    # CONFIG_SND_SOC_CS42L83 is not set
    # CONFIG_SND_SOC_CS4234 is not set
    # CONFIG_SND_SOC_CS4265 is not set
    # CONFIG_SND_SOC_CS4270 is not set
    # CONFIG_SND_SOC_CS4271_I2C is not set
    # CONFIG_SND_SOC_CS4271_SPI is not set
    # CONFIG_SND_SOC_CS42XX8_I2C is not set
    # CONFIG_SND_SOC_CS43130 is not set
    # CONFIG_SND_SOC_CS4341 is not set
    # CONFIG_SND_SOC_CS4349 is not set
    # CONFIG_SND_SOC_CS53L30 is not set
    # CONFIG_SND_SOC_CX2072X is not set
    # CONFIG_SND_SOC_DA7213 is not set
    CONFIG_SND_SOC_DMIC=m
    CONFIG_SND_SOC_HDMI_CODEC=m
    # CONFIG_SND_SOC_ES7134 is not set
    # CONFIG_SND_SOC_ES7241 is not set
    # CONFIG_SND_SOC_ES8316 is not set
    # CONFIG_SND_SOC_ES8326 is not set
    # CONFIG_SND_SOC_ES8328_I2C is not set
    # CONFIG_SND_SOC_ES8328_SPI is not set
    CONFIG_SND_SOC_GTM601=m
    # CONFIG_SND_SOC_HDA is not set
    # CONFIG_SND_SOC_ICS43432 is not set
    # CONFIG_SND_SOC_INNO_RK3036 is not set
    # CONFIG_SND_SOC_MAX98088 is not set
    CONFIG_SND_SOC_MAX98357A=m
    # CONFIG_SND_SOC_MAX98504 is not set
    # CONFIG_SND_SOC_MAX9867 is not set
    CONFIG_SND_SOC_MAX98927=m
    # CONFIG_SND_SOC_MAX98520 is not set
    # CONFIG_SND_SOC_MAX98373_I2C is not set
    # CONFIG_SND_SOC_MAX98373_SDW is not set
    # CONFIG_SND_SOC_MAX98390 is not set
    # CONFIG_SND_SOC_MAX98396 is not set
    # CONFIG_SND_SOC_MAX9860 is not set
    # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
    # CONFIG_SND_SOC_PCM1681 is not set
    # CONFIG_SND_SOC_PCM1789_I2C is not set
    # CONFIG_SND_SOC_PCM179X_I2C is not set
    # CONFIG_SND_SOC_PCM179X_SPI is not set
    # CONFIG_SND_SOC_PCM186X_I2C is not set
    # CONFIG_SND_SOC_PCM186X_SPI is not set
    # CONFIG_SND_SOC_PCM3060_I2C is not set
    # CONFIG_SND_SOC_PCM3060_SPI is not set
    CONFIG_SND_SOC_PCM3168A=m
    CONFIG_SND_SOC_PCM3168A_I2C=m
    # CONFIG_SND_SOC_PCM3168A_SPI is not set
    # CONFIG_SND_SOC_PCM5102A is not set
    # CONFIG_SND_SOC_PCM512x_I2C is not set
    # CONFIG_SND_SOC_PCM512x_SPI is not set
    # CONFIG_SND_SOC_RK3328 is not set
    # CONFIG_SND_SOC_RK817 is not set
    # CONFIG_SND_SOC_RT1308_SDW is not set
    # CONFIG_SND_SOC_RT1316_SDW is not set
    # CONFIG_SND_SOC_RT1318_SDW is not set
    # CONFIG_SND_SOC_RT5616 is not set
    # CONFIG_SND_SOC_RT5631 is not set
    # CONFIG_SND_SOC_RT5640 is not set
    # CONFIG_SND_SOC_RT5659 is not set
    # CONFIG_SND_SOC_RT5682_SDW is not set
    # CONFIG_SND_SOC_RT700_SDW is not set
    # CONFIG_SND_SOC_RT711_SDW is not set
    # CONFIG_SND_SOC_RT711_SDCA_SDW is not set
    # CONFIG_SND_SOC_RT715_SDW is not set
    # CONFIG_SND_SOC_RT715_SDCA_SDW is not set
    # CONFIG_SND_SOC_RT9120 is not set
    # CONFIG_SND_SOC_SDW_MOCKUP is not set
    CONFIG_SND_SOC_SGTL5000=y
    CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m
    CONFIG_SND_SOC_SIMPLE_MUX=m
    CONFIG_SND_SOC_SPDIF=m
    # CONFIG_SND_SOC_SRC4XXX_I2C is not set
    # CONFIG_SND_SOC_SSM2305 is not set
    # CONFIG_SND_SOC_SSM2518 is not set
    # CONFIG_SND_SOC_SSM2602_SPI is not set
    # CONFIG_SND_SOC_SSM2602_I2C is not set
    # CONFIG_SND_SOC_SSM4567 is not set
    # CONFIG_SND_SOC_STA32X is not set
    # CONFIG_SND_SOC_STA350 is not set
    # CONFIG_SND_SOC_STI_SAS is not set
    # CONFIG_SND_SOC_TAS2552 is not set
    # CONFIG_SND_SOC_TAS2562 is not set
    # CONFIG_SND_SOC_TAS2764 is not set
    # CONFIG_SND_SOC_TAS2770 is not set
    # CONFIG_SND_SOC_TAS2780 is not set
    # CONFIG_SND_SOC_TAS5086 is not set
    # CONFIG_SND_SOC_TAS571X is not set
    # CONFIG_SND_SOC_TAS5720 is not set
    # CONFIG_SND_SOC_TAS5805M is not set
    # CONFIG_SND_SOC_TAS6424 is not set
    # CONFIG_SND_SOC_TDA7419 is not set
    # CONFIG_SND_SOC_TFA9879 is not set
    # CONFIG_SND_SOC_TFA989X is not set
    # CONFIG_SND_SOC_TLV320ADC3XXX is not set
    # CONFIG_SND_SOC_TLV320AIC23_I2C is not set
    # CONFIG_SND_SOC_TLV320AIC23_SPI is not set
    CONFIG_SND_SOC_TLV320AIC31XX=m
    CONFIG_SND_SOC_TLV320AIC32X4=m
    CONFIG_SND_SOC_TLV320AIC32X4_I2C=m
    # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
    CONFIG_SND_SOC_TLV320AIC3X=m
    CONFIG_SND_SOC_TLV320AIC3X_I2C=m
    # CONFIG_SND_SOC_TLV320AIC3X_SPI is not set
    # CONFIG_SND_SOC_TLV320ADCX140 is not set
    # CONFIG_SND_SOC_TS3A227E is not set
    # CONFIG_SND_SOC_TSCS42XX is not set
    # CONFIG_SND_SOC_TSCS454 is not set
    # CONFIG_SND_SOC_UDA1334 is not set
    # CONFIG_SND_SOC_WCD938X_SDW is not set
    # CONFIG_SND_SOC_WM8510 is not set
    # CONFIG_SND_SOC_WM8523 is not set
    # CONFIG_SND_SOC_WM8524 is not set
    # CONFIG_SND_SOC_WM8580 is not set
    # CONFIG_SND_SOC_WM8711 is not set
    # CONFIG_SND_SOC_WM8728 is not set
    # CONFIG_SND_SOC_WM8731_I2C is not set
    # CONFIG_SND_SOC_WM8731_SPI is not set
    # CONFIG_SND_SOC_WM8737 is not set
    # CONFIG_SND_SOC_WM8741 is not set
    # CONFIG_SND_SOC_WM8750 is not set
    # CONFIG_SND_SOC_WM8753 is not set
    # CONFIG_SND_SOC_WM8770 is not set
    # CONFIG_SND_SOC_WM8776 is not set
    # CONFIG_SND_SOC_WM8782 is not set
    # CONFIG_SND_SOC_WM8804_I2C is not set
    # CONFIG_SND_SOC_WM8804_SPI is not set
    # CONFIG_SND_SOC_WM8903 is not set
    CONFIG_SND_SOC_WM8904=m
    # CONFIG_SND_SOC_WM8940 is not set
    # CONFIG_SND_SOC_WM8960 is not set
    # CONFIG_SND_SOC_WM8962 is not set
    # CONFIG_SND_SOC_WM8974 is not set
    # CONFIG_SND_SOC_WM8978 is not set
    # CONFIG_SND_SOC_WM8985 is not set
    # CONFIG_SND_SOC_WSA881X is not set
    # CONFIG_SND_SOC_WSA883X is not set
    # CONFIG_SND_SOC_ZL38060 is not set
    # CONFIG_SND_SOC_MAX9759 is not set
    # CONFIG_SND_SOC_MT6351 is not set
    # CONFIG_SND_SOC_MT6358 is not set
    # CONFIG_SND_SOC_MT6660 is not set
    # CONFIG_SND_SOC_NAU8315 is not set
    # CONFIG_SND_SOC_NAU8540 is not set
    # CONFIG_SND_SOC_NAU8810 is not set
    # CONFIG_SND_SOC_NAU8821 is not set
    CONFIG_SND_SOC_NAU8822=m
    # CONFIG_SND_SOC_NAU8824 is not set
    # CONFIG_SND_SOC_TPA6130A2 is not set
    CONFIG_SND_SOC_LPASS_MACRO_COMMON=m
    CONFIG_SND_SOC_LPASS_WSA_MACRO=m
    CONFIG_SND_SOC_LPASS_VA_MACRO=m
    CONFIG_SND_SOC_LPASS_RX_MACRO=m
    CONFIG_SND_SOC_LPASS_TX_MACRO=m
    # end of CODEC drivers
    CONFIG_SND_SIMPLE_CARD_UTILS=m
    CONFIG_SND_SIMPLE_CARD=m
    CONFIG_SND_AUDIO_GRAPH_CARD=m
    CONFIG_SND_AUDIO_GRAPH_CARD2=m
    # CONFIG_SND_AUDIO_GRAPH_CARD2_CUSTOM_SAMPLE is not set
    # CONFIG_SND_TEST_COMPONENT is not set
    # CONFIG_SND_VIRTIO is not set
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    CONFIG_UHID=m
    CONFIG_HID_GENERIC=y
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACCUTOUCH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_ASUS is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_BETOP_FF is not set
    # CONFIG_HID_BIGBEN_FF is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_CORSAIR is not set
    # CONFIG_HID_COUGAR is not set
    # CONFIG_HID_MACALLY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CMEDIA is not set
    # CONFIG_HID_CREATIVE_SB0540 is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELAN is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_GEMBIRD is not set
    # CONFIG_HID_GFRM is not set
    # CONFIG_HID_GLORIOUS is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_VIVALDI is not set
    # CONFIG_HID_GT683R is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_VIEWSONIC is not set
    # CONFIG_HID_VRC2 is not set
    # CONFIG_HID_XIAOMI is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_ITE is not set
    # CONFIG_HID_JABRA is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LED is not set
    # CONFIG_HID_LENOVO is not set
    # CONFIG_HID_LETSKETCH is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    # CONFIG_HID_MALTRON is not set
    # CONFIG_HID_MAYFLASH is not set
    # CONFIG_HID_MEGAWORLD_FF is not set
    # CONFIG_HID_REDRAGON is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    CONFIG_HID_MULTITOUCH=m
    # CONFIG_HID_NINTENDO is not set
    # CONFIG_HID_NTI is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PENMOUNT is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PLANTRONICS is not set
    # CONFIG_HID_PLAYSTATION is not set
    # CONFIG_HID_PXRC is not set
    # CONFIG_HID_RAZER is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_RETRODE is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SEMITEK is not set
    # CONFIG_HID_SIGMAMICRO is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEAM is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_RMI is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_TOPRE is not set
    # CONFIG_HID_THINGM is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_UDRAW_PS3 is not set
    # CONFIG_HID_U2FZERO is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_WIIMOTE is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # CONFIG_HID_ALPS is not set
    # CONFIG_HID_MCP2221 is not set
    # end of Special HID drivers
    # USB HID support
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    CONFIG_USB_HIDDEV=y
    # end of USB HID support
    # I2C HID support
    CONFIG_I2C_HID_OF=m
    # CONFIG_I2C_HID_OF_ELAN is not set
    # CONFIG_I2C_HID_OF_GOODIX is not set
    # end of I2C HID support
    CONFIG_I2C_HID_CORE=m
    # end of HID support
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    # CONFIG_USB_LED_TRIG is not set
    CONFIG_USB_ULPI_BUS=y
    CONFIG_USB_CONN_GPIO=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=y
    # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_FEW_INIT_RETRIES is not set
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_PRODUCTLIST is not set
    # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set
    # CONFIG_USB_OTG_FSM is not set
    # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
    CONFIG_USB_AUTOSUSPEND_DELAY=2
    # CONFIG_USB_MON is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_XHCI_HCD=y
    # CONFIG_USB_XHCI_DBGCAP is not set
    CONFIG_USB_XHCI_PCI_RENESAS=m
    CONFIG_USB_XHCI_PLATFORM=y
    CONFIG_USB_EHCI_HCD=y
    CONFIG_USB_EHCI_ROOT_HUB_TT=y
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    # CONFIG_USB_EHCI_FSL is not set
    CONFIG_USB_EHCI_HCD_PLATFORM=y
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_MAX3421_HCD is not set
    CONFIG_USB_OHCI_HCD=y
    CONFIG_USB_OHCI_HCD_PLATFORM=y
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    # USB Device Class drivers
    CONFIG_USB_ACM=m
    # CONFIG_USB_PRINTER is not set
    # CONFIG_USB_WDM is not set
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    # CONFIG_USB_UAS is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # CONFIG_USBIP_CORE is not set
    CONFIG_USB_CDNS_SUPPORT=m
    CONFIG_USB_CDNS_HOST=y
    CONFIG_USB_CDNS3=m
    CONFIG_USB_CDNS3_GADGET=y
    CONFIG_USB_CDNS3_HOST=y
    CONFIG_USB_CDNS3_TI=m
    # CONFIG_USB_MUSB_HDRC is not set
    CONFIG_USB_DWC3=y
    # CONFIG_USB_DWC3_ULPI is not set
    # CONFIG_USB_DWC3_HOST is not set
    # CONFIG_USB_DWC3_GADGET is not set
    CONFIG_USB_DWC3_DUAL_ROLE=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_KEYSTONE=m
    CONFIG_USB_DWC3_OF_SIMPLE=m
    CONFIG_USB_DWC3_AM62=y
    # CONFIG_USB_DWC2 is not set
    # CONFIG_USB_CHIPIDEA is not set
    # CONFIG_USB_ISP1760 is not set
    # USB port drivers
    CONFIG_USB_SERIAL=m
    # CONFIG_USB_SERIAL_GENERIC is not set
    # CONFIG_USB_SERIAL_SIMPLE is not set
    # CONFIG_USB_SERIAL_AIRCABLE is not set
    # CONFIG_USB_SERIAL_ARK3116 is not set
    # CONFIG_USB_SERIAL_BELKIN is not set
    # CONFIG_USB_SERIAL_CH341 is not set
    # CONFIG_USB_SERIAL_WHITEHEAT is not set
    # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
    CONFIG_USB_SERIAL_CP210X=m
    # CONFIG_USB_SERIAL_CYPRESS_M8 is not set
    # CONFIG_USB_SERIAL_EMPEG is not set
    CONFIG_USB_SERIAL_FTDI_SIO=m
    # CONFIG_USB_SERIAL_VISOR is not set
    # CONFIG_USB_SERIAL_IPAQ is not set
    # CONFIG_USB_SERIAL_IR is not set
    # CONFIG_USB_SERIAL_EDGEPORT is not set
    # CONFIG_USB_SERIAL_EDGEPORT_TI is not set
    # CONFIG_USB_SERIAL_F81232 is not set
    # CONFIG_USB_SERIAL_F8153X is not set
    # CONFIG_USB_SERIAL_GARMIN is not set
    # CONFIG_USB_SERIAL_IPW is not set
    # CONFIG_USB_SERIAL_IUU is not set
    # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
    # CONFIG_USB_SERIAL_KEYSPAN is not set
    # CONFIG_USB_SERIAL_KLSI is not set
    # CONFIG_USB_SERIAL_KOBIL_SCT is not set
    # CONFIG_USB_SERIAL_MCT_U232 is not set
    # CONFIG_USB_SERIAL_METRO is not set
    # CONFIG_USB_SERIAL_MOS7720 is not set
    # CONFIG_USB_SERIAL_MOS7840 is not set
    # CONFIG_USB_SERIAL_MXUPORT is not set
    # CONFIG_USB_SERIAL_NAVMAN is not set
    # CONFIG_USB_SERIAL_PL2303 is not set
    # CONFIG_USB_SERIAL_OTI6858 is not set
    # CONFIG_USB_SERIAL_QCAUX is not set
    # CONFIG_USB_SERIAL_QUALCOMM is not set
    # CONFIG_USB_SERIAL_SPCP8X5 is not set
    # CONFIG_USB_SERIAL_SAFE is not set
    # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
    # CONFIG_USB_SERIAL_SYMBOL is not set
    # CONFIG_USB_SERIAL_TI is not set
    # CONFIG_USB_SERIAL_CYBERJACK is not set
    CONFIG_USB_SERIAL_WWAN=m
    CONFIG_USB_SERIAL_OPTION=m
    # CONFIG_USB_SERIAL_OMNINET is not set
    # CONFIG_USB_SERIAL_OPTICON is not set
    # CONFIG_USB_SERIAL_XSENS_MT is not set
    # CONFIG_USB_SERIAL_WISHBONE is not set
    # CONFIG_USB_SERIAL_SSU100 is not set
    # CONFIG_USB_SERIAL_QT2 is not set
    # CONFIG_USB_SERIAL_UPD78F0730 is not set
    # CONFIG_USB_SERIAL_XR is not set
    # CONFIG_USB_SERIAL_DEBUG is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_APPLE_MFI_FASTCHARGE is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    # CONFIG_USB_TEST is not set
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    CONFIG_USB_HUB_USB251XB=y
    # CONFIG_USB_HSIC_USB3503 is not set
    # CONFIG_USB_HSIC_USB4604 is not set
    # CONFIG_USB_LINK_LAYER_TEST is not set
    # CONFIG_USB_CHAOSKEY is not set
    CONFIG_USB_ONBOARD_HUB=y
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    CONFIG_NOP_USB_XCEIV=y
    # CONFIG_USB_GPIO_VBUS is not set
    # CONFIG_USB_ISP1301 is not set
    CONFIG_USB_ULPI=y
    CONFIG_USB_ULPI_VIEWPORT=y
    # end of USB Physical Layer drivers
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    # CONFIG_USB_GADGET_DEBUG_FS is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
    # CONFIG_U_SERIAL_CONSOLE is not set
    # USB Peripheral Controller
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_GR_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    CONFIG_USB_SNP_CORE=y
    CONFIG_USB_SNP_UDC_PLAT=y
    # CONFIG_USB_M66592 is not set
    CONFIG_USB_BDC_UDC=y
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_GADGET_XILINX is not set
    # CONFIG_USB_MAX3420_UDC is not set
    # CONFIG_USB_DUMMY_HCD is not set
    # end of USB Peripheral Controller
    CONFIG_USB_LIBCOMPOSITE=m
    CONFIG_USB_F_ACM=m
    CONFIG_USB_F_SS_LB=m
    CONFIG_USB_U_SERIAL=m
    CONFIG_USB_U_ETHER=m
    CONFIG_USB_F_SERIAL=m
    CONFIG_USB_F_OBEX=m
    CONFIG_USB_F_NCM=m
    CONFIG_USB_F_ECM=m
    CONFIG_USB_F_EEM=m
    CONFIG_USB_F_SUBSET=m
    CONFIG_USB_F_RNDIS=m
    CONFIG_USB_F_MASS_STORAGE=m
    CONFIG_USB_F_FS=m
    CONFIG_USB_CONFIGFS=m
    CONFIG_USB_CONFIGFS_SERIAL=y
    CONFIG_USB_CONFIGFS_ACM=y
    CONFIG_USB_CONFIGFS_OBEX=y
    CONFIG_USB_CONFIGFS_NCM=y
    CONFIG_USB_CONFIGFS_ECM=y
    CONFIG_USB_CONFIGFS_ECM_SUBSET=y
    CONFIG_USB_CONFIGFS_RNDIS=y
    CONFIG_USB_CONFIGFS_EEM=y
    CONFIG_USB_CONFIGFS_MASS_STORAGE=y
    # CONFIG_USB_CONFIGFS_F_LB_SS is not set
    CONFIG_USB_CONFIGFS_F_FS=y
    # CONFIG_USB_CONFIGFS_F_UAC1 is not set
    # CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set
    # CONFIG_USB_CONFIGFS_F_UAC2 is not set
    # CONFIG_USB_CONFIGFS_F_MIDI is not set
    # CONFIG_USB_CONFIGFS_F_HID is not set
    # CONFIG_USB_CONFIGFS_F_UVC is not set
    # CONFIG_USB_CONFIGFS_F_PRINTER is not set
    # USB Gadget precomposed configurations
    CONFIG_USB_ZERO=m
    # CONFIG_USB_ZERO_HNPTEST is not set
    # CONFIG_USB_AUDIO is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    CONFIG_USB_G_NCM=m
    CONFIG_USB_GADGETFS=m
    # CONFIG_USB_FUNCTIONFS is not set
    CONFIG_USB_MASS_STORAGE=m
    CONFIG_USB_G_SERIAL=m
    # CONFIG_USB_MIDI_GADGET is not set
    # CONFIG_USB_G_PRINTER is not set
    CONFIG_USB_CDC_COMPOSITE=m
    # CONFIG_USB_G_ACM_MS is not set
    CONFIG_USB_G_MULTI=m
    CONFIG_USB_G_MULTI_RNDIS=y
    CONFIG_USB_G_MULTI_CDC=y
    # CONFIG_USB_G_HID is not set
    # CONFIG_USB_G_DBGP is not set
    # CONFIG_USB_G_WEBCAM is not set
    # CONFIG_USB_RAW_GADGET is not set
    # end of USB Gadget precomposed configurations
    CONFIG_TYPEC=m
    CONFIG_TYPEC_TCPM=m
    CONFIG_TYPEC_TCPCI=m
    # CONFIG_TYPEC_RT1711H is not set
    # CONFIG_TYPEC_MT6360 is not set
    # CONFIG_TYPEC_TCPCI_MAXIM is not set
    CONFIG_TYPEC_FUSB302=m
    # CONFIG_TYPEC_UCSI is not set
    CONFIG_TYPEC_TPS6598X=m
    # CONFIG_TYPEC_ANX7411 is not set
    # CONFIG_TYPEC_RT1719 is not set
    CONFIG_TYPEC_HD3SS3220=m
    # CONFIG_TYPEC_STUSB160X is not set
    # CONFIG_TYPEC_WUSB3801 is not set
    # USB Type-C Multiplexer/DeMultiplexer Switch support
    # CONFIG_TYPEC_MUX_FSA4480 is not set
    # CONFIG_TYPEC_MUX_GPIO_SBU is not set
    # CONFIG_TYPEC_MUX_PI3USB30532 is not set
    # end of USB Type-C Multiplexer/DeMultiplexer Switch support
    # USB Type-C Alternate Mode drivers
    # CONFIG_TYPEC_DP_ALTMODE is not set
    # end of USB Type-C Alternate Mode drivers
    CONFIG_USB_ROLE_SWITCH=y
    CONFIG_MMC=y
    CONFIG_PWRSEQ_EMMC=y
    # CONFIG_PWRSEQ_SD8787 is not set
    CONFIG_PWRSEQ_SIMPLE=y
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=32
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_DEBUG is not set
    # CONFIG_MMC_ARMMMCI is not set
    CONFIG_MMC_SDHCI=y
    CONFIG_MMC_SDHCI_IO_ACCESSORS=y
    CONFIG_MMC_SDHCI_PLTFM=y
    CONFIG_MMC_SDHCI_OF_ARASAN=y
    # CONFIG_MMC_SDHCI_OF_AT91 is not set
    # CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
    # CONFIG_MMC_SDHCI_CADENCE is not set
    # CONFIG_MMC_SDHCI_F_SDH30 is not set
    # CONFIG_MMC_SDHCI_MILBEAUT is not set
    CONFIG_MMC_SPI=y
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MMC_USDHI6ROL0 is not set
    CONFIG_MMC_CQHCI=y
    # CONFIG_MMC_HSQ is not set
    # CONFIG_MMC_MTK is not set
    # CONFIG_MMC_SDHCI_XENON is not set
    CONFIG_MMC_SDHCI_AM654=y
    CONFIG_SCSI_UFSHCD=y
    CONFIG_SCSI_UFS_BSG=y
    # CONFIG_SCSI_UFS_HPB is not set
    # CONFIG_SCSI_UFS_HWMON is not set
    CONFIG_SCSI_UFSHCD_PLATFORM=y
    CONFIG_SCSI_UFS_CDNS_PLATFORM=m
    # CONFIG_SCSI_UFS_DWC_TC_PLATFORM is not set
    CONFIG_SCSI_UFS_TI_J721E=m
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # CONFIG_LEDS_CLASS_FLASH is not set
    CONFIG_LEDS_CLASS_MULTICOLOR=m
    # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
    # LED drivers
    # CONFIG_LEDS_AN30259A is not set
    # CONFIG_LEDS_AW2013 is not set
    # CONFIG_LEDS_BCM6328 is not set
    # CONFIG_LEDS_BCM6358 is not set
    # CONFIG_LEDS_CR0014114 is not set
    # CONFIG_LEDS_EL15203000 is not set
    # CONFIG_LEDS_LM3530 is not set
    # CONFIG_LEDS_LM3532 is not set
    # CONFIG_LEDS_LM3642 is not set
    CONFIG_LEDS_LM3692X=m
    # CONFIG_LEDS_MT6323 is not set
    CONFIG_LEDS_PCA9532=m
    # CONFIG_LEDS_PCA9532_GPIO is not set
    CONFIG_LEDS_GPIO=y
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP3952 is not set
    # CONFIG_LEDS_LP50XX is not set
    # CONFIG_LEDS_LP55XX_COMMON is not set
    # CONFIG_LEDS_LP8860 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_PCA963X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    CONFIG_LEDS_PWM=y
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    # CONFIG_LEDS_TCA6507 is not set
    # CONFIG_LEDS_TLC591XX is not set
    # CONFIG_LEDS_LM355x is not set
    # CONFIG_LEDS_IS31FL319X is not set
    # CONFIG_LEDS_IS31FL32XX is not set
    # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
    # CONFIG_LEDS_BLINKM is not set
    CONFIG_LEDS_SYSCON=y
    # CONFIG_LEDS_MLXREG is not set
    # CONFIG_LEDS_USER is not set
    # CONFIG_LEDS_SPI_BYTE is not set
    # CONFIG_LEDS_TI_LMU_COMMON is not set
    # Flash and Torch LED drivers
    # RGB LED drivers
    # CONFIG_LEDS_PWM_MULTICOLOR is not set
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=y
    # CONFIG_LEDS_TRIGGER_ONESHOT is not set
    CONFIG_LEDS_TRIGGER_DISK=y
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
    CONFIG_LEDS_TRIGGER_CPU=y
    # CONFIG_LEDS_TRIGGER_ACTIVITY is not set
    # CONFIG_LEDS_TRIGGER_GPIO is not set
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
    # iptables trigger is under Netfilter config (LED target)
    # CONFIG_LEDS_TRIGGER_TRANSIENT is not set
    # CONFIG_LEDS_TRIGGER_CAMERA is not set
    CONFIG_LEDS_TRIGGER_PANIC=y
    # CONFIG_LEDS_TRIGGER_NETDEV is not set
    # CONFIG_LEDS_TRIGGER_PATTERN is not set
    # CONFIG_LEDS_TRIGGER_AUDIO is not set
    # CONFIG_LEDS_TRIGGER_TTY is not set
    # Simple LED drivers
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_INFINIBAND is not set
    CONFIG_EDAC_SUPPORT=y
    CONFIG_EDAC=y
    CONFIG_EDAC_LEGACY_SYSFS=y
    # CONFIG_EDAC_DEBUG is not set
    # CONFIG_EDAC_XGENE is not set
    # CONFIG_EDAC_DMC520 is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    CONFIG_RTC_NVMEM=y
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_ABB5ZES3 is not set
    # CONFIG_RTC_DRV_ABEOZ9 is not set
    # CONFIG_RTC_DRV_ABX80X is not set
    CONFIG_RTC_DRV_DS1307=y
    # CONFIG_RTC_DRV_DS1307_CENTURY is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    CONFIG_RTC_DRV_HYM8563=m
    # CONFIG_RTC_DRV_MAX6900 is not set
    CONFIG_RTC_DRV_MAX77686=y
    # CONFIG_RTC_DRV_NCT3018Y is not set
    CONFIG_RTC_DRV_RK808=m
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_ISL12026 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    CONFIG_RTC_DRV_PCF85063=m
    CONFIG_RTC_DRV_PCF85363=m
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    CONFIG_RTC_DRV_M41T80=m
    # CONFIG_RTC_DRV_M41T80_WDT is not set
    CONFIG_RTC_DRV_BQ32K=m
    CONFIG_RTC_DRV_TPS6594=y
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8010 is not set
    CONFIG_RTC_DRV_RX8581=m
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    CONFIG_RTC_DRV_RV3028=m
    # CONFIG_RTC_DRV_RV3032 is not set
    CONFIG_RTC_DRV_RV8803=m
    # CONFIG_RTC_DRV_SD3078 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1302 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1343 is not set
    # CONFIG_RTC_DRV_DS1347 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6916 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_MCP795 is not set
    CONFIG_RTC_I2C_AND_SPI=y
    # SPI and I2C RTC drivers
    CONFIG_RTC_DRV_DS3232=y
    CONFIG_RTC_DRV_DS3232_HWMON=y
    CONFIG_RTC_DRV_PCF2127=m
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # CONFIG_RTC_DRV_RX6110 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1685_FAMILY is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    CONFIG_RTC_DRV_EFI=y
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # CONFIG_RTC_DRV_OPTEE is not set
    # CONFIG_RTC_DRV_ZYNQMP is not set
    # on-CPU RTC drivers
    # CONFIG_RTC_DRV_PL030 is not set
    # CONFIG_RTC_DRV_PL031 is not set
    # CONFIG_RTC_DRV_CADENCE is not set
    # CONFIG_RTC_DRV_FTRTC010 is not set
    CONFIG_RTC_DRV_MT6397=m
    # CONFIG_RTC_DRV_R7301 is not set
    CONFIG_RTC_DRV_TI_K3=m
    # HID Sensor RTC drivers
    # CONFIG_RTC_DRV_GOLDFISH is not set
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_VIRTUAL_CHANNELS=y
    CONFIG_DMA_OF=y
    # CONFIG_ALTERA_MSGDMA is not set
    # CONFIG_AMBA_PL08X is not set
    CONFIG_BCM_SBA_RAID=m
    # CONFIG_DW_AXI_DMAC is not set
    # CONFIG_FSL_EDMA is not set
    # CONFIG_FSL_QDMA is not set
    # CONFIG_INTEL_IDMA64 is not set
    # CONFIG_MV_XOR_V2 is not set
    # CONFIG_PL330_DMA is not set
    # CONFIG_XILINX_DMA is not set
    # CONFIG_XILINX_ZYNQMP_DMA is not set
    # CONFIG_XILINX_ZYNQMP_DPDMA is not set
    # CONFIG_QCOM_HIDMA_MGMT is not set
    # CONFIG_QCOM_HIDMA is not set
    # CONFIG_DW_DMAC is not set
    # CONFIG_SF_PDMA is not set
    CONFIG_TI_K3_UDMA=y
    CONFIG_TI_K3_UDMA_GLUE_LAYER=y
    CONFIG_TI_K3_PSIL=y
    # DMA Clients
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    CONFIG_DMA_ENGINE_RAID=y
    # DMABUF options
    CONFIG_SYNC_FILE=y
    # CONFIG_SW_SYNC is not set
    # CONFIG_UDMABUF is not set
    # CONFIG_DMABUF_MOVE_NOTIFY is not set
    # CONFIG_DMABUF_DEBUG is not set
    # CONFIG_DMABUF_SELFTESTS is not set
    CONFIG_DMABUF_HEAPS=y
    # CONFIG_DMABUF_SYSFS_STATS is not set
    CONFIG_DMABUF_HEAPS_SYSTEM=y
    CONFIG_DMABUF_HEAPS_CMA=y
    CONFIG_DMABUF_HEAPS_CARVEOUT=y
    # end of DMABUF options
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_UIO is not set
    CONFIG_VFIO=y
    CONFIG_VFIO_IOMMU_TYPE1=y
    # CONFIG_VFIO_NOIOMMU is not set
    # CONFIG_VFIO_PLATFORM is not set
    # CONFIG_VFIO_MDEV is not set
    # CONFIG_VIRT_DRIVERS is not set
    CONFIG_VIRTIO_ANCHOR=y
    CONFIG_VIRTIO=y
    CONFIG_VIRTIO_MENU=y
    CONFIG_VIRTIO_BALLOON=y
    # CONFIG_VIRTIO_MEM is not set
    # CONFIG_VIRTIO_INPUT is not set
    CONFIG_VIRTIO_MMIO=y
    # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set
    # CONFIG_VDPA is not set
    CONFIG_VHOST_MENU=y
    # CONFIG_VHOST_NET is not set
    # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
    # Microsoft Hyper-V guest support
    # end of Microsoft Hyper-V guest support
    # CONFIG_GREYBUS is not set
    # CONFIG_COMEDI is not set
    CONFIG_STAGING=y
    # CONFIG_PRISM2_USB is not set
    # CONFIG_RTLLIB is not set
    # CONFIG_RTL8723BS is not set
    # CONFIG_R8712U is not set
    CONFIG_R8188EU=m
    # CONFIG_VT6656 is not set
    # IIO staging drivers
    # Accelerometers
    # CONFIG_ADIS16203 is not set
    # CONFIG_ADIS16240 is not set
    # end of Accelerometers
    # Analog to digital converters
    # CONFIG_AD7816 is not set
    # end of Analog to digital converters
    # Analog digital bi-direction converters
    # CONFIG_ADT7316 is not set
    # end of Analog digital bi-direction converters
    # Direct Digital Synthesis
    # CONFIG_AD9832 is not set
    # CONFIG_AD9834 is not set
    # end of Direct Digital Synthesis
    # Network Analyzer, Impedance Converters
    # CONFIG_AD5933 is not set
    # end of Network Analyzer, Impedance Converters
    # Active energy metering IC
    # CONFIG_ADE7854 is not set
    # end of Active energy metering IC
    # Resolver to digital converters
    # CONFIG_AD2S1210 is not set
    # end of Resolver to digital converters
    # end of IIO staging drivers
    CONFIG_STAGING_MEDIA=y
    CONFIG_VIDEO_MAX96712=m
    # CONFIG_STAGING_MEDIA_DEPRECATED is not set
    # CONFIG_STAGING_BOARD is not set
    # CONFIG_LTE_GDM724X is not set
    # CONFIG_FB_TFT is not set
    # CONFIG_KS7010 is not set
    # CONFIG_PI433 is not set
    # CONFIG_XIL_AXIS_FIFO is not set
    # CONFIG_FIELDBUS_DEV is not set
    # CONFIG_GOLDFISH is not set
    # CONFIG_CHROME_PLATFORMS is not set
    # CONFIG_MELLANOX_PLATFORM is not set
    # CONFIG_SURFACE_PLATFORMS is not set
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # Clock driver for ARM Reference designs
    # CONFIG_CLK_ICST is not set
    # CONFIG_CLK_SP810 is not set
    # end of Clock driver for ARM Reference designs
    # CONFIG_LMK04832 is not set
    # CONFIG_COMMON_CLK_MAX77686 is not set
    # CONFIG_COMMON_CLK_MAX9485 is not set
    # CONFIG_COMMON_CLK_RK808 is not set
    CONFIG_COMMON_CLK_SCMI=y
    # CONFIG_COMMON_CLK_SI5341 is not set
    # CONFIG_COMMON_CLK_SI5351 is not set
    # CONFIG_COMMON_CLK_SI514 is not set
    # CONFIG_COMMON_CLK_SI544 is not set
    # CONFIG_COMMON_CLK_SI570 is not set
    # CONFIG_COMMON_CLK_CDCE706 is not set
    # CONFIG_COMMON_CLK_CDCE925 is not set
    CONFIG_COMMON_CLK_CS2000_CP=y
    # CONFIG_COMMON_CLK_AXI_CLKGEN is not set
    # CONFIG_COMMON_CLK_XGENE is not set
    CONFIG_COMMON_CLK_PWM=y
    # CONFIG_COMMON_CLK_RS9_PCIE is not set
    # CONFIG_COMMON_CLK_VC5 is not set
    # CONFIG_COMMON_CLK_VC7 is not set
    # CONFIG_COMMON_CLK_BD718XX is not set
    # CONFIG_COMMON_CLK_FIXED_MMIO is not set
    CONFIG_TI_SCI_CLK=y
    # CONFIG_TI_SCI_CLK_PROBE_FROM_FW is not set
    CONFIG_TI_SYSCON_CLK=y
    # CONFIG_XILINX_VCU is not set
    # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
    CONFIG_HWSPINLOCK=y
    # CONFIG_HWSPINLOCK_OMAP is not set
    # Clock Source drivers
    CONFIG_TIMER_OF=y
    CONFIG_TIMER_PROBE=y
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_ARM_ARCH_TIMER=y
    CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
    CONFIG_ARM_ARCH_TIMER_OOL_WORKAROUND=y
    # CONFIG_FSL_ERRATUM_A008585 is not set
    # CONFIG_HISILICON_ERRATUM_161010101 is not set
    CONFIG_ARM64_ERRATUM_858921=y
    # CONFIG_MICROCHIP_PIT64B is not set
    # end of Clock Source drivers
    CONFIG_MAILBOX=y
    # CONFIG_ARM_MHU is not set
    # CONFIG_ARM_MHU_V2 is not set
    # CONFIG_PLATFORM_MHU is not set
    # CONFIG_PL320_MBOX is not set
    CONFIG_OMAP2PLUS_MBOX=y
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    # CONFIG_ALTERA_MBOX is not set
    CONFIG_TI_MESSAGE_MANAGER=y
    # CONFIG_MAILBOX_TEST is not set
    CONFIG_IOMMU_IOVA=y
    CONFIG_IOMMU_API=y
    CONFIG_IOMMU_SUPPORT=y
    # Generic IOMMU Pagetable Support
    CONFIG_IOMMU_IO_PGTABLE=y
    CONFIG_IOMMU_IO_PGTABLE_LPAE=y
    # CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set
    CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y
    # CONFIG_IOMMU_IO_PGTABLE_ARMV7S_SELFTEST is not set
    CONFIG_IOMMU_IO_PGTABLE_DART=y
    # end of Generic IOMMU Pagetable Support
    # CONFIG_IOMMU_DEBUGFS is not set
    CONFIG_IOMMU_DEFAULT_DMA_STRICT=y
    # CONFIG_IOMMU_DEFAULT_DMA_LAZY is not set
    # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set
    CONFIG_OF_IOMMU=y
    CONFIG_IOMMU_DMA=y
    CONFIG_ARM_SMMU=y
    # CONFIG_ARM_SMMU_LEGACY_DT_BINDINGS is not set
    CONFIG_ARM_SMMU_DISABLE_BYPASS_BY_DEFAULT=y
    CONFIG_ARM_SMMU_V3=y
    # CONFIG_ARM_SMMU_V3_SVA is not set
    # CONFIG_VIRTIO_IOMMU is not set
    # Remoteproc drivers
    CONFIG_REMOTEPROC=y
    # CONFIG_REMOTEPROC_CDEV is not set
    CONFIG_PRU_REMOTEPROC=m
    CONFIG_TI_K3_DSP_REMOTEPROC=m
    CONFIG_TI_K3_M4_REMOTEPROC=m
    CONFIG_TI_K3_R5_REMOTEPROC=m
    # end of Remoteproc drivers
    # Rpmsg drivers
    CONFIG_RPMSG=y
    CONFIG_RPMSG_CHAR=m
    CONFIG_RPMSG_CTRL=m
    CONFIG_RPMSG_NS=m
    # CONFIG_RPMSG_QCOM_GLINK_RPM is not set
    CONFIG_RPMSG_VIRTIO=m
    CONFIG_RPMSG_PRU=m
    # end of Rpmsg drivers
    # Rpmsg virtual device drivers
    CONFIG_RPMSG_KDRV=y
    # CONFIG_RPMSG_KDRV_DEMO is not set
    # CONFIG_RPMSG_KDRV_DISPLAY is not set
    CONFIG_RPMSG_KDRV_ETH_SWITCH=y
    # end of Rpmsg virtual device drivers
    CONFIG_SOUNDWIRE=m
    # SoundWire Devices
    # CONFIG_SOUNDWIRE_QCOM is not set
    # SOC (System On Chip) specific Drivers
    # Amlogic SoC drivers
    # end of Amlogic SoC drivers
    # Broadcom SoC drivers
    # CONFIG_SOC_BRCMSTB is not set
    # end of Broadcom SoC drivers
    # NXP/Freescale QorIQ SoC drivers
    # CONFIG_QUICC_ENGINE is not set
    CONFIG_FSL_RCPM=y
    # end of NXP/Freescale QorIQ SoC drivers
    # fujitsu SoC drivers
    # end of fujitsu SoC drivers
    # i.MX SoC drivers
    # end of i.MX SoC drivers
    # Enable LiteX SoC Builder specific drivers
    # CONFIG_LITEX_SOC_CONTROLLER is not set
    # end of Enable LiteX SoC Builder specific drivers
    # Qualcomm SoC drivers
    # end of Qualcomm SoC drivers
    CONFIG_SOC_TI=y
    CONFIG_TI_SCI_PM_DOMAINS=y
    CONFIG_TI_K3_RINGACC=y
    CONFIG_TI_K3_SOCINFO=y
    CONFIG_TI_PRUSS=m
    CONFIG_TI_SCI_INTA_MSI_DOMAIN=y
    # Xilinx SoC drivers
    # end of Xilinx SoC drivers
    # end of SOC (System On Chip) specific Drivers
    CONFIG_PM_DEVFREQ=y
    # DEVFREQ Governors
    CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
    # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set
    # CONFIG_DEVFREQ_GOV_POWERSAVE is not set
    CONFIG_DEVFREQ_GOV_USERSPACE=m
    # CONFIG_DEVFREQ_GOV_PASSIVE is not set
    # DEVFREQ Drivers
    # CONFIG_PM_DEVFREQ_EVENT is not set
    CONFIG_EXTCON=y
    # Extcon Device Drivers
    # CONFIG_EXTCON_ADC_JACK is not set
    # CONFIG_EXTCON_FSA9480 is not set
    CONFIG_EXTCON_GPIO=y
    # CONFIG_EXTCON_MAX3355 is not set
    CONFIG_EXTCON_PTN5150=m
    # CONFIG_EXTCON_RT8973A is not set
    # CONFIG_EXTCON_SM5502 is not set
    CONFIG_EXTCON_USB_GPIO=y
    # CONFIG_EXTCON_USBC_TUSB320 is not set
    CONFIG_MEMORY=y
    # CONFIG_ARM_PL172_MPMC is not set
    CONFIG_OMAP_GPMC=y
    # CONFIG_OMAP_GPMC_DEBUG is not set
    CONFIG_IIO=y
    CONFIG_IIO_BUFFER=y
    # CONFIG_IIO_BUFFER_CB is not set
    # CONFIG_IIO_BUFFER_DMA is not set
    # CONFIG_IIO_BUFFER_DMAENGINE is not set
    # CONFIG_IIO_BUFFER_HW_CONSUMER is not set
    CONFIG_IIO_KFIFO_BUF=y
    CONFIG_IIO_TRIGGERED_BUFFER=y
    # CONFIG_IIO_CONFIGFS is not set
    CONFIG_IIO_TRIGGER=y
    CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
    # CONFIG_IIO_SW_DEVICE is not set
    # CONFIG_IIO_SW_TRIGGER is not set
    # CONFIG_IIO_TRIGGERED_EVENT is not set
    # Accelerometers
    # CONFIG_ADIS16201 is not set
    # CONFIG_ADIS16209 is not set
    # CONFIG_ADXL313_I2C is not set
    # CONFIG_ADXL313_SPI is not set
    # CONFIG_ADXL345_I2C is not set
    # CONFIG_ADXL345_SPI is not set
    # CONFIG_ADXL355_I2C is not set
    # CONFIG_ADXL355_SPI is not set
    # CONFIG_ADXL367_SPI is not set
    # CONFIG_ADXL367_I2C is not set
    # CONFIG_ADXL372_SPI is not set
    # CONFIG_ADXL372_I2C is not set
    # CONFIG_BMA180 is not set
    # CONFIG_BMA220 is not set
    # CONFIG_BMA400 is not set
    # CONFIG_BMC150_ACCEL is not set
    # CONFIG_BMI088_ACCEL is not set
    # CONFIG_DA280 is not set
    # CONFIG_DA311 is not set
    # CONFIG_DMARD06 is not set
    # CONFIG_DMARD09 is not set
    # CONFIG_DMARD10 is not set
    # CONFIG_FXLS8962AF_I2C is not set
    # CONFIG_FXLS8962AF_SPI is not set
    # CONFIG_IIO_ST_ACCEL_3AXIS is not set
    # CONFIG_KXSD9 is not set
    # CONFIG_KXCJK1013 is not set
    # CONFIG_MC3230 is not set
    # CONFIG_MMA7455_I2C is not set
    # CONFIG_MMA7455_SPI is not set
    # CONFIG_MMA7660 is not set
    # CONFIG_MMA8452 is not set
    # CONFIG_MMA9551 is not set
    # CONFIG_MMA9553 is not set
    # CONFIG_MSA311 is not set
    # CONFIG_MXC4005 is not set
    # CONFIG_MXC6255 is not set
    # CONFIG_SCA3000 is not set
    # CONFIG_SCA3300 is not set
    # CONFIG_STK8312 is not set
    # CONFIG_STK8BA50 is not set
    CONFIG_ADAS1000=m
    # CONFIG_AD7091R5 is not set
    # CONFIG_AD7124 is not set
    # CONFIG_AD7192 is not set
    # CONFIG_AD7266 is not set
    # CONFIG_AD7280 is not set
    # CONFIG_AD7291 is not set
    # CONFIG_AD7292 is not set
    # CONFIG_AD7298 is not set
    # CONFIG_AD7476 is not set
    # CONFIG_AD7606_IFACE_PARALLEL is not set
    # CONFIG_AD7606_IFACE_SPI is not set
    # CONFIG_AD7766 is not set
    # CONFIG_AD7768_1 is not set
    # CONFIG_AD7780 is not set
    # CONFIG_AD7791 is not set
    # CONFIG_AD7793 is not set
    # CONFIG_AD7887 is not set
    # CONFIG_AD7923 is not set
    # CONFIG_AD7949 is not set
    # CONFIG_AD799X is not set
    # CONFIG_ADI_AXI_ADC is not set
    # CONFIG_AXP20X_ADC is not set
    # CONFIG_AXP288_ADC is not set
    # CONFIG_CC10001_ADC is not set
    # CONFIG_ENVELOPE_DETECTOR is not set
    # CONFIG_HI8435 is not set
    # CONFIG_HX711 is not set
    # CONFIG_INA2XX_ADC is not set
    # CONFIG_LTC2471 is not set
    # CONFIG_LTC2485 is not set
    # CONFIG_LTC2496 is not set
    # CONFIG_LTC2497 is not set
    # CONFIG_MAX1027 is not set
    # CONFIG_MAX11100 is not set
    # CONFIG_MAX1118 is not set
    # CONFIG_MAX11205 is not set
    # CONFIG_MAX1241 is not set
    # CONFIG_MAX1363 is not set
    CONFIG_MAX9611=m
    # CONFIG_MCP320X is not set
    # CONFIG_MCP3422 is not set
    # CONFIG_MCP3911 is not set
    # CONFIG_MEDIATEK_MT6360_ADC is not set
    # CONFIG_NAU7802 is not set
    # CONFIG_RICHTEK_RTQ6056 is not set
    # CONFIG_SD_ADC_MODULATOR is not set
    # CONFIG_TI_ADC081C is not set
    # CONFIG_TI_ADC0832 is not set
    # CONFIG_TI_ADC084S021 is not set
    # CONFIG_TI_ADC12138 is not set
    # CONFIG_TI_ADC108S102 is not set
    # CONFIG_TI_ADC128S052 is not set
    # CONFIG_TI_ADC161S626 is not set
    CONFIG_TI_ADS1015=y
    # CONFIG_TI_ADS7950 is not set
    # CONFIG_TI_ADS8344 is not set
    # CONFIG_TI_ADS8688 is not set
    # CONFIG_TI_ADS124S08 is not set
    # CONFIG_TI_ADS131E08 is not set
    CONFIG_TI_AM335X_ADC=m
    # CONFIG_TI_TLC4541 is not set
    # CONFIG_TI_TSC2046 is not set
    # CONFIG_VF610_ADC is not set
    # CONFIG_XILINX_XADC is not set
    # Analog to digital and digital to analog converters
    # CONFIG_AD74413R is not set
    # end of Analog to digital and digital to analog converters
    # Analog Front Ends
    # CONFIG_IIO_RESCALE is not set
    # end of Analog Front Ends
    # Amplifiers
    # CONFIG_AD8366 is not set
    # CONFIG_ADA4250 is not set
    # CONFIG_HMC425 is not set
    # end of Amplifiers
    # Capacitance to digital converters
    # CONFIG_AD7150 is not set
    # CONFIG_AD7746 is not set
    # end of Capacitance to digital converters
    # Chemical Sensors
    # CONFIG_ATLAS_PH_SENSOR is not set
    # CONFIG_ATLAS_EZO_SENSOR is not set
    # CONFIG_BME680 is not set
    # CONFIG_CCS811 is not set
    # CONFIG_IAQCORE is not set
    # CONFIG_PMS7003 is not set
    # CONFIG_SCD30_CORE is not set
    # CONFIG_SCD4X is not set
    # CONFIG_SENSIRION_SGP30 is not set
    # CONFIG_SENSIRION_SGP40 is not set
    # CONFIG_SPS30_I2C is not set
    # CONFIG_SPS30_SERIAL is not set
    # CONFIG_SENSEAIR_SUNRISE_CO2 is not set
    # CONFIG_VZ89X is not set
    # end of Chemical Sensors
    # Hid Sensor IIO Common
    # end of Hid Sensor IIO Common
    # IIO SCMI Sensors
    # CONFIG_IIO_SCMI is not set
    # end of IIO SCMI Sensors
    # SSP Sensor Common
    # CONFIG_IIO_SSP_SENSORHUB is not set
    # end of SSP Sensor Common
    CONFIG_IIO_ST_SENSORS_I2C=m
    CONFIG_IIO_ST_SENSORS_SPI=m
    CONFIG_IIO_ST_SENSORS_CORE=m
    # Digital to analog converters
    # CONFIG_AD3552R is not set
    # CONFIG_AD5064 is not set
    # CONFIG_AD5360 is not set
    # CONFIG_AD5380 is not set
    # CONFIG_AD5421 is not set
    # CONFIG_AD5446 is not set
    # CONFIG_AD5449 is not set
    # CONFIG_AD5592R is not set
    # CONFIG_AD5593R is not set
    # CONFIG_AD5504 is not set
    # CONFIG_AD5624R_SPI is not set
    # CONFIG_LTC2688 is not set
    # CONFIG_AD5686_SPI is not set
    # CONFIG_AD5696_I2C is not set
    # CONFIG_AD5755 is not set
    # CONFIG_AD5758 is not set
    # CONFIG_AD5761 is not set
    # CONFIG_AD5764 is not set
    # CONFIG_AD5766 is not set
    # CONFIG_AD5770R is not set
    # CONFIG_AD5791 is not set
    # CONFIG_AD7293 is not set
    # CONFIG_AD7303 is not set
    # CONFIG_AD8801 is not set
    # CONFIG_DPOT_DAC is not set
    # CONFIG_DS4424 is not set
    # CONFIG_LTC1660 is not set
    # CONFIG_LTC2632 is not set
    # CONFIG_M62332 is not set
    # CONFIG_MAX517 is not set
    # CONFIG_MAX5821 is not set
    # CONFIG_MCP4725 is not set
    # CONFIG_MCP4922 is not set
    # CONFIG_TI_DAC082S085 is not set
    # CONFIG_TI_DAC5571 is not set
    # CONFIG_TI_DAC7311 is not set
    # CONFIG_TI_DAC7612 is not set
    # CONFIG_VF610_DAC is not set
    # end of Digital to analog converters
    # IIO dummy driver
    # end of IIO dummy driver
    # Filters
    # CONFIG_ADMV8818 is not set
    # end of Filters
    # Frequency Synthesizers DDS/PLL
    # Clock Generator/Distribution
    # CONFIG_AD9523 is not set
    # end of Clock Generator/Distribution
    # Phase-Locked Loop (PLL) frequency synthesizers
    # CONFIG_ADF4350 is not set
    # CONFIG_ADF4371 is not set
    # CONFIG_ADMV1013 is not set
    # CONFIG_ADMV1014 is not set
    # CONFIG_ADMV4420 is not set
    # CONFIG_ADRF6780 is not set
    # end of Phase-Locked Loop (PLL) frequency synthesizers
    # end of Frequency Synthesizers DDS/PLL
    # Digital gyroscope sensors
    # CONFIG_ADIS16080 is not set
    # CONFIG_ADIS16130 is not set
    # CONFIG_ADIS16136 is not set
    # CONFIG_ADIS16260 is not set
    # CONFIG_ADXRS290 is not set
    # CONFIG_ADXRS450 is not set
    # CONFIG_BMG160 is not set
    # CONFIG_FXAS21002C is not set
    # CONFIG_MPU3050_I2C is not set
    # CONFIG_IIO_ST_GYRO_3AXIS is not set
    # CONFIG_ITG3200 is not set
    # end of Digital gyroscope sensors
    # Health Sensors
    # Heart Rate Monitors
    CONFIG_AFE4403=m
    # CONFIG_AFE4404 is not set
    # CONFIG_MAX30100 is not set
    # CONFIG_MAX30102 is not set
    # end of Heart Rate Monitors
    # end of Health Sensors
    # Humidity sensors
    # CONFIG_AM2315 is not set
    # CONFIG_DHT11 is not set
    # CONFIG_HDC100X is not set
    # CONFIG_HDC2010 is not set
    # CONFIG_HTS221 is not set
    # CONFIG_HTU21 is not set
    # CONFIG_SI7005 is not set
    # CONFIG_SI7020 is not set
    # end of Humidity sensors
    # Inertial measurement units
    # CONFIG_ADIS16400 is not set
    # CONFIG_ADIS16460 is not set
    # CONFIG_ADIS16475 is not set
    # CONFIG_ADIS16480 is not set
    # CONFIG_BMI160_I2C is not set
    # CONFIG_BMI160_SPI is not set
    # CONFIG_BOSCH_BNO055_SERIAL is not set
    # CONFIG_BOSCH_BNO055_I2C is not set
    # CONFIG_FXOS8700_I2C is not set
    # CONFIG_FXOS8700_SPI is not set
    # CONFIG_KMX61 is not set
    # CONFIG_INV_ICM42600_I2C is not set
    # CONFIG_INV_ICM42600_SPI is not set
    # CONFIG_INV_MPU6050_I2C is not set
    # CONFIG_INV_MPU6050_SPI is not set
    CONFIG_IIO_ST_LSM6DSX=m
    CONFIG_IIO_ST_LSM6DSX_I2C=m
    CONFIG_IIO_ST_LSM6DSX_SPI=m
    # CONFIG_IIO_ST_LSM9DS0 is not set
    # end of Inertial measurement units
    # Light sensors
    # CONFIG_ADJD_S311 is not set
    # CONFIG_ADUX1020 is not set
    # CONFIG_AL3010 is not set
    # CONFIG_AL3320A is not set
    # CONFIG_APDS9300 is not set
    # CONFIG_APDS9960 is not set
    # CONFIG_AS73211 is not set
    # CONFIG_BH1750 is not set
    # CONFIG_BH1780 is not set
    # CONFIG_CM32181 is not set
    # CONFIG_CM3232 is not set
    # CONFIG_CM3323 is not set
    # CONFIG_CM3605 is not set
    # CONFIG_CM36651 is not set
    # CONFIG_GP2AP002 is not set
    # CONFIG_GP2AP020A00F is not set
    CONFIG_SENSORS_ISL29018=m
    # CONFIG_SENSORS_ISL29028 is not set
    # CONFIG_ISL29125 is not set
    # CONFIG_JSA1212 is not set
    # CONFIG_RPR0521 is not set
    # CONFIG_LTR501 is not set
    # CONFIG_LTRF216A is not set
    # CONFIG_LV0104CS is not set
    # CONFIG_MAX44000 is not set
    # CONFIG_MAX44009 is not set
    # CONFIG_NOA1305 is not set
    # CONFIG_OPT3001 is not set
    # CONFIG_PA12203001 is not set
    # CONFIG_SI1133 is not set
    # CONFIG_SI1145 is not set
    # CONFIG_STK3310 is not set
    # CONFIG_ST_UVIS25 is not set
    # CONFIG_TCS3414 is not set
    # CONFIG_TCS3472 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_TSL2583 is not set
    # CONFIG_TSL2591 is not set
    # CONFIG_TSL2772 is not set
    # CONFIG_TSL4531 is not set
    # CONFIG_US5182D is not set
    CONFIG_VCNL4000=m
    # CONFIG_VCNL4035 is not set
    # CONFIG_VEML6030 is not set
    # CONFIG_VEML6070 is not set
    # CONFIG_VL6180 is not set
    # CONFIG_ZOPT2201 is not set
    # end of Light sensors
    # Magnetometer sensors
    # CONFIG_AK8974 is not set
    # CONFIG_AK8975 is not set
    # CONFIG_AK09911 is not set
    # CONFIG_BMC150_MAGN_I2C is not set
    # CONFIG_BMC150_MAGN_SPI is not set
    # CONFIG_MAG3110 is not set
    # CONFIG_MMC35240 is not set
    CONFIG_IIO_ST_MAGN_3AXIS=m
    CONFIG_IIO_ST_MAGN_I2C_3AXIS=m
    CONFIG_IIO_ST_MAGN_SPI_3AXIS=m
    # CONFIG_SENSORS_HMC5843_I2C is not set
    # CONFIG_SENSORS_HMC5843_SPI is not set
    # CONFIG_SENSORS_RM3100_I2C is not set
    # CONFIG_SENSORS_RM3100_SPI is not set
    # CONFIG_YAMAHA_YAS530 is not set
    # end of Magnetometer sensors
    # Multiplexers
    # CONFIG_IIO_MUX is not set
    # end of Multiplexers
    # Inclinometer sensors
    # end of Inclinometer sensors
    # Triggers - standalone
    # CONFIG_IIO_INTERRUPT_TRIGGER is not set
    # CONFIG_IIO_SYSFS_TRIGGER is not set
    # end of Triggers - standalone
    # Linear and angular position sensors
    # end of Linear and angular position sensors
    # Digital potentiometers
    # CONFIG_AD5110 is not set
    # CONFIG_AD5272 is not set
    # CONFIG_DS1803 is not set
    # CONFIG_MAX5432 is not set
    # CONFIG_MAX5481 is not set
    # CONFIG_MAX5487 is not set
    # CONFIG_MCP4018 is not set
    # CONFIG_MCP4131 is not set
    # CONFIG_MCP4531 is not set
    # CONFIG_MCP41010 is not set
    # CONFIG_TPL0102 is not set
    # end of Digital potentiometers
    # Digital potentiostats
    # CONFIG_LMP91000 is not set
    # end of Digital potentiostats
    # Pressure sensors
    # CONFIG_ABP060MG is not set
    # CONFIG_BMP280 is not set
    # CONFIG_DLHL60D is not set
    # CONFIG_DPS310 is not set
    # CONFIG_HP03 is not set
    # CONFIG_ICP10100 is not set
    # CONFIG_MPL115_I2C is not set
    # CONFIG_MPL115_SPI is not set
    CONFIG_MPL3115=m
    # CONFIG_MS5611 is not set
    # CONFIG_MS5637 is not set
    # CONFIG_IIO_ST_PRESS is not set
    # CONFIG_T5403 is not set
    # CONFIG_HP206C is not set
    # CONFIG_ZPA2326 is not set
    # end of Pressure sensors
    # Lightning sensors
    # CONFIG_AS3935 is not set
    # end of Lightning sensors
    # Proximity and distance sensors
    # CONFIG_ISL29501 is not set
    # CONFIG_LIDAR_LITE_V2 is not set
    # CONFIG_MB1232 is not set
    # CONFIG_PING is not set
    # CONFIG_RFD77402 is not set
    # CONFIG_SRF04 is not set
    # CONFIG_SX9310 is not set
    # CONFIG_SX9324 is not set
    # CONFIG_SX9360 is not set
    # CONFIG_SX9500 is not set
    # CONFIG_SRF08 is not set
    # CONFIG_VCNL3020 is not set
    # CONFIG_VL53L0X_I2C is not set
    # end of Proximity and distance sensors
    # CONFIG_AD2S90 is not set
    # CONFIG_AD2S1200 is not set
    # Temperature sensors
    # CONFIG_LTC2983 is not set
    # CONFIG_MAXIM_THERMOCOUPLE is not set
    # CONFIG_MLX90614 is not set
    # CONFIG_MLX90632 is not set
    # CONFIG_TMP006 is not set
    # CONFIG_TMP007 is not set
    # CONFIG_TMP117 is not set
    # CONFIG_TSYS01 is not set
    # CONFIG_TSYS02D is not set
    # CONFIG_MAX31856 is not set
    # CONFIG_MAX31865 is not set
    # end of Temperature sensors
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    # CONFIG_PWM_DEBUG is not set
    # CONFIG_PWM_ATMEL_TCB is not set
    # CONFIG_PWM_CLK is not set
    # CONFIG_PWM_FSL_FTM is not set
    CONFIG_PWM_OMAP_DMTIMER=m
    # CONFIG_PWM_PCA9685 is not set
    CONFIG_PWM_TIECAP=m
    CONFIG_PWM_TIEHRPWM=m
    # CONFIG_PWM_XILINX is not set
    # IRQ chip support
    CONFIG_IRQCHIP=y
    CONFIG_ARM_GIC=y
    CONFIG_ARM_GIC_MAX_NR=1
    CONFIG_ARM_GIC_V3=y
    CONFIG_ARM_GIC_V3_ITS=y
    # CONFIG_AL_FIC is not set
    # CONFIG_XILINX_INTC is not set
    CONFIG_PARTITION_PERCPU=y
    CONFIG_TI_SCI_INTR_IRQCHIP=y
    CONFIG_TI_SCI_INTA_IRQCHIP=y
    CONFIG_TI_PRUSS_INTC=m
    # end of IRQ chip support
    # CONFIG_IPACK_BUS is not set
    CONFIG_RESET_CONTROLLER=y
    CONFIG_RESET_SCMI=y
    CONFIG_RESET_SIMPLE=y
    CONFIG_RESET_TI_SCI=y
    # CONFIG_RESET_TI_SYSCON is not set
    # CONFIG_RESET_TI_TPS380X is not set
    # PHY Subsystem
    CONFIG_GENERIC_PHY=y
    CONFIG_GENERIC_PHY_MIPI_DPHY=y
    CONFIG_PHY_XGENE=y
    CONFIG_PHY_CAN_TRANSCEIVER=m
    # PHY drivers for Broadcom platforms
    # CONFIG_BCM_KONA_USB2_PHY is not set
    # end of PHY drivers for Broadcom platforms
    CONFIG_PHY_CADENCE_TORRENT=y
    CONFIG_PHY_CADENCE_DPHY=m
    CONFIG_PHY_CADENCE_DPHY_RX=m
    CONFIG_PHY_CADENCE_SIERRA=y
    # CONFIG_PHY_CADENCE_SALVO is not set
    # CONFIG_PHY_PXA_28NM_HSIC is not set
    # CONFIG_PHY_PXA_28NM_USB2 is not set
    # CONFIG_PHY_LAN966X_SERDES is not set
    # CONFIG_PHY_CPCAP_USB is not set
    # CONFIG_PHY_MAPPHONE_MDM6600 is not set
    # CONFIG_PHY_OCELOT_SERDES is not set
    CONFIG_PHY_QCOM_USB_HS=m
    # CONFIG_PHY_QCOM_USB_HSIC is not set
    CONFIG_PHY_AM654_SERDES=y
    CONFIG_PHY_J721E_WIZ=y
    CONFIG_OMAP_USB2=m
    # CONFIG_PHY_TUSB1210 is not set
    CONFIG_PHY_TI_GMII_SEL=y
    # end of PHY Subsystem
    # CONFIG_POWERCAP is not set
    # CONFIG_MCB is not set
    # Performance monitor support
    CONFIG_ARM_CCI_PMU=m
    CONFIG_ARM_CCI400_PMU=y
    CONFIG_ARM_CCI5xx_PMU=y
    CONFIG_ARM_CCN=m
    CONFIG_ARM_CMN=m
    CONFIG_ARM_PMU=y
    CONFIG_ARM_DSU_PMU=m
    CONFIG_ARM_SPE_PMU=m
    # end of Performance monitor support
    CONFIG_RAS=y
    # Android
    # CONFIG_ANDROID_BINDER_IPC is not set
    # end of Android
    # CONFIG_LIBNVDIMM is not set
    # CONFIG_DAX is not set
    CONFIG_NVMEM=y
    CONFIG_NVMEM_SYSFS=y
    CONFIG_NVMEM_RMEM=m
    # HW tracing support
    CONFIG_STM=m
    # CONFIG_STM_PROTO_BASIC is not set
    # CONFIG_STM_PROTO_SYS_T is not set
    # CONFIG_STM_DUMMY is not set
    # CONFIG_STM_SOURCE_CONSOLE is not set
    # CONFIG_STM_SOURCE_HEARTBEAT is not set
    # CONFIG_INTEL_TH is not set
    # end of HW tracing support
    CONFIG_FPGA=y
    # CONFIG_ALTERA_PR_IP_CORE is not set
    # CONFIG_FPGA_MGR_ALTERA_PS_SPI is not set
    # CONFIG_FPGA_MGR_XILINX_SPI is not set
    # CONFIG_FPGA_MGR_ICE40_SPI is not set
    # CONFIG_FPGA_MGR_MACHXO2_SPI is not set
    CONFIG_FPGA_BRIDGE=m
    CONFIG_ALTERA_FREEZE_BRIDGE=m
    # CONFIG_XILINX_PR_DECOUPLER is not set
    CONFIG_FPGA_REGION=m
    CONFIG_OF_FPGA_REGION=m
    # CONFIG_FPGA_DFL is not set
    # CONFIG_FPGA_MGR_MICROCHIP_SPI is not set
    # CONFIG_FSI is not set
    CONFIG_TEE=y
    CONFIG_OPTEE=y
    CONFIG_MULTIPLEXER=y
    # Multiplexer drivers
    # CONFIG_MUX_ADG792A is not set
    # CONFIG_MUX_ADGS1408 is not set
    CONFIG_MUX_GPIO=y
    CONFIG_MUX_MMIO=y
    # end of Multiplexer drivers
    CONFIG_PM_OPP=y
    # CONFIG_SIOX is not set
    # CONFIG_SLIMBUS is not set
    CONFIG_INTERCONNECT=y
    CONFIG_COUNTER=m
    # CONFIG_INTERRUPT_CNT is not set
    CONFIG_TI_EQEP=m
    # CONFIG_FTM_QUADDEC is not set
    # CONFIG_MICROCHIP_TCB_CAPTURE is not set
    CONFIG_TI_ECAP_CAPTURE=m
    # CONFIG_MOST is not set
    # CONFIG_PECI is not set
    # CONFIG_HTE is not set
    # end of Device Drivers
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    # CONFIG_VALIDATE_FS_PARSER is not set
    CONFIG_FS_IOMAP=y
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    CONFIG_EXT3_FS=y
    CONFIG_EXT3_FS_POSIX_ACL=y
    CONFIG_EXT3_FS_SECURITY=y
    CONFIG_EXT4_FS=y
    CONFIG_EXT4_FS_POSIX_ACL=y
    CONFIG_EXT4_FS_SECURITY=y
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    CONFIG_BTRFS_FS=m
    CONFIG_BTRFS_FS_POSIX_ACL=y
    # CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set
    # CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
    # CONFIG_BTRFS_DEBUG is not set
    # CONFIG_BTRFS_ASSERT is not set
    # CONFIG_BTRFS_FS_REF_VERIFY is not set
    # CONFIG_NILFS2_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_EXPORTFS=y
    # CONFIG_EXPORTFS_BLOCK_OPS is not set
    CONFIG_FILE_LOCKING=y
    # CONFIG_FS_ENCRYPTION is not set
    # CONFIG_FS_VERITY is not set
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    CONFIG_FANOTIFY=y
    CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    # CONFIG_QUOTA_DEBUG is not set
    # CONFIG_QFMT_V1 is not set
    # CONFIG_QFMT_V2 is not set
    CONFIG_QUOTACTL=y
    CONFIG_AUTOFS4_FS=y
    CONFIG_AUTOFS_FS=y
    CONFIG_FUSE_FS=m
    CONFIG_CUSE=m
    # CONFIG_VIRTIO_FS is not set
    # CONFIG_OVERLAY_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # end of Caches
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # end of CD-ROM/DVD Filesystems
    # DOS/FAT/EXFAT/NT Filesystems
    CONFIG_FAT_FS=y
    # CONFIG_MSDOS_FS is not set
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_FAT_DEFAULT_UTF8 is not set
    CONFIG_EXFAT_FS=m
    CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8"
    CONFIG_NTFS_FS=m
    # CONFIG_NTFS_DEBUG is not set
    CONFIG_NTFS_RW=y
    # CONFIG_NTFS3_FS is not set
    # end of DOS/FAT/EXFAT/NT Filesystems
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    # CONFIG_PROC_KCORE is not set
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    # CONFIG_PROC_CHILDREN is not set
    CONFIG_KERNFS=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    CONFIG_TMPFS_POSIX_ACL=y
    CONFIG_TMPFS_XATTR=y
    # CONFIG_TMPFS_INODE64 is not set
    CONFIG_ARCH_SUPPORTS_HUGETLBFS=y
    CONFIG_HUGETLBFS=y
    CONFIG_HUGETLB_PAGE=y
    CONFIG_MEMFD_CREATE=y
    CONFIG_ARCH_HAS_GIGANTIC_PAGE=y
    CONFIG_CONFIGFS_FS=y
    CONFIG_EFIVAR_FS=y
    # end of Pseudo filesystems
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ORANGEFS_FS is not set
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_ECRYPT_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    # CONFIG_CRAMFS is not set
    CONFIG_SQUASHFS=y
    CONFIG_SQUASHFS_FILE_CACHE=y
    # CONFIG_SQUASHFS_FILE_DIRECT is not set
    CONFIG_SQUASHFS_DECOMP_SINGLE=y
    # CONFIG_SQUASHFS_DECOMP_MULTI is not set
    # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
    # CONFIG_SQUASHFS_XATTR is not set
    CONFIG_SQUASHFS_ZLIB=y
    CONFIG_SQUASHFS_LZ4=y
    # CONFIG_SQUASHFS_LZO is not set
    # CONFIG_SQUASHFS_XZ is not set
    # CONFIG_SQUASHFS_ZSTD is not set
    # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
    # CONFIG_SQUASHFS_EMBEDDED is not set
    CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    CONFIG_PSTORE=y
    CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240
    CONFIG_PSTORE_DEFLATE_COMPRESS=y
    # CONFIG_PSTORE_LZO_COMPRESS is not set
    # CONFIG_PSTORE_LZ4_COMPRESS is not set
    # CONFIG_PSTORE_LZ4HC_COMPRESS is not set
    # CONFIG_PSTORE_842_COMPRESS is not set
    # CONFIG_PSTORE_ZSTD_COMPRESS is not set
    CONFIG_PSTORE_COMPRESS=y
    CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y
    CONFIG_PSTORE_COMPRESS_DEFAULT="deflate"
    # CONFIG_PSTORE_CONSOLE is not set
    # CONFIG_PSTORE_PMSG is not set
    # CONFIG_PSTORE_RAM is not set
    # CONFIG_PSTORE_BLK is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    # CONFIG_EROFS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    # CONFIG_NFS_V3_ACL is not set
    CONFIG_NFS_V4=y
    # CONFIG_NFS_SWAP is not set
    CONFIG_NFS_V4_1=y
    CONFIG_NFS_V4_2=y
    CONFIG_PNFS_FILE_LAYOUT=y
    CONFIG_PNFS_BLOCK=m
    CONFIG_PNFS_FLEXFILE_LAYOUT=y
    CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
    # CONFIG_NFS_V4_1_MIGRATION is not set
    CONFIG_NFS_V4_SECURITY_LABEL=y
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    CONFIG_NFS_DISABLE_UDP_SUPPORT=y
    # CONFIG_NFS_V4_2_READ_PLUS is not set
    # CONFIG_NFSD is not set
    CONFIG_GRACE_PERIOD=y
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_COMMON=y
    CONFIG_NFS_V4_2_SSC_HELPER=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    CONFIG_SUNRPC_BACKCHANNEL=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_SMB_SERVER is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    # CONFIG_NLS_ASCII is not set
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    # CONFIG_NLS_UTF8 is not set
    # CONFIG_DLM is not set
    # CONFIG_UNICODE is not set
    CONFIG_IO_WQ=y
    # end of File systems
    # Security options
    CONFIG_KEYS=y
    # CONFIG_KEYS_REQUEST_CACHE is not set
    # CONFIG_PERSISTENT_KEYRINGS is not set
    # CONFIG_TRUSTED_KEYS is not set
    # CONFIG_ENCRYPTED_KEYS is not set
    # CONFIG_KEY_DH_OPERATIONS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    CONFIG_SECURITY=y
    CONFIG_SECURITYFS=y
    # CONFIG_SECURITY_NETWORK is not set
    # CONFIG_SECURITY_PATH is not set
    CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
    # CONFIG_HARDENED_USERCOPY is not set
    # CONFIG_FORTIFY_SOURCE is not set
    # CONFIG_STATIC_USERMODEHELPER is not set
    # CONFIG_SECURITY_SMACK is not set
    # CONFIG_SECURITY_TOMOYO is not set
    # CONFIG_SECURITY_APPARMOR is not set
    # CONFIG_SECURITY_LOADPIN is not set
    # CONFIG_SECURITY_YAMA is not set
    # CONFIG_SECURITY_SAFESETID is not set
    # CONFIG_SECURITY_LOCKDOWN_LSM is not set
    # CONFIG_SECURITY_LANDLOCK is not set
    CONFIG_INTEGRITY=y
    # CONFIG_INTEGRITY_SIGNATURE is not set
    CONFIG_INTEGRITY_AUDIT=y
    # CONFIG_IMA is not set
    # CONFIG_IMA_SECURE_AND_OR_TRUSTED_BOOT is not set
    # CONFIG_EVM is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf"
    # Kernel hardening options
    # Memory initialization
    CONFIG_CC_HAS_AUTO_VAR_INIT_PATTERN=y
    CONFIG_CC_HAS_AUTO_VAR_INIT_ZERO_BARE=y
    CONFIG_CC_HAS_AUTO_VAR_INIT_ZERO=y
    CONFIG_INIT_STACK_NONE=y
    # CONFIG_INIT_STACK_ALL_PATTERN is not set
    # CONFIG_INIT_STACK_ALL_ZERO is not set
    # CONFIG_GCC_PLUGIN_STACKLEAK is not set
    # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
    # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
    CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y
    # CONFIG_ZERO_CALL_USED_REGS is not set
    # end of Memory initialization
    CONFIG_RANDSTRUCT_NONE=y
    # CONFIG_RANDSTRUCT_FULL is not set
    # CONFIG_RANDSTRUCT_PERFORMANCE is not set
    # end of Kernel hardening options
    # end of Security options
    CONFIG_XOR_BLOCKS=m
    CONFIG_ASYNC_TX_DISABLE_PQ_VAL_DMA=y
    CONFIG_ASYNC_TX_DISABLE_XOR_VAL_DMA=y
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=y
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_SKCIPHER=y
    CONFIG_CRYPTO_SKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=y
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_RNG_DEFAULT=y
    CONFIG_CRYPTO_AKCIPHER2=y
    CONFIG_CRYPTO_AKCIPHER=y
    CONFIG_CRYPTO_KPP2=y
    CONFIG_CRYPTO_KPP=m
    CONFIG_CRYPTO_ACOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    # CONFIG_CRYPTO_USER is not set
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    CONFIG_CRYPTO_GF128MUL=y
    CONFIG_CRYPTO_NULL=y
    CONFIG_CRYPTO_NULL2=y
    # CONFIG_CRYPTO_PCRYPT is not set
    # CONFIG_CRYPTO_CRYPTD is not set
    CONFIG_CRYPTO_AUTHENC=y
    CONFIG_CRYPTO_TEST=m
    CONFIG_CRYPTO_ENGINE=m
    # end of Crypto core or helper
    # Public-key cryptography
    CONFIG_CRYPTO_RSA=y
    CONFIG_CRYPTO_DH=m
    # CONFIG_CRYPTO_DH_RFC7919_GROUPS is not set
    CONFIG_CRYPTO_ECC=m
    CONFIG_CRYPTO_ECDH=m
    # CONFIG_CRYPTO_ECDSA is not set
    # CONFIG_CRYPTO_ECRDSA is not set
    # CONFIG_CRYPTO_SM2 is not set
    CONFIG_CRYPTO_CURVE25519=m
    # end of Public-key cryptography
    # Block ciphers
    CONFIG_CRYPTO_AES=y
    # CONFIG_CRYPTO_AES_TI is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    # CONFIG_CRYPTO_ARIA is not set
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    CONFIG_CRYPTO_DES=m
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    CONFIG_CRYPTO_SM4=m
    CONFIG_CRYPTO_SM4_GENERIC=m
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # end of Block ciphers
    # Length-preserving ciphers and modes
    # CONFIG_CRYPTO_ADIANTUM is not set
    # CONFIG_CRYPTO_ARC4 is not set
    # CONFIG_CRYPTO_CHACHA20 is not set
    CONFIG_CRYPTO_CBC=y
    # CONFIG_CRYPTO_CFB is not set
    CONFIG_CRYPTO_CTR=y
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=m
    # CONFIG_CRYPTO_HCTR2 is not set
    # CONFIG_CRYPTO_KEYWRAP is not set
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_OFB is not set
    # CONFIG_CRYPTO_PCBC is not set
    CONFIG_CRYPTO_XTS=m
    # end of Length-preserving ciphers and modes
    # AEAD (authenticated encryption with associated data) ciphers
    # CONFIG_CRYPTO_AEGIS128 is not set
    # CONFIG_CRYPTO_CHACHA20POLY1305 is not set
    CONFIG_CRYPTO_CCM=m
    CONFIG_CRYPTO_GCM=y
    CONFIG_CRYPTO_SEQIV=y
    CONFIG_CRYPTO_ECHAINIV=y
    # CONFIG_CRYPTO_ESSIV is not set
    # end of AEAD (authenticated encryption with associated data) ciphers
    # Hashes, digests, and MACs
    CONFIG_CRYPTO_BLAKE2B=m
    CONFIG_CRYPTO_CMAC=m
    CONFIG_CRYPTO_GHASH=y
    CONFIG_CRYPTO_HMAC=y
    # CONFIG_CRYPTO_MD4 is not set
    CONFIG_CRYPTO_MD5=m
    CONFIG_CRYPTO_MICHAEL_MIC=m
    # CONFIG_CRYPTO_POLY1305 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    CONFIG_CRYPTO_SHA1=y
    CONFIG_CRYPTO_SHA256=y
    CONFIG_CRYPTO_SHA512=y
    CONFIG_CRYPTO_SHA3=m
    CONFIG_CRYPTO_SM3=m
    CONFIG_CRYPTO_SM3_GENERIC=m
    # CONFIG_CRYPTO_STREEBOG is not set
    # CONFIG_CRYPTO_VMAC is not set
    # CONFIG_CRYPTO_WP512 is not set
    # CONFIG_CRYPTO_XCBC is not set
    CONFIG_CRYPTO_XXHASH=m
    # end of Hashes, digests, and MACs
    # CRCs (cyclic redundancy checks)
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    CONFIG_CRYPTO_CRCT10DIF=y
    CONFIG_CRYPTO_CRC64_ROCKSOFT=y
    # end of CRCs (cyclic redundancy checks)
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    CONFIG_CRYPTO_LZO=y
    # CONFIG_CRYPTO_842 is not set
    CONFIG_CRYPTO_LZ4=y
    # CONFIG_CRYPTO_LZ4HC is not set
    CONFIG_CRYPTO_ZSTD=y
    # end of Compression
    # Random number generation
    CONFIG_CRYPTO_ANSI_CPRNG=y
    CONFIG_CRYPTO_DRBG_MENU=y
    CONFIG_CRYPTO_DRBG_HMAC=y
    # CONFIG_CRYPTO_DRBG_HASH is not set
    # CONFIG_CRYPTO_DRBG_CTR is not set
    CONFIG_CRYPTO_DRBG=y
    CONFIG_CRYPTO_JITTERENTROPY=y
    # end of Random number generation
    # Userspace interface
    CONFIG_CRYPTO_USER_API=m
    CONFIG_CRYPTO_USER_API_HASH=m
    # CONFIG_CRYPTO_USER_API_SKCIPHER is not set
    CONFIG_CRYPTO_USER_API_RNG=m
    # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
    # CONFIG_CRYPTO_USER_API_AEAD is not set
    CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y
    # end of Userspace interface
    CONFIG_CRYPTO_HASH_INFO=y
    # CONFIG_CRYPTO_NHPOLY1305_NEON is not set
    CONFIG_CRYPTO_CHACHA20_NEON=m
    # Accelerated Cryptographic Algorithms for CPU (arm64)
    CONFIG_CRYPTO_GHASH_ARM64_CE=y
    # CONFIG_CRYPTO_POLY1305_NEON is not set
    CONFIG_CRYPTO_SHA1_ARM64_CE=y
    CONFIG_CRYPTO_SHA256_ARM64=y
    CONFIG_CRYPTO_SHA2_ARM64_CE=y
    CONFIG_CRYPTO_SHA512_ARM64=m
    CONFIG_CRYPTO_SHA512_ARM64_CE=m
    CONFIG_CRYPTO_SHA3_ARM64=m
    # CONFIG_CRYPTO_SM3_NEON is not set
    CONFIG_CRYPTO_SM3_ARM64_CE=m
    # CONFIG_CRYPTO_POLYVAL_ARM64_CE is not set
    # CONFIG_CRYPTO_AES_ARM64 is not set
    CONFIG_CRYPTO_AES_ARM64_CE=y
    CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
    CONFIG_CRYPTO_AES_ARM64_NEON_BLK=m
    CONFIG_CRYPTO_AES_ARM64_BS=m
    # CONFIG_CRYPTO_SM4_ARM64_CE is not set
    # CONFIG_CRYPTO_SM4_ARM64_CE_BLK is not set
    # CONFIG_CRYPTO_SM4_ARM64_NEON_BLK is not set
    CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
    CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m
    # end of Accelerated Cryptographic Algorithms for CPU (arm64)
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
    # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
    # CONFIG_CRYPTO_DEV_CCP is not set
    # CONFIG_CRYPTO_DEV_VIRTIO is not set
    # CONFIG_CRYPTO_DEV_SAFEXCEL is not set
    CONFIG_CRYPTO_DEV_CCREE=m
    # CONFIG_CRYPTO_DEV_HISI_SEC is not set
    CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m
    # CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set
    CONFIG_CRYPTO_DEV_SA2UL=m
    CONFIG_CRYPTO_DEV_TI_MCRC64=m\
    CONFIG_ASYMMETRIC_KEY_TYPE=y
    CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
    CONFIG_X509_CERTIFICATE_PARSER=y
    # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
    CONFIG_PKCS7_MESSAGE_PARSER=y
    # CONFIG_PKCS7_TEST_KEY is not set
    # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
    # CONFIG_FIPS_SIGNATURE_SELFTEST is not set
    # Certificates for signature checking
    CONFIG_SYSTEM_TRUSTED_KEYRING=y
    CONFIG_SYSTEM_TRUSTED_KEYS=""
    # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
    # CONFIG_SECONDARY_TRUSTED_KEYRING is not set
    # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
    # end of Certificates for signature checking
    CONFIG_BINARY_PRINTF=y
    # Library routines
    CONFIG_RAID6_PQ=m
    CONFIG_RAID6_PQ_BENCHMARK=y
    CONFIG_LINEAR_RANGES=y
    CONFIG_PACKING=y
    CONFIG_BITREVERSE=y
    CONFIG_HAVE_ARCH_BITREVERSE=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    # CONFIG_CORDIC is not set
    # CONFIG_PRIME_NUMBERS is not set
    CONFIG_RATIONAL=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
    CONFIG_ARCH_HAS_FAST_MULTIPLIER=y
    CONFIG_ARCH_USE_SYM_ANNOTATIONS=y
    CONFIG_INDIRECT_PIO=y
    # Crypto library routines
    CONFIG_CRYPTO_LIB_UTILS=y
    CONFIG_CRYPTO_LIB_AES=y
    CONFIG_CRYPTO_LIB_ARC4=m
    CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y
    CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m
    CONFIG_CRYPTO_LIB_CHACHA_GENERIC=m
    # CONFIG_CRYPTO_LIB_CHACHA is not set
    CONFIG_CRYPTO_LIB_CURVE25519_GENERIC=m
    # CONFIG_CRYPTO_LIB_CURVE25519 is not set
    CONFIG_CRYPTO_LIB_DES=m
    CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
    # CONFIG_CRYPTO_LIB_POLY1305 is not set
    # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
    CONFIG_CRYPTO_LIB_SHA1=y
    CONFIG_CRYPTO_LIB_SHA256=y
    # end of Crypto library routines
    CONFIG_CRC_CCITT=m
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=y
    CONFIG_CRC64_ROCKSOFT=y
    CONFIG_CRC_ITU_T=y
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    CONFIG_CRC64=y
    # CONFIG_CRC4 is not set
    CONFIG_CRC7=y
    CONFIG_LIBCRC32C=m
    CONFIG_CRC8=y
    CONFIG_XXHASH=y
    CONFIG_AUDIT_GENERIC=y
    CONFIG_AUDIT_ARCH_COMPAT_GENERIC=y
    CONFIG_AUDIT_COMPAT_GENERIC=y
    # CONFIG_RANDOM32_SELFTEST is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    CONFIG_LZ4_COMPRESS=y
    CONFIG_LZ4_DECOMPRESS=y
    CONFIG_ZSTD_COMMON=y
    CONFIG_ZSTD_COMPRESS=y
    CONFIG_ZSTD_DECOMPRESS=y
    CONFIG_XZ_DEC=y
    CONFIG_XZ_DEC_X86=y
    CONFIG_XZ_DEC_POWERPC=y
    CONFIG_XZ_DEC_IA64=y
    CONFIG_XZ_DEC_ARM=y
    CONFIG_XZ_DEC_ARMTHUMB=y
    CONFIG_XZ_DEC_SPARC=y
    # CONFIG_XZ_DEC_MICROLZMA is not set
    CONFIG_XZ_DEC_BCJ=y
    # CONFIG_XZ_DEC_TEST is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_DECOMPRESS_BZIP2=y
    CONFIG_DECOMPRESS_LZMA=y
    CONFIG_DECOMPRESS_XZ=y
    CONFIG_DECOMPRESS_LZO=y
    CONFIG_DECOMPRESS_LZ4=y
    CONFIG_DECOMPRESS_ZSTD=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_TEXTSEARCH=y
    CONFIG_TEXTSEARCH_KMP=m
    CONFIG_TEXTSEARCH_BM=m
    CONFIG_TEXTSEARCH_FSM=m
    CONFIG_INTERVAL_TREE=y
    CONFIG_XARRAY_MULTI=y
    CONFIG_ASSOCIATIVE_ARRAY=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_DMA=y
    CONFIG_DMA_OPS=y
    CONFIG_NEED_SG_DMA_LENGTH=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_ARCH_DMA_ADDR_T_64BIT=y
    CONFIG_DMA_DECLARE_COHERENT=y
    CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
    CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
    CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y
    CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y
    CONFIG_ARCH_HAS_DMA_PREP_COHERENT=y
    CONFIG_SWIOTLB=y
    # CONFIG_DMA_RESTRICTED_POOL is not set
    CONFIG_DMA_NONCOHERENT_MMAP=y
    CONFIG_DMA_COHERENT_POOL=y
    CONFIG_DMA_DIRECT_REMAP=y
    CONFIG_DMA_CMA=y
    CONFIG_DMA_PERNUMA_CMA=y
    # Default contiguous memory area size:
    CONFIG_CMA_SIZE_MBYTES=128
    CONFIG_CMA_SIZE_SEL_MBYTES=y
    # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
    # CONFIG_CMA_SIZE_SEL_MIN is not set
    # CONFIG_CMA_SIZE_SEL_MAX is not set
    CONFIG_CMA_ALIGNMENT=8
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_DMA_MAP_BENCHMARK is not set
    CONFIG_SGL_ALLOC=y
    # CONFIG_FORCE_NR_CPUS is not set
    CONFIG_CPU_RMAP=y
    CONFIG_DQL=y
    CONFIG_GLOB=y
    # CONFIG_GLOB_SELFTEST is not set
    CONFIG_NLATTR=y
    CONFIG_CLZ_TAB=y
    CONFIG_IRQ_POLL=y
    CONFIG_MPILIB=y
    CONFIG_LIBFDT=y
    CONFIG_OID_REGISTRY=y
    CONFIG_UCS2_STRING=y
    CONFIG_HAVE_GENERIC_VDSO=y
    CONFIG_GENERIC_GETTIMEOFDAY=y
    CONFIG_GENERIC_VDSO_TIME_NS=y
    CONFIG_FONT_SUPPORT=y
    # CONFIG_FONTS is not set
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    CONFIG_SG_SPLIT=y
    CONFIG_SG_POOL=y
    CONFIG_ARCH_STACKWALK=y
    CONFIG_STACKDEPOT=y
    CONFIG_SBITMAP=y
    # end of Library routines
    CONFIG_GENERIC_IOREMAP=y
    CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y
    # Kernel hacking
    # printk and dmesg options
    CONFIG_PRINTK_TIME=y
    # CONFIG_PRINTK_CALLER is not set
    # CONFIG_STACKTRACE_BUILD_ID is not set
    CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
    CONFIG_CONSOLE_LOGLEVEL_QUIET=4
    CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    CONFIG_DYNAMIC_DEBUG=y
    CONFIG_DYNAMIC_DEBUG_CORE=y
    CONFIG_SYMBOLIC_ERRNAME=y
    CONFIG_DEBUG_BUGVERBOSE=y
    # end of printk and dmesg options
    CONFIG_DEBUG_KERNEL=y
    CONFIG_DEBUG_MISC=y
    # Compile-time checks and compiler options
    CONFIG_DEBUG_INFO=y
    CONFIG_AS_HAS_NON_CONST_LEB128=y
    # CONFIG_DEBUG_INFO_NONE is not set
    CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT=y
    # CONFIG_DEBUG_INFO_DWARF4 is not set
    # CONFIG_DEBUG_INFO_DWARF5 is not set
    CONFIG_DEBUG_INFO_REDUCED=y
    # CONFIG_DEBUG_INFO_COMPRESSED is not set
    # CONFIG_DEBUG_INFO_SPLIT is not set
    # CONFIG_GDB_SCRIPTS is not set
    CONFIG_FRAME_WARN=2048
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_HEADERS_INSTALL is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_SECTION_MISMATCH_WARN_ONLY=y
    # CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_64B is not set
    CONFIG_ARCH_WANT_FRAME_POINTERS=y
    CONFIG_FRAME_POINTER=y
    # CONFIG_VMLINUX_MAP is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # end of Compile-time checks and compiler options
    # Generic Kernel Debugging Instruments
    CONFIG_MAGIC_SYSRQ=y
    CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
    CONFIG_MAGIC_SYSRQ_SERIAL=y
    CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
    CONFIG_DEBUG_FS=y
    CONFIG_DEBUG_FS_ALLOW_ALL=y
    # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
    # CONFIG_DEBUG_FS_ALLOW_NONE is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    CONFIG_ARCH_HAS_UBSAN_SANITIZE_ALL=y
    # CONFIG_UBSAN is not set
    CONFIG_HAVE_ARCH_KCSAN=y
    CONFIG_HAVE_KCSAN_COMPILER=y
    # CONFIG_KCSAN is not set
    # end of Generic Kernel Debugging Instruments
    # Networking Debugging
    # CONFIG_NET_DEV_REFCNT_TRACKER is not set
    # CONFIG_NET_NS_REFCNT_TRACKER is not set
    # CONFIG_DEBUG_NET is not set
    # end of Networking Debugging
    # Memory Debugging
    # CONFIG_PAGE_EXTENSION is not set
    # CONFIG_DEBUG_PAGEALLOC is not set
    CONFIG_SLUB_DEBUG=y
    # CONFIG_SLUB_DEBUG_ON is not set
    # CONFIG_PAGE_OWNER is not set
    # CONFIG_PAGE_TABLE_CHECK is not set
    # CONFIG_PAGE_POISONING is not set
    # CONFIG_DEBUG_RODATA_TEST is not set
    CONFIG_ARCH_HAS_DEBUG_WX=y
    # CONFIG_DEBUG_WX is not set
    CONFIG_GENERIC_PTDUMP=y
    # CONFIG_PTDUMP_DEBUGFS is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_SHRINKER_DEBUG is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_SCHED_STACK_END_CHECK is not set
    CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_VM_PGTABLE is not set
    CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
    # CONFIG_DEBUG_VIRTUAL is not set
    CONFIG_DEBUG_MEMORY_INIT=y
    # CONFIG_DEBUG_PER_CPU_MAPS is not set
    CONFIG_HAVE_ARCH_KASAN=y
    CONFIG_HAVE_ARCH_KASAN_SW_TAGS=y
    CONFIG_HAVE_ARCH_KASAN_HW_TAGS=y
    CONFIG_HAVE_ARCH_KASAN_VMALLOC=y
    CONFIG_CC_HAS_KASAN_GENERIC=y
    CONFIG_CC_HAS_KASAN_SW_TAGS=y
    CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
    # CONFIG_KASAN is not set
    CONFIG_HAVE_ARCH_KFENCE=y
    # CONFIG_KFENCE is not set
    # end of Memory Debugging
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Oops, Lockups and Hangs
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    CONFIG_PANIC_TIMEOUT=0
    # CONFIG_SOFTLOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_WQ_WATCHDOG is not set
    # CONFIG_TEST_LOCKUP is not set
    # end of Debug Oops, Lockups and Hangs
    # Scheduler Debugging
    # CONFIG_SCHED_DEBUG is not set
    # CONFIG_SCHEDSTATS is not set
    # end of Scheduler Debugging
    # CONFIG_DEBUG_TIMEKEEPING is not set
    # CONFIG_DEBUG_PREEMPT is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    CONFIG_LOCK_DEBUGGING_SUPPORT=y
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_RWSEMS is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_LOCK_TORTURE_TEST is not set
    # CONFIG_WW_MUTEX_SELFTEST is not set
    # CONFIG_SCF_TORTURE_TEST is not set
    # CONFIG_CSD_LOCK_WAIT_DEBUG is not set
    # end of Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_DEBUG_IRQFLAGS is not set
    CONFIG_STACKTRACE=y
    # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # Debug kernel data structures
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_PLIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_BUG_ON_DATA_CORRUPTION is not set
    # CONFIG_DEBUG_MAPLE_TREE is not set
    # end of Debug kernel data structures
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_RCU_SCALE_TEST is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_REF_SCALE_TEST is not set
    CONFIG_RCU_CPU_STALL_TIMEOUT=21
    CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0
    CONFIG_RCU_TRACE=y
    # CONFIG_RCU_EQS_DEBUG is not set
    # end of RCU Debugging
    # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
    # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
    # CONFIG_LATENCYTOP is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACE_CLOCK=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    CONFIG_SAMPLES=y
    # CONFIG_SAMPLE_AUXDISPLAY is not set
    # CONFIG_SAMPLE_KOBJECT is not set
    # CONFIG_SAMPLE_HW_BREAKPOINT is not set
    # CONFIG_SAMPLE_KFIFO is not set
    CONFIG_SAMPLE_RPMSG_CLIENT=m
    # CONFIG_SAMPLE_CONFIGFS is not set
    # CONFIG_SAMPLE_VFIO_MDEV_MDPY_FB is not set
    # CONFIG_SAMPLE_WATCHDOG is not set
    # CONFIG_SAMPLE_CORESIGHT_SYSCFG is not set
    CONFIG_STRICT_DEVMEM=y
    # CONFIG_IO_STRICT_DEVMEM is not set
    # arm64 Debugging
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # CONFIG_DEBUG_EFI is not set
    # CONFIG_ARM64_RELOC_TEST is not set
    CONFIG_CORESIGHT=m
    CONFIG_CORESIGHT_LINKS_AND_SINKS=m
    CONFIG_CORESIGHT_LINK_AND_SINK_TMC=m
    CONFIG_CORESIGHT_CATU=m
    CONFIG_CORESIGHT_SINK_TPIU=m
    CONFIG_CORESIGHT_SINK_ETBV10=m
    # CONFIG_CORESIGHT_SOURCE_ETM4X is not set
    CONFIG_CORESIGHT_STM=m
    CONFIG_CORESIGHT_CPU_DEBUG=m
    # CONFIG_CORESIGHT_CPU_DEBUG_DEFAULT_ON is not set
    CONFIG_CORESIGHT_CTI=m
    # CONFIG_CORESIGHT_CTI_INTEGRATION_REGS is not set
    # end of arm64 Debugging
    # Kernel Testing and Coverage
    # CONFIG_KUNIT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    CONFIG_ARCH_HAS_KCOV=y
    CONFIG_CC_HAS_SANCOV_TRACE_PC=y
    # CONFIG_KCOV is not set
    CONFIG_RUNTIME_TESTING_MENU=y
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_MIN_HEAP is not set
    # CONFIG_TEST_DIV64 is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_TEST_REF_TRACKER is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_REED_SOLOMON_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_PERCPU_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_HEXDUMP is not set
    # CONFIG_STRING_SELFTEST is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_STRSCPY is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_TEST_PRINTF is not set
    # CONFIG_TEST_SCANF is not set
    # CONFIG_TEST_BITMAP is not set
    # CONFIG_TEST_UUID is not set
    # CONFIG_TEST_XARRAY is not set
    # CONFIG_TEST_MAPLE_TREE is not set
    # CONFIG_TEST_RHASHTABLE is not set
    # CONFIG_TEST_SIPHASH is not set
    # CONFIG_TEST_IDA is not set
    # CONFIG_TEST_LKM is not set
    # CONFIG_TEST_BITOPS is not set
    # CONFIG_TEST_VMALLOC is not set
    # CONFIG_TEST_USER_COPY is not set
    # CONFIG_TEST_BPF is not set
    # CONFIG_TEST_BLACKHOLE_DEV is not set
    # CONFIG_FIND_BIT_BENCHMARK is not set
    # CONFIG_TEST_FIRMWARE is not set
    # CONFIG_TEST_SYSCTL is not set
    # CONFIG_TEST_UDELAY is not set
    # CONFIG_TEST_STATIC_KEYS is not set
    # CONFIG_TEST_DYNAMIC_DEBUG is not set
    # CONFIG_TEST_KMOD is not set
    # CONFIG_TEST_MEMCAT_P is not set
    # CONFIG_TEST_MEMINIT is not set
    # CONFIG_TEST_FREE_PAGES is not set
    CONFIG_ARCH_USE_MEMTEST=y
    CONFIG_MEMTEST=y
    # end of Kernel Testing and Coverage
    # Rust hacking
    # end of Rust hacking
    # end of Kernel hacking
    I am routing your query to our McSPI expert for comments.
