Linux 3.12 on AM335x / Beaglebone
Other Parts Discussed in Thread: DA8XX, TPS65217, OMAP3530, DAC7512, PMP, TCA6416, TCA8418, LM8323, LM8333, ADS7846, TSC2005, TSC2007, TWL6040, PCF8574, TPS65910, BQ27000, LP8727, BQ24190, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95234, LM95241, LM95245, ADS1015, ADS7828, ADS7871, AMC6821, INA209, TMP102, TMP401, TMP421, DRA752, TPS65010, TPS65090, TPS65218, TPS65912, LM3533, LP3971, LP3972, TPS51632, TPS62360, TPS65023, TLV320AIC23B, TVP5150, TVP7002, THS8200, THS7303, TFP410, TPD12S015, LM3630, LM3639, TWL6030, LM3530, LM3642, LP3944, LP5521, LP5523, LP5562, LP8501, DAC124S085, TCA6507, TMP006, BQ24735, LP3943, LM3560, LM3630A
Just downloaded the latest SDK release from TI (Linux 3.12)
When I cross-compiled it and load it to BeagleBone Black board, I get the following error, Any ideas?
## Booting kernel from Legacy Image at 815f0000 ...
   Image Name:   Linux-3.12.10-ti2013.12.01
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4387592 Bytes = 4.2 MiB
   Load Address: 815f0000
   Entry Point:  815f0000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
Starting kernel ...
undefined instruction
pc : [<815f0008>]          lr : [<9f74e184>]
sp : 9f62cd70  ip : ffffffff     fp : 9f7a33dc
r10: 00000000  r9 : 9f62cf28     r8 : 9f6331cc
r7 : 00000000  r6 : 815f0000     r5 : 9f7a7248  r4 : 00000000
r3 : 9f62cfe0  r2 : 80000100     r1 : 00000e05  r0 : 9f62cfe0
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32
Resetting CPU ...
resetting ...
  • Desmond,
    Ok, those values are expected. What change you made to get these register values?
    Now, you have to modify the driver to change the VBUS sensing logic, since I don't know the 3.8 kernel you use, I cannot give you the exact patch, but please find where the USB PHY power on/off API is or anywhere modifies USB_CTRL0 register (TRM section 9.3.1.20), to keep the bit 19 (otgvdet_en) unset. If you do it correctly, at the end you should see register 0x47401460 is 0x19 when no usb device plugged in.
  • Hi Bin,
    Thanks a lot. Our hardware engineer made some change on hardware side to change the register value. Right now I am using the package from TI
    am335x-evm-sdk-src-07.00.00.00.tar.gz
    linux-3.12.10-ti2013.12.01
    Could you tell me how to modify USB_CTRL0 register?
    desmond
  • Desmond,
    Please use the following patch.
    diff --git a/drivers/usb/phy/phy-am335x-control.c b/drivers/usb/phy/phy-am335x-control.c
    index 634f49a..59a55e0 100644
    --- a/drivers/usb/phy/phy-am335x-control.c
    +++ b/drivers/usb/phy/phy-am335x-control.c
    @@ -85,6 +85,10 @@ static void am335x_phy_power(struct phy_control *phy_ctrl, u32 id, bool on)
            if (on) {
                    val &= ~(USBPHY_CM_PWRDN | USBPHY_OTG_PWRDN);
                    val |= USBPHY_OTGVDET_EN | USBPHY_OTGSESSEND_EN;
    +               /* for USB0 in host-only mode and USB0_VBUS pin is directly tied to 5V, ignore first vbus sensing */
    +               if (id == 0)
    +                       val &= ~USBPHY_OTGVDET_EN;
            } else {
                    val |= USBPHY_CM_PWRDN | USBPHY_OTG_PWRDN;
  • please don't forget the previous patch which sets dr_mode to host.
  • Hi Bin,
    Thank you so much!
    Could you tell me which patch I should use?
    desmond
    Patch 1:
    diff --git a/arch/arm/mach-omap2/board-am335xevm.c b/arch/arm/mach-omap2/board-am335xevm.c
    index 119ef2d..1eb3d5b 100644
    --- a/arch/arm/mach-omap2/board-am335xevm.c
    +++ b/arch/arm/mach-omap2/board-am335xevm.c
    @@ -2636,8 +2636,8 @@ static struct omap_musb_board_data musb_board_data = {
             * mode[4:7] = USB1PORT's mode
             * AM335X beta EVM has USB0 in OTG mode and USB1 in host mode.
    -       .mode           = (MUSB_HOST << 4) | MUSB_OTG,
    +       .mode           = (MUSB_HOST << 4) | MUSB_HOST,
            .instances      = 1,
    Patch 2:
    diff --git a/arch/arm/boot/dts/am335x-boneblack.dts b/arch/arm/boot/dts/am335x-boneblack.dts
    index 2f64afa..4dae962 100644
    --- a/arch/arm/boot/dts/am335x-boneblack.dts
    +++ b/arch/arm/boot/dts/am335x-boneblack.dts
    @@ -62,6 +62,14 @@
    +ocp {
    +       musb: usb@47400000 {
    +               usb@47401000 {
    +                       dr_mode = "host";
     &i2c0 {
            hdmi1: hdmi@70 {
                  compatible = "nxp,tda998x";
  • Hi Bin,
    Thank you very much for your help.
    desmond
  • Desmond, is the issue solved?
  • Hi Bin,
    This issue has been solved. Thank you so much!
    Have a nice day!
    I have another question, that is, how set gpio pin as output and set it as high? because if I use mmap, it gives me bus error.
    desmond
  • Desmond,
    Thanks for the update.
    gpio is not in the scope of my support area, but if your question is in the kernel space, you should set the pgio pin mode in pinmux; or refer to kernel Documentation/gpio.txt, which explains using gpio in both kernel and user space.
    By the way, your new questions would get more attention if you post them in new threads. It is hard to monitor closed forum threads.
  • Hi guys,
    I am wondering if wakeup from mem has been fixed in SDK 07.00.00.
    Did anyone try it on BeagleBone Black?
    The command I am using to put the board into mem (Suspend-to-RAM) is:
    rtcwake -d /dev/rtc0 -m mem -s 60
  • Hi Bin,
    Why do you have to add this line of code to disable the bit-19. and why the USB1 still works even with this bit-19 set.
    By the way, I have to add this line in order to make my USB0 works. So your patch is working but I just can not see the logic behind, please advice.
    Note: I have modify the USB0 circuit by referring to  USB1. So when the board is power on, both USB0 and USB1 are power on to both the USBx_VBUS analogue pin.
  • Zhi Yong,
    AM335x MUSB is a OTG dual-role USB controller, which transitions between host and peripheral mode ( A-device or B-device in OTG terms) depending on some conditions. Due to the nature of OTG logic, while transition to host mode, MUSB first senses USBx_VBUS to ensure VBUS does NOT have any voltage, (this is called the first VBUS sensing.) then starts the transition. Within 100ms, MUSB senses VBUS again to ensure VBUS has been raised to the valid threshold, (this is the seconds VBUS sensing.)
    In the case that USBx_VBUS is directly tied to 5V power rail, MUSB may work after the system boots up. The first VBUS sensing passed due to the boot-up timing. However, in normal USB host operation, there are conditions, such as VBUS ERROR or babble, which will cause MUSB transition to peripheral/B-device mode. If that happens, MUSB is no longer able to transition to host mode again, because the first VBUS sensing will fail due to USBx_VBUS tied to 5V. Clearing bit-19 makes MUSB bypass the first VBUS sensing, which fixes this issue.
  • Hi Bin,
    Okay... Correct me if I am wrong.
    In BBB, the design uses USB1_DRVVBUS to control external circuit so that USB1_VBUS is able to sense the voltage correctly. As you have mentioned, MUSB first senses USB1_VBUS to ensure VBUS does NOT have any voltage. Meaning that the USB1_DRVVBUS shall remain disable the external circuit until 2nd transition is entered. In 2nd transition, MUSB senses USB1_VBUS again after 100mS where the USB1_DRVVBUS has enabled the external circuit. Therefore in my case, when my USB0_VBUS is supply to voltage in the first stage and which makes MUSB think I am in Peripheral mode.
    Thank you for your effort in the detail explanation! Very appreciated! I have learn a new thing!
  • Zhi Yong,
    Yes, your understanding is correct!
    I just wanted to mention that USBx_DRVVBUS pin is completely controlled by MUSB controller based on the OTG logic.
  • Franklin/Steve/Bin,
    I am using am335x-evm-sdk-src-07.00.00.00.tar.gz,  board-support/linux-3.12.10-ti2013.12.01, when I use the following command to put processor into sleep mode,
    echo mem > sys/power/state
    [ 1464.928314] PM: Syncing filesystems ... done.
    [ 1464.933605] Freezing user space processes ... (elapsed 0.001 seconds) done.
    [ 1464.941695] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
    [ 1464.950234] Suspending console(s) (use no_console_suspend to debug)
    When we  measured the voltages.
    The first issue  is that PWR_EN pin is not going low.
    The unit should go to Deep Sleep mode with VDD_CORE and VDD_MPU dropping to 0.9V
    So the second issue is VDD_MPU voltage does not drop; it stays at 1.1V.
    The current draw changes only by 100mA to 120mA.
    Could you give me any clue?
    Thank you!
    desmond
  • Hello Franklin,
    I need to port 3.12.22 kernel to Beagle bone(model: TI AM335x BeagleBone). 3.14 boots fine on this but we want specifically 3.12.22 kernel.
    I configured 3.12.22 kernel for 'omap2plus_defconfig' config file. The kernel image booted in board once.
    After enabling CFG80211 and MAC80211 flags in kernel, it is not booting now. The board resets after loading the kernel
    as below:
    ## Booting kernel from Legacy Image at 80200000 ...
       Image Name:   Linux-3.12.22-01895-g90a0540-dir
       Data Size:    5048968 Bytes = 4.8 MiB
       Load Address: 80200000
       Entry Point:  80200000
    Starting kernel ...
    pc : [<8020001c>]          lr : [<9f74f21c>]
    sp : 9f62dd98  ip : 0000000c     fp : 9f7a4210
    r10: 9f7a39f4  r9 : 9f62df38     r8 : 9f630ca4
    r7 : 00000000  r6 : 80200000     r5 : 9f7a4210  r4 : 00000000
    r3 : 9f62dfe0  r2 : 1e409fc0     r1 : 00000e05  r0 : 9f62dfe0
    Resetting CPU ...
    I have taken kernel from:git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git
    branch: ti-linux-3.12.y
    Please let us know how to debug this. I believe just enabling these flags shouldn't affect booting.
    As I already mentioned, 3.14 kernel boots finely. The .config file is attached for both the kernel.
    I should refer 3.14 kernel config and should make 3.12 kernel to boot properly in board.
    Not understanding what flags/feature is missing in 3.12 that 3.14 has and making 3.14 boot well.
    I am stumped, not able to find the points that affect booting of kernel into the board.
    Or else please give me any suggestions how to overcome this.
    Any help is highly appreciated.
    ------------------- 3.12.22 config  -----------------------
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 3.12.22 Kernel Configuration
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_ARCH_HAS_BANDGAP=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_DMA_NONCOHERENT=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_EXTABLE_SORT=y
    # General setup
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_CROSS_COMPILE=""
    # CONFIG_COMPILE_TEST is not set
    CONFIG_LOCALVERSION=""
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_XZ=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_HAVE_KERNEL_LZ4=y
    CONFIG_KERNEL_GZIP=y
    # CONFIG_KERNEL_LZMA is not set
    # CONFIG_KERNEL_XZ is not set
    # CONFIG_KERNEL_LZO is not set
    # CONFIG_KERNEL_LZ4 is not set
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    # CONFIG_FHANDLE is not set
    # CONFIG_AUDIT is not set
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    # CONFIG_IRQ_DOMAIN_DEBUG is not set
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    CONFIG_KTIME_SCALAR=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    CONFIG_ARCH_HAS_TICK_BROADCAST=y
    CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_IRQ_TIME_ACCOUNTING is not set
    CONFIG_BSD_PROCESS_ACCT=y
    # CONFIG_BSD_PROCESS_ACCT_V3 is not set
    # CONFIG_TASKSTATS is not set
    # RCU Subsystem
    CONFIG_TREE_RCU=y
    # CONFIG_PREEMPT_RCU is not set
    CONFIG_RCU_STALL_COMMON=y
    # CONFIG_RCU_USER_QS is not set
    CONFIG_RCU_FANOUT=32
    CONFIG_RCU_FANOUT_LEAF=16
    # CONFIG_RCU_FANOUT_EXACT is not set
    # CONFIG_RCU_FAST_NO_HZ is not set
    # CONFIG_TREE_RCU_TRACE is not set
    # CONFIG_RCU_NOCB_CPU is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=16
    CONFIG_GENERIC_SCHED_CLOCK=y
    # CONFIG_CGROUPS is not set
    # CONFIG_CHECKPOINT_RESTORE is not set
    # CONFIG_NAMESPACES is not set
    # CONFIG_UIDGID_STRICT_TYPE_CHECKS is not set
    # CONFIG_SCHED_AUTOGROUP is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    # CONFIG_RD_BZIP2 is not set
    # CONFIG_RD_LZMA is not set
    # CONFIG_RD_XZ is not set
    # CONFIG_RD_LZO is not set
    # CONFIG_RD_LZ4 is not set
    # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_HAVE_UID16=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    # CONFIG_SYSCTL_SYSCALL is not set
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_PCI_QUIRKS=y
    # CONFIG_EMBEDDED is not set
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    CONFIG_VM_EVENT_COUNTERS=y
    CONFIG_COMPAT_BRK=y
    CONFIG_SLAB=y
    # CONFIG_SLUB is not set
    # CONFIG_SLOB is not set
    CONFIG_PROFILING=y
    CONFIG_OPROFILE=y
    CONFIG_HAVE_OPROFILE=y
    CONFIG_KPROBES=y
    CONFIG_JUMP_LABEL=y
    # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
    CONFIG_KRETPROBES=y
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_ATTRS=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_USE_GENERIC_SMP_HELPERS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_DMA_API_DEBUG=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
    CONFIG_HAVE_CONTEXT_TRACKING=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_MODULES_USE_ELF_REL=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_SIGACTION=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL=y
    # CONFIG_MODULE_SIG is not set
    CONFIG_STOP_MACHINE=y
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_BSGLIB is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # CONFIG_BLK_CMDLINE_PARSER is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_AIX_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    # CONFIG_CMDLINE_PARTITION is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    CONFIG_IOSCHED_DEADLINE=y
    CONFIG_IOSCHED_CFQ=y
    # CONFIG_DEFAULT_DEADLINE is not set
    CONFIG_DEFAULT_CFQ=y
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="cfq"
    CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
    CONFIG_INLINE_READ_UNLOCK=y
    CONFIG_INLINE_READ_UNLOCK_IRQ=y
    CONFIG_INLINE_WRITE_UNLOCK=y
    CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
    CONFIG_MUTEX_SPIN_ON_OWNER=y
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    # CONFIG_ARCH_MULTIPLATFORM is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_LPC32XX is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_MSM is not set
    # CONFIG_ARCH_SHMOBILE is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C24XX is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_S5P64X0 is not set
    # CONFIG_ARCH_S5PC100 is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_SHARK is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_ARCH_OMAP1 is not set
    CONFIG_ARCH_OMAP2PLUS=y
    # Multiple platform selection
    # CPU Core family selection
    CONFIG_ARCH_MULTI_V6=y
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    # CONFIG_ARCH_MULTI_CPU_AUTO is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_ARCH_BCM2835 is not set
    # CONFIG_ARCH_CNS3XXX is not set
    CONFIG_GPIO_PCA953X=y
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_KEYSTONE is not set
    # CONFIG_ARCH_MXC is not set
    # TI OMAP Common Features
    # OMAP Feature Selections
    CONFIG_OMAP_DEBUG_DEVICES=y
    CONFIG_OMAP_DEBUG_LEDS=y
    CONFIG_OMAP_RESET_CLOCKS=y
    CONFIG_OMAP_MUX=y
    CONFIG_OMAP_MUX_DEBUG=y
    CONFIG_OMAP_MUX_WARNINGS=y
    CONFIG_OMAP_32K_TIMER=y
    # CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_OMAP_PM_NOOP=y
    CONFIG_MACH_OMAP_GENERIC=y
    CONFIG_ARCH_OMAP=y
    CONFIG_ARCH_OMAP2=y
    CONFIG_ARCH_OMAP3=y
    CONFIG_ARCH_OMAP4=y
    CONFIG_SOC_OMAP5=y
    CONFIG_SOC_AM33XX=y
    CONFIG_SOC_AM43XX=y
    # TI OMAP2/3/4 Specific Features
    CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
    CONFIG_SOC_HAS_OMAP2_SDRC=y
    CONFIG_SOC_HAS_REALTIME_COUNTER=y
    CONFIG_SOC_DRA7XX=y
    # OMAP Core Type
    CONFIG_SOC_OMAP2420=y
    CONFIG_SOC_OMAP2430=y
    CONFIG_SOC_OMAP3430=y
    CONFIG_SOC_TI81XX=y
    CONFIG_OMAP_PACKAGE_ZAF=y
    CONFIG_OMAP_PACKAGE_ZAC=y
    CONFIG_OMAP_PACKAGE_CBB=y
    CONFIG_OMAP_PACKAGE_CUS=y
    CONFIG_OMAP_PACKAGE_CBP=y
    # OMAP Board Type
    CONFIG_MACH_OMAP2_TUSB6010=y
    CONFIG_MACH_OMAP_H4=y
    CONFIG_MACH_OMAP_2430SDP=y
    CONFIG_MACH_OMAP3_BEAGLE=y
    CONFIG_MACH_DEVKIT8000=y
    CONFIG_MACH_OMAP_LDP=y
    CONFIG_MACH_OMAP3530_LV_SOM=y
    CONFIG_MACH_OMAP3_TORPEDO=y
    CONFIG_MACH_OVERO=y
    CONFIG_MACH_OMAP3EVM=y
    CONFIG_MACH_OMAP3517EVM=y
    # CONFIG_MACH_CRANEBOARD is not set
    CONFIG_MACH_OMAP3_PANDORA=y
    CONFIG_MACH_TOUCHBOOK=y
    CONFIG_MACH_OMAP_3430SDP=y
    CONFIG_MACH_NOKIA_N800=y
    CONFIG_MACH_NOKIA_N810=y
    CONFIG_MACH_NOKIA_N810_WIMAX=y
    CONFIG_MACH_NOKIA_N8X0=y
    CONFIG_MACH_NOKIA_RM680=y
    CONFIG_MACH_NOKIA_RX51=y
    CONFIG_MACH_OMAP_ZOOM2=y
    CONFIG_MACH_OMAP_ZOOM3=y
    CONFIG_MACH_CM_T35=y
    CONFIG_MACH_CM_T3517=y
    CONFIG_MACH_CM_T3730=y
    CONFIG_MACH_IGEP0020=y
    CONFIG_MACH_IGEP0030=y
    CONFIG_MACH_SBC3530=y
    CONFIG_MACH_OMAP_3630SDP=y
    CONFIG_MACH_TI8168EVM=y
    CONFIG_MACH_TI8148EVM=y
    # CONFIG_OMAP3_EMU is not set
    # CONFIG_OMAP3_SDRC_AC_TIMING is not set
    CONFIG_OMAP4_ERRATA_I688=y
    # CONFIG_ARCH_PICOXCELL is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_SHMOBILE_MULTI is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_SIRF is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_VIRT is not set
    # CONFIG_ARCH_WM8750 is not set
    # CONFIG_ARCH_WM8850 is not set
    # CONFIG_ARCH_ZYNQ is not set
    # Processor Type
    CONFIG_CPU_V6=y
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v6=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV6=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V6=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V6=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
    CONFIG_ARM_THUMB=y
    CONFIG_ARM_THUMBEE=y
    CONFIG_ARM_VIRT_EXT=y
    CONFIG_SWP_EMULATE=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_KUSER_HELPERS=y
    CONFIG_OUTER_CACHE=y
    CONFIG_OUTER_CACHE_SYNC=y
    CONFIG_MIGHT_HAVE_CACHE_L2X0=y
    CONFIG_CACHE_L2X0=y
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARCH_HAS_BARRIERS=y
    CONFIG_ARM_NR_BANKS=8
    CONFIG_MULTI_IRQ_HANDLER=y
    # CONFIG_ARM_ERRATA_326103 is not set
    CONFIG_ARM_ERRATA_411920=y
    # CONFIG_ARM_ERRATA_430973 is not set
    # CONFIG_ARM_ERRATA_458693 is not set
    # CONFIG_ARM_ERRATA_460075 is not set
    # CONFIG_ARM_ERRATA_742230 is not set
    # CONFIG_ARM_ERRATA_742231 is not set
    CONFIG_PL310_ERRATA_588369=y
    # CONFIG_ARM_ERRATA_643719 is not set
    CONFIG_ARM_ERRATA_720789=y
    CONFIG_PL310_ERRATA_727915=y
    # CONFIG_ARM_ERRATA_743622 is not set
    # CONFIG_ARM_ERRATA_751472 is not set
    CONFIG_ARM_ERRATA_754322=y
    # CONFIG_ARM_ERRATA_754327 is not set
    # CONFIG_ARM_ERRATA_364296 is not set
    # CONFIG_ARM_ERRATA_764369 is not set
    # CONFIG_PL310_ERRATA_769419 is not set
    CONFIG_ARM_ERRATA_775420=y
    CONFIG_ARM_ERRATA_798181=y
    # CONFIG_ARM_ERRATA_773022 is not set
    CONFIG_ARM_ERRATA_799270=y
    CONFIG_TI_PRIV_EDMA=y
    # Bus support
    CONFIG_PCI=y
    CONFIG_PCI_SYSCALL=y
    # CONFIG_PCI_MSI is not set
    # CONFIG_PCI_DEBUG is not set
    # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
    # CONFIG_PCI_STUB is not set
    # CONFIG_PCI_IOV is not set
    # CONFIG_PCI_PRI is not set
    # CONFIG_PCI_PASID is not set
    # PCI host controller drivers
    CONFIG_PCIE_DRA7XX=y
    CONFIG_PCIE_DW=y
    CONFIG_PCIEPORTBUS=y
    CONFIG_PCIEAER=y
    # CONFIG_PCIE_ECRC is not set
    # CONFIG_PCIEAER_INJECT is not set
    CONFIG_PCIEASPM=y
    # CONFIG_PCIEASPM_DEBUG is not set
    CONFIG_PCIEASPM_DEFAULT=y
    # CONFIG_PCIEASPM_POWERSAVE is not set
    # CONFIG_PCIEASPM_PERFORMANCE is not set
    CONFIG_PCIE_PME=y
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_HAVE_SMP=y
    CONFIG_SMP=y
    CONFIG_SMP_ON_UP=y
    CONFIG_ARM_CPU_TOPOLOGY=y
    # CONFIG_SCHED_MC is not set
    # CONFIG_SCHED_SMT is not set
    CONFIG_HAVE_ARM_SCU=y
    CONFIG_HAVE_ARM_ARCH_TIMER=y
    CONFIG_HAVE_ARM_TWD=y
    # CONFIG_MCPM is not set
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    CONFIG_NR_CPUS=2
    CONFIG_HOTPLUG_CPU=y
    # CONFIG_ARM_PSCI is not set
    CONFIG_ARCH_NR_GPIO=512
    # CONFIG_PREEMPT_NONE is not set
    CONFIG_PREEMPT_VOLUNTARY=y
    # CONFIG_PREEMPT is not set
    CONFIG_HZ_FIXED=0
    CONFIG_HZ_100=y
    # CONFIG_HZ_200 is not set
    # CONFIG_HZ_250 is not set
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_500 is not set
    # CONFIG_HZ_1000 is not set
    CONFIG_HZ=100
    CONFIG_SCHED_HRTICK=y
    CONFIG_AEABI=y
    CONFIG_OABI_COMPAT=y
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    CONFIG_HAVE_ARCH_PFN_VALID=y
    CONFIG_HIGHMEM=y
    # CONFIG_HIGHPTE is not set
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_HAVE_MEMBLOCK=y
    CONFIG_MEMORY_ISOLATION=y
    # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    CONFIG_COMPACTION=y
    CONFIG_MIGRATION=y
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_BOUNCE=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_CROSS_MEMORY_ATTACH=y
    # CONFIG_CLEANCACHE is not set
    # CONFIG_FRONTSWAP is not set
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_ZBUD is not set
    CONFIG_FORCE_MAX_ZONEORDER=12
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_SECCOMP is not set
    # CONFIG_CC_STACKPROTECTOR is not set
    # Boot options
    CONFIG_USE_OF=y
    CONFIG_ATAGS=y
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_ARM_APPENDED_DTB=y
    CONFIG_ARM_ATAG_DTB_COMPAT=y
    CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
    CONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO2,115200"
    CONFIG_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_CMDLINE_EXTEND is not set
    # CONFIG_CMDLINE_FORCE is not set
    # CONFIG_XIP_KERNEL is not set
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CONFIG_CRASH_DUMP is not set
    CONFIG_AUTO_ZRELADDR=y
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    CONFIG_GENERIC_CPUFREQ_CPU0=y
    # ARM CPU frequency scaling drivers
    # CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set
    # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
    # CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set
    # CPU Idle
    CONFIG_CPU_IDLE=y
    # CONFIG_CPU_IDLE_MULTIPLE_DRIVERS is not set
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
    # ARM CPU Idle Drivers
    CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=y
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_FPE_NWFPE=y
    # CONFIG_FPE_NWFPE_XP is not set
    # CONFIG_FPE_FASTFPE is not set
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # CONFIG_KERNEL_MODE_NEON is not set
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE=y
    CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
    CONFIG_BINFMT_SCRIPT=y
    # CONFIG_HAVE_AOUT is not set
    CONFIG_BINFMT_MISC=y
    CONFIG_COREDUMP=y
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    CONFIG_PM_SLEEP=y
    CONFIG_PM_SLEEP_SMP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM_RUNTIME=y
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_ADVANCED_DEBUG is not set
    # CONFIG_PM_TEST_SUSPEND is not set
    CONFIG_PM_SLEEP_DEBUG=y
    # CONFIG_APM_EMULATION is not set
    CONFIG_ARCH_HAS_OPP=y
    CONFIG_PM_OPP=y
    CONFIG_PM_CLK=y
    # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    # CONFIG_UNIX_DIAG is not set
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=y
    CONFIG_XFRM_USER=y
    # CONFIG_XFRM_SUB_POLICY is not set
    CONFIG_XFRM_MIGRATE=y
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_NET_KEY=y
    CONFIG_NET_KEY_MIGRATE=y
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    # CONFIG_NET_IP_TUNNEL is not set
    # CONFIG_IP_MROUTE is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    # CONFIG_INET_AH is not set
    # CONFIG_INET_ESP is not set
    # CONFIG_INET_IPCOMP is not set
    # CONFIG_INET_XFRM_TUNNEL is not set
    # CONFIG_INET_TUNNEL is not set
    CONFIG_INET_XFRM_MODE_TRANSPORT=m
    CONFIG_INET_XFRM_MODE_TUNNEL=m
    CONFIG_INET_XFRM_MODE_BEET=m
    # CONFIG_INET_LRO is not set
    CONFIG_INET_DIAG=m
    CONFIG_INET_TCP_DIAG=m
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    # CONFIG_IPV6 is not set
    # CONFIG_NETLABEL is not set
    # CONFIG_NETWORK_SECMARK is not set
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    CONFIG_BRIDGE_NETFILTER=y
    # Core Netfilter Configuration
    # CONFIG_NETFILTER_NETLINK_ACCT is not set
    # CONFIG_NETFILTER_NETLINK_QUEUE is not set
    # CONFIG_NETFILTER_NETLINK_LOG is not set
    CONFIG_NF_CONNTRACK=m
    # CONFIG_NF_CONNTRACK_MARK is not set
    CONFIG_NF_CONNTRACK_PROCFS=y
    # CONFIG_NF_CONNTRACK_EVENTS is not set
    # CONFIG_NF_CONNTRACK_TIMEOUT is not set
    # CONFIG_NF_CONNTRACK_TIMESTAMP is not set
    # CONFIG_NF_CT_PROTO_DCCP is not set
    # CONFIG_NF_CT_PROTO_SCTP is not set
    # CONFIG_NF_CT_PROTO_UDPLITE is not set
    # CONFIG_NF_CONNTRACK_AMANDA is not set
    # CONFIG_NF_CONNTRACK_FTP is not set
    # CONFIG_NF_CONNTRACK_H323 is not set
    # CONFIG_NF_CONNTRACK_IRC is not set
    # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
    # CONFIG_NF_CONNTRACK_SNMP is not set
    # CONFIG_NF_CONNTRACK_PPTP is not set
    # CONFIG_NF_CONNTRACK_SANE is not set
    # CONFIG_NF_CONNTRACK_SIP is not set
    # CONFIG_NF_CONNTRACK_TFTP is not set
    # CONFIG_NF_CT_NETLINK is not set
    # CONFIG_NF_CT_NETLINK_TIMEOUT is not set
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_NEEDED=y
    # CONFIG_NF_NAT_AMANDA is not set
    # CONFIG_NF_NAT_FTP is not set
    # CONFIG_NF_NAT_IRC is not set
    # CONFIG_NF_NAT_SIP is not set
    # CONFIG_NF_NAT_TFTP is not set
    CONFIG_NETFILTER_XTABLES=m
    # Xtables combined modules
    # CONFIG_NETFILTER_XT_MARK is not set
    # CONFIG_NETFILTER_XT_CONNMARK is not set
    # Xtables targets
    # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
    # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_HMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
    # CONFIG_NETFILTER_XT_TARGET_LED is not set
    # CONFIG_NETFILTER_XT_TARGET_LOG is not set
    # CONFIG_NETFILTER_XT_TARGET_MARK is not set
    # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
    # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
    # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
    # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
    # CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set
    # CONFIG_NETFILTER_XT_TARGET_TEE is not set
    # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
    # Xtables matches
    # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_BPF is not set
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
    # CONFIG_NETFILTER_XT_MATCH_CPU is not set
    # CONFIG_NETFILTER_XT_MATCH_DCCP is not set
    # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_DSCP is not set
    # CONFIG_NETFILTER_XT_MATCH_ECN is not set
    # CONFIG_NETFILTER_XT_MATCH_ESP is not set
    # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_HELPER is not set
    # CONFIG_NETFILTER_XT_MATCH_HL is not set
    # CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
    # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
    # CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_MAC is not set
    # CONFIG_NETFILTER_XT_MATCH_MARK is not set
    # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
    # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
    # CONFIG_NETFILTER_XT_MATCH_OWNER is not set
    # CONFIG_NETFILTER_XT_MATCH_POLICY is not set
    # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
    # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
    # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
    # CONFIG_NETFILTER_XT_MATCH_REALM is not set
    # CONFIG_NETFILTER_XT_MATCH_RECENT is not set
    # CONFIG_NETFILTER_XT_MATCH_SCTP is not set
    # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
    # CONFIG_NETFILTER_XT_MATCH_STATE is not set
    # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
    # CONFIG_NETFILTER_XT_MATCH_STRING is not set
    # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
    # CONFIG_NETFILTER_XT_MATCH_TIME is not set
    # CONFIG_NETFILTER_XT_MATCH_U32 is not set
    # CONFIG_IP_VS is not set
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    CONFIG_NF_CONNTRACK_IPV4=m
    CONFIG_NF_CONNTRACK_PROC_COMPAT=y
    CONFIG_IP_NF_IPTABLES=m
    # CONFIG_IP_NF_MATCH_AH is not set
    # CONFIG_IP_NF_MATCH_ECN is not set
    # CONFIG_IP_NF_MATCH_TTL is not set
    CONFIG_IP_NF_FILTER=m
    # CONFIG_IP_NF_TARGET_REJECT is not set
    # CONFIG_IP_NF_TARGET_SYNPROXY is not set
    # CONFIG_IP_NF_TARGET_ULOG is not set
    CONFIG_NF_NAT_IPV4=m
    CONFIG_IP_NF_TARGET_MASQUERADE=m
    # CONFIG_IP_NF_TARGET_NETMAP is not set
    # CONFIG_IP_NF_TARGET_REDIRECT is not set
    # CONFIG_NF_NAT_PPTP is not set
    # CONFIG_NF_NAT_H323 is not set
    # CONFIG_IP_NF_MANGLE is not set
    # CONFIG_IP_NF_RAW is not set
    # CONFIG_IP_NF_SECURITY is not set
    # CONFIG_IP_NF_ARPTABLES is not set
    # CONFIG_BRIDGE_NF_EBTABLES is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    CONFIG_STP=m
    CONFIG_BRIDGE=m
    CONFIG_BRIDGE_IGMP_SNOOPING=y
    # CONFIG_BRIDGE_VLAN_FILTERING is not set
    CONFIG_HAVE_NET_DSA=y
    CONFIG_VLAN_8021Q=y
    # CONFIG_VLAN_8021Q_GVRP is not set
    # CONFIG_VLAN_8021Q_MVRP is not set
    # CONFIG_DECNET is not set
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_PHONET is not set
    # CONFIG_IEEE802154 is not set
    # CONFIG_NET_SCHED is not set
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_MMAP is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_NET_MPLS_GSO is not set
    CONFIG_RPS=y
    CONFIG_RFS_ACCEL=y
    CONFIG_XPS=y
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    # CONFIG_BPF_JIT is not set
    CONFIG_NET_FLOW_LIMIT=y
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_NET_TCPPROBE is not set
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    CONFIG_CAN_GW=m
    # CAN Device Drivers
    # CONFIG_CAN_VCAN is not set
    # CONFIG_CAN_SLCAN is not set
    CONFIG_CAN_DEV=m
    CONFIG_CAN_CALC_BITTIMING=y
    # CONFIG_CAN_LEDS is not set
    # CONFIG_CAN_AT91 is not set
    # CONFIG_CAN_TI_HECC is not set
    # CONFIG_CAN_MCP251X is not set
    # CONFIG_CAN_FLEXCAN is not set
    # CONFIG_PCH_CAN is not set
    # CONFIG_CAN_GRCAN is not set
    # CONFIG_CAN_SJA1000 is not set
    CONFIG_CAN_C_CAN=m
    CONFIG_CAN_C_CAN_PLATFORM=m
    # CONFIG_CAN_C_CAN_PCI is not set
    # CONFIG_CAN_CC770 is not set
    # CAN USB interfaces
    # CONFIG_CAN_EMS_USB is not set
    # CONFIG_CAN_ESD_USB2 is not set
    # CONFIG_CAN_KVASER_USB is not set
    # CONFIG_CAN_PEAK_USB is not set
    # CONFIG_CAN_8DEV_USB is not set
    # CONFIG_CAN_SOFTING is not set
    # CONFIG_CAN_DEBUG_DEVICES is not set
    # CONFIG_IRDA is not set
    CONFIG_BT=m
    # CONFIG_BT_RFCOMM is not set
    # CONFIG_BT_BNEP is not set
    # CONFIG_BT_HIDP is not set
    # Bluetooth device drivers
    # CONFIG_BT_HCIBTUSB is not set
    # CONFIG_BT_HCIBTSDIO is not set
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_H4=y
    CONFIG_BT_HCIUART_BCSP=y
    # CONFIG_BT_HCIUART_ATH3K is not set
    CONFIG_BT_HCIUART_LL=y
    # CONFIG_BT_HCIUART_3WIRE is not set
    CONFIG_BT_HCIBCM203X=m
    CONFIG_BT_HCIBPA10X=m
    # CONFIG_BT_HCIBFUSB is not set
    # CONFIG_BT_HCIVHCI is not set
    # CONFIG_BT_MRVL is not set
    CONFIG_BT_WILINK=m
    # CONFIG_AF_RXRPC is not set
    CONFIG_WIRELESS=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WEXT_CORE=y
    CONFIG_WEXT_PROC=y
    CONFIG_WEXT_SPY=y
    CONFIG_CFG80211=y
    CONFIG_NL80211_TESTMODE=y
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_REG_DEBUG is not set
    # CONFIG_CFG80211_CERTIFICATION_ONUS is not set
    CONFIG_CFG80211_DEFAULT_PS=y
    # CONFIG_CFG80211_DEBUGFS is not set
    # CONFIG_CFG80211_INTERNAL_REGDB is not set
    # CONFIG_CFG80211_WEXT is not set
    CONFIG_LIB80211=m
    # CONFIG_LIB80211_DEBUG is not set
    CONFIG_MAC80211=y
    CONFIG_MAC80211_HAS_RC=y
    CONFIG_MAC80211_RC_PID=y
    CONFIG_MAC80211_RC_MINSTREL=y
    CONFIG_MAC80211_RC_MINSTREL_HT=y
    CONFIG_MAC80211_RC_DEFAULT_PID=y
    # CONFIG_MAC80211_RC_DEFAULT_MINSTREL is not set
    CONFIG_MAC80211_RC_DEFAULT="pid"
    # CONFIG_MAC80211_MESH is not set
    # CONFIG_MAC80211_LEDS is not set
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_MESSAGE_TRACING is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    # CONFIG_WIMAX is not set
    CONFIG_RFKILL=y
    CONFIG_RFKILL_LEDS=y
    # CONFIG_RFKILL_INPUT is not set
    # CONFIG_RFKILL_REGULATOR is not set
    # CONFIG_RFKILL_GPIO is not set
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # CONFIG_NFC is not set
    CONFIG_HAVE_BPF_JIT=y
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    CONFIG_FW_LOADER_USER_HELPER=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_GENERIC_CPU_DEVICES is not set
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=m
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_SHARED_BUFFER=y
    CONFIG_DMA_CMA=y
    # Default contiguous memory area size:
    CONFIG_CMA_SIZE_MBYTES=24
    CONFIG_CMA_SIZE_SEL_MBYTES=y
    # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
    # CONFIG_CMA_SIZE_SEL_MIN is not set
    # CONFIG_CMA_SIZE_SEL_MAX is not set
    CONFIG_CMA_ALIGNMENT=8
    CONFIG_CMA_AREAS=7
    # Bus devices
    CONFIG_OMAP_OCP2SCP=y
    CONFIG_OMAP_INTERCONNECT=y
    # CONFIG_ARM_CCI is not set
    CONFIG_CONNECTOR=y
    CONFIG_PROC_EVENTS=y
    CONFIG_MTD=y
    # CONFIG_MTD_TESTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    # CONFIG_MTD_AFS_PARTS is not set
    CONFIG_MTD_OF_PARTS=y
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    CONFIG_MTD_OOPS=y
    # CONFIG_MTD_SWAP is not set
    # RAM/ROM/Flash chip drivers
    CONFIG_MTD_CFI=y
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_GEN_PROBE=y
    # CONFIG_MTD_CFI_ADV_OPTIONS is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    CONFIG_MTD_CFI_INTELEXT=y
    # CONFIG_MTD_CFI_AMDSTD is not set
    # CONFIG_MTD_CFI_STAA is not set
    CONFIG_MTD_CFI_UTIL=y
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    # CONFIG_MTD_PHYSMAP is not set
    # CONFIG_MTD_PHYSMAP_OF is not set
    # CONFIG_MTD_INTEL_VR_NOR is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_PMC551 is not set
    # CONFIG_MTD_DATAFLASH is not set
    CONFIG_MTD_M25P80=y
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    CONFIG_BCH_CONST_M=13
    CONFIG_MTD_NAND_ECC=y
    # CONFIG_MTD_NAND_ECC_SMC is not set
    CONFIG_MTD_NAND=y
    # CONFIG_MTD_NAND_ECC_BCH is not set
    # CONFIG_MTD_SM_COMMON is not set
    # CONFIG_MTD_NAND_DENALI is not set
    # CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_OMAP_BCH=y
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND_RICOH is not set
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_NAND_DOCG4 is not set
    # CONFIG_MTD_NAND_CAFE is not set
    # CONFIG_MTD_NAND_NANDSIM is not set
    # CONFIG_MTD_NAND_PLATFORM is not set
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_LIMIT=20
    # CONFIG_MTD_UBI_FASTMAP is not set
    # CONFIG_MTD_UBI_GLUEBI is not set
    CONFIG_DTC=y
    CONFIG_OF=y
    # Device Tree and Open Firmware support
    CONFIG_PROC_DEVICETREE=y
    # CONFIG_OF_SELFTEST is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_NET=y
    CONFIG_OF_MDIO=y
    CONFIG_OF_PCI=y
    CONFIG_OF_PCI_IRQ=y
    CONFIG_OF_MTD=y
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
    # CONFIG_BLK_CPQ_CISS_DA is not set
    # CONFIG_BLK_DEV_DAC960 is not set
    # CONFIG_BLK_DEV_UMEM is not set
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # CONFIG_BLK_DEV_DRBD is not set
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_NVME is not set
    # CONFIG_BLK_DEV_SX8 is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=16384
    # CONFIG_BLK_DEV_XIP is not set
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    # CONFIG_MG_DISK is not set
    # CONFIG_BLK_DEV_RBD is not set
    # CONFIG_BLK_DEV_RSXX is not set
    # Misc devices
    CONFIG_SENSORS_LIS3LV02D=m
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_ATMEL_PWM is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_PHANTOM is not set
    # CONFIG_SGI_IOC4 is not set
    # CONFIG_TIFM_CORE is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ATMEL_SSC is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_HP_ILO is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    CONFIG_SENSORS_TSL2550=m
    # CONFIG_SENSORS_BH1780 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_TI_DAC7512 is not set
    CONFIG_BMP085=y
    CONFIG_BMP085_I2C=m
    # CONFIG_BMP085_SPI is not set
    # CONFIG_PCH_PHUB is not set
    # CONFIG_USB_SWITCH_FSA9480 is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    # CONFIG_SRAM is not set
    CONFIG_CROSSBAR=y
    # CONFIG_C2PORT is not set
    # EEPROM support
    # CONFIG_EEPROM_AT24 is not set
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    CONFIG_EEPROM_93CX6=y
    # CONFIG_EEPROM_93XX46 is not set
    # CONFIG_CB710_CORE is not set
    # Texas Instruments shared transport line discipline
    CONFIG_TI_ST=y
    # CONFIG_SENSORS_LIS3_SPI is not set
    CONFIG_SENSORS_LIS3_I2C=m
    # Altera FPGA firmware download module
    # CONFIG_ALTERA_STAPL is not set
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_TGT is not set
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    # CONFIG_BLK_DEV_SR is not set
    # CONFIG_CHR_DEV_SG is not set
    # CONFIG_CHR_DEV_SCH is not set
    CONFIG_SCSI_MULTI_LUN=y
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    CONFIG_SCSI_SCAN_ASYNC=y
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_CXGB3_ISCSI is not set
    # CONFIG_SCSI_CXGB4_ISCSI is not set
    # CONFIG_SCSI_BNX2_ISCSI is not set
    # CONFIG_SCSI_BNX2X_FCOE is not set
    # CONFIG_BE2ISCSI is not set
    # CONFIG_BLK_DEV_3W_XXXX_RAID is not set
    # CONFIG_SCSI_HPSA is not set
    # CONFIG_SCSI_3W_9XXX is not set
    # CONFIG_SCSI_3W_SAS is not set
    # CONFIG_SCSI_ACARD is not set
    # CONFIG_SCSI_AACRAID is not set
    # CONFIG_SCSI_AIC7XXX is not set
    # CONFIG_SCSI_AIC7XXX_OLD is not set
    # CONFIG_SCSI_AIC79XX is not set
    # CONFIG_SCSI_AIC94XX is not set
    # CONFIG_SCSI_MVSAS is not set
    # CONFIG_SCSI_MVUMI is not set
    # CONFIG_SCSI_ARCMSR is not set
    # CONFIG_SCSI_ESAS2R is not set
    # CONFIG_MEGARAID_NEWGEN is not set
    # CONFIG_MEGARAID_LEGACY is not set
    # CONFIG_MEGARAID_SAS is not set
    # CONFIG_SCSI_MPT2SAS is not set
    # CONFIG_SCSI_MPT3SAS is not set
    # CONFIG_SCSI_UFSHCD is not set
    # CONFIG_SCSI_HPTIOP is not set
    # CONFIG_LIBFC is not set
    # CONFIG_LIBFCOE is not set
    # CONFIG_FCOE is not set
    # CONFIG_SCSI_DMX3191D is not set
    # CONFIG_SCSI_FUTURE_DOMAIN is not set
    # CONFIG_SCSI_IPS is not set
    # CONFIG_SCSI_INITIO is not set
    # CONFIG_SCSI_INIA100 is not set
    # CONFIG_SCSI_STEX is not set
    # CONFIG_SCSI_SYM53C8XX_2 is not set
    # CONFIG_SCSI_IPR is not set
    # CONFIG_SCSI_QLOGIC_1280 is not set
    # CONFIG_SCSI_QLA_FC is not set
    # CONFIG_SCSI_QLA_ISCSI is not set
    # CONFIG_SCSI_LPFC is not set
    # CONFIG_SCSI_DC395x is not set
    # CONFIG_SCSI_DC390T is not set
    # CONFIG_SCSI_NSP32 is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_PMCRAID is not set
    # CONFIG_SCSI_PM8001 is not set
    # CONFIG_SCSI_SRP is not set
    # CONFIG_SCSI_BFA_FC is not set
    # CONFIG_SCSI_CHELSIO_FCOE is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    CONFIG_ATA=y
    # CONFIG_ATA_NONSTANDARD is not set
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    # CONFIG_SATA_AHCI is not set
    CONFIG_SATA_AHCI_PLATFORM=y
    # CONFIG_AHCI_IMX is not set
    # CONFIG_SATA_INIC162X is not set
    # CONFIG_SATA_ACARD_AHCI is not set
    # CONFIG_SATA_SIL24 is not set
    CONFIG_SATA_TI=y
    CONFIG_ATA_SFF=y
    # SFF controllers with custom DMA interface
    # CONFIG_PDC_ADMA is not set
    # CONFIG_SATA_QSTOR is not set
    # CONFIG_SATA_SX4 is not set
    CONFIG_ATA_BMDMA=y
    # SATA SFF controllers with BMDMA
    # CONFIG_ATA_PIIX is not set
    # CONFIG_SATA_HIGHBANK is not set
    # CONFIG_SATA_MV is not set
    # CONFIG_SATA_NV is not set
    # CONFIG_SATA_PROMISE is not set
    # CONFIG_SATA_RCAR is not set
    # CONFIG_SATA_SIL is not set
    # CONFIG_SATA_SIS is not set
    # CONFIG_SATA_SVW is not set
    # CONFIG_SATA_ULI is not set
    # CONFIG_SATA_VIA is not set
    # CONFIG_SATA_VITESSE is not set
    # PATA SFF controllers with BMDMA
    # CONFIG_PATA_ALI is not set
    # CONFIG_PATA_AMD is not set
    # CONFIG_PATA_ARASAN_CF is not set
    # CONFIG_PATA_ARTOP is not set
    # CONFIG_PATA_ATIIXP is not set
    # CONFIG_PATA_ATP867X is not set
    # CONFIG_PATA_CMD64X is not set
    # CONFIG_PATA_CS5520 is not set
    # CONFIG_PATA_CS5530 is not set
    # CONFIG_PATA_CS5536 is not set
    # CONFIG_PATA_CYPRESS is not set
    # CONFIG_PATA_EFAR is not set
    # CONFIG_PATA_HPT366 is not set
    # CONFIG_PATA_HPT37X is not set
    # CONFIG_PATA_HPT3X2N is not set
    # CONFIG_PATA_HPT3X3 is not set
    # CONFIG_PATA_IT8213 is not set
    # CONFIG_PATA_IT821X is not set
    # CONFIG_PATA_JMICRON is not set
    # CONFIG_PATA_MARVELL is not set
    # CONFIG_PATA_NETCELL is not set
    # CONFIG_PATA_NINJA32 is not set
    # CONFIG_PATA_NS87415 is not set
    # CONFIG_PATA_OLDPIIX is not set
    # CONFIG_PATA_OPTIDMA is not set
    # CONFIG_PATA_PDC2027X is not set
    # CONFIG_PATA_PDC_OLD is not set
    # CONFIG_PATA_RADISYS is not set
    # CONFIG_PATA_RDC is not set
    # CONFIG_PATA_SC1200 is not set
    # CONFIG_PATA_SCH is not set
    # CONFIG_PATA_SERVERWORKS is not set
    # CONFIG_PATA_SIL680 is not set
    # CONFIG_PATA_SIS is not set
    # CONFIG_PATA_TOSHIBA is not set
    # CONFIG_PATA_TRIFLEX is not set
    # CONFIG_PATA_VIA is not set
    # CONFIG_PATA_WINBOND is not set
    # PIO-only SFF controllers
    # CONFIG_PATA_CMD640_PCI is not set
    # CONFIG_PATA_MPIIX is not set
    # CONFIG_PATA_NS87410 is not set
    # CONFIG_PATA_OPTI is not set
    # CONFIG_PATA_PLATFORM is not set
    # CONFIG_PATA_RZ1000 is not set
    # Generic fallback / legacy drivers
    # CONFIG_ATA_GENERIC is not set
    # CONFIG_PATA_LEGACY is not set
    CONFIG_MD=y
    # CONFIG_BLK_DEV_MD is not set
    # CONFIG_BCACHE is not set
    # CONFIG_BLK_DEV_DM is not set
    # CONFIG_TARGET_CORE is not set
    # CONFIG_FUSION is not set
    # IEEE 1394 (FireWire) support
    # CONFIG_FIREWIRE is not set
    # CONFIG_FIREWIRE_NOSY is not set
    # CONFIG_I2O is not set
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    # CONFIG_DUMMY is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_NET_FC is not set
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_VXLAN is not set
    # CONFIG_NETCONSOLE is not set
    # CONFIG_NETPOLL is not set
    # CONFIG_NET_POLL_CONTROLLER is not set
    # CONFIG_TUN is not set
    # CONFIG_VETH is not set
    # CONFIG_NLMON is not set
    # CONFIG_ARCNET is not set
    # CAIF transport drivers
    # Distributed Switch Architecture drivers
    # CONFIG_NET_DSA_MV88E6XXX is not set
    # CONFIG_NET_DSA_MV88E6060 is not set
    # CONFIG_NET_DSA_MV88E6XXX_NEED_PPU is not set
    # CONFIG_NET_DSA_MV88E6131 is not set
    # CONFIG_NET_DSA_MV88E6123_61_65 is not set
    CONFIG_ETHERNET=y
    CONFIG_NET_VENDOR_3COM=y
    # CONFIG_VORTEX is not set
    # CONFIG_TYPHOON is not set
    CONFIG_NET_VENDOR_ADAPTEC=y
    # CONFIG_ADAPTEC_STARFIRE is not set
    CONFIG_NET_VENDOR_ALTEON=y
    # CONFIG_ACENIC is not set
    CONFIG_NET_VENDOR_AMD=y
    # CONFIG_AMD8111_ETH is not set
    # CONFIG_PCNET32 is not set
    CONFIG_NET_VENDOR_ARC=y
    # CONFIG_ARC_EMAC is not set
    CONFIG_NET_VENDOR_ATHEROS=y
    # CONFIG_ATL2 is not set
    # CONFIG_ATL1 is not set
    # CONFIG_ATL1E is not set
    # CONFIG_ATL1C is not set
    # CONFIG_ALX is not set
    CONFIG_NET_CADENCE=y
    # CONFIG_ARM_AT91_ETHER is not set
    # CONFIG_MACB is not set
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_BNX2 is not set
    # CONFIG_CNIC is not set
    # CONFIG_TIGON3 is not set
    # CONFIG_BNX2X is not set
    CONFIG_NET_VENDOR_BROCADE=y
    # CONFIG_BNA is not set
    # CONFIG_NET_CALXEDA_XGMAC is not set
    CONFIG_NET_VENDOR_CHELSIO=y
    # CONFIG_CHELSIO_T1 is not set
    # CONFIG_CHELSIO_T3 is not set
    # CONFIG_CHELSIO_T4 is not set
    # CONFIG_CHELSIO_T4VF is not set
    CONFIG_NET_VENDOR_CIRRUS=y
    # CONFIG_CS89x0 is not set
    CONFIG_NET_VENDOR_CISCO=y
    # CONFIG_ENIC is not set
    # CONFIG_DM9000 is not set
    # CONFIG_DNET is not set
    CONFIG_NET_VENDOR_DEC=y
    # CONFIG_NET_TULIP is not set
    CONFIG_NET_VENDOR_DLINK=y
    # CONFIG_DL2K is not set
    # CONFIG_SUNDANCE is not set
    CONFIG_NET_VENDOR_EMULEX=y
    # CONFIG_BE2NET is not set
    CONFIG_NET_VENDOR_EXAR=y
    # CONFIG_S2IO is not set
    # CONFIG_VXGE is not set
    CONFIG_NET_VENDOR_FARADAY=y
    # CONFIG_FTMAC100 is not set
    # CONFIG_FTGMAC100 is not set
    CONFIG_NET_VENDOR_HP=y
    # CONFIG_HP100 is not set
    CONFIG_NET_VENDOR_INTEL=y
    # CONFIG_E100 is not set
    # CONFIG_E1000 is not set
    # CONFIG_E1000E is not set
    # CONFIG_IGB is not set
    # CONFIG_IGBVF is not set
    # CONFIG_IXGB is not set
    # CONFIG_IXGBE is not set
    # CONFIG_I40E is not set
    CONFIG_NET_VENDOR_I825XX=y
    # CONFIG_IP1000 is not set
    # CONFIG_JME is not set
    CONFIG_NET_VENDOR_MARVELL=y
    # CONFIG_MVMDIO is not set
    # CONFIG_SKGE is not set
    # CONFIG_SKY2 is not set
    CONFIG_NET_VENDOR_MELLANOX=y
    # CONFIG_MLX4_EN is not set
    # CONFIG_MLX4_CORE is not set
    CONFIG_NET_VENDOR_MICREL=y
    # CONFIG_KS8842 is not set
    CONFIG_KS8851=y
    CONFIG_KS8851_MLL=y
    # CONFIG_KSZ884X_PCI is not set
    CONFIG_NET_VENDOR_MICROCHIP=y
    # CONFIG_ENC28J60 is not set
    CONFIG_NET_VENDOR_MYRI=y
    # CONFIG_MYRI10GE is not set
    # CONFIG_FEALNX is not set
    CONFIG_NET_VENDOR_NATSEMI=y
    # CONFIG_NATSEMI is not set
    # CONFIG_NS83820 is not set
    CONFIG_NET_VENDOR_8390=y
    # CONFIG_AX88796 is not set
    # CONFIG_NE2K_PCI is not set
    CONFIG_NET_VENDOR_NVIDIA=y
    # CONFIG_FORCEDETH is not set
    CONFIG_NET_VENDOR_OKI=y
    # CONFIG_ETHOC is not set
    CONFIG_NET_PACKET_ENGINE=y
    # CONFIG_HAMACHI is not set
    # CONFIG_YELLOWFIN is not set
    CONFIG_NET_VENDOR_QLOGIC=y
    # CONFIG_QLA3XXX is not set
    # CONFIG_QLCNIC is not set
    # CONFIG_QLGE is not set
    # CONFIG_NETXEN_NIC is not set
    CONFIG_NET_VENDOR_REALTEK=y
    # CONFIG_8139CP is not set
    # CONFIG_8139TOO is not set
    # CONFIG_R8169 is not set
    # CONFIG_SH_ETH is not set
    CONFIG_NET_VENDOR_RDC=y
    # CONFIG_R6040 is not set
    CONFIG_NET_VENDOR_SEEQ=y
    CONFIG_NET_VENDOR_SILAN=y
    # CONFIG_SC92031 is not set
    CONFIG_NET_VENDOR_SIS=y
    # CONFIG_SIS900 is not set
    # CONFIG_SIS190 is not set
    # CONFIG_SFC is not set
    CONFIG_NET_VENDOR_SMSC=y
    CONFIG_SMC91X=y
    # CONFIG_EPIC100 is not set
    # CONFIG_SMC911X is not set
    CONFIG_SMSC911X=y
    # CONFIG_SMSC911X_ARCH_HOOKS is not set
    # CONFIG_SMSC9420 is not set
    CONFIG_NET_VENDOR_STMICRO=y
    # CONFIG_STMMAC_ETH is not set
    CONFIG_NET_VENDOR_SUN=y
    # CONFIG_HAPPYMEAL is not set
    # CONFIG_SUNGEM is not set
    # CONFIG_CASSINI is not set
    # CONFIG_NIU is not set
    CONFIG_NET_VENDOR_TEHUTI=y
    # CONFIG_TEHUTI is not set
    CONFIG_NET_VENDOR_TI=y
    # CONFIG_TI_DAVINCI_EMAC is not set
    CONFIG_TI_DAVINCI_MDIO=y
    CONFIG_TI_DAVINCI_CPDMA=y
    CONFIG_TI_CPSW_PHY_SEL=y
    CONFIG_TI_CPSW=y
    CONFIG_TI_CPTS=y
    # CONFIG_TLAN is not set
    CONFIG_NET_VENDOR_VIA=y
    # CONFIG_VIA_RHINE is not set
    # CONFIG_VIA_VELOCITY is not set
    CONFIG_NET_VENDOR_WIZNET=y
    # CONFIG_WIZNET_W5100 is not set
    # CONFIG_WIZNET_W5300 is not set
    # CONFIG_FDDI is not set
    # CONFIG_HIPPI is not set
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    CONFIG_AT803X_PHY=y
    # CONFIG_AMD_PHY is not set
    # CONFIG_MARVELL_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_CICADA_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    CONFIG_SMSC_PHY=y
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    # CONFIG_MICREL_PHY is not set
    # CONFIG_FIXED_PHY is not set
    # CONFIG_MDIO_BITBANG is not set
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    # USB Network Adapters
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    # CONFIG_USB_PEGASUS is not set
    # CONFIG_USB_RTL8150 is not set
    # CONFIG_USB_RTL8152 is not set
    CONFIG_USB_USBNET=y
    CONFIG_USB_NET_AX8817X=y
    CONFIG_USB_NET_AX88179_178A=y
    CONFIG_USB_NET_CDCETHER=y
    # CONFIG_USB_NET_CDC_EEM is not set
    CONFIG_USB_NET_CDC_NCM=y
    # CONFIG_USB_NET_CDC_MBIM is not set
    # CONFIG_USB_NET_DM9601 is not set
    # CONFIG_USB_NET_SR9700 is not set
    # CONFIG_USB_NET_SMSC75XX is not set
    CONFIG_USB_NET_SMSC95XX=y
    # CONFIG_USB_NET_GL620A is not set
    CONFIG_USB_NET_NET1080=y
    # CONFIG_USB_NET_PLUSB is not set
    # CONFIG_USB_NET_MCS7830 is not set
    # CONFIG_USB_NET_RNDIS_HOST is not set
    CONFIG_USB_NET_CDC_SUBSET=y
    CONFIG_USB_ALI_M5632=y
    CONFIG_USB_AN2720=y
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    CONFIG_USB_EPSON2888=y
    CONFIG_USB_KC2190=y
    CONFIG_USB_NET_ZAURUS=y
    # CONFIG_USB_NET_CX82310_ETH is not set
    # CONFIG_USB_NET_KALMIA is not set
    # CONFIG_USB_NET_QMI_WWAN is not set
    # CONFIG_USB_HSO is not set
    # CONFIG_USB_NET_INT51X1 is not set
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_USB_VL600 is not set
    CONFIG_WLAN=y
    # CONFIG_LIBERTAS_THINFIRM is not set
    # CONFIG_ATMEL is not set
    # CONFIG_AT76C50X_USB is not set
    # CONFIG_PRISM54 is not set
    # CONFIG_USB_ZD1201 is not set
    # CONFIG_USB_NET_RNDIS_WLAN is not set
    # CONFIG_RTL8180 is not set
    # CONFIG_RTL8187 is not set
    # CONFIG_ADM8211 is not set
    # CONFIG_MAC80211_HWSIM is not set
    # CONFIG_MWL8K is not set
    # CONFIG_ATH_CARDS is not set
    # CONFIG_B43 is not set
    # CONFIG_B43LEGACY is not set
    # CONFIG_BRCMFMAC is not set
    # CONFIG_HOSTAP is not set
    # CONFIG_IPW2100 is not set
    # CONFIG_IWLWIFI is not set
    # CONFIG_IWL4965 is not set
    # CONFIG_IWL3945 is not set
    CONFIG_LIBERTAS=m
    CONFIG_LIBERTAS_USB=m
    CONFIG_LIBERTAS_SDIO=m
    # CONFIG_LIBERTAS_SPI is not set
    CONFIG_LIBERTAS_DEBUG=y
    # CONFIG_LIBERTAS_MESH is not set
    # CONFIG_P54_COMMON is not set
    # CONFIG_RT2X00 is not set
    CONFIG_RTL_CARDS=m
    # CONFIG_RTL8192CE is not set
    # CONFIG_RTL8192SE is not set
    # CONFIG_RTL8192DE is not set
    # CONFIG_RTL8723AE is not set
    # CONFIG_RTL8188EE is not set
    # CONFIG_RTL8192CU is not set
    CONFIG_WL_TI=y
    # CONFIG_WL1251 is not set
    CONFIG_WL12XX=m
    CONFIG_WL18XX=m
    CONFIG_WLCORE=m
    # CONFIG_WLCORE_SPI is not set
    CONFIG_WLCORE_SDIO=m
    CONFIG_WILINK_PLATFORM_DATA=y
    # CONFIG_ZD1211RW is not set
    # CONFIG_MWIFIEX is not set
    # CONFIG_CW1200 is not set
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # CONFIG_WAN is not set
    # CONFIG_VMXNET3 is not set
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    CONFIG_INPUT_POLLDEV=m
    # CONFIG_INPUT_SPARSEKMAP is not set
    CONFIG_INPUT_MATRIXKMAP=y
    # Userland interfaces
    CONFIG_INPUT_MOUSEDEV=y
    CONFIG_INPUT_MOUSEDEV_PSAUX=y
    CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
    CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
    CONFIG_INPUT_JOYDEV=y
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=y
    # CONFIG_KEYBOARD_QT1070 is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    CONFIG_KEYBOARD_MATRIX=y
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_SAMSUNG is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_OMAP4 is not set
    CONFIG_KEYBOARD_TWL4030=y
    # CONFIG_KEYBOARD_XTKBD is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_CYPRESS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    # CONFIG_MOUSE_PS2_ELANTECH is not set
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_CYAPA is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_MOUSE_SYNAPTICS_USB is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    CONFIG_TOUCHSCREEN_ADS7846=y
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    CONFIG_TOUCHSCREEN_ATMEL_MXT=y
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
    # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    # CONFIG_TOUCHSCREEN_ILI210X is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    # CONFIG_TOUCHSCREEN_MMS114 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    CONFIG_TOUCHSCREEN_TI_AM335X_TSC=y
    CONFIG_TOUCHSCREEN_PIXCIR=m
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    # CONFIG_TOUCHSCREEN_TSC2005 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    # CONFIG_TOUCHSCREEN_W90X900 is not set
    # CONFIG_TOUCHSCREEN_ST1232 is not set
    # CONFIG_TOUCHSCREEN_TPS6507X is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_BMA150 is not set
    # CONFIG_INPUT_MMA8450 is not set
    # CONFIG_INPUT_MPU3050 is not set
    # CONFIG_INPUT_GP2A is not set
    # CONFIG_INPUT_GPIO_TILT_POLLED is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_KXTJ9 is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    CONFIG_INPUT_TWL4030_PWRBUTTON=y
    # CONFIG_INPUT_TWL4030_VIBRA is not set
    # CONFIG_INPUT_TWL6040_VIBRA is not set
    CONFIG_INPUT_UINPUT=y
    # CONFIG_INPUT_PCF8574 is not set
    # CONFIG_INPUT_PWM_BEEPER is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    # CONFIG_INPUT_ADXL34X is not set
    # CONFIG_INPUT_IMS_PCU is not set
    # CONFIG_INPUT_CMA3000 is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    # CONFIG_SERIO_PCIPS2 is not set
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_SERIO_OLPC_APSP is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_NOZOMI is not set
    # CONFIG_N_GSM is not set
    # CONFIG_TRACE_SINK is not set
    CONFIG_DEVKMEM=y
    # Serial drivers
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_DMA=y
    CONFIG_SERIAL_8250_PCI=y
    CONFIG_SERIAL_8250_NR_UARTS=32
    CONFIG_SERIAL_8250_RUNTIME_UARTS=4
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    CONFIG_SERIAL_8250_DETECT_IRQ=y
    CONFIG_SERIAL_8250_RSA=y
    # CONFIG_SERIAL_8250_DW is not set
    # CONFIG_SERIAL_8250_EM is not set
    # Non-8250 serial port support
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    # CONFIG_SERIAL_MFD_HSU is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_JSM is not set
    # CONFIG_SERIAL_OF_PLATFORM is not set
    CONFIG_SERIAL_OMAP=y
    CONFIG_SERIAL_OMAP_CONSOLE=y
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_TIMBERDALE is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_IFX6X60 is not set
    # CONFIG_SERIAL_PCH_UART is not set
    # CONFIG_SERIAL_XILINX_PS_UART is not set
    # CONFIG_SERIAL_ARC is not set
    # CONFIG_SERIAL_RP2 is not set
    # CONFIG_SERIAL_FSL_LPUART is not set
    # CONFIG_SERIAL_ST_ASC is not set
    # CONFIG_TTY_PRINTK is not set
    # CONFIG_HVC_DCC is not set
    # CONFIG_IPMI_HANDLER is not set
    CONFIG_HW_RANDOM=y
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    # CONFIG_HW_RANDOM_ATMEL is not set
    CONFIG_HW_RANDOM_OMAP=y
    # CONFIG_HW_RANDOM_EXYNOS is not set
    # CONFIG_R3964 is not set
    # CONFIG_APPLICOM is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    CONFIG_DEVPORT=y
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    # CONFIG_I2C_MUX is not set
    CONFIG_I2C_HELPER_AUTO=y
    # I2C Hardware Bus support
    # PC SMBus host controller drivers
    # CONFIG_I2C_ALI1535 is not set
    # CONFIG_I2C_ALI1563 is not set
    # CONFIG_I2C_ALI15X3 is not set
    # CONFIG_I2C_AMD756 is not set
    # CONFIG_I2C_AMD8111 is not set
    # CONFIG_I2C_I801 is not set
    # CONFIG_I2C_ISCH is not set
    # CONFIG_I2C_PIIX4 is not set
    # CONFIG_I2C_NFORCE2 is not set
    # CONFIG_I2C_SIS5595 is not set
    # CONFIG_I2C_SIS630 is not set
    # CONFIG_I2C_SIS96X is not set
    # CONFIG_I2C_VIA is not set
    # CONFIG_I2C_VIAPRO is not set
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    # CONFIG_I2C_DESIGNWARE_PCI is not set
    # CONFIG_I2C_EG20T is not set
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_PXA_PCI is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_STUB is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_FSL_DSPI is not set
    # CONFIG_SPI_OC_TINY is not set
    CONFIG_SPI_OMAP24XX=y
    CONFIG_SPI_TI_QSPI=y
    # CONFIG_SPI_PXA2XX is not set
    # CONFIG_SPI_PXA2XX_PCI is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_TOPCLIFF_PCH is not set
    # CONFIG_SPI_XCOMM is not set
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_DESIGNWARE is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_TLE62X0 is not set
    # CONFIG_HSI is not set
    # PPS support
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    # CONFIG_PPS_CLIENT_LDISC is not set
    # CONFIG_PPS_CLIENT_GPIO is not set
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    CONFIG_PINCTRL=y
    # Pin controllers
    CONFIG_PINMUX=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    # CONFIG_DEBUG_PINCTRL is not set
    CONFIG_PINCTRL_SINGLE=y
    # CONFIG_PINCTRL_PALMAS is not set
    CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIO_DEVRES=y
    CONFIG_GPIOLIB=y
    CONFIG_OF_GPIO=y
    CONFIG_DEBUG_GPIO=y
    CONFIG_GPIO_SYSFS=y
    # Memory mapped GPIO drivers:
    # CONFIG_GPIO_GENERIC_PLATFORM is not set
    # CONFIG_GPIO_EM is not set
    # CONFIG_GPIO_RCAR is not set
    # CONFIG_GPIO_TS5500 is not set
    # CONFIG_GPIO_VX855 is not set
    # CONFIG_GPIO_GRGPIO is not set
    # I2C GPIO expanders:
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCA953X_IRQ is not set
    CONFIG_GPIO_PCF857X=y
    # CONFIG_GPIO_SX150X is not set
    CONFIG_GPIO_TWL4030=y
    # CONFIG_GPIO_TWL6040 is not set
    # CONFIG_GPIO_ADP5588 is not set
    # CONFIG_GPIO_ADNP is not set
    # PCI GPIO expanders:
    # CONFIG_GPIO_BT8XX is not set
    # CONFIG_GPIO_AMD8111 is not set
    # CONFIG_GPIO_ML_IOH is not set
    # CONFIG_GPIO_RDC321X is not set
    # SPI GPIO expanders:
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_74X164 is not set
    # AC97 GPIO expanders:
    # LPC GPIO expanders:
    # MODULbus GPIO expanders:
    # CONFIG_GPIO_PALMAS is not set
    # CONFIG_GPIO_TPS65910 is not set
    # USB GPIO expanders:
    CONFIG_W1=y
    CONFIG_W1_CON=y
    # 1-wire Bus Masters
    # CONFIG_W1_MASTER_MATROX is not set
    # CONFIG_W1_MASTER_DS2490 is not set
    # CONFIG_W1_MASTER_DS2482 is not set
    # CONFIG_W1_MASTER_DS1WM is not set
    # CONFIG_W1_MASTER_GPIO is not set
    # CONFIG_HDQ_MASTER_OMAP is not set
    # 1-wire Slaves
    # CONFIG_W1_SLAVE_THERM is not set
    # CONFIG_W1_SLAVE_SMEM is not set
    # CONFIG_W1_SLAVE_DS2408 is not set
    # CONFIG_W1_SLAVE_DS2413 is not set
    # CONFIG_W1_SLAVE_DS2423 is not set
    # CONFIG_W1_SLAVE_DS2431 is not set
    # CONFIG_W1_SLAVE_DS2433 is not set
    # CONFIG_W1_SLAVE_DS2760 is not set
    # CONFIG_W1_SLAVE_DS2780 is not set
    # CONFIG_W1_SLAVE_DS2781 is not set
    # CONFIG_W1_SLAVE_DS28E04 is not set
    # CONFIG_W1_SLAVE_BQ27000 is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_GENERIC_ADC_BATTERY is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_SBS is not set
    # CONFIG_BATTERY_BQ27x00 is not set
    # CONFIG_BATTERY_MAX17040 is not set
    # CONFIG_BATTERY_MAX17042 is not set
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_MAX8903 is not set
    # CONFIG_CHARGER_TWL4030 is not set
    # CONFIG_CHARGER_LP8727 is not set
    # CONFIG_CHARGER_GPIO is not set
    # CONFIG_CHARGER_MANAGER is not set
    # CONFIG_CHARGER_BQ2415X is not set
    # CONFIG_CHARGER_BQ24190 is not set
    # CONFIG_CHARGER_SMB347 is not set
    # CONFIG_POWER_RESET is not set
    # CONFIG_POWER_RESET_RESTART is not set
    # CONFIG_POWER_AVS is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_VID is not set
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_I5K_AMB is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_GPIO_FAN is not set
    # CONFIG_SENSORS_HIH6130 is not set
    # CONFIG_SENSORS_HTU21 is not set
    # CONFIG_SENSORS_IIO_HWMON is not set
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    CONFIG_SENSORS_LM75=m
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    # CONFIG_SENSORS_LM90 is not set
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    # CONFIG_SENSORS_LM95245 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6642 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_NCT6775 is not set
    # CONFIG_SENSORS_NTC_THERMISTOR is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SIS5595 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH56XX_COMMON is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_ADS1015 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    # CONFIG_SENSORS_INA2XX is not set
    # CONFIG_SENSORS_THMC50 is not set
    # CONFIG_SENSORS_TMP102 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_VIA686A is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_VT8231 is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_THERMAL=y
    CONFIG_THERMAL_HWMON=y
    CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
    # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
    CONFIG_THERMAL_GOV_FAIR_SHARE=y
    CONFIG_THERMAL_GOV_STEP_WISE=y
    CONFIG_THERMAL_GOV_USER_SPACE=y
    CONFIG_CPU_THERMAL=y
    # CONFIG_THERMAL_EMULATION is not set
    # CONFIG_IMX_THERMAL is not set
    # Texas Instruments thermal drivers
    CONFIG_TI_SOC_THERMAL=y
    CONFIG_TI_THERMAL=y
    CONFIG_OMAP4_THERMAL=y
    CONFIG_OMAP5_THERMAL=y
    CONFIG_DRA752_THERMAL=y
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_OMAP_WATCHDOG=y
    CONFIG_TWL4030_WATCHDOG=y
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_ALIM7101_WDT is not set
    # CONFIG_I6300ESB_WDT is not set
    # CONFIG_MEN_A21_WDT is not set
    # PCI-based Watchdog Cards
    # CONFIG_PCIPCWATCHDOG is not set
    # CONFIG_WDTPCI is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    # Broadcom specific AMBA
    # CONFIG_BCMA is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_CROS_EC is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_LPC_ICH is not set
    # CONFIG_LPC_SCH is not set
    # CONFIG_MFD_JANZ_CMODIO is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_RDC321X is not set
    # CONFIG_MFD_RTSX_PCI is not set
    # CONFIG_MFD_RC5T583 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SMSC is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_MFD_STMPE is not set
    CONFIG_MFD_SYSCON=y
    CONFIG_MFD_TI_AM335X_TSCADC=y
    # CONFIG_MFD_LP8788 is not set
    CONFIG_MFD_OMAP_USB_HOST=y
    CONFIG_MFD_PALMAS=y
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65090 is not set
    CONFIG_MFD_TPS65217=y
    CONFIG_MFD_TPS65218=y
    # CONFIG_MFD_TPS6586X is not set
    CONFIG_MFD_TPS65910=y
    # CONFIG_MFD_TPS65912 is not set
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_MFD_TPS80031 is not set
    CONFIG_TWL4030_CORE=y
    # CONFIG_TWL4030_MADC is not set
    CONFIG_TWL4030_POWER=y
    CONFIG_MFD_TWL4030_AUDIO=y
    CONFIG_TWL6040_CORE=y
    CONFIG_MENELAUS=y
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TIMBERDALE is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_MFD_VX855 is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    # CONFIG_VEXPRESS_CONFIG is not set
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    # CONFIG_REGULATOR_DUMMY is not set
    CONFIG_REGULATOR_FIXED_VOLTAGE=y
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_AD5398 is not set
    # CONFIG_REGULATOR_ANATOP is not set
    # CONFIG_REGULATOR_DA9210 is not set
    # CONFIG_REGULATOR_FAN53555 is not set
    # CONFIG_REGULATOR_GPIO is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_LP872X is not set
    # CONFIG_REGULATOR_LP8755 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    # CONFIG_REGULATOR_MAX8973 is not set
    CONFIG_REGULATOR_PALMAS=y
    CONFIG_REGULATOR_PBIAS=y
    # CONFIG_REGULATOR_PFUZE100 is not set
    # CONFIG_REGULATOR_TI_ABB is not set
    # CONFIG_REGULATOR_TPS51632 is not set
    # CONFIG_REGULATOR_TPS62360 is not set
    CONFIG_REGULATOR_TPS65023=y
    CONFIG_REGULATOR_TPS6507X=y
    CONFIG_REGULATOR_TPS65217=y
    CONFIG_REGULATOR_TPS65218=y
    # CONFIG_REGULATOR_TPS6524X is not set
    CONFIG_REGULATOR_TPS65910=y
    CONFIG_REGULATOR_TWL4030=y
    CONFIG_REGULATOR_TIAVSCLASS0=y
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    CONFIG_MEDIA_CAMERA_SUPPORT=y
    # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
    # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
    # CONFIG_MEDIA_RADIO_SUPPORT is not set
    # CONFIG_MEDIA_RC_SUPPORT is not set
    CONFIG_MEDIA_CONTROLLER=y
    CONFIG_VIDEO_DEV=y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    CONFIG_VIDEO_V4L2=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_VIDEOBUF2_CORE=y
    CONFIG_VIDEOBUF2_MEMOPS=y
    CONFIG_VIDEOBUF2_DMA_CONTIG=y
    CONFIG_VIDEOBUF2_VMALLOC=m
    # CONFIG_VIDEO_V4L2_INT_DEVICE is not set
    # CONFIG_TTPCI_EEPROM is not set
    # Media drivers
    CONFIG_MEDIA_USB_SUPPORT=y
    # Webcam devices
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    CONFIG_USB_GSPCA=m
    # CONFIG_USB_M5602 is not set
    # CONFIG_USB_STV06XX is not set
    # CONFIG_USB_GL860 is not set
    # CONFIG_USB_GSPCA_BENQ is not set
    # CONFIG_USB_GSPCA_CONEX is not set
    # CONFIG_USB_GSPCA_CPIA1 is not set
    # CONFIG_USB_GSPCA_ETOMS is not set
    # CONFIG_USB_GSPCA_FINEPIX is not set
    # CONFIG_USB_GSPCA_JEILINJ is not set
    # CONFIG_USB_GSPCA_JL2005BCD is not set
    # CONFIG_USB_GSPCA_KINECT is not set
    # CONFIG_USB_GSPCA_KONICA is not set
    # CONFIG_USB_GSPCA_MARS is not set
    # CONFIG_USB_GSPCA_MR97310A is not set
    # CONFIG_USB_GSPCA_NW80X is not set
    # CONFIG_USB_GSPCA_OV519 is not set
    # CONFIG_USB_GSPCA_OV534 is not set
    # CONFIG_USB_GSPCA_OV534_9 is not set
    # CONFIG_USB_GSPCA_PAC207 is not set
    # CONFIG_USB_GSPCA_PAC7302 is not set
    # CONFIG_USB_GSPCA_PAC7311 is not set
    # CONFIG_USB_GSPCA_SE401 is not set
    # CONFIG_USB_GSPCA_SN9C2028 is not set
    # CONFIG_USB_GSPCA_SN9C20X is not set
    # CONFIG_USB_GSPCA_SONIXB is not set
    # CONFIG_USB_GSPCA_SONIXJ is not set
    # CONFIG_USB_GSPCA_SPCA500 is not set
    # CONFIG_USB_GSPCA_SPCA501 is not set
    # CONFIG_USB_GSPCA_SPCA505 is not set
    # CONFIG_USB_GSPCA_SPCA506 is not set
    # CONFIG_USB_GSPCA_SPCA508 is not set
    # CONFIG_USB_GSPCA_SPCA561 is not set
    # CONFIG_USB_GSPCA_SPCA1528 is not set
    # CONFIG_USB_GSPCA_SQ905 is not set
    # CONFIG_USB_GSPCA_SQ905C is not set
    # CONFIG_USB_GSPCA_SQ930X is not set
    # CONFIG_USB_GSPCA_STK014 is not set
    # CONFIG_USB_GSPCA_STK1135 is not set
    # CONFIG_USB_GSPCA_STV0680 is not set
    # CONFIG_USB_GSPCA_SUNPLUS is not set
    # CONFIG_USB_GSPCA_T613 is not set
    # CONFIG_USB_GSPCA_TOPRO is not set
    # CONFIG_USB_GSPCA_TV8532 is not set
    # CONFIG_USB_GSPCA_VC032X is not set
    # CONFIG_USB_GSPCA_VICAM is not set
    # CONFIG_USB_GSPCA_XIRLINK_CIT is not set
    # CONFIG_USB_GSPCA_ZC3XX is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_USB_ZR364XX is not set
    # CONFIG_USB_STKWEBCAM is not set
    # CONFIG_USB_S2255 is not set
    # CONFIG_USB_SN9C102 is not set
    # CONFIG_VIDEO_USBTV is not set
    # Webcam, TV (analog/digital) USB devices
    # CONFIG_VIDEO_EM28XX is not set
    # CONFIG_MEDIA_PCI_SUPPORT is not set
    CONFIG_V4L_PLATFORM_DRIVERS=y
    # CONFIG_VIDEO_CAFE_CCIC is not set
    # CONFIG_VIDEO_DM6446_CCDC is not set
    # CONFIG_VIDEO_OMAP2_VOUT is not set
    # CONFIG_VIDEO_TIMBERDALE is not set
    # CONFIG_SOC_CAMERA is not set
    CONFIG_VIDEO_AM437X_VPFE=y
    # CONFIG_V4L_MEM2MEM_DRIVERS is not set
    # CONFIG_V4L_TEST_DRIVERS is not set
    # Supported MMC/SDIO adapters
    # CONFIG_CYPRESS_FIRMWARE is not set
    # Media ancillary drivers (tuners, sensors, i2c, frontends)
    # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
    # Encoders, decoders, sensors and other helper chips
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_UDA1342 is not set
    # CONFIG_VIDEO_WM8775 is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # CONFIG_VIDEO_SONY_BTF_MPX is not set
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # Video decoders
    # CONFIG_VIDEO_ADV7180 is not set
    # CONFIG_VIDEO_ADV7183 is not set
    # CONFIG_VIDEO_ADV7604 is not set
    # CONFIG_VIDEO_ADV7842 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_ML86V7667 is not set
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_SAA7191 is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_TW2804 is not set
    # CONFIG_VIDEO_TW9903 is not set
    # CONFIG_VIDEO_TW9906 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # Video encoders
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_ADV7393 is not set
    # CONFIG_VIDEO_ADV7511 is not set
    # CONFIG_VIDEO_AD9389B is not set
    # CONFIG_VIDEO_AK881X is not set
    # CONFIG_VIDEO_THS8200 is not set
    # Camera sensor devices
    CONFIG_VIDEO_OV2659=y
    # CONFIG_VIDEO_OV7640 is not set
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_OV9650 is not set
    # CONFIG_VIDEO_VS6624 is not set
    # CONFIG_VIDEO_MT9M032 is not set
    # CONFIG_VIDEO_MT9P031 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_MT9V032 is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_VIDEO_NOON010PC30 is not set
    # CONFIG_VIDEO_M5MOLS is not set
    # CONFIG_VIDEO_S5K6AA is not set
    # CONFIG_VIDEO_S5K4ECGX is not set
    # CONFIG_VIDEO_SMIAPP is not set
    # CONFIG_VIDEO_S5C73M3 is not set
    # Flash devices
    # CONFIG_VIDEO_ADP1653 is not set
    # CONFIG_VIDEO_AS3645A is not set
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # Miscelaneous helper chips
    # CONFIG_VIDEO_THS7303 is not set
    # CONFIG_VIDEO_M52790 is not set
    # Sensors used on soc_camera driver
    # Customise DVB Frontends
    CONFIG_DVB_AU8522=m
    CONFIG_DVB_AU8522_V4L=m
    CONFIG_DVB_TUNER_DIB0070=m
    CONFIG_DVB_TUNER_DIB0090=m
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # Graphics support
    CONFIG_VGA_ARB=y
    CONFIG_VGA_ARB_MAX_GPUS=16
    # CONFIG_DRM is not set
    # CONFIG_VGASTATE is not set
    # CONFIG_VIDEO_OUTPUT_CONTROL is not set
    CONFIG_VIDEOMODE_HELPERS=y
    CONFIG_FB=y
    CONFIG_FIRMWARE_EDID=y
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    CONFIG_FB_CFB_REV_PIXELS_IN_BYTE=y
    # CONFIG_FB_SYS_FILLRECT is not set
    # CONFIG_FB_SYS_COPYAREA is not set
    # CONFIG_FB_SYS_IMAGEBLIT is not set
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    # CONFIG_FB_SYS_FOPS is not set
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    CONFIG_FB_MODE_HELPERS=y
    CONFIG_FB_TILEBLITTING=y
    # Frame buffer hardware drivers
    # CONFIG_FB_CIRRUS is not set
    # CONFIG_FB_PM2 is not set
    # CONFIG_FB_CYBER2000 is not set
    # CONFIG_FB_ASILIANT is not set
    # CONFIG_FB_IMSTT is not set
    # CONFIG_FB_UVESA is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_NVIDIA is not set
    # CONFIG_FB_RIVA is not set
    # CONFIG_FB_I740 is not set
    # CONFIG_FB_MATROX is not set
    # CONFIG_FB_RADEON is not set
    # CONFIG_FB_ATY128 is not set
    # CONFIG_FB_ATY is not set
    # CONFIG_FB_S3 is not set
    # CONFIG_FB_SAVAGE is not set
    # CONFIG_FB_SIS is not set
    # CONFIG_FB_NEOMAGIC is not set
    # CONFIG_FB_KYRO is not set
    # CONFIG_FB_3DFX is not set
    # CONFIG_FB_VOODOO1 is not set
    # CONFIG_FB_VT8623 is not set
    # CONFIG_FB_TRIDENT is not set
    # CONFIG_FB_ARK is not set
    # CONFIG_FB_PM3 is not set
    # CONFIG_FB_CARMINE is not set
    # CONFIG_FB_TMIO is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_GOLDFISH is not set
    CONFIG_FB_DA8XX=y
    CONFIG_FB_DA8XX_TDA998X=y
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_FB_AUO_K190X is not set
    # CONFIG_FB_SIMPLE is not set
    CONFIG_OMAP2_VRFB=y
    CONFIG_OMAP2_DSS=y
    # CONFIG_OMAP2_DSS_DEBUG is not set
    # CONFIG_OMAP2_DSS_DEBUGFS is not set
    CONFIG_OMAP2_DSS_DPI=y
    CONFIG_OMAP2_DSS_DRA7XX_DPI=y
    CONFIG_OMAP2_DSS_VENC=y
    CONFIG_OMAP4_DSS_HDMI=y
    CONFIG_OMAP5_DSS_HDMI=y
    CONFIG_OMAP2_DSS_SDI=y
    CONFIG_OMAP2_DSS_DSI=y
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
    CONFIG_FB_OMAP2=y
    CONFIG_FB_OMAP2_DEBUG_SUPPORT=y
    CONFIG_FB_OMAP2_NUM_FBS=3
    # OMAP Display Device Drivers (new device model)
    CONFIG_DISPLAY_ENCODER_TFP410=y
    CONFIG_DISPLAY_ENCODER_TPD12S015=y
    CONFIG_DISPLAY_DRA_EVM_ENCODER_TPD12S015=y
    CONFIG_DISPLAY_ENCODER_SIL9022=y
    CONFIG_DISPLAY_CONNECTOR_DVI=y
    CONFIG_DISPLAY_CONNECTOR_HDMI=y
    # CONFIG_DISPLAY_CONNECTOR_ANALOG_TV is not set
    CONFIG_DISPLAY_PANEL_DPI=y
    # CONFIG_DISPLAY_PANEL_DSI_CM is not set
    # CONFIG_DISPLAY_PANEL_SONY_ACX565AKM is not set
    # CONFIG_DISPLAY_PANEL_LGPHILIPS_LB035Q02 is not set
    # CONFIG_DISPLAY_PANEL_SHARP_LS037V7DW01 is not set
    # CONFIG_DISPLAY_PANEL_TPO_TD043MTEA1 is not set
    # CONFIG_DISPLAY_PANEL_NEC_NL8048HL11 is not set
    CONFIG_DISPLAY_PANEL_TFCS9700=y
    # CONFIG_EXYNOS_VIDEO is not set
    CONFIG_BACKLIGHT_LCD_SUPPORT=y
    CONFIG_LCD_CLASS_DEVICE=y
    # CONFIG_LCD_L4F00242T03 is not set
    # CONFIG_LCD_LMS283GF05 is not set
    # CONFIG_LCD_LTV350QV is not set
    # CONFIG_LCD_ILI922X is not set
    # CONFIG_LCD_ILI9320 is not set
    # CONFIG_LCD_TDO24M is not set
    # CONFIG_LCD_VGG2432A4 is not set
    CONFIG_LCD_PLATFORM=y
    # CONFIG_LCD_S6E63M0 is not set
    # CONFIG_LCD_LD9040 is not set
    # CONFIG_LCD_AMS369FG06 is not set
    # CONFIG_LCD_LMS501KF03 is not set
    # CONFIG_LCD_HX8357 is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    CONFIG_BACKLIGHT_GENERIC=y
    CONFIG_BACKLIGHT_PWM=y
    # CONFIG_BACKLIGHT_ADP8860 is not set
    # CONFIG_BACKLIGHT_ADP8870 is not set
    # CONFIG_BACKLIGHT_LM3630 is not set
    # CONFIG_BACKLIGHT_LM3639 is not set
    # CONFIG_BACKLIGHT_LP855X is not set
    # CONFIG_BACKLIGHT_PANDORA is not set
    # CONFIG_BACKLIGHT_TPS65217 is not set
    # CONFIG_BACKLIGHT_GPIO is not set
    # CONFIG_BACKLIGHT_LV5207LP is not set
    # CONFIG_BACKLIGHT_BD6107 is not set
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
    CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
    CONFIG_LOGO=y
    CONFIG_LOGO_LINUX_MONO=y
    CONFIG_LOGO_LINUX_VGA16=y
    CONFIG_LOGO_LINUX_CLUT224=y
    # CONFIG_FB_SSD1307 is not set
    CONFIG_SOUND=m
    CONFIG_SOUND_OSS_CORE=y
    CONFIG_SOUND_OSS_CORE_PRECLAIM=y
    CONFIG_SND=m
    CONFIG_SND_TIMER=m
    CONFIG_SND_PCM=m
    CONFIG_SND_DMAENGINE_PCM=m
    CONFIG_SND_HWDEP=m
    CONFIG_SND_RAWMIDI=m
    CONFIG_SND_COMPRESS_OFFLOAD=m
    CONFIG_SND_JACK=y
    # CONFIG_SND_SEQUENCER is not set
    CONFIG_SND_OSSEMUL=y
    CONFIG_SND_MIXER_OSS=m
    CONFIG_SND_PCM_OSS=m
    CONFIG_SND_PCM_OSS_PLUGINS=y
    # CONFIG_SND_HRTIMER is not set
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    CONFIG_SND_VERBOSE_PRINTK=y
    CONFIG_SND_DEBUG=y
    # CONFIG_SND_DEBUG_VERBOSE is not set
    # CONFIG_SND_PCM_XRUN_DEBUG is not set
    # CONFIG_SND_RAWMIDI_SEQ is not set
    # CONFIG_SND_OPL3_LIB_SEQ is not set
    # CONFIG_SND_OPL4_LIB_SEQ is not set
    # CONFIG_SND_SBAWE_SEQ is not set
    # CONFIG_SND_EMU10K1_SEQ is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    CONFIG_SND_PCI=y
    # CONFIG_SND_AD1889 is not set
    # CONFIG_SND_ALS300 is not set
    # CONFIG_SND_ALI5451 is not set
    # CONFIG_SND_ATIIXP is not set
    # CONFIG_SND_ATIIXP_MODEM is not set
    # CONFIG_SND_AU8810 is not set
    # CONFIG_SND_AU8820 is not set
    # CONFIG_SND_AU8830 is not set
    # CONFIG_SND_AW2 is not set
    # CONFIG_SND_AZT3328 is not set
    # CONFIG_SND_BT87X is not set
    # CONFIG_SND_CA0106 is not set
    # CONFIG_SND_CMIPCI is not set
    # CONFIG_SND_OXYGEN is not set
    # CONFIG_SND_CS4281 is not set
    # CONFIG_SND_CS46XX is not set
    # CONFIG_SND_CS5535AUDIO is not set
    # CONFIG_SND_CTXFI is not set
    # CONFIG_SND_DARLA20 is not set
    # CONFIG_SND_GINA20 is not set
    # CONFIG_SND_LAYLA20 is not set
    # CONFIG_SND_DARLA24 is not set
    # CONFIG_SND_GINA24 is not set
    # CONFIG_SND_LAYLA24 is not set
    # CONFIG_SND_MONA is not set
    # CONFIG_SND_MIA is not set
    # CONFIG_SND_ECHO3G is not set
    # CONFIG_SND_INDIGO is not set
    # CONFIG_SND_INDIGOIO is not set
    # CONFIG_SND_INDIGODJ is not set
    # CONFIG_SND_INDIGOIOX is not set
    # CONFIG_SND_INDIGODJX is not set
    # CONFIG_SND_EMU10K1 is not set
    # CONFIG_SND_EMU10K1X is not set
    # CONFIG_SND_ENS1370 is not set
    # CONFIG_SND_ENS1371 is not set
    # CONFIG_SND_ES1938 is not set
    # CONFIG_SND_ES1968 is not set
    # CONFIG_SND_FM801 is not set
    # CONFIG_SND_HDA_INTEL is not set
    # CONFIG_SND_HDSP is not set
    # CONFIG_SND_HDSPM is not set
    # CONFIG_SND_ICE1712 is not set
    # CONFIG_SND_ICE1724 is not set
    # CONFIG_SND_INTEL8X0 is not set
    # CONFIG_SND_INTEL8X0M is not set
    # CONFIG_SND_KORG1212 is not set
    # CONFIG_SND_LOLA is not set
    # CONFIG_SND_LX6464ES is not set
    # CONFIG_SND_MAESTRO3 is not set
    # CONFIG_SND_MIXART is not set
    # CONFIG_SND_NM256 is not set
    # CONFIG_SND_PCXHR is not set
    # CONFIG_SND_RIPTIDE is not set
    # CONFIG_SND_RME32 is not set
    # CONFIG_SND_RME96 is not set
    # CONFIG_SND_RME9652 is not set
    # CONFIG_SND_SONICVIBES is not set
    # CONFIG_SND_TRIDENT is not set
    # CONFIG_SND_VIA82XX is not set
    # CONFIG_SND_VIA82XX_MODEM is not set
    # CONFIG_SND_VIRTUOSO is not set
    # CONFIG_SND_VX222 is not set
    # CONFIG_SND_YMFPCI is not set
    CONFIG_SND_ARM=y
    CONFIG_SND_SPI=y
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=m
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_6FIRE is not set
    # CONFIG_SND_USB_HIFACE is not set
    CONFIG_SND_SOC=m
    # CONFIG_SND_ATMEL_SOC is not set
    CONFIG_SND_DAVINCI_SOC=m
    CONFIG_SND_DAVINCI_SOC_MCASP=m
    CONFIG_SND_DAVINCI_SOC_GENERIC_EVM=m
    CONFIG_SND_AM33XX_SOC_EVM=m
    CONFIG_SND_AM43XX_SOC_EPOS_EVM=m
    # CONFIG_SND_DESIGNWARE_I2S is not set
    CONFIG_SND_OMAP_SOC=m
    CONFIG_SND_OMAP_SOC_DMIC=m
    CONFIG_SND_OMAP_SOC_MCBSP=m
    CONFIG_SND_OMAP_SOC_MCPDM=m
    # CONFIG_SND_OMAP_SOC_N810 is not set
    # CONFIG_SND_OMAP_SOC_RX51 is not set
    # CONFIG_SND_OMAP_SOC_AM3517EVM is not set
    CONFIG_SND_OMAP_SOC_DRA7EVM=m
    CONFIG_SND_OMAP_SOC_OMAP_TWL4030=m
    CONFIG_SND_OMAP_SOC_OMAP_ABE_TWL6040=m
    # CONFIG_SND_OMAP_SOC_OMAP_HDMI is not set
    CONFIG_SND_OMAP_SOC_OMAP3_PANDORA=m
    CONFIG_SND_SOC_I2C_AND_SPI=m
    CONFIG_SND_SOC_DMIC=m
    CONFIG_SND_SOC_TLV320AIC3X=m
    CONFIG_SND_SOC_TLV320AIC31XX=m
    CONFIG_SND_SOC_TWL4030=m
    CONFIG_SND_SOC_TWL6040=m
    # CONFIG_SND_SIMPLE_CARD is not set
    # CONFIG_SOUND_PRIME is not set
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    # CONFIG_UHID is not set
    CONFIG_HID_GENERIC=y
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_HUION is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LENOVO_TPKBD is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_MULTITOUCH is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THINGM is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_WIIMOTE is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # USB HID support
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # I2C HID support
    # CONFIG_I2C_HID is not set
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_ARCH_HAS_EHCI=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    # CONFIG_USB_OTG is not set
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    CONFIG_USB_MON=y
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_XHCI_HCD=y
    CONFIG_USB_XHCI_PLATFORM=m
    CONFIG_USB_EHCI_HCD=y
    # CONFIG_USB_EHCI_ROOT_HUB_TT is not set
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    CONFIG_USB_EHCI_PCI=y
    CONFIG_USB_EHCI_HCD_OMAP=y
    # CONFIG_USB_EHCI_HCD_PLATFORM is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1760_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_FUSBH200_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    CONFIG_USB_MUSB_HDRC=m
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    CONFIG_USB_MUSB_DUAL_ROLE=y
    # CONFIG_USB_MUSB_TUSB6010 is not set
    CONFIG_USB_MUSB_OMAP2PLUS=m
    # CONFIG_USB_MUSB_AM35X is not set
    CONFIG_USB_MUSB_DSPS=m
    # CONFIG_USB_MUSB_UX500 is not set
    CONFIG_USB_MUSB_AM335X_CHILD=m
    # CONFIG_USB_INVENTRA_DMA is not set
    CONFIG_USB_TI_CPPI41_DMA=y
    # CONFIG_MUSB_PIO_ONLY is not set
    # CONFIG_USB_RENESAS_USBHS is not set
    # USB Device Class drivers
    # CONFIG_USB_ACM is not set
    # CONFIG_USB_PRINTER is not set
    CONFIG_USB_WDM=y
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    CONFIG_USB_DWC3=m
    # CONFIG_USB_DWC3_HOST is not set
    # CONFIG_USB_DWC3_GADGET is not set
    CONFIG_USB_DWC3_DUAL_ROLE=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=m
    # CONFIG_USB_DWC3_EXYNOS is not set
    # CONFIG_USB_DWC3_PCI is not set
    # Debugging features
    # CONFIG_USB_DWC3_DEBUG is not set
    # CONFIG_USB_CHIPIDEA is not set
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_LED is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    CONFIG_USB_TEST=m
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    # CONFIG_USB_HSIC_USB3503 is not set
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_AM335X_CONTROL_USB=y
    CONFIG_AM335X_PHY_USB=y
    # CONFIG_SAMSUNG_USB2PHY is not set
    # CONFIG_SAMSUNG_USB3PHY is not set
    CONFIG_TWL6030_USB=m
    # CONFIG_USB_GPIO_VBUS is not set
    # CONFIG_USB_ISP1301 is not set
    # CONFIG_USB_RCAR_PHY is not set
    # CONFIG_USB_ULPI is not set
    CONFIG_USB_GADGET=y
    CONFIG_USB_GADGET_DEBUG=y
    # CONFIG_USB_GADGET_VERBOSE is not set
    CONFIG_USB_GADGET_DEBUG_FILES=y
    CONFIG_USB_GADGET_DEBUG_FS=y
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
    # USB Peripheral Controller
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    # CONFIG_USB_M66592 is not set
    # CONFIG_USB_AMD5536UDC is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_NET2280 is not set
    # CONFIG_USB_GOKU is not set
    # CONFIG_USB_EG20T is not set
    # CONFIG_USB_DUMMY_HCD is not set
    CONFIG_USB_LIBCOMPOSITE=m
    CONFIG_USB_F_ACM=m
    CONFIG_USB_F_SS_LB=m
    CONFIG_USB_U_SERIAL=m
    CONFIG_USB_U_ETHER=m
    CONFIG_USB_U_RNDIS=m
    CONFIG_USB_F_SERIAL=m
    CONFIG_USB_F_OBEX=m
    CONFIG_USB_F_NCM=m
    CONFIG_USB_F_ECM=m
    CONFIG_USB_F_SUBSET=m
    CONFIG_USB_F_RNDIS=m
    CONFIG_USB_F_MASS_STORAGE=m
    # CONFIG_USB_CONFIGFS is not set
    CONFIG_USB_ZERO=m
    CONFIG_USB_AUDIO=m
    # CONFIG_GADGET_UAC1 is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    CONFIG_USB_G_NCM=m
    CONFIG_USB_GADGETFS=m
    CONFIG_USB_FUNCTIONFS=m
    CONFIG_USB_FUNCTIONFS_ETH=y
    CONFIG_USB_FUNCTIONFS_RNDIS=y
    CONFIG_USB_FUNCTIONFS_GENERIC=y
    CONFIG_USB_MASS_STORAGE=m
    CONFIG_USB_G_SERIAL=m
    CONFIG_USB_MIDI_GADGET=m
    CONFIG_USB_G_PRINTER=m
    CONFIG_USB_CDC_COMPOSITE=m
    CONFIG_USB_G_ACM_MS=m
    CONFIG_USB_G_MULTI=m
    CONFIG_USB_G_MULTI_RNDIS=y
    CONFIG_USB_G_MULTI_CDC=y
    CONFIG_USB_G_HID=m
    CONFIG_USB_G_DBGP=m
    # CONFIG_USB_G_DBGP_PRINTK is not set
    CONFIG_USB_G_DBGP_SERIAL=y
    CONFIG_USB_G_WEBCAM=m
    # CONFIG_UWB is not set
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    CONFIG_MMC_UNSAFE_RESUME=y
    # CONFIG_MMC_CLKGATE is not set
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=8
    CONFIG_MMC_BLOCK_BOUNCE=y
    CONFIG_SDIO_UART=y
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_MMC_SDHCI_PXAV3 is not set
    # CONFIG_MMC_SDHCI_PXAV2 is not set
    CONFIG_MMC_OMAP=y
    CONFIG_MMC_OMAP_HS=y
    # CONFIG_MMC_TIFM_SD is not set
    # CONFIG_MMC_CB710 is not set
    # CONFIG_MMC_VIA_SDMMC is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # LED drivers
    # CONFIG_LEDS_LM3530 is not set
    # CONFIG_LEDS_LM3642 is not set
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=y
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP5521 is not set
    # CONFIG_LEDS_LP5523 is not set
    # CONFIG_LEDS_LP5562 is not set
    # CONFIG_LEDS_LP8501 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_PCA963X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    # CONFIG_LEDS_PWM is not set
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    # CONFIG_LEDS_TCA6507 is not set
    # CONFIG_LEDS_LM355x is not set
    # CONFIG_LEDS_OT200 is not set
    # CONFIG_LEDS_BLINKM is not set
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=y
    CONFIG_LEDS_TRIGGER_ONESHOT=y
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    CONFIG_LEDS_TRIGGER_BACKLIGHT=y
    CONFIG_LEDS_TRIGGER_CPU=y
    CONFIG_LEDS_TRIGGER_GPIO=y
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
    # iptables trigger is under Netfilter config (LED target)
    # CONFIG_LEDS_TRIGGER_TRANSIENT is not set
    # CONFIG_LEDS_TRIGGER_CAMERA is not set
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_INFINIBAND is not set
    # CONFIG_EDAC is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_DS1307 is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    CONFIG_RTC_DRV_PALMAS=y
    # CONFIG_RTC_DRV_PCF2127 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    CONFIG_RTC_DRV_TWL92330=y
    CONFIG_RTC_DRV_TWL4030=y
    # CONFIG_RTC_DRV_TPS65910 is not set
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    # on-CPU RTC drivers
    CONFIG_RTC_DRV_OMAP=y
    # CONFIG_RTC_DRV_SNVS is not set
    # CONFIG_RTC_DRV_MOXART is not set
    # HID Sensor RTC drivers
    # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    # CONFIG_DW_DMAC_CORE is not set
    # CONFIG_DW_DMAC is not set
    # CONFIG_DW_DMAC_PCI is not set
    # CONFIG_TIMB_DMA is not set
    CONFIG_TI_EDMA=y
    CONFIG_DMA_OMAP=y
    CONFIG_TI_CPPI41=y
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_VIRTUAL_CHANNELS=y
    CONFIG_DMA_OF=y
    # DMA Clients
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_UIO is not set
    # CONFIG_VIRT_DRIVERS is not set
    # Virtio drivers
    # CONFIG_VIRTIO_PCI is not set
    # CONFIG_VIRTIO_MMIO is not set
    # Microsoft Hyper-V guest support
    # CONFIG_STAGING is not set
    CONFIG_CLKDEV_LOOKUP=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # Common Clock Framework
    CONFIG_COMMON_CLK_DEBUG=y
    # CONFIG_COMMON_CLK_SI5351 is not set
    # CONFIG_CLK_TWL6040 is not set
    CONFIG_COMMON_CLK_PALMAS=y
    # Hardware Spinlock drivers
    # CONFIG_HWSPINLOCK_OMAP is not set
    CONFIG_CLKSRC_OF=y
    CONFIG_CLKSRC_MMIO=y
    CONFIG_ARM_ARCH_TIMER=y
    CONFIG_MAILBOX=y
    CONFIG_OMAP_MBOX=y
    CONFIG_OMAP2PLUS_MBOX=y
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    CONFIG_IOMMU_SUPPORT=y
    CONFIG_OF_IOMMU=y
    # CONFIG_OMAP_IOMMU is not set
    # Remoteproc drivers
    # CONFIG_STE_MODEM_RPROC is not set
    # Rpmsg drivers
    # CONFIG_PM_DEVFREQ is not set
    CONFIG_EXTCON=y
    # Extcon Device Drivers
    CONFIG_OF_EXTCON=y
    # CONFIG_EXTCON_GPIO is not set
    # CONFIG_EXTCON_ADC_JACK is not set
    CONFIG_EXTCON_PALMAS=y
    CONFIG_EXTCON_GPIO_USBVID=y
    # CONFIG_MEMORY is not set
    CONFIG_IIO=m
    CONFIG_IIO_BUFFER=y
    CONFIG_IIO_BUFFER_CB=y
    CONFIG_IIO_KFIFO_BUF=m
    CONFIG_IIO_TRIGGER=y
    CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
    # Accelerometers
    # CONFIG_BMA180 is not set
    # CONFIG_IIO_ST_ACCEL_3AXIS is not set
    # CONFIG_KXSD9 is not set
    # Analog to digital converters
    # CONFIG_AD7266 is not set
    # CONFIG_AD7298 is not set
    # CONFIG_AD7476 is not set
    # CONFIG_AD7791 is not set
    # CONFIG_AD7793 is not set
    # CONFIG_AD7887 is not set
    # CONFIG_AD7923 is not set
    # CONFIG_EXYNOS_ADC is not set
    # CONFIG_MAX1363 is not set
    # CONFIG_MCP320X is not set
    # CONFIG_NAU7802 is not set
    # CONFIG_TI_ADC081C is not set
    CONFIG_TI_AM335X_ADC=m
    # CONFIG_TWL6030_GPADC is not set
    # Amplifiers
    # CONFIG_AD8366 is not set
    # Hid Sensor IIO Common
    # Digital to analog converters
    # CONFIG_AD5064 is not set
    # CONFIG_AD5360 is not set
    # CONFIG_AD5380 is not set
    # CONFIG_AD5421 is not set
    # CONFIG_AD5446 is not set
    # CONFIG_AD5449 is not set
    # CONFIG_AD5504 is not set
    # CONFIG_AD5624R_SPI is not set
    # CONFIG_AD5686 is not set
    # CONFIG_AD5755 is not set
    # CONFIG_AD5764 is not set
    # CONFIG_AD5791 is not set
    # CONFIG_AD7303 is not set
    # CONFIG_MAX517 is not set
    # CONFIG_MCP4725 is not set
    # Frequency Synthesizers DDS/PLL
    # Clock Generator/Distribution
    # CONFIG_AD9523 is not set
    # Phase-Locked Loop (PLL) frequency synthesizers
    # CONFIG_ADF4350 is not set
    # Digital gyroscope sensors
    # CONFIG_ADIS16080 is not set
    # CONFIG_ADIS16130 is not set
    # CONFIG_ADIS16136 is not set
    # CONFIG_ADIS16260 is not set
    # CONFIG_ADXRS450 is not set
    # CONFIG_IIO_ST_GYRO_3AXIS is not set
    # CONFIG_ITG3200 is not set
    # Inertial measurement units
    # CONFIG_ADIS16400 is not set
    # CONFIG_ADIS16480 is not set
    # CONFIG_INV_MPU6050_IIO is not set
    # Light sensors
    # CONFIG_ADJD_S311 is not set
    # CONFIG_APDS9300 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_VCNL4000 is not set
    # Magnetometer sensors
    # CONFIG_AK8975 is not set
    # CONFIG_IIO_ST_MAGN_3AXIS is not set
    # Triggers - standalone
    # CONFIG_IIO_INTERRUPT_TRIGGER is not set
    # CONFIG_IIO_SYSFS_TRIGGER is not set
    # Pressure sensors
    # CONFIG_IIO_ST_PRESS is not set
    # Temperature sensors
    # CONFIG_TMP006 is not set
    # CONFIG_VME_BUS is not set
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    # CONFIG_PWM_PCA9685 is not set
    CONFIG_PWM_TIECAP=y
    CONFIG_PWM_TIEHRPWM=y
    CONFIG_PWM_TIPWMSS=y
    # CONFIG_PWM_TWL is not set
    # CONFIG_PWM_TWL_LED is not set
    CONFIG_IRQCHIP=y
    CONFIG_ARM_GIC=y
    # CONFIG_IPACK_BUS is not set
    CONFIG_ARCH_HAS_RESET_CONTROLLER=y
    CONFIG_RESET_CONTROLLER=y
    CONFIG_RESET_TI=y
    # CONFIG_FMC is not set
    # PHY Subsystem
    CONFIG_GENERIC_PHY=y
    CONFIG_OMAP_CONTROL_PHY=y
    CONFIG_OMAP_USB2=y
    CONFIG_OMAP_PIPE3=y
    CONFIG_TWL4030_USB=m
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    # CONFIG_EXT2_FS_XIP is not set
    CONFIG_EXT3_FS=y
    CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
    # CONFIG_EXT3_FS_XATTR is not set
    CONFIG_EXT4_FS=y
    # CONFIG_EXT4_FS_POSIX_ACL is not set
    # CONFIG_EXT4_FS_SECURITY is not set
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY is not set
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    # CONFIG_QUOTA_DEBUG is not set
    CONFIG_QUOTA_TREE=y
    # CONFIG_QFMT_V1 is not set
    CONFIG_QFMT_V2=y
    CONFIG_QUOTACTL=y
    # CONFIG_AUTOFS4_FS is not set
    # CONFIG_FUSE_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_NTFS_FS is not set
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    # CONFIG_TMPFS_POSIX_ACL is not set
    # CONFIG_TMPFS_XATTR is not set
    # CONFIG_HUGETLB_PAGE is not set
    CONFIG_CONFIGFS_FS=m
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_ECRYPT_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    CONFIG_JFFS2_FS_XATTR=y
    CONFIG_JFFS2_FS_POSIX_ACL=y
    CONFIG_JFFS2_FS_SECURITY=y
    CONFIG_JFFS2_COMPRESSION_OPTIONS=y
    CONFIG_JFFS2_ZLIB=y
    CONFIG_JFFS2_LZO=y
    CONFIG_JFFS2_RTIME=y
    CONFIG_JFFS2_RUBIN=y
    # CONFIG_JFFS2_CMODE_NONE is not set
    CONFIG_JFFS2_CMODE_PRIORITY=y
    # CONFIG_JFFS2_CMODE_SIZE is not set
    # CONFIG_JFFS2_CMODE_FAVOURLZO is not set
    CONFIG_UBIFS_FS=y
    # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    # CONFIG_LOGFS is not set
    CONFIG_CRAMFS=y
    # CONFIG_SQUASHFS is not set
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    # CONFIG_PSTORE is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    CONFIG_NFS_V3_ACL=y
    CONFIG_NFS_V4=y
    # CONFIG_NFS_SWAP is not set
    # CONFIG_NFS_V4_1 is not set
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    # CONFIG_NFSD is not set
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_SUPPORT=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_NCP_FS is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    # CONFIG_NLS_ASCII is not set
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    # CONFIG_NLS_UTF8 is not set
    # CONFIG_DLM is not set
    # Kernel hacking
    # printk and dmesg options
    CONFIG_PRINTK_TIME=y
    CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # Compile-time checks and compiler options
    CONFIG_DEBUG_INFO=y
    # CONFIG_DEBUG_INFO_REDUCED is not set
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_FRAME_POINTER=y
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    CONFIG_MAGIC_SYSRQ=y
    CONFIG_DEBUG_KERNEL=y
    # Memory Debugging
    # CONFIG_DEBUG_PAGEALLOC is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_DEBUG_SLAB is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_PER_CPU_MAPS is not set
    # CONFIG_DEBUG_HIGHMEM is not set
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Lockups and Hangs
    # CONFIG_LOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    # CONFIG_SCHED_DEBUG is not set
    # CONFIG_SCHEDSTATS is not set
    # CONFIG_TIMER_STATS is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_SPARSE_RCU_POINTER is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    CONFIG_RCU_CPU_STALL_TIMEOUT=21
    # CONFIG_RCU_CPU_STALL_INFO is not set
    # CONFIG_RCU_TRACE is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACE_CLOCK=y
    CONFIG_RING_BUFFER=y
    CONFIG_RING_BUFFER_ALLOW_SWAP=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    # Runtime Testing
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_KPROBES_SANITY_TEST is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_STRICT_DEVMEM is not set
    # CONFIG_ARM_UNWIND is not set
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_LL is not set
    CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
    # CONFIG_DEBUG_UART_PL01X is not set
    # CONFIG_DEBUG_UART_8250 is not set
    CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
    # CONFIG_ARM_KPROBES_TEST is not set
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # Security options
    CONFIG_KEYS=y
    # CONFIG_ENCRYPTED_KEYS is not set
    # CONFIG_KEYS_DEBUG_PROC_KEYS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    CONFIG_SECURITY=y
    # CONFIG_SECURITYFS is not set
    # CONFIG_SECURITY_NETWORK is not set
    # CONFIG_SECURITY_PATH is not set
    # CONFIG_SECURITY_SMACK is not set
    # CONFIG_SECURITY_TOMOYO is not set
    # CONFIG_SECURITY_APPARMOR is not set
    # CONFIG_SECURITY_YAMA is not set
    # CONFIG_IMA is not set
    # CONFIG_EVM is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_BLKCIPHER=y
    CONFIG_CRYPTO_BLKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_PCOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    # CONFIG_CRYPTO_USER is not set
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    # CONFIG_CRYPTO_GF128MUL is not set
    # CONFIG_CRYPTO_NULL is not set
    # CONFIG_CRYPTO_PCRYPT is not set
    CONFIG_CRYPTO_WORKQUEUE=y
    # CONFIG_CRYPTO_CRYPTD is not set
    # CONFIG_CRYPTO_AUTHENC is not set
    CONFIG_CRYPTO_TEST=m
    # Authenticated Encryption with Associated Data
    # CONFIG_CRYPTO_CCM is not set
    # CONFIG_CRYPTO_GCM is not set
    # CONFIG_CRYPTO_SEQIV is not set
    # Block modes
    # CONFIG_CRYPTO_CBC is not set
    # CONFIG_CRYPTO_CTR is not set
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=y
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_PCBC is not set
    # CONFIG_CRYPTO_XTS is not set
    # Hash modes
    # CONFIG_CRYPTO_CMAC is not set
    CONFIG_CRYPTO_HMAC=y
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    CONFIG_CRYPTO_CRCT10DIF=y
    # CONFIG_CRYPTO_GHASH is not set
    # CONFIG_CRYPTO_MD4 is not set
    CONFIG_CRYPTO_MD5=y
    CONFIG_CRYPTO_MICHAEL_MIC=y
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    CONFIG_CRYPTO_SHA1=y
    # CONFIG_CRYPTO_SHA1_ARM is not set
    CONFIG_CRYPTO_SHA256=y
    CONFIG_CRYPTO_SHA512=y
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    CONFIG_CRYPTO_AES=y
    # CONFIG_CRYPTO_AES_ARM is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    CONFIG_CRYPTO_ARC4=y
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    CONFIG_CRYPTO_DES=y
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    # CONFIG_CRYPTO_ZLIB is not set
    CONFIG_CRYPTO_LZO=y
    # CONFIG_CRYPTO_LZ4 is not set
    # CONFIG_CRYPTO_LZ4HC is not set
    # Random Number Generation
    # CONFIG_CRYPTO_ANSI_CPRNG is not set
    CONFIG_CRYPTO_USER_API=y
    CONFIG_CRYPTO_USER_API_HASH=y
    CONFIG_CRYPTO_USER_API_SKCIPHER=y
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_HIFN_795X is not set
    CONFIG_CRYPTO_DEV_OMAP_SHAM=y
    CONFIG_CRYPTO_DEV_OMAP_AES=y
    CONFIG_CRYPTO_DEV_OMAP_DES=y
    # CONFIG_ASYMMETRIC_KEY_TYPE is not set
    # CONFIG_BINARY_PRINTF is not set
    # Library routines
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_GENERIC_IO=y
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=y
    CONFIG_CRC_ITU_T=y
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    CONFIG_CRC7=y
    CONFIG_LIBCRC32C=y
    # CONFIG_CRC8 is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    # CONFIG_XZ_DEC is not set
    # CONFIG_XZ_DEC_BCJ is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_BCH=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
    CONFIG_CPU_RMAP=y
    CONFIG_DQL=y
    CONFIG_NLATTR=y
    CONFIG_GENERIC_ATOMIC64=y
    CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE=y
    CONFIG_AVERAGE=y
    # CONFIG_CORDIC is not set
    # CONFIG_DDR is not set
    CONFIG_OID_REGISTRY=y
    CONFIG_FONT_SUPPORT=y
    CONFIG_FONTS=y
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    # CONFIG_FONT_6x11 is not set
    # CONFIG_FONT_7x14 is not set
    # CONFIG_FONT_PEARL_8x8 is not set
    # CONFIG_FONT_ACORN_8x8 is not set
    # CONFIG_FONT_MINI_4x6 is not set
    # CONFIG_FONT_SUN8x16 is not set
    # CONFIG_FONT_SUN12x22 is not set
    # CONFIG_FONT_10x18 is not set
    # CONFIG_VIRTUALIZATION is not set
    ========================================== 3.14 kernel config =============================
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 3.14.0-rc2 Kernel Configuration
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_ARCH_HAS_BANDGAP=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_EXTABLE_SORT=y
    # General setup
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_CROSS_COMPILE=""
    # CONFIG_COMPILE_TEST is not set
    CONFIG_LOCALVERSION=""
    # CONFIG_LOCALVERSION_AUTO is not set
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_XZ=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_HAVE_KERNEL_LZ4=y
    CONFIG_KERNEL_GZIP=y
    # CONFIG_KERNEL_LZMA is not set
    # CONFIG_KERNEL_XZ is not set
    # CONFIG_KERNEL_LZO is not set
    # CONFIG_KERNEL_LZ4 is not set
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    # CONFIG_FHANDLE is not set
    # CONFIG_AUDIT is not set
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    # CONFIG_IRQ_DOMAIN_DEBUG is not set
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    CONFIG_KTIME_SCALAR=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
    # CONFIG_IRQ_TIME_ACCOUNTING is not set
    CONFIG_BSD_PROCESS_ACCT=y
    # CONFIG_BSD_PROCESS_ACCT_V3 is not set
    # CONFIG_TASKSTATS is not set
    # RCU Subsystem
    CONFIG_TINY_RCU=y
    # CONFIG_PREEMPT_RCU is not set
    # CONFIG_RCU_STALL_COMMON is not set
    # CONFIG_TREE_RCU_TRACE is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=16
    CONFIG_GENERIC_SCHED_CLOCK=y
    # CONFIG_CGROUPS is not set
    # CONFIG_CHECKPOINT_RESTORE is not set
    # CONFIG_NAMESPACES is not set
    # CONFIG_SCHED_AUTOGROUP is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    # CONFIG_RD_BZIP2 is not set
    # CONFIG_RD_LZMA is not set
    # CONFIG_RD_XZ is not set
    # CONFIG_RD_LZO is not set
    # CONFIG_RD_LZ4 is not set
    # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_HAVE_UID16=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    # CONFIG_SYSCTL_SYSCALL is not set
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    # CONFIG_EMBEDDED is not set
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    CONFIG_VM_EVENT_COUNTERS=y
    CONFIG_COMPAT_BRK=y
    CONFIG_SLAB=y
    # CONFIG_SLUB is not set
    # CONFIG_SLOB is not set
    CONFIG_PROFILING=y
    CONFIG_OPROFILE=y
    CONFIG_HAVE_OPROFILE=y
    CONFIG_KPROBES=y
    CONFIG_JUMP_LABEL=y
    # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
    CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
    CONFIG_ARCH_USE_BUILTIN_BSWAP=y
    CONFIG_KRETPROBES=y
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_ATTRS=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_DMA_API_DEBUG=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_PERF_REGS=y
    CONFIG_HAVE_PERF_USER_STACK_DUMP=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_CC_STACKPROTECTOR=y
    # CONFIG_CC_STACKPROTECTOR is not set
    CONFIG_CC_STACKPROTECTOR_NONE=y
    # CONFIG_CC_STACKPROTECTOR_REGULAR is not set
    # CONFIG_CC_STACKPROTECTOR_STRONG is not set
    CONFIG_HAVE_CONTEXT_TRACKING=y
    CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_MODULES_USE_ELF_REL=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_SIGACTION=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    # CONFIG_SYSTEM_TRUSTED_KEYRING is not set
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL=y
    # CONFIG_MODULE_SIG is not set
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_BSGLIB is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # CONFIG_BLK_CMDLINE_PARSER is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_AIX_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    # CONFIG_CMDLINE_PARTITION is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    CONFIG_IOSCHED_DEADLINE=y
    CONFIG_IOSCHED_CFQ=y
    # CONFIG_DEFAULT_DEADLINE is not set
    CONFIG_DEFAULT_CFQ=y
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="cfq"
    CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
    CONFIG_INLINE_READ_UNLOCK=y
    CONFIG_INLINE_READ_UNLOCK_IRQ=y
    CONFIG_INLINE_WRITE_UNLOCK=y
    CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    CONFIG_ARCH_MULTIPLATFORM=y
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_LPC32XX is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_MSM_NODT is not set
    # CONFIG_ARCH_SHMOBILE_LEGACY is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C24XX is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_S5P64X0 is not set
    # CONFIG_ARCH_S5PC100 is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_ARCH_OMAP1 is not set
    # Multiple platform selection
    # CPU Core family selection
    CONFIG_ARCH_MULTI_V6=y
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    # CONFIG_ARCH_MULTI_CPU_AUTO is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_ARCH_BCM2835 is not set
    # CONFIG_ARCH_BERLIN is not set
    # CONFIG_ARCH_CNS3XXX is not set
    CONFIG_GPIO_PCA953X=y
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_HI3xxx is not set
    # CONFIG_ARCH_KEYSTONE is not set
    # CONFIG_ARCH_MSM_DT is not set
    # CONFIG_ARCH_MXC is not set
    # TI OMAP Common Features
    # OMAP Feature Selections
    CONFIG_OMAP_RESET_CLOCKS=y
    CONFIG_OMAP_MUX=y
    CONFIG_OMAP_MUX_DEBUG=y
    CONFIG_OMAP_MUX_WARNINGS=y
    CONFIG_OMAP_32K_TIMER=y
    # CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_OMAP_PM_NOOP=y
    CONFIG_MACH_OMAP_GENERIC=y
    CONFIG_ARCH_OMAP=y
    CONFIG_ARCH_OMAP2=y
    CONFIG_ARCH_OMAP3=y
    CONFIG_ARCH_OMAP4=y
    CONFIG_SOC_OMAP5=y
    CONFIG_SOC_AM33XX=y
    CONFIG_SOC_AM43XX=y
    CONFIG_SOC_DRA7XX=y
    CONFIG_ARCH_OMAP2PLUS=y
    # TI OMAP2/3/4 Specific Features
    CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
    CONFIG_SOC_HAS_OMAP2_SDRC=y
    CONFIG_SOC_HAS_REALTIME_COUNTER=y
    # OMAP Core Type
    CONFIG_SOC_OMAP2420=y
    CONFIG_SOC_OMAP2430=y
    CONFIG_SOC_OMAP3430=y
    CONFIG_SOC_TI81XX=y
    CONFIG_OMAP_PACKAGE_ZAC=y
    CONFIG_OMAP_PACKAGE_CBB=y
    CONFIG_OMAP_PACKAGE_CUS=y
    # OMAP Legacy Platform Data Board Type
    CONFIG_MACH_OMAP2_TUSB6010=y
    CONFIG_MACH_OMAP3_BEAGLE=y
    CONFIG_MACH_DEVKIT8000=y
    CONFIG_MACH_OMAP_LDP=y
    CONFIG_MACH_OMAP3530_LV_SOM=y
    CONFIG_MACH_OMAP3_TORPEDO=y
    CONFIG_MACH_OVERO=y
    CONFIG_MACH_OMAP3517EVM=y
    # CONFIG_MACH_CRANEBOARD is not set
    CONFIG_MACH_OMAP3_PANDORA=y
    CONFIG_MACH_TOUCHBOOK=y
    CONFIG_MACH_OMAP_3430SDP=y
    CONFIG_MACH_NOKIA_N800=y
    CONFIG_MACH_NOKIA_N810=y
    CONFIG_MACH_NOKIA_N810_WIMAX=y
    CONFIG_MACH_NOKIA_N8X0=y
    CONFIG_MACH_NOKIA_RX51=y
    CONFIG_MACH_CM_T35=y
    CONFIG_MACH_CM_T3517=y
    CONFIG_MACH_CM_T3730=y
    CONFIG_MACH_SBC3530=y
    CONFIG_MACH_TI8168EVM=y
    CONFIG_MACH_TI8148EVM=y
    # CONFIG_OMAP3_EMU is not set
    # CONFIG_OMAP3_SDRC_AC_TIMING is not set
    # CONFIG_ARCH_PICOXCELL is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_SHMOBILE_MULTI is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_SIRF is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_VIRT is not set
    # CONFIG_ARCH_WM8750 is not set
    # CONFIG_ARCH_WM8850 is not set
    # CONFIG_ARCH_ZYNQ is not set
    # Processor Type
    CONFIG_CPU_V6=y
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v6=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV6=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V6=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V6=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    CONFIG_CPU_USE_DOMAINS=y
    # Processor Features
    # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
    CONFIG_ARM_THUMB=y
    CONFIG_ARM_THUMBEE=y
    CONFIG_ARM_VIRT_EXT=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_KUSER_HELPERS=y
    CONFIG_OUTER_CACHE=y
    CONFIG_OUTER_CACHE_SYNC=y
    CONFIG_CACHE_L2X0=y
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_NR_BANKS=8
    CONFIG_MULTI_IRQ_HANDLER=y
    # CONFIG_ARM_ERRATA_326103 is not set
    CONFIG_ARM_ERRATA_411920=y
    # CONFIG_ARM_ERRATA_430973 is not set
    CONFIG_PL310_ERRATA_588369=y
    CONFIG_ARM_ERRATA_720789=y
    CONFIG_PL310_ERRATA_727915=y
    CONFIG_ARM_ERRATA_754322=y
    # CONFIG_ARM_ERRATA_364296 is not set
    # CONFIG_PL310_ERRATA_769419 is not set
    CONFIG_ARM_ERRATA_775420=y
    # CONFIG_ARM_ERRATA_773022 is not set
    CONFIG_TI_PRIV_EDMA=y
    # Bus support
    # CONFIG_PCI_SYSCALL is not set
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_HAVE_SMP=y
    # CONFIG_SMP is not set
    CONFIG_HAVE_ARM_ARCH_TIMER=y
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    # CONFIG_ARM_PSCI is not set
    CONFIG_ARCH_NR_GPIO=512
    # CONFIG_PREEMPT_NONE is not set
    CONFIG_PREEMPT_VOLUNTARY=y
    # CONFIG_PREEMPT is not set
    CONFIG_HZ_FIXED=0
    # CONFIG_HZ_100 is not set
    # CONFIG_HZ_200 is not set
    # CONFIG_HZ_250 is not set
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_500 is not set
    CONFIG_HZ_1000=y
    CONFIG_HZ=1000
    CONFIG_SCHED_HRTICK=y
    CONFIG_AEABI=y
    CONFIG_OABI_COMPAT=y
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    CONFIG_HAVE_ARCH_PFN_VALID=y
    CONFIG_HIGHMEM=y
    # CONFIG_HIGHPTE is not set
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_HAVE_MEMBLOCK=y
    CONFIG_NO_BOOTMEM=y
    CONFIG_MEMORY_ISOLATION=y
    # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    CONFIG_COMPACTION=y
    CONFIG_MIGRATION=y
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_BOUNCE=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_CROSS_MEMORY_ATTACH=y
    CONFIG_NEED_PER_CPU_KM=y
    # CONFIG_CLEANCACHE is not set
    # CONFIG_FRONTSWAP is not set
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_ZBUD is not set
    # CONFIG_ZSMALLOC is not set
    CONFIG_FORCE_MAX_ZONEORDER=12
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_SECCOMP is not set
    CONFIG_SWIOTLB=y
    CONFIG_IOMMU_HELPER=y
    # Boot options
    CONFIG_USE_OF=y
    CONFIG_ATAGS=y
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_ARM_APPENDED_DTB=y
    CONFIG_ARM_ATAG_DTB_COMPAT=y
    CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
    CONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO2,115200"
    CONFIG_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_CMDLINE_EXTEND is not set
    # CONFIG_CMDLINE_FORCE is not set
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CONFIG_CRASH_DUMP is not set
    CONFIG_AUTO_ZRELADDR=y
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    # CONFIG_CPU_FREQ_GOV_PERFORMANCE is not set
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    # CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    CONFIG_GENERIC_CPUFREQ_CPU0=y
    # ARM CPU frequency scaling drivers
    # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
    # CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set
    # CPU Idle
    CONFIG_CPU_IDLE=y
    # CONFIG_CPU_IDLE_MULTIPLE_DRIVERS is not set
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
    # ARM CPU Idle Drivers
    # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_FPE_NWFPE=y
    # CONFIG_FPE_NWFPE_XP is not set
    # CONFIG_FPE_FASTFPE is not set
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # CONFIG_KERNEL_MODE_NEON is not set
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE=y
    CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
    CONFIG_BINFMT_SCRIPT=y
    # CONFIG_HAVE_AOUT is not set
    CONFIG_BINFMT_MISC=y
    CONFIG_COREDUMP=y
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    CONFIG_PM_SLEEP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM_RUNTIME=y
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_ADVANCED_DEBUG is not set
    # CONFIG_PM_TEST_SUSPEND is not set
    CONFIG_PM_SLEEP_DEBUG=y
    # CONFIG_APM_EMULATION is not set
    CONFIG_ARCH_HAS_OPP=y
    CONFIG_PM_OPP=y
    CONFIG_PM_CLK=y
    # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    # CONFIG_UNIX_DIAG is not set
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=y
    CONFIG_XFRM_USER=y
    # CONFIG_XFRM_SUB_POLICY is not set
    CONFIG_XFRM_MIGRATE=y
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_NET_KEY=y
    CONFIG_NET_KEY_MIGRATE=y
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    # CONFIG_NET_IP_TUNNEL is not set
    # CONFIG_IP_MROUTE is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    # CONFIG_INET_AH is not set
    # CONFIG_INET_ESP is not set
    # CONFIG_INET_IPCOMP is not set
    # CONFIG_INET_XFRM_TUNNEL is not set
    # CONFIG_INET_TUNNEL is not set
    CONFIG_INET_XFRM_MODE_TRANSPORT=m
    CONFIG_INET_XFRM_MODE_TUNNEL=m
    CONFIG_INET_XFRM_MODE_BEET=m
    # CONFIG_INET_LRO is not set
    CONFIG_INET_DIAG=m
    CONFIG_INET_TCP_DIAG=m
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    # CONFIG_IPV6 is not set
    # CONFIG_NETLABEL is not set
    # CONFIG_NETWORK_SECMARK is not set
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    CONFIG_BRIDGE_NETFILTER=y
    # Core Netfilter Configuration
    # CONFIG_NETFILTER_NETLINK_ACCT is not set
    # CONFIG_NETFILTER_NETLINK_QUEUE is not set
    # CONFIG_NETFILTER_NETLINK_LOG is not set
    CONFIG_NF_CONNTRACK=m
    # CONFIG_NF_CONNTRACK_MARK is not set
    CONFIG_NF_CONNTRACK_PROCFS=y
    # CONFIG_NF_CONNTRACK_EVENTS is not set
    # CONFIG_NF_CONNTRACK_TIMEOUT is not set
    # CONFIG_NF_CONNTRACK_TIMESTAMP is not set
    # CONFIG_NF_CT_PROTO_DCCP is not set
    # CONFIG_NF_CT_PROTO_SCTP is not set
    # CONFIG_NF_CT_PROTO_UDPLITE is not set
    # CONFIG_NF_CONNTRACK_AMANDA is not set
    # CONFIG_NF_CONNTRACK_FTP is not set
    # CONFIG_NF_CONNTRACK_H323 is not set
    # CONFIG_NF_CONNTRACK_IRC is not set
    # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
    # CONFIG_NF_CONNTRACK_SNMP is not set
    # CONFIG_NF_CONNTRACK_PPTP is not set
    # CONFIG_NF_CONNTRACK_SANE is not set
    # CONFIG_NF_CONNTRACK_SIP is not set
    # CONFIG_NF_CONNTRACK_TFTP is not set
    # CONFIG_NF_CT_NETLINK is not set
    # CONFIG_NF_CT_NETLINK_TIMEOUT is not set
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_NEEDED=y
    # CONFIG_NF_NAT_AMANDA is not set
    # CONFIG_NF_NAT_FTP is not set
    # CONFIG_NF_NAT_IRC is not set
    # CONFIG_NF_NAT_SIP is not set
    # CONFIG_NF_NAT_TFTP is not set
    # CONFIG_NF_TABLES is not set
    CONFIG_NETFILTER_XTABLES=m
    # Xtables combined modules
    # CONFIG_NETFILTER_XT_MARK is not set
    # CONFIG_NETFILTER_XT_CONNMARK is not set
    # Xtables targets
    # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
    # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_HMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
    # CONFIG_NETFILTER_XT_TARGET_LED is not set
    # CONFIG_NETFILTER_XT_TARGET_LOG is not set
    # CONFIG_NETFILTER_XT_TARGET_MARK is not set
    # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
    # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
    # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
    # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
    # CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set
    # CONFIG_NETFILTER_XT_TARGET_TEE is not set
    # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
    # Xtables matches
    # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_BPF is not set
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
    # CONFIG_NETFILTER_XT_MATCH_CPU is not set
    # CONFIG_NETFILTER_XT_MATCH_DCCP is not set
    # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_DSCP is not set
    # CONFIG_NETFILTER_XT_MATCH_ECN is not set
    # CONFIG_NETFILTER_XT_MATCH_ESP is not set
    # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_HELPER is not set
    # CONFIG_NETFILTER_XT_MATCH_HL is not set
    # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
    # CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
    # CONFIG_NETFILTER_XT_MATCH_L2TP is not set
    # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
    # CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_MAC is not set
    # CONFIG_NETFILTER_XT_MATCH_MARK is not set
    # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
    # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
    # CONFIG_NETFILTER_XT_MATCH_OWNER is not set
    # CONFIG_NETFILTER_XT_MATCH_POLICY is not set
    # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
    # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
    # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
    # CONFIG_NETFILTER_XT_MATCH_REALM is not set
    # CONFIG_NETFILTER_XT_MATCH_RECENT is not set
    # CONFIG_NETFILTER_XT_MATCH_SCTP is not set
    # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
    # CONFIG_NETFILTER_XT_MATCH_STATE is not set
    # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
    # CONFIG_NETFILTER_XT_MATCH_STRING is not set
    # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
    # CONFIG_NETFILTER_XT_MATCH_TIME is not set
    # CONFIG_NETFILTER_XT_MATCH_U32 is not set
    # CONFIG_IP_SET is not set
    # CONFIG_IP_VS is not set
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    CONFIG_NF_CONNTRACK_IPV4=m
    CONFIG_NF_CONNTRACK_PROC_COMPAT=y
    CONFIG_IP_NF_IPTABLES=m
    # CONFIG_IP_NF_MATCH_AH is not set
    # CONFIG_IP_NF_MATCH_ECN is not set
    # CONFIG_IP_NF_MATCH_TTL is not set
    CONFIG_IP_NF_FILTER=m
    # CONFIG_IP_NF_TARGET_REJECT is not set
    # CONFIG_IP_NF_TARGET_SYNPROXY is not set
    # CONFIG_IP_NF_TARGET_ULOG is not set
    CONFIG_NF_NAT_IPV4=m
    CONFIG_IP_NF_TARGET_MASQUERADE=m
    # CONFIG_IP_NF_TARGET_NETMAP is not set
    # CONFIG_IP_NF_TARGET_REDIRECT is not set
    # CONFIG_NF_NAT_PPTP is not set
    # CONFIG_NF_NAT_H323 is not set
    # CONFIG_IP_NF_MANGLE is not set
    # CONFIG_IP_NF_RAW is not set
    # CONFIG_IP_NF_SECURITY is not set
    # CONFIG_IP_NF_ARPTABLES is not set
    # CONFIG_BRIDGE_NF_EBTABLES is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    CONFIG_STP=m
    CONFIG_BRIDGE=m
    CONFIG_BRIDGE_IGMP_SNOOPING=y
    # CONFIG_BRIDGE_VLAN_FILTERING is not set
    CONFIG_HAVE_NET_DSA=y
    CONFIG_VLAN_8021Q=y
    # CONFIG_VLAN_8021Q_GVRP is not set
    # CONFIG_VLAN_8021Q_MVRP is not set
    # CONFIG_DECNET is not set
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_PHONET is not set
    # CONFIG_IEEE802154 is not set
    CONFIG_6LOWPAN_IPHC=m
    # CONFIG_NET_SCHED is not set
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_MMAP is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_NET_MPLS_GSO is not set
    # CONFIG_HSR is not set
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    # CONFIG_BPF_JIT is not set
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_NET_TCPPROBE is not set
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    CONFIG_CAN_GW=m
    # CAN Device Drivers
    # CONFIG_CAN_VCAN is not set
    # CONFIG_CAN_SLCAN is not set
    CONFIG_CAN_DEV=m
    CONFIG_CAN_CALC_BITTIMING=y
    # CONFIG_CAN_LEDS is not set
    # CONFIG_CAN_AT91 is not set
    # CONFIG_CAN_TI_HECC is not set
    # CONFIG_CAN_MCP251X is not set
    # CONFIG_CAN_GRCAN is not set
    # CONFIG_CAN_SJA1000 is not set
    CONFIG_CAN_C_CAN=m
    CONFIG_CAN_C_CAN_PLATFORM=m
    # CONFIG_CAN_CC770 is not set
    # CAN USB interfaces
    # CONFIG_CAN_EMS_USB is not set
    # CONFIG_CAN_ESD_USB2 is not set
    # CONFIG_CAN_KVASER_USB is not set
    # CONFIG_CAN_PEAK_USB is not set
    # CONFIG_CAN_8DEV_USB is not set
    # CONFIG_CAN_SOFTING is not set
    # CONFIG_CAN_DEBUG_DEVICES is not set
    # CONFIG_IRDA is not set
    CONFIG_BT=m
    # CONFIG_BT_RFCOMM is not set
    # CONFIG_BT_BNEP is not set
    # CONFIG_BT_HIDP is not set
    # Bluetooth device drivers
    # CONFIG_BT_HCIBTUSB is not set
    # CONFIG_BT_HCIBTSDIO is not set
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_H4=y
    CONFIG_BT_HCIUART_BCSP=y
    # CONFIG_BT_HCIUART_ATH3K is not set
    CONFIG_BT_HCIUART_LL=y
    # CONFIG_BT_HCIUART_3WIRE is not set
    CONFIG_BT_HCIBCM203X=m
    CONFIG_BT_HCIBPA10X=m
    # CONFIG_BT_HCIBFUSB is not set
    # CONFIG_BT_HCIVHCI is not set
    # CONFIG_BT_MRVL is not set
    CONFIG_BT_WILINK=m
    # CONFIG_AF_RXRPC is not set
    CONFIG_WIRELESS=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WEXT_CORE=y
    CONFIG_WEXT_PROC=y
    CONFIG_WEXT_SPY=y
    CONFIG_WEXT_PRIV=y
    # CONFIG_CFG80211 is not set
    CONFIG_LIB80211=m
    CONFIG_LIB80211_CRYPT_WEP=m
    CONFIG_LIB80211_CRYPT_CCMP=m
    CONFIG_LIB80211_CRYPT_TKIP=m
    # CONFIG_LIB80211_DEBUG is not set
    # CFG80211 needs to be enabled for MAC80211
    # CONFIG_WIMAX is not set
    # CONFIG_RFKILL is not set
    # CONFIG_RFKILL_REGULATOR is not set
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # CONFIG_NFC is not set
    CONFIG_HAVE_BPF_JIT=y
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    CONFIG_FW_LOADER_USER_HELPER=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_GENERIC_CPU_DEVICES is not set
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=m
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_SHARED_BUFFER=y
    CONFIG_DMA_CMA=y
    # Default contiguous memory area size:
    CONFIG_CMA_SIZE_MBYTES=24
    CONFIG_CMA_SIZE_SEL_MBYTES=y
    # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
    # CONFIG_CMA_SIZE_SEL_MIN is not set
    # CONFIG_CMA_SIZE_SEL_MAX is not set
    CONFIG_CMA_ALIGNMENT=8
    CONFIG_CMA_AREAS=7
    # Bus devices
    CONFIG_OMAP_OCP2SCP=y
    CONFIG_OMAP_INTERCONNECT=y
    # CONFIG_ARM_CCI is not set
    CONFIG_CONNECTOR=y
    CONFIG_PROC_EVENTS=y
    CONFIG_MTD=y
    # CONFIG_MTD_TESTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    # CONFIG_MTD_AFS_PARTS is not set
    CONFIG_MTD_OF_PARTS=y
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    CONFIG_MTD_OOPS=y
    # CONFIG_MTD_SWAP is not set
    # RAM/ROM/Flash chip drivers
    CONFIG_MTD_CFI=y
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_GEN_PROBE=y
    # CONFIG_MTD_CFI_ADV_OPTIONS is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    CONFIG_MTD_CFI_INTELEXT=y
    # CONFIG_MTD_CFI_AMDSTD is not set
    # CONFIG_MTD_CFI_STAA is not set
    CONFIG_MTD_CFI_UTIL=y
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    # CONFIG_MTD_PHYSMAP is not set
    # CONFIG_MTD_PHYSMAP_OF is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_DATAFLASH is not set
    CONFIG_MTD_M25P80=y
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    CONFIG_MTD_NAND_ECC=y
    # CONFIG_MTD_NAND_ECC_SMC is not set
    CONFIG_MTD_NAND=y
    # CONFIG_MTD_NAND_ECC_BCH is not set
    # CONFIG_MTD_SM_COMMON is not set
    # CONFIG_MTD_NAND_DENALI is not set
    # CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_OMAP_BCH=y
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_NAND_DOCG4 is not set
    # CONFIG_MTD_NAND_NANDSIM is not set
    # CONFIG_MTD_NAND_PLATFORM is not set
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_LIMIT=20
    # CONFIG_MTD_UBI_FASTMAP is not set
    # CONFIG_MTD_UBI_GLUEBI is not set
    CONFIG_DTC=y
    CONFIG_OF=y
    # Device Tree and Open Firmware support
    CONFIG_PROC_DEVICETREE=y
    # CONFIG_OF_SELFTEST is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_NET=y
    CONFIG_OF_MDIO=y
    CONFIG_OF_MTD=y
    # CONFIG_PARPORT is not set
    CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_NULL_BLK is not set
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # CONFIG_BLK_DEV_DRBD is not set
    # CONFIG_BLK_DEV_NBD is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=16384
    # CONFIG_BLK_DEV_XIP is not set
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    # CONFIG_MG_DISK is not set
    # CONFIG_BLK_DEV_RBD is not set
    # Misc devices
    CONFIG_SENSORS_LIS3LV02D=m
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_ATMEL_PWM is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ATMEL_SSC is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    CONFIG_SENSORS_TSL2550=m
    # CONFIG_SENSORS_BH1780 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_TI_DAC7512 is not set
    CONFIG_BMP085=y
    CONFIG_BMP085_I2C=m
    # CONFIG_BMP085_SPI is not set
    # CONFIG_USB_SWITCH_FSA9480 is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    # CONFIG_SRAM is not set
    # CONFIG_C2PORT is not set
    # EEPROM support
    # CONFIG_EEPROM_AT24 is not set
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    CONFIG_EEPROM_93CX6=y
    # CONFIG_EEPROM_93XX46 is not set
    # Texas Instruments shared transport line discipline
    CONFIG_TI_ST=y
    # CONFIG_SENSORS_LIS3_SPI is not set
    CONFIG_SENSORS_LIS3_I2C=m
    # Altera FPGA firmware download module
    # CONFIG_ALTERA_STAPL is not set
    # Intel MIC Host Driver
    # Intel MIC Card Driver
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_TGT is not set
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    # CONFIG_BLK_DEV_SR is not set
    # CONFIG_CHR_DEV_SG is not set
    # CONFIG_CHR_DEV_SCH is not set
    CONFIG_SCSI_MULTI_LUN=y
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    CONFIG_SCSI_SCAN_ASYNC=y
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_UFSHCD is not set
    # CONFIG_LIBFC is not set
    # CONFIG_LIBFCOE is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    CONFIG_ATA=y
    # CONFIG_ATA_NONSTANDARD is not set
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    CONFIG_SATA_AHCI_PLATFORM=y
    # CONFIG_AHCI_IMX is not set
    CONFIG_ATA_SFF=y
    # SFF controllers with custom DMA interface
    CONFIG_ATA_BMDMA=y
    # SATA SFF controllers with BMDMA
    # CONFIG_SATA_HIGHBANK is not set
    # CONFIG_SATA_MV is not set
    # CONFIG_SATA_RCAR is not set
    # PATA SFF controllers with BMDMA
    # CONFIG_PATA_ARASAN_CF is not set
    # PIO-only SFF controllers
    # CONFIG_PATA_PLATFORM is not set
    # Generic fallback / legacy drivers
    CONFIG_MD=y
    # CONFIG_BLK_DEV_MD is not set
    # CONFIG_BCACHE is not set
    # CONFIG_BLK_DEV_DM is not set
    # CONFIG_TARGET_CORE is not set
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    # CONFIG_DUMMY is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_VXLAN is not set
    # CONFIG_NETCONSOLE is not set
    # CONFIG_NETPOLL is not set
    # CONFIG_NET_POLL_CONTROLLER is not set
    # CONFIG_TUN is not set
    # CONFIG_VETH is not set
    # CONFIG_NLMON is not set
    # CAIF transport drivers
    # Distributed Switch Architecture drivers
    # CONFIG_NET_DSA_MV88E6XXX is not set
    # CONFIG_NET_DSA_MV88E6060 is not set
    # CONFIG_NET_DSA_MV88E6XXX_NEED_PPU is not set
    # CONFIG_NET_DSA_MV88E6131 is not set
    # CONFIG_NET_DSA_MV88E6123_61_65 is not set
    CONFIG_ETHERNET=y
    CONFIG_NET_VENDOR_ARC=y
    # CONFIG_ARC_EMAC is not set
    CONFIG_NET_CADENCE=y
    # CONFIG_ARM_AT91_ETHER is not set
    # CONFIG_MACB is not set
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_NET_CALXEDA_XGMAC is not set
    CONFIG_NET_VENDOR_CIRRUS=y
    # CONFIG_CS89x0 is not set
    # CONFIG_DM9000 is not set
    # CONFIG_DNET is not set
    CONFIG_NET_VENDOR_FARADAY=y
    # CONFIG_FTMAC100 is not set
    # CONFIG_FTGMAC100 is not set
    CONFIG_NET_VENDOR_INTEL=y
    CONFIG_NET_VENDOR_I825XX=y
    CONFIG_NET_VENDOR_MARVELL=y
    # CONFIG_MVMDIO is not set
    CONFIG_NET_VENDOR_MICREL=y
    # CONFIG_KS8842 is not set
    CONFIG_KS8851=y
    CONFIG_KS8851_MLL=y
    CONFIG_NET_VENDOR_MICROCHIP=y
    # CONFIG_ENC28J60 is not set
    CONFIG_NET_VENDOR_NATSEMI=y
    CONFIG_NET_VENDOR_8390=y
    # CONFIG_AX88796 is not set
    # CONFIG_ETHOC is not set
    # CONFIG_SH_ETH is not set
    CONFIG_NET_VENDOR_SEEQ=y
    CONFIG_NET_VENDOR_SMSC=y
    CONFIG_SMC91X=y
    # CONFIG_SMC911X is not set
    CONFIG_SMSC911X=y
    # CONFIG_SMSC911X_ARCH_HOOKS is not set
    CONFIG_NET_VENDOR_STMICRO=y
    # CONFIG_STMMAC_ETH is not set
    CONFIG_NET_VENDOR_TI=y
    # CONFIG_TI_DAVINCI_EMAC is not set
    CONFIG_TI_DAVINCI_MDIO=y
    CONFIG_TI_DAVINCI_CPDMA=y
    CONFIG_TI_CPSW_PHY_SEL=y
    CONFIG_TI_CPSW=y
    CONFIG_TI_CPTS=y
    CONFIG_NET_VENDOR_VIA=y
    # CONFIG_VIA_VELOCITY is not set
    CONFIG_NET_VENDOR_WIZNET=y
    # CONFIG_WIZNET_W5100 is not set
    # CONFIG_WIZNET_W5300 is not set
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    CONFIG_AT803X_PHY=y
    # CONFIG_AMD_PHY is not set
    # CONFIG_MARVELL_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_CICADA_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    CONFIG_SMSC_PHY=y
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    # CONFIG_MICREL_PHY is not set
    # CONFIG_FIXED_PHY is not set
    # CONFIG_MDIO_BITBANG is not set
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    # USB Network Adapters
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    # CONFIG_USB_PEGASUS is not set
    # CONFIG_USB_RTL8150 is not set
    # CONFIG_USB_RTL8152 is not set
    CONFIG_USB_USBNET=y
    CONFIG_USB_NET_AX8817X=y
    CONFIG_USB_NET_AX88179_178A=y
    CONFIG_USB_NET_CDCETHER=y
    # CONFIG_USB_NET_CDC_EEM is not set
    CONFIG_USB_NET_CDC_NCM=y
    # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
    # CONFIG_USB_NET_CDC_MBIM is not set
    # CONFIG_USB_NET_DM9601 is not set
    # CONFIG_USB_NET_SR9700 is not set
    # CONFIG_USB_NET_SMSC75XX is not set
    CONFIG_USB_NET_SMSC95XX=y
    # CONFIG_USB_NET_GL620A is not set
    CONFIG_USB_NET_NET1080=y
    # CONFIG_USB_NET_PLUSB is not set
    # CONFIG_USB_NET_MCS7830 is not set
    # CONFIG_USB_NET_RNDIS_HOST is not set
    CONFIG_USB_NET_CDC_SUBSET=y
    CONFIG_USB_ALI_M5632=y
    CONFIG_USB_AN2720=y
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    CONFIG_USB_EPSON2888=y
    CONFIG_USB_KC2190=y
    CONFIG_USB_NET_ZAURUS=y
    # CONFIG_USB_NET_CX82310_ETH is not set
    # CONFIG_USB_NET_KALMIA is not set
    # CONFIG_USB_NET_QMI_WWAN is not set
    # CONFIG_USB_NET_INT51X1 is not set
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_USB_VL600 is not set
    CONFIG_WLAN=y
    # CONFIG_USB_ZD1201 is not set
    CONFIG_HOSTAP=m
    # CONFIG_HOSTAP_FIRMWARE is not set
    # CONFIG_WL_TI is not set
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # CONFIG_WAN is not set
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    CONFIG_INPUT_POLLDEV=m
    # CONFIG_INPUT_SPARSEKMAP is not set
    CONFIG_INPUT_MATRIXKMAP=y
    # Userland interfaces
    CONFIG_INPUT_MOUSEDEV=y
    CONFIG_INPUT_MOUSEDEV_PSAUX=y
    CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
    CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
    CONFIG_INPUT_JOYDEV=y
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=y
    # CONFIG_KEYBOARD_QT1070 is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    CONFIG_KEYBOARD_MATRIX=y
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_SAMSUNG is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_OMAP4 is not set
    CONFIG_KEYBOARD_TWL4030=y
    # CONFIG_KEYBOARD_XTKBD is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_CYPRESS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    # CONFIG_MOUSE_PS2_ELANTECH is not set
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_CYAPA is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_MOUSE_SYNAPTICS_USB is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    CONFIG_TOUCHSCREEN_ADS7846=y
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    CONFIG_TOUCHSCREEN_ATMEL_MXT=y
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
    # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    # CONFIG_TOUCHSCREEN_ILI210X is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    # CONFIG_TOUCHSCREEN_MMS114 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    CONFIG_TOUCHSCREEN_TI_AM335X_TSC=y
    CONFIG_TOUCHSCREEN_PIXCIR=m
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    # CONFIG_TOUCHSCREEN_TSC2005 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    # CONFIG_TOUCHSCREEN_W90X900 is not set
    # CONFIG_TOUCHSCREEN_ST1232 is not set
    # CONFIG_TOUCHSCREEN_SUR40 is not set
    # CONFIG_TOUCHSCREEN_TPS6507X is not set
    # CONFIG_TOUCHSCREEN_ZFORCE is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_BMA150 is not set
    # CONFIG_INPUT_MMA8450 is not set
    # CONFIG_INPUT_MPU3050 is not set
    # CONFIG_INPUT_GP2A is not set
    # CONFIG_INPUT_GPIO_BEEPER is not set
    # CONFIG_INPUT_GPIO_TILT_POLLED is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_KXTJ9 is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    CONFIG_INPUT_TWL4030_PWRBUTTON=y
    # CONFIG_INPUT_TWL4030_VIBRA is not set
    # CONFIG_INPUT_TWL6040_VIBRA is not set
    CONFIG_INPUT_UINPUT=y
    # CONFIG_INPUT_PCF8574 is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    # CONFIG_INPUT_ADXL34X is not set
    # CONFIG_INPUT_IMS_PCU is not set
    # CONFIG_INPUT_CMA3000 is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_SERIO_OLPC_APSP is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_N_GSM is not set
    # CONFIG_TRACE_SINK is not set
    CONFIG_DEVKMEM=y
    # Serial drivers
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_DMA=y
    CONFIG_SERIAL_8250_NR_UARTS=32
    CONFIG_SERIAL_8250_RUNTIME_UARTS=4
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    CONFIG_SERIAL_8250_DETECT_IRQ=y
    CONFIG_SERIAL_8250_RSA=y
    # CONFIG_SERIAL_8250_DW is not set
    # CONFIG_SERIAL_8250_EM is not set
    # Non-8250 serial port support
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    # CONFIG_SERIAL_SH_SCI is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_OF_PLATFORM is not set
    CONFIG_SERIAL_OMAP=y
    CONFIG_SERIAL_OMAP_CONSOLE=y
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_TIMBERDALE is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_IFX6X60 is not set
    # CONFIG_SERIAL_XILINX_PS_UART is not set
    # CONFIG_SERIAL_ARC is not set
    # CONFIG_SERIAL_FSL_LPUART is not set
    # CONFIG_SERIAL_ST_ASC is not set
    # CONFIG_TTY_PRINTK is not set
    # CONFIG_HVC_DCC is not set
    # CONFIG_IPMI_HANDLER is not set
    CONFIG_HW_RANDOM=y
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    # CONFIG_HW_RANDOM_ATMEL is not set
    CONFIG_HW_RANDOM_OMAP=y
    CONFIG_HW_RANDOM_OMAP3_ROM=y
    # CONFIG_HW_RANDOM_EXYNOS is not set
    # CONFIG_R3964 is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    # CONFIG_I2C_MUX is not set
    CONFIG_I2C_HELPER_AUTO=y
    # I2C Hardware Bus support
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_PXA_PCI is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_ROBOTFUZZ_OSIF is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_STUB is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_OC_TINY is not set
    CONFIG_SPI_OMAP24XX=y
    CONFIG_SPI_TI_QSPI=y
    # CONFIG_SPI_PXA2XX_PCI is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_XCOMM is not set
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_DESIGNWARE is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_TLE62X0 is not set
    # CONFIG_HSI is not set
    # PPS support
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    # CONFIG_PPS_CLIENT_LDISC is not set
    # CONFIG_PPS_CLIENT_GPIO is not set
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    CONFIG_PINCTRL=y
    # Pin controllers
    CONFIG_PINMUX=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    # CONFIG_DEBUG_PINCTRL is not set
    # CONFIG_PINCTRL_CAPRI is not set
    # CONFIG_PINCTRL_MSM8X74 is not set
    CONFIG_PINCTRL_SINGLE=y
    # CONFIG_PINCTRL_PALMAS is not set
    CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIOLIB=y
    CONFIG_GPIO_DEVRES=y
    CONFIG_OF_GPIO=y
    CONFIG_DEBUG_GPIO=y
    CONFIG_GPIO_SYSFS=y
    # Memory mapped GPIO drivers:
    # CONFIG_GPIO_GENERIC_PLATFORM is not set
    # CONFIG_GPIO_EM is not set
    # CONFIG_GPIO_RCAR is not set
    # CONFIG_GPIO_SCH311X is not set
    # CONFIG_GPIO_TS5500 is not set
    # CONFIG_GPIO_GRGPIO is not set
    # I2C GPIO expanders:
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCA953X_IRQ is not set
    CONFIG_GPIO_PCF857X=y
    # CONFIG_GPIO_SX150X is not set
    CONFIG_GPIO_TWL4030=y
    # CONFIG_GPIO_TWL6040 is not set
    # CONFIG_GPIO_ADP5588 is not set
    # CONFIG_GPIO_ADNP is not set
    # PCI GPIO expanders:
    # SPI GPIO expanders:
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_74X164 is not set
    # AC97 GPIO expanders:
    # LPC GPIO expanders:
    # MODULbus GPIO expanders:
    # CONFIG_GPIO_PALMAS is not set
    # CONFIG_GPIO_TPS65910 is not set
    # CONFIG_GPIO_BCM_KONA is not set
    # USB GPIO expanders:
    CONFIG_W1=y
    CONFIG_W1_CON=y
    # 1-wire Bus Masters
    # CONFIG_W1_MASTER_DS2490 is not set
    # CONFIG_W1_MASTER_DS2482 is not set
    # CONFIG_W1_MASTER_DS1WM is not set
    # CONFIG_W1_MASTER_GPIO is not set
    # CONFIG_HDQ_MASTER_OMAP is not set
    # 1-wire Slaves
    # CONFIG_W1_SLAVE_THERM is not set
    # CONFIG_W1_SLAVE_SMEM is not set
    # CONFIG_W1_SLAVE_DS2408 is not set
    # CONFIG_W1_SLAVE_DS2413 is not set
    # CONFIG_W1_SLAVE_DS2423 is not set
    # CONFIG_W1_SLAVE_DS2431 is not set
    # CONFIG_W1_SLAVE_DS2433 is not set
    # CONFIG_W1_SLAVE_DS2760 is not set
    # CONFIG_W1_SLAVE_DS2780 is not set
    # CONFIG_W1_SLAVE_DS2781 is not set
    # CONFIG_W1_SLAVE_DS28E04 is not set
    # CONFIG_W1_SLAVE_BQ27000 is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_GENERIC_ADC_BATTERY is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_SBS is not set
    # CONFIG_BATTERY_BQ27x00 is not set
    # CONFIG_BATTERY_MAX17040 is not set
    # CONFIG_BATTERY_MAX17042 is not set
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_MAX8903 is not set
    # CONFIG_CHARGER_TWL4030 is not set
    # CONFIG_CHARGER_LP8727 is not set
    # CONFIG_CHARGER_GPIO is not set
    # CONFIG_CHARGER_MANAGER is not set
    # CONFIG_CHARGER_BQ2415X is not set
    # CONFIG_CHARGER_BQ24190 is not set
    # CONFIG_CHARGER_BQ24735 is not set
    # CONFIG_CHARGER_SMB347 is not set
    # CONFIG_POWER_RESET is not set
    # CONFIG_POWER_RESET_RESTART is not set
    # CONFIG_POWER_AVS is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_VID is not set
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_GPIO_FAN is not set
    # CONFIG_SENSORS_HIH6130 is not set
    # CONFIG_SENSORS_HTU21 is not set
    # CONFIG_SENSORS_IIO_HWMON is not set
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    CONFIG_SENSORS_LM75=m
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    # CONFIG_SENSORS_LM90 is not set
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    # CONFIG_SENSORS_LM95245 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6642 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_NCT6775 is not set
    # CONFIG_SENSORS_NTC_THERMISTOR is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH56XX_COMMON is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_ADS1015 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    # CONFIG_SENSORS_INA2XX is not set
    # CONFIG_SENSORS_THMC50 is not set
    # CONFIG_SENSORS_TMP102 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_THERMAL=y
    CONFIG_THERMAL_HWMON=y
    CONFIG_THERMAL_OF=y
    CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
    # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
    CONFIG_THERMAL_GOV_FAIR_SHARE=y
    CONFIG_THERMAL_GOV_STEP_WISE=y
    CONFIG_THERMAL_GOV_USER_SPACE=y
    CONFIG_CPU_THERMAL=y
    # CONFIG_THERMAL_EMULATION is not set
    # CONFIG_IMX_THERMAL is not set
    # Texas Instruments thermal drivers
    CONFIG_TI_SOC_THERMAL=y
    CONFIG_TI_THERMAL=y
    CONFIG_OMAP4_THERMAL=y
    CONFIG_OMAP5_THERMAL=y
    CONFIG_DRA752_THERMAL=y
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_GPIO_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_OMAP_WATCHDOG=y
    CONFIG_TWL4030_WATCHDOG=y
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_MEN_A21_WDT is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    # Broadcom specific AMBA
    # CONFIG_BCMA is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_MFD_AS3722 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_CROS_EC is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX14577 is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_RC5T583 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SMSC is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_MFD_STMPE is not set
    CONFIG_MFD_SYSCON=y
    CONFIG_MFD_TI_AM335X_TSCADC=y
    # CONFIG_MFD_LP3943 is not set
    # CONFIG_MFD_LP8788 is not set
    CONFIG_MFD_OMAP_USB_HOST=y
    CONFIG_MFD_PALMAS=y
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65090 is not set
    CONFIG_MFD_TPS65217=y
    # CONFIG_MFD_TPS6586X is not set
    CONFIG_MFD_TPS65910=y
    # CONFIG_MFD_TPS65912 is not set
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_MFD_TPS80031 is not set
    CONFIG_TWL4030_CORE=y
    # CONFIG_TWL4030_MADC is not set
    CONFIG_TWL4030_POWER=y
    CONFIG_MFD_TWL4030_AUDIO=y
    CONFIG_TWL6040_CORE=y
    CONFIG_MENELAUS=y
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    # CONFIG_VEXPRESS_CONFIG is not set
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    CONFIG_REGULATOR_FIXED_VOLTAGE=y
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_ACT8865 is not set
    # CONFIG_REGULATOR_AD5398 is not set
    # CONFIG_REGULATOR_ANATOP is not set
    # CONFIG_REGULATOR_DA9210 is not set
    # CONFIG_REGULATOR_FAN53555 is not set
    # CONFIG_REGULATOR_GPIO is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_LP872X is not set
    # CONFIG_REGULATOR_LP8755 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    # CONFIG_REGULATOR_MAX8973 is not set
    CONFIG_REGULATOR_PALMAS=y
    CONFIG_REGULATOR_PBIAS=y
    # CONFIG_REGULATOR_PFUZE100 is not set
    # CONFIG_REGULATOR_TI_ABB is not set
    # CONFIG_REGULATOR_TPS51632 is not set
    # CONFIG_REGULATOR_TPS62360 is not set
    CONFIG_REGULATOR_TPS65023=y
    CONFIG_REGULATOR_TPS6507X=y
    CONFIG_REGULATOR_TPS65217=y
    # CONFIG_REGULATOR_TPS6524X is not set
    CONFIG_REGULATOR_TPS65910=y
    CONFIG_REGULATOR_TWL4030=y
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    CONFIG_MEDIA_CAMERA_SUPPORT=y
    # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
    # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
    # CONFIG_MEDIA_RADIO_SUPPORT is not set
    # CONFIG_MEDIA_RC_SUPPORT is not set
    CONFIG_MEDIA_CONTROLLER=y
    CONFIG_VIDEO_DEV=y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    CONFIG_VIDEO_V4L2=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_VIDEOBUF2_CORE=m
    CONFIG_VIDEOBUF2_MEMOPS=m
    CONFIG_VIDEOBUF2_VMALLOC=m
    # CONFIG_TTPCI_EEPROM is not set
    # Media drivers
    CONFIG_MEDIA_USB_SUPPORT=y
    # Webcam devices
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    CONFIG_USB_GSPCA=m
    # CONFIG_USB_M5602 is not set
    # CONFIG_USB_STV06XX is not set
    # CONFIG_USB_GL860 is not set
    # CONFIG_USB_GSPCA_BENQ is not set
    # CONFIG_USB_GSPCA_CONEX is not set
    # CONFIG_USB_GSPCA_CPIA1 is not set
    # CONFIG_USB_GSPCA_ETOMS is not set
    # CONFIG_USB_GSPCA_FINEPIX is not set
    # CONFIG_USB_GSPCA_JEILINJ is not set
    # CONFIG_USB_GSPCA_JL2005BCD is not set
    # CONFIG_USB_GSPCA_KINECT is not set
    # CONFIG_USB_GSPCA_KONICA is not set
    # CONFIG_USB_GSPCA_MARS is not set
    # CONFIG_USB_GSPCA_MR97310A is not set
    # CONFIG_USB_GSPCA_NW80X is not set
    # CONFIG_USB_GSPCA_OV519 is not set
    # CONFIG_USB_GSPCA_OV534 is not set
    # CONFIG_USB_GSPCA_OV534_9 is not set
    # CONFIG_USB_GSPCA_PAC207 is not set
    # CONFIG_USB_GSPCA_PAC7302 is not set
    # CONFIG_USB_GSPCA_PAC7311 is not set
    # CONFIG_USB_GSPCA_SE401 is not set
    # CONFIG_USB_GSPCA_SN9C2028 is not set
    # CONFIG_USB_GSPCA_SN9C20X is not set
    # CONFIG_USB_GSPCA_SONIXB is not set
    # CONFIG_USB_GSPCA_SONIXJ is not set
    # CONFIG_USB_GSPCA_SPCA500 is not set
    # CONFIG_USB_GSPCA_SPCA501 is not set
    # CONFIG_USB_GSPCA_SPCA505 is not set
    # CONFIG_USB_GSPCA_SPCA506 is not set
    # CONFIG_USB_GSPCA_SPCA508 is not set
    # CONFIG_USB_GSPCA_SPCA561 is not set
    # CONFIG_USB_GSPCA_SPCA1528 is not set
    # CONFIG_USB_GSPCA_SQ905 is not set
    # CONFIG_USB_GSPCA_SQ905C is not set
    # CONFIG_USB_GSPCA_SQ930X is not set
    # CONFIG_USB_GSPCA_STK014 is not set
    # CONFIG_USB_GSPCA_STK1135 is not set
    # CONFIG_USB_GSPCA_STV0680 is not set
    # CONFIG_USB_GSPCA_SUNPLUS is not set
    # CONFIG_USB_GSPCA_T613 is not set
    # CONFIG_USB_GSPCA_TOPRO is not set
    # CONFIG_USB_GSPCA_TV8532 is not set
    # CONFIG_USB_GSPCA_VC032X is not set
    # CONFIG_USB_GSPCA_VICAM is not set
    # CONFIG_USB_GSPCA_XIRLINK_CIT is not set
    # CONFIG_USB_GSPCA_ZC3XX is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_USB_ZR364XX is not set
    # CONFIG_USB_STKWEBCAM is not set
    # CONFIG_USB_S2255 is not set
    # CONFIG_VIDEO_USBTV is not set
    # Webcam, TV (analog/digital) USB devices
    # CONFIG_VIDEO_EM28XX is not set
    CONFIG_V4L_PLATFORM_DRIVERS=y
    # CONFIG_VIDEO_DM6446_CCDC is not set
    # CONFIG_VIDEO_OMAP2_VOUT is not set
    # CONFIG_VIDEO_TIMBERDALE is not set
    # CONFIG_SOC_CAMERA is not set
    # CONFIG_V4L_MEM2MEM_DRIVERS is not set
    # CONFIG_V4L_TEST_DRIVERS is not set
    # Supported MMC/SDIO adapters
    # CONFIG_CYPRESS_FIRMWARE is not set
    # Media ancillary drivers (tuners, sensors, i2c, frontends)
    # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
    # Encoders, decoders, sensors and other helper chips
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_UDA1342 is not set
    # CONFIG_VIDEO_WM8775 is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # CONFIG_VIDEO_SONY_BTF_MPX is not set
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # Video decoders
    # CONFIG_VIDEO_ADV7180 is not set
    # CONFIG_VIDEO_ADV7183 is not set
    # CONFIG_VIDEO_ADV7604 is not set
    # CONFIG_VIDEO_ADV7842 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_ML86V7667 is not set
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_SAA7191 is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_TW2804 is not set
    # CONFIG_VIDEO_TW9903 is not set
    # CONFIG_VIDEO_TW9906 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # Video encoders
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_ADV7393 is not set
    # CONFIG_VIDEO_ADV7511 is not set
    # CONFIG_VIDEO_AD9389B is not set
    # CONFIG_VIDEO_AK881X is not set
    # CONFIG_VIDEO_THS8200 is not set
    # Camera sensor devices
    # CONFIG_VIDEO_OV7640 is not set
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_OV9650 is not set
    # CONFIG_VIDEO_VS6624 is not set
    # CONFIG_VIDEO_MT9M032 is not set
    # CONFIG_VIDEO_MT9P031 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_MT9V032 is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_VIDEO_NOON010PC30 is not set
    # CONFIG_VIDEO_M5MOLS is not set
    # CONFIG_VIDEO_S5K6AA is not set
    # CONFIG_VIDEO_S5K4ECGX is not set
    # CONFIG_VIDEO_S5K5BAF is not set
    # CONFIG_VIDEO_SMIAPP is not set
    # CONFIG_VIDEO_S5C73M3 is not set
    # Flash devices
    # CONFIG_VIDEO_ADP1653 is not set
    # CONFIG_VIDEO_AS3645A is not set
    # CONFIG_VIDEO_LM3560 is not set
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # Audio/Video compression chips
    # CONFIG_VIDEO_SAA6752HS is not set
    # Miscellaneous helper chips
    # CONFIG_VIDEO_THS7303 is not set
    # CONFIG_VIDEO_M52790 is not set
    # Sensors used on soc_camera driver
    # Customise DVB Frontends
    CONFIG_DVB_AU8522=m
    CONFIG_DVB_AU8522_V4L=m
    CONFIG_DVB_TUNER_DIB0070=m
    CONFIG_DVB_TUNER_DIB0090=m
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # Graphics support
    # CONFIG_DRM is not set
    # CONFIG_VGASTATE is not set
    # CONFIG_VIDEO_OUTPUT_CONTROL is not set
    CONFIG_VIDEOMODE_HELPERS=y
    CONFIG_FB=y
    CONFIG_FIRMWARE_EDID=y
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    CONFIG_FB_CFB_REV_PIXELS_IN_BYTE=y
    # CONFIG_FB_SYS_FILLRECT is not set
    # CONFIG_FB_SYS_COPYAREA is not set
    # CONFIG_FB_SYS_IMAGEBLIT is not set
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    # CONFIG_FB_SYS_FOPS is not set
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    CONFIG_FB_MODE_HELPERS=y
    CONFIG_FB_TILEBLITTING=y
    # Frame buffer hardware drivers
    # CONFIG_FB_UVESA is not set
    # CONFIG_FB_OPENCORES is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_TMIO is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_GOLDFISH is not set
    CONFIG_FB_DA8XX=y
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_FB_AUO_K190X is not set
    # CONFIG_FB_SIMPLE is not set
    CONFIG_OMAP2_VRFB=y
    CONFIG_OMAP2_DSS=y
    # CONFIG_OMAP2_DSS_DEBUG is not set
    # CONFIG_OMAP2_DSS_DEBUGFS is not set
    CONFIG_OMAP2_DSS_DPI=y
    CONFIG_OMAP2_DSS_VENC=y
    CONFIG_OMAP4_DSS_HDMI=y
    CONFIG_OMAP2_DSS_SDI=y
    CONFIG_OMAP2_DSS_DSI=y
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
    CONFIG_FB_OMAP2=y
    CONFIG_FB_OMAP2_DEBUG_SUPPORT=y
    CONFIG_FB_OMAP2_NUM_FBS=3
    # OMAP Display Device Drivers (new device model)
    CONFIG_DISPLAY_ENCODER_TFP410=y
    CONFIG_DISPLAY_ENCODER_TPD12S015=y
    CONFIG_DISPLAY_CONNECTOR_DVI=y
    CONFIG_DISPLAY_CONNECTOR_HDMI=y
    # CONFIG_DISPLAY_CONNECTOR_ANALOG_TV is not set
    CONFIG_DISPLAY_PANEL_DPI=y
    # CONFIG_DISPLAY_PANEL_DSI_CM is not set
    # CONFIG_DISPLAY_PANEL_SONY_ACX565AKM is not set
    # CONFIG_DISPLAY_PANEL_LGPHILIPS_LB035Q02 is not set
    # CONFIG_DISPLAY_PANEL_SHARP_LS037V7DW01 is not set
    # CONFIG_DISPLAY_PANEL_TPO_TD028TTEC1 is not set
    # CONFIG_DISPLAY_PANEL_TPO_TD043MTEA1 is not set
    # CONFIG_DISPLAY_PANEL_NEC_NL8048HL11 is not set
    # CONFIG_EXYNOS_VIDEO is not set
    CONFIG_BACKLIGHT_LCD_SUPPORT=y
    CONFIG_LCD_CLASS_DEVICE=y
    # CONFIG_LCD_L4F00242T03 is not set
    # CONFIG_LCD_LMS283GF05 is not set
    # CONFIG_LCD_LTV350QV is not set
    # CONFIG_LCD_ILI922X is not set
    # CONFIG_LCD_ILI9320 is not set
    # CONFIG_LCD_TDO24M is not set
    # CONFIG_LCD_VGG2432A4 is not set
    CONFIG_LCD_PLATFORM=y
    # CONFIG_LCD_S6E63M0 is not set
    # CONFIG_LCD_LD9040 is not set
    # CONFIG_LCD_AMS369FG06 is not set
    # CONFIG_LCD_LMS501KF03 is not set
    # CONFIG_LCD_HX8357 is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    CONFIG_BACKLIGHT_GENERIC=y
    CONFIG_BACKLIGHT_PWM=y
    # CONFIG_BACKLIGHT_ADP8860 is not set
    # CONFIG_BACKLIGHT_ADP8870 is not set
    # CONFIG_BACKLIGHT_LM3630A is not set
    # CONFIG_BACKLIGHT_LM3639 is not set
    # CONFIG_BACKLIGHT_LP855X is not set
    # CONFIG_BACKLIGHT_PANDORA is not set
    # CONFIG_BACKLIGHT_TPS65217 is not set
    # CONFIG_BACKLIGHT_GPIO is not set
    # CONFIG_BACKLIGHT_LV5207LP is not set
    # CONFIG_BACKLIGHT_BD6107 is not set
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
    CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
    CONFIG_LOGO=y
    CONFIG_LOGO_LINUX_MONO=y
    CONFIG_LOGO_LINUX_VGA16=y
    CONFIG_LOGO_LINUX_CLUT224=y
    # CONFIG_FB_SSD1307 is not set
    CONFIG_SOUND=m
    CONFIG_SOUND_OSS_CORE=y
    CONFIG_SOUND_OSS_CORE_PRECLAIM=y
    CONFIG_SND=m
    CONFIG_SND_TIMER=m
    CONFIG_SND_PCM=m
    CONFIG_SND_DMAENGINE_PCM=m
    CONFIG_SND_HWDEP=m
    CONFIG_SND_RAWMIDI=m
    CONFIG_SND_COMPRESS_OFFLOAD=m
    CONFIG_SND_JACK=y
    # CONFIG_SND_SEQUENCER is not set
    CONFIG_SND_OSSEMUL=y
    CONFIG_SND_MIXER_OSS=m
    CONFIG_SND_PCM_OSS=m
    CONFIG_SND_PCM_OSS_PLUGINS=y
    # CONFIG_SND_HRTIMER is not set
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    CONFIG_SND_VERBOSE_PRINTK=y
    CONFIG_SND_DEBUG=y
    # CONFIG_SND_DEBUG_VERBOSE is not set
    # CONFIG_SND_PCM_XRUN_DEBUG is not set
    # CONFIG_SND_RAWMIDI_SEQ is not set
    # CONFIG_SND_OPL3_LIB_SEQ is not set
    # CONFIG_SND_OPL4_LIB_SEQ is not set
    # CONFIG_SND_SBAWE_SEQ is not set
    # CONFIG_SND_EMU10K1_SEQ is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    CONFIG_SND_ARM=y
    CONFIG_SND_SPI=y
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=m
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_6FIRE is not set
    # CONFIG_SND_USB_HIFACE is not set
    CONFIG_SND_SOC=m
    # CONFIG_SND_ATMEL_SOC is not set
    CONFIG_SND_DAVINCI_SOC=m
    CONFIG_SND_DAVINCI_SOC_MCASP=m
    CONFIG_SND_DAVINCI_SOC_GENERIC_EVM=m
    CONFIG_SND_AM33XX_SOC_EVM=m
    # CONFIG_SND_DESIGNWARE_I2S is not set
    CONFIG_SND_OMAP_SOC=m
    CONFIG_SND_OMAP_SOC_DMIC=m
    CONFIG_SND_OMAP_SOC_MCBSP=m
    CONFIG_SND_OMAP_SOC_MCPDM=m
    # CONFIG_SND_OMAP_SOC_N810 is not set
    # CONFIG_SND_OMAP_SOC_RX51 is not set
    # CONFIG_SND_OMAP_SOC_AM3517EVM is not set
    CONFIG_SND_OMAP_SOC_OMAP_TWL4030=m
    CONFIG_SND_OMAP_SOC_OMAP_ABE_TWL6040=m
    # CONFIG_SND_OMAP_SOC_OMAP_HDMI is not set
    CONFIG_SND_OMAP_SOC_OMAP3_PANDORA=m
    CONFIG_SND_SOC_I2C_AND_SPI=m
    CONFIG_SND_SOC_DMIC=m
    CONFIG_SND_SOC_TLV320AIC3X=m
    CONFIG_SND_SOC_TWL4030=m
    CONFIG_SND_SOC_TWL6040=m
    # CONFIG_SND_SIMPLE_CARD is not set
    # CONFIG_SOUND_PRIME is not set
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    # CONFIG_UHID is not set
    CONFIG_HID_GENERIC=y
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_HUION is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LENOVO_TPKBD is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_MULTITOUCH is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THINGM is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_WIIMOTE is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # USB HID support
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # I2C HID support
    # CONFIG_I2C_HID is not set
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_ARCH_HAS_EHCI=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    # CONFIG_USB_OTG is not set
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    CONFIG_USB_MON=y
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_XHCI_HCD=y
    CONFIG_USB_XHCI_PLATFORM=m
    CONFIG_USB_EHCI_HCD=y
    # CONFIG_USB_EHCI_ROOT_HUB_TT is not set
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    CONFIG_USB_EHCI_HCD_OMAP=y
    # CONFIG_USB_EHCI_HCD_PLATFORM is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1760_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_FUSBH200_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    # CONFIG_USB_RENESAS_USBHS is not set
    # USB Device Class drivers
    # CONFIG_USB_ACM is not set
    # CONFIG_USB_PRINTER is not set
    CONFIG_USB_WDM=y
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    CONFIG_USB_MUSB_HDRC=m
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    CONFIG_USB_MUSB_DUAL_ROLE=y
    # CONFIG_USB_MUSB_TUSB6010 is not set
    CONFIG_USB_MUSB_OMAP2PLUS=m
    # CONFIG_USB_MUSB_AM35X is not set
    CONFIG_USB_MUSB_DSPS=m
    # CONFIG_USB_MUSB_UX500 is not set
    CONFIG_USB_MUSB_AM335X_CHILD=m
    # CONFIG_USB_INVENTRA_DMA is not set
    CONFIG_USB_TI_CPPI41_DMA=y
    # CONFIG_MUSB_PIO_ONLY is not set
    CONFIG_USB_DWC3=m
    # CONFIG_USB_DWC3_HOST is not set
    # CONFIG_USB_DWC3_GADGET is not set
    CONFIG_USB_DWC3_DUAL_ROLE=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=m
    # CONFIG_USB_DWC3_EXYNOS is not set
    CONFIG_USB_DWC3_KEYSTONE=m
    # Debugging features
    # CONFIG_USB_DWC3_DEBUG is not set
    # CONFIG_USB_DWC2 is not set
    # CONFIG_USB_CHIPIDEA is not set
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_LED is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    CONFIG_USB_TEST=m
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    # CONFIG_USB_HSIC_USB3503 is not set
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    # CONFIG_USB_OTG_FSM is not set
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_OMAP_CONTROL_USB=y
    # CONFIG_OMAP_USB3 is not set
    CONFIG_AM335X_CONTROL_USB=y
    CONFIG_AM335X_PHY_USB=y
    # CONFIG_SAMSUNG_USB2PHY is not set
    # CONFIG_SAMSUNG_USB3PHY is not set
    CONFIG_TWL6030_USB=m
    # CONFIG_USB_GPIO_VBUS is not set
    # CONFIG_USB_ISP1301 is not set
    # CONFIG_USB_RCAR_PHY is not set
    # CONFIG_USB_ULPI is not set
    CONFIG_USB_GADGET=y
    CONFIG_USB_GADGET_DEBUG=y
    # CONFIG_USB_GADGET_VERBOSE is not set
    CONFIG_USB_GADGET_DEBUG_FILES=y
    CONFIG_USB_GADGET_DEBUG_FS=y
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
    # USB Peripheral Controller
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_GR_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_S3C_HSOTG is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    # CONFIG_USB_M66592 is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_DUMMY_HCD is not set
    CONFIG_USB_LIBCOMPOSITE=m
    CONFIG_USB_F_ACM=m
    CONFIG_USB_F_SS_LB=m
    CONFIG_USB_U_SERIAL=m
    CONFIG_USB_U_ETHER=m
    CONFIG_USB_F_SERIAL=m
    CONFIG_USB_F_OBEX=m
    CONFIG_USB_F_NCM=m
    CONFIG_USB_F_ECM=m
    CONFIG_USB_F_SUBSET=m
    CONFIG_USB_F_RNDIS=m
    CONFIG_USB_F_MASS_STORAGE=m
    CONFIG_USB_F_FS=m
    # CONFIG_USB_CONFIGFS is not set
    CONFIG_USB_ZERO=m
    CONFIG_USB_AUDIO=m
    # CONFIG_GADGET_UAC1 is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    CONFIG_USB_G_NCM=m
    CONFIG_USB_GADGETFS=m
    CONFIG_USB_FUNCTIONFS=m
    CONFIG_USB_FUNCTIONFS_ETH=y
    CONFIG_USB_FUNCTIONFS_RNDIS=y
    CONFIG_USB_FUNCTIONFS_GENERIC=y
    CONFIG_USB_MASS_STORAGE=m
    CONFIG_USB_G_SERIAL=m
    CONFIG_USB_MIDI_GADGET=m
    CONFIG_USB_G_PRINTER=m
    CONFIG_USB_CDC_COMPOSITE=m
    CONFIG_USB_G_ACM_MS=m
    CONFIG_USB_G_MULTI=m
    CONFIG_USB_G_MULTI_RNDIS=y
    CONFIG_USB_G_MULTI_CDC=y
    CONFIG_USB_G_HID=m
    CONFIG_USB_G_DBGP=m
    # CONFIG_USB_G_DBGP_PRINTK is not set
    CONFIG_USB_G_DBGP_SERIAL=y
    CONFIG_USB_G_WEBCAM=m
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    # CONFIG_MMC_CLKGATE is not set
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=8
    CONFIG_MMC_BLOCK_BOUNCE=y
    CONFIG_SDIO_UART=y
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_MMC_SDHCI_PXAV3 is not set
    # CONFIG_MMC_SDHCI_PXAV2 is not set
    CONFIG_MMC_OMAP=y
    CONFIG_MMC_OMAP_HS=y
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # LED drivers
    # CONFIG_LEDS_LM3530 is not set
    # CONFIG_LEDS_LM3642 is not set
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=y
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP5521 is not set
    # CONFIG_LEDS_LP5523 is not set
    # CONFIG_LEDS_LP5562 is not set
    # CONFIG_LEDS_LP8501 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_PCA963X is not set
    # CONFIG_LEDS_PCA9685 is not set
    # CONFIG_LEDS_DAC124S085 is not set
    # CONFIG_LEDS_PWM is not set
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    # CONFIG_LEDS_TCA6507 is not set
    # CONFIG_LEDS_LM355x is not set
    # CONFIG_LEDS_OT200 is not set
    # CONFIG_LEDS_BLINKM is not set
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=y
    CONFIG_LEDS_TRIGGER_ONESHOT=y
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    CONFIG_LEDS_TRIGGER_BACKLIGHT=y
    CONFIG_LEDS_TRIGGER_CPU=y
    CONFIG_LEDS_TRIGGER_GPIO=y
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
    # iptables trigger is under Netfilter config (LED target)
    # CONFIG_LEDS_TRIGGER_TRANSIENT is not set
    # CONFIG_LEDS_TRIGGER_CAMERA is not set
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_EDAC is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_DS1307 is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_HYM8563 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_ISL12057 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    CONFIG_RTC_DRV_PALMAS=y
    # CONFIG_RTC_DRV_PCF2127 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    CONFIG_RTC_DRV_TWL92330=y
    CONFIG_RTC_DRV_TWL4030=y
    # CONFIG_RTC_DRV_TPS65910 is not set
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    # on-CPU RTC drivers
    CONFIG_RTC_DRV_OMAP=y
    # CONFIG_RTC_DRV_SNVS is not set
    # CONFIG_RTC_DRV_MOXART is not set
    # HID Sensor RTC drivers
    # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    # CONFIG_DW_DMAC_CORE is not set
    # CONFIG_DW_DMAC is not set
    # CONFIG_TIMB_DMA is not set
    CONFIG_TI_EDMA=y
    CONFIG_DMA_OMAP=y
    CONFIG_TI_CPPI41=y
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_VIRTUAL_CHANNELS=y
    CONFIG_DMA_OF=y
    # DMA Clients
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_UIO is not set
    # CONFIG_VIRT_DRIVERS is not set
    # Virtio drivers
    # CONFIG_VIRTIO_MMIO is not set
    # Microsoft Hyper-V guest support
    # CONFIG_STAGING is not set
    CONFIG_CLKDEV_LOOKUP=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # Common Clock Framework
    # CONFIG_COMMON_CLK_SI5351 is not set
    # CONFIG_COMMON_CLK_SI570 is not set
    # CONFIG_CLK_TWL6040 is not set
    # CONFIG_COMMON_CLK_QCOM is not set
    # Hardware Spinlock drivers
    # CONFIG_HWSPINLOCK_OMAP is not set
    CONFIG_CLKSRC_OF=y
    CONFIG_CLKSRC_MMIO=y
    CONFIG_ARM_ARCH_TIMER=y
    CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
    CONFIG_MAILBOX=y
    CONFIG_OMAP_MBOX=y
    CONFIG_OMAP2PLUS_MBOX=y
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    CONFIG_IOMMU_SUPPORT=y
    CONFIG_OF_IOMMU=y
    # CONFIG_OMAP_IOMMU is not set
    # Remoteproc drivers
    # CONFIG_STE_MODEM_RPROC is not set
    # Rpmsg drivers
    # CONFIG_PM_DEVFREQ is not set
    CONFIG_EXTCON=y
    # Extcon Device Drivers
    CONFIG_OF_EXTCON=y
    # CONFIG_EXTCON_GPIO is not set
    # CONFIG_EXTCON_ADC_JACK is not set
    CONFIG_EXTCON_PALMAS=y
    # CONFIG_MEMORY is not set
    CONFIG_IIO=m
    CONFIG_IIO_BUFFER=y
    CONFIG_IIO_BUFFER_CB=y
    CONFIG_IIO_KFIFO_BUF=m
    CONFIG_IIO_TRIGGER=y
    CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
    # Accelerometers
    # CONFIG_BMA180 is not set
    # CONFIG_IIO_ST_ACCEL_3AXIS is not set
    # CONFIG_KXSD9 is not set
    # Analog to digital converters
    # CONFIG_AD7266 is not set
    # CONFIG_AD7298 is not set
    # CONFIG_AD7476 is not set
    # CONFIG_AD7791 is not set
    # CONFIG_AD7793 is not set
    # CONFIG_AD7887 is not set
    # CONFIG_AD7923 is not set
    # CONFIG_EXYNOS_ADC is not set
    # CONFIG_MAX1363 is not set
    # CONFIG_MCP320X is not set
    # CONFIG_MCP3422 is not set
    # CONFIG_NAU7802 is not set
    # CONFIG_TI_ADC081C is not set
    CONFIG_TI_AM335X_ADC=m
    # CONFIG_TWL6030_GPADC is not set
    # Amplifiers
    # CONFIG_AD8366 is not set
    # Hid Sensor IIO Common
    # Digital to analog converters
    # CONFIG_AD5064 is not set
    # CONFIG_AD5360 is not set
    # CONFIG_AD5380 is not set
    # CONFIG_AD5421 is not set
    # CONFIG_AD5446 is not set
    # CONFIG_AD5449 is not set
    # CONFIG_AD5504 is not set
    # CONFIG_AD5624R_SPI is not set
    # CONFIG_AD5686 is not set
    # CONFIG_AD5755 is not set
    # CONFIG_AD5764 is not set
    # CONFIG_AD5791 is not set
    # CONFIG_AD7303 is not set
    # CONFIG_MAX517 is not set
    # CONFIG_MCP4725 is not set
    # Frequency Synthesizers DDS/PLL
    # Clock Generator/Distribution
    # CONFIG_AD9523 is not set
    # Phase-Locked Loop (PLL) frequency synthesizers
    # CONFIG_ADF4350 is not set
    # Digital gyroscope sensors
    # CONFIG_ADIS16080 is not set
    # CONFIG_ADIS16130 is not set
    # CONFIG_ADIS16136 is not set
    # CONFIG_ADIS16260 is not set
    # CONFIG_ADXRS450 is not set
    # CONFIG_IIO_ST_GYRO_3AXIS is not set
    # CONFIG_ITG3200 is not set
    # Humidity sensors
    # CONFIG_DHT11 is not set
    # Inertial measurement units
    # CONFIG_ADIS16400 is not set
    # CONFIG_ADIS16480 is not set
    # CONFIG_INV_MPU6050_IIO is not set
    # Light sensors
    # CONFIG_ADJD_S311 is not set
    # CONFIG_APDS9300 is not set
    # CONFIG_CM32181 is not set
    # CONFIG_CM36651 is not set
    # CONFIG_GP2AP020A00F is not set
    # CONFIG_TCS3472 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_TSL4531 is not set
    # CONFIG_VCNL4000 is not set
    # Magnetometer sensors
    # CONFIG_AK8975 is not set
    # CONFIG_MAG3110 is not set
    # CONFIG_IIO_ST_MAGN_3AXIS is not set
    # Inclinometer sensors
    # Triggers - standalone
    # CONFIG_IIO_INTERRUPT_TRIGGER is not set
    # CONFIG_IIO_SYSFS_TRIGGER is not set
    # Pressure sensors
    # CONFIG_MPL3115 is not set
    # CONFIG_IIO_ST_PRESS is not set
    # Temperature sensors
    # CONFIG_TMP006 is not set
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    # CONFIG_PWM_PCA9685 is not set
    CONFIG_PWM_TIECAP=y
    CONFIG_PWM_TIEHRPWM=y
    CONFIG_PWM_TIPWMSS=y
    # CONFIG_PWM_TWL is not set
    # CONFIG_PWM_TWL_LED is not set
    CONFIG_IRQCHIP=y
    CONFIG_ARM_GIC=y
    # CONFIG_IPACK_BUS is not set
    CONFIG_RESET_CONTROLLER=y
    # CONFIG_FMC is not set
    # PHY Subsystem
    CONFIG_GENERIC_PHY=y
    # CONFIG_PHY_EXYNOS_MIPI_VIDEO is not set
    CONFIG_OMAP_USB2=y
    CONFIG_TWL4030_USB=m
    # CONFIG_PHY_EXYNOS_DP_VIDEO is not set
    # CONFIG_BCM_KONA_USB2_PHY is not set
    # CONFIG_POWERCAP is not set
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    # CONFIG_EXT2_FS_XIP is not set
    CONFIG_EXT3_FS=y
    CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
    # CONFIG_EXT3_FS_XATTR is not set
    CONFIG_EXT4_FS=y
    # CONFIG_EXT4_FS_POSIX_ACL is not set
    # CONFIG_EXT4_FS_SECURITY is not set
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY is not set
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    # CONFIG_QUOTA_DEBUG is not set
    CONFIG_QUOTA_TREE=y
    # CONFIG_QFMT_V1 is not set
    CONFIG_QFMT_V2=y
    CONFIG_QUOTACTL=y
    # CONFIG_AUTOFS4_FS is not set
    # CONFIG_FUSE_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_NTFS_FS is not set
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    # CONFIG_TMPFS_POSIX_ACL is not set
    # CONFIG_TMPFS_XATTR is not set
    # CONFIG_HUGETLB_PAGE is not set
    CONFIG_CONFIGFS_FS=m
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_ECRYPT_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    CONFIG_JFFS2_FS_XATTR=y
    CONFIG_JFFS2_FS_POSIX_ACL=y
    CONFIG_JFFS2_FS_SECURITY=y
    CONFIG_JFFS2_COMPRESSION_OPTIONS=y
    CONFIG_JFFS2_ZLIB=y
    CONFIG_JFFS2_LZO=y
    CONFIG_JFFS2_RTIME=y
    CONFIG_JFFS2_RUBIN=y
    # CONFIG_JFFS2_CMODE_NONE is not set
    CONFIG_JFFS2_CMODE_PRIORITY=y
    # CONFIG_JFFS2_CMODE_SIZE is not set
    # CONFIG_JFFS2_CMODE_FAVOURLZO is not set
    CONFIG_UBIFS_FS=y
    # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    # CONFIG_LOGFS is not set
    CONFIG_CRAMFS=y
    # CONFIG_SQUASHFS is not set
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    # CONFIG_PSTORE is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    CONFIG_NFS_V3_ACL=y
    CONFIG_NFS_V4=y
    # CONFIG_NFS_SWAP is not set
    # CONFIG_NFS_V4_1 is not set
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    # CONFIG_NFSD is not set
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_SUPPORT=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_NCP_FS is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    # CONFIG_NLS_ASCII is not set
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    # CONFIG_NLS_UTF8 is not set
    # CONFIG_DLM is not set
    # Kernel hacking
    # printk and dmesg options
    CONFIG_PRINTK_TIME=y
    CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # Compile-time checks and compiler options
    CONFIG_DEBUG_INFO=y
    # CONFIG_DEBUG_INFO_REDUCED is not set
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_FRAME_POINTER=y
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    CONFIG_MAGIC_SYSRQ=y
    CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
    CONFIG_DEBUG_KERNEL=y
    # Memory Debugging
    # CONFIG_DEBUG_PAGEALLOC is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_DEBUG_SLAB is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_HIGHMEM is not set
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Lockups and Hangs
    # CONFIG_LOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    CONFIG_PANIC_TIMEOUT=0
    # CONFIG_SCHED_DEBUG is not set
    # CONFIG_SCHEDSTATS is not set
    # CONFIG_TIMER_STATS is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_SPARSE_RCU_POINTER is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_TRACE is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    # CONFIG_LATENCYTOP is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACE_CLOCK=y
    CONFIG_RING_BUFFER=y
    CONFIG_RING_BUFFER_ALLOW_SWAP=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    # Runtime Testing
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_KPROBES_SANITY_TEST is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_PERCPU_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_TEST_MODULE is not set
    # CONFIG_TEST_USER_COPY is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_ARM_PTDUMP is not set
    # CONFIG_STRICT_DEVMEM is not set
    # CONFIG_ARM_UNWIND is not set
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_LL is not set
    CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
    # CONFIG_DEBUG_UART_PL01X is not set
    # CONFIG_DEBUG_UART_8250 is not set
    CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
    # CONFIG_ARM_KPROBES_TEST is not set
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # CONFIG_DEBUG_SET_MODULE_RONX is not set
    # Security options
    CONFIG_KEYS=y
    # CONFIG_PERSISTENT_KEYRINGS is not set
    # CONFIG_BIG_KEYS is not set
    # CONFIG_ENCRYPTED_KEYS is not set
    # CONFIG_KEYS_DEBUG_PROC_KEYS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    CONFIG_SECURITY=y
    # CONFIG_SECURITYFS is not set
    # CONFIG_SECURITY_NETWORK is not set
    # CONFIG_SECURITY_PATH is not set
    # CONFIG_SECURITY_SMACK is not set
    # CONFIG_SECURITY_TOMOYO is not set
    # CONFIG_SECURITY_APPARMOR is not set
    # CONFIG_SECURITY_YAMA is not set
    # CONFIG_IMA is not set
    # CONFIG_EVM is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=m
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_BLKCIPHER=y
    CONFIG_CRYPTO_BLKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_PCOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    # CONFIG_CRYPTO_USER is not set
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    # CONFIG_CRYPTO_GF128MUL is not set
    # CONFIG_CRYPTO_NULL is not set
    CONFIG_CRYPTO_WORKQUEUE=y
    # CONFIG_CRYPTO_CRYPTD is not set
    # CONFIG_CRYPTO_AUTHENC is not set
    CONFIG_CRYPTO_TEST=m
    # Authenticated Encryption with Associated Data
    CONFIG_CRYPTO_CCM=m
    # CONFIG_CRYPTO_GCM is not set
    CONFIG_CRYPTO_SEQIV=m
    # Block modes
    # CONFIG_CRYPTO_CBC is not set
    CONFIG_CRYPTO_CTR=m
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=y
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_PCBC is not set
    # CONFIG_CRYPTO_XTS is not set
    # Hash modes
    # CONFIG_CRYPTO_CMAC is not set
    CONFIG_CRYPTO_HMAC=y
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    CONFIG_CRYPTO_CRCT10DIF=y
    # CONFIG_CRYPTO_GHASH is not set
    # CONFIG_CRYPTO_MD4 is not set
    CONFIG_CRYPTO_MD5=y
    CONFIG_CRYPTO_MICHAEL_MIC=y
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    CONFIG_CRYPTO_SHA1=y
    # CONFIG_CRYPTO_SHA1_ARM is not set
    CONFIG_CRYPTO_SHA256=y
    CONFIG_CRYPTO_SHA512=y
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    CONFIG_CRYPTO_AES=y
    # CONFIG_CRYPTO_AES_ARM is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    CONFIG_CRYPTO_ARC4=y
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    CONFIG_CRYPTO_DES=y
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    # CONFIG_CRYPTO_ZLIB is not set
    CONFIG_CRYPTO_LZO=y
    # CONFIG_CRYPTO_LZ4 is not set
    # CONFIG_CRYPTO_LZ4HC is not set
    # Random Number Generation
    # CONFIG_CRYPTO_ANSI_CPRNG is not set
    CONFIG_CRYPTO_USER_API=y
    CONFIG_CRYPTO_USER_API_HASH=y
    CONFIG_CRYPTO_USER_API_SKCIPHER=y
    CONFIG_CRYPTO_HW=y
    CONFIG_CRYPTO_DEV_OMAP_SHAM=y
    CONFIG_CRYPTO_DEV_OMAP_AES=y
    # CONFIG_ASYMMETRIC_KEY_TYPE is not set
    # CONFIG_BINARY_PRINTF is not set
    # Library routines
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_GENERIC_IO=y
    CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=y
    CONFIG_CRC_ITU_T=y
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    CONFIG_CRC7=y
    CONFIG_LIBCRC32C=y
    # CONFIG_CRC8 is not set
    # CONFIG_RANDOM32_SELFTEST is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    # CONFIG_XZ_DEC is not set
    # CONFIG_XZ_DEC_BCJ is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_BCH=y
    CONFIG_ASSOCIATIVE_ARRAY=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
    CONFIG_DQL=y
    CONFIG_NLATTR=y
    CONFIG_GENERIC_ATOMIC64=y
    CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE=y
    CONFIG_AVERAGE=y
    # CONFIG_CORDIC is not set
    # CONFIG_DDR is not set
    CONFIG_OID_REGISTRY=y
    CONFIG_FONT_SUPPORT=y
    CONFIG_FONTS=y
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    # CONFIG_FONT_6x11 is not set
    # CONFIG_FONT_7x14 is not set
    # CONFIG_FONT_PEARL_8x8 is not set
    # CONFIG_FONT_ACORN_8x8 is not set
    # CONFIG_FONT_MINI_4x6 is not set
    # CONFIG_FONT_SUN8x16 is not set
    # CONFIG_FONT_SUN12x22 is not set
    # CONFIG_FONT_10x18 is not set
    # CONFIG_VIRTUALIZATION is not set
  • Does anyone know if there is a similar patch available for the Adenio Windows CE Board Support Package? We have a similar configuration with USB1_VBUS tied to 5V. In our configuration we have intermittent behavior - our system sometimes boots up with our USB1 / HUB configuration working. If I manually hold 5V low during bootup, I can make the USB1 / HUB configuration function every time. Unfortunately, the patch above does not appear to be easy to figure out how to cut into our existing Board Support Package...
  • Hi Bin,
    Could you please confirm the below regarding newer processor SDKs like SDK 1.x and SDK 2.x:
    Is it enough to follow the "porting" section of the below wiki to turn any AM335x USB port to Host?
    http://processors.wiki.ti.com/index.php/Processor_SDK_Linux_MUSB
    Or are there still patches needed in the USB driver and DTS file?
    thanks in advance,
    A.
