Other Parts Discussed in Thread: AMIC120
Hi TI Support Team,
I would like to confirm the proper handling of the WARMRSTn pin on the AM4378 MPU when it is not used in the design.
Thank you for your assistance.
Conor
Hello Conor,
Thank you for the query
Refer below section of the checklist
https://www.ti.com/lit/an/sprace0a/sprace0a.pdf
2.2.4 Warm Reset
• The WARMRSTn pin (nRESETIN_OUT signal) is an open-drain signal and requires an external pullup.
• If you are using nRESETIN_OUT as a bi-directional reset signal with a push-button, you may need a debounce circuit. Sometimes this is omitted in cases where the button is strictly for development purposes.
• nRESETIN_OUT is undefined during supply ramp. If your external devices require reset to be actively driven low during the entire power-up/down sequence, you can implement a circuit as shown in the External Buffer for nRESETIN_OUT figure in the AM437x and AMIC120 ARM® Cortex-A9 processors technical reference manual.
Sreenivasa
