Hi
We are currently migrating from SDK 9.2 to 10.1. First problem we are currently seeing is that the SERDES, CPSW9G and PCIe configuration is somehow broken.
If we connect the interfaces we see for some of them that unexpected interfaces receives link up/down.
Also the interfaces are not really sending any data to the line.
We see the following errors / warnings:
$ dmesg --level err [ 0.216096] mux muxchip0: unable to set idle state [ 0.301939] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19 [ 0.302040] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19 [ 0.302181] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19 [ 1.426716] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22 [ 1.657589] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22 [ 2.662996] pcieport 0002:00:00.0: of_irq_parse_pci: failed with rc=-22 [ 2.892869] pcieport 0003:00:00.0: of_irq_parse_pci: failed with rc=-22 $ dmesg --level warn [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.192978] SPI driver spidev has no spi_device_id for rohm,bh2228fv [ 0.216100] mmio-mux: probe of 104080.mux-controller failed with error -5 [ 0.419937] cdns-torrent-phy: probe of 5020000.serdes failed with error -22 [ 1.424255] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.654006] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.660583] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.889686] pci_bus 0003:00: 2-byte config write to 0003:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 3.246298] systemd[1]: MachineID 'uninitialized' is not valid, ignoring: Invalid argument
The relevant parts of our device tree are:
&serdes0 {
status = "okay";
serdes0_pcie1_link: phy@0 {
reg = <0>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz0 1>;
serdes0_pcie3_link: phy@2 {
reg = <2>;
#phy-cells = <0>;
resets = <&serdes_wiz0 3>;
&serdes_wiz0 {
status = "okay";
&serdes1 {
status = "okay";
serdes1_pcie0_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz1 1>;
serdes1_pcie2_link: phy@2 {
reg = <2>;
#phy-cells = <0>;
resets = <&serdes_wiz1 3>;
&serdes_wiz1 {
status = "okay";
&serdes2 {
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
serdes2_sgmii_link1: phy@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_SGMII>;
resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
serdes2_qsgmii_link: phy@2 {
reg = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_QSGMII>;
resets = <&serdes_wiz2 3>;
serdes2_sgmii_link2: phy@3 {
reg = <3>;
#phy-cells = <0>;
resets = <&serdes_wiz2 4>;
&serdes_wiz2 {
status = "okay";
&serdes4 {
status = "okay";
serdes4_sgmii_link: phy@2 {
reg = <2>;
#phy-cells = <0>;
resets = <&serdes_wiz4 3>;
serdes4_usb_link: phy@3 {
reg = <3>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_USB3>;
resets = <&serdes_wiz4 4>;
&serdes_wiz4 {
status = "okay";
/* refer to include/dt-bindings/mux/ti-serdes.h */
&serdes_ln_ctrl {
mux-reg-masks = <0x00 0x3>, <0x04 0x3>, /* SERDES0 lane0/1 select */
<0x08 0x3>, <0x0c 0x3>, /* SERDES0 lane2/3 select */
<0x10 0x3>, <0x14 0x3>, /* SERDES1 lane0/1 select */
<0x18 0x3>, <0x1c 0x3>, /* SERDES1 lane2/3 select */
<0x20 0x3>, <0x24 0x3>, /* SERDES2 lane0/1 select */
<0x28 0x3>, <0x2c 0x3>, /* SERDES2 lane2/3 select */
<0x40 0x3>, <0x44 0x3>, /* SERDES4 lane0/1 select */
<0x48 0x3>, <0x4c 0x3>; /* SERDES4 lane2/3 select */
idle-states = <J784S4_SERDES0_LANE0_PCIE1_LANE0>, /* PCIe1 */
<J784S4_SERDES0_LANE1_IP4_UNUSED>,
<J784S4_SERDES0_LANE2_PCIE3_LANE0>, /* PCIe3 */
<J784S4_SERDES0_LANE3_IP4_UNUSED>,
<J784S4_SERDES1_LANE0_PCIE0_LANE0>, /* PCIe0 */
<J784S4_SERDES1_LANE1_IP4_UNUSED>,
<J784S4_SERDES1_LANE2_PCIE2_LANE0>, /* PCIe2 */
<J784S4_SERDES1_LANE3_IP4_UNUSED>,
<J784S4_SERDES2_LANE0_QSGMII_LANE5>, /* SGMII: RTL8211 */
<J784S4_SERDES2_LANE1_QSGMII_LANE6>, /* SGMII: RTL8211 */
<J784S4_SERDES2_LANE2_QSGMII_LANE1>, /* QSGMII: YT8614 */
<J784S4_SERDES2_LANE3_QSGMII_LANE8>, /* SGMII: RTL8211 */
<J784S4_SERDES4_LANE0_IP3_UNUSED>,
<J784S4_SERDES4_LANE1_IP3_UNUSED>,
<J784S4_SERDES4_LANE2_QSGMII_LANE7>, /* SGMII: RTL8211 */
<J784S4_SERDES4_LANE3_USB>; /* USB */
&serdes_refclk {
clock-frequency = <100000000>;
&main_gpio0 {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&pcie_reset_pins_default>,
<&network_pins_default>,
<&board_id_eeprom_wp_pins_default>,
<&pwr_mgmt_pins_main_default>,
<&sleep_led_pins_default>;
gpio-line-names = MAIN_GPIO0_LINE_NAMES;
&wkup_gpio0 {
status = "okay";
pinctrl-0 = <&mcu_adc0_sel_on_pins_default>,
<&wkup_gpio_0_vddshv2_mcu_pins_default>,
<&pwr_mgmt_pins_wkup_default>;
gpio-line-names = WKUP_GPIO0_LINE_NAMES;
&pcie0_rc {
status = "okay";
num-lanes = <1>;
phys = <&serdes1_pcie0_link>;
phy-names = "pcie-phy";
&pcie1_rc {
status = "okay";
num-lanes = <1>;
phys = <&serdes0_pcie1_link>;
&pcie2_rc {
status = "okay";
num-lanes = <1>;
phys = <&serdes1_pcie2_link>;
&pcie3_rc {
status = "okay";
num-lanes = <1>;
phys = <&serdes0_pcie3_link>;
&cpsw0_phy_gmii_sel {
ti,qsgmii-main-ports = <1>, <1>;
&main_cpsw0 {
status = "okay";
&main_cpsw0_port1 {
status = "okay";
phy-handle = <&cpsw9g_eexb_tp>;
phy-mode = "qsgmii";
local-mac-address = [02 60 C8 00 00 00];
phys = <&cpsw0_phy_gmii_sel 1>;
phy-names = "mac";
&main_cpsw0_port2 {
status = "okay";
phy-handle = <&cpsw9g_ksi>;
local-mac-address = [02 60 C8 00 00 01];
phys = <&cpsw0_phy_gmii_sel 2>;
phy-names = "mac";
&main_cpsw0_port3 {
status = "okay";
phy-handle = <&cpsw9g_tp>;
local-mac-address = [02 60 C8 00 00 02];
phys = <&cpsw0_phy_gmii_sel 3>;
phy-names = "mac";
&main_cpsw0_port4 {
status = "okay";
phy-handle = <&cpsw9g_diob>;
local-mac-address = [02 60 C8 00 00 03];
phys = <&cpsw0_phy_gmii_sel 4>;
phy-names = "mac";
&main_cpsw0_port5 {
status = "okay";
phy-handle = <&cpsw9g_koni>;
phy-mode = "sgmii";
local-mac-address = [02 60 C8 00 00 04];
phys = <&cpsw0_phy_gmii_sel 5>;
phy-names = "mac";
&main_cpsw0_port6 {
status = "okay";
phy-handle = <&cpsw9g_kli_ot>;
phy-mode = "sgmii";
local-mac-address = [02 60 C8 00 00 05];
phys = <&cpsw0_phy_gmii_sel 6>;
phy-names = "mac";
&main_cpsw0_port7 {
status = "okay";
phy-handle = <&cpsw9g_profinet4>;
phy-mode = "sgmii";
local-mac-address = [02 60 C8 00 00 06];
phys = <&cpsw0_phy_gmii_sel 7>;
phy-names = "mac";
&main_cpsw0_port8 {
status = "okay";
phy-handle = <&cpsw9g_profinet3>;
phy-mode = "sgmii";
local-mac-address = [02 60 C8 00 00 07];
phys = <&cpsw0_phy_gmii_sel 8>;
phy-names = "mac";
&main_cpsw0_mdio {
status = "okay";
pinctrl-0 = <&main_cpsw9g_mdio_pins_default>;
bus_freq = <1000000>;
reset-gpios = <&main_gpio0 10 GPIO_ACTIVE_LOW>;
reset-post-delay-us = <120000>;
#size-cells = <0>;
cpsw9g_koni: ethernet-phy@1 {
reg = <1>;
cpsw9g_kli_ot: ethernet-phy@2 {
reg = <2>;
cpsw9g_profinet4: ethernet-phy@3 {
reg = <3>;
cpsw9g_profinet3: ethernet-phy@4 {
reg = <4>;
cpsw9g_eexb_tp: ethernet-phy@8 {
reg = <8>;
cpsw9g_ksi: ethernet-phy@9 {
reg = <9>;
cpsw9g_tp: ethernet-phy@10 {
reg = <10>;
cpsw9g_diob: ethernet-phy@11 {
reg = <11>;
&usb_serdes_mux {
idle-states = <1>; /* USB0 to SERDES4 lane 3 */
&usbss0 {
status = "okay";
pinctrl-0 = <&main_usbss0_pins_default>;
ti,vbus-divider;
&usb0 {
status = "okay";
dr_mode = "host";
maximum-speed = "super-speed";
phys = <&serdes4_usb_link>;
phy-names = "cdns3,usb3-phy";
The SERDES configuration has been ported like this:
Adding SERDES4 here seems to cause the error "mux muxchip0: unable to set idle state".
Is there anything else we need to adjust?
Just let me know if you need any further information.
Daniel
