Hi Support,
The Assigned Focus customer asks:
In the table below, we have note (1) next to the CAP_VDDSHV_MMC signal name. I’m having trouble understanding what the note is trying to say.
Specifically, where is says “when the SDIO_LDO is being used to source VDDSHV3 or VDDSHV4”.
For example, if I am using MMC2 and I want to use it at 3.3V, then I would supply the VDDSHV4 pin with 3.3V.
If I want to use MMC2 at 1.8V, then I would need to supply the VDDSHV4 pin with 1.8V.
What SDIO_LDO is the datasheet talking about? Is there a way to use MMC2 with out supplying the voltage to the VDDSHV4 pin using an external supply?
Blake
