Reboot error on dm8168 base on RDK01.09.00.06
Other Parts Discussed in Thread: PCM1773, TPS40400, PMP, TMP75, TVP5158
Hi guys,
Our applycation  base  on links of RDK01.09.00.06. And we add interface for links stop/del for applicaions.
Besides, we add running "unload.sh" under path: /opt/dvr_rdk/ti816x when system reboot.
When we try to run "reboot" under shell. The system procedue maybe as following:
[App to stop/del links and deinit]  --> [./unload.sh deinit the DSP/VPSS/HDVICP] --> [Kill the process and reboot].
Our problem is: sometimes, we found the kernnel may crash when boot up again (No drop power just software reboot).
1. Is my reboot procedule wrong?
2. How to fix this?
Any body came across the same problems?
Thanks.
logs:
[root@/]#
[root@/]# reboot
[root@/]#  * Stopping /etc/init.d/serviced...
 * Stopping mediaserver...
AUDIO >>  deInitAudioCaptureDevice@1758
AUDIO >> Device closed
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c chains_media_stop()@line1572
 [m3vpss ]  42634: CAPTURE: Stop in progress !!!
 [m3video]  42641: ENCODE: CH-1:
 [m3video] Stop in progress !!!
 [m3vpss ]  42634: CAPTURE: Stop Done !!!
 [m3vpss ]  42640: DEI    : Stop in progress, 0 requests pending !!!
 [m3vpss ]  42641: DEI    : Stop Done !!!
 [host] CHAINS_IPCBITS:Chains_ipcBitsRecvFxn_primary:Leaving... [m3video]  42659: ENCODE: CH-1:
 [m3video] Stop done !!!
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c chains_media_del()@line1605
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1345: Del links->capture
 [host]
22764: IPCFRAMESIN:Link[3000001b]:
 [host] RECV:3728       FREE:3728,DROPPED:0,AVGLATENCY:53
 [host]  22764: IPC_FRAMES_IN   : Delete in progress !!!
 [host]
22765: IPCFRAMESIN:Link[3000001b]:
 [host] Map of Frame buffers...Count = 0,Size = 0
 [host]
 [host] UnMap of Frame buffers...Count = 0,Size = 0
 [host]  22765: IPC_FRAMES_IN   : Delete Done !!!
 [m3vpss ]
 [host]  22765: IPC_FRAMES_OUT   : Delete in progress !!!
 [host]
22765: IPCFRAMESOUT:Link[30000018]:
 [host] RECV:3728,DROPPED:0,FREED:3728,AVGLATENCY:17
 [host]  22766: IPC_FRAMES_OUT   : Delete Done !!!
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1375: Del links->nsf
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1386: Del links->deiId
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1391: Del links->merge_1
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1394: Del links->merge_2
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1397: Del links->merge_3
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1403: Del links->ipcOutVpss
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1406: Del links->ipcInVideo
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1409: Del links->enc
 [m3video]  43660: IPC_IN_M3   : Delete in progress !!!
 [m3vpss ]  *** Capture Driver Advanced Statistics ***
 [m3video]  43660: IPC_IN_M3   : Delete Done !!!
 [m3vpss ]
 [m3video]  43660: ENCODE: CH-1:
 [m3vpss ]  VIP Parser Reset Count : 0
 [m3video]  43661: ENCODE: CH-1:
 [m3vpss ]
 [m3video]  ENC    : Delete in progress !!!
 [m3video] MemoryLeak:STAGE:0   HEAPNUM:0       ALLOC=14024     FREED=12128
 [m3vpss ]      |   Total    Even     Odd  Total  Even   Odd  Min /  Max  Min /  Max Dropped Fid Repeat Frame Error Y/C
 [m3video]  43661: ENCODE: CH0: FrameNum :      463, Processed Frames :      458, Total Process Time :     1527, Total Frame Interval:    18256, Dropped Frames:        0, FPS:       25 (Required FPS:       25)
 [m3video]  43662: ENCODE: CH1: FrameNum :      463, Processed Frames :      458, Total Process Time :     3275, Total Frame Interval:    18256, Dropped Frames:        0, FPS:       25 (Required FPS:       25)
 [m3vpss ]  CH  |  Fields  Fields  Fields    FPS   FPS   FPS       Width      Height  Fields      Count (Desc Error Y/C)
 [m3video]  43663: ENCODE: CH2: FrameNum :      463, Processed Frames :      271, Total Process Time :     2965, Total Frame Interval:    18224, Dropped Frames:      187, FPS:       15 (Required FPS:       25)
 [m3vpss ]  ------------------------------------------------------------------------------------------------------------
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1412: Del links->ipcBitsOutVideo
chains_multiChDucatiSystemUseCaseSwMs1_TriDisplay.c __chain_media_links_del()@line1415: Del links->ipcBitsInHost
 [host] 22780: IPCBITSIN:Link[3000001f]:
 [host] RECV:2941       FREE:2941,DROPPED:0,AVGLATENCY:0,AVG_APP_CB_TIME:0
 [host]  22780: IPC_BITS_IN   : Delete in progress !!!
 [host]  22780: IPC_BITS_IN   : Delete Done !!!
 [m3video]  43664: ENCODE: CH3: FrameNum :      463, Processed Frames :      458, Total Process Time :     4973, Total Frame Interval:    18256, Dropped Frames:        0, FPS:       25 (Required FPS:       25)
 [m3vpss ]  000 |    1009     505     504     53    26    26  719 /  720  288 /  288      76          0 0/0 (0/0)
 [m3video]  43665: ENCODE: CH4: FrameNum :      463, Processed Frames :      386, Total Process Time :     2696, Total Frame Interval:    15416, Dropped Frames:       72, FPS:       26 (Required FPS:       25)
 [m3video]  43665: ENCODE: CH5: FrameNum :      463, Processed Frames :      338, Total Process Time :     3713, Total Frame Interval:    14448, Dropped Frames:      120, FPS:       24 (Required FPS:       25)
 [m3vpss ]  001 |    1009     505     504     53    26    26  719 /  720  288 /  288      76          0 0/0 (0/0)
 [m3video]  43665: ENCODE: CH6: FrameNum :      463, Processed Frames :      290, Total Process Time :     4346, Total Frame Interval:    14448, Dropped Frames:      168, FPS:       21 (Required FPS:       25)
 [m3video]  43666: ENCODE: CH7: FrameNum :      463, Processed Frames :      242, Total Process Time :     4421, Total Frame Interval:    14448, Dropped Frames:      216, FPS:       17 (Required FPS:       25)
 [m3vpss ]  002 |    1009     505     504     53    26    26  719 /  720  288 /  288      76          0 0/0 (0/0)
 [m3video]  43667: ENCODE: CH-1:
 [m3video]  ENC    : Delete done !!!
 [m3vpss ]  003 |    1009     505     504     53    26    26  720 /  720  288 /  288      76          0 0/0 (0/0)
 [m3video]  43667: IPC_BITS_OUT   : Delete in progress !!!
 [m3vpss ]
 [m3video] 43667: IPCBITSOUT:Link[1000001d]:
 [m3video] RECV:2941    FREE:2941,DROPPED:0,AVGLATENCY:12
 [m3video]  43667: PRF : IPC_BITS_OUT0 : t: 58 ms, c: 2589, f: 2941, fps: 50706, fpc: 1
 [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
 [m3video]  43668: IPC_BITS_OUT   : Delete Done !!!
 [m3vpss ]
 [m3vpss ]  *** Capture List Manager Advanced Statistics ***
 [m3vpss ]
 [m3vpss ]  List Post Count        : 2492
 [m3vpss ]  List Stall Count       : 0
 [m3vpss ]  List Post Time (ms)    : Max = 0, Min = 0, Avg = 0, Total = 0
 [m3vpss ]  INTC Timeout Count     : (0, 0) (Min timeout value = 944, 1000)
 [m3vpss ]  Descriptor miss found count : 0
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  VIP and VPDMA registers,
 [m3vpss ]  VIP0 : FIQ_STATUS  : 0x4810551c = 0x00000400
 [m3vpss ]  VIP1 : FIQ_STATUS  : 0x48105a1c = 0x00000000
 [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x00000000
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]  43650: CAPTURE: Fields = 3728 (fps = 186, CPU Load = 51)
 [m3vpss ]  43650: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
 [m3vpss ]  43650: SYSTEM  : Heap Free Space (System = 20648 bytes, SR0 = 14614912 bytes, FrmBuf = 300946304 bytes,
 [m3vpss ]          BitBuf = 81710976 bytes, Mbx = 10239 msgs)
 [m3vpss ]  43651: CAPTURE: Delete in progress !!!
 [m3vpss ]  43651: CAPTURE: Delete Done !!!
 [m3vpss ]  43651: IPC_FRAMES_OUT   : Delete in progress !!!
 [m3vpss ] 43652: IPCFRAMESOUT:Link[20000018]:
 [m3vpss ] RECV:3728    FORWARD:0,DROPPED:0,AVGLATENCY:0
 [m3vpss ]  43652: PRF : IPC_FRAMES_OUT0 : t: 70 ms, c: 995, f: 3728, fps: 53257, fpc: 3
 [m3vpss ]  43652: IPC_FRAMES_OUT   : Delete Done !!!
 [m3vpss ] 43654: IPCFRAMESIN:Link[2000001b]:
 [m3vpss ] RECV:3724    FREE:3724,DROPPED:4,AVGLATENCY:7
 [m3vpss ]  43654: IPC_FRAMES_IN   : Delete in progress !!!
 [m3vpss ]  43654: IPC_FRAMES_IN   : Delete Done !!!
 [m3vpss ]  43655: NSF    : Fields = 1852 (fps = 463) !!!
 [m3vpss ]  43655: NSF: Delete in progress !!!
 [m3vpss ]  43655: NSF: Delete Done !!!
 [m3vpss ]  43656: DEI    : Stop in progress, 0 requests pending !!!
 [m3vpss ]  43656: DEI    : Stop Done !!!
 [m3vpss ]  43656: DEI    : Fields = 3700 (fps = 550), !!!
 [m3vpss ]  43656: DEI    : Delete in progress !!!
 [m3vpss ]  43658: DEI    : Delete Done !!!
 [m3vpss ]  43658: MERGE   : Delete Done !!!
 [m3vpss ]  43659: MERGE   : Delete Done !!!
 [m3vpss ]  43659: IPC_OUT_M3   : Delete in progress !!!
 [m3vpss ]  43660: IPC_OUT_M3   : Delete Done !!!
 [host] Entered:Chains_ipcBitsExit...
 [host] Leaving:Chains_ipcBitsExit...
 [host] Entered:Chains_ipcFramesExit...
 [host] Leaving:Chains_ipcFramesExit... [c6xdsp ]
 [m3video]
 [m3vpss ]
 [c6xdsp ]  43862: LOAD: CPU: 1% HWI: 0%, SWI:0%
 [m3video]  45645: LOAD: CPU: 9% HWI: 0%, SWI:0%
 [m3vpss ]  45644: LOAD: CPU: 12% HWI: 1%, SWI:0%
 [c6xdsp ]
 [m3video]
 [m3vpss ]
 28784: SYSTEM: System Common De-Init in progress !!!
 [host] OSA_tskDelete:In progress...
 [host] OSA_tskDelete:In progress... 28789: SYSTEM: IPC de-init in progress !!!
 28805: SYSTEM: IPC de-init DONE !!!
 28805: SYSTEM: System Common De-Init Done !!!
 ASSERT (system_ipc_msgq.c|System_ipcMsgQSendMsg|336)
stopped /opt/ad/bin/mediaserver (pid 318)                               [ ok ]
[module] vpss remove done.
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff05020
 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
 [c6xdsp ]  47946: SYSTEM  : System Dsp De-Init in progress !!!
 [c6xdsp ]  47951: SYSTEM  : De-Initializing Links !!!
 [c6xdsp ] Received character 'e'
 [c6xdsp ]  47961: SYSTEM  : De-Initializing Links ... DONE !!!
 [c6xdsp ]  47961: SYSTEM  : System Dsp De-Init Done !!!
 [c6xdsp ]  49101: SYSTEM  : System Common De-Init in progress !!!
 [c6xdsp ]  49102: SYSTEM: IPC de-init in progress !!!
 [c6xdsp ]  49102: SYSTEM: IPC Notify de-init in progress !!!
 [c6xdsp ]  49102: SYSTEM: IPC Notify de-init DONE !!!
 [c6xdsp ]  49102: SYSTEM: IPC MsgQ de-init in progress !!!
 [c6xdsp ]  49102: SYSTEM: IPC MsgQ Task Delete in progress !!!
 [c6xdsp ]  49103: SYSTEM: IPC MsgQ Task Delete DONE !!!
 [c6xdsp ]  49103: SYSTEM: IPC MsgQ Close in progress !!!
 [c6xdsp ]  49103: SYSTEM: IPC MsgQ Close DONE !!!
 [c6xdsp ]  49103: SYSTEM: IPC MsgQ Heap Close in progress !!!
 [c6xdsp ]  49103: SYSTEM: IPC MsgQ Heap Close DONE !!!
 [c6xdsp ]  49103: SYSTEM: IPC MsgQ de-init DONE !!!
 [c6xdsp ]  49103: SYSTEM: IPC de-init DONE !!!
 [c6xdsp ]  49103: SYSTEM  : System Common De-Init Done !!!
 [m3video]  50784: SYSTEM  : De-Initializing Links !!!
 [m3video]  50793: SYSTEM  : Heap Free Space (System = 2088376 bytes, SR0 = 15795840 bytes, FrmBuf = 374225792 bytes,
 [m3video]          BitBuf = 93323136 bytes, Mbx = 10240 msgs)
 [m3video] Received character 'e'
 [m3video]  50793: SYSTEM  : De-Initializing Links ... DONE !!!
 [m3video]  50793: SYSTEM  : System Video De-Init in progress !!!
 [m3video]  50793: SYSTEM  : System Video De-Init Done !!!
 [m3video]  50793: SYSTEM  : System Common De-Init in progress !!!
 [m3video]  50794: SYSTEM: IPC de-init in progress !!!
 [m3video]  50794: SYSTEM: IPC Notify de-init in progress !!!
 [m3video]  50794: SYSTEM: IPC Notify de-init DONE !!!
 [m3video]  50794: SYSTEM: IPC MsgQ de-init in progress !!!
 [m3video]  50794: SYSTEM: IPC MsgQ Task Delete in progress !!!
 [m3video]  50795: SYSTEM: IPC MsgQ Task Delete DONE !!!
 [m3video]  50795: SYSTEM: IPC MsgQ Close in progress !!!
 [m3video]  50795: SYSTEM: IPC MsgQ Close DONE !!!
 [m3video]  50795: SYSTEM: IPC MsgQ Heap Close in progress !!!
 [m3video]  50795: SYSTEM: IPC MsgQ Heap Close DONE !!!
 [m3video]  50795: SYSTEM: IPC MsgQ de-init DONE !!!
 [m3video]  50795: SYSTEM: IPC de-init DONE !!!
 [m3video]  50795: SYSTEM  : System Common De-Init Done !!!
 [m3vpss ]  50868: SYSTEM  : De-Initializing Links !!!
 [m3vpss ]  50902: SYSTEM  : Heap Free Space (System = 28360 bytes, SR0 = 16206464 bytes, FrmBuf = 374225792 bytes,
 [m3vpss ]          BitBuf = 93323136 bytes, Mbx = 10240 msgs)
 [m3vpss ] Received character 'e'
/opt/dvr_rdk/ti816x
 [m3vpss ]  50902: SYSTEM  : De-Initializing Links ... DONE !!!
After Ipc_stopCallback status: [0x00000000]
Stopped slave procId 0.
Unloaded slave procId 0.
Detached from slave procId 0.
Stopped slave procId 1.
 [m3vpss ]  50902: SYSTEM  : System VPSS De-Init in progress !!!
 [m3vpss ]  50904: SYSTEM  : System VPSS De-Init Done !!!
 [m3vpss ]  50904: SYSTEM  : System Common De-Init in progress !!!
 [m3vpss ]  50905: SYSTEM: IPC de-init in progress !!!
 [m3vpss ]  50905: SYSTEM: IPC Notify de-init in progress !!!
 [m3vpss ]  50905: SYSTEM: IPC Notify de-init DONE !!!
 [m3vpss ]  50905: SYSTEM: IPC MsgQ de-init in progress !!!
 [m3vpss ]  50905: SYSTEM: IPC MsgQ Task Delete in progress !!!
 [m3vpss ]  50906: SYSTEM: IPC MsgQ Task Delete DONE !!!
 [m3vpss ]  50906: SYSTEM: IPC MsgQ Close in progress !!!
 [m3vpss ]  50906: SYSTEM: IPC MsgQ Close DONE !!!
 [m3vpss ]  50906: SYSTEM: IPC MsgQ Heap Close in progress !!!
 [m3vpss ]  50906: SYSTEM: IPC MsgQ Heap Close DONE !!!
 [m3vpss ]  50906: SYSTEM: IPC MsgQ de-init DONE !!!
 [m3vpss ]  50907: SYSTEM: IPC de-init DONE !!!
 [m3vpss ]  50907: SYSTEM  : System Common De-Init Done !!!
Unloaded slave procId 1.
Detached from slave procId 1.
Stopped slave procId 2.
Unloaded slave procId 2.
Detached from slave procId 2.
Removed syslink kernel module                                           [ ok ]
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
musb-hdrc musb-hdrc.1: remove, state 1
usb usb2: USB disconnect, address 1
musb-hdrc musb-hdrc.1: USB bus 2 deregistered
musb-hdrc musb-hdrc.0: remove, state 1
usb usb1: USB disconnect, address 1
musb-hdrc musb-hdrc.0: USB bus 1 deregistered
Restarting system.
U-Boot 2010.06 (Feb 13 2012 - 01:01:27)
TI8168-GP rev 1.1
ARM clk: 987MHz
DDR clk: 796MHz
I2C:   ready
DRAM:  2 GiB
NAND:  256 MiB
No Found BOOTROOT using default var /dev/mtdblock5
No Found BOOTKERNEL using default var 0x280000
No Found BOOTTYPE using default var jffs2
No Found BTL_BOOT_COUNT using default var 0
No Found BTL_CH_PART using default var 0
Net:   Ethernet PHY: GENERIC @ 0x00
DaVinci EMAC
Hit any key to stop autoboot:  0
Connect speed 100M Full
Using DaVinci EMAC device
TFTP from server 10.51.237.220; our IP address is 10.51.252.243; sending through gateway 10.51.252.1
Filename 'ym/uImage.base'.
Load address: 0x81000000
Loading: #################################################################
done
Bytes transferred = 2231356 (220c3c hex)
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-2.6.37
   Created:      2012-02-13  11:52:46 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2231292 Bytes = 2.1 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.37 (root@ad-dev-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #5 Mon Feb 13 19:52:41 CST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8168evm
vram size = 20971520 at 0
reserved size = 20971520 at 0
FB: Reserving 20971520 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 1.1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 59396
Kernel command line: mem=254M console=ttyO0,115200n8 root=/dev/mtdblock5 rw rootfstype=jffs2 init=/linuxrc ip=off vram=20M notifyk.vpssm3_sva=0xBFD00000 rootdelay=1
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 234MB = 234MB total
Memory: 232500k/232500k available, 27596k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd0000000 - 0xf8000000   ( 640 MB)
    lowmem  : 0xc0000000 - 0xcfe00000   ( 254 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0036000   ( 184 kB)
      .text : 0xc0036000 - 0xc0438000   (4104 kB)
      .data : 0xc0438000 - 0xc0479800   ( 262 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
registered PCM1773 device
registered ti816x_vpss device
registered ti816x_sr device
pm_dbg_init: only OMAP3 supported
Registered ti81xx_fb device
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: pmbus_vr: 800 <--> 1100 mV at 1125 mV
269:tps40400_probe TPS40400 exponent:-10
282:tps40400_probe PMBUS_REVISION: 17
285:tps40400_probe VOUT_CAL_OFFSET: 112
288:tps40400_probe VOUT_CAL_GAIN: 0
291:tps40400_probe PMBUS_VOUT_SCALE_LOOP: b933
295:tps40400_probe Set PMBUS_VOUT_SCALE_LOOP: 0
298:tps40400_probe PMBUS_VOUT_SCALE_LOOP: b933
302:tps40400_probe PMBUS_VOUT_MARGIN_HIGH: 547
306:tps40400_probe PMBUS_VOUT_MARGIN_LOW: 33d
314:tps40400_probe PMBUS_VOUT_MARGIN_LOW: 33d
318:tps40400_probe PMBUS_READ_VOUT: 490
324:tps40400_probe Read VOUT_TRIM: 0x36
337:tps40400_probe VOUT_CAL_OFFSET: 241
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
musb-hdrc: kernel must blacklist external hubs
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d000c000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d001e800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
msgmni has been set to 454
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 9 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000240000 : "U-Boot"
0x000000240000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "KernelA"
0x000000680000-0x000000a80000 : "KernelB"
0x000000a80000-0x000001280000 : "Conf"
0x000001280000-0x000005280000 : "RootfsA"
0x000005280000-0x000005380000 : "System-param"
0x000005380000-0x000009380000 : "RootfsB"
0x000009380000-0x000010000000 : "Work"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver Vitesse VSC8641
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
bq3200: reg[8] = 0x20
bq32k 1-0068: rtc core: registered bq32k as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbfd00000
tmp75 1-0049: TMP75 core: registered tmp75 as temper0
usbcore: registered new interface driver snd-usb-audio
PCM1773 FUNC[pcm1773_modinit]---------------
PCM1773 FUNC[pcm1773_codec_probe]---------------
 File soc-core.c line#963 1
PCM1773 SoC Audio Codec probe---------------
asoc: pcm1773-hifi <-> davinci-mcasp.1 mapping ok
asoc: tvp5158-hifi <-> davinci-mcasp.2 mapping ok
ALSA device list:
  #0: TI8168 ADLOONG (PCM1773)
  #1: TI81XX ADLOONG {TVP5158}
oprofile: hardware counters not available
oprofile: using timer interrupt.
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
smartreflex smartreflex: Driver initialized
bq32k 1-0068: setting system clock to 2012-02-13 18:15:26 UTC (1329156926)
Waiting 1sec before mounting root device...
Unable to handle kernel paging request at virtual address 000010fe
pgd = c0004000
[000010fe] *pgd=00000000
Internal error: Oops: 5 [#1]
last sysfs file:
Modules linked in:
CPU: 0    Not tainted  (2.6.37 #5)
PC is at jffs2_add_fd_to_list+0x9c/0xb8
LR is at jffs2_scan_medium+0xb94/0x1168
pc : [<c0140d14>]    lr : [<c0146cdc>]    psr: 20000013
sp : ce42bc68  ip : ce42bc90  fp : ce42bc8c
r10: ce6b8600  r9 : 00000000  r8 : ce6b8600
r7 : ce6ec525  r6 : ce6ec51c  r5 : ce6ec510  r4 : 000010ee
r3 : 7c3acba2  r2 : 49616d69  r1 : ce6ec510  r0 : ce6b8600
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c5387d  Table: 80004019  DAC: 00000017
Process swapper (pid: 1, stack limit = 0xce42a2e8)
Stack: (0xce42bc68 to 0xce42c000)
bc60:                   000010ee 00000000 ce6ec510 cdc1a1a4 028ba4d8 00000000
bc80: ce42bd2c ce42bc90 c0146cdc c0140c84 cdc89798 c0479488 c00c8248 c00c7f5c
bca0: 00000072 ce6ec525 cdc00000 ce6b86bc ce6b86cc ce6b8684 ce6b86d4 00000145
bcc0: 00000000 00000000 00020000 ce6e4204 0000000a 0001fccc fa3ebe78 cdc89798
bce0: 00004204 028a0334 c009f464 e0011985 00000030 ce42bd00 c00bc57c cdc00000
bd00: ce42bd1c ce6b86a4 ce6b86bc ce6b86b4 ce6b86ac ce6b869c 00000000 ce6b8694
bd20: ce42bd74 ce42bd30 c0149140 c0146154 00000920 c00e6918 ce42bd74 ce6b8600
bd40: c00bc584 00000000 ce6b8400 00020000 00000000 ce6b8600 ce6b8400 00000000
bd60: 00000000 c014b8ec ce42bd94 ce42bd78 c014ac14 c0148fac ce6b8600 ce6b8400
bd80: 00000000 00000001 ce42bdb4 ce42bd98 c014b9a8 c014aac4 ce6b8400 ce67e000
bda0: 00008000 00000000 ce42bdd4 ce42bdb8 c01e6d04 c014b8f8 ce6b5740 00000000
bdc0: c045ceb0 00008000 ce42bdfc ce42bdd8 c01e6df4 c01e6cbc ce67e000 c014b8ec
bde0: ce6b5740 01f00005 00008000 c045ceb0 ce42be34 ce42be00 c01e6f3c c01e6da4
be00: 00000005 c014b8ec 0000000a c00a8fe0 ce6b7580 ce6b5740 00000000 ce6b5740
be20: c045ceb0 00008000 ce42be4c ce42be38 c014b680 c01e6e08 c014b8ec ce6b5740
be40: ce42be84 ce42be50 c00c17f4 c014b670 c00d44fc c00d448c ce42be84 00008000
be60: ce6b5740 00000000 ce6b5700 c045ceb0 00000000 ce6b5700 ce42beac ce42be88
be80: c00c197c c00c1754 00008000 00000000 00000000 00000020 ce6b5740 00000000
bea0: ce42befc ce42beb0 c00d74b8 c00c194c 00000000 00001000 ce42bee4 ce42bec8
bec0: c00a8f28 c00a8e44 ce404a80 ce007b80 c03c99a5 00000000 ce415000 c03c99a5
bee0: 00008000 00008000 00000000 c03c99a5 ce42bf34 ce42bf00 c00d75a4 c00d6e38
bf00: 00000000 ce42bf10 c00cadc8 00000000 ce6b5740 ce6b5700 ce412000 c002a39c
bf20: c0067758 ce412000 ce42bf54 ce42bf38 c0008ef4 c00d7524 00000000 c002a39c
bf40: c0067758 ce412000 ce42bf9c ce42bf58 c0009178 c0008ed8 00000003 c0167bec
bf60: 00000080 5c2d2f7c 6b636f6c ce412000 01f00005 c002a39c 01f00005 c002a39c
bf80: c0067758 00000013 00000000 00000000 ce42bfbc ce42bfa0 c0009344 c0009084
bfa0: ce42bfbc c002a3ac c002a3ac c0479864 ce42bfdc ce42bfc0 c00094d4 c00092a4
bfc0: ce42bfdc ce42bfd0 c0479800 c0008670 ce42bff4 ce42bfe0 c0008784 c0009370
bfe0: 00000000 c0008670 00000000 ce42bff8 c0067758 c000867c ffffffff ffffffff
Backtrace:
[<c0140c78>] (jffs2_add_fd_to_list+0x0/0xb8) from [<c0146cdc>] (jffs2_scan_medium+0xb94/0x1168)
 r9:00000000 r8:028ba4d8 r7:cdc1a1a4 r6:ce6ec510 r5:00000000
r4:000010ee
[<c0146148>] (jffs2_scan_medium+0x0/0x1168) from [<c0149140>] (jffs2_do_mount_fs+0x1a0/0x648)
[<c0148fa0>] (jffs2_do_mount_fs+0x0/0x648) from [<c014ac14>] (jffs2_do_fill_super+0x15c/0x238)
[<c014aab8>] (jffs2_do_fill_super+0x0/0x238) from [<c014b9a8>] (jffs2_fill_super+0xbc/0xd4)
 r7:00000001 r6:00000000 r5:ce6b8400 r4:ce6b8600
[<c014b8ec>] (jffs2_fill_super+0x0/0xd4) from [<c01e6d04>] (mount_mtd_aux+0x54/0xe8)
 r7:00000000 r6:00008000 r5:ce67e000 r4:ce6b8400
[<c01e6cb0>] (mount_mtd_aux+0x0/0xe8) from [<c01e6df4>] (mount_mtd_nr+0x5c/0x64)
 r7:00008000 r6:c045ceb0 r5:00000000 r4:ce6b5740
[<c01e6d98>] (mount_mtd_nr+0x0/0x64) from [<c01e6f3c>] (mount_mtd+0x140/0x170)
 r7:c045ceb0 r6:00008000 r5:01f00005 r4:ce6b5740
[<c01e6dfc>] (mount_mtd+0x0/0x170) from [<c014b680>] (jffs2_mount+0x1c/0x28)
[<c014b664>] (jffs2_mount+0x0/0x28) from [<c00c17f4>] (vfs_kern_mount+0xac/0x1d8)
[<c00c1748>] (vfs_kern_mount+0x0/0x1d8) from [<c00c197c>] (do_kern_mount+0x3c/0xe0)
[<c00c1940>] (do_kern_mount+0x0/0xe0) from [<c00d74b8>] (do_mount+0x68c/0x6ec)
 r9:00000000 r8:ce6b5740 r7:00000020 r6:00000000 r5:00000000
r4:00008000
[<c00d6e2c>] (do_mount+0x0/0x6ec) from [<c00d75a4>] (sys_mount+0x8c/0xcc)
[<c00d7518>] (sys_mount+0x0/0xcc) from [<c0008ef4>] (do_mount_root+0x28/0xc0)
 r7:ce412000 r6:c0067758 r5:c002a39c r4:ce412000
[<c0008ecc>] (do_mount_root+0x0/0xc0) from [<c0009178>] (mount_block_root+0x100/0x220)
 r4:ce412000
[<c0009078>] (mount_block_root+0x0/0x220) from [<c0009344>] (mount_root+0xac/0xcc)
[<c0009298>] (mount_root+0x0/0xcc) from [<c00094d4>] (prepare_namespace+0x170/0x1d4)
 r4:c0479864
[<c0009364>] (prepare_namespace+0x0/0x1d4) from [<c0008784>] (kernel_init+0x114/0x154)
 r5:c0008670 r4:c0479800
[<c0008670>] (kernel_init+0x0/0x154) from [<c0067758>] (do_exit+0x0/0x5ec)
 r5:c0008670 r4:00000000
Code: e2846004 e5964000 e3540000 0a000003 (e5942010)
---[ end trace b12f3aa5b609a20f ]---
Kernel panic - not syncing: Attempted to kill init!
Backtrace:
[<c0044b7c>] (dump_backtrace+0x0/0x110) from [<c0325374>] (dump_stack+0x18/0x1c)
 r7:ce428000 r6:ce428000 r5:c0140d16 r4:c0479ed0
[<c032535c>] (dump_stack+0x0/0x1c) from [<c03253d8>] (panic+0x60/0x17c)
[<c0325378>] (panic+0x0/0x17c) from [<c00677d4>] (do_exit+0x7c/0x5ec)
 r3:c04518d0 r2:ce42ba30 r1:ce4280fc r0:c03d4961
[<c0067758>] (do_exit+0x0/0x5ec) from [<c0044f28>] (die+0x29c/0x2d8)
[<c0044c8c>] (die+0x0/0x2d8) from [<c00473c4>] (__do_kernel_fault+0x6c/0x8c)
[<c0047358>] (__do_kernel_fault+0x0/0x8c) from [<c03293d4>] (do_page_fault+0x1f0/0x20c)
 r9:00000005 r8:000010fe r7:00000000 r6:ce428000 r5:ce42bc20
r4:c043c59c
[<c03291e4>] (do_page_fault+0x0/0x20c) from [<c0329414>] (do_translation_fault+0x24/0xa8)
[<c03293f0>] (do_translation_fault+0x0/0xa8) from [<c00362a4>] (do_DataAbort+0x3c/0x9c)
 r7:ce42bc20 r6:00000005 r5:c043c5ec r4:c043c59c
[<c0036268>] (do_DataAbort+0x0/0x9c) from [<c03273ac>] (__dabt_svc+0x4c/0x60)
Exception stack(0xce42bc20 to 0xce42bc68)
bc20: ce6b8600 ce6ec510 49616d69 7c3acba2 000010ee ce6ec510 ce6ec51c ce6ec525
bc40: ce6b8600 00000000 ce6b8600 ce42bc8c ce42bc90 ce42bc68 c0146cdc c0140d14
bc60: 20000013 ffffffff
 r8:ce6b8600 r7:ce6ec525 r6:ce6ec51c r5:ce42bc54 r4:ffffffff
r4:000010ee
r4:00008000
 r4:ce412000
 r4:c0479864
  • I delete the duplicated post:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/164739.aspx.
    The most important thing is that we found:
    The initial process (init.sh and load.sh) and deinitial process (unload.sh) of M3 and dsp is not corresponding in TI RDK sometimes.
    We just run init.sh, load.sh after system bootup. After that we run unload.sh. Then reboot the system. It is easy to cause the kernel crash during this process.
    But if we do not run init.sh and load.sh to initialize the M3 and dsp, the kernel seems stable.
    Our quest:
    1. Is my test process wrong? What is the problem caused it?
    2. How to fix it?
    Thank.
  • Yaming,
    From the log, it seems the problem is due to JFFS2 filesystem. Have you done "sync" and 'umount' before reboot?
    You can also try with NFS and see if the problem is stil there to confirm the problem is related to filesystem or not.
  • As Chris mentioned, can we get similar test result with NFS? The binary uImage and JFFS2 with 01.09.00.16 had issues and could not be used as-is. We recommend to build the code and use with NFS. If issue comes again, we wouls look into it. Sorry for the inconvinience.
    Anshuman
  • Chris and Anshuman, thanks for your replay.
      I try to sync and umount the jffs2 before system reboot. The kernel crash and block still exist. The NFS maybe have the same issue.
     The log I pasted about "mount root issue" is just a part of the kernel crash .  Actualy, the kernel crash we came across also happen at other part of kernel such as in EMAC driver init, edma, and soon on. Even after the system boot ok, the kernel crash happen when A8 initialize the M3 and DSP (init.sh and load.sh). The problem we came across not just mounting rootfs error.
    It seems some modules in kernel is no stable when kernel reboot. We need to catch it.
    So, we want to check whether the "init.sh/load.sh" and "unload.sh" is exactly corresponding firstly. Because if we do run "init.sh and load.sh", the kernel reboot well.
    I can confirm init.sh, load.sh and unload.sh correspond to each other in the release. I want to confirm a few things - are you using uImage from our release package? Are you using uImage for DM8168 EVM or DM8168 DVR? Are you using mem=128M or mem=256M?
    Anshuman
  • Thanks Anshuman.
    Our uImage inherit from DM8168DVR from kernel_40012. And we make some patches according our hareware change.
    And kernel memory, we use "MEM=254" following the release note of RDK 01.09.00.06.
    We found if we do not run M3 and DSP init, this kernel is stable.
    Besides, Kernel crash did not happen everytime when system reboot. If we continue reboot some times, kernel will crash.
    As you mentioned, if init.sh, load.sh and unload.sh is correspoconding, we will check the other part kernel.
    Allen
