Other Parts Discussed in Thread: AM5718
Our usb host die, I want to check register. However, usb register manual does't exit in AM5716 TRM doc.
Can you share it to me? Thanks!
zmg, Zekun,
Can you share any more information about this failure? Historically I can assume a custom board and you are using linux correct?
Extra information about the USB can only be obtained under NDA so we can resolve that over email.
See:
What registers is the customer looking for? Does this chapter not have what they need?
26.3 USB3 PHY and SATA PHY Register Manual
-Josue
Hi Josue:
I am zmg's colleague. Yes, we are using a custom board and linux. We use usb,connectting to a mcu board which is used as usb device. AM5716 sends firmware to mcu board through usb host, mcu upgrades firmware and reboot. While mcu rebooting, AM5716 USB host detects disconnection. After rebooting, usb host detects connection, 5716 sends firmware again. We test this loop several 400+ times. At last, the usb host die. The log is as follows:
usb 3-1: USB disconnect, device number 77
2025-02-25 20:25:47 SunGrow user.info sg_klogd: [10391.172160] usb 3-1: new full-speed USB device number 78 using xhci-hcd
2025-02-25 20:25:48 SunGrow user.info sg_klogd: [10391.307264] usb 3-1: New USB device found, idVendor=28e9, idProduct=018a, bcdDevice= 1.00
2025-02-25 20:25:48 SunGrow user.info sg_klogd: [10391.322100] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2025-02-25 20:25:48 SunGrow user.info sg_klogd: [10391.331526] usb 3-1: Product: GD32-CDC_ACM
2025-02-25 20:25:48 SunGrow user.info sg_klogd: [10391.336181] usb 3-1: Manufacturer: GigaDevice
2025-02-25 20:25:48 SunGrow user.info sg_klogd: [10391.340874] usb 3-1: SerialNumber: 7A8D59810932
2025-02-25 20:25:48 SunGrow user.info sg_klogd: [10391.374718] cdc_acm 3-1:1.0: ttyACM1: USB ACM device
2025-02-25 20:27:40 SunGrow user.info sg_klogd: [10503.628845] usb 3-1: USB disconnect, device number 78
2025-02-25 20:27:45 SunGrow user.warn sg_klogd: [10508.780159] xhci-hcd xhci-hcd.1.auto: xHCI host not responding to stop endpoint command.
2025-02-25 20:27:45 SunGrow user.err sg_klogd: [10508.803460] xhci-hcd xhci-hcd.1.auto: xHCI host controller not responding, assume dead
2025-02-25 20:27:45 SunGrow user.err sg_klogd: [10508.811508] xhci-hcd xhci-hcd.1.auto: HC died; cleaning up
We have to repower am5716 board to recover usb function. I dump registers
root@SunGrow:/sys/kernel/debug/488d0000.usb# cat regdump
GSBUSCFG0 = 0x0000000e
GSBUSCFG1 = 0x00000f00
GTXTHRCFG = 0x00000000
GRXTHRCFG = 0x00000000
GCTL = 0x25801000
GEVTEN = 0x00000000
GSTS = 0x3e800002
GUCTL1 = 0x00000000
GSNPSID = 0x5533202a
GGPIO = 0x00000000
GUID = 0x0004135e
GUCTL = 0x0000c010
GBUSERRADDR0 = 0x00000000
GBUSERRADDR1 = 0x00000000
GPRTBIMAP0 = 0x00000000
GPRTBIMAP1 = 0x00000000
GHWPARAMS0 = 0x202040ca
GHWPARAMS1 = 0x01c0c93b
GHWPARAMS2 = 0x00000000
GHWPARAMS3 = 0x1042008d
GHWPARAMS4 = 0x48822004
GHWPARAMS5 = 0x04202088
GHWPARAMS6 = 0x0b000c20
GHWPARAMS7 = 0x03080780
GDBGFIFOSPACE = 0x00820000
GDBGLTSSM = 0x01514c42
GDBGBMU = 0x20a00000
GDBGLSPMUX = 0x00000000
GDBGLSP = 0x00402041
GDBGEPINFO0 = 0x00000000
GDBGEPINFO1 = 0x00800000
GPRTBIMAP_HS0 = 0x00000000
GPRTBIMAP_HS1 = 0x00000000
GPRTBIMAP_FS0 = 0x00000000
GPRTBIMAP_FS1 = 0x00000000
GUSB2PHYCFG(0) = 0x00002500
GUSB2PHYCFG(1) = 0x00000000
GUSB2PHYCFG(2) = 0x00000000
GUSB2PHYCFG(3) = 0x00000000
GUSB2PHYCFG(4) = 0x00000000
GUSB2PHYCFG(5) = 0x00000000
GUSB2PHYCFG(6) = 0x00000000
GUSB2PHYCFG(7) = 0x00000000
GUSB2PHYCFG(8) = 0x00000000
GUSB2PHYCFG(9) = 0x00000000
GUSB2PHYCFG(10) = 0x00000000
GUSB2PHYCFG(11) = 0x00000000
GUSB2PHYCFG(12) = 0x00000000
GUSB2PHYCFG(13) = 0x00000000
GUSB2PHYCFG(14) = 0x00000000
GUSB2PHYCFG(15) = 0x00000000
GUSB2I2CCTL(0) = 0x00000000
GUSB2I2CCTL(1) = 0x00000000
GUSB2I2CCTL(2) = 0x00000000
GUSB2I2CCTL(3) = 0x00000000
GUSB2I2CCTL(4) = 0x00000000
GUSB2I2CCTL(5) = 0x00000000
GUSB2I2CCTL(6) = 0x00000000
GUSB2I2CCTL(7) = 0x00000000
GUSB2I2CCTL(8) = 0x00000000
GUSB2I2CCTL(9) = 0x00000000
GUSB2I2CCTL(10) = 0x00000000
GUSB2I2CCTL(11) = 0x00000000
GUSB2I2CCTL(12) = 0x00000000
GUSB2I2CCTL(13) = 0x00000000
GUSB2I2CCTL(14) = 0x00000000
GUSB2I2CCTL(15) = 0x00000000
GUSB2PHYACC(0) = 0x00000000
GUSB2PHYACC(1) = 0x00000000
GUSB2PHYACC(2) = 0x00000000
GUSB2PHYACC(3) = 0x00000000
GUSB2PHYACC(4) = 0x00000000
GUSB2PHYACC(5) = 0x00000000
GUSB2PHYACC(6) = 0x00000000
GUSB2PHYACC(7) = 0x00000000
GUSB2PHYACC(8) = 0x00000000
GUSB2PHYACC(9) = 0x00000000
GUSB2PHYACC(10) = 0x00000000
GUSB2PHYACC(11) = 0x00000000
GUSB2PHYACC(12) = 0x00000000
GUSB2PHYACC(13) = 0x00000000
GUSB2PHYACC(14) = 0x00000000
GUSB2PHYACC(15) = 0x00000000
GUSB3PIPECTL(0) = 0x00040002
GUSB3PIPECTL(1) = 0x00000000
GUSB3PIPECTL(2) = 0x00000000
GUSB3PIPECTL(3) = 0x00000000
GUSB3PIPECTL(4) = 0x00000000
GUSB3PIPECTL(5) = 0x00000000
GUSB3PIPECTL(6) = 0x00000000
GUSB3PIPECTL(7) = 0x00000000
GUSB3PIPECTL(8) = 0x00000000
GUSB3PIPECTL(9) = 0x00000000
GUSB3PIPECTL(10) = 0x00000000
GUSB3PIPECTL(11) = 0x00000000
GUSB3PIPECTL(12) = 0x00000000
GUSB3PIPECTL(13) = 0x00000000
GUSB3PIPECTL(14) = 0x00000000
GUSB3PIPECTL(15) = 0x00000000
GTXFIFOSIZ(0) = 0x00000082
GTXFIFOSIZ(1) = 0x00820103
GTXFIFOSIZ(2) = 0x01850205
GTXFIFOSIZ(3) = 0x038a0000
GTXFIFOSIZ(4) = 0x038a0000
GTXFIFOSIZ(5) = 0x038a0000
GTXFIFOSIZ(6) = 0x038a0000
GTXFIFOSIZ(7) = 0x038a0000
GTXFIFOSIZ(8) = 0x038a0000
GTXFIFOSIZ(9) = 0x038a0000
GTXFIFOSIZ(10) = 0x038a0000
GTXFIFOSIZ(11) = 0x038a0000
GTXFIFOSIZ(12) = 0x038a0000
GTXFIFOSIZ(13) = 0x038a0000
GTXFIFOSIZ(14) = 0x038a0000
GTXFIFOSIZ(15) = 0x038a0000
GTXFIFOSIZ(16) = 0x00000000
GTXFIFOSIZ(17) = 0x00000000
GTXFIFOSIZ(18) = 0x00000000
GTXFIFOSIZ(19) = 0x00000000
GTXFIFOSIZ(20) = 0x00000000
GTXFIFOSIZ(21) = 0x00000000
GTXFIFOSIZ(22) = 0x00000000
GTXFIFOSIZ(23) = 0x00000000
GTXFIFOSIZ(24) = 0x00000000
GTXFIFOSIZ(25) = 0x00000000
GTXFIFOSIZ(26) = 0x00000000
GTXFIFOSIZ(27) = 0x00000000
GTXFIFOSIZ(28) = 0x00000000
GTXFIFOSIZ(29) = 0x00000000
GTXFIFOSIZ(30) = 0x00000000
GTXFIFOSIZ(31) = 0x00000000
GRXFIFOSIZ(0) = 0x071e0084
GRXFIFOSIZ(1) = 0x07a20104
GRXFIFOSIZ(2) = 0x08a60180
GRXFIFOSIZ(3) = 0x00000000
GRXFIFOSIZ(4) = 0x00000000
GRXFIFOSIZ(5) = 0x00000000
GRXFIFOSIZ(6) = 0x00000000
GRXFIFOSIZ(7) = 0x00000000
GRXFIFOSIZ(8) = 0x00000000
GRXFIFOSIZ(9) = 0x00000000
GRXFIFOSIZ(10) = 0x00000000
GRXFIFOSIZ(11) = 0x00000000
GRXFIFOSIZ(12) = 0x00000000
GRXFIFOSIZ(13) = 0x00000000
GRXFIFOSIZ(14) = 0x00000000
GRXFIFOSIZ(15) = 0x00000000
GRXFIFOSIZ(16) = 0x00000000
GRXFIFOSIZ(17) = 0x00000000
GRXFIFOSIZ(18) = 0x00000000
GRXFIFOSIZ(19) = 0x00000000
GRXFIFOSIZ(20) = 0x00000000
GRXFIFOSIZ(21) = 0x00000000
GRXFIFOSIZ(22) = 0x00000000
GRXFIFOSIZ(23) = 0x00000000
GRXFIFOSIZ(24) = 0x00000000
GRXFIFOSIZ(25) = 0x00000000
GRXFIFOSIZ(26) = 0x00000000
GRXFIFOSIZ(27) = 0x00000000
GRXFIFOSIZ(28) = 0x00000000
GRXFIFOSIZ(29) = 0x00000000
GRXFIFOSIZ(30) = 0x00000000
GRXFIFOSIZ(31) = 0x00000000
GEVNTADRLO(0) = 0x00000000
GEVNTADRHI(0) = 0x00000000
GEVNTSIZ(0) = 0x00000000
GEVNTCOUNT(0) = 0x00000000
GHWPARAMS8 = 0x0000071e
DCFG = 0x00080800
DCTL = 0x00000000
DEVTEN = 0x00000000
DSTS = 0x00520001
DGCMDPAR = 0x00000000
DGCMD = 0x00000000
DALEPENA = 0x00000000
DEPCMDPAR2(0) = 0x00000000
DEPCMDPAR1(0) = 0x00000002
DEPCMDPAR0(0) = 0xbe471001
DEPCMD(0) = 0x00000000
DEPCMDPAR2(1) = 0x00000000
DEPCMDPAR1(1) = 0x00000000
DEPCMDPAR0(1) = 0x00000000
DEPCMD(1) = 0x00000000
DEPCMDPAR2(2) = 0xbe470000
DEPCMDPAR1(2) = 0x00000000
DEPCMDPAR0(2) = 0x00000040
DEPCMD(2) = 0x00000000
DEPCMDPAR2(3) = 0x00000000
DEPCMDPAR1(3) = 0x00000000
DEPCMDPAR0(3) = 0x00000000
DEPCMD(3) = 0x00000000
DEPCMDPAR2(4) = 0xbe474000
DEPCMDPAR1(4) = 0x00000000
DEPCMDPAR0(4) = 0xbe473bc8
DEPCMD(4) = 0x00000000
DEPCMDPAR2(5) = 0x00000000
DEPCMDPAR1(5) = 0x00000020
DEPCMDPAR0(5) = 0x00000000
DEPCMD(5) = 0x00000000
DEPCMDPAR2(6) = 0x00000000
DEPCMDPAR1(6) = 0x00000000
DEPCMDPAR0(6) = 0x00000000
DEPCMD(6) = 0x00000000
DEPCMDPAR2(7) = 0x00000000
DEPCMDPAR1(7) = 0x00000000
DEPCMDPAR0(7) = 0x00000000
DEPCMD(7) = 0x00000000
DEPCMDPAR2(8) = 0x00000000
DEPCMDPAR1(8) = 0x00000000
DEPCMDPAR0(8) = 0x00000000
DEPCMD(8) = 0x00000000
DEPCMDPAR2(9) = 0x00000000
DEPCMDPAR1(9) = 0x00000000
DEPCMDPAR0(9) = 0x00000000
DEPCMD(9) = 0x00000000
DEPCMDPAR2(10) = 0x00000000
DEPCMDPAR1(10) = 0x00000000
DEPCMDPAR0(10) = 0x00000000
DEPCMD(10) = 0x00000000
DEPCMDPAR2(11) = 0x00000000
DEPCMDPAR1(11) = 0x00000000
DEPCMDPAR0(11) = 0x00000000
DEPCMD(11) = 0x00000000
DEPCMDPAR2(12) = 0x00000000
DEPCMDPAR1(12) = 0x00000000
DEPCMDPAR0(12) = 0x00000000
DEPCMD(12) = 0x00000000
DEPCMDPAR2(13) = 0x00000000
DEPCMDPAR1(13) = 0x00000000
DEPCMDPAR0(13) = 0x00000000
DEPCMD(13) = 0x00000000
DEPCMDPAR2(14) = 0x00000000
DEPCMDPAR1(14) = 0x00000000
DEPCMDPAR0(14) = 0x00000000
DEPCMD(14) = 0x00000000
DEPCMDPAR2(15) = 0x00000000
DEPCMDPAR1(15) = 0x00000000
DEPCMDPAR0(15) = 0x00000000
DEPCMD(15) = 0x00000000
DEPCMDPAR2(16) = 0x00000000
DEPCMDPAR1(16) = 0x00000000
DEPCMDPAR0(16) = 0x00000000
DEPCMD(16) = 0x00000000
DEPCMDPAR2(17) = 0x00000000
DEPCMDPAR1(17) = 0x00000000
DEPCMDPAR0(17) = 0x00000000
DEPCMD(17) = 0x00000000
DEPCMDPAR2(18) = 0x00000000
DEPCMDPAR1(18) = 0x00000000
DEPCMDPAR0(18) = 0x00000000
DEPCMD(18) = 0x00000000
DEPCMDPAR2(19) = 0x00000000
DEPCMDPAR1(19) = 0x00000000
DEPCMDPAR0(19) = 0x00000000
DEPCMD(19) = 0x00000000
DEPCMDPAR2(20) = 0x00000000
DEPCMDPAR1(20) = 0x00000000
DEPCMDPAR0(20) = 0x00000000
DEPCMD(20) = 0x00000000
DEPCMDPAR2(21) = 0x00000000
DEPCMDPAR1(21) = 0x00000000
DEPCMDPAR0(21) = 0x00000000
DEPCMD(21) = 0x00000000
DEPCMDPAR2(22) = 0x00000000
DEPCMDPAR1(22) = 0x00000000
DEPCMDPAR0(22) = 0x00511010
DEPCMD(22) = 0x00000000
DEPCMDPAR2(23) = 0x00000000
DEPCMDPAR1(23) = 0x00000000
DEPCMDPAR0(23) = 0x00000000
DEPCMD(23) = 0x00000000
DEPCMDPAR2(24) = 0x00000000
DEPCMDPAR1(24) = 0x00000000
DEPCMDPAR0(24) = 0x00000000
DEPCMD(24) = 0x00000000
DEPCMDPAR2(25) = 0x00000000
DEPCMDPAR1(25) = 0x00000000
DEPCMDPAR0(25) = 0x00000000
DEPCMD(25) = 0x00000000
DEPCMDPAR2(26) = 0x00000000
DEPCMDPAR1(26) = 0x00000000
DEPCMDPAR0(26) = 0x00000000
DEPCMD(26) = 0x00000000
DEPCMDPAR2(27) = 0x00000000
DEPCMDPAR1(27) = 0x00000000
DEPCMDPAR0(27) = 0x00000000
DEPCMD(27) = 0x00000000
DEPCMDPAR2(28) = 0x00000000
DEPCMDPAR1(28) = 0x00000000
DEPCMDPAR0(28) = 0x00000000
DEPCMD(28) = 0x00000000
DEPCMDPAR2(29) = 0x00000000
DEPCMDPAR1(29) = 0x00000000
DEPCMDPAR0(29) = 0x00000000
DEPCMD(29) = 0x00000000
DEPCMDPAR2(30) = 0x00000000
DEPCMDPAR1(30) = 0x00000000
DEPCMDPAR0(30) = 0x00000000
DEPCMD(30) = 0x00000000
DEPCMDPAR2(31) = 0x00000000
DEPCMDPAR1(31) = 0x00000000
DEPCMDPAR0(31) = 0x00000000
DEPCMD(31) = 0x00000000
OCFG = 0x00000000
OCTL = 0x00000040
OEVT = 0x00000000
OEVTEN = 0x00000000
OSTS = 0x00000008
Could you help to analyse this failure?Thank you!
Hello Liying,
I am out of office in a business trip. I will return next week, Please expect delays.
-Josue
Hi Josue
From customer's feedback, they use AM57 as USB host and do the pressure test with external MCU.
Could you help to analyze the possible reason of this phenomenon?
Zekun
Hi Ying
Could you elaborate the test procedure of this?
Like how long does it takes to boot the MCU? How to control the MCU reboot?
Zekun
Hello Zekun,
I will have to confer internally. Please expect a 1-2 day delay in response.
-Josue
Ying,
After internal discussion, it appears that there are certain USB compliance timings for discharging and charging of V-BUS.
Can you please share the following
What kind of connection is it? USB A, C?
Can you share schematics of this subsystem?
What SDK version is being used?
-Josue
AM5716 doesn't control MCU reboot. When MCU receives firwmare from 5716, it reboots and upgrade self.
This needs about 6 seconds,while the usb pins may be float.
AM5716 connects to MCU only through USB D+、D-, no V-BUS, the PCB is as follows,
the connection is pin to pin, not USB A or C?
SDK version is ti-processor-sdk-linux-am57xx-evm-06.03.00.106
Liying,
Can you please elaborate with how the MCU and the AM5716 are connected? Am I understanding correctly that they are "Hardwired"?
As my USB engineer colleague explained via email:
"One of the aspect which was discussed is that if this type of stress test is a valid use case? Power-on / power-off hundreds of time would cause the Vbus charge / discharge cycles through the connectors.
The connectors are also rated for certain number of connect/disconnect cycles – and those connectors must also be USB certified which in many cases are not. "
-Josue
Liying
Based on some internal discussions with our USB engineers, it appears that this USB scenario does not comply with USB specification. The USB specification requires the USB device DP/DM lines should be powered and in a known state before attached to the USB host. But in this use case, the MCU USB DP/DM lines may be float during its reboot, this could confuse the USB host. Since it doesn't seems be a valid USB use case, it is out of our support scope.
Josue
Hello Josue
is there any demo to show to our customer for reference in TI EVM?
Semon
Semon,
Define demo? The way we showcase USB host is available in the EVMs.
AM572x evm exerpt:
I am working internally to set up an experiment to simulate attach/detach behavior stress test using a USB exerciser.
I will update with results.
-Best
Josue
Semon,
Liying,
Ran a test overnight testing the USB host on AM5718 IDK.
Setup:
Procedure:
See picture above for pictographic details.
Set the MCCI Cricket UI in loop mode to connect/disconnect every 8000 ms (8 seconds) with a 50% duty cycle. This effectively made a connection/disconnection every 4 seconds for 800 cycles.
Results:
MCCI Cricket UI Logs:
[2025-03-20 21:37:22.156] Loop Mode start : ON-Time = 4000 ms, OFF-Time = 4000 ms, Cycle = 800 [2025-03-20 21:37:22.156] Port ON [2025-03-20 21:37:26.167] Port OFF [2025-03-20 21:37:30.176] Port ON [2025-03-20 21:37:34.173] Port OFF [2025-03-20 21:37:38.168] Port ON [2025-03-20 21:37:42.190] Port OFF [2025-03-20 21:37:46.194] Port ON [2025-03-20 21:37:50.193] Port OFF [2025-03-20 21:37:54.187] Port ON [2025-03-20 21:37:58.193] Port OFF [2025-03-20 21:38:02.195] Port ON [2025-03-20 21:38:06.192] Port OFF [2025-03-20 21:38:10.208] Port ON [2025-03-20 21:38:14.209] Port OFF [2025-03-20 21:38:18.217] Port ON [2025-03-20 21:38:22.214] Port OFF [2025-03-20 21:38:26.230] Port ON [2025-03-20 21:38:30.232] Port OFF [2025-03-20 21:38:34.231] Port ON [2025-03-20 21:38:38.230] Port OFF [2025-03-20 21:38:42.237] Port ON [2025-03-20 21:38:46.235] Port OFF [2025-03-20 21:38:50.253] Port ON [2025-03-20 21:38:54.250] Port OFF [2025-03-20 21:38:58.255] Port ON [2025-03-20 21:39:02.260] Port OFF [2025-03-20 21:39:06.268] Port ON [2025-03-20 21:39:10.269] Port OFF [2025-03-20 21:39:14.278] Port ON [2025-03-20 21:39:18.293] Port OFF [2025-03-20 21:39:22.303] Port ON [2025-03-20 21:39:26.307] Port OFF [2025-03-20 21:39:30.316] Port ON [2025-03-20 21:39:34.318] Port OFF [2025-03-20 21:39:38.337] Port ON [2025-03-20 21:39:42.346] Port OFF [2025-03-20 21:39:46.346] Port ON [2025-03-20 21:39:50.345] Port OFF [2025-03-20 21:39:54.363] Port ON [2025-03-20 21:39:58.361] Port OFF [2025-03-20 21:40:02.380] Port ON [2025-03-20 21:40:06.398] Port OFF [2025-03-20 21:40:10.414] Port ON [2025-03-20 21:40:14.429] Port OFF [2025-03-20 21:40:18.460] Port ON [2025-03-20 21:40:22.470] Port OFF [2025-03-20 21:40:26.475] Port ON [2025-03-20 21:40:30.494] Port OFF [2025-03-20 21:40:34.510] Port ON [2025-03-20 21:40:38.514] Port OFF [2025-03-20 21:40:42.523] Port ON [2025-03-20 21:40:46.520] Port OFF [2025-03-20 21:40:50.512] Port ON [2025-03-20 21:40:54.520] Port OFF [2025-03-20 21:40:58.538] Port ON [2025-03-20 21:41:02.528] Port OFF [2025-03-20 21:41:06.542] Port ON [2025-03-20 21:41:10.556] Port OFF [2025-03-20 21:41:14.580] Port ON [2025-03-20 21:41:18.581] Port OFF [2025-03-20 21:41:22.598] Port ON [2025-03-20 21:41:26.596] Port OFF [2025-03-20 21:41:30.598] Port ON [2025-03-20 21:41:34.594] Port OFF [2025-03-20 21:41:38.590] Port ON [2025-03-20 21:41:42.595] Port OFF [2025-03-20 21:41:46.607] Port ON [2025-03-20 21:41:50.612] Port OFF [2025-03-20 21:41:54.616] Port ON [2025-03-20 21:41:58.616] Port OFF [2025-03-20 21:42:02.611] Port ON [2025-03-20 21:42:06.613] Port OFF [2025-03-20 21:42:10.630] Port ON [2025-03-20 21:42:14.625] Port OFF [2025-03-20 21:42:18.636] Port ON [2025-03-20 21:42:22.640] Port OFF [2025-03-20 21:42:26.645] Port ON [2025-03-20 21:42:30.649] Port OFF [2025-03-20 21:42:34.645] Port ON [2025-03-20 21:42:38.646] Port OFF [2025-03-20 21:42:42.637] Port ON [2025-03-20 21:42:46.661] Port OFF [2025-03-20 21:42:50.652] Port ON [2025-03-20 21:42:54.658] Port OFF [2025-03-20 21:42:58.663] Port ON [2025-03-20 21:43:02.654] Port OFF [2025-03-20 21:43:06.661] Port ON [2025-03-20 21:43:10.656] Port OFF [2025-03-20 21:43:14.663] Port ON [2025-03-20 21:43:18.657] Port OFF [2025-03-20 21:43:22.655] Port ON [2025-03-20 21:43:26.657] Port OFF [2025-03-20 21:43:30.657] Port ON [2025-03-20 21:43:34.658] Port OFF [2025-03-20 21:43:38.663] Port ON [2025-03-20 21:43:42.656] Port OFF [2025-03-20 21:43:46.666] Port ON [2025-03-20 21:43:50.677] Port OFF [2025-03-20 21:43:54.675] Port ON [2025-03-20 21:43:58.693] Port OFF [2025-03-20 21:44:02.692] Port ON [2025-03-20 21:44:06.686] Port OFF [2025-03-20 21:44:10.686] Port ON [2025-03-20 21:44:14.708] Port OFF [2025-03-20 21:44:18.713] Port ON [2025-03-20 21:44:22.723] Port OFF [2025-03-20 21:44:26.728] Port ON [2025-03-20 21:44:30.719] Port OFF [2025-03-20 21:44:34.751] Port ON [2025-03-20 21:44:38.755] Port OFF [2025-03-20 21:44:42.756] Port ON [2025-03-20 21:44:46.761] Port OFF [2025-03-20 21:44:50.777] Port ON [2025-03-20 21:44:54.788] Port OFF [2025-03-20 21:44:58.809] Port ON [2025-03-20 21:45:02.822] Port OFF [2025-03-20 21:45:06.839] Port ON [2025-03-20 21:45:10.855] Port OFF [2025-03-20 21:45:14.858] Port ON [2025-03-20 21:45:18.865] Port OFF [2025-03-20 21:45:22.870] Port ON [2025-03-20 21:45:26.885] Port OFF [2025-03-20 21:45:30.915] Port ON [2025-03-20 21:45:34.931] Port OFF [2025-03-20 21:45:38.939] Port ON [2025-03-20 21:45:42.944] Port OFF [2025-03-20 21:45:46.935] Port ON [2025-03-20 21:45:50.943] Port OFF [2025-03-20 21:45:54.936] Port ON [2025-03-20 21:45:58.937] Port OFF [2025-03-20 21:46:02.947] Port ON [2025-03-20 21:46:06.956] Port OFF [2025-03-20 21:46:10.962] Port ON [2025-03-20 21:46:14.996] Port OFF [2025-03-20 21:46:19.000] Port ON [2025-03-20 21:46:23.012] Port OFF [2025-03-20 21:46:27.027] Port ON [2025-03-20 21:46:31.037] Port OFF [2025-03-20 21:46:35.032] Port ON [2025-03-20 21:46:39.040] Port OFF [2025-03-20 21:46:43.031] Port ON [2025-03-20 21:46:47.043] Port OFF [2025-03-20 21:46:51.053] Port ON [2025-03-20 21:46:55.074] Port OFF [2025-03-20 21:46:59.085] Port ON [2025-03-20 21:47:03.092] Port OFF [2025-03-20 21:47:07.095] Port ON [2025-03-20 21:47:11.096] Port OFF [2025-03-20 21:47:15.096] Port ON [2025-03-20 21:47:19.097] Port OFF [2025-03-20 21:47:23.099] Port ON [2025-03-20 21:47:27.102] Port OFF [2025-03-20 21:47:31.115] Port ON [2025-03-20 21:47:35.115] Port OFF [2025-03-20 21:47:39.135] Port ON [2025-03-20 21:47:43.151] Port OFF [2025-03-20 21:47:47.151] Port ON [2025-03-20 21:47:51.156] Port OFF [2025-03-20 21:47:55.169] Port ON [2025-03-20 21:47:59.195] Port OFF [2025-03-20 21:48:03.206] Port ON [2025-03-20 21:48:07.211] Port OFF [2025-03-20 21:48:11.204] Port ON [2025-03-20 21:48:15.228] Port OFF [2025-03-20 21:48:19.225] Port ON [2025-03-20 21:48:23.228] Port OFF [2025-03-20 21:48:27.225] Port ON [2025-03-20 21:48:31.240] Port OFF [2025-03-20 21:48:35.249] Port ON [2025-03-20 21:48:39.273] Port OFF [2025-03-20 21:48:43.279] Port ON [2025-03-20 21:48:47.295] Port OFF [2025-03-20 21:48:51.285] Port ON [2025-03-20 21:48:55.286] Port OFF [2025-03-20 21:48:59.291] Port ON [2025-03-20 21:49:03.310] Port OFF [2025-03-20 21:49:07.299] Port ON [2025-03-20 21:49:11.303] Port OFF [2025-03-20 21:49:15.302] Port ON [2025-03-20 21:49:19.306] Port OFF [2025-03-20 21:49:23.304] Port ON [2025-03-20 21:49:27.313] Port OFF [2025-03-20 21:49:31.329] Port ON [2025-03-20 21:49:35.342] Port OFF [2025-03-20 21:49:39.341] Port ON [2025-03-20 21:49:43.377] Port OFF [2025-03-20 21:49:47.380] Port ON [2025-03-20 21:49:51.415] Port OFF [2025-03-20 21:49:55.419] Port ON [2025-03-20 21:49:59.411] Port OFF [2025-03-20 21:50:03.420] Port ON [2025-03-20 21:50:07.418] Port OFF [2025-03-20 21:50:11.424] Port ON [2025-03-20 21:50:15.429] Port OFF [2025-03-20 21:50:19.446] Port ON [2025-03-20 21:50:23.447] Port OFF [2025-03-20 21:50:27.442] Port ON [2025-03-20 21:50:31.473] Port OFF [2025-03-20 21:50:35.480] Port ON [2025-03-20 21:50:39.484] Port OFF [2025-03-20 21:50:43.492] Port ON [2025-03-20 21:50:47.503] Port OFF [2025-03-20 21:50:51.515] Port ON [2025-03-20 21:50:55.527] Port OFF [2025-03-20 21:50:59.529] Port ON [2025-03-20 21:51:03.528] Port OFF [2025-03-20 21:51:07.547] Port ON [2025-03-20 21:51:11.545] Port OFF [2025-03-20 21:51:15.569] Port ON [2025-03-20 21:51:19.575] Port OFF [2025-03-20 21:51:23.593] Port ON [2025-03-20 21:51:27.587] Port OFF [2025-03-20 21:51:31.623] Port ON [2025-03-20 21:51:35.627] Port OFF [2025-03-20 21:51:39.642] Port ON [2025-03-20 21:51:43.638] Port OFF [2025-03-20 21:51:47.650] Port ON [2025-03-20 21:51:51.654] Port OFF [2025-03-20 21:51:55.661] Port ON [2025-03-20 21:51:59.669] Port OFF [2025-03-20 21:52:03.671] Port ON [2025-03-20 21:52:07.692] Port OFF [2025-03-20 21:52:11.694] Port ON [2025-03-20 21:52:15.712] Port OFF [2025-03-20 21:52:19.717] Port ON [2025-03-20 21:52:23.720] Port OFF [2025-03-20 21:52:27.725] Port ON [2025-03-20 21:52:31.754] Port OFF [2025-03-20 21:52:35.768] Port ON [2025-03-20 21:52:39.777] Port OFF [2025-03-20 21:52:43.774] Port ON [2025-03-20 21:52:47.774] Port OFF [2025-03-20 21:52:51.784] Port ON [2025-03-20 21:52:55.798] Port OFF [2025-03-20 21:52:59.809] Port ON [2025-03-20 21:53:03.806] Port OFF [2025-03-20 21:53:07.804] Port ON [2025-03-20 21:53:11.805] Port OFF [2025-03-20 21:53:15.816] Port ON [2025-03-20 21:53:19.825] Port OFF [2025-03-20 21:53:23.835] Port ON [2025-03-20 21:53:27.846] Port OFF [2025-03-20 21:53:31.878] Port ON [2025-03-20 21:53:35.893] Port OFF [2025-03-20 21:53:39.904] Port ON [2025-03-20 21:53:43.923] Port OFF [2025-03-20 21:53:47.927] Port ON [2025-03-20 21:53:51.935] Port OFF [2025-03-20 21:53:55.938] Port ON [2025-03-20 21:53:59.946] Port OFF [2025-03-20 21:54:03.947] Port ON [2025-03-20 21:54:07.958] Port OFF [2025-03-20 21:54:11.970] Port ON [2025-03-20 21:54:15.990] Port OFF [2025-03-20 21:54:19.997] Port ON [2025-03-20 21:54:24.013] Port OFF [2025-03-20 21:54:28.019] Port ON [2025-03-20 21:54:32.025] Port OFF [2025-03-20 21:54:36.031] Port ON [2025-03-20 21:54:40.021] Port OFF [2025-03-20 21:54:44.032] Port ON [2025-03-20 21:54:48.024] Port OFF [2025-03-20 21:54:52.034] Port ON [2025-03-20 21:54:56.052] Port OFF [2025-03-20 21:55:00.063] Port ON [2025-03-20 21:55:04.098] Port OFF [2025-03-20 21:55:08.112] Port ON [2025-03-20 21:55:12.144] Port OFF [2025-03-20 21:55:16.155] Port ON [2025-03-20 21:55:20.160] Port OFF [2025-03-20 21:55:24.170] Port ON [2025-03-20 21:55:28.184] Port OFF [2025-03-20 21:55:32.192] Port ON [2025-03-20 21:55:36.209] Port OFF [2025-03-20 21:55:40.212] Port ON [2025-03-20 21:55:44.217] Port OFF [2025-03-20 21:55:48.222] Port ON [2025-03-20 21:55:52.230] Port OFF [2025-03-20 21:55:56.232] Port ON [2025-03-20 21:56:00.254] Port OFF [2025-03-20 21:56:04.258] Port ON [2025-03-20 21:56:08.257] Port OFF [2025-03-20 21:56:12.259] Port ON [2025-03-20 21:56:16.262] Port OFF [2025-03-20 21:56:20.300] Port ON [2025-03-20 21:56:24.304] Port OFF [2025-03-20 21:56:28.313] Port ON [2025-03-20 21:56:32.325] Port OFF [2025-03-20 21:56:36.331] Port ON [2025-03-20 21:56:40.345] Port OFF [2025-03-20 21:56:44.354] Port ON [2025-03-20 21:56:48.361] Port OFF [2025-03-20 21:56:52.378] Port ON [2025-03-20 21:56:56.383] Port OFF [2025-03-20 21:57:00.396] Port ON [2025-03-20 21:57:04.411] Port OFF [2025-03-20 21:57:08.419] Port ON [2025-03-20 21:57:12.420] Port OFF [2025-03-20 21:57:16.415] Port ON [2025-03-20 21:57:20.418] Port OFF [2025-03-20 21:57:24.414] Port ON [2025-03-20 21:57:28.423] Port OFF [2025-03-20 21:57:32.447] Port ON [2025-03-20 21:57:36.446] Port OFF [2025-03-20 21:57:40.445] Port ON [2025-03-20 21:57:44.453] Port OFF [2025-03-20 21:57:48.448] Port ON [2025-03-20 21:57:52.454] Port OFF [2025-03-20 21:57:56.472] Port ON [2025-03-20 21:58:00.493] Port OFF [2025-03-20 21:58:04.505] Port ON [2025-03-20 21:58:08.515] Port OFF [2025-03-20 21:58:12.530] Port ON [2025-03-20 21:58:16.529] Port OFF [2025-03-20 21:58:20.529] Port ON [2025-03-20 21:58:24.523] Port OFF [2025-03-20 21:58:28.534] Port ON [2025-03-20 21:58:32.550] Port OFF [2025-03-20 21:58:36.554] Port ON [2025-03-20 21:58:40.559] Port OFF [2025-03-20 21:58:44.553] Port ON [2025-03-20 21:58:48.559] Port OFF [2025-03-20 21:58:52.555] Port ON [2025-03-20 21:58:56.581] Port OFF [2025-03-20 21:59:00.590] Port ON [2025-03-20 21:59:04.591] Port OFF [2025-03-20 21:59:08.594] Port ON [2025-03-20 21:59:12.586] Port OFF [2025-03-20 21:59:16.594] Port ON [2025-03-20 21:59:20.597] Port OFF [2025-03-20 21:59:24.596] Port ON [2025-03-20 21:59:28.597] Port OFF [2025-03-20 21:59:32.620] Port ON [2025-03-20 21:59:36.620] Port OFF [2025-03-20 21:59:40.622] Port ON [2025-03-20 21:59:44.615] Port OFF [2025-03-20 21:59:48.640] Port ON [2025-03-20 21:59:52.634] Port OFF [2025-03-20 21:59:56.642] Port ON [2025-03-20 22:00:00.631] Port OFF [2025-03-20 22:00:04.635] Port ON [2025-03-20 22:00:08.643] Port OFF [2025-03-20 22:00:12.657] Port ON [2025-03-20 22:00:16.653] Port OFF [2025-03-20 22:00:20.661] Port ON [2025-03-20 22:00:24.661] Port OFF [2025-03-20 22:00:28.666] Port ON [2025-03-20 22:00:32.674] Port OFF [2025-03-20 22:00:36.698] Port ON [2025-03-20 22:00:40.695] Port OFF [2025-03-20 22:00:44.704] Port ON [2025-03-20 22:00:48.715] Port OFF [2025-03-20 22:00:52.716] Port ON [2025-03-20 22:00:56.709] Port OFF [2025-03-20 22:01:00.715] Port ON [2025-03-20 22:01:04.713] Port OFF [2025-03-20 22:01:08.715] Port ON [2025-03-20 22:01:12.722] Port OFF [2025-03-20 22:01:16.729] Port ON [2025-03-20 22:01:20.737] Port OFF [2025-03-20 22:01:24.751] Port ON [2025-03-20 22:01:28.744] Port OFF [2025-03-20 22:01:32.751] Port ON [2025-03-20 22:01:36.765] Port OFF [2025-03-20 22:01:40.764] Port ON [2025-03-20 22:01:44.760] Port OFF [2025-03-20 22:01:48.781] Port ON [2025-03-20 22:01:52.776] Port OFF [2025-03-20 22:01:56.777] Port ON [2025-03-20 22:02:00.779] Port OFF [2025-03-20 22:02:04.771] Port ON [2025-03-20 22:02:08.777] Port OFF [2025-03-20 22:02:12.782] Port ON [2025-03-20 22:02:16.799] Port OFF [2025-03-20 22:02:20.812] Port ON [2025-03-20 22:02:24.802] Port OFF [2025-03-20 22:02:28.827] Port ON [2025-03-20 22:02:32.827] Port OFF [2025-03-20 22:02:36.819] Port ON [2025-03-20 22:02:40.823] Port OFF [2025-03-20 22:02:44.823] Port ON [2025-03-20 22:02:48.826] Port OFF [2025-03-20 22:02:52.835] Port ON [2025-03-20 22:02:56.839] Port OFF [2025-03-20 22:03:00.845] Port ON [2025-03-20 22:03:04.843] Port OFF [2025-03-20 22:03:08.843] Port ON [2025-03-20 22:03:12.843] Port OFF [2025-03-20 22:03:16.844] Port ON [2025-03-20 22:03:20.842] Port OFF [2025-03-20 22:03:24.836] Port ON [2025-03-20 22:03:28.845] Port OFF [2025-03-20 22:03:32.848] Port ON [2025-03-20 22:03:36.865] Port OFF [2025-03-20 22:03:40.882] Port ON [2025-03-20 22:03:44.887] Port OFF [2025-03-20 22:03:48.891] Port ON [2025-03-20 22:03:52.908] Port OFF [2025-03-20 22:03:56.903] Port ON [2025-03-20 22:04:00.927] Port OFF [2025-03-20 22:04:04.944] Port ON [2025-03-20 22:04:08.952] Port OFF [2025-03-20 22:04:12.958] Port ON [2025-03-20 22:04:16.966] Port OFF [2025-03-20 22:04:20.965] Port ON [2025-03-20 22:04:24.967] Port OFF [2025-03-20 22:04:28.963] Port ON [2025-03-20 22:04:32.969] Port OFF [2025-03-20 22:04:36.966] Port ON [2025-03-20 22:04:40.969] Port OFF [2025-03-20 22:04:44.974] Port ON [2025-03-20 22:04:48.984] Port OFF [2025-03-20 22:04:52.982] Port ON [2025-03-20 22:04:56.986] Port OFF [2025-03-20 22:05:00.980] Port ON [2025-03-20 22:05:04.984] Port OFF [2025-03-20 22:05:08.982] Port ON [2025-03-20 22:05:12.986] Port OFF [2025-03-20 22:05:16.983] Port ON [2025-03-20 22:05:20.978] Port OFF [2025-03-20 22:05:25.003] Port ON [2025-03-20 22:05:28.994] Port OFF [2025-03-20 22:05:33.007] Port ON [2025-03-20 22:05:37.016] Port OFF [2025-03-20 22:05:41.017] Port ON [2025-03-20 22:05:45.019] Port OFF [2025-03-20 22:05:49.020] Port ON [2025-03-20 22:05:53.014] Port OFF [2025-03-20 22:05:57.019] Port ON [2025-03-20 22:06:01.020] Port OFF [2025-03-20 22:06:05.011] Port ON [2025-03-20 22:06:09.021] Port OFF [2025-03-20 22:06:13.015] Port ON [2025-03-20 22:06:17.021] Port OFF [2025-03-20 22:06:21.017] Port ON [2025-03-20 22:06:25.020] Port OFF [2025-03-20 22:06:29.022] Port ON [2025-03-20 22:06:33.024] Port OFF [2025-03-20 22:06:37.013] Port ON [2025-03-20 22:06:41.017] Port OFF [2025-03-20 22:06:45.014] Port ON [2025-03-20 22:06:49.023] Port OFF [2025-03-20 22:06:53.026] Port ON [2025-03-20 22:06:57.018] Port OFF [2025-03-20 22:07:01.017] Port ON [2025-03-20 22:07:05.016] Port OFF [2025-03-20 22:07:09.023] Port ON [2025-03-20 22:07:13.012] Port OFF [2025-03-20 22:07:17.011] Port ON [2025-03-20 22:07:21.023] Port OFF [2025-03-20 22:07:25.026] Port ON [2025-03-20 22:07:29.057] Port OFF [2025-03-20 22:07:33.045] Port ON [2025-03-20 22:07:37.050] Port OFF [2025-03-20 22:07:41.053] Port ON [2025-03-20 22:07:45.057] Port OFF [2025-03-20 22:07:49.052] Port ON [2025-03-20 22:07:53.046] Port OFF [2025-03-20 22:07:57.061] Port ON [2025-03-20 22:08:01.066] Port OFF [2025-03-20 22:08:05.080] Port ON [2025-03-20 22:08:09.081] Port OFF [2025-03-20 22:08:13.101] Port ON [2025-03-20 22:08:17.095] Port OFF [2025-03-20 22:08:21.092] Port ON [2025-03-20 22:08:25.104] Port OFF [2025-03-20 22:08:29.101] Port ON [2025-03-20 22:08:33.100] Port OFF [2025-03-20 22:08:37.100] Port ON [2025-03-20 22:08:41.106] Port OFF [2025-03-20 22:08:45.106] Port ON [2025-03-20 22:08:49.093] Port OFF [2025-03-20 22:08:53.098] Port ON [2025-03-20 22:08:57.096] Port OFF [2025-03-20 22:09:01.115] Port ON [2025-03-20 22:09:05.111] Port OFF [2025-03-20 22:09:09.109] Port ON [2025-03-20 22:09:13.109] Port OFF [2025-03-20 22:09:17.116] Port ON [2025-03-20 22:09:21.129] Port OFF [2025-03-20 22:09:25.133] Port ON [2025-03-20 22:09:29.127] Port OFF [2025-03-20 22:09:33.124] Port ON [2025-03-20 22:09:37.124] Port OFF [2025-03-20 22:09:41.161] Port ON [2025-03-20 22:09:45.157] Port OFF [2025-03-20 22:09:49.182] Port ON [2025-03-20 22:09:53.213] Port OFF [2025-03-20 22:09:57.203] Port ON [2025-03-20 22:10:01.219] Port OFF [2025-03-20 22:10:05.219] Port ON [2025-03-20 22:10:09.218] Port OFF [2025-03-20 22:10:13.221] Port ON [2025-03-20 22:10:17.238] Port OFF [2025-03-20 22:10:21.238] Port ON [2025-03-20 22:10:25.248] Port OFF [2025-03-20 22:10:29.258] Port ON [2025-03-20 22:10:33.253] Port OFF [2025-03-20 22:10:37.255] Port ON [2025-03-20 22:10:41.254] Port OFF [2025-03-20 22:10:45.260] Port ON [2025-03-20 22:10:49.258] Port OFF [2025-03-20 22:10:53.250] Port ON [2025-03-20 22:10:57.260] Port OFF [2025-03-20 22:11:01.258] Port ON [2025-03-20 22:11:05.248] Port OFF [2025-03-20 22:11:09.251] Port ON [2025-03-20 22:11:13.247] Port OFF [2025-03-20 22:11:17.253] Port ON [2025-03-20 22:11:21.257] Port OFF [2025-03-20 22:11:25.254] Port ON [2025-03-20 22:11:29.269] Port OFF [2025-03-20 22:11:33.270] Port ON [2025-03-20 22:11:37.264] Port OFF [2025-03-20 22:11:41.271] Port ON [2025-03-20 22:11:45.271] Port OFF [2025-03-20 22:11:49.277] Port ON [2025-03-20 22:11:53.275] Port OFF [2025-03-20 22:11:57.281] Port ON [2025-03-20 22:12:01.288] Port OFF [2025-03-20 22:12:05.280] Port ON [2025-03-20 22:12:09.281] Port OFF [2025-03-20 22:12:13.286] Port ON [2025-03-20 22:12:17.279] Port OFF [2025-03-20 22:12:21.292] Port ON [2025-03-20 22:12:25.283] Port OFF [2025-03-20 22:12:29.289] Port ON [2025-03-20 22:12:33.287] Port OFF [2025-03-20 22:12:37.280] Port ON [2025-03-20 22:12:41.280] Port OFF [2025-03-20 22:12:45.289] Port ON [2025-03-20 22:12:49.282] Port OFF [2025-03-20 22:12:53.289] Port ON [2025-03-20 22:12:57.282] Port OFF [2025-03-20 22:13:01.278] Port ON [2025-03-20 22:13:05.288] Port OFF [2025-03-20 22:13:09.291] Port ON [2025-03-20 22:13:13.286] Port OFF [2025-03-20 22:13:17.283] Port ON [2025-03-20 22:13:21.299] Port OFF [2025-03-20 22:13:25.327] Port ON [2025-03-20 22:13:29.331] Port OFF [2025-03-20 22:13:33.328] Port ON [2025-03-20 22:13:37.326] Port OFF [2025-03-20 22:13:41.330] Port ON [2025-03-20 22:13:45.326] Port OFF [2025-03-20 22:13:49.326] Port ON [2025-03-20 22:13:53.354] Port OFF [2025-03-20 22:13:57.353] Port ON [2025-03-20 22:14:01.367] Port OFF [2025-03-20 22:14:05.381] Port ON [2025-03-20 22:14:09.384] Port OFF [2025-03-20 22:14:13.389] Port ON [2025-03-20 22:14:17.402] Port OFF [2025-03-20 22:14:21.392] Port ON [2025-03-20 22:14:25.391] Port OFF [2025-03-20 22:14:29.400] Port ON [2025-03-20 22:14:33.410] Port OFF [2025-03-20 22:14:37.412] Port ON [2025-03-20 22:14:41.418] Port OFF [2025-03-20 22:14:45.433] Port ON [2025-03-20 22:14:49.435] Port OFF [2025-03-20 22:14:53.440] Port ON [2025-03-20 22:14:57.438] Port OFF [2025-03-20 22:15:01.437] Port ON [2025-03-20 22:15:05.439] Port OFF [2025-03-20 22:15:09.437] Port ON [2025-03-20 22:15:13.443] Port OFF [2025-03-20 22:15:17.438] Port ON [2025-03-20 22:15:21.444] Port OFF [2025-03-20 22:15:25.440] Port ON [2025-03-20 22:15:29.443] Port OFF [2025-03-20 22:15:33.438] Port ON [2025-03-20 22:15:37.444] Port OFF [2025-03-20 22:15:41.445] Port ON [2025-03-20 22:15:45.443] Port OFF [2025-03-20 22:15:49.449] Port ON [2025-03-20 22:15:53.448] Port OFF [2025-03-20 22:15:57.445] Port ON [2025-03-20 22:16:01.438] Port OFF [2025-03-20 22:16:05.439] Port ON [2025-03-20 22:16:09.439] Port OFF [2025-03-20 22:16:13.440] Port ON [2025-03-20 22:16:17.442] Port OFF [2025-03-20 22:16:21.437] Port ON [2025-03-20 22:16:25.439] Port OFF [2025-03-20 22:16:29.436] Port ON [2025-03-20 22:16:33.441] Port OFF [2025-03-20 22:16:37.439] Port ON [2025-03-20 22:16:41.447] Port OFF [2025-03-20 22:16:45.437] Port ON [2025-03-20 22:16:49.437] Port OFF [2025-03-20 22:16:53.446] Port ON [2025-03-20 22:16:57.438] Port OFF [2025-03-20 22:17:01.438] Port ON [2025-03-20 22:17:05.437] Port OFF [2025-03-20 22:17:09.453] Port ON [2025-03-20 22:17:13.470] Port OFF [2025-03-20 22:17:17.473] Port ON [2025-03-20 22:17:21.480] Port OFF [2025-03-20 22:17:25.489] Port ON [2025-03-20 22:17:29.497] Port OFF [2025-03-20 22:17:33.503] Port ON [2025-03-20 22:17:37.510] Port OFF [2025-03-20 22:17:41.505] Port ON [2025-03-20 22:17:45.515] Port OFF [2025-03-20 22:17:49.527] Port ON [2025-03-20 22:17:53.555] Port OFF [2025-03-20 22:17:57.576] Port ON [2025-03-20 22:18:01.595] Port OFF [2025-03-20 22:18:05.597] Port ON [2025-03-20 22:18:09.601] Port OFF [2025-03-20 22:18:13.607] Port ON [2025-03-20 22:18:17.619] Port OFF [2025-03-20 22:18:21.632] Port ON [2025-03-20 22:18:25.653] Port OFF [2025-03-20 22:18:29.664] Port ON [2025-03-20 22:18:33.659] Port OFF [2025-03-20 22:18:37.656] Port ON [2025-03-20 22:18:41.686] Port OFF [2025-03-20 22:18:45.703] Port ON [2025-03-20 22:18:49.708] Port OFF [2025-03-20 22:18:53.717] Port ON [2025-03-20 22:18:57.750] Port OFF [2025-03-20 22:19:01.757] Port ON [2025-03-20 22:19:05.786] Port OFF [2025-03-20 22:19:09.785] Port ON [2025-03-20 22:19:13.789] Port OFF [2025-03-20 22:19:17.804] Port ON [2025-03-20 22:19:21.811] Port OFF [2025-03-20 22:19:25.837] Port ON [2025-03-20 22:19:29.855] Port OFF [2025-03-20 22:19:33.873] Port ON [2025-03-20 22:19:37.897] Port OFF [2025-03-20 22:19:41.903] Port ON [2025-03-20 22:19:45.923] Port OFF [2025-03-20 22:19:49.935] Port ON [2025-03-20 22:19:53.940] Port OFF [2025-03-20 22:19:57.938] Port ON [2025-03-20 22:20:01.943] Port OFF [2025-03-20 22:20:05.939] Port ON [2025-03-20 22:20:09.953] Port OFF [2025-03-20 22:20:13.967] Port ON [2025-03-20 22:20:17.980] Port OFF [2025-03-20 22:20:21.987] Port ON [2025-03-20 22:20:25.999] Port OFF [2025-03-20 22:20:30.024] Port ON [2025-03-20 22:20:34.032] Port OFF [2025-03-20 22:20:38.055] Port ON [2025-03-20 22:20:42.057] Port OFF [2025-03-20 22:20:46.050] Port ON [2025-03-20 22:20:50.057] Port OFF [2025-03-20 22:20:54.059] Port ON [2025-03-20 22:20:58.080] Port OFF [2025-03-20 22:21:02.083] Port ON [2025-03-20 22:21:06.093] Port OFF [2025-03-20 22:21:10.100] Port ON [2025-03-20 22:21:14.099] Port OFF [2025-03-20 22:21:18.103] Port ON [2025-03-20 22:21:22.102] Port OFF [2025-03-20 22:21:26.105] Port ON [2025-03-20 22:21:30.118] Port OFF [2025-03-20 22:21:34.115] Port ON [2025-03-20 22:21:38.116] Port OFF [2025-03-20 22:21:42.113] Port ON [2025-03-20 22:21:46.122] Port OFF [2025-03-20 22:21:50.141] Port ON [2025-03-20 22:21:54.144] Port OFF [2025-03-20 22:21:58.168] Port ON [2025-03-20 22:22:02.160] Port OFF [2025-03-20 22:22:06.165] Port ON [2025-03-20 22:22:10.175] Port OFF [2025-03-20 22:22:14.183] Port ON [2025-03-20 22:22:18.181] Port OFF [2025-03-20 22:22:22.207] Port ON [2025-03-20 22:22:26.217] Port OFF [2025-03-20 22:22:30.235] Port ON [2025-03-20 22:22:34.261] Port OFF [2025-03-20 22:22:38.286] Port ON [2025-03-20 22:22:42.287] Port OFF [2025-03-20 22:22:46.304] Port ON [2025-03-20 22:22:50.311] Port OFF [2025-03-20 22:22:54.341] Port ON [2025-03-20 22:22:58.333] Port OFF [2025-03-20 22:23:02.373] Port ON [2025-03-20 22:23:06.366] Port OFF [2025-03-20 22:23:10.387] Port ON [2025-03-20 22:23:14.390] Port OFF [2025-03-20 22:23:18.381] Port ON [2025-03-20 22:23:22.395] Port OFF [2025-03-20 22:23:26.411] Port ON [2025-03-20 22:23:30.417] Port OFF [2025-03-20 22:23:34.441] Port ON [2025-03-20 22:23:38.448] Port OFF [2025-03-20 22:23:42.443] Port ON [2025-03-20 22:23:46.468] Port OFF [2025-03-20 22:23:50.473] Port ON [2025-03-20 22:23:54.478] Port OFF [2025-03-20 22:23:58.501] Port ON [2025-03-20 22:24:02.493] Port OFF [2025-03-20 22:24:06.501] Port ON [2025-03-20 22:24:10.514] Port OFF [2025-03-20 22:24:14.532] Port ON [2025-03-20 22:24:18.545] Port OFF [2025-03-20 22:24:22.556] Port ON [2025-03-20 22:24:26.551] Port OFF [2025-03-20 22:24:30.568] Port ON [2025-03-20 22:24:34.588] Port OFF [2025-03-20 22:24:38.599] Port ON [2025-03-20 22:24:42.608] Port OFF [2025-03-20 22:24:46.616] Port ON [2025-03-20 22:24:50.635] Port OFF [2025-03-20 22:24:54.634] Port ON [2025-03-20 22:24:58.642] Port OFF [2025-03-20 22:25:02.659] Port ON [2025-03-20 22:25:06.674] Port OFF [2025-03-20 22:25:10.688] Port ON [2025-03-20 22:25:14.692] Port OFF [2025-03-20 22:25:18.696] Port ON [2025-03-20 22:25:22.693] Port OFF [2025-03-20 22:25:26.699] Port ON [2025-03-20 22:25:30.699] Port OFF [2025-03-20 22:25:34.697] Port ON [2025-03-20 22:25:38.722] Port OFF [2025-03-20 22:25:42.729] Port ON [2025-03-20 22:25:46.730] Port OFF [2025-03-20 22:25:50.742] Port ON [2025-03-20 22:25:54.746] Port OFF [2025-03-20 22:25:58.755] Port ON [2025-03-20 22:26:02.772] Port OFF [2025-03-20 22:26:06.779] Port ON [2025-03-20 22:26:10.779] Port OFF [2025-03-20 22:26:14.776] Port ON [2025-03-20 22:26:18.775] Port OFF [2025-03-20 22:26:22.782] Port ON [2025-03-20 22:26:26.782] Port OFF [2025-03-20 22:26:30.782] Port ON [2025-03-20 22:26:34.802] Port OFF [2025-03-20 22:26:38.815] Port ON [2025-03-20 22:26:42.842] Port OFF [2025-03-20 22:26:46.861] Port ON [2025-03-20 22:26:50.852] Port OFF [2025-03-20 22:26:54.850] Port ON [2025-03-20 22:26:58.859] Port OFF [2025-03-20 22:27:02.855] Port ON [2025-03-20 22:27:06.865] Port OFF [2025-03-20 22:27:10.872] Port ON [2025-03-20 22:27:14.872] Port OFF [2025-03-20 22:27:18.872] Port ON [2025-03-20 22:27:22.867] Port OFF [2025-03-20 22:27:26.872] Port ON [2025-03-20 22:27:30.869] Port OFF [2025-03-20 22:27:34.873] Port ON [2025-03-20 22:27:38.904] Port OFF [2025-03-20 22:27:42.900] Port ON [2025-03-20 22:27:46.929] Port OFF [2025-03-20 22:27:50.942] Port ON [2025-03-20 22:27:54.972] Port OFF [2025-03-20 22:27:58.972] Port ON [2025-03-20 22:28:02.996] Port OFF [2025-03-20 22:28:07.000] Port ON [2025-03-20 22:28:11.030] Port OFF [2025-03-20 22:28:15.024] Port ON [2025-03-20 22:28:19.055] Port OFF [2025-03-20 22:28:23.067] Port ON [2025-03-20 22:28:27.065] Port OFF [2025-03-20 22:28:31.066] Port ON [2025-03-20 22:28:35.059] Port OFF [2025-03-20 22:28:39.059] Port ON [2025-03-20 22:28:43.069] Port OFF [2025-03-20 22:28:47.089] Port ON [2025-03-20 22:28:51.101] Port OFF [2025-03-20 22:28:55.107] Port ON [2025-03-20 22:28:59.120] Port OFF [2025-03-20 22:29:03.129] Port ON [2025-03-20 22:29:07.147] Port OFF [2025-03-20 22:29:11.159] Port ON [2025-03-20 22:29:15.148] Port OFF [2025-03-20 22:29:19.159] Port ON [2025-03-20 22:29:23.156] Port OFF [2025-03-20 22:29:27.157] Port ON [2025-03-20 22:29:31.161] Port OFF [2025-03-20 22:29:35.153] Port ON [2025-03-20 22:29:39.165] Port OFF [2025-03-20 22:29:43.180] Port ON [2025-03-20 22:29:47.188] Port OFF [2025-03-20 22:29:51.185] Port ON [2025-03-20 22:29:55.195] Port OFF [2025-03-20 22:29:59.208] Port ON [2025-03-20 22:30:03.198] Port OFF [2025-03-20 22:30:07.209] Port ON [2025-03-20 22:30:11.229] Port OFF [2025-03-20 22:30:15.227] Port ON [2025-03-20 22:30:19.240] Port OFF [2025-03-20 22:30:23.243] Port ON [2025-03-20 22:30:27.248] Port OFF [2025-03-20 22:30:31.242] Port ON [2025-03-20 22:30:35.257] Port OFF [2025-03-20 22:30:39.273] Port ON [2025-03-20 22:30:43.275] Port OFF [2025-03-20 22:30:47.284] Port ON [2025-03-20 22:30:51.305] Port OFF [2025-03-20 22:30:55.319] Port ON [2025-03-20 22:30:59.323] Port OFF [2025-03-20 22:31:03.338] Port ON [2025-03-20 22:31:07.336] Port OFF [2025-03-20 22:31:11.350] Port ON [2025-03-20 22:31:15.360] Port OFF [2025-03-20 22:31:19.359] Port ON [2025-03-20 22:31:23.358] Port OFF [2025-03-20 22:31:27.356] Port ON [2025-03-20 22:31:31.362] Port OFF [2025-03-20 22:31:35.371] Port ON [2025-03-20 22:31:39.380] Port OFF [2025-03-20 22:31:43.387] Port ON [2025-03-20 22:31:47.391] Port OFF [2025-03-20 22:31:51.397] Port ON [2025-03-20 22:31:55.401] Port OFF [2025-03-20 22:31:59.401] Port ON [2025-03-20 22:32:03.402] Port OFF [2025-03-20 22:32:07.405] Port ON [2025-03-20 22:32:11.404] Port OFF [2025-03-20 22:32:15.408] Port ON [2025-03-20 22:32:19.408] Port OFF [2025-03-20 22:32:23.416] Port ON [2025-03-20 22:32:27.419] Port OFF [2025-03-20 22:32:31.425] Port ON [2025-03-20 22:32:35.420] Port OFF [2025-03-20 22:32:39.440] Port ON [2025-03-20 22:32:43.447] Port OFF [2025-03-20 22:32:47.450] Port ON [2025-03-20 22:32:51.455] Port OFF [2025-03-20 22:32:55.472] Port ON [2025-03-20 22:32:59.475] Port OFF [2025-03-20 22:33:03.515] Port ON [2025-03-20 22:33:07.526] Port OFF [2025-03-20 22:33:11.557] Port ON [2025-03-20 22:33:15.567] Port OFF [2025-03-20 22:33:19.577] Port ON [2025-03-20 22:33:23.579] Port OFF [2025-03-20 22:33:27.578] Port ON [2025-03-20 22:33:31.575] Port OFF [2025-03-20 22:33:35.587] Port ON [2025-03-20 22:33:39.594] Port OFF [2025-03-20 22:33:43.612] Port ON [2025-03-20 22:33:47.618] Port OFF [2025-03-20 22:33:51.622] Port ON [2025-03-20 22:33:55.628] Port OFF [2025-03-20 22:33:59.623] Port ON [2025-03-20 22:34:03.632] Port OFF [2025-03-20 22:34:07.643] Port ON [2025-03-20 22:34:11.646] Port OFF [2025-03-20 22:34:15.653] Port ON [2025-03-20 22:34:19.659] Port OFF [2025-03-20 22:34:23.659] Port ON [2025-03-20 22:34:27.662] Port OFF [2025-03-20 22:34:31.689] Port ON [2025-03-20 22:34:35.697] Port OFF [2025-03-20 22:34:39.699] Port ON [2025-03-20 22:34:43.723] Port OFF [2025-03-20 22:34:47.727] Port ON [2025-03-20 22:34:51.741] Port OFF [2025-03-20 22:34:55.732] Port ON [2025-03-20 22:34:59.730] Port OFF [2025-03-20 22:35:03.737] Port ON [2025-03-20 22:35:07.742] Port OFF [2025-03-20 22:35:11.751] Port ON [2025-03-20 22:35:15.746] Port OFF [2025-03-20 22:35:19.747] Port ON [2025-03-20 22:35:23.748] Port OFF [2025-03-20 22:35:27.756] Port ON [2025-03-20 22:35:31.764] Port OFF [2025-03-20 22:35:35.763] Port ON [2025-03-20 22:35:39.776] Port OFF [2025-03-20 22:35:43.777] Port ON [2025-03-20 22:35:47.777] Port OFF [2025-03-20 22:35:51.782] Port ON [2025-03-20 22:35:55.775] Port OFF [2025-03-20 22:35:59.778] Port ON [2025-03-20 22:36:03.784] Port OFF [2025-03-20 22:36:07.790] Port ON [2025-03-20 22:36:11.809] Port OFF [2025-03-20 22:36:15.807] Port ON [2025-03-20 22:36:19.807] Port OFF [2025-03-20 22:36:23.808] Port ON [2025-03-20 22:36:27.819] Port OFF [2025-03-20 22:36:31.824] Port ON [2025-03-20 22:36:35.822] Port OFF [2025-03-20 22:36:39.833] Port ON [2025-03-20 22:36:43.830] Port OFF [2025-03-20 22:36:47.833] Port ON [2025-03-20 22:36:51.837] Port OFF [2025-03-20 22:36:55.843] Port ON [2025-03-20 22:36:59.844] Port OFF [2025-03-20 22:37:03.840] Port ON [2025-03-20 22:37:07.865] Port OFF [2025-03-20 22:37:11.866] Port ON [2025-03-20 22:37:15.857] Port OFF [2025-03-20 22:37:19.856] Port ON [2025-03-20 22:37:23.857] Port OFF [2025-03-20 22:37:27.860] Port ON [2025-03-20 22:37:31.865] Port OFF [2025-03-20 22:37:35.855] Port ON [2025-03-20 22:37:39.869] Port OFF [2025-03-20 22:37:43.877] Port ON [2025-03-20 22:37:47.875] Port OFF [2025-03-20 22:37:51.871] Port ON [2025-03-20 22:37:55.879] Port OFF [2025-03-20 22:37:59.876] Port ON [2025-03-20 22:38:03.884] Port OFF [2025-03-20 22:38:07.903] Port ON [2025-03-20 22:38:11.915] Port OFF [2025-03-20 22:38:15.927] Port ON [2025-03-20 22:38:19.926] Port OFF [2025-03-20 22:38:23.920] Port ON [2025-03-20 22:38:27.941] Port OFF [2025-03-20 22:38:31.946] Port ON [2025-03-20 22:38:35.933] Port OFF [2025-03-20 22:38:39.955] Port ON [2025-03-20 22:38:43.957] Port OFF [2025-03-20 22:38:47.977] Port ON [2025-03-20 22:38:51.969] Port OFF [2025-03-20 22:38:55.983] Port ON [2025-03-20 22:38:59.988] Port OFF [2025-03-20 22:39:03.985] Port ON [2025-03-20 22:39:07.996] Port OFF [2025-03-20 22:39:12.019] Port ON [2025-03-20 22:39:16.029] Port OFF [2025-03-20 22:39:20.032] Port ON [2025-03-20 22:39:24.034] Port OFF [2025-03-20 22:39:28.035] Port ON [2025-03-20 22:39:32.031] Port OFF [2025-03-20 22:39:36.035] Port ON [2025-03-20 22:39:40.033] Port OFF [2025-03-20 22:39:44.038] Port ON [2025-03-20 22:39:48.037] Port OFF [2025-03-20 22:39:52.063] Port ON [2025-03-20 22:39:56.071] Port OFF [2025-03-20 22:40:00.098] Port ON [2025-03-20 22:40:04.106] Port OFF [2025-03-20 22:40:08.129] Port ON [2025-03-20 22:40:12.152] Port OFF [2025-03-20 22:40:16.161] Port ON [2025-03-20 22:40:20.158] Port OFF [2025-03-20 22:40:24.180] Port ON [2025-03-20 22:40:28.179] Port OFF [2025-03-20 22:40:32.207] Port ON [2025-03-20 22:40:36.209] Port OFF [2025-03-20 22:40:40.217] Port ON [2025-03-20 22:40:44.227] Port OFF [2025-03-20 22:40:48.240] Port ON [2025-03-20 22:40:52.240] Port OFF [2025-03-20 22:40:56.246] Port ON [2025-03-20 22:41:00.256] Port OFF [2025-03-20 22:41:04.269] Port ON [2025-03-20 22:41:08.270] Port OFF [2025-03-20 22:41:12.276] Port ON [2025-03-20 22:41:16.275] Port OFF [2025-03-20 22:41:20.296] Port ON [2025-03-20 22:41:24.297] Port OFF [2025-03-20 22:41:28.323] Port ON [2025-03-20 22:41:32.321] Port OFF [2025-03-20 22:41:36.317] Port ON [2025-03-20 22:41:40.326] Port OFF [2025-03-20 22:41:44.356] Port ON [2025-03-20 22:41:48.374] Port OFF [2025-03-20 22:41:52.386] Port ON [2025-03-20 22:41:56.391] Port OFF [2025-03-20 22:42:00.395] Port ON [2025-03-20 22:42:04.418] Port OFF [2025-03-20 22:42:08.413] Port ON [2025-03-20 22:42:12.412] Port OFF [2025-03-20 22:42:16.441] Port ON [2025-03-20 22:42:20.446] Port OFF [2025-03-20 22:42:24.459] Port ON [2025-03-20 22:42:28.467] Port OFF [2025-03-20 22:42:32.482] Port ON [2025-03-20 22:42:36.501] Port OFF [2025-03-20 22:42:40.514] Port ON [2025-03-20 22:42:44.502] Port OFF [2025-03-20 22:42:48.512] Port ON [2025-03-20 22:42:52.507] Port OFF [2025-03-20 22:42:56.513] Port ON [2025-03-20 22:43:00.507] Port OFF [2025-03-20 22:43:04.518] Port ON [2025-03-20 22:43:08.518] Port OFF [2025-03-20 22:43:12.521] Port ON [2025-03-20 22:43:16.528] Port OFF [2025-03-20 22:43:20.526] Port ON [2025-03-20 22:43:24.538] Port OFF [2025-03-20 22:43:28.546] Port ON [2025-03-20 22:43:32.560] Port OFF [2025-03-20 22:43:36.564] Port ON [2025-03-20 22:43:40.577] Port OFF [2025-03-20 22:43:44.592] Port ON [2025-03-20 22:43:48.602] Port OFF [2025-03-20 22:43:52.616] Port ON [2025-03-20 22:43:56.621] Port OFF [2025-03-20 22:44:00.621] Port ON [2025-03-20 22:44:04.618] Port OFF [2025-03-20 22:44:08.615] Port ON [2025-03-20 22:44:12.612] Port OFF [2025-03-20 22:44:16.619] Port ON [2025-03-20 22:44:20.618] Port OFF [2025-03-20 22:44:24.620] Port ON [2025-03-20 22:44:28.623] Port OFF [2025-03-20 22:44:32.638] Port ON [2025-03-20 22:44:36.641] Port OFF [2025-03-20 22:44:40.659] Port ON [2025-03-20 22:44:44.660] Port OFF [2025-03-20 22:44:48.661] Port ON [2025-03-20 22:44:52.661] Port OFF [2025-03-20 22:44:56.671] Port ON [2025-03-20 22:45:00.679] Port OFF [2025-03-20 22:45:04.679] Port ON [2025-03-20 22:45:08.681] Port OFF [2025-03-20 22:45:12.675] Port ON [2025-03-20 22:45:16.688] Port OFF [2025-03-20 22:45:20.700] Port ON [2025-03-20 22:45:24.694] Port OFF [2025-03-20 22:45:28.690] Port ON [2025-03-20 22:45:32.690] Port OFF [2025-03-20 22:45:36.697] Port ON [2025-03-20 22:45:40.705] Port OFF [2025-03-20 22:45:44.710] Port ON [2025-03-20 22:45:48.733] Port OFF [2025-03-20 22:45:52.729] Port ON [2025-03-20 22:45:56.728] Port OFF [2025-03-20 22:46:00.730] Port ON [2025-03-20 22:46:04.729] Port OFF [2025-03-20 22:46:08.724] Port ON [2025-03-20 22:46:12.723] Port OFF [2025-03-20 22:46:16.727] Port ON [2025-03-20 22:46:20.739] Port OFF [2025-03-20 22:46:24.744] Port ON [2025-03-20 22:46:28.748] Port OFF [2025-03-20 22:46:32.738] Port ON [2025-03-20 22:46:36.740] Port OFF [2025-03-20 22:46:40.773] Port ON [2025-03-20 22:46:44.779] Port OFF [2025-03-20 22:46:48.807] Port ON [2025-03-20 22:46:52.812] Port OFF [2025-03-20 22:46:56.819] Port ON [2025-03-20 22:47:00.841] Port OFF [2025-03-20 22:47:04.835] Port ON [2025-03-20 22:47:08.844] Port OFF [2025-03-20 22:47:12.860] Port ON [2025-03-20 22:47:16.873] Port OFF [2025-03-20 22:47:20.864] Port ON [2025-03-20 22:47:24.877] Port OFF [2025-03-20 22:47:28.890] Port ON [2025-03-20 22:47:32.881] Port OFF [2025-03-20 22:47:36.886] Port ON [2025-03-20 22:47:40.880] Port OFF [2025-03-20 22:47:44.883] Port ON [2025-03-20 22:47:48.881] Port OFF [2025-03-20 22:47:52.899] Port ON [2025-03-20 22:47:56.906] Port OFF [2025-03-20 22:48:00.902] Port ON [2025-03-20 22:48:04.906] Port OFF [2025-03-20 22:48:08.914] Port ON [2025-03-20 22:48:12.920] Port OFF [2025-03-20 22:48:16.918] Port ON [2025-03-20 22:48:20.924] Port OFF [2025-03-20 22:48:24.942] Port ON [2025-03-20 22:48:28.950] Port OFF [2025-03-20 22:48:32.944] Port ON [2025-03-20 22:48:36.948] Port OFF [2025-03-20 22:48:40.968] Port ON [2025-03-20 22:48:44.963] Port OFF [2025-03-20 22:48:48.974] Port ON [2025-03-20 22:48:52.983] Port OFF [2025-03-20 22:48:56.996] Port ON [2025-03-20 22:49:00.992] Port OFF [2025-03-20 22:49:04.995] Port ON [2025-03-20 22:49:08.991] Port OFF [2025-03-20 22:49:13.005] Port ON [2025-03-20 22:49:17.020] Port OFF [2025-03-20 22:49:21.020] Port ON [2025-03-20 22:49:25.047] Port OFF [2025-03-20 22:49:29.057] Port ON [2025-03-20 22:49:33.075] Port OFF [2025-03-20 22:49:37.070] Port ON [2025-03-20 22:49:41.072] Port OFF [2025-03-20 22:49:45.084] Port ON [2025-03-20 22:49:49.091] Port OFF [2025-03-20 22:49:53.087] Port ON [2025-03-20 22:49:57.097] Port OFF [2025-03-20 22:50:01.140] Port ON [2025-03-20 22:50:05.142] Port OFF [2025-03-20 22:50:09.152] Port ON [2025-03-20 22:50:13.164] Port OFF [2025-03-20 22:50:17.172] Port ON [2025-03-20 22:50:21.177] Port OFF [2025-03-20 22:50:25.190] Port ON [2025-03-20 22:50:29.201] Port OFF [2025-03-20 22:50:33.201] Port ON [2025-03-20 22:50:37.200] Port OFF [2025-03-20 22:50:41.208] Port ON [2025-03-20 22:50:45.210] Port OFF [2025-03-20 22:50:49.209] Port ON [2025-03-20 22:50:53.209] Port OFF [2025-03-20 22:50:57.244] Port ON [2025-03-20 22:51:01.254] Port OFF [2025-03-20 22:51:05.258] Port ON [2025-03-20 22:51:09.256] Port OFF [2025-03-20 22:51:13.267] Port ON [2025-03-20 22:51:17.264] Port OFF [2025-03-20 22:51:21.261] Port ON [2025-03-20 22:51:25.256] Port OFF [2025-03-20 22:51:29.263] Port ON [2025-03-20 22:51:33.262] Port OFF [2025-03-20 22:51:37.259] Port ON [2025-03-20 22:51:41.279] Port OFF [2025-03-20 22:51:45.278] Port ON [2025-03-20 22:51:49.270] Port OFF [2025-03-20 22:51:53.282] Port ON [2025-03-20 22:51:57.277] Port OFF [2025-03-20 22:52:01.274] Port ON [2025-03-20 22:52:05.300] Port OFF [2025-03-20 22:52:09.331] Port ON [2025-03-20 22:52:13.357] Port OFF [2025-03-20 22:52:17.369] Port ON [2025-03-20 22:52:21.373] Port OFF [2025-03-20 22:52:25.371] Port ON [2025-03-20 22:52:29.369] Port OFF [2025-03-20 22:52:33.371] Port ON [2025-03-20 22:52:37.366] Port OFF [2025-03-20 22:52:41.402] Port ON [2025-03-20 22:52:45.415] Port OFF [2025-03-20 22:52:49.424] Port ON [2025-03-20 22:52:53.431] Port OFF [2025-03-20 22:52:57.444] Port ON [2025-03-20 22:53:01.451] Port OFF [2025-03-20 22:53:05.443] Port ON [2025-03-20 22:53:09.451] Port OFF [2025-03-20 22:53:13.449] Port ON [2025-03-20 22:53:17.447] Port OFF [2025-03-20 22:53:21.459] Port ON [2025-03-20 22:53:25.465] Port OFF [2025-03-20 22:53:29.470] Port ON [2025-03-20 22:53:33.473] Port OFF [2025-03-20 22:53:37.501] Port ON [2025-03-20 22:53:41.518] Port OFF [2025-03-20 22:53:45.545] Port ON [2025-03-20 22:53:49.546] Port OFF [2025-03-20 22:53:53.561] Port ON [2025-03-20 22:53:57.560] Port OFF [2025-03-20 22:54:01.579] Port ON [2025-03-20 22:54:05.594] Port OFF [2025-03-20 22:54:09.611] Port ON [2025-03-20 22:54:13.624] Port OFF [2025-03-20 22:54:17.616] Port ON [2025-03-20 22:54:21.614] Port OFF [2025-03-20 22:54:25.622] Port ON [2025-03-20 22:54:29.613] Port OFF [2025-03-20 22:54:33.622] Port ON [2025-03-20 22:54:37.626] Port OFF [2025-03-20 22:54:41.633] Port ON [2025-03-20 22:54:45.641] Port OFF [2025-03-20 22:54:49.649] Port ON [2025-03-20 22:54:53.652] Port OFF [2025-03-20 22:54:57.651] Port ON [2025-03-20 22:55:01.652] Port OFF [2025-03-20 22:55:05.649] Port ON [2025-03-20 22:55:09.660] Port OFF [2025-03-20 22:55:13.677] Port ON [2025-03-20 22:55:17.692] Port OFF [2025-03-20 22:55:21.704] Port ON [2025-03-20 22:55:25.724] Port OFF [2025-03-20 22:55:29.738] Port ON [2025-03-20 22:55:33.741] Port OFF [2025-03-20 22:55:37.749] Port ON [2025-03-20 22:55:41.753] Port OFF [2025-03-20 22:55:45.770] Port ON [2025-03-20 22:55:49.782] Port OFF [2025-03-20 22:55:53.802] Port ON [2025-03-20 22:55:57.814] Port OFF [2025-03-20 22:56:01.828] Port ON [2025-03-20 22:56:05.818] Port OFF [2025-03-20 22:56:09.834] Port ON [2025-03-20 22:56:13.836] Port OFF [2025-03-20 22:56:17.846] Port ON [2025-03-20 22:56:21.866] Port OFF [2025-03-20 22:56:25.866] Port ON [2025-03-20 22:56:29.885] Port OFF [2025-03-20 22:56:33.882] Port ON [2025-03-20 22:56:37.890] Port OFF [2025-03-20 22:56:41.890] Port ON [2025-03-20 22:56:45.919] Port OFF [2025-03-20 22:56:49.918] Port ON [2025-03-20 22:56:53.941] Port OFF [2025-03-20 22:56:57.948] Port ON [2025-03-20 22:57:01.952] Port OFF [2025-03-20 22:57:05.943] Port ON [2025-03-20 22:57:09.944] Port OFF [2025-03-20 22:57:13.949] Port ON [2025-03-20 22:57:17.953] Port OFF [2025-03-20 22:57:21.955] Port ON [2025-03-20 22:57:25.968] Port OFF [2025-03-20 22:57:29.962] Port ON [2025-03-20 22:57:33.961] Port OFF [2025-03-20 22:57:37.959] Port ON [2025-03-20 22:57:41.999] Port OFF [2025-03-20 22:57:46.000] Port ON [2025-03-20 22:57:50.005] Port OFF [2025-03-20 22:57:54.006] Port ON [2025-03-20 22:57:58.029] Port OFF [2025-03-20 22:58:02.048] Port ON [2025-03-20 22:58:06.058] Port OFF [2025-03-20 22:58:10.060] Port ON [2025-03-20 22:58:14.090] Port OFF [2025-03-20 22:58:18.088] Port ON [2025-03-20 22:58:22.093] Port OFF [2025-03-20 22:58:26.110] Port ON [2025-03-20 22:58:30.135] Port OFF [2025-03-20 22:58:34.142] Port ON [2025-03-20 22:58:38.148] Port OFF [2025-03-20 22:58:42.150] Port ON [2025-03-20 22:58:46.157] Port OFF [2025-03-20 22:58:50.167] Port ON [2025-03-20 22:58:54.172] Port OFF [2025-03-20 22:58:58.167] Port ON [2025-03-20 22:59:02.164] Port OFF [2025-03-20 22:59:06.175] Port ON [2025-03-20 22:59:10.190] Port OFF [2025-03-20 22:59:14.202] Port ON [2025-03-20 22:59:18.214] Port OFF [2025-03-20 22:59:22.212] Port ON [2025-03-20 22:59:26.220] Port OFF [2025-03-20 22:59:30.220] Port ON [2025-03-20 22:59:34.235] Port OFF [2025-03-20 22:59:38.243] Port ON [2025-03-20 22:59:42.249] Port OFF [2025-03-20 22:59:46.263] Port ON [2025-03-20 22:59:50.271] Port OFF [2025-03-20 22:59:54.297] Port ON [2025-03-20 22:59:58.300] Port OFF [2025-03-20 23:00:02.308] Port ON [2025-03-20 23:00:06.306] Port OFF [2025-03-20 23:00:10.324] Port ON [2025-03-20 23:00:14.332] Port OFF [2025-03-20 23:00:18.338] Port ON [2025-03-20 23:00:22.334] Port OFF [2025-03-20 23:00:26.345] Port ON [2025-03-20 23:00:30.338] Port OFF [2025-03-20 23:00:34.332] Port ON [2025-03-20 23:00:38.333] Port OFF [2025-03-20 23:00:42.347] Port ON [2025-03-20 23:00:46.374] Port OFF [2025-03-20 23:00:50.377] Port ON [2025-03-20 23:00:54.385] Port OFF [2025-03-20 23:00:58.384] Port ON [2025-03-20 23:01:02.384] Port OFF [2025-03-20 23:01:06.403] Port ON [2025-03-20 23:01:10.406] Port OFF [2025-03-20 23:01:14.417] Port ON [2025-03-20 23:01:18.418] Port OFF [2025-03-20 23:01:22.413] Port ON [2025-03-20 23:01:26.414] Port OFF [2025-03-20 23:01:30.415] Port ON [2025-03-20 23:01:34.427] Port OFF [2025-03-20 23:01:38.428] Port ON [2025-03-20 23:01:42.437] Port OFF [2025-03-20 23:01:46.436] Port ON [2025-03-20 23:01:50.426] Port OFF [2025-03-20 23:01:54.430] Port ON [2025-03-20 23:01:58.436] Port OFF [2025-03-20 23:02:02.426] Port ON [2025-03-20 23:02:06.433] Port OFF [2025-03-20 23:02:10.433] Port ON [2025-03-20 23:02:14.437] Port OFF [2025-03-20 23:02:18.449] Port ON [2025-03-20 23:02:22.445] Port OFF [2025-03-20 23:02:26.448] Port ON [2025-03-20 23:02:30.450] Port OFF [2025-03-20 23:02:34.456] Port ON [2025-03-20 23:02:38.463] Port OFF [2025-03-20 23:02:42.469] Port ON [2025-03-20 23:02:46.493] Port OFF [2025-03-20 23:02:50.493] Port ON [2025-03-20 23:02:54.490] Port OFF [2025-03-20 23:02:58.497] Port ON [2025-03-20 23:03:02.492] Port OFF [2025-03-20 23:03:06.502] Port ON [2025-03-20 23:03:10.512] Port OFF [2025-03-20 23:03:14.513] Port ON [2025-03-20 23:03:18.506] Port OFF [2025-03-20 23:03:22.531] Port ON [2025-03-20 23:03:26.538] Port OFF [2025-03-20 23:03:30.545] Port ON [2025-03-20 23:03:34.554] Port OFF [2025-03-20 23:03:38.553] Port ON [2025-03-20 23:03:42.568] Port OFF [2025-03-20 23:03:46.578] Port ON [2025-03-20 23:03:50.582] Port OFF [2025-03-20 23:03:54.597] Port ON [2025-03-20 23:03:58.626] Port OFF [2025-03-20 23:04:02.654] Port ON [2025-03-20 23:04:06.645] Port OFF [2025-03-20 23:04:10.656] Port ON [2025-03-20 23:04:14.649] Port OFF [2025-03-20 23:04:18.673] Port ON [2025-03-20 23:04:22.675] Port OFF [2025-03-20 23:04:26.684] Port ON [2025-03-20 23:04:30.685] Port OFF [2025-03-20 23:04:34.679] Port ON [2025-03-20 23:04:38.687] Port OFF [2025-03-20 23:04:42.689] Port ON [2025-03-20 23:04:46.704] Port OFF [2025-03-20 23:04:50.715] Port ON [2025-03-20 23:04:54.711] Port OFF [2025-03-20 23:04:58.712] Port ON [2025-03-20 23:05:02.712] Port OFF [2025-03-20 23:05:06.727] Port ON [2025-03-20 23:05:10.736] Port OFF [2025-03-20 23:05:14.742] Port ON [2025-03-20 23:05:18.740] Port OFF [2025-03-20 23:05:22.742] Port ON [2025-03-20 23:05:26.739] Port OFF [2025-03-20 23:05:30.741] Port ON [2025-03-20 23:05:34.753] Port OFF [2025-03-20 23:05:38.779] Port ON [2025-03-20 23:05:42.774] Port OFF [2025-03-20 23:05:46.773] Port ON [2025-03-20 23:05:50.792] Port OFF [2025-03-20 23:05:54.799] Port ON [2025-03-20 23:05:58.811] Port OFF [2025-03-20 23:06:02.825] Port ON [2025-03-20 23:06:06.821] Port OFF [2025-03-20 23:06:10.824] Port ON [2025-03-20 23:06:14.819] Port OFF [2025-03-20 23:06:18.823] Port ON [2025-03-20 23:06:22.831] Port OFF [2025-03-20 23:06:26.845] Port ON [2025-03-20 23:06:30.873] Port OFF [2025-03-20 23:06:34.906] Port ON [2025-03-20 23:06:38.901] Port OFF [2025-03-20 23:06:42.910] Port ON [2025-03-20 23:06:46.917] Port OFF [2025-03-20 23:06:50.925] Port ON [2025-03-20 23:06:54.930] Port OFF [2025-03-20 23:06:58.938] Port ON [2025-03-20 23:07:02.939] Port OFF [2025-03-20 23:07:06.949] Port ON [2025-03-20 23:07:10.948] Port OFF [2025-03-20 23:07:14.947] Port ON [2025-03-20 23:07:18.954] Port OFF [2025-03-20 23:07:22.958] Port ON [2025-03-20 23:07:26.970] Port OFF [2025-03-20 23:07:30.975] Port ON [2025-03-20 23:07:34.973] Port OFF [2025-03-20 23:07:38.978] Port ON [2025-03-20 23:07:42.978] Port OFF [2025-03-20 23:07:46.982] Port ON [2025-03-20 23:07:50.980] Port OFF [2025-03-20 23:07:54.979] Port ON [2025-03-20 23:07:58.976] Port OFF [2025-03-20 23:08:02.980] Port ON [2025-03-20 23:08:06.977] Port OFF [2025-03-20 23:08:10.973] Port ON [2025-03-20 23:08:14.978] Port OFF [2025-03-20 23:08:18.981] Port ON [2025-03-20 23:08:22.973] Port OFF [2025-03-20 23:08:26.978] Port ON [2025-03-20 23:08:30.977] Port OFF [2025-03-20 23:08:34.978] Port ON [2025-03-20 23:08:38.977] Port OFF [2025-03-20 23:08:42.982] Port ON [2025-03-20 23:08:46.982] Port OFF [2025-03-20 23:08:50.986] Port ON [2025-03-20 23:08:54.975] Port OFF [2025-03-20 23:08:58.975] Port ON [2025-03-20 23:09:02.976] Port OFF [2025-03-20 23:09:06.978] Port ON [2025-03-20 23:09:10.977] Port OFF [2025-03-20 23:09:14.999] Port ON [2025-03-20 23:09:18.992] Port OFF [2025-03-20 23:09:23.001] Port ON [2025-03-20 23:09:26.988] Port OFF [2025-03-20 23:09:30.987] Port ON [2025-03-20 23:09:34.992] Port OFF [2025-03-20 23:09:38.998] Port ON [2025-03-20 23:09:43.010] Port OFF [2025-03-20 23:09:47.008] Port ON [2025-03-20 23:09:51.032] Port OFF [2025-03-20 23:09:55.023] Port ON [2025-03-20 23:09:59.020] Port OFF [2025-03-20 23:10:03.027] Port ON [2025-03-20 23:10:07.028] Port OFF [2025-03-20 23:10:11.036] Port ON [2025-03-20 23:10:15.045] Port OFF [2025-03-20 23:10:19.036] Port ON [2025-03-20 23:10:23.036] Port OFF [2025-03-20 23:10:27.042] Port ON [2025-03-20 23:10:31.035] Port OFF [2025-03-20 23:10:35.048] Port ON [2025-03-20 23:10:39.041] Port OFF [2025-03-20 23:10:43.039] Port ON [2025-03-20 23:10:47.040] Port OFF [2025-03-20 23:10:51.039] Port ON [2025-03-20 23:10:55.043] Port OFF [2025-03-20 23:10:59.038] Port ON [2025-03-20 23:11:03.035] Port OFF [2025-03-20 23:11:07.039] Port ON [2025-03-20 23:11:11.045] Port OFF [2025-03-20 23:11:15.039] Port ON [2025-03-20 23:11:19.037] Port OFF [2025-03-20 23:11:23.047] Port ON [2025-03-20 23:11:27.045] Port OFF [2025-03-20 23:11:31.040] Port ON [2025-03-20 23:11:35.050] Port OFF [2025-03-20 23:11:39.039] Port ON [2025-03-20 23:11:43.044] Port OFF [2025-03-20 23:11:47.050] Port ON [2025-03-20 23:11:51.043] Port OFF [2025-03-20 23:11:55.045] Port ON [2025-03-20 23:11:59.045] Port OFF [2025-03-20 23:12:03.042] Port ON [2025-03-20 23:12:07.049] Port OFF [2025-03-20 23:12:11.062] Port ON [2025-03-20 23:12:15.062] Port OFF [2025-03-20 23:12:19.058] Port ON [2025-03-20 23:12:23.062] Port OFF [2025-03-20 23:12:27.058] Port ON [2025-03-20 23:12:31.064] Port OFF [2025-03-20 23:12:35.070] Port ON [2025-03-20 23:12:39.085] Port OFF [2025-03-20 23:12:43.089] Port ON [2025-03-20 23:12:47.097] Port OFF [2025-03-20 23:12:51.104] Port ON [2025-03-20 23:12:55.107] Port OFF [2025-03-20 23:12:59.105] Port ON [2025-03-20 23:13:03.102] Port OFF [2025-03-20 23:13:07.123] Port ON [2025-03-20 23:13:11.122] Port OFF [2025-03-20 23:13:15.131] Port ON [2025-03-20 23:13:19.143] Port OFF [2025-03-20 23:13:23.158] Port ON [2025-03-20 23:13:27.178] Port OFF [2025-03-20 23:13:31.210] Port ON [2025-03-20 23:13:35.232] Port OFF [2025-03-20 23:13:39.236] Port ON [2025-03-20 23:13:43.231] Port OFF [2025-03-20 23:13:47.239] Port ON [2025-03-20 23:13:51.250] Port OFF [2025-03-20 23:13:55.247] Port ON [2025-03-20 23:13:59.253] Port OFF [2025-03-20 23:14:03.248] Port ON [2025-03-20 23:14:07.245] Port OFF [2025-03-20 23:14:11.249] Port ON [2025-03-20 23:14:15.257] Port OFF [2025-03-20 23:14:19.271] Port ON [2025-03-20 23:14:23.260] Port OFF [2025-03-20 23:14:27.283] Port ON [2025-03-20 23:14:31.284] Port OFF [2025-03-20 23:14:35.279] Port ON [2025-03-20 23:14:39.294] Port OFF [2025-03-20 23:14:43.299] Port ON [2025-03-20 23:14:47.315] Port OFF [2025-03-20 23:14:51.319] Port ON [2025-03-20 23:14:55.358] Port OFF [2025-03-20 23:14:59.371] Port ON [2025-03-20 23:15:03.381] Port OFF [2025-03-20 23:15:07.374] Port ON [2025-03-20 23:15:11.379] Port OFF [2025-03-20 23:15:15.381] Port ON [2025-03-20 23:15:19.407] Port OFF [2025-03-20 23:15:23.418] Port ON [2025-03-20 23:15:27.431] Port OFF [2025-03-20 23:15:31.432] Port ON [2025-03-20 23:15:35.437] Port OFF [2025-03-20 23:15:39.443] Port ON [2025-03-20 23:15:43.439] Port OFF [2025-03-20 23:15:47.443] Port ON [2025-03-20 23:15:51.435] Port OFF [2025-03-20 23:15:55.458] Port ON [2025-03-20 23:15:59.455] Port OFF [2025-03-20 23:16:03.467] Port ON [2025-03-20 23:16:07.470] Port OFF [2025-03-20 23:16:11.479] Port ON [2025-03-20 23:16:15.500] Port OFF [2025-03-20 23:16:19.506] Port ON [2025-03-20 23:16:23.501] Port OFF [2025-03-20 23:16:27.506] Port ON [2025-03-20 23:16:31.511] Port OFF [2025-03-20 23:16:35.526] Port ON [2025-03-20 23:16:39.543] Port OFF [2025-03-20 23:16:43.555] Port ON [2025-03-20 23:16:47.552] Port OFF [2025-03-20 23:16:51.561] Port ON [2025-03-20 23:16:55.564] Port OFF [2025-03-20 23:16:59.585] Port ON [2025-03-20 23:17:03.590] Port OFF [2025-03-20 23:17:07.593] Port ON [2025-03-20 23:17:11.601] Port OFF [2025-03-20 23:17:15.611] Port ON [2025-03-20 23:17:19.612] Port OFF [2025-03-20 23:17:23.615] Port ON [2025-03-20 23:17:27.624] Port OFF [2025-03-20 23:17:31.627] Port ON [2025-03-20 23:17:35.639] Port OFF [2025-03-20 23:17:39.653] Port ON [2025-03-20 23:17:43.645] Port OFF [2025-03-20 23:17:47.666] Port ON [2025-03-20 23:17:51.675] Port OFF [2025-03-20 23:17:55.680] Port ON [2025-03-20 23:17:59.679] Port OFF [2025-03-20 23:18:03.681] Port ON [2025-03-20 23:18:07.674] Port OFF [2025-03-20 23:18:11.682] Port ON [2025-03-20 23:18:15.674] Port OFF [2025-03-20 23:18:19.688] Port ON [2025-03-20 23:18:23.693] Port OFF [2025-03-20 23:18:27.698] Port ON [2025-03-20 23:18:31.722] Port OFF [2025-03-20 23:18:35.725] Port ON [2025-03-20 23:18:39.747] Port OFF [2025-03-20 23:18:43.759] Port ON [2025-03-20 23:18:47.753] Port OFF [2025-03-20 23:18:51.757] Port ON [2025-03-20 23:18:55.761] Port OFF [2025-03-20 23:18:59.783] Port ON [2025-03-20 23:19:03.795] Port OFF [2025-03-20 23:19:07.802] Port ON [2025-03-20 23:19:11.798] Port OFF [2025-03-20 23:19:15.800] Port ON [2025-03-20 23:19:19.804] Port OFF [2025-03-20 23:19:23.816] Port ON [2025-03-20 23:19:27.827] Port OFF [2025-03-20 23:19:31.831] Port ON [2025-03-20 23:19:35.836] Port OFF [2025-03-20 23:19:39.842] Port ON [2025-03-20 23:19:43.832] Port OFF [2025-03-20 23:19:47.840] Port ON [2025-03-20 23:19:51.851] Port OFF [2025-03-20 23:19:55.863] Port ON [2025-03-20 23:19:59.865] Port OFF [2025-03-20 23:20:03.872] Port ON [2025-03-20 23:20:07.884] Port OFF [2025-03-20 23:20:11.891] Port ON [2025-03-20 23:20:15.894] Port OFF [2025-03-20 23:20:19.922] Port ON [2025-03-20 23:20:23.929] Port OFF [2025-03-20 23:20:27.939] Port ON [2025-03-20 23:20:31.944] Port OFF [2025-03-20 23:20:35.951] Port ON [2025-03-20 23:20:39.963] Port OFF [2025-03-20 23:20:43.973] Port ON [2025-03-20 23:20:47.973] Port OFF [2025-03-20 23:20:51.982] Port ON [2025-03-20 23:20:55.993] Port OFF [2025-03-20 23:20:59.992] Port ON [2025-03-20 23:21:03.990] Port OFF [2025-03-20 23:21:07.995] Port ON [2025-03-20 23:21:11.996] Port OFF [2025-03-20 23:21:15.992] Port ON [2025-03-20 23:21:19.990] Port OFF [2025-03-20 23:21:23.988] Port ON [2025-03-20 23:21:27.993] Port OFF [2025-03-20 23:21:32.001] Port ON [2025-03-20 23:21:36.009] Port OFF [2025-03-20 23:21:40.017] Port ON [2025-03-20 23:21:44.070] Port OFF [2025-03-20 23:21:48.069] Port ON [2025-03-20 23:21:52.072] Port OFF [2025-03-20 23:21:56.088] Port ON [2025-03-20 23:22:00.084] Port OFF [2025-03-20 23:22:04.088] Port ON [2025-03-20 23:22:08.092] Port OFF [2025-03-20 23:22:12.101] Port ON [2025-03-20 23:22:16.101] Port OFF [2025-03-20 23:22:20.105] Port ON [2025-03-20 23:22:24.120] Port OFF [2025-03-20 23:22:28.124] Port ON [2025-03-20 23:22:32.131] Port OFF [2025-03-20 23:22:36.141] Port ON [2025-03-20 23:22:40.158] Port OFF [2025-03-20 23:22:44.169] Port ON [2025-03-20 23:22:48.172] Port OFF [2025-03-20 23:22:52.189] Port ON [2025-03-20 23:22:56.210] Port OFF [2025-03-20 23:23:00.221] Port ON [2025-03-20 23:23:04.230] Port OFF [2025-03-20 23:23:08.226] Port ON [2025-03-20 23:23:12.226] Port OFF [2025-03-20 23:23:16.234] Port ON [2025-03-20 23:23:20.228] Port OFF [2025-03-20 23:23:24.246] Port ON [2025-03-20 23:23:28.248] Port OFF [2025-03-20 23:23:32.248] Port ON [2025-03-20 23:23:36.245] Port OFF [2025-03-20 23:23:40.239] Port ON [2025-03-20 23:23:44.251] Port OFF [2025-03-20 23:23:48.264] Port ON [2025-03-20 23:23:52.264] Port OFF [2025-03-20 23:23:56.281] Port ON [2025-03-20 23:24:00.276] Port OFF [2025-03-20 23:24:04.279] Port ON [2025-03-20 23:24:08.284] Port OFF [2025-03-20 23:24:08.290] Loop Mode Completed [2025-03-20 23:24:08.298] Loop Mode Stopped!
Linux Kernel Logs:usb_test.txt
Conclusion:
There was no failures.
The Host USB driver did not die.
From this test it can be concluded that USB host in AM571x should be capable of being stress tested past the customers 400 cycle test as long as the USB connection complies with USB-IF spec.
Josue
Hello Liying
please provide a complete schematics to be reviewed by TI,
and give feedback about the works after TI comments
semon
Hello Josue
please find the schematic from Sungrow:
USB device end
A15 Host end
Sungrow have following doubts:
1. when Sungrow AM5716 USB works in host mode, D+/D- signal has pull-down resistance connected, so D+/D- signal is stable, so Sungrow engineer
can not understand why their AM5716 host USB can't work properly, what's the real reason?
previous TI comments said
"this USB scenario does not comply with USB specification The USB specification requires the USB device DP/DM lines should be powered
this could confuse the USB host. Since it doesn't seems be a valid USB use case"
if this protocol specification words can be shared?
2. as TI said previously, the remote end USB device may be in floating state during MCU board reboot, Sungrow engineer measure the D+/D- signal,
it's always low voltage level in the duration, now add the pull-down resistance, it doesn't work, this issue happened yet
please review the provided schematic and the qustions from Sungrow, and give comments about Sungrow's question
Semon
Semon,
I have reassigned this thread to our HW team for further comment. TI's recommendations for USB have been documented in the following App note:
as well as the recommendations on proper USB signal connection and routing, see the High-Speed Interface Layout Guidelines.
Design options beyond our recommendations are not supported by TI.
Josue
Hello shreyas
any comments about the customer USB HW design? please review customer design and give comments, this is a urgent issue.
customer has following question:
1. can AM5716 turn on/turn off USB host through AM5716 PRCM module, how to congure it, and which register can be used to do this?
2. for USB connection, in customer design, DRVVBUS is not connected, but this will not affect anything, for DRVVBUS is used to control output to the outside,
even DRVVBUS is enabled always, there should be OK, so what the real reason of the customer design and cause this issue?
Semon
Semon,
Adding series resistors on DP/DM lines and external pullup or pulldown resistors is not recommended as per USB spec.
I do not know about the PRCM module configuration but wanted to know why the customer is asking for the register to control the USB host.
As per my understanding, the Host VBUS is powered, and when a device attaches, then the USB host will detect and enable the DRVBUS which enables the power switch to connect the Vbus to the device and initiate the USB handshake protocol.
It seems that the MCU connect/disconnect is somehow not enabling this sequence. i.e the s/w at some point is not able to determine the device is present/ or unable to determine its host role and enable the DRVBUS/ power the VBUS to the device.
For reference, the MCCI exerciser mimics the connect/ disconnect according to the USB spec. The MCU exercise that you have performed may not be enabling this according to the USB spec.
ShreyasRao
Sungrow want the review result of the USB schematic, the schematic is attached above, could you help give a conclusion?
uusb:
2:
host:
Semon,
The hardwire connection through the connectors will not likely be 90ohms differential as required by the USB spec either. Please refer to the above reply for additional info on the issue.
Follow up from Customer meeting:
Semon,
Our recommendation to customer is to follow USB-IF spec for TI to support software behavior/bugs.
The bug from this issue is directly related to the physical design of the connection and the host/device interaction. There are many online resources that can help customer achieve the desired outcome. Key point from meeting are:
We do not think a SW bug exists given that the experiment above did not produce any errors.
The PRCM-Reset WA that the customer is chasing is also in my opinion not a viable option given the dependencies involved and consequently the undetermined SW behavior thereof.
Notes from meeting:
RST line is also the MMC reset
Only allowed when Ethernet is not being used
Customer can attempt this using direct register writes, i.e. using omapconf, but we are not sure that this will work or not, nor do we have a way to test.
-Josue
hello Josue
from the feedback of Sungrow:
1. there has no change to the USB driver of TI SDK, so there is difference between TI sdk and Sungrow system,
2. customer is trying to verify ID pin and VBUS pin according to suggested change, but there is no clear description how to connect vbus,
from TRM, there is a diagram to describe such connection,
is this to be used as reference>
Semon,
See other answer:
-Josue
Hi Semon,
The host provides the Vbus and when the Vbus is detected by the device, it is used to pull the DP/DM lines high and start the enumeration.
Just to reconfirm again,
* The MCU is HS capable,
* You are doing a soft reset/reboot on the MCU/ SoC with the power supply still on. (s/w vs h/w reset)
Can you monitor the DP/DM and the Vbus line when the issue happens?
- connector ID has to be grounded
- VBUS has to be involved in some way in order for USB host to work properly
Hello Josue
customer already connect VBUS and ID as suggested, they have completed a long times test,
after over 1000 times MCU reboot test, this issue is triggered again,
see following log:
customer will do more test,
any suggestion here?
Semon
Can you please confirm?
Hello Shreyas
the following is customer USB HW connection after your suggestion.
1. VBUS2 connect to USB device ARM 5V power
2. USB2-ID connect to ground
3. USB2_DRVVBUS if connected to power supply directly, system cant bring up,
so connected to the USB device ARM IO.
with above change, in one day test, this issue is re-produced one time, but with lower frequency.
customer is trying do more test
Semon
HI Liying
this issue seems to be a bug in Linux system, this link reports a similar case.
xHCI host controller not responding, assume dead / Kernel & Hardware / Arch Linux Forums
after the issue happened, following operation can recover USB system:
echo -n "0000:00:14.0" | tee /sys/bus/pci/drivers/xhci_hcd/unbind
sleep 5
echo -n "0000:00:14.0" | tee /sys/bus/pci/drivers/xhci_hcd/bind
also there has suggestion to disable usb autosuspend by following kernel parameter
usbcore.autosuspend=-1
Semon
USB_DRVBUS is a digital output signal that controls the Vbus supply to the device when in host mode. Otherwise, it will be turned low.
1000 times reboot cycle is significantly over-above a normal use case would be.
Hello Shreyas
Sungrow executed another test from last Wednesday to Saturday, this issue happened again after 1000 times reboot cycle test?
Semon
Hello Josue/Shreyas
customer re-produce this issue two times again recently:
1. occurred after 1000 times reboot test,
2. occurred after 54 times reboot test.
so this issue is not fixed, even the frequency is lower down, need further investigation, customer want this issue is to be fixed, or at least a solution to recover system after issue happened,
semon
Hi Josue, Shreyas
following command list is used to recover system when this issue happened, customer verified it can work after issue happened by manual,
customer will integrate it into their code system and test it again, if ok, then this issue maybe closed
rmmod uas
rmmod usb_storage
rmmod ftdi_sio
rmmod usbserial
rmmod xhci_plat_hcd
rmmod xhci_hcd
rmmod usbcore
------------------------insert---------------
root@am57xx-evm:/# insmod ./lib/modules/4.19.94-gbe5389fd85/kernel/drivers/usb/host/xhci-plat-hcd.ko
[ 4801.779830] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 4801.785620] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
Semon
Semon,
This is good to know. Is this sequence documented on the TRM that you had to follow or found elsewhere?
Please let us know the progress.
Semon,
Nice work-around, This could be simplified using modprobe I think.
See modprobe -r in https://linux.die.net/man/8/modprobe.
Glad you were able to find this WA for the customer.
-Josue
Glad to know that the issue is resolved, great resolve to close this down, Semon.
Josue, Semon,
It will be good to have this documented internally for benefit of others who might have the same issue on hand.
