AM62P: cadence-qspi probe failure
Part Number: AM62P
working on a custom board based on TI AM62P processor, and the cadence-qspi probe fails.
[   18.147644] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
[   18.155721] platform fc40000.spi: deferred probe pending
root@verdin-am62p-15664920:~# cat /sys/kernel/debug/devices_deferred
fc40000.spi	cadence-qspi: No Rx DMA available
Complete kernel logs:
kern  :info  : [    0.000000 <    0.000000>] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
kern  :notice: [    0.000000 <    0.000000>] Linux version 6.6.58-7.2.0-devel-g9d7c5d371546 (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Fri Feb 28 16:55:00 UTC 2025
kern  :warn  : [    0.000000 <    0.000000>] KASLR disabled due to lack of seed
kern  :info  : [    0.000000 <    0.000000>] Machine model: Toradex Verdin AM62P WB on Verdin Development Board
kern  :info  : [    0.000000 <    0.000000>] efi: UEFI not found.
kern  :info  : [    0.000000 <    0.000000>] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
kern  :info  : [    0.000000 <    0.000000>] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
kern  :info  : [    0.000000 <    0.000000>] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
kern  :info  : [    0.000000 <    0.000000>] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000
kern  :info  : [    0.000000 <    0.000000>] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
kern  :info  : [    0.000000 <    0.000000>] Zone ranges:
kern  :info  : [    0.000000 <    0.000000>]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
kern  :info  : [    0.000000 <    0.000000>]   DMA32    empty
kern  :info  : [    0.000000 <    0.000000>]   Normal   empty
kern  :info  : [    0.000000 <    0.000000>] Movable zone start for each node
kern  :info  : [    0.000000 <    0.000000>] Early memory node ranges
kern  :info  : [    0.000000 <    0.000000>]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
kern  :info  : [    0.000000 <    0.000000>]   node   0: [mem 0x0000000080080000-0x000000009c8fffff]
kern  :info  : [    0.000000 <    0.000000>]   node   0: [mem 0x000000009c900000-0x000000009e6fffff]
kern  :info  : [    0.000000 <    0.000000>]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
kern  :info  : [    0.000000 <    0.000000>]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
kern  :info  : [    0.000000 <    0.000000>]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
kern  :info  : [    0.000000 <    0.000000>] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
kern  :info  : [    0.000000 <    0.000000>] cma: Reserved 410 MiB at 0x00000000e3400000 on node -1
kern  :info  : [    0.000000 <    0.000000>] psci: probing for conduit method from DT.
kern  :info  : [    0.000000 <    0.000000>] psci: PSCIv1.1 detected in firmware.
kern  :info  : [    0.000000 <    0.000000>] psci: Using standard PSCI v0.2 function IDs
kern  :info  : [    0.000000 <    0.000000>] psci: Trusted OS migration not required
kern  :info  : [    0.000000 <    0.000000>] psci: SMC Calling Convention v1.5
kern  :info  : [    0.000000 <    0.000000>] percpu: Embedded 20 pages/cpu s42792 r8192 d30936 u81920
kern  :debug : [    0.000000 <    0.000000>] pcpu-alloc: s42792 r8192 d30936 u81920 alloc=20*4096
kern  :debug : [    0.000000 <    0.000000>] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
kern  :info  : [    0.000000 <    0.000000>] Detected VIPT I-cache on CPU0
kern  :info  : [    0.000000 <    0.000000>] CPU features: detected: GIC system register CPU interface
kern  :info  : [    0.000000 <    0.000000>] alternatives: applying boot alternatives
kern  :notice: [    0.000000 <    0.000000>] Kernel command line: root=PARTUUID=fd47d490-02 ro rootwait console=tty1 console=ttyS2,115200
kern  :info  : [    0.000000 <    0.000000>] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
kern  :info  : [    0.000000 <    0.000000>] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
kern  :info  : [    0.000000 <    0.000000>] Built 1 zonelists, mobility grouping on.  Total pages: 516096
kern  :info  : [    0.000000 <    0.000000>] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
kern  :info  : [    0.000000 <    0.000000>] software IO TLB: area num 4.
kern  :info  : [    0.000000 <    0.000000>] software IO TLB: mapped [mem 0x00000000df400000-0x00000000e3400000] (64MB)
kern  :info  : [    0.000000 <    0.000000>] Memory: 1495488K/2097152K available (11264K kernel code, 1222K rwdata, 3496K rodata, 2496K init, 458K bss, 181824K reserved, 419840K cma-reserved)
kern  :info  : [    0.000000 <    0.000000>] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
kern  :info  : [    0.000000 <    0.000000>] rcu: Preemptible hierarchical RCU implementation.
kern  :info  : [    0.000000 <    0.000000>] rcu: 	RCU event tracing is enabled.
kern  :info  : [    0.000000 <    0.000000>] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
kern  :info  : [    0.000000 <    0.000000>] 	Trampoline variant of Tasks RCU enabled.
kern  :info  : [    0.000000 <    0.000000>] 	Tracing variant of Tasks RCU enabled.
kern  :info  : [    0.000000 <    0.000000>] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
kern  :info  : [    0.000000 <    0.000000>] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
kern  :info  : [    0.000000 <    0.000000>] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
kern  :info  : [    0.000000 <    0.000000>] GICv3: GIC: Using split EOI/Deactivate mode
kern  :info  : [    0.000000 <    0.000000>] GICv3: 256 SPIs implemented
kern  :info  : [    0.000000 <    0.000000>] GICv3: 0 Extended SPIs implemented
kern  :info  : [    0.000000 <    0.000000>] Root IRQ handler: gic_handle_irq
kern  :info  : [    0.000000 <    0.000000>] GICv3: GICv3 features: 16 PPIs
kern  :info  : [    0.000000 <    0.000000>] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
kern  :info  : [    0.000000 <    0.000000>] ITS [mem 0x01820000-0x0182ffff]
kern  :info  : [    0.000000 <    0.000000>] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
kern  :warn  : [    0.000000 <    0.000000>] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
kern  :info  : [    0.000000 <    0.000000>] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
kern  :info  : [    0.000000 <    0.000000>] ITS: using cache flushing for cmd queue
kern  :info  : [    0.000000 <    0.000000>] GICv3: using LPI property table @0x0000000080440000
kern  :info  : [    0.000000 <    0.000000>] GIC: using cache flushing for LPI property table
kern  :info  : [    0.000000 <    0.000000>] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000
kern  :info  : [    0.000000 <    0.000000>] rcu: srcu_init: Setting srcu_struct sizes based on contention.
kern  :info  : [    0.000000 <    0.000000>] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
kern  :info  : [    0.000000 <    0.000000>] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
kern  :info  : [    0.000000 <    0.000000>] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
kern  :info  : [    0.000420 <    0.000000>] Console: colour dummy device 80x25
kern  :info  : [    0.000430 <    0.000010>] printk: console [tty1] enabled
kern  :info  : [    0.000953 <    0.000523>] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
kern  :info  : [    0.000976 <    0.000023>] pid_max: default: 32768 minimum: 301
kern  :info  : [    0.001139 <    0.000163>] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
kern  :info  : [    0.001162 <    0.000023>] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
kern  :info  : [    0.002821 <    0.001659>] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
kern  :info  : [    0.002905 <    0.000084>] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
kern  :info  : [    0.003087 <    0.000182>] rcu: Hierarchical SRCU implementation.
kern  :info  : [    0.003099 <    0.000012>] rcu: 	Max phase no-delay instances is 1000.
kern  :info  : [    0.003775 <    0.000676>] Platform MSI: msi-controller@1820000 domain created
kern  :info  : [    0.004108 <    0.000333>] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
kern  :info  : [    0.004219 <    0.000111>] EFI services will not be available.
kern  :info  : [    0.004538 <    0.000319>] smp: Bringing up secondary CPUs ...
kern  :info  : [    0.005131 <    0.000593>] Detected VIPT I-cache on CPU1
kern  :info  : [    0.005199 <    0.000068>] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
kern  :info  : [    0.005214 <    0.000015>] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
kern  :info  : [    0.005263 <    0.000049>] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
kern  :info  : [    0.005909 <    0.000646>] Detected VIPT I-cache on CPU2
kern  :info  : [    0.005961 <    0.000052>] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
kern  :info  : [    0.005974 <    0.000013>] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000
kern  :info  : [    0.006006 <    0.000032>] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
kern  :info  : [    0.006579 <    0.000573>] Detected VIPT I-cache on CPU3
kern  :info  : [    0.006629 <    0.000050>] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
kern  :info  : [    0.006640 <    0.000011>] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000
kern  :info  : [    0.006669 <    0.000029>] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
kern  :info  : [    0.006742 <    0.000073>] smp: Brought up 1 node, 4 CPUs
kern  :info  : [    0.006849 <    0.000107>] SMP: Total of 4 processors activated.
kern  :info  : [    0.006860 <    0.000011>] CPU features: detected: 32-bit EL0 Support
kern  :info  : [    0.006870 <    0.000010>] CPU features: detected: CRC32 instructions
kern  :info  : [    0.006941 <    0.000071>] CPU: All CPU(s) started at EL2
kern  :info  : [    0.006951 <    0.000010>] alternatives: applying system-wide alternatives
kern  :info  : [    0.008564 <    0.001613>] devtmpfs: initialized
kern  :info  : [    0.017527 <    0.008963>] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
kern  :info  : [    0.017578 <    0.000051>] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
kern  :info  : [    0.028572 <    0.010994>] pinctrl core: initialized pinctrl subsystem
kern  :info  : [    0.029232 <    0.000660>] DMI not present or invalid.
kern  :info  : [    0.029881 <    0.000649>] NET: Registered PF_NETLINK/PF_ROUTE protocol family
kern  :info  : [    0.030710 <    0.000829>] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
kern  :info  : [    0.030825 <    0.000115>] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
kern  :info  : [    0.030952 <    0.000127>] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
kern  :info  : [    0.031444 <    0.000492>] thermal_sys: Registered thermal governor 'step_wise'
kern  :info  : [    0.031450 <    0.000006>] thermal_sys: Registered thermal governor 'user_space'
kern  :info  : [    0.031463 <    0.000013>] thermal_sys: Registered thermal governor 'power_allocator'
kern  :info  : [    0.031506 <    0.000043>] cpuidle: using governor menu
kern  :info  : [    0.031631 <    0.000125>] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
kern  :info  : [    0.031727 <    0.000096>] ASID allocator initialised with 65536 entries
kern  :info  : [    0.038974 <    0.007247>] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
kern  :info  : [    0.039342 <    0.000368>] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0
kern  :info  : [    0.039379 <    0.000037>] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1
kern  :info  : [    0.039418 <    0.000039>] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
kern  :info  : [    0.039452 <    0.000034>] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /panel-lvds-mez
kern  :info  : [    0.039565 <    0.000113>] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
kern  :info  : [    0.039604 <    0.000039>] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /panel-lvds-mez
kern  :info  : [    0.050309 <    0.010705>] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0
kern  :info  : [    0.050370 <    0.000061>] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1
kern  :info  : [    0.050416 <    0.000046>] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
kern  :info  : [    0.050456 <    0.000040>] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /panel-lvds-mez
kern  :info  : [    0.050543 <    0.000087>] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
kern  :info  : [    0.050586 <    0.000043>] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /panel-lvds-mez
kern  :info  : [    0.051102 <    0.000516>] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /connector
kern  :info  : [    0.051178 <    0.000076>] /connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
kern  :info  : [    0.052823 <    0.001645>] Modules: 27984 pages in range for non-PLT usage
kern  :info  : [    0.052833 <    0.000010>] Modules: 519504 pages in range for PLT usage
kern  :info  : [    0.053518 <    0.000685>] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
kern  :info  : [    0.053549 <    0.000031>] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
kern  :info  : [    0.053562 <    0.000013>] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
kern  :info  : [    0.053572 <    0.000010>] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
kern  :info  : [    0.053584 <    0.000012>] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
kern  :info  : [    0.053595 <    0.000011>] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
kern  :info  : [    0.053607 <    0.000012>] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
kern  :info  : [    0.053618 <    0.000011>] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
kern  :info  : [    0.055064 <    0.001446>] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
kern  :info  : [    0.055455 <    0.000391>] iommu: Default domain type: Translated
kern  :info  : [    0.055474 <    0.000019>] iommu: DMA domain TLB invalidation policy: strict mode
kern  :notice: [    0.055789 <    0.000315>] SCSI subsystem initialized
kern  :info  : [    0.055938 <    0.000149>] usbcore: registered new interface driver usbfs
kern  :info  : [    0.055973 <    0.000035>] usbcore: registered new interface driver hub
kern  :info  : [    0.056018 <    0.000045>] usbcore: registered new device driver usb
kern  :info  : [    0.056763 <    0.000745>] mc: Linux media interface: v0.10
kern  :info  : [    0.056810 <    0.000047>] videodev: Linux video capture interface: v2.00
kern  :info  : [    0.056841 <    0.000031>] pps_core: LinuxPPS API ver. 1 registered
kern  :info  : [    0.056852 <    0.000011>] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
kern  :info  : [    0.056874 <    0.000022>] PTP clock support registered
kern  :info  : [    0.057413 <    0.000539>] Advanced Linux Sound Architecture Driver Initialized.
kern  :info  : [    0.058726 <    0.001313>] clocksource: Switched to clocksource arch_sys_counter
kern  :info  : [    0.065325 <    0.006599>] NET: Registered PF_INET protocol family
kern  :info  : [    0.065511 <    0.000186>] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
kern  :info  : [    0.067142 <    0.001631>] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
kern  :info  : [    0.067224 <    0.000082>] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
kern  :info  : [    0.067248 <    0.000024>] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
kern  :info  : [    0.067368 <    0.000120>] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
kern  :info  : [    0.067796 <    0.000428>] TCP: Hash tables configured (established 16384 bind 16384)
kern  :info  : [    0.067929 <    0.000133>] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
kern  :info  : [    0.067994 <    0.000065>] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
kern  :info  : [    0.068179 <    0.000185>] NET: Registered PF_UNIX/PF_LOCAL protocol family
kern  :info  : [    0.068631 <    0.000452>] RPC: Registered named UNIX socket transport module.
kern  :info  : [    0.068653 <    0.000022>] RPC: Registered udp transport module.
kern  :info  : [    0.068663 <    0.000010>] RPC: Registered tcp transport module.
kern  :info  : [    0.068672 <    0.000009>] RPC: Registered tcp-with-tls transport module.
kern  :info  : [    0.068681 <    0.000009>] RPC: Registered tcp NFSv4.1 backchannel transport module.
kern  :info  : [    0.068703 <    0.000022>] PCI: CLS 0 bytes, default 64
kern  :notice: [    0.069808 <    0.001105>] Initialise system trusted keyrings
kern  :info  : [    0.070008 <    0.000200>] workingset: timestamp_bits=46 max_order=19 bucket_order=0
kern  :notice: [    0.070534 <    0.000526>] NFS: Registering the id_resolver key type
kern  :notice: [    0.070570 <    0.000036>] Key type id_resolver registered
kern  :notice: [    0.070581 <    0.000011>] Key type id_legacy registered
kern  :info  : [    0.070606 <    0.000025>] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
kern  :info  : [    0.070620 <    0.000014>] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
kern  :notice: [    0.070801 <    0.000181>] Key type asymmetric registered
kern  :notice: [    0.070814 <    0.000013>] Asymmetric key parser 'x509' registered
kern  :info  : [    0.070865 <    0.000051>] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
kern  :info  : [    0.070884 <    0.000019>] io scheduler mq-deadline registered
kern  :info  : [    0.070895 <    0.000011>] io scheduler kyber registered
kern  :info  : [    0.070930 <    0.000035>] io scheduler bfq registered
kern  :info  : [    0.074449 <    0.003519>] pinctrl-single 4084000.pinctrl: 34 pins, size 136
kern  :info  : [    0.075450 <    0.001001>] pinctrl-single f4000.pinctrl: 171 pins, size 684
kern  :info  : [    0.120160 <    0.044710>] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
kern  :info  : [    0.127544 <    0.007384>] usbcore: registered new interface driver usb-storage
kern  :info  : [    0.127785 <    0.000241>] i2c_dev: i2c /dev entries driver
kern  :info  : [    0.130197 <    0.002412>] sdhci: Secure Digital Host Controller Interface driver
kern  :info  : [    0.130223 <    0.000026>] sdhci: Copyright(c) Pierre Ossman
kern  :info  : [    0.130459 <    0.000236>] sdhci-pltfm: SDHCI platform and OF driver helper
kern  :info  : [    0.130992 <    0.000533>] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
kern  :info  : [    0.131419 <    0.000427>] usbcore: registered new interface driver usbhid
kern  :info  : [    0.131433 <    0.000014>] usbhid: USB HID core driver
kern  :info  : [    0.132788 <    0.001355>] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
kern  :info  : [    0.135162 <    0.002374>] NET: Registered PF_PACKET protocol family
kern  :notice: [    0.135264 <    0.000102>] Key type dns_resolver registered
kern  :notice: [    0.141239 <    0.005975>] Loading compiled-in X.509 certificates
kern  :info  : [    0.153619 <    0.012380>] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.2-v11.00.02 (Fancy Rat)')
kern  :info  : [    0.205193 <    0.051574>] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
kern  :info  : [    0.206364 <    0.001171>] /bus@f0000/bus@b00000/i2c@2b200000/pmic@30: Fixed dependency cycle(s) with /bus@f0000/bus@b00000/i2c@2b200000/pmic@30/regulators/buck2
kern  :info  : [    0.206416 <    0.000052>] /bus@f0000/bus@b00000/i2c@2b200000/pmic@30: Fixed dependency cycle(s) with /bus@f0000/bus@b00000/i2c@2b200000/pmic@30/regulators/buck1
kern  :warn  : [    0.234632 <    0.028216>] rtc-ds1307 0-0032: oscillator failed, set time!
kern  :info  : [    0.234898 <    0.000266>] rtc-ds1307 0-0032: registered as rtc0
kern  :err   : [    0.235197 <    0.000299>] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
kern  :warn  : [    0.235703 <    0.000506>] at24 0-0050: supply vcc not found, using dummy regulator
kern  :info  : [    0.236137 <    0.000434>] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
kern  :info  : [    0.236191 <    0.000054>] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
kern  :warn  : [    0.237909 <    0.001718>] at24 1-0057: supply vcc not found, using dummy regulator
kern  :err   : [    0.247072 <    0.009163>] tps65219 0-0030: Error IRQ trap residual voltage for LDO4
kern  :info  : [    0.259313 <    0.012241>] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
kern  :info  : [    0.259381 <    0.000068>] omap_i2c 20000000.i2c: bus 1 rev0.12 at 100 kHz
kern  :info  : [    0.260640 <    0.001259>] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz
kern  :info  : [    0.261600 <    0.000960>] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
kern  :info  : [    0.261865 <    0.000265>] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
kern  :info  : [    0.262030 <    0.000165>] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
kern  :info  : [    0.262263 <    0.000233>] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
kern  :info  : [    0.262527 <    0.000264>] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
kern  :info  : [    0.264172 <    0.001645>] ti-udma 485c0100.dma-controller: Number of rings: 82
kern  :info  : [    0.266680 <    0.002508>] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
kern  :info  : [    0.269494 <    0.002814>] ti-udma 485c0000.dma-controller: Number of rings: 150
kern  :info  : [    0.274181 <    0.004687>] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
kern  :info  : [    0.276395 <    0.002214>] ti-udma 4e230000.dma-controller: Number of rings: 6
kern  :info  : [    0.276966 <    0.000571>] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
kern  :info  : [    0.278751 <    0.001785>] 4a00000.serial: ttyS1 at MMIO 0x4a00000 (irq = 302, base_baud = 3000000) is a 8250
kern  :info  : [    0.280315 <    0.001564>] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 303, base_baud = 3000000) is a 8250
kern  :info  : [    0.280378 <    0.000063>] printk: console [ttyS2] enabled
kern  :info  : [    1.742376 <    1.461998>] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 304, base_baud = 3000000) is a 8250
kern  :err   : [    1.751784 <    0.009408>] omap8250 2860000.serial: failed to get alias
kern  :info  : [    1.798752 <    0.046968>] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
kern  :info  : [    1.807865 <    0.009113>] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
kern  :info  : [    1.820753 <    0.012888>] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
kern  :info  : [    1.827892 <    0.007139>] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
kern  :info  : [    1.834458 <    0.006566>] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
kern  :info  : [    1.848423 <    0.013965>] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
kern  :info  : [    1.861999 <    0.013576>] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
kern  :info  : [    1.874693 <    0.012694>] mmc0: CQHCI version 5.10
kern  :info  : [    1.874756 <    0.000063>] mmc2: CQHCI version 5.10
kern  :info  : [    1.914739 <    0.039983>] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
kern  :info  : [    1.919272 <    0.004533>] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
kern  :info  : [    1.926735 <    0.007463>] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
kern  :info  : [    1.945014 <    0.018279>] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
kern  :info  : [    1.953135 <    0.008121>] davinci_mdio 8000f00.mdio: phy[7]: device 8000f00.mdio:07, driver Microchip KSZ9131 Gigabit PHY
kern  :info  : [    1.964184 <    0.011049>] sdhci-am654 fa00000.mmc: Got CD GPIO
kern  :info  : [    1.966887 <    0.002703>] clk: Disabling unused clocks
kern  :info  : [    1.973072 <    0.006185>] mmc1: CQHCI version 5.10
kern  :info  : [    1.979171 <    0.006099>] ALSA device list:
kern  :info  : [    1.982154 <    0.002983>]   No soundcards found.
kern  :info  : [    1.985660 <    0.003506>] mmc2: new ultra high speed SDR104 SDIO card at address 0001
kern  :info  : [    2.030841 <    0.045181>] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
kern  :info  : [    2.038491 <    0.007650>] mmc0: Command Queue Engine enabled
kern  :info  : [    2.038751 <    0.000260>] Waiting for root device PARTUUID=fd47d490-02...
kern  :info  : [    2.042964 <    0.004213>] mmc0: new HS200 MMC card at address 0001
kern  :info  : [    2.054420 <    0.011456>] mmcblk0: mmc0:0001 S40016 14.6 GiB
kern  :info  : [    2.060563 <    0.006143>]  mmcblk0: p1 p2
kern  :info  : [    2.064012 <    0.003449>] mmcblk0boot0: mmc0:0001 S40016 4.00 MiB
kern  :info  : [    2.069712 <    0.005700>] mmcblk0boot1: mmc0:0001 S40016 4.00 MiB
kern  :info  : [    2.075359 <    0.005647>] mmcblk0rpmb: mmc0:0001 S40016 4.00 MiB, chardev (242:0)
kern  :info  : [    2.097935 <    0.022576>] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
kern  :info  : [    2.105299 <    0.007364>] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
kern  :info  : [    2.121733 <    0.016434>] EXT4-fs (mmcblk0p2): recovery complete
kern  :info  : [    2.127872 <    0.006139>] EXT4-fs (mmcblk0p2): mounted filesystem f09729b3-29df-4b34-8b8a-021fdbf270e3 ro with ordered data mode. Quota mode: disabled.
kern  :info  : [    2.140303 <    0.012431>] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
kern  :info  : [    2.149217 <    0.008914>] devtmpfs: mounted
kern  :info  : [    2.153048 <    0.003831>] Freeing unused kernel memory: 2496K
kern  :info  : [    2.157674 <    0.004626>] Run /sbin/init as init process
kern  :debug : [    2.161778 <    0.004104>]   with arguments:
kern  :debug : [    2.161785 <    0.000007>]     /sbin/init
kern  :debug : [    2.161791 <    0.000006>]   with environment:
kern  :debug : [    2.161796 <    0.000005>]     HOME=/
kern  :debug : [    2.161801 <    0.000005>]     TERM=linux
daemon:info  : [    2.293023 <    0.131222>] systemd[1]: System time before build time, advancing clock.
daemon:info  : [    2.315369 <    0.022346>] systemd[1]: Inserted module 'autofs4'
kern  :info  : [    2.346623 <    0.031254>] NET: Registered PF_INET6 protocol family
kern  :info  : [    2.352870 <    0.006247>] Segment Routing with IPv6
kern  :info  : [    2.356627 <    0.003757>] In-situ OAM (IOAM) with IPv6
daemon:info  : [    2.384660 <    0.028033>] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
daemon:info  : [    2.416768 <    0.032108>] systemd[1]: Detected architecture arm64.
daemon:info  : [    2.443361 <    0.026593>] systemd[1]: Hostname set to <verdin-am62p-15664920>.
daemon:info  : [    2.824452 <    0.381091>] systemd[1]: Queued start job for default target Graphical Interface.
daemon:info  : [    2.866530 <    0.042078>] systemd[1]: Created slice Slice /system/getty.
daemon:info  : [    2.888532 <    0.022002>] systemd[1]: Created slice Slice /system/modprobe.
daemon:info  : [    2.912585 <    0.024053>] systemd[1]: Created slice Slice /system/serial-getty.
daemon:info  : [    2.936617 <    0.024032>] systemd[1]: Created slice User and Session Slice.
daemon:info  : [    2.959258 <    0.022641>] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
daemon:info  : [    2.983239 <    0.023981>] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
daemon:info  : [    3.007060 <    0.023821>] systemd[1]: Expecting device /dev/ttyS2...
daemon:info  : [    3.023163 <    0.016103>] systemd[1]: Reached target Host and Network Name Lookups.
daemon:info  : [    3.047118 <    0.023955>] systemd[1]: Reached target Path Units.
daemon:info  : [    3.063022 <    0.015904>] systemd[1]: Reached target Remote File Systems.
daemon:info  : [    3.083088 <    0.020066>] systemd[1]: Reached target Slice Units.
daemon:info  : [    3.099162 <    0.016074>] systemd[1]: Reached target Swaps.
daemon:info  : [    3.160926 <    0.061764>] systemd[1]: Listening on RPCbind Server Activation Socket.
daemon:info  : [    3.187294 <    0.026368>] systemd[1]: Reached target RPC Port Mapper.
daemon:info  : [    3.215189 <    0.027895>] systemd[1]: Listening on Syslog Socket.
daemon:info  : [    3.231963 <    0.016774>] systemd[1]: Listening on initctl Compatibility Named Pipe.
daemon:info  : [    3.268535 <    0.036572>] systemd[1]: Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
daemon:info  : [    3.280980 <    0.012445>] systemd[1]: Listening on Journal Socket (/dev/log).
daemon:info  : [    3.304563 <    0.023583>] systemd[1]: Listening on Journal Socket.
daemon:info  : [    3.321048 <    0.016485>] systemd[1]: Listening on Network Service Netlink Socket.
daemon:info  : [    3.346675 <    0.025627>] systemd[1]: Listening on udev Control Socket.
daemon:info  : [    3.368259 <    0.021584>] systemd[1]: Listening on udev Kernel Socket.
daemon:info  : [    3.393751 <    0.025492>] systemd[1]: Listening on User Database Manager Socket.
daemon:info  : [    3.447182 <    0.053431>] systemd[1]: Mounting Huge Pages File System...
daemon:info  : [    3.467622 <    0.020440>] systemd[1]: Mounting POSIX Message Queue File System...
daemon:info  : [    3.494613 <    0.026991>] systemd[1]: Mounting Kernel Debug File System...
daemon:info  : [    3.511472 <    0.016859>] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
daemon:info  : [    3.529904 <    0.018432>] systemd[1]: Mounting Temporary Directory /tmp...
daemon:info  : [    3.551668 <    0.021764>] systemd[1]: Starting Create List of Static Device Nodes...
daemon:info  : [    3.579982 <    0.028314>] systemd[1]: Starting Load Kernel Module configfs...
daemon:info  : [    3.599551 <    0.019569>] systemd[1]: Starting Load Kernel Module drm...
daemon:info  : [    3.619342 <    0.019791>] systemd[1]: Starting Load Kernel Module fuse...
daemon:info  : [    3.640609 <    0.021267>] systemd[1]: Starting RPC Bind...
kern  :info  : [    3.651427 <    0.010818>] fuse: init (API version 7.39)
daemon:info  : [    3.659808 <    0.008381>] systemd[1]: Starting File System Check on Root Device...
daemon:info  : [    3.690540 <    0.030732>] systemd[1]: Starting Journal Service...
daemon:info  : [    3.708605 <    0.018065>] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
daemon:info  : [    3.722599 <    0.013994>] systemd[1]: Starting Generate network units from Kernel command line...
daemon:info  : [    3.736541 <    0.013942>] systemd[1]: Starting Apply Kernel Variables...
daemon:info  : [    3.750419 <    0.013878>] systemd[1]: Starting Coldplug All udev Devices...
daemon:info  : [    3.773545 <    0.023126>] systemd[1]: Started RPC Bind.
daemon:info  : [    3.784116 <    0.010571>] systemd[1]: Mounted Huge Pages File System.
syslog:info  : [    3.799947 <    0.015831>] systemd-journald[121]: Collecting audit messages is disabled.
daemon:info  : [    3.811921 <    0.011974>] systemd[1]: Mounted POSIX Message Queue File System.
daemon:info  : [    3.835822 <    0.023901>] systemd[1]: Mounted Kernel Debug File System.
daemon:info  : [    3.859430 <    0.023608>] systemd[1]: Started Journal Service.
kern  :info  : [    4.168338 <    0.308908>] EXT4-fs (mmcblk0p2): re-mounted f09729b3-29df-4b34-8b8a-021fdbf270e3 r/w. Quota mode: disabled.
syslog:info  : [    4.278560 <    0.110222>] systemd-journald[121]: Received client request to flush runtime journal.
kern  :notice: [    5.382806 <    1.104246>] random: crng init done
kern  :warn  : [    5.464213 <    0.081407>] lm75 0-0048: supply vs not found, using dummy regulator
kern  :warn  : [    5.476288 <    0.012075>] ina2xx 1-0040: supply vs not found, using dummy regulator
kern  :info  : [    5.478633 <    0.002345>] hwmon hwmon0: temp1_input not attached to any thermal zone
kern  :info  : [    5.493494 <    0.014861>] lm75 0-0048: hwmon0: sensor 'tmp1075'
kern  :info  : [    5.501618 <    0.008124>] ina2xx 1-0040: power monitor ina219 (Rshunt = 10000 uOhm)
kern  :err   : [    5.502198 <    0.000580>] omap8250 2b300000.serial: failed to get alias
kern  :warn  : [    5.516745 <    0.014547>] lm75 1-004f: supply vs not found, using dummy regulator
kern  :info  : [    5.530176 <    0.013431>] CAN device driver interface
kern  :warn  : [    5.539217 <    0.009041>] atmel_mxt_ts 2-004a: supply vdda not found, using dummy regulator
kern  :info  : [    5.540680 <    0.001463>] hwmon hwmon2: temp1_input not attached to any thermal zone
kern  :warn  : [    5.541445 <    0.000765>] pca953x 0-0021: supply vcc not found, using dummy regulator
kern  :info  : [    5.541672 <    0.000227>] pca953x 0-0021: using no AI
kern  :warn  : [    5.544131 <    0.002459>] pca953x 1-0021: supply vcc not found, using dummy regulator
kern  :info  : [    5.544309 <    0.000178>] pca953x 1-0021: using no AI
kern  :info  : [    5.550873 <    0.006564>] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
kern  :info  : [    5.552982 <    0.002109>] lm75 1-004f: hwmon2: sensor 'tmp75c'
kern  :warn  : [    5.572048 <    0.019066>] atmel_mxt_ts 2-004a: supply vdd not found, using dummy regulator
kern  :info  : [    5.587221 <    0.015173>] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
kern  :err   : [    5.608091 <    0.020870>] omap-mailbox 29020000.mailbox: no available mbox devices found
kern  :info  : [    5.608420 <    0.000329>] m_can_platform 4e08000.can: m_can device registered (irq=504, version=32)
kern  :err   : [    5.625438 <    0.017018>] omap-mailbox 29030000.mailbox: no available mbox devices found
kern  :err   : [    5.638494 <    0.013056>] tidss 30200000.dss: failed to init OLDI: -517
kern  :info  : [    5.639660 <    0.001166>] m_can_platform 20701000.can: m_can device registered (irq=508, version=32)
kern  :err   : [    5.644194 <    0.004534>] vdec 30210000.video-codec: OPP table not found in device tree
kern  :info  : [    5.691839 <    0.047645>] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
kern  :info  : [    5.701153 <    0.009314>] vdec 30210000.video-codec: Product Code:      0x521c
kern  :info  : [    5.707500 <    0.006347>] vdec 30210000.video-codec: Firmware Revision: 344874
kern  :err   : [    5.737801 <    0.030301>] tidss 30200000.dss: failed to init OLDI: -517
kern  :err   : [    5.838844 <    0.101043>] tidss 30200000.dss: failed to init OLDI: -517
kern  :info  : [    5.859878 <    0.021034>] /connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
kern  :info  : [    5.869058 <    0.009180>] atmel_mxt_ts 2-004a: Family: 164 Variant: 11 Firmware V1.2.AA Objects: 41
kern  :warn  : [    5.879186 <    0.010128>] atmel_mxt_ts 2-004a: Enabling RETRIGEN workaround
kern  :info  : [    5.898244 <    0.019058>] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /connector
kern  :info  : [    5.929094 <    0.030850>] input: tps65219-pwrbutton as /devices/platform/bus@f0000/bus@f0000:bus@b00000/2b200000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
kern  :err   : [    5.931314 <    0.002220>] tidss 30200000.dss: failed to init OLDI: -517
kern  :info  : [    5.931488 <    0.000174>] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
kern  :info  : [    5.965912 <    0.034424>] input: gpio-keys as /devices/platform/gpio-keys/input/input1
kern  :info  : [    5.975477 <    0.009565>] optee: probing for conduit method.
kern  :warn  : [    5.980239 <    0.004762>] atmel_mxt_ts 2-004a: Direct firmware load for maxtouch.cfg failed with error -2
kern  :info  : [    5.981879 <    0.001640>] optee: revision 4.5 (ef1ebdc23034a804)
kern  :warn  : [    5.986776 <    0.004897>] pvrsrvkm: loading out-of-tree module taints kernel.
kern  :err   : [    6.001008 <    0.014232>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    6.007666 <    0.006658>] optee: dynamic shared memory is enabled
kern  :info  : [    6.007996 <    0.000330>] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
kern  :info  : [    6.013829 <    0.005833>] PVR_K:  177: Device: fd80000.gpu
kern  :info  : [    6.017969 <    0.004140>] optee: initialized driver
kern  :info  : [    6.030830 <    0.012861>] atmel_mxt_ts 2-004a: Touchscreen size X1279Y799
kern  :info  : [    6.037475 <    0.006645>] input: Atmel maXTouch Touchscreen as /devices/platform/bus@f0000/20010000.i2c/i2c-2/2-004a/input/input2
kern  :info  : [    6.052986 <    0.015511>] PVR_K:  177: Read BVNC 36.53.104.796 from HW device registers
kern  :info  : [    6.053118 <    0.000132>] PVR_K:  177: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
kern  :info  : [    6.054696 <    0.001578>] [drm] Initialized pvr 24.2.6643903 20170530 for fd80000.gpu on minor 1
kern  :info  : [    6.082355 <    0.027659>] Console: switching to colour frame buffer device 160x50
kern  :info  : [    6.172797 <    0.090442>] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
kern  :err   : [    6.223215 <    0.050418>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    6.332067 <    0.108852>] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
kern  :err   : [    6.333115 <    0.001048>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    6.338329 <    0.005214>] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
kern  :info  : [    6.352867 <    0.014538>] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
kern  :err   : [    6.357521 <    0.004654>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    6.359002 <    0.001481>] xhci-hcd xhci-hcd.4.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
kern  :info  : [    6.359083 <    0.000081>] xhci-hcd xhci-hcd.4.auto: irq 522, io mem 0x31100000
kern  :info  : [    6.381347 <    0.022264>] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
kern  :info  : [    6.389856 <    0.008509>] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern  :info  : [    6.397345 <    0.007489>] usb usb1: Product: xHCI Host Controller
kern  :info  : [    6.402352 <    0.005007>] usb usb1: Manufacturer: Linux 6.6.58-7.2.0-devel-g9d7c5d371546 xhci-hcd
kern  :info  : [    6.410143 <    0.007791>] usb usb1: SerialNumber: xhci-hcd.4.auto
kern  :info  : [    6.415693 <    0.005550>] hub 1-0:1.0: USB hub found
kern  :info  : [    6.419661 <    0.003968>] hub 1-0:1.0: 1 port detected
kern  :err   : [    6.424981 <    0.005320>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    6.678776 <    0.253795>] usb 1-1: new high-speed USB device number 2 using xhci-hcd
kern  :info  : [    6.835475 <    0.156699>] usb 1-1: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.21
kern  :info  : [    6.845858 <    0.010383>] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kern  :info  : [    6.853694 <    0.007836>] usb 1-1: Product: USB2744
kern  :info  : [    6.853705 <    0.000011>] usb 1-1: Manufacturer: Microchip Tech
kern  :info  : [    6.893589 <    0.039884>] hub 1-1:1.0: USB hub found
kern  :info  : [    6.900584 <    0.006995>] hub 1-1:1.0: 4 ports detected
kern  :err   : [    6.968779 <    0.068195>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :err   : [    6.981138 <    0.012359>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    7.047541 <    0.066403>] usbcore: registered new device driver onboard-usb-hub
kern  :info  : [    7.279470 <    0.231929>] hub 1-1:1.0: USB hub found
kern  :info  : [    7.285955 <    0.006485>] hub 1-1:1.0: 4 ports detected
kern  :err   : [    7.345646 <    0.059691>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    7.439503 <    0.093857>] hub 1-1:1.0: USB hub found
kern  :info  : [    7.452149 <    0.012646>] hub 1-1:1.0: 4 ports detected
kern  :err   : [    7.506792 <    0.054643>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    7.794796 <    0.288004>] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
kern  :info  : [    7.885889 <    0.091093>] Bluetooth: Core ver 2.22
kern  :info  : [    7.892226 <    0.006337>] NET: Registered PF_BLUETOOTH protocol family
kern  :info  : [    7.900132 <    0.007906>] Bluetooth: HCI device and connection manager initialized
kern  :info  : [    7.909121 <    0.008989>] Bluetooth: HCI socket layer initialized
kern  :info  : [    7.909137 <    0.000016>] Bluetooth: L2CAP socket layer initialized
kern  :info  : [    7.909170 <    0.000033>] Bluetooth: SCO socket layer initialized
kern  :info  : [    7.933721 <    0.024551>] usb 1-1.4: New USB device found, idVendor=0424, idProduct=2740, bcdDevice= 2.00
kern  :info  : [    7.945144 <    0.011423>] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kern  :info  : [    7.963441 <    0.018297>] usb 1-1.4: Product: Hub Controller
kern  :info  : [    7.975307 <    0.011866>] configfs-gadget.g1 gadget.0: HOST MAC 6e:57:ac:54:7e:d4
kern  :info  : [    7.985487 <    0.010180>] configfs-gadget.g1 gadget.0: MAC 62:b0:6e:54:34:43
kern  :info  : [    7.987235 <    0.001748>] usb 1-1.4: Manufacturer: Microchip Tech
kern  :err   : [    8.007552 <    0.020317>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :err   : [    8.024174 <    0.016622>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [    8.400346 <    0.376172>] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=386)
kern  :info  : [    8.413685 <    0.013339>] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
kern  :info  : [    8.509332 <    0.095647>] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:07] driver [Microchip KSZ9131 Gigabit PHY] (irq=392)
kern  :info  : [    8.523903 <    0.014571>] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
kern  :notice: [    8.543224 <    0.019321>] cfg80211: Loading compiled-in X.509 certificates for regulatory database
kern  :notice: [    8.567828 <    0.024604>] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
kern  :notice: [    8.576729 <    0.008901>] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
kern  :info  : [   11.505560 <    2.928831>] PVR_K:  448: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
kern  :info  : [   11.519112 <    0.013552>] PVR_K:  448: Shader binary image 'rgx.sh.36.53.104.796' loaded
kern  :warn  : [   11.555255 <    0.036143>] weston[448]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
kern  :info  : [   11.840037 <    0.284782>] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
kern  :info  : [   11.872742 <    0.032705>] 8021q: 802.1Q VLAN Support v1.8
kern  :info  : [   11.877179 <    0.004437>] 8021q: adding VLAN 0 to HW filter on device eth0
kern  :info  : [   11.882965 <    0.005786>] 8021q: adding VLAN 0 to HW filter on device eth1
kern  :err   : [   18.147644 <    6.264679>] ti-udma 485c0100.dma-controller: bchan0 cfg failed -22
kern  :info  : [   18.155721 <    0.008077>] platform fc40000.spi: deferred probe pending
Linux kernel is based on the latest 6.6 from TI, GIT sources here, https://git.toradex.com/cgit/linux-toradex.git/log/?h=toradex_ti-linux-6.6.y, based on TI SDK 10.01.10.04.
Board device tree file: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm64/boot/dts/ti/k3-am62p5-verdin-wifi-dev.dts?h=toradex_ti-linux-6.6.y
Can you help?
