TLV320AIC3206 and Sitara Linux SDK
Other Parts Discussed in Thread: TLV320AIC3206, TLV320AIC3204, TLV320AIC3106, DAC7512, PMP, TCA6416, TCA8418, LM8323, LM8333, ADS7846, TSC2005, TSC2007, TPS65218, TWL6040, PCF8574, DRV2667, TPS65910, BQ27000, LP8727, BQ24190, BQ24735, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95234, LM95241, LM95245, ADC128D818, ADS1015, ADS7828, ADS7871, AMC6821, INA209, TMP102, TMP103, TMP401, TMP421, LP3943, TPS65010, TPS65090, TPS65217, TPS65912, LM3533, LP3971, LP3972, TPS51632, TPS62360, TPS65023, TVP5150, TVP7002, THS8200, LM3560, THS7303, DA8XX, OPA362, TFP410, TPD12S015, TLC59108, LM3630A, LM3639, PCM1681, PCM1792A, TAS2552, TAS5086, TS3A227E, TPA6130A2, TWL6030, LM3530, LM3642, LP3944, LP5521, LP5523, LP5562, LP8501, DAC124S085, TCA6507, CDCE706, ADC128S052, TMP006
We are building the board based on beaglebone black and have a TLV320AIC3206 codec on the board, I would like to know if Sitara Linux SDK supports TLV320AIC3206 codec.
To verify that, I load Linux SDK to BeagleBone Black and modify the am335 am335x-boneblack.dts (see the attached file am335x-boneblack.dts  on the bottom).
I boot the board with this changed am335x-boneblack.dts, use aplay to playback the sample ALSA wav file:
aplay /usr/share/sounds/alsa/Front_Left.wav
However, I get the errors:
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/confmisc.c:768:(parse_card) cannot find card '0'
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/confmisc.c:1251:(snd_func_refer) error evaluating name
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib /home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8hf-vfp-neon-linux-gnueabi/alsa-lib/1.0.28-r0/alsa-lib-1.0.28/src/pcm/pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM default
aplay: main:730: audio open error: No such file or directory
I don't know why. Any hep will be appreciated.
/dts-v1/;
#include "am33xx.dtsi"
#include "am335x-bone-common.dtsi"
model = "TI AM335x BeagleBone Black";
compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx";
&ldo3_reg {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-always-on;
&mmc1 {
vmmc-supply = <&vmmcsd_fixed>;
&mmc2 {
pinctrl-names = "default";
pinctrl-0 = <&emmc_pins>;
bus-width = <8>;
status = "okay";
&sgx {
status = "okay";
&am33xx_pinmux {
mcasp0_pins: mcasp0_pins {
pinctrl-single,pins = <
0x06c (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 */
0x1ac ( PIN_OUTPUT_PULLDOWN | MUX_MODE0 ) /* (A14) mcasp0_ahclkx.mcasp0_ahclkx */
0x190 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0 ) /* (A13) mcasp0_aclkx.mcasp0_aclkx */
0x194 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0 ) /* (B13) mcasp0_fsx.mcasp0_fsx */
0x1a0 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0 ) /* (B12) mcasp0_aclkr.mcasp0_aclkr */
0x198 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0 ) /* (D12) mcasp0_axr0.mcasp0_axr0 */
0x1a8 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (D13) mcasp0_axr1.mcasp0_axr1 */
0x19c ( PIN_INPUT_PULLDOWN | MUX_MODE2 ) /* (C12) mcasp0_ahclkr.mcasp0_axr2 */
mcasp0_pins_sleep: mcasp0_pins_sleep {
0x06c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 */
0x1ac (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (A14) mcasp0_ahclkx.mcasp0_ahclkx */
0x190 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (A13) mcasp0_aclkx.mcasp0_aclkx */
0x194 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (B13) mcasp0_fsx.mcasp0_fsx */
0x1a0 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (B12) mcasp0_aclkr.mcasp0_aclkr */
0x198 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (D12) mcasp0_axr0.mcasp0_axr0 */
0x1a8 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (D13) mcasp0_axr1.mcasp0_axr1 */
0x19c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (C12) mcasp0_ahclkr.mcasp0_axr2 */
&lcdc {
status = "okay";
&mcasp0 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&mcasp0_pins>;
pinctrl-1 = <&mcasp0_pins_sleep>;
status = "okay";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 0 1 2
tx-num-evt = <1>;
rx-num-evt = <1>;
clk_mcasp0_fixed: clk_mcasp0_fixed {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24576000>;
clk_mcasp0: clk_mcasp0 {
#clock-cells = <0>;
compatible = "gpio-gate-clock";
clocks = <&clk_mcasp0_fixed>;
enable-gpios = <&gpio1 27 0>; /* BeagleBone Black Clk enable on GPIO1_27 */
tlv320aic3x: tlv320aix3x {
compatible = "ti,tlv320aic3x";
status = "okay";
sound {
compatible = "ti,da830-evm-audio";
ti,model = "DA830 EVM";
ti,audio-codec = <&tlv320aic3x>;
ti,mcasp-controller = <&mcasp0>;
ti,codec-clock-rate = <12000000>;
ti,audio-routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"LINE1L", "Line In",
"LINE1R", "Line In";
    I will forward this to the software team.
  • Hi Bruce,
    AFAIK, there is no special driver dedicated to tlv320aic3206 codec. However, I noticed that registers & functionality is similar to tlv320aic3204, and based on this post: e2e.ti.com/.../266169 the corresponding driver for tlv320aic3204 is tlv320aic32x4.c.
    So try adding
    CONFIG_SND_SOC_TLV320AIC32X4=y in your defconfig
    modify your dts node to:
    tlv320aic32x4: tlv320aix324x {
    compatible = "ti,tlv320aic32x4";
    status = "okay";
    and test if ALSA will detect your sound card (codec).
    Yordan
  • Hi Yordan,
    Thanks a lot for your response.
    I see that the device driver TLV320AIC32x4 is built and detected from Kernel. I tried to run the following test:
    I got the message as following:
    Playing WAVE '/usr/share/sounds/alsa/Front_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
    but it hangs. I check the hardware devices with
    aplay -l
    and I got:
    **** List of PLAYBACK Hardware Devices ****
    card 0: AIC32X4 [TI AIC32X4], device 0: AIC3X tlv320aic3x-hifi-0 []
    Subdevices: 1/1
    Subdevice #0: subdevice #0
    I am not sure if I need to make changes in other places, such as in /davinci
  • Hi Yordan,
    I just found that something is not right, I mistakenly modified dts node i2c2 in am335x-bone-common.dtsi (I use i2c2 on beaglebone black to configure the codec) as following:
    tlv320aic32x4: tlv320aic32x4@18 {
    compatible = "ti,tlv320aic3106";
    reg = <0x18>;
    status = "okay";
    and I ran
    and I found that it hangs. If I added changes to i2c2 on dts.
    &i2c2 {
    pinctrl-0 = <&i2c2_pins>;
    status = "okay";
    clock-frequency = <400000>;
    tlv320aic32x4: tlv320aic32x4 {
    status = "okay";
    I ran the same command, I still get errors:
    I don't know why. Maybe I have to modify davinci/davinci-evm.c as well, any help will be highly appreciated.
  • Hi Yordan,
    Thank you very much for your help, we are still working on the issue which BeagleBone Black is not able to find the card.
    I found the link(e2e.ti.com/.../1293890), it seems that the following modules should be installed in order to solve this issue:
    sound/soc/snd-soc-core.ko
    sound/soc/davinci/snd-soc-davinci.ko
    sound/soc/davinci/snd-soc-evm.ko
    But I only see snd-soc-evm.ko in /lib/modules/4.1.13-g8dc6617/kernel/sound/soc/davinci, is it the reason that BBB cannot find the card and how can we get snd-soc-core.ko and snd-soc-davinci.ko?
    Since our development board is not available yet, the current test set up is:
    We use BeagleBone Black (Rev C) and TLV320AIC3206EVM-U Evaluation module.we connect McASP 0 ports and I2C2 ports on BBB P9 to I2C and I2S ports on AIC3206EVM-U module.
    Thanks.
    Yes, this could be the root cause for your problem. Could you run lsmod on your test setup?
    Also can you share your defconfig file: arch/arm/configs/tisdk_am335x-evm_defconfig? If you haven't change this file the two modules snd-soc-davinci & snd-soc-evm should be built-in your kernel.
    Yordan
  • Hi Yordan,
    Here is the result after I run lsmod:
    root@am335x-evm:~# lsmod
    Module Size Used by
    ipv6 307420 24
    cryptodev 33648 0
    musb_dsps 7807 0
    musb_hdrc 69197 1 musb_dsps
    udc_core 11604 1 musb_hdrc
    usbcore 190649 1 musb_hdrc
    snd_soc_evm 5106 0
    pm33xx 4633 0
    omapdrm_pvr 336119 0
    omap_rng 4470 0
    rng_core 7728 2 omap_rng
    musb_am335x 1240 0
    rtc_omap 7578 1
    omap_wdt 4347 0
    leds_gpio 3445 0
    snd_soc_hdmi_codec 2178 1
    I insert tisdk_am335x-evm_defconfig here, the only change which I manually add is
    Below is copy of the file tisdk_am335x-evm_defconfig
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 4.1.13 Kernel Configuration
    CONFIG_ARM=y
    CONFIG_ARM_HAS_SG_CHAIN=y
    CONFIG_MIGHT_HAVE_PCI=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_RWSEM_XCHGADD_ALGORITHM=y
    CONFIG_ARCH_HAS_BANDGAP=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_ARCH_SUPPORTS_UPROBES=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_PGTABLE_LEVELS=2
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_EXTABLE_SORT=y
    # General setup
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_CROSS_COMPILE=""
    # CONFIG_COMPILE_TEST is not set
    CONFIG_LOCALVERSION=""
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_XZ=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_HAVE_KERNEL_LZ4=y
    # CONFIG_KERNEL_GZIP is not set
    CONFIG_KERNEL_LZMA=y
    # CONFIG_KERNEL_XZ is not set
    # CONFIG_KERNEL_LZO is not set
    # CONFIG_KERNEL_LZ4 is not set
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    CONFIG_CROSS_MEMORY_ATTACH=y
    CONFIG_FHANDLE=y
    CONFIG_USELIB=y
    CONFIG_AUDIT=y
    CONFIG_HAVE_ARCH_AUDITSYSCALL=y
    # CONFIG_AUDITSYSCALL is not set
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    CONFIG_HANDLE_DOMAIN_IRQ=y
    # CONFIG_IRQ_DOMAIN_DEBUG is not set
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    CONFIG_GENERIC_TIME_VSYSCALL=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
    # CONFIG_IRQ_TIME_ACCOUNTING is not set
    CONFIG_BSD_PROCESS_ACCT=y
    # CONFIG_BSD_PROCESS_ACCT_V3 is not set
    # CONFIG_TASKSTATS is not set
    # RCU Subsystem
    CONFIG_PREEMPT_RCU=y
    CONFIG_SRCU=y
    # CONFIG_TASKS_RCU is not set
    CONFIG_RCU_STALL_COMMON=y
    CONFIG_RCU_FANOUT=32
    CONFIG_RCU_FANOUT_LEAF=16
    # CONFIG_RCU_FANOUT_EXACT is not set
    # CONFIG_TREE_RCU_TRACE is not set
    # CONFIG_RCU_BOOST is not set
    CONFIG_RCU_KTHREAD_PRIO=0
    # CONFIG_RCU_NOCB_CPU is not set
    # CONFIG_RCU_EXPEDITE_BOOT is not set
    CONFIG_BUILD_BIN2C=y
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=16
    CONFIG_GENERIC_SCHED_CLOCK=y
    CONFIG_CGROUPS=y
    # CONFIG_CGROUP_DEBUG is not set
    CONFIG_CGROUP_FREEZER=y
    CONFIG_CGROUP_DEVICE=y
    CONFIG_CPUSETS=y
    CONFIG_PROC_PID_CPUSET=y
    CONFIG_CGROUP_CPUACCT=y
    CONFIG_PAGE_COUNTER=y
    CONFIG_MEMCG=y
    CONFIG_MEMCG_SWAP=y
    CONFIG_MEMCG_SWAP_ENABLED=y
    CONFIG_MEMCG_KMEM=y
    CONFIG_CGROUP_PERF=y
    CONFIG_CGROUP_SCHED=y
    CONFIG_FAIR_GROUP_SCHED=y
    CONFIG_CFS_BANDWIDTH=y
    CONFIG_RT_GROUP_SCHED=y
    CONFIG_BLK_CGROUP=y
    # CONFIG_DEBUG_BLK_CGROUP is not set
    # CONFIG_CHECKPOINT_RESTORE is not set
    CONFIG_NAMESPACES=y
    CONFIG_UTS_NS=y
    CONFIG_IPC_NS=y
    # CONFIG_USER_NS is not set
    CONFIG_PID_NS=y
    CONFIG_NET_NS=y
    # CONFIG_SCHED_AUTOGROUP is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    CONFIG_RD_BZIP2=y
    CONFIG_RD_LZMA=y
    CONFIG_RD_XZ=y
    CONFIG_RD_LZO=y
    CONFIG_RD_LZ4=y
    # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_HAVE_UID16=y
    CONFIG_BPF=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    CONFIG_MULTIUSER=y
    # CONFIG_SGETMASK_SYSCALL is not set
    CONFIG_SYSFS_SYSCALL=y
    # CONFIG_SYSCTL_SYSCALL is not set
    CONFIG_KALLSYMS=y
    CONFIG_KALLSYMS_ALL=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    # CONFIG_BPF_SYSCALL is not set
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_ADVISE_SYSCALLS=y
    CONFIG_PCI_QUIRKS=y
    # CONFIG_EMBEDDED is not set
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    CONFIG_VM_EVENT_COUNTERS=y
    # CONFIG_SLUB_DEBUG is not set
    CONFIG_COMPAT_BRK=y
    # CONFIG_SLAB is not set
    CONFIG_SLUB=y
    # CONFIG_SLOB is not set
    # CONFIG_SYSTEM_TRUSTED_KEYRING is not set
    CONFIG_PROFILING=y
    CONFIG_OPROFILE=y
    CONFIG_HAVE_OPROFILE=y
    CONFIG_KPROBES=y
    CONFIG_JUMP_LABEL=y
    # CONFIG_UPROBES is not set
    # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
    CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
    CONFIG_ARCH_USE_BUILTIN_BSWAP=y
    CONFIG_KRETPROBES=y
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_OPTPROBES=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_ATTRS=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_DMA_API_DEBUG=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_PERF_REGS=y
    CONFIG_HAVE_PERF_USER_STACK_DUMP=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
    CONFIG_SECCOMP_FILTER=y
    CONFIG_HAVE_CC_STACKPROTECTOR=y
    # CONFIG_CC_STACKPROTECTOR is not set
    CONFIG_CC_STACKPROTECTOR_NONE=y
    # CONFIG_CC_STACKPROTECTOR_REGULAR is not set
    # CONFIG_CC_STACKPROTECTOR_STRONG is not set
    CONFIG_HAVE_CONTEXT_TRACKING=y
    CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_MODULES_USE_ELF_REL=y
    CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_SIGACTION=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL=y
    # CONFIG_MODULE_SIG is not set
    # CONFIG_MODULE_COMPRESS is not set
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_BSGLIB is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # CONFIG_BLK_DEV_THROTTLING is not set
    # CONFIG_BLK_CMDLINE_PARSER is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_AIX_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    # CONFIG_CMDLINE_PARTITION is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    CONFIG_IOSCHED_DEADLINE=y
    CONFIG_IOSCHED_CFQ=y
    # CONFIG_CFQ_GROUP_IOSCHED is not set
    # CONFIG_DEFAULT_DEADLINE is not set
    CONFIG_DEFAULT_CFQ=y
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="cfq"
    CONFIG_UNINLINE_SPIN_UNLOCK=y
    CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    CONFIG_ARCH_MULTIPLATFORM=y
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_LPC32XX is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_SHMOBILE_LEGACY is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C24XX is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_ARCH_OMAP1 is not set
    # Multiple platform selection
    # CPU Core family selection
    CONFIG_ARCH_MULTI_V6=y
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    # CONFIG_ARCH_MULTI_CPU_AUTO is not set
    # CONFIG_ARCH_VIRT is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_ALPINE is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_ARCH_BERLIN is not set
    # CONFIG_ARCH_CNS3XXX is not set
    # CONFIG_ARCH_DIGICOLOR is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_HISI is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_KEYSTONE is not set
    # CONFIG_ARCH_MESON is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_MEDIATEK is not set
    CONFIG_ARCH_OMAP=y
    # TI OMAP Common Features
    # OMAP Feature Selections
    CONFIG_OMAP_RESET_CLOCKS=y
    CONFIG_OMAP_MUX=y
    CONFIG_OMAP_MUX_DEBUG=y
    CONFIG_OMAP_MUX_WARNINGS=y
    CONFIG_OMAP_32K_TIMER=y
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_OMAP_PM_NOOP=y
    CONFIG_MACH_OMAP_GENERIC=y
    # TI OMAP/AM/DM/DRA Family
    # CONFIG_ARCH_OMAP2 is not set
    # CONFIG_ARCH_OMAP3 is not set
    # CONFIG_ARCH_OMAP4 is not set
    # CONFIG_SOC_OMAP5 is not set
    CONFIG_SOC_AM33XX=y
    # CONFIG_SOC_AM43XX is not set
    # CONFIG_SOC_DRA7XX is not set
    CONFIG_ARCH_OMAP2PLUS=y
    # TI OMAP2/3/4 Specific Features
    CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
    CONFIG_SOC_HAS_OMAP2_SDRC=y
    # OMAP Legacy Platform Data Board Type
    CONFIG_AMX3_PM=m
    # CONFIG_ARCH_PICOXCELL is not set
    # CONFIG_ARCH_QCOM is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_SHMOBILE_MULTI is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_SIRF is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_WM8750 is not set
    # CONFIG_ARCH_WM8850 is not set
    # CONFIG_ARCH_ZYNQ is not set
    # Processor Type
    CONFIG_CPU_V6K=y
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v6=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV6=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V6=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V6=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
    CONFIG_ARM_THUMB=y
    CONFIG_ARM_THUMBEE=y
    CONFIG_ARM_VIRT_EXT=y
    CONFIG_SWP_EMULATE=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_KUSER_HELPERS=y
    CONFIG_VDSO=y
    CONFIG_OUTER_CACHE=y
    CONFIG_OUTER_CACHE_SYNC=y
    CONFIG_MIGHT_HAVE_CACHE_L2X0=y
    CONFIG_CACHE_L2X0=y
    CONFIG_PL310_ERRATA_588369=y
    CONFIG_PL310_ERRATA_727915=y
    # CONFIG_PL310_ERRATA_753970 is not set
    # CONFIG_PL310_ERRATA_769419 is not set
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_HEAVY_MB=y
    # CONFIG_ARM_KERNMEM_PERMS is not set
    CONFIG_MULTI_IRQ_HANDLER=y
    CONFIG_ARM_ERRATA_411920=y
    CONFIG_ARM_ERRATA_430973=y
    CONFIG_ARM_ERRATA_720789=y
    CONFIG_ARM_ERRATA_754322=y
    CONFIG_ARM_ERRATA_775420=y
    # CONFIG_ARM_ERRATA_773022 is not set
    CONFIG_TI_PRIV_EDMA=y
    # Bus support
    CONFIG_PCI=y
    # CONFIG_PCI_DOMAINS_GENERIC is not set
    CONFIG_PCI_SYSCALL=y
    # CONFIG_PCI_MSI is not set
    # CONFIG_PCI_DEBUG is not set
    # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
    # CONFIG_PCI_STUB is not set
    # CONFIG_PCI_IOV is not set
    # CONFIG_PCI_PRI is not set
    # CONFIG_PCI_PASID is not set
    # PCI host controller drivers
    CONFIG_PCI_DRA7XX=y
    CONFIG_PCIE_DW=y
    # CONFIG_PCI_HOST_GENERIC is not set
    # CONFIG_PCI_LAYERSCAPE is not set
    # CONFIG_PCIE_IPROC is not set
    # CONFIG_PCIEPORTBUS is not set
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_HAVE_SMP=y
    # CONFIG_SMP is not set
    CONFIG_HAVE_ARM_ARCH_TIMER=y
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    # CONFIG_ARM_PSCI is not set
    CONFIG_ARCH_NR_GPIO=0
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_PREEMPT_COUNT=y
    CONFIG_HZ_FIXED=0
    CONFIG_HZ_100=y
    # CONFIG_HZ_200 is not set
    # CONFIG_HZ_250 is not set
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_500 is not set
    # CONFIG_HZ_1000 is not set
    CONFIG_HZ=100
    CONFIG_SCHED_HRTICK=y
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    CONFIG_HAVE_ARCH_PFN_VALID=y
    CONFIG_HIGHMEM=y
    # CONFIG_HIGHPTE is not set
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_HAVE_MEMBLOCK=y
    CONFIG_NO_BOOTMEM=y
    CONFIG_MEMORY_ISOLATION=y
    # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    CONFIG_COMPACTION=y
    CONFIG_MIGRATION=y
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_BOUNCE=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_NEED_PER_CPU_KM=y
    # CONFIG_CLEANCACHE is not set
    # CONFIG_FRONTSWAP is not set
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_CMA_DEBUGFS is not set
    CONFIG_CMA_AREAS=7
    # CONFIG_ZPOOL is not set
    # CONFIG_ZBUD is not set
    # CONFIG_ZSMALLOC is not set
    CONFIG_FORCE_MAX_ZONEORDER=12
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    CONFIG_SECCOMP=y
    CONFIG_SWIOTLB=y
    CONFIG_IOMMU_HELPER=y
    # CONFIG_XEN is not set
    # Boot options
    CONFIG_USE_OF=y
    CONFIG_ATAGS=y
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_ARM_APPENDED_DTB=y
    CONFIG_ARM_ATAG_DTB_COMPAT=y
    CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
    CONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO2,115200"
    CONFIG_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_CMDLINE_EXTEND is not set
    # CONFIG_CMDLINE_FORCE is not set
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CONFIG_CRASH_DUMP is not set
    CONFIG_AUTO_ZRELADDR=y
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    # CPU frequency scaling drivers
    CONFIG_CPUFREQ_DT=m
    CONFIG_CPUFREQ_VOLTDM=y
    # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
    # CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set
    # CONFIG_QORIQ_CPUFREQ is not set
    # CPU Idle
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
    # ARM CPU Idle Drivers
    # CONFIG_ARM_CPUIDLE is not set
    # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # CONFIG_KERNEL_MODE_NEON is not set
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
    CONFIG_BINFMT_SCRIPT=y
    # CONFIG_HAVE_AOUT is not set
    CONFIG_BINFMT_MISC=y
    CONFIG_COREDUMP=y
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    # CONFIG_HIBERNATION is not set
    CONFIG_PM_SLEEP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_ADVANCED_DEBUG is not set
    # CONFIG_PM_TEST_SUSPEND is not set
    CONFIG_PM_SLEEP_DEBUG=y
    # CONFIG_APM_EMULATION is not set
    CONFIG_PM_OPP=y
    CONFIG_PM_CLK=y
    # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_ARCH_HIBERNATION_POSSIBLE=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    # CONFIG_UNIX_DIAG is not set
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=y
    CONFIG_XFRM_USER=y
    # CONFIG_XFRM_SUB_POLICY is not set
    CONFIG_XFRM_MIGRATE=y
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_IPCOMP=m
    CONFIG_NET_KEY=y
    CONFIG_NET_KEY_MIGRATE=y
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_ROUTE_CLASSID=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    CONFIG_NET_IP_TUNNEL=m
    # CONFIG_IP_MROUTE is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    # CONFIG_NET_UDP_TUNNEL is not set
    # CONFIG_NET_FOU is not set
    # CONFIG_NET_FOU_IP_TUNNELS is not set
    # CONFIG_GENEVE is not set
    # CONFIG_INET_AH is not set
    CONFIG_INET_ESP=y
    # CONFIG_INET_IPCOMP is not set
    # CONFIG_INET_XFRM_TUNNEL is not set
    CONFIG_INET_TUNNEL=m
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
    # CONFIG_INET_LRO is not set
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=m
    # CONFIG_IPV6_ROUTER_PREF is not set
    # CONFIG_IPV6_OPTIMISTIC_DAD is not set
    CONFIG_INET6_AH=m
    # CONFIG_INET6_ESP is not set
    CONFIG_INET6_IPCOMP=m
    # CONFIG_IPV6_MIP6 is not set
    CONFIG_INET6_XFRM_TUNNEL=m
    CONFIG_INET6_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_TRANSPORT=m
    CONFIG_INET6_XFRM_MODE_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_BEET=m
    # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
    # CONFIG_IPV6_VTI is not set
    CONFIG_IPV6_SIT=m
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    CONFIG_IPV6_TUNNEL=m
    # CONFIG_IPV6_GRE is not set
    # CONFIG_IPV6_MULTIPLE_TABLES is not set
    # CONFIG_IPV6_MROUTE is not set
    # CONFIG_NETLABEL is not set
    # CONFIG_NETWORK_SECMARK is not set
    CONFIG_NET_PTP_CLASSIFY=y
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    CONFIG_BRIDGE_NETFILTER=m
    # Core Netfilter Configuration
    # CONFIG_NETFILTER_NETLINK_ACCT is not set
    # CONFIG_NETFILTER_NETLINK_QUEUE is not set
    # CONFIG_NETFILTER_NETLINK_LOG is not set
    CONFIG_NF_CONNTRACK=m
    # CONFIG_NF_CONNTRACK_MARK is not set
    CONFIG_NF_CONNTRACK_PROCFS=y
    # CONFIG_NF_CONNTRACK_EVENTS is not set
    # CONFIG_NF_CONNTRACK_TIMEOUT is not set
    # CONFIG_NF_CONNTRACK_TIMESTAMP is not set
    # CONFIG_NF_CT_PROTO_DCCP is not set
    CONFIG_NF_CT_PROTO_SCTP=m
    # CONFIG_NF_CT_PROTO_UDPLITE is not set
    # CONFIG_NF_CONNTRACK_AMANDA is not set
    # CONFIG_NF_CONNTRACK_FTP is not set
    # CONFIG_NF_CONNTRACK_H323 is not set
    # CONFIG_NF_CONNTRACK_IRC is not set
    # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
    # CONFIG_NF_CONNTRACK_SNMP is not set
    # CONFIG_NF_CONNTRACK_PPTP is not set
    # CONFIG_NF_CONNTRACK_SANE is not set
    # CONFIG_NF_CONNTRACK_SIP is not set
    # CONFIG_NF_CONNTRACK_TFTP is not set
    # CONFIG_NF_CT_NETLINK is not set
    # CONFIG_NF_CT_NETLINK_TIMEOUT is not set
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_NEEDED=y
    CONFIG_NF_NAT_PROTO_SCTP=m
    # CONFIG_NF_NAT_AMANDA is not set
    # CONFIG_NF_NAT_FTP is not set
    # CONFIG_NF_NAT_IRC is not set
    # CONFIG_NF_NAT_SIP is not set
    # CONFIG_NF_NAT_TFTP is not set
    # CONFIG_NF_NAT_REDIRECT is not set
    # CONFIG_NF_TABLES is not set
    CONFIG_NETFILTER_XTABLES=m
    # Xtables combined modules
    CONFIG_NETFILTER_XT_MARK=m
    # CONFIG_NETFILTER_XT_CONNMARK is not set
    # Xtables targets
    # CONFIG_NETFILTER_XT_TARGET_AUDIT is not set
    CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
    # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_HMARK is not set
    CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
    # CONFIG_NETFILTER_XT_TARGET_LED is not set
    # CONFIG_NETFILTER_XT_TARGET_LOG is not set
    CONFIG_NETFILTER_XT_TARGET_MARK=m
    # CONFIG_NETFILTER_XT_NAT is not set
    # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
    # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
    # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
    # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
    # CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set
    # CONFIG_NETFILTER_XT_TARGET_TEE is not set
    # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
    # Xtables matches
    # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_BPF is not set
    # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    CONFIG_NETFILTER_XT_MATCH_COMMENT=m
    # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
    CONFIG_NETFILTER_XT_MATCH_CPU=m
    # CONFIG_NETFILTER_XT_MATCH_DCCP is not set
    # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_DSCP is not set
    # CONFIG_NETFILTER_XT_MATCH_ECN is not set
    # CONFIG_NETFILTER_XT_MATCH_ESP is not set
    # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_HELPER is not set
    # CONFIG_NETFILTER_XT_MATCH_HL is not set
    # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
    CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
    # CONFIG_NETFILTER_XT_MATCH_L2TP is not set
    CONFIG_NETFILTER_XT_MATCH_LENGTH=m
    CONFIG_NETFILTER_XT_MATCH_LIMIT=m
    CONFIG_NETFILTER_XT_MATCH_MAC=m
    CONFIG_NETFILTER_XT_MATCH_MARK=m
    CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
    # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
    # CONFIG_NETFILTER_XT_MATCH_OWNER is not set
    # CONFIG_NETFILTER_XT_MATCH_POLICY is not set
    # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
    CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
    # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
    # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
    # CONFIG_NETFILTER_XT_MATCH_REALM is not set
    # CONFIG_NETFILTER_XT_MATCH_RECENT is not set
    CONFIG_NETFILTER_XT_MATCH_SCTP=m
    # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
    # CONFIG_NETFILTER_XT_MATCH_STATE is not set
    # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
    # CONFIG_NETFILTER_XT_MATCH_STRING is not set
    # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
    # CONFIG_NETFILTER_XT_MATCH_TIME is not set
    # CONFIG_NETFILTER_XT_MATCH_U32 is not set
    # CONFIG_IP_SET is not set
    # CONFIG_IP_VS is not set
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    CONFIG_NF_CONNTRACK_IPV4=m
    CONFIG_NF_CONNTRACK_PROC_COMPAT=y
    # CONFIG_NF_LOG_ARP is not set
    # CONFIG_NF_LOG_IPV4 is not set
    # CONFIG_NF_REJECT_IPV4 is not set
    CONFIG_NF_NAT_IPV4=m
    # CONFIG_NF_NAT_MASQUERADE_IPV4 is not set
    # CONFIG_NF_NAT_PPTP is not set
    # CONFIG_NF_NAT_H323 is not set
    CONFIG_IP_NF_IPTABLES=m
    # CONFIG_IP_NF_MATCH_AH is not set
    # CONFIG_IP_NF_MATCH_ECN is not set
    # CONFIG_IP_NF_MATCH_TTL is not set
    CONFIG_IP_NF_FILTER=m
    # CONFIG_IP_NF_TARGET_REJECT is not set
    # CONFIG_IP_NF_TARGET_SYNPROXY is not set
    # CONFIG_IP_NF_NAT is not set
    # CONFIG_IP_NF_MANGLE is not set
    # CONFIG_IP_NF_RAW is not set
    # CONFIG_IP_NF_SECURITY is not set
    CONFIG_IP_NF_ARPTABLES=m
    CONFIG_IP_NF_ARPFILTER=m
    CONFIG_IP_NF_ARP_MANGLE=m
    # IPv6: Netfilter Configuration
    # CONFIG_NF_DEFRAG_IPV6 is not set
    # CONFIG_NF_CONNTRACK_IPV6 is not set
    # CONFIG_NF_REJECT_IPV6 is not set
    # CONFIG_NF_LOG_IPV6 is not set
    # CONFIG_IP6_NF_IPTABLES is not set
    CONFIG_BRIDGE_NF_EBTABLES=m
    CONFIG_BRIDGE_EBT_BROUTE=m
    CONFIG_BRIDGE_EBT_T_FILTER=m
    CONFIG_BRIDGE_EBT_T_NAT=m
    CONFIG_BRIDGE_EBT_802_3=m
    CONFIG_BRIDGE_EBT_AMONG=m
    CONFIG_BRIDGE_EBT_ARP=m
    CONFIG_BRIDGE_EBT_IP=m
    CONFIG_BRIDGE_EBT_IP6=m
    CONFIG_BRIDGE_EBT_LIMIT=m
    CONFIG_BRIDGE_EBT_MARK=m
    CONFIG_BRIDGE_EBT_PKTTYPE=m
    CONFIG_BRIDGE_EBT_STP=m
    CONFIG_BRIDGE_EBT_VLAN=m
    CONFIG_BRIDGE_EBT_ARPREPLY=m
    CONFIG_BRIDGE_EBT_DNAT=m
    CONFIG_BRIDGE_EBT_MARK_T=m
    CONFIG_BRIDGE_EBT_REDIRECT=m
    CONFIG_BRIDGE_EBT_SNAT=m
    CONFIG_BRIDGE_EBT_LOG=m
    CONFIG_BRIDGE_EBT_NFLOG=m
    # CONFIG_IP_DCCP is not set
    CONFIG_IP_SCTP=m
    # CONFIG_NET_SCTPPROBE is not set
    # CONFIG_SCTP_DBG_OBJCNT is not set
    CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
    # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
    # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
    CONFIG_SCTP_COOKIE_HMAC_MD5=y
    # CONFIG_SCTP_COOKIE_HMAC_SHA1 is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    CONFIG_STP=m
    CONFIG_BRIDGE=m
    CONFIG_BRIDGE_IGMP_SNOOPING=y
    # CONFIG_BRIDGE_VLAN_FILTERING is not set
    CONFIG_HAVE_NET_DSA=y
    CONFIG_VLAN_8021Q=m
    # CONFIG_VLAN_8021Q_GVRP is not set
    # CONFIG_VLAN_8021Q_MVRP is not set
    # CONFIG_DECNET is not set
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    CONFIG_PHONET=m
    # CONFIG_6LOWPAN is not set
    # CONFIG_IEEE802154 is not set
    CONFIG_NET_SCHED=y
    # Queueing/Scheduling
    CONFIG_NET_SCH_CBQ=m
    CONFIG_NET_SCH_HTB=m
    CONFIG_NET_SCH_HFSC=m
    CONFIG_NET_SCH_PRIO=m
    CONFIG_NET_SCH_MULTIQ=m
    CONFIG_NET_SCH_RED=m
    CONFIG_NET_SCH_SFB=m
    CONFIG_NET_SCH_SFQ=m
    CONFIG_NET_SCH_TEQL=m
    CONFIG_NET_SCH_TBF=m
    CONFIG_NET_SCH_GRED=m
    CONFIG_NET_SCH_DSMARK=m
    CONFIG_NET_SCH_NETEM=m
    CONFIG_NET_SCH_DRR=m
    CONFIG_NET_SCH_MQPRIO=m
    CONFIG_NET_SCH_CHOKE=m
    CONFIG_NET_SCH_QFQ=m
    CONFIG_NET_SCH_CODEL=m
    CONFIG_NET_SCH_FQ_CODEL=m
    # CONFIG_NET_SCH_FQ is not set
    # CONFIG_NET_SCH_HHF is not set
    # CONFIG_NET_SCH_PIE is not set
    CONFIG_NET_SCH_INGRESS=m
    # CONFIG_NET_SCH_PLUG is not set
    # Classification
    CONFIG_NET_CLS=y
    CONFIG_NET_CLS_BASIC=m
    CONFIG_NET_CLS_TCINDEX=m
    CONFIG_NET_CLS_ROUTE4=m
    CONFIG_NET_CLS_FW=m
    CONFIG_NET_CLS_U32=m
    # CONFIG_CLS_U32_PERF is not set
    CONFIG_CLS_U32_MARK=y
    CONFIG_NET_CLS_RSVP=m
    CONFIG_NET_CLS_RSVP6=m
    CONFIG_NET_CLS_FLOW=m
    # CONFIG_NET_CLS_CGROUP is not set
    # CONFIG_NET_CLS_BPF is not set
    CONFIG_NET_EMATCH=y
    CONFIG_NET_EMATCH_STACK=32
    CONFIG_NET_EMATCH_CMP=m
    CONFIG_NET_EMATCH_NBYTE=m
    CONFIG_NET_EMATCH_U32=m
    CONFIG_NET_EMATCH_META=m
    CONFIG_NET_EMATCH_TEXT=m
    # CONFIG_NET_EMATCH_CANID is not set
    CONFIG_NET_CLS_ACT=y
    CONFIG_NET_ACT_POLICE=m
    CONFIG_NET_ACT_GACT=m
    CONFIG_GACT_PROB=y
    CONFIG_NET_ACT_MIRRED=m
    CONFIG_NET_ACT_IPT=m
    CONFIG_NET_ACT_NAT=m
    CONFIG_NET_ACT_PEDIT=m
    CONFIG_NET_ACT_SIMP=m
    CONFIG_NET_ACT_SKBEDIT=m
    CONFIG_NET_ACT_CSUM=m
    # CONFIG_NET_ACT_VLAN is not set
    # CONFIG_NET_ACT_BPF is not set
    CONFIG_NET_CLS_IND=y
    CONFIG_NET_SCH_FIFO=y
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_MMAP is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_MPLS is not set
    # CONFIG_HSR is not set
    # CONFIG_NET_SWITCHDEV is not set
    # CONFIG_CGROUP_NET_PRIO is not set
    # CONFIG_CGROUP_NET_CLASSID is not set
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    # CONFIG_BPF_JIT is not set
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_NET_TCPPROBE is not set
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    CONFIG_CAN_GW=m
    # CAN Device Drivers
    # CONFIG_CAN_VCAN is not set
    # CONFIG_CAN_SLCAN is not set
    CONFIG_CAN_DEV=m
    CONFIG_CAN_CALC_BITTIMING=y
    # CONFIG_CAN_LEDS is not set
    # CONFIG_CAN_TI_HECC is not set
    # CONFIG_CAN_FLEXCAN is not set
    # CONFIG_CAN_GRCAN is not set
    # CONFIG_CAN_RCAR is not set
    # CONFIG_CAN_SJA1000 is not set
    CONFIG_CAN_C_CAN=m
    CONFIG_CAN_C_CAN_PLATFORM=m
    # CONFIG_CAN_C_CAN_PCI is not set
    # CONFIG_CAN_M_CAN is not set
    # CONFIG_CAN_CC770 is not set
    # CAN SPI interfaces
    # CONFIG_CAN_MCP251X is not set
    # CAN USB interfaces
    # CONFIG_CAN_EMS_USB is not set
    # CONFIG_CAN_ESD_USB2 is not set
    # CONFIG_CAN_GS_USB is not set
    # CONFIG_CAN_KVASER_USB is not set
    # CONFIG_CAN_PEAK_USB is not set
    # CONFIG_CAN_8DEV_USB is not set
    # CONFIG_CAN_SOFTING is not set
    # CONFIG_CAN_DEBUG_DEVICES is not set
    # CONFIG_IRDA is not set
    CONFIG_BT=m
    CONFIG_BT_BREDR=y
    CONFIG_BT_RFCOMM=m
    CONFIG_BT_RFCOMM_TTY=y
    CONFIG_BT_BNEP=m
    CONFIG_BT_BNEP_MC_FILTER=y
    CONFIG_BT_BNEP_PROTO_FILTER=y
    CONFIG_BT_HIDP=m
    CONFIG_BT_LE=y
    # CONFIG_BT_SELFTEST is not set
    CONFIG_BT_DEBUGFS=y
    # Bluetooth device drivers
    CONFIG_BT_INTEL=m
    CONFIG_BT_BCM=m
    CONFIG_BT_HCIBTUSB=m
    CONFIG_BT_HCIBTUSB_BCM=y
    CONFIG_BT_HCIBTSDIO=m
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_H4=y
    CONFIG_BT_HCIUART_BCSP=y
    # CONFIG_BT_HCIUART_ATH3K is not set
    CONFIG_BT_HCIUART_LL=y
    CONFIG_BT_HCIUART_3WIRE=y
    # CONFIG_BT_HCIUART_INTEL is not set
    # CONFIG_BT_HCIUART_BCM is not set
    CONFIG_BT_HCIBCM203X=m
    CONFIG_BT_HCIBPA10X=m
    CONFIG_BT_HCIBFUSB=m
    CONFIG_BT_HCIVHCI=m
    CONFIG_BT_MRVL=m
    CONFIG_BT_MRVL_SDIO=m
    # CONFIG_BT_ATH3K is not set
    CONFIG_BT_WILINK=m
    CONFIG_AF_RXRPC=m
    # CONFIG_AF_RXRPC_DEBUG is not set
    CONFIG_RXKAD=m
    CONFIG_WIRELESS=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WEXT_CORE=y
    CONFIG_WEXT_PROC=y
    CONFIG_WEXT_SPY=y
    CONFIG_CFG80211=m
    # CONFIG_NL80211_TESTMODE is not set
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_REG_DEBUG is not set
    # CONFIG_CFG80211_CERTIFICATION_ONUS is not set
    CONFIG_CFG80211_DEFAULT_PS=y
    # CONFIG_CFG80211_DEBUGFS is not set
    # CONFIG_CFG80211_INTERNAL_REGDB is not set
    # CONFIG_CFG80211_WEXT is not set
    CONFIG_LIB80211=m
    # CONFIG_LIB80211_DEBUG is not set
    CONFIG_MAC80211=m
    CONFIG_MAC80211_HAS_RC=y
    CONFIG_MAC80211_RC_MINSTREL=y
    CONFIG_MAC80211_RC_MINSTREL_HT=y
    # CONFIG_MAC80211_RC_MINSTREL_VHT is not set
    CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
    # CONFIG_MAC80211_MESH is not set
    CONFIG_MAC80211_LEDS=y
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_MESSAGE_TRACING is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    # CONFIG_WIMAX is not set
    # CONFIG_RFKILL is not set
    # CONFIG_RFKILL_REGULATOR is not set
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # CONFIG_NFC is not set
    CONFIG_HAVE_BPF_JIT=y
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER=y
    CONFIG_UEVENT_HELPER_PATH=""
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    CONFIG_FW_LOADER_USER_HELPER=y
    CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
    CONFIG_WANT_DEV_COREDUMP=y
    CONFIG_ALLOW_DEV_COREDUMP=y
    CONFIG_DEV_COREDUMP=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_GENERIC_CPU_DEVICES is not set
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=y
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_SHARED_BUFFER=y
    # CONFIG_FENCE_TRACE is not set
    CONFIG_DMA_CMA=y
    # Default contiguous memory area size:
    CONFIG_CMA_SIZE_MBYTES=24
    CONFIG_CMA_SIZE_SEL_MBYTES=y
    # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
    # CONFIG_CMA_SIZE_SEL_MIN is not set
    # CONFIG_CMA_SIZE_SEL_MAX is not set
    CONFIG_CMA_ALIGNMENT=8
    # Bus devices
    CONFIG_ARM_CCI=y
    CONFIG_ARM_CCI400_COMMON=y
    CONFIG_ARM_CCI400_PMU=y
    # CONFIG_ARM_CCN is not set
    # CONFIG_BRCMSTB_GISB_ARB is not set
    CONFIG_OMAP_INTERCONNECT=y
    CONFIG_OMAP_OCP2SCP=y
    # CONFIG_VEXPRESS_CONFIG is not set
    CONFIG_CONNECTOR=m
    CONFIG_MTD=y
    CONFIG_MTD_TESTS=m
    # CONFIG_MTD_REDBOOT_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    # CONFIG_MTD_AFS_PARTS is not set
    CONFIG_MTD_OF_PARTS=y
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    CONFIG_MTD_OOPS=y
    # CONFIG_MTD_SWAP is not set
    # CONFIG_MTD_PARTITIONED_MASTER is not set
    # RAM/ROM/Flash chip drivers
    CONFIG_MTD_CFI=y
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_GEN_PROBE=y
    # CONFIG_MTD_CFI_ADV_OPTIONS is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    CONFIG_MTD_CFI_INTELEXT=y
    # CONFIG_MTD_CFI_AMDSTD is not set
    # CONFIG_MTD_CFI_STAA is not set
    CONFIG_MTD_CFI_UTIL=y
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    CONFIG_MTD_PHYSMAP=y
    # CONFIG_MTD_PHYSMAP_COMPAT is not set
    CONFIG_MTD_PHYSMAP_OF=y
    # CONFIG_MTD_INTEL_VR_NOR is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_PMC551 is not set
    # CONFIG_MTD_DATAFLASH is not set
    CONFIG_MTD_M25P80=m
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    CONFIG_MTD_NAND_ECC=y
    # CONFIG_MTD_NAND_ECC_SMC is not set
    CONFIG_MTD_NAND=y
    CONFIG_MTD_NAND_BCH=y
    CONFIG_MTD_NAND_ECC_BCH=y
    # CONFIG_MTD_SM_COMMON is not set
    # CONFIG_MTD_NAND_DENALI is not set
    # CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_OMAP_BCH=y
    CONFIG_MTD_NAND_OMAP_BCH_BUILD=y
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND_RICOH is not set
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_NAND_DOCG4 is not set
    # CONFIG_MTD_NAND_CAFE is not set
    # CONFIG_MTD_NAND_NANDSIM is not set
    # CONFIG_MTD_NAND_PLATFORM is not set
    # CONFIG_MTD_NAND_HISI504 is not set
    CONFIG_MTD_ONENAND=y
    CONFIG_MTD_ONENAND_VERIFY_WRITE=y
    # CONFIG_MTD_ONENAND_GENERIC is not set
    # CONFIG_MTD_ONENAND_OTP is not set
    # CONFIG_MTD_ONENAND_2X_PROGRAM is not set
    # LPDDR & LPDDR2 PCM memory drivers
    # CONFIG_MTD_LPDDR is not set
    # CONFIG_MTD_LPDDR2_NVM is not set
    CONFIG_MTD_SPI_NOR=m
    CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_LIMIT=20
    # CONFIG_MTD_UBI_FASTMAP is not set
    # CONFIG_MTD_UBI_GLUEBI is not set
    # CONFIG_MTD_UBI_BLOCK is not set
    CONFIG_DTC=y
    CONFIG_OF=y
    # Device Tree and Open Firmware support
    # CONFIG_OF_UNITTEST is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_ADDRESS_PCI=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_NET=y
    CONFIG_OF_MDIO=y
    CONFIG_OF_PCI=y
    CONFIG_OF_PCI_IRQ=y
    CONFIG_OF_MTD=y
    CONFIG_OF_RESERVED_MEM=y
    # CONFIG_OF_OVERLAY is not set
    CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_NULL_BLK is not set
    # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
    # CONFIG_BLK_CPQ_CISS_DA is not set
    # CONFIG_BLK_DEV_DAC960 is not set
    # CONFIG_BLK_DEV_UMEM is not set
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # CONFIG_BLK_DEV_DRBD is not set
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_NVME is not set
    # CONFIG_BLK_DEV_SX8 is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=8096
    # CONFIG_BLK_DEV_PMEM is not set
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    # CONFIG_MG_DISK is not set
    # CONFIG_VIRTIO_BLK is not set
    # CONFIG_BLK_DEV_RBD is not set
    # CONFIG_BLK_DEV_RSXX is not set
    # Misc devices
    CONFIG_SENSORS_LIS3LV02D=m
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_PHANTOM is not set
    # CONFIG_SGI_IOC4 is not set
    # CONFIG_TIFM_CORE is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_HP_ILO is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    CONFIG_SENSORS_TSL2550=m
    # CONFIG_SENSORS_BH1780 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_TI_DAC7512 is not set
    CONFIG_BMP085=y
    CONFIG_BMP085_I2C=m
    # CONFIG_BMP085_SPI is not set
    # CONFIG_USB_SWITCH_FSA9480 is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    CONFIG_SRAM=y
    # CONFIG_C2PORT is not set
    # EEPROM support
    # CONFIG_EEPROM_AT24 is not set
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    CONFIG_EEPROM_93CX6=y
    # CONFIG_EEPROM_93XX46 is not set
    # CONFIG_CB710_CORE is not set
    # Texas Instruments shared transport line discipline
    CONFIG_TI_ST=m
    # CONFIG_SENSORS_LIS3_SPI is not set
    CONFIG_SENSORS_LIS3_I2C=m
    # Altera FPGA firmware download module
    # CONFIG_ALTERA_STAPL is not set
    # Intel MIC Bus Driver
    # Intel MIC Host Driver
    # Intel MIC Card Driver
    # CONFIG_ECHO is not set
    # CONFIG_CXL_BASE is not set
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_NETLINK is not set
    # CONFIG_SCSI_MQ_DEFAULT is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    # CONFIG_BLK_DEV_SR is not set
    # CONFIG_CHR_DEV_SG is not set
    # CONFIG_CHR_DEV_SCH is not set
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    CONFIG_SCSI_SCAN_ASYNC=y
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_CXGB3_ISCSI is not set
    # CONFIG_SCSI_CXGB4_ISCSI is not set
    # CONFIG_SCSI_BNX2_ISCSI is not set
    # CONFIG_BE2ISCSI is not set
    # CONFIG_BLK_DEV_3W_XXXX_RAID is not set
    # CONFIG_SCSI_HPSA is not set
    # CONFIG_SCSI_3W_9XXX is not set
    # CONFIG_SCSI_3W_SAS is not set
    # CONFIG_SCSI_ACARD is not set
    # CONFIG_SCSI_AACRAID is not set
    # CONFIG_SCSI_AIC7XXX is not set
    # CONFIG_SCSI_AIC79XX is not set
    # CONFIG_SCSI_AIC94XX is not set
    # CONFIG_SCSI_MVSAS is not set
    # CONFIG_SCSI_MVUMI is not set
    # CONFIG_SCSI_ARCMSR is not set
    # CONFIG_SCSI_ESAS2R is not set
    # CONFIG_MEGARAID_NEWGEN is not set
    # CONFIG_MEGARAID_LEGACY is not set
    # CONFIG_MEGARAID_SAS is not set
    # CONFIG_SCSI_MPT2SAS is not set
    # CONFIG_SCSI_MPT3SAS is not set
    # CONFIG_SCSI_UFSHCD is not set
    # CONFIG_SCSI_HPTIOP is not set
    # CONFIG_SCSI_DMX3191D is not set
    # CONFIG_SCSI_FUTURE_DOMAIN is not set
    # CONFIG_SCSI_IPS is not set
    # CONFIG_SCSI_INITIO is not set
    # CONFIG_SCSI_INIA100 is not set
    # CONFIG_SCSI_STEX is not set
    # CONFIG_SCSI_SYM53C8XX_2 is not set
    # CONFIG_SCSI_IPR is not set
    # CONFIG_SCSI_QLOGIC_1280 is not set
    # CONFIG_SCSI_QLA_ISCSI is not set
    # CONFIG_SCSI_DC395x is not set
    # CONFIG_SCSI_AM53C974 is not set
    # CONFIG_SCSI_NSP32 is not set
    # CONFIG_SCSI_WD719X is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_PMCRAID is not set
    # CONFIG_SCSI_PM8001 is not set
    # CONFIG_SCSI_VIRTIO is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    CONFIG_ATA=m
    # CONFIG_ATA_NONSTANDARD is not set
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    CONFIG_SATA_AHCI=m
    CONFIG_SATA_AHCI_PLATFORM=m
    # CONFIG_SATA_INIC162X is not set
    # CONFIG_SATA_ACARD_AHCI is not set
    # CONFIG_SATA_SIL24 is not set
    CONFIG_ATA_SFF=y
    # SFF controllers with custom DMA interface
    # CONFIG_PDC_ADMA is not set
    # CONFIG_SATA_QSTOR is not set
    # CONFIG_SATA_SX4 is not set
    CONFIG_ATA_BMDMA=y
    # SATA SFF controllers with BMDMA
    # CONFIG_ATA_PIIX is not set
    # CONFIG_SATA_MV is not set
    # CONFIG_SATA_NV is not set
    # CONFIG_SATA_PROMISE is not set
    # CONFIG_SATA_SIL is not set
    # CONFIG_SATA_SIS is not set
    # CONFIG_SATA_SVW is not set
    # CONFIG_SATA_ULI is not set
    # CONFIG_SATA_VIA is not set
    # CONFIG_SATA_VITESSE is not set
    # PATA SFF controllers with BMDMA
    # CONFIG_PATA_ALI is not set
    # CONFIG_PATA_AMD is not set
    # CONFIG_PATA_ARTOP is not set
    # CONFIG_PATA_ATIIXP is not set
    # CONFIG_PATA_ATP867X is not set
    # CONFIG_PATA_CMD64X is not set
    # CONFIG_PATA_CYPRESS is not set
    # CONFIG_PATA_EFAR is not set
    # CONFIG_PATA_HPT366 is not set
    # CONFIG_PATA_HPT37X is not set
    # CONFIG_PATA_HPT3X2N is not set
    # CONFIG_PATA_HPT3X3 is not set
    # CONFIG_PATA_IT8213 is not set
    # CONFIG_PATA_IT821X is not set
    # CONFIG_PATA_JMICRON is not set
    # CONFIG_PATA_MARVELL is not set
    # CONFIG_PATA_NETCELL is not set
    # CONFIG_PATA_NINJA32 is not set
    # CONFIG_PATA_NS87415 is not set
    # CONFIG_PATA_OLDPIIX is not set
    # CONFIG_PATA_OPTIDMA is not set
    # CONFIG_PATA_PDC2027X is not set
    # CONFIG_PATA_PDC_OLD is not set
    # CONFIG_PATA_RADISYS is not set
    # CONFIG_PATA_RDC is not set
    # CONFIG_PATA_SCH is not set
    # CONFIG_PATA_SERVERWORKS is not set
    # CONFIG_PATA_SIL680 is not set
    # CONFIG_PATA_SIS is not set
    # CONFIG_PATA_TOSHIBA is not set
    # CONFIG_PATA_TRIFLEX is not set
    # CONFIG_PATA_VIA is not set
    # CONFIG_PATA_WINBOND is not set
    # PIO-only SFF controllers
    # CONFIG_PATA_CMD640_PCI is not set
    # CONFIG_PATA_MPIIX is not set
    # CONFIG_PATA_NS87410 is not set
    # CONFIG_PATA_OPTI is not set
    # CONFIG_PATA_PLATFORM is not set
    # CONFIG_PATA_RZ1000 is not set
    # Generic fallback / legacy drivers
    # CONFIG_ATA_GENERIC is not set
    # CONFIG_PATA_LEGACY is not set
    # CONFIG_MD is not set
    # CONFIG_TARGET_CORE is not set
    # CONFIG_FUSION is not set
    # IEEE 1394 (FireWire) support
    # CONFIG_FIREWIRE is not set
    # CONFIG_FIREWIRE_NOSY is not set
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    # CONFIG_DUMMY is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_NET_FC is not set
    # CONFIG_IFB is not set
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_IPVLAN is not set
    # CONFIG_VXLAN is not set
    # CONFIG_NETCONSOLE is not set
    # CONFIG_NETPOLL is not set
    # CONFIG_NET_POLL_CONTROLLER is not set
    # CONFIG_TUN is not set
    # CONFIG_VETH is not set
    # CONFIG_VIRTIO_NET is not set
    # CONFIG_NLMON is not set
    # CONFIG_ARCNET is not set
    # CAIF transport drivers
    # Distributed Switch Architecture drivers
    # CONFIG_NET_DSA_MV88E6XXX is not set
    # CONFIG_NET_DSA_MV88E6XXX_NEED_PPU is not set
    CONFIG_ETHERNET=y
    CONFIG_NET_VENDOR_3COM=y
    # CONFIG_VORTEX is not set
    # CONFIG_TYPHOON is not set
    CONFIG_NET_VENDOR_ADAPTEC=y
    # CONFIG_ADAPTEC_STARFIRE is not set
    CONFIG_NET_VENDOR_AGERE=y
    # CONFIG_ET131X is not set
    CONFIG_NET_VENDOR_ALTEON=y
    # CONFIG_ACENIC is not set
    # CONFIG_ALTERA_TSE is not set
    CONFIG_NET_VENDOR_AMD=y
    # CONFIG_AMD8111_ETH is not set
    # CONFIG_PCNET32 is not set
    # CONFIG_NET_VENDOR_ARC is not set
    CONFIG_NET_VENDOR_ATHEROS=y
    # CONFIG_ATL2 is not set
    # CONFIG_ATL1 is not set
    # CONFIG_ATL1E is not set
    # CONFIG_ATL1C is not set
    # CONFIG_ALX is not set
    # CONFIG_NET_CADENCE is not set
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_BCMGENET is not set
    # CONFIG_BNX2 is not set
    # CONFIG_CNIC is not set
    CONFIG_TIGON3=m
    # CONFIG_BNX2X is not set
    # CONFIG_SYSTEMPORT is not set
    CONFIG_NET_VENDOR_BROCADE=y
    # CONFIG_BNA is not set
    CONFIG_NET_VENDOR_CHELSIO=y
    # CONFIG_CHELSIO_T1 is not set
    # CONFIG_CHELSIO_T3 is not set
    # CONFIG_CHELSIO_T4 is not set
    # CONFIG_CHELSIO_T4VF is not set
    # CONFIG_NET_VENDOR_CIRRUS is not set
    CONFIG_NET_VENDOR_CISCO=y
    # CONFIG_ENIC is not set
    # CONFIG_DM9000 is not set
    # CONFIG_DNET is not set
    CONFIG_NET_VENDOR_DEC=y
    # CONFIG_NET_TULIP is not set
    CONFIG_NET_VENDOR_DLINK=y
    # CONFIG_DL2K is not set
    # CONFIG_SUNDANCE is not set
    CONFIG_NET_VENDOR_EMULEX=y
    # CONFIG_BE2NET is not set
    CONFIG_NET_VENDOR_EXAR=y
    # CONFIG_S2IO is not set
    # CONFIG_VXGE is not set
    # CONFIG_NET_VENDOR_FARADAY is not set
    # CONFIG_NET_VENDOR_HISILICON is not set
    CONFIG_NET_VENDOR_HP=y
    # CONFIG_HP100 is not set
    CONFIG_NET_VENDOR_INTEL=y
    # CONFIG_E100 is not set
    CONFIG_E1000=m
    CONFIG_E1000E=m
    # CONFIG_IGB is not set
    # CONFIG_IGBVF is not set
    # CONFIG_IXGB is not set
    # CONFIG_IXGBE is not set
    # CONFIG_I40E is not set
    CONFIG_NET_VENDOR_I825XX=y
    # CONFIG_IP1000 is not set
    # CONFIG_JME is not set
    CONFIG_NET_VENDOR_MARVELL=y
    # CONFIG_MVMDIO is not set
    CONFIG_SKGE=m
    # CONFIG_SKGE_DEBUG is not set
    # CONFIG_SKGE_GENESIS is not set
    # CONFIG_SKY2 is not set
    CONFIG_NET_VENDOR_MELLANOX=y
    # CONFIG_MLX4_EN is not set
    # CONFIG_MLX4_CORE is not set
    # CONFIG_MLX5_CORE is not set
    CONFIG_NET_VENDOR_MICREL=y
    # CONFIG_KS8842 is not set
    CONFIG_KS8851=y
    CONFIG_KS8851_MLL=y
    # CONFIG_KSZ884X_PCI is not set
    # CONFIG_NET_VENDOR_MICROCHIP is not set
    CONFIG_NET_VENDOR_MYRI=y
    # CONFIG_MYRI10GE is not set
    # CONFIG_FEALNX is not set
    # CONFIG_NET_VENDOR_NATSEMI is not set
    CONFIG_NET_VENDOR_NVIDIA=y
    # CONFIG_FORCEDETH is not set
    CONFIG_NET_VENDOR_OKI=y
    # CONFIG_ETHOC is not set
    CONFIG_NET_PACKET_ENGINE=y
    # CONFIG_HAMACHI is not set
    # CONFIG_YELLOWFIN is not set
    CONFIG_NET_VENDOR_QLOGIC=y
    # CONFIG_QLA3XXX is not set
    # CONFIG_QLCNIC is not set
    # CONFIG_QLGE is not set
    # CONFIG_NETXEN_NIC is not set
    # CONFIG_NET_VENDOR_QUALCOMM is not set
    CONFIG_NET_VENDOR_REALTEK=y
    # CONFIG_8139CP is not set
    # CONFIG_8139TOO is not set
    # CONFIG_R8169 is not set
    CONFIG_NET_VENDOR_RDC=y
    # CONFIG_R6040 is not set
    CONFIG_NET_VENDOR_ROCKER=y
    # CONFIG_NET_VENDOR_SAMSUNG is not set
    # CONFIG_NET_VENDOR_SEEQ is not set
    CONFIG_NET_VENDOR_SILAN=y
    # CONFIG_SC92031 is not set
    CONFIG_NET_VENDOR_SIS=y
    # CONFIG_SIS900 is not set
    # CONFIG_SIS190 is not set
    # CONFIG_SFC is not set
    CONFIG_NET_VENDOR_SMSC=y
    CONFIG_SMC91X=y
    # CONFIG_EPIC100 is not set
    # CONFIG_SMC911X is not set
    CONFIG_SMSC911X=y
    # CONFIG_SMSC911X_ARCH_HOOKS is not set
    # CONFIG_SMSC9420 is not set
    # CONFIG_NET_VENDOR_STMICRO is not set
    CONFIG_NET_VENDOR_SUN=y
    # CONFIG_HAPPYMEAL is not set
    # CONFIG_SUNGEM is not set
    # CONFIG_CASSINI is not set
    # CONFIG_NIU is not set
    CONFIG_NET_VENDOR_TEHUTI=y
    # CONFIG_TEHUTI is not set
    CONFIG_NET_VENDOR_TI=y
    CONFIG_TI_DAVINCI_MDIO=y
    CONFIG_TI_DAVINCI_CPDMA=y
    CONFIG_TI_CPSW_PHY_SEL=y
    CONFIG_TI_CPSW_ALE=y
    CONFIG_TI_CPSW=y
    CONFIG_TI_CPTS=y
    # CONFIG_TLAN is not set
    # CONFIG_NET_VENDOR_VIA is not set
    # CONFIG_NET_VENDOR_WIZNET is not set
    # CONFIG_FDDI is not set
    # CONFIG_HIPPI is not set
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    CONFIG_AT803X_PHY=y
    # CONFIG_AMD_PHY is not set
    # CONFIG_MARVELL_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_CICADA_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    CONFIG_SMSC_PHY=y
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM7XXX_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    CONFIG_MICREL_PHY=y
    # CONFIG_DP83867_PHY is not set
    # CONFIG_FIXED_PHY is not set
    # CONFIG_MDIO_BITBANG is not set
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
    # CONFIG_MDIO_BCM_UNIMAC is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    # Host-side USB support is needed for USB Network Adapter support
    CONFIG_USB_NET_DRIVERS=m
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    # CONFIG_USB_PEGASUS is not set
    # CONFIG_USB_RTL8150 is not set
    # CONFIG_USB_RTL8152 is not set
    CONFIG_USB_USBNET=m
    CONFIG_USB_NET_AX8817X=m
    CONFIG_USB_NET_AX88179_178A=m
    CONFIG_USB_NET_CDCETHER=m
    # CONFIG_USB_NET_CDC_EEM is not set
    CONFIG_USB_NET_CDC_NCM=m
    # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
    # CONFIG_USB_NET_CDC_MBIM is not set
    # CONFIG_USB_NET_DM9601 is not set
    # CONFIG_USB_NET_SR9700 is not set
    # CONFIG_USB_NET_SR9800 is not set
    # CONFIG_USB_NET_SMSC75XX is not set
    CONFIG_USB_NET_SMSC95XX=m
    # CONFIG_USB_NET_GL620A is not set
    CONFIG_USB_NET_NET1080=m
    # CONFIG_USB_NET_PLUSB is not set
    # CONFIG_USB_NET_MCS7830 is not set
    # CONFIG_USB_NET_RNDIS_HOST is not set
    CONFIG_USB_NET_CDC_SUBSET=m
    CONFIG_USB_ALI_M5632=y
    CONFIG_USB_AN2720=y
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    CONFIG_USB_EPSON2888=y
    CONFIG_USB_KC2190=y
    CONFIG_USB_NET_ZAURUS=m
    # CONFIG_USB_NET_CX82310_ETH is not set
    # CONFIG_USB_NET_KALMIA is not set
    # CONFIG_USB_NET_QMI_WWAN is not set
    # CONFIG_USB_NET_INT51X1 is not set
    CONFIG_USB_CDC_PHONET=m
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_USB_VL600 is not set
    CONFIG_WLAN=y
    # CONFIG_LIBERTAS_THINFIRM is not set
    # CONFIG_ATMEL is not set
    # CONFIG_AT76C50X_USB is not set
    # CONFIG_PRISM54 is not set
    # CONFIG_USB_ZD1201 is not set
    # CONFIG_USB_NET_RNDIS_WLAN is not set
    # CONFIG_RTL8180 is not set
    # CONFIG_RTL8187 is not set
    # CONFIG_ADM8211 is not set
    # CONFIG_MAC80211_HWSIM is not set
    # CONFIG_MWL8K is not set
    # CONFIG_ATH_CARDS is not set
    # CONFIG_B43 is not set
    # CONFIG_B43LEGACY is not set
    # CONFIG_BRCMSMAC is not set
    # CONFIG_BRCMFMAC is not set
    # CONFIG_HOSTAP is not set
    # CONFIG_IPW2100 is not set
    # CONFIG_IPW2200 is not set
    CONFIG_IWLWIFI=m
    CONFIG_IWLWIFI_LEDS=y
    CONFIG_IWLDVM=m
    # CONFIG_IWLMVM is not set
    CONFIG_IWLWIFI_OPMODE_MODULAR=y
    # Debugging Options
    # CONFIG_IWLWIFI_DEBUG is not set
    # CONFIG_IWL4965 is not set
    # CONFIG_IWL3945 is not set
    CONFIG_LIBERTAS=m
    CONFIG_LIBERTAS_USB=m
    CONFIG_LIBERTAS_SDIO=m
    # CONFIG_LIBERTAS_SPI is not set
    CONFIG_LIBERTAS_DEBUG=y
    # CONFIG_LIBERTAS_MESH is not set
    # CONFIG_HERMES is not set
    # CONFIG_P54_COMMON is not set
    # CONFIG_RT2X00 is not set
    CONFIG_RTL_CARDS=m
    # CONFIG_RTL8192CE is not set
    # CONFIG_RTL8192SE is not set
    # CONFIG_RTL8192DE is not set
    # CONFIG_RTL8723AE is not set
    # CONFIG_RTL8723BE is not set
    # CONFIG_RTL8188EE is not set
    # CONFIG_RTL8192EE is not set
    # CONFIG_RTL8821AE is not set
    # CONFIG_RTL8192CU is not set
    CONFIG_WL_TI=y
    # CONFIG_WL1251 is not set
    CONFIG_WL12XX=m
    CONFIG_WL18XX=m
    CONFIG_WLCORE=m
    CONFIG_WLCORE_SPI=m
    CONFIG_WLCORE_SDIO=m
    CONFIG_WILINK_PLATFORM_DATA=y
    # CONFIG_ZD1211RW is not set
    CONFIG_MWIFIEX=m
    CONFIG_MWIFIEX_SDIO=m
    # CONFIG_MWIFIEX_PCIE is not set
    CONFIG_MWIFIEX_USB=m
    # CONFIG_CW1200 is not set
    # CONFIG_RSI_91X is not set
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # CONFIG_WAN is not set
    # CONFIG_VMXNET3 is not set
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    CONFIG_INPUT_POLLDEV=m
    # CONFIG_INPUT_SPARSEKMAP is not set
    CONFIG_INPUT_MATRIXKMAP=m
    # Userland interfaces
    CONFIG_INPUT_MOUSEDEV=y
    CONFIG_INPUT_MOUSEDEV_PSAUX=y
    CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
    CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
    CONFIG_INPUT_JOYDEV=m
    CONFIG_INPUT_EVDEV=m
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=m
    # CONFIG_KEYBOARD_QT1070 is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=m
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    CONFIG_KEYBOARD_MATRIX=m
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_SAMSUNG is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    CONFIG_KEYBOARD_OMAP4=m
    CONFIG_KEYBOARD_TWL4030=m
    # CONFIG_KEYBOARD_XTKBD is not set
    # CONFIG_KEYBOARD_CAP11XX is not set
    # CONFIG_KEYBOARD_BCM is not set
    # CONFIG_INPUT_MOUSE is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    CONFIG_TOUCHSCREEN_PROPERTIES=y
    CONFIG_TOUCHSCREEN_ADS7846=m
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    # CONFIG_TOUCHSCREEN_AR1021_I2C is not set
    # CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
    # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    # CONFIG_TOUCHSCREEN_GOODIX is not set
    # CONFIG_TOUCHSCREEN_ILI210X is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_ELAN is not set
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    # CONFIG_TOUCHSCREEN_MMS114 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    CONFIG_TOUCHSCREEN_EDT_FT5X06=m
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m
    CONFIG_TOUCHSCREEN_PIXCIR=m
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    CONFIG_TOUCHSCREEN_TSC2005=m
    CONFIG_TOUCHSCREEN_TSC2007=m
    # CONFIG_TOUCHSCREEN_ST1232 is not set
    # CONFIG_TOUCHSCREEN_SUR40 is not set
    # CONFIG_TOUCHSCREEN_SX8654 is not set
    # CONFIG_TOUCHSCREEN_TPS6507X is not set
    # CONFIG_TOUCHSCREEN_ZFORCE is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_BMA150 is not set
    # CONFIG_INPUT_E3X0_BUTTON is not set
    # CONFIG_INPUT_MMA8450 is not set
    # CONFIG_INPUT_MPU3050 is not set
    # CONFIG_INPUT_GP2A is not set
    # CONFIG_INPUT_GPIO_BEEPER is not set
    # CONFIG_INPUT_GPIO_TILT_POLLED is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_KXTJ9 is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    # CONFIG_INPUT_REGULATOR_HAPTIC is not set
    CONFIG_INPUT_TPS65218_PWRBUTTON=m
    CONFIG_INPUT_TWL4030_PWRBUTTON=m
    # CONFIG_INPUT_TWL4030_VIBRA is not set
    # CONFIG_INPUT_TWL6040_VIBRA is not set
    # CONFIG_INPUT_UINPUT is not set
    CONFIG_INPUT_PALMAS_PWRBUTTON=m
    # CONFIG_INPUT_PCF8574 is not set
    # CONFIG_INPUT_PWM_BEEPER is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    # CONFIG_INPUT_ADXL34X is not set
    # CONFIG_INPUT_IMS_PCU is not set
    # CONFIG_INPUT_CMA3000 is not set
    # CONFIG_INPUT_SOC_BUTTON_ARRAY is not set
    # CONFIG_INPUT_DRV260X_HAPTICS is not set
    # CONFIG_INPUT_DRV2667_HAPTICS is not set
    # Hardware I/O ports
    CONFIG_SERIO=m
    CONFIG_SERIO_SERPORT=m
    # CONFIG_SERIO_PCIPS2 is not set
    CONFIG_SERIO_LIBPS2=m
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_NOZOMI is not set
    # CONFIG_N_GSM is not set
    # CONFIG_TRACE_SINK is not set
    CONFIG_DEVMEM=y
    CONFIG_DEVKMEM=y
    # Serial drivers
    CONFIG_SERIAL_EARLYCON=y
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
    CONFIG_SERIAL_8250_CONSOLE=y
    # CONFIG_SERIAL_8250_DMA is not set
    CONFIG_SERIAL_8250_PCI=y
    CONFIG_SERIAL_8250_NR_UARTS=32
    CONFIG_SERIAL_8250_RUNTIME_UARTS=10
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    CONFIG_SERIAL_8250_DETECT_IRQ=y
    CONFIG_SERIAL_8250_RSA=y
    # CONFIG_SERIAL_8250_DW is not set
    # CONFIG_SERIAL_8250_EM is not set
    CONFIG_SERIAL_8250_OMAP=y
    CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
    # Non-8250 serial port support
    # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_JSM is not set
    CONFIG_SERIAL_OF_PLATFORM=y
    # CONFIG_SERIAL_OMAP is not set
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_SC16IS7XX is not set
    # CONFIG_SERIAL_BCM63XX is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_IFX6X60 is not set
    # CONFIG_SERIAL_XILINX_PS_UART is not set
    # CONFIG_SERIAL_ARC is not set
    # CONFIG_SERIAL_RP2 is not set
    # CONFIG_SERIAL_FSL_LPUART is not set
    # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
    # CONFIG_SERIAL_ST_ASC is not set
    # CONFIG_TTY_PRINTK is not set
    # CONFIG_HVC_DCC is not set
    # CONFIG_VIRTIO_CONSOLE is not set
    # CONFIG_IPMI_HANDLER is not set
    CONFIG_HW_RANDOM=m
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    CONFIG_HW_RANDOM_OMAP=m
    # CONFIG_HW_RANDOM_VIRTIO is not set
    # CONFIG_R3964 is not set
    # CONFIG_APPLICOM is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    CONFIG_DEVPORT=y
    # CONFIG_XILLYBUS is not set
    # I2C support
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    # CONFIG_I2C_MUX is not set
    CONFIG_I2C_HELPER_AUTO=y
    CONFIG_I2C_ALGOBIT=y
    # I2C Hardware Bus support
    # PC SMBus host controller drivers
    # CONFIG_I2C_ALI1535 is not set
    # CONFIG_I2C_ALI1563 is not set
    # CONFIG_I2C_ALI15X3 is not set
    # CONFIG_I2C_AMD756 is not set
    # CONFIG_I2C_AMD8111 is not set
    # CONFIG_I2C_I801 is not set
    # CONFIG_I2C_ISCH is not set
    # CONFIG_I2C_PIIX4 is not set
    # CONFIG_I2C_NFORCE2 is not set
    # CONFIG_I2C_SIS5595 is not set
    # CONFIG_I2C_SIS630 is not set
    # CONFIG_I2C_SIS96X is not set
    # CONFIG_I2C_VIA is not set
    # CONFIG_I2C_VIAPRO is not set
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    # CONFIG_I2C_DESIGNWARE_PCI is not set
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_PXA_PCI is not set
    # CONFIG_I2C_RK3X is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_ROBOTFUZZ_OSIF is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_STUB is not set
    # CONFIG_I2C_SLAVE is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_CADENCE is not set
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_OC_TINY is not set
    CONFIG_SPI_OMAP24XX=y
    CONFIG_SPI_TI_QSPI=m
    # CONFIG_SPI_PXA2XX is not set
    # CONFIG_SPI_PXA2XX_PCI is not set
    # CONFIG_SPI_ROCKCHIP is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_XCOMM is not set
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_DESIGNWARE is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_TLE62X0 is not set
    # CONFIG_SPMI is not set
    CONFIG_HSI=m
    CONFIG_HSI_BOARDINFO=y
    # HSI controllers
    # HSI clients
    # CONFIG_HSI_CHAR is not set
    # PPS support
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    # CONFIG_PPS_CLIENT_LDISC is not set
    # CONFIG_PPS_CLIENT_GPIO is not set
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    CONFIG_PINCTRL=y
    # Pin controllers
    CONFIG_PINMUX=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    # CONFIG_DEBUG_PINCTRL is not set
    # CONFIG_PINCTRL_AMD is not set
    CONFIG_PINCTRL_SINGLE=y
    CONFIG_PINCTRL_TI_IODELAY=y
    # CONFIG_PINCTRL_PALMAS is not set
    CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
    CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIOLIB=y
    CONFIG_GPIO_DEVRES=y
    CONFIG_OF_GPIO=y
    CONFIG_GPIOLIB_IRQCHIP=y
    CONFIG_DEBUG_GPIO=y
    CONFIG_GPIO_SYSFS=y
    # Memory mapped GPIO drivers
    # CONFIG_GPIO_74XX_MMIO is not set
    # CONFIG_GPIO_ALTERA is not set
    # CONFIG_GPIO_DWAPB is not set
    # CONFIG_GPIO_EM is not set
    # CONFIG_GPIO_GENERIC_PLATFORM is not set
    # CONFIG_GPIO_GRGPIO is not set
    CONFIG_GPIO_OMAP=y
    # CONFIG_GPIO_SCH311X is not set
    # CONFIG_GPIO_SYSCON is not set
    # CONFIG_GPIO_VX855 is not set
    # CONFIG_GPIO_ZEVIO is not set
    # I2C GPIO expanders
    # CONFIG_GPIO_ADP5588 is not set
    # CONFIG_GPIO_ADNP is not set
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCA953X is not set
    CONFIG_GPIO_PCF857X=y
    # CONFIG_GPIO_SX150X is not set
    # MFD GPIO expanders
    CONFIG_GPIO_PALMAS=y
    # CONFIG_GPIO_TPS65910 is not set
    CONFIG_GPIO_TWL4030=y
    # CONFIG_GPIO_TWL6040 is not set
    # PCI GPIO expanders
    # CONFIG_GPIO_AMD8111 is not set
    # CONFIG_GPIO_BT8XX is not set
    # CONFIG_GPIO_ML_IOH is not set
    # CONFIG_GPIO_RDC321X is not set
    # SPI GPIO expanders
    # CONFIG_GPIO_74X164 is not set
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_GPIO_MC33880 is not set
    # USB GPIO expanders
    CONFIG_W1=m
    CONFIG_W1_CON=y
    # 1-wire Bus Masters
    # CONFIG_W1_MASTER_MATROX is not set
    # CONFIG_W1_MASTER_DS2490 is not set
    # CONFIG_W1_MASTER_DS2482 is not set
    # CONFIG_W1_MASTER_DS1WM is not set
    # CONFIG_W1_MASTER_GPIO is not set
    CONFIG_HDQ_MASTER_OMAP=m
    # 1-wire Slaves
    # CONFIG_W1_SLAVE_THERM is not set
    # CONFIG_W1_SLAVE_SMEM is not set
    # CONFIG_W1_SLAVE_DS2408 is not set
    # CONFIG_W1_SLAVE_DS2413 is not set
    # CONFIG_W1_SLAVE_DS2406 is not set
    # CONFIG_W1_SLAVE_DS2423 is not set
    # CONFIG_W1_SLAVE_DS2431 is not set
    # CONFIG_W1_SLAVE_DS2433 is not set
    # CONFIG_W1_SLAVE_DS2760 is not set
    # CONFIG_W1_SLAVE_DS2780 is not set
    # CONFIG_W1_SLAVE_DS2781 is not set
    # CONFIG_W1_SLAVE_DS28E04 is not set
    # CONFIG_W1_SLAVE_BQ27000 is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_GENERIC_ADC_BATTERY is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_SBS is not set
    CONFIG_BATTERY_BQ27x00=m
    CONFIG_BATTERY_BQ27X00_I2C=y
    CONFIG_BATTERY_BQ27X00_PLATFORM=y
    # CONFIG_BATTERY_MAX17040 is not set
    # CONFIG_BATTERY_MAX17042 is not set
    CONFIG_CHARGER_ISP1704=m
    # CONFIG_CHARGER_MAX8903 is not set
    CONFIG_CHARGER_TWL4030=m
    # CONFIG_CHARGER_LP8727 is not set
    # CONFIG_CHARGER_GPIO is not set
    # CONFIG_CHARGER_MANAGER is not set
    CONFIG_CHARGER_BQ2415X=m
    CONFIG_CHARGER_BQ24190=m
    CONFIG_CHARGER_BQ24735=m
    # CONFIG_CHARGER_SMB347 is not set
    # CONFIG_BATTERY_GAUGE_LTC2941 is not set
    CONFIG_POWER_RESET=y
    # CONFIG_POWER_RESET_BRCMSTB is not set
    # CONFIG_POWER_RESET_GPIO is not set
    # CONFIG_POWER_RESET_GPIO_RESTART is not set
    # CONFIG_POWER_RESET_LTC2952 is not set
    # CONFIG_POWER_RESET_RESTART is not set
    # CONFIG_POWER_RESET_VERSATILE is not set
    # CONFIG_POWER_RESET_SYSCON is not set
    # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
    CONFIG_POWER_AVS=y
    CONFIG_VOLTAGE_DOMAIN=y
    # Voltage Domain Framework Drivers
    CONFIG_VOLTAGE_DOMAIN_OMAP=y
    CONFIG_HWMON=y
    # CONFIG_HWMON_VID is not set
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_I5K_AMB is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    CONFIG_SENSORS_GPIO_FAN=y
    # CONFIG_SENSORS_HIH6130 is not set
    # CONFIG_SENSORS_IIO_HWMON is not set
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_POWR1220 is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LTC2945 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4222 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4260 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6642 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_HTU21 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    CONFIG_SENSORS_LM75=m
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    # CONFIG_SENSORS_LM90 is not set
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    # CONFIG_SENSORS_LM95245 is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_NTC_THERMISTOR is not set
    # CONFIG_SENSORS_NCT6683 is not set
    # CONFIG_SENSORS_NCT6775 is not set
    # CONFIG_SENSORS_NCT7802 is not set
    # CONFIG_SENSORS_NCT7904 is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    # CONFIG_SENSORS_PWM_FAN is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SHTC1 is not set
    # CONFIG_SENSORS_SIS5595 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH56XX_COMMON is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_ADC128D818 is not set
    # CONFIG_SENSORS_ADS1015 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    # CONFIG_SENSORS_INA2XX is not set
    # CONFIG_SENSORS_THMC50 is not set
    CONFIG_SENSORS_TMP102=y
    # CONFIG_SENSORS_TMP103 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_VIA686A is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_VT8231 is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_THERMAL=y
    CONFIG_THERMAL_HWMON=y
    CONFIG_THERMAL_OF=y
    # CONFIG_THERMAL_WRITABLE_TRIPS is not set
    CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
    # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
    CONFIG_THERMAL_GOV_FAIR_SHARE=y
    CONFIG_THERMAL_GOV_STEP_WISE=y
    # CONFIG_THERMAL_GOV_BANG_BANG is not set
    CONFIG_THERMAL_GOV_USER_SPACE=y
    # CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
    CONFIG_CPU_THERMAL=y
    # CONFIG_CLOCK_THERMAL is not set
    # CONFIG_THERMAL_EMULATION is not set
    # CONFIG_IMX_THERMAL is not set
    # Texas Instruments thermal drivers
    CONFIG_TI_SOC_THERMAL=y
    CONFIG_TI_THERMAL=y
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_GPIO_WATCHDOG is not set
    # CONFIG_XILINX_WATCHDOG is not set
    # CONFIG_CADENCE_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_OMAP_WATCHDOG=m
    CONFIG_TWL4030_WATCHDOG=m
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_ALIM7101_WDT is not set
    # CONFIG_I6300ESB_WDT is not set
    # CONFIG_MEN_A21_WDT is not set
    # PCI-based Watchdog Cards
    # CONFIG_PCIPCWATCHDOG is not set
    # CONFIG_WDTPCI is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    # Broadcom specific AMBA
    # CONFIG_BCMA is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_MFD_AS3722 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_ATMEL_HLCDC is not set
    # CONFIG_MFD_BCM590XX is not set
    # CONFIG_MFD_AXP20X is not set
    # CONFIG_MFD_CROS_EC is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_DA9150 is not set
    # CONFIG_MFD_DLN2 is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_MFD_HI6421_PMIC is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_LPC_ICH is not set
    # CONFIG_LPC_SCH is not set
    # CONFIG_INTEL_SOC_PMIC is not set
    # CONFIG_MFD_JANZ_CMODIO is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX14577 is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX77843 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_MFD_MT6397 is not set
    # CONFIG_MFD_MENF21BMC is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_PM8921_CORE is not set
    # CONFIG_MFD_RDC321X is not set
    # CONFIG_MFD_RTSX_PCI is not set
    # CONFIG_MFD_RT5033 is not set
    # CONFIG_MFD_RTSX_USB is not set
    # CONFIG_MFD_RC5T583 is not set
    # CONFIG_MFD_RK808 is not set
    # CONFIG_MFD_RN5T618 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SKY81452 is not set
    # CONFIG_MFD_SMSC is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_MFD_STMPE is not set
    CONFIG_MFD_SYSCON=y
    CONFIG_MFD_TI_AM335X_TSCADC=m
    # CONFIG_MFD_LP3943 is not set
    # CONFIG_MFD_LP8788 is not set
    CONFIG_MFD_OMAP_USB_HOST=y
    CONFIG_MFD_PALMAS=y
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65090 is not set
    CONFIG_MFD_TPS65217=y
    CONFIG_MFD_TPS65218=y
    # CONFIG_MFD_TPS6586X is not set
    CONFIG_MFD_TPS65910=y
    # CONFIG_MFD_TPS65912 is not set
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_MFD_TPS80031 is not set
    CONFIG_TWL4030_CORE=y
    CONFIG_TWL4030_POWER=y
    CONFIG_MFD_TWL4030_AUDIO=y
    CONFIG_TWL6040_CORE=y
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_MFD_VX855 is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    CONFIG_REGULATOR_FIXED_VOLTAGE=y
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_ACT8865 is not set
    # CONFIG_REGULATOR_AD5398 is not set
    # CONFIG_REGULATOR_ANATOP is not set
    # CONFIG_REGULATOR_DA9210 is not set
    # CONFIG_REGULATOR_DA9211 is not set
    # CONFIG_REGULATOR_FAN53555 is not set
    # CONFIG_REGULATOR_GPIO is not set
    # CONFIG_REGULATOR_ISL9305 is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_LP872X is not set
    # CONFIG_REGULATOR_LP8755 is not set
    # CONFIG_REGULATOR_LTC3589 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    # CONFIG_REGULATOR_MAX8973 is not set
    CONFIG_REGULATOR_PALMAS=y
    CONFIG_REGULATOR_PBIAS=y
    # CONFIG_REGULATOR_PFUZE100 is not set
    # CONFIG_REGULATOR_PWM is not set
    CONFIG_REGULATOR_TI_ABB=y
    # CONFIG_REGULATOR_TPS51632 is not set
    CONFIG_REGULATOR_TPS62360=m
    CONFIG_REGULATOR_TPS65023=y
    CONFIG_REGULATOR_TPS6507X=y
    CONFIG_REGULATOR_TPS65217=y
    CONFIG_REGULATOR_TPS65218=y
    # CONFIG_REGULATOR_TPS6524X is not set
    CONFIG_REGULATOR_TPS65910=y
    CONFIG_REGULATOR_TWL4030=y
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    CONFIG_MEDIA_CAMERA_SUPPORT=y
    # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
    # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
    # CONFIG_MEDIA_RADIO_SUPPORT is not set
    # CONFIG_MEDIA_SDR_SUPPORT is not set
    # CONFIG_MEDIA_RC_SUPPORT is not set
    CONFIG_MEDIA_CONTROLLER=y
    CONFIG_VIDEO_DEV=y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    CONFIG_VIDEO_V4L2=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_V4L2_MEM2MEM_DEV=y
    CONFIG_VIDEOBUF2_CORE=y
    CONFIG_VIDEOBUF2_MEMOPS=y
    CONFIG_VIDEOBUF2_DMA_CONTIG=y
    CONFIG_VIDEOBUF2_VMALLOC=m
    # CONFIG_TTPCI_EEPROM is not set
    # Media drivers
    CONFIG_MEDIA_USB_SUPPORT=y
    # Webcam devices
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    CONFIG_USB_GSPCA=m
    # CONFIG_USB_M5602 is not set
    # CONFIG_USB_STV06XX is not set
    # CONFIG_USB_GL860 is not set
    # CONFIG_USB_GSPCA_BENQ is not set
    # CONFIG_USB_GSPCA_CONEX is not set
    # CONFIG_USB_GSPCA_CPIA1 is not set
    # CONFIG_USB_GSPCA_DTCS033 is not set
    # CONFIG_USB_GSPCA_ETOMS is not set
    # CONFIG_USB_GSPCA_FINEPIX is not set
    # CONFIG_USB_GSPCA_JEILINJ is not set
    # CONFIG_USB_GSPCA_JL2005BCD is not set
    # CONFIG_USB_GSPCA_KINECT is not set
    # CONFIG_USB_GSPCA_KONICA is not set
    # CONFIG_USB_GSPCA_MARS is not set
    # CONFIG_USB_GSPCA_MR97310A is not set
    # CONFIG_USB_GSPCA_NW80X is not set
    # CONFIG_USB_GSPCA_OV519 is not set
    # CONFIG_USB_GSPCA_OV534 is not set
    # CONFIG_USB_GSPCA_OV534_9 is not set
    # CONFIG_USB_GSPCA_PAC207 is not set
    # CONFIG_USB_GSPCA_PAC7302 is not set
    # CONFIG_USB_GSPCA_PAC7311 is not set
    # CONFIG_USB_GSPCA_SE401 is not set
    # CONFIG_USB_GSPCA_SN9C2028 is not set
    # CONFIG_USB_GSPCA_SN9C20X is not set
    # CONFIG_USB_GSPCA_SONIXB is not set
    # CONFIG_USB_GSPCA_SONIXJ is not set
    # CONFIG_USB_GSPCA_SPCA500 is not set
    # CONFIG_USB_GSPCA_SPCA501 is not set
    # CONFIG_USB_GSPCA_SPCA505 is not set
    # CONFIG_USB_GSPCA_SPCA506 is not set
    # CONFIG_USB_GSPCA_SPCA508 is not set
    # CONFIG_USB_GSPCA_SPCA561 is not set
    # CONFIG_USB_GSPCA_SPCA1528 is not set
    # CONFIG_USB_GSPCA_SQ905 is not set
    # CONFIG_USB_GSPCA_SQ905C is not set
    # CONFIG_USB_GSPCA_SQ930X is not set
    # CONFIG_USB_GSPCA_STK014 is not set
    # CONFIG_USB_GSPCA_STK1135 is not set
    # CONFIG_USB_GSPCA_STV0680 is not set
    # CONFIG_USB_GSPCA_SUNPLUS is not set
    # CONFIG_USB_GSPCA_T613 is not set
    # CONFIG_USB_GSPCA_TOPRO is not set
    # CONFIG_USB_GSPCA_TOUPTEK is not set
    # CONFIG_USB_GSPCA_TV8532 is not set
    # CONFIG_USB_GSPCA_VC032X is not set
    # CONFIG_USB_GSPCA_VICAM is not set
    # CONFIG_USB_GSPCA_XIRLINK_CIT is not set
    # CONFIG_USB_GSPCA_ZC3XX is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_USB_ZR364XX is not set
    # CONFIG_USB_STKWEBCAM is not set
    # CONFIG_USB_S2255 is not set
    # CONFIG_VIDEO_USBTV is not set
    # Webcam, TV (analog/digital) USB devices
    # CONFIG_VIDEO_EM28XX is not set
    # CONFIG_MEDIA_PCI_SUPPORT is not set
    CONFIG_V4L_PLATFORM_DRIVERS=y
    # CONFIG_VIDEO_CAFE_CCIC is not set
    # CONFIG_SOC_CAMERA is not set
    # CONFIG_VIDEO_XILINX is not set
    CONFIG_V4L_MEM2MEM_DRIVERS=y
    # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
    # CONFIG_VIDEO_SH_VEU is not set
    # CONFIG_V4L_TEST_DRIVERS is not set
    # Supported MMC/SDIO adapters
    # CONFIG_CYPRESS_FIRMWARE is not set
    # Media ancillary drivers (tuners, sensors, i2c, frontends)
    # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
    # Encoders, decoders, sensors and other helper chips
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_UDA1342 is not set
    # CONFIG_VIDEO_WM8775 is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # CONFIG_VIDEO_SONY_BTF_MPX is not set
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # Video decoders
    # CONFIG_VIDEO_ADV7180 is not set
    # CONFIG_VIDEO_ADV7183 is not set
    # CONFIG_VIDEO_ADV7604 is not set
    # CONFIG_VIDEO_ADV7842 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_ML86V7667 is not set
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_TW2804 is not set
    # CONFIG_VIDEO_TW9903 is not set
    # CONFIG_VIDEO_TW9906 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # Video encoders
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_ADV7393 is not set
    # CONFIG_VIDEO_ADV7511 is not set
    # CONFIG_VIDEO_AD9389B is not set
    # CONFIG_VIDEO_AK881X is not set
    # CONFIG_VIDEO_THS8200 is not set
    # Camera sensor devices
    CONFIG_VIDEO_OV2659=m
    # CONFIG_VIDEO_OV7640 is not set
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_OV9650 is not set
    CONFIG_VIDEO_OV1063X=m
    # CONFIG_VIDEO_VS6624 is not set
    # CONFIG_VIDEO_MT9M032 is not set
    # CONFIG_VIDEO_MT9P031 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_MT9V032 is not set
    CONFIG_VIDEO_MT9T11X=m
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_VIDEO_NOON010PC30 is not set
    # CONFIG_VIDEO_M5MOLS is not set
    # CONFIG_VIDEO_S5K6AA is not set
    # CONFIG_VIDEO_S5K6A3 is not set
    # CONFIG_VIDEO_S5K4ECGX is not set
    # CONFIG_VIDEO_S5K5BAF is not set
    # CONFIG_VIDEO_SMIAPP is not set
    # CONFIG_VIDEO_S5C73M3 is not set
    # Flash devices
    # CONFIG_VIDEO_ADP1653 is not set
    # CONFIG_VIDEO_AS3645A is not set
    # CONFIG_VIDEO_LM3560 is not set
    # CONFIG_VIDEO_LM3646 is not set
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # Audio/Video compression chips
    # CONFIG_VIDEO_SAA6752HS is not set
    # Miscellaneous helper chips
    # CONFIG_VIDEO_THS7303 is not set
    # CONFIG_VIDEO_M52790 is not set
    # Sensors used on soc_camera driver
    # Customise DVB Frontends
    CONFIG_DVB_AU8522=m
    CONFIG_DVB_AU8522_V4L=m
    CONFIG_DVB_TUNER_DIB0070=m
    CONFIG_DVB_TUNER_DIB0090=m
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # Graphics support
    CONFIG_VGA_ARB=y
    CONFIG_VGA_ARB_MAX_GPUS=16
    # Direct Rendering Manager
    CONFIG_DRM=y
    CONFIG_DRM_KMS_HELPER=y
    CONFIG_DRM_KMS_FB_HELPER=y
    # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
    CONFIG_DRM_GEM_CMA_HELPER=y
    CONFIG_DRM_KMS_CMA_HELPER=y
    # I2C encoder or helper chips
    # CONFIG_DRM_I2C_ADV7511 is not set
    # CONFIG_DRM_I2C_CH7006 is not set
    # CONFIG_DRM_I2C_SIL164 is not set
    CONFIG_DRM_I2C_NXP_TDA998X=y
    # CONFIG_DRM_PTN3460 is not set
    # CONFIG_DRM_PS8622 is not set
    # CONFIG_DRM_TDFX is not set
    # CONFIG_DRM_R128 is not set
    # CONFIG_DRM_RADEON is not set
    # CONFIG_DRM_NOUVEAU is not set
    # CONFIG_DRM_MGA is not set
    # CONFIG_DRM_VIA is not set
    # CONFIG_DRM_SAVAGE is not set
    # CONFIG_DRM_VGEM is not set
    # CONFIG_DRM_EXYNOS is not set
    # CONFIG_DRM_VMWGFX is not set
    # CONFIG_DRM_UDL is not set
    # CONFIG_DRM_AST is not set
    # CONFIG_DRM_MGAG200 is not set
    # CONFIG_DRM_CIRRUS_QEMU is not set
    # CONFIG_DRM_ARMADA is not set
    CONFIG_DRM_OMAP=y
    CONFIG_DRM_OMAP_NUM_CRTCS=2
    CONFIG_DRM_OMAP_SGX_PLUGIN=y
    CONFIG_DRM_OMAP_WB_M2M=y
    CONFIG_DRM_TILCDC=y
    # CONFIG_DRM_QXL is not set
    # CONFIG_DRM_BOCHS is not set
    # CONFIG_DRM_STI is not set
    # Frame buffer Devices
    CONFIG_FB=y
    CONFIG_FIRMWARE_EDID=y
    CONFIG_FB_CMDLINE=y
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    # CONFIG_FB_CFB_FILLRECT is not set
    # CONFIG_FB_CFB_COPYAREA is not set
    # CONFIG_FB_CFB_IMAGEBLIT is not set
    # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
    CONFIG_FB_SYS_FILLRECT=y
    CONFIG_FB_SYS_COPYAREA=y
    CONFIG_FB_SYS_IMAGEBLIT=y
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    CONFIG_FB_SYS_FOPS=y
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    CONFIG_FB_MODE_HELPERS=y
    CONFIG_FB_TILEBLITTING=y
    # Frame buffer hardware drivers
    # CONFIG_FB_CIRRUS is not set
    # CONFIG_FB_PM2 is not set
    # CONFIG_FB_CYBER2000 is not set
    # CONFIG_FB_ASILIANT is not set
    # CONFIG_FB_IMSTT is not set
    # CONFIG_FB_UVESA is not set
    # CONFIG_FB_OPENCORES is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_NVIDIA is not set
    # CONFIG_FB_RIVA is not set
    # CONFIG_FB_I740 is not set
    # CONFIG_FB_MATROX is not set
    # CONFIG_FB_RADEON is not set
    # CONFIG_FB_ATY128 is not set
    # CONFIG_FB_ATY is not set
    # CONFIG_FB_S3 is not set
    # CONFIG_FB_SAVAGE is not set
    # CONFIG_FB_SIS is not set
    # CONFIG_FB_NEOMAGIC is not set
    # CONFIG_FB_KYRO is not set
    # CONFIG_FB_3DFX is not set
    # CONFIG_FB_VOODOO1 is not set
    # CONFIG_FB_VT8623 is not set
    # CONFIG_FB_TRIDENT is not set
    # CONFIG_FB_ARK is not set
    # CONFIG_FB_PM3 is not set
    # CONFIG_FB_CARMINE is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_DA8XX is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_FB_AUO_K190X is not set
    # CONFIG_FB_SIMPLE is not set
    CONFIG_OMAP2_DSS_INIT=y
    CONFIG_OMAP_DSS_BASE=y
    CONFIG_OMAP2_DSS=y
    # CONFIG_OMAP2_DSS_DEBUG is not set
    # CONFIG_OMAP2_DSS_DEBUGFS is not set
    CONFIG_OMAP2_DSS_DPI=y
    CONFIG_OMAP2_DSS_VENC=y
    CONFIG_OMAP2_DSS_HDMI_COMMON=y
    CONFIG_OMAP4_DSS_HDMI=y
    CONFIG_OMAP5_DSS_HDMI=y
    CONFIG_OMAP2_DSS_SDI=y
    CONFIG_OMAP2_DSS_DSI=y
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
    # OMAP Display Device Drivers (new device model)
    # CONFIG_DISPLAY_ENCODER_OPA362 is not set
    CONFIG_DISPLAY_ENCODER_TFP410=m
    CONFIG_DISPLAY_ENCODER_TPD12S015=y
    CONFIG_DISPLAY_DRA7EVM_ENCODER_TPD12S015=y
    CONFIG_DISPLAY_ENCODER_SII9022=y
    CONFIG_DISPLAY_ENCODER_SII9022_AUDIO_CODEC=y
    CONFIG_DISPLAY_ENCODER_TC358768=y
    CONFIG_DISPLAY_CONNECTOR_DVI=m
    CONFIG_DISPLAY_CONNECTOR_HDMI=y
    CONFIG_DISPLAY_CONNECTOR_ANALOG_TV=m
    CONFIG_DISPLAY_PANEL_DPI=y
    CONFIG_DISPLAY_PANEL_DSI_CM=m
    CONFIG_DISPLAY_PANEL_SONY_ACX565AKM=m
    CONFIG_DISPLAY_PANEL_LGPHILIPS_LB035Q02=m
    CONFIG_DISPLAY_PANEL_SHARP_LS037V7DW01=m
    CONFIG_DISPLAY_PANEL_TPO_TD028TTEC1=m
    CONFIG_DISPLAY_PANEL_TPO_TD043MTEA1=m
    CONFIG_DISPLAY_PANEL_NEC_NL8048HL11=m
    CONFIG_DISPLAY_PANEL_TLC59108=y
    # CONFIG_FB_SSD1307 is not set
    CONFIG_BACKLIGHT_LCD_SUPPORT=y
    CONFIG_LCD_CLASS_DEVICE=y
    # CONFIG_LCD_L4F00242T03 is not set
    # CONFIG_LCD_LMS283GF05 is not set
    # CONFIG_LCD_LTV350QV is not set
    # CONFIG_LCD_ILI922X is not set
    # CONFIG_LCD_ILI9320 is not set
    # CONFIG_LCD_TDO24M is not set
    # CONFIG_LCD_VGG2432A4 is not set
    CONFIG_LCD_PLATFORM=y
    # CONFIG_LCD_S6E63M0 is not set
    # CONFIG_LCD_LD9040 is not set
    # CONFIG_LCD_AMS369FG06 is not set
    # CONFIG_LCD_LMS501KF03 is not set
    # CONFIG_LCD_HX8357 is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    CONFIG_BACKLIGHT_GENERIC=m
    CONFIG_BACKLIGHT_PWM=y
    # CONFIG_BACKLIGHT_ADP8860 is not set
    # CONFIG_BACKLIGHT_ADP8870 is not set
    # CONFIG_BACKLIGHT_LM3630A is not set
    # CONFIG_BACKLIGHT_LM3639 is not set
    # CONFIG_BACKLIGHT_LP855X is not set
    CONFIG_BACKLIGHT_PANDORA=m
    # CONFIG_BACKLIGHT_TPS65217 is not set
    CONFIG_BACKLIGHT_GPIO=y
    # CONFIG_BACKLIGHT_LV5207LP is not set
    # CONFIG_BACKLIGHT_BD6107 is not set
    CONFIG_BACKLIGHT_LED=y
    # CONFIG_VGASTATE is not set
    CONFIG_VIDEOMODE_HELPERS=y
    CONFIG_HDMI=y
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
    CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
    CONFIG_LOGO=y
    CONFIG_LOGO_LINUX_MONO=y
    CONFIG_LOGO_LINUX_VGA16=y
    CONFIG_LOGO_LINUX_CLUT224=y
    CONFIG_SOUND=y
    CONFIG_SOUND_OSS_CORE=y
    CONFIG_SOUND_OSS_CORE_PRECLAIM=y
    CONFIG_SND=y
    CONFIG_SND_TIMER=y
    CONFIG_SND_PCM=y
    CONFIG_SND_DMAENGINE_PCM=y
    CONFIG_SND_HWDEP=m
    CONFIG_SND_RAWMIDI=m
    CONFIG_SND_COMPRESS_OFFLOAD=y
    CONFIG_SND_JACK=y
    # CONFIG_SND_SEQUENCER is not set
    CONFIG_SND_OSSEMUL=y
    CONFIG_SND_MIXER_OSS=m
    CONFIG_SND_PCM_OSS=m
    CONFIG_SND_PCM_OSS_PLUGINS=y
    # CONFIG_SND_HRTIMER is not set
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    CONFIG_SND_VERBOSE_PRINTK=y
    CONFIG_SND_DEBUG=y
    # CONFIG_SND_DEBUG_VERBOSE is not set
    # CONFIG_SND_PCM_XRUN_DEBUG is not set
    # CONFIG_SND_RAWMIDI_SEQ is not set
    # CONFIG_SND_OPL3_LIB_SEQ is not set
    # CONFIG_SND_OPL4_LIB_SEQ is not set
    # CONFIG_SND_SBAWE_SEQ is not set
    # CONFIG_SND_EMU10K1_SEQ is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    CONFIG_SND_PCI=y
    # CONFIG_SND_AD1889 is not set
    # CONFIG_SND_ALS300 is not set
    # CONFIG_SND_ALI5451 is not set
    # CONFIG_SND_ATIIXP is not set
    # CONFIG_SND_ATIIXP_MODEM is not set
    # CONFIG_SND_AU8810 is not set
    # CONFIG_SND_AU8820 is not set
    # CONFIG_SND_AU8830 is not set
    # CONFIG_SND_AW2 is not set
    # CONFIG_SND_AZT3328 is not set
    # CONFIG_SND_BT87X is not set
    # CONFIG_SND_CA0106 is not set
    # CONFIG_SND_CMIPCI is not set
    # CONFIG_SND_OXYGEN is not set
    # CONFIG_SND_CS4281 is not set
    # CONFIG_SND_CS46XX is not set
    # CONFIG_SND_CTXFI is not set
    # CONFIG_SND_DARLA20 is not set
    # CONFIG_SND_GINA20 is not set
    # CONFIG_SND_LAYLA20 is not set
    # CONFIG_SND_DARLA24 is not set
    # CONFIG_SND_GINA24 is not set
    # CONFIG_SND_LAYLA24 is not set
    # CONFIG_SND_MONA is not set
    # CONFIG_SND_MIA is not set
    # CONFIG_SND_ECHO3G is not set
    # CONFIG_SND_INDIGO is not set
    # CONFIG_SND_INDIGOIO is not set
    # CONFIG_SND_INDIGODJ is not set
    # CONFIG_SND_INDIGOIOX is not set
    # CONFIG_SND_INDIGODJX is not set
    # CONFIG_SND_EMU10K1 is not set
    # CONFIG_SND_EMU10K1X is not set
    # CONFIG_SND_ENS1370 is not set
    # CONFIG_SND_ENS1371 is not set
    # CONFIG_SND_ES1938 is not set
    # CONFIG_SND_ES1968 is not set
    # CONFIG_SND_FM801 is not set
    # CONFIG_SND_HDSP is not set
    # CONFIG_SND_HDSPM is not set
    # CONFIG_SND_ICE1712 is not set
    # CONFIG_SND_ICE1724 is not set
    # CONFIG_SND_INTEL8X0 is not set
    # CONFIG_SND_INTEL8X0M is not set
    # CONFIG_SND_KORG1212 is not set
    # CONFIG_SND_LOLA is not set
    # CONFIG_SND_LX6464ES is not set
    # CONFIG_SND_MAESTRO3 is not set
    # CONFIG_SND_MIXART is not set
    # CONFIG_SND_NM256 is not set
    # CONFIG_SND_PCXHR is not set
    # CONFIG_SND_RIPTIDE is not set
    # CONFIG_SND_RME32 is not set
    # CONFIG_SND_RME96 is not set
    # CONFIG_SND_RME9652 is not set
    # CONFIG_SND_SE6X is not set
    # CONFIG_SND_SONICVIBES is not set
    # CONFIG_SND_TRIDENT is not set
    # CONFIG_SND_VIA82XX is not set
    # CONFIG_SND_VIA82XX_MODEM is not set
    # CONFIG_SND_VIRTUOSO is not set
    # CONFIG_SND_VX222 is not set
    # CONFIG_SND_YMFPCI is not set
    # HD-Audio
    # CONFIG_SND_HDA_INTEL is not set
    CONFIG_SND_ARM=y
    CONFIG_SND_SPI=y
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=m
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_6FIRE is not set
    # CONFIG_SND_USB_HIFACE is not set
    # CONFIG_SND_BCD2000 is not set
    # CONFIG_SND_USB_POD is not set
    # CONFIG_SND_USB_PODHD is not set
    # CONFIG_SND_USB_TONEPORT is not set
    # CONFIG_SND_USB_VARIAX is not set
    CONFIG_SND_SOC=y
    CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
    # CONFIG_SND_ATMEL_SOC is not set
    CONFIG_SND_EDMA_SOC=y
    CONFIG_SND_DAVINCI_SOC_MCASP=y
    CONFIG_SND_DAVINCI_SOC_GENERIC_EVM=m
    CONFIG_SND_AM33XX_SOC_EVM=m
    # CONFIG_SND_DESIGNWARE_I2S is not set
    # SoC Audio for Freescale CPUs
    # Common SoC Audio options for Freescale CPUs:
    # CONFIG_SND_SOC_FSL_ASRC is not set
    # CONFIG_SND_SOC_FSL_SAI is not set
    # CONFIG_SND_SOC_FSL_SSI is not set
    # CONFIG_SND_SOC_FSL_SPDIF is not set
    # CONFIG_SND_SOC_FSL_ESAI is not set
    # CONFIG_SND_SOC_IMX_AUDMUX is not set
    CONFIG_SND_OMAP_SOC=y
    CONFIG_SND_OMAP_SOC_MCBSP=m
    CONFIG_SND_OMAP_SOC_HDMI_AUDIO=m
    # CONFIG_SND_OMAP_SOC_RX51 is not set
    CONFIG_SND_OMAP_SOC_OMAP_TWL4030=m
    # CONFIG_SND_SOC_QCOM is not set
    # CONFIG_SND_SOC_XTFPGA_I2S is not set
    CONFIG_SND_SOC_I2C_AND_SPI=y
    # CODEC drivers
    # CONFIG_SND_SOC_ADAU1701 is not set
    # CONFIG_SND_SOC_AK4104 is not set
    # CONFIG_SND_SOC_AK4554 is not set
    # CONFIG_SND_SOC_AK4642 is not set
    # CONFIG_SND_SOC_AK5386 is not set
    # CONFIG_SND_SOC_ALC5623 is not set
    # CONFIG_SND_SOC_CS35L32 is not set
    CONFIG_SND_SOC_TLV320AIC32X4=y
    # CONFIG_SND_SOC_CS42L51_I2C is not set
    # CONFIG_SND_SOC_CS42L52 is not set
    # CONFIG_SND_SOC_CS42L56 is not set
    # CONFIG_SND_SOC_CS42L73 is not set
    # CONFIG_SND_SOC_CS4265 is not set
    # CONFIG_SND_SOC_CS4270 is not set
    # CONFIG_SND_SOC_CS4271_I2C is not set
    # CONFIG_SND_SOC_CS4271_SPI is not set
    # CONFIG_SND_SOC_CS42XX8_I2C is not set
    CONFIG_SND_SOC_HDMI_CODEC=m
    # CONFIG_SND_SOC_ES8328 is not set
    # CONFIG_SND_SOC_PCM1681 is not set
    # CONFIG_SND_SOC_PCM1792A is not set
    # CONFIG_SND_SOC_PCM512x_I2C is not set
    # CONFIG_SND_SOC_PCM512x_SPI is not set
    # CONFIG_SND_SOC_RT5631 is not set
    # CONFIG_SND_SOC_RT5677_SPI is not set
    # CONFIG_SND_SOC_SGTL5000 is not set
    # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
    # CONFIG_SND_SOC_SPDIF is not set
    # CONFIG_SND_SOC_SSM2602_SPI is not set
    # CONFIG_SND_SOC_SSM2602_I2C is not set
    # CONFIG_SND_SOC_SSM4567 is not set
    # CONFIG_SND_SOC_STA32X is not set
    # CONFIG_SND_SOC_STA350 is not set
    # CONFIG_SND_SOC_TAS2552 is not set
    # CONFIG_SND_SOC_TAS5086 is not set
    # CONFIG_SND_SOC_TFA9879 is not set
    # CONFIG_SND_SOC_TLV320AIC23_I2C is not set
    # CONFIG_SND_SOC_TLV320AIC23_SPI is not set
    CONFIG_SND_SOC_TLV320AIC31XX=m
    CONFIG_SND_SOC_TLV320AIC3X=m
    # CONFIG_SND_SOC_TS3A227E is not set
    CONFIG_SND_SOC_TWL4030=m
    # CONFIG_SND_SOC_WM8510 is not set
    # CONFIG_SND_SOC_WM8523 is not set
    # CONFIG_SND_SOC_WM8580 is not set
    # CONFIG_SND_SOC_WM8711 is not set
    # CONFIG_SND_SOC_WM8728 is not set
    # CONFIG_SND_SOC_WM8731 is not set
    # CONFIG_SND_SOC_WM8737 is not set
    # CONFIG_SND_SOC_WM8741 is not set
    # CONFIG_SND_SOC_WM8750 is not set
    # CONFIG_SND_SOC_WM8753 is not set
    # CONFIG_SND_SOC_WM8770 is not set
    # CONFIG_SND_SOC_WM8776 is not set
    # CONFIG_SND_SOC_WM8804_I2C is not set
    # CONFIG_SND_SOC_WM8804_SPI is not set
    # CONFIG_SND_SOC_WM8903 is not set
    # CONFIG_SND_SOC_WM8962 is not set
    # CONFIG_SND_SOC_WM8978 is not set
    # CONFIG_SND_SOC_TPA6130A2 is not set
    CONFIG_SND_SIMPLE_CARD=m
    # CONFIG_SOUND_PRIME is not set
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    # CONFIG_UHID is not set
    CONFIG_HID_GENERIC=m
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_BETOP_FF is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CP2112 is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_GT683R is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LENOVO is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_MULTITOUCH is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PENMOUNT is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PLANTRONICS is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_RMI is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THINGM is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_WIIMOTE is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # USB HID support
    CONFIG_USB_HID=m
    # CONFIG_HID_PID is not set
    CONFIG_USB_HIDDEV=y
    # USB HID Boot Protocol drivers
    CONFIG_USB_KBD=m
    CONFIG_USB_MOUSE=m
    # I2C HID support
    # CONFIG_I2C_HID is not set
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=m
    CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    CONFIG_USB_MON=m
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_XHCI_HCD=m
    CONFIG_USB_XHCI_PCI=m
    CONFIG_USB_XHCI_PLATFORM=m
    CONFIG_USB_EHCI_HCD=m
    # CONFIG_USB_EHCI_ROOT_HUB_TT is not set
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    CONFIG_USB_EHCI_PCI=m
    CONFIG_USB_EHCI_HCD_OMAP=m
    # CONFIG_USB_EHCI_HCD_PLATFORM is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_FUSBH200_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_MAX3421_HCD is not set
    CONFIG_USB_OHCI_HCD=m
    CONFIG_USB_OHCI_HCD_PCI=m
    # CONFIG_USB_OHCI_HCD_PLATFORM is not set
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    # USB Device Class drivers
    # CONFIG_USB_ACM is not set
    # CONFIG_USB_PRINTER is not set
    CONFIG_USB_WDM=m
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=m
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    # CONFIG_USB_UAS is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # CONFIG_USBIP_CORE is not set
    CONFIG_USB_MUSB_HDRC=m
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    CONFIG_USB_MUSB_DUAL_ROLE=y
    # Platform Glue Layer
    CONFIG_USB_MUSB_OMAP2PLUS=m
    CONFIG_USB_MUSB_AM35X=m
    CONFIG_USB_MUSB_DSPS=m
    CONFIG_USB_MUSB_AM335X_CHILD=m
    # CONFIG_USB_INVENTRA_DMA is not set
    CONFIG_USB_TI_CPPI41_DMA=y
    # CONFIG_MUSB_PIO_ONLY is not set
    CONFIG_USB_DWC3=m
    # CONFIG_USB_DWC3_HOST is not set
    # CONFIG_USB_DWC3_GADGET is not set
    CONFIG_USB_DWC3_DUAL_ROLE=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=m
    CONFIG_USB_DWC3_PCI=m
    # Debugging features
    # CONFIG_USB_DWC3_DEBUG is not set
    # CONFIG_USB_DWC2 is not set
    # CONFIG_USB_CHIPIDEA is not set
    # CONFIG_USB_ISP1760 is not set
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_LED is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    CONFIG_USB_TEST=m
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    # CONFIG_USB_HSIC_USB3503 is not set
    # CONFIG_USB_LINK_LAYER_TEST is not set
    # CONFIG_USB_CHAOSKEY is not set
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_AM335X_CONTROL_USB=y
    CONFIG_AM335X_PHY_USB=y
    # CONFIG_TWL6030_USB is not set
    # CONFIG_USB_GPIO_VBUS is not set
    # CONFIG_USB_ISP1301 is not set
    # CONFIG_USB_ULPI is not set
    CONFIG_USB_GADGET=m
    CONFIG_USB_GADGET_DEBUG=y
    # CONFIG_USB_GADGET_VERBOSE is not set
    CONFIG_USB_GADGET_DEBUG_FILES=y
    CONFIG_USB_GADGET_DEBUG_FS=y
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
    # USB Peripheral Controller
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_GR_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    # CONFIG_USB_M66592 is not set
    # CONFIG_USB_BDC_UDC is not set
    # CONFIG_USB_AMD5536UDC is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_NET2280 is not set
    # CONFIG_USB_GOKU is not set
    # CONFIG_USB_EG20T is not set
    # CONFIG_USB_GADGET_XILINX is not set
    # CONFIG_USB_DUMMY_HCD is not set
    CONFIG_USB_LIBCOMPOSITE=m
    CONFIG_USB_F_ACM=m
    CONFIG_USB_F_SS_LB=m
    CONFIG_USB_U_SERIAL=m
    CONFIG_USB_U_ETHER=m
    CONFIG_USB_F_SERIAL=m
    CONFIG_USB_F_OBEX=m
    CONFIG_USB_F_NCM=m
    CONFIG_USB_F_ECM=m
    CONFIG_USB_F_PHONET=m
    CONFIG_USB_F_EEM=m
    CONFIG_USB_F_SUBSET=m
    CONFIG_USB_F_RNDIS=m
    CONFIG_USB_F_MASS_STORAGE=m
    CONFIG_USB_F_FS=m
    CONFIG_USB_F_UAC1=m
    CONFIG_USB_F_UAC2=m
    CONFIG_USB_F_UVC=m
    CONFIG_USB_F_MIDI=m
    CONFIG_USB_F_HID=m
    CONFIG_USB_F_PRINTER=m
    CONFIG_USB_CONFIGFS=m
    CONFIG_USB_CONFIGFS_SERIAL=y
    CONFIG_USB_CONFIGFS_ACM=y
    CONFIG_USB_CONFIGFS_OBEX=y
    CONFIG_USB_CONFIGFS_NCM=y
    CONFIG_USB_CONFIGFS_ECM=y
    CONFIG_USB_CONFIGFS_ECM_SUBSET=y
    CONFIG_USB_CONFIGFS_RNDIS=y
    CONFIG_USB_CONFIGFS_EEM=y
    CONFIG_USB_CONFIGFS_PHONET=y
    CONFIG_USB_CONFIGFS_MASS_STORAGE=y
    CONFIG_USB_CONFIGFS_F_LB_SS=y
    CONFIG_USB_CONFIGFS_F_FS=y
    CONFIG_USB_CONFIGFS_F_UAC1=y
    CONFIG_USB_CONFIGFS_F_UAC2=y
    CONFIG_USB_CONFIGFS_F_MIDI=y
    CONFIG_USB_CONFIGFS_F_HID=y
    # CONFIG_USB_CONFIGFS_F_UVC is not set
    # CONFIG_USB_CONFIGFS_F_PRINTER is not set
    CONFIG_USB_ZERO=m
    # CONFIG_USB_ZERO_HNPTEST is not set
    CONFIG_USB_AUDIO=m
    # CONFIG_GADGET_UAC1 is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    CONFIG_USB_G_NCM=m
    CONFIG_USB_GADGETFS=m
    CONFIG_USB_FUNCTIONFS=m
    CONFIG_USB_FUNCTIONFS_ETH=y
    CONFIG_USB_FUNCTIONFS_RNDIS=y
    CONFIG_USB_FUNCTIONFS_GENERIC=y
    CONFIG_USB_MASS_STORAGE=m
    CONFIG_USB_G_SERIAL=m
    CONFIG_USB_MIDI_GADGET=m
    CONFIG_USB_G_PRINTER=m
    CONFIG_USB_CDC_COMPOSITE=m
    CONFIG_USB_G_NOKIA=m
    CONFIG_USB_G_ACM_MS=m
    CONFIG_USB_G_MULTI=m
    CONFIG_USB_G_MULTI_RNDIS=y
    CONFIG_USB_G_MULTI_CDC=y
    CONFIG_USB_G_HID=m
    CONFIG_USB_G_DBGP=m
    # CONFIG_USB_G_DBGP_PRINTK is not set
    CONFIG_USB_G_DBGP_SERIAL=y
    CONFIG_USB_G_WEBCAM=m
    # CONFIG_USB_LED_TRIG is not set
    # CONFIG_UWB is not set
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    # CONFIG_MMC_CLKGATE is not set
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=8
    CONFIG_MMC_BLOCK_BOUNCE=y
    CONFIG_SDIO_UART=y
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    CONFIG_MMC_OMAP=y
    CONFIG_MMC_OMAP_HS=y
    # CONFIG_MMC_TIFM_SD is not set
    # CONFIG_MMC_CB710 is not set
    # CONFIG_MMC_VIA_SDMMC is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MMC_USDHI6ROL0 is not set
    # CONFIG_MMC_TOSHIBA_PCI is not set
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # CONFIG_LEDS_CLASS_FLASH is not set
    # LED drivers
    # CONFIG_LEDS_LM3530 is not set
    # CONFIG_LEDS_LM3642 is not set
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=m
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP5521 is not set
    # CONFIG_LEDS_LP5523 is not set
    # CONFIG_LEDS_LP5562 is not set
    # CONFIG_LEDS_LP8501 is not set
    # CONFIG_LEDS_LP8860 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_PCA963X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    CONFIG_LEDS_PWM=m
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    # CONFIG_LEDS_TCA6507 is not set
    CONFIG_LEDS_TLC591XX=y
    # CONFIG_LEDS_LM355x is not set
    # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
    # CONFIG_LEDS_BLINKM is not set
    # CONFIG_LEDS_SYSCON is not set
    # CONFIG_LEDS_PM8941_WLED is not set
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=m
    CONFIG_LEDS_TRIGGER_ONESHOT=m
    CONFIG_LEDS_TRIGGER_HEARTBEAT=m
    CONFIG_LEDS_TRIGGER_BACKLIGHT=m
    CONFIG_LEDS_TRIGGER_CPU=y
    CONFIG_LEDS_TRIGGER_GPIO=m
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=m
    # iptables trigger is under Netfilter config (LED target)
    # CONFIG_LEDS_TRIGGER_TRANSIENT is not set
    # CONFIG_LEDS_TRIGGER_CAMERA is not set
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_INFINIBAND is not set
    # CONFIG_EDAC is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_ABB5ZES3 is not set
    # CONFIG_RTC_DRV_ABX80X is not set
    CONFIG_RTC_DRV_DS1307=m
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_HYM8563 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_ISL12057 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    CONFIG_RTC_DRV_PALMAS=m
    # CONFIG_RTC_DRV_PCF2127 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF85063 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    CONFIG_RTC_DRV_TWL4030=m
    # CONFIG_RTC_DRV_TPS65910 is not set
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1343 is not set
    # CONFIG_RTC_DRV_DS1347 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # CONFIG_RTC_DRV_MCP795 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1685_FAMILY is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # on-CPU RTC drivers
    CONFIG_RTC_DRV_OMAP=m
    # CONFIG_RTC_DRV_SNVS is not set
    # CONFIG_RTC_DRV_XGENE is not set
    # HID Sensor RTC drivers
    # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    # CONFIG_DW_DMAC is not set
    # CONFIG_DW_DMAC_PCI is not set
    # CONFIG_HSU_DMA_PCI is not set
    CONFIG_TI_EDMA=y
    CONFIG_DMA_OMAP=y
    CONFIG_TI_CPPI41=y
    # CONFIG_FSL_EDMA is not set
    # CONFIG_NBPFAXI_DMA is not set
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_VIRTUAL_CHANNELS=y
    CONFIG_DMA_OF=y
    # DMA Clients
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    # CONFIG_AUXDISPLAY is not set
    CONFIG_UIO=m
    # CONFIG_UIO_CIF is not set
    # CONFIG_UIO_PDRV_GENIRQ is not set
    # CONFIG_UIO_DMEM_GENIRQ is not set
    # CONFIG_UIO_AEC is not set
    # CONFIG_UIO_SERCOS3 is not set
    # CONFIG_UIO_PCI_GENERIC is not set
    # CONFIG_UIO_NETX is not set
    # CONFIG_UIO_MF624 is not set
    # CONFIG_VFIO is not set
    # CONFIG_VIRT_DRIVERS is not set
    CONFIG_VIRTIO=y
    # Virtio drivers
    # CONFIG_VIRTIO_PCI is not set
    # CONFIG_VIRTIO_BALLOON is not set
    # CONFIG_VIRTIO_INPUT is not set
    # CONFIG_VIRTIO_MMIO is not set
    # Microsoft Hyper-V guest support
    # CONFIG_STAGING is not set
    # CONFIG_CHROME_PLATFORMS is not set
    CONFIG_CLKDEV_LOOKUP=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # Common Clock Framework
    # CONFIG_COMMON_CLK_SI5351 is not set
    # CONFIG_COMMON_CLK_SI570 is not set
    # CONFIG_CLK_TWL6040 is not set
    # CONFIG_CLK_QORIQ is not set
    CONFIG_COMMON_CLK_PALMAS=y
    # CONFIG_COMMON_CLK_PWM is not set
    # CONFIG_COMMON_CLK_PXA is not set
    # CONFIG_COMMON_CLK_CDCE706 is not set
    CONFIG_HWSPINLOCK=y
    # Hardware Spinlock drivers
    CONFIG_HWSPINLOCK_OMAP=y
    # Clock Source drivers
    CONFIG_CLKSRC_OF=y
    CONFIG_CLKSRC_MMIO=y
    CONFIG_ARM_ARCH_TIMER=y
    CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
    # CONFIG_ATMEL_PIT is not set
    # CONFIG_SH_TIMER_CMT is not set
    # CONFIG_SH_TIMER_MTU2 is not set
    # CONFIG_SH_TIMER_TMU is not set
    # CONFIG_EM_TIMER_STI is not set
    CONFIG_MAILBOX=y
    CONFIG_OMAP2PLUS_MBOX=y
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    # CONFIG_ALTERA_MBOX is not set
    CONFIG_IOMMU_API=y
    CONFIG_IOMMU_SUPPORT=y
    # Generic IOMMU Pagetable Support
    # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set
    CONFIG_OF_IOMMU=y
    CONFIG_OMAP_IOMMU=y
    CONFIG_OMAP_IOMMU_DEBUG=y
    # CONFIG_ARM_SMMU is not set
    # Remoteproc drivers
    CONFIG_REMOTEPROC=y
    # CONFIG_STE_MODEM_RPROC is not set
    CONFIG_WKUP_M3_RPROC=y
    # CONFIG_PRUSS_REMOTEPROC is not set
    # Rpmsg drivers
    # SOC (System On Chip) specific Drivers
    CONFIG_SOC_TI=y
    CONFIG_WKUP_M3_IPC=y
    # CONFIG_PM_DEVFREQ is not set
    CONFIG_EXTCON=m
    # Extcon Device Drivers
    # CONFIG_EXTCON_ADC_JACK is not set
    # CONFIG_EXTCON_GPIO is not set
    CONFIG_EXTCON_PALMAS=m
    # CONFIG_EXTCON_RT8973A is not set
    # CONFIG_EXTCON_SM5502 is not set
    CONFIG_EXTCON_USB_GPIO=m
    CONFIG_MEMORY=y
    CONFIG_TI_EMIF=m
    CONFIG_OMAP_GPMC=y
    CONFIG_TI_EMIF_SRAM=y
    CONFIG_IIO=m
    CONFIG_IIO_BUFFER=y
    # CONFIG_IIO_BUFFER_CB is not set
    CONFIG_IIO_KFIFO_BUF=m
    # CONFIG_IIO_TRIGGER is not set
    # Accelerometers
    # CONFIG_BMA180 is not set
    # CONFIG_BMC150_ACCEL is not set
    # CONFIG_IIO_ST_ACCEL_3AXIS is not set
    # CONFIG_KXSD9 is not set
    # CONFIG_MMA8452 is not set
    # CONFIG_KXCJK1013 is not set
    # CONFIG_MMA9551 is not set
    # CONFIG_MMA9553 is not set
    # Analog to digital converters
    # CONFIG_AD7266 is not set
    # CONFIG_AD7291 is not set
    # CONFIG_AD7298 is not set
    # CONFIG_AD7476 is not set
    # CONFIG_AD7791 is not set
    # CONFIG_AD7793 is not set
    # CONFIG_AD7887 is not set
    # CONFIG_AD7923 is not set
    # CONFIG_AD799X is not set
    # CONFIG_CC10001_ADC is not set
    # CONFIG_MAX1027 is not set
    # CONFIG_MAX1363 is not set
    # CONFIG_MCP320X is not set
    # CONFIG_MCP3422 is not set
    # CONFIG_NAU7802 is not set
    # CONFIG_TI_ADC081C is not set
    # CONFIG_TI_ADC128S052 is not set
    CONFIG_TI_AM335X_ADC=m
    # CONFIG_TWL4030_MADC is not set
    # CONFIG_TWL6030_GPADC is not set
    # CONFIG_VF610_ADC is not set
    # Amplifiers
    # CONFIG_AD8366 is not set
    # Hid Sensor IIO Common
    # SSP Sensor Common
    # CONFIG_IIO_SSP_SENSORHUB is not set
    # Digital to analog converters
    # CONFIG_AD5064 is not set
    # CONFIG_AD5360 is not set
    # CONFIG_AD5380 is not set
    # CONFIG_AD5421 is not set
    # CONFIG_AD5446 is not set
    # CONFIG_AD5449 is not set
    # CONFIG_AD5504 is not set
    # CONFIG_AD5624R_SPI is not set
    # CONFIG_AD5686 is not set
    # CONFIG_AD5755 is not set
    # CONFIG_AD5764 is not set
    # CONFIG_AD5791 is not set
    # CONFIG_AD7303 is not set
    # CONFIG_MAX517 is not set
    # CONFIG_MAX5821 is not set
    # CONFIG_MCP4725 is not set
    # CONFIG_MCP4922 is not set
    # Frequency Synthesizers DDS/PLL
    # Clock Generator/Distribution
    # CONFIG_AD9523 is not set
    # Phase-Locked Loop (PLL) frequency synthesizers
    # CONFIG_ADF4350 is not set
    # Digital gyroscope sensors
    # CONFIG_ADIS16080 is not set
    # CONFIG_ADIS16130 is not set
    # CONFIG_ADIS16136 is not set
    # CONFIG_ADIS16260 is not set
    # CONFIG_ADXRS450 is not set
    # CONFIG_BMG160 is not set
    # CONFIG_IIO_ST_GYRO_3AXIS is not set
    # CONFIG_ITG3200 is not set
    # Humidity sensors
    # CONFIG_DHT11 is not set
    # CONFIG_SI7005 is not set
    # CONFIG_SI7020 is not set
    # Inertial measurement units
    # CONFIG_ADIS16400 is not set
    # CONFIG_ADIS16480 is not set
    # CONFIG_KMX61 is not set
    # CONFIG_INV_MPU6050_IIO is not set
    # Light sensors
    # CONFIG_ADJD_S311 is not set
    # CONFIG_AL3320A is not set
    # CONFIG_APDS9300 is not set
    # CONFIG_CM32181 is not set
    # CONFIG_CM3232 is not set
    # CONFIG_CM3323 is not set
    # CONFIG_CM36651 is not set
    # CONFIG_GP2AP020A00F is not set
    # CONFIG_ISL29125 is not set
    # CONFIG_JSA1212 is not set
    # CONFIG_LTR501 is not set
    # CONFIG_TCS3414 is not set
    # CONFIG_TCS3472 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_TSL4531 is not set
    # CONFIG_VCNL4000 is not set
    # Magnetometer sensors
    # CONFIG_AK8975 is not set
    # CONFIG_AK09911 is not set
    # CONFIG_MAG3110 is not set
    # CONFIG_IIO_ST_MAGN_3AXIS is not set
    # Inclinometer sensors
    # Pressure sensors
    # CONFIG_BMP280 is not set
    # CONFIG_MPL115 is not set
    # CONFIG_MPL3115 is not set
    # CONFIG_MS5611 is not set
    # CONFIG_IIO_ST_PRESS is not set
    # CONFIG_T5403 is not set
    # Lightning sensors
    # CONFIG_AS3935 is not set
    # Proximity sensors
    # CONFIG_SX9500 is not set
    # Temperature sensors
    # CONFIG_MLX90614 is not set
    # CONFIG_TMP006 is not set
    # CONFIG_VME_BUS is not set
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    # CONFIG_PWM_FSL_FTM is not set
    # CONFIG_PWM_PCA9685 is not set
    CONFIG_PWM_TIECAP=y
    CONFIG_PWM_TIEHRPWM=y
    CONFIG_PWM_TIPWMSS=y
    CONFIG_PWM_TWL=m
    CONFIG_PWM_TWL_LED=m
    CONFIG_IRQCHIP=y
    CONFIG_OMAP_IRQCHIP=y
    # CONFIG_IPACK_BUS is not set
    # CONFIG_RESET_CONTROLLER is not set
    # CONFIG_FMC is not set
    # PHY Subsystem
    CONFIG_GENERIC_PHY=y
    # CONFIG_PHY_DM816X_USB is not set
    CONFIG_OMAP_CONTROL_PHY=y
    CONFIG_OMAP_USB2=m
    CONFIG_TI_PIPE3=y
    CONFIG_TWL4030_USB=m
    # CONFIG_BCM_KONA_USB2_PHY is not set
    # CONFIG_POWERCAP is not set
    # CONFIG_MCB is not set
    # CONFIG_THUNDERBOLT is not set
    # Android
    # CONFIG_ANDROID is not set
    # Firmware Drivers
    # CONFIG_FIRMWARE_MEMMAP is not set
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    CONFIG_EXT3_FS=y
    CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
    # CONFIG_EXT3_FS_XATTR is not set
    CONFIG_EXT4_FS=y
    # CONFIG_EXT4_FS_POSIX_ACL is not set
    # CONFIG_EXT4_FS_SECURITY is not set
    # CONFIG_EXT4_ENCRYPTION is not set
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_EXPORTFS=y
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    CONFIG_FANOTIFY=y
    # CONFIG_FANOTIFY_ACCESS_PERMISSIONS is not set
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    # CONFIG_QUOTA_DEBUG is not set
    CONFIG_QUOTA_TREE=y
    # CONFIG_QFMT_V1 is not set
    CONFIG_QFMT_V2=y
    CONFIG_QUOTACTL=y
    CONFIG_AUTOFS4_FS=m
    # CONFIG_FUSE_FS is not set
    # CONFIG_OVERLAY_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_NTFS_FS is not set
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_KERNFS=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    CONFIG_TMPFS_POSIX_ACL=y
    CONFIG_TMPFS_XATTR=y
    # CONFIG_HUGETLB_PAGE is not set
    CONFIG_CONFIGFS_FS=y
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_ECRYPT_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    CONFIG_JFFS2_FS_XATTR=y
    CONFIG_JFFS2_FS_POSIX_ACL=y
    CONFIG_JFFS2_FS_SECURITY=y
    CONFIG_JFFS2_COMPRESSION_OPTIONS=y
    CONFIG_JFFS2_ZLIB=y
    CONFIG_JFFS2_LZO=y
    CONFIG_JFFS2_RTIME=y
    CONFIG_JFFS2_RUBIN=y
    # CONFIG_JFFS2_CMODE_NONE is not set
    CONFIG_JFFS2_CMODE_PRIORITY=y
    # CONFIG_JFFS2_CMODE_SIZE is not set
    # CONFIG_JFFS2_CMODE_FAVOURLZO is not set
    CONFIG_UBIFS_FS=y
    # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    # CONFIG_LOGFS is not set
    CONFIG_CRAMFS=y
    # CONFIG_SQUASHFS is not set
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    # CONFIG_PSTORE is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    CONFIG_NFS_V3_ACL=y
    CONFIG_NFS_V4=y
    # CONFIG_NFS_SWAP is not set
    # CONFIG_NFS_V4_1 is not set
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    # CONFIG_NFSD is not set
    CONFIG_GRACE_PERIOD=y
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_SUPPORT=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_NCP_FS is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    # CONFIG_NLS_ASCII is not set
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    # CONFIG_NLS_UTF8 is not set
    # CONFIG_DLM is not set
    # Kernel hacking
    # printk and dmesg options
    CONFIG_PRINTK_TIME=y
    CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # Compile-time checks and compiler options
    CONFIG_DEBUG_INFO=y
    # CONFIG_DEBUG_INFO_REDUCED is not set
    # CONFIG_DEBUG_INFO_SPLIT is not set
    # CONFIG_DEBUG_INFO_DWARF4 is not set
    # CONFIG_GDB_SCRIPTS is not set
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    # CONFIG_PAGE_OWNER is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_FRAME_POINTER=y
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    CONFIG_MAGIC_SYSRQ=y
    CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
    CONFIG_DEBUG_KERNEL=y
    # Memory Debugging
    # CONFIG_PAGE_EXTENSION is not set
    # CONFIG_DEBUG_PAGEALLOC is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_SLUB_STATS is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_HIGHMEM is not set
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Lockups and Hangs
    # CONFIG_LOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    CONFIG_PANIC_TIMEOUT=0
    # CONFIG_SCHED_DEBUG is not set
    # CONFIG_SCHEDSTATS is not set
    # CONFIG_SCHED_STACK_END_CHECK is not set
    # CONFIG_DEBUG_TIMEKEEPING is not set
    # CONFIG_TIMER_STATS is not set
    # CONFIG_DEBUG_PREEMPT is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_LOCK_TORTURE_TEST is not set
    # CONFIG_STACKTRACE is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_PI_LIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_PROVE_RCU is not set
    # CONFIG_SPARSE_RCU_POINTER is not set
    # CONFIG_TORTURE_TEST is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    CONFIG_RCU_CPU_STALL_TIMEOUT=21
    CONFIG_RCU_CPU_STALL_INFO=y
    # CONFIG_RCU_TRACE is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    # CONFIG_LATENCYTOP is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACE_CLOCK=y
    CONFIG_RING_BUFFER=y
    CONFIG_RING_BUFFER_ALLOW_SWAP=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    # Runtime Testing
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_KPROBES_SANITY_TEST is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_PERCPU_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_HEXDUMP is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_TEST_RHASHTABLE is not set
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_TEST_LKM is not set
    # CONFIG_TEST_USER_COPY is not set
    # CONFIG_TEST_BPF is not set
    # CONFIG_TEST_FIRMWARE is not set
    # CONFIG_TEST_UDELAY is not set
    # CONFIG_MEMTEST is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_ARM_PTDUMP is not set
    # CONFIG_STRICT_DEVMEM is not set
    # CONFIG_ARM_UNWIND is not set
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_LL is not set
    CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
    # CONFIG_DEBUG_UART_8250 is not set
    # CONFIG_DEBUG_UART_BCM63XX is not set
    CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
    # CONFIG_ARM_KPROBES_TEST is not set
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # CONFIG_DEBUG_SET_MODULE_RONX is not set
    # CONFIG_CORESIGHT is not set
    # Security options
    CONFIG_KEYS=y
    # CONFIG_PERSISTENT_KEYRINGS is not set
    # CONFIG_BIG_KEYS is not set
    # CONFIG_ENCRYPTED_KEYS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    CONFIG_SECURITY=y
    # CONFIG_SECURITYFS is not set
    # CONFIG_SECURITY_NETWORK is not set
    # CONFIG_SECURITY_PATH is not set
    # CONFIG_SECURITY_SMACK is not set
    # CONFIG_SECURITY_TOMOYO is not set
    # CONFIG_SECURITY_APPARMOR is not set
    # CONFIG_SECURITY_YAMA is not set
    CONFIG_INTEGRITY=y
    # CONFIG_INTEGRITY_SIGNATURE is not set
    CONFIG_INTEGRITY_AUDIT=y
    # CONFIG_IMA is not set
    # CONFIG_EVM is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=y
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_BLKCIPHER=y
    CONFIG_CRYPTO_BLKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_PCOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    # CONFIG_CRYPTO_USER is not set
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    CONFIG_CRYPTO_GF128MUL=m
    CONFIG_CRYPTO_NULL=m
    CONFIG_CRYPTO_WORKQUEUE=y
    # CONFIG_CRYPTO_CRYPTD is not set
    # CONFIG_CRYPTO_MCRYPTD is not set
    CONFIG_CRYPTO_AUTHENC=y
    # CONFIG_CRYPTO_TEST is not set
    # Authenticated Encryption with Associated Data
    CONFIG_CRYPTO_CCM=m
    CONFIG_CRYPTO_GCM=m
    CONFIG_CRYPTO_SEQIV=m
    # Block modes
    CONFIG_CRYPTO_CBC=y
    CONFIG_CRYPTO_CTR=m
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=m
    # CONFIG_CRYPTO_LRW is not set
    CONFIG_CRYPTO_PCBC=m
    # CONFIG_CRYPTO_XTS is not set
    # Hash modes
    CONFIG_CRYPTO_CMAC=m
    CONFIG_CRYPTO_HMAC=y
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    CONFIG_CRYPTO_CRCT10DIF=y
    CONFIG_CRYPTO_GHASH=m
    # CONFIG_CRYPTO_MD4 is not set
    CONFIG_CRYPTO_MD5=y
    CONFIG_CRYPTO_MICHAEL_MIC=y
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    CONFIG_CRYPTO_SHA1=y
    CONFIG_CRYPTO_SHA256=y
    CONFIG_CRYPTO_SHA512=y
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    CONFIG_CRYPTO_AES=y
    # CONFIG_CRYPTO_ANUBIS is not set
    CONFIG_CRYPTO_ARC4=m
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    CONFIG_CRYPTO_DES=y
    CONFIG_CRYPTO_FCRYPT=m
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    # CONFIG_CRYPTO_ZLIB is not set
    CONFIG_CRYPTO_LZO=y
    # CONFIG_CRYPTO_LZ4 is not set
    # CONFIG_CRYPTO_LZ4HC is not set
    # Random Number Generation
    # CONFIG_CRYPTO_ANSI_CPRNG is not set
    # CONFIG_CRYPTO_DRBG_MENU is not set
    CONFIG_CRYPTO_USER_API=y
    CONFIG_CRYPTO_USER_API_HASH=y
    CONFIG_CRYPTO_USER_API_SKCIPHER=y
    # CONFIG_CRYPTO_USER_API_RNG is not set
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_HIFN_795X is not set
    CONFIG_CRYPTO_DEV_OMAP_SHAM=y
    CONFIG_CRYPTO_DEV_OMAP_AES=y
    CONFIG_CRYPTO_DEV_OMAP_DES=y
    # CONFIG_ASYMMETRIC_KEY_TYPE is not set
    # CONFIG_ARM_CRYPTO is not set
    # CONFIG_BINARY_PRINTF is not set
    # Library routines
    CONFIG_BITREVERSE=y
    # CONFIG_HAVE_ARCH_BITREVERSE is not set
    CONFIG_RATIONAL=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_GENERIC_IO=y
    CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=y
    CONFIG_CRC_ITU_T=y
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    CONFIG_CRC7=y
    CONFIG_LIBCRC32C=y
    # CONFIG_CRC8 is not set
    CONFIG_AUDIT_GENERIC=y
    # CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set
    # CONFIG_RANDOM32_SELFTEST is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    CONFIG_LZ4_DECOMPRESS=y
    CONFIG_XZ_DEC=y
    CONFIG_XZ_DEC_X86=y
    CONFIG_XZ_DEC_POWERPC=y
    CONFIG_XZ_DEC_IA64=y
    CONFIG_XZ_DEC_ARM=y
    CONFIG_XZ_DEC_ARMTHUMB=y
    CONFIG_XZ_DEC_SPARC=y
    CONFIG_XZ_DEC_BCJ=y
    # CONFIG_XZ_DEC_TEST is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_DECOMPRESS_BZIP2=y
    CONFIG_DECOMPRESS_LZMA=y
    CONFIG_DECOMPRESS_XZ=y
    CONFIG_DECOMPRESS_LZO=y
    CONFIG_DECOMPRESS_LZ4=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_BCH=y
    CONFIG_TEXTSEARCH=y
    CONFIG_TEXTSEARCH_KMP=m
    CONFIG_TEXTSEARCH_BM=m
    CONFIG_TEXTSEARCH_FSM=m
    CONFIG_ASSOCIATIVE_ARRAY=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT_MAP=y
    CONFIG_HAS_DMA=y
    CONFIG_DQL=y
    CONFIG_GLOB=y
    # CONFIG_GLOB_SELFTEST is not set
    CONFIG_NLATTR=y
    CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE=y
    CONFIG_AVERAGE=y
    # CONFIG_CORDIC is not set
    CONFIG_DDR=y
    CONFIG_LIBFDT=y
    CONFIG_OID_REGISTRY=y
    CONFIG_FONT_SUPPORT=y
    CONFIG_FONTS=y
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    # CONFIG_FONT_6x11 is not set
    # CONFIG_FONT_7x14 is not set
    # CONFIG_FONT_PEARL_8x8 is not set
    # CONFIG_FONT_ACORN_8x8 is not set
    # CONFIG_FONT_MINI_4x6 is not set
    # CONFIG_FONT_6x10 is not set
    # CONFIG_FONT_SUN8x16 is not set
    # CONFIG_FONT_SUN12x22 is not set
    # CONFIG_FONT_10x18 is not set
    CONFIG_ARCH_HAS_SG_CHAIN=y
    CONFIG_VIRTUALIZATION=y
  • Hi Yordan,
    I also notice when I install snd-soc-evm.ko on BeagleBone Black, I got errors:
    [ 541.521118] davinci_evm sound: ASoC: CODEC DAI tlv320aic32x4-hifi not registered
    [ 541.529900] davinci_evm sound: snd_soc_register_card failed (-517)
    I don't know how it occurs.
