Why there's no resize device file : /dev/omap-resizer on my device ?
Other Parts Discussed in Thread: LM8323, PCF8574, PCF8575, PCA9539, TSC2301, LM63, LM70, LM77, LM80, LM83, LM87, LM90, LM92, LM93, ADS7828, TPS65010, TVP5150, LP5521, BQ24022, OMAP3530, ADS7846
Hi all ,
      when I play video with following command:
gst-launch -v filesrc location=xmw-h264mp3.avi ! avide
mux name=demux demux.audio_00 ! queue max-size-buffers=1200 max-size-time=0 max-
size-bytes=0 ! TIAuddec1 ! alsasink demux.video_00 ! queue !  TIViddec2 ! queue
max-size-buffers=2 max-size-time=0 max-size-bytes=0 ! typefind ! TIVidresize ! '
video/x-raw-yuv,width=640,height=480' ! TIDmaiVideoSink videoStd=VGA videoOutput
=DVI
It prints:  ERROR: from element /GstPipeline:pipeline0/GstTIVidresize:tividresize0: failed to create resize handle
when I check the code in gsttidmaivideosink.c, it will open file : /dev/omap-resizer, but i found there's no such a file on my device ! What's the reason ? anybody can help me ? Thanks !!!!
Carl
  • Hi Carl,
    Which release are you using? And also it would be helpful if you provide me .config file and boot log.
    Vaibhav
  • Hi Vaibhav,
         Thank you for reply! my kernel version is 2.6.29-r46, I get the kernel code from oe build environment. I don't know how to attach file. Bellow are the .config and bootlog:
         .config:
    # Automatically generated make config: don't edit
    # Linux kernel version: 2.6.29-omap1
    # Tue Feb 23 01:53:07 2010
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_GENERIC_GPIO=y
    CONFIG_GENERIC_TIME=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_MMU=y
    # CONFIG_NO_IOPORT is not set
    CONFIG_GENERIC_HARDIRQS=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    # CONFIG_ARCH_HAS_ILOG2_U32 is not set
    # CONFIG_ARCH_HAS_ILOG2_U64 is not set
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
    CONFIG_OPROFILE_ARMV7=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    # General setup
    CONFIG_EXPERIMENTAL=y
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_LOCK_KERNEL=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_LOCALVERSION=""
    # CONFIG_LOCALVERSION_AUTO is not set
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    # CONFIG_POSIX_MQUEUE is not set
    CONFIG_BSD_PROCESS_ACCT=y
    # CONFIG_BSD_PROCESS_ACCT_V3 is not set
    CONFIG_TASKSTATS=y
    CONFIG_TASK_DELAY_ACCT=y
    CONFIG_TASK_XACCT=y
    CONFIG_TASK_IO_ACCOUNTING=y
    # CONFIG_AUDIT is not set
    # RCU Subsystem
    CONFIG_CLASSIC_RCU=y
    # CONFIG_TREE_RCU is not set
    # CONFIG_PREEMPT_RCU is not set
    # CONFIG_TREE_RCU_TRACE is not set
    # CONFIG_PREEMPT_RCU_TRACE is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=14
    CONFIG_GROUP_SCHED=y
    CONFIG_FAIR_GROUP_SCHED=y
    # CONFIG_RT_GROUP_SCHED is not set
    CONFIG_USER_SCHED=y
    # CONFIG_CGROUP_SCHED is not set
    # CONFIG_CGROUPS is not set
    # CONFIG_SYSFS_DEPRECATED_V2 is not set
    # CONFIG_RELAY is not set
    # CONFIG_NAMESPACES is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_EMBEDDED=y
    CONFIG_UID16=y
    # CONFIG_SYSCTL_SYSCALL is not set
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    # CONFIG_KALLSYMS_EXTRA_PASS is not set
    CONFIG_HOTPLUG=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    # CONFIG_ELF_CORE is not set
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_VM_EVENT_COUNTERS=y
    # CONFIG_COMPAT_BRK is not set
    CONFIG_SLAB=y
    # CONFIG_SLUB is not set
    # CONFIG_SLOB is not set
    CONFIG_PROFILING=y
    CONFIG_TRACEPOINTS=y
    # CONFIG_MARKERS is not set
    CONFIG_OPROFILE=y
    CONFIG_HAVE_OPROFILE=y
    # CONFIG_KPROBES is not set
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL=y
    CONFIG_BLOCK=y
    CONFIG_LBD=y
    # CONFIG_BLK_DEV_IO_TRACE is not set
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    CONFIG_IOSCHED_AS=y
    CONFIG_IOSCHED_DEADLINE=y
    CONFIG_IOSCHED_CFQ=y
    # CONFIG_DEFAULT_AS is not set
    # CONFIG_DEFAULT_DEADLINE is not set
    CONFIG_DEFAULT_CFQ=y
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="cfq"
    CONFIG_FREEZER=y
    # System Type
    # CONFIG_ARCH_AAEC2000 is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_H720X is not set
    # CONFIG_ARCH_IMX is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP23XX is not set
    # CONFIG_ARCH_IXP2000 is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_L7200 is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_NS9XXX is not set
    # CONFIG_ARCH_LOKI is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_PNX4008 is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C2410 is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_SHARK is not set
    # CONFIG_ARCH_LH7A40X is not set
    # CONFIG_ARCH_DAVINCI is not set
    CONFIG_ARCH_OMAP=y
    # CONFIG_ARCH_MSM is not set
    # CONFIG_ARCH_W90X900 is not set
    # TI OMAP Implementations
    CONFIG_ARCH_OMAP_OTG=y
    # CONFIG_ARCH_OMAP1 is not set
    # CONFIG_ARCH_OMAP2 is not set
    CONFIG_ARCH_OMAP3=y
    # OMAP Feature Selections
    # CONFIG_OMAP_DEBUG_POWERDOMAIN is not set
    # CONFIG_OMAP_DEBUG_CLOCKDOMAIN is not set
    # CONFIG_OMAP_SMARTREFLEX is not set
    CONFIG_OMAP_RESET_CLOCKS=y
    CONFIG_OMAP_BOOT_TAG=y
    CONFIG_OMAP_BOOT_REASON=y
    # CONFIG_OMAP_COMPONENT_VERSION is not set
    # CONFIG_OMAP_GPIO_SWITCH is not set
    # CONFIG_OMAP_MUX is not set
    CONFIG_OMAP_MCBSP=y
    # CONFIG_OMAP_MBOX_FWK is not set
    CONFIG_OMAP_IOMMU=m
    # CONFIG_OMAP_MPU_TIMER is not set
    CONFIG_OMAP_32K_TIMER=y
    CONFIG_OMAP_32K_TIMER_HZ=128
    CONFIG_OMAP_TICK_GPTIMER=12
    CONFIG_OMAP_DM_TIMER=y
    # CONFIG_OMAP_LL_DEBUG_UART1 is not set
    # CONFIG_OMAP_LL_DEBUG_UART2 is not set
    CONFIG_OMAP_LL_DEBUG_UART3=y
    CONFIG_ARCH_OMAP34XX=y
    CONFIG_ARCH_OMAP3430=y
    # OMAP Board Type
    # CONFIG_MACH_NOKIA_RX51 is not set
    # CONFIG_MACH_OMAP_LDP is not set
    # CONFIG_MACH_OMAP_3430SDP is not set
    CONFIG_MACH_OMAP3EVM=y
    CONFIG_MACH_OMAP3_BEAGLE=y
    CONFIG_MACH_OVERO=y
    # CONFIG_MACH_OMAP3_PANDORA is not set
    # Processor Type
    CONFIG_CPU_32=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_IFAR=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    CONFIG_ARM_THUMB=y
    CONFIG_ARM_THUMBEE=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_HAS_TLS_REG=y
    # CONFIG_OUTER_CACHE is not set
    CONFIG_ARM_L1_CACHE_SHIFT=6
    # Bus support
    # CONFIG_PCI_SYSCALL is not set
    # CONFIG_ARCH_SUPPORTS_MSI is not set
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    CONFIG_PREEMPT=y
    CONFIG_HZ=128
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
    # CONFIG_DISCONTIGMEM_MANUAL is not set
    # CONFIG_SPARSEMEM_MANUAL is not set
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_VIRT_TO_BUS=y
    CONFIG_UNEVICTABLE_LRU=y
    CONFIG_LEDS=y
    CONFIG_ALIGNMENT_TRAP=y
    # Boot options
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_CMDLINE=" debug "
    # CONFIG_XIP_KERNEL is not set
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CPU Power Management
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
    CONFIG_CPU_FREQ_DEBUG=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    # CONFIG_CPU_IDLE is not set
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # CONFIG_ARM_ERRATUM_451034 is not set
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    CONFIG_HAVE_AOUT=y
    CONFIG_BINFMT_AOUT=m
    CONFIG_BINFMT_MISC=y
    # Power management options
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_VERBOSE is not set
    CONFIG_CAN_PM_TRACE=y
    CONFIG_PM_SLEEP=y
    CONFIG_SUSPEND=y
    # CONFIG_PM_TEST_SUSPEND is not set
    CONFIG_SUSPEND_FREEZER=y
    # CONFIG_APM_EMULATION is not set
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_NET=y
    # Networking options
    CONFIG_COMPAT_NET_DEV_OPS=y
    CONFIG_PACKET=y
    CONFIG_PACKET_MMAP=y
    CONFIG_UNIX=y
    CONFIG_XFRM=y
    # CONFIG_XFRM_USER is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_IPCOMP=m
    CONFIG_NET_KEY=y
    # CONFIG_NET_KEY_MIGRATE is not set
    CONFIG_INET=y
    # CONFIG_IP_MULTICAST is not set
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_FIB_HASH=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    CONFIG_NET_IPIP=m
    CONFIG_NET_IPGRE=m
    # CONFIG_ARPD is not set
    # CONFIG_SYN_COOKIES is not set
    CONFIG_INET_AH=m
    CONFIG_INET_ESP=m
    CONFIG_INET_IPCOMP=m
    CONFIG_INET_XFRM_TUNNEL=m
    CONFIG_INET_TUNNEL=m
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
    CONFIG_INET_LRO=m
    CONFIG_INET_DIAG=m
    CONFIG_INET_TCP_DIAG=m
    CONFIG_TCP_CONG_ADVANCED=y
    CONFIG_TCP_CONG_BIC=m
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_TCP_CONG_WESTWOOD=m
    CONFIG_TCP_CONG_HTCP=m
    CONFIG_TCP_CONG_HSTCP=m
    CONFIG_TCP_CONG_HYBLA=m
    CONFIG_TCP_CONG_VEGAS=m
    CONFIG_TCP_CONG_SCALABLE=m
    CONFIG_TCP_CONG_LP=m
    CONFIG_TCP_CONG_VENO=m
    CONFIG_TCP_CONG_YEAH=m
    CONFIG_TCP_CONG_ILLINOIS=m
    # CONFIG_DEFAULT_BIC is not set
    CONFIG_DEFAULT_CUBIC=y
    # CONFIG_DEFAULT_HTCP is not set
    # CONFIG_DEFAULT_VEGAS is not set
    # CONFIG_DEFAULT_WESTWOOD is not set
    # CONFIG_DEFAULT_RENO is not set
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=m
    # CONFIG_IPV6_PRIVACY is not set
    # CONFIG_IPV6_ROUTER_PREF is not set
    # CONFIG_IPV6_OPTIMISTIC_DAD is not set
    CONFIG_INET6_AH=m
    CONFIG_INET6_ESP=m
    CONFIG_INET6_IPCOMP=m
    CONFIG_IPV6_MIP6=m
    CONFIG_INET6_XFRM_TUNNEL=m
    CONFIG_INET6_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_TRANSPORT=m
    CONFIG_INET6_XFRM_MODE_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_BEET=m
    CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION=m
    CONFIG_IPV6_SIT=m
    CONFIG_IPV6_NDISC_NODETYPE=y
    CONFIG_IPV6_TUNNEL=m
    CONFIG_IPV6_MULTIPLE_TABLES=y
    CONFIG_IPV6_SUBTREES=y
    CONFIG_IPV6_MROUTE=y
    # CONFIG_IPV6_PIMSM_V2 is not set
    # CONFIG_NETWORK_SECMARK is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    CONFIG_BRIDGE_NETFILTER=y
    # Core Netfilter Configuration
    CONFIG_NETFILTER_NETLINK=m
    CONFIG_NETFILTER_NETLINK_QUEUE=m
    CONFIG_NETFILTER_NETLINK_LOG=m
    CONFIG_NF_CONNTRACK=m
    CONFIG_NF_CT_ACCT=y
    CONFIG_NF_CONNTRACK_MARK=y
    CONFIG_NF_CONNTRACK_EVENTS=y
    CONFIG_NF_CT_PROTO_DCCP=m
    CONFIG_NF_CT_PROTO_GRE=m
    CONFIG_NF_CT_PROTO_SCTP=m
    CONFIG_NF_CT_PROTO_UDPLITE=m
    CONFIG_NF_CONNTRACK_AMANDA=m
    CONFIG_NF_CONNTRACK_FTP=m
    CONFIG_NF_CONNTRACK_H323=m
    CONFIG_NF_CONNTRACK_IRC=m
    CONFIG_NF_CONNTRACK_NETBIOS_NS=m
    CONFIG_NF_CONNTRACK_PPTP=m
    CONFIG_NF_CONNTRACK_SANE=m
    CONFIG_NF_CONNTRACK_SIP=m
    CONFIG_NF_CONNTRACK_TFTP=m
    CONFIG_NF_CT_NETLINK=m
    # CONFIG_NETFILTER_TPROXY is not set
    CONFIG_NETFILTER_XTABLES=m
    CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
    CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
    # CONFIG_NETFILTER_XT_TARGET_DSCP is not set
    CONFIG_NETFILTER_XT_TARGET_MARK=m
    CONFIG_NETFILTER_XT_TARGET_NFLOG=m
    CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
    # CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
    CONFIG_NETFILTER_XT_TARGET_RATEEST=m
    # CONFIG_NETFILTER_XT_TARGET_TRACE is not set
    CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
    # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
    CONFIG_NETFILTER_XT_MATCH_COMMENT=m
    CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
    CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
    CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
    CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
    CONFIG_NETFILTER_XT_MATCH_DCCP=m
    CONFIG_NETFILTER_XT_MATCH_DSCP=m
    CONFIG_NETFILTER_XT_MATCH_ESP=m
    CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
    CONFIG_NETFILTER_XT_MATCH_HELPER=m
    CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
    CONFIG_NETFILTER_XT_MATCH_LENGTH=m
    CONFIG_NETFILTER_XT_MATCH_LIMIT=m
    CONFIG_NETFILTER_XT_MATCH_MAC=m
    CONFIG_NETFILTER_XT_MATCH_MARK=m
    CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
    CONFIG_NETFILTER_XT_MATCH_OWNER=m
    CONFIG_NETFILTER_XT_MATCH_POLICY=m
    # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
    CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
    CONFIG_NETFILTER_XT_MATCH_QUOTA=m
    CONFIG_NETFILTER_XT_MATCH_RATEEST=m
    CONFIG_NETFILTER_XT_MATCH_REALM=m
    CONFIG_NETFILTER_XT_MATCH_RECENT=m
    # CONFIG_NETFILTER_XT_MATCH_RECENT_PROC_COMPAT is not set
    CONFIG_NETFILTER_XT_MATCH_SCTP=m
    CONFIG_NETFILTER_XT_MATCH_STATE=m
    CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
    CONFIG_NETFILTER_XT_MATCH_STRING=m
    CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
    CONFIG_NETFILTER_XT_MATCH_TIME=m
    CONFIG_NETFILTER_XT_MATCH_U32=m
    CONFIG_IP_VS=m
    CONFIG_IP_VS_IPV6=y
    CONFIG_IP_VS_DEBUG=y
    CONFIG_IP_VS_TAB_BITS=12
    # IPVS transport protocol load balancing support
    CONFIG_IP_VS_PROTO_TCP=y
    CONFIG_IP_VS_PROTO_UDP=y
    CONFIG_IP_VS_PROTO_AH_ESP=y
    CONFIG_IP_VS_PROTO_ESP=y
    CONFIG_IP_VS_PROTO_AH=y
    # IPVS scheduler
    CONFIG_IP_VS_RR=m
    CONFIG_IP_VS_WRR=m
    CONFIG_IP_VS_LC=m
    CONFIG_IP_VS_WLC=m
    CONFIG_IP_VS_LBLC=m
    CONFIG_IP_VS_LBLCR=m
    CONFIG_IP_VS_DH=m
    CONFIG_IP_VS_SH=m
    CONFIG_IP_VS_SED=m
    CONFIG_IP_VS_NQ=m
    # IPVS application helper
    CONFIG_IP_VS_FTP=m
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    CONFIG_NF_CONNTRACK_IPV4=m
    CONFIG_NF_CONNTRACK_PROC_COMPAT=y
    CONFIG_IP_NF_QUEUE=m
    CONFIG_IP_NF_IPTABLES=m
    CONFIG_IP_NF_MATCH_ADDRTYPE=m
    CONFIG_IP_NF_MATCH_AH=m
    CONFIG_IP_NF_MATCH_ECN=m
    CONFIG_IP_NF_MATCH_TTL=m
    CONFIG_IP_NF_FILTER=m
    CONFIG_IP_NF_TARGET_REJECT=m
    CONFIG_IP_NF_TARGET_LOG=m
    CONFIG_IP_NF_TARGET_ULOG=m
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_NEEDED=y
    CONFIG_IP_NF_TARGET_MASQUERADE=m
    CONFIG_IP_NF_TARGET_NETMAP=m
    CONFIG_IP_NF_TARGET_REDIRECT=m
    CONFIG_IP_NF_TARGET_IDLETIMER=m
    CONFIG_NF_NAT_SNMP_BASIC=m
    CONFIG_NF_NAT_PROTO_DCCP=m
    CONFIG_NF_NAT_PROTO_GRE=m
    CONFIG_NF_NAT_PROTO_UDPLITE=m
    CONFIG_NF_NAT_PROTO_SCTP=m
    CONFIG_NF_NAT_FTP=m
    CONFIG_NF_NAT_IRC=m
    CONFIG_NF_NAT_TFTP=m
    CONFIG_NF_NAT_AMANDA=m
    CONFIG_NF_NAT_PPTP=m
    CONFIG_NF_NAT_H323=m
    CONFIG_NF_NAT_SIP=m
    CONFIG_IP_NF_MANGLE=m
    CONFIG_IP_NF_TARGET_CLUSTERIP=m
    CONFIG_IP_NF_TARGET_ECN=m
    CONFIG_IP_NF_TARGET_TTL=m
    CONFIG_IP_NF_RAW=m
    CONFIG_IP_NF_ARPTABLES=m
    CONFIG_IP_NF_ARPFILTER=m
    CONFIG_IP_NF_ARP_MANGLE=m
    # IPv6: Netfilter Configuration
    CONFIG_NF_CONNTRACK_IPV6=m
    CONFIG_IP6_NF_QUEUE=m
    CONFIG_IP6_NF_IPTABLES=m
    CONFIG_IP6_NF_MATCH_AH=m
    CONFIG_IP6_NF_MATCH_EUI64=m
    CONFIG_IP6_NF_MATCH_FRAG=m
    CONFIG_IP6_NF_MATCH_OPTS=m
    CONFIG_IP6_NF_MATCH_HL=m
    CONFIG_IP6_NF_MATCH_IPV6HEADER=m
    CONFIG_IP6_NF_MATCH_MH=m
    CONFIG_IP6_NF_MATCH_RT=m
    CONFIG_IP6_NF_TARGET_LOG=m
    CONFIG_IP6_NF_FILTER=m
    CONFIG_IP6_NF_TARGET_REJECT=m
    CONFIG_IP6_NF_MANGLE=m
    CONFIG_IP6_NF_TARGET_HL=m
    CONFIG_IP6_NF_RAW=m
    # CONFIG_BRIDGE_NF_EBTABLES is not set
    CONFIG_IP_DCCP=m
    CONFIG_INET_DCCP_DIAG=m
    # DCCP CCIDs Configuration (EXPERIMENTAL)
    # CONFIG_IP_DCCP_CCID2_DEBUG is not set
    CONFIG_IP_DCCP_CCID3=y
    # CONFIG_IP_DCCP_CCID3_DEBUG is not set
    CONFIG_IP_DCCP_CCID3_RTO=100
    CONFIG_IP_DCCP_TFRC_LIB=y
    # DCCP Kernel Hacking
    # CONFIG_IP_DCCP_DEBUG is not set
    CONFIG_IP_SCTP=m
    # CONFIG_SCTP_DBG_MSG is not set
    # CONFIG_SCTP_DBG_OBJCNT is not set
    # CONFIG_SCTP_HMAC_NONE is not set
    # CONFIG_SCTP_HMAC_SHA1 is not set
    CONFIG_SCTP_HMAC_MD5=y
    CONFIG_TIPC=m
    # CONFIG_TIPC_ADVANCED is not set
    # CONFIG_TIPC_DEBUG is not set
    CONFIG_ATM=m
    CONFIG_ATM_CLIP=m
    # CONFIG_ATM_CLIP_NO_ICMP is not set
    CONFIG_ATM_LANE=m
    CONFIG_ATM_MPOA=m
    CONFIG_ATM_BR2684=m
    # CONFIG_ATM_BR2684_IPFILTER is not set
    CONFIG_STP=m
    CONFIG_GARP=m
    CONFIG_BRIDGE=m
    # CONFIG_NET_DSA is not set
    CONFIG_VLAN_8021Q=m
    CONFIG_VLAN_8021Q_GVRP=y
    # CONFIG_DECNET is not set
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_ECONET is not set
    CONFIG_WAN_ROUTER=m
    CONFIG_NET_SCHED=y
    # Queueing/Scheduling
    CONFIG_NET_SCH_CBQ=m
    CONFIG_NET_SCH_HTB=m
    CONFIG_NET_SCH_HFSC=m
    CONFIG_NET_SCH_ATM=m
    CONFIG_NET_SCH_PRIO=m
    CONFIG_NET_SCH_MULTIQ=m
    CONFIG_NET_SCH_RED=m
    CONFIG_NET_SCH_SFQ=m
    CONFIG_NET_SCH_TEQL=m
    CONFIG_NET_SCH_TBF=m
    CONFIG_NET_SCH_GRED=m
    CONFIG_NET_SCH_DSMARK=m
    CONFIG_NET_SCH_NETEM=m
    CONFIG_NET_SCH_DRR=m
    # Classification
    CONFIG_NET_CLS=y
    CONFIG_NET_CLS_BASIC=m
    CONFIG_NET_CLS_TCINDEX=m
    CONFIG_NET_CLS_ROUTE4=m
    CONFIG_NET_CLS_ROUTE=y
    CONFIG_NET_CLS_FW=m
    CONFIG_NET_CLS_U32=m
    CONFIG_CLS_U32_PERF=y
    CONFIG_CLS_U32_MARK=y
    CONFIG_NET_CLS_RSVP=m
    CONFIG_NET_CLS_RSVP6=m
    CONFIG_NET_CLS_FLOW=m
    # CONFIG_NET_EMATCH is not set
    # CONFIG_NET_CLS_ACT is not set
    CONFIG_NET_CLS_IND=y
    CONFIG_NET_SCH_FIFO=y
    # CONFIG_DCB is not set
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    # CAN Device Drivers
    CONFIG_CAN_VCAN=m
    # CONFIG_CAN_DEBUG_DEVICES is not set
    CONFIG_IRDA=m
    # IrDA protocols
    CONFIG_IRLAN=m
    CONFIG_IRNET=m
    CONFIG_IRCOMM=m
    CONFIG_IRDA_ULTRA=y
    # IrDA options
    CONFIG_IRDA_CACHE_LAST_LSAP=y
    CONFIG_IRDA_FAST_RR=y
    CONFIG_IRDA_DEBUG=y
    # Infrared-port device drivers
    # SIR device drivers
    CONFIG_IRTTY_SIR=m
    # Dongle support
    CONFIG_DONGLE=y
    CONFIG_ESI_DONGLE=m
    CONFIG_ACTISYS_DONGLE=m
    CONFIG_TEKRAM_DONGLE=m
    CONFIG_TOIM3232_DONGLE=m
    CONFIG_LITELINK_DONGLE=m
    CONFIG_MA600_DONGLE=m
    CONFIG_GIRBIL_DONGLE=m
    CONFIG_MCP2120_DONGLE=m
    CONFIG_OLD_BELKIN_DONGLE=m
    # CONFIG_ACT200L_DONGLE is not set
    CONFIG_KINGSUN_DONGLE=m
    CONFIG_KSDAZZLE_DONGLE=m
    CONFIG_KS959_DONGLE=m
    # FIR device drivers
    CONFIG_USB_IRDA=m
    CONFIG_SIGMATEL_FIR=m
    CONFIG_MCS_FIR=m
    # CONFIG_OMAP_IR is not set
    CONFIG_BT=y
    CONFIG_BT_L2CAP=y
    CONFIG_BT_SCO=y
    CONFIG_BT_RFCOMM=y
    CONFIG_BT_RFCOMM_TTY=y
    CONFIG_BT_BNEP=y
    CONFIG_BT_BNEP_MC_FILTER=y
    CONFIG_BT_BNEP_PROTO_FILTER=y
    CONFIG_BT_HIDP=y
    # Bluetooth device drivers
    CONFIG_BT_HCIBTUSB=y
    CONFIG_BT_HCIBTSDIO=y
    CONFIG_BT_HCIUART=y
    CONFIG_BT_HCIUART_H4=y
    CONFIG_BT_HCIUART_BCSP=y
    CONFIG_BT_HCIUART_LL=y
    CONFIG_BT_HCIBCM203X=y
    CONFIG_BT_HCIBPA10X=y
    CONFIG_BT_HCIBFUSB=y
    # CONFIG_BT_HCIBRF6150 is not set
    # CONFIG_BT_HCIH4P is not set
    # CONFIG_BT_HCIVHCI is not set
    CONFIG_AF_RXRPC=m
    # CONFIG_AF_RXRPC_DEBUG is not set
    # CONFIG_RXKAD is not set
    # CONFIG_PHONET is not set
    CONFIG_FIB_RULES=y
    CONFIG_WIRELESS=y
    CONFIG_CFG80211=y
    # CONFIG_CFG80211_REG_DEBUG is not set
    CONFIG_NL80211=y
    CONFIG_WIRELESS_OLD_REGULATORY=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WIRELESS_EXT_SYSFS=y
    CONFIG_LIB80211=y
    CONFIG_LIB80211_CRYPT_WEP=y
    CONFIG_LIB80211_CRYPT_CCMP=y
    CONFIG_LIB80211_CRYPT_TKIP=y
    # CONFIG_LIB80211_DEBUG is not set
    CONFIG_MAC80211=y
    # Rate control algorithm selection
    CONFIG_MAC80211_RC_PID=y
    # CONFIG_MAC80211_RC_MINSTREL is not set
    CONFIG_MAC80211_RC_DEFAULT_PID=y
    # CONFIG_MAC80211_RC_DEFAULT_MINSTREL is not set
    CONFIG_MAC80211_RC_DEFAULT="pid"
    # CONFIG_MAC80211_MESH is not set
    CONFIG_MAC80211_LEDS=y
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    CONFIG_WIMAX=m
    CONFIG_WIMAX_DEBUG_LEVEL=8
    # CONFIG_RFKILL is not set
    CONFIG_NET_9P=m
    # CONFIG_NET_9P_DEBUG is not set
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_CONNECTOR is not set
    CONFIG_MTD=y
    # CONFIG_MTD_DEBUG is not set
    CONFIG_MTD_CONCAT=y
    CONFIG_MTD_PARTITIONS=y
    # CONFIG_MTD_TESTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    # CONFIG_MTD_CMDLINE_PARTS is not set
    # CONFIG_MTD_AFS_PARTS is not set
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_CHAR=y
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_MTD_OOPS is not set
    # RAM/ROM/Flash chip drivers
    # CONFIG_MTD_CFI is not set
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_DATAFLASH is not set
    # CONFIG_MTD_M25P80 is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOC2000 is not set
    # CONFIG_MTD_DOC2001 is not set
    # CONFIG_MTD_DOC2001PLUS is not set
    CONFIG_MTD_NAND=y
    # CONFIG_MTD_NAND_VERIFY_WRITE is not set
    # CONFIG_MTD_NAND_ECC_SMC is not set
    # CONFIG_MTD_NAND_MUSEUM_IDS is not set
    # CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_NAND_NANDSIM is not set
    CONFIG_MTD_NAND_PLATFORM=y
    # CONFIG_MTD_ALAUDA is not set
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    # UBI - Unsorted block images
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_RESERVE=1
    # CONFIG_MTD_UBI_GLUEBI is not set
    # UBI debugging options
    # CONFIG_MTD_UBI_DEBUG is not set
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_CRYPTOLOOP=m
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_UB is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=16384
    # CONFIG_BLK_DEV_XIP is not set
    CONFIG_CDROM_PKTCDVD=m
    CONFIG_CDROM_PKTCDVD_BUFFERS=8
    # CONFIG_CDROM_PKTCDVD_WCACHE is not set
    # CONFIG_ATA_OVER_ETH is not set
    CONFIG_MISC_DEVICES=y
    # CONFIG_ICS932S401 is not set
    # CONFIG_OMAP_STI is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_C2PORT is not set
    # EEPROM support
    # CONFIG_EEPROM_AT24 is not set
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    CONFIG_EEPROM_93CX6=y
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_RAID_ATTRS=m
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_TGT is not set
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    CONFIG_BLK_DEV_SR=y
    CONFIG_BLK_DEV_SR_VENDOR=y
    CONFIG_CHR_DEV_SG=y
    CONFIG_CHR_DEV_SCH=m
    # Some SCSI devices (e.g. CD jukebox) support multiple LUNs
    CONFIG_SCSI_MULTI_LUN=y
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    CONFIG_SCSI_WAIT_SCAN=m
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    CONFIG_SCSI_ISCSI_ATTRS=m
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    CONFIG_ISCSI_TCP=m
    # CONFIG_LIBFC is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_ATA is not set
    CONFIG_MD=y
    CONFIG_BLK_DEV_MD=m
    CONFIG_MD_LINEAR=m
    CONFIG_MD_RAID0=m
    CONFIG_MD_RAID1=m
    CONFIG_MD_RAID10=m
    CONFIG_MD_RAID456=m
    CONFIG_MD_RAID5_RESHAPE=y
    CONFIG_MD_MULTIPATH=m
    CONFIG_MD_FAULTY=m
    CONFIG_BLK_DEV_DM=m
    # CONFIG_DM_DEBUG is not set
    CONFIG_DM_CRYPT=m
    CONFIG_DM_SNAPSHOT=m
    CONFIG_DM_MIRROR=m
    CONFIG_DM_ZERO=m
    CONFIG_DM_MULTIPATH=m
    CONFIG_DM_DELAY=m
    # CONFIG_DM_UEVENT is not set
    CONFIG_NETDEVICES=y
    CONFIG_DUMMY=m
    CONFIG_BONDING=m
    CONFIG_MACVLAN=m
    CONFIG_EQUALIZER=m
    CONFIG_TUN=m
    CONFIG_VETH=m
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    # CONFIG_MARVELL_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_CICADA_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    # CONFIG_SMSC_PHY is not set
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    # CONFIG_FIXED_PHY is not set
    # CONFIG_MDIO_BITBANG is not set
    CONFIG_NET_ETHERNET=y
    CONFIG_MII=y
    # CONFIG_AX88796 is not set
    # CONFIG_SMC91X is not set
    # CONFIG_DM9000 is not set
    CONFIG_ENC28J60=y
    # CONFIG_ENC28J60_WRITEVERIFY is not set
    CONFIG_SMC911X=y
    CONFIG_SMSC911X=y
    # CONFIG_DNET is not set
    # CONFIG_IBM_NEW_EMAC_ZMII is not set
    # CONFIG_IBM_NEW_EMAC_RGMII is not set
    # CONFIG_IBM_NEW_EMAC_TAH is not set
    # CONFIG_IBM_NEW_EMAC_EMAC4 is not set
    # CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
    # CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
    # CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
    # CONFIG_B44 is not set
    # CONFIG_NETDEV_1000 is not set
    # CONFIG_NETDEV_10000 is not set
    # Wireless LAN
    # CONFIG_WLAN_PRE80211 is not set
    CONFIG_WLAN_80211=y
    CONFIG_LIBERTAS=y
    CONFIG_LIBERTAS_USB=y
    # CONFIG_LIBERTAS_SDIO is not set
    # CONFIG_LIBERTAS_DEBUG is not set
    # CONFIG_LIBERTAS_THINFIRM is not set
    CONFIG_USB_ZD1201=y
    CONFIG_USB_NET_RNDIS_WLAN=y
    CONFIG_RTL8187=y
    # CONFIG_MAC80211_HWSIM is not set
    CONFIG_P54_COMMON=y
    CONFIG_P54_USB=y
    # CONFIG_IWLWIFI_LEDS is not set
    CONFIG_HOSTAP=y
    CONFIG_HOSTAP_FIRMWARE=y
    CONFIG_HOSTAP_FIRMWARE_NVRAM=y
    CONFIG_B43=y
    CONFIG_B43_LEDS=y
    # CONFIG_B43_DEBUG is not set
    # CONFIG_B43LEGACY is not set
    CONFIG_ZD1211RW=y
    # CONFIG_ZD1211RW_DEBUG is not set
    CONFIG_RT2X00=y
    CONFIG_RT2500USB=y
    CONFIG_RT73USB=y
    CONFIG_RT2X00_LIB_USB=y
    CONFIG_RT2X00_LIB=y
    CONFIG_RT2X00_LIB_FIRMWARE=y
    CONFIG_RT2X00_LIB_CRYPTO=y
    CONFIG_RT2X00_LIB_LEDS=y
    # CONFIG_RT2X00_DEBUG is not set
    # WiMAX Wireless Broadband devices
    # CONFIG_WIMAX_I2400M_USB is not set
    # CONFIG_WIMAX_I2400M_SDIO is not set
    # USB Network Adapters
    CONFIG_USB_CATC=y
    CONFIG_USB_KAWETH=y
    CONFIG_USB_PEGASUS=y
    CONFIG_USB_RTL8150=y
    CONFIG_USB_USBNET=y
    CONFIG_USB_NET_AX8817X=y
    CONFIG_USB_NET_CDCETHER=y
    CONFIG_USB_NET_DM9601=y
    CONFIG_USB_NET_SMSC95XX=y
    CONFIG_USB_NET_GL620A=y
    CONFIG_USB_NET_NET1080=y
    CONFIG_USB_NET_PLUSB=y
    CONFIG_USB_NET_MCS7830=y
    CONFIG_USB_NET_RNDIS_HOST=y
    CONFIG_USB_NET_CDC_SUBSET=y
    CONFIG_USB_ALI_M5632=y
    CONFIG_USB_AN2720=y
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    CONFIG_USB_EPSON2888=y
    CONFIG_USB_KC2190=y
    CONFIG_USB_NET_ZAURUS=y
    # CONFIG_WAN is not set
    CONFIG_ATM_DRIVERS=y
    # CONFIG_ATM_DUMMY is not set
    # CONFIG_ATM_TCP is not set
    CONFIG_PPP=m
    CONFIG_PPP_MULTILINK=y
    CONFIG_PPP_FILTER=y
    CONFIG_PPP_ASYNC=m
    CONFIG_PPP_SYNC_TTY=m
    CONFIG_PPP_DEFLATE=m
    CONFIG_PPP_BSDCOMP=m
    CONFIG_PPP_MPPE=m
    CONFIG_PPPOE=m
    # CONFIG_PPPOATM is not set
    CONFIG_PPPOL2TP=m
    # CONFIG_SLIP is not set
    CONFIG_SLHC=m
    CONFIG_NETCONSOLE=m
    CONFIG_NETCONSOLE_DYNAMIC=y
    CONFIG_NETPOLL=y
    CONFIG_NETPOLL_TRAP=y
    CONFIG_NET_POLL_CONTROLLER=y
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    CONFIG_INPUT_FF_MEMLESS=y
    # CONFIG_INPUT_POLLDEV is not set
    # Userland interfaces
    CONFIG_INPUT_MOUSEDEV=y
    CONFIG_INPUT_MOUSEDEV_PSAUX=y
    CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
    CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
    # CONFIG_INPUT_JOYDEV is not set
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ATKBD is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    # CONFIG_KEYBOARD_XTKBD is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_TWL4030 is not set
    # CONFIG_KEYBOARD_LM8323 is not set
    CONFIG_KEYBOARD_GPIO=y
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    # CONFIG_MOUSE_PS2_ELANTECH is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    # CONFIG_INPUT_TOUCHSCREEN is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_ATI_REMOTE is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    CONFIG_INPUT_TWL4030_PWRBUTTON=y
    CONFIG_INPUT_UINPUT=y
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_DEVKMEM=y
    # CONFIG_SERIAL_NONSTANDARD is not set
    # Serial drivers
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_NR_UARTS=32
    CONFIG_SERIAL_8250_RUNTIME_UARTS=4
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    CONFIG_SERIAL_8250_DETECT_IRQ=y
    CONFIG_SERIAL_8250_RSA=y
    # Non-8250 serial port support
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_IPMI_HANDLER is not set
    CONFIG_HW_RANDOM=y
    # CONFIG_R3964 is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_HELPER_AUTO=y
    # I2C Hardware Bus support
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_SIMTEC is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_STUB is not set
    # Miscellaneous I2C Chip support
    # CONFIG_DS1682 is not set
    # CONFIG_SENSORS_PCF8574 is not set
    # CONFIG_PCF8575 is not set
    # CONFIG_SENSORS_PCA9539 is not set
    # CONFIG_SENSORS_PCF8591 is not set
    CONFIG_TWL4030_MADC=m
    CONFIG_TWL4030_POWEROFF=y
    # CONFIG_SENSORS_MAX6875 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    # CONFIG_I2C_DEBUG_CHIP is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_GPIO is not set
    CONFIG_SPI_OMAP24XX=y
    # SPI Protocol Masters
    # CONFIG_SPI_TSC210X is not set
    # CONFIG_SPI_TSC2301 is not set
    CONFIG_SPI_SPIDEV=y
    # CONFIG_SPI_TLE62X0 is not set
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIOLIB=y
    # CONFIG_DEBUG_GPIO is not set
    CONFIG_GPIO_SYSFS=y
    # Memory mapped GPIO expanders:
    # I2C GPIO expanders:
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCA953X is not set
    # CONFIG_GPIO_PCF857X is not set
    CONFIG_GPIO_TWL4030=y
    # PCI GPIO expanders:
    # SPI GPIO expanders:
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_W1 is not set
    CONFIG_POWER_SUPPLY=m
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_BATTERY_DS2760 is not set
    # CONFIG_TWL4030_BCI_BATTERY is not set
    # CONFIG_BATTERY_BQ27x00 is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_VID is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7473 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM75 is not set
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    # CONFIG_SENSORS_LM90 is not set
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_THMC50 is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    # CONFIG_SENSORS_TSC210X is not set
    CONFIG_SENSORS_OMAP34XX=y
    # CONFIG_HWMON_DEBUG_CHIP is not set
    CONFIG_THERMAL=y
    CONFIG_THERMAL_HWMON=y
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_NOWAYOUT=y
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    CONFIG_OMAP_WATCHDOG=y
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    CONFIG_SSB=y
    # CONFIG_SSB_SILENT is not set
    # CONFIG_SSB_DEBUG is not set
    # Multifunction device drivers
    # CONFIG_MFD_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_TPS65010 is not set
    CONFIG_TWL4030_CORE=y
    # CONFIG_TWL4030_POWER is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_PCF50633 is not set
    # Multimedia devices
    # Multimedia core support
    CONFIG_VIDEO_DEV=m
    CONFIG_VIDEO_V4L2_COMMON=m
    CONFIG_VIDEO_ALLOW_V4L1=y
    CONFIG_VIDEO_V4L1_COMPAT=y
    CONFIG_DVB_CORE=m
    CONFIG_VIDEO_MEDIA=m
    # Multimedia drivers
    CONFIG_MEDIA_ATTACH=y
    CONFIG_MEDIA_TUNER=m
    # CONFIG_MEDIA_TUNER_CUSTOMIZE is not set
    CONFIG_MEDIA_TUNER_SIMPLE=m
    CONFIG_MEDIA_TUNER_TDA8290=m
    CONFIG_MEDIA_TUNER_TDA827X=m
    CONFIG_MEDIA_TUNER_TDA18271=m
    CONFIG_MEDIA_TUNER_TDA9887=m
    CONFIG_MEDIA_TUNER_TEA5761=m
    CONFIG_MEDIA_TUNER_TEA5767=m
    CONFIG_MEDIA_TUNER_MT20XX=m
    CONFIG_MEDIA_TUNER_MT2060=m
    CONFIG_MEDIA_TUNER_MT2266=m
    CONFIG_MEDIA_TUNER_QT1010=m
    CONFIG_MEDIA_TUNER_XC2028=m
    CONFIG_MEDIA_TUNER_XC5000=m
    CONFIG_MEDIA_TUNER_MXL5005S=m
    CONFIG_VIDEO_V4L2=m
    CONFIG_VIDEO_V4L1=m
    CONFIG_VIDEOBUF_GEN=m
    CONFIG_VIDEOBUF_DMA_SG=m
    CONFIG_VIDEOBUF_VMALLOC=m
    CONFIG_VIDEOBUF_DVB=m
    CONFIG_VIDEO_IR=m
    CONFIG_VIDEO_TVEEPROM=m
    CONFIG_VIDEO_TUNER=m
    CONFIG_VIDEO_CAPTURE_DRIVERS=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_VIDEO_HELPER_CHIPS_AUTO=y
    CONFIG_VIDEO_IR_I2C=m
    CONFIG_VIDEO_MSP3400=m
    CONFIG_VIDEO_CS53L32A=m
    CONFIG_VIDEO_WM8775=m
    CONFIG_VIDEO_SAA711X=m
    CONFIG_VIDEO_TVP5150=m
    CONFIG_VIDEO_CX25840=m
    CONFIG_VIDEO_CX2341X=m
    CONFIG_VIDEO_VIVI=m
    # CONFIG_VIDEO_CPIA is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_VIDEO_SAA5246A is not set
    # CONFIG_VIDEO_SAA5249 is not set
    # CONFIG_VIDEO_AU0828 is not set
    CONFIG_VIDEO_OMAP3=m
    CONFIG_VIDEO_OMAP34XX_ISP_RESIZER=m
    # CONFIG_SOC_CAMERA is not set
    CONFIG_V4L_USB_DRIVERS=y
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    CONFIG_USB_GSPCA=m
    CONFIG_USB_M5602=m
    CONFIG_USB_STV06XX=m
    CONFIG_USB_GSPCA_CONEX=m
    CONFIG_USB_GSPCA_ETOMS=m
    CONFIG_USB_GSPCA_FINEPIX=m
    CONFIG_USB_GSPCA_MARS=m
    CONFIG_USB_GSPCA_OV519=m
    CONFIG_USB_GSPCA_OV534=m
    CONFIG_USB_GSPCA_PAC207=m
    CONFIG_USB_GSPCA_PAC7311=m
    CONFIG_USB_GSPCA_SONIXB=m
    CONFIG_USB_GSPCA_SONIXJ=m
    CONFIG_USB_GSPCA_SPCA500=m
    CONFIG_USB_GSPCA_SPCA501=m
    CONFIG_USB_GSPCA_SPCA505=m
    CONFIG_USB_GSPCA_SPCA506=m
    CONFIG_USB_GSPCA_SPCA508=m
    CONFIG_USB_GSPCA_SPCA561=m
    CONFIG_USB_GSPCA_STK014=m
    CONFIG_USB_GSPCA_SUNPLUS=m
    CONFIG_USB_GSPCA_T613=m
    CONFIG_USB_GSPCA_TV8532=m
    CONFIG_USB_GSPCA_VC032X=m
    CONFIG_USB_GSPCA_ZC3XX=m
    CONFIG_VIDEO_PVRUSB2=m
    CONFIG_VIDEO_PVRUSB2_SYSFS=y
    CONFIG_VIDEO_PVRUSB2_DVB=y
    # CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
    CONFIG_VIDEO_EM28XX=m
    CONFIG_VIDEO_EM28XX_ALSA=m
    CONFIG_VIDEO_EM28XX_DVB=m
    CONFIG_VIDEO_USBVISION=m
    CONFIG_VIDEO_USBVIDEO=m
    CONFIG_USB_VICAM=m
    CONFIG_USB_IBMCAM=m
    CONFIG_USB_KONICAWC=m
    CONFIG_USB_QUICKCAM_MESSENGER=m
    CONFIG_USB_ET61X251=m
    CONFIG_VIDEO_OVCAMCHIP=m
    CONFIG_USB_W9968CF=m
    CONFIG_USB_OV511=m
    CONFIG_USB_SE401=m
    CONFIG_USB_SN9C102=m
    CONFIG_USB_STV680=m
    CONFIG_USB_ZC0301=m
    CONFIG_USB_PWC=m
    # CONFIG_USB_PWC_DEBUG is not set
    CONFIG_USB_ZR364XX=m
    CONFIG_USB_STKWEBCAM=m
    CONFIG_USB_S2255=m
    CONFIG_RADIO_ADAPTERS=y
    # CONFIG_USB_DSBR is not set
    # CONFIG_USB_SI470X is not set
    # CONFIG_USB_MR800 is not set
    # CONFIG_RADIO_TEA5764 is not set
    CONFIG_DVB_DYNAMIC_MINORS=y
    CONFIG_DVB_CAPTURE_DRIVERS=y
    # CONFIG_TTPCI_EEPROM is not set
    # Supported USB Adapters
    CONFIG_DVB_USB=m
    # CONFIG_DVB_USB_DEBUG is not set
    CONFIG_DVB_USB_A800=m
    CONFIG_DVB_USB_DIBUSB_MB=m
    # CONFIG_DVB_USB_DIBUSB_MB_FAULTY is not set
    CONFIG_DVB_USB_DIBUSB_MC=m
    CONFIG_DVB_USB_DIB0700=m
    CONFIG_DVB_USB_UMT_010=m
    CONFIG_DVB_USB_CXUSB=m
    CONFIG_DVB_USB_M920X=m
    CONFIG_DVB_USB_GL861=m
    CONFIG_DVB_USB_AU6610=m
    CONFIG_DVB_USB_DIGITV=m
    CONFIG_DVB_USB_VP7045=m
    CONFIG_DVB_USB_VP702X=m
    CONFIG_DVB_USB_GP8PSK=m
    CONFIG_DVB_USB_NOVA_T_USB2=m
    CONFIG_DVB_USB_TTUSB2=m
    CONFIG_DVB_USB_DTT200U=m
    CONFIG_DVB_USB_OPERA1=m
    CONFIG_DVB_USB_AF9005=m
    CONFIG_DVB_USB_AF9005_REMOTE=m
    CONFIG_DVB_USB_DW2102=m
    CONFIG_DVB_USB_CINERGY_T2=m
    CONFIG_DVB_USB_ANYSEE=m
    CONFIG_DVB_USB_DTV5100=m
    CONFIG_DVB_USB_AF9015=m
    CONFIG_DVB_SIANO_SMS1XXX=m
    CONFIG_DVB_SIANO_SMS1XXX_SMS_IDS=y
    # Supported FlexCopII (B2C2) Adapters
    CONFIG_DVB_B2C2_FLEXCOP=m
    CONFIG_DVB_B2C2_FLEXCOP_USB=m
    # CONFIG_DVB_B2C2_FLEXCOP_DEBUG is not set
    # Supported DVB Frontends
    # Customise DVB Frontends
    # CONFIG_DVB_FE_CUSTOMISE is not set
    # Multistandard (satellite) frontends
    CONFIG_DVB_STB0899=m
    CONFIG_DVB_STB6100=m
    # DVB-S (satellite) frontends
    CONFIG_DVB_CX24110=m
    CONFIG_DVB_CX24123=m
    CONFIG_DVB_MT312=m
    CONFIG_DVB_S5H1420=m
    CONFIG_DVB_STV0288=m
    CONFIG_DVB_STB6000=m
    CONFIG_DVB_STV0299=m
    CONFIG_DVB_TDA8083=m
    CONFIG_DVB_TDA10086=m
    CONFIG_DVB_TDA8261=m
    CONFIG_DVB_VES1X93=m
    CONFIG_DVB_TUNER_ITD1000=m
    CONFIG_DVB_TUNER_CX24113=m
    CONFIG_DVB_TDA826X=m
    CONFIG_DVB_TUA6100=m
    CONFIG_DVB_CX24116=m
    CONFIG_DVB_SI21XX=m
    # DVB-T (terrestrial) frontends
    CONFIG_DVB_SP8870=m
    CONFIG_DVB_SP887X=m
    CONFIG_DVB_CX22700=m
    CONFIG_DVB_CX22702=m
    CONFIG_DVB_DRX397XD=m
    CONFIG_DVB_L64781=m
    CONFIG_DVB_TDA1004X=m
    CONFIG_DVB_NXT6000=m
    CONFIG_DVB_MT352=m
    CONFIG_DVB_ZL10353=m
    CONFIG_DVB_DIB3000MB=m
    CONFIG_DVB_DIB3000MC=m
    CONFIG_DVB_DIB7000M=m
    CONFIG_DVB_DIB7000P=m
    CONFIG_DVB_TDA10048=m
    # DVB-C (cable) frontends
    CONFIG_DVB_VES1820=m
    CONFIG_DVB_TDA10021=m
    CONFIG_DVB_TDA10023=m
    CONFIG_DVB_STV0297=m
    # ATSC (North American/Korean Terrestrial/Cable DTV) frontends
    CONFIG_DVB_NXT200X=m
    CONFIG_DVB_OR51211=m
    CONFIG_DVB_OR51132=m
    CONFIG_DVB_BCM3510=m
    CONFIG_DVB_LGDT330X=m
    CONFIG_DVB_LGDT3304=m
    CONFIG_DVB_S5H1409=m
    CONFIG_DVB_AU8522=m
    CONFIG_DVB_S5H1411=m
    # ISDB-T (terrestrial) frontends
    CONFIG_DVB_S921=m
    # Digital terrestrial only tuners/PLL
    CONFIG_DVB_PLL=m
    CONFIG_DVB_TUNER_DIB0070=m
    # SEC control devices for DVB-S
    CONFIG_DVB_LNBP21=m
    # CONFIG_DVB_ISL6405 is not set
    CONFIG_DVB_ISL6421=m
    CONFIG_DVB_LGS8GL5=m
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    CONFIG_DVB_AF9013=m
    # CONFIG_DAB is not set
    # Graphics support
    # CONFIG_VGASTATE is not set
    # CONFIG_VIDEO_OUTPUT_CONTROL is not set
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
    # CONFIG_FB_SYS_FILLRECT is not set
    # CONFIG_FB_SYS_COPYAREA is not set
    # CONFIG_FB_SYS_IMAGEBLIT is not set
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    # CONFIG_FB_SYS_FOPS is not set
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    # CONFIG_FB_MODE_HELPERS is not set
    # CONFIG_FB_TILEBLITTING is not set
    # Frame buffer hardware drivers
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_OMAP_BOOTLOADER_INIT is not set
    CONFIG_OMAP2_DSS=y
    CONFIG_OMAP2_DSS_VRAM_SIZE=14
    CONFIG_OMAP2_DSS_DEBUG_SUPPORT=y
    # CONFIG_OMAP2_DSS_RFBI is not set
    CONFIG_OMAP2_DSS_VENC=y
    # CONFIG_OMAP2_DSS_SDI is not set
    CONFIG_OMAP2_DSS_DSI=y
    CONFIG_OMAP2_DSS_USE_DSI_PLL=y
    # CONFIG_OMAP2_DSS_FAKE_VSYNC is not set
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=1
    # OMAP2/3 Display Device Drivers
    CONFIG_PANEL_GENERIC=y
    CONFIG_PANEL_SAMSUNG_LTE430WQ_F0C=m
    # CONFIG_PANEL_SHARP_LS037V7DW01 is not set
    # CONFIG_PANEL_N800 is not set
    # CONFIG_CTRL_BLIZZARD is not set
    CONFIG_FB_OMAP2=y
    CONFIG_FB_OMAP2_DEBUG_SUPPORT=y
    # CONFIG_FB_OMAP2_FORCE_AUTO_UPDATE is not set
    CONFIG_FB_OMAP2_NUM_FBS=3
    # CONFIG_BACKLIGHT_LCD_SUPPORT is not set
    # Display device support
    CONFIG_DISPLAY_SUPPORT=y
    # Display hardware drivers
    # Console display driver support
    # CONFIG_VGA_CONSOLE is not set
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
    CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
    # CONFIG_FONTS is not set
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    CONFIG_LOGO=y
    CONFIG_LOGO_LINUX_MONO=y
    CONFIG_LOGO_LINUX_VGA16=y
    CONFIG_LOGO_LINUX_CLUT224=y
    CONFIG_SOUND=y
    CONFIG_SOUND_OSS_CORE=y
    CONFIG_SND=y
    CONFIG_SND_TIMER=y
    CONFIG_SND_PCM=y
    CONFIG_SND_HWDEP=y
    CONFIG_SND_RAWMIDI=y
    CONFIG_SND_SEQUENCER=m
    # CONFIG_SND_SEQ_DUMMY is not set
    CONFIG_SND_OSSEMUL=y
    CONFIG_SND_MIXER_OSS=y
    CONFIG_SND_PCM_OSS=y
    CONFIG_SND_PCM_OSS_PLUGINS=y
    CONFIG_SND_SEQUENCER_OSS=y
    CONFIG_SND_HRTIMER=m
    CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    # CONFIG_SND_DEBUG is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_VIRMIDI is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    # CONFIG_SND_ARM is not set
    CONFIG_SND_SPI=y
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=y
    CONFIG_SND_USB_CAIAQ=m
    CONFIG_SND_USB_CAIAQ_INPUT=y
    CONFIG_SND_SOC=y
    CONFIG_SND_OMAP_SOC=y
    CONFIG_SND_OMAP_SOC_MCBSP=y
    # CONFIG_SND_OMAP_SOC_OVERO is not set
    CONFIG_SND_OMAP_SOC_OMAP3_BEAGLE=y
    CONFIG_SND_SOC_I2C_AND_SPI=y
    # CONFIG_SND_SOC_ALL_CODECS is not set
    CONFIG_SND_SOC_TWL4030=y
    # CONFIG_SOUND_PRIME is not set
    CONFIG_HID_SUPPORT=y
    CONFIG_HID=y
    CONFIG_HID_DEBUG=y
    # CONFIG_HIDRAW is not set
    # USB Input Devices
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # Special HID drivers
    CONFIG_HID_COMPAT=y
    CONFIG_HID_A4TECH=y
    CONFIG_HID_APPLE=y
    CONFIG_HID_BELKIN=y
    CONFIG_HID_CHERRY=y
    CONFIG_HID_CHICONY=y
    CONFIG_HID_CYPRESS=y
    CONFIG_HID_EZKEY=y
    CONFIG_HID_GYRATION=y
    CONFIG_HID_LOGITECH=y
    # CONFIG_LOGITECH_FF is not set
    # CONFIG_LOGIRUMBLEPAD2_FF is not set
    CONFIG_HID_MICROSOFT=y
    CONFIG_HID_MONTEREY=y
    CONFIG_HID_NTRIG=y
    CONFIG_HID_PANTHERLORD=y
    # CONFIG_PANTHERLORD_FF is not set
    CONFIG_HID_PETALYNX=y
    CONFIG_HID_SAMSUNG=y
    CONFIG_HID_SONY=y
    CONFIG_HID_SUNPLUS=y
    CONFIG_GREENASIA_FF=y
    CONFIG_HID_TOPSEED=y
    # CONFIG_THRUSTMASTER_FF is not set
    # CONFIG_ZEROPLUS_FF is not set
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB_ARCH_HAS_OHCI=y
    CONFIG_USB_ARCH_HAS_EHCI=y
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
    # Miscellaneous USB options
    CONFIG_USB_DEVICEFS=y
    CONFIG_USB_DEVICE_CLASS=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_SUSPEND=y
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    CONFIG_USB_MON=y
    # CONFIG_USB_WUSB is not set
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_EHCI_HCD=y
    CONFIG_OMAP_EHCI_PHY_MODE=y
    # CONFIG_OMAP_EHCI_TLL_MODE is not set
    CONFIG_USB_EHCI_ROOT_HUB_TT=y
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    CONFIG_USB_OXU210HP_HCD=y
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_U132_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HWA_HCD is not set
    CONFIG_USB_MUSB_HDRC=y
    CONFIG_USB_MUSB_SOC=y
    # OMAP 343x high speed USB support
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_PERIPHERAL is not set
    CONFIG_USB_MUSB_OTG=y
    CONFIG_USB_GADGET_MUSB_HDRC=y
    CONFIG_USB_MUSB_HDRC_HCD=y
    # CONFIG_MUSB_PIO_ONLY is not set
    CONFIG_USB_INVENTRA_DMA=y
    # CONFIG_USB_TI_CPPI_DMA is not set
    # CONFIG_USB_MUSB_DEBUG is not set
    # USB Device Class drivers
    CONFIG_USB_ACM=m
    CONFIG_USB_PRINTER=m
    CONFIG_USB_WDM=m
    CONFIG_USB_TMC=m
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may also be needed;
    # see USB_STORAGE Help for more information
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_LIBUSUAL is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # USB port drivers
    CONFIG_USB_SERIAL=m
    CONFIG_USB_EZUSB=y
    CONFIG_USB_SERIAL_GENERIC=y
    CONFIG_USB_SERIAL_AIRCABLE=m
    CONFIG_USB_SERIAL_ARK3116=m
    CONFIG_USB_SERIAL_BELKIN=m
    CONFIG_USB_SERIAL_CH341=m
    CONFIG_USB_SERIAL_WHITEHEAT=m
    CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
    CONFIG_USB_SERIAL_CP2101=m
    CONFIG_USB_SERIAL_CYPRESS_M8=m
    CONFIG_USB_SERIAL_EMPEG=m
    CONFIG_USB_SERIAL_FTDI_SIO=m
    CONFIG_USB_SERIAL_FUNSOFT=m
    CONFIG_USB_SERIAL_VISOR=m
    CONFIG_USB_SERIAL_IPAQ=m
    CONFIG_USB_SERIAL_IR=m
    CONFIG_USB_SERIAL_EDGEPORT=m
    CONFIG_USB_SERIAL_EDGEPORT_TI=m
    CONFIG_USB_SERIAL_GARMIN=m
    CONFIG_USB_SERIAL_IPW=m
    CONFIG_USB_SERIAL_IUU=m
    CONFIG_USB_SERIAL_KEYSPAN_PDA=m
    CONFIG_USB_SERIAL_KEYSPAN=m
    CONFIG_USB_SERIAL_KEYSPAN_MPR=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28X=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28XA=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28XB=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19=y
    CONFIG_USB_SERIAL_KEYSPAN_USA18X=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19W=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19QW=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19QI=y
    CONFIG_USB_SERIAL_KEYSPAN_USA49W=y
    CONFIG_USB_SERIAL_KEYSPAN_USA49WLC=y
    CONFIG_USB_SERIAL_KLSI=m
    CONFIG_USB_SERIAL_KOBIL_SCT=m
    CONFIG_USB_SERIAL_MCT_U232=m
    CONFIG_USB_SERIAL_MOS7720=m
    CONFIG_USB_SERIAL_MOS7840=m
    CONFIG_USB_SERIAL_MOTOROLA=m
    CONFIG_USB_SERIAL_NAVMAN=m
    CONFIG_USB_SERIAL_PL2303=m
    CONFIG_USB_SERIAL_OTI6858=m
    CONFIG_USB_SERIAL_SPCP8X5=m
    CONFIG_USB_SERIAL_HP4X=m
    CONFIG_USB_SERIAL_SAFE=m
    # CONFIG_USB_SERIAL_SAFE_PADDED is not set
    CONFIG_USB_SERIAL_SIEMENS_MPI=m
    CONFIG_USB_SERIAL_SIERRAWIRELESS=m
    CONFIG_USB_SERIAL_TI=m
    CONFIG_USB_SERIAL_CYBERJACK=m
    CONFIG_USB_SERIAL_XIRCOM=m
    CONFIG_USB_SERIAL_OPTION=m
    CONFIG_USB_SERIAL_OMNINET=m
    CONFIG_USB_SERIAL_OPTICON=m
    CONFIG_USB_SERIAL_DEBUG=m
    # USB Miscellaneous drivers
    CONFIG_USB_EMI62=m
    CONFIG_USB_EMI26=m
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    CONFIG_USB_LEGOTOWER=m
    CONFIG_USB_LCD=m
    CONFIG_USB_BERRY_CHARGE=m
    CONFIG_USB_LED=m
    CONFIG_USB_CYPRESS_CY7C63=m
    CONFIG_USB_CYTHERM=m
    CONFIG_USB_PHIDGET=m
    CONFIG_USB_PHIDGETKIT=m
    CONFIG_USB_PHIDGETMOTORCONTROL=m
    CONFIG_USB_PHIDGETSERVO=m
    CONFIG_USB_IDMOUSE=m
    CONFIG_USB_FTDI_ELAN=m
    # CONFIG_USB_APPLEDISPLAY is not set
    CONFIG_USB_SISUSBVGA=m
    CONFIG_USB_SISUSBVGA_CON=y
    CONFIG_USB_LD=m
    CONFIG_USB_TRANCEVIBRATOR=m
    # CONFIG_USB_IOWARRIOR is not set
    CONFIG_USB_TEST=m
    # CONFIG_USB_ISIGHTFW is not set
    CONFIG_USB_VST=m
    CONFIG_USB_ATM=m
    CONFIG_USB_SPEEDTOUCH=m
    CONFIG_USB_CXACRU=m
    CONFIG_USB_UEAGLEATM=m
    CONFIG_USB_XUSBATM=m
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    CONFIG_USB_GADGET_DEBUG_FS=y
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_SELECTED=y
    # CONFIG_USB_GADGET_AT91 is not set
    # CONFIG_USB_GADGET_ATMEL_USBA is not set
    # CONFIG_USB_GADGET_FSL_USB2 is not set
    # CONFIG_USB_GADGET_LH7A40X is not set
    # CONFIG_USB_GADGET_OMAP is not set
    # CONFIG_USB_GADGET_PXA25X is not set
    # CONFIG_USB_GADGET_PXA27X is not set
    # CONFIG_USB_GADGET_S3C2410 is not set
    # CONFIG_USB_GADGET_IMX is not set
    # CONFIG_USB_GADGET_M66592 is not set
    # CONFIG_USB_GADGET_AMD5536UDC is not set
    # CONFIG_USB_GADGET_FSL_QE is not set
    # CONFIG_USB_GADGET_CI13XXX is not set
    # CONFIG_USB_GADGET_NET2280 is not set
    # CONFIG_USB_GADGET_GOKU is not set
    # CONFIG_USB_GADGET_DUMMY_HCD is not set
    CONFIG_USB_GADGET_DUALSPEED=y
    CONFIG_USB_ZERO=m
    CONFIG_USB_ZERO_HNPTEST=y
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    CONFIG_USB_GADGETFS=m
    CONFIG_USB_FILE_STORAGE=m
    # CONFIG_USB_FILE_STORAGE_TEST is not set
    CONFIG_USB_G_SERIAL=m
    CONFIG_USB_MIDI_GADGET=m
    CONFIG_USB_G_PRINTER=m
    CONFIG_USB_CDC_COMPOSITE=m
    # OTG and related infrastructure
    CONFIG_USB_OTG_UTILS=y
    CONFIG_USB_GPIO_VBUS=y
    # CONFIG_ISP1301_OMAP is not set
    CONFIG_TWL4030_USB=y
    # CONFIG_NOP_USB_XCEIV is not set
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    CONFIG_MMC_UNSAFE_RESUME=y
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_BOUNCE=y
    CONFIG_SDIO_UART=y
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    CONFIG_MMC_OMAP_HS=y
    CONFIG_MMC_SPI=m
    # CONFIG_MEMSTICK is not set
    # CONFIG_ACCESSIBILITY is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # LED drivers
    # CONFIG_LEDS_OMAP_DEBUG is not set
    CONFIG_LEDS_OMAP=y
    # CONFIG_LEDS_OMAP_PWM is not set
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=y
    # CONFIG_LEDS_LP5521 is not set
    # CONFIG_LEDS_PCA955X is not set
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=m
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    CONFIG_LEDS_TRIGGER_BACKLIGHT=m
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=m
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    CONFIG_RTC_DRV_DS1307=y
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    CONFIG_RTC_DRV_TWL4030=m
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # on-CPU RTC drivers
    # CONFIG_DMADEVICES is not set
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    # CONFIG_REGULATOR_FIXED_VOLTAGE is not set
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_BQ24022 is not set
    CONFIG_REGULATOR_TWL4030=y
    CONFIG_UIO=m
    CONFIG_UIO_PDRV=m
    CONFIG_UIO_PDRV_GENIRQ=m
    # CONFIG_UIO_SMX is not set
    # CONFIG_UIO_SERCOS3 is not set
    CONFIG_STAGING=y
    # CONFIG_STAGING_EXCLUDE_BUILD is not set
    # CONFIG_MEILHAUS is not set
    # CONFIG_USB_IP_COMMON is not set
    CONFIG_W35UND=m
    CONFIG_PRISM2_USB=m
    # CONFIG_ECHO is not set
    CONFIG_USB_ATMEL=m
    # CONFIG_AGNX is not set
    CONFIG_OTUS=m
    # CONFIG_COMEDI is not set
    # CONFIG_ASUS_OLED is not set
    # CONFIG_INPUT_MIMIO is not set
    # CONFIG_TRANZPORT is not set
    # Android
    CONFIG_ANDROID=y
    CONFIG_ANDROID_BINDER_IPC=y
    CONFIG_ANDROID_LOGGER=m
    CONFIG_ANDROID_RAM_CONSOLE=y
    CONFIG_ANDROID_RAM_CONSOLE_ENABLE_VERBOSE=y
    # CONFIG_ANDROID_RAM_CONSOLE_ERROR_CORRECTION is not set
    # CONFIG_ANDROID_RAM_CONSOLE_EARLY_INIT is not set
    CONFIG_ANDROID_TIMED_GPIO=m
    CONFIG_ANDROID_LOW_MEMORY_KILLER=y
    CONFIG_BMI=y
    # BMI Hardware Slot support
    CONFIG_OMAP_SLOT=m
    CONFIG_BMI_PIMS=m
    # BMI PIMS
    # CONFIG_BUG_FACTORY_TEST is not set
    CONFIG_BMI_GPS=m
    CONFIG_BMI_MDACC=m
    # CONFIG_BMI_AUDIO is not set
    CONFIG_BMI_VH=m
    # CONFIG_BMI_SENSOR is not set
    # CONFIG_BMI_ZB is not set
    CONFIG_BMI_GSM=m
    # CBUS support
    # CONFIG_CBUS is not set
    # File systems
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    # CONFIG_EXT2_FS_XIP is not set
    CONFIG_EXT3_FS=y
    # CONFIG_EXT3_FS_XATTR is not set
    CONFIG_EXT4_FS=m
    # CONFIG_EXT4DEV_COMPAT is not set
    CONFIG_EXT4_FS_XATTR=y
    # CONFIG_EXT4_FS_POSIX_ACL is not set
    # CONFIG_EXT4_FS_SECURITY is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_JBD2=m
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=m
    CONFIG_REISERFS_FS=m
    # CONFIG_REISERFS_CHECK is not set
    CONFIG_REISERFS_PROC_INFO=y
    CONFIG_REISERFS_FS_XATTR=y
    # CONFIG_REISERFS_FS_POSIX_ACL is not set
    # CONFIG_REISERFS_FS_SECURITY is not set
    CONFIG_JFS_FS=m
    # CONFIG_JFS_POSIX_ACL is not set
    # CONFIG_JFS_SECURITY is not set
    # CONFIG_JFS_DEBUG is not set
    # CONFIG_JFS_STATISTICS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_FILE_LOCKING=y
    CONFIG_XFS_FS=m
    # CONFIG_XFS_QUOTA is not set
    # CONFIG_XFS_POSIX_ACL is not set
    # CONFIG_XFS_RT is not set
    # CONFIG_XFS_DEBUG is not set
    CONFIG_GFS2_FS=m
    CONFIG_GFS2_FS_LOCKING_DLM=m
    CONFIG_OCFS2_FS=m
    CONFIG_OCFS2_FS_O2CB=m
    CONFIG_OCFS2_FS_USERSPACE_CLUSTER=m
    CONFIG_OCFS2_FS_STATS=y
    CONFIG_OCFS2_DEBUG_MASKLOG=y
    # CONFIG_OCFS2_DEBUG_FS is not set
    # CONFIG_OCFS2_FS_POSIX_ACL is not set
    CONFIG_BTRFS_FS=m
    # CONFIG_BTRFS_FS_POSIX_ACL is not set
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY=y
    CONFIG_INOTIFY_USER=y
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    CONFIG_QUOTA_TREE=y
    # CONFIG_QFMT_V1 is not set
    CONFIG_QFMT_V2=y
    CONFIG_QUOTACTL=y
    # CONFIG_AUTOFS_FS is not set
    CONFIG_AUTOFS4_FS=m
    CONFIG_FUSE_FS=m
    # CD-ROM/DVD Filesystems
    CONFIG_ISO9660_FS=m
    CONFIG_JOLIET=y
    CONFIG_ZISOFS=y
    CONFIG_UDF_FS=m
    CONFIG_UDF_NLS=y
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    CONFIG_NTFS_FS=m
    # CONFIG_NTFS_DEBUG is not set
    CONFIG_NTFS_RW=y
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    # CONFIG_TMPFS_POSIX_ACL is not set
    # CONFIG_HUGETLB_PAGE is not set
    CONFIG_CONFIGFS_FS=m
    CONFIG_MISC_FILESYSTEMS=y
    CONFIG_ADFS_FS=m
    # CONFIG_ADFS_FS_RW is not set
    CONFIG_AFFS_FS=m
    # CONFIG_ECRYPT_FS is not set
    CONFIG_HFS_FS=m
    CONFIG_HFSPLUS_FS=m
    CONFIG_BEFS_FS=m
    # CONFIG_BEFS_DEBUG is not set
    CONFIG_BFS_FS=m
    CONFIG_EFS_FS=m
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    CONFIG_JFFS2_FS_XATTR=y
    CONFIG_JFFS2_FS_POSIX_ACL=y
    CONFIG_JFFS2_FS_SECURITY=y
    CONFIG_JFFS2_COMPRESSION_OPTIONS=y
    CONFIG_JFFS2_ZLIB=y
    CONFIG_JFFS2_LZO=y
    CONFIG_JFFS2_RTIME=y
    CONFIG_JFFS2_RUBIN=y
    # CONFIG_JFFS2_CMODE_NONE is not set
    # CONFIG_JFFS2_CMODE_PRIORITY is not set
    # CONFIG_JFFS2_CMODE_SIZE is not set
    CONFIG_JFFS2_CMODE_FAVOURLZO=y
    CONFIG_UBIFS_FS=y
    CONFIG_UBIFS_FS_XATTR=y
    CONFIG_UBIFS_FS_ADVANCED_COMPR=y
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    # CONFIG_UBIFS_FS_DEBUG is not set
    CONFIG_CRAMFS=m
    CONFIG_SQUASHFS=y
    # CONFIG_SQUASHFS_EMBEDDED is not set
    CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
    CONFIG_VXFS_FS=m
    CONFIG_MINIX_FS=m
    CONFIG_OMFS_FS=m
    CONFIG_HPFS_FS=m
    CONFIG_QNX4FS_FS=m
    CONFIG_ROMFS_FS=m
    CONFIG_SYSV_FS=m
    CONFIG_UFS_FS=m
    # CONFIG_UFS_FS_WRITE is not set
    # CONFIG_UFS_DEBUG is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V3=y
    # CONFIG_NFS_V3_ACL is not set
    CONFIG_NFS_V4=y
    CONFIG_ROOT_NFS=y
    CONFIG_NFSD=m
    CONFIG_NFSD_V2_ACL=y
    CONFIG_NFSD_V3=y
    CONFIG_NFSD_V3_ACL=y
    CONFIG_NFSD_V4=y
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_EXPORTFS=m
    CONFIG_NFS_ACL_SUPPORT=m
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    # CONFIG_SUNRPC_REGISTER_V4 is not set
    CONFIG_RPCSEC_GSS_KRB5=y
    # CONFIG_RPCSEC_GSS_SPKM3 is not set
    CONFIG_SMB_FS=m
    # CONFIG_SMB_NLS_DEFAULT is not set
    CONFIG_CIFS=m
    CONFIG_CIFS_STATS=y
    CONFIG_CIFS_STATS2=y
    # CONFIG_CIFS_WEAK_PW_HASH is not set
    # CONFIG_CIFS_UPCALL is not set
    # CONFIG_CIFS_XATTR is not set
    # CONFIG_CIFS_DEBUG2 is not set
    CONFIG_CIFS_EXPERIMENTAL=y
    # CONFIG_CIFS_DFS_UPCALL is not set
    CONFIG_NCP_FS=m
    # CONFIG_NCPFS_PACKET_SIGNING is not set
    # CONFIG_NCPFS_IOCTL_LOCKING is not set
    # CONFIG_NCPFS_STRONG is not set
    # CONFIG_NCPFS_NFS_NS is not set
    # CONFIG_NCPFS_OS2_NS is not set
    # CONFIG_NCPFS_SMALLDOS is not set
    # CONFIG_NCPFS_NLS is not set
    # CONFIG_NCPFS_EXTRAS is not set
    CONFIG_CODA_FS=m
    CONFIG_AFS_FS=m
    # CONFIG_AFS_DEBUG is not set
    CONFIG_9P_FS=m
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    CONFIG_MAC_PARTITION=y
    CONFIG_MSDOS_PARTITION=y
    CONFIG_BSD_DISKLABEL=y
    CONFIG_MINIX_SUBPARTITION=y
    CONFIG_SOLARIS_X86_PARTITION=y
    CONFIG_UNIXWARE_DISKLABEL=y
    CONFIG_LDM_PARTITION=y
    CONFIG_LDM_DEBUG=y
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    CONFIG_NLS_CODEPAGE_737=m
    CONFIG_NLS_CODEPAGE_775=m
    CONFIG_NLS_CODEPAGE_850=m
    CONFIG_NLS_CODEPAGE_852=m
    CONFIG_NLS_CODEPAGE_855=m
    CONFIG_NLS_CODEPAGE_857=m
    CONFIG_NLS_CODEPAGE_860=m
    CONFIG_NLS_CODEPAGE_861=m
    CONFIG_NLS_CODEPAGE_862=m
    CONFIG_NLS_CODEPAGE_863=m
    CONFIG_NLS_CODEPAGE_864=m
    CONFIG_NLS_CODEPAGE_865=m
    CONFIG_NLS_CODEPAGE_866=m
    CONFIG_NLS_CODEPAGE_869=m
    CONFIG_NLS_CODEPAGE_936=m
    CONFIG_NLS_CODEPAGE_950=m
    CONFIG_NLS_CODEPAGE_932=m
    CONFIG_NLS_CODEPAGE_949=m
    CONFIG_NLS_CODEPAGE_874=m
    CONFIG_NLS_ISO8859_8=m
    CONFIG_NLS_CODEPAGE_1250=m
    CONFIG_NLS_CODEPAGE_1251=m
    CONFIG_NLS_ASCII=m
    CONFIG_NLS_ISO8859_1=m
    CONFIG_NLS_ISO8859_2=m
    CONFIG_NLS_ISO8859_3=m
    CONFIG_NLS_ISO8859_4=m
    CONFIG_NLS_ISO8859_5=m
    CONFIG_NLS_ISO8859_6=m
    CONFIG_NLS_ISO8859_7=m
    CONFIG_NLS_ISO8859_9=m
    CONFIG_NLS_ISO8859_13=m
    CONFIG_NLS_ISO8859_14=m
    CONFIG_NLS_ISO8859_15=m
    CONFIG_NLS_KOI8_R=m
    CONFIG_NLS_KOI8_U=m
    CONFIG_NLS_UTF8=y
    CONFIG_DLM=m
    # CONFIG_DLM_DEBUG is not set
    # Kernel hacking
    CONFIG_PRINTK_TIME=y
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    CONFIG_MAGIC_SYSRQ=y
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    CONFIG_DEBUG_KERNEL=y
    # CONFIG_DEBUG_SHIRQ is not set
    CONFIG_DETECT_SOFTLOCKUP=y
    # CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set
    CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0
    CONFIG_SCHED_DEBUG=y
    CONFIG_SCHEDSTATS=y
    CONFIG_TIMER_STATS=y
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_DEBUG_SLAB is not set
    CONFIG_DEBUG_PREEMPT=y
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    CONFIG_DEBUG_MUTEXES=y
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_SPINLOCK_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    CONFIG_STACKTRACE=y
    # CONFIG_DEBUG_KOBJECT is not set
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    CONFIG_FRAME_POINTER=y
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_CPU_STALL_DETECTOR is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_FAULT_INJECTION is not set
    # CONFIG_LATENCYTOP is not set
    CONFIG_NOP_TRACER=y
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_RING_BUFFER=y
    CONFIG_TRACING=y
    # Tracers
    # CONFIG_FUNCTION_TRACER is not set
    # CONFIG_IRQSOFF_TRACER is not set
    # CONFIG_PREEMPT_TRACER is not set
    # CONFIG_SCHED_TRACER is not set
    # CONFIG_CONTEXT_SWITCH_TRACER is not set
    # CONFIG_BOOT_TRACER is not set
    # CONFIG_TRACE_BRANCH_PROFILING is not set
    # CONFIG_STACK_TRACER is not set
    # CONFIG_FTRACE_STARTUP_TEST is not set
    # CONFIG_DYNAMIC_PRINTK_DEBUG is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_ERRORS is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_LL is not set
    # Security options
    CONFIG_KEYS=y
    # CONFIG_KEYS_DEBUG_PROC_KEYS is not set
    # CONFIG_SECURITY is not set
    # CONFIG_SECURITYFS is not set
    # CONFIG_SECURITY_FILE_CAPABILITIES is not set
    CONFIG_XOR_BLOCKS=m
    CONFIG_ASYNC_CORE=m
    CONFIG_ASYNC_MEMCPY=m
    CONFIG_ASYNC_XOR=m
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_FIPS=y
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=m
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_BLKCIPHER=y
    CONFIG_CRYPTO_BLKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    CONFIG_CRYPTO_GF128MUL=m
    CONFIG_CRYPTO_NULL=m
    CONFIG_CRYPTO_CRYPTD=m
    CONFIG_CRYPTO_AUTHENC=m
    CONFIG_CRYPTO_TEST=m
    # Authenticated Encryption with Associated Data
    CONFIG_CRYPTO_CCM=m
    CONFIG_CRYPTO_GCM=m
    CONFIG_CRYPTO_SEQIV=m
    # Block modes
    CONFIG_CRYPTO_CBC=y
    CONFIG_CRYPTO_CTR=m
    CONFIG_CRYPTO_CTS=m
    CONFIG_CRYPTO_ECB=y
    CONFIG_CRYPTO_LRW=m
    CONFIG_CRYPTO_PCBC=m
    CONFIG_CRYPTO_XTS=m
    # Hash modes
    CONFIG_CRYPTO_HMAC=m
    CONFIG_CRYPTO_XCBC=m
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    CONFIG_CRYPTO_MD4=m
    CONFIG_CRYPTO_MD5=y
    CONFIG_CRYPTO_MICHAEL_MIC=y
    CONFIG_CRYPTO_RMD128=m
    CONFIG_CRYPTO_RMD160=m
    CONFIG_CRYPTO_RMD256=m
    CONFIG_CRYPTO_RMD320=m
    CONFIG_CRYPTO_SHA1=m
    CONFIG_CRYPTO_SHA256=m
    CONFIG_CRYPTO_SHA512=m
    CONFIG_CRYPTO_TGR192=m
    CONFIG_CRYPTO_WP512=m
    # Ciphers
    CONFIG_CRYPTO_AES=y
    CONFIG_CRYPTO_ANUBIS=m
    CONFIG_CRYPTO_ARC4=y
    CONFIG_CRYPTO_BLOWFISH=m
    CONFIG_CRYPTO_CAMELLIA=m
    CONFIG_CRYPTO_CAST5=m
    CONFIG_CRYPTO_CAST6=m
    CONFIG_CRYPTO_DES=y
    CONFIG_CRYPTO_FCRYPT=m
    CONFIG_CRYPTO_KHAZAD=m
    CONFIG_CRYPTO_SALSA20=m
    CONFIG_CRYPTO_SEED=m
    CONFIG_CRYPTO_SERPENT=m
    CONFIG_CRYPTO_TEA=m
    CONFIG_CRYPTO_TWOFISH=m
    CONFIG_CRYPTO_TWOFISH_COMMON=m
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    CONFIG_CRYPTO_LZO=y
    # Random Number Generation
    CONFIG_CRYPTO_ANSI_CPRNG=m
    CONFIG_CRYPTO_HW=y
    # Library routines
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_FIND_LAST_BIT=y
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=y
    CONFIG_CRC_ITU_T=y
    CONFIG_CRC32=y
    CONFIG_CRC7=y
    CONFIG_LIBCRC32C=y
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    CONFIG_TEXTSEARCH=y
    CONFIG_TEXTSEARCH_KMP=m
    CONFIG_TEXTSEARCH_BM=m
    CONFIG_TEXTSEARCH_FSM=m
    CONFIG_PLIST=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
     the boot log:
    Uncompressing Linux.............................................................................................
    [    0.000000] Linux version 2.6.29-omap1 (root@carl) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PR0
    [    0.000000] CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=10c5387f
    [    0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
    [    0.000000] Machine: OMAP3 Beagle Board
    [    0.000000] Memory policy: ECC disabled, Data cache writeback
    [    0.000000] OMAP3430 ES2.1
    [    0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
    [    0.000000] Reserving 25165824 bytes SDRAM for VRAM
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 50800
    [    0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p2 rootfstype=ext3 rw rootwait vramM
    [    0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
    [    0.000000] GPMC revision 5.0
    [    0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
    [    0.000000] Total of 96 interrupts on 1 active controller
    [    0.000000] OMAP34xx GPIO hardware version 2.5
    [    0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
    [    0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
    [    0.000000] Console: colour dummy device 80x30
    [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    [    0.000000] Memory: 200MB = 200MB total
    [    0.000000] Memory: 171776KB available (5588K code, 576K data, 196K init)
    [    0.000000] Calibrating delay loop... 503.12 BogoMIPS (lpj=1966080)
    [    0.000000] Mount-cache hash table entries: 512
    [    0.000000] CPU: Testing write buffer coherency: ok
    [    0.000000] net_namespace: 1036 bytes
    [    0.000000] regulator: core version 0.5
    [    0.000000] NET: Registered protocol family 16
    [    0.000000] GPIO-156 autorequested
    [    0.000000] GPIO-159 autorequested
    [    0.000000] Found NAND on CS0
    [    0.000000] Registering NAND on CS0
    [   21.210388] OMAP DMA hardware revision 4.0
    [   21.258056] bio: create slab <bio-0> at 0
    [   21.317993] OMAP DSS rev 2.0
    [   21.318145] OMAP DISPC rev 3.0
    [   21.318145] OMAP VENC rev 2
    [   21.318328] OMAP DSI rev 1.0
    [   21.321594] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
    [   21.325744] twl4030: PIH (irq 7) chaining IRQs 368..375
    [   21.325775] twl4030: power (irq 373) chaining IRQs 376..383
    [   21.326446] twl4030: gpio (irq 368) chaining IRQs 384..401
    [   21.329711] regulator: VMMC1: 1850 <--> 3150 mV normal standby
    [   21.330718] regulator: VDAC: 1800 mV normal standby
    [   21.331665] regulator: VUSB1V5: 1500 <--> 0 mV normal standby
    [   21.332641] regulator: VUSB1V8: 1800 <--> 0 mV normal standby
    [   21.333587] regulator: VUSB3V1: 3100 <--> 0 mV normal standby
    [   21.334564] regulator: VPLL2: 1800 mV normal standby
    [   21.335571] regulator: VMMC2: 2800 <--> 3150 mV normal standby
    [   21.336517] regulator: VSIM: 1800 <--> 3000 mV normal standby
    [   21.336761] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
    [   21.337615] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
    [   21.339843] SCSI subsystem initialized
    [   21.342651]
    [   21.342681]  carl: usb mode is:1
    [   21.344085]  carl: twl4030_phy_power---on....
    [   21.346374] carl: the otg-ctrl value:0
    [   21.346405] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
    [   21.347961] usbcore: registered new interface driver usbfs
    [   21.348571] usbcore: registered new interface driver hub
    [   21.349060] usbcore: registered new device driver usb
    [   21.352569] Bluetooth: Core ver 2.14
    [   21.353210] NET: Registered protocol family 31
    [   21.353210] Bluetooth: HCI device and connection manager initialized
    [   21.353240] Bluetooth: HCI socket layer initialized
    [   21.354064] cfg80211: Using static regulatory domain info
    [   21.354095] cfg80211: Regulatory domain: US
    [   21.354095]  (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [   21.354125]  (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
    [   21.354156]  (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
    [   21.354156]  (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
    [   21.354187]  (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
    [   21.354217]  (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
    [   21.354217]  (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
    [   21.354248] cfg80211: Calling CRDA for country: US
    [   21.359375] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
    [   21.359619] carl: ...> musb_hdrc: ConfigData=0x55 (UTMI-16, dyn FIFOs, bulk split (X), HB-ISO Rx)
    [   21.360107] musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
    [   21.361480] NET: Registered protocol family 2
    [   21.361724] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [   21.362396] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [   21.362670] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [   21.362854] TCP: Hash tables configured (established 8192 bind 8192)
    [   21.362884] TCP reno registered
    [   21.363159] NET: Registered protocol family 1
    [   21.367797] VFS: Disk quotas dquot_6.5.2
    [   21.367919] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [   21.368530] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [   21.369354] JFFS2 version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
    [   21.370330] msgmni has been set to 335
    [   21.375457] alg: No test for stdrng (krng)
    [   21.375579] io scheduler noop registered
    [   21.375610] io scheduler anticipatory registered
    [   21.375610] io scheduler deadline registered
    [   21.375854] io scheduler cfq registered (default)
    [   21.402374] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [   21.425689] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
    [   21.448089] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
    [   21.469360] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
    [   21.469421] console [ttyS2] enabled
    [   22.028564] brd: module loaded
    [   22.038574] loop: module loaded
    [   22.042510] enc28j60 spi4.0: enc28j60 Ethernet driver 1.01 loaded
    [   22.063385] net eth0: enc28j60 driver registered
    [   22.068786] usbcore: registered new interface driver catc
    [   22.074279] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
    [   22.080657] usbcore: registered new interface driver kaweth
    [   22.086395] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
    [   22.094299] usbcore: registered new interface driver pegasus
    [   22.100067] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
    [   22.107360] usbcore: registered new interface driver rtl8150
    [   22.113464] usbcore: registered new interface driver asix
    [   22.119262] usbcore: registered new interface driver cdc_ether
    [   22.125488] usbcore: registered new interface driver dm9601
    [   22.131469] usbcore: registered new interface driver smsc95xx
    [   22.137573] usbcore: registered new interface driver gl620a
    [   22.143585] usbcore: registered new interface driver net1080
    [   22.149658] usbcore: registered new interface driver plusb
    [   22.155578] usbcore: registered new interface driver rndis_host
    [   22.161834] usbcore: registered new interface driver cdc_subset
    [   22.168151] usbcore: registered new interface driver zaurus
    [   22.174255] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
    [   22.182098] Broadcom 43xx driver loaded [ Features: L, Firmware-ID: FW13 ]
    [   22.189544] usbcore: registered new interface driver zd1211rw
    [   22.195678] usbcore: registered new interface driver rtl8187
    [   22.201812] usbcore: registered new interface driver rndis_wlan
    [   22.208068] usbcore: registered new interface driver zd1201
    [   22.214111] usbcore: registered new interface driver usb8xxx
    [   22.220245] usbcore: registered new interface driver rt2500usb
    [   22.226531] usbcore: registered new interface driver rt73usb
    [   22.232543] usbcore: registered new interface driver p54usb
    [   22.238220] i2c /dev entries driver
    [   22.243927] Driver 'sd' needs updating - please use bus_type methods
    [   22.250671] Driver 'sr' needs updating - please use bus_type methods
    [   22.258422] omap2-nand driver initializing
    [   22.262847] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit)
    [   22.272033] cmdlinepart partition parsing not available
    [   22.277282] Creating 5 MTD partitions on "omap2-nand":
    [   22.282592] 0x000000000000-0x000000080000 : "X-Loader"
    [   22.290069] 0x000000080000-0x000000260000 : "U-Boot"
    [   22.297424] 0x000000260000-0x000000280000 : "U-Boot Env"
    [   22.304412] 0x000000280000-0x000000680000 : "Kernel"
    [   22.312561] 0x000000680000-0x000020000000 : "File System"
    [   22.539581] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [   22.546691] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
    [   22.553497]  carl: USB bus register.....
    [   22.557495] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
    [   22.565490] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
    [   22.584381] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
    [   22.591033] usb usb1: configuration #1 chosen from 1 choice
    [   22.597198] hub 1-0:1.0: USB hub found
    [   22.601165] hub 1-0:1.0: 3 ports detected
    [   22.607543] Initializing USB Mass Storage driver...
    [   22.613037] usbcore: registered new interface driver usb-storage
    [   22.619201] USB Mass Storage support registered.
    [   22.624664] mice: PS/2 mouse device common for all mice
    [   22.630615] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [   22.640441] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-adapter/i2c-1/1-0049/twl4030_pwrbut1
    [   23.651000] i2c_omap i2c_omap.2: controller timed out
    [   23.656188] rtc-ds1307: probe of 2-0068 failed with error -5
    [   23.664123] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
    [   23.670654] Bluetooth: HCI UART driver ver 2.2
    [   23.675109] Bluetooth: HCI H4 protocol initialized
    [   23.679992] Bluetooth: HCI BCSP protocol initialized
    [   23.684997] Bluetooth: HCILL protocol initialized
    [   23.689788] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
    [   23.696411] usbcore: registered new interface driver bcm203x
    [   23.702209] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
    [   23.708557] usbcore: registered new interface driver bpa10x
    [   23.714263] Bluetooth: BlueFRITZ! USB driver ver 1.2
    [   23.719635] usbcore: registered new interface driver bfusb
    [   23.725250] Bluetooth: Generic Bluetooth USB driver ver 0.4
    [   23.731231] usbcore: registered new interface driver btusb
    [   23.736846] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
    [   23.743804] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
    [   23.857849] mmci-omap-hs mmci-omap-hs.1: Failed to get debounce clock
    [   23.864440] regulator: Unable to get requested regulator: vmmc_aux
    [   23.873687] Registered led device: beagleboard::usr0
    [   23.879089] Registered led device: beagleboard::usr1
    [   23.891876] usbcore: registered new interface driver usbhid
    [   23.897552] usbhid: v2.6:USB HID core driver
    [   23.903198] Advanced Linux Sound Architecture Driver Version 1.0.18a.
    [   23.910797] usbcore: registered new interface driver snd-usb-audio
    [   23.917510] No device for DAI twl4030
    [   23.921386] No device for DAI omap-mcbsp-dai-0
    [   23.925903] No device for DAI omap-mcbsp-dai-1
    [   23.930511] No device for DAI omap-mcbsp-dai-2
    [   23.934997] No device for DAI omap-mcbsp-dai-3
    [   23.939514] No device for DAI omap-mcbsp-dai-4
    [   23.944061] OMAP3 Beagle SoC init
    [   23.947875] TWL4030 Audio Codec init
    [   23.953186] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
    [   23.969787] ALSA device list:
    [   23.972839]   #0: omap3beagle (twl4030)
    [   23.985321] oprofile: using arm/armv7
    [   23.989288] TCP cubic registered
    [   23.992706] NET: Registered protocol family 17
    [   23.997283] NET: Registered protocol family 15
    [   24.001953] Bluetooth: L2CAP ver 2.11
    [   24.005645] Bluetooth: L2CAP socket layer initialized
    [   24.010803] Bluetooth: SCO (Voice Link) ver 0.6
    [   24.015441] Bluetooth: SCO socket layer initialized
    [   24.020538] Bluetooth: RFCOMM socket layer initialized
    [   24.025817] Bluetooth: RFCOMM TTY layer initialized
    [   24.030792] Bluetooth: RFCOMM ver 1.10
    [   24.034637] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   24.040100] Bluetooth: BNEP filters: protocol multicast
    [   24.045410] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [   24.056335] RPC: Registered udp transport module.
    [   24.061157] RPC: Registered tcp transport module.
    [   24.065979] lib80211: common routines for IEEE802.11 drivers
    [   24.071807] ThumbEE CPU extension supported.
    [   24.076110] Power Management for TI OMAP3.
    [   24.089508] Disabling unused clock "sr2_fck"
    [   24.093933] Disabling unused clock "sr1_fck"
    [   24.098236] Disabling unused clock "mcbsp_fck"
    [   24.102752] Disabling unused clock "mcbsp_fck"
    [   24.107238] Disabling unused clock "mcbsp_fck"
    [   24.111785] Disabling unused clock "mcbsp_ick"
    [   24.116302] Disabling unused clock "mcbsp_ick"
    [   24.120758] Disabling unused clock "mcbsp_ick"
    [   24.125305] Disabling unused clock "gpt2_ick"
    [   24.129699] Disabling unused clock "gpt3_ick"
    [   24.134094] Disabling unused clock "gpt4_ick"
    [   24.138519] Disabling unused clock "gpt5_ick"
    [   24.143005] Disabling unused clock "gpt6_ick"
    [   24.147460] Disabling unused clock "gpt7_ick"
    [   24.151885] Disabling unused clock "gpt8_ick"
    [   24.156311] Disabling unused clock "gpt9_ick"
    [   24.160675] Disabling unused clock "wdt3_ick"
    [   24.165130] Disabling unused clock "wdt3_fck"
    [   24.169525] Disabling unused clock "gpio2_dbck"
    [   24.174102] Disabling unused clock "gpio3_dbck"
    [   24.178710] Disabling unused clock "gpio4_dbck"
    [   24.183258] Disabling unused clock "gpio5_dbck"
    [   24.187896] Disabling unused clock "gpio6_dbck"
    [   24.192443] Disabling unused clock "gpt9_fck"
    [   24.196899] Disabling unused clock "gpt8_fck"
    [   24.201293] Disabling unused clock "gpt7_fck"
    [   24.205718] Disabling unused clock "gpt6_fck"
    [   24.210144] Disabling unused clock "gpt5_fck"
    [   24.214569] Disabling unused clock "gpt4_fck"
    [   24.218963] Disabling unused clock "gpt3_fck"
    [   24.223358] Disabling unused clock "gpt2_fck"
    [   24.227783] Disabling unused clock "gpt1_ick"
    [   24.232147] Disabling unused clock "wdt1_ick"
    [   24.236602] Disabling unused clock "wdt2_ick"
    [   24.241058] Disabling unused clock "wdt2_fck"
    [   24.245452] Disabling unused clock "gpio1_dbck"
    [   24.250061] Disabling unused clock "gpt1_fck"
    [   24.254516] Disabling unused clock "cam_ick"
    [   24.258880] Disabling unused clock "cam_mclk"
    [   24.263305] Disabling unused clock "des1_ick"
    [   24.267730] Disabling unused clock "sha11_ick"
    [   24.272247] Disabling unused clock "rng_ick"
    [   24.276550] Disabling unused clock "aes1_ick"
    [   24.281036] Disabling unused clock "ssi_ick"
    [   24.285339] Disabling unused clock "mailboxes_ick"
    [   24.290191] Disabling unused clock "mcbsp_ick"
    [   24.294708] Disabling unused clock "mcbsp_ick"
    [   24.299194] Disabling unused clock "gpt10_ick"
    [   24.303710] Disabling unused clock "gpt11_ick"
    [   24.308227] Disabling unused clock "hdq_ick"
    [   24.312591] Disabling unused clock "mspro_ick"
    [   24.317047] Disabling unused clock "des2_ick"
    [   24.321472] Disabling unused clock "sha12_ick"
    [   24.325958] Disabling unused clock "aes2_ick"
    [   24.330352] Disabling unused clock "icr_ick"
    [   24.334686] Disabling unused clock "pka_ick"
    [   24.338989] Disabling unused clock "ssi_ssr_fck"
    [   24.343750] Disabling unused clock "hdq_fck"
    [   24.348083] Disabling unused clock "mcbsp_fck"
    [   24.352569] Disabling unused clock "mcbsp_fck"
    [   24.357055] Disabling unused clock "mspro_fck"
    [   24.361572] Disabling unused clock "gpt11_fck"
    [   24.366088] Disabling unused clock "gpt10_fck"
    [   24.370574] Disabling unused clock "dpll4_m6x2_ck"
    [   24.375457] Disabling unused clock "dpll3_m3x2_ck"
    [   24.380310] Disabling unused clock "sys_clkout1"
    [   24.385040] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
    [   24.395172] registered taskstats version 1
    [   24.401000] fbcvt: 1024x640@60: CVT Name - .655MA-R
    [   24.529846] mmc0: new high speed SD card at address c992
    [   24.536102] mmcblk0: mmc0:c992 SD02G 1.83 GiB
    [   24.540985]  mmcblk0: p1 p2 p3
    [   24.580566] Console: switching to colour frame buffer device 128x40
    [   24.598999] clock: clksel_round_rate_div: dpll4_m4_ck target_rate 48000000
    [   24.605926] clock: new_div = 9, new_rate = 48000000
    [   24.613555] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
    [   34.234283] kjournald starting.  Commit interval 5 seconds
    [   34.239898] EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
    [   34.254058] EXT3 FS on mmcblk0p2, internal journal
    [   34.258911] EXT3-fs: recovery complete.
    [   34.270446] EXT3-fs: mounted filesystem with ordered data mode.
    [   34.276550] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [   34.282806] Freeing init memory: 196K
    INIT: version 2.86 booting
    Starting udev[   35.249511] udevd version 124 started
    Remounting root file system...
    Unknown HZ value! (37) Assume 100.
    ALSA: Restoring mixer settings...
    Configuring network interfaces... No state is present for card omap3beagle
    /usr/sbin/alsactl: parse:1620: Unable to open file '/usr/share/alsa/init/00main': No such file or directory
    [   43.727691] net eth0: hw_reset() failed
    ifconfig: SIOCSIFFLAGS: Invalid argument
    eth0      no wireless extensions.
    [   43.805877] net eth0: hw_reset() failed
    done.
    Starting portmap daemon: portmap.
    Unknown HZ value! (44) Assume 100.
    net.ipv4.conf.default.rp_filter = 1
    net.ipv4.conf.all.rp_filter = 1
    hwclock: can't open '/dev/misc/rtc': No such file or directory
    Mon Jan 18 11:43:00 GMT 2010
    INIT: Entering runlevel: 5
    Starting Dropbear SSH server: dropbear.
    Starting advanced power management daemon: No APM support in kernel
    (failed.)
    Starting system message bus: dbus.
    Starting Hardware abstraction layer hald
    Starting syslogd/klogd: done
     * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
    [ ok ]
    Starting Connection Manager
    Running ntpdate to synchronize clock[   46.436492] net eth0: hw_reset() failed
    Error : Temporary failure in name resolution
    [   46.738708] PVRSRV_PIXEL_FORMAT_RGB565
    /dev/mem opened.
    Memory mapped at address 0x4001f000.
    Value at address 0x48004B40 (0x4001fb40): 0x0
    Written 0x0; readback 0x0
    |       |     | __  |  ---'| '--.|  .-'|     |     |
    The Angstrom Distribution beagleboard ttyS2
    Angstrom 2009.X-stable beagleboard ttyS2
    beagleboard login:
    carl
  • Hi Carl,
    The Resizer driver has been build as Module,
    So are you inserting the module into kernel?
    Vaibhav
  • Hi Vaibhav,
          Thanks again! When I compiled the RESIZER module into the kernel(must include Video for Linux module,Virtual Video Driver and OMAP 3 Camera support at the same time ), I can found the /dev/omap-resizer and /dev/video , /dev/video0. But when I execute gst , it said open dsp failure , Do them conflict ? following is information:
    gst-launch -v filesrc location=1.264 !
     TIViddec2 codecName=h264dec engineName=codecServer ! TIDmaiVideoSink videoStd=VGA videoOutput=DVI sync=false
     Setting pipeline to PAUSED ...
     Pipeline is PREROLLING ...
     carl---> opening codec engine "codecServer"
    [  498.799652]  DSP_init status [0x80008008]
    [  498.803894] Assertion failed ((isrObj!= NULL) && (ISR_InstalledIsrs [isrObj->dspId][isrObj->irq] == isrObj)). Fi4
    gst-launch-0.10: BufTab.c:440: BufTab_getNumBufs: Assertion `hBufTab' failed.
    ERROR: from element /GstPipeline:pipeline0/GstTIViddec2:tividdec20: failed to open codec engine "codecServer"
    Additional debug info:
    gsttividdec2.c(1162): gst_tividdec2_codec_start (): /GstPipeline:pipeline0/GstTIViddec2:tividdec20
    ERROR: pipeline doesn't want to preroll.
    Setting pipeline to NULL ...
    Carl
  • Carl,
    I am really not familiar with the codecs and Dmai stuff here so not sure whether I will be able to help you in those areas, but I can make sure that driver interface is working fine. Atleast after looking to above log, I could see it is failing in "getNumBuffers", now I do not know whether it is failing in driver REQBUF or at some codecs level.
    Can you please provide me the boot log and also dmesg log after you run the application?
    How to attach file: File attachment option is present under "options" tab.
    Vaibhav
  • Hi Vaibhav,
         Anyway, thank you! the attached file are boot log and dmesg, you can check it ! Thanks ! I am trying to rebuild the dsp driver and gstreamer when I rebuild the kernel, I don't know if it will work.
    Carl
  •   the attached file is dmesg
  • Unfortunately the log is pointing to dsplink, so not sure what it means.
    Vaibhav
  • Hi  Vaibhav,
          I do a test for dsp, it also failed:
         ./messagegpp message.out 1000
     ========== Sample Application : MESSAGE ==========
    Entered MESS[  525.526184]
    DSP_init status [0x80008008] AGE_Create ()
    [  525.532867] Assertion failed ((isrObj!= NULL) && (ISR_InstalledIsrs [isrObj->dspId][isrObj->irq] == isrObj)). Fi4
    PROC_attach () failed. Status = [0x80008008]
    PROC_setup () failed. Status = [0x80008008]
    Leaving MESSAGE_Create ()
    Entered MESSAGE_Delete ()
    MSGQ_release () failed. Status = [0x8000800b]
    Leaving MESSAGE_Delete ()
    From the following dmesg, it showed the program failed when the dsp register ISR:
    Assertion failed ((isrObj!= NULL) && (ISR_InstalledIsrs [isrObj->dspId][isrObj->irq] == isrObj)). File : /root/work/workspace/OMAP3530/oe-kernel-2.6.29-r46/gstreamer_ti/dsp-oe/ti-dsplink-module-1613-r46a/dsplink_1_61_03/dsplink/gpp/src/../../gpp/src/osal/Linux/2.6.18/isr.c Line : 504
    can I check the Interrupt of the system , and found after enable: Device Drivers->Multimedia Devices->Video Capture Adapters->OMAP 3 Camera Support
    it will occupy irq 28 and 24.:
    cat /proc/interrupts
     CPU0
     11:          0        INTC  prcm
     12:       1191        INTC  DMA
     21:          0        INTC  SGX ISR
     24:          0        INTC  omap-iommu.1, Omap 3 Camera ISP
     25:          1        INTC  OMAP DSS
     28:          0        INTC  omap-iommu.2
     56:        425        INTC  i2c_omap
     57:          1        INTC  i2c_omap
     61:          0        INTC  i2c_omap
     72:          2        INTC  serial idle
     73:          2        INTC  serial idle
     74:       1633        INTC  serial idle, serial
     77:          0        INTC  ehci_hcd:usb1
     83:      33992        INTC  mmc0
     86:         14        INTC  mmc1
     92:          0        INTC  musb_hdrc
     93:          0        INTC  musb_hdrc
     95:       8961        INTC  gp timer
    167:          0        GPIO  user
    322:          1        GPIO  mmc1
    376:          0     twl4030  twl4030_pwrbutton
    378:          0     twl4030  twl4030_usb
    384:          0     twl4030  mmc0
    I don't know it's a DSPLink bug or not. Do you have any idea ?
    Carl
  • I mean the Camera and the DSPLink will request the same ISR number 28.
  • Carl,
    DSPlink programs the MMU for the DSP. The number 28 is the interrupt id to be used to catch DSP MMU faults. DSPLink registers an ISR on 28 to catch MMU faults if DSP tries to access an invalid MMU address.
    The camera sub system should not use 28 as it is reserved for DSP.
    Deepali
  • Hi Deepali
        But is there any patch to fix the problem, the orginal code use isr 28 for camera. Thanks !
    Carl
  • Hi Carl,
    Sorry for delayed response, I was busy with some another OMAP release.
    I checked on OMAP3EVM platform, I do not have interrupt 28 registered to the kernel. Below is the log just for your reference -
    root@omap3evm:# cat /proc/interrupts
               CPU0
      7:          0        INTC  TWL4030-PIH
     11:          0        INTC  prcm
     12:          1        INTC  DMA
     24:        734        INTC  omap-iommu.0, Omap 3 Camera ISP
     25:          3        INTC  OMAP DSS
     37:      16349        INTC  gp timer
     56:        514        INTC  i2c_omap
     57:          0        INTC  i2c_omap
     61:         70        INTC  i2c_omap
     72:      15717        INTC  serial idle, serial
     73:          1        INTC  serial idle
     74:          1        INTC  serial idle
     83:          0        INTC  mmc0
    335:          0        GPIO  ads7846
    336:      66892        GPIO  eth0
    369:          0     twl4030  twl4030_keypad
    379:          0     twl4030  rtc0
    384:          0     twl4030  mmc0
    Err:          0
    root@omap3evm:#
    In addition to that, I checked the kernel code, the IRQ (28) declaration/registration is happening in "arch/arm/mach-omap2/omap3-iommu.c" , which will only be applicable when you define "CONFIG_MPU_BRIDGE_IOMMU". Neither PSP release nor your .config (I checked the .config file which you had pasted last time) defines this. So at this point of time I am completely clue-less.
    Vaibhav
