Hi TI,
I try to compilate qat v2 model,I change the model config
'advanced_options:prequantized_model': 1,
data_convert = 0
I compilate mobilenet_v2_lite_wt-v2_qat-v2-wc8-at8_20231120_model.onnx downloaded from model zoo link http://software-dl.ti.com/jacinto7/esd/modelzoo/11_01_00/modelartifacts/AM68A/8bits/cl-6508_onnxrt_imagenet1k_edgeai-tv2_mobilenet_v2_lite_wt-v2_qat-v2-wc8-at8_20231120_model_onnx.tar.gz successfully, but the qat model generated by edgeai-tensorlab/edgeai-modeloptimization/torchmodelopt/main/model_surgery_examples.py is fialed,
test_qatv2.zip
the log as follows:
/home/szz/anaconda3/envs/edgeai-tidl-1100/bin/python /home/szz/zx/code/edgeai-tidl-tools-11-00/examples/osrt_python/ort/imotion_onnxrt_ep.py -c -m mobilenet_v2_qat -ca ./quantization_data/calib_data/mobilenet_v2 -onnx /home/szz/zx/code/edgeai-tensorlab/edgeai-modeloptimization/torchmodelopt/main/data/checkpoints/v2/mobilenet_v2_quant_lite.onnx -output ./quantization_data/quantization
Skipping import of model optimizer
env SOC: am68a
env TIDL_TOOLS_PATH: /home/szz/zx/code/edgeai-tidl-tools-11-00/tools/AM68A/tidl_tools
env LD_LIBRARY_PATH: $LD_LIBRARY_PATH:/home/szz/zx/code/edgeai-tidl-tools-11-00/tools/AM68A/tidl_tools
env ARM64_GCC_PATH: /home/szz/zx/code/edgeai-tidl-tools-11-00/tools/arago-2025.01
env TIDL_RT_PERFSTATS: 1
Available execution providers : ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running model - mobilenet_v2_qat
Running shape inference on model /home/szz/zx/code/edgeai-tensorlab/edgeai-modeloptimization/torchmodelopt/main/data/checkpoints/v2/mobilenet_v2_quant_lite.onnx
tidl_tools_path = /home/szz/zx/code/edgeai-tidl-tools-11-00/tools/AM68A/tidl_tools
artifacts_folder = ./quantization_data/quantization/mobilenet_v2_qat
tidl_tensor_bits = 8
debug_level = 4
num_tidl_subgraphs = 16
num_tidl_subgraph_max_node = 0
enable_rt_multi_subgraph_support = 0
tidl_denylist =
tidl_denylist_layer_name =
tidl_denylist_layer_type =
tidl_allowlist_layer_name =
model_type =
tidl_calibration_accuracy_level = 64
tidl_calibration_options:num_frames_calibration = 1
tidl_calibration_options:bias_calibration_iterations = 1
mixed_precision_factor = -1.000000
model_group_id = 0
power_of_2_quantization = 3
ONNX QDQ Enabled = 1
enable_high_resolution_optimization = 0
pre_batchnorm_fold = 1
add_data_convert_ops = 0
output_feature_16bit_names_list =
m_params_16bit_names_list =
m_single_core_layers_names_list =
m_spatial_split_layers_names_list =
m_channel_split_layers_names_list =
Inference mode = 0
Number of cores = 1
reserved_compile_constraints_flag = 1601
partial_init_during_compile = 0
packetize_mode = 0
enable_tfr_optimization = 0
ti_internal_reserved_1 =
========================= [Model Compilation Started] =========================
Model compilation will perform the following stages:
1. Parsing
2. Graph Optimization
3. Quantization & Calibration
4. Memory Planning
============================== [Version Summary] ==============================
| TIDL Tools Version | 11_00_06_00 |
| C7x Firmware Version | 11_00_00_00 |
| Runtime Version | 1.15.0 |
| Model Opset Version | 18 |
============================== [Parsing Started] ==============================
[TIDL Import] [PARSER] WARNING: Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/1_1/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/1_1/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_34/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_34/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_15/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_15/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_33/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_33/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_32/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_32/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_14/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_14/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_31/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_31/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_30/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_30/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_13/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_13/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_29/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_29/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_28/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_28/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_12/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_12/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_27/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_27/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_26/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_26/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_11/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_11/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_25/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_25/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_24/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_24/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_10/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_10/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_23/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_23/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_22/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_22/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_9/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_9/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_21/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_21/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_20/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_20/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_8/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_8/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_19/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_19/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_18/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_18/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_7/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_7/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_17/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_17/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_16/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_16/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_6/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_6/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_15/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_15/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_14/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_14/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_5/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_5/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_13/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_13/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_12/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_12/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_4/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_4/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_11/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_11/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_10/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_10/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_3/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_3/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_9/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_9/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_8/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_8/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_2/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_2/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_7/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_7/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_6/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_6/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_1/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_1/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_5/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_5/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_4/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_4/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_3/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_3/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_2/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_2/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/1/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/1/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_1/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_1/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_1/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_1/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_1/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/1/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/1/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/1/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_2/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_2/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_2/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_3/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_3/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_3/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_4/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_4/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_4/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_5/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_5/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_5/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_1/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_1/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_1/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_6/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_6/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_6/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_7/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_7/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_7/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_2/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_2/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_2/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_8/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_8/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_8/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_9/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_9/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_9/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_3/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_3/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_3/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_3 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_1 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_10/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_4 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_10/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_10/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_11/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_11/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_11/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_4/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_4/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_4/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_5 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_2 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_3 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_12/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_12/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_12/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_13/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_13/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_13/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_5/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_5/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_5/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_14/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_6 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_14/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_14/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_15/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_15/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_15/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_6/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_6/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_6/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_7 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_3 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_4 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_16/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_8 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_16/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_16/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_17/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_17/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_17/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_7/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_7/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_7/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_9 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_4 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_5 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_18/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_10 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_18/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_18/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_19/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_19/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_19/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_8/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_8/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_8/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_11 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_5 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_6 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_20/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_20/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_20/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_21/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_21/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_21/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_9/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_9/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_9/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_22/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_12 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_22/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_22/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_23/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_23/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_23/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_10/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_10/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_10/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_13 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_6 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_7 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_24/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_14 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_24/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_24/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_25/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_25/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_25/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_11/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_11/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_11/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_15 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_7 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_8 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_26/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_26/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_26/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_27/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_27/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_27/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_12/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_12/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_12/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_28/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_16 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_28/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_28/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_29/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_29/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_29/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_13/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_13/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_13/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_17 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_8 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_9 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_30/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_18 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_30/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_30/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_31/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_31/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_31/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_14/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_14/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_14/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_19 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Add, Node name - /module/Add_9 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_10 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_32/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_32/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_32/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_33/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_33/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_33/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/2_15/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/2_15/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/2_15/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/0_34/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Conv, Node name - /module/0_34/Conv -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/0_34/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_20 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - GlobalAveragePool, Node name - /module/GlobalAveragePool -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_11 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_21 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Flatten, Node name - /module/Flatten -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/QuantizeLinear_12 -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/1_1/DequantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - Gemm, Node name - /module/1_1/Gemm -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - QuantizeLinear, Node name - /module/1_1/QuantizeLinear -- [tidl_onnxRtImport_core.cpp, 624]
[TIDL Import] [PARSER] SUPPORTED: Layers type supported by TIDL --- layer type - DequantizeLinear, Node name - /module/DequantizeLinear_22 -- [tidl_onnxRtImport_core.cpp, 624]
------------------------- Subgraph Information Summary -------------------------
| Core | No. of Nodes | Number of Subgraphs |
| C7x | 313 | 1 |
| CPU | 0 | x |
Running Runtimes GraphViz - /home/szz/zx/code/edgeai-tidl-tools-11-00/tools/AM68A/tidl_tools/tidl_graphVisualiser_runtimes.out ./quantization_data/quantization/mobilenet_v2_qat/allowedNode.txt ./quantization_data/quantization/mobilenet_v2_qat/tempDir/graphvizInfo.txt ./quantization_data/quantization/mobilenet_v2_qat/tempDir/runtimes_visualization.svg
============================= [Parsing Completed] =============================
TIDL_createStateImportFunc Started:
Compute on node : TIDLExecutionProvider_TIDL_0_0
0, QuantizeLinear, 3, 1, x, /module/QuantizeLinear_output_0
1, DequantizeLinear, 3, 1, /module/QuantizeLinear_output_0, /module/0/DequantizeLinear_output_0
2, DequantizeLinear, 3, 1, /module/0/Constant_output_0, /module/0/DequantizeLinear_1_output_0
3, DequantizeLinear, 3, 1, onnx::DequantizeLinear_1646, /module/0/DequantizeLinear_2_output_0
4, Conv, 3, 1, /module/0/DequantizeLinear_output_0, /module/0/Conv_output_0
5, QuantizeLinear, 3, 1, /module/0/Conv_output_0, /module/0/QuantizeLinear_output_0
6, DequantizeLinear, 3, 1, /module/0/QuantizeLinear_output_0, /module/0_1/DequantizeLinear_output_0
7, DequantizeLinear, 3, 1, /module/0_1/Constant_2_output_0, /module/0_1/DequantizeLinear_1_output_0
8, DequantizeLinear, 3, 1, /module/0_1/Constant_6_output_0, /module/0_1/DequantizeLinear_2_output_0
9, Conv, 3, 1, /module/0_1/DequantizeLinear_output_0, /module/0_1/Conv_output_0
10, QuantizeLinear, 3, 1, /module/0_1/Conv_output_0, /module/0_1/QuantizeLinear_output_0
11, DequantizeLinear, 3, 1, /module/0_1/QuantizeLinear_output_0, /module/1/DequantizeLinear_output_0
12, DequantizeLinear, 3, 1, /module/1/Constant_2_output_0, /module/1/DequantizeLinear_1_output_0
13, DequantizeLinear, 3, 1, /module/1/Constant_6_output_0, /module/1/DequantizeLinear_2_output_0
14, Conv, 3, 1, /module/1/DequantizeLinear_output_0, /module/1/Conv_output_0
15, QuantizeLinear, 3, 1, /module/1/Conv_output_0, /module/1/QuantizeLinear_output_0
16, DequantizeLinear, 3, 1, /module/1/QuantizeLinear_output_0, /module/0_2/DequantizeLinear_output_0
17, DequantizeLinear, 3, 1, /module/0_2/Constant_2_output_0, /module/0_2/DequantizeLinear_1_output_0
18, DequantizeLinear, 3, 1, /module/0_2/Constant_6_output_0, /module/0_2/DequantizeLinear_2_output_0
19, Conv, 3, 1, /module/0_2/DequantizeLinear_output_0, /module/0_2/Conv_output_0
20, QuantizeLinear, 3, 1, /module/0_2/Conv_output_0, /module/0_2/QuantizeLinear_output_0
21, DequantizeLinear, 3, 1, /module/0_2/QuantizeLinear_output_0, /module/0_3/DequantizeLinear_output_0
22, DequantizeLinear, 3, 1, /module/0_3/Constant_2_output_0, /module/0_3/DequantizeLinear_1_output_0
23, DequantizeLinear, 3, 1, /module/0_3/Constant_6_output_0, /module/0_3/DequantizeLinear_2_output_0
24, Conv, 3, 1, /module/0_3/DequantizeLinear_output_0, /module/0_3/Conv_output_0
25, QuantizeLinear, 3, 1, /module/0_3/Conv_output_0, /module/0_3/QuantizeLinear_output_0
26, DequantizeLinear, 3, 1, /module/0_3/QuantizeLinear_output_0, /module/2/DequantizeLinear_output_0
27, DequantizeLinear, 3, 1, /module/2/Constant_2_output_0, /module/2/DequantizeLinear_1_output_0
28, DequantizeLinear, 3, 1, /module/2/Constant_6_output_0, /module/2/DequantizeLinear_2_output_0
29, Conv, 3, 1, /module/2/DequantizeLinear_output_0, /module/2/Conv_output_0
30, QuantizeLinear, 3, 1, /module/2/Conv_output_0, /module/2/QuantizeLinear_output_0
31, DequantizeLinear, 3, 1, /module/2/QuantizeLinear_output_0, /module/0_4/DequantizeLinear_output_0
32, DequantizeLinear, 3, 1, /module/0_4/Constant_2_output_0, /module/0_4/DequantizeLinear_1_output_0
33, DequantizeLinear, 3, 1, /module/0_4/Constant_6_output_0, /module/0_4/DequantizeLinear_2_output_0
34, Conv, 3, 1, /module/0_4/DequantizeLinear_output_0, /module/0_4/Conv_output_0
35, QuantizeLinear, 3, 1, /module/0_4/Conv_output_0, /module/0_4/QuantizeLinear_output_0
36, DequantizeLinear, 3, 1, /module/0_4/QuantizeLinear_output_0, /module/0_5/DequantizeLinear_output_0
37, DequantizeLinear, 3, 1, /module/0_5/Constant_2_output_0, /module/0_5/DequantizeLinear_1_output_0
38, DequantizeLinear, 3, 1, /module/0_5/Constant_6_output_0, /module/0_5/DequantizeLinear_2_output_0
39, Conv, 3, 1, /module/0_5/DequantizeLinear_output_0, /module/0_5/Conv_output_0
40, QuantizeLinear, 3, 1, /module/0_5/Conv_output_0, /module/0_5/QuantizeLinear_output_0
41, DequantizeLinear, 3, 1, /module/0_5/QuantizeLinear_output_0, /module/2_1/DequantizeLinear_output_0
42, DequantizeLinear, 3, 1, /module/2_1/Constant_2_output_0, /module/2_1/DequantizeLinear_1_output_0
43, DequantizeLinear, 3, 1, /module/2_1/Constant_6_output_0, /module/2_1/DequantizeLinear_2_output_0
44, Conv, 3, 1, /module/2_1/DequantizeLinear_output_0, /module/2_1/Conv_output_0
45, QuantizeLinear, 3, 1, /module/2_1/Conv_output_0, /module/2_1/QuantizeLinear_output_0
46, DequantizeLinear, 3, 1, /module/2_1/QuantizeLinear_output_0, /module/DequantizeLinear_1_output_0
47, DequantizeLinear, 3, 1, /module/2/QuantizeLinear_output_0, /module/DequantizeLinear_output_0
48, Add, 2, 1, /module/DequantizeLinear_output_0, /module/Add_output_0
49, QuantizeLinear, 3, 1, /module/Add_output_0, /module/QuantizeLinear_1_output_0
50, DequantizeLinear, 3, 1, /module/QuantizeLinear_1_output_0, /module/0_6/DequantizeLinear_output_0
51, DequantizeLinear, 3, 1, /module/0_6/Constant_2_output_0, /module/0_6/DequantizeLinear_1_output_0
52, DequantizeLinear, 3, 1, /module/0_6/Constant_6_output_0, /module/0_6/DequantizeLinear_2_output_0
53, Conv, 3, 1, /module/0_6/DequantizeLinear_output_0, /module/0_6/Conv_output_0
54, QuantizeLinear, 3, 1, /module/0_6/Conv_output_0, /module/0_6/QuantizeLinear_output_0
55, DequantizeLinear, 3, 1, /module/0_6/QuantizeLinear_output_0, /module/0_7/DequantizeLinear_output_0
56, DequantizeLinear, 3, 1, /module/0_7/Constant_2_output_0, /module/0_7/DequantizeLinear_1_output_0
57, DequantizeLinear, 3, 1, /module/0_7/Constant_6_output_0, /module/0_7/DequantizeLinear_2_output_0
58, Conv, 3, 1, /module/0_7/DequantizeLinear_output_0, /module/0_7/Conv_output_0
59, QuantizeLinear, 3, 1, /module/0_7/Conv_output_0, /module/0_7/QuantizeLinear_output_0
60, DequantizeLinear, 3, 1, /module/0_7/QuantizeLinear_output_0, /module/2_2/DequantizeLinear_output_0
61, DequantizeLinear, 3, 1, /module/2_2/Constant_2_output_0, /module/2_2/DequantizeLinear_1_output_0
62, DequantizeLinear, 3, 1, /module/2_2/Constant_6_output_0, /module/2_2/DequantizeLinear_2_output_0
63, Conv, 3, 1, /module/2_2/DequantizeLinear_output_0, /module/2_2/Conv_output_0
64, QuantizeLinear, 3, 1, /module/2_2/Conv_output_0, /module/2_2/QuantizeLinear_output_0
65, DequantizeLinear, 3, 1, /module/2_2/QuantizeLinear_output_0, /module/0_8/DequantizeLinear_output_0
66, DequantizeLinear, 3, 1, /module/0_8/Constant_2_output_0, /module/0_8/DequantizeLinear_1_output_0
67, DequantizeLinear, 3, 1, /module/0_8/Constant_6_output_0, /module/0_8/DequantizeLinear_2_output_0
68, Conv, 3, 1, /module/0_8/DequantizeLinear_output_0, /module/0_8/Conv_output_0
69, QuantizeLinear, 3, 1, /module/0_8/Conv_output_0, /module/0_8/QuantizeLinear_output_0
70, DequantizeLinear, 3, 1, /module/0_8/QuantizeLinear_output_0, /module/0_9/DequantizeLinear_output_0
71, DequantizeLinear, 3, 1, /module/0_9/Constant_2_output_0, /module/0_9/DequantizeLinear_1_output_0
72, DequantizeLinear, 3, 1, /module/0_9/Constant_6_output_0, /module/0_9/DequantizeLinear_2_output_0
73, Conv, 3, 1, /module/0_9/DequantizeLinear_output_0, /module/0_9/Conv_output_0
74, QuantizeLinear, 3, 1, /module/0_9/Conv_output_0, /module/0_9/QuantizeLinear_output_0
75, DequantizeLinear, 3, 1, /module/0_9/QuantizeLinear_output_0, /module/2_3/DequantizeLinear_output_0
76, DequantizeLinear, 3, 1, /module/2_3/Constant_2_output_0, /module/2_3/DequantizeLinear_1_output_0
77, DequantizeLinear, 3, 1, /module/2_3/Constant_6_output_0, /module/2_3/DequantizeLinear_2_output_0
78, Conv, 3, 1, /module/2_3/DequantizeLinear_output_0, /module/2_3/Conv_output_0
79, QuantizeLinear, 3, 1, /module/2_3/Conv_output_0, /module/2_3/QuantizeLinear_output_0
80, DequantizeLinear, 3, 1, /module/2_3/QuantizeLinear_output_0, /module/DequantizeLinear_3_output_0
81, DequantizeLinear, 3, 1, /module/2_2/QuantizeLinear_output_0, /module/DequantizeLinear_2_output_0
82, Add, 2, 1, /module/DequantizeLinear_2_output_0, /module/Add_1_output_0
83, QuantizeLinear, 3, 1, /module/Add_1_output_0, /module/QuantizeLinear_2_output_0
84, DequantizeLinear, 3, 1, /module/QuantizeLinear_2_output_0, /module/0_10/DequantizeLinear_output_0
85, DequantizeLinear, 3, 1, /module/0_10/Constant_2_output_0, /module/0_10/DequantizeLinear_1_output_0
86, DequantizeLinear, 3, 1, /module/0_10/Constant_6_output_0, /module/0_10/DequantizeLinear_2_output_0
87, Conv, 3, 1, /module/0_10/DequantizeLinear_output_0, /module/0_10/Conv_output_0
88, QuantizeLinear, 3, 1, /module/0_10/Conv_output_0, /module/0_10/QuantizeLinear_output_0
89, DequantizeLinear, 3, 1, /module/0_10/QuantizeLinear_output_0, /module/0_11/DequantizeLinear_output_0
90, DequantizeLinear, 3, 1, /module/0_11/Constant_2_output_0, /module/0_11/DequantizeLinear_1_output_0
91, DequantizeLinear, 3, 1, /module/0_11/Constant_6_output_0, /module/0_11/DequantizeLinear_2_output_0
92, Conv, 3, 1, /module/0_11/DequantizeLinear_output_0, /module/0_11/Conv_output_0
93, QuantizeLinear, 3, 1, /module/0_11/Conv_output_0, /module/0_11/QuantizeLinear_output_0
94, DequantizeLinear, 3, 1, /module/0_11/QuantizeLinear_output_0, /module/2_4/DequantizeLinear_output_0
95, DequantizeLinear, 3, 1, /module/2_4/Constant_2_output_0, /module/2_4/DequantizeLinear_1_output_0
96, DequantizeLinear, 3, 1, /module/2_4/Constant_6_output_0, /module/2_4/DequantizeLinear_2_output_0
97, Conv, 3, 1, /module/2_4/DequantizeLinear_output_0, /module/2_4/Conv_output_0
98, QuantizeLinear, 3, 1, /module/2_4/Conv_output_0, /module/2_4/QuantizeLinear_output_0
99, DequantizeLinear, 3, 1, /module/2_4/QuantizeLinear_output_0, /module/DequantizeLinear_5_output_0
100, DequantizeLinear, 3, 1, /module/QuantizeLinear_2_output_0, /module/DequantizeLinear_4_output_0
101, Add, 2, 1, /module/DequantizeLinear_4_output_0, /module/Add_2_output_0
102, QuantizeLinear, 3, 1, /module/Add_2_output_0, /module/QuantizeLinear_3_output_0
103, DequantizeLinear, 3, 1, /module/QuantizeLinear_3_output_0, /module/0_12/DequantizeLinear_output_0
104, DequantizeLinear, 3, 1, /module/0_12/Constant_2_output_0, /module/0_12/DequantizeLinear_1_output_0
105, DequantizeLinear, 3, 1, /module/0_12/Constant_6_output_0, /module/0_12/DequantizeLinear_2_output_0
106, Conv, 3, 1, /module/0_12/DequantizeLinear_output_0, /module/0_12/Conv_output_0
107, QuantizeLinear, 3, 1, /module/0_12/Conv_output_0, /module/0_12/QuantizeLinear_output_0
108, DequantizeLinear, 3, 1, /module/0_12/QuantizeLinear_output_0, /module/0_13/DequantizeLinear_output_0
109, DequantizeLinear, 3, 1, /module/0_13/Constant_2_output_0, /module/0_13/DequantizeLinear_1_output_0
110, DequantizeLinear, 3, 1, /module/0_13/Constant_6_output_0, /module/0_13/DequantizeLinear_2_output_0
111, Conv, 3, 1, /module/0_13/DequantizeLinear_output_0, /module/0_13/Conv_output_0
112, QuantizeLinear, 3, 1, /module/0_13/Conv_output_0, /module/0_13/QuantizeLinear_output_0
113, DequantizeLinear, 3, 1, /module/0_13/QuantizeLinear_output_0, /module/2_5/DequantizeLinear_output_0
114, DequantizeLinear, 3, 1, /module/2_5/Constant_2_output_0, /module/2_5/DequantizeLinear_1_output_0
115, DequantizeLinear, 3, 1, /module/2_5/Constant_6_output_0, /module/2_5/DequantizeLinear_2_output_0
116, Conv, 3, 1, /module/2_5/DequantizeLinear_output_0, /module/2_5/Conv_output_0
117, QuantizeLinear, 3, 1, /module/2_5/Conv_output_0, /module/2_5/QuantizeLinear_output_0
118, DequantizeLinear, 3, 1, /module/2_5/QuantizeLinear_output_0, /module/0_14/DequantizeLinear_output_0
119, DequantizeLinear, 3, 1, /module/0_14/Constant_2_output_0, /module/0_14/DequantizeLinear_1_output_0
120, DequantizeLinear, 3, 1, /module/0_14/Constant_6_output_0, /module/0_14/DequantizeLinear_2_output_0
121, Conv, 3, 1, /module/0_14/DequantizeLinear_output_0, /module/0_14/Conv_output_0
122, QuantizeLinear, 3, 1, /module/0_14/Conv_output_0, /module/0_14/QuantizeLinear_output_0
123, DequantizeLinear, 3, 1, /module/0_14/QuantizeLinear_output_0, /module/0_15/DequantizeLinear_output_0
124, DequantizeLinear, 3, 1, /module/0_15/Constant_2_output_0, /module/0_15/DequantizeLinear_1_output_0
125, DequantizeLinear, 3, 1, /module/0_15/Constant_6_output_0, /module/0_15/DequantizeLinear_2_output_0
126, Conv, 3, 1, /module/0_15/DequantizeLinear_output_0, /module/0_15/Conv_output_0
127, QuantizeLinear, 3, 1, /module/0_15/Conv_output_0, /module/0_15/QuantizeLinear_output_0
128, DequantizeLinear, 3, 1, /module/0_15/QuantizeLinear_output_0, /module/2_6/DequantizeLinear_output_0
129, DequantizeLinear, 3, 1, /module/2_6/Constant_2_output_0, /module/2_6/DequantizeLinear_1_output_0
130, DequantizeLinear, 3, 1, /module/2_6/Constant_6_output_0, /module/2_6/DequantizeLinear_2_output_0
131, Conv, 3, 1, /module/2_6/DequantizeLinear_output_0, /module/2_6/Conv_output_0
132, QuantizeLinear, 3, 1, /module/2_6/Conv_output_0, /module/2_6/QuantizeLinear_output_0
133, DequantizeLinear, 3, 1, /module/2_6/QuantizeLinear_output_0, /module/DequantizeLinear_7_output_0
134, DequantizeLinear, 3, 1, /module/2_5/QuantizeLinear_output_0, /module/DequantizeLinear_6_output_0
135, Add, 2, 1, /module/DequantizeLinear_6_output_0, /module/Add_3_output_0
136, QuantizeLinear, 3, 1, /module/Add_3_output_0, /module/QuantizeLinear_4_output_0
137, DequantizeLinear, 3, 1, /module/QuantizeLinear_4_output_0, /module/0_16/DequantizeLinear_output_0
138, DequantizeLinear, 3, 1, /module/0_16/Constant_2_output_0, /module/0_16/DequantizeLinear_1_output_0
139, DequantizeLinear, 3, 1, /module/0_16/Constant_6_output_0, /module/0_16/DequantizeLinear_2_output_0
140, Conv, 3, 1, /module/0_16/DequantizeLinear_output_0, /module/0_16/Conv_output_0
141, QuantizeLinear, 3, 1, /module/0_16/Conv_output_0, /module/0_16/QuantizeLinear_output_0
142, DequantizeLinear, 3, 1, /module/0_16/QuantizeLinear_output_0, /module/0_17/DequantizeLinear_output_0
143, DequantizeLinear, 3, 1, /module/0_17/Constant_2_output_0, /module/0_17/DequantizeLinear_1_output_0
144, DequantizeLinear, 3, 1, /module/0_17/Constant_6_output_0, /module/0_17/DequantizeLinear_2_output_0
145, Conv, 3, 1, /module/0_17/DequantizeLinear_output_0, /module/0_17/Conv_output_0
146, QuantizeLinear, 3, 1, /module/0_17/Conv_output_0, /module/0_17/QuantizeLinear_output_0
147, DequantizeLinear, 3, 1, /module/0_17/QuantizeLinear_output_0, /module/2_7/DequantizeLinear_output_0
148, DequantizeLinear, 3, 1, /module/2_7/Constant_2_output_0, /module/2_7/DequantizeLinear_1_output_0
149, DequantizeLinear, 3, 1, /module/2_7/Constant_6_output_0, /module/2_7/DequantizeLinear_2_output_0
150, Conv, 3, 1, /module/2_7/DequantizeLinear_output_0, /module/2_7/Conv_output_0
151, QuantizeLinear, 3, 1, /module/2_7/Conv_output_0, /module/2_7/QuantizeLinear_output_0
152, DequantizeLinear, 3, 1, /module/2_7/QuantizeLinear_output_0, /module/DequantizeLinear_9_output_0
153, DequantizeLinear, 3, 1, /module/QuantizeLinear_4_output_0, /module/DequantizeLinear_8_output_0
154, Add, 2, 1, /module/DequantizeLinear_8_output_0, /module/Add_4_output_0
155, QuantizeLinear, 3, 1, /module/Add_4_output_0, /module/QuantizeLinear_5_output_0
156, DequantizeLinear, 3, 1, /module/QuantizeLinear_5_output_0, /module/0_18/DequantizeLinear_output_0
157, DequantizeLinear, 3, 1, /module/0_18/Constant_2_output_0, /module/0_18/DequantizeLinear_1_output_0
158, DequantizeLinear, 3, 1, /module/0_18/Constant_6_output_0, /module/0_18/DequantizeLinear_2_output_0
159, Conv, 3, 1, /module/0_18/DequantizeLinear_output_0, /module/0_18/Conv_output_0
160, QuantizeLinear, 3, 1, /module/0_18/Conv_output_0, /module/0_18/QuantizeLinear_output_0
161, DequantizeLinear, 3, 1, /module/0_18/QuantizeLinear_output_0, /module/0_19/DequantizeLinear_output_0
162, DequantizeLinear, 3, 1, /module/0_19/Constant_2_output_0, /module/0_19/DequantizeLinear_1_output_0
163, DequantizeLinear, 3, 1, /module/0_19/Constant_6_output_0, /module/0_19/DequantizeLinear_2_output_0
164, Conv, 3, 1, /module/0_19/DequantizeLinear_output_0, /module/0_19/Conv_output_0
165, QuantizeLinear, 3, 1, /module/0_19/Conv_output_0, /module/0_19/QuantizeLinear_output_0
166, DequantizeLinear, 3, 1, /module/0_19/QuantizeLinear_output_0, /module/2_8/DequantizeLinear_output_0
167, DequantizeLinear, 3, 1, /module/2_8/Constant_2_output_0, /module/2_8/DequantizeLinear_1_output_0
168, DequantizeLinear, 3, 1, /module/2_8/Constant_6_output_0, /module/2_8/DequantizeLinear_2_output_0
169, Conv, 3, 1, /module/2_8/DequantizeLinear_output_0, /module/2_8/Conv_output_0
170, QuantizeLinear, 3, 1, /module/2_8/Conv_output_0, /module/2_8/QuantizeLinear_output_0
171, DequantizeLinear, 3, 1, /module/2_8/QuantizeLinear_output_0, /module/DequantizeLinear_11_output_0
172, DequantizeLinear, 3, 1, /module/QuantizeLinear_5_output_0, /module/DequantizeLinear_10_output_0
173, Add, 2, 1, /module/DequantizeLinear_10_output_0, /module/Add_5_output_0
174, QuantizeLinear, 3, 1, /module/Add_5_output_0, /module/QuantizeLinear_6_output_0
175, DequantizeLinear, 3, 1, /module/QuantizeLinear_6_output_0, /module/0_20/DequantizeLinear_output_0
176, DequantizeLinear, 3, 1, /module/0_20/Constant_2_output_0, /module/0_20/DequantizeLinear_1_output_0
177, DequantizeLinear, 3, 1, /module/0_20/Constant_6_output_0, /module/0_20/DequantizeLinear_2_output_0
178, Conv, 3, 1, /module/0_20/DequantizeLinear_output_0, /module/0_20/Conv_output_0
179, QuantizeLinear, 3, 1, /module/0_20/Conv_output_0, /module/0_20/QuantizeLinear_output_0
180, DequantizeLinear, 3, 1, /module/0_20/QuantizeLinear_output_0, /module/0_21/DequantizeLinear_output_0
181, DequantizeLinear, 3, 1, /module/0_21/Constant_2_output_0, /module/0_21/DequantizeLinear_1_output_0
182, DequantizeLinear, 3, 1, /module/0_21/Constant_6_output_0, /module/0_21/DequantizeLinear_2_output_0
183, Conv, 3, 1, /module/0_21/DequantizeLinear_output_0, /module/0_21/Conv_output_0
184, QuantizeLinear, 3, 1, /module/0_21/Conv_output_0, /module/0_21/QuantizeLinear_output_0
185, DequantizeLinear, 3, 1, /module/0_21/QuantizeLinear_output_0, /module/2_9/DequantizeLinear_output_0
186, DequantizeLinear, 3, 1, /module/2_9/Constant_2_output_0, /module/2_9/DequantizeLinear_1_output_0
187, DequantizeLinear, 3, 1, /module/2_9/Constant_6_output_0, /module/2_9/DequantizeLinear_2_output_0
188, Conv, 3, 1, /module/2_9/DequantizeLinear_output_0, /module/2_9/Conv_output_0
189, QuantizeLinear, 3, 1, /module/2_9/Conv_output_0, /module/2_9/QuantizeLinear_output_0
190, DequantizeLinear, 3, 1, /module/2_9/QuantizeLinear_output_0, /module/0_22/DequantizeLinear_output_0
191, DequantizeLinear, 3, 1, /module/0_22/Constant_2_output_0, /module/0_22/DequantizeLinear_1_output_0
192, DequantizeLinear, 3, 1, /module/0_22/Constant_6_output_0, /module/0_22/DequantizeLinear_2_output_0
193, Conv, 3, 1, /module/0_22/DequantizeLinear_output_0, /module/0_22/Conv_output_0
194, QuantizeLinear, 3, 1, /module/0_22/Conv_output_0, /module/0_22/QuantizeLinear_output_0
195, DequantizeLinear, 3, 1, /module/0_22/QuantizeLinear_output_0, /module/0_23/DequantizeLinear_output_0
196, DequantizeLinear, 3, 1, /module/0_23/Constant_2_output_0, /module/0_23/DequantizeLinear_1_output_0
197, DequantizeLinear, 3, 1, /module/0_23/Constant_6_output_0, /module/0_23/DequantizeLinear_2_output_0
198, Conv, 3, 1, /module/0_23/DequantizeLinear_output_0, /module/0_23/Conv_output_0
199, QuantizeLinear, 3, 1, /module/0_23/Conv_output_0, /module/0_23/QuantizeLinear_output_0
200, DequantizeLinear, 3, 1, /module/0_23/QuantizeLinear_output_0, /module/2_10/DequantizeLinear_output_0
201, DequantizeLinear, 3, 1, /module/2_10/Constant_2_output_0, /module/2_10/DequantizeLinear_1_output_0
202, DequantizeLinear, 3, 1, /module/2_10/Constant_6_output_0, /module/2_10/DequantizeLinear_2_output_0
203, Conv, 3, 1, /module/2_10/DequantizeLinear_output_0, /module/2_10/Conv_output_0
204, QuantizeLinear, 3, 1, /module/2_10/Conv_output_0, /module/2_10/QuantizeLinear_output_0
205, DequantizeLinear, 3, 1, /module/2_10/QuantizeLinear_output_0, /module/DequantizeLinear_13_output_0
206, DequantizeLinear, 3, 1, /module/2_9/QuantizeLinear_output_0, /module/DequantizeLinear_12_output_0
207, Add, 2, 1, /module/DequantizeLinear_12_output_0, /module/Add_6_output_0
208, QuantizeLinear, 3, 1, /module/Add_6_output_0, /module/QuantizeLinear_7_output_0
209, DequantizeLinear, 3, 1, /module/QuantizeLinear_7_output_0, /module/0_24/DequantizeLinear_output_0
210, DequantizeLinear, 3, 1, /module/0_24/Constant_2_output_0, /module/0_24/DequantizeLinear_1_output_0
211, DequantizeLinear, 3, 1, /module/0_24/Constant_6_output_0, /module/0_24/DequantizeLinear_2_output_0
212, Conv, 3, 1, /module/0_24/DequantizeLinear_output_0, /module/0_24/Conv_output_0
213, QuantizeLinear, 3, 1, /module/0_24/Conv_output_0, /module/0_24/QuantizeLinear_output_0
214, DequantizeLinear, 3, 1, /module/0_24/QuantizeLinear_output_0, /module/0_25/DequantizeLinear_output_0
215, DequantizeLinear, 3, 1, /module/0_25/Constant_2_output_0, /module/0_25/DequantizeLinear_1_output_0
216, DequantizeLinear, 3, 1, /module/0_25/Constant_6_output_0, /module/0_25/DequantizeLinear_2_output_0
217, Conv, 3, 1, /module/0_25/DequantizeLinear_output_0, /module/0_25/Conv_output_0
218, QuantizeLinear, 3, 1, /module/0_25/Conv_output_0, /module/0_25/QuantizeLinear_output_0
219, DequantizeLinear, 3, 1, /module/0_25/QuantizeLinear_output_0, /module/2_11/DequantizeLinear_output_0
220, DequantizeLinear, 3, 1, /module/2_11/Constant_2_output_0, /module/2_11/DequantizeLinear_1_output_0
221, DequantizeLinear, 3, 1, /module/2_11/Constant_6_output_0, /module/2_11/DequantizeLinear_2_output_0
222, Conv, 3, 1, /module/2_11/DequantizeLinear_output_0, /module/2_11/Conv_output_0
223, QuantizeLinear, 3, 1, /module/2_11/Conv_output_0, /module/2_11/QuantizeLinear_output_0
224, DequantizeLinear, 3, 1, /module/2_11/QuantizeLinear_output_0, /module/DequantizeLinear_15_output_0
225, DequantizeLinear, 3, 1, /module/QuantizeLinear_7_output_0, /module/DequantizeLinear_14_output_0
226, Add, 2, 1, /module/DequantizeLinear_14_output_0, /module/Add_7_output_0
227, QuantizeLinear, 3, 1, /module/Add_7_output_0, /module/QuantizeLinear_8_output_0
228, DequantizeLinear, 3, 1, /module/QuantizeLinear_8_output_0, /module/0_26/DequantizeLinear_output_0
229, DequantizeLinear, 3, 1, /module/0_26/Constant_2_output_0, /module/0_26/DequantizeLinear_1_output_0
230, DequantizeLinear, 3, 1, /module/0_26/Constant_6_output_0, /module/0_26/DequantizeLinear_2_output_0
231, Conv, 3, 1, /module/0_26/DequantizeLinear_output_0, /module/0_26/Conv_output_0
232, QuantizeLinear, 3, 1, /module/0_26/Conv_output_0, /module/0_26/QuantizeLinear_output_0
233, DequantizeLinear, 3, 1, /module/0_26/QuantizeLinear_output_0, /module/0_27/DequantizeLinear_output_0
234, DequantizeLinear, 3, 1, /module/0_27/Constant_2_output_0, /module/0_27/DequantizeLinear_1_output_0
235, DequantizeLinear, 3, 1, /module/0_27/Constant_6_output_0, /module/0_27/DequantizeLinear_2_output_0
236, Conv, 3, 1, /module/0_27/DequantizeLinear_output_0, /module/0_27/Conv_output_0
237, QuantizeLinear, 3, 1, /module/0_27/Conv_output_0, /module/0_27/QuantizeLinear_output_0
238, DequantizeLinear, 3, 1, /module/0_27/QuantizeLinear_output_0, /module/2_12/DequantizeLinear_output_0
239, DequantizeLinear, 3, 1, /module/2_12/Constant_2_output_0, /module/2_12/DequantizeLinear_1_output_0
240, DequantizeLinear, 3, 1, /module/2_12/Constant_6_output_0, /module/2_12/DequantizeLinear_2_output_0
241, Conv, 3, 1, /module/2_12/DequantizeLinear_output_0, /module/2_12/Conv_output_0
242, QuantizeLinear, 3, 1, /module/2_12/Conv_output_0, /module/2_12/QuantizeLinear_output_0
243, DequantizeLinear, 3, 1, /module/2_12/QuantizeLinear_output_0, /module/0_28/DequantizeLinear_output_0
244, DequantizeLinear, 3, 1, /module/0_28/Constant_2_output_0, /module/0_28/DequantizeLinear_1_output_0
245, DequantizeLinear, 3, 1, /module/0_28/Constant_6_output_0, /module/0_28/DequantizeLinear_2_output_0
246, Conv, 3, 1, /module/0_28/DequantizeLinear_output_0, /module/0_28/Conv_output_0
247, QuantizeLinear, 3, 1, /module/0_28/Conv_output_0, /module/0_28/QuantizeLinear_output_0
248, DequantizeLinear, 3, 1, /module/0_28/QuantizeLinear_output_0, /module/0_29/DequantizeLinear_output_0
249, DequantizeLinear, 3, 1, /module/0_29/Constant_2_output_0, /module/0_29/DequantizeLinear_1_output_0
250, DequantizeLinear, 3, 1, /module/0_29/Constant_6_output_0, /module/0_29/DequantizeLinear_2_output_0
251, Conv, 3, 1, /module/0_29/DequantizeLinear_output_0, /module/0_29/Conv_output_0
252, QuantizeLinear, 3, 1, /module/0_29/Conv_output_0, /module/0_29/QuantizeLinear_output_0
253, DequantizeLinear, 3, 1, /module/0_29/QuantizeLinear_output_0, /module/2_13/DequantizeLinear_output_0
254, DequantizeLinear, 3, 1, /module/2_13/Constant_2_output_0, /module/2_13/DequantizeLinear_1_output_0
255, DequantizeLinear, 3, 1, /module/2_13/Constant_6_output_0, /module/2_13/DequantizeLinear_2_output_0
256, Conv, 3, 1, /module/2_13/DequantizeLinear_output_0, /module/2_13/Conv_output_0
257, QuantizeLinear, 3, 1, /module/2_13/Conv_output_0, /module/2_13/QuantizeLinear_output_0
258, DequantizeLinear, 3, 1, /module/2_13/QuantizeLinear_output_0, /module/DequantizeLinear_17_output_0
259, DequantizeLinear, 3, 1, /module/2_12/QuantizeLinear_output_0, /module/DequantizeLinear_16_output_0
260, Add, 2, 1, /module/DequantizeLinear_16_output_0, /module/Add_8_output_0
261, QuantizeLinear, 3, 1, /module/Add_8_output_0, /module/QuantizeLinear_9_output_0
262, DequantizeLinear, 3, 1, /module/QuantizeLinear_9_output_0, /module/0_30/DequantizeLinear_output_0
263, DequantizeLinear, 3, 1, /module/0_30/Constant_2_output_0, /module/0_30/DequantizeLinear_1_output_0
264, DequantizeLinear, 3, 1, /module/0_30/Constant_6_output_0, /module/0_30/DequantizeLinear_2_output_0
265, Conv, 3, 1, /module/0_30/DequantizeLinear_output_0, /module/0_30/Conv_output_0
266, QuantizeLinear, 3, 1, /module/0_30/Conv_output_0, /module/0_30/QuantizeLinear_output_0
267, DequantizeLinear, 3, 1, /module/0_30/QuantizeLinear_output_0, /module/0_31/DequantizeLinear_output_0
268, DequantizeLinear, 3, 1, /module/0_31/Constant_2_output_0, /module/0_31/DequantizeLinear_1_output_0
269, DequantizeLinear, 3, 1, /module/0_31/Constant_6_output_0, /module/0_31/DequantizeLinear_2_output_0
270, Conv, 3, 1, /module/0_31/DequantizeLinear_output_0, /module/0_31/Conv_output_0
271, QuantizeLinear, 3, 1, /module/0_31/Conv_output_0, /module/0_31/QuantizeLinear_output_0
272, DequantizeLinear, 3, 1, /module/0_31/QuantizeLinear_output_0, /module/2_14/DequantizeLinear_output_0
273, DequantizeLinear, 3, 1, /module/2_14/Constant_2_output_0, /module/2_14/DequantizeLinear_1_output_0
274, DequantizeLinear, 3, 1, /module/2_14/Constant_6_output_0, /module/2_14/DequantizeLinear_2_output_0
275, Conv, 3, 1, /module/2_14/DequantizeLinear_output_0, /module/2_14/Conv_output_0
276, QuantizeLinear, 3, 1, /module/2_14/Conv_output_0, /module/2_14/QuantizeLinear_output_0
277, DequantizeLinear, 3, 1, /module/2_14/QuantizeLinear_output_0, /module/DequantizeLinear_19_output_0
278, DequantizeLinear, 3, 1, /module/QuantizeLinear_9_output_0, /module/DequantizeLinear_18_output_0
279, Add, 2, 1, /module/DequantizeLinear_18_output_0, /module/Add_9_output_0
280, QuantizeLinear, 3, 1, /module/Add_9_output_0, /module/QuantizeLinear_10_output_0
281, DequantizeLinear, 3, 1, /module/QuantizeLinear_10_output_0, /module/0_32/DequantizeLinear_output_0
282, DequantizeLinear, 3, 1, /module/0_32/Constant_2_output_0, /module/0_32/DequantizeLinear_1_output_0
283, DequantizeLinear, 3, 1, /module/0_32/Constant_6_output_0, /module/0_32/DequantizeLinear_2_output_0
284, Conv, 3, 1, /module/0_32/DequantizeLinear_output_0, /module/0_32/Conv_output_0
285, QuantizeLinear, 3, 1, /module/0_32/Conv_output_0, /module/0_32/QuantizeLinear_output_0
286, DequantizeLinear, 3, 1, /module/0_32/QuantizeLinear_output_0, /module/0_33/DequantizeLinear_output_0
287, DequantizeLinear, 3, 1, /module/0_33/Constant_2_output_0, /module/0_33/DequantizeLinear_1_output_0
288, DequantizeLinear, 3, 1, /module/0_33/Constant_6_output_0, /module/0_33/DequantizeLinear_2_output_0
289, Conv, 3, 1, /module/0_33/DequantizeLinear_output_0, /module/0_33/Conv_output_0
290, QuantizeLinear, 3, 1, /module/0_33/Conv_output_0, /module/0_33/QuantizeLinear_output_0
291, DequantizeLinear, 3, 1, /module/0_33/QuantizeLinear_output_0, /module/2_15/DequantizeLinear_output_0
292, DequantizeLinear, 3, 1, /module/2_15/Constant_2_output_0, /module/2_15/DequantizeLinear_1_output_0
293, DequantizeLinear, 3, 1, /module/2_15/Constant_6_output_0, /module/2_15/DequantizeLinear_2_output_0
294, Conv, 3, 1, /module/2_15/DequantizeLinear_output_0, /module/2_15/Conv_output_0
295, QuantizeLinear, 3, 1, /module/2_15/Conv_output_0, /module/2_15/QuantizeLinear_output_0
296, DequantizeLinear, 3, 1, /module/2_15/QuantizeLinear_output_0, /module/0_34/DequantizeLinear_output_0
297, DequantizeLinear, 3, 1, /module/0_34/Constant_2_output_0, /module/0_34/DequantizeLinear_1_output_0
298, DequantizeLinear, 3, 1, /module/0_34/Constant_6_output_0, /module/0_34/DequantizeLinear_2_output_0
299, Conv, 3, 1, /module/0_34/DequantizeLinear_output_0, /module/0_34/Conv_output_0
300, QuantizeLinear, 3, 1, /module/0_34/Conv_output_0, /module/0_34/QuantizeLinear_output_0
301, DequantizeLinear, 3, 1, /module/0_34/QuantizeLinear_output_0, /module/DequantizeLinear_20_output_0
302, GlobalAveragePool, 1, 1, /module/DequantizeLinear_20_output_0, /module/GlobalAveragePool_output_0
303, QuantizeLinear, 3, 1, /module/GlobalAveragePool_output_0, /module/QuantizeLinear_11_output_0
304, DequantizeLinear, 3, 1, /module/QuantizeLinear_11_output_0, /module/DequantizeLinear_21_output_0
305, Flatten, 1, 1, /module/DequantizeLinear_21_output_0, /module/Flatten_output_0
306, QuantizeLinear, 3, 1, /module/Flatten_output_0, /module/QuantizeLinear_12_output_0
307, DequantizeLinear, 3, 1, /module/QuantizeLinear_12_output_0, /module/1_1/DequantizeLinear_output_0
308, DequantizeLinear, 3, 1, /module/1_1/Constant_2_output_0, /module/1_1/DequantizeLinear_1_output_0
309, DequantizeLinear, 3, 1, /module/1_1/Constant_6_output_0, /module/1_1/DequantizeLinear_2_output_0
310, Gemm, 3, 1, /module/1_1/DequantizeLinear_output_0, /module/1_1/Gemm_output_0
311, QuantizeLinear, 3, 1, /module/1_1/Gemm_output_0, /module/1_1/QuantizeLinear_output_0
312, DequantizeLinear, 3, 1, /module/1_1/QuantizeLinear_output_0, 1634
Input tensor name - x
Output tensor name - 1634
In TIDL_onnxRtImportInit subgraph_name=mobilenet_v2_0
Layer 0, subgraph id mobilenet_v2_0, name=1634
Layer 1, subgraph id mobilenet_v2_0, name=x
================== [Optimization for mobilenet_v2_0 Started] ==================
In TIDL_runtimesOptimizeNet: LayerIndex = 315, dataIndex = 314
[TIDL Import] [PARSER] ERROR: Unable to merge Dequantize - /module/DequantizeLinear_output_0 upwards - DQ without initializer? -- [tidl_import_common.cpp, 7973]
[TIDL Import] ERROR: - Failed in function: tidl_optimizeNet -- [tidl_import_core.cpp, 2678]
[TIDL Import] ERROR: Network Optimization failed - Failed in function: TIDL_runtimesOptimizeNet -- [tidl_runtimes_import_common.cpp, 1392]
[TIDL Import] [PARSER] ERROR: - Failed in function: TIDL_computeImportFunc -- [tidl_onnxRtImport_EP.cpp, 2672]
************ in TIDL_subgraphRtDelete ************
2025-10-10 15:51:12.899147989 [E:onnxruntime:, sequential_executor.cc:514 ExecuteKernel] Non-zero status code returned while running TIDL_0 node. Name:'TIDLExecutionProvider_TIDL_0_0' Status Message: TIDL Compute Import Failed.
Traceback (most recent call last):
File "/home/szz/zx/code/edgeai-tidl-tools-11-00/examples/osrt_python/ort/imotion_onnxrt_ep.py", line 303, in <module>
run_model(model, all_calibration_files, required_options)
File "/home/szz/zx/code/edgeai-tidl-tools-11-00/examples/osrt_python/ort/imotion_onnxrt_ep.py", line 236, in run_model
output, proc_time, sub_graph_time, height, width = infer_npy(sess, all_calibration_files[i], config)
File "/home/szz/zx/code/edgeai-tidl-tools-11-00/examples/osrt_python/ort/imotion_onnxrt_ep.py", line 153, in infer_npy
output = list(sess.run(None, {input_name: input_data}))
File "/home/szz/anaconda3/envs/edgeai-tidl-1100/lib/python3.10/site-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 217, in run
return self._sess.run(output_names, input_feed, run_options)
onnxruntime.capi.onnxruntime_pybind11_state.Fail: [ONNXRuntimeError] : 1 : FAIL : Non-zero status code returned while running TIDL_0 node. Name:'TIDLExecutionProvider_TIDL_0_0' Status Message: TIDL Compute Import Failed.
Process finished with exit code 139 (interrupted by signal 11:SIGSEGV)
