Hello TI Experts,
I'll like to know, is it advisable to put test points on lpddr4 lines for debugging purposes?
Expecting your response. Thank you.
Paul.
Typically customer work with the memory vendors to install interposers between the memory and the board. This can give you access to the signals that do not have test points. Clock and reset do have resistors/caps connected, so you can tap into those probe points. You can also typically access the embedded signals by locating associated vias on the board.
James
