Linux/DRA722: Video input capture hanged
Part Number: DRA722
Other Parts Discussed in Thread: DRA72
Tool/software: Linux
Hi all,
There is an error with video input capture hanged when I use gst-launch-1.0 to capture video source.
Currently we use J6 eco custom board with GLSDK 3.00.00.03.
We use ov10633 to be video intput decoder.
The below is my log and DTS
log file:
U-Boot SPL 2016.05 (May 22 2017 - 12:45:39)
DRA722-GP ES1.0
MMC Device 1 not found
*** Warning - No MMC card found, using default environment
Trying to boot from MMC1
reading u-boot.img
reading u-boot.img
U-Boot 2016.05 (May 22 2017 - 12:45:39 +0800)
CPU  : DRA722-GP ES1.0
Board: DRA72x EVM REV <NULL>
I2C:   ready
DRAM:  1 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
Warning: fastboot.board_rev: unknown board revision
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
i2c_write: error waiting for addr ACK (status=0x116)
SCSI:  Net:   <ethaddr> not set. Validating first E-fuse MAC
Could not get PHY for cpsw: addr 3
cpsw
Hit any key to stop autoboot:  0
J6E ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
3736416 bytes read in 336 ms (10.6 MiB/s)
102151 bytes read in 32 ms (3 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x390360 ]
   Loading Device Tree to 8ffe4000, end 8fffff06 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.14 (root@louis-VirtualBox) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #5 SMP PREEMPT Mon May 22 18:26:32 CST 2017
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI DRA722 Louis 20170516 13:50
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000be000000
[    0.000000] Forcing write-allocate cache policy for SMP
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[    0.000000] DRA722 ES1.0
[    0.000000] PERCPU: Embedded 12 pages/cpu @ef644000 s19008 r8192 d21952 u49152
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258368
[    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=4320892c-02 rw rootfstype=ext4 rootwait omapdrm.num_crtc=2 drm.debug=0xff
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 839120K/1040384K available (6663K kernel code, 364K rwdata, 2512K rodata, 356K init, 293K bss, 21040K reserved, 180224K cma-reserved, 233472K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08fe084   (9177 kB)
[    0.000000]       .init : 0xc08ff000 - 0xc0958000   ( 356 kB)
[    0.000000]       .data : 0xc0958000 - 0xc09b3150   ( 365 kB)
[    0.000000]        .bss : 0xc09b5000 - 0xc09fe618   ( 294 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000]  RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 31475 Hz
[    0.000000] Architected cp15 timer(s) running at 5.90MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
[    0.000005] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
[    0.000015] Switching to timer-based delay loop, resolution 169ns
[    0.000334] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000342] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000758] Console: colour dummy device 80x30
[    0.000775] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.000782] This ensures that you still see kernel messages. Please
[    0.000787] update your kernel commandline.
[    0.000800] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
[    0.000811] pid_max: default: 32768 minimum: 301
[    0.000903] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000914] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001430] Initializing cgroup subsys io
[    0.001448] Initializing cgroup subsys memory
[    0.001470] Initializing cgroup subsys devices
[    0.001482] Initializing cgroup subsys freezer
[    0.001493] Initializing cgroup subsys perf_event
[    0.001504] Initializing cgroup subsys pids
[    0.001526] CPU: Testing write buffer coherency: ok
[    0.001725] /cpus/cpu@0 missing clock-frequency property
[    0.001737] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001773] Setting up static identity map for 0x80008380 - 0x800083d8
[    0.050026] Brought up 1 CPUs
[    0.050037] SMP: Total of 1 processors activated (11.80 BogoMIPS).
[    0.050044] CPU: All CPU(s) started in SVC mode.
[    0.050352] devtmpfs: initialized
[    0.080041] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.080983] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.266003] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.273601] pinctrl core: initialized pinctrl subsystem
[    0.274510] NET: Registered protocol family 16
[    0.275457] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.300197] cpuidle: using governor ladder
[    0.330224] cpuidle: using governor menu
[    0.338896] OMAP GPIO hardware version 0.1
[    0.342833] GPIO line 161 (radio_rst) hogged as output/low
[    0.345078] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.369108] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.369119] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.369528] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.369538] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.370128] OMAP DMA hardware revision 0.0
[    0.444060] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.445176] edma 43300000.edma: memcpy is disabled
[    0.449992] edma 43300000.edma: TI EDMA DMA engine driver
[    0.453428] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.453610] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.453768] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.453918] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.455899] SCSI subsystem initialized
[    0.460751] usbcore: registered new interface driver usbfs
[    0.460807] usbcore: registered new interface driver hub
[    0.460874] usbcore: registered new device driver usb
[    0.461960] palmas 0-0058: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/tps65917_pins_default, deferring probe
[    0.480574] pcf857x: probe of 0-0020 failed with error -121
[    0.480845] pcf857x: probe of 0-0021 failed with error -121
[    0.481003] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.481424] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    0.500597] pcf857x: probe of 3-0021 failed with error -121
[    0.500635] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[    0.520612] pcf857x: probe of 4-0026 failed with error -121
[    0.520936] pca953x 4-0020: failed reading register
[    0.520954] pca953x: probe of 4-0020 failed with error -121
[    0.521105] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    0.521275] media: Linux media interface: v0.10
[    0.521326] Linux video capture interface: v2.00
[    0.521364] pps_core: LinuxPPS API ver. 1 registered
[    0.521371] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.521394] PTP clock support registered
[    0.521421] EDAC MC: Ver: 3.0.0
[    0.531111] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.531307] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.532439] clocksource: Switched to clocksource arch_sys_counter
[    0.542617] NET: Registered protocol family 2
[    0.543125] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.543197] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.543328] TCP: Hash tables configured (established 8192 bind 8192)
[    0.543380] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.543411] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.543596] NET: Registered protocol family 1
[    0.553889] RPC: Registered named UNIX socket transport module.
[    0.553899] RPC: Registered udp transport module.
[    0.553906] RPC: Registered tcp transport module.
[    0.553912] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.554951] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.557020] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.574795] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.585484] NFS: Registering the id_resolver key type
[    0.585512] Key type id_resolver registered
[    0.585520] Key type id_legacy registered
[    0.585593] ntfs: driver 2.1.32 [Flags: R/O].
[    0.587894] bounce: pool size: 64 pages
[    0.588056] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.588070] io scheduler noop registered
[    0.588081] io scheduler deadline registered
[    0.588111] io scheduler cfq registered (default)
[    0.592875] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.593004] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[    0.596098] PCI host bridge /ocp/axi@0/pcie@51000000 ranges:
[    0.596110]   No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
[    0.596143]    IO 0x20003000..0x20012fff -> 0x00000000
[    0.596164]   MEM 0x20013000..0x2fffffff -> 0x20013000
[    0.606403] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    0.606417] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.606428] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.606437] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    0.606847] PCI: bus0: Fast back to back transfers disabled
[    0.622524] PCI: bus1: Fast back to back transfers disabled
[    0.622579] irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
[    0.622622] irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
[    0.622659] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    0.622674] pci 0000:00:00.0: BAR 8: assigned [mem 0x20200000-0x202fffff]
[    0.622685] pci 0000:00:00.0: BAR 9: assigned [mem 0x20300000-0x203fffff pref]
[    0.622696] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    0.622708] pci 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    0.622723] pci 0000:01:00.0: BAR 6: assigned [mem 0x20300000-0x2033ffff pref]
[    0.622734] pci 0000:01:00.0: BAR 0: assigned [mem 0x20200000-0x2021ffff]
[    0.622754] pci 0000:01:00.0: BAR 1: assigned [mem 0x20220000-0x2022ffff]
[    0.622774] pci 0000:01:00.0: BAR 3: assigned [mem 0x20230000-0x20233fff]
[    0.622794] pci 0000:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
[    0.622814] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.622824] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    0.622835] pci 0000:00:00.0:   bridge window [mem 0x20200000-0x202fffff]
[    0.622846] pci 0000:00:00.0:   bridge window [mem 0x20300000-0x203fffff pref]
[    0.623072] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    0.623082] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    0.679871] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.683480] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[    0.684373] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[    0.685235] console [ttyS2] disabled
[    0.685282] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[    1.773057] console [ttyS2] enabled
[    1.777435] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 304, base_baud = 3000000) is a 8250
[    1.787165] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 305, base_baud = 3000000) is a 8250
[    1.796842] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 306, base_baud = 3000000) is a 8250
[    1.806515] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 307, base_baud = 3000000) is a 8250
[    1.816547] [drm] Initialized drm 1.1.0 20060810
[    1.822238] omapdss_dss 58000000.dss: master bind failed: -517
[    1.829804] panel-dpi display@2: failed to find video source
[    2.006300] brd: module loaded
[    2.094614] loop: module loaded
[    2.104158] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
[    2.111679] libphy: Fixed MDIO Bus: probed
[    2.117416] cpsw 48484000.ethernet: gpio request failed, ret -517
[    2.124306] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.130864] ehci-pci: EHCI PCI platform driver
[    2.135438] ehci-omap: OMAP-EHCI Host Controller driver
[    2.141012] usbcore: registered new interface driver usbserial
[    2.147206] mousedev: PS/2 mouse device common for all mice
[    2.163491] i2c /dev entries driver
[    2.167687] ov1063x 4-0037: ov1063x Product ID 0 Manufacturer ID 0
[    2.173946] ov1063x 4-0037: ov1063x 4-0037 sensor driver registered !!
[    2.180684] ov490 4-0024: Failed reading register 0x300a!
[    2.186135] ov490: probe of 4-0024 failed with error -121
[    2.192290] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    2.198338] pinctrl-single 4a003400.pinmux: pin 4a00363c.0 already requested by 4806a000.serial; cannot claim for 48970000.vip
[    2.209801] pinctrl-single 4a003400.pinmux: pin-143 (48970000.vip) status -22
[    2.217160] vpe 489d0000.vpe: Device registered as /dev/video0
[    2.223045] pinctrl-single 4a003400.pinmux: could not request pin 143 (4a00363c.0) from group pinmux_vin2a_pins  on device pinctrl-single
[    2.235474] vip 48970000.vip: Error applying setting, reverse things back
[    2.242373] pinctrl-single 4a003400.pinmux: pin 4a00363c.0 already requested by 4806a000.serial; cannot claim for 48970000.vip
[    2.253832] pinctrl-single 4a003400.pinmux: pin-143 (48970000.vip) status -22
[    2.261000] pinctrl-single 4a003400.pinmux: could not request pin 143 (4a00363c.0) from group pinmux_vin2a_pins  on device pinctrl-single
[    2.273411] vip 48970000.vip: Error applying setting, reverse things back
[    2.281239] vip 48970000.vip: loading firmware vpdma-1b8.bin
[    2.290713] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    2.302474] vip 48970000.vip: VPDMA firmware loaded
[    2.307490] vip1-s1: Port A: Using subdev ov1063x 4-0037 for capture
[    2.314085] vip1-s1: device registered as video1
[    2.372794] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
[    2.413189] ledtrig-cpu: registered to indicate activity on CPUs
[    2.419264] mmc0: MAN_BKOPS_EN bit is not set
[    2.423844] usbcore: registered new interface driver usbhid
[    2.429438] usbhid: USB HID core driver
[    2.435093] hwspinlock_user gatemp: requested 10 hwspinlocks
[    2.442527] NET: Registered protocol family 10
[    2.457696] sit: IPv6 over IPv4 tunneling driver
[    2.462945] NET: Registered protocol family 17
[    2.467634] Key type dns_resolver registered
[    2.472027] omap_voltage_late_init: Voltage driver support not added
[    2.478979] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.485209] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.491443] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[    2.498056] Power Management for TI OMAP4+ devices.
[    2.503208] Registering SWP/SWPB emulation handler
[    2.510830] dmm 4e000000.dmm: initialized all PAT entries
[    2.537310] pinctrl-single 4a003400.pinmux: pin 4a003824.0 already requested by 4806a000.serial; cannot claim for 0-0058
[    2.548314] mmc0: new high speed MMC card at address 0001
[    2.554087] pinctrl-single 4a003400.pinmux: pin-265 (0-0058) status -22
[    2.560734] pinctrl-single 4a003400.pinmux: could not request pin 265 (4a003824.0) from group tps65917_pins_default  on device pinctrl-single
[    2.573632] palmas 0-0058: Error applying setting, reverse things back
[    2.580250] palmas 0-0058: Irq flag is 0x00000000
[    2.585020] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
[    2.591936] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[    2.599868] mmcblk0boot0: mmc0:0001 R1J55A partition 1 128 KiB
[    2.616410] mmcblk0boot1: mmc0:0001 R1J55A partition 2 128 KiB
[    2.623748]  mmcblk0: p1 p2
[    2.629048] OMAP DSS rev 6.1
[    2.635462] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    2.646062] cpsw 48484000.ethernet: gpio request failed, ret -517
[    2.652899] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    2.692889] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.699100] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.705836] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.712045] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.723709] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.730348] [drm] No driver support for vblank timestamp query.
[    2.746683] [drm] Enabling DMM ywrap scrolling
[    2.753011] mmc1: host does not support reading read-only switch, assuming write-enable
[    2.753068] mmc1: new SDHC card at address 1234
[    2.764227] mmcblk1: mmc1:1234 SA04G 3.71 GiB
[    2.765374]  mmcblk1: p1
[    2.802039] Console: switching to colour frame buffer device 240x67
[    2.844124] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    2.854444] mmc2: host does not support reading read-only switch, assuming write-enable
[    2.862568] mmc2: new SDHC card at address 0001
[    2.872791] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    2.879408] cpsw 48484000.ethernet: gpio request failed, ret -517
[    2.885580] mmcblk2: mmc2:0001 SD4GB 3.64 GiB
[    2.890898] hctosys: unable to open rtc device (rtc0)
[    2.896081]  mmcblk2: p1 p2
[    2.899839] cpsw 48484000.ethernet: gpio request failed, ret -517
[    2.916703] aic_dvdd: disabling
[    2.920199] ldo4: disabling
[    3.282868] EXT4-fs (mmcblk2p2): recovery complete
[    3.290304] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.298470] VFS: Mounted root (ext4 filesystem) on device 179:66.
[    3.307013] devtmpfs: mounted
[    3.310177] Freeing unused kernel memory: 356K (c08ff000 - c0958000)
[    3.316578] This architecture does not have kernel memory protection.
INIT: version 2.88 booting
Starting udev
[    4.020365] udevd[109]: starting version 182
[    4.357507] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[    4.508199]  remoteproc0: 58820000.ipu is available
[    4.619507]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[    4.852492]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    5.002803] cpsw 48484000.ethernet: gpio request failed, ret -517
[    5.009078]  remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[    5.022327] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    5.071946] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    5.079021] cpsw 48484000.ethernet: gpio request failed, ret -517
[    5.102049]  remoteproc0: failed to load dra7-ipu1-fw.xem4
[    5.141457] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[    5.252280] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[    5.343028] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[    5.481947] 491, r3003 = 17 , r3004 = 23
[    5.531808] ov1063x 4-0037: r3003 = 17 , r3004 = 23
[    5.542213] cpsw 48484000.ethernet: gpio request failed, ret -517
[    5.549580] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
[    5.592217] 574, width x height = 720 x 480
[    5.598920] cpsw 48484000.ethernet: gpio request failed, ret -517
[    5.608033] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
udevd[347]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory[    5.695786] ov1063x 4-0037: width x height = 720 x 480
udevd[348]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
[    5.729246]  remoteproc1: 55020000.ipu is available
[    5.779414] cpsw 48484000.ethernet: gpio request failed, ret -517
[    5.842362] 590, hts x vts = 1083 x 530
udevd[362]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory[    5.854316]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[    5.887191] CAN device driver interface
[    5.930760] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    5.939657] ov1063x 4-0037: hts x vts = 1083 x 530
[    6.011964] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    6.069110] e1000e 0000:01:00.0: enabling device (0140 -> 0142)
[    6.106211]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    6.130157] e1000e 0000:01:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    6.173115] cpsw 48484000.ethernet: gpio request failed, ret -517
[    6.179485] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    6.191109] e1000e 0000:01:00.0 0000:01:00.0 (uninitialized): Failed to initialize MSI-X interrupts.  Falling back to MSI interrupts.
[    6.387710] e1000e 0000:01:00.0 eth0: registered PHC clock
[    6.417169] e1000e 0000:01:00.0 eth0: (PCI Express:2.5GT/s:Width x1) 88:88:88:88:87:88
[    6.456674] e1000e 0000:01:00.0 eth0: Intel(R) PRO/1000 Network Connection
[    6.491945] e1000e 0000:01:00.0 eth0: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
[    6.526584] cpsw 48484000.ethernet: gpio request failed, ret -517
[    6.653289] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    6.659788] cpsw 48484000.ethernet: gpio request failed, ret -517
[    6.679773] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    6.690970] cpsw 48484000.ethernet: gpio request failed, ret -517
[    6.722612] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    6.745054] cpsw 48484000.ethernet: gpio request failed, ret -517
[    6.802653]  remoteproc1: registered virtio0 (type 7)
deuvd[416]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/dev/scripts/mount.sh': No such file or directory
udevd[419]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
[    7.231353] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.274716] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.281341] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x0 impl platform mode
[    7.302505] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
[    7.333094] scsi host0: ahci
[    7.342544] ata1: DUMMY
[    7.345629] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.352543] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=358)
[    7.373102] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.382672] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    7.390494]  remoteproc2: 40800000.dsp is available
[    7.412487]  remoteproc2: Note: remoteproc is still under development and considered experimental.
[    7.421501]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    7.453559] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.476107] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[    7.493234] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.557381]  remoteproc2: registered virtio1 (type 7)
[    7.573429]  remoteproc1: powering up 55020000.ipu
[    7.582302]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3484972
[    7.602525] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[    7.643225] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.676239] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.681772] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    7.702788] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    7.711571] xhci-hcd xhci-hcd.0.auto: irq 469, io mem 0x48890000
[    7.727050]  remoteproc1: remote processor 55020000.ipu is now up
[    7.734120] hub 1-0:1.0: USB hub found
[    7.738766] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.744335] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
[    7.751459] hub 1-0:1.0: 1 port detected
[    7.756000] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.763054]  remoteproc2: powering up 40800000.dsp
[    7.769020]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 929770
[    7.776313] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.781831] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    7.790978] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.803449] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[    7.809342] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[    7.815271] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[    7.821224] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.830240] hub 2-0:1.0: USB hub found
[    7.834074] hub 2-0:1.0: 1 port detected
[    7.838656] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.845066] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    7.850588] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    7.863096] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.882752] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    7.891534] xhci-hcd xhci-hcd.1.auto: irq 470, io mem 0x488d0000
[    7.913374] hub 3-0:1.0: USB hub found
[    7.922496] hub 3-0:1.0: 1 port detected
[    7.927136] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.933592] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    7.939109] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    7.952950] cpsw 48484000.ethernet: gpio request failed, ret -517
[    7.967429]  remoteproc2: remote processor 40800000.dsp is now up
[    7.973673] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.982321] virtio_rpmsg_bus virtio1: rpmsg host is online
[    7.987885] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x36
[    7.996524] hub 4-0:1.0: USB hub found
[    8.000318] hub 4-0:1.0: 1 port detected
[    8.004485] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x37
[    8.012940] cpsw 48484000.ethernet: gpio request failed, ret -517
[    8.019951] cpsw 48484000.ethernet: gpio request failed, ret -517
[    8.029190] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
[    8.082188] rpmsg_rpc rpmsg0: probing service rpmsg-dce with src 1024 dst 59
[    8.099703] rpmsg_rpc rpmsg3: probing service rpmsg-dce-dsp with src 1024 dst 59
[    8.108407] cpsw 48484000.ethernet: gpio request failed, ret -517
[    8.115545] cpsw 48484000.ethernet: gpio request failed, ret -517
[    8.123565] rpmsg_rpc rpmsg3: published functions = 8
[    8.140241] rpmsg_rpc rpmsg0: published functions = 8
[    8.168248] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
Starting Bootlog daemon: bootlogd.
[    8.250460] random: dd urandom read with 65 bits of entropy available
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1729: No soundcards found...
Thu Sep  3 18:41:00 UTC 2015
omapconf: powerdm_deinit(): cpu not supported!!!
omapconf: clockdm_deinit(): cpu not supported!!!
/etc/rcS.d/S98_AB_auto_execution.sh: line 17: /proc/irq/301/smp_affinity: No such file or directory
/usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
/usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
/usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio187/direction: No such file or directory
INIT: Entering runlevel: 5
Configuring network interfaces... [   10.572900] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.22.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting system message bus: dbus.
UIM SYSFS Node Not Found
Starting telnet daemon.
Starting tiipclad daemon
GateMP support enabled on host
Opened log file: lad.txt
numProcessors = 5 id = 0 baseId = 0
Spawned daemon: /usr/bin/lad_dra7xx
Starting rpcbind daemon...done.
creating NFS state directory: done
starting statd: done
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
Starting thttpd.
Enabling thermal zones...
Stopping Bootlog daemon: bootlogd.
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# ls -al /dev/video1
crw-rw----    1 root     video      81,   1 Jan  1  1970 /dev/video1
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# ls -al /dev/video*
crw-rw----    1 root     video      81,   0 Jan  1  1970 /dev/video0
crw-rw----    1 root     video      81,   3 Jan  1  1970 /dev/video10
crw-rw----    1 root     video      81,   2 Jan  1  1970 /dev/video11
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# sh debug_dss_clockdumps.sh
=====================DSS clock script===================
Dumps internal clocks and muxes of DSS
CTRL_CORE_DSS_PLL_CONTROL (0x4a002538) = 0x000002AF
video1 PLL :  Disabled
video2 PLL :  Disabled
HDMI   PLL :  Disabled
DSI1_A_CLK mux : DPLL HDMI
DSI1_B_CLK mux : DPLL video2
DSI1_C_CLK mux : DPLL Video2
DSS_CTRL (0x58000040) = 0x00000000
 2: LCD1 clk switch :  DSS clk
 3: LCD2 clk switch :  DSS clk
10: LCD3 clk switch :  DSS clk
 1: func clk switch :  DSS clk
13: DPI1 output     :  HDMI
Clock O/P of MUXes
DSI1_A_CLK :  0
DSI1_B_CLK :  0
DSI1_C_CLK :  0
 2: LCD1 clk :  69000000
 3: LCD2 clk :  69000000
10: LCD3 clk :  69000000
 1: func clk :  69000000
LCD1 logic clk(/ 1 ) :  69000000  pix clk(/ 2 ) :  34500000
LCD2 logic clk(/ 4 ) :  17250000  pix clk(/ 1 ) :  17250000
LCD3 logic clk(/ 1 ) :  69000000  pix clk(/ 1 ) :  69000000
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# [   59.347201] random: nonblocking pool is initialized
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# gst-launch-1.0      v4l2src      device=/dev/video1      num-buffers=1      !      jpegenc      !      filesink      location=./JPEG_FILE
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...[   68.794781] 491, r3003 = 17 , r3004 = 23
New clock: GstSystemClock
[   68.802976] ov1063x 4-0037: r3003 = 17 , r3004 = 23
[   68.810333] 574, width x height = 720 x 480
[   68.814834] ov1063x 4-0037: width x height = 720 x 480
[   68.819996] 590, hts x vts = 1083 x 530
[   68.825137] ov1063x 4-0037: hts x vts = 1083 x 530
DTS file:
 * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
 * Based on "omap4.dtsi"
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/pinctrl/dra.h>
#include "skeleton.dtsi"
#define MAX_SOURCES 400
	#address-cells = <2>;
	#size-cells = <2>;
	compatible = "ti,dra7xx";
	interrupt-parent = <&crossbar_mpu>;
	aliases {
		i2c0 = &i2c1;
		i2c1 = &i2c2;
		i2c2 = &i2c3;
		i2c3 = &i2c4;
		i2c4 = &i2c5;
		serial0 = &uart1;
		serial1 = &uart2;
		serial2 = &uart3;
		serial3 = &uart4;
		serial4 = &uart5;
		serial5 = &uart6;
		serial6 = &uart7;
		serial7 = &uart8;
		serial8 = &uart9;
		serial9 = &uart10;
		ethernet0 = &cpsw_emac0;
		ethernet1 = &cpsw_emac1;
		d_can0 = &dcan1;
		d_can1 = &dcan2;
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
		interrupt-parent = <&gic>;
	gic: interrupt-controller@48211000 {
		compatible = "arm,cortex-a15-gic";
		interrupt-controller;
		#interrupt-cells = <3>;
		reg = <0x0 0x48211000 0x0 0x1000>,
		      <0x0 0x48212000 0x0 0x1000>,
		      <0x0 0x48214000 0x0 0x2000>,
		      <0x0 0x48216000 0x0 0x2000>;
		interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>;
	wakeupgen: interrupt-controller@48281000 {
		compatible = "ti,omap5-wugen-mpu", "ti,omap4-wugen-mpu";
		reg = <0x0 0x48281000 0x0 0x1000>;
	cpus {
		#address-cells = <1>;
		#size-cells = <0>;
		cpu0: cpu@0 {
			device_type = "cpu";
			compatible = "arm,cortex-a15";
			reg = <0>;
			operating-points-v2 = <&cpu0_opp_table>;
			cpu-opp-domain = <&oppdm_mpu>;
			ti,syscon-efuse = <&scm_wkup 0x20c 0xf80000 19>;
			ti,syscon-rev = <&scm_wkup 0x204>;
			clocks = <&dpll_mpu_ck>;
			clock-names = "cpu";
			clock-latency = <300000>; /* From omap-cpufreq driver */
			/* cooling options */
			cooling-min-level = <0>;
			cooling-max-level = <2>;
			#cooling-cells = <2>; /* min followed by max */
	cpu0_opp_table: opp_table0 {
		compatible = "operating-points-v2";
		opp-shared;
		opp_nom@1000000000 {
			opp-hz = /bits/ 64 <1000000000>;
			opp-microvolt = <1060000 850000 1150000>;
			opp-supported-hw = <0xFF 0x01>;
			opp-suspend;
		opp_od@1176000000 {
			opp-hz = /bits/ 64 <1176000000>;
			opp-microvolt = <1160000 885000 1160000>;
			opp-supported-hw = <0xFF 0x02>;
		opp_high@1500000000 {
			opp-hz = /bits/ 64 <1500000000>;
			opp-microvolt = <1210000 950000 1250000>;
			opp-supported-hw = <0xFF 0x04>;
	 * The soc node represents the soc top level view. It is used for IPs
	 * that are not memory mapped in the MPU view or for the MPU itself.
	soc {
		compatible = "ti,omap-infra";
		mpu {
			compatible = "ti,omap5-mpu";
			ti,hwmods = "mpu";
	 * XXX: Use a flat representation of the SOC interconnect.
	 * The real OMAP interconnect network is quite complex.
	 * Since it will not bring real advantage to represent that in DT for
	 * the moment, just use a fake OCP bus entry to represent the whole bus
	 * hierarchy.
	ocp {
		compatible = "ti,dra7-l3-noc", "simple-bus";
		#size-cells = <1>;
		ranges = <0x0 0x0 0x0 0xc0000000>;
		ti,hwmods = "l3_main_1", "l3_main_2";
		reg = <0x0 0x44000000 0x0 0x1000000>,
		      <0x0 0x45000000 0x0 0x1000>;
		interrupts-extended = <&crossbar_mpu GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>,
				      <&wakeupgen GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
		l4_cfg: l4@4a000000 {
			compatible = "ti,dra7-l4-cfg", "simple-bus";
			#size-cells = <1>;
			ranges = <0 0x4a000000 0x22c000>;
			scm: scm@2000 {
				compatible = "ti,dra7-scm-core", "simple-bus";
				reg = <0x2000 0x2000>;
				#size-cells = <1>;
				ranges = <0 0x2000 0x2000>;
				scm_conf: scm_conf@0 {
					compatible = "syscon", "simple-bus";
					reg = <0x0 0x1400>;
					#size-cells = <1>;
					ranges = <0 0x0 0x1400>;
					pbias_regulator: pbias_regulator {
						compatible = "ti,pbias-dra7", "ti,pbias-omap";
						reg = <0xe00 0x4>;
						syscon = <&scm_conf>;
						pbias_mmc_reg: pbias_mmc_omap5 {
							regulator-name = "pbias_mmc_omap5";
							regulator-min-microvolt = <1800000>;
							regulator-max-microvolt = <3000000>;
					scm_conf_clocks: clocks {
						#size-cells = <0>;
				dra7_pmx_core: pinmux@1400 {
					compatible = "ti,dra7-padconf",
						     "pinctrl-single";
					reg = <0x1400 0x0468>;
					#size-cells = <0>;
					#interrupt-cells = <1>;
					pinctrl-single,register-width = <32>;
					pinctrl-single,function-mask = <0x3fffffff>;
				scm_conf1: scm_conf@1c04 {
					compatible = "syscon";
					reg = <0x1c04 0x0020>;
				scm_conf_pcie: scm_conf@1c24 {
					reg = <0x1c24 0x0024>;
				sdma_xbar: dma-router@b78 {
					compatible = "ti,dra7-dma-crossbar";
					reg = <0xb78 0xfc>;
					#dma-cells = <1>;
					dma-requests = <205>;
					ti,dma-safe-map = <0>;
					dma-masters = <&sdma>;
				edma_xbar: dma-router@c78 {
					reg = <0xc78 0x7c>;
					#dma-cells = <2>;
					dma-requests = <204>;
					dma-masters = <&edma>;
			cm_core_aon: cm_core_aon@5000 {
				compatible = "ti,dra7-cm-core-aon";
				reg = <0x5000 0x2000>;
				cm_core_aon_clocks: clocks {
					#size-cells = <0>;
				cm_core_aon_clockdomains: clockdomains {
			cm_core: cm_core@8000 {
				compatible = "ti,dra7-cm-core";
				reg = <0x8000 0x3000>;
				cm_core_clocks: clocks {
					#size-cells = <0>;
				cm_core_clockdomains: clockdomains {
		l4_wkup: l4@4ae00000 {
			compatible = "ti,dra7-l4-wkup", "simple-bus";
			#size-cells = <1>;
			ranges = <0 0x4ae00000 0x3f000>;
			counter32k: counter@4000 {
				compatible = "ti,omap-counter32k";
				reg = <0x4000 0x40>;
				ti,hwmods = "counter_32k";
			prm: prm@6000 {
				compatible = "ti,dra7-prm";
				reg = <0x6000 0x3000>;
				interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
				prm_clocks: clocks {
					#size-cells = <0>;
				prm_clockdomains: clockdomains {
			scm_wkup: scm_conf@c000 {
				reg = <0xc000 0x1000>;
		axi@0 {
			compatible = "simple-bus";
			#size-cells = <1>;
			ranges = <0x51000000 0x51000000 0x3000
				  0x0	     0x20000000 0x10000000>;
			pcie1: pcie@51000000 {
				compatible = "ti,dra7-pcie";
				reg = <0x51000000 0x2000>, <0x51002000 0x14c>, <0x1000 0x2000>;
				reg-names = "rc_dbics", "ti_conf", "config";
				interrupts = <0 232 0x4>, <0 233 0x4>;
				#address-cells = <3>;
				#size-cells = <2>;
				device_type = "pci";
				ranges = <0x81000000 0 0          0x03000 0 0x00010000
					  0x82000000 0 0x20013000 0x13000 0 0xffed000>;
				num-lanes = <1>;
				linux,pci-domain = <0>;
				ti,hwmods = "pcie1";
				phys = <&pcie1_phy>;
				phy-names = "pcie-phy0";
				interrupt-map-mask = <0 0 0 7>;
				interrupt-map = <0 0 0 1 &pcie1_intc 1>,
						<0 0 0 2 &pcie1_intc 2>,
						<0 0 0 3 &pcie1_intc 3>,
						<0 0 0 4 &pcie1_intc 4>;
				pcie1_intc: interrupt-controller {
					#address-cells = <0>;
		axi@1 {
			#size-cells = <1>;
			ranges = <0x51800000 0x51800000 0x3000
				  0x0	     0x30000000 0x10000000>;
			status = "disabled";
			pcie@51800000 {
				reg = <0x51800000 0x2000>, <0x51802000 0x14c>, <0x1000 0x2000>;
				interrupts = <0 355 0x4>, <0 356 0x4>;
				#size-cells = <2>;
					  0x82000000 0 0x30013000 0x13000 0 0xffed000>;
				num-lanes = <1>;
				linux,pci-domain = <1>;
				ti,hwmods = "pcie2";
				phys = <&pcie2_phy>;
				interrupt-map = <0 0 0 1 &pcie2_intc 1>,
						<0 0 0 2 &pcie2_intc 2>,
						<0 0 0 3 &pcie2_intc 3>,
						<0 0 0 4 &pcie2_intc 4>;
				pcie2_intc: interrupt-controller {
		ocmcram1: ocmcram@40300000 {
			compatible = "mmio-sram";
			reg = <0x40300000 0x80000>;
			ranges = <0x0 0x40300000 0x80000>;
			#size-cells = <1>;
			 * This is a placeholder for an optional reserved
			 * region for use by secure software. The size
			 * of this region is not known until runtime so it
			 * is set as zero to either be updated to reserve
			 * space or left unchanged to leave all SRAM for use.
			 * On HS parts that that require the reserved region
			 * either the bootloader can update the size to
			 * the required amount or the node can be overriden
			 * from the board dts file for the secure platform.
			sram-hs@0 {
				compatible = "ti,secure-ram";
				reg = <0x0 0x0>;
		 * NOTE: ocmcram2 and ocmcram3 are not available on all
		 * DRA7xx and AM57xx variants. Confirm availability in
		 * the data manual for the exact part number in use
		 * before enabling these nodes in the board dts file.
		ocmcram2: ocmcram@40400000 {
			reg = <0x40400000 0x100000>;
			ranges = <0x0 0x40400000 0x100000>;
			#size-cells = <1>;
		ocmcram3: ocmcram@40500000 {
			reg = <0x40500000 0x100000>;
			ranges = <0x0 0x40500000 0x100000>;
			#size-cells = <1>;
		bandgap: bandgap@4a0021e0 {
			reg = <0x4a0021e0 0xc
				0x4a00232c 0xc
				0x4a002380 0x2c
				0x4a0023C0 0x3c
				0x4a002564 0x8
				0x4a002574 0x50>;
				compatible = "ti,dra752-bandgap";
				interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>;
				#thermal-sensor-cells = <1>;
		dsp1_system: dsp_system@40d00000 {
			reg = <0x40d00000 0x100>;
		dra7_iodelay_core: padconf@4844a000 {
			compatible = "ti,dra7-iodelay";
			reg = <0x4844a000 0x0d1c>;
			#size-cells = <0>;
		sdma: dma-controller@4a056000 {
			compatible = "ti,omap4430-sdma";
			reg = <0x4a056000 0x1000>;
			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
			#dma-cells = <1>;
			dma-channels = <32>;
			dma-requests = <127>;
		edma: edma@43300000 {
			compatible = "ti,edma3-tpcc";
			ti,hwmods = "tpcc";
			reg = <0x43300000 0x100000>;
			reg-names = "edma3_cc";
			interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "edma3_ccint", "emda3_mperr",
					  "edma3_ccerrint";
			dma-requests = <64>;
			#dma-cells = <2>;
			ti,tptcs = <&edma_tptc0 7>, <&edma_tptc1 0>;
			 * memcpy is disabled, can be enabled with:
			 * ti,edma-memcpy-channels = <20 21>;
			 * for example. Note that these channels need to be
			 * masked in the xbar as well.
		edma_tptc0: tptc@43400000 {
			compatible = "ti,edma3-tptc";
			ti,hwmods = "tptc0";
			reg =	<0x43400000 0x100000>;
			interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "edma3_tcerrint";
		edma_tptc1: tptc@43500000 {
			ti,hwmods = "tptc1";
			reg =	<0x43500000 0x100000>;
			interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
		gpio1: gpio@4ae10000 {
			compatible = "ti,omap4-gpio";
			reg = <0x4ae10000 0x200>;
			interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio1";
			gpio-controller;
			#gpio-cells = <2>;
			#interrupt-cells = <2>;
		gpio2: gpio@48055000 {
			reg = <0x48055000 0x200>;
			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio2";
			gpio-controller;
			#gpio-cells = <2>;
		gpio3: gpio@48057000 {
			reg = <0x48057000 0x200>;
			interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio3";
			gpio-controller;
			#gpio-cells = <2>;
		gpio4: gpio@48059000 {
			reg = <0x48059000 0x200>;
			interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio4";
			gpio-controller;
			#gpio-cells = <2>;
		gpio5: gpio@4805b000 {
			reg = <0x4805b000 0x200>;
			interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio5";
			gpio-controller;
			#gpio-cells = <2>;
		gpio6: gpio@4805d000 {
			reg = <0x4805d000 0x200>;
			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio6";
			gpio-controller;
			#gpio-cells = <2>;
		gpio7: gpio@48051000 {
			reg = <0x48051000 0x200>;
			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio7";
			gpio-controller;
			#gpio-cells = <2>;
		gpio8: gpio@48053000 {
			reg = <0x48053000 0x200>;
			interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpio8";
			gpio-controller;
			#gpio-cells = <2>;
		uart1: serial@4806a000 {
			compatible = "ti,dra742-uart", "ti,omap4-uart";
			reg = <0x4806a000 0x100>;
			interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart1";
			clock-frequency = <48000000>;
			dmas = <&edma_xbar 49 0>, <&edma_xbar 50 0>;
			dma-names = "tx", "rx";
		uart2: serial@4806c000 {
			reg = <0x4806c000 0x100>;
			interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart2";
			dmas = <&edma_xbar 51 0>, <&edma_xbar 52 0>;
		uart3: serial@48020000 {
			reg = <0x48020000 0x100>;
			interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart3";
			dmas = <&edma_xbar 53 0>, <&edma_xbar 54 0>;
		uart4: serial@4806e000 {
			reg = <0x4806e000 0x100>;
			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart4";
			dmas = <&edma_xbar 55 0>, <&edma_xbar 56 0>;
		uart5: serial@48066000 {
			reg = <0x48066000 0x100>;
			interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart5";
			dmas = <&edma_xbar 63 0>, <&edma_xbar 64 0>;
		uart6: serial@48068000 {
			reg = <0x48068000 0x100>;
			interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart6";
			dmas = <&edma_xbar 79 0>, <&edma_xbar 80 0>;
		uart7: serial@48420000 {
			reg = <0x48420000 0x100>;
			interrupts = <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart7";
		uart8: serial@48422000 {
			reg = <0x48422000 0x100>;
			interrupts = <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart8";
		uart9: serial@48424000 {
			reg = <0x48424000 0x100>;
			interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart9";
		uart10: serial@4ae2b000 {
			reg = <0x4ae2b000 0x100>;
			interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "uart10";
		mailbox1: mailbox@4a0f4000 {
			compatible = "ti,omap4-mailbox";
			reg = <0x4a0f4000 0x200>;
			interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox1";
			#mbox-cells = <1>;
			ti,mbox-num-users = <3>;
			ti,mbox-num-fifos = <8>;
		mailbox2: mailbox@4883a000 {
			reg = <0x4883a000 0x200>;
			interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox2";
			#mbox-cells = <1>;
			ti,mbox-num-users = <4>;
			ti,mbox-num-fifos = <12>;
		mailbox3: mailbox@4883c000 {
			reg = <0x4883c000 0x200>;
			interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox3";
			#mbox-cells = <1>;
		mailbox4: mailbox@4883e000 {
			reg = <0x4883e000 0x200>;
			interrupts = <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox4";
			#mbox-cells = <1>;
		mailbox5: mailbox@48840000 {
			reg = <0x48840000 0x200>;
			interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox5";
			#mbox-cells = <1>;
		mailbox6: mailbox@48842000 {
			reg = <0x48842000 0x200>;
			interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox6";
			#mbox-cells = <1>;
		mailbox7: mailbox@48844000 {
			reg = <0x48844000 0x200>;
			interrupts = <GIC_SPI 257 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox7";
			#mbox-cells = <1>;
		mailbox8: mailbox@48846000 {
			reg = <0x48846000 0x200>;
			interrupts = <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox8";
			#mbox-cells = <1>;
		mailbox9: mailbox@4885e000 {
			reg = <0x4885e000 0x200>;
			interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox9";
			#mbox-cells = <1>;
		mailbox10: mailbox@48860000 {
			reg = <0x48860000 0x200>;
			interrupts = <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 271 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox10";
			#mbox-cells = <1>;
		mailbox11: mailbox@48862000 {
			reg = <0x48862000 0x200>;
			interrupts = <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox11";
			#mbox-cells = <1>;
		mailbox12: mailbox@48864000 {
			reg = <0x48864000 0x200>;
			interrupts = <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox12";
			#mbox-cells = <1>;
		mailbox13: mailbox@48802000 {
			reg = <0x48802000 0x200>;
			interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 380 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 381 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mailbox13";
			#mbox-cells = <1>;
		timer1: timer@4ae18000 {
			compatible = "ti,omap5430-timer";
			reg = <0x4ae18000 0x80>;
			interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer1";
			ti,timer-alwon;
		timer2: timer@48032000 {
			reg = <0x48032000 0x80>;
			interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer2";
		timer3: timer@48034000 {
			reg = <0x48034000 0x80>;
			interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer3";
		timer4: timer@48036000 {
			reg = <0x48036000 0x80>;
			interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer4";
		timer5: timer@48820000 {
			reg = <0x48820000 0x80>;
			interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer5";
		timer6: timer@48822000 {
			reg = <0x48822000 0x80>;
			interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer6";
		timer7: timer@48824000 {
			reg = <0x48824000 0x80>;
			interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer7";
		timer8: timer@48826000 {
			reg = <0x48826000 0x80>;
			interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer8";
		timer9: timer@4803e000 {
			reg = <0x4803e000 0x80>;
			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer9";
		timer10: timer@48086000 {
			reg = <0x48086000 0x80>;
			interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer10";
		timer11: timer@48088000 {
			reg = <0x48088000 0x80>;
			interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer11";
		timer12: timer@4ae20000 {
			reg = <0x4ae20000 0x80>;
			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer12";
			ti,timer-alwon;
			ti,timer-secure;
		timer13: timer@48828000 {
			reg = <0x48828000 0x80>;
			interrupts = <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer13";
		timer14: timer@4882a000 {
			reg = <0x4882a000 0x80>;
			interrupts = <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer14";
		timer15: timer@4882c000 {
			reg = <0x4882c000 0x80>;
			interrupts = <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer15";
		timer16: timer@4882e000 {
			reg = <0x4882e000 0x80>;
			interrupts = <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "timer16";
		wdt2: wdt@4ae14000 {
			compatible = "ti,omap3-wdt";
			reg = <0x4ae14000 0x80>;
			interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "wd_timer2";
		hwspinlock: spinlock@4a0f6000 {
			compatible = "ti,omap4-hwspinlock";
			reg = <0x4a0f6000 0x1000>;
			ti,hwmods = "spinlock";
			#hwlock-cells = <1>;
		dmm@4e000000 {
			compatible = "ti,omap5-dmm";
			reg = <0x4e000000 0x800>;
			interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "dmm";
		ipu1: ipu@58820000 {
			compatible = "ti,dra7-ipu";
			reg = <0x58820000 0x10000>;
			reg-names = "l2ram";
			ti,hwmods = "ipu1";
			iommus = <&mmu_ipu1>;
			ti,rproc-standby-info = <0x4a005520>;
		ipu2: ipu@55020000 {
			reg = <0x55020000 0x10000>;
			ti,hwmods = "ipu2";
			iommus = <&mmu_ipu2>;
			ti,rproc-standby-info = <0x4a008920>;
		dsp1: dsp@40800000 {
			compatible = "ti,dra7-dsp";
			reg = <0x40800000 0x48000>,
			      <0x40e00000 0x8000>,
			      <0x40f00000 0x8000>;
			reg-names = "l2ram", "l1pram", "l1dram";
			ti,hwmods = "dsp1";
			syscon-bootreg = <&scm_conf 0x55c>;
			iommus = <&mmu0_dsp1>, <&mmu1_dsp1>;
			ti,rproc-standby-info = <0x4a005420>;
		gpu: gpu@56000000 {
			compatible = "ti,dra7-sgx544", "img,sgx544";
			reg = <0x56000000 0x10000>;
			reg-names = "gpu_ocp_base";
			interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "gpu";
			clocks = <&l3_iclk_div>, <&gpu_core_gclk_mux>,
				 <&gpu_hyd_gclk_mux>;
			clock-names = "iclk", "fclk1", "fclk2";
		bb2d: bb2d@59000000 {
			compatible = "ti,dra7-bb2d";
			reg = <0x59000000 0x0700>;
			interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "bb2d";
			clocks = <&dpll_core_h24x2_ck>;
			clock-names = "fck";
		i2c1: i2c@48070000 {
			compatible = "ti,omap4-i2c";
			reg = <0x48070000 0x100>;
			interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "i2c1";
		i2c2: i2c@48072000 {
			reg = <0x48072000 0x100>;
			interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "i2c2";
		i2c3: i2c@48060000 {
			reg = <0x48060000 0x100>;
			interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "i2c3";
		i2c4: i2c@4807a000 {
			reg = <0x4807a000 0x100>;
			interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "i2c4";
		i2c5: i2c@4807c000 {
			reg = <0x4807c000 0x100>;
			interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "i2c5";
		mmc1: mmc@4809c000 {
			compatible = "ti,dra7-hsmmc", "ti,omap4-hsmmc";
			reg = <0x4809c000 0x400>;
			interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmc1";
			ti,dual-volt;
			ti,needs-special-reset;
			dmas = <&sdma_xbar 61>, <&sdma_xbar 62>;
			pbias-supply = <&pbias_mmc_reg>;
			sd-uhs-sdr104;
			sd-uhs-sdr50;
			sd-uhs-ddr50;
			sd-uhs-sdr25;
			sd-uhs-sdr12;
		mmc2: mmc@480b4000 {
			reg = <0x480b4000 0x400>;
			interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmc2";
			dmas = <&sdma_xbar 47>, <&sdma_xbar 48>;
#if 0
			sd-uhs-sdr25;
			sd-uhs-sdr12;
			mmc-hs200-1_8v;
			mmc-ddr-1_8v;
#endif
		mmc3: mmc@480ad000 {
			reg = <0x480ad000 0x400>;
			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmc3";
			dmas = <&sdma_xbar 77>, <&sdma_xbar 78>;
			sd-uhs-sdr12;
			sd-uhs-sdr25;
			sd-uhs-sdr50;
		mmc4: mmc@480d1000 {
			reg = <0x480d1000 0x400>;
			interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmc4";
			dmas = <&sdma_xbar 57>, <&sdma_xbar 58>;
#if 0
			sd-uhs-sdr12;
			sd-uhs-sdr25;
#endif
		mmu0_dsp1: mmu@40d01000 {
			compatible = "ti,dra7-dsp-iommu";
			reg = <0x40d01000 0x100>;
			interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmu0_dsp1";
			#iommu-cells = <0>;
			ti,syscon-mmuconfig = <&dsp1_system 0x0>;
		mmu1_dsp1: mmu@40d02000 {
			reg = <0x40d02000 0x100>;
			interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmu1_dsp1";
			#iommu-cells = <0>;
			ti,syscon-mmuconfig = <&dsp1_system 0x1>;
		mmu_ipu1: mmu@58882000 {
			compatible = "ti,dra7-iommu";
			reg = <0x58882000 0x100>;
			interrupts = <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmu_ipu1";
			#iommu-cells = <0>;
			ti,iommu-bus-err-back;
		mmu_ipu2: mmu@55082000 {
			reg = <0x55082000 0x100>;
			interrupts = <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "mmu_ipu2";
			#iommu-cells = <0>;
		pruss1: pruss@4b200000 {
			compatible = "ti,am5728-pruss";
			ti,hwmods = "pruss1";
			reg = <0x4b200000 0x2000>,
			      <0x4b202000 0x2000>,
			      <0x4b210000 0x8000>,
			      <0x4b226000 0x2000>,
			      <0x4b22e000 0x31c>,
			      <0x4b232000 0x58>;
			reg-names = "dram0", "dram1", "shrdram2", "cfg",
				    "iep", "mii_rt";
			#size-cells = <1>;
			ranges;
			pruss1_intc: intc@4b220000 {
				compatible = "ti,am5728-pruss-intc";
				reg = <0x4b220000 0x2000>;
				reg-names = "intc";
				interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
				interrupt-names = "host2", "host3", "host4",
						  "host5", "host6", "host7",
						  "host8", "host9";
			pru1_0: pru0@4b234000 {
				compatible = "ti,am5728-pru";
				reg = <0x4b234000 0x3000>,
				      <0x4b222000 0x400>,
				      <0x4b222400 0x100>;
				reg-names = "iram", "control", "debug";
			pru1_1: pru1@4b238000 {
				reg = <0x4b238000 0x3000>,
				      <0x4b224000 0x400>,
				      <0x4b224400 0x100>;
			pruss1_mdio: mdio@4b232400 {
				compatible = "ti,davinci_mdio";
				#size-cells = <0>;
				clocks = <&dpll_gmac_h13x2_ck>;
				bus_freq = <1000000>;
				reg = <0x4b232400 0x90>;
		pruss2: pruss@4b280000 {
			ti,hwmods = "pruss2";
			reg = <0x4b280000 0x2000>,
			      <0x4b282000 0x2000>,
			      <0x4b290000 0x8000>,
			      <0x4b2a6000 0x2000>,
			      <0x4b2ae000 0x31c>,
			      <0x4b2b2000 0x58>;
				    "iep", "mii_rt";
			#size-cells = <1>;
			ranges;
			pruss2_intc: intc@4b2a0000 {
				reg = <0x4b2a0000 0x2000>;
				reg-names = "intc";
				interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>;
						  "host8", "host9";
			pru2_0: pru0@4b2b4000 {
				reg = <0x4b2b4000 0x3000>,
				      <0x4b2a2000 0x400>,
				      <0x4b2a2400 0x100>;
			pru2_1: pru1@4b2b8000 {
				reg = <0x4b2b8000 0x3000>,
				      <0x4b2a4000 0x400>,
				      <0x4b2a4400 0x100>;
			pruss2_mdio: mdio@4b2b2400 {
				#size-cells = <0>;
				reg = <0x4b2b2400 0x90>;
		abb_mpu: regulator-abb-mpu {
			compatible = "ti,abb-v3";
			regulator-name = "abb_mpu";
			#size-cells = <0>;
			clocks = <&sys_clkin1>;
			ti,settling-time = <50>;
			ti,clock-cycles = <16>;
			reg = <0x4ae07ddc 0x4>, <0x4ae07de0 0x4>,
			      <0x4ae06014 0x4>, <0x4a003b20 0xc>,
			      <0x4ae0c158 0x4>;
			reg-names = "setup-address", "control-address",
				    "int-address", "efuse-address",
				    "ldo-address";
			ti,tranxdone-status-mask = <0x80>;
			/* LDOVBBMPU_FBB_MUX_CTRL */
			ti,ldovbb-override-mask = <0x400>;
			/* LDOVBBMPU_FBB_VSET_OUT */
			ti,ldovbb-vset-mask = <0x1F>;
			 * NOTE: only FBB mode used but actual vset will
			 * determine final biasing
			ti,abb_info = <
			/*uV		ABB	efuse	rbb_m fbb_m	vset_m*/
			1060000		0	0x0	0 0x02000000 0x01F00000
			1160000		0	0x4	0 0x02000000 0x01F00000
			1210000		0	0x8	0 0x02000000 0x01F00000
		abb_ivahd: regulator-abb-ivahd {
			regulator-name = "abb_ivahd";
			#size-cells = <0>;
			reg = <0x4ae07e34 0x4>, <0x4ae07e24 0x4>,
			      <0x4ae06010 0x4>, <0x4a0025cc 0xc>,
			      <0x4a002470 0x4>;
				    "ldo-address";
			ti,tranxdone-status-mask = <0x40000000>;
			/* LDOVBBIVA_FBB_MUX_CTRL */
			/* LDOVBBIVA_FBB_VSET_OUT */
			ti,abb_info = <
			1055000		0	0x0	0 0x02000000 0x01F00000
			1150000		0	0x4	0 0x02000000 0x01F00000
			1250000		0	0x8	0 0x02000000 0x01F00000
		abb_dspeve: regulator-abb-dspeve {
			regulator-name = "abb_dspeve";
			#size-cells = <0>;
			reg = <0x4ae07e30 0x4>, <0x4ae07e20 0x4>,
			      <0x4ae06010 0x4>, <0x4a0025e0 0xc>,
			      <0x4a00246c 0x4>;
				    "ldo-address";
			ti,tranxdone-status-mask = <0x20000000>;
			/* LDOVBBDSPEVE_FBB_MUX_CTRL */
			/* LDOVBBDSPEVE_FBB_VSET_OUT */
			ti,abb_info = <
		abb_gpu: regulator-abb-gpu {
			regulator-name = "abb_gpu";
			#size-cells = <0>;
			reg = <0x4ae07de4 0x4>, <0x4ae07de8 0x4>,
			      <0x4ae06010 0x4>, <0x4a003b08 0xc>,
			      <0x4ae0c154 0x4>;
				    "ldo-address";
			ti,tranxdone-status-mask = <0x10000000>;
			/* LDOVBBGPU_FBB_MUX_CTRL */
			/* LDOVBBGPU_FBB_VSET_OUT */
			ti,abb_info = <
			1090000		0	0x0	0 0x02000000 0x01F00000
			1210000		0	0x4	0 0x02000000 0x01F00000
			1280000		0	0x8	0 0x02000000 0x01F00000
		oppdm_mpu: oppdm@4a003b20 {
			compatible = "ti,omap5-oppdm";
			#oppdm-cells = <0>;
			vbb-supply = <&abb_mpu>;
			reg = <0x4a003b20 0xc>;
			ti,efuse-settings = <
			/* uV   offset */
			1060000 0x0
			1160000 0x4
			1210000 0x8
			ti,absolute-max-voltage-uv = <1500000>;
		oppdm_ivahd: oppdm@4a0025cc {
			#oppdm-cells = <0>;
			vbb-supply = <&abb_ivahd>;
			reg = <0x4a0025cc 0xc>;
			/* uV   offset */
			1055000 0x0
			1150000 0x4
			1250000 0x8
		oppdm_dspeve: oppdm@4a0025e0 {
			#oppdm-cells = <0>;
			vbb-supply = <&abb_dspeve>;
			reg = <0x4a0025e0 0xc>;
			/* uV   offset */
			1055000 0x0
			1150000 0x4
			1250000 0x8
		oppdm_gpu: oppdm@4a003b08 {
			#oppdm-cells = <0>;
			vbb-supply = <&abb_gpu>;
			reg = <0x4a003b08 0xc>;
			/* uV   offset */
			1090000 0x0
			1210000 0x4
			1280000 0x8
		oppdm_core: oppdm@4a0025f4 {
			compatible = "ti,omap5-core-oppdm";
			#oppdm-cells = <0>;
			reg = <0x4a0025f4 0x4>;
			/* uV   offset */
			1090000 0x0
		mcspi1: spi@48098000 {
			compatible = "ti,omap4-mcspi";
			reg = <0x48098000 0x200>;
			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "mcspi1";
			ti,spi-num-cs = <4>;
			dmas = <&sdma_xbar 35>,
			       <&sdma_xbar 36>,
			       <&sdma_xbar 37>,
			       <&sdma_xbar 38>,
			       <&sdma_xbar 39>,
			       <&sdma_xbar 40>,
			       <&sdma_xbar 41>,
			       <&sdma_xbar 42>;
			dma-names = "tx0", "rx0", "tx1", "rx1",
				    "tx2", "rx2", "tx3", "rx3";
		mcspi2: spi@4809a000 {
			reg = <0x4809a000 0x200>;
			interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "mcspi2";
			ti,spi-num-cs = <2>;
			dmas = <&sdma_xbar 43>,
			       <&sdma_xbar 44>,
			       <&sdma_xbar 45>,
			       <&sdma_xbar 46>;
			dma-names = "tx0", "rx0", "tx1", "rx1";
		mcspi3: spi@480b8000 {
			reg = <0x480b8000 0x200>;
			interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "mcspi3";
			dmas = <&sdma_xbar 15>, <&sdma_xbar 16>;
			dma-names = "tx0", "rx0";
		mcspi4: spi@480ba000 {
			reg = <0x480ba000 0x200>;
			interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ti,hwmods = "mcspi4";
			ti,spi-num-cs = <1>;
			dmas = <&sdma_xbar 70>, <&sdma_xbar 71>;
		qspi: qspi@4b300000 {
			compatible = "ti,dra7xxx-qspi";
			reg = <0x4b300000 0x100>,
			      <0x5c000000 0x4000000>;
			reg-names = "qspi_base", "qspi_mmap";
			syscon-chipselects = <&scm_conf 0x558>;
			#size-cells = <0>;
			ti,hwmods = "qspi";
			clocks = <&qspi_gfclk_div>;
			num-cs = <4>;
			interrupts = <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>;
		/* OCP2SCP3 */
		ocp2scp@4a090000 {
			compatible = "ti,omap-ocp2scp";
			#size-cells = <1>;
			ranges;
			reg = <0x4a090000 0x20>;
			ti,hwmods = "ocp2scp3";
			sata_phy: phy@4A096000 {
				compatible = "ti,phy-pipe3-sata";
				reg = <0x4A096000 0x80>, /* phy_rx */
				      <0x4A096400 0x64>, /* phy_tx */
				      <0x4A096800 0x40>; /* pll_ctrl */
				reg-names = "phy_rx", "phy_tx", "pll_ctrl";
				syscon-phy-power = <&scm_conf 0x374>;
				clocks = <&sys_clkin1>, <&sata_ref_clk>;
				clock-names = "sysclk", "refclk";
				syscon-pllreset = <&scm_conf 0x3fc>;
				#phy-cells = <0>;
			pcie1_phy: pciephy@4a094000 {
				compatible = "ti,phy-pipe3-pcie";
				reg = <0x4a094000 0x80>, /* phy_rx */
				      <0x4a094400 0x64>; /* phy_tx */
				reg-names = "phy_rx", "phy_tx";
				syscon-phy-power = <&scm_conf_pcie 0x1c>;
				syscon-pcs = <&scm_conf_pcie 0x10>;
				clocks = <&dpll_pcie_ref_ck>,
					 <&dpll_pcie_ref_m2ldo_ck>,
					 <&optfclk_pciephy1_32khz>,
					 <&optfclk_pciephy1_clk>,
					 <&optfclk_pciephy1_div_clk>,
					 <&optfclk_pciephy_div>,
					 <&sys_clkin1>;
				clock-names = "dpll_ref", "dpll_ref_m2",
					      "wkupclk", "refclk",
					      "div-clk", "phy-div", "sysclk";
				#phy-cells = <0>;
			pcie2_phy: pciephy@4a095000 {
				reg = <0x4a095000 0x80>, /* phy_rx */
				      <0x4a095400 0x64>; /* phy_tx */
				syscon-phy-power = <&scm_conf_pcie 0x20>;
					 <&optfclk_pciephy2_32khz>,
					 <&optfclk_pciephy2_clk>,
					 <&optfclk_pciephy2_div_clk>,
					 <&sys_clkin1>;
				#phy-cells = <0>;
		sata: sata@4a141100 {
			compatible = "snps,dwc-ahci";
			reg = <0x4a140000 0x1100>, <0x4a141100 0x7>;
			interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;
			phys = <&sata_phy>;
			phy-names = "sata-phy";
			clocks = <&sata_ref_clk>;
			ti,hwmods = "sata";
		rtc: rtc@48838000 {
			compatible = "ti,am3352-rtc";
			reg = <0x48838000 0x100>;
			interrupts = <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "rtcss";
			clocks = <&sys_32k_ck>;
		/* OCP2SCP1 */
		ocp2scp@4a080000 {
			#size-cells = <1>;
			ranges;
			reg = <0x4a080000 0x20>;
			ti,hwmods = "ocp2scp1";
			usb2_phy1: phy@4a084000 {
				compatible = "ti,dra7x-usb2", "ti,omap-usb2";
				reg = <0x4a084000 0x400>;
				syscon-phy-power = <&scm_conf 0x300>;
				clocks = <&usb_phy1_always_on_clk32k>,
					 <&usb_otg_ss1_refclk960m>;
				clock-names =	"wkupclk",
						"refclk";
				#phy-cells = <0>;
			usb2_phy2: phy@4a085000 {
				compatible = "ti,dra7x-usb2-phy2",
					     "ti,omap-usb2";
				reg = <0x4a085000 0x400>;
				syscon-phy-power = <&scm_conf 0xe74>;
				clocks = <&usb_phy2_always_on_clk32k>,
					 <&usb_otg_ss2_refclk960m>;
						"refclk";
				#phy-cells = <0>;
			usb3_phy1: phy@4a084400 {
				compatible = "ti,omap-usb3";
				reg = <0x4a084400 0x80>,
				      <0x4a084800 0x64>,
				      <0x4a084c00 0x40>;
				syscon-phy-power = <&scm_conf 0x370>;
				clocks = <&usb_phy3_always_on_clk32k>,
					 <&sys_clkin1>,
						"sysclk",
						"refclk";
				#phy-cells = <0>;
		omap_dwc3_1: omap_dwc3_1@48880000 {
			compatible = "ti,dwc3";
			ti,hwmods = "usb_otg_ss1";
			reg = <0x48880000 0x10000>;
			interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <1>;
			utmi-mode = <2>;
			ranges;
			usb1: usb@48890000 {
				compatible = "snps,dwc3";
				reg = <0x48890000 0x17000>;
				interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
				interrupt-names = "peripheral",
						  "host",
						  "otg";
				phys = <&usb2_phy1>, <&usb3_phy1>;
				phy-names = "usb2-phy", "usb3-phy";
				tx-fifo-resize;
				maximum-speed = "super-speed";
				dr_mode = "otg";
				snps,dis_u3_susphy_quirk;
				snps,dis_u2_susphy_quirk;
		omap_dwc3_2: omap_dwc3_2@488c0000 {
			ti,hwmods = "usb_otg_ss2";
			reg = <0x488c0000 0x10000>;
			interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <1>;
			utmi-mode = <2>;
			ranges;
			usb2: usb@488d0000 {
				reg = <0x488d0000 0x17000>;
				interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
						  "host",
						  "otg";
				phys = <&usb2_phy2>;
				phy-names = "usb2-phy";
				tx-fifo-resize;
				maximum-speed = "high-speed";
				dr_mode = "otg";
		/* IRQ for DWC3_3 and DWC3_4 need IRQ crossbar */
		omap_dwc3_3: omap_dwc3_3@48900000 {
			ti,hwmods = "usb_otg_ss3";
			reg = <0x48900000 0x10000>;
			interrupts = <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <1>;
			utmi-mode = <2>;
			ranges;
			//status = "disabled";
			usb3: usb@48910000 {
				reg = <0x48910000 0x17000>;
				interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>,
						  "host",
						  "otg";
				tx-fifo-resize;
				dr_mode = "otg";
		elm: elm@48078000 {
			compatible = "ti,am3352-elm";
			reg = <0x48078000 0xfc0>;      /* device IO registers */
			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
			ti,hwmods = "elm";
		gpmc: gpmc@50000000 {
			compatible = "ti,am3352-gpmc";
			ti,hwmods = "gpmc";
			reg = <0x50000000 0x37c>;      /* device IO registers */
			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 4 0>;
			dma-names = "rxtx";
			gpmc,num-cs = <8>;
			gpmc,num-waitpins = <2>;
			#size-cells = <1>;
			gpio-controller;
			#gpio-cells = <2>;
		atl: atl@4843c000 {
			compatible = "ti,dra7-atl";
			reg = <0x4843c000 0x3ff>;
			ti,hwmods = "atl";
			ti,provided-clocks = <&atl_clkin0_ck>, <&atl_clkin1_ck>,
					     <&atl_clkin2_ck>, <&atl_clkin3_ck>;
			clocks = <&atl_gfclk_mux>;
		mcasp1: mcasp@48460000 {
			compatible = "ti,dra7-mcasp-audio";
			ti,hwmods = "mcasp1";
			reg = <0x48460000 0x2000>,
			      <0x45800000 0x1000>;
			reg-names = "mpu","dat";
			interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "tx", "rx";
			dmas = <&edma_xbar 129 1>, <&edma_xbar 128 1>;
			clocks = <&mcasp1_aux_gfclk_mux>, <&mcasp1_ahclkx_mux>,
				 <&mcasp1_ahclkr_mux>;
			clock-names = "fck", "ahclkx", "ahclkr";
		mcasp2: mcasp@48464000 {
			ti,hwmods = "mcasp2";
			reg = <0x48464000 0x2000>,
			      <0x45c00000 0x1000>;
			interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 131 1>, <&edma_xbar 130 1>;
			clocks = <&mcasp2_aux_gfclk_mux>, <&mcasp2_ahclkx_mux>,
				 <&mcasp2_ahclkr_mux>;
		mcasp3: mcasp@48468000 {
			ti,hwmods = "mcasp3";
			reg = <0x48468000 0x2000>,
			      <0x46000000 0x1000>;
			interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 133 1>, <&edma_xbar 132 1>;
			clocks = <&mcasp3_aux_gfclk_mux>, <&mcasp3_ahclkx_mux>;
			clock-names = "fck", "ahclkx";
		mcasp4: mcasp@4846c000 {
			ti,hwmods = "mcasp4";
			reg = <0x4846c000 0x2000>,
			      <0x48436000 0x1000>;
			interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 135 1>, <&edma_xbar 134 1>;
			clocks = <&mcasp4_aux_gfclk_mux>, <&mcasp4_ahclkx_mux>;
		mcasp5: mcasp@48470000 {
			ti,hwmods = "mcasp5";
			reg = <0x48470000 0x2000>,
			      <0x4843a000 0x1000>;
			interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 137 1>, <&edma_xbar 136 1>;
			clocks = <&mcasp5_aux_gfclk_mux>, <&mcasp5_ahclkx_mux>;
		mcasp6: mcasp@48474000 {
			ti,hwmods = "mcasp6";
			reg = <0x48474000 0x2000>,
			      <0x4844c000 0x1000>;
			interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 139 1>, <&edma_xbar 138 1>;
			clocks = <&mcasp6_aux_gfclk_mux>, <&mcasp6_ahclkx_mux>;
		mcasp7: mcasp@48478000 {
			ti,hwmods = "mcasp7";
			reg = <0x48478000 0x2000>,
			      <0x48450000 0x1000>;
			interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 141 1>, <&edma_xbar 140 1>;
			clocks = <&mcasp7_aux_gfclk_mux>, <&mcasp7_ahclkx_mux>;
		mcasp8: mcasp@4847c000 {
			ti,hwmods = "mcasp8";
			reg = <0x4847c000 0x2000>,
			      <0x48454000 0x1000>;
			interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 143 1>, <&edma_xbar 142 1>;
			clocks = <&mcasp8_aux_gfclk_mux>, <&mcasp8_ahclkx_mux>;
		crossbar_mpu: crossbar@4a002a48 {
			compatible = "ti,irq-crossbar";
			reg = <0x4a002a48 0x130>;
			interrupt-parent = <&wakeupgen>;
			ti,max-irqs = <160>;
			ti,max-crossbar-sources = <MAX_SOURCES>;
			ti,reg-size = <2>;
			ti,irqs-reserved = <0 1 2 3 5 6 131 132>;
			ti,irqs-skip = <10 133 139 140>;
			ti,irqs-safe-map = <0>;
		mac: ethernet@48484000 {
			compatible = "ti,dra7-cpsw","ti,cpsw";
			ti,hwmods = "gmac";
			clocks = <&dpll_gmac_ck>, <&gmac_gmii_ref_clk_div>;
			clock-names = "fck", "cpts";
			cpdma_channels = <8>;
			ale_entries = <1024>;
			bd_ram_size = <0x2000>;
			no_bd_ram = <0>;
			rx_descs = <64>;
			mac_control = <0x20>;
			slaves = <2>;
			active_slave = <0>;
			cpts_clock_mult = <0x80000000>;
			cpts_clock_shift = <29>;
			reg = <0x48484000 0x1000
			       0x48485200 0x2E00>;
			#size-cells = <1>;
			 * Do not allow gating of cpsw clock as workaround
			 * for errata i877. Keeping internal clock disabled
			 * causes the device switching characteristics
			 * to degrade over time and eventually fail to meet
			 * the data manual delay time/skew specs.
			ti,no-idle;
			 * rx_thresh_pend
			 * rx_pend
			 * tx_pend
			 * misc_pend
			interrupts = <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>;
			ranges;
			davinci_mdio: mdio@48485000 {
				compatible = "ti,cpsw-mdio";
				#size-cells = <0>;
				ti,hwmods = "davinci_mdio";
				reg = <0x48485000 0x100>;
			cpsw_emac0: slave@48480200 {
				/* Filled in by U-Boot */
				mac-address = [ 00 00 00 00 00 00 ];
			cpsw_emac1: slave@48480300 {
			phy_sel: cpsw-phy-sel@4a002554 {
				compatible = "ti,dra7xx-cpsw-phy-sel";
				reg= <0x4a002554 0x4>;
				reg-names = "gmii-sel";
		dcan1: can@481cc000 {
			compatible = "ti,dra7-d_can";
			ti,hwmods = "dcan1";
			reg = <0x4ae3c000 0x2000>;
			syscon-raminit = <&scm_conf 0x558 0>;
			interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&dcan1_sys_clk_mux>;
		dcan2: can@481d0000 {
			ti,hwmods = "dcan2";
			reg = <0x48480000 0x2000>;
			syscon-raminit = <&scm_conf 0x558 1>;
			interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>;
		dss: dss@58000000 {
			compatible = "ti,dra7-dss";
			/* 'reg' defined in dra72x.dtsi and dra74x.dtsi */
			/* 'clocks' defined in dra72x.dtsi and dra74x.dtsi */
			ti,hwmods = "dss_core";
			/* CTRL_CORE_DSS_PLL_CONTROL */
			syscon-pll-ctrl = <&scm_conf 0x538>;
			#size-cells = <1>;
			ranges;
			dispc@58001000 {
				compatible = "ti,dra7-dispc";
				reg = <0x58001000 0x1000>;
				interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
				ti,hwmods = "dss_dispc";
				clocks = <&dss_dss_clk>;
				/* CTRL_CORE_SMA_SW_1 */
				syscon-pol = <&scm_conf 0x534>;
			hdmi: encoder@58060000 {
				compatible = "ti,dra7-hdmi";
				reg = <0x58040000 0x200>,
				      <0x58040200 0x80>,
				      <0x58040300 0x80>,
				      <0x58060000 0x19000>;
				reg-names = "wp", "pll", "phy", "core";
				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
				ti,hwmods = "dss_hdmi";
				clocks = <&dss_48mhz_clk>, <&dss_hdmi_clk>;
				clock-names = "fck", "sys_clk";
				dmas = <&sdma_xbar 76>;
				dma-names = "audio_tx";
		vpe {
			compatible = "ti,vpe";
			ti,hwmods = "vpe";
			clocks = <&dpll_core_h23x2_ck>;
			reg = <0x489d0000 0x120>,
			      <0x489d0300 0x20>,
			      <0x489d0400 0x20>,
			      <0x489d0500 0x20>,
			      <0x489d0600 0x3c>,
			      <0x489d0700 0x80>,
			      <0x489d5700 0x18>,
			      <0x489dd000 0x400>;
			reg-names = "vpe_top",
				    "vpe_chr_us0",
				    "vpe_chr_us1",
				    "vpe_chr_us2",
				    "vpe_dei",
				    "sc",
				    "csc",
				    "vpdma";
			interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		vip1: vip@0x48970000 {
			compatible = "ti,vip1";
			reg = <0x48970000 0x114>,
			      <0x48975500 0xD8>,
			      <0x48975700 0x18>,
			      <0x48975800 0x80>,
			      <0x48975a00 0xD8>,
			      <0x48975c00 0x18>,
			      <0x48975d00 0x80>,
			      <0x4897d000 0x400>;
			reg-names = "vip",
				    "parser0",
				    "csc0",
				    "sc0",
				    "parser1",
				    "csc1",
				    "sc1",
				    "vpdma";
			ti,hwmods = "vip1";
			interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 392 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			vin1a: port@0 {
				#size-cells = <0>;
				reg = <0>;
			vin2a: port@1 {
				#size-cells = <0>;
				reg = <1>;
			vin1b: port@2 {
				#size-cells = <0>;
				reg = <2>;
			vin2b: port@3 {
				#size-cells = <0>;
				reg = <3>;
		epwmss0: epwmss@4843e000 {
			compatible = "ti,dra7xx-pwmss", "ti,am33xx-pwmss";
			reg = <0x4843e000 0x30>;
			ti,hwmods = "epwmss0";
			#size-cells = <1>;
			ranges;
			ehrpwm0: pwm@4843e200 {
				compatible = "ti,dra7xx-ehrpwm",
					     "ti,am33xx-ehrpwm";
				#pwm-cells = <3>;
				reg = <0x4843e200 0x80>;
				clocks = <&ehrpwm0_tbclk>;
				clock-names = "tbclk";
			ecap0: ecap@4843e100 {
				compatible = "ti,dra7xx-ecap",
					     "ti,am33xx-ecap";
				#pwm-cells = <3>;
				reg = <0x4843e100 0x80>;
		epwmss1: epwmss@48440000 {
			reg = <0x48440000 0x30>;
			ti,hwmods = "epwmss1";
			#size-cells = <1>;
			ranges;
			ehrpwm1: pwm@48440200 {
					     "ti,am33xx-ehrpwm";
				#pwm-cells = <3>;
				reg = <0x48440200 0x80>;
				clocks = <&ehrpwm1_tbclk>;
			ecap1: ecap@48440100 {
					     "ti,am33xx-ecap";
				#pwm-cells = <3>;
				reg = <0x48440100 0x80>;
		epwmss2: epwmss@48442000 {
			reg = <0x48442000 0x30>;
			ti,hwmods = "epwmss2";
			#size-cells = <1>;
			ranges;
			ehrpwm2: pwm@48442200 {
					     "ti,am33xx-ehrpwm";
				#pwm-cells = <3>;
				reg = <0x48442200 0x80>;
				clocks = <&ehrpwm2_tbclk>;
			ecap2: ecap@48442100 {
					     "ti,am33xx-ecap";
				#pwm-cells = <3>;
				reg = <0x48442100 0x80>;
		aes1: aes@4b500000 {
			compatible = "ti,omap4-aes";
			ti,hwmods = "aes1";
			reg = <0x4b500000 0xa0>;
			interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 111 0>, <&edma_xbar 110 0>;
			clocks = <&l3_iclk_div>;
		aes2: aes@4b700000 {
			ti,hwmods = "aes2";
			reg = <0x4b700000 0xa0>;
			interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 114 0>, <&edma_xbar 113 0>;
		des: des@480a5000 {
			compatible = "ti,omap4-des";
			ti,hwmods = "des";
			reg = <0x480a5000 0xa0>;
			interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&sdma_xbar 117>, <&sdma_xbar 116>;
		sham: sham@53100000 {
			compatible = "ti,omap5-sham";
			ti,hwmods = "sham";
			reg = <0x4b101000 0x300>;
			interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
			dmas = <&edma_xbar 119 0>;
			dma-names = "rx";
		rng: rng@48090000 {
			compatible = "ti,omap4-rng";
			ti,hwmods = "rng";
			reg = <0x48090000 0x2000>;
			interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>;
	thermal_zones: thermal-zones {
		#include "omap4-cpu-thermal.dtsi"
		#include "omap5-gpu-thermal.dtsi"
		#include "omap5-core-thermal.dtsi"
		#include "dra7-dspeve-thermal.dtsi"
		#include "dra7-iva-thermal.dtsi"
&cpu_thermal {
	polling-delay = <500>; /* milliseconds */
/include/ "dra7xx-clocks.dtsi"
 * Device Tree Source for DRA7xx clock data
 * Copyright (C) 2013 Texas Instruments, Inc.
&cm_core_aon_clocks {
	atl_clkin0_ck: atl_clkin0_ck {
		#clock-cells = <0>;
		compatible = "ti,dra7-atl-clock";
	atl_clkin1_ck: atl_clkin1_ck {
		#clock-cells = <0>;
	atl_clkin2_ck: atl_clkin2_ck {
		#clock-cells = <0>;
	atl_clkin3_ck: atl_clkin3_ck {
		#clock-cells = <0>;
	hdmi_clkin_ck: hdmi_clkin_ck {
		#clock-cells = <0>;
		compatible = "fixed-clock";
		clock-frequency = <0>;
	mlb_clkin_ck: mlb_clkin_ck {
		#clock-cells = <0>;
	mlbp_clkin_ck: mlbp_clkin_ck {
		#clock-cells = <0>;
	pciesref_acs_clk_ck: pciesref_acs_clk_ck {
		#clock-cells = <0>;
		clock-frequency = <100000000>;
	ref_clkin0_ck: ref_clkin0_ck {
		#clock-cells = <0>;
	ref_clkin1_ck: ref_clkin1_ck {
		#clock-cells = <0>;
	ref_clkin2_ck: ref_clkin2_ck {
		#clock-cells = <0>;
	ref_clkin3_ck: ref_clkin3_ck {
		#clock-cells = <0>;
	rmii_clk_ck: rmii_clk_ck {
		#clock-cells = <0>;
	sdvenc_clkin_ck: sdvenc_clkin_ck {
		#clock-cells = <0>;
	secure_32k_clk_src_ck: secure_32k_clk_src_ck {
		#clock-cells = <0>;
		clock-frequency = <32768>;
	sys_clk32_crystal_ck: sys_clk32_crystal_ck {
		#clock-cells = <0>;
	sys_clk32_pseudo_ck: sys_clk32_pseudo_ck {
		#clock-cells = <0>;
		compatible = "fixed-factor-clock";
		clock-mult = <1>;
		clock-div = <610>;
	virt_12000000_ck: virt_12000000_ck {
		#clock-cells = <0>;
		clock-frequency = <12000000>;
	virt_13000000_ck: virt_13000000_ck {
		#clock-cells = <0>;
		clock-frequency = <13000000>;
	virt_16800000_ck: virt_16800000_ck {
		#clock-cells = <0>;
		clock-frequency = <16800000>;
	virt_19200000_ck: virt_19200000_ck {
		#clock-cells = <0>;
		clock-frequency = <19200000>;
	virt_20000000_ck: virt_20000000_ck {
		#clock-cells = <0>;
		clock-frequency = <20000000>;
	virt_26000000_ck: virt_26000000_ck {
		#clock-cells = <0>;
		clock-frequency = <26000000>;
	virt_27000000_ck: virt_27000000_ck {
		#clock-cells = <0>;
		clock-frequency = <27000000>;
	virt_38400000_ck: virt_38400000_ck {
		#clock-cells = <0>;
		clock-frequency = <38400000>;
	sys_clkin2: sys_clkin2 {
		#clock-cells = <0>;
		clock-frequency = <22579200>;
	usb_otg_clkin_ck: usb_otg_clkin_ck {
		#clock-cells = <0>;
	video1_clkin_ck: video1_clkin_ck {
		#clock-cells = <0>;
	video1_m2_clkin_ck: video1_m2_clkin_ck {
		#clock-cells = <0>;
	video2_clkin_ck: video2_clkin_ck {
		#clock-cells = <0>;
	video2_m2_clkin_ck: video2_m2_clkin_ck {
		#clock-cells = <0>;
	dpll_abe_ck: dpll_abe_ck {
		#clock-cells = <0>;
		compatible = "ti,omap4-dpll-m4xen-clock";
		clocks = <&abe_dpll_clk_mux>, <&abe_dpll_bypass_clk_mux>;
		reg = <0x01e0>, <0x01e4>, <0x01ec>, <0x01e8>;
	dpll_abe_x2_ck: dpll_abe_x2_ck {
		#clock-cells = <0>;
		compatible = "ti,omap4-dpll-x2-clock";
		clocks = <&dpll_abe_ck>;
	dpll_abe_m2x2_ck: dpll_abe_m2x2_ck {
		#clock-cells = <0>;
		compatible = "ti,divider-clock";
		clocks = <&dpll_abe_x2_ck>;
		ti,max-div = <31>;
		ti,autoidle-shift = <8>;
		reg = <0x01f0>;
		ti,index-starts-at-one;
		ti,invert-autoidle-bit;
	abe_clk: abe_clk {
		#clock-cells = <0>;
		clocks = <&dpll_abe_m2x2_ck>;
		ti,max-div = <4>;
		reg = <0x0108>;
		ti,index-power-of-two;
	dpll_abe_m2_ck: dpll_abe_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x01f0>;
	dpll_abe_m3x2_ck: dpll_abe_m3x2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x01f4>;
	dpll_core_byp_mux: dpll_core_byp_mux {
		#clock-cells = <0>;
		compatible = "ti,mux-clock";
		clocks = <&sys_clkin1>, <&dpll_abe_m3x2_ck>;
		ti,bit-shift = <23>;
		reg = <0x012c>;
	dpll_core_ck: dpll_core_ck {
		#clock-cells = <0>;
		compatible = "ti,omap4-dpll-core-clock";
		clocks = <&sys_clkin1>, <&dpll_core_byp_mux>;
		reg = <0x0120>, <0x0124>, <0x012c>, <0x0128>;
	dpll_core_x2_ck: dpll_core_x2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_core_ck>;
	dpll_core_h12x2_ck: dpll_core_h12x2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_core_x2_ck>;
		ti,max-div = <63>;
		reg = <0x013c>;
	mpu_dpll_hs_clk_div: mpu_dpll_hs_clk_div {
		#clock-cells = <0>;
		clocks = <&dpll_core_h12x2_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_mpu_ck: dpll_mpu_ck {
		#clock-cells = <0>;
		compatible = "ti,omap5-mpu-dpll-clock";
		clocks = <&sys_clkin1>, <&mpu_dpll_hs_clk_div>;
		reg = <0x0160>, <0x0164>, <0x016c>, <0x0168>;
	dpll_mpu_m2_ck: dpll_mpu_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x0170>;
	mpu_dclk_div: mpu_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_mpu_m2_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	dsp_dpll_hs_clk_div: dsp_dpll_hs_clk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_dsp_byp_mux: dpll_dsp_byp_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dsp_dpll_hs_clk_div>;
		reg = <0x0240>;
	dpll_dsp_ck: dpll_dsp_ck {
		#clock-cells = <0>;
		compatible = "ti,omap4-dpll-clock";
		clocks = <&sys_clkin1>, <&dpll_dsp_byp_mux>;
		reg = <0x0234>, <0x0238>, <0x0240>, <0x023c>;
		assigned-clocks = <&dpll_dsp_ck>;
		assigned-clock-rates = <600000000>;
	dpll_dsp_m2_ck: dpll_dsp_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x0244>;
		assigned-clocks = <&dpll_dsp_m2_ck>;
	iva_dpll_hs_clk_div: iva_dpll_hs_clk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_iva_byp_mux: dpll_iva_byp_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&iva_dpll_hs_clk_div>;
		reg = <0x01ac>;
	dpll_iva_ck: dpll_iva_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dpll_iva_byp_mux>;
		reg = <0x01a0>, <0x01a4>, <0x01ac>, <0x01a8>;
		assigned-clocks = <&dpll_iva_ck>;
		assigned-clock-rates = <1165000000>;
	dpll_iva_m2_ck: dpll_iva_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x01b0>;
		assigned-clocks = <&dpll_iva_m2_ck>;
		assigned-clock-rates = <388333334>;
	iva_dclk: iva_dclk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_gpu_byp_mux: dpll_gpu_byp_mux {
		#clock-cells = <0>;
		reg = <0x02e4>;
	dpll_gpu_ck: dpll_gpu_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dpll_gpu_byp_mux>;
		reg = <0x02d8>, <0x02dc>, <0x02e4>, <0x02e0>;
		assigned-clocks = <&dpll_gpu_ck>;
		assigned-clock-rates = <1277000000>;
	dpll_gpu_m2_ck: dpll_gpu_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x02e8>;
		assigned-clocks = <&dpll_gpu_m2_ck>;
		assigned-clock-rates = <425666667>;
	dpll_core_m2_ck: dpll_core_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x0130>;
	core_dpll_out_dclk_div: core_dpll_out_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_core_m2_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_ddr_byp_mux: dpll_ddr_byp_mux {
		#clock-cells = <0>;
		reg = <0x021c>;
	dpll_ddr_ck: dpll_ddr_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dpll_ddr_byp_mux>;
		reg = <0x0210>, <0x0214>, <0x021c>, <0x0218>;
	dpll_ddr_m2_ck: dpll_ddr_m2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_ddr_ck>;
		ti,max-div = <31>;
		reg = <0x0220>;
	dpll_gmac_byp_mux: dpll_gmac_byp_mux {
		#clock-cells = <0>;
		reg = <0x02b4>;
	dpll_gmac_ck: dpll_gmac_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dpll_gmac_byp_mux>;
		reg = <0x02a8>, <0x02ac>, <0x02b4>, <0x02b0>;
	dpll_gmac_m2_ck: dpll_gmac_m2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_gmac_ck>;
		ti,max-div = <31>;
		reg = <0x02b8>;
	video2_dclk_div: video2_dclk_div {
		#clock-cells = <0>;
		clocks = <&video2_m2_clkin_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	video1_dclk_div: video1_dclk_div {
		#clock-cells = <0>;
		clocks = <&video1_m2_clkin_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	hdmi_dclk_div: hdmi_dclk_div {
		#clock-cells = <0>;
		clocks = <&hdmi_clkin_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	per_dpll_hs_clk_div: per_dpll_hs_clk_div {
		#clock-cells = <0>;
		clocks = <&dpll_abe_m3x2_ck>;
		clock-mult = <1>;
		clock-div = <2>;
	usb_dpll_hs_clk_div: usb_dpll_hs_clk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <3>;
	eve_dpll_hs_clk_div: eve_dpll_hs_clk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_eve_byp_mux: dpll_eve_byp_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&eve_dpll_hs_clk_div>;
		reg = <0x0290>;
	dpll_eve_ck: dpll_eve_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dpll_eve_byp_mux>;
		reg = <0x0284>, <0x0288>, <0x0290>, <0x028c>;
	dpll_eve_m2_ck: dpll_eve_m2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_eve_ck>;
		ti,max-div = <31>;
		reg = <0x0294>;
	eve_dclk_div: eve_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_eve_m2_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_core_h13x2_ck: dpll_core_h13x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x0140>;
	dpll_core_h14x2_ck: dpll_core_h14x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x0144>;
	dpll_core_h22x2_ck: dpll_core_h22x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x0154>;
	dpll_core_h23x2_ck: dpll_core_h23x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x0158>;
	dpll_core_h24x2_ck: dpll_core_h24x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x015c>;
	dpll_ddr_x2_ck: dpll_ddr_x2_ck {
		#clock-cells = <0>;
	dpll_ddr_h11x2_ck: dpll_ddr_h11x2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_ddr_x2_ck>;
		ti,max-div = <63>;
		reg = <0x0228>;
	dpll_dsp_x2_ck: dpll_dsp_x2_ck {
		#clock-cells = <0>;
	dpll_dsp_m3x2_ck: dpll_dsp_m3x2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_dsp_x2_ck>;
		ti,max-div = <31>;
		reg = <0x0248>;
		assigned-clocks = <&dpll_dsp_m3x2_ck>;
		assigned-clock-rates = <400000000>;
	dpll_gmac_x2_ck: dpll_gmac_x2_ck {
		#clock-cells = <0>;
	dpll_gmac_h11x2_ck: dpll_gmac_h11x2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_gmac_x2_ck>;
		ti,max-div = <63>;
		reg = <0x02c0>;
	dpll_gmac_h12x2_ck: dpll_gmac_h12x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x02c4>;
	dpll_gmac_h13x2_ck: dpll_gmac_h13x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x02c8>;
	dpll_gmac_m3x2_ck: dpll_gmac_m3x2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x02bc>;
	gmii_m_clk_div: gmii_m_clk_div {
		#clock-cells = <0>;
		clocks = <&dpll_gmac_h11x2_ck>;
		clock-mult = <1>;
		clock-div = <2>;
	hdmi_clk2_div: hdmi_clk2_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	hdmi_div_clk: hdmi_div_clk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	l3_iclk_div: l3_iclk_div {
		#clock-cells = <0>;
		ti,max-div = <2>;
		ti,bit-shift = <4>;
		reg = <0x0100>;
	l4_root_clk_div: l4_root_clk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <2>;
	video1_clk2_div: video1_clk2_div {
		#clock-cells = <0>;
		clocks = <&video1_clkin_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	video1_div_clk: video1_div_clk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	video2_clk2_div: video2_clk2_div {
		#clock-cells = <0>;
		clocks = <&video2_clkin_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	video2_div_clk: video2_div_clk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	ipu1_gfclk_mux: ipu1_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&dpll_abe_m2x2_ck>, <&dpll_core_h22x2_ck>;
		ti,bit-shift = <24>;
		reg = <0x0520>;
		assigned-clocks = <&ipu1_gfclk_mux>;
		assigned-clock-parents = <&dpll_core_h22x2_ck>;
	mcasp1_ahclkr_mux: mcasp1_ahclkr_mux {
		#clock-cells = <0>;
		clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>;
		ti,bit-shift = <28>;
		reg = <0x0550>;
	mcasp1_ahclkx_mux: mcasp1_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x0550>;
	mcasp1_aux_gfclk_mux: mcasp1_aux_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>;
		ti,bit-shift = <22>;
		reg = <0x0550>;
	timer5_gfclk_mux: timer5_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>, <&clkoutmux0_clk_mux>;
		reg = <0x0558>;
	timer6_gfclk_mux: timer6_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x0560>;
	timer7_gfclk_mux: timer7_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x0568>;
	timer8_gfclk_mux: timer8_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x0570>;
	uart6_gfclk_mux: uart6_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>;
		reg = <0x0580>;
	dummy_ck: dummy_ck {
		#clock-cells = <0>;
&prm_clocks {
	sys_clkin1: sys_clkin1 {
		#clock-cells = <0>;
		clocks = <&virt_12000000_ck>, <&virt_20000000_ck>, <&virt_16800000_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_27000000_ck>, <&virt_38400000_ck>;
		reg = <0x0110>;
	abe_dpll_sys_clk_mux: abe_dpll_sys_clk_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&sys_clkin2>;
		reg = <0x0118>;
	abe_dpll_bypass_clk_mux: abe_dpll_bypass_clk_mux {
		#clock-cells = <0>;
		clocks = <&abe_dpll_sys_clk_mux>, <&sys_32k_ck>;
		reg = <0x0114>;
	abe_dpll_clk_mux: abe_dpll_clk_mux {
		#clock-cells = <0>;
		reg = <0x010c>;
	abe_24m_fclk: abe_24m_fclk {
		#clock-cells = <0>;
		reg = <0x011c>;
		ti,dividers = <8>, <16>;
	aess_fclk: aess_fclk {
		#clock-cells = <0>;
		clocks = <&abe_clk>;
		reg = <0x0178>;
		ti,max-div = <2>;
	abe_giclk_div: abe_giclk_div {
		#clock-cells = <0>;
		clocks = <&aess_fclk>;
		reg = <0x0174>;
		ti,max-div = <2>;
	abe_lp_clk_div: abe_lp_clk_div {
		#clock-cells = <0>;
		reg = <0x01d8>;
		ti,dividers = <16>, <32>;
	abe_sys_clk_div: abe_sys_clk_div {
		#clock-cells = <0>;
		reg = <0x0120>;
		ti,max-div = <2>;
	adc_gfclk_mux: adc_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&sys_clkin2>, <&sys_32k_ck>;
		reg = <0x01dc>;
	sys_clk1_dclk_div: sys_clk1_dclk_div {
		#clock-cells = <0>;
		ti,max-div = <64>;
		reg = <0x01c8>;
	sys_clk2_dclk_div: sys_clk2_dclk_div {
		#clock-cells = <0>;
		clocks = <&sys_clkin2>;
		ti,max-div = <64>;
		reg = <0x01cc>;
	per_abe_x1_dclk_div: per_abe_x1_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_abe_m2_ck>;
		ti,max-div = <64>;
		reg = <0x01bc>;
	dsp_gclk_div: dsp_gclk_div {
		#clock-cells = <0>;
		ti,max-div = <64>;
		reg = <0x018c>;
	gpu_dclk: gpu_dclk {
		#clock-cells = <0>;
		ti,max-div = <64>;
		reg = <0x01a0>;
	emif_phy_dclk_div: emif_phy_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_ddr_m2_ck>;
		ti,max-div = <64>;
		reg = <0x0190>;
	gmac_250m_dclk_div: gmac_250m_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_gmac_m2_ck>;
		ti,max-div = <64>;
		reg = <0x019c>;
	l3init_480m_dclk_div: l3init_480m_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_usb_m2_ck>;
		ti,max-div = <64>;
		reg = <0x01ac>;
	usb_otg_dclk_div: usb_otg_dclk_div {
		#clock-cells = <0>;
		clocks = <&usb_otg_clkin_ck>;
		ti,max-div = <64>;
		reg = <0x0184>;
	sata_dclk_div: sata_dclk_div {
		#clock-cells = <0>;
		ti,max-div = <64>;
		reg = <0x01c0>;
	pcie2_dclk_div: pcie2_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_pcie_ref_m2_ck>;
		ti,max-div = <64>;
		reg = <0x01b8>;
	pcie_dclk_div: pcie_dclk_div {
		#clock-cells = <0>;
		clocks = <&apll_pcie_m2_ck>;
		ti,max-div = <64>;
		reg = <0x01b4>;
	emu_dclk_div: emu_dclk_div {
		#clock-cells = <0>;
		ti,max-div = <64>;
		reg = <0x0194>;
	secure_32k_dclk_div: secure_32k_dclk_div {
		#clock-cells = <0>;
		clocks = <&secure_32k_clk_src_ck>;
		ti,max-div = <64>;
		reg = <0x01c4>;
	clkoutmux0_clk_mux: clkoutmux0_clk_mux {
		#clock-cells = <0>;
		clocks = <&sys_clk1_dclk_div>, <&sys_clk2_dclk_div>, <&per_abe_x1_dclk_div>, <&mpu_dclk_div>, <&dsp_gclk_div>, <&iva_dclk>, <&gpu_dclk>, <&core_dpll_out_dclk_div>, <&emif_phy_dclk_div>, <&gmac_250m_dclk_div>, <&video2_dclk_div>, <&video1_dclk_div>, <&hdmi_dclk_div>, <&func_96m_aon_dclk_div>, <&l3init_480m_dclk_div>, <&usb_otg_dclk_div>, <&sata_dclk_div>, <&pcie2_dclk_div>, <&pcie_dclk_div>, <&emu_dclk_div>, <&secure_32k_dclk_div>, <&eve_dclk_div>;
		reg = <0x0158>;
	clkoutmux1_clk_mux: clkoutmux1_clk_mux {
		#clock-cells = <0>;
		reg = <0x015c>;
	clkoutmux2_clk_mux: clkoutmux2_clk_mux {
		#clock-cells = <0>;
		reg = <0x0160>;
	custefuse_sys_gfclk_div: custefuse_sys_gfclk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <2>;
	eve_clk: eve_clk {
		#clock-cells = <0>;
		clocks = <&dpll_eve_m2_ck>, <&dpll_dsp_m3x2_ck>;
		reg = <0x0180>;
	hdmi_dpll_clk_mux: hdmi_dpll_clk_mux {
		#clock-cells = <0>;
		reg = <0x0164>;
	mlb_clk: mlb_clk {
		#clock-cells = <0>;
		clocks = <&mlb_clkin_ck>;
		ti,max-div = <64>;
		reg = <0x0134>;
	mlbp_clk: mlbp_clk {
		#clock-cells = <0>;
		clocks = <&mlbp_clkin_ck>;
		ti,max-div = <64>;
		reg = <0x0130>;
	per_abe_x1_gfclk2_div: per_abe_x1_gfclk2_div {
		#clock-cells = <0>;
		ti,max-div = <64>;
		reg = <0x0138>;
	timer_sys_clk_div: timer_sys_clk_div {
		#clock-cells = <0>;
		reg = <0x0144>;
		ti,max-div = <2>;
	video1_dpll_clk_mux: video1_dpll_clk_mux {
		#clock-cells = <0>;
		reg = <0x0168>;
	video2_dpll_clk_mux: video2_dpll_clk_mux {
		#clock-cells = <0>;
		reg = <0x016c>;
	wkupaon_iclk_mux: wkupaon_iclk_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&abe_lp_clk_div>;
		reg = <0x0108>;
	gpio1_dbclk: gpio1_dbclk {
		#clock-cells = <0>;
		compatible = "ti,gate-clock";
		ti,bit-shift = <8>;
		reg = <0x1838>;
	dcan1_sys_clk_mux: dcan1_sys_clk_mux {
		#clock-cells = <0>;
		reg = <0x1888>;
	timer1_gfclk_mux: timer1_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>;
		reg = <0x1840>;
	uart10_gfclk_mux: uart10_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1880>;
&cm_core_clocks {
	dpll_pcie_ref_ck: dpll_pcie_ref_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&sys_clkin1>;
		reg = <0x0200>, <0x0204>, <0x020c>, <0x0208>;
	dpll_pcie_ref_m2ldo_ck: dpll_pcie_ref_m2ldo_ck {
		#clock-cells = <0>;
		clocks = <&dpll_pcie_ref_ck>;
		ti,max-div = <31>;
		reg = <0x0210>;
	apll_pcie_in_clk_mux: apll_pcie_in_clk_mux@4ae06118 {
		clocks = <&dpll_pcie_ref_m2ldo_ck>, <&pciesref_acs_clk_ck>;
		#clock-cells = <0>;
		reg = <0x021c 0x4>;
		ti,bit-shift = <7>;
	apll_pcie_ck: apll_pcie_ck {
		#clock-cells = <0>;
		compatible = "ti,dra7-apll-clock";
		clocks = <&apll_pcie_in_clk_mux>, <&dpll_pcie_ref_ck>;
		reg = <0x021c>, <0x0220>;
	optfclk_pciephy1_32khz: optfclk_pciephy1_32khz@4a0093b0 {
		#clock-cells = <0>;
		reg = <0x13b0>;
		ti,bit-shift = <8>;
	optfclk_pciephy2_32khz: optfclk_pciephy2_32khz@4a0093b8 {
		#clock-cells = <0>;
		reg = <0x13b8>;
		ti,bit-shift = <8>;
	optfclk_pciephy_div: optfclk_pciephy_div@4a00821c {
		clocks = <&apll_pcie_ck>;
		#clock-cells = <0>;
		reg = <0x021c>;
		ti,dividers = <2>, <1>;
		ti,bit-shift = <8>;
		ti,max-div = <2>;
	optfclk_pciephy1_clk: optfclk_pciephy1_clk@4a0093b0 {
		#clock-cells = <0>;
		reg = <0x13b0>;
		ti,bit-shift = <9>;
	optfclk_pciephy2_clk: optfclk_pciephy2_clk@4a0093b8 {
		#clock-cells = <0>;
		reg = <0x13b8>;
		ti,bit-shift = <9>;
	optfclk_pciephy1_div_clk: optfclk_pciephy1_div_clk@4a0093b0 {
		clocks = <&optfclk_pciephy_div>;
		#clock-cells = <0>;
		reg = <0x13b0>;
		ti,bit-shift = <10>;
	optfclk_pciephy2_div_clk: optfclk_pciephy2_div_clk@4a0093b8 {
		#clock-cells = <0>;
		reg = <0x13b8>;
	apll_pcie_clkvcoldo: apll_pcie_clkvcoldo {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	apll_pcie_clkvcoldo_div: apll_pcie_clkvcoldo_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	apll_pcie_m2_ck: apll_pcie_m2_ck {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_per_byp_mux: dpll_per_byp_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&per_dpll_hs_clk_div>;
		reg = <0x014c>;
	dpll_per_ck: dpll_per_ck {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&dpll_per_byp_mux>;
		reg = <0x0140>, <0x0144>, <0x014c>, <0x0148>;
	dpll_per_m2_ck: dpll_per_m2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_per_ck>;
		ti,max-div = <31>;
		reg = <0x0150>;
	func_96m_aon_dclk_div: func_96m_aon_dclk_div {
		#clock-cells = <0>;
		clocks = <&dpll_per_m2_ck>;
		clock-mult = <1>;
		clock-div = <1>;
	dpll_usb_byp_mux: dpll_usb_byp_mux {
		#clock-cells = <0>;
		clocks = <&sys_clkin1>, <&usb_dpll_hs_clk_div>;
		reg = <0x018c>;
	dpll_usb_ck: dpll_usb_ck {
		#clock-cells = <0>;
		compatible = "ti,omap4-dpll-j-type-clock";
		clocks = <&sys_clkin1>, <&dpll_usb_byp_mux>;
		reg = <0x0180>, <0x0184>, <0x018c>, <0x0188>;
	dpll_usb_m2_ck: dpll_usb_m2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_usb_ck>;
		ti,max-div = <127>;
		reg = <0x0190>;
	dpll_pcie_ref_m2_ck: dpll_pcie_ref_m2_ck {
		#clock-cells = <0>;
		ti,max-div = <127>;
		reg = <0x0210>;
	dpll_per_x2_ck: dpll_per_x2_ck {
		#clock-cells = <0>;
	dpll_per_h11x2_ck: dpll_per_h11x2_ck {
		#clock-cells = <0>;
		clocks = <&dpll_per_x2_ck>;
		ti,max-div = <63>;
		reg = <0x0158>;
	dpll_per_h12x2_ck: dpll_per_h12x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x015c>;
	dpll_per_h13x2_ck: dpll_per_h13x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x0160>;
	dpll_per_h14x2_ck: dpll_per_h14x2_ck {
		#clock-cells = <0>;
		ti,max-div = <63>;
		reg = <0x0164>;
	dpll_per_m2x2_ck: dpll_per_m2x2_ck {
		#clock-cells = <0>;
		ti,max-div = <31>;
		reg = <0x0150>;
	dpll_usb_clkdcoldo: dpll_usb_clkdcoldo {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <1>;
	func_128m_clk: func_128m_clk {
		#clock-cells = <0>;
		clocks = <&dpll_per_h11x2_ck>;
		clock-mult = <1>;
		clock-div = <2>;
	func_12m_fclk: func_12m_fclk {
		#clock-cells = <0>;
		clocks = <&dpll_per_m2x2_ck>;
		clock-mult = <1>;
		clock-div = <16>;
	func_24m_clk: func_24m_clk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <4>;
	func_48m_fclk: func_48m_fclk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <4>;
	func_96m_fclk: func_96m_fclk {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <2>;
	l3init_60m_fclk: l3init_60m_fclk {
		#clock-cells = <0>;
		reg = <0x0104>;
		ti,dividers = <1>, <8>;
	clkout2_clk: clkout2_clk {
		#clock-cells = <0>;
		clocks = <&clkoutmux2_clk_mux>;
		ti,bit-shift = <8>;
		reg = <0x06b0>;
	l3init_960m_gfclk: l3init_960m_gfclk {
		#clock-cells = <0>;
		clocks = <&dpll_usb_clkdcoldo>;
		ti,bit-shift = <8>;
		reg = <0x06c0>;
	dss_32khz_clk: dss_32khz_clk {
		#clock-cells = <0>;
		ti,bit-shift = <11>;
		reg = <0x1120>;
	dss_48mhz_clk: dss_48mhz_clk {
		#clock-cells = <0>;
		clocks = <&func_48m_fclk>;
		ti,bit-shift = <9>;
		reg = <0x1120>;
	dss_dss_clk: dss_dss_clk {
		#clock-cells = <0>;
		clocks = <&dpll_per_h12x2_ck>;
		ti,bit-shift = <8>;
		reg = <0x1120>;
		ti,set-rate-parent;
	dss_hdmi_clk: dss_hdmi_clk {
		#clock-cells = <0>;
		clocks = <&hdmi_dpll_clk_mux>;
		reg = <0x1120>;
	dss_video1_clk: dss_video1_clk {
		#clock-cells = <0>;
		clocks = <&video1_dpll_clk_mux>;
		ti,bit-shift = <12>;
		reg = <0x1120>;
	dss_video2_clk: dss_video2_clk {
		#clock-cells = <0>;
		clocks = <&video2_dpll_clk_mux>;
		ti,bit-shift = <13>;
		reg = <0x1120>;
	gpio2_dbclk: gpio2_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1760>;
	gpio3_dbclk: gpio3_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1768>;
	gpio4_dbclk: gpio4_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1770>;
	gpio5_dbclk: gpio5_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1778>;
	gpio6_dbclk: gpio6_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1780>;
	gpio7_dbclk: gpio7_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1810>;
	gpio8_dbclk: gpio8_dbclk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1818>;
	mmc1_clk32k: mmc1_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1328>;
	mmc2_clk32k: mmc2_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1330>;
	mmc3_clk32k: mmc3_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1820>;
	mmc4_clk32k: mmc4_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1828>;
	sata_ref_clk: sata_ref_clk {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1388>;
	usb_otg_ss1_refclk960m: usb_otg_ss1_refclk960m {
		#clock-cells = <0>;
		clocks = <&l3init_960m_gfclk>;
		ti,bit-shift = <8>;
		reg = <0x13f0>;
	usb_otg_ss2_refclk960m: usb_otg_ss2_refclk960m {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x1340>;
	usb_phy1_always_on_clk32k: usb_phy1_always_on_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x0640>;
	usb_phy2_always_on_clk32k: usb_phy2_always_on_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x0688>;
	usb_phy3_always_on_clk32k: usb_phy3_always_on_clk32k {
		#clock-cells = <0>;
		ti,bit-shift = <8>;
		reg = <0x0698>;
	atl_dpll_clk_mux: atl_dpll_clk_mux {
		#clock-cells = <0>;
		clocks = <&sys_32k_ck>, <&video1_clkin_ck>, <&video2_clkin_ck>, <&hdmi_clkin_ck>;
		reg = <0x0c00>;
	atl_gfclk_mux: atl_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&l3_iclk_div>, <&dpll_abe_m2_ck>, <&atl_dpll_clk_mux>;
		ti,bit-shift = <26>;
		reg = <0x0c00>;
	rmii_50mhz_clk_mux: rmii_50mhz_clk_mux@13d0 {
		#clock-cells = <0>;
		clocks = <&dpll_gmac_h11x2_ck>, <&rmii_clk_ck>;
		reg = <0x13d0>;
	gmac_gmii_ref_clk_div: gmac_gmii_ref_clk_div {
		#clock-cells = <0>;
		clock-mult = <1>;
		clock-div = <2>;
	gmac_rft_clk_mux: gmac_rft_clk_mux {
		#clock-cells = <0>;
		clocks = <&video1_clkin_ck>, <&video2_clkin_ck>, <&dpll_abe_m2_ck>, <&hdmi_clkin_ck>, <&l3_iclk_div>;
		ti,bit-shift = <25>;
		reg = <0x13d0>;
	gpu_core_gclk_mux: gpu_core_gclk_mux {
		#clock-cells = <0>;
		clocks = <&dpll_core_h14x2_ck>, <&dpll_per_h14x2_ck>, <&dpll_gpu_m2_ck>;
		reg = <0x1220>;
		assigned-clocks = <&gpu_core_gclk_mux>;
		assigned-clock-parents = <&dpll_gpu_m2_ck>;
	gpu_hyd_gclk_mux: gpu_hyd_gclk_mux {
		#clock-cells = <0>;
		reg = <0x1220>;
		assigned-clocks = <&gpu_hyd_gclk_mux>;
	l3instr_ts_gclk_div: l3instr_ts_gclk_div {
		#clock-cells = <0>;
		clocks = <&wkupaon_iclk_mux>;
		reg = <0x0e50>;
		ti,dividers = <8>, <16>, <32>;
	mcasp2_ahclkr_mux: mcasp2_ahclkr_mux {
		#clock-cells = <0>;
		reg = <0x1860>;
	mcasp2_ahclkx_mux: mcasp2_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1860>;
	mcasp2_aux_gfclk_mux: mcasp2_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1860>;
	mcasp3_ahclkx_mux: mcasp3_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1868>;
	mcasp3_aux_gfclk_mux: mcasp3_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1868>;
	mcasp4_ahclkx_mux: mcasp4_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1898>;
	mcasp4_aux_gfclk_mux: mcasp4_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1898>;
	mcasp5_ahclkx_mux: mcasp5_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1878>;
	mcasp5_aux_gfclk_mux: mcasp5_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1878>;
	mcasp6_ahclkx_mux: mcasp6_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1904>;
	mcasp6_aux_gfclk_mux: mcasp6_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1904>;
	mcasp7_ahclkx_mux: mcasp7_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1908>;
	mcasp7_aux_gfclk_mux: mcasp7_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1908>;
	mcasp8_ahclkx_mux: mcasp8_ahclkx_mux {
		#clock-cells = <0>;
		reg = <0x1890>;
	mcasp8_aux_gfclk_mux: mcasp8_aux_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1890>;
	mmc1_fclk_mux: mmc1_fclk_mux {
		#clock-cells = <0>;
		clocks = <&func_128m_clk>, <&dpll_per_m2x2_ck>;
		reg = <0x1328>;
	mmc1_fclk_div: mmc1_fclk_div {
		#clock-cells = <0>;
		clocks = <&mmc1_fclk_mux>;
		ti,max-div = <4>;
		reg = <0x1328>;
	mmc2_fclk_mux: mmc2_fclk_mux {
		#clock-cells = <0>;
		reg = <0x1330>;
	mmc2_fclk_div: mmc2_fclk_div {
		#clock-cells = <0>;
		clocks = <&mmc2_fclk_mux>;
		ti,max-div = <4>;
		reg = <0x1330>;
	mmc3_gfclk_mux: mmc3_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1820>;
	mmc3_gfclk_div: mmc3_gfclk_div {
		#clock-cells = <0>;
		clocks = <&mmc3_gfclk_mux>;
		ti,max-div = <4>;
		reg = <0x1820>;
	mmc4_gfclk_mux: mmc4_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1828>;
	mmc4_gfclk_div: mmc4_gfclk_div {
		#clock-cells = <0>;
		clocks = <&mmc4_gfclk_mux>;
		ti,max-div = <4>;
		reg = <0x1828>;
	qspi_gfclk_mux: qspi_gfclk_mux {
		#clock-cells = <0>;
		clocks = <&func_128m_clk>, <&dpll_per_h13x2_ck>;
		reg = <0x1838>;
	qspi_gfclk_div: qspi_gfclk_div {
		#clock-cells = <0>;
		clocks = <&qspi_gfclk_mux>;
		ti,max-div = <4>;
		reg = <0x1838>;
	timer10_gfclk_mux: timer10_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1728>;
	timer11_gfclk_mux: timer11_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1730>;
	timer13_gfclk_mux: timer13_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x17c8>;
	timer14_gfclk_mux: timer14_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x17d0>;
	timer15_gfclk_mux: timer15_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x17d8>;
	timer16_gfclk_mux: timer16_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1830>;
	timer2_gfclk_mux: timer2_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1738>;
	timer3_gfclk_mux: timer3_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1740>;
	timer4_gfclk_mux: timer4_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1748>;
	timer9_gfclk_mux: timer9_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1750>;
	uart1_gfclk_mux: uart1_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1840>;
	uart2_gfclk_mux: uart2_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1848>;
	uart3_gfclk_mux: uart3_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1850>;
	uart4_gfclk_mux: uart4_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1858>;
	uart5_gfclk_mux: uart5_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x1870>;
	uart7_gfclk_mux: uart7_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x18d0>;
	uart8_gfclk_mux: uart8_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x18e0>;
	uart9_gfclk_mux: uart9_gfclk_mux {
		#clock-cells = <0>;
		reg = <0x18e8>;
	vip1_gclk_mux: vip1_gclk_mux {
		#clock-cells = <0>;
		clocks = <&l3_iclk_div>, <&dpll_core_h23x2_ck>;
		reg = <0x1020>;
	vip2_gclk_mux: vip2_gclk_mux {
		#clock-cells = <0>;
		reg = <0x1028>;
	vip3_gclk_mux: vip3_gclk_mux {
		#clock-cells = <0>;
		reg = <0x1030>;
&cm_core_clockdomains {
	coreaon_clkdm: coreaon_clkdm {
		compatible = "ti,clockdomain";
&scm_conf_clocks {
	dss_deshdcp_clk: dss_deshdcp_clk {
		#clock-cells = <0>;
		ti,bit-shift = <0>;
		reg = <0x558>;
	sys_32k_ck: sys_32k_ck {
		#clock-cells = <0>;
		clocks = <&sys_clk32_crystal_ck>, <&sys_clk32_pseudo_ck>, <&sys_clk32_pseudo_ck>, <&sys_clk32_pseudo_ck>;
		ti,bit-shift = <8>;
		reg = <0x6c4>;
	ehrpwm0_tbclk: ehrpwm0_tbclk {
		#clock-cells = <0>;
		clocks = <&l4_root_clk_div>;
		ti,bit-shift = <20>;
		reg = <0x0558>;
	ehrpwm1_tbclk: ehrpwm1_tbclk {
		#clock-cells = <0>;
		ti,bit-shift = <21>;
		reg = <0x0558>;
	ehrpwm2_tbclk: ehrpwm2_tbclk {
		#clock-cells = <0>;
		reg = <0x0558>;
 * Copyright (C) 2016 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
#include <dt-bindings/clk/ti-dra7-atl.h>
#if 0
	jamr3_sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "DRA7xx-JAMR3";
		simple-audio-card,widgets =
			"Line", "Line Out",
			"Line", "Line In";
		simple-audio-card,routing =
			"Line Out",		"LLOUT",
			"Line Out",		"RLOUT",
			"LINE1L",		"Line In",
			"LINE1R",		"Line In";
		simple-audio-card,format = "dsp_b";
		simple-audio-card,bitclock-master = <&jamr3_sound_master>;
		simple-audio-card,frame-master = <&jamr3_sound_master>;
		simple-audio-card,bitclock-inversion;
		jamr3_sound_master: simple-audio-card,cpu {
			sound-dai = <&mcasp6>;
			system-clock-frequency = <11289600>;
		simple-audio-card,codec {
			sound-dai = <&tlv320aic3106a>;
			clocks = <&atl_clkin1_ck>;
#endif
	gatemp {
		compatible = "hwspinlock-user";
		hwlocks = <&hwspinlock 0>,
			  <&hwspinlock 1>,
			  <&hwspinlock 2>,
			  <&hwspinlock 3>,
			  <&hwspinlock 4>,
			  <&hwspinlock 5>,
			  <&hwspinlock 6>,
			  <&hwspinlock 7>,
			  <&hwspinlock 8>,
			  <&hwspinlock 9>;
	sr0 {
		compatible = "generic-uio";
		reg = <0x0 0xbfb00000 0x0 0x100000>;
&reserved_mem {
	/* Required by cmem driver used by radio */
	cmem_radio: cmem@95400000 {
		reg = <0x0 0x95400000 0x0 0x400000>;
		no-map;
		status = "okay";
	dsp1_sr0: dsp1_sr0@bfb00000 {
		no-map;
		status = "okay";
&gpio6 {
	p20 {
		/* Radio reset GPIO */
		gpio-hog;
		gpios = <1 GPIO_ACTIVE_LOW>;
		output-low;
		line-name = "radio_rst";
&atl {
	atl1 {
		bws = <DRA7_ATL_WS_MCASP2_FSX>;
		aws = <DRA7_ATL_WS_MCASP6_FSX>;
&mcasp2 {
	assigned-clocks = <&mcasp2_ahclkx_mux>;
	assigned-clock-parents = <&atl_clkin2_ck>;
	op-mode = <0>;          /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	/* 8 serializers */
	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
		2 0 0 0 0 0 0 0
	shared-dai;
&mcasp6 {
	#sound-dai-cells = <0>;
	assigned-clocks = <&mcasp6_ahclkx_mux>;
	assigned-clock-parents = <&atl_clkin1_ck>;
	tdm-slots = <2>;
	/* 4 serializer */
		1 2 0 0
	tx-num-evt = <32>;
	rx-num-evt = <32>;
	shared-dai;
&i2c4 {
	status = "okay";
	clock-frequency = <400000>;
	pcf_jamr3_21: pcf8575@21 {
		compatible = "nxp,pcf8575";
		reg = <0x21>;
		gpio-controller;
		#gpio-cells = <2>;
&i2c_p3_exp {
#if 0
	tlv320aic3106a: tlv320aic3106@18 {
		compatible = "ti,tlv320aic3106";
		reg = <0x18>;
		adc-settle-ms = <40>;
		ai3x-micbias-vg = <1>;		/* 2.0V */
		name-prefix = "J3A";
		status = "okay";
		/* Regulators */
		AVDD-supply = <&evm_3v3_sw>;
		IOVDD-supply = <&evm_3v3_sw>;
		DRVDD-supply = <&evm_3v3_sw>;
		DVDD-supply = <&aic_dvdd>;
	tlv320aic3106b: tlv320aic3106@19 {
		reg = <0x19>;
		name-prefix = "J3B";
		status = "okay";
		/* Regulators */
	tlv320aic3106c: tlv320aic3106@1a {
		reg = <0x1a>;
		name-prefix = "J3C";
		status = "okay";
		/* Regulators */
#endif
#if 1
	tvp_5158: tvp5158@58 {
		compatible= "ti,tvp5158";
		reg = <0x58>;
		port {
			tvp_decoder: endpoint@0 {
				//channels = <0 2 4 6>;
				channels = <0>;
				//pixel-mux;
#else
		reg = <0x58>;
		port {
#endif
&video_in {
	endpoint {
		slave-mode;
		remote-endpoint = <&tvp_decoder>;
 * Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/
#include "dra72-evm-common.dtsi"
#include "dt-bindings/pinmux/mux_dra7xx.h"
	model = "TI DRA722 Louis 20170516 13:50";
	aliases {
		display0 = &hdmi0;
		display1 = &lcd2;
		sound1 = &hdmi;
	lcd2: display@2 {
		compatible = "omapdss,panel-dpi", "panel-dpi";
		status = "ok";
		label = "lcd";
		//enable-gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>;
		// 1920x1200@60
		// 1920x1200@30
		// 1920x1080@60
		// 1920x1080@30
		// 1280x720@30
		// 800x480@30
		// 1920x1200@60
		// (1920+226)*(1200+32)*60=158632320
		panel-timing {
				clock-frequency = <158000000>;
				hactive = <1920>;
				vactive = <1200>;
				hfront-porch = <210>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vfront-porch = <22>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
				pixelclk-active = <1>;
		// 1920x1200@30
		// (1920+226)*(1200+32)*30=79316160
		panel-timing {
				clock-frequency = <79000000>;
				hactive = <1920>;
				vactive = <1200>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
		// 1920x1080@60
		// (1920+226)*(1080+32)*60=142181120
		panel-timing {
				clock-frequency = <142000000>;
				hactive = <1920>;
				vactive = <1080>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
		// 1920x1080@30
		// (1920+226)*(1080+32)*30=71590560
		panel-timing {
				clock-frequency = <72000000>;
				hactive = <1920>;
				vactive = <1080>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
		// 1280x720@30
		// (1280+226)*(720+32)*30=33975360
		panel-timing {
				clock-frequency = <24000000>;
				hactive = <1280>;
				vactive = <720>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
		// 800x480@30
		// (800+226)*(480+32)*30=15759360
		panel-timing {
				clock-frequency = <16000000>;
				hactive = <800>;
				vactive = <480>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
		port {
			lcd2_in: endpoint {
				remote-endpoint = <&dpi2_out>;
	memory {
		device_type = "memory";
		reg = <0x0 0x80000000 0x0 0x40000000>; /* 1024 MB */
	reserved_mem: reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		ipu2_cma_pool: ipu2_cma@95800000 {
			compatible = "shared-dma-pool";
			reg = <0x0 0x95800000 0x0 0x3800000>;
			reusable;
			status = "okay";
		dsp1_cma_pool: dsp1_cma@99000000 {
			reg = <0x0 0x99000000 0x0 0x4000000>;
			reusable;
			status = "okay";
		ipu1_cma_pool: ipu1_cma@9d000000 {
			reg = <0x0 0x9d000000 0x0 0x2000000>;
			reusable;
			status = "okay";
&tps65917_regulators {
	ldo2_reg: ldo2 {
		/* LDO2_OUT --> TP1017 (UNUSED)  */
		regulator-name = "ldo2";
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <3300000>;
		regulator-allow-bypass;
&dra7_pmx_core {
        vin2a_pins: pinmux_vin2a_pins {
		pinctrl-single,pins = <
			0x23c	(PIN_INPUT | MUX_MODE4)	//	0x23C gpio5_15 V1 mdio_mclk.vin2a_clk0
			0x240	(PIN_INPUT | MUX_MODE4)	//	0x240	 gpio5_16 U4  mdio_d.vin2a_d0
			0x248	(PIN_INPUT | MUX_MODE4)	//	0x248 gpio5_18 V2 uart3_rxd.vin2a_d1
			0x24c	(PIN_INPUT | MUX_MODE4)	//	0x24C	gpio5_19 Y1 uart3_txd.vin2a_d2
			0x250	(PIN_INPUT | MUX_MODE4)	//	0x250	gpio5_20 W9 rgmii0_txc.vin2a_d3
			0x254	(PIN_INPUT | MUX_MODE4)	//	0x254 gpio5_21 V9 rgmii0_txctl.vin2a_d4
			0x268	(PIN_INPUT | MUX_MODE4)	//	0x268 U5 gpio5_26 rgmii_rxc.vin2a_d5
			0x26c	(PIN_INPUT | MUX_MODE4)	//	0x26C gpio5_27 V5 rgmii0_rxctl.vin2a_d6
			0x270	(PIN_INPUT | MUX_MODE4)	//	0x270 gpio5_28 V4 rgmii0_rxd3.vin2a_d7
	vout3_pins: pinmux_vout3_pins {
			GPMC_A0	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d16 GPIO7_3 R6	 */
			GPMC_A1   (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A1.vout3_d17	 */
			GPMC_A2	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A2.vout3_d18  */
			GPMC_A3   (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A3.vout3_d18 */
			GPMC_A4	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A4.vout3_d20  */
			GPMC_A5	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A5.vout3_d21	 */
			GPMC_A6	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A6.vout3_d22	 */
			GPMC_A7	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A7.vout3_d23 */
			GPMC_AD8	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD8.vout3_d8	 */
			GPMC_AD9  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD9.vout3_d9	 */
			GPMC_AD10 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD10.vout3_d10  */
			GPMC_AD11 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD11.vout3_d11	 */
			GPMC_AD12 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD12.vout3_d12  */
			GPMC_AD13 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD13.vout3_d13	 */
			GPMC_AD14	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD14.vout3_d14	 */
			GPMC_AD15	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD15.vout3_d15 */
			GPMC_AD0	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d0	 */
			GPMC_AD1  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d1	 */
			GPMC_AD2	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d2  */
			GPMC_AD3	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d3	 */
			GPMC_AD4	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d4  */
			GPMC_AD5	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d5	 */
			GPMC_AD6	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d6	 */
			GPMC_AD7	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d7	 */
			GPMC_A11	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A11.vout3_fld	 */
			GPMC_A10	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A10.vout3_de	 */
			GPMC_A8	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A8.vout3_hsync	 */
			GPMC_A9	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A9.vout3_vsync	 */
			GPMC_CS3	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_CS3.vout3_clk	 */
			VIN2A_D9	(PIN_OUTPUT | MUX_MODE14)	/* VIN2A_D9.gpio4_10  DISP_RESETQ	 */
	uart1_pins: uart1_pins {
			// i2c_3
			GPMC_ADVN_ALE (PIN_INPUT | MUX_MODE8)	/* gpmc_advn_ale.i2c3_sda -> 8 */
			GPMC_CLK      (PIN_INPUT | MUX_MODE8)	/* gpmc_clk.i2c3_scl -> 8 */
			// i2c_4
			MMC1_SDCD (PIN_INPUT | MUX_MODE4)  		/* mmc1_sdcd.i2c4_sda -> 4 */
			MMC1_SDWP (PIN_INPUT | MUX_MODE4)  		/* mmc1_sdwp.i2c4_scl -> 4 */
			// i2c_5
			MCASP1_AXR0 (PIN_INPUT | MUX_MODE10)	/* mcasp1_axr0.i2c5_sda -> 10 */
			MCASP1_AXR1 (PIN_INPUT | MUX_MODE10)	/* mcasp1_axr1.i2c5_scl -> 10 */
			// spi 1.0, 1.1, 1.3
			SPI1_SCLK	(PIN_INPUT | MUX_MODE0)	/*	0x3A4	*/
			SPI1_D1		(PIN_INPUT | MUX_MODE0)	/*	0x3A8	*/
			SPI1_D0		(PIN_INPUT | MUX_MODE0)	/*	0x3AC	*/
			SPI1_CS0	(PIN_INPUT | MUX_MODE0)	/*	0x3B0	*/
			SPI1_CS1	(PIN_INPUT | MUX_MODE0)	/*	0x3B4	*/
			SPI1_CS3	(PIN_INPUT | MUX_MODE0)	/*	0x3BC	*/
			// spi 2.0
			SPI2_SCLK	( PIN_INPUT | MUX_MODE0 )	/*	0x3C0	*/
			SPI2_D1		( PIN_INPUT | MUX_MODE0 )	/*	0x3C4	*/
			SPI2_D0		( PIN_INPUT | MUX_MODE0 )	/*	0x3C8	*/
			SPI2_CS0	( PIN_INPUT | MUX_MODE0 )	/*	0x3CC	*/
			// spi 3.0
			VOUT1_CLK		(PIN_INPUT | MUX_MODE8)	// DAB_SPI_CS		GPIO4_19
			VOUT1_DE		(PIN_INPUT | MUX_MODE8)	// DAB_SPI_MISO	GPIO4_20
			VOUT1_HSYNC	(PIN_INPUT | MUX_MODE8)	// DAB_SPI_MOSI	GPIO4_22
			VOUT1_VSYNC	(PIN_INPUT | MUX_MODE8)	// DAB_SPI_SCK		GPIO4_23
			// BT656 vin4b
			MDIO_MCLK	(PIN_INPUT | MUX_MODE5)		/*	0x23C	*/	// BT656_CLK1
			MDIO_D	(PIN_INPUT | MUX_MODE5)		/*	0x240	*/		// BT656_DO
			UART3_RXD	(PIN_INPUT | MUX_MODE5)	/*	0x248	*/		// BT656_D1
			UART3_TXD	(PIN_INPUT | MUX_MODE5)	/*	0x24C	*/		// BT656_D2
			RGMII0_TXC	(PIN_INPUT | MUX_MODE5)	/*	0x250	*/	// BT656_D3
			RGMII0_TXCTL	(PIN_INPUT | MUX_MODE5)	/*	0x254	*/	// BT656_D4
			RGMII0_RXC	(PIN_INPUT | MUX_MODE5)	/*	0x268	*/		// BT656_D5
			RGMII0_RXCTL	(PIN_INPUT | MUX_MODE5)	/*	0x26C	*/	// BT656_D6
			RGMII0_RXD3	(PIN_INPUT | MUX_MODE5)	/*	0x270	*/		// BT656_D7
			RGMII0_RXD2	(PIN_INPUT | MUX_MODE14)	/*	0x274	*/
			VIN2A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x158	*/
		//GPMC_AD0	(PIN_INPUT | MUX_MODE14)	/*	0x000	*/
		//GPMC_AD1	(PIN_INPUT | MUX_MODE14)	/*	0x004	*/
		//GPMC_AD2	(PIN_INPUT | MUX_MODE14)	/*	0x008	*/
		//GPMC_AD3	(PIN_INPUT | MUX_MODE14)	/*	0x00C	*/
		//GPMC_AD4	(PIN_INPUT | MUX_MODE14)	/*	0x010	*/
		//GPMC_AD5	(PIN_INPUT | MUX_MODE14)	/*	0x014	*/
		//GPMC_AD6	(PIN_INPUT | MUX_MODE14)	/*	0x018	*/
		//GPMC_AD7	(PIN_INPUT | MUX_MODE14)	/*	0x01C	*/
		//GPMC_AD8	(PIN_INPUT | MUX_MODE14)	/*	0x020	*/
		//GPMC_AD9	(PIN_INPUT | MUX_MODE14)	/*	0x024	*/
		//GPMC_AD10	(PIN_INPUT | MUX_MODE14)	/*	0x028	*/
		//GPMC_AD11	(PIN_INPUT | MUX_MODE14)	/*	0x02C	*/
		//GPMC_AD12	(PIN_INPUT | MUX_MODE14)	/*	0x030	*/
		//GPMC_AD13	(PIN_INPUT | MUX_MODE14)	/*	0x034	*/
		//GPMC_AD14	(PIN_INPUT | MUX_MODE14)	/*	0x038	*/
		//GPMC_AD15	(PIN_INPUT | MUX_MODE14)	/*	0x03C	*/
		//GPMC_A0	(PIN_INPUT | MUX_MODE14)	/*	0x040	*/
		//GPMC_A1	(PIN_INPUT | MUX_MODE14)	/*	0x044	*/
		//GPMC_A2	(PIN_INPUT | MUX_MODE14)	/*	0x048	*/
		//GPMC_A3	(PIN_INPUT | MUX_MODE14)	/*	0x04C	*/
		//GPMC_A4	(PIN_INPUT | MUX_MODE14)	/*	0x050	*/
		//GPMC_A5	(PIN_INPUT | MUX_MODE14)	/*	0x054	*/
		//GPMC_A6	(PIN_INPUT | MUX_MODE14)	/*	0x058	*/
		//GPMC_A7	(PIN_INPUT | MUX_MODE14)	/*	0x05C	*/
		//GPMC_A8	(PIN_INPUT | MUX_MODE14)	/*	0x060	*/
		//GPMC_A9	(PIN_INPUT | MUX_MODE14)	/*	0x064	*/
		//GPMC_A10	(PIN_INPUT | MUX_MODE14)	/*	0x068	*/
		//GPMC_A11	(PIN_INPUT | MUX_MODE14)	/*	0x06C	*/
		GPMC_A12	(PIN_INPUT | MUX_MODE14)	/*	0x070	*/
		GPMC_A13	(PIN_INPUT | MUX_MODE14)	/*	0x074	*/
		GPMC_A14	(PIN_INPUT | MUX_MODE14)	/*	0x078	*/
		GPMC_A15	(PIN_INPUT | MUX_MODE14)	/*	0x07C	*/
		GPMC_A16	(PIN_INPUT | MUX_MODE14)	/*	0x080	*/
		GPMC_A17	(PIN_INPUT | MUX_MODE14)	/*	0x084	*/
		GPMC_A18	(PIN_INPUT | MUX_MODE14)	/*	0x088	*/
		//GPMC_A19	(PIN_INPUT | MUX_MODE14)	/*	0x08C	*/
		//GPMC_A20	(PIN_INPUT | MUX_MODE14)	/*	0x090	*/
		//GPMC_A21	(PIN_INPUT | MUX_MODE14)	/*	0x094	*/
		//GPMC_A22	(PIN_INPUT | MUX_MODE14)	/*	0x098	*/
		//GPMC_A23	(PIN_INPUT | MUX_MODE14)	/*	0x09C	*/
		//GPMC_A24	(PIN_INPUT | MUX_MODE14)	/*	0x0A0	*/
		//GPMC_A25	(PIN_INPUT | MUX_MODE14)	/*	0x0A4	*/
		//GPMC_A26	(PIN_INPUT | MUX_MODE14)	/*	0x0A8	*/
		//GPMC_A27	(PIN_INPUT | MUX_MODE14)	/*	0x0AC	*/
		//GPMC_CS1	(PIN_INPUT | MUX_MODE14)	/*	0x0B0	*/
		GPMC_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x0B4	*/
		GPMC_CS2	(PIN_INPUT | MUX_MODE14)	/*	0x0B8	*/
		//GPMC_CS3	(PIN_INPUT | MUX_MODE14)	/*	0x0BC	*/
		//GPMC_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x0C0	*/
		//GPMC_ADVN_ALE	(PIN_INPUT | MUX_MODE14)	/*	0x0C4	*/
		GPMC_OEN_REN	(PIN_INPUT | MUX_MODE14)	/*	0x0C8	*/
		GPMC_WEN	(PIN_INPUT | MUX_MODE14)	/*	0x0CC	*/
		GPMC_BEN0	(PIN_INPUT | MUX_MODE14)	/*	0x0D0	*/
		GPMC_BEN1	(PIN_INPUT | MUX_MODE14)	/*	0x0D4	*/
		GPMC_WAIT0	(PIN_INPUT | MUX_MODE14)	/*	0x0D8	*/
		VIN1A_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x0DC	*/
		VIN1B_CLK1	(PIN_INPUT | MUX_MODE14)	/*	0x0E0	*/
		VIN1A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x0E4	*/
		VIN1A_FLD0	(PIN_INPUT | MUX_MODE14)	/*	0x0E8	*/
		VIN1A_HSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x0EC	*/
		VIN1A_VSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x0F0	*/
		VIN1A_D0	(PIN_INPUT | MUX_MODE14)	/*	0x0F4	*/
		VIN1A_D1	(PIN_INPUT | MUX_MODE14)	/*	0x0F8	*/
		VIN1A_D2	(PIN_INPUT | MUX_MODE14)	/*	0x0FC	*/
		VIN1A_D3	(PIN_INPUT | MUX_MODE14)	/*	0x100	*/
		VIN1A_D4	(PIN_INPUT | MUX_MODE14)	/*	0x104	*/
		VIN1A_D5	(PIN_INPUT | MUX_MODE14)	/*	0x108	*/
		VIN1A_D6	(PIN_INPUT | MUX_MODE14)	/*	0x10C	*/
		VIN1A_D7	(PIN_INPUT | MUX_MODE14)	/*	0x110	*/
		VIN1A_D8	(PIN_INPUT | MUX_MODE14)	/*	0x114	*/
		VIN1A_D9	(PIN_INPUT | MUX_MODE14)	/*	0x118	*/
		VIN1A_D10	(PIN_INPUT | MUX_MODE14)	/*	0x11C	*/
		VIN1A_D11	(PIN_INPUT | MUX_MODE14)	/*	0x120	*/
		VIN1A_D12	(PIN_INPUT | MUX_MODE14)	/*	0x124	*/
		VIN1A_D13	(PIN_INPUT | MUX_MODE14)	/*	0x128	*/
		VIN1A_D14	(PIN_INPUT | MUX_MODE14)	/*	0x12C	*/
		VIN1A_D15	(PIN_INPUT | MUX_MODE14)	/*	0x130	*/
		VIN1A_D16	(PIN_INPUT | MUX_MODE14)	/*	0x134	*/
		VIN1A_D17	(PIN_INPUT | MUX_MODE14)	/*	0x138	*/
		VIN1A_D18	(PIN_INPUT | MUX_MODE14)	/*	0x13C	*/
		VIN1A_D19	(PIN_INPUT | MUX_MODE14)	/*	0x140	*/
		VIN1A_D20	(PIN_INPUT | MUX_MODE14)	/*	0x144	*/
		VIN1A_D21	(PIN_INPUT | MUX_MODE14)	/*	0x148	*/
		VIN1A_D22	(PIN_INPUT | MUX_MODE14)	/*	0x14C	*/
		VIN1A_D23	(PIN_INPUT | MUX_MODE14)	/*	0x150	*/
		VIN2A_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x154	*/
//		VIN2A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x158	*/
		VIN2A_FLD0	(PIN_INPUT | MUX_MODE14)	/*	0x15C	*/
		VIN2A_HSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x160	*/
		VIN2A_VSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x164	*/
		VIN2A_D0	(PIN_INPUT | MUX_MODE14)	/*	0x168	*/
		VIN2A_D1	(PIN_INPUT | MUX_MODE14)	/*	0x16C	*/
		//VIN2A_D2	(PIN_INPUT | MUX_MODE14)	/*	0x170	*/
		//VIN2A_D3	(PIN_INPUT | MUX_MODE14)	/*	0x174	*/
		//VIN2A_D4	(PIN_INPUT | MUX_MODE14)	/*	0x178	*/
		//VIN2A_D5	(PIN_INPUT | MUX_MODE14)	/*	0x17C	*/
		VIN2A_D6	(PIN_INPUT | MUX_MODE14)	/*	0x180	*/
		VIN2A_D7	(PIN_INPUT | MUX_MODE14)	/*	0x184	*/
		//VIN2A_D8	(PIN_INPUT | MUX_MODE14)	/*	0x188	*/
		//VIN2A_D9	(PIN_INPUT | MUX_MODE14)	/*	0x18C	*/
		VIN2A_D10	(PIN_INPUT | MUX_MODE14)	/*	0x190	*/
		VIN2A_D11	(PIN_INPUT | MUX_MODE14)	/*	0x194	*/
		VIN2A_D12	(PIN_INPUT | MUX_MODE14)	/*	0x198	*/
		VIN2A_D13	(PIN_INPUT | MUX_MODE14)	/*	0x19C	*/
		VIN2A_D14	(PIN_INPUT | MUX_MODE14)	/*	0x1A0	*/
		VIN2A_D15	(PIN_INPUT | MUX_MODE14)	/*	0x1A4	*/
		VIN2A_D16	(PIN_INPUT | MUX_MODE14)	/*	0x1A8	*/
		VIN2A_D17	(PIN_INPUT | MUX_MODE14)	/*	0x1AC	*/
		VIN2A_D18	(PIN_INPUT | MUX_MODE14)	/*	0x1B0	*/
		VIN2A_D19	(PIN_INPUT | MUX_MODE14)	/*	0x1B4	*/
		VIN2A_D20	(PIN_INPUT | MUX_MODE14)	/*	0x1B8	*/
		VIN2A_D21	(PIN_INPUT | MUX_MODE14)	/*	0x1BC	*/
		VIN2A_D22	(PIN_INPUT | MUX_MODE14)	/*	0x1C0	*/
		VIN2A_D23	(PIN_INPUT | MUX_MODE14)	/*	0x1C4	*/
		//VOUT1_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x1C8	*/
		//VOUT1_DE	(PIN_INPUT | MUX_MODE14)	/*	0x1CC	*/
		VOUT1_FLD	(PIN_INPUT | MUX_MODE14)	/*	0x1D0	*/
		//VOUT1_HSYNC	(PIN_INPUT | MUX_MODE14)	/*	0x1D4	*/
		//VOUT1_VSYNC	(PIN_INPUT | MUX_MODE14)	/*	0x1D8	*/
		//VOUT1_D0	(PIN_INPUT | MUX_MODE14)	/*	0x1DC	*/	// uart5
		//VOUT1_D1	(PIN_INPUT | MUX_MODE14)	/*	0x1E0	*/	// uart5
		VOUT1_D2	(PIN_INPUT | MUX_MODE14)	/*	0x1E4	*/
		VOUT1_D3	(PIN_INPUT | MUX_MODE14)	/*	0x1E8	*/
		VOUT1_D4	(PIN_INPUT | MUX_MODE14)	/*	0x1EC	*/
		VOUT1_D5	(PIN_INPUT | MUX_MODE14)	/*	0x1F0	*/
		VOUT1_D6	(PIN_INPUT | MUX_MODE14)	/*	0x1F4	*/
		VOUT1_D7	(PIN_INPUT | MUX_MODE14)	/*	0x1F8	*/
		//VOUT1_D8	(PIN_INPUT | MUX_MODE14)	/*	0x1FC	*/	// uart6
		//VOUT1_D9	(PIN_INPUT | MUX_MODE14)	/*	0x200	*/	// uart6
		VOUT1_D10	(PIN_INPUT | MUX_MODE14)	/*	0x204	*/
		VOUT1_D11	(PIN_INPUT | MUX_MODE14)	/*	0x208	*/
		VOUT1_D12	(PIN_INPUT | MUX_MODE14)	/*	0x20C	*/
		VOUT1_D13	(PIN_INPUT | MUX_MODE14)	/*	0x210	*/
		VOUT1_D14	(PIN_INPUT | MUX_MODE14)	/*	0x214	*/
		VOUT1_D15	(PIN_INPUT | MUX_MODE14)	/*	0x218	*/
		VOUT1_D16	(PIN_INPUT | MUX_MODE14)	/*	0x21C	*/
		VOUT1_D17	(PIN_INPUT | MUX_MODE14)	/*	0x220	*/
		VOUT1_D18	(PIN_INPUT | MUX_MODE14)	/*	0x224	*/
		VOUT1_D19	(PIN_INPUT | MUX_MODE14)	/*	0x228	*/
		VOUT1_D20	(PIN_INPUT | MUX_MODE14)	/*	0x22C	*/
		VOUT1_D21	(PIN_INPUT | MUX_MODE14)	/*	0x230	*/
		VOUT1_D22	(PIN_INPUT | MUX_MODE14)	/*	0x234	*/
		VOUT1_D23	(PIN_INPUT | MUX_MODE14)	/*	0x238	*/
//		MDIO_MCLK	(PIN_INPUT | MUX_MODE14)	/*	0x23C	*/
//		MDIO_D	(PIN_INPUT | MUX_MODE14)	/*	0x240	*/
		RMII_MHZ_50_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x244	*/
//		UART3_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x248	*/
//		UART3_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x24C	*/
//		RGMII0_TXC	(PIN_INPUT | MUX_MODE14)	/*	0x250	*/
//		RGMII0_TXCTL	(PIN_INPUT | MUX_MODE14)	/*	0x254	*/
		RGMII0_TXD3	(PIN_INPUT | MUX_MODE14)	/*	0x258	*/
		RGMII0_TXD2	(PIN_INPUT | MUX_MODE14)	/*	0x25C	*/
		RGMII0_TXD1	(PIN_INPUT | MUX_MODE14)	/*	0x260	*/
		RGMII0_TXD0	(PIN_INPUT | MUX_MODE14)	/*	0x264	*/
//		RGMII0_RXC	(PIN_INPUT | MUX_MODE14)	/*	0x268	*/
//		RGMII0_RXCTL	(PIN_INPUT | MUX_MODE14)	/*	0x26C	*/
//		RGMII0_RXD3	(PIN_INPUT | MUX_MODE14)	/*	0x270	*/
//		RGMII0_RXD2	(PIN_INPUT | MUX_MODE14)	/*	0x274	*/
		RGMII0_RXD1	(PIN_INPUT | MUX_MODE14)	/*	0x278	*/
		RGMII0_RXD0	(PIN_INPUT | MUX_MODE14)	/*	0x27C	*/
		USB1_DRVVBUS	(PIN_INPUT | MUX_MODE14)	/*	0x280	*/
		USB2_DRVVBUS	(PIN_INPUT | MUX_MODE14)	/*	0x284	*/
		GPIO6_14	(PIN_INPUT | MUX_MODE14)	/*	0x288	*/
		GPIO6_15	(PIN_INPUT | MUX_MODE14)	/*	0x28C	*/
		GPIO6_16	(PIN_INPUT | MUX_MODE14)	/*	0x290	*/
		XREF_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x294	*/
		XREF_CLK1	(PIN_INPUT | MUX_MODE14)	/*	0x298	*/
		XREF_CLK2	(PIN_INPUT | MUX_MODE14)	/*	0x29C	*/
		XREF_CLK3	(PIN_INPUT | MUX_MODE14)	/*	0x2A0	*/
		MCASP1_ACLKX	(PIN_INPUT | MUX_MODE14)	/*	0x2A4	*/
		MCASP1_FSX	(PIN_INPUT | MUX_MODE14)	/*	0x2A8	*/
		MCASP1_ACLKR	(PIN_INPUT | MUX_MODE14)	/*	0x2AC	*/
		MCASP1_FSR	(PIN_INPUT | MUX_MODE14)	/*	0x2B0	*/
		//MCASP1_AXR0	(PIN_INPUT | MUX_MODE14)	/*	0x2B4	*/
		//MCASP1_AXR1	(PIN_INPUT | MUX_MODE14)	/*	0x2B8	*/
		MCASP1_AXR2	(PIN_INPUT | MUX_MODE14)	/*	0x2BC	*/
		MCASP1_AXR3	(PIN_INPUT | MUX_MODE14)	/*	0x2C0	*/
		MCASP1_AXR4	(PIN_INPUT | MUX_MODE14)	/*	0x2C4	*/
		MCASP1_AXR5	(PIN_INPUT | MUX_MODE14)	/*	0x2C8	*/
		MCASP1_AXR6	(PIN_INPUT | MUX_MODE14)	/*	0x2CC	*/
		MCASP1_AXR7	(PIN_INPUT | MUX_MODE14)	/*	0x2D0	*/
		MCASP1_AXR8	(PIN_INPUT | MUX_MODE14)	/*	0x2D4	*/
		MCASP1_AXR9	(PIN_INPUT | MUX_MODE14)	/*	0x2D8	*/
		MCASP1_AXR10	(PIN_INPUT | MUX_MODE14)	/*	0x2DC	*/
		MCASP1_AXR11	(PIN_INPUT | MUX_MODE14)	/*	0x2E0	*/
		MCASP1_AXR12	(PIN_INPUT | MUX_MODE14)	/*	0x2E4	*/
		MCASP1_AXR13	(PIN_INPUT | MUX_MODE14)	/*	0x2E8	*/
		MCASP1_AXR14	(PIN_INPUT | MUX_MODE14)	/*	0x2EC	*/
		MCASP1_AXR15	(PIN_INPUT | MUX_MODE14)	/*	0x2F0	*/
		MCASP2_AXR2	(PIN_INPUT | MUX_MODE14)	/*	0x30C	*/
		MCASP2_AXR3	(PIN_INPUT | MUX_MODE14)	/*	0x310	*/
		MCASP2_AXR4	(PIN_INPUT | MUX_MODE14)	/*	0x314	*/
		MCASP2_AXR5	(PIN_INPUT | MUX_MODE14)	/*	0x318	*/
		MCASP2_AXR6	(PIN_INPUT | MUX_MODE14)	/*	0x31C	*/
		MCASP2_AXR7	(PIN_INPUT | MUX_MODE14)	/*	0x320	*/
		MCASP3_ACLKX	(PIN_INPUT | MUX_MODE14)	/*	0x324	*/
		MCASP3_FSX	(PIN_INPUT | MUX_MODE14)	/*	0x328	*/
		//MMC1_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x354	*/
		//MMC1_CMD	(PIN_INPUT | MUX_MODE14)	/*	0x358	*/
		//MMC1_DAT0	(PIN_INPUT | MUX_MODE14)	/*	0x35C	*/
		//MMC1_DAT1	(PIN_INPUT | MUX_MODE14)	/*	0x360	*/
		//MMC1_DAT2	(PIN_INPUT | MUX_MODE14)	/*	0x364	*/
		//MMC1_DAT3	(PIN_INPUT | MUX_MODE14)	/*	0x368	*/
		//MMC1_SDCD	(PIN_INPUT | MUX_MODE14)	/*	0x36C	*/
		//MMC1_SDWP	(PIN_INPUT | MUX_MODE14)	/*	0x370	*/
		//ulpi
		//GPIO6_10	(PIN_INPUT | MUX_MODE14)	/*	0x374	*/
		//GPIO6_11	(PIN_INPUT | MUX_MODE14)	/*	0x378	*/
		//MMC3_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x37C	*/
		//MMC3_CMD	(PIN_INPUT | MUX_MODE14)	/*	0x380	*/
		//MMC3_DAT0	(PIN_INPUT | MUX_MODE14)	/*	0x384	*/
		//MMC3_DAT1	(PIN_INPUT | MUX_MODE14)	/*	0x388	*/
		//MMC3_DAT2	(PIN_INPUT | MUX_MODE14)	/*	0x38C	*/
		//MMC3_DAT3	(PIN_INPUT | MUX_MODE14)	/*	0x390	*/
		//MMC3_DAT4	(PIN_INPUT | MUX_MODE14)	/*	0x394	*/
		//MMC3_DAT5	(PIN_INPUT | MUX_MODE14)	/*	0x398	*/
		//MMC3_DAT6	(PIN_INPUT | MUX_MODE14)	/*	0x39C	*/
		//MMC3_DAT7	(PIN_INPUT | MUX_MODE14)	/*	0x3A0	*/
		//SPI1_SCLK	(PIN_INPUT | MUX_MODE14)	/*	0x3A4	*/
		//SPI1_D1	(PIN_INPUT | MUX_MODE14)	/*	0x3A8	*/
		//SPI1_D0	(PIN_INPUT | MUX_MODE14)	/*	0x3AC	*/
		//SPI1_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x3B0	*/
		//SPI1_CS1	(PIN_INPUT | MUX_MODE14)	/*	0x3B4	*/
		SPI1_CS2	(PIN_INPUT | MUX_MODE14)	/*	0x3B8	*/
		//SPI1_CS3	(PIN_INPUT | MUX_MODE14)	/*	0x3BC	*/
		//SPI2_SCLK	(PIN_INPUT | MUX_MODE14)	/*	0x3C0	*/
		//SPI2_D1	(PIN_INPUT | MUX_MODE14)	/*	0x3C4	*/
		//SPI2_D0	(PIN_INPUT | MUX_MODE14)	/*	0x3C8	*/
		//SPI2_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x3CC	*/
		DCAN1_TX	(PIN_INPUT | MUX_MODE14)	/*	0x3D0	*/
		DCAN1_RX	(PIN_INPUT | MUX_MODE14)	/*	0x3D4	*/
		DCAN2_TX	(PIN_INPUT | MUX_MODE14)	/*	0x3D8	*/
		DCAN2_RX	(PIN_INPUT | MUX_MODE14)	/*	0x3DC	*/
		UART1_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x3E0	*/
		UART1_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x3E4	*/
		//UART1_CTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3E8	*/
		//UART1_RTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3EC	*/
		//UART2_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x3F0	*/
		//UART2_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x3F4	*/
		//UART2_CTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3F8	*/
		//UART2_RTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3FC	*/
		WAKEUP0	(PIN_INPUT | MUX_MODE14)	/*	0x418	*/
		WAKEUP1	(PIN_INPUT | MUX_MODE14)	/*	0x41C	*/
		WAKEUP2	(PIN_INPUT | MUX_MODE14)	/*	0x420	*/
		WAKEUP3	(PIN_INPUT | MUX_MODE14)	/*	0x424	*/
		TDI	(PIN_INPUT | MUX_MODE14)	/*	0x434	*/
		TDO	(PIN_INPUT | MUX_MODE14)	/*	0x438	*/
		TCLK	(PIN_INPUT | MUX_MODE14)	/*	0x43C	*/
		TRSTN	(PIN_INPUT | MUX_MODE14)	/*	0x440	*/
		RTCK	(PIN_INPUT | MUX_MODE14)	/*	0x444	*/
		EMU2	(PIN_INPUT | MUX_MODE14)	/*	0x450	*/
		EMU3	(PIN_INPUT | MUX_MODE14)	/*	0x454	*/
	uart3_pins_default: pinmux_uart3_pins {
			0x34c (PIN_INPUT | MUX_MODE4) /* mcasp5_axr0.uart3_rxd */
			0x350 (PIN_OUTPUT | MUX_MODE4) /* mcasp5_axr1.uart3_txd */
	uart5_pins_default: pinmux_uart5_pins {
			VOUT1_D0 (WAKEUP_EN | PIN_INPUT | MUX_MODE2)	/* vout1_d0.uart5_rxd */
			VOUT1_D1 (PIN_OUTPUT | MUX_MODE2)						/* vout1_d1.uart5_txd */
	uart6_pins_default: pinmux_uart6_pins {
			VOUT1_D8 (PIN_INPUT | MUX_MODE2)  /* vout1_d8.uart6_rxd */
			VOUT1_D9 (PIN_OUTPUT | MUX_MODE2) /* vout1_d9.uart6_txd */
			VIN2A_D4 (PIN_OUTPUT | MUX_MODE8)  /* vin2a_d4.uart6_ctsn */
			VIN2A_D5 (PIN_INPUT | MUX_MODE8) /* vin2a_d5.uart6_rtsn */
	uart9_pins_default: pinmux_uart9_pins {
			MCASP5_ACLKX (PIN_INPUT | MUX_MODE8)  /* mcasp5_aclkx.uart9_rxd */
			MCASP5_FSX (PIN_OUTPUT | MUX_MODE3) /* mcasp5_fsx.uart9_txd */
	uart10_pins_default: pinmux_uart10_pins {
			0x170 (PIN_INPUT | MUX_MODE8)  /* vin2a_d2.uart10_rxd */
			0x174 (PIN_OUTPUT | MUX_MODE8) /* vin2a_d3.uart10_txd */
	mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins {
			0x354 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */
			0x358 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */
			0x35c (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */
			0x360 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */
			0x364 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */
			0x368 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */
	mmc1_pins_hs: pinmux_mmc1_hs_pins {
	mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
	mmc1_pins_sdr50: pinmux_mmc1_sdr50_pins {
			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_clk.mmc1_clk */
			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_cmd.mmc1_cmd */
			0x35C (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat0.mmc1_dat0 */
			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat1.mmc1_dat1 */
			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat2.mmc1_dat2 */
			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat3.mmc1_dat3 */
	mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
			0x354	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_clk.mmc1_clk */
			0x358	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_cmd.mmc1_cmd */
			0x35C	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat0.mmc1_dat0 */
			0x360	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat1.mmc1_dat1 */
			0x364	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat2.mmc1_dat2 */
			0x368	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat3.mmc1_dat3 */
	mmc1_pins_sdr104: pinmux_mmc1_sdr104_pins {
			0x354	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_clk.mmc1_clk */
			0x358	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_cmd.mmc1_cmd */
			0x35C	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat0.mmc1_dat0 */
			0x360	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat1.mmc1_dat1 */
			0x364	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat2.mmc1_dat2 */
			0x368	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat3.mmc1_dat3 */
	mmc2_pins_hs: pinmux_mmc2_hs_pins {
			0x08C	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
			0x090	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
			0x094	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
			0x098	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
			0x09C	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
			0x0A0	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
			0x0A4	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
			0x0A8	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
			0x0AC	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
			0x0B0	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
	mmc2_pins_ddr_1_8v: pinmux_mmc2_ddr_1_8v_pins {
	mmc2_pins_hs200_1_8v: pinmux_mmc2_hs200_1_8v_pins {
			0x08C	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
			0x090	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
			0x094	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
			0x098	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
			0x09C	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
			0x0A0	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
			0x0A4	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
			0x0A8	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
			0x0AC	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
			0x0B0	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
&dra7_iodelay_core {
	mmc1_iodelay_sdr104_conf: mmc1_iodelay_sdr104_conf {
			0x620 (A_DELAY(560) | G_DELAY(365))	/* CFG_MMC1_CLK_OUT */
			0x62C (A_DELAY(0)   | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
			0x638 (A_DELAY(29)  | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
			0x644 (A_DELAY(0)   | G_DELAY(0))	/* CFG_MMC1_DAT1_OUT */
			0x650 (A_DELAY(47)  | G_DELAY(0))	/* CFG_MMC1_DAT2_OUT */
			0x65C (A_DELAY(30)  | G_DELAY(0))	/* CFG_MMC1_DAT3_OUT */
			0x628 (A_DELAY(125) | G_DELAY(0))	/* CFG_MMC1_CMD_OEN */
			0x634 (A_DELAY(43)  | G_DELAY(0))	/* CFG_MMC1_DAT0_OEN */
			0x640 (A_DELAY(433) | G_DELAY(0))	/* CFG_MMC1_DAT1_OEN */
			0x64C (A_DELAY(287) | G_DELAY(0))	/* CFG_MMC1_DAT2_OEN */
			0x658 (A_DELAY(351) | G_DELAY(0))	/* CFG_MMC1_DAT3_OEN */
	mmc2_iodelay_hs200_1_8v_conf: mmc2_iodelay_hs200_1_8v_conf {
			0x194 (A_DELAY(150) | G_DELAY(95))	/* CFG_GPMC_A19_OUT */
			0x1AC (A_DELAY(250) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
			0x1B8 (A_DELAY(125) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
			0x1C4 (A_DELAY(100) | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
			0x1D0 (A_DELAY(870) | G_DELAY(415))	/* CFG_GPMC_A23_OUT */
			0x1DC (A_DELAY(30)  | G_DELAY(0))	/* CFG_GPMC_A24_OUT */
			0x1E8 (A_DELAY(200) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
			0x1F4 (A_DELAY(200) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
			0x200 (A_DELAY(0)   | G_DELAY(0))	/* CFG_GPMC_A27_OUT */
			0x368 (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
			0x190 (A_DELAY(695) | G_DELAY(0))	/* CFG_GPMC_A19_OEN */
			0x1A8 (A_DELAY(924) | G_DELAY(0))	/* CFG_GPMC_A20_OEN */
			0x1B4 (A_DELAY(719) | G_DELAY(0))	/* CFG_GPMC_A21_OEN */
			0x1C0 (A_DELAY(824) | G_DELAY(0))	/* CFG_GPMC_A22_OEN */
			0x1D8 (A_DELAY(877) | G_DELAY(0))	/* CFG_GPMC_A24_OEN */
			0x1E4 (A_DELAY(446) | G_DELAY(0))	/* CFG_GPMC_A25_OEN */
			0x1F0 (A_DELAY(847) | G_DELAY(0))	/* CFG_GPMC_A26_OEN */
			0x1FC (A_DELAY(586) | G_DELAY(0))	/* CFG_GPMC_A27_OEN */
			0x364 (A_DELAY(1039) | G_DELAY(0))	/* CFG_GPMC_CS1_OEN */
&i2c3 {
	status = "okay";
&i2c5 {
	ov10633@37 {
		compatible = "ovti,ov10633";
		reg = <0x37>;
		mux-gpios = <&pcf_hdmi 3	GPIO_ACTIVE_LOW>; /* CAM_FPD_MUX_S0 */
		port {
			onboardLI: endpoint@0 {
				remote-endpoint = <&vin2a>;
				//hsync-active = <1>;
				//vsync-active = <1>;
				pclk-sample = <0>;
				channels = <0>;
	gpio_csi2_adap: tca6416@20 {
		status = "okay";
		compatible = "ti,tca6416";
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
	ov490@24 {
		compatible = "ovti,ov490";
		reg = <0x24>;
		mux-gpios = <&gpio_csi2_adap 0	GPIO_ACTIVE_LOW>,
						/* CSI2_SEL_I2C_CLK */
			    <&gpio_csi2_adap 1	GPIO_ACTIVE_HIGH>,
						/* CSI2_SEL_REF_CLK */
			    <&gpio_csi2_adap 3	GPIO_ACTIVE_HIGH>,
						/* CSI2_CAM0_RESETn */
			    <&gpio_csi2_adap 4	GPIO_ACTIVE_LOW>;
						/* CSI2_CAM0_PWR_DWN */
		port {
			csi2_cam0: endpoint@0 {
				clock-lanes = <0>;
				data-lanes = <1 2 3 4>;
				remote-endpoint = <&csi2_phy0>;
&dss {
	pinctrl-names = "default";
	pinctrl-0 = <&vout3_pins>;
	status = "ok";
	vdda_video-supply = <&ldo5_reg>;
	ports {
		#address-cells = <1>;
		#size-cells = <0>;
		status = "okay";
		port@lcd2 {
			reg = <2>;
			dpi2_out: endpoint {
				remote-endpoint = <&lcd2_in>;
				data-lines = <24>;
&hdmi {
&pcf_gpio_21 {
	interrupt-parent = <&gpio6>;
	interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
&mmc1 {
	pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104";
	pinctrl-0 = <&mmc1_pins_default>;
	pinctrl-1 = <&mmc1_pins_hs>;
	pinctrl-2 = <&mmc1_pins_sdr12>;
	pinctrl-3 = <&mmc1_pins_sdr25>;
	pinctrl-4 = <&mmc1_pins_sdr50>;
	pinctrl-5 = <&mmc1_pins_ddr50>;
	pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_conf>;
&mmc2 {
	pinctrl-names = "default", "hs", "ddr_1_8v", "hs200_1_8v";
	pinctrl-0 = <&mmc2_pins_default>;
	pinctrl-1 = <&mmc2_pins_hs>;
	pinctrl-2 = <&mmc2_pins_ddr_1_8v>;
	pinctrl-3 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_conf>;
// WNC
&uart1 {
/* use for GPIO declare */
	status = "okay";
	pinctrl-0 = <&uart1_pins>;
&uart2 {
	status = "okay";
&uart3 {
	status = "okay";
	/* gpios = <&pcf_gpio_21 14 GPIO_ACTIVE_LOW>; */
	pinctrl-0 = <&uart3_pins_default>;
&uart5 {
	status = "okay";
	pinctrl-0 = <&uart5_pins_default>;
&uart6 {
	status = "okay";
	pinctrl-0 = <&uart6_pins_default>;
&uart9 {
	status = "okay";
	pinctrl-0 = <&uart9_pins_default>;
&uart10 {
	status = "okay";
	pinctrl-0 = <&uart10_pins_default>;
&mac {
	slaves = <1>;
	mode-gpios = <&pcf_gpio_21 4 GPIO_ACTIVE_HIGH>;
&cpsw_emac0 {
	phy_id = <&davinci_mdio>, <3>;
	phy-mode = "rgmii";
&ipu2 {
	status = "okay";
	memory-region = <&ipu2_cma_pool>;
&ipu1 {
	status = "okay";
	memory-region = <&ipu1_cma_pool>;
&dsp1 {
	status = "okay";
	memory-region = <&dsp1_cma_pool>;
&vip1 {
	status = "okay";
	pinctrl-0 = <&vin2a_pins>;
	vin2a: port@1 {
		status = "okay";
video_in: &vin2a {
	status = "okay";
	endpoint@0 {
		slave-mode;
		remote-endpoint = <&onboardLI>;
&cal {
	status = "okay";
&csi2_0 {
	csi2_phy0: endpoint@0 {
		slave-mode;
		remote-endpoint = <&csi2_cam0>;
#include "dra7xx-jamr3.dtsi"
&tvp_5158{
	status = "disabled";
	mux-gpios = <&pcf_hdmi 2 GPIO_ACTIVE_LOW>,	/*VIN2_S0*/
		    <&pcf_jamr3_21 8 GPIO_ACTIVE_LOW>,	/*SEL_TVP_FPD*/
		    <&pcf_hdmi 6 GPIO_ACTIVE_HIGH>;	/*VIN2_S2*/
 * Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
/dts-v1/;
#include "dra72x.dtsi"
#include <dt-bindings/gpio/gpio.h>
	compatible = "ti,dra72-evm", "ti,dra722", "ti,dra72", "ti,dra7";
	aliases {
		display0 = &hdmi0;
		display1 = &lcd2;
		sound0 = &snd0;
		sound1 = &hdmi;
	evm_3v3_sw: fixedregulator-evm_3v3 {
		compatible = "regulator-fixed";
		regulator-name = "evm_3v3";
		regulator-min-microvolt = <3300000>;
	aic_dvdd: fixedregulator-aic_dvdd {
		/* TPS77018DBVT */
		regulator-name = "aic_dvdd";
		vin-supply = <&evm_3v3_sw>;
		regulator-max-microvolt = <1800000>;
	evm_3v3_sd: fixedregulator-sd {
		regulator-name = "evm_3v3_sd";
		enable-active-high;
		gpio = <&pcf_gpio_21 5 GPIO_ACTIVE_HIGH>;
#if 0
	extcon_usb1: extcon_usb1 {
		compatible = "linux,extcon-usb-gpio";
		id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>;
	extcon_usb2: extcon_usb2 {
		id-gpio = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>;
#endif
	hdmi0: connector {
		compatible = "hdmi-connector";
		label = "hdmi";
		type = "a";
		port {
			hdmi_connector_in: endpoint {
				remote-endpoint = <&tpd12s015_out>;
	tpd12s015: encoder {
		compatible = "ti,tpd12s015";
		gpios = <&pcf_hdmi 4 GPIO_ACTIVE_HIGH>,	/* P4, CT CP HPD */
			<&pcf_hdmi 5 GPIO_ACTIVE_HIGH>,	/* P5, LS OE */
			<&gpio7 12 GPIO_ACTIVE_HIGH>;	/* gpio7_12/sp1_cs2, HPD */
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				tpd12s015_in: endpoint {
					remote-endpoint = <&hdmi_out>;
			port@1 {
				reg = <1>;
				tpd12s015_out: endpoint {
					remote-endpoint = <&hdmi_connector_in>;
	snd0: sound@0 {
		simple-audio-card,name = "DRA7xx-EVM";
			"Headphone", "Headphone Jack",
			"Line", "Line Out",
			"Microphone", "Mic Jack",
			"Line", "Line In";
			"Headphone Jack",       "HPLOUT",
			"Headphone Jack",       "HPROUT",
			"MIC3L",		"Mic Jack",
			"MIC3R",		"Mic Jack",
			"Mic Jack",		"Mic Bias",
		simple-audio-card,bitclock-master = <&sound0_master>;
		simple-audio-card,frame-master = <&sound0_master>;
		sound0_master: simple-audio-card,cpu {
			sound-dai = <&mcasp3>;
			sound-dai = <&tlv320aic3106>;
			clocks = <&atl_clkin2_ck>;
#if 0
	// GPIO5_8 is used for TDM pin
	vmmcwl_fixed: fixedregulator-mmcwl {
		regulator-name = "vmmcwl_fixed";
		gpio = <&gpio5 8 GPIO_ACTIVE_HIGH>;
		enable-active-high;
#endif
&dra7_pmx_core {
        tps65917_pins_default: tps65917_pins_default {
                        0x424 (PIN_INPUT_PULLUP | MUX_MODE1)    /* wakeup3.sys_nirq1 */
	mmc1_pins_default: mmc1_pins_default {
	mmc2_pins_default: mmc2_pins_default {
			0x9c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */
			0xb0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
			0xa0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
			0xa4 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
			0xa8 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
			0xac (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
			0x8c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
			0x90 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
			0x94 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
			0x98 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
	mmc4_pins_default: mmc4_pins_default {
			0x3e8 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
			0x3ec (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
			0x3f0 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
			0x3f4 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
			0x3f8 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
			0x3fC (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
	dcan1_pins_default: dcan1_pins_default {
			0x3d0   (PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */
			0x418   (PULL_UP | MUX_MODE1)	/* wakeup0.dcan1_rx */
	dcan1_pins_sleep: dcan1_pins_sleep {
			0x3d0   (MUX_MODE15 | PULL_UP)	/* dcan1_tx.off */
			0x418   (MUX_MODE15 | PULL_UP)	/* wakeup0.off */
#if 0
	// GPIO5_8 function in TDM
	wlan_pins: pinmux_wlan_pins {
			0x3fc (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart2_rtsn.mmc4_dat3 */
			0x2cc (PIN_OUTPUT | MUX_MODE14)		/* mcasp1_axr6.gpio5_8 - WLAN_EN */
#endif
	wlirq_pins: pinmux_wlirq_pins {
			0x2c8 (PIN_INPUT_PULLUP | WAKEUP_EN | MUX_MODE14 ) /* mcasp1_axr5.gpio5_7 - WLAN_IRQ */
&i2c1 {
	status = "okay";
	tps65917: tps65917@58 {
		compatible = "ti,tps65917";
		reg = <0x58>;
#if 0
		interrupts = <GIC_SPI 2 IRQ_TYPE_NONE>;  /* IRQ_SYS_1N */
#else
                pinctrl-0 = <&tps65917_pins_default>;
                interrupts-extended = <&gic GIC_SPI 2 IRQ_TYPE_NONE
                                        &dra7_pmx_core 0x424>;
                interrupt-parent = <&gic>;
#endif
		interrupt-controller;
		#interrupt-cells = <2>;
		ti,system-power-controller;
		tps65917_pmic {
			compatible = "ti,tps65917-pmic";
			tps65917_regulators: regulators {
				smps1_reg: smps1 {
					/* VDD_MPU */
					regulator-name = "smps1";
					regulator-min-microvolt = <850000>;
					regulator-max-microvolt = <1250000>;
					regulator-always-on;
					regulator-boot-on;
				smps2_reg: smps2 {
					/* VDD_CORE */
					regulator-name = "smps2";
					regulator-max-microvolt = <1150000>;
					regulator-boot-on;
				smps3_reg: smps3 {
					/* VDD_GPU IVA DSPEVE */
					regulator-name = "smps3";
					regulator-boot-on;
				smps4_reg: smps4 {
					/* VDDS1V8 */
					regulator-name = "smps4";
					regulator-boot-on;
				smps5_reg: smps5 {
					/* VDD_DDR */
					regulator-name = "smps5";
					regulator-min-microvolt = <1350000>;
					regulator-max-microvolt = <1350000>;
					regulator-boot-on;
				ldo1_reg: ldo1 {
					/* LDO1_OUT --> SDIO  */
					regulator-name = "ldo1";
					regulator-boot-on;
				ldo3_reg: ldo3 {
					/* VDDA_1V8_PHY */
					regulator-name = "ldo3";
					regulator-boot-on;
				ldo5_reg: ldo5 {
					/* VDDA_1V8_PLL */
					regulator-name = "ldo5";
					regulator-boot-on;
				ldo4_reg: ldo4 {
					/* VDDA_3V_USB: VDDA_USBHS33 */
					regulator-name = "ldo4";
					regulator-boot-on;
		tps65917_power_button {
			compatible = "ti,palmas-pwrbutton";
			interrupt-parent = <&tps65917>;
			interrupts = <1 IRQ_TYPE_NONE>;
			wakeup-source;
			ti,palmas-long-press-seconds = <6>;
	pcf_lcd: gpio@20 {
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
	pcf_gpio_21: gpio@21 {
		compatible = "ti,pcf8575";
		reg = <0x21>;
		lines-initial-states = <0x1408>;
		gpio-controller;
		#gpio-cells = <2>;
	tlv320aic3106: tlv320aic3106@19 {
		reg = <0x19>;
		status = "okay";
		/* Regulators */
i2c_p3_exp: &i2c5 {
	status = "okay";
	pcf_hdmi: pcf8575@26 {
		reg = <0x26>;
		gpio-controller;
		#gpio-cells = <2>;
		 * initial state is used here to keep the mdio interface
		 * selected on RU89 through SEL_VIN4_MUX_S0, VIN2_S1 and
		 * VIN2_S0 driven high otherwise Ethernet stops working
		 * VIN6_SEL_S0 is low, thus selecting McASP3 over VIN6
		lines-initial-states = <0x0f2b>;
		p1 {
			/* vin6_sel_s0: high: VIN6, low: audio */
			gpio-hog;
			gpios = <1 GPIO_ACTIVE_HIGH>;
			output-low;
			line-name = "vin6_sel_s0";
&mcspi1 {
        status = "okay";
        ti,pindir-d0-out-d1-in;
        spidev@0
    spi-max-frequency = <100000>;
    reg = <0>;
        compatible = "rohm,dh2228fv";
        status = "okay" ;
        spidev@1
    reg = <1>;
        status = "okay" ;
        spidev@3
    reg = <3>;
        status = "okay" ;
&mcspi2 {
        status = "okay";
        spidev@0
    reg = <0>;
&mcspi3 {
        status = "okay";
        spidev@0
    reg = <0>;
&uart1 {
	status = "okay";
	interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>,
			      <&dra7_pmx_core 0x3e0>;
&uart3 {
	status = "okay";
&elm {
	status = "okay";
&gpmc {
	 * For the existing IOdelay configuration via U-Boot we don't
	 * support NAND on dra72-evm. Keep it disabled. Enabling it
	 * requires a different configuration by U-Boot.
	ranges = <0 0 0x08000000 0x01000000>;	/* minimum GPMC partition = 16MB */
	nand@0,0 {
		/* To use NAND, DIP switch SW5 must be set like so:
		 * SW5.1 (NAND_SELn) = ON (LOW)
		 * SW5.9 (GPMC_WPN) = OFF (HIGH)
		compatible = "ti,omap2-nand";
		reg = <0 0 4>;          /* device IO registers */
		interrupt-parent = <&gpmc>;
		interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
			     <1 IRQ_TYPE_NONE>; /* termcount */
		rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 pin */	/* device IO registers */
		ti,nand-ecc-opt = "bch8";
		ti,elm-id = <&elm>;
		nand-bus-width = <16>;
		gpmc,device-width = <2>;
		gpmc,sync-clk-ps = <0>;
		gpmc,cs-on-ns = <0>;
		gpmc,cs-rd-off-ns = <80>;
		gpmc,cs-wr-off-ns = <80>;
		gpmc,adv-on-ns = <0>;
		gpmc,adv-rd-off-ns = <60>;
		gpmc,adv-wr-off-ns = <60>;
		gpmc,we-on-ns = <10>;
		gpmc,we-off-ns = <50>;
		gpmc,oe-on-ns = <4>;
		gpmc,oe-off-ns = <40>;
		gpmc,access-ns = <40>;
		gpmc,wr-access-ns = <80>;
		gpmc,rd-cycle-ns = <80>;
		gpmc,wr-cycle-ns = <80>;
		gpmc,bus-turnaround-ns = <0>;
		gpmc,cycle2cycle-delay-ns = <0>;
		gpmc,clk-activation-ns = <0>;
		gpmc,wait-monitoring-ns = <0>;
		gpmc,wr-data-mux-bus-ns = <0>;
		/* MTD partition table */
		/* All SPL-* partitions are sized to minimal length
		 * which can be independently programmable. For
		 * NAND flash this is equal to size of erase-block */
		#size-cells = <1>;
		partition@0 {
			label = "NAND.SPL";
			reg = <0x00000000 0x000020000>;
		partition@1 {
			label = "NAND.SPL.backup1";
			reg = <0x00020000 0x00020000>;
		partition@2 {
			label = "NAND.SPL.backup2";
			reg = <0x00040000 0x00020000>;
		partition@3 {
			label = "NAND.SPL.backup3";
			reg = <0x00060000 0x00020000>;
		partition@4 {
			label = "NAND.u-boot-spl-os";
			reg = <0x00080000 0x00040000>;
		partition@5 {
			label = "NAND.u-boot";
			reg = <0x000c0000 0x00100000>;
		partition@6 {
			label = "NAND.u-boot-env";
			reg = <0x001c0000 0x00020000>;
		partition@7 {
			label = "NAND.u-boot-env.backup1";
			reg = <0x001e0000 0x00020000>;
		partition@8 {
			label = "NAND.kernel";
			reg = <0x00200000 0x00800000>;
		partition@9 {
			label = "NAND.file-system";
			reg = <0x00a00000 0x0f600000>;
&usb2_phy1 {
	phy-supply = <&ldo4_reg>;
&usb2_phy2 {
&omap_dwc3_1 {
//	extcon = <&extcon_usb1>;
&omap_dwc3_2 {
//	extcon = <&extcon_usb2>;
&usb1 {
	status = "ok";
	dr_mode = "host";
&usb2 {
	status = "ok";
	dr_mode = "host";
&usb3 {
&mmc1 {
	status = "okay";
	vmmc-supply = <&evm_3v3_sw>;
	vmmc_aux-supply = <&ldo1_reg>;
	bus-width = <4>;
	 * SDCD signal is not being used here - using the fact that GPIO mode
	 * is a viable alternative
	cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
	max-frequency = <192000000>;
&mmc2 {
	/* SW5-3 in ON position */
	status = "okay";
	bus-width = <8>;
	ti,non-removable;
&mmc4 {
#if 1
        status = "okay";
        bus-width = <4>;
        pinctrl-0 = <&mmc4_pins_default>;
#else
	status = "okay";
	vmmc-supply = <&vmmcwl_fixed>;
	bus-width = <4>;
	pinctrl-0 = <&wlan_pins &wlirq_pins>;
	cap-power-off-card;
	keep-power-in-suspend;
	ti,non-removable;
	#size-cells = <0>;
	wlcore: wlcore@0 {
		compatible = "ti,wl1835";
		reg = <2>;
		interrupt-parent = <&gpio5>;
		interrupts = <7 IRQ_TYPE_LEVEL_HIGH>;
#endif
&mac {
	status = "okay";
&dcan1 {
	status = "ok";
&qspi {
	status = "okay";
	spi-max-frequency = <64000000>;
	m25p80@0 {
		compatible = "s25fl256s1";
		reg = <0>;
		spi-tx-bus-width = <1>;
		spi-rx-bus-width = <4>;
		#size-cells = <1>;
		/* MTD partition table.
		 * The ROM checks the first four physical blocks
		 * for a valid file to boot and the flash here is
		 * 64KiB block size.
		partition@0 {
			label = "QSPI.SPL";
			reg = <0x00000000 0x000040000>;
		partition@1 {
			label = "QSPI.u-boot";
			reg = <0x00040000 0x00100000>;
		partition@2 {
			label = "QSPI.u-boot-spl-os";
			reg = <0x00140000 0x00080000>;
		partition@3 {
			label = "QSPI.u-boot-env";
			reg = <0x001c0000 0x00010000>;
		partition@4 {
			label = "QSPI.u-boot-env.backup1";
			reg = <0x001d0000 0x0010000>;
		partition@5 {
			label = "QSPI.kernel";
			reg = <0x001e0000 0x0800000>;
		partition@6 {
			label = "QSPI.file-system";
			reg = <0x009e0000 0x01620000>;
&hdmi {
	port {
		hdmi_out: endpoint {
			remote-endpoint = <&tpd12s015_in>;
&atl {
	assigned-clocks = <&abe_dpll_sys_clk_mux>,
			  <&atl_gfclk_mux>,
			  <&dpll_abe_ck>,
			  <&dpll_abe_m2x2_ck>,
			  <&atl_clkin1_ck>,
			  <&atl_clkin2_ck>;
	assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>;
	assigned-clock-rates = <0>, <0>, <180633600>, <361267200>,
			       <11289600>, <11289600>;
	atl2 {
		aws = <DRA7_ATL_WS_MCASP3_FSX>;
&mcasp3 {
	assigned-clocks = <&mcasp3_ahclkx_mux>;
	status = "okay";
	tdm-slots = <2>;
	/* 4 serializer */
		1 2 0 0
	tx-num-evt = <32>;
	rx-num-evt = <32>;
&mailbox5 {
	status = "okay";
	mbox_ipu1_ipc3x: mbox_ipu1_ipc3x {
		status = "okay";
	mbox_dsp1_ipc3x: mbox_dsp1_ipc3x {
		status = "okay";
&mailbox6 {
	status = "okay";
	mbox_ipu2_ipc3x: mbox_ipu2_ipc3x {
		status = "okay";
&mmu0_dsp1 {
	status = "okay";
&mmu1_dsp1 {
	status = "okay";
&mmu_ipu1 {
	status = "okay";
&mmu_ipu2 {
	status = "okay";
&ipu2 {
	mboxes = <&mailbox6 &mbox_ipu2_ipc3x>;
	timers = <&timer3>;
	watchdog-timers = <&timer4>, <&timer9>;
&ipu1 {
	mboxes = <&mailbox5 &mbox_ipu1_ipc3x>;
	timers = <&timer11>;
	watchdog-timers = <&timer7>, <&timer8>;
&dsp1 {
	mboxes = <&mailbox5 &mbox_dsp1_ipc3x>;
	timers = <&timer5>;
	watchdog-timers = <&timer10>;
&oppdm_mpu {
	vdd-supply = <&smps1_reg>;
&oppdm_core {
	vdd-supply = <&smps2_reg>;
&oppdm_dspeve {
	vdd-supply = <&smps3_reg>;
&oppdm_gpu {
&oppdm_ivahd {
 * Based on "omap4.dtsi"
#include "dra7.dtsi"
	compatible = "ti,dra722", "ti,dra72", "ti,dra7";
	cpus {
		#size-cells = <0>;
		cpu0: cpu@0 {
			device_type = "cpu";
			compatible = "arm,cortex-a15";
			reg = <0>;
			/* cooling options */
			cooling-min-level = <0>;
			cooling-max-level = <2>;
			#cooling-cells = <2>; /* min followed by max */
	aliases {
		rproc0 = &ipu1;
		rproc1 = &ipu2;
		rproc2 = &dsp1;
	pmu {
		compatible = "arm,cortex-a15-pmu";
		interrupt-parent = <&wakeupgen>;
		interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>;
	ocp {
		cal: cal@4845b000 {
			compatible = "ti,dra72-cal";
			ti,hwmods = "cal";
			reg = <0x4845B000 0x400>,
			      <0x4845B800 0x40>,
			      <0x4845B900 0x40>,
			      <0x4A002e94 0x4>;
			reg-names = "cal_top",
				    "cal_rx_core0",
				    "cal_rx_core1",
				    "camerrx_control";
			interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			ports {
				#size-cells = <0>;
				csi2_0: port@0 {
					reg = <0>;
				csi2_1: port@1 {
					reg = <1>;
&scm {
	dra72_vip_mux: pinmux@4a002e8c {
		compatible = "pinctrl-single";
		reg = <0xe8c 0x4>;
		#size-cells = <0>;
		pinctrl-single,register-width = <32>;
		pinctrl-single,function-mask = <0x7f>;
&dss {
	reg = <0x58000000 0x80>,
	      <0x58004054 0x4>,
	      <0x58004300 0x20>;
	reg-names = "dss", "pll1_clkctrl", "pll1";
	clocks = <&dss_dss_clk>,
		 <&dss_video1_clk>;
	clock-names = "fck", "video1_clk";
&mailbox3 {
	mbox_pru1_0: mbox_pru1_0 {
		ti,mbox-tx = <0 0 0>;
		ti,mbox-rx = <1 0 0>;
	mbox_pru1_1: mbox_pru1_1 {
		ti,mbox-tx = <2 0 0>;
		ti,mbox-rx = <3 0 0>;
&mailbox4 {
	mbox_pru2_0: mbox_pru2_0 {
	mbox_pru2_1: mbox_pru2_1 {
&mailbox5 {
		ti,mbox-tx = <6 2 2>;
		ti,mbox-rx = <4 2 2>;
		ti,mbox-tx = <5 2 2>;
		ti,mbox-rx = <1 2 2>;
&mailbox6 {
BRs
Louis
    I have forwarded your question to a video expert.
    Yordan
  • There are many things wrong in your log * I see all the pcf drivers probe have failed * VIP driver is requesting for conflicting pinmux entries * MMC driver requesting conflicting pinsmux * All GPIO requests failed because of PCF failure Most likely the capture is also failing because setting boardmuxe GPIOs would have failed. Please check the PCF failures. Also, you can use the probe script to identify if the data is available at the pads. Nikhil D
  • Hi Nikhil,
    1. In our board, we does not have pcf (io-expander), so I disabled this function.
    2. I fixed pin conflicting to vip (please attached boot log --> "update_J6_eco_boot_log_and_register_dump.txt")
    3. mmc driver fixed (please attached boot log --> "update_J6_eco_boot_log_and_register_dump.txt")
    But it cannot work, either.
    4. How do I turn on "video1 PLL" in "CTRL_CORE_DSS_PLL_CONTROL"? I cannot use omapconf write to force assign value, this will cause system hang... Or is there has any configuration that I miss...
    5. seldom occur kernel panic when I dump dss clock
    This is boot log that I updated --> "update_J6_eco_boot_log_and_register_dump.txt"
    U-Boot SPL 2016.05 (May 31 2017 - 15:48:20)
    DRA722-GP ES1.0
    MMC Device 1 not found
    *** Warning - No MMC card found, using default environment
    Trying to boot from MMC1
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05 (May 31 2017 - 15:48:20 +0800)
    CPU  : DRA722-GP ES1.0
    Board: DRA72x EVM REV <NULL>
    I2C:   ready
    DRAM:  1 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    *** Warning - bad CRC, using default environment
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    i2c_write: error waiting for addr ACK (status=0x116)
    SCSI:  Net:   <ethaddr> not set. Validating first E-fuse MAC
    Could not get PHY for cpsw: addr 3
    cpsw
    Hit any key to stop autoboot:  0
    J6E ...
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    3736024 bytes read in 200 ms (17.8 MiB/s)
    101631 bytes read in 28 ms (3.5 MiB/s)
    Booting from mmc0 ...
    Kernel image @ 0x82000000 [ 0x000000 - 0x3901d8 ]
       Loading Device Tree to 8ffe4000, end 8ffffcfe ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.4.14 (root@louis-VirtualBox) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #13 SMP PREEMPT Wed May 31 15:50:31 CST 2017
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine model: TI DRA722 Louis 20170531 18:10
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
    [    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
    [    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
    [    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x00000000be000000
    [    0.000000] Forcing write-allocate cache policy for SMP
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
    [    0.000000] DRA722 ES1.0
    [    0.000000] PERCPU: Embedded 12 pages/cpu @ef645000 s19008 r8192 d21952 u49152
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258368
    [    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=23dc3179-02 rw rootfstype=ext4 rootwait omapdrm.num_crtc=2 drm.debug=0xff
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 839124K/1040384K available (6663K kernel code, 364K rwdata, 2512K rodata, 356K init, 293K bss, 21036K reserved, 180224K cma-reserved, 233472K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc08fe084   (9177 kB)
    [    0.000000]       .init : 0xc08ff000 - 0xc0958000   ( 356 kB)
    [    0.000000]       .data : 0xc0958000 - 0xc09b3150   ( 365 kB)
    [    0.000000]        .bss : 0xc09b5000 - 0xc09fe618   ( 294 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000]  Build-time adjustment of leaf fanout to 32.
    [    0.000000]  RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] OMAP clockevent source: timer1 at 31475 Hz
    [    0.000000] Architected cp15 timer(s) running at 5.90MHz (virt).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
    [    0.000004] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
    [    0.000015] Switching to timer-based delay loop, resolution 169ns
    [    0.000338] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000346] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000756] Console: colour dummy device 80x30
    [    0.000773] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000779] This ensures that you still see kernel messages. Please
    [    0.000785] update your kernel commandline.
    [    0.000798] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000810] pid_max: default: 32768 minimum: 301
    [    0.000902] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000913] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001433] Initializing cgroup subsys io
    [    0.001449] Initializing cgroup subsys memory
    [    0.001471] Initializing cgroup subsys devices
    [    0.001484] Initializing cgroup subsys freezer
    [    0.001495] Initializing cgroup subsys perf_event
    [    0.001506] Initializing cgroup subsys pids
    [    0.001528] CPU: Testing write buffer coherency: ok
    [    0.001727] /cpus/cpu@0 missing clock-frequency property
    [    0.001739] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001775] Setting up static identity map for 0x80008380 - 0x800083d8
    [    0.050027] Brought up 1 CPUs
    [    0.050039] SMP: Total of 1 processors activated (11.80 BogoMIPS).
    [    0.050046] CPU: All CPU(s) started in SVC mode.
    [    0.050355] devtmpfs: initialized
    [    0.080048] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.081000] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.265871] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.273585] pinctrl core: initialized pinctrl subsystem
    [    0.274478] NET: Registered protocol family 16
    [    0.275416] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.300195] cpuidle: using governor ladder
    [    0.330220] cpuidle: using governor menu
    [    0.338987] OMAP GPIO hardware version 0.1
    [    0.342934] GPIO line 161 (radio_rst) hogged as output/low
    [    0.345207] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [    0.369451] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.369463] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.369859] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.369868] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.370493] OMAP DMA hardware revision 0.0
    [    0.444053] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
    [    0.445178] edma 43300000.edma: memcpy is disabled
    [    0.449962] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.453504] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.453691] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.453848] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.454010] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.455992] SCSI subsystem initialized
    [    0.460744] usbcore: registered new interface driver usbfs
    [    0.460799] usbcore: registered new interface driver hub
    [    0.460868] usbcore: registered new device driver usb
    [    0.461954] palmas 0-0058: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/tps65917_pins_default, deferring probe
    [    0.462107] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.462528] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.462919] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.463406] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.463568] media: Linux media interface: v0.10
    [    0.463619] Linux video capture interface: v2.00
    [    0.463656] pps_core: LinuxPPS API ver. 1 registered
    [    0.463662] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.463685] PTP clock support registered
    [    0.463712] EDAC MC: Ver: 3.0.0
    [    0.471040] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.471240] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.472360] clocksource: Switched to clocksource arch_sys_counter
    [    0.482557] NET: Registered protocol family 2
    [    0.483064] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.483137] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.483268] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.483321] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.483353] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.483542] NET: Registered protocol family 1
    [    0.493840] RPC: Registered named UNIX socket transport module.
    [    0.493849] RPC: Registered udp transport module.
    [    0.493856] RPC: Registered tcp transport module.
    [    0.493862] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.494897] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.496967] futex hash table entries: 256 (order: 2, 16384 bytes)
    [    0.514796] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.525490] NFS: Registering the id_resolver key type
    [    0.525519] Key type id_resolver registered
    [    0.525526] Key type id_legacy registered
    [    0.525596] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.527880] bounce: pool size: 64 pages
    [    0.528033] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    0.528047] io scheduler noop registered
    [    0.528058] io scheduler deadline registered
    [    0.528088] io scheduler cfq registered (default)
    [    0.532897] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.533027] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
    [    0.536073] PCI host bridge /ocp/axi@0/pcie@51000000 ranges:
    [    0.536085]   No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
    [    0.536118]    IO 0x20003000..0x20012fff -> 0x00000000
    [    0.536139]   MEM 0x20013000..0x2fffffff -> 0x20013000
    [    0.541197] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [    0.541210] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.541221] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    0.541230] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    0.541643] PCI: bus0: Fast back to back transfers disabled
    [    0.562445] PCI: bus1: Fast back to back transfers disabled
    [    0.562499] irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
    [    0.562542] irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
    [    0.562581] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    0.562596] pci 0000:00:00.0: BAR 8: assigned [mem 0x20200000-0x202fffff]
    [    0.562608] pci 0000:00:00.0: BAR 9: assigned [mem 0x20300000-0x203fffff pref]
    [    0.562619] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    0.562631] pci 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
    [    0.562648] pci 0000:01:00.0: BAR 6: assigned [mem 0x20300000-0x2033ffff pref]
    [    0.562658] pci 0000:01:00.0: BAR 0: assigned [mem 0x20200000-0x2021ffff]
    [    0.562679] pci 0000:01:00.0: BAR 1: assigned [mem 0x20220000-0x2022ffff]
    [    0.562699] pci 0000:01:00.0: BAR 3: assigned [mem 0x20230000-0x20233fff]
    [    0.562719] pci 0000:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
    [    0.562740] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.562750] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
    [    0.562761] pci 0000:00:00.0:   bridge window [mem 0x20200000-0x202fffff]
    [    0.562771] pci 0000:00:00.0:   bridge window [mem 0x20300000-0x203fffff pref]
    [    0.563004] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [    0.563014] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
    [    0.619694] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    0.623278] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
    [    0.624180] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
    [    0.625037] console [ttyS2] disabled
    [    0.625084] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
    [    1.680024] console [ttyS2] enabled
    [    1.684423] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 304, base_baud = 3000000) is a 8250
    [    1.694142] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 305, base_baud = 3000000) is a 8250
    [    1.703812] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 306, base_baud = 3000000) is a 8250
    [    1.713479] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 307, base_baud = 3000000) is a 8250
    [    1.723508] [drm] Initialized drm 1.1.0 20060810
    [    1.729189] omapdss_dss 58000000.dss: master bind failed: -517
    [    1.736747] panel-dpi display@2: failed to find video source
    [    1.913227] brd: module loaded
    [    2.001549] loop: module loaded
    [    2.011073] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    2.018651] libphy: Fixed MDIO Bus: probed
    [    2.024353] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    2.031228] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.037844] ehci-pci: EHCI PCI platform driver
    [    2.042495] ehci-omap: OMAP-EHCI Host Controller driver
    [    2.048071] usbcore: registered new interface driver usbserial
    [    2.054273] mousedev: PS/2 mouse device common for all mice
    [    2.070459] i2c /dev entries driver
    [    2.074679] ov1063x 4-0037: ov1063x Product ID 0 Manufacturer ID 0
    [    2.080890] ov1063x 4-0037: ov1063x 4-0037 sensor driver registered !!
    [    2.088260] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    2.095377] vip 48970000.vip: loading firmware vpdma-1b8.bin
    [    2.101541] cal: Neither port is configured, no point in staying up
    [    2.111188] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    2.116045] vpe 489d0000.vpe: Device registered as /dev/video0
    [    2.122392] vip 48970000.vip: VPDMA firmware loaded
    [    2.127402] vip1-s1: Port A: Using subdev ov1063x 4-0037 for capture
    [    2.133988] vip1-s1: device registered as video1
    [    2.192713] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
    [    2.233097] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.239172] mmc0: MAN_BKOPS_EN bit is not set
    [    2.243751] usbcore: registered new interface driver usbhid
    [    2.249345] usbhid: USB HID core driver
    [    2.255009] hwspinlock_user gatemp: requested 10 hwspinlocks
    [    2.262417] NET: Registered protocol family 10
    [    2.277578] sit: IPv6 over IPv4 tunneling driver
    [    2.282822] NET: Registered protocol family 17
    [    2.287498] Key type dns_resolver registered
    [    2.291891] omap_voltage_late_init: Voltage driver support not added
    [    2.298852] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.305081] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.311315] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.317931] Power Management for TI OMAP4+ devices.
    [    2.323083] Registering SWP/SWPB emulation handler
    [    2.330733] dmm 4e000000.dmm: initialized all PAT entries
    [    2.356921] pinctrl-single 4a003400.pinmux: pin 4a003824.0 already requested by 4806a000.serial; cannot claim for 0-0058
    [    2.367918] mmc0: new high speed MMC card at address 0001
    [    2.373682] pinctrl-single 4a003400.pinmux: pin-265 (0-0058) status -22
    [    2.380329] pinctrl-single 4a003400.pinmux: could not request pin 265 (4a003824.0) from group tps65917_pins_default  on device pinctrl-single
    [    2.393226] palmas 0-0058: Error applying setting, reverse things back
    [    2.399846] palmas 0-0058: Irq flag is 0x00000000
    [    2.404617] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
    [    2.419443] mmcblk0boot0: mmc0:0001 R1J55A partition 1 128 KiB
    [    2.427161] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
    [    2.435730] mmcblk0boot1: mmc0:0001 R1J55A partition 2 128 KiB
    [    2.443449]  mmcblk0: p1 p2
    [    2.466585] OMAP DSS rev 6.1
    [    2.470376] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    2.478842] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    2.485591] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    2.522793] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.529028] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.535711] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.541919] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.553825] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.560487] mmc1: host does not support reading read-only switch, assuming write-enable
    [    2.568591] [drm] No driver support for vblank timestamp query.
    [    2.582433] mmc1: new SDHC card at address 1234
    [    2.589441] [drm] Enabling DMM ywrap scrolling
    [    2.604100] mmcblk1: mmc1:1234 SA04G 3.71 GiB
    [    2.605270]  mmcblk1: p1
    [    2.644960] Console: switching to colour frame buffer device 240x67
    [    2.649464] mmc2: host does not support reading read-only switch, assuming write-enable
    [    2.651387] mmc2: new high speed SDHC card at address 1234
    [    2.685211] mmcblk2: mmc2:1234 SA04G 3.71 GiB
    [    2.690046]  mmcblk2: p1 p2
    [    2.693112] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    2.722660] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [    2.728917] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    2.735578] hctosys: unable to open rtc device (rtc0)
    [    2.751260] aic_dvdd: disabling
    [    2.754503] evm_3v3_sd: disabling
    [    2.758161] ldo4: disabling
    [    3.645000] EXT4-fs (mmcblk2p2): recovery complete
    [    3.656067] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.664240] VFS: Mounted root (ext4 filesystem) on device 179:66.
    [    3.672703] devtmpfs: mounted
    [    3.675903] Freeing unused kernel memory: 356K (c08ff000 - c0958000)
    [    3.682282] This architecture does not have kernel memory protection.
    INIT: version 2.88 booting
    Starting udev
    [    4.288715] udevd[110]: starting version 182
    [    4.571795] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    4.696947]  remoteproc0: 58820000.ipu is available
    [    4.701870]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    4.997490]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.113179] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    5.119437]  remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
    [    5.127872] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    5.188909]  remoteproc0: failed to load dra7-ipu1-fw.xem4
    [    5.214854]  remoteproc1: 55020000.ipu is available
    [    5.219758]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    5.406383]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.493266] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    udevd[285]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[286]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    5.597556] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    5.605338] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    5.625848] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    5.663285] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    5.674303] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    5.709160] e1000e 0000:01:00.0: enabling device (0140 -> 0142)
    [    5.729460] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.772939] e1000e 0000:01:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
    [    5.834698]  remoteproc1: registered virtio0 (type 7)
    [    5.841455] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    udevd[318]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    5.901002] CAN device driver interface
    [    5.962777] e1000e 0000:01:00.0 0000:01:00.0 (uninitialized): Failed to initialize MSI-X interrupts.  Falling back to MSI interrupts.
    [    6.002408] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.130291] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    6.138139] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
    [    6.194056] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    6.203028] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    6.210861]  remoteproc2: 40800000.dsp is available
    udevd[360]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory[    6.275420] cpsw 48484000.ethernet: gpio request failed, ret -517
    udevd[361]: failed to execute '/etc/udev/scripts/mount.sh' 'etc/udev/scripts/mount.sh': No such file or directory
    [    6.288700] e1000e 0000:01:00.0 eth0: registered PHC clock
    [    6.320761]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    6.365369]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    6.381931] e1000e 0000:01:00.0 eth0: (PCI Express:2.5GT/s:Width x1) 88:88:88:88:87:88
    [    6.420885] e1000e 0000:01:00.0 eth0: Intel(R) PRO/1000 Network Connection
    [    6.433059] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    6.439553] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    6.479022]  remoteproc2: registered virtio1 (type 7)
    [    6.485626] e1000e 0000:01:00.0 eth0: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
    [    6.520736] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    6.868563]  remoteproc1: powering up 55020000.ipu
    [    6.883414]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3484972
    [    6.890785] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [    6.954367] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    6.963196] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    6.975970] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.002568] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    7.045464]  remoteproc1: remote processor 55020000.ipu is now up
    [    7.062706] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.068243] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
    [    7.078153] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.085155]  remoteproc2: powering up 40800000.dsp
    [    7.091138]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 929770
    [    7.116454] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    7.122664] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.129254] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x0 impl platform mode
    [    7.148287] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [    7.154177] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    7.160110] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    7.185851] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [    7.213329] scsi host0: ahci
    [    7.222746] ata1: DUMMY
    [    7.225640] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.232596] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=358)
    [    7.262761] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.283076] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [    7.292786] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.370487]  remoteproc2: remote processor 40800000.dsp is now up
    [    7.392904] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.398446] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x36
    [    7.412676] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.427127] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x37
    [    7.453633] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
    [    7.464149] rpmsg_rpc rpmsg0: probing service rpmsg-dce with src 1024 dst 59
    [    7.486199] rpmsg_rpc rpmsg3: probing service rpmsg-dce-dsp with src 1024 dst 59
    [    7.494265] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.502938] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.510856] rpmsg_rpc rpmsg3: published functions = 8
    [    7.531267] rpmsg_rpc rpmsg0: published functions = 8
    [    7.562523] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.769769] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.795528] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.801057] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    7.809912] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
    [    7.818834] xhci-hcd xhci-hcd.0.auto: irq 469, io mem 0x48890000
    [    7.825789] hub 1-0:1.0: USB hub found
    [    7.829582] hub 1-0:1.0: 1 port detected
    [    7.834019] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.840406] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.846174] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.852399] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    7.860194] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.869169] hub 2-0:1.0: USB hub found
    [    7.873001] hub 2-0:1.0: 1 port detected
    [    7.877312] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.883705] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.889229] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
    [    7.897269] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.903745] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
    [    7.912556] xhci-hcd xhci-hcd.1.auto: irq 470, io mem 0x488d0000
    [    7.919389] hub 3-0:1.0: USB hub found
    [    7.923219] hub 3-0:1.0: 1 port detected
    [    7.927532] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.933938] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.939454] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
    [    7.947445] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.953738] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.962678] hub 4-0:1.0: USB hub found
    [    7.966467] hub 4-0:1.0: 1 port detected
    [    7.970763] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    8.003102] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    8.043454] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
    taSrting Bootlog daemon: obotlogd.
    [    8.118121] random: dd urandom read with 59 bits of entropy available
    LASA: Restoring mixer settings...
    us/r/sbin/alsactl: load_state:1729: No soundcards found...
    hTu Sep  3 18:41:00 UTC 2015
    moapconf: powerdm_deinit(): cpu not supported!!!
    omapconf: clockm_deinit(): cpu not supported!!!
    /etc/rcS.d/S98_AB_auto_execution.sh: line 17: /proc/irq/301/smp_affinity: No such file or directory
    /usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
    /usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
    /usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio187/direction: No such file or directory
    INIT: Entering runlevel: 5
    Configuring network interfaces... [   10.372820] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    udhcpc (v1.22.1) started
    Sending discover...
    Sending discover...
    Sending discover...
    No lease, forking to background
    done.
    Starting system message bus: dbus.
    UIM SYSFS Node Not Found
    Starting telnet daemon.
    Starting tiipclad daemon
    GateMP support enabled on host
    Opened log file: lad.txt
    numProcessors = 5 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_dra7xx
    Starting rpcbind daemon...done.
    creating NFS state directory: done
    starting statd: done
    NFS daemon support not enabled in kernel
    Starting syslogd/klogd: done
    Starting thttpd.
    Enabling thermal zones...
    Stopping Bootlog daemon: bootlogd.
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~# ./debug_dss_clockdumps.sh
    =====================DSS clock script===================
    Dumps internal clocks and muxes of DSS
    CTRL_CORE_DSS_PLL_CONTROL (0x4a002538) = 0x000002AF
    video1 PLL :  Disabled
    video2 PLL :  Disabled
    HDMI   PLL :  Disabled
    DSI1_A_CLK mux : DPLL HDMI
    DSI1_B_CLK mux : DPLL video2
    DSI1_C_CLK mux : DPLL Video2
    DSS_CTRL (0x58000040) = 0x00000000
     2: LCD1 clk switch :  DSS clk
     3: LCD2 clk switch :  DSS clk
    10: LCD3 clk switch :  DSS clk
     1: func clk switch :  DSS clk
    13: DPI1 output     :  HDMI
    Clock O/P of MUXes
    DSI1_A_CLK :  0
    DSI1_B_CLK :  0
    DSI1_C_CLK :  0
     2: LCD1 clk :  69000000
     3: LCD2 clk :  69000000
    10: LCD3 clk :  69000000
     1: func clk :  69000000
    LCD1 logic clk(/ 1 ) :  69000000  pix clk(/ 2 ) :  34500000
    LCD2 logic clk(/ 4 ) :  17250000  pix clk(/ 1 ) :  17250000
    LCD3 logic clk(/ 1 ) :  69000000  pix clk(/ 1 ) :  69000000
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~# cat /proc/partitions
    major minor  #blocks  name
       1        0       4096 ram0
       1        1       4096 ram1
       1        2       4096 ram2
       1        3       4096 ram3
       1        4       4096 ram4
       1        5       4096 ram5
       1        6       4096 ram6
       1        7       4096 ram7
       1        8       4096 ram8
       1        9       4096 ram9
       1       10       4096 ram10
       1       11       4096 ram11
       1       12       4096 ram12
       1       13       4096 ram13
       1       14       4096 ram14
       1       15       4096 ram15
     179        0    7634944 mmcblk0
     179        1      65536 mmcblk0p1
     179        2    7568384 mmcblk0p2
     179       32        128 mmcblk0boot1
     179       16        128 mmcblk0boot0
     179       48    3887104 mmcblk1
     179       49    3886080 mmcblk1p1
     179       64    3887104 mmcblk2
     179       65      63488 mmcblk2p1
     179       66    3822592 mmcblk2p2
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~# cat /proc/device-tree/model
    TI DRA722 Louis 20170531 18:10root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    root@wnc-j6:~#
    These are DTS files that I updated
     * Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    #include "dra72-evm-common.dtsi"
    #include "dt-bindings/pinmux/mux_dra7xx.h"
    	model = "TI DRA722 Louis 20170531 18:10";
    	aliases {
    		display0 = &hdmi0;
    		display1 = &lcd2;
    		sound1 = &hdmi;
    	lcd2: display@2 {
    		compatible = "omapdss,panel-dpi", "panel-dpi";
    		status = "ok";
    		label = "lcd";
    		//enable-gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>;
    		// 1920x1200@60
    		// 1920x1200@30
    		// 1920x1080@60
    		// 1920x1080@30
    		// 1280x720@30
    		// 800x480@30
    		// 1920x1200@60
    		// (1920+226)*(1200+32)*60=158632320
    		panel-timing {
    				clock-frequency = <158000000>;
    				hactive = <1920>;
    				vactive = <1200>;
    				hfront-porch = <210>;
    				hback-porch = <16>;
    				hsync-len = <30>;
    				vback-porch = <10>;
    				vfront-porch = <22>;
    				vsync-len = <13>;
    				hsync-active = <0>;
    				vsync-active = <0>;
    				de-active = <1>;
    				pixelclk-active = <1>;
    		// 1920x1200@30
    		// (1920+226)*(1200+32)*30=79316160
    		panel-timing {
    				clock-frequency = <79000000>;
    				hactive = <1920>;
    				vactive = <1200>;
    				hback-porch = <16>;
    				hsync-len = <30>;
    				vback-porch = <10>;
    				vsync-len = <13>;
    				hsync-active = <0>;
    				vsync-active = <0>;
    				de-active = <1>;
    		// 1920x1080@60
    		// (1920+226)*(1080+32)*60=142181120
    		panel-timing {
    				clock-frequency = <142000000>;
    				hactive = <1920>;
    				vactive = <1080>;
    				hback-porch = <16>;
    				hsync-len = <30>;
    				vback-porch = <10>;
    				vsync-len = <13>;
    				hsync-active = <0>;
    				vsync-active = <0>;
    				de-active = <1>;
    		// 1920x1080@30
    		// (1920+226)*(1080+32)*30=71590560
    		panel-timing {
    				clock-frequency = <72000000>;
    				hactive = <1920>;
    				vactive = <1080>;
    				hback-porch = <16>;
    				hsync-len = <30>;
    				vback-porch = <10>;
    				vsync-len = <13>;
    				hsync-active = <0>;
    				vsync-active = <0>;
    				de-active = <1>;
    		// 1280x720@30
    		// (1280+226)*(720+32)*30=33975360
    		panel-timing {
    				clock-frequency = <34000000>;
    				hactive = <1280>;
    				vactive = <720>;
    				hback-porch = <16>;
    				hsync-len = <30>;
    				vback-porch = <10>;
    				vsync-len = <13>;
    				hsync-active = <0>;
    				vsync-active = <0>;
    				de-active = <1>;
    		// 800x480@30
    		// (800+226)*(480+32)*30=15759360
    		panel-timing {
    				clock-frequency = <16000000>;
    				hactive = <800>;
    				vactive = <480>;
    				hback-porch = <16>;
    				hsync-len = <30>;
    				vback-porch = <10>;
    				vsync-len = <13>;
    				hsync-active = <0>;
    				vsync-active = <0>;
    				de-active = <1>;
    		port {
    			lcd2_in: endpoint {
    				remote-endpoint = <&dpi2_out>;
    	memory {
    		device_type = "memory";
    		reg = <0x0 0x80000000 0x0 0x40000000>; /* 1024 MB */
    	reserved_mem: reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		ipu2_cma_pool: ipu2_cma@95800000 {
    			compatible = "shared-dma-pool";
    			reg = <0x0 0x95800000 0x0 0x3800000>;
    			reusable;
    			status = "okay";
    		dsp1_cma_pool: dsp1_cma@99000000 {
    			reg = <0x0 0x99000000 0x0 0x4000000>;
    			reusable;
    			status = "okay";
    		ipu1_cma_pool: ipu1_cma@9d000000 {
    			reg = <0x0 0x9d000000 0x0 0x2000000>;
    			reusable;
    			status = "okay";
    &tps65917_regulators {
    	ldo2_reg: ldo2 {
    		/* LDO2_OUT --> TP1017 (UNUSED)  */
    		regulator-name = "ldo2";
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-allow-bypass;
    &dra7_pmx_core {
            vin2a_pins: pinmux_vin2a_pins {
    		pinctrl-single,pins = <
    			0x23c	(PIN_INPUT | MUX_MODE4)	//	0x23C gpio5_15 V1 mdio_mclk.vin2a_clk0
    			0x240	(PIN_INPUT | MUX_MODE4)	//	0x240	 gpio5_16 U4  mdio_d.vin2a_d0
    			0x248	(PIN_INPUT | MUX_MODE4)	//	0x248 gpio5_18 V2 uart3_rxd.vin2a_d1
    			0x24c	(PIN_INPUT | MUX_MODE4)	//	0x24C	gpio5_19 Y1 uart3_txd.vin2a_d2
    			0x250	(PIN_INPUT | MUX_MODE4)	//	0x250	gpio5_20 W9 rgmii0_txc.vin2a_d3
    			0x254	(PIN_INPUT | MUX_MODE4)	//	0x254 gpio5_21 V9 rgmii0_txctl.vin2a_d4
    			0x268	(PIN_INPUT | MUX_MODE4)	//	0x268 U5 gpio5_26 rgmii_rxc.vin2a_d5
    			0x26c	(PIN_INPUT | MUX_MODE4)	//	0x26C gpio5_27 V5 rgmii0_rxctl.vin2a_d6
    			0x270	(PIN_INPUT | MUX_MODE4)	//	0x270 gpio5_28 V4 rgmii0_rxd3.vin2a_d7
    	vout3_pins: pinmux_vout3_pins {
    			GPMC_A0	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d16 GPIO7_3 R6	 */
    			GPMC_A1   (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A1.vout3_d17	 */
    			GPMC_A2	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A2.vout3_d18  */
    			GPMC_A3   (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A3.vout3_d18 */
    			GPMC_A4	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A4.vout3_d20  */
    			GPMC_A5	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A5.vout3_d21	 */
    			GPMC_A6	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A6.vout3_d22	 */
    			GPMC_A7	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A7.vout3_d23 */
    			GPMC_AD8	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD8.vout3_d8	 */
    			GPMC_AD9  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD9.vout3_d9	 */
    			GPMC_AD10 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD10.vout3_d10  */
    			GPMC_AD11 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD11.vout3_d11	 */
    			GPMC_AD12 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD12.vout3_d12  */
    			GPMC_AD13 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD13.vout3_d13	 */
    			GPMC_AD14	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD14.vout3_d14	 */
    			GPMC_AD15	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD15.vout3_d15 */
    			GPMC_AD0	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d0	 */
    			GPMC_AD1  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d1	 */
    			GPMC_AD2	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d2  */
    			GPMC_AD3	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d3	 */
    			GPMC_AD4	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d4  */
    			GPMC_AD5	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d5	 */
    			GPMC_AD6	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d6	 */
    			GPMC_AD7	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d7	 */
    			GPMC_A11	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A11.vout3_fld	 */
    			GPMC_A10	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A10.vout3_de	 */
    			GPMC_A8	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A8.vout3_hsync	 */
    			GPMC_A9	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A9.vout3_vsync	 */
    			GPMC_CS3	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_CS3.vout3_clk	 */
    			VIN2A_D9	(PIN_OUTPUT | MUX_MODE14)	/* VIN2A_D9.gpio4_10  DISP_RESETQ	 */
    	uart1_pins: uart1_pins {
    			// i2c_3
    			GPMC_ADVN_ALE (PIN_INPUT | MUX_MODE8)	/* gpmc_advn_ale.i2c3_sda -> 8 */
    			GPMC_CLK      (PIN_INPUT | MUX_MODE8)	/* gpmc_clk.i2c3_scl -> 8 */
    			// i2c_4
    			MMC1_SDCD (PIN_INPUT | MUX_MODE4)  		/* mmc1_sdcd.i2c4_sda -> 4 */
    			MMC1_SDWP (PIN_INPUT | MUX_MODE4)  		/* mmc1_sdwp.i2c4_scl -> 4 */
    			// i2c_5
    			MCASP1_AXR0 (PIN_INPUT | MUX_MODE10)	/* mcasp1_axr0.i2c5_sda -> 10 */
    			MCASP1_AXR1 (PIN_INPUT | MUX_MODE10)	/* mcasp1_axr1.i2c5_scl -> 10 */
    			// spi 1.0, 1.1, 1.3
    			SPI1_SCLK	(PIN_INPUT | MUX_MODE0)	/*	0x3A4	*/
    			SPI1_D1		(PIN_INPUT | MUX_MODE0)	/*	0x3A8	*/
    			SPI1_D0		(PIN_INPUT | MUX_MODE0)	/*	0x3AC	*/
    			SPI1_CS0	(PIN_INPUT | MUX_MODE0)	/*	0x3B0	*/
    			SPI1_CS1	(PIN_INPUT | MUX_MODE0)	/*	0x3B4	*/
    			SPI1_CS3	(PIN_INPUT | MUX_MODE0)	/*	0x3BC	*/
    			// spi 2.0
    			SPI2_SCLK	( PIN_INPUT | MUX_MODE0 )	/*	0x3C0	*/
    			SPI2_D1		( PIN_INPUT | MUX_MODE0 )	/*	0x3C4	*/
    			SPI2_D0		( PIN_INPUT | MUX_MODE0 )	/*	0x3C8	*/
    			SPI2_CS0	( PIN_INPUT | MUX_MODE0 )	/*	0x3CC	*/
    			// spi 3.0
    			VOUT1_CLK		(PIN_INPUT | MUX_MODE8)	// DAB_SPI_CS		GPIO4_19
    			VOUT1_DE		(PIN_INPUT | MUX_MODE8)	// DAB_SPI_MISO	GPIO4_20
    			VOUT1_HSYNC	(PIN_INPUT | MUX_MODE8)	// DAB_SPI_MOSI	GPIO4_22
    			VOUT1_VSYNC	(PIN_INPUT | MUX_MODE8)	// DAB_SPI_SCK		GPIO4_23
    			RGMII0_RXD2	(PIN_INPUT | MUX_MODE14)	/*	0x274	*/
    			VIN2A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x158	*/
    		//GPMC_AD0	(PIN_INPUT | MUX_MODE14)	/*	0x000	*/
    		//GPMC_AD1	(PIN_INPUT | MUX_MODE14)	/*	0x004	*/
    		//GPMC_AD2	(PIN_INPUT | MUX_MODE14)	/*	0x008	*/
    		//GPMC_AD3	(PIN_INPUT | MUX_MODE14)	/*	0x00C	*/
    		//GPMC_AD4	(PIN_INPUT | MUX_MODE14)	/*	0x010	*/
    		//GPMC_AD5	(PIN_INPUT | MUX_MODE14)	/*	0x014	*/
    		//GPMC_AD6	(PIN_INPUT | MUX_MODE14)	/*	0x018	*/
    		//GPMC_AD7	(PIN_INPUT | MUX_MODE14)	/*	0x01C	*/
    		//GPMC_AD8	(PIN_INPUT | MUX_MODE14)	/*	0x020	*/
    		//GPMC_AD9	(PIN_INPUT | MUX_MODE14)	/*	0x024	*/
    		//GPMC_AD10	(PIN_INPUT | MUX_MODE14)	/*	0x028	*/
    		//GPMC_AD11	(PIN_INPUT | MUX_MODE14)	/*	0x02C	*/
    		//GPMC_AD12	(PIN_INPUT | MUX_MODE14)	/*	0x030	*/
    		//GPMC_AD13	(PIN_INPUT | MUX_MODE14)	/*	0x034	*/
    		//GPMC_AD14	(PIN_INPUT | MUX_MODE14)	/*	0x038	*/
    		//GPMC_AD15	(PIN_INPUT | MUX_MODE14)	/*	0x03C	*/
    		//GPMC_A0	(PIN_INPUT | MUX_MODE14)	/*	0x040	*/
    		//GPMC_A1	(PIN_INPUT | MUX_MODE14)	/*	0x044	*/
    		//GPMC_A2	(PIN_INPUT | MUX_MODE14)	/*	0x048	*/
    		//GPMC_A3	(PIN_INPUT | MUX_MODE14)	/*	0x04C	*/
    		//GPMC_A4	(PIN_INPUT | MUX_MODE14)	/*	0x050	*/
    		//GPMC_A5	(PIN_INPUT | MUX_MODE14)	/*	0x054	*/
    		//GPMC_A6	(PIN_INPUT | MUX_MODE14)	/*	0x058	*/
    		//GPMC_A7	(PIN_INPUT | MUX_MODE14)	/*	0x05C	*/
    		//GPMC_A8	(PIN_INPUT | MUX_MODE14)	/*	0x060	*/
    		//GPMC_A9	(PIN_INPUT | MUX_MODE14)	/*	0x064	*/
    		//GPMC_A10	(PIN_INPUT | MUX_MODE14)	/*	0x068	*/
    		//GPMC_A11	(PIN_INPUT | MUX_MODE14)	/*	0x06C	*/
    		GPMC_A12	(PIN_INPUT | MUX_MODE14)	/*	0x070	*/
    		GPMC_A13	(PIN_INPUT | MUX_MODE14)	/*	0x074	*/
    		GPMC_A14	(PIN_INPUT | MUX_MODE14)	/*	0x078	*/
    		GPMC_A15	(PIN_INPUT | MUX_MODE14)	/*	0x07C	*/
    		GPMC_A16	(PIN_INPUT | MUX_MODE14)	/*	0x080	*/
    		GPMC_A17	(PIN_INPUT | MUX_MODE14)	/*	0x084	*/
    		GPMC_A18	(PIN_INPUT | MUX_MODE14)	/*	0x088	*/
    		//GPMC_A19	(PIN_INPUT | MUX_MODE14)	/*	0x08C	*/
    		//GPMC_A20	(PIN_INPUT | MUX_MODE14)	/*	0x090	*/
    		//GPMC_A21	(PIN_INPUT | MUX_MODE14)	/*	0x094	*/
    		//GPMC_A22	(PIN_INPUT | MUX_MODE14)	/*	0x098	*/
    		//GPMC_A23	(PIN_INPUT | MUX_MODE14)	/*	0x09C	*/
    		//GPMC_A24	(PIN_INPUT | MUX_MODE14)	/*	0x0A0	*/
    		//GPMC_A25	(PIN_INPUT | MUX_MODE14)	/*	0x0A4	*/
    		//GPMC_A26	(PIN_INPUT | MUX_MODE14)	/*	0x0A8	*/
    		//GPMC_A27	(PIN_INPUT | MUX_MODE14)	/*	0x0AC	*/
    		//GPMC_CS1	(PIN_INPUT | MUX_MODE14)	/*	0x0B0	*/
    		GPMC_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x0B4	*/
    		GPMC_CS2	(PIN_INPUT | MUX_MODE14)	/*	0x0B8	*/
    		//GPMC_CS3	(PIN_INPUT | MUX_MODE14)	/*	0x0BC	*/
    		//GPMC_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x0C0	*/
    		//GPMC_ADVN_ALE	(PIN_INPUT | MUX_MODE14)	/*	0x0C4	*/
    		GPMC_OEN_REN	(PIN_INPUT | MUX_MODE14)	/*	0x0C8	*/
    		GPMC_WEN	(PIN_INPUT | MUX_MODE14)	/*	0x0CC	*/
    		GPMC_BEN0	(PIN_INPUT | MUX_MODE14)	/*	0x0D0	*/
    		GPMC_BEN1	(PIN_INPUT | MUX_MODE14)	/*	0x0D4	*/
    		GPMC_WAIT0	(PIN_INPUT | MUX_MODE14)	/*	0x0D8	*/
    		VIN1A_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x0DC	*/
    		VIN1B_CLK1	(PIN_INPUT | MUX_MODE14)	/*	0x0E0	*/
    		VIN1A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x0E4	*/
    		VIN1A_FLD0	(PIN_INPUT | MUX_MODE14)	/*	0x0E8	*/
    		VIN1A_HSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x0EC	*/
    		VIN1A_VSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x0F0	*/
    		VIN1A_D0	(PIN_INPUT | MUX_MODE14)	/*	0x0F4	*/
    		VIN1A_D1	(PIN_INPUT | MUX_MODE14)	/*	0x0F8	*/
    		VIN1A_D2	(PIN_INPUT | MUX_MODE14)	/*	0x0FC	*/
    		VIN1A_D3	(PIN_INPUT | MUX_MODE14)	/*	0x100	*/
    		VIN1A_D4	(PIN_INPUT | MUX_MODE14)	/*	0x104	*/
    		VIN1A_D5	(PIN_INPUT | MUX_MODE14)	/*	0x108	*/
    		VIN1A_D6	(PIN_INPUT | MUX_MODE14)	/*	0x10C	*/
    		VIN1A_D7	(PIN_INPUT | MUX_MODE14)	/*	0x110	*/
    		VIN1A_D8	(PIN_INPUT | MUX_MODE14)	/*	0x114	*/
    		VIN1A_D9	(PIN_INPUT | MUX_MODE14)	/*	0x118	*/
    		VIN1A_D10	(PIN_INPUT | MUX_MODE14)	/*	0x11C	*/
    		VIN1A_D11	(PIN_INPUT | MUX_MODE14)	/*	0x120	*/
    		VIN1A_D12	(PIN_INPUT | MUX_MODE14)	/*	0x124	*/
    		VIN1A_D13	(PIN_INPUT | MUX_MODE14)	/*	0x128	*/
    		VIN1A_D14	(PIN_INPUT | MUX_MODE14)	/*	0x12C	*/
    		VIN1A_D15	(PIN_INPUT | MUX_MODE14)	/*	0x130	*/
    		VIN1A_D16	(PIN_INPUT | MUX_MODE14)	/*	0x134	*/
    		VIN1A_D17	(PIN_INPUT | MUX_MODE14)	/*	0x138	*/
    		VIN1A_D18	(PIN_INPUT | MUX_MODE14)	/*	0x13C	*/
    		VIN1A_D19	(PIN_INPUT | MUX_MODE14)	/*	0x140	*/
    		VIN1A_D20	(PIN_INPUT | MUX_MODE14)	/*	0x144	*/
    		VIN1A_D21	(PIN_INPUT | MUX_MODE14)	/*	0x148	*/
    		VIN1A_D22	(PIN_INPUT | MUX_MODE14)	/*	0x14C	*/
    		VIN1A_D23	(PIN_INPUT | MUX_MODE14)	/*	0x150	*/
    		VIN2A_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x154	*/
    //		VIN2A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x158	*/
    		VIN2A_FLD0	(PIN_INPUT | MUX_MODE14)	/*	0x15C	*/
    		VIN2A_HSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x160	*/
    		VIN2A_VSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x164	*/
    		VIN2A_D0	(PIN_INPUT | MUX_MODE14)	/*	0x168	*/
    		VIN2A_D1	(PIN_INPUT | MUX_MODE14)	/*	0x16C	*/
    		//VIN2A_D2	(PIN_INPUT | MUX_MODE14)	/*	0x170	*/
    		//VIN2A_D3	(PIN_INPUT | MUX_MODE14)	/*	0x174	*/
    		//VIN2A_D4	(PIN_INPUT | MUX_MODE14)	/*	0x178	*/
    		//VIN2A_D5	(PIN_INPUT | MUX_MODE14)	/*	0x17C	*/
    		VIN2A_D6	(PIN_INPUT | MUX_MODE14)	/*	0x180	*/
    		VIN2A_D7	(PIN_INPUT | MUX_MODE14)	/*	0x184	*/
    		//VIN2A_D8	(PIN_INPUT | MUX_MODE14)	/*	0x188	*/
    		//VIN2A_D9	(PIN_INPUT | MUX_MODE14)	/*	0x18C	*/
    		VIN2A_D10	(PIN_INPUT | MUX_MODE14)	/*	0x190	*/
    		VIN2A_D11	(PIN_INPUT | MUX_MODE14)	/*	0x194	*/
    		VIN2A_D12	(PIN_INPUT | MUX_MODE14)	/*	0x198	*/
    		VIN2A_D13	(PIN_INPUT | MUX_MODE14)	/*	0x19C	*/
    		VIN2A_D14	(PIN_INPUT | MUX_MODE14)	/*	0x1A0	*/
    		VIN2A_D15	(PIN_INPUT | MUX_MODE14)	/*	0x1A4	*/
    		VIN2A_D16	(PIN_INPUT | MUX_MODE14)	/*	0x1A8	*/
    		VIN2A_D17	(PIN_INPUT | MUX_MODE14)	/*	0x1AC	*/
    		VIN2A_D18	(PIN_INPUT | MUX_MODE14)	/*	0x1B0	*/
    		VIN2A_D19	(PIN_INPUT | MUX_MODE14)	/*	0x1B4	*/
    		VIN2A_D20	(PIN_INPUT | MUX_MODE14)	/*	0x1B8	*/
    		VIN2A_D21	(PIN_INPUT | MUX_MODE14)	/*	0x1BC	*/
    		VIN2A_D22	(PIN_INPUT | MUX_MODE14)	/*	0x1C0	*/
    		VIN2A_D23	(PIN_INPUT | MUX_MODE14)	/*	0x1C4	*/
    		//VOUT1_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x1C8	*/
    		//VOUT1_DE	(PIN_INPUT | MUX_MODE14)	/*	0x1CC	*/
    		VOUT1_FLD	(PIN_INPUT | MUX_MODE14)	/*	0x1D0	*/
    		//VOUT1_HSYNC	(PIN_INPUT | MUX_MODE14)	/*	0x1D4	*/
    		//VOUT1_VSYNC	(PIN_INPUT | MUX_MODE14)	/*	0x1D8	*/
    		//VOUT1_D0	(PIN_INPUT | MUX_MODE14)	/*	0x1DC	*/	// uart5
    		//VOUT1_D1	(PIN_INPUT | MUX_MODE14)	/*	0x1E0	*/	// uart5
    		VOUT1_D2	(PIN_INPUT | MUX_MODE14)	/*	0x1E4	*/
    		VOUT1_D3	(PIN_INPUT | MUX_MODE14)	/*	0x1E8	*/
    		VOUT1_D4	(PIN_INPUT | MUX_MODE14)	/*	0x1EC	*/
    		VOUT1_D5	(PIN_INPUT | MUX_MODE14)	/*	0x1F0	*/
    		VOUT1_D6	(PIN_INPUT | MUX_MODE14)	/*	0x1F4	*/
    		VOUT1_D7	(PIN_INPUT | MUX_MODE14)	/*	0x1F8	*/
    		//VOUT1_D8	(PIN_INPUT | MUX_MODE14)	/*	0x1FC	*/	// uart6
    		//VOUT1_D9	(PIN_INPUT | MUX_MODE14)	/*	0x200	*/	// uart6
    		VOUT1_D10	(PIN_INPUT | MUX_MODE14)	/*	0x204	*/
    		VOUT1_D11	(PIN_INPUT | MUX_MODE14)	/*	0x208	*/
    		VOUT1_D12	(PIN_INPUT | MUX_MODE14)	/*	0x20C	*/
    		VOUT1_D13	(PIN_INPUT | MUX_MODE14)	/*	0x210	*/
    		VOUT1_D14	(PIN_INPUT | MUX_MODE14)	/*	0x214	*/
    		VOUT1_D15	(PIN_INPUT | MUX_MODE14)	/*	0x218	*/
    		VOUT1_D16	(PIN_INPUT | MUX_MODE14)	/*	0x21C	*/
    		VOUT1_D17	(PIN_INPUT | MUX_MODE14)	/*	0x220	*/
    		VOUT1_D18	(PIN_INPUT | MUX_MODE14)	/*	0x224	*/
    		VOUT1_D19	(PIN_INPUT | MUX_MODE14)	/*	0x228	*/
    		VOUT1_D20	(PIN_INPUT | MUX_MODE14)	/*	0x22C	*/
    		VOUT1_D21	(PIN_INPUT | MUX_MODE14)	/*	0x230	*/
    		VOUT1_D22	(PIN_INPUT | MUX_MODE14)	/*	0x234	*/
    		VOUT1_D23	(PIN_INPUT | MUX_MODE14)	/*	0x238	*/
    //		MDIO_MCLK	(PIN_INPUT | MUX_MODE14)	/*	0x23C	*/
    //		MDIO_D	(PIN_INPUT | MUX_MODE14)	/*	0x240	*/
    		RMII_MHZ_50_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x244	*/
    //		UART3_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x248	*/
    //		UART3_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x24C	*/
    //		RGMII0_TXC	(PIN_INPUT | MUX_MODE14)	/*	0x250	*/
    //		RGMII0_TXCTL	(PIN_INPUT | MUX_MODE14)	/*	0x254	*/
    		RGMII0_TXD3	(PIN_INPUT | MUX_MODE14)	/*	0x258	*/
    		RGMII0_TXD2	(PIN_INPUT | MUX_MODE14)	/*	0x25C	*/
    		RGMII0_TXD1	(PIN_INPUT | MUX_MODE14)	/*	0x260	*/
    		RGMII0_TXD0	(PIN_INPUT | MUX_MODE14)	/*	0x264	*/
    //		RGMII0_RXC	(PIN_INPUT | MUX_MODE14)	/*	0x268	*/
    //		RGMII0_RXCTL	(PIN_INPUT | MUX_MODE14)	/*	0x26C	*/
    //		RGMII0_RXD3	(PIN_INPUT | MUX_MODE14)	/*	0x270	*/
    //		RGMII0_RXD2	(PIN_INPUT | MUX_MODE14)	/*	0x274	*/
    		RGMII0_RXD1	(PIN_INPUT | MUX_MODE14)	/*	0x278	*/
    		RGMII0_RXD0	(PIN_INPUT | MUX_MODE14)	/*	0x27C	*/
    		USB1_DRVVBUS	(PIN_INPUT | MUX_MODE14)	/*	0x280	*/
    		USB2_DRVVBUS	(PIN_INPUT | MUX_MODE14)	/*	0x284	*/
    		GPIO6_14	(PIN_INPUT | MUX_MODE14)	/*	0x288	*/
    		GPIO6_15	(PIN_INPUT | MUX_MODE14)	/*	0x28C	*/
    		GPIO6_16	(PIN_INPUT | MUX_MODE14)	/*	0x290	*/
    		XREF_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x294	*/
    		XREF_CLK1	(PIN_INPUT | MUX_MODE14)	/*	0x298	*/
    		XREF_CLK2	(PIN_INPUT | MUX_MODE14)	/*	0x29C	*/
    		XREF_CLK3	(PIN_INPUT | MUX_MODE14)	/*	0x2A0	*/
    		MCASP1_ACLKX	(PIN_INPUT | MUX_MODE14)	/*	0x2A4	*/
    		MCASP1_FSX	(PIN_INPUT | MUX_MODE14)	/*	0x2A8	*/
    		MCASP1_ACLKR	(PIN_INPUT | MUX_MODE14)	/*	0x2AC	*/
    		MCASP1_FSR	(PIN_INPUT | MUX_MODE14)	/*	0x2B0	*/
    		//MCASP1_AXR0	(PIN_INPUT | MUX_MODE14)	/*	0x2B4	*/
    		//MCASP1_AXR1	(PIN_INPUT | MUX_MODE14)	/*	0x2B8	*/
    		MCASP1_AXR2	(PIN_INPUT | MUX_MODE14)	/*	0x2BC	*/
    		MCASP1_AXR3	(PIN_INPUT | MUX_MODE14)	/*	0x2C0	*/
    		MCASP1_AXR4	(PIN_INPUT | MUX_MODE14)	/*	0x2C4	*/
    		MCASP1_AXR5	(PIN_INPUT | MUX_MODE14)	/*	0x2C8	*/
    		MCASP1_AXR6	(PIN_INPUT | MUX_MODE14)	/*	0x2CC	*/
    		MCASP1_AXR7	(PIN_INPUT | MUX_MODE14)	/*	0x2D0	*/
    		MCASP1_AXR8	(PIN_INPUT | MUX_MODE14)	/*	0x2D4	*/
    		MCASP1_AXR9	(PIN_INPUT | MUX_MODE14)	/*	0x2D8	*/
    		MCASP1_AXR10	(PIN_INPUT | MUX_MODE14)	/*	0x2DC	*/
    		MCASP1_AXR11	(PIN_INPUT | MUX_MODE14)	/*	0x2E0	*/
    		MCASP1_AXR12	(PIN_INPUT | MUX_MODE14)	/*	0x2E4	*/
    		MCASP1_AXR13	(PIN_INPUT | MUX_MODE14)	/*	0x2E8	*/
    		MCASP1_AXR14	(PIN_INPUT | MUX_MODE14)	/*	0x2EC	*/
    		MCASP1_AXR15	(PIN_INPUT | MUX_MODE14)	/*	0x2F0	*/
    		MCASP2_AXR2	(PIN_INPUT | MUX_MODE14)	/*	0x30C	*/
    		MCASP2_AXR3	(PIN_INPUT | MUX_MODE14)	/*	0x310	*/
    		MCASP2_AXR4	(PIN_INPUT | MUX_MODE14)	/*	0x314	*/
    		MCASP2_AXR5	(PIN_INPUT | MUX_MODE14)	/*	0x318	*/
    		MCASP2_AXR6	(PIN_INPUT | MUX_MODE14)	/*	0x31C	*/
    		MCASP2_AXR7	(PIN_INPUT | MUX_MODE14)	/*	0x320	*/
    		MCASP3_ACLKX	(PIN_INPUT | MUX_MODE14)	/*	0x324	*/
    		MCASP3_FSX	(PIN_INPUT | MUX_MODE14)	/*	0x328	*/
    		//MMC1_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x354	*/
    		//MMC1_CMD	(PIN_INPUT | MUX_MODE14)	/*	0x358	*/
    		//MMC1_DAT0	(PIN_INPUT | MUX_MODE14)	/*	0x35C	*/
    		//MMC1_DAT1	(PIN_INPUT | MUX_MODE14)	/*	0x360	*/
    		//MMC1_DAT2	(PIN_INPUT | MUX_MODE14)	/*	0x364	*/
    		//MMC1_DAT3	(PIN_INPUT | MUX_MODE14)	/*	0x368	*/
    		//MMC1_SDCD	(PIN_INPUT | MUX_MODE14)	/*	0x36C	*/
    		//MMC1_SDWP	(PIN_INPUT | MUX_MODE14)	/*	0x370	*/
    		//ulpi
    		//GPIO6_10	(PIN_INPUT | MUX_MODE14)	/*	0x374	*/
    		//GPIO6_11	(PIN_INPUT | MUX_MODE14)	/*	0x378	*/
    		//MMC3_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x37C	*/
    		//MMC3_CMD	(PIN_INPUT | MUX_MODE14)	/*	0x380	*/
    		//MMC3_DAT0	(PIN_INPUT | MUX_MODE14)	/*	0x384	*/
    		//MMC3_DAT1	(PIN_INPUT | MUX_MODE14)	/*	0x388	*/
    		//MMC3_DAT2	(PIN_INPUT | MUX_MODE14)	/*	0x38C	*/
    		//MMC3_DAT3	(PIN_INPUT | MUX_MODE14)	/*	0x390	*/
    		//MMC3_DAT4	(PIN_INPUT | MUX_MODE14)	/*	0x394	*/
    		//MMC3_DAT5	(PIN_INPUT | MUX_MODE14)	/*	0x398	*/
    		//MMC3_DAT6	(PIN_INPUT | MUX_MODE14)	/*	0x39C	*/
    		//MMC3_DAT7	(PIN_INPUT | MUX_MODE14)	/*	0x3A0	*/
    		//SPI1_SCLK	(PIN_INPUT | MUX_MODE14)	/*	0x3A4	*/
    		//SPI1_D1	(PIN_INPUT | MUX_MODE14)	/*	0x3A8	*/
    		//SPI1_D0	(PIN_INPUT | MUX_MODE14)	/*	0x3AC	*/
    		//SPI1_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x3B0	*/
    		//SPI1_CS1	(PIN_INPUT | MUX_MODE14)	/*	0x3B4	*/
    		SPI1_CS2	(PIN_INPUT | MUX_MODE14)	/*	0x3B8	*/
    		//SPI1_CS3	(PIN_INPUT | MUX_MODE14)	/*	0x3BC	*/
    		//SPI2_SCLK	(PIN_INPUT | MUX_MODE14)	/*	0x3C0	*/
    		//SPI2_D1	(PIN_INPUT | MUX_MODE14)	/*	0x3C4	*/
    		//SPI2_D0	(PIN_INPUT | MUX_MODE14)	/*	0x3C8	*/
    		//SPI2_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x3CC	*/
    		DCAN1_TX	(PIN_INPUT | MUX_MODE14)	/*	0x3D0	*/
    		DCAN1_RX	(PIN_INPUT | MUX_MODE14)	/*	0x3D4	*/
    		DCAN2_TX	(PIN_INPUT | MUX_MODE14)	/*	0x3D8	*/
    		DCAN2_RX	(PIN_INPUT | MUX_MODE14)	/*	0x3DC	*/
    		UART1_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x3E0	*/
    		UART1_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x3E4	*/
    		//UART1_CTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3E8	*/
    		//UART1_RTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3EC	*/
    		//UART2_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x3F0	*/
    		//UART2_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x3F4	*/
    		//UART2_CTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3F8	*/
    		//UART2_RTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3FC	*/
    		WAKEUP0	(PIN_INPUT | MUX_MODE14)	/*	0x418	*/
    		WAKEUP1	(PIN_INPUT | MUX_MODE14)	/*	0x41C	*/
    		WAKEUP2	(PIN_INPUT | MUX_MODE14)	/*	0x420	*/
    		WAKEUP3	(PIN_INPUT | MUX_MODE14)	/*	0x424	*/
    		TDI	(PIN_INPUT | MUX_MODE14)	/*	0x434	*/
    		TDO	(PIN_INPUT | MUX_MODE14)	/*	0x438	*/
    		TCLK	(PIN_INPUT | MUX_MODE14)	/*	0x43C	*/
    		TRSTN	(PIN_INPUT | MUX_MODE14)	/*	0x440	*/
    		RTCK	(PIN_INPUT | MUX_MODE14)	/*	0x444	*/
    		EMU2	(PIN_INPUT | MUX_MODE14)	/*	0x450	*/
    		EMU3	(PIN_INPUT | MUX_MODE14)	/*	0x454	*/
    	uart3_pins_default: pinmux_uart3_pins {
    			0x34c (PIN_INPUT | MUX_MODE4) /* mcasp5_axr0.uart3_rxd */
    			0x350 (PIN_OUTPUT | MUX_MODE4) /* mcasp5_axr1.uart3_txd */
    	uart5_pins_default: pinmux_uart5_pins {
    			VOUT1_D0 (WAKEUP_EN | PIN_INPUT | MUX_MODE2)	/* vout1_d0.uart5_rxd */
    			VOUT1_D1 (PIN_OUTPUT | MUX_MODE2)						/* vout1_d1.uart5_txd */
    	uart6_pins_default: pinmux_uart6_pins {
    			VOUT1_D8 (PIN_INPUT | MUX_MODE2)  /* vout1_d8.uart6_rxd */
    			VOUT1_D9 (PIN_OUTPUT | MUX_MODE2) /* vout1_d9.uart6_txd */
    			VIN2A_D4 (PIN_OUTPUT | MUX_MODE8)  /* vin2a_d4.uart6_ctsn */
    			VIN2A_D5 (PIN_INPUT | MUX_MODE8) /* vin2a_d5.uart6_rtsn */
    	uart9_pins_default: pinmux_uart9_pins {
    			MCASP5_ACLKX (PIN_INPUT | MUX_MODE8)  /* mcasp5_aclkx.uart9_rxd */
    			MCASP5_FSX (PIN_OUTPUT | MUX_MODE3) /* mcasp5_fsx.uart9_txd */
    	uart10_pins_default: pinmux_uart10_pins {
    			0x170 (PIN_INPUT | MUX_MODE8)  /* vin2a_d2.uart10_rxd */
    			0x174 (PIN_OUTPUT | MUX_MODE8) /* vin2a_d3.uart10_txd */
    	mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */
    	mmc1_pins_hs: pinmux_mmc1_hs_pins {
    	mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
    	mmc1_pins_sdr50: pinmux_mmc1_sdr50_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_clk.mmc1_clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_cmd.mmc1_cmd */
    			0x35C (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat0.mmc1_dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat1.mmc1_dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat2.mmc1_dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)	/* mmc1_dat3.mmc1_dat3 */
    	mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
    			0x354	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_clk.mmc1_clk */
    			0x358	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_cmd.mmc1_cmd */
    			0x35C	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat0.mmc1_dat0 */
    			0x360	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat1.mmc1_dat1 */
    			0x364	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat2.mmc1_dat2 */
    			0x368	(PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)	/* mmc1_dat3.mmc1_dat3 */
    	mmc1_pins_sdr104: pinmux_mmc1_sdr104_pins {
    			0x354	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_clk.mmc1_clk */
    			0x358	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_cmd.mmc1_cmd */
    			0x35C	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat0.mmc1_dat0 */
    			0x360	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat1.mmc1_dat1 */
    			0x364	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat2.mmc1_dat2 */
    			0x368	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat3.mmc1_dat3 */
    	mmc2_pins_hs: pinmux_mmc2_hs_pins {
    			0x08C	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
    			0x090	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
    			0x094	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
    			0x098	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
    			0x09C	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
    			0x0A0	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
    			0x0A4	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
    			0x0A8	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
    			0x0AC	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
    			0x0B0	(PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
    	mmc2_pins_ddr_1_8v: pinmux_mmc2_ddr_1_8v_pins {
    	mmc2_pins_hs200_1_8v: pinmux_mmc2_hs200_1_8v_pins {
    			0x08C	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
    			0x090	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
    			0x094	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
    			0x098	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
    			0x09C	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
    			0x0A0	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
    			0x0A4	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
    			0x0A8	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
    			0x0AC	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
    			0x0B0	(PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
    &dra7_iodelay_core {
    	mmc1_iodelay_sdr104_conf: mmc1_iodelay_sdr104_conf {
    			0x620 (A_DELAY(560) | G_DELAY(365))	/* CFG_MMC1_CLK_OUT */
    			0x62C (A_DELAY(0)   | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
    			0x638 (A_DELAY(29)  | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
    			0x644 (A_DELAY(0)   | G_DELAY(0))	/* CFG_MMC1_DAT1_OUT */
    			0x650 (A_DELAY(47)  | G_DELAY(0))	/* CFG_MMC1_DAT2_OUT */
    			0x65C (A_DELAY(30)  | G_DELAY(0))	/* CFG_MMC1_DAT3_OUT */
    			0x628 (A_DELAY(125) | G_DELAY(0))	/* CFG_MMC1_CMD_OEN */
    			0x634 (A_DELAY(43)  | G_DELAY(0))	/* CFG_MMC1_DAT0_OEN */
    			0x640 (A_DELAY(433) | G_DELAY(0))	/* CFG_MMC1_DAT1_OEN */
    			0x64C (A_DELAY(287) | G_DELAY(0))	/* CFG_MMC1_DAT2_OEN */
    			0x658 (A_DELAY(351) | G_DELAY(0))	/* CFG_MMC1_DAT3_OEN */
    	mmc2_iodelay_hs200_1_8v_conf: mmc2_iodelay_hs200_1_8v_conf {
    			0x194 (A_DELAY(150) | G_DELAY(95))	/* CFG_GPMC_A19_OUT */
    			0x1AC (A_DELAY(250) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1B8 (A_DELAY(125) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
    			0x1C4 (A_DELAY(100) | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
    			0x1D0 (A_DELAY(870) | G_DELAY(415))	/* CFG_GPMC_A23_OUT */
    			0x1DC (A_DELAY(30)  | G_DELAY(0))	/* CFG_GPMC_A24_OUT */
    			0x1E8 (A_DELAY(200) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
    			0x1F4 (A_DELAY(200) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
    			0x200 (A_DELAY(0)   | G_DELAY(0))	/* CFG_GPMC_A27_OUT */
    			0x368 (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
    			0x190 (A_DELAY(695) | G_DELAY(0))	/* CFG_GPMC_A19_OEN */
    			0x1A8 (A_DELAY(924) | G_DELAY(0))	/* CFG_GPMC_A20_OEN */
    			0x1B4 (A_DELAY(719) | G_DELAY(0))	/* CFG_GPMC_A21_OEN */
    			0x1C0 (A_DELAY(824) | G_DELAY(0))	/* CFG_GPMC_A22_OEN */
    			0x1D8 (A_DELAY(877) | G_DELAY(0))	/* CFG_GPMC_A24_OEN */
    			0x1E4 (A_DELAY(446) | G_DELAY(0))	/* CFG_GPMC_A25_OEN */
    			0x1F0 (A_DELAY(847) | G_DELAY(0))	/* CFG_GPMC_A26_OEN */
    			0x1FC (A_DELAY(586) | G_DELAY(0))	/* CFG_GPMC_A27_OEN */
    			0x364 (A_DELAY(1039) | G_DELAY(0))	/* CFG_GPMC_CS1_OEN */
    &i2c3 {
    	status = "okay";
    	clock-frequency = <400000>;
    &i2c5 {
    	ov10633@37 {
    		compatible = "ovti,ov10633";
    		reg = <0x37>;
    		mux-gpios = <&pcf_hdmi 3	GPIO_ACTIVE_LOW>; /* CAM_FPD_MUX_S0 */
    		port {
    			onboardLI: endpoint@0 {
    				remote-endpoint = <&vin2a>;
    				//hsync-active = <1>;
    				//vsync-active = <1>;
    				pclk-sample = <0>;
    				channels = <0>;
    &dss {
    	pinctrl-names = "default";
    	pinctrl-0 = <&vout3_pins>;
    	status = "ok";
    	vdda_video-supply = <&ldo5_reg>;
    	ports {
    		#address-cells = <1>;
    		#size-cells = <0>;
    		status = "okay";
    		port@lcd2 {
    			reg = <2>;
    			dpi2_out: endpoint {
    				remote-endpoint = <&lcd2_in>;
    				data-lines = <24>;
    &hdmi {
    &pcf_gpio_21 {
    	status = "disabled";
    	interrupt-parent = <&gpio6>;
    	interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
    &mmc1 {
    	pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104";
    	pinctrl-0 = <&mmc1_pins_default>;
    	pinctrl-1 = <&mmc1_pins_hs>;
    	pinctrl-2 = <&mmc1_pins_sdr12>;
    	pinctrl-3 = <&mmc1_pins_sdr25>;
    	pinctrl-4 = <&mmc1_pins_sdr50>;
    	pinctrl-5 = <&mmc1_pins_ddr50>;
    	pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_conf>;
    &mmc2 {
    	pinctrl-names = "default", "hs", "ddr_1_8v", "hs200_1_8v";
    	pinctrl-0 = <&mmc2_pins_default>;
    	pinctrl-1 = <&mmc2_pins_hs>;
    	pinctrl-2 = <&mmc2_pins_ddr_1_8v>;
    	pinctrl-3 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_conf>;
    // WNC
    &uart1 {
    /* use for GPIO declare */
    	status = "okay";
    	pinctrl-0 = <&uart1_pins>;
    &uart2 {
    	status = "okay";
    &uart3 {
    	status = "okay";
    	/* gpios = <&pcf_gpio_21 14 GPIO_ACTIVE_LOW>; */
    	pinctrl-0 = <&uart3_pins_default>;
    &uart5 {
    	status = "okay";
    	pinctrl-0 = <&uart5_pins_default>;
    &uart6 {
    	status = "okay";
    	pinctrl-0 = <&uart6_pins_default>;
    &uart9 {
    	status = "okay";
    	pinctrl-0 = <&uart9_pins_default>;
    &uart10 {
    	status = "okay";
    	pinctrl-0 = <&uart10_pins_default>;
    &mac {
    	slaves = <1>;
    	mode-gpios = <&pcf_gpio_21 4 GPIO_ACTIVE_HIGH>;
    &cpsw_emac0 {
    	phy_id = <&davinci_mdio>, <3>;
    	phy-mode = "rgmii";
    &ipu2 {
    	status = "okay";
    	memory-region = <&ipu2_cma_pool>;
    &ipu1 {
    	status = "okay";
    	memory-region = <&ipu1_cma_pool>;
    &dsp1 {
    	status = "okay";
    	memory-region = <&dsp1_cma_pool>;
    &vip1 {
    	status = "okay";
    	pinctrl-0 = <&vin2a_pins>;
    	vin2a: port@1 {
    		status = "okay";
    video_in: &vin2a {
    	status = "okay";
    	endpoint@0 {
    		slave-mode;
    		remote-endpoint = <&onboardLI>;
    &cal {
    	status = "okay";
    #include "dra7xx-jamr3.dtsi"
    &tvp_5158{
    	mux-gpios = <&pcf_hdmi 2 GPIO_ACTIVE_LOW>,	/*VIN2_S0*/
    		    <&pcf_jamr3_21 8 GPIO_ACTIVE_LOW>,	/*SEL_TVP_FPD*/
    		    <&pcf_hdmi 6 GPIO_ACTIVE_HIGH>;	/*VIN2_S2*/
     * Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
    /dts-v1/;
    #include "dra72x.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/clk/ti-dra7-atl.h>
    	compatible = "ti,dra72-evm", "ti,dra722", "ti,dra72", "ti,dra7";
    	aliases {
    		display0 = &hdmi0;
    		display1 = &lcd2;
    		sound0 = &snd0;
    		sound1 = &hdmi;
    	evm_3v3_sw: fixedregulator-evm_3v3 {
    		compatible = "regulator-fixed";
    		regulator-name = "evm_3v3";
    		regulator-min-microvolt = <3300000>;
    	aic_dvdd: fixedregulator-aic_dvdd {
    		/* TPS77018DBVT */
    		regulator-name = "aic_dvdd";
    		vin-supply = <&evm_3v3_sw>;
    		regulator-max-microvolt = <1800000>;
    	evm_3v3_sd: fixedregulator-sd {
    		regulator-name = "evm_3v3_sd";
    		enable-active-high;
    #if 0
    	extcon_usb1: extcon_usb1 {
    		compatible = "linux,extcon-usb-gpio";
    		id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>;
    	extcon_usb2: extcon_usb2 {
    		id-gpio = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>;
    #endif
    	hdmi0: connector {
    		compatible = "hdmi-connector";
    		label = "hdmi";
    		type = "a";
    		port {
    			hdmi_connector_in: endpoint {
    				remote-endpoint = <&tpd12s015_out>;
    	tpd12s015: encoder {
    		compatible = "ti,tpd12s015";
    		gpios = <&pcf_hdmi 4 GPIO_ACTIVE_HIGH>,	/* P4, CT CP HPD */
    			<&pcf_hdmi 5 GPIO_ACTIVE_HIGH>,	/* P5, LS OE */
    			<&gpio7 12 GPIO_ACTIVE_HIGH>;	/* gpio7_12/sp1_cs2, HPD */
    		ports {
    			#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				tpd12s015_in: endpoint {
    					remote-endpoint = <&hdmi_out>;
    			port@1 {
    				reg = <1>;
    				tpd12s015_out: endpoint {
    					remote-endpoint = <&hdmi_connector_in>;
    	snd0: sound@0 {
    		compatible = "simple-audio-card";
    		simple-audio-card,name = "DRA7xx-EVM";
    		simple-audio-card,widgets =
    			"Headphone", "Headphone Jack",
    			"Line", "Line Out",
    			"Microphone", "Mic Jack",
    			"Line", "Line In";
    		simple-audio-card,routing =
    			"Headphone Jack",       "HPLOUT",
    			"Headphone Jack",       "HPROUT",
    			"Line Out",		"LLOUT",
    			"Line Out",		"RLOUT",
    			"MIC3L",		"Mic Jack",
    			"MIC3R",		"Mic Jack",
    			"Mic Jack",		"Mic Bias",
    			"LINE1L",               "Line In",
    			"LINE1R",               "Line In";
    		simple-audio-card,format = "dsp_b";
    		simple-audio-card,bitclock-master = <&sound0_master>;
    		simple-audio-card,frame-master = <&sound0_master>;
    		simple-audio-card,bitclock-inversion;
    		sound0_master: simple-audio-card,cpu {
    			sound-dai = <&mcasp3>;
    			system-clock-frequency = <11289600>;
    		simple-audio-card,codec {
    			sound-dai = <&tlv320aic3106>;
    			clocks = <&atl_clkin2_ck>;
    #if 0
    	// GPIO5_8 is used for TDM pin
    	vmmcwl_fixed: fixedregulator-mmcwl {
    		regulator-name = "vmmcwl_fixed";
    		gpio = <&gpio5 8 GPIO_ACTIVE_HIGH>;
    		enable-active-high;
    #endif
    &dra7_pmx_core {
            tps65917_pins_default: tps65917_pins_default {
                            0x424 (PIN_INPUT_PULLUP | MUX_MODE1)    /* wakeup3.sys_nirq1 */
    	mmc1_pins_default: mmc1_pins_default {
    	mmc2_pins_default: mmc2_pins_default {
    			0x9c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */
    			0xb0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
    			0xa0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
    			0xa4 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
    			0xa8 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
    			0xac (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
    			0x8c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
    			0x90 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
    			0x94 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
    			0x98 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
    	mmc4_pins_default: mmc4_pins_default {
    			0x3e8 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
    			0x3ec (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
    			0x3f0 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
    			0x3f4 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
    			0x3f8 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
    			0x3fC (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    	dcan1_pins_default: dcan1_pins_default {
    			0x3d0   (PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */
    			0x418   (PULL_UP | MUX_MODE1)	/* wakeup0.dcan1_rx */
    	dcan1_pins_sleep: dcan1_pins_sleep {
    			0x3d0   (MUX_MODE15 | PULL_UP)	/* dcan1_tx.off */
    			0x418   (MUX_MODE15 | PULL_UP)	/* wakeup0.off */
    #if 0
    	// GPIO5_8 function in TDM
    	wlan_pins: pinmux_wlan_pins {
    			0x3fc (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart2_rtsn.mmc4_dat3 */
    			0x2cc (PIN_OUTPUT | MUX_MODE14)		/* mcasp1_axr6.gpio5_8 - WLAN_EN */
    #endif
    	wlirq_pins: pinmux_wlirq_pins {
    			0x2c8 (PIN_INPUT_PULLUP | WAKEUP_EN | MUX_MODE14 ) /* mcasp1_axr5.gpio5_7 - WLAN_IRQ */
    &i2c1 {
    	status = "okay";
    	tps65917: tps65917@58 {
    		compatible = "ti,tps65917";
    		reg = <0x58>;
    #if 0
    		interrupts = <GIC_SPI 2 IRQ_TYPE_NONE>;  /* IRQ_SYS_1N */
    #else
                    pinctrl-0 = <&tps65917_pins_default>;
                    interrupts-extended = <&gic GIC_SPI 2 IRQ_TYPE_NONE
                                            &dra7_pmx_core 0x424>;
                    interrupt-parent = <&gic>;
    #endif
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		ti,system-power-controller;
    		tps65917_pmic {
    			compatible = "ti,tps65917-pmic";
    			tps65917_regulators: regulators {
    				smps1_reg: smps1 {
    					/* VDD_MPU */
    					regulator-name = "smps1";
    					regulator-min-microvolt = <850000>;
    					regulator-max-microvolt = <1250000>;
    					regulator-always-on;
    					regulator-boot-on;
    				smps2_reg: smps2 {
    					/* VDD_CORE */
    					regulator-name = "smps2";
    					regulator-max-microvolt = <1150000>;
    					regulator-boot-on;
    				smps3_reg: smps3 {
    					/* VDD_GPU IVA DSPEVE */
    					regulator-name = "smps3";
    					regulator-boot-on;
    				smps4_reg: smps4 {
    					/* VDDS1V8 */
    					regulator-name = "smps4";
    					regulator-boot-on;
    				smps5_reg: smps5 {
    					/* VDD_DDR */
    					regulator-name = "smps5";
    					regulator-min-microvolt = <1350000>;
    					regulator-max-microvolt = <1350000>;
    					regulator-boot-on;
    				ldo1_reg: ldo1 {
    					/* LDO1_OUT --> SDIO  */
    					regulator-name = "ldo1";
    					regulator-boot-on;
    				ldo3_reg: ldo3 {
    					/* VDDA_1V8_PHY */
    					regulator-name = "ldo3";
    					regulator-boot-on;
    				ldo5_reg: ldo5 {
    					/* VDDA_1V8_PLL */
    					regulator-name = "ldo5";
    					regulator-boot-on;
    				ldo4_reg: ldo4 {
    					/* VDDA_3V_USB: VDDA_USBHS33 */
    					regulator-name = "ldo4";
    					regulator-boot-on;
    		tps65917_power_button {
    			compatible = "ti,palmas-pwrbutton";
    			interrupt-parent = <&tps65917>;
    			interrupts = <1 IRQ_TYPE_NONE>;
    			wakeup-source;
    			ti,palmas-long-press-seconds = <6>;
    	pcf_lcd: gpio@20 {
    		compatible = "nxp,pcf8575";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	pcf_gpio_21: gpio@21 {
    		compatible = "ti,pcf8575";
    		reg = <0x21>;
    		lines-initial-states = <0x1408>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	tlv320aic3106: tlv320aic3106@19 {
    		#sound-dai-cells = <0>;
    		compatible = "ti,tlv320aic3106";
    		reg = <0x19>;
    		adc-settle-ms = <40>;
    		ai3x-micbias-vg = <1>;		/* 2.0V */
    		status = "okay";
    		/* Regulators */
    		AVDD-supply = <&evm_3v3_sw>;
    		IOVDD-supply = <&evm_3v3_sw>;
    		DRVDD-supply = <&evm_3v3_sw>;
    		DVDD-supply = <&aic_dvdd>;
    i2c_p3_exp: &i2c5 {
    	status = "okay";
    	pcf_hdmi: pcf8575@26 {
    		reg = <0x26>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		 * initial state is used here to keep the mdio interface
    		 * selected on RU89 through SEL_VIN4_MUX_S0, VIN2_S1 and
    		 * VIN2_S0 driven high otherwise Ethernet stops working
    		 * VIN6_SEL_S0 is low, thus selecting McASP3 over VIN6
    		lines-initial-states = <0x0f2b>;
    		p1 {
    			/* vin6_sel_s0: high: VIN6, low: audio */
    			gpio-hog;
    			gpios = <1 GPIO_ACTIVE_HIGH>;
    			output-low;
    			line-name = "vin6_sel_s0";
    &mcspi1 {
            status = "okay";
            ti,pindir-d0-out-d1-in;
            spidev@0
        spi-max-frequency = <100000>;
        reg = <0>;
            compatible = "rohm,dh2228fv";
            status = "okay" ;
            spidev@1
        reg = <1>;
            status = "okay" ;
            spidev@3
        reg = <3>;
            status = "okay" ;
    &mcspi2 {
            status = "okay";
            spidev@0
        reg = <0>;
    &mcspi3 {
            status = "okay";
            spidev@0
        reg = <0>;
    &uart1 {
    	status = "okay";
    	interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>,
    			      <&dra7_pmx_core 0x3e0>;
    &uart3 {
    	status = "okay";
    &elm {
    	status = "okay";
    &gpmc {
    	 * For the existing IOdelay configuration via U-Boot we don't
    	 * support NAND on dra72-evm. Keep it disabled. Enabling it
    	 * requires a different configuration by U-Boot.
    	ranges = <0 0 0x08000000 0x01000000>;	/* minimum GPMC partition = 16MB */
    	nand@0,0 {
    		/* To use NAND, DIP switch SW5 must be set like so:
    		 * SW5.1 (NAND_SELn) = ON (LOW)
    		 * SW5.9 (GPMC_WPN) = OFF (HIGH)
    		compatible = "ti,omap2-nand";
    		reg = <0 0 4>;          /* device IO registers */
    		interrupt-parent = <&gpmc>;
    		interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
    			     <1 IRQ_TYPE_NONE>; /* termcount */
    		rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 pin */	/* device IO registers */
    		ti,nand-ecc-opt = "bch8";
    		ti,elm-id = <&elm>;
    		nand-bus-width = <16>;
    		gpmc,device-width = <2>;
    		gpmc,sync-clk-ps = <0>;
    		gpmc,cs-on-ns = <0>;
    		gpmc,cs-rd-off-ns = <80>;
    		gpmc,cs-wr-off-ns = <80>;
    		gpmc,adv-on-ns = <0>;
    		gpmc,adv-rd-off-ns = <60>;
    		gpmc,adv-wr-off-ns = <60>;
    		gpmc,we-on-ns = <10>;
    		gpmc,we-off-ns = <50>;
    		gpmc,oe-on-ns = <4>;
    		gpmc,oe-off-ns = <40>;
    		gpmc,access-ns = <40>;
    		gpmc,wr-access-ns = <80>;
    		gpmc,rd-cycle-ns = <80>;
    		gpmc,wr-cycle-ns = <80>;
    		gpmc,bus-turnaround-ns = <0>;
    		gpmc,cycle2cycle-delay-ns = <0>;
    		gpmc,clk-activation-ns = <0>;
    		gpmc,wait-monitoring-ns = <0>;
    		gpmc,wr-data-mux-bus-ns = <0>;
    		/* MTD partition table */
    		/* All SPL-* partitions are sized to minimal length
    		 * which can be independently programmable. For
    		 * NAND flash this is equal to size of erase-block */
    		#size-cells = <1>;
    		partition@0 {
    			label = "NAND.SPL";
    			reg = <0x00000000 0x000020000>;
    		partition@1 {
    			label = "NAND.SPL.backup1";
    			reg = <0x00020000 0x00020000>;
    		partition@2 {
    			label = "NAND.SPL.backup2";
    			reg = <0x00040000 0x00020000>;
    		partition@3 {
    			label = "NAND.SPL.backup3";
    			reg = <0x00060000 0x00020000>;
    		partition@4 {
    			label = "NAND.u-boot-spl-os";
    			reg = <0x00080000 0x00040000>;
    		partition@5 {
    			label = "NAND.u-boot";
    			reg = <0x000c0000 0x00100000>;
    		partition@6 {
    			label = "NAND.u-boot-env";
    			reg = <0x001c0000 0x00020000>;
    		partition@7 {
    			label = "NAND.u-boot-env.backup1";
    			reg = <0x001e0000 0x00020000>;
    		partition@8 {
    			label = "NAND.kernel";
    			reg = <0x00200000 0x00800000>;
    		partition@9 {
    			label = "NAND.file-system";
    			reg = <0x00a00000 0x0f600000>;
    &usb2_phy1 {
    	phy-supply = <&ldo4_reg>;
    &usb2_phy2 {
    &omap_dwc3_1 {
    //	extcon = <&extcon_usb1>;
    &omap_dwc3_2 {
    //	extcon = <&extcon_usb2>;
    &usb1 {
    	status = "ok";
    	dr_mode = "host";
    &usb2 {
    	status = "ok";
    	dr_mode = "host";
    &usb3 {
    &mmc1 {
    	status = "okay";
    	vmmc-supply = <&evm_3v3_sw>;
    	vmmc_aux-supply = <&ldo1_reg>;
    	bus-width = <4>;
    	 * SDCD signal is not being used here - using the fact that GPIO mode
    	 * is a viable alternative
    	cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
    	max-frequency = <192000000>;
    &mmc2 {
    	/* SW5-3 in ON position */
    	status = "okay";
    	bus-width = <8>;
    	ti,non-removable;
    &mmc4 {
    #if 1
            status = "okay";
            bus-width = <4>;
            pinctrl-0 = <&mmc4_pins_default>;
    #else
    	status = "okay";
    	vmmc-supply = <&vmmcwl_fixed>;
    	bus-width = <4>;
    	pinctrl-0 = <&wlan_pins &wlirq_pins>;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	ti,non-removable;
    	#size-cells = <0>;
    	wlcore: wlcore@0 {
    		compatible = "ti,wl1835";
    		reg = <2>;
    		interrupt-parent = <&gpio5>;
    		interrupts = <7 IRQ_TYPE_LEVEL_HIGH>;
    #endif
    &mac {
    	status = "okay";
    &dcan1 {
    	status = "ok";
    &qspi {
    	status = "okay";
    	spi-max-frequency = <64000000>;
    	m25p80@0 {
    		compatible = "s25fl256s1";
    		reg = <0>;
    		spi-tx-bus-width = <1>;
    		spi-rx-bus-width = <4>;
    		#size-cells = <1>;
    		/* MTD partition table.
    		 * The ROM checks the first four physical blocks
    		 * for a valid file to boot and the flash here is
    		 * 64KiB block size.
    		partition@0 {
    			label = "QSPI.SPL";
    			reg = <0x00000000 0x000040000>;
    		partition@1 {
    			label = "QSPI.u-boot";
    			reg = <0x00040000 0x00100000>;
    		partition@2 {
    			label = "QSPI.u-boot-spl-os";
    			reg = <0x00140000 0x00080000>;
    		partition@3 {
    			label = "QSPI.u-boot-env";
    			reg = <0x001c0000 0x00010000>;
    		partition@4 {
    			label = "QSPI.u-boot-env.backup1";
    			reg = <0x001d0000 0x0010000>;
    		partition@5 {
    			label = "QSPI.kernel";
    			reg = <0x001e0000 0x0800000>;
    		partition@6 {
    			label = "QSPI.file-system";
    			reg = <0x009e0000 0x01620000>;
    &hdmi {
    	port {
    		hdmi_out: endpoint {
    			remote-endpoint = <&tpd12s015_in>;
    &atl {
    	assigned-clocks = <&abe_dpll_sys_clk_mux>,
    			  <&atl_gfclk_mux>,
    			  <&dpll_abe_ck>,
    			  <&dpll_abe_m2x2_ck>,
    			  <&atl_clkin1_ck>,
    			  <&atl_clkin2_ck>;
    	assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>;
    	assigned-clock-rates = <0>, <0>, <180633600>, <361267200>,
    			       <11289600>, <11289600>;
    	atl2 {
    		bws = <DRA7_ATL_WS_MCASP2_FSX>;
    		aws = <DRA7_ATL_WS_MCASP3_FSX>;
    &mcasp3 {
    	assigned-clocks = <&mcasp3_ahclkx_mux>;
    	assigned-clock-parents = <&atl_clkin2_ck>;
    	status = "okay";
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	/* 4 serializer */
    	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
    		1 2 0 0
    	tx-num-evt = <32>;
    	rx-num-evt = <32>;
    &mailbox5 {
    	status = "okay";
    	mbox_ipu1_ipc3x: mbox_ipu1_ipc3x {
    		status = "okay";
    	mbox_dsp1_ipc3x: mbox_dsp1_ipc3x {
    		status = "okay";
    &mailbox6 {
    	status = "okay";
    	mbox_ipu2_ipc3x: mbox_ipu2_ipc3x {
    		status = "okay";
    &mmu0_dsp1 {
    	status = "okay";
    &mmu1_dsp1 {
    	status = "okay";
    &mmu_ipu1 {
    	status = "okay";
    &mmu_ipu2 {
    	status = "okay";
    &ipu2 {
    	mboxes = <&mailbox6 &mbox_ipu2_ipc3x>;
    	timers = <&timer3>;
    	watchdog-timers = <&timer4>, <&timer9>;
    &ipu1 {
    	mboxes = <&mailbox5 &mbox_ipu1_ipc3x>;
    	timers = <&timer11>;
    	watchdog-timers = <&timer7>, <&timer8>;
    &dsp1 {
    	mboxes = <&mailbox5 &mbox_dsp1_ipc3x>;
    	timers = <&timer5>;
    	watchdog-timers = <&timer10>;
    &oppdm_mpu {
    	vdd-supply = <&smps1_reg>;
    &oppdm_core {
    	vdd-supply = <&smps2_reg>;
    &oppdm_dspeve {
    	vdd-supply = <&smps3_reg>;
    &oppdm_gpu {
    &oppdm_ivahd {
     * Copyright (C) 2016 Texas Instruments Incorporated - http://www.ti.com/
    #if 0
    	jamr3_sound {
    		simple-audio-card,name = "DRA7xx-JAMR3";
    			"Line", "Line Out",
    			"Line", "Line In";
    		simple-audio-card,bitclock-master = <&jamr3_sound_master>;
    		simple-audio-card,frame-master = <&jamr3_sound_master>;
    		jamr3_sound_master: simple-audio-card,cpu {
    			sound-dai = <&mcasp6>;
    			sound-dai = <&tlv320aic3106a>;
    			clocks = <&atl_clkin1_ck>;
    #endif
    	gatemp {
    		compatible = "hwspinlock-user";
    		hwlocks = <&hwspinlock 0>,
    			  <&hwspinlock 1>,
    			  <&hwspinlock 2>,
    			  <&hwspinlock 3>,
    			  <&hwspinlock 4>,
    			  <&hwspinlock 5>,
    			  <&hwspinlock 6>,
    			  <&hwspinlock 7>,
    			  <&hwspinlock 8>,
    			  <&hwspinlock 9>;
    	sr0 {
    		compatible = "generic-uio";
    		reg = <0x0 0xbfb00000 0x0 0x100000>;
    &reserved_mem {
    	/* Required by cmem driver used by radio */
    	cmem_radio: cmem@95400000 {
    		reg = <0x0 0x95400000 0x0 0x400000>;
    		no-map;
    		status = "okay";
    	dsp1_sr0: dsp1_sr0@bfb00000 {
    		no-map;
    		status = "okay";
    &gpio6 {
    	p20 {
    		/* Radio reset GPIO */
    		gpio-hog;
    		gpios = <1 GPIO_ACTIVE_LOW>;
    		output-low;
    		line-name = "radio_rst";
    &atl {
    	atl1 {
    		aws = <DRA7_ATL_WS_MCASP6_FSX>;
    &mcasp2 {
    	assigned-clocks = <&mcasp2_ahclkx_mux>;
    	tdm-slots = <2>;
    	/* 8 serializers */
    		2 0 0 0 0 0 0 0
    	shared-dai;
    &mcasp6 {
    	assigned-clocks = <&mcasp6_ahclkx_mux>;
    	assigned-clock-parents = <&atl_clkin1_ck>;
    	tdm-slots = <2>;
    	/* 4 serializer */
    		1 2 0 0
    	tx-num-evt = <32>;
    	rx-num-evt = <32>;
    	shared-dai;
    &i2c4 {
    	status = "okay";
    	pcf_jamr3_21: pcf8575@21 {
    		reg = <0x21>;
    		gpio-controller;
    		#gpio-cells = <2>;
    &i2c_p3_exp {
    #if 0
    	tlv320aic3106a: tlv320aic3106@18 {
    		reg = <0x18>;
    		name-prefix = "J3A";
    		status = "okay";
    		/* Regulators */
    	tlv320aic3106b: tlv320aic3106@19 {
    		reg = <0x19>;
    		name-prefix = "J3B";
    		status = "okay";
    		/* Regulators */
    	tlv320aic3106c: tlv320aic3106@1a {
    		reg = <0x1a>;
    		name-prefix = "J3C";
    		status = "okay";
    		/* Regulators */
    #endif
    #if 1
    	tvp_5158: tvp5158@58 {
    		compatible= "ti,tvp5158";
    		reg = <0x58>;
    		port {
    			tvp_decoder: endpoint@0 {
    				//channels = <0 2 4 6>;
    				channels = <0>;
    				//pixel-mux;
    #else
    		reg = <0x58>;
    		port {
    #endif
    &video_in {
    	endpoint {
    		slave-mode;
    		remote-endpoint = <&tvp_decoder>;
     * Based on "omap4.dtsi"
    #include "dra7.dtsi"
    	compatible = "ti,dra722", "ti,dra72", "ti,dra7";
    	cpus {
    		#size-cells = <0>;
    		cpu0: cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-a15";
    			reg = <0>;
    			/* cooling options */
    			cooling-min-level = <0>;
    			cooling-max-level = <2>;
    			#cooling-cells = <2>; /* min followed by max */
    	aliases {
    		rproc0 = &ipu1;
    		rproc1 = &ipu2;
    		rproc2 = &dsp1;
    	pmu {
    		compatible = "arm,cortex-a15-pmu";
    		interrupt-parent = <&wakeupgen>;
    		interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>;
    	ocp {
    		cal: cal@4845b000 {
    			compatible = "ti,dra72-cal";
    			ti,hwmods = "cal";
    			reg = <0x4845B000 0x400>,
    			      <0x4845B800 0x40>,
    			      <0x4845B900 0x40>,
    			      <0x4A002e94 0x4>;
    			reg-names = "cal_top",
    				    "cal_rx_core0",
    				    "cal_rx_core1",
    				    "camerrx_control";
    			interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ports {
    				#size-cells = <0>;
    				csi2_0: port@0 {
    					reg = <0>;
    				csi2_1: port@1 {
    					reg = <1>;
    &scm {
    	dra72_vip_mux: pinmux@4a002e8c {
    		compatible = "pinctrl-single";
    		reg = <0xe8c 0x4>;
    		#size-cells = <0>;
    		pinctrl-single,register-width = <32>;
    		pinctrl-single,function-mask = <0x7f>;
    &dss {
    	reg = <0x58000000 0x80>,
    	      <0x58004054 0x4>,
    	      <0x58004300 0x20>;
    	reg-names = "dss", "pll1_clkctrl", "pll1";
    	clocks = <&dss_dss_clk>,
    		 <&dss_video1_clk>;
    	clock-names = "fck", "video1_clk";
    &mailbox3 {
    	mbox_pru1_0: mbox_pru1_0 {
    		ti,mbox-tx = <0 0 0>;
    		ti,mbox-rx = <1 0 0>;
    	mbox_pru1_1: mbox_pru1_1 {
    		ti,mbox-tx = <2 0 0>;
    		ti,mbox-rx = <3 0 0>;
    &mailbox4 {
    	mbox_pru2_0: mbox_pru2_0 {
    	mbox_pru2_1: mbox_pru2_1 {
    &mailbox5 {
    		ti,mbox-tx = <6 2 2>;
    		ti,mbox-rx = <4 2 2>;
    		ti,mbox-tx = <5 2 2>;
    		ti,mbox-rx = <1 2 2>;
    &mailbox6 {
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
    #include <dt-bindings/interrupt-controller/arm-gic.h>
    #include <dt-bindings/pinctrl/dra.h>
    #include "skeleton.dtsi"
    #define MAX_SOURCES 400
    	#size-cells = <2>;
    	compatible = "ti,dra7xx";
    	interrupt-parent = <&crossbar_mpu>;
    	aliases {
    		i2c0 = &i2c1;
    		i2c1 = &i2c2;
    		i2c2 = &i2c3;
    		i2c3 = &i2c4;
    		i2c4 = &i2c5;
    		serial0 = &uart1;
    		serial1 = &uart2;
    		serial2 = &uart3;
    		serial3 = &uart4;
    		serial4 = &uart5;
    		serial5 = &uart6;
    		serial6 = &uart7;
    		serial7 = &uart8;
    		serial8 = &uart9;
    		serial9 = &uart10;
    		ethernet0 = &cpsw_emac0;
    		ethernet1 = &cpsw_emac1;
    		d_can0 = &dcan1;
    		d_can1 = &dcan2;
    	timer {
    		compatible = "arm,armv7-timer";
    		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
    			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
    			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
    			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
    	gic: interrupt-controller@48211000 {
    		compatible = "arm,cortex-a15-gic";
    		#interrupt-cells = <3>;
    		reg = <0x0 0x48211000 0x0 0x1000>,
    		      <0x0 0x48212000 0x0 0x1000>,
    		      <0x0 0x48214000 0x0 0x2000>,
    		      <0x0 0x48216000 0x0 0x2000>;
    		interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>;
    	wakeupgen: interrupt-controller@48281000 {
    		compatible = "ti,omap5-wugen-mpu", "ti,omap4-wugen-mpu";
    		reg = <0x0 0x48281000 0x0 0x1000>;
    	cpus {
    		#size-cells = <0>;
    		cpu0: cpu@0 {
    			reg = <0>;
    			operating-points-v2 = <&cpu0_opp_table>;
    			cpu-opp-domain = <&oppdm_mpu>;
    			ti,syscon-efuse = <&scm_wkup 0x20c 0xf80000 19>;
    			ti,syscon-rev = <&scm_wkup 0x204>;
    			clocks = <&dpll_mpu_ck>;
    			clock-names = "cpu";
    			clock-latency = <300000>; /* From omap-cpufreq driver */
    	cpu0_opp_table: opp_table0 {
    		compatible = "operating-points-v2";
    		opp-shared;
    		opp_nom@1000000000 {
    			opp-hz = /bits/ 64 <1000000000>;
    			opp-microvolt = <1060000 850000 1150000>;
    			opp-supported-hw = <0xFF 0x01>;
    			opp-suspend;
    		opp_od@1176000000 {
    			opp-hz = /bits/ 64 <1176000000>;
    			opp-microvolt = <1160000 885000 1160000>;
    			opp-supported-hw = <0xFF 0x02>;
    		opp_high@1500000000 {
    			opp-hz = /bits/ 64 <1500000000>;
    			opp-microvolt = <1210000 950000 1250000>;
    			opp-supported-hw = <0xFF 0x04>;
    	 * The soc node represents the soc top level view. It is used for IPs
    	 * that are not memory mapped in the MPU view or for the MPU itself.
    	soc {
    		compatible = "ti,omap-infra";
    		mpu {
    			compatible = "ti,omap5-mpu";
    			ti,hwmods = "mpu";
    	 * XXX: Use a flat representation of the SOC interconnect.
    	 * The real OMAP interconnect network is quite complex.
    	 * Since it will not bring real advantage to represent that in DT for
    	 * the moment, just use a fake OCP bus entry to represent the whole bus
    	 * hierarchy.
    	ocp {
    		compatible = "ti,dra7-l3-noc", "simple-bus";
    		#size-cells = <1>;
    		ranges = <0x0 0x0 0x0 0xc0000000>;
    		ti,hwmods = "l3_main_1", "l3_main_2";
    		reg = <0x0 0x44000000 0x0 0x1000000>,
    		      <0x0 0x45000000 0x0 0x1000>;
    		interrupts-extended = <&crossbar_mpu GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>,
    				      <&wakeupgen GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
    		l4_cfg: l4@4a000000 {
    			compatible = "ti,dra7-l4-cfg", "simple-bus";
    			#size-cells = <1>;
    			ranges = <0 0x4a000000 0x22c000>;
    			scm: scm@2000 {
    				compatible = "ti,dra7-scm-core", "simple-bus";
    				reg = <0x2000 0x2000>;
    				#size-cells = <1>;
    				ranges = <0 0x2000 0x2000>;
    				scm_conf: scm_conf@0 {
    					compatible = "syscon", "simple-bus";
    					reg = <0x0 0x1400>;
    					#size-cells = <1>;
    					ranges = <0 0x0 0x1400>;
    					pbias_regulator: pbias_regulator {
    						compatible = "ti,pbias-dra7", "ti,pbias-omap";
    						reg = <0xe00 0x4>;
    						syscon = <&scm_conf>;
    						pbias_mmc_reg: pbias_mmc_omap5 {
    							regulator-name = "pbias_mmc_omap5";
    							regulator-max-microvolt = <3000000>;
    					scm_conf_clocks: clocks {
    						#size-cells = <0>;
    				dra7_pmx_core: pinmux@1400 {
    					compatible = "ti,dra7-padconf",
    						     "pinctrl-single";
    					reg = <0x1400 0x0468>;
    					#size-cells = <0>;
    					#interrupt-cells = <1>;
    					pinctrl-single,function-mask = <0x3fffffff>;
    				scm_conf1: scm_conf@1c04 {
    					compatible = "syscon";
    					reg = <0x1c04 0x0020>;
    				scm_conf_pcie: scm_conf@1c24 {
    					reg = <0x1c24 0x0024>;
    				sdma_xbar: dma-router@b78 {
    					compatible = "ti,dra7-dma-crossbar";
    					reg = <0xb78 0xfc>;
    					#dma-cells = <1>;
    					dma-requests = <205>;
    					ti,dma-safe-map = <0>;
    					dma-masters = <&sdma>;
    				edma_xbar: dma-router@c78 {
    					reg = <0xc78 0x7c>;
    					#dma-cells = <2>;
    					dma-requests = <204>;
    					dma-masters = <&edma>;
    			cm_core_aon: cm_core_aon@5000 {
    				compatible = "ti,dra7-cm-core-aon";
    				reg = <0x5000 0x2000>;
    				cm_core_aon_clocks: clocks {
    					#size-cells = <0>;
    				cm_core_aon_clockdomains: clockdomains {
    			cm_core: cm_core@8000 {
    				compatible = "ti,dra7-cm-core";
    				reg = <0x8000 0x3000>;
    				cm_core_clocks: clocks {
    					#size-cells = <0>;
    				cm_core_clockdomains: clockdomains {
    		l4_wkup: l4@4ae00000 {
    			compatible = "ti,dra7-l4-wkup", "simple-bus";
    			#size-cells = <1>;
    			ranges = <0 0x4ae00000 0x3f000>;
    			counter32k: counter@4000 {
    				compatible = "ti,omap-counter32k";
    				reg = <0x4000 0x40>;
    				ti,hwmods = "counter_32k";
    			prm: prm@6000 {
    				compatible = "ti,dra7-prm";
    				reg = <0x6000 0x3000>;
    				interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
    				prm_clocks: clocks {
    					#size-cells = <0>;
    				prm_clockdomains: clockdomains {
    			scm_wkup: scm_conf@c000 {
    				reg = <0xc000 0x1000>;
    		axi@0 {
    			compatible = "simple-bus";
    			#size-cells = <1>;
    			ranges = <0x51000000 0x51000000 0x3000
    				  0x0	     0x20000000 0x10000000>;
    			pcie1: pcie@51000000 {
    				compatible = "ti,dra7-pcie";
    				reg = <0x51000000 0x2000>, <0x51002000 0x14c>, <0x1000 0x2000>;
    				reg-names = "rc_dbics", "ti_conf", "config";
    				interrupts = <0 232 0x4>, <0 233 0x4>;
    				#address-cells = <3>;
    				#size-cells = <2>;
    				device_type = "pci";
    				ranges = <0x81000000 0 0          0x03000 0 0x00010000
    					  0x82000000 0 0x20013000 0x13000 0 0xffed000>;
    				num-lanes = <1>;
    				linux,pci-domain = <0>;
    				ti,hwmods = "pcie1";
    				phys = <&pcie1_phy>;
    				phy-names = "pcie-phy0";
    				interrupt-map-mask = <0 0 0 7>;
    				interrupt-map = <0 0 0 1 &pcie1_intc 1>,
    						<0 0 0 2 &pcie1_intc 2>,
    						<0 0 0 3 &pcie1_intc 3>,
    						<0 0 0 4 &pcie1_intc 4>;
    				pcie1_intc: interrupt-controller {
    					#address-cells = <0>;
    		axi@1 {
    			#size-cells = <1>;
    			ranges = <0x51800000 0x51800000 0x3000
    				  0x0	     0x30000000 0x10000000>;
    			pcie@51800000 {
    				reg = <0x51800000 0x2000>, <0x51802000 0x14c>, <0x1000 0x2000>;
    				interrupts = <0 355 0x4>, <0 356 0x4>;
    				#size-cells = <2>;
    					  0x82000000 0 0x30013000 0x13000 0 0xffed000>;
    				num-lanes = <1>;
    				linux,pci-domain = <1>;
    				ti,hwmods = "pcie2";
    				phys = <&pcie2_phy>;
    				interrupt-map = <0 0 0 1 &pcie2_intc 1>,
    						<0 0 0 2 &pcie2_intc 2>,
    						<0 0 0 3 &pcie2_intc 3>,
    						<0 0 0 4 &pcie2_intc 4>;
    				pcie2_intc: interrupt-controller {
    		ocmcram1: ocmcram@40300000 {
    			compatible = "mmio-sram";
    			reg = <0x40300000 0x80000>;
    			ranges = <0x0 0x40300000 0x80000>;
    			#size-cells = <1>;
    			 * This is a placeholder for an optional reserved
    			 * region for use by secure software. The size
    			 * of this region is not known until runtime so it
    			 * is set as zero to either be updated to reserve
    			 * space or left unchanged to leave all SRAM for use.
    			 * On HS parts that that require the reserved region
    			 * either the bootloader can update the size to
    			 * the required amount or the node can be overriden
    			 * from the board dts file for the secure platform.
    			sram-hs@0 {
    				compatible = "ti,secure-ram";
    				reg = <0x0 0x0>;
    		 * NOTE: ocmcram2 and ocmcram3 are not available on all
    		 * DRA7xx and AM57xx variants. Confirm availability in
    		 * the data manual for the exact part number in use
    		 * before enabling these nodes in the board dts file.
    		ocmcram2: ocmcram@40400000 {
    			reg = <0x40400000 0x100000>;
    			ranges = <0x0 0x40400000 0x100000>;
    			#size-cells = <1>;
    		ocmcram3: ocmcram@40500000 {
    			reg = <0x40500000 0x100000>;
    			ranges = <0x0 0x40500000 0x100000>;
    			#size-cells = <1>;
    		bandgap: bandgap@4a0021e0 {
    			reg = <0x4a0021e0 0xc
    				0x4a00232c 0xc
    				0x4a002380 0x2c
    				0x4a0023C0 0x3c
    				0x4a002564 0x8
    				0x4a002574 0x50>;
    				compatible = "ti,dra752-bandgap";
    				interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>;
    				#thermal-sensor-cells = <1>;
    		dsp1_system: dsp_system@40d00000 {
    			reg = <0x40d00000 0x100>;
    		dra7_iodelay_core: padconf@4844a000 {
    			compatible = "ti,dra7-iodelay";
    			reg = <0x4844a000 0x0d1c>;
    			#size-cells = <0>;
    		sdma: dma-controller@4a056000 {
    			compatible = "ti,omap4430-sdma";
    			reg = <0x4a056000 0x1000>;
    			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
    			#dma-cells = <1>;
    			dma-channels = <32>;
    			dma-requests = <127>;
    		edma: edma@43300000 {
    			compatible = "ti,edma3-tpcc";
    			ti,hwmods = "tpcc";
    			reg = <0x43300000 0x100000>;
    			reg-names = "edma3_cc";
    			interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
    			interrupt-names = "edma3_ccint", "emda3_mperr",
    					  "edma3_ccerrint";
    			dma-requests = <64>;
    			#dma-cells = <2>;
    			ti,tptcs = <&edma_tptc0 7>, <&edma_tptc1 0>;
    			 * memcpy is disabled, can be enabled with:
    			 * ti,edma-memcpy-channels = <20 21>;
    			 * for example. Note that these channels need to be
    			 * masked in the xbar as well.
    		edma_tptc0: tptc@43400000 {
    			compatible = "ti,edma3-tptc";
    			ti,hwmods = "tptc0";
    			reg =	<0x43400000 0x100000>;
    			interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
    			interrupt-names = "edma3_tcerrint";
    		edma_tptc1: tptc@43500000 {
    			ti,hwmods = "tptc1";
    			reg =	<0x43500000 0x100000>;
    			interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
    		gpio1: gpio@4ae10000 {
    			compatible = "ti,omap4-gpio";
    			reg = <0x4ae10000 0x200>;
    			interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio1";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio2: gpio@48055000 {
    			reg = <0x48055000 0x200>;
    			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio2";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio3: gpio@48057000 {
    			reg = <0x48057000 0x200>;
    			interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio3";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio4: gpio@48059000 {
    			reg = <0x48059000 0x200>;
    			interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio4";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio5: gpio@4805b000 {
    			reg = <0x4805b000 0x200>;
    			interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio5";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio6: gpio@4805d000 {
    			reg = <0x4805d000 0x200>;
    			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio6";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio7: gpio@48051000 {
    			reg = <0x48051000 0x200>;
    			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio7";
    			gpio-controller;
    			#gpio-cells = <2>;
    		gpio8: gpio@48053000 {
    			reg = <0x48053000 0x200>;
    			interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpio8";
    			gpio-controller;
    			#gpio-cells = <2>;
    		uart1: serial@4806a000 {
    			compatible = "ti,dra742-uart", "ti,omap4-uart";
    			reg = <0x4806a000 0x100>;
    			interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart1";
    			clock-frequency = <48000000>;
    			dmas = <&edma_xbar 49 0>, <&edma_xbar 50 0>;
    			dma-names = "tx", "rx";
    		uart2: serial@4806c000 {
    			reg = <0x4806c000 0x100>;
    			interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart2";
    			dmas = <&edma_xbar 51 0>, <&edma_xbar 52 0>;
    		uart3: serial@48020000 {
    			reg = <0x48020000 0x100>;
    			interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart3";
    			dmas = <&edma_xbar 53 0>, <&edma_xbar 54 0>;
    		uart4: serial@4806e000 {
    			reg = <0x4806e000 0x100>;
    			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart4";
    			dmas = <&edma_xbar 55 0>, <&edma_xbar 56 0>;
    		uart5: serial@48066000 {
    			reg = <0x48066000 0x100>;
    			interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart5";
    			dmas = <&edma_xbar 63 0>, <&edma_xbar 64 0>;
    		uart6: serial@48068000 {
    			reg = <0x48068000 0x100>;
    			interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart6";
    			dmas = <&edma_xbar 79 0>, <&edma_xbar 80 0>;
    		uart7: serial@48420000 {
    			reg = <0x48420000 0x100>;
    			interrupts = <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart7";
    		uart8: serial@48422000 {
    			reg = <0x48422000 0x100>;
    			interrupts = <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart8";
    		uart9: serial@48424000 {
    			reg = <0x48424000 0x100>;
    			interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart9";
    		uart10: serial@4ae2b000 {
    			reg = <0x4ae2b000 0x100>;
    			interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "uart10";
    		mailbox1: mailbox@4a0f4000 {
    			compatible = "ti,omap4-mailbox";
    			reg = <0x4a0f4000 0x200>;
    			interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox1";
    			#mbox-cells = <1>;
    			ti,mbox-num-users = <3>;
    			ti,mbox-num-fifos = <8>;
    		mailbox2: mailbox@4883a000 {
    			reg = <0x4883a000 0x200>;
    			interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox2";
    			#mbox-cells = <1>;
    			ti,mbox-num-users = <4>;
    			ti,mbox-num-fifos = <12>;
    		mailbox3: mailbox@4883c000 {
    			reg = <0x4883c000 0x200>;
    			interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox3";
    			#mbox-cells = <1>;
    		mailbox4: mailbox@4883e000 {
    			reg = <0x4883e000 0x200>;
    			interrupts = <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox4";
    			#mbox-cells = <1>;
    		mailbox5: mailbox@48840000 {
    			reg = <0x48840000 0x200>;
    			interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox5";
    			#mbox-cells = <1>;
    		mailbox6: mailbox@48842000 {
    			reg = <0x48842000 0x200>;
    			interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox6";
    			#mbox-cells = <1>;
    		mailbox7: mailbox@48844000 {
    			reg = <0x48844000 0x200>;
    			interrupts = <GIC_SPI 257 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox7";
    			#mbox-cells = <1>;
    		mailbox8: mailbox@48846000 {
    			reg = <0x48846000 0x200>;
    			interrupts = <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox8";
    			#mbox-cells = <1>;
    		mailbox9: mailbox@4885e000 {
    			reg = <0x4885e000 0x200>;
    			interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox9";
    			#mbox-cells = <1>;
    		mailbox10: mailbox@48860000 {
    			reg = <0x48860000 0x200>;
    			interrupts = <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 271 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox10";
    			#mbox-cells = <1>;
    		mailbox11: mailbox@48862000 {
    			reg = <0x48862000 0x200>;
    			interrupts = <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox11";
    			#mbox-cells = <1>;
    		mailbox12: mailbox@48864000 {
    			reg = <0x48864000 0x200>;
    			interrupts = <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox12";
    			#mbox-cells = <1>;
    		mailbox13: mailbox@48802000 {
    			reg = <0x48802000 0x200>;
    			interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 380 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 381 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mailbox13";
    			#mbox-cells = <1>;
    		timer1: timer@4ae18000 {
    			compatible = "ti,omap5430-timer";
    			reg = <0x4ae18000 0x80>;
    			interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer1";
    			ti,timer-alwon;
    		timer2: timer@48032000 {
    			reg = <0x48032000 0x80>;
    			interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer2";
    		timer3: timer@48034000 {
    			reg = <0x48034000 0x80>;
    			interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer3";
    		timer4: timer@48036000 {
    			reg = <0x48036000 0x80>;
    			interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer4";
    		timer5: timer@48820000 {
    			reg = <0x48820000 0x80>;
    			interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer5";
    		timer6: timer@48822000 {
    			reg = <0x48822000 0x80>;
    			interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer6";
    		timer7: timer@48824000 {
    			reg = <0x48824000 0x80>;
    			interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer7";
    		timer8: timer@48826000 {
    			reg = <0x48826000 0x80>;
    			interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer8";
    		timer9: timer@4803e000 {
    			reg = <0x4803e000 0x80>;
    			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer9";
    		timer10: timer@48086000 {
    			reg = <0x48086000 0x80>;
    			interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer10";
    		timer11: timer@48088000 {
    			reg = <0x48088000 0x80>;
    			interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer11";
    		timer12: timer@4ae20000 {
    			reg = <0x4ae20000 0x80>;
    			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer12";
    			ti,timer-alwon;
    			ti,timer-secure;
    		timer13: timer@48828000 {
    			reg = <0x48828000 0x80>;
    			interrupts = <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer13";
    		timer14: timer@4882a000 {
    			reg = <0x4882a000 0x80>;
    			interrupts = <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer14";
    		timer15: timer@4882c000 {
    			reg = <0x4882c000 0x80>;
    			interrupts = <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer15";
    		timer16: timer@4882e000 {
    			reg = <0x4882e000 0x80>;
    			interrupts = <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "timer16";
    		wdt2: wdt@4ae14000 {
    			compatible = "ti,omap3-wdt";
    			reg = <0x4ae14000 0x80>;
    			interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "wd_timer2";
    		hwspinlock: spinlock@4a0f6000 {
    			compatible = "ti,omap4-hwspinlock";
    			reg = <0x4a0f6000 0x1000>;
    			ti,hwmods = "spinlock";
    			#hwlock-cells = <1>;
    		dmm@4e000000 {
    			compatible = "ti,omap5-dmm";
    			reg = <0x4e000000 0x800>;
    			interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "dmm";
    		ipu1: ipu@58820000 {
    			compatible = "ti,dra7-ipu";
    			reg = <0x58820000 0x10000>;
    			reg-names = "l2ram";
    			ti,hwmods = "ipu1";
    			iommus = <&mmu_ipu1>;
    			ti,rproc-standby-info = <0x4a005520>;
    		ipu2: ipu@55020000 {
    			reg = <0x55020000 0x10000>;
    			ti,hwmods = "ipu2";
    			iommus = <&mmu_ipu2>;
    			ti,rproc-standby-info = <0x4a008920>;
    		dsp1: dsp@40800000 {
    			compatible = "ti,dra7-dsp";
    			reg = <0x40800000 0x48000>,
    			      <0x40e00000 0x8000>,
    			      <0x40f00000 0x8000>;
    			reg-names = "l2ram", "l1pram", "l1dram";
    			ti,hwmods = "dsp1";
    			syscon-bootreg = <&scm_conf 0x55c>;
    			iommus = <&mmu0_dsp1>, <&mmu1_dsp1>;
    			ti,rproc-standby-info = <0x4a005420>;
    		gpu: gpu@56000000 {
    			compatible = "ti,dra7-sgx544", "img,sgx544";
    			reg = <0x56000000 0x10000>;
    			reg-names = "gpu_ocp_base";
    			interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "gpu";
    			clocks = <&l3_iclk_div>, <&gpu_core_gclk_mux>,
    				 <&gpu_hyd_gclk_mux>;
    			clock-names = "iclk", "fclk1", "fclk2";
    		bb2d: bb2d@59000000 {
    			compatible = "ti,dra7-bb2d";
    			reg = <0x59000000 0x0700>;
    			interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "bb2d";
    			clocks = <&dpll_core_h24x2_ck>;
    			clock-names = "fck";
    		i2c1: i2c@48070000 {
    			compatible = "ti,omap4-i2c";
    			reg = <0x48070000 0x100>;
    			interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "i2c1";
    		i2c2: i2c@48072000 {
    			reg = <0x48072000 0x100>;
    			interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "i2c2";
    		i2c3: i2c@48060000 {
    			reg = <0x48060000 0x100>;
    			interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "i2c3";
    		i2c4: i2c@4807a000 {
    			reg = <0x4807a000 0x100>;
    			interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "i2c4";
    		i2c5: i2c@4807c000 {
    			reg = <0x4807c000 0x100>;
    			interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "i2c5";
    		mmc1: mmc@4809c000 {
    			compatible = "ti,dra7-hsmmc", "ti,omap4-hsmmc";
    			reg = <0x4809c000 0x400>;
    			interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmc1";
    			ti,dual-volt;
    			ti,needs-special-reset;
    			dmas = <&sdma_xbar 61>, <&sdma_xbar 62>;
    			pbias-supply = <&pbias_mmc_reg>;
    			sd-uhs-sdr104;
    			sd-uhs-sdr50;
    			sd-uhs-ddr50;
    			sd-uhs-sdr25;
    			sd-uhs-sdr12;
    		mmc2: mmc@480b4000 {
    			reg = <0x480b4000 0x400>;
    			interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmc2";
    			dmas = <&sdma_xbar 47>, <&sdma_xbar 48>;
    #if 0
    			sd-uhs-sdr25;
    			sd-uhs-sdr12;
    			mmc-hs200-1_8v;
    			mmc-ddr-1_8v;
    #endif
    		mmc3: mmc@480ad000 {
    			reg = <0x480ad000 0x400>;
    			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmc3";
    			dmas = <&sdma_xbar 77>, <&sdma_xbar 78>;
    			sd-uhs-sdr12;
    			sd-uhs-sdr25;
    			sd-uhs-sdr50;
    		mmc4: mmc@480d1000 {
    			reg = <0x480d1000 0x400>;
    			interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmc4";
    			dmas = <&sdma_xbar 57>, <&sdma_xbar 58>;
    #if 0
    			sd-uhs-sdr12;
    			sd-uhs-sdr25;
    #endif
    		mmu0_dsp1: mmu@40d01000 {
    			compatible = "ti,dra7-dsp-iommu";
    			reg = <0x40d01000 0x100>;
    			interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmu0_dsp1";
    			#iommu-cells = <0>;
    			ti,syscon-mmuconfig = <&dsp1_system 0x0>;
    		mmu1_dsp1: mmu@40d02000 {
    			reg = <0x40d02000 0x100>;
    			interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmu1_dsp1";
    			#iommu-cells = <0>;
    			ti,syscon-mmuconfig = <&dsp1_system 0x1>;
    		mmu_ipu1: mmu@58882000 {
    			compatible = "ti,dra7-iommu";
    			reg = <0x58882000 0x100>;
    			interrupts = <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmu_ipu1";
    			#iommu-cells = <0>;
    			ti,iommu-bus-err-back;
    		mmu_ipu2: mmu@55082000 {
    			reg = <0x55082000 0x100>;
    			interrupts = <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "mmu_ipu2";
    			#iommu-cells = <0>;
    		pruss1: pruss@4b200000 {
    			compatible = "ti,am5728-pruss";
    			ti,hwmods = "pruss1";
    			reg = <0x4b200000 0x2000>,
    			      <0x4b202000 0x2000>,
    			      <0x4b210000 0x8000>,
    			      <0x4b226000 0x2000>,
    			      <0x4b22e000 0x31c>,
    			      <0x4b232000 0x58>;
    			reg-names = "dram0", "dram1", "shrdram2", "cfg",
    				    "iep", "mii_rt";
    			#size-cells = <1>;
    			ranges;
    			pruss1_intc: intc@4b220000 {
    				compatible = "ti,am5728-pruss-intc";
    				reg = <0x4b220000 0x2000>;
    				reg-names = "intc";
    				interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
    				interrupt-names = "host2", "host3", "host4",
    						  "host5", "host6", "host7",
    						  "host8", "host9";
    			pru1_0: pru0@4b234000 {
    				compatible = "ti,am5728-pru";
    				reg = <0x4b234000 0x3000>,
    				      <0x4b222000 0x400>,
    				      <0x4b222400 0x100>;
    				reg-names = "iram", "control", "debug";
    			pru1_1: pru1@4b238000 {
    				reg = <0x4b238000 0x3000>,
    				      <0x4b224000 0x400>,
    				      <0x4b224400 0x100>;
    			pruss1_mdio: mdio@4b232400 {
    				compatible = "ti,davinci_mdio";
    				#size-cells = <0>;
    				clocks = <&dpll_gmac_h13x2_ck>;
    				bus_freq = <1000000>;
    				reg = <0x4b232400 0x90>;
    		pruss2: pruss@4b280000 {
    			ti,hwmods = "pruss2";
    			reg = <0x4b280000 0x2000>,
    			      <0x4b282000 0x2000>,
    			      <0x4b290000 0x8000>,
    			      <0x4b2a6000 0x2000>,
    			      <0x4b2ae000 0x31c>,
    			      <0x4b2b2000 0x58>;
    				    "iep", "mii_rt";
    			#size-cells = <1>;
    			ranges;
    			pruss2_intc: intc@4b2a0000 {
    				reg = <0x4b2a0000 0x2000>;
    				reg-names = "intc";
    				interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
    					     <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>;
    						  "host8", "host9";
    			pru2_0: pru0@4b2b4000 {
    				reg = <0x4b2b4000 0x3000>,
    				      <0x4b2a2000 0x400>,
    				      <0x4b2a2400 0x100>;
    			pru2_1: pru1@4b2b8000 {
    				reg = <0x4b2b8000 0x3000>,
    				      <0x4b2a4000 0x400>,
    				      <0x4b2a4400 0x100>;
    			pruss2_mdio: mdio@4b2b2400 {
    				#size-cells = <0>;
    				reg = <0x4b2b2400 0x90>;
    		abb_mpu: regulator-abb-mpu {
    			compatible = "ti,abb-v3";
    			regulator-name = "abb_mpu";
    			#size-cells = <0>;
    			clocks = <&sys_clkin1>;
    			ti,settling-time = <50>;
    			ti,clock-cycles = <16>;
    			reg = <0x4ae07ddc 0x4>, <0x4ae07de0 0x4>,
    			      <0x4ae06014 0x4>, <0x4a003b20 0xc>,
    			      <0x4ae0c158 0x4>;
    			reg-names = "setup-address", "control-address",
    				    "int-address", "efuse-address",
    				    "ldo-address";
    			ti,tranxdone-status-mask = <0x80>;
    			/* LDOVBBMPU_FBB_MUX_CTRL */
    			ti,ldovbb-override-mask = <0x400>;
    			/* LDOVBBMPU_FBB_VSET_OUT */
    			ti,ldovbb-vset-mask = <0x1F>;
    			 * NOTE: only FBB mode used but actual vset will
    			 * determine final biasing
    			ti,abb_info = <
    			/*uV		ABB	efuse	rbb_m fbb_m	vset_m*/
    			1060000		0	0x0	0 0x02000000 0x01F00000
    			1160000		0	0x4	0 0x02000000 0x01F00000
    			1210000		0	0x8	0 0x02000000 0x01F00000
    		abb_ivahd: regulator-abb-ivahd {
    			regulator-name = "abb_ivahd";
    			#size-cells = <0>;
    			reg = <0x4ae07e34 0x4>, <0x4ae07e24 0x4>,
    			      <0x4ae06010 0x4>, <0x4a0025cc 0xc>,
    			      <0x4a002470 0x4>;
    				    "ldo-address";
    			ti,tranxdone-status-mask = <0x40000000>;
    			/* LDOVBBIVA_FBB_MUX_CTRL */
    			/* LDOVBBIVA_FBB_VSET_OUT */
    			ti,abb_info = <
    			1055000		0	0x0	0 0x02000000 0x01F00000
    			1150000		0	0x4	0 0x02000000 0x01F00000
    			1250000		0	0x8	0 0x02000000 0x01F00000
    		abb_dspeve: regulator-abb-dspeve {
    			regulator-name = "abb_dspeve";
    			#size-cells = <0>;
    			reg = <0x4ae07e30 0x4>, <0x4ae07e20 0x4>,
    			      <0x4ae06010 0x4>, <0x4a0025e0 0xc>,
    			      <0x4a00246c 0x4>;
    				    "ldo-address";
    			ti,tranxdone-status-mask = <0x20000000>;
    			/* LDOVBBDSPEVE_FBB_MUX_CTRL */
    			/* LDOVBBDSPEVE_FBB_VSET_OUT */
    			ti,abb_info = <
    		abb_gpu: regulator-abb-gpu {
    			regulator-name = "abb_gpu";
    			#size-cells = <0>;
    			reg = <0x4ae07de4 0x4>, <0x4ae07de8 0x4>,
    			      <0x4ae06010 0x4>, <0x4a003b08 0xc>,
    			      <0x4ae0c154 0x4>;
    				    "ldo-address";
    			ti,tranxdone-status-mask = <0x10000000>;
    			/* LDOVBBGPU_FBB_MUX_CTRL */
    			/* LDOVBBGPU_FBB_VSET_OUT */
    			ti,abb_info = <
    			1090000		0	0x0	0 0x02000000 0x01F00000
    			1210000		0	0x4	0 0x02000000 0x01F00000
    			1280000		0	0x8	0 0x02000000 0x01F00000
    		oppdm_mpu: oppdm@4a003b20 {
    			compatible = "ti,omap5-oppdm";
    			#oppdm-cells = <0>;
    			vbb-supply = <&abb_mpu>;
    			reg = <0x4a003b20 0xc>;
    			ti,efuse-settings = <
    			/* uV   offset */
    			1060000 0x0
    			1160000 0x4
    			1210000 0x8
    			ti,absolute-max-voltage-uv = <1500000>;
    		oppdm_ivahd: oppdm@4a0025cc {
    			#oppdm-cells = <0>;
    			vbb-supply = <&abb_ivahd>;
    			reg = <0x4a0025cc 0xc>;
    			/* uV   offset */
    			1055000 0x0
    			1150000 0x4
    			1250000 0x8
    		oppdm_dspeve: oppdm@4a0025e0 {
    			#oppdm-cells = <0>;
    			vbb-supply = <&abb_dspeve>;
    			reg = <0x4a0025e0 0xc>;
    			/* uV   offset */
    			1055000 0x0
    			1150000 0x4
    			1250000 0x8
    		oppdm_gpu: oppdm@4a003b08 {
    			#oppdm-cells = <0>;
    			vbb-supply = <&abb_gpu>;
    			reg = <0x4a003b08 0xc>;
    			/* uV   offset */
    			1090000 0x0
    			1210000 0x4
    			1280000 0x8
    		oppdm_core: oppdm@4a0025f4 {
    			compatible = "ti,omap5-core-oppdm";
    			#oppdm-cells = <0>;
    			reg = <0x4a0025f4 0x4>;
    			/* uV   offset */
    			1090000 0x0
    		mcspi1: spi@48098000 {
    			compatible = "ti,omap4-mcspi";
    			reg = <0x48098000 0x200>;
    			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "mcspi1";
    			ti,spi-num-cs = <4>;
    			dmas = <&sdma_xbar 35>,
    			       <&sdma_xbar 36>,
    			       <&sdma_xbar 37>,
    			       <&sdma_xbar 38>,
    			       <&sdma_xbar 39>,
    			       <&sdma_xbar 40>,
    			       <&sdma_xbar 41>,
    			       <&sdma_xbar 42>;
    			dma-names = "tx0", "rx0", "tx1", "rx1",
    				    "tx2", "rx2", "tx3", "rx3";
    		mcspi2: spi@4809a000 {
    			reg = <0x4809a000 0x200>;
    			interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "mcspi2";
    			ti,spi-num-cs = <2>;
    			dmas = <&sdma_xbar 43>,
    			       <&sdma_xbar 44>,
    			       <&sdma_xbar 45>,
    			       <&sdma_xbar 46>;
    			dma-names = "tx0", "rx0", "tx1", "rx1";
    		mcspi3: spi@480b8000 {
    			reg = <0x480b8000 0x200>;
    			interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "mcspi3";
    			dmas = <&sdma_xbar 15>, <&sdma_xbar 16>;
    			dma-names = "tx0", "rx0";
    		mcspi4: spi@480ba000 {
    			reg = <0x480ba000 0x200>;
    			interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			ti,hwmods = "mcspi4";
    			ti,spi-num-cs = <1>;
    			dmas = <&sdma_xbar 70>, <&sdma_xbar 71>;
    		qspi: qspi@4b300000 {
    			compatible = "ti,dra7xxx-qspi";
    			reg = <0x4b300000 0x100>,
    			      <0x5c000000 0x4000000>;
    			reg-names = "qspi_base", "qspi_mmap";
    			syscon-chipselects = <&scm_conf 0x558>;
    			#size-cells = <0>;
    			ti,hwmods = "qspi";
    			clocks = <&qspi_gfclk_div>;
    			num-cs = <4>;
    			interrupts = <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>;
    		/* OCP2SCP3 */
    		ocp2scp@4a090000 {
    			compatible = "ti,omap-ocp2scp";
    			#size-cells = <1>;
    			ranges;
    			reg = <0x4a090000 0x20>;
    			ti,hwmods = "ocp2scp3";
    			sata_phy: phy@4A096000 {
    				compatible = "ti,phy-pipe3-sata";
    				reg = <0x4A096000 0x80>, /* phy_rx */
    				      <0x4A096400 0x64>, /* phy_tx */
    				      <0x4A096800 0x40>; /* pll_ctrl */
    				reg-names = "phy_rx", "phy_tx", "pll_ctrl";
    				syscon-phy-power = <&scm_conf 0x374>;
    				clocks = <&sys_clkin1>, <&sata_ref_clk>;
    				clock-names = "sysclk", "refclk";
    				syscon-pllreset = <&scm_conf 0x3fc>;
    				#phy-cells = <0>;
    			pcie1_phy: pciephy@4a094000 {
    				compatible = "ti,phy-pipe3-pcie";
    				reg = <0x4a094000 0x80>, /* phy_rx */
    				      <0x4a094400 0x64>; /* phy_tx */
    				reg-names = "phy_rx", "phy_tx";
    				syscon-phy-power = <&scm_conf_pcie 0x1c>;
    				syscon-pcs = <&scm_conf_pcie 0x10>;
    				clocks = <&dpll_pcie_ref_ck>,
    					 <&dpll_pcie_ref_m2ldo_ck>,
    					 <&optfclk_pciephy1_32khz>,
    					 <&optfclk_pciephy1_clk>,
    					 <&optfclk_pciephy1_div_clk>,
    					 <&optfclk_pciephy_div>,
    					 <&sys_clkin1>;
    				clock-names = "dpll_ref", "dpll_ref_m2",
    					      "wkupclk", "refclk",
    					      "div-clk", "phy-div", "sysclk";
    				#phy-cells = <0>;
    			pcie2_phy: pciephy@4a095000 {
    				reg = <0x4a095000 0x80>, /* phy_rx */
    				      <0x4a095400 0x64>; /* phy_tx */
    				syscon-phy-power = <&scm_conf_pcie 0x20>;
    					 <&optfclk_pciephy2_32khz>,
    					 <&optfclk_pciephy2_clk>,
    					 <&optfclk_pciephy2_div_clk>,
    					 <&sys_clkin1>;
    				#phy-cells = <0>;
    		sata: sata@4a141100 {
    			compatible = "snps,dwc-ahci";
    			reg = <0x4a140000 0x1100>, <0x4a141100 0x7>;
    			interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;
    			phys = <&sata_phy>;
    			phy-names = "sata-phy";
    			clocks = <&sata_ref_clk>;
    			ti,hwmods = "sata";
    		rtc: rtc@48838000 {
    			compatible = "ti,am3352-rtc";
    			reg = <0x48838000 0x100>;
    			interrupts = <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "rtcss";
    			clocks = <&sys_32k_ck>;
    		/* OCP2SCP1 */
    		ocp2scp@4a080000 {
    			#size-cells = <1>;
    			ranges;
    			reg = <0x4a080000 0x20>;
    			ti,hwmods = "ocp2scp1";
    			usb2_phy1: phy@4a084000 {
    				compatible = "ti,dra7x-usb2", "ti,omap-usb2";
    				reg = <0x4a084000 0x400>;
    				syscon-phy-power = <&scm_conf 0x300>;
    				clocks = <&usb_phy1_always_on_clk32k>,
    					 <&usb_otg_ss1_refclk960m>;
    				clock-names =	"wkupclk",
    						"refclk";
    				#phy-cells = <0>;
    			usb2_phy2: phy@4a085000 {
    				compatible = "ti,dra7x-usb2-phy2",
    					     "ti,omap-usb2";
    				reg = <0x4a085000 0x400>;
    				syscon-phy-power = <&scm_conf 0xe74>;
    				clocks = <&usb_phy2_always_on_clk32k>,
    					 <&usb_otg_ss2_refclk960m>;
    						"refclk";
    				#phy-cells = <0>;
    			usb3_phy1: phy@4a084400 {
    				compatible = "ti,omap-usb3";
    				reg = <0x4a084400 0x80>,
    				      <0x4a084800 0x64>,
    				      <0x4a084c00 0x40>;
    				syscon-phy-power = <&scm_conf 0x370>;
    				clocks = <&usb_phy3_always_on_clk32k>,
    					 <&sys_clkin1>,
    						"sysclk",
    						"refclk";
    				#phy-cells = <0>;
    		omap_dwc3_1: omap_dwc3_1@48880000 {
    			compatible = "ti,dwc3";
    			ti,hwmods = "usb_otg_ss1";
    			reg = <0x48880000 0x10000>;
    			interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <1>;
    			utmi-mode = <2>;
    			ranges;
    			usb1: usb@48890000 {
    				compatible = "snps,dwc3";
    				reg = <0x48890000 0x17000>;
    				interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
    				interrupt-names = "peripheral",
    						  "host",
    						  "otg";
    				phys = <&usb2_phy1>, <&usb3_phy1>;
    				phy-names = "usb2-phy", "usb3-phy";
    				tx-fifo-resize;
    				maximum-speed = "super-speed";
    				dr_mode = "otg";
    				snps,dis_u3_susphy_quirk;
    				snps,dis_u2_susphy_quirk;
    		omap_dwc3_2: omap_dwc3_2@488c0000 {
    			ti,hwmods = "usb_otg_ss2";
    			reg = <0x488c0000 0x10000>;
    			interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <1>;
    			utmi-mode = <2>;
    			ranges;
    			usb2: usb@488d0000 {
    				reg = <0x488d0000 0x17000>;
    				interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
    						  "host",
    						  "otg";
    				phys = <&usb2_phy2>;
    				phy-names = "usb2-phy";
    				tx-fifo-resize;
    				maximum-speed = "high-speed";
    				dr_mode = "otg";
    		/* IRQ for DWC3_3 and DWC3_4 need IRQ crossbar */
    		omap_dwc3_3: omap_dwc3_3@48900000 {
    			ti,hwmods = "usb_otg_ss3";
    			reg = <0x48900000 0x10000>;
    			interrupts = <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <1>;
    			utmi-mode = <2>;
    			ranges;
    			//status = "disabled";
    			usb3: usb@48910000 {
    				reg = <0x48910000 0x17000>;
    				interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>,
    						  "host",
    						  "otg";
    				tx-fifo-resize;
    				dr_mode = "otg";
    		elm: elm@48078000 {
    			compatible = "ti,am3352-elm";
    			reg = <0x48078000 0xfc0>;      /* device IO registers */
    			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
    			ti,hwmods = "elm";
    		gpmc: gpmc@50000000 {
    			compatible = "ti,am3352-gpmc";
    			ti,hwmods = "gpmc";
    			reg = <0x50000000 0x37c>;      /* device IO registers */
    			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 4 0>;
    			dma-names = "rxtx";
    			gpmc,num-cs = <8>;
    			gpmc,num-waitpins = <2>;
    			#address-cells = <2>;
    			#size-cells = <1>;
    			gpio-controller;
    			#gpio-cells = <2>;
    		atl: atl@4843c000 {
    			compatible = "ti,dra7-atl";
    			reg = <0x4843c000 0x3ff>;
    			ti,hwmods = "atl";
    			ti,provided-clocks = <&atl_clkin0_ck>, <&atl_clkin1_ck>,
    					     <&atl_clkin2_ck>, <&atl_clkin3_ck>;
    			clocks = <&atl_gfclk_mux>;
    		mcasp1: mcasp@48460000 {
    			compatible = "ti,dra7-mcasp-audio";
    			ti,hwmods = "mcasp1";
    			reg = <0x48460000 0x2000>,
    			      <0x45800000 0x1000>;
    			reg-names = "mpu","dat";
    			interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>;
    			interrupt-names = "tx", "rx";
    			dmas = <&edma_xbar 129 1>, <&edma_xbar 128 1>;
    			clocks = <&mcasp1_aux_gfclk_mux>, <&mcasp1_ahclkx_mux>,
    				 <&mcasp1_ahclkr_mux>;
    			clock-names = "fck", "ahclkx", "ahclkr";
    		mcasp2: mcasp@48464000 {
    			ti,hwmods = "mcasp2";
    			reg = <0x48464000 0x2000>,
    			      <0x45c00000 0x1000>;
    			interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 131 1>, <&edma_xbar 130 1>;
    			clocks = <&mcasp2_aux_gfclk_mux>, <&mcasp2_ahclkx_mux>,
    				 <&mcasp2_ahclkr_mux>;
    		mcasp3: mcasp@48468000 {
    			ti,hwmods = "mcasp3";
    			reg = <0x48468000 0x2000>,
    			      <0x46000000 0x1000>;
    			interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 133 1>, <&edma_xbar 132 1>;
    			clocks = <&mcasp3_aux_gfclk_mux>, <&mcasp3_ahclkx_mux>;
    			clock-names = "fck", "ahclkx";
    		mcasp4: mcasp@4846c000 {
    			ti,hwmods = "mcasp4";
    			reg = <0x4846c000 0x2000>,
    			      <0x48436000 0x1000>;
    			interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 135 1>, <&edma_xbar 134 1>;
    			clocks = <&mcasp4_aux_gfclk_mux>, <&mcasp4_ahclkx_mux>;
    		mcasp5: mcasp@48470000 {
    			ti,hwmods = "mcasp5";
    			reg = <0x48470000 0x2000>,
    			      <0x4843a000 0x1000>;
    			interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 137 1>, <&edma_xbar 136 1>;
    			clocks = <&mcasp5_aux_gfclk_mux>, <&mcasp5_ahclkx_mux>;
    		mcasp6: mcasp@48474000 {
    			ti,hwmods = "mcasp6";
    			reg = <0x48474000 0x2000>,
    			      <0x4844c000 0x1000>;
    			interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 139 1>, <&edma_xbar 138 1>;
    			clocks = <&mcasp6_aux_gfclk_mux>, <&mcasp6_ahclkx_mux>;
    		mcasp7: mcasp@48478000 {
    			ti,hwmods = "mcasp7";
    			reg = <0x48478000 0x2000>,
    			      <0x48450000 0x1000>;
    			interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 141 1>, <&edma_xbar 140 1>;
    			clocks = <&mcasp7_aux_gfclk_mux>, <&mcasp7_ahclkx_mux>;
    		mcasp8: mcasp@4847c000 {
    			ti,hwmods = "mcasp8";
    			reg = <0x4847c000 0x2000>,
    			      <0x48454000 0x1000>;
    			interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 143 1>, <&edma_xbar 142 1>;
    			clocks = <&mcasp8_aux_gfclk_mux>, <&mcasp8_ahclkx_mux>;
    		crossbar_mpu: crossbar@4a002a48 {
    			compatible = "ti,irq-crossbar";
    			reg = <0x4a002a48 0x130>;
    			ti,max-irqs = <160>;
    			ti,max-crossbar-sources = <MAX_SOURCES>;
    			ti,reg-size = <2>;
    			ti,irqs-reserved = <0 1 2 3 5 6 131 132>;
    			ti,irqs-skip = <10 133 139 140>;
    			ti,irqs-safe-map = <0>;
    		mac: ethernet@48484000 {
    			compatible = "ti,dra7-cpsw","ti,cpsw";
    			ti,hwmods = "gmac";
    			clocks = <&dpll_gmac_ck>, <&gmac_gmii_ref_clk_div>;
    			clock-names = "fck", "cpts";
    			cpdma_channels = <8>;
    			ale_entries = <1024>;
    			bd_ram_size = <0x2000>;
    			no_bd_ram = <0>;
    			rx_descs = <64>;
    			mac_control = <0x20>;
    			slaves = <2>;
    			active_slave = <0>;
    			cpts_clock_mult = <0x80000000>;
    			cpts_clock_shift = <29>;
    			reg = <0x48484000 0x1000
    			       0x48485200 0x2E00>;
    			#size-cells = <1>;
    			 * Do not allow gating of cpsw clock as workaround
    			 * for errata i877. Keeping internal clock disabled
    			 * causes the device switching characteristics
    			 * to degrade over time and eventually fail to meet
    			 * the data manual delay time/skew specs.
    			ti,no-idle;
    			 * rx_thresh_pend
    			 * rx_pend
    			 * tx_pend
    			 * misc_pend
    			interrupts = <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>;
    			ranges;
    			davinci_mdio: mdio@48485000 {
    				compatible = "ti,cpsw-mdio";
    				#size-cells = <0>;
    				ti,hwmods = "davinci_mdio";
    				reg = <0x48485000 0x100>;
    			cpsw_emac0: slave@48480200 {
    				/* Filled in by U-Boot */
    				mac-address = [ 00 00 00 00 00 00 ];
    			cpsw_emac1: slave@48480300 {
    			phy_sel: cpsw-phy-sel@4a002554 {
    				compatible = "ti,dra7xx-cpsw-phy-sel";
    				reg= <0x4a002554 0x4>;
    				reg-names = "gmii-sel";
    		dcan1: can@481cc000 {
    			compatible = "ti,dra7-d_can";
    			ti,hwmods = "dcan1";
    			reg = <0x4ae3c000 0x2000>;
    			syscon-raminit = <&scm_conf 0x558 0>;
    			interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>;
    			clocks = <&dcan1_sys_clk_mux>;
    		dcan2: can@481d0000 {
    			ti,hwmods = "dcan2";
    			reg = <0x48480000 0x2000>;
    			syscon-raminit = <&scm_conf 0x558 1>;
    			interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>;
    		dss: dss@58000000 {
    			compatible = "ti,dra7-dss";
    			/* 'reg' defined in dra72x.dtsi and dra74x.dtsi */
    			/* 'clocks' defined in dra72x.dtsi and dra74x.dtsi */
    			ti,hwmods = "dss_core";
    			/* CTRL_CORE_DSS_PLL_CONTROL */
    			syscon-pll-ctrl = <&scm_conf 0x538>;
    			#size-cells = <1>;
    			ranges;
    			dispc@58001000 {
    				compatible = "ti,dra7-dispc";
    				reg = <0x58001000 0x1000>;
    				interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
    				ti,hwmods = "dss_dispc";
    				clocks = <&dss_dss_clk>;
    				/* CTRL_CORE_SMA_SW_1 */
    				syscon-pol = <&scm_conf 0x534>;
    			hdmi: encoder@58060000 {
    				compatible = "ti,dra7-hdmi";
    				reg = <0x58040000 0x200>,
    				      <0x58040200 0x80>,
    				      <0x58040300 0x80>,
    				      <0x58060000 0x19000>;
    				reg-names = "wp", "pll", "phy", "core";
    				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
    				ti,hwmods = "dss_hdmi";
    				clocks = <&dss_48mhz_clk>, <&dss_hdmi_clk>;
    				clock-names = "fck", "sys_clk";
    				dmas = <&sdma_xbar 76>;
    				dma-names = "audio_tx";
    		vpe {
    			compatible = "ti,vpe";
    			ti,hwmods = "vpe";
    			clocks = <&dpll_core_h23x2_ck>;
    			reg = <0x489d0000 0x120>,
    			      <0x489d0300 0x20>,
    			      <0x489d0400 0x20>,
    			      <0x489d0500 0x20>,
    			      <0x489d0600 0x3c>,
    			      <0x489d0700 0x80>,
    			      <0x489d5700 0x18>,
    			      <0x489dd000 0x400>;
    			reg-names = "vpe_top",
    				    "vpe_chr_us0",
    				    "vpe_chr_us1",
    				    "vpe_chr_us2",
    				    "vpe_dei",
    				    "sc",
    				    "csc",
    				    "vpdma";
    			interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    		vip1: vip@0x48970000 {
    			compatible = "ti,vip1";
    			reg = <0x48970000 0x114>,
    			      <0x48975500 0xD8>,
    			      <0x48975700 0x18>,
    			      <0x48975800 0x80>,
    			      <0x48975a00 0xD8>,
    			      <0x48975c00 0x18>,
    			      <0x48975d00 0x80>,
    			      <0x4897d000 0x400>;
    			reg-names = "vip",
    				    "parser0",
    				    "csc0",
    				    "sc0",
    				    "parser1",
    				    "csc1",
    				    "sc1",
    				    "vpdma";
    			ti,hwmods = "vip1";
    			interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>,
    				     <GIC_SPI 392 IRQ_TYPE_LEVEL_HIGH>;
    			#size-cells = <0>;
    			vin1a: port@0 {
    				#size-cells = <0>;
    				reg = <0>;
    			vin2a: port@1 {
    				#size-cells = <0>;
    				reg = <1>;
    			vin1b: port@2 {
    				#size-cells = <0>;
    				reg = <2>;
    			vin2b: port@3 {
    				#size-cells = <0>;
    				reg = <3>;
    		epwmss0: epwmss@4843e000 {
    			compatible = "ti,dra7xx-pwmss", "ti,am33xx-pwmss";
    			reg = <0x4843e000 0x30>;
    			ti,hwmods = "epwmss0";
    			#size-cells = <1>;
    			ranges;
    			ehrpwm0: pwm@4843e200 {
    				compatible = "ti,dra7xx-ehrpwm",
    					     "ti,am33xx-ehrpwm";
    				#pwm-cells = <3>;
    				reg = <0x4843e200 0x80>;
    				clocks = <&ehrpwm0_tbclk>;
    				clock-names = "tbclk";
    			ecap0: ecap@4843e100 {
    				compatible = "ti,dra7xx-ecap",
    					     "ti,am33xx-ecap";
    				#pwm-cells = <3>;
    				reg = <0x4843e100 0x80>;
    		epwmss1: epwmss@48440000 {
    			reg = <0x48440000 0x30>;
    			ti,hwmods = "epwmss1";
    			#size-cells = <1>;
    			ranges;
    			ehrpwm1: pwm@48440200 {
    					     "ti,am33xx-ehrpwm";
    				#pwm-cells = <3>;
    				reg = <0x48440200 0x80>;
    				clocks = <&ehrpwm1_tbclk>;
    			ecap1: ecap@48440100 {
    					     "ti,am33xx-ecap";
    				#pwm-cells = <3>;
    				reg = <0x48440100 0x80>;
    		epwmss2: epwmss@48442000 {
    			reg = <0x48442000 0x30>;
    			ti,hwmods = "epwmss2";
    			#size-cells = <1>;
    			ranges;
    			ehrpwm2: pwm@48442200 {
    					     "ti,am33xx-ehrpwm";
    				#pwm-cells = <3>;
    				reg = <0x48442200 0x80>;
    				clocks = <&ehrpwm2_tbclk>;
    			ecap2: ecap@48442100 {
    					     "ti,am33xx-ecap";
    				#pwm-cells = <3>;
    				reg = <0x48442100 0x80>;
    		aes1: aes@4b500000 {
    			compatible = "ti,omap4-aes";
    			ti,hwmods = "aes1";
    			reg = <0x4b500000 0xa0>;
    			interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 111 0>, <&edma_xbar 110 0>;
    			clocks = <&l3_iclk_div>;
    		aes2: aes@4b700000 {
    			ti,hwmods = "aes2";
    			reg = <0x4b700000 0xa0>;
    			interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 114 0>, <&edma_xbar 113 0>;
    		des: des@480a5000 {
    			compatible = "ti,omap4-des";
    			ti,hwmods = "des";
    			reg = <0x480a5000 0xa0>;
    			interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&sdma_xbar 117>, <&sdma_xbar 116>;
    		sham: sham@53100000 {
    			compatible = "ti,omap5-sham";
    			ti,hwmods = "sham";
    			reg = <0x4b101000 0x300>;
    			interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
    			dmas = <&edma_xbar 119 0>;
    			dma-names = "rx";
    		rng: rng@48090000 {
    			compatible = "ti,omap4-rng";
    			ti,hwmods = "rng";
    			reg = <0x48090000 0x2000>;
    			interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>;
    	thermal_zones: thermal-zones {
    		#include "omap4-cpu-thermal.dtsi"
    		#include "omap5-gpu-thermal.dtsi"
    		#include "omap5-core-thermal.dtsi"
    		#include "dra7-dspeve-thermal.dtsi"
    		#include "dra7-iva-thermal.dtsi"
    &cpu_thermal {
    	polling-delay = <500>; /* milliseconds */
    /include/ "dra7xx-clocks.dtsi"
     * Device Tree Source for DRA7xx clock data
     * Copyright (C) 2013 Texas Instruments, Inc.
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    &cm_core_aon_clocks {
    	atl_clkin0_ck: atl_clkin0_ck {
    		#clock-cells = <0>;
    		compatible = "ti,dra7-atl-clock";
    	atl_clkin1_ck: atl_clkin1_ck {
    		#clock-cells = <0>;
    	atl_clkin2_ck: atl_clkin2_ck {
    		#clock-cells = <0>;
    	atl_clkin3_ck: atl_clkin3_ck {
    		#clock-cells = <0>;
    	hdmi_clkin_ck: hdmi_clkin_ck {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    		clock-frequency = <0>;
    	mlb_clkin_ck: mlb_clkin_ck {
    		#clock-cells = <0>;
    	mlbp_clkin_ck: mlbp_clkin_ck {
    		#clock-cells = <0>;
    	pciesref_acs_clk_ck: pciesref_acs_clk_ck {
    		#clock-cells = <0>;
    		clock-frequency = <100000000>;
    	ref_clkin0_ck: ref_clkin0_ck {
    		#clock-cells = <0>;
    	ref_clkin1_ck: ref_clkin1_ck {
    		#clock-cells = <0>;
    	ref_clkin2_ck: ref_clkin2_ck {
    		#clock-cells = <0>;
    	ref_clkin3_ck: ref_clkin3_ck {
    		#clock-cells = <0>;
    	rmii_clk_ck: rmii_clk_ck {
    		#clock-cells = <0>;
    	sdvenc_clkin_ck: sdvenc_clkin_ck {
    		#clock-cells = <0>;
    	secure_32k_clk_src_ck: secure_32k_clk_src_ck {
    		#clock-cells = <0>;
    		clock-frequency = <32768>;
    	sys_clk32_crystal_ck: sys_clk32_crystal_ck {
    		#clock-cells = <0>;
    	sys_clk32_pseudo_ck: sys_clk32_pseudo_ck {
    		#clock-cells = <0>;
    		compatible = "fixed-factor-clock";
    		clock-mult = <1>;
    		clock-div = <610>;
    	virt_12000000_ck: virt_12000000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <12000000>;
    	virt_13000000_ck: virt_13000000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <13000000>;
    	virt_16800000_ck: virt_16800000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <16800000>;
    	virt_19200000_ck: virt_19200000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <19200000>;
    	virt_20000000_ck: virt_20000000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <20000000>;
    	virt_26000000_ck: virt_26000000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <26000000>;
    	virt_27000000_ck: virt_27000000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <27000000>;
    	virt_38400000_ck: virt_38400000_ck {
    		#clock-cells = <0>;
    		clock-frequency = <38400000>;
    	sys_clkin2: sys_clkin2 {
    		#clock-cells = <0>;
    		clock-frequency = <22579200>;
    	usb_otg_clkin_ck: usb_otg_clkin_ck {
    		#clock-cells = <0>;
    	video1_clkin_ck: video1_clkin_ck {
    		#clock-cells = <0>;
    	video1_m2_clkin_ck: video1_m2_clkin_ck {
    		#clock-cells = <0>;
    	video2_clkin_ck: video2_clkin_ck {
    		#clock-cells = <0>;
    	video2_m2_clkin_ck: video2_m2_clkin_ck {
    		#clock-cells = <0>;
    	dpll_abe_ck: dpll_abe_ck {
    		#clock-cells = <0>;
    		compatible = "ti,omap4-dpll-m4xen-clock";
    		clocks = <&abe_dpll_clk_mux>, <&abe_dpll_bypass_clk_mux>;
    		reg = <0x01e0>, <0x01e4>, <0x01ec>, <0x01e8>;
    	dpll_abe_x2_ck: dpll_abe_x2_ck {
    		#clock-cells = <0>;
    		compatible = "ti,omap4-dpll-x2-clock";
    		clocks = <&dpll_abe_ck>;
    	dpll_abe_m2x2_ck: dpll_abe_m2x2_ck {
    		#clock-cells = <0>;
    		compatible = "ti,divider-clock";
    		clocks = <&dpll_abe_x2_ck>;
    		ti,max-div = <31>;
    		ti,autoidle-shift = <8>;
    		reg = <0x01f0>;
    		ti,index-starts-at-one;
    		ti,invert-autoidle-bit;
    	abe_clk: abe_clk {
    		#clock-cells = <0>;
    		clocks = <&dpll_abe_m2x2_ck>;
    		ti,max-div = <4>;
    		reg = <0x0108>;
    		ti,index-power-of-two;
    	dpll_abe_m2_ck: dpll_abe_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x01f0>;
    	dpll_abe_m3x2_ck: dpll_abe_m3x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x01f4>;
    	dpll_core_byp_mux: dpll_core_byp_mux {
    		#clock-cells = <0>;
    		compatible = "ti,mux-clock";
    		clocks = <&sys_clkin1>, <&dpll_abe_m3x2_ck>;
    		ti,bit-shift = <23>;
    		reg = <0x012c>;
    	dpll_core_ck: dpll_core_ck {
    		#clock-cells = <0>;
    		compatible = "ti,omap4-dpll-core-clock";
    		clocks = <&sys_clkin1>, <&dpll_core_byp_mux>;
    		reg = <0x0120>, <0x0124>, <0x012c>, <0x0128>;
    	dpll_core_x2_ck: dpll_core_x2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_core_ck>;
    	dpll_core_h12x2_ck: dpll_core_h12x2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_core_x2_ck>;
    		ti,max-div = <63>;
    		reg = <0x013c>;
    	mpu_dpll_hs_clk_div: mpu_dpll_hs_clk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_core_h12x2_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_mpu_ck: dpll_mpu_ck {
    		#clock-cells = <0>;
    		compatible = "ti,omap5-mpu-dpll-clock";
    		clocks = <&sys_clkin1>, <&mpu_dpll_hs_clk_div>;
    		reg = <0x0160>, <0x0164>, <0x016c>, <0x0168>;
    	dpll_mpu_m2_ck: dpll_mpu_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x0170>;
    	mpu_dclk_div: mpu_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_mpu_m2_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dsp_dpll_hs_clk_div: dsp_dpll_hs_clk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_dsp_byp_mux: dpll_dsp_byp_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dsp_dpll_hs_clk_div>;
    		reg = <0x0240>;
    	dpll_dsp_ck: dpll_dsp_ck {
    		#clock-cells = <0>;
    		compatible = "ti,omap4-dpll-clock";
    		clocks = <&sys_clkin1>, <&dpll_dsp_byp_mux>;
    		reg = <0x0234>, <0x0238>, <0x0240>, <0x023c>;
    		assigned-clocks = <&dpll_dsp_ck>;
    		assigned-clock-rates = <600000000>;
    	dpll_dsp_m2_ck: dpll_dsp_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x0244>;
    		assigned-clocks = <&dpll_dsp_m2_ck>;
    	iva_dpll_hs_clk_div: iva_dpll_hs_clk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_iva_byp_mux: dpll_iva_byp_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&iva_dpll_hs_clk_div>;
    		reg = <0x01ac>;
    	dpll_iva_ck: dpll_iva_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dpll_iva_byp_mux>;
    		reg = <0x01a0>, <0x01a4>, <0x01ac>, <0x01a8>;
    		assigned-clocks = <&dpll_iva_ck>;
    		assigned-clock-rates = <1165000000>;
    	dpll_iva_m2_ck: dpll_iva_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x01b0>;
    		assigned-clocks = <&dpll_iva_m2_ck>;
    		assigned-clock-rates = <388333334>;
    	iva_dclk: iva_dclk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_gpu_byp_mux: dpll_gpu_byp_mux {
    		#clock-cells = <0>;
    		reg = <0x02e4>;
    	dpll_gpu_ck: dpll_gpu_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dpll_gpu_byp_mux>;
    		reg = <0x02d8>, <0x02dc>, <0x02e4>, <0x02e0>;
    		assigned-clocks = <&dpll_gpu_ck>;
    		assigned-clock-rates = <1277000000>;
    	dpll_gpu_m2_ck: dpll_gpu_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x02e8>;
    		assigned-clocks = <&dpll_gpu_m2_ck>;
    		assigned-clock-rates = <425666667>;
    	dpll_core_m2_ck: dpll_core_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x0130>;
    	core_dpll_out_dclk_div: core_dpll_out_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_core_m2_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_ddr_byp_mux: dpll_ddr_byp_mux {
    		#clock-cells = <0>;
    		reg = <0x021c>;
    	dpll_ddr_ck: dpll_ddr_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dpll_ddr_byp_mux>;
    		reg = <0x0210>, <0x0214>, <0x021c>, <0x0218>;
    	dpll_ddr_m2_ck: dpll_ddr_m2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_ddr_ck>;
    		ti,max-div = <31>;
    		reg = <0x0220>;
    	dpll_gmac_byp_mux: dpll_gmac_byp_mux {
    		#clock-cells = <0>;
    		reg = <0x02b4>;
    	dpll_gmac_ck: dpll_gmac_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dpll_gmac_byp_mux>;
    		reg = <0x02a8>, <0x02ac>, <0x02b4>, <0x02b0>;
    	dpll_gmac_m2_ck: dpll_gmac_m2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_gmac_ck>;
    		ti,max-div = <31>;
    		reg = <0x02b8>;
    	video2_dclk_div: video2_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&video2_m2_clkin_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	video1_dclk_div: video1_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&video1_m2_clkin_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	hdmi_dclk_div: hdmi_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&hdmi_clkin_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	per_dpll_hs_clk_div: per_dpll_hs_clk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_abe_m3x2_ck>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	usb_dpll_hs_clk_div: usb_dpll_hs_clk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <3>;
    	eve_dpll_hs_clk_div: eve_dpll_hs_clk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_eve_byp_mux: dpll_eve_byp_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&eve_dpll_hs_clk_div>;
    		reg = <0x0290>;
    	dpll_eve_ck: dpll_eve_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dpll_eve_byp_mux>;
    		reg = <0x0284>, <0x0288>, <0x0290>, <0x028c>;
    	dpll_eve_m2_ck: dpll_eve_m2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_eve_ck>;
    		ti,max-div = <31>;
    		reg = <0x0294>;
    	eve_dclk_div: eve_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_eve_m2_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_core_h13x2_ck: dpll_core_h13x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x0140>;
    	dpll_core_h14x2_ck: dpll_core_h14x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x0144>;
    	dpll_core_h22x2_ck: dpll_core_h22x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x0154>;
    	dpll_core_h23x2_ck: dpll_core_h23x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x0158>;
    	dpll_core_h24x2_ck: dpll_core_h24x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x015c>;
    	dpll_ddr_x2_ck: dpll_ddr_x2_ck {
    		#clock-cells = <0>;
    	dpll_ddr_h11x2_ck: dpll_ddr_h11x2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_ddr_x2_ck>;
    		ti,max-div = <63>;
    		reg = <0x0228>;
    	dpll_dsp_x2_ck: dpll_dsp_x2_ck {
    		#clock-cells = <0>;
    	dpll_dsp_m3x2_ck: dpll_dsp_m3x2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_dsp_x2_ck>;
    		ti,max-div = <31>;
    		reg = <0x0248>;
    		assigned-clocks = <&dpll_dsp_m3x2_ck>;
    		assigned-clock-rates = <400000000>;
    	dpll_gmac_x2_ck: dpll_gmac_x2_ck {
    		#clock-cells = <0>;
    	dpll_gmac_h11x2_ck: dpll_gmac_h11x2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_gmac_x2_ck>;
    		ti,max-div = <63>;
    		reg = <0x02c0>;
    	dpll_gmac_h12x2_ck: dpll_gmac_h12x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x02c4>;
    	dpll_gmac_h13x2_ck: dpll_gmac_h13x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x02c8>;
    	dpll_gmac_m3x2_ck: dpll_gmac_m3x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x02bc>;
    	gmii_m_clk_div: gmii_m_clk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_gmac_h11x2_ck>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	hdmi_clk2_div: hdmi_clk2_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	hdmi_div_clk: hdmi_div_clk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	l3_iclk_div: l3_iclk_div {
    		#clock-cells = <0>;
    		ti,max-div = <2>;
    		ti,bit-shift = <4>;
    		reg = <0x0100>;
    	l4_root_clk_div: l4_root_clk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	video1_clk2_div: video1_clk2_div {
    		#clock-cells = <0>;
    		clocks = <&video1_clkin_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	video1_div_clk: video1_div_clk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	video2_clk2_div: video2_clk2_div {
    		#clock-cells = <0>;
    		clocks = <&video2_clkin_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	video2_div_clk: video2_div_clk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	ipu1_gfclk_mux: ipu1_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&dpll_abe_m2x2_ck>, <&dpll_core_h22x2_ck>;
    		ti,bit-shift = <24>;
    		reg = <0x0520>;
    		assigned-clocks = <&ipu1_gfclk_mux>;
    		assigned-clock-parents = <&dpll_core_h22x2_ck>;
    	mcasp1_ahclkr_mux: mcasp1_ahclkr_mux {
    		#clock-cells = <0>;
    		clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>;
    		ti,bit-shift = <28>;
    		reg = <0x0550>;
    	mcasp1_ahclkx_mux: mcasp1_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x0550>;
    	mcasp1_aux_gfclk_mux: mcasp1_aux_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>;
    		ti,bit-shift = <22>;
    		reg = <0x0550>;
    	timer5_gfclk_mux: timer5_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>, <&clkoutmux0_clk_mux>;
    		reg = <0x0558>;
    	timer6_gfclk_mux: timer6_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x0560>;
    	timer7_gfclk_mux: timer7_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x0568>;
    	timer8_gfclk_mux: timer8_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x0570>;
    	uart6_gfclk_mux: uart6_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>;
    		reg = <0x0580>;
    	dummy_ck: dummy_ck {
    		#clock-cells = <0>;
    &prm_clocks {
    	sys_clkin1: sys_clkin1 {
    		#clock-cells = <0>;
    		clocks = <&virt_12000000_ck>, <&virt_20000000_ck>, <&virt_16800000_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_27000000_ck>, <&virt_38400000_ck>;
    		reg = <0x0110>;
    	abe_dpll_sys_clk_mux: abe_dpll_sys_clk_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&sys_clkin2>;
    		reg = <0x0118>;
    	abe_dpll_bypass_clk_mux: abe_dpll_bypass_clk_mux {
    		#clock-cells = <0>;
    		clocks = <&abe_dpll_sys_clk_mux>, <&sys_32k_ck>;
    		reg = <0x0114>;
    	abe_dpll_clk_mux: abe_dpll_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x010c>;
    	abe_24m_fclk: abe_24m_fclk {
    		#clock-cells = <0>;
    		reg = <0x011c>;
    		ti,dividers = <8>, <16>;
    	aess_fclk: aess_fclk {
    		#clock-cells = <0>;
    		clocks = <&abe_clk>;
    		reg = <0x0178>;
    		ti,max-div = <2>;
    	abe_giclk_div: abe_giclk_div {
    		#clock-cells = <0>;
    		clocks = <&aess_fclk>;
    		reg = <0x0174>;
    		ti,max-div = <2>;
    	abe_lp_clk_div: abe_lp_clk_div {
    		#clock-cells = <0>;
    		reg = <0x01d8>;
    		ti,dividers = <16>, <32>;
    	abe_sys_clk_div: abe_sys_clk_div {
    		#clock-cells = <0>;
    		reg = <0x0120>;
    		ti,max-div = <2>;
    	adc_gfclk_mux: adc_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&sys_clkin2>, <&sys_32k_ck>;
    		reg = <0x01dc>;
    	sys_clk1_dclk_div: sys_clk1_dclk_div {
    		#clock-cells = <0>;
    		ti,max-div = <64>;
    		reg = <0x01c8>;
    	sys_clk2_dclk_div: sys_clk2_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin2>;
    		ti,max-div = <64>;
    		reg = <0x01cc>;
    	per_abe_x1_dclk_div: per_abe_x1_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_abe_m2_ck>;
    		ti,max-div = <64>;
    		reg = <0x01bc>;
    	dsp_gclk_div: dsp_gclk_div {
    		#clock-cells = <0>;
    		ti,max-div = <64>;
    		reg = <0x018c>;
    	gpu_dclk: gpu_dclk {
    		#clock-cells = <0>;
    		ti,max-div = <64>;
    		reg = <0x01a0>;
    	emif_phy_dclk_div: emif_phy_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_ddr_m2_ck>;
    		ti,max-div = <64>;
    		reg = <0x0190>;
    	gmac_250m_dclk_div: gmac_250m_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_gmac_m2_ck>;
    		ti,max-div = <64>;
    		reg = <0x019c>;
    	l3init_480m_dclk_div: l3init_480m_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_usb_m2_ck>;
    		ti,max-div = <64>;
    		reg = <0x01ac>;
    	usb_otg_dclk_div: usb_otg_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&usb_otg_clkin_ck>;
    		ti,max-div = <64>;
    		reg = <0x0184>;
    	sata_dclk_div: sata_dclk_div {
    		#clock-cells = <0>;
    		ti,max-div = <64>;
    		reg = <0x01c0>;
    	pcie2_dclk_div: pcie2_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_pcie_ref_m2_ck>;
    		ti,max-div = <64>;
    		reg = <0x01b8>;
    	pcie_dclk_div: pcie_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&apll_pcie_m2_ck>;
    		ti,max-div = <64>;
    		reg = <0x01b4>;
    	emu_dclk_div: emu_dclk_div {
    		#clock-cells = <0>;
    		ti,max-div = <64>;
    		reg = <0x0194>;
    	secure_32k_dclk_div: secure_32k_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&secure_32k_clk_src_ck>;
    		ti,max-div = <64>;
    		reg = <0x01c4>;
    	clkoutmux0_clk_mux: clkoutmux0_clk_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clk1_dclk_div>, <&sys_clk2_dclk_div>, <&per_abe_x1_dclk_div>, <&mpu_dclk_div>, <&dsp_gclk_div>, <&iva_dclk>, <&gpu_dclk>, <&core_dpll_out_dclk_div>, <&emif_phy_dclk_div>, <&gmac_250m_dclk_div>, <&video2_dclk_div>, <&video1_dclk_div>, <&hdmi_dclk_div>, <&func_96m_aon_dclk_div>, <&l3init_480m_dclk_div>, <&usb_otg_dclk_div>, <&sata_dclk_div>, <&pcie2_dclk_div>, <&pcie_dclk_div>, <&emu_dclk_div>, <&secure_32k_dclk_div>, <&eve_dclk_div>;
    		reg = <0x0158>;
    	clkoutmux1_clk_mux: clkoutmux1_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x015c>;
    	clkoutmux2_clk_mux: clkoutmux2_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x0160>;
    	custefuse_sys_gfclk_div: custefuse_sys_gfclk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	eve_clk: eve_clk {
    		#clock-cells = <0>;
    		clocks = <&dpll_eve_m2_ck>, <&dpll_dsp_m3x2_ck>;
    		reg = <0x0180>;
    	hdmi_dpll_clk_mux: hdmi_dpll_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x0164>;
    	mlb_clk: mlb_clk {
    		#clock-cells = <0>;
    		clocks = <&mlb_clkin_ck>;
    		ti,max-div = <64>;
    		reg = <0x0134>;
    	mlbp_clk: mlbp_clk {
    		#clock-cells = <0>;
    		clocks = <&mlbp_clkin_ck>;
    		ti,max-div = <64>;
    		reg = <0x0130>;
    	per_abe_x1_gfclk2_div: per_abe_x1_gfclk2_div {
    		#clock-cells = <0>;
    		ti,max-div = <64>;
    		reg = <0x0138>;
    	timer_sys_clk_div: timer_sys_clk_div {
    		#clock-cells = <0>;
    		reg = <0x0144>;
    		ti,max-div = <2>;
    	video1_dpll_clk_mux: video1_dpll_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x0168>;
    	video2_dpll_clk_mux: video2_dpll_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x016c>;
    	wkupaon_iclk_mux: wkupaon_iclk_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&abe_lp_clk_div>;
    		reg = <0x0108>;
    	gpio1_dbclk: gpio1_dbclk {
    		#clock-cells = <0>;
    		compatible = "ti,gate-clock";
    		ti,bit-shift = <8>;
    		reg = <0x1838>;
    	dcan1_sys_clk_mux: dcan1_sys_clk_mux {
    		#clock-cells = <0>;
    		reg = <0x1888>;
    	timer1_gfclk_mux: timer1_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>;
    		reg = <0x1840>;
    	uart10_gfclk_mux: uart10_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1880>;
    &cm_core_clocks {
    	dpll_pcie_ref_ck: dpll_pcie_ref_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&sys_clkin1>;
    		reg = <0x0200>, <0x0204>, <0x020c>, <0x0208>;
    	dpll_pcie_ref_m2ldo_ck: dpll_pcie_ref_m2ldo_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_pcie_ref_ck>;
    		ti,max-div = <31>;
    		reg = <0x0210>;
    	apll_pcie_in_clk_mux: apll_pcie_in_clk_mux@4ae06118 {
    		clocks = <&dpll_pcie_ref_m2ldo_ck>, <&pciesref_acs_clk_ck>;
    		#clock-cells = <0>;
    		reg = <0x021c 0x4>;
    		ti,bit-shift = <7>;
    	apll_pcie_ck: apll_pcie_ck {
    		#clock-cells = <0>;
    		compatible = "ti,dra7-apll-clock";
    		clocks = <&apll_pcie_in_clk_mux>, <&dpll_pcie_ref_ck>;
    		reg = <0x021c>, <0x0220>;
    	optfclk_pciephy1_32khz: optfclk_pciephy1_32khz@4a0093b0 {
    		#clock-cells = <0>;
    		reg = <0x13b0>;
    		ti,bit-shift = <8>;
    	optfclk_pciephy2_32khz: optfclk_pciephy2_32khz@4a0093b8 {
    		#clock-cells = <0>;
    		reg = <0x13b8>;
    		ti,bit-shift = <8>;
    	optfclk_pciephy_div: optfclk_pciephy_div@4a00821c {
    		clocks = <&apll_pcie_ck>;
    		#clock-cells = <0>;
    		reg = <0x021c>;
    		ti,dividers = <2>, <1>;
    		ti,bit-shift = <8>;
    		ti,max-div = <2>;
    	optfclk_pciephy1_clk: optfclk_pciephy1_clk@4a0093b0 {
    		#clock-cells = <0>;
    		reg = <0x13b0>;
    		ti,bit-shift = <9>;
    	optfclk_pciephy2_clk: optfclk_pciephy2_clk@4a0093b8 {
    		#clock-cells = <0>;
    		reg = <0x13b8>;
    		ti,bit-shift = <9>;
    	optfclk_pciephy1_div_clk: optfclk_pciephy1_div_clk@4a0093b0 {
    		clocks = <&optfclk_pciephy_div>;
    		#clock-cells = <0>;
    		reg = <0x13b0>;
    		ti,bit-shift = <10>;
    	optfclk_pciephy2_div_clk: optfclk_pciephy2_div_clk@4a0093b8 {
    		#clock-cells = <0>;
    		reg = <0x13b8>;
    	apll_pcie_clkvcoldo: apll_pcie_clkvcoldo {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	apll_pcie_clkvcoldo_div: apll_pcie_clkvcoldo_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	apll_pcie_m2_ck: apll_pcie_m2_ck {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_per_byp_mux: dpll_per_byp_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&per_dpll_hs_clk_div>;
    		reg = <0x014c>;
    	dpll_per_ck: dpll_per_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&dpll_per_byp_mux>;
    		reg = <0x0140>, <0x0144>, <0x014c>, <0x0148>;
    	dpll_per_m2_ck: dpll_per_m2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_per_ck>;
    		ti,max-div = <31>;
    		reg = <0x0150>;
    	func_96m_aon_dclk_div: func_96m_aon_dclk_div {
    		#clock-cells = <0>;
    		clocks = <&dpll_per_m2_ck>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	dpll_usb_byp_mux: dpll_usb_byp_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_clkin1>, <&usb_dpll_hs_clk_div>;
    		reg = <0x018c>;
    	dpll_usb_ck: dpll_usb_ck {
    		#clock-cells = <0>;
    		compatible = "ti,omap4-dpll-j-type-clock";
    		clocks = <&sys_clkin1>, <&dpll_usb_byp_mux>;
    		reg = <0x0180>, <0x0184>, <0x018c>, <0x0188>;
    	dpll_usb_m2_ck: dpll_usb_m2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_usb_ck>;
    		ti,max-div = <127>;
    		reg = <0x0190>;
    	dpll_pcie_ref_m2_ck: dpll_pcie_ref_m2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <127>;
    		reg = <0x0210>;
    	dpll_per_x2_ck: dpll_per_x2_ck {
    		#clock-cells = <0>;
    	dpll_per_h11x2_ck: dpll_per_h11x2_ck {
    		#clock-cells = <0>;
    		clocks = <&dpll_per_x2_ck>;
    		ti,max-div = <63>;
    		reg = <0x0158>;
    	dpll_per_h12x2_ck: dpll_per_h12x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x015c>;
    	dpll_per_h13x2_ck: dpll_per_h13x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x0160>;
    	dpll_per_h14x2_ck: dpll_per_h14x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <63>;
    		reg = <0x0164>;
    	dpll_per_m2x2_ck: dpll_per_m2x2_ck {
    		#clock-cells = <0>;
    		ti,max-div = <31>;
    		reg = <0x0150>;
    	dpll_usb_clkdcoldo: dpll_usb_clkdcoldo {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <1>;
    	func_128m_clk: func_128m_clk {
    		#clock-cells = <0>;
    		clocks = <&dpll_per_h11x2_ck>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	func_12m_fclk: func_12m_fclk {
    		#clock-cells = <0>;
    		clocks = <&dpll_per_m2x2_ck>;
    		clock-mult = <1>;
    		clock-div = <16>;
    	func_24m_clk: func_24m_clk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <4>;
    	func_48m_fclk: func_48m_fclk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <4>;
    	func_96m_fclk: func_96m_fclk {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	l3init_60m_fclk: l3init_60m_fclk {
    		#clock-cells = <0>;
    		reg = <0x0104>;
    		ti,dividers = <1>, <8>;
    	clkout2_clk: clkout2_clk {
    		#clock-cells = <0>;
    		clocks = <&clkoutmux2_clk_mux>;
    		ti,bit-shift = <8>;
    		reg = <0x06b0>;
    	l3init_960m_gfclk: l3init_960m_gfclk {
    		#clock-cells = <0>;
    		clocks = <&dpll_usb_clkdcoldo>;
    		ti,bit-shift = <8>;
    		reg = <0x06c0>;
    	dss_32khz_clk: dss_32khz_clk {
    		#clock-cells = <0>;
    		ti,bit-shift = <11>;
    		reg = <0x1120>;
    	dss_48mhz_clk: dss_48mhz_clk {
    		#clock-cells = <0>;
    		clocks = <&func_48m_fclk>;
    		ti,bit-shift = <9>;
    		reg = <0x1120>;
    	dss_dss_clk: dss_dss_clk {
    		#clock-cells = <0>;
    		clocks = <&dpll_per_h12x2_ck>;
    		ti,bit-shift = <8>;
    		reg = <0x1120>;
    		ti,set-rate-parent;
    	dss_hdmi_clk: dss_hdmi_clk {
    		#clock-cells = <0>;
    		clocks = <&hdmi_dpll_clk_mux>;
    		reg = <0x1120>;
    	dss_video1_clk: dss_video1_clk {
    		#clock-cells = <0>;
    		clocks = <&video1_dpll_clk_mux>;
    		ti,bit-shift = <12>;
    		reg = <0x1120>;
    	dss_video2_clk: dss_video2_clk {
    		#clock-cells = <0>;
    		clocks = <&video2_dpll_clk_mux>;
    		ti,bit-shift = <13>;
    		reg = <0x1120>;
    	gpio2_dbclk: gpio2_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1760>;
    	gpio3_dbclk: gpio3_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1768>;
    	gpio4_dbclk: gpio4_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1770>;
    	gpio5_dbclk: gpio5_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1778>;
    	gpio6_dbclk: gpio6_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1780>;
    	gpio7_dbclk: gpio7_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1810>;
    	gpio8_dbclk: gpio8_dbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1818>;
    	mmc1_clk32k: mmc1_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1328>;
    	mmc2_clk32k: mmc2_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1330>;
    	mmc3_clk32k: mmc3_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1820>;
    	mmc4_clk32k: mmc4_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1828>;
    	sata_ref_clk: sata_ref_clk {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1388>;
    	usb_otg_ss1_refclk960m: usb_otg_ss1_refclk960m {
    		#clock-cells = <0>;
    		clocks = <&l3init_960m_gfclk>;
    		ti,bit-shift = <8>;
    		reg = <0x13f0>;
    	usb_otg_ss2_refclk960m: usb_otg_ss2_refclk960m {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x1340>;
    	usb_phy1_always_on_clk32k: usb_phy1_always_on_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x0640>;
    	usb_phy2_always_on_clk32k: usb_phy2_always_on_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x0688>;
    	usb_phy3_always_on_clk32k: usb_phy3_always_on_clk32k {
    		#clock-cells = <0>;
    		ti,bit-shift = <8>;
    		reg = <0x0698>;
    	atl_dpll_clk_mux: atl_dpll_clk_mux {
    		#clock-cells = <0>;
    		clocks = <&sys_32k_ck>, <&video1_clkin_ck>, <&video2_clkin_ck>, <&hdmi_clkin_ck>;
    		reg = <0x0c00>;
    	atl_gfclk_mux: atl_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&l3_iclk_div>, <&dpll_abe_m2_ck>, <&atl_dpll_clk_mux>;
    		ti,bit-shift = <26>;
    		reg = <0x0c00>;
    	rmii_50mhz_clk_mux: rmii_50mhz_clk_mux@13d0 {
    		#clock-cells = <0>;
    		clocks = <&dpll_gmac_h11x2_ck>, <&rmii_clk_ck>;
    		reg = <0x13d0>;
    	gmac_gmii_ref_clk_div: gmac_gmii_ref_clk_div {
    		#clock-cells = <0>;
    		clock-mult = <1>;
    		clock-div = <2>;
    	gmac_rft_clk_mux: gmac_rft_clk_mux {
    		#clock-cells = <0>;
    		clocks = <&video1_clkin_ck>, <&video2_clkin_ck>, <&dpll_abe_m2_ck>, <&hdmi_clkin_ck>, <&l3_iclk_div>;
    		ti,bit-shift = <25>;
    		reg = <0x13d0>;
    	gpu_core_gclk_mux: gpu_core_gclk_mux {
    		#clock-cells = <0>;
    		clocks = <&dpll_core_h14x2_ck>, <&dpll_per_h14x2_ck>, <&dpll_gpu_m2_ck>;
    		reg = <0x1220>;
    		assigned-clocks = <&gpu_core_gclk_mux>;
    		assigned-clock-parents = <&dpll_gpu_m2_ck>;
    	gpu_hyd_gclk_mux: gpu_hyd_gclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1220>;
    		assigned-clocks = <&gpu_hyd_gclk_mux>;
    	l3instr_ts_gclk_div: l3instr_ts_gclk_div {
    		#clock-cells = <0>;
    		clocks = <&wkupaon_iclk_mux>;
    		reg = <0x0e50>;
    		ti,dividers = <8>, <16>, <32>;
    	mcasp2_ahclkr_mux: mcasp2_ahclkr_mux {
    		#clock-cells = <0>;
    		reg = <0x1860>;
    	mcasp2_ahclkx_mux: mcasp2_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1860>;
    	mcasp2_aux_gfclk_mux: mcasp2_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1860>;
    	mcasp3_ahclkx_mux: mcasp3_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1868>;
    	mcasp3_aux_gfclk_mux: mcasp3_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1868>;
    	mcasp4_ahclkx_mux: mcasp4_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1898>;
    	mcasp4_aux_gfclk_mux: mcasp4_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1898>;
    	mcasp5_ahclkx_mux: mcasp5_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1878>;
    	mcasp5_aux_gfclk_mux: mcasp5_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1878>;
    	mcasp6_ahclkx_mux: mcasp6_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1904>;
    	mcasp6_aux_gfclk_mux: mcasp6_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1904>;
    	mcasp7_ahclkx_mux: mcasp7_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1908>;
    	mcasp7_aux_gfclk_mux: mcasp7_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1908>;
    	mcasp8_ahclkx_mux: mcasp8_ahclkx_mux {
    		#clock-cells = <0>;
    		reg = <0x1890>;
    	mcasp8_aux_gfclk_mux: mcasp8_aux_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1890>;
    	mmc1_fclk_mux: mmc1_fclk_mux {
    		#clock-cells = <0>;
    		clocks = <&func_128m_clk>, <&dpll_per_m2x2_ck>;
    		reg = <0x1328>;
    	mmc1_fclk_div: mmc1_fclk_div {
    		#clock-cells = <0>;
    		clocks = <&mmc1_fclk_mux>;
    		ti,max-div = <4>;
    		reg = <0x1328>;
    	mmc2_fclk_mux: mmc2_fclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1330>;
    	mmc2_fclk_div: mmc2_fclk_div {
    		#clock-cells = <0>;
    		clocks = <&mmc2_fclk_mux>;
    		ti,max-div = <4>;
    		reg = <0x1330>;
    	mmc3_gfclk_mux: mmc3_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1820>;
    	mmc3_gfclk_div: mmc3_gfclk_div {
    		#clock-cells = <0>;
    		clocks = <&mmc3_gfclk_mux>;
    		ti,max-div = <4>;
    		reg = <0x1820>;
    	mmc4_gfclk_mux: mmc4_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1828>;
    	mmc4_gfclk_div: mmc4_gfclk_div {
    		#clock-cells = <0>;
    		clocks = <&mmc4_gfclk_mux>;
    		ti,max-div = <4>;
    		reg = <0x1828>;
    	qspi_gfclk_mux: qspi_gfclk_mux {
    		#clock-cells = <0>;
    		clocks = <&func_128m_clk>, <&dpll_per_h13x2_ck>;
    		reg = <0x1838>;
    	qspi_gfclk_div: qspi_gfclk_div {
    		#clock-cells = <0>;
    		clocks = <&qspi_gfclk_mux>;
    		ti,max-div = <4>;
    		reg = <0x1838>;
    	timer10_gfclk_mux: timer10_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1728>;
    	timer11_gfclk_mux: timer11_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1730>;
    	timer13_gfclk_mux: timer13_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x17c8>;
    	timer14_gfclk_mux: timer14_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x17d0>;
    	timer15_gfclk_mux: timer15_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x17d8>;
    	timer16_gfclk_mux: timer16_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1830>;
    	timer2_gfclk_mux: timer2_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1738>;
    	timer3_gfclk_mux: timer3_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1740>;
    	timer4_gfclk_mux: timer4_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1748>;
    	timer9_gfclk_mux: timer9_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1750>;
    	uart1_gfclk_mux: uart1_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1840>;
    	uart2_gfclk_mux: uart2_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1848>;
    	uart3_gfclk_mux: uart3_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1850>;
    	uart4_gfclk_mux: uart4_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1858>;
    	uart5_gfclk_mux: uart5_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1870>;
    	uart7_gfclk_mux: uart7_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x18d0>;
    	uart8_gfclk_mux: uart8_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x18e0>;
    	uart9_gfclk_mux: uart9_gfclk_mux {
    		#clock-cells = <0>;
    		reg = <0x18e8>;
    	vip1_gclk_mux: vip1_gclk_mux {
    		#clock-cells = <0>;
    		clocks = <&l3_iclk_div>, <&dpll_core_h23x2_ck>;
    		reg = <0x1020>;
    	vip2_gclk_mux: vip2_gclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1028>;
    	vip3_gclk_mux: vip3_gclk_mux {
    		#clock-cells = <0>;
    		reg = <0x1030>;
    &cm_core_clockdomains {
    	coreaon_clkdm: coreaon_clkdm {
    		compatible = "ti,clockdomain";
    &scm_conf_clocks {
    	dss_deshdcp_clk: dss_deshdcp_clk {
    		#clock-cells = <0>;
    		ti,bit-shift = <0>;
    		reg = <0x558>;
    	sys_32k_ck: sys_32k_ck {
    		#clock-cells = <0>;
    		clocks = <&sys_clk32_crystal_ck>, <&sys_clk32_pseudo_ck>, <&sys_clk32_pseudo_ck>, <&sys_clk32_pseudo_ck>;
    		ti,bit-shift = <8>;
    		reg = <0x6c4>;
    	ehrpwm0_tbclk: ehrpwm0_tbclk {
    		#clock-cells = <0>;
    		clocks = <&l4_root_clk_div>;
    		ti,bit-shift = <20>;
    		reg = <0x0558>;
    	ehrpwm1_tbclk: ehrpwm1_tbclk {
    		#clock-cells = <0>;
    		ti,bit-shift = <21>;
    		reg = <0x0558>;
    	ehrpwm2_tbclk: ehrpwm2_tbclk {
    		#clock-cells = <0>;
    		reg = <0x0558>;
    kernel panic when I dump dss clock register
    root@wnc-j6:~# ./debug_dss_clockdumps.sh
    =====================DSS clock script===================
    Dumps internal clocks and muxes of DSS
    CTRL_CORE_DSS_PLL_CONTROL (0x4a002538) = 0x000002AF
    video1 PLL :  Disabled
    video2 PLL :  Disabled
    HDMI   PLL :  Disabled
    DSI1_A_CLK mux : DPLL HDMI
    DSI1_B_CLK mux : DPLL video2
    DSI1_C_CLK mux : DPLL Video2
    [  910.072690] ------------[ cut here ]------------
    [  910.077346] WARNING: CPU: 0 PID: 1256 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  910.086956] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x00000040 : Data Access in User mode during Functional access
    [  910.100748] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  910.135422] CPU: 0 PID: 1256 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  910.142848] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  910.148964] Backtrace:
    [  910.151437] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  910.159037]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  910.164760] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  910.172016] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  910.180138]  r5:00000093 r4:ef093e08
    [  910.183745] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  910.192477]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  910.199251] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  910.208159]  r3:ef161a40 r2:c085fe50
    [  910.211770] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  910.221113]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  910.229015]  r4:ef161f40
    [  910.231569] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  910.240477]  r10:00000000 r9:bee12d1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  910.248377]  r4:ef15a780
    [  910.250930] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  910.259488]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  910.265205] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  910.273850]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  910.279569] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  910.288306] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  910.296689]  r8:fa213000 r7:fa212000 r6:ef093fb0 r5:c095a8d8 r4:fa21200c r3:ef093fb0
    [  910.304506] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  910.312020] Exception stack(0xef093fb0 to 0xef093ff8)
    [  910.317092] 3fa0:                                     0010b49f 0010b49f 58000000 00000000
    [  910.325304] 3fc0: 0010b49f 00000000 00000030 00000002 bee12d18 bee12d1c 00000000 001d5f34
    [  910.333516] 3fe0: 00000000 bee12a10 000098fc 000d4cb0 60000030 ffffffff
    [  910.340154]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000030 r4:000d4cb0 r3:0010b49f
    [  910.347970] ---[ end trace 6dd630470b1517d1 ]---
    [  910.354036] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  910.361377] pgd = ee8df3c0
    [  910.364093] [00000000] *pgd=ad1e0003, *pmd=ade64003, *pte=00000000
    DSS_CTRL (0x58000040) = 0x
    !!! OUPS... MEMORY ERROR @ 0x00000000 !!!
    Are you sure that:
        MEMORY ADDRESS IS VALID?
        TARGETED MODULE IS CLOCKED?
    ./debug_dss_clockdumps.sh: line 36: 0x >> !!! : syntax error: operand expected (error token is " ")
    ./debug_dss_clockdumps.sh: line 37: & 0xOUPS... : syntax error: operand expected (error token is "& 0xOUPS... ")
     2: LCD1 clk switch :
     3: LCD2 clk switch :
    10: LCD3 clk switch :
     1: func clk switch :
    13: DPI1 output     :
    Clock O/P of MUXes
    DSI1_A_CLK :  0
    DSI1_B_CLK :  0
    DSI1_C_CLK :  0
    [  910.511643] ------------[ cut here ]------------
    [  910.516294] WARNING: CPU: 0 PID: 1313 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  910.525902] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x00000040 : Data Access in User mode during Functional access
    [  910.539692] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  910.574331] CPU: 0 PID: 1313 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  910.581756] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  910.587871] Backtrace:
    [  910.590341] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  910.597938]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  910.603653] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  910.610907] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  910.619028]  r5:00000093 r4:ede35e08
    [  910.622632] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  910.631362]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  910.638130] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  910.647035]  r3:ef161a40 r2:c085fe50
    [  910.650643] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  910.659985]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  910.667883]  r4:ef161f40
    [  910.670434] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  910.679339]  r10:00000000 r9:be88ad1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  910.687237]  r4:ef15a780
    [  910.689787] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  910.698342]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  910.704054] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  910.712697]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  910.718410] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  910.727146] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  910.735528]  r8:fa213000 r7:fa212000 r6:ede35fb0 r5:c095a8d8 r4:fa21200c r3:ede35fb0
    [  910.743340] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  910.750852] Exception stack(0xede35fb0 to 0xede35ff8)
    [  910.755923] 5fa0:                                     0010b4a0 0010b4a0 00000068 00000068
    [  910.764135] 5fc0: 0010b49f 00000000 00000030 00000002 be88ad18 be88ad1c 00000000 001d5f34
    [  910.772344] 5fe0: 00000000 be88aa10 000098fc 000d4cba 60000030 ffffffff
    [  910.778982]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000030 r4:000d4cba r3:0010b4a0
    [  910.786793] ---[ end trace 6dd630470b1517d2 ]---
    [  910.791607] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  910.798946] pgd = ec09cec0
    [  910.801661] [00000000] *pgd=ad1e2003, *pmd=bdc58003
    ./debug_dss_clockdumps.sh: line 36: 0x >> !!! : syntax error: operand expected (error token is " ")[  910.834433] ------------[ cut here ]------------
    [  910.843763] WARNING: CPU: 0 PID: 1327 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  910.853370] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x00001070 : Data Access in User mode during Functional access
    [  910.867160] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  910.901799] CPU: 0 PID: 1327 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  910.909225] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  910.915339] Backtrace:
    [  910.917809] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  910.925407]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  910.931123] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  910.938376] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  910.946497]  r5:00000093 r4:edda3e08
    [  910.950099] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  910.958830]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  910.965597] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  910.974503]  r3:ef161a40 r2:c085fe50
    [  910.978109] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  910.987451]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  910.995349]  r4:ef161f40
    [  910.997901] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  911.006806]  r10:00000000 r9:beea2d1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  911.014704]  r4:ef15a780
    [  911.017254] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  911.025811]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  911.031524] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  911.040167]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  911.045881] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  911.054616] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  911.062998]  r8:fa213000 r7:fa212000 r6:edda3fb0 r5:c095a8d8 r4:fa21200c r3:edda3fb0
    [  911.070813] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  911.078324] Exception stack(0xedda3fb0 to 0xedda3ff8)
    [  911.083394] 3fa0:                                     0010b49f 0010b49f 58000000 00000000
    [  911.091605] 3fc0: 0010b49f 00000000 00000030 00000002 beea2d18 beea2d1c 00000000 001d5f34
    [  911.099816] 3fe0: 00000000 beea2a10 000098fc 000d4cb0 60000030 ffffffff
    [  911.106453]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000030 r4:000d4cb0 r3:0010b49f
    [  911.114263] ---[ end trace 6dd630470b1517d3 ]---
    ./debug_dss_clockdumps.sh: line 37: & 0xOUPS... : sy[  911.119028] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  911.130987] pgd = ec1d86c0
    [  911.133702] [00000000] *pgd=ade5b003, *pmd=adf47003, *pte=00000000
     2: LCD1 clk :
     3: LCD2 clk :
    10: LCD3 clk :
     1: func clk :
      911.160129] ------------[ cut here ]------------
    [  911.193519] WARNING: CPU: 0 PID: 1335 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  911.203127] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x0000140C : Data Access in User mode during Functional access
    [  911.216917] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  911.251557] CPU: 0 PID: 1335 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  911.258982] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  911.265096] Backtrace:
    [  911.267564] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  911.275162]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  911.280878] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  911.288132] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  911.296252]  r5:00000093 r4:ede33e08
    [  911.299857] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  911.308588]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  911.315355] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  911.324260]  r3:ef161a40 r2:c085fe50
    [  911.327868] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  911.337210]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  911.345108]  r4:ef161f40
    [  911.347660] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  911.356565]  r10:00000000 r9:bee58d1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  911.364464]  r4:ef15a780
    [  911.367015] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  911.375571]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  911.381284] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  911.389927]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  911.395641] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  911.404378] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  911.412761]  r8:fa213000 r7:fa212000 r6:ede33fb0 r5:c095a8d8 r4:fa21200c r3:ede33fb0
    [  911.420574] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  911.428086] Exception stack(0xede33fb0 to 0xede33ff8)
    [  911.433156] 3fa0:                                     00000000 00000003 58000000 00000000
    [  911.441366] 3fc0: 0010b49f 00000000 00000030 00000002 bee58d18 bee58d1c 00000000 001d5f34
    [  911.449575] 3fe0: 00000000 bee58a10 000be8b8 000098f0 60000010 ffffffff
    [  911.456214]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000010 r4:000098f0 r3:00000000
    [  911.464024] ---[ end trace 6dd630470b1517d4 ]---
    [  911.468770] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  911.476108] pgd = ee3e8cc0
    [  911.478823] [00000000] *pgd=ae3ef003, *pmd=add99003, *pte=00000000
    /d.ebug_dss_clockdumps.sh: line 62: 0x
    !!! OUPS... MEMORY ERRO @ 0x00000000 !!!
    Are you sure that:
        TARGETED MODULE IS CLOCKED? >> 16 : syntax error in expression (error token is "!!! OUPS... MEMORY ERROR @ 0x00000000 !!!
    Are you sure that:
        TARGETED MODULE IS CLOCKED? >> 16 ")
    ./debug_dss_clockdumps.sh: line 63: & 0xff : syntax error: operand expected (error token is "& 0xff ")
      911.501639] ------------[ cut here ]------------
    [  911.533222] WARNING: CPU: 0 PID: 1343 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  911.542829] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x00001838 : Data Access in User mode during Functional access
    [  911.556619] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  911.591258] CPU: 0 PID: 1343 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  911.598683] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  911.604798] Backtrace:
    [  911.607268] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  911.614866]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  911.620582] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  911.627836] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  911.635956]  r5:00000093 r4:edda3e08
    [  911.639560] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  911.648291]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  911.655059] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  911.663964]  r3:ef161a40 r2:c085fe50
    [  911.667571] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  911.676914]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  911.684811]  r4:ef161f40
    [  911.687362] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  911.696267]  r10:00000000 r9:befddd1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  911.704164]  r4:ef15a780
    [  911.706715] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  911.715271]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  911.720983] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  911.729628]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  911.735341] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  911.744077] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  911.752458]  r8:fa213000 r7:fa212000 r6:edda3fb0 r5:c095a8d8 r4:fa21200c r3:edda3fb0
    [  911.760272] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  911.767783] Exception stack(0xedda3fb0 to 0xedda3ff8)
    [  911.772853] 3fa0:                                     0010b49f 0010b49f 58000000 00000000
    [  911.781063] 3fc0: 0010b49f 00000000 00000030 00000002 befddd18 befddd1c 00000000 001d5f34
    [  911.789274] 3fe0: 00000000 befdda10 000098fc 000d4cb0 60000030 ffffffff
    [  911.795913]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000030 r4:000d4cb0 r3:0010b49f
    [  911.803724] ---[ end trace 6dd630470b1517d5 ]---
    [  911.809608] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  911.816947] pgd = ede89ec0
    [  911.819662] [00000000] *pgd=ad12d003, *pmd=ad15b003, *pte=00000000
    Are you sure that:
    Are you sure that:
    ./debug_dss_clockdumps.sh: line 216: [: !=: unary operator expected
    ./debug_dss_clockdumps.sh: line 217: [: !=: unary operator expected
    ./debug_dss_clockdumps.sh: line 218: [: !=: unary operator expected
     911.842912] ------------[ cut here ]------------
    [  911.891978] WARNING: CPU: 0 PID: 1351 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  911.901585] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x00001070 : Data Access in User mode during Functional access
    [  911.915375] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  911.950012] CPU: 0 PID: 1351 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  911.957437] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  911.963552] Backtrace:
    [  911.966022] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  911.973619]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  911.979336] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  911.986590] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  911.994710]  r5:00000093 r4:ede33e08
    [  911.998313] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  912.007044]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  912.013812] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  912.022717]  r3:ef161a40 r2:c085fe50
    [  912.026323] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  912.035664]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  912.043560]  r4:ef161f40
    [  912.046112] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  912.055018]  r10:00000000 r9:be929d1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  912.062915]  r4:ef15a780
    [  912.065465] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  912.074022]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  912.079734] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  912.088378]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  912.094091] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  912.102826] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  912.111209]  r8:fa213000 r7:fa212000 r6:ede33fb0 r5:c095a8d8 r4:fa21200c r3:ede33fb0
    [  912.119022] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  912.126533] Exception stack(0xede33fb0 to 0xede33ff8)
    [  912.131603] 3fa0:                                     00000000 0010b4a3 00000000 00000000
    [  912.139813] 3fc0: 0010b49f 00000000 00000000 00000002 be929d18 be929d1c 00000000 001d5f34
    [  912.148022] 3fe0: 00000000 be929a10 000098fc 00009904 60000010 ffffffff
    [  912.154661]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000010 r4:00009904 r3:00000000
    [  912.162470] ---[ end trace 6dd630470b1517d6 ]---
    [  912.167384] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  912.174723] pgd = ec09cec0
    [  912.177438] [00000000] *pgd=ad183003, *pmd=bdc35003
    /.debug_dss_clockdumps.sh: line 62: 0x
    Are you sure that:
        TARGETED MODULE IS CLOCKED? >> 0 : syntax error in expression (error token is "!!! OUPS... MEMORY ERROR @ 0x00000000 !!!
    Are you sure that:
        TARGETED MODULE IS CLOCKED? >> 0 ")
      912.199065] ------------[ cut here ]------------
    [  912.230124] WARNING: CPU: 0 PID: 1359 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  912.239731] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x0000140C : Data Access in User mode during Functional access
    [  912.253521] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  912.288163] CPU: 0 PID: 1359 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  912.295586] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  912.301702] Backtrace:
    [  912.304172] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  912.311770]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  912.317486] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  912.324740] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  912.332860]  r5:00000093 r4:edda3e08
    [  912.336463] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  912.345194]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  912.351963] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  912.360869]  r3:ef161a40 r2:c085fe50
    [  912.364477] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  912.373819]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  912.381716]  r4:ef161f40
    [  912.384266] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  912.393171]  r10:00000000 r9:bec16d1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  912.401069]  r4:ef15a780
    [  912.403619] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  912.412176]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  912.417888] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  912.426531]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  912.432244] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  912.440980] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  912.449362]  r8:fa213000 r7:fa212000 r6:edda3fb0 r5:c095a8d8 r4:fa21200c r3:edda3fb0
    [  912.457176] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  912.464687] Exception stack(0xedda3fb0 to 0xedda3ff8)
    [  912.469757] 3fa0:                                     00000000 00000003 58000000 00000000
    [  912.477968] 3fc0: 0010b49f 00000000 00000030 00000002 bec16d18 bec16d1c 00000000 001d5f34
    [  912.486178] 3fe0: 00000000 bec16a10 000be8b8 000098f0 60000010 ffffffff
    [  912.492816]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000010 r4:000098f0 r3:00000000
    [  912.500626] ---[ end trace 6dd630470b1517d7 ]---
    [  912.506431] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  912.513769] pgd = ee3e8b40
    [  912.516485] [00000000] *pgd=ad1e2003, *pmd=ade5b003, *pte=00000000
    Are you sure that:
    Are you sure that:
      912.539350] ------------[ cut here ]------------
    [  912.570541] WARNING: CPU: 0 PID: 1367 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
    [  912.580149] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read Link): At Address: 0x00001838 : Data Access in User mode during Functional access
    [  912.593938] Modules linked in: xhci_plat_hcd rpmsg_rpc ecb dwc3 sha512_generic udc_core virtio_rpmsg_bus sha512_arm sha256_generic hmac md5 sha1_generic sha1_arm_neon sha1_arm pvrsrvkm(O) c_can_platform c_can ahci_platform omap_aes_driver libahci_platform can_dev omap_wdt omap_sham libahci dwc3_omap rtc_omap e1000e omap_des omap_rng rng_core omap_remoteproc remoteproc virtio_ring virtio
    [  912.628577] CPU: 0 PID: 1367 Comm: omapconf Tainted: G        W  O    4.4.14 #13
    [  912.636001] Hardware name: Generic DRA72X (Flattened Device Tree)
    [  912.642116] Backtrace:
    [  912.644586] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
    [  912.652184]  r6:c085fe34 r5:00000000 r4:20000193 r3:00000000
    [  912.657900] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
    [  912.665154] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
    [  912.673275]  r5:00000093 r4:ede33e08
    [  912.676878] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
    [  912.685609]  r8:c06c353c r7:ef161bd0 r6:c085fd24 r5:c085fd84 r4:80080001
    [  912.692376] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
    [  912.701281]  r3:ef161a40 r2:c085fe50
    [  912.704890] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
    [  912.714232]  r10:ef15a780 r9:c09b240b r8:00000017 r7:00000000 r6:00000000 r5:ef15a7e0
    [  912.722130]  r4:ef161f40
    [  912.724682] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
    [  912.733587]  r10:00000000 r9:bed9ed1c r8:ef006000 r7:00000000 r6:c095fe44 r5:ef15a7e0
    [  912.741485]  r4:ef15a780
    [  912.744035] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
    [  912.752593]  r6:c095fe44 r5:ef15a7e0 r4:ef15a780 r3:00000000
    [  912.758305] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
    [  912.766949]  r7:00000000 r6:00000000 r5:c0953424 r4:00000017
    [  912.772664] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
    [  912.781400] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
    [  912.789781]  r8:fa213000 r7:fa212000 r6:ede33fb0 r5:c095a8d8 r4:fa21200c r3:ede33fb0
    [  912.797596] [<c0009420>] (gic_handle_irq) from [<c0013ae8>] (__irq_usr+0x48/0x60)
    [  912.805107] Exception stack(0xede33fb0 to 0xede33ff8)
    [  912.810177] 3fa0:                                     0012a901 0010b4a3 00000000 00000000
    [  912.818389] 3fc0: 0010b49f 00000000 00000000 00000002 bed9ed18 bed9ed1c 00000000 001d5f34
    [  912.826600] 3fe0: 00000000 bed9ea10 000098fc 00009908 60000010 ffffffff
    [  912.833238]  r8:30c5387d r7:30c5387d r6:ffffffff r5:60000010 r4:00009908 r3:0012a901
    [  912.841049] ---[ end trace 6dd630470b1517d8 ]---
    [  912.845823] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [  912.853160] pgd = ec09c640
    [  912.855875] [00000000] *pgd=ac39c003, *pmd=ad15b003, *pte=00000000
    Are you sure that:
    Are you sure that:
    ./debug_dss_clockdumps.sh: line 222: [: !=: unary operator expected
    ./debug_dss_clockdumps.sh: line 223: [: !=: unary operator expected
    ./debug_dss_clockdumps.sh: line 224: [: !=: unary operator expected
    LCD1 logic clk(/ 0 ) :  0  pix clk(/ ) :  0
    LCD2 logic clk(/ ) :  0  pix clk(/ ) :  0
    LCD3 logic clk(/ ) :  0  pix clk(/ ) :  0
    root@wnc-j6:~#
    Could you please provide more debug hints.
    Thank you.
  • I am confused with your responce.
    Did my last answer solve the capture hang issue?
    If so, please mark this question as answered.
    Raise a separate thread for DSS related issues.
    Lets keep this thread only related to capture issues.
