Other Parts Discussed in Thread: BEAGLE, OMAP3530, TEST, DAC7512, TCA6416, LM8323, TWL6040, PCF8574, TPS65910, BQ27000, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95241, LM95245, ADS1015, ADS7828, ADS7871, AMC6821, THMC50, TMP102, TMP401, TMP421, TPS65010, TPS65217, TPS65912, TWL6030, BQ24022, LP3971, LP3972, TPS65023, DA8XX, TLC59108, CYPRESS, TUSB6010, LM3530, LP3944, LP5521, LP5523, DAC124S085, BEAGLEBONE
Tool/software: Linux
My kernel version is 3.2.0,we want to use RNDIS and am335x in host mode,below is the Kernel dmesg log generated when the USB device was plugged in. However,when a u disk was pluged in, its ok.
usb 2-1: new high-speed USB device number 42 using musb-hdrc
Jan 1 00:05:54 OCU-X1 user.info kernel: usb 2-1: new high-speed USB device number 42 using musb-hdrc
hub 2-0:1.0: unable to enumerate USB device on port 1
I have tried cat /proc/driver/musb_hdrc.0 below is printed.
cat musb_hdrc.0
Status: MHDRC, Mode=Host (Power=e0, DevCtl=19)
OTG state: a_wait_bcon; inactive
Options: ?dma?, otg (peripheral+host), [eps=16]
Peripheral address: 00
Root port status: 00000100
CPPI: txcr=0 txsrc=0 txena=0; rxcr=0 rxsrc=280de80 rxena=0
cat musb_hdrc.1
Status: MHDRC, Mode=Host (Power=e0, DevCtl=5d)
OTG state: a_host; active
Root port status: 00000101
Gadget driver: g_ether
board-am335xevm.c
static struct omap_musb_board_data musb_board_data = {
.interface_type = MUSB_INTERFACE_ULPI,
* mode[0:3] = USB0PORT's mode
* mode[4:7] = USB1PORT's mode
.mode = (MUSB_OTG << 4) | MUSB_HOST,
.power = 500,
.instances = 1,
below is the .config file
# Automatically generated file; DO NOT EDIT.
# Linux/arm 3.2.0 Kernel Configuration
CONFIG_ARM=y
CONFIG_HAVE_PWM=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_SCHED_CLOCK=y
CONFIG_GENERIC_GPIO=y
# CONFIG_ARCH_USES_GETTIMEOFFSET is not set
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_KTIME_SCALAR=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
CONFIG_ARCH_HAS_CPUFREQ=y
CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_HAVE_IRQ_WORK=y
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_LZO is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
# CONFIG_FHANDLE is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_GENERIC_HARDIRQS=y
# IRQ subsystem
CONFIG_GENERIC_HARDIRQS=y
CONFIG_HAVE_SPARSE_IRQ=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
# CONFIG_SPARSE_IRQ is not set
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_PREEMPT_RCU is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_TREE_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=16
# CONFIG_CGROUPS is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_KALLSYMS=y
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
# CONFIG_PERF_EVENTS is not set
# CONFIG_PERF_COUNTERS is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
CONFIG_PROFILING=y
CONFIG_OPROFILE=y
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_DMA_API_DEBUG=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
# CONFIG_INLINE_SPIN_TRYLOCK is not set
# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK is not set
# CONFIG_INLINE_SPIN_LOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
CONFIG_INLINE_SPIN_UNLOCK=y
# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_READ_TRYLOCK is not set
# CONFIG_INLINE_READ_LOCK is not set
# CONFIG_INLINE_READ_LOCK_BH is not set
# CONFIG_INLINE_READ_LOCK_IRQ is not set
# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
CONFIG_INLINE_READ_UNLOCK=y
# CONFIG_INLINE_READ_UNLOCK_BH is not set
CONFIG_INLINE_READ_UNLOCK_IRQ=y
# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_WRITE_TRYLOCK is not set
# CONFIG_INLINE_WRITE_LOCK is not set
# CONFIG_INLINE_WRITE_LOCK_BH is not set
# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
CONFIG_INLINE_WRITE_UNLOCK=y
# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
# CONFIG_MUTEX_SPIN_ON_OWNER is not set
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCMRING is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_CNS3XXX is not set
# CONFIG_ARCH_GEMINI is not set
# CONFIG_ARCH_PRIMA2 is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_MXS is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_H720X is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP23XX is not set
# CONFIG_ARCH_IXP2000 is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KIRKWOOD is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_PICOXCELL is not set
# CONFIG_ARCH_PNX4008 is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_MSM is not set
# CONFIG_ARCH_SHMOBILE is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C2410 is not set
# CONFIG_ARCH_S3C64XX is not set
# CONFIG_ARCH_S5P64X0 is not set
# CONFIG_ARCH_S5PC100 is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_SHARK is not set
# CONFIG_ARCH_TCC_926 is not set
# CONFIG_ARCH_U300 is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_NOMADIK is not set
# CONFIG_ARCH_DAVINCI is not set
CONFIG_ARCH_OMAP=y
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_VT8500 is not set
# CONFIG_ARCH_ZYNQ is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# TI OMAP Common Features
# CONFIG_ARCH_OMAP1 is not set
CONFIG_ARCH_OMAP2PLUS=y
# OMAP Feature Selections
CONFIG_AM33XX_SMARTREFLEX=y
# CONFIG_OMAP_SMARTREFLEX is not set
CONFIG_OMAP_RESET_CLOCKS=y
CONFIG_OMAP_MUX=y
CONFIG_OMAP_MUX_DEBUG=y
CONFIG_OMAP_MUX_WARNINGS=y
# CONFIG_OMAP_MCBSP is not set
CONFIG_OMAP_MBOX_FWK=y
CONFIG_OMAP_MBOX_KFIFO_SIZE=256
# CONFIG_OMAP_32K_TIMER is not set
# CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
CONFIG_OMAP_DM_TIMER=y
CONFIG_OMAP_PM_NOOP=y
CONFIG_MACH_OMAP_GENERIC=y
# TI OMAP2/3/4 Specific Features
CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
# CONFIG_ARCH_OMAP2 is not set
CONFIG_ARCH_OMAP3=y
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP3430 is not set
CONFIG_SOC_OMAPTI81XX=y
CONFIG_SOC_OMAPAM33XX=y
CONFIG_OMAP_PACKAGE_CBB=y
# OMAP Board Type
CONFIG_MACH_OMAP3_BEAGLE=y
# CONFIG_MACH_DEVKIT8000 is not set
# CONFIG_MACH_OMAP_LDP is not set
# CONFIG_MACH_OMAP3530_LV_SOM is not set
# CONFIG_MACH_OMAP3_TORPEDO is not set
# CONFIG_MACH_ENCORE is not set
# CONFIG_MACH_OVERO is not set
# CONFIG_MACH_OMAP3EVM is not set
# CONFIG_MACH_OMAP3517EVM is not set
# CONFIG_MACH_CRANEBOARD is not set
# CONFIG_MACH_OMAP3_PANDORA is not set
# CONFIG_MACH_OMAP3_TOUCHBOOK is not set
# CONFIG_MACH_OMAP_3430SDP is not set
# CONFIG_MACH_NOKIA_RM680 is not set
# CONFIG_MACH_NOKIA_RX51 is not set
# CONFIG_MACH_OMAP_ZOOM2 is not set
# CONFIG_MACH_OMAP_ZOOM3 is not set
# CONFIG_MACH_CM_T35 is not set
# CONFIG_MACH_CM_T3517 is not set
# CONFIG_MACH_IGEP0020 is not set
# CONFIG_MACH_IGEP0030 is not set
# CONFIG_MACH_SBC3530 is not set
# CONFIG_MACH_OMAP_3630SDP is not set
CONFIG_MACH_TI8168EVM=y
CONFIG_MACH_TI8148EVM=y
CONFIG_MACH_AM335XEVM=y
CONFIG_MACH_AM335XIAEVM=y
# CONFIG_OMAP3_EMU is not set
CONFIG_TI_PM_DISABLE_VT_SWITCH=y
# CONFIG_OMAP3_SDRC_AC_TIMING is not set
CONFIG_OMAP3_EDMA=y
# System MMU
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
CONFIG_ARM_THUMB=y
CONFIG_ARM_THUMBEE=y
# CONFIG_SWP_EMULATE is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_MULTI_IRQ_HANDLER=y
# CONFIG_ARM_ERRATA_430973 is not set
# CONFIG_ARM_ERRATA_458693 is not set
# CONFIG_ARM_ERRATA_460075 is not set
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_743622 is not set
# CONFIG_ARM_ERRATA_751472 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# Bus support
# CONFIG_PCI_SYSCALL is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
CONFIG_HZ=100
# CONFIG_THUMB2_KERNEL is not set
CONFIG_AEABI=y
CONFIG_OABI_COMPAT=y
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
# CONFIG_HIGHMEM is not set
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_COMPACTION is not set
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_VIRT_TO_BUS=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
CONFIG_FORCE_MAX_ZONEORDER=12
# CONFIG_LEDS is not set
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
# CONFIG_CC_STACKPROTECTOR is not set
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
# Boot options
CONFIG_USE_OF=y
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
# CONFIG_ARM_APPENDED_DTB is not set
CONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO0,115200"
CONFIG_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_CMDLINE_EXTEND is not set
# CONFIG_CMDLINE_FORCE is not set
# CONFIG_XIP_KERNEL is not set
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
# CONFIG_AUTO_ZRELADDR is not set
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_TABLE=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_STAT_DETAILS=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
# ARM CPU frequency scaling drivers
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_GOV_LADDER=y
CONFIG_CPU_IDLE_GOV_MENU=y
# Floating point emulation
# At least one emulation must be selected
CONFIG_FPE_NWFPE=y
# CONFIG_FPE_NWFPE_XP is not set
# CONFIG_FPE_FASTFPE is not set
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# Userspace binary formats
CONFIG_BINFMT_ELF=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_HAVE_AOUT=y
# CONFIG_BINFMT_AOUT is not set
CONFIG_BINFMT_MISC=y
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
CONFIG_PM_SLEEP=y
CONFIG_PM_RUNTIME=y
CONFIG_PM=y
CONFIG_PM_DEBUG=y
CONFIG_PM_ADVANCED_DEBUG=y
# CONFIG_PM_TEST_SUSPEND is not set
CONFIG_CAN_PM_TRACE=y
# CONFIG_APM_EMULATION is not set
CONFIG_ARCH_HAS_OPP=y
CONFIG_PM_OPP=y
CONFIG_PM_CLK=y
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_UNIX=y
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_IP_MROUTE is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET_XFRM_MODE_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_BEET is not set
# CONFIG_INET_LRO is not set
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETLABEL is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_NETFILTER_ADVANCED=y
# Core Netfilter Configuration
# CONFIG_NETFILTER_NETLINK_QUEUE is not set
# CONFIG_NETFILTER_NETLINK_LOG is not set
CONFIG_NF_CONNTRACK=y
# CONFIG_NF_CONNTRACK_MARK is not set
# CONFIG_NF_CONNTRACK_EVENTS is not set
# CONFIG_NF_CONNTRACK_TIMESTAMP is not set
# CONFIG_NF_CT_PROTO_DCCP is not set
# CONFIG_NF_CT_PROTO_SCTP is not set
# CONFIG_NF_CT_PROTO_UDPLITE is not set
# CONFIG_NF_CONNTRACK_AMANDA is not set
# CONFIG_NF_CONNTRACK_FTP is not set
# CONFIG_NF_CONNTRACK_H323 is not set
# CONFIG_NF_CONNTRACK_IRC is not set
# CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
# CONFIG_NF_CONNTRACK_SNMP is not set
# CONFIG_NF_CONNTRACK_PPTP is not set
# CONFIG_NF_CONNTRACK_SANE is not set
# CONFIG_NF_CONNTRACK_SIP is not set
# CONFIG_NF_CONNTRACK_TFTP is not set
# CONFIG_NF_CT_NETLINK is not set
CONFIG_NETFILTER_XTABLES=y
# Xtables combined modules
# CONFIG_NETFILTER_XT_MARK is not set
# CONFIG_NETFILTER_XT_CONNMARK is not set
# Xtables targets
# CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
# CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
# CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
# CONFIG_NETFILTER_XT_TARGET_LED is not set
# CONFIG_NETFILTER_XT_TARGET_MARK is not set
# CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
# CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
# CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
# CONFIG_NETFILTER_XT_TARGET_TEE is not set
# CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
# Xtables matches
# CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set
# CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
# CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
# CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
# CONFIG_NETFILTER_XT_MATCH_CPU is not set
# CONFIG_NETFILTER_XT_MATCH_DCCP is not set
# CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
# CONFIG_NETFILTER_XT_MATCH_DSCP is not set
# CONFIG_NETFILTER_XT_MATCH_ESP is not set
# CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_HELPER is not set
# CONFIG_NETFILTER_XT_MATCH_HL is not set
# CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
# CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
# CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_MAC is not set
# CONFIG_NETFILTER_XT_MATCH_MARK is not set
# CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
# CONFIG_NETFILTER_XT_MATCH_OWNER is not set
# CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
# CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
# CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
# CONFIG_NETFILTER_XT_MATCH_REALM is not set
# CONFIG_NETFILTER_XT_MATCH_RECENT is not set
# CONFIG_NETFILTER_XT_MATCH_SCTP is not set
# CONFIG_NETFILTER_XT_MATCH_STATE is not set
# CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
# CONFIG_NETFILTER_XT_MATCH_STRING is not set
# CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
# CONFIG_NETFILTER_XT_MATCH_TIME is not set
# CONFIG_NETFILTER_XT_MATCH_U32 is not set
# CONFIG_IP_VS is not set
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=y
CONFIG_NF_CONNTRACK_IPV4=y
CONFIG_NF_CONNTRACK_PROC_COMPAT=y
# CONFIG_IP_NF_QUEUE is not set
CONFIG_IP_NF_IPTABLES=y
# CONFIG_IP_NF_MATCH_AH is not set
# CONFIG_IP_NF_MATCH_ECN is not set
# CONFIG_IP_NF_MATCH_TTL is not set
CONFIG_IP_NF_FILTER=y
# CONFIG_IP_NF_TARGET_REJECT is not set
CONFIG_IP_NF_TARGET_LOG=y
# CONFIG_IP_NF_TARGET_ULOG is not set
CONFIG_NF_NAT=y
CONFIG_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
# CONFIG_IP_NF_TARGET_NETMAP is not set
# CONFIG_IP_NF_TARGET_REDIRECT is not set
# CONFIG_NF_NAT_FTP is not set
# CONFIG_NF_NAT_IRC is not set
# CONFIG_NF_NAT_TFTP is not set
# CONFIG_NF_NAT_AMANDA is not set
# CONFIG_NF_NAT_PPTP is not set
# CONFIG_NF_NAT_H323 is not set
# CONFIG_NF_NAT_SIP is not set
# CONFIG_IP_NF_MANGLE is not set
# CONFIG_IP_NF_RAW is not set
# CONFIG_IP_NF_SECURITY is not set
# CONFIG_IP_NF_ARPTABLES is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
CONFIG_BT=y
CONFIG_BT_L2CAP=y
CONFIG_BT_SCO=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
# Bluetooth device drivers
CONFIG_BT_HCIBTUSB=y
CONFIG_BT_HCIBTSDIO=y
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIBCM203X=y
CONFIG_BT_HCIBPA10X=y
CONFIG_BT_HCIBFUSB=y
CONFIG_BT_HCIVHCI=y
CONFIG_BT_MRVL=y
CONFIG_BT_MRVL_SDIO=y
CONFIG_BT_ATH3K=y
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_CFG80211=y
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_REG_DEBUG is not set
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
# CONFIG_CFG80211_INTERNAL_REGDB is not set
CONFIG_CFG80211_WEXT=y
# CONFIG_WIRELESS_EXT_SYSFS is not set
CONFIG_LIB80211=y
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=y
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_MINSTREL_HT=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
# CONFIG_MAC80211_LEDS is not set
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_RFKILL_REGULATOR is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE="am335x-pm-firmware.bin"
CONFIG_EXTRA_FIRMWARE_DIR="firmware"
# CONFIG_SYS_HYPERVISOR is not set
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
# CBUS support
# CONFIG_CBUS is not set
CONFIG_CONNECTOR=y
CONFIG_PROC_EVENTS=y
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_OF_PARTS is not set
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
CONFIG_MTD_OOPS=y
# CONFIG_MTD_SWAP is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_CFI_INTELEXT is not set
# CONFIG_MTD_CFI_AMDSTD is not set
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PHYSMAP is not set
# CONFIG_MTD_PHYSMAP_OF is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_M25P80 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
# CONFIG_MTD_DOCG3 is not set
CONFIG_MTD_NAND_ECC=y
# CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND=y
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
# CONFIG_MTD_NAND_ECC_BCH is not set
# CONFIG_MTD_SM_COMMON is not set
# CONFIG_MTD_NAND_MUSEUM_IDS is not set
# CONFIG_MTD_NAND_GPIO is not set
CONFIG_MTD_NAND_OMAP2=y
CONFIG_MTD_NAND_IDS=y
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_ALAUDA is not set
CONFIG_MTD_ONENAND=y
# CONFIG_MTD_ONENAND_VERIFY_WRITE is not set
# CONFIG_MTD_ONENAND_GENERIC is not set
CONFIG_MTD_ONENAND_OMAP2=y
# CONFIG_MTD_ONENAND_OTP is not set
# CONFIG_MTD_ONENAND_2X_PROGRAM is not set
# CONFIG_MTD_ONENAND_SIM is not set
# LPDDR flash memory drivers
# CONFIG_MTD_LPDDR is not set
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_RESERVE=1
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_DEBUG is not set
CONFIG_DTC=y
CONFIG_OF=y
# Device Tree and Open Firmware support
CONFIG_PROC_DEVICETREE=y
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_DEVICE=y
CONFIG_OF_GPIO=y
CONFIG_OF_I2C=y
CONFIG_OF_NET=y
CONFIG_OF_SPI=y
CONFIG_OF_MDIO=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=32768
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_MG_DISK is not set
# CONFIG_BLK_DEV_RBD is not set
CONFIG_SENSORS_LIS3LV02D=y
CONFIG_MISC_DEVICES=y
# CONFIG_AD525X_DPOT is not set
# CONFIG_ATMEL_PWM is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1780 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_TI_DAC7512 is not set
# CONFIG_BMP085 is not set
# CONFIG_USB_SWITCH_FSA9480 is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_IWMC3200TOP is not set
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# CONFIG_SENSORS_LIS3_SPI is not set
CONFIG_SENSORS_LIS3_I2C=y
# Altera FPGA firmware download module
# CONFIG_ALTERA_STAPL is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_TGT is not set
# CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
CONFIG_SCSI_MULTI_LUN=y
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
CONFIG_SCSI_SCAN_ASYNC=y
CONFIG_SCSI_WAIT_SCAN=m
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_LIBFC is not set
# CONFIG_LIBFCOE is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_EQUALIZER is not set
CONFIG_MII=y
# CONFIG_MACVLAN is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_TUN is not set
# CONFIG_VETH is not set
# CAIF transport drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_BROADCOM=y
# CONFIG_B44 is not set
CONFIG_NET_VENDOR_CHELSIO=y
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_FARADAY=y
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
CONFIG_NET_VENDOR_INTEL=y
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_MARVELL=y
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
CONFIG_NET_VENDOR_MICROCHIP=y
# CONFIG_ENC28J60 is not set
CONFIG_NET_VENDOR_NATSEMI=y
CONFIG_NET_VENDOR_8390=y
# CONFIG_AX88796 is not set
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_SEEQ=y
# CONFIG_SEEQ8005 is not set
CONFIG_NET_VENDOR_SMSC=y
CONFIG_SMC91X=y
# CONFIG_SMC911X is not set
CONFIG_SMSC911X=y
# CONFIG_SMSC911X_ARCH_HOOKS is not set
CONFIG_NET_VENDOR_STMICRO=y
# CONFIG_STMMAC_ETH is not set
CONFIG_NET_VENDOR_TI=y
# CONFIG_TI_DAVINCI_EMAC is not set
CONFIG_TI_DAVINCI_MDIO=y
CONFIG_TI_DAVINCI_CPDMA=y
CONFIG_TI_CPSW=y
CONFIG_TI_CPSW_DUAL_EMAC=y
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
CONFIG_SMSC_PHY=y
# CONFIG_BROADCOM_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_MICREL_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOE=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
# CONFIG_SLIP is not set
CONFIG_SLHC=y
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
CONFIG_USB_USBNET=y
# CONFIG_USB_NET_AX8817X is not set
CONFIG_USB_NET_CDCETHER=y
CONFIG_USB_NET_CDC_EEM=y
CONFIG_USB_NET_CDC_NCM=y
CONFIG_USB_NET_DM9601=y
# CONFIG_USB_NET_SMSC75XX is not set
# CONFIG_USB_NET_SMSC95XX is not set
# CONFIG_USB_NET_GL620A is not set
# CONFIG_USB_NET_NET1080 is not set
# CONFIG_USB_NET_PLUSB is not set
# CONFIG_USB_NET_MCS7830 is not set
# CONFIG_USB_NET_RNDIS_HOST is not set
# CONFIG_USB_NET_CDC_SUBSET is not set
# CONFIG_USB_NET_ZAURUS is not set
# CONFIG_USB_NET_CX82310_ETH is not set
# CONFIG_USB_NET_KALMIA is not set
# CONFIG_USB_NET_INT51X1 is not set
# CONFIG_USB_IPHETH is not set
# CONFIG_USB_SIERRA_NET is not set
# CONFIG_USB_VL600 is not set
CONFIG_WLAN=y
# CONFIG_LIBERTAS_THINFIRM is not set
# CONFIG_AT76C50X_USB is not set
# CONFIG_USB_ZD1201 is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_RTL8187 is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_ATH_COMMON is not set
# CONFIG_B43 is not set
# CONFIG_B43LEGACY is not set
# CONFIG_BRCMFMAC is not set
# CONFIG_HOSTAP is not set
# CONFIG_IWM is not set
# CONFIG_LIBERTAS is not set
# CONFIG_P54_COMMON is not set
# CONFIG_RT2X00 is not set
CONFIG_RTL8192CU=y
CONFIG_RTLWIFI=y
CONFIG_RTL8192C_COMMON=y
# CONFIG_WL1251 is not set
# CONFIG_WL12XX_MENU is not set
CONFIG_WL12XX_PLATFORM_DATA=y
# CONFIG_ZD1211RW is not set
# CONFIG_MWIFIEX is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
CONFIG_INPUT_POLLDEV=y
# CONFIG_INPUT_SPARSEKMAP is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_TCA6416 is not set
CONFIG_KEYBOARD_MATRIX=y
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_TWL4030 is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_MMA8450 is not set
CONFIG_INPUT_FXLS8471Q=y
# CONFIG_INPUT_MPU3050 is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_TWL4030_PWRBUTTON is not set
# CONFIG_INPUT_TWL4030_VIBRA is not set
# CONFIG_INPUT_TWL6040_VIBRA is not set
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_CMA3000 is not set
# Hardware I/O ports
CONFIG_SERIO=y
# CONFIG_SERIO_SERPORT is not set
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
# CONFIG_LEGACY_PTYS is not set
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_DEVKMEM=y
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX3107 is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_OMAP=y
CONFIG_SERIAL_OMAP_CONSOLE=y
# CONFIG_SERIAL_TIMBERDALE is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
CONFIG_detector=y
CONFIG_vol_int=y
# CONFIG_TCG_TPM is not set
# CONFIG_RAMOOPS is not set
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
# CONFIG_I2C_HELPER_AUTO is not set
CONFIG_I2C_SMBUS=y
# I2C Algorithms
CONFIG_I2C_ALGOBIT=y
# CONFIG_I2C_ALGOPCF is not set
# CONFIG_I2C_ALGOPCA is not set
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_OMAP=y
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_PXA_PCI is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_OC_TINY is not set
CONFIG_SPI_OMAP24XX=y
# CONFIG_SPI_PXA2XX_PCI is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_DESIGNWARE is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=y
# CONFIG_SPI_TLE62X0 is not set
# PPS support
# CONFIG_PPS is not set
# PPS generators support
# PTP clock support
# Enable Device Drivers -> PPS to see the PTP clock options.
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers:
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_IT8761E is not set
# I2C GPIO expanders:
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_SX150X is not set
# CONFIG_GPIO_TWL4030 is not set
# CONFIG_GPIO_ADP5588 is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MCP23S08 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_74X164 is not set
# AC97 GPIO expanders:
# MODULbus GPIO expanders:
CONFIG_GPIO_TPS65910=y
CONFIG_GENERIC_PWM=y
CONFIG_DAVINCI_EHRPWM=y
CONFIG_ECAP_PWM=y
CONFIG_W1=y
CONFIG_W1_CON=y
# 1-wire Bus Masters
# CONFIG_W1_MASTER_DS2490 is not set
CONFIG_W1_MASTER_DS2482=y
# CONFIG_W1_MASTER_DS1WM is not set
# CONFIG_W1_MASTER_GPIO is not set
# CONFIG_HDQ_MASTER_OMAP is not set
# 1-wire Slaves
# CONFIG_W1_SLAVE_THERM is not set
# CONFIG_W1_SLAVE_SMEM is not set
# CONFIG_W1_SLAVE_DS2408 is not set
# CONFIG_W1_SLAVE_DS2423 is not set
# CONFIG_W1_SLAVE_DS2431 is not set
# CONFIG_W1_SLAVE_DS2433 is not set
# CONFIG_W1_SLAVE_DS2760 is not set
# CONFIG_W1_SLAVE_DS2780 is not set
# CONFIG_W1_SLAVE_BQ27000 is not set
# CONFIG_POWER_SUPPLY is not set
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_SHT15 is not set
CONFIG_SENSORS_SHT21=y
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH56XX_COMMON is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_ADS1015 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
# CONFIG_THERMAL is not set
CONFIG_WATCHDOG=y
# CONFIG_WATCHDOG_CORE is not set
# CONFIG_WATCHDOG_NOWAYOUT is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_OMAP_WATCHDOG=y
# CONFIG_TWL4030_WATCHDOG is not set
# CONFIG_MAX63XX_WATCHDOG is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# Broadcom specific AMBA
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_HTC_EGPIO is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
CONFIG_MFD_TI_TSCADC=y
CONFIG_MFD_TPS65217=y
# CONFIG_MFD_TPS6586X is not set
CONFIG_MFD_TPS65910=y
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
CONFIG_TWL4030_CORE=y
# CONFIG_TWL4030_MADC is not set
CONFIG_TWL4030_POWER=y
# CONFIG_MFD_TWL4030_AUDIO is not set
# CONFIG_TWL6030_PWM is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_STMPE is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_MC13XXX is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_WL1273_CORE is not set
CONFIG_MFD_OMAP_USB_HOST=y
# CONFIG_MFD_AAT2870_CORE is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_DUMMY=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_GPIO is not set
# CONFIG_REGULATOR_BQ24022 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_TWL4030 is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
CONFIG_REGULATOR_TPS65217=y
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_TPS6524X is not set
CONFIG_REGULATOR_TPS65910=y
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
CONFIG_DRM=y
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
CONFIG_HDMI=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
# CONFIG_FB_DDC is not set
# CONFIG_FB_BOOT_VESA_SUPPORT is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
# CONFIG_FB_SYS_FILLRECT is not set
# CONFIG_FB_SYS_COPYAREA is not set
# CONFIG_FB_SYS_IMAGEBLIT is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
# CONFIG_FB_SYS_FOPS is not set
# CONFIG_FB_WMT_GE_ROPS is not set
# CONFIG_FB_SVGALIB is not set
# CONFIG_FB_MACMODES is not set
# CONFIG_FB_BACKLIGHT is not set
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_UVESA is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_TMIO is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
CONFIG_FB_DA8XX=y
CONFIG_FB_DA8XX_CONSISTENT_DMA_SIZE=8
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_BROADSHEET is not set
# CONFIG_FB_OMAP is not set
# CONFIG_OMAP2_DSS is not set
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=y
# CONFIG_LCD_L4F00242T03 is not set
# CONFIG_LCD_LMS283GF05 is not set
# CONFIG_LCD_LTV350QV is not set
# CONFIG_LCD_TDO24M is not set
# CONFIG_LCD_VGG2432A4 is not set
# CONFIG_LCD_PLATFORM is not set
# CONFIG_LCD_S6E63M0 is not set
# CONFIG_LCD_LD9040 is not set
# CONFIG_LCD_AMS369FG06 is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_GENERIC is not set
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
CONFIG_BACKLIGHT_TLC59108=y
# Display device support
CONFIG_DISPLAY_SUPPORT=y
# Display hardware drivers
# NXP I2C encoder chips
CONFIG_DRM_I2C_NXP_TDA998X=m
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
# CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# CONFIG_SOUND is not set
CONFIG_HID_SUPPORT=y
CONFIG_HID=y
# CONFIG_HIDRAW is not set
# USB Input Devices
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# Special HID drivers
CONFIG_HID_A4TECH=y
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=y
CONFIG_HID_BELKIN=y
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
CONFIG_HID_CYPRESS=y
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELECOM is not set
CONFIG_HID_EZKEY=y
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_KEYTOUCH is not set
CONFIG_HID_KYE=y
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_TWINHAN is not set
CONFIG_HID_KENSINGTON=y
# CONFIG_HID_LCPOWER is not set
CONFIG_HID_LOGITECH=y
CONFIG_HID_LOGITECH_DJ=m
# CONFIG_LOGITECH_FF is not set
# CONFIG_LOGIRUMBLEPAD2_FF is not set
# CONFIG_LOGIG940_FF is not set
# CONFIG_LOGIWHEELS_FF is not set
# CONFIG_HID_MAGICMOUSE is not set
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_QUANTA is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
# CONFIG_USB_ARCH_HAS_XHCI is not set
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_SUSPEND=y
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_HCD_OMAP=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HWA_HCD is not set
CONFIG_USB_MUSB_HDRC=y
# Platform Glue Layer
# CONFIG_USB_MUSB_TUSB6010_GLUE is not set
# CONFIG_USB_MUSB_OMAP2PLUS_GLUE is not set
# CONFIG_USB_MUSB_AM35X_GLUE is not set
CONFIG_USB_MUSB_TI81XX_GLUE=y
# CONFIG_USB_MUSB_DAVINCI is not set
# CONFIG_USB_MUSB_DA8XX is not set
# CONFIG_USB_MUSB_TUSB6010 is not set
# CONFIG_USB_MUSB_OMAP2PLUS is not set
# CONFIG_USB_MUSB_AM35X is not set
CONFIG_USB_MUSB_TI81XX=y
# CONFIG_USB_MUSB_BLACKFIN is not set
# CONFIG_USB_MUSB_UX500 is not set
CONFIG_USB_TI_CPPI41_DMA_HW=y
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_INVENTRA_DMA is not set
# CONFIG_USB_TI_CPPI_DMA is not set
CONFIG_USB_TI_CPPI41_DMA=y
# CONFIG_USB_TUSB_OMAP_DMA is not set
# CONFIG_USB_UX500_DMA is not set
# CONFIG_USB_RENESAS_USBHS is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
CONFIG_USB_WDM=y
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# CONFIG_USB_LIBUSUAL is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB port drivers
CONFIG_USB_SERIAL=y
# CONFIG_USB_SERIAL_CONSOLE is not set
# CONFIG_USB_EZUSB is not set
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_CH341 is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
# CONFIG_USB_SERIAL_CP210X is not set
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
# CONFIG_USB_SERIAL_FTDI_SIO is not set
# CONFIG_USB_SERIAL_FUNSOFT is not set
# CONFIG_USB_SERIAL_VISOR is not set
# CONFIG_USB_SERIAL_IPAQ is not set
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MOTOROLA is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
# CONFIG_USB_SERIAL_PL2303 is not set
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_QCAUX is not set
# CONFIG_USB_SERIAL_QUALCOMM is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_HP4X is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SIEMENS_MPI is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_SYMBOL is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
CONFIG_USB_SERIAL_WWAN=y
CONFIG_USB_SERIAL_OPTION=y
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_OPTICON is not set
# CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set
# CONFIG_USB_SERIAL_ZIO is not set
# CONFIG_USB_SERIAL_SSU100 is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_OMAP is not set
# CONFIG_USB_R8A66597 is not set
CONFIG_USB_GADGET_MUSB_HDRC=y
# CONFIG_USB_M66592 is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
# CONFIG_USB_ZERO is not set
CONFIG_USB_ETH=y
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_FILE_STORAGE is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ULPI is not set
# CONFIG_TWL6030_USB is not set
CONFIG_NOP_USB_XCEIV=y
CONFIG_MMC=y
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_UNSAFE_RESUME=y
# CONFIG_MMC_CLKGATE is not set
# MMC/SD/SDIO Card Drivers
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
CONFIG_MMC_BLOCK_BOUNCE=y
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_SDHCI_PXAV3 is not set
# CONFIG_MMC_SDHCI_PXAV2 is not set
# CONFIG_MMC_OMAP is not set
CONFIG_MMC_OMAP_HS=y
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# LED drivers
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_RENESAS_TPU is not set
CONFIG_LEDS_TRIGGERS=y
# LED Triggers
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
# CONFIG_LEDS_TRIGGER_DEFAULT_ON is not set
# iptables trigger is under Netfilter config (LED target)
# CONFIG_ACCESSIBILITY is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_TWL4030 is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_DS3234 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_OMAP=y
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# Virtio drivers
# CONFIG_VIRTIO_BALLOON is not set
# CONFIG_VIRTIO_MMIO is not set
# CONFIG_STAGING is not set
CONFIG_CLKDEV_LOOKUP=y
# Hardware Spinlock drivers
CONFIG_CLKSRC_MMIO=y
# CONFIG_IOMMU_SUPPORT is not set
# CONFIG_VIRT_DRIVERS is not set
# CONFIG_PM_DEVFREQ is not set
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
# CONFIG_EXT3_FS_XATTR is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_FS_XATTR=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
CONFIG_QUOTA=y
# CONFIG_QUOTA_NETLINK_INTERFACE is not set
CONFIG_PRINT_QUOTA_WARNING=y
# CONFIG_QUOTA_DEBUG is not set
CONFIG_QUOTA_TREE=y
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_TMPFS_XATTR is not set
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
CONFIG_UBIFS_FS=y
# CONFIG_UBIFS_FS_XATTR is not set
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
# CONFIG_UBIFS_FS_DEBUG is not set
# CONFIG_LOGFS is not set
CONFIG_CRAMFS=y
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
# CONFIG_NFS_V4_1 is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
# CONFIG_NFS_USE_NEW_IDMAPPER is not set
# CONFIG_NFSD is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Kernel hacking
# CONFIG_PRINTK_TIME is not set
CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
CONFIG_MAGIC_SYSRQ=y
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
# CONFIG_DEBUG_KERNEL is not set
# CONFIG_HARDLOCKUP_DETECTOR is not set
# CONFIG_SPARSE_RCU_POINTER is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_DEBUG_MEMORY_INIT=y
CONFIG_FRAME_POINTER=y
# CONFIG_LKDTM is not set
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_RING_BUFFER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
CONFIG_DYNAMIC_DEBUG=y
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_UNWIND is not set
# CONFIG_DEBUG_USER is not set
CONFIG_DEBUG_JTAG_ENABLE=y
# Security options
CONFIG_KEYS=y
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEYS_DEBUG_PROC_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
CONFIG_SECURITY=y
# CONFIG_SECURITYFS is not set
# CONFIG_SECURITY_NETWORK is not set
# CONFIG_SECURITY_PATH is not set
# CONFIG_SECURITY_TOMOYO is not set
# CONFIG_SECURITY_APPARMOR is not set
# CONFIG_IMA is not set
# CONFIG_EVM is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
# CONFIG_CRYPTO_MANAGER_DISABLE_TESTS is not set
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
CONFIG_CRYPTO_TEST=m
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
CONFIG_CRYPTO_SEQIV=y
# Block modes
CONFIG_CRYPTO_CBC=y
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=y
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
# CONFIG_CRYPTO_ZLIB is not set
CONFIG_CRYPTO_LZO=y
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_OMAP4_AES=y
CONFIG_CRYPTO_DEV_OMAP4_SHAM=y
# OCF Configuration
CONFIG_OCF_OCF=y
# CONFIG_OCF_RANDOMHARVEST is not set
CONFIG_OCF_CRYPTODEV=y
CONFIG_OCF_CRYPTOSOFT=y
# CONFIG_OCF_OCFNULL is not set
# CONFIG_OCF_BENCH is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=y
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
CONFIG_CRC7=y
CONFIG_LIBCRC32C=y
# CONFIG_CRC8 is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_NLATTR=y
CONFIG_AVERAGE=y
# CONFIG_CORDIC is not set
## Automatically generated file; DO NOT EDIT.# Linux/arm 3.2.0 Kernel Configuration#CONFIG_ARM=yCONFIG_HAVE_PWM=yCONFIG_SYS_SUPPORTS_APM_EMULATION=yCONFIG_HAVE_SCHED_CLOCK=yCONFIG_GENERIC_GPIO=y# CONFIG_ARCH_USES_GETTIMEOFFSET is not setCONFIG_GENERIC_CLOCKEVENTS=yCONFIG_KTIME_SCALAR=yCONFIG_HAVE_PROC_CPU=yCONFIG_STACKTRACE_SUPPORT=yCONFIG_HAVE_LATENCYTOP_SUPPORT=yCONFIG_LOCKDEP_SUPPORT=yCONFIG_TRACE_IRQFLAGS_SUPPORT=yCONFIG_HARDIRQS_SW_RESEND=yCONFIG_GENERIC_IRQ_PROBE=yCONFIG_RWSEM_GENERIC_SPINLOCK=yCONFIG_ARCH_HAS_CPUFREQ=yCONFIG_ARCH_HAS_CPU_IDLE_WAIT=yCONFIG_GENERIC_HWEIGHT=yCONFIG_GENERIC_CALIBRATE_DELAY=yCONFIG_NEED_DMA_MAP_STATE=yCONFIG_VECTORS_BASE=0xffff0000CONFIG_ARM_PATCH_PHYS_VIRT=yCONFIG_GENERIC_BUG=yCONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"CONFIG_HAVE_IRQ_WORK=y
## General setup#CONFIG_EXPERIMENTAL=yCONFIG_BROKEN_ON_SMP=yCONFIG_INIT_ENV_ARG_LIMIT=32CONFIG_CROSS_COMPILE=""CONFIG_LOCALVERSION=""CONFIG_LOCALVERSION_AUTO=yCONFIG_HAVE_KERNEL_GZIP=yCONFIG_HAVE_KERNEL_LZMA=yCONFIG_HAVE_KERNEL_LZO=yCONFIG_KERNEL_GZIP=y# CONFIG_KERNEL_LZMA is not set# CONFIG_KERNEL_LZO is not setCONFIG_DEFAULT_HOSTNAME="(none)"CONFIG_SWAP=yCONFIG_SYSVIPC=yCONFIG_SYSVIPC_SYSCTL=yCONFIG_POSIX_MQUEUE=yCONFIG_POSIX_MQUEUE_SYSCTL=yCONFIG_BSD_PROCESS_ACCT=y# CONFIG_BSD_PROCESS_ACCT_V3 is not set# CONFIG_FHANDLE is not set# CONFIG_TASKSTATS is not set# CONFIG_AUDIT is not setCONFIG_HAVE_GENERIC_HARDIRQS=y
## IRQ subsystem#CONFIG_GENERIC_HARDIRQS=yCONFIG_HAVE_SPARSE_IRQ=yCONFIG_GENERIC_IRQ_SHOW=yCONFIG_GENERIC_IRQ_CHIP=yCONFIG_IRQ_DOMAIN=y# CONFIG_SPARSE_IRQ is not set
## RCU Subsystem#CONFIG_TINY_RCU=y# CONFIG_PREEMPT_RCU is not set# CONFIG_RCU_TRACE is not set# CONFIG_TREE_RCU_TRACE is not setCONFIG_IKCONFIG=yCONFIG_IKCONFIG_PROC=yCONFIG_LOG_BUF_SHIFT=16# CONFIG_CGROUPS is not setCONFIG_NAMESPACES=yCONFIG_UTS_NS=yCONFIG_IPC_NS=yCONFIG_USER_NS=yCONFIG_PID_NS=yCONFIG_NET_NS=y# CONFIG_SCHED_AUTOGROUP is not set# CONFIG_SYSFS_DEPRECATED is not set# CONFIG_RELAY is not setCONFIG_BLK_DEV_INITRD=yCONFIG_INITRAMFS_SOURCE=""CONFIG_RD_GZIP=yCONFIG_RD_BZIP2=yCONFIG_RD_LZMA=yCONFIG_RD_XZ=yCONFIG_RD_LZO=y# CONFIG_CC_OPTIMIZE_FOR_SIZE is not setCONFIG_SYSCTL=yCONFIG_ANON_INODES=y# CONFIG_EXPERT is not setCONFIG_UID16=y# CONFIG_SYSCTL_SYSCALL is not setCONFIG_KALLSYMS=yCONFIG_HOTPLUG=yCONFIG_PRINTK=yCONFIG_BUG=yCONFIG_ELF_CORE=yCONFIG_BASE_FULL=yCONFIG_FUTEX=yCONFIG_EPOLL=yCONFIG_SIGNALFD=yCONFIG_TIMERFD=yCONFIG_EVENTFD=yCONFIG_SHMEM=yCONFIG_AIO=y# CONFIG_EMBEDDED is not setCONFIG_HAVE_PERF_EVENTS=yCONFIG_PERF_USE_VMALLOC=y
## Kernel Performance Events And Counters## CONFIG_PERF_EVENTS is not set# CONFIG_PERF_COUNTERS is not setCONFIG_VM_EVENT_COUNTERS=yCONFIG_COMPAT_BRK=yCONFIG_SLAB=y# CONFIG_SLUB is not setCONFIG_PROFILING=yCONFIG_OPROFILE=yCONFIG_HAVE_OPROFILE=y# CONFIG_KPROBES is not setCONFIG_HAVE_KPROBES=yCONFIG_HAVE_KRETPROBES=yCONFIG_HAVE_REGS_AND_STACK_ACCESS_API=yCONFIG_HAVE_CLK=yCONFIG_HAVE_DMA_API_DEBUG=y
## GCOV-based kernel profiling## CONFIG_GCOV_KERNEL is not setCONFIG_HAVE_GENERIC_DMA_COHERENT=yCONFIG_SLABINFO=yCONFIG_RT_MUTEXES=yCONFIG_BASE_SMALL=0CONFIG_MODULES=yCONFIG_MODULE_FORCE_LOAD=yCONFIG_MODULE_UNLOAD=yCONFIG_MODULE_FORCE_UNLOAD=yCONFIG_MODVERSIONS=yCONFIG_MODULE_SRCVERSION_ALL=yCONFIG_BLOCK=yCONFIG_LBDAF=y# CONFIG_BLK_DEV_BSG is not set# CONFIG_BLK_DEV_BSGLIB is not set# CONFIG_BLK_DEV_INTEGRITY is not set
## IO Schedulers#CONFIG_IOSCHED_NOOP=yCONFIG_IOSCHED_DEADLINE=yCONFIG_IOSCHED_CFQ=y# CONFIG_DEFAULT_DEADLINE is not setCONFIG_DEFAULT_CFQ=y# CONFIG_DEFAULT_NOOP is not setCONFIG_DEFAULT_IOSCHED="cfq"# CONFIG_INLINE_SPIN_TRYLOCK is not set# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set# CONFIG_INLINE_SPIN_LOCK is not set# CONFIG_INLINE_SPIN_LOCK_BH is not set# CONFIG_INLINE_SPIN_LOCK_IRQ is not set# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not setCONFIG_INLINE_SPIN_UNLOCK=y# CONFIG_INLINE_SPIN_UNLOCK_BH is not setCONFIG_INLINE_SPIN_UNLOCK_IRQ=y# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set# CONFIG_INLINE_READ_TRYLOCK is not set# CONFIG_INLINE_READ_LOCK is not set# CONFIG_INLINE_READ_LOCK_BH is not set# CONFIG_INLINE_READ_LOCK_IRQ is not set# CONFIG_INLINE_READ_LOCK_IRQSAVE is not setCONFIG_INLINE_READ_UNLOCK=y# CONFIG_INLINE_READ_UNLOCK_BH is not setCONFIG_INLINE_READ_UNLOCK_IRQ=y# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set# CONFIG_INLINE_WRITE_TRYLOCK is not set# CONFIG_INLINE_WRITE_LOCK is not set# CONFIG_INLINE_WRITE_LOCK_BH is not set# CONFIG_INLINE_WRITE_LOCK_IRQ is not set# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not setCONFIG_INLINE_WRITE_UNLOCK=y# CONFIG_INLINE_WRITE_UNLOCK_BH is not setCONFIG_INLINE_WRITE_UNLOCK_IRQ=y# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set# CONFIG_MUTEX_SPIN_ON_OWNER is not setCONFIG_FREEZER=y
## System Type#CONFIG_MMU=y# CONFIG_ARCH_INTEGRATOR is not set# CONFIG_ARCH_REALVIEW is not set# CONFIG_ARCH_VERSATILE is not set# CONFIG_ARCH_VEXPRESS is not set# CONFIG_ARCH_AT91 is not set# CONFIG_ARCH_BCMRING is not set# CONFIG_ARCH_HIGHBANK is not set# CONFIG_ARCH_CLPS711X is not set# CONFIG_ARCH_CNS3XXX is not set# CONFIG_ARCH_GEMINI is not set# CONFIG_ARCH_PRIMA2 is not set# CONFIG_ARCH_EBSA110 is not set# CONFIG_ARCH_EP93XX is not set# CONFIG_ARCH_FOOTBRIDGE is not set# CONFIG_ARCH_MXC is not set# CONFIG_ARCH_MXS is not set# CONFIG_ARCH_NETX is not set# CONFIG_ARCH_H720X is not set# CONFIG_ARCH_IOP13XX is not set# CONFIG_ARCH_IOP32X is not set# CONFIG_ARCH_IOP33X is not set# CONFIG_ARCH_IXP23XX is not set# CONFIG_ARCH_IXP2000 is not set# CONFIG_ARCH_IXP4XX is not set# CONFIG_ARCH_DOVE is not set# CONFIG_ARCH_KIRKWOOD is not set# CONFIG_ARCH_LPC32XX is not set# CONFIG_ARCH_MV78XX0 is not set# CONFIG_ARCH_ORION5X is not set# CONFIG_ARCH_MMP is not set# CONFIG_ARCH_KS8695 is not set# CONFIG_ARCH_W90X900 is not set# CONFIG_ARCH_TEGRA is not set# CONFIG_ARCH_PICOXCELL is not set# CONFIG_ARCH_PNX4008 is not set# CONFIG_ARCH_PXA is not set# CONFIG_ARCH_MSM is not set# CONFIG_ARCH_SHMOBILE is not set# CONFIG_ARCH_RPC is not set# CONFIG_ARCH_SA1100 is not set# CONFIG_ARCH_S3C2410 is not set# CONFIG_ARCH_S3C64XX is not set# CONFIG_ARCH_S5P64X0 is not set# CONFIG_ARCH_S5PC100 is not set# CONFIG_ARCH_S5PV210 is not set# CONFIG_ARCH_EXYNOS is not set# CONFIG_ARCH_SHARK is not set# CONFIG_ARCH_TCC_926 is not set# CONFIG_ARCH_U300 is not set# CONFIG_ARCH_U8500 is not set# CONFIG_ARCH_NOMADIK is not set# CONFIG_ARCH_DAVINCI is not setCONFIG_ARCH_OMAP=y# CONFIG_PLAT_SPEAR is not set# CONFIG_ARCH_VT8500 is not set# CONFIG_ARCH_ZYNQ is not set# CONFIG_GPIO_PCA953X is not set# CONFIG_KEYBOARD_GPIO_POLLED is not set
## TI OMAP Common Features## CONFIG_ARCH_OMAP1 is not setCONFIG_ARCH_OMAP2PLUS=y
## OMAP Feature Selections#CONFIG_AM33XX_SMARTREFLEX=y# CONFIG_OMAP_SMARTREFLEX is not setCONFIG_OMAP_RESET_CLOCKS=yCONFIG_OMAP_MUX=yCONFIG_OMAP_MUX_DEBUG=yCONFIG_OMAP_MUX_WARNINGS=y# CONFIG_OMAP_MCBSP is not setCONFIG_OMAP_MBOX_FWK=yCONFIG_OMAP_MBOX_KFIFO_SIZE=256# CONFIG_OMAP_32K_TIMER is not set# CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not setCONFIG_OMAP_DM_TIMER=yCONFIG_OMAP_PM_NOOP=yCONFIG_MACH_OMAP_GENERIC=y
## TI OMAP2/3/4 Specific Features#CONFIG_ARCH_OMAP2PLUS_TYPICAL=y# CONFIG_ARCH_OMAP2 is not setCONFIG_ARCH_OMAP3=y# CONFIG_ARCH_OMAP4 is not set# CONFIG_SOC_OMAP3430 is not setCONFIG_SOC_OMAPTI81XX=yCONFIG_SOC_OMAPAM33XX=yCONFIG_OMAP_PACKAGE_CBB=y
## OMAP Board Type#CONFIG_MACH_OMAP3_BEAGLE=y# CONFIG_MACH_DEVKIT8000 is not set# CONFIG_MACH_OMAP_LDP is not set# CONFIG_MACH_OMAP3530_LV_SOM is not set# CONFIG_MACH_OMAP3_TORPEDO is not set# CONFIG_MACH_ENCORE is not set# CONFIG_MACH_OVERO is not set# CONFIG_MACH_OMAP3EVM is not set# CONFIG_MACH_OMAP3517EVM is not set# CONFIG_MACH_CRANEBOARD is not set# CONFIG_MACH_OMAP3_PANDORA is not set# CONFIG_MACH_OMAP3_TOUCHBOOK is not set# CONFIG_MACH_OMAP_3430SDP is not set# CONFIG_MACH_NOKIA_RM680 is not set# CONFIG_MACH_NOKIA_RX51 is not set# CONFIG_MACH_OMAP_ZOOM2 is not set# CONFIG_MACH_OMAP_ZOOM3 is not set# CONFIG_MACH_CM_T35 is not set# CONFIG_MACH_CM_T3517 is not set# CONFIG_MACH_IGEP0020 is not set# CONFIG_MACH_IGEP0030 is not set# CONFIG_MACH_SBC3530 is not set# CONFIG_MACH_OMAP_3630SDP is not setCONFIG_MACH_TI8168EVM=yCONFIG_MACH_TI8148EVM=yCONFIG_MACH_AM335XEVM=yCONFIG_MACH_AM335XIAEVM=y# CONFIG_OMAP3_EMU is not setCONFIG_TI_PM_DISABLE_VT_SWITCH=y# CONFIG_OMAP3_SDRC_AC_TIMING is not setCONFIG_OMAP3_EDMA=y
## System MMU#
## Processor Type#CONFIG_CPU_V7=yCONFIG_CPU_32v6K=yCONFIG_CPU_32v7=yCONFIG_CPU_ABRT_EV7=yCONFIG_CPU_PABRT_V7=yCONFIG_CPU_CACHE_V7=yCONFIG_CPU_CACHE_VIPT=yCONFIG_CPU_COPY_V6=yCONFIG_CPU_TLB_V7=yCONFIG_CPU_HAS_ASID=yCONFIG_CPU_CP15=yCONFIG_CPU_CP15_MMU=y
## Processor Features#CONFIG_ARM_THUMB=yCONFIG_ARM_THUMBEE=y# CONFIG_SWP_EMULATE is not set# CONFIG_CPU_ICACHE_DISABLE is not set# CONFIG_CPU_DCACHE_DISABLE is not set# CONFIG_CPU_BPREDICT_DISABLE is not setCONFIG_ARM_L1_CACHE_SHIFT_6=yCONFIG_ARM_L1_CACHE_SHIFT=6CONFIG_ARM_DMA_MEM_BUFFERABLE=yCONFIG_MULTI_IRQ_HANDLER=y# CONFIG_ARM_ERRATA_430973 is not set# CONFIG_ARM_ERRATA_458693 is not set# CONFIG_ARM_ERRATA_460075 is not set# CONFIG_ARM_ERRATA_720789 is not set# CONFIG_ARM_ERRATA_743622 is not set# CONFIG_ARM_ERRATA_751472 is not set# CONFIG_ARM_ERRATA_754322 is not set
## Bus support## CONFIG_PCI_SYSCALL is not set# CONFIG_ARCH_SUPPORTS_MSI is not set# CONFIG_PCCARD is not set
## Kernel Features#CONFIG_TICK_ONESHOT=yCONFIG_NO_HZ=yCONFIG_HIGH_RES_TIMERS=yCONFIG_GENERIC_CLOCKEVENTS_BUILD=yCONFIG_VMSPLIT_3G=y# CONFIG_VMSPLIT_2G is not set# CONFIG_VMSPLIT_1G is not setCONFIG_PAGE_OFFSET=0xC0000000CONFIG_PREEMPT_NONE=y# CONFIG_PREEMPT_VOLUNTARY is not set# CONFIG_PREEMPT is not setCONFIG_HZ=100# CONFIG_THUMB2_KERNEL is not setCONFIG_AEABI=yCONFIG_OABI_COMPAT=yCONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set# CONFIG_ARCH_SELECT_MEMORY_MODEL is not setCONFIG_HAVE_ARCH_PFN_VALID=y# CONFIG_HIGHMEM is not setCONFIG_SELECT_MEMORY_MODEL=yCONFIG_FLATMEM_MANUAL=yCONFIG_FLATMEM=yCONFIG_FLAT_NODE_MEM_MAP=yCONFIG_HAVE_MEMBLOCK=yCONFIG_PAGEFLAGS_EXTENDED=yCONFIG_SPLIT_PTLOCK_CPUS=4# CONFIG_COMPACTION is not set# CONFIG_PHYS_ADDR_T_64BIT is not setCONFIG_ZONE_DMA_FLAG=0CONFIG_VIRT_TO_BUS=y# CONFIG_KSM is not setCONFIG_DEFAULT_MMAP_MIN_ADDR=4096CONFIG_NEED_PER_CPU_KM=y# CONFIG_CLEANCACHE is not setCONFIG_FORCE_MAX_ZONEORDER=12# CONFIG_LEDS is not setCONFIG_ALIGNMENT_TRAP=y# CONFIG_UACCESS_WITH_MEMCPY is not set# CONFIG_SECCOMP is not set# CONFIG_CC_STACKPROTECTOR is not set# CONFIG_DEPRECATED_PARAM_STRUCT is not set
## Boot options#CONFIG_USE_OF=yCONFIG_ZBOOT_ROM_TEXT=0x0CONFIG_ZBOOT_ROM_BSS=0x0# CONFIG_ARM_APPENDED_DTB is not setCONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO0,115200"CONFIG_CMDLINE_FROM_BOOTLOADER=y# CONFIG_CMDLINE_EXTEND is not set# CONFIG_CMDLINE_FORCE is not set# CONFIG_XIP_KERNEL is not set# CONFIG_KEXEC is not set# CONFIG_CRASH_DUMP is not set# CONFIG_AUTO_ZRELADDR is not set
## CPU Power Management#
## CPU Frequency scaling#CONFIG_CPU_FREQ=yCONFIG_CPU_FREQ_TABLE=yCONFIG_CPU_FREQ_STAT=yCONFIG_CPU_FREQ_STAT_DETAILS=y# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not setCONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not setCONFIG_CPU_FREQ_GOV_PERFORMANCE=yCONFIG_CPU_FREQ_GOV_POWERSAVE=yCONFIG_CPU_FREQ_GOV_USERSPACE=yCONFIG_CPU_FREQ_GOV_ONDEMAND=yCONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
## ARM CPU frequency scaling drivers#CONFIG_CPU_IDLE=yCONFIG_CPU_IDLE_GOV_LADDER=yCONFIG_CPU_IDLE_GOV_MENU=y
## Floating point emulation#
## At least one emulation must be selected#CONFIG_FPE_NWFPE=y# CONFIG_FPE_NWFPE_XP is not set# CONFIG_FPE_FASTFPE is not setCONFIG_VFP=yCONFIG_VFPv3=yCONFIG_NEON=y
## Userspace binary formats#CONFIG_BINFMT_ELF=yCONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=yCONFIG_HAVE_AOUT=y# CONFIG_BINFMT_AOUT is not setCONFIG_BINFMT_MISC=y
## Power management options#CONFIG_SUSPEND=yCONFIG_SUSPEND_FREEZER=yCONFIG_PM_SLEEP=yCONFIG_PM_RUNTIME=yCONFIG_PM=yCONFIG_PM_DEBUG=yCONFIG_PM_ADVANCED_DEBUG=y# CONFIG_PM_TEST_SUSPEND is not setCONFIG_CAN_PM_TRACE=y# CONFIG_APM_EMULATION is not setCONFIG_ARCH_HAS_OPP=yCONFIG_PM_OPP=yCONFIG_PM_CLK=yCONFIG_CPU_PM=yCONFIG_ARCH_SUSPEND_POSSIBLE=yCONFIG_ARM_CPU_SUSPEND=yCONFIG_NET=y
## Networking options#CONFIG_PACKET=yCONFIG_UNIX=y# CONFIG_NET_KEY is not setCONFIG_INET=yCONFIG_IP_MULTICAST=y# CONFIG_IP_ADVANCED_ROUTER is not setCONFIG_IP_PNP=yCONFIG_IP_PNP_DHCP=yCONFIG_IP_PNP_BOOTP=yCONFIG_IP_PNP_RARP=y# CONFIG_NET_IPIP is not set# CONFIG_NET_IPGRE_DEMUX is not set# CONFIG_IP_MROUTE is not set# CONFIG_ARPD is not set# CONFIG_SYN_COOKIES is not set# CONFIG_INET_AH is not set# CONFIG_INET_ESP is not set# CONFIG_INET_IPCOMP is not set# CONFIG_INET_XFRM_TUNNEL is not set# CONFIG_INET_TUNNEL is not set# CONFIG_INET_XFRM_MODE_TRANSPORT is not set# CONFIG_INET_XFRM_MODE_TUNNEL is not set# CONFIG_INET_XFRM_MODE_BEET is not set# CONFIG_INET_LRO is not set# CONFIG_INET_DIAG is not set# CONFIG_TCP_CONG_ADVANCED is not setCONFIG_TCP_CONG_CUBIC=yCONFIG_DEFAULT_TCP_CONG="cubic"# CONFIG_TCP_MD5SIG is not set# CONFIG_IPV6 is not set# CONFIG_NETLABEL is not set# CONFIG_NETWORK_SECMARK is not set# CONFIG_NETWORK_PHY_TIMESTAMPING is not setCONFIG_NETFILTER=y# CONFIG_NETFILTER_DEBUG is not setCONFIG_NETFILTER_ADVANCED=y
## Core Netfilter Configuration## CONFIG_NETFILTER_NETLINK_QUEUE is not set# CONFIG_NETFILTER_NETLINK_LOG is not setCONFIG_NF_CONNTRACK=y# CONFIG_NF_CONNTRACK_MARK is not set# CONFIG_NF_CONNTRACK_EVENTS is not set# CONFIG_NF_CONNTRACK_TIMESTAMP is not set# CONFIG_NF_CT_PROTO_DCCP is not set# CONFIG_NF_CT_PROTO_SCTP is not set# CONFIG_NF_CT_PROTO_UDPLITE is not set# CONFIG_NF_CONNTRACK_AMANDA is not set# CONFIG_NF_CONNTRACK_FTP is not set# CONFIG_NF_CONNTRACK_H323 is not set# CONFIG_NF_CONNTRACK_IRC is not set# CONFIG_NF_CONNTRACK_NETBIOS_NS is not set# CONFIG_NF_CONNTRACK_SNMP is not set# CONFIG_NF_CONNTRACK_PPTP is not set# CONFIG_NF_CONNTRACK_SANE is not set# CONFIG_NF_CONNTRACK_SIP is not set# CONFIG_NF_CONNTRACK_TFTP is not set# CONFIG_NF_CT_NETLINK is not setCONFIG_NETFILTER_XTABLES=y
## Xtables combined modules## CONFIG_NETFILTER_XT_MARK is not set# CONFIG_NETFILTER_XT_CONNMARK is not set
## Xtables targets## CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set# CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set# CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set# CONFIG_NETFILTER_XT_TARGET_LED is not set# CONFIG_NETFILTER_XT_TARGET_MARK is not set# CONFIG_NETFILTER_XT_TARGET_NFLOG is not set# CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set# CONFIG_NETFILTER_XT_TARGET_RATEEST is not set# CONFIG_NETFILTER_XT_TARGET_TEE is not set# CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
## Xtables matches## CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set# CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set# CONFIG_NETFILTER_XT_MATCH_COMMENT is not set# CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set# CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set# CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set# CONFIG_NETFILTER_XT_MATCH_CPU is not set# CONFIG_NETFILTER_XT_MATCH_DCCP is not set# CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set# CONFIG_NETFILTER_XT_MATCH_DSCP is not set# CONFIG_NETFILTER_XT_MATCH_ESP is not set# CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set# CONFIG_NETFILTER_XT_MATCH_HELPER is not set# CONFIG_NETFILTER_XT_MATCH_HL is not set# CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set# CONFIG_NETFILTER_XT_MATCH_LENGTH is not set# CONFIG_NETFILTER_XT_MATCH_LIMIT is not set# CONFIG_NETFILTER_XT_MATCH_MAC is not set# CONFIG_NETFILTER_XT_MATCH_MARK is not set# CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set# CONFIG_NETFILTER_XT_MATCH_OWNER is not set# CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set# CONFIG_NETFILTER_XT_MATCH_QUOTA is not set# CONFIG_NETFILTER_XT_MATCH_RATEEST is not set# CONFIG_NETFILTER_XT_MATCH_REALM is not set# CONFIG_NETFILTER_XT_MATCH_RECENT is not set# CONFIG_NETFILTER_XT_MATCH_SCTP is not set# CONFIG_NETFILTER_XT_MATCH_STATE is not set# CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set# CONFIG_NETFILTER_XT_MATCH_STRING is not set# CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set# CONFIG_NETFILTER_XT_MATCH_TIME is not set# CONFIG_NETFILTER_XT_MATCH_U32 is not set# CONFIG_IP_VS is not set
## IP: Netfilter Configuration#CONFIG_NF_DEFRAG_IPV4=yCONFIG_NF_CONNTRACK_IPV4=yCONFIG_NF_CONNTRACK_PROC_COMPAT=y# CONFIG_IP_NF_QUEUE is not setCONFIG_IP_NF_IPTABLES=y# CONFIG_IP_NF_MATCH_AH is not set# CONFIG_IP_NF_MATCH_ECN is not set# CONFIG_IP_NF_MATCH_TTL is not setCONFIG_IP_NF_FILTER=y# CONFIG_IP_NF_TARGET_REJECT is not setCONFIG_IP_NF_TARGET_LOG=y# CONFIG_IP_NF_TARGET_ULOG is not setCONFIG_NF_NAT=yCONFIG_NF_NAT_NEEDED=yCONFIG_IP_NF_TARGET_MASQUERADE=y# CONFIG_IP_NF_TARGET_NETMAP is not set# CONFIG_IP_NF_TARGET_REDIRECT is not set# CONFIG_NF_NAT_FTP is not set# CONFIG_NF_NAT_IRC is not set# CONFIG_NF_NAT_TFTP is not set# CONFIG_NF_NAT_AMANDA is not set# CONFIG_NF_NAT_PPTP is not set# CONFIG_NF_NAT_H323 is not set# CONFIG_NF_NAT_SIP is not set# CONFIG_IP_NF_MANGLE is not set# CONFIG_IP_NF_RAW is not set# CONFIG_IP_NF_SECURITY is not set# CONFIG_IP_NF_ARPTABLES is not set# CONFIG_IP_DCCP is not set# CONFIG_IP_SCTP is not set# CONFIG_RDS is not set# CONFIG_TIPC is not set# CONFIG_ATM is not set# CONFIG_L2TP is not set# CONFIG_BRIDGE is not set# CONFIG_NET_DSA is not set# CONFIG_VLAN_8021Q is not set# CONFIG_DECNET is not set# CONFIG_LLC2 is not set# CONFIG_IPX is not set# CONFIG_ATALK is not set# CONFIG_X25 is not set# CONFIG_LAPB is not set# CONFIG_ECONET is not set# CONFIG_WAN_ROUTER is not set# CONFIG_PHONET is not set# CONFIG_IEEE802154 is not set# CONFIG_NET_SCHED is not set# CONFIG_DCB is not setCONFIG_DNS_RESOLVER=y# CONFIG_BATMAN_ADV is not set
## Network testing## CONFIG_NET_PKTGEN is not set# CONFIG_HAMRADIO is not set# CONFIG_CAN is not set# CONFIG_IRDA is not setCONFIG_BT=yCONFIG_BT_L2CAP=yCONFIG_BT_SCO=yCONFIG_BT_RFCOMM=yCONFIG_BT_RFCOMM_TTY=yCONFIG_BT_BNEP=yCONFIG_BT_BNEP_MC_FILTER=yCONFIG_BT_BNEP_PROTO_FILTER=yCONFIG_BT_HIDP=y
## Bluetooth device drivers#CONFIG_BT_HCIBTUSB=yCONFIG_BT_HCIBTSDIO=yCONFIG_BT_HCIUART=yCONFIG_BT_HCIUART_H4=yCONFIG_BT_HCIUART_BCSP=yCONFIG_BT_HCIUART_ATH3K=yCONFIG_BT_HCIUART_LL=yCONFIG_BT_HCIBCM203X=yCONFIG_BT_HCIBPA10X=yCONFIG_BT_HCIBFUSB=yCONFIG_BT_HCIVHCI=yCONFIG_BT_MRVL=yCONFIG_BT_MRVL_SDIO=yCONFIG_BT_ATH3K=y# CONFIG_AF_RXRPC is not setCONFIG_WIRELESS=yCONFIG_WIRELESS_EXT=yCONFIG_WEXT_CORE=yCONFIG_WEXT_PROC=yCONFIG_CFG80211=y# CONFIG_NL80211_TESTMODE is not set# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set# CONFIG_CFG80211_REG_DEBUG is not setCONFIG_CFG80211_DEFAULT_PS=y# CONFIG_CFG80211_DEBUGFS is not set# CONFIG_CFG80211_INTERNAL_REGDB is not setCONFIG_CFG80211_WEXT=y# CONFIG_WIRELESS_EXT_SYSFS is not setCONFIG_LIB80211=y# CONFIG_LIB80211_DEBUG is not setCONFIG_MAC80211=yCONFIG_MAC80211_HAS_RC=yCONFIG_MAC80211_RC_MINSTREL=yCONFIG_MAC80211_RC_MINSTREL_HT=yCONFIG_MAC80211_RC_DEFAULT_MINSTREL=yCONFIG_MAC80211_RC_DEFAULT="minstrel_ht"# CONFIG_MAC80211_MESH is not set# CONFIG_MAC80211_LEDS is not set# CONFIG_MAC80211_DEBUGFS is not set# CONFIG_MAC80211_DEBUG_MENU is not set# CONFIG_WIMAX is not set# CONFIG_RFKILL is not set# CONFIG_RFKILL_REGULATOR is not set# CONFIG_NET_9P is not set# CONFIG_CAIF is not set# CONFIG_CEPH_LIB is not set# CONFIG_NFC is not set
## Device Drivers#
## Generic Driver Options#CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"CONFIG_DEVTMPFS=yCONFIG_DEVTMPFS_MOUNT=yCONFIG_STANDALONE=yCONFIG_PREVENT_FIRMWARE_BUILD=yCONFIG_FW_LOADER=yCONFIG_FIRMWARE_IN_KERNEL=yCONFIG_EXTRA_FIRMWARE="am335x-pm-firmware.bin"CONFIG_EXTRA_FIRMWARE_DIR="firmware"# CONFIG_SYS_HYPERVISOR is not setCONFIG_REGMAP=yCONFIG_REGMAP_I2C=y
## CBUS support## CONFIG_CBUS is not setCONFIG_CONNECTOR=yCONFIG_PROC_EVENTS=yCONFIG_MTD=y# CONFIG_MTD_TESTS is not set# CONFIG_MTD_REDBOOT_PARTS is not setCONFIG_MTD_CMDLINE_PARTS=y# CONFIG_MTD_AFS_PARTS is not set# CONFIG_MTD_OF_PARTS is not set# CONFIG_MTD_AR7_PARTS is not set
## User Modules And Translation Layers#CONFIG_MTD_CHAR=yCONFIG_MTD_BLKDEVS=yCONFIG_MTD_BLOCK=y# CONFIG_FTL is not set# CONFIG_NFTL is not set# CONFIG_INFTL is not set# CONFIG_RFD_FTL is not set# CONFIG_SSFDC is not set# CONFIG_SM_FTL is not setCONFIG_MTD_OOPS=y# CONFIG_MTD_SWAP is not set
## RAM/ROM/Flash chip drivers#CONFIG_MTD_CFI=y# CONFIG_MTD_JEDECPROBE is not setCONFIG_MTD_GEN_PROBE=y# CONFIG_MTD_CFI_ADV_OPTIONS is not setCONFIG_MTD_MAP_BANK_WIDTH_1=yCONFIG_MTD_MAP_BANK_WIDTH_2=yCONFIG_MTD_MAP_BANK_WIDTH_4=y# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set# CONFIG_MTD_MAP_BANK_WIDTH_32 is not setCONFIG_MTD_CFI_I1=yCONFIG_MTD_CFI_I2=y# CONFIG_MTD_CFI_I4 is not set# CONFIG_MTD_CFI_I8 is not set# CONFIG_MTD_CFI_INTELEXT is not set# CONFIG_MTD_CFI_AMDSTD is not set# CONFIG_MTD_CFI_STAA is not setCONFIG_MTD_CFI_UTIL=y# CONFIG_MTD_RAM is not set# CONFIG_MTD_ROM is not set# CONFIG_MTD_ABSENT is not set
## Mapping drivers for chip access## CONFIG_MTD_COMPLEX_MAPPINGS is not set# CONFIG_MTD_PHYSMAP is not set# CONFIG_MTD_PHYSMAP_OF is not set# CONFIG_MTD_PLATRAM is not set
## Self-contained MTD device drivers## CONFIG_MTD_DATAFLASH is not set# CONFIG_MTD_M25P80 is not set# CONFIG_MTD_SST25L is not set# CONFIG_MTD_SLRAM is not set# CONFIG_MTD_PHRAM is not set# CONFIG_MTD_MTDRAM is not set# CONFIG_MTD_BLOCK2MTD is not set
## Disk-On-Chip Device Drivers## CONFIG_MTD_DOC2000 is not set# CONFIG_MTD_DOC2001 is not set# CONFIG_MTD_DOC2001PLUS is not set# CONFIG_MTD_DOCG3 is not setCONFIG_MTD_NAND_ECC=y# CONFIG_MTD_NAND_ECC_SMC is not setCONFIG_MTD_NAND=y# CONFIG_MTD_NAND_VERIFY_WRITE is not set# CONFIG_MTD_NAND_ECC_BCH is not set# CONFIG_MTD_SM_COMMON is not set# CONFIG_MTD_NAND_MUSEUM_IDS is not set# CONFIG_MTD_NAND_GPIO is not setCONFIG_MTD_NAND_OMAP2=yCONFIG_MTD_NAND_IDS=y# CONFIG_MTD_NAND_DISKONCHIP is not set# CONFIG_MTD_NAND_NANDSIM is not set# CONFIG_MTD_NAND_PLATFORM is not set# CONFIG_MTD_ALAUDA is not setCONFIG_MTD_ONENAND=y# CONFIG_MTD_ONENAND_VERIFY_WRITE is not set# CONFIG_MTD_ONENAND_GENERIC is not setCONFIG_MTD_ONENAND_OMAP2=y# CONFIG_MTD_ONENAND_OTP is not set# CONFIG_MTD_ONENAND_2X_PROGRAM is not set# CONFIG_MTD_ONENAND_SIM is not set
## LPDDR flash memory drivers## CONFIG_MTD_LPDDR is not setCONFIG_MTD_UBI=yCONFIG_MTD_UBI_WL_THRESHOLD=4096CONFIG_MTD_UBI_BEB_RESERVE=1# CONFIG_MTD_UBI_GLUEBI is not set# CONFIG_MTD_UBI_DEBUG is not setCONFIG_DTC=yCONFIG_OF=y
## Device Tree and Open Firmware support#CONFIG_PROC_DEVICETREE=yCONFIG_OF_FLATTREE=yCONFIG_OF_EARLY_FLATTREE=yCONFIG_OF_ADDRESS=yCONFIG_OF_IRQ=yCONFIG_OF_DEVICE=yCONFIG_OF_GPIO=yCONFIG_OF_I2C=yCONFIG_OF_NET=yCONFIG_OF_SPI=yCONFIG_OF_MDIO=y# CONFIG_PARPORT is not setCONFIG_BLK_DEV=y# CONFIG_BLK_DEV_COW_COMMON is not setCONFIG_BLK_DEV_LOOP=yCONFIG_BLK_DEV_LOOP_MIN_COUNT=8# CONFIG_BLK_DEV_CRYPTOLOOP is not set# CONFIG_BLK_DEV_DRBD is not set# CONFIG_BLK_DEV_NBD is not set# CONFIG_BLK_DEV_UB is not setCONFIG_BLK_DEV_RAM=yCONFIG_BLK_DEV_RAM_COUNT=16CONFIG_BLK_DEV_RAM_SIZE=32768# CONFIG_BLK_DEV_XIP is not set# CONFIG_CDROM_PKTCDVD is not set# CONFIG_ATA_OVER_ETH is not set# CONFIG_MG_DISK is not set# CONFIG_BLK_DEV_RBD is not setCONFIG_SENSORS_LIS3LV02D=yCONFIG_MISC_DEVICES=y# CONFIG_AD525X_DPOT is not set# CONFIG_ATMEL_PWM is not set# CONFIG_ICS932S401 is not set# CONFIG_ENCLOSURE_SERVICES is not set# CONFIG_APDS9802ALS is not set# CONFIG_ISL29003 is not set# CONFIG_ISL29020 is not set# CONFIG_SENSORS_TSL2550 is not set# CONFIG_SENSORS_BH1780 is not set# CONFIG_SENSORS_BH1770 is not set# CONFIG_SENSORS_APDS990X is not set# CONFIG_HMC6352 is not set# CONFIG_DS1682 is not set# CONFIG_TI_DAC7512 is not set# CONFIG_BMP085 is not set# CONFIG_USB_SWITCH_FSA9480 is not set# CONFIG_C2PORT is not set
## EEPROM support## CONFIG_EEPROM_AT24 is not set# CONFIG_EEPROM_AT25 is not set# CONFIG_EEPROM_LEGACY is not set# CONFIG_EEPROM_MAX6875 is not set# CONFIG_EEPROM_93CX6 is not set# CONFIG_EEPROM_93XX46 is not set# CONFIG_IWMC3200TOP is not set
## Texas Instruments shared transport line discipline## CONFIG_TI_ST is not set# CONFIG_SENSORS_LIS3_SPI is not setCONFIG_SENSORS_LIS3_I2C=y
## Altera FPGA firmware download module## CONFIG_ALTERA_STAPL is not set
## SCSI device support#CONFIG_SCSI_MOD=y# CONFIG_RAID_ATTRS is not setCONFIG_SCSI=yCONFIG_SCSI_DMA=y# CONFIG_SCSI_TGT is not set# CONFIG_SCSI_NETLINK is not setCONFIG_SCSI_PROC_FS=y
## SCSI support type (disk, tape, CD-ROM)#CONFIG_BLK_DEV_SD=y# CONFIG_CHR_DEV_ST is not set# CONFIG_CHR_DEV_OSST is not set# CONFIG_BLK_DEV_SR is not set# CONFIG_CHR_DEV_SG is not set# CONFIG_CHR_DEV_SCH is not setCONFIG_SCSI_MULTI_LUN=y# CONFIG_SCSI_CONSTANTS is not set# CONFIG_SCSI_LOGGING is not setCONFIG_SCSI_SCAN_ASYNC=yCONFIG_SCSI_WAIT_SCAN=m
## SCSI Transports## CONFIG_SCSI_SPI_ATTRS is not set# CONFIG_SCSI_FC_ATTRS is not set# CONFIG_SCSI_ISCSI_ATTRS is not set# CONFIG_SCSI_SAS_ATTRS is not set# CONFIG_SCSI_SAS_LIBSAS is not set# CONFIG_SCSI_SRP_ATTRS is not setCONFIG_SCSI_LOWLEVEL=y# CONFIG_ISCSI_TCP is not set# CONFIG_ISCSI_BOOT_SYSFS is not set# CONFIG_LIBFC is not set# CONFIG_LIBFCOE is not set# CONFIG_SCSI_DEBUG is not set# CONFIG_SCSI_DH is not set# CONFIG_SCSI_OSD_INITIATOR is not set# CONFIG_ATA is not set# CONFIG_MD is not set# CONFIG_TARGET_CORE is not setCONFIG_NETDEVICES=yCONFIG_NET_CORE=y# CONFIG_BONDING is not set# CONFIG_DUMMY is not set# CONFIG_EQUALIZER is not setCONFIG_MII=y# CONFIG_MACVLAN is not set# CONFIG_NETCONSOLE is not set# CONFIG_NETPOLL is not set# CONFIG_NET_POLL_CONTROLLER is not set# CONFIG_TUN is not set# CONFIG_VETH is not set
## CAIF transport drivers#CONFIG_ETHERNET=yCONFIG_NET_VENDOR_BROADCOM=y# CONFIG_B44 is not setCONFIG_NET_VENDOR_CHELSIO=y# CONFIG_DM9000 is not set# CONFIG_DNET is not setCONFIG_NET_VENDOR_FARADAY=y# CONFIG_FTMAC100 is not set# CONFIG_FTGMAC100 is not setCONFIG_NET_VENDOR_INTEL=yCONFIG_NET_VENDOR_I825XX=yCONFIG_NET_VENDOR_MARVELL=yCONFIG_NET_VENDOR_MICREL=y# CONFIG_KS8851 is not set# CONFIG_KS8851_MLL is not setCONFIG_NET_VENDOR_MICROCHIP=y# CONFIG_ENC28J60 is not setCONFIG_NET_VENDOR_NATSEMI=yCONFIG_NET_VENDOR_8390=y# CONFIG_AX88796 is not set# CONFIG_ETHOC is not setCONFIG_NET_VENDOR_SEEQ=y# CONFIG_SEEQ8005 is not setCONFIG_NET_VENDOR_SMSC=yCONFIG_SMC91X=y# CONFIG_SMC911X is not setCONFIG_SMSC911X=y# CONFIG_SMSC911X_ARCH_HOOKS is not setCONFIG_NET_VENDOR_STMICRO=y# CONFIG_STMMAC_ETH is not setCONFIG_NET_VENDOR_TI=y# CONFIG_TI_DAVINCI_EMAC is not setCONFIG_TI_DAVINCI_MDIO=yCONFIG_TI_DAVINCI_CPDMA=yCONFIG_TI_CPSW=yCONFIG_TI_CPSW_DUAL_EMAC=yCONFIG_PHYLIB=y
## MII PHY device drivers## CONFIG_MARVELL_PHY is not set# CONFIG_DAVICOM_PHY is not set# CONFIG_QSEMI_PHY is not set# CONFIG_LXT_PHY is not set# CONFIG_CICADA_PHY is not set# CONFIG_VITESSE_PHY is not setCONFIG_SMSC_PHY=y# CONFIG_BROADCOM_PHY is not set# CONFIG_ICPLUS_PHY is not set# CONFIG_REALTEK_PHY is not set# CONFIG_NATIONAL_PHY is not set# CONFIG_STE10XP is not set# CONFIG_LSI_ET1011C_PHY is not set# CONFIG_MICREL_PHY is not set# CONFIG_FIXED_PHY is not set# CONFIG_MDIO_BITBANG is not setCONFIG_PPP=yCONFIG_PPP_BSDCOMP=yCONFIG_PPP_DEFLATE=yCONFIG_PPP_FILTER=yCONFIG_PPP_MPPE=yCONFIG_PPP_MULTILINK=yCONFIG_PPPOE=yCONFIG_PPP_ASYNC=yCONFIG_PPP_SYNC_TTY=y# CONFIG_SLIP is not setCONFIG_SLHC=y
## USB Network Adapters## CONFIG_USB_CATC is not set# CONFIG_USB_KAWETH is not set# CONFIG_USB_PEGASUS is not set# CONFIG_USB_RTL8150 is not setCONFIG_USB_USBNET=y# CONFIG_USB_NET_AX8817X is not setCONFIG_USB_NET_CDCETHER=yCONFIG_USB_NET_CDC_EEM=yCONFIG_USB_NET_CDC_NCM=yCONFIG_USB_NET_DM9601=y# CONFIG_USB_NET_SMSC75XX is not set# CONFIG_USB_NET_SMSC95XX is not set# CONFIG_USB_NET_GL620A is not set# CONFIG_USB_NET_NET1080 is not set# CONFIG_USB_NET_PLUSB is not set# CONFIG_USB_NET_MCS7830 is not set# CONFIG_USB_NET_RNDIS_HOST is not set# CONFIG_USB_NET_CDC_SUBSET is not set# CONFIG_USB_NET_ZAURUS is not set# CONFIG_USB_NET_CX82310_ETH is not set# CONFIG_USB_NET_KALMIA is not set# CONFIG_USB_NET_INT51X1 is not set# CONFIG_USB_IPHETH is not set# CONFIG_USB_SIERRA_NET is not set# CONFIG_USB_VL600 is not setCONFIG_WLAN=y# CONFIG_LIBERTAS_THINFIRM is not set# CONFIG_AT76C50X_USB is not set# CONFIG_USB_ZD1201 is not set# CONFIG_USB_NET_RNDIS_WLAN is not set# CONFIG_RTL8187 is not set# CONFIG_MAC80211_HWSIM is not set# CONFIG_ATH_COMMON is not set# CONFIG_B43 is not set# CONFIG_B43LEGACY is not set# CONFIG_BRCMFMAC is not set# CONFIG_HOSTAP is not set# CONFIG_IWM is not set# CONFIG_LIBERTAS is not set# CONFIG_P54_COMMON is not set# CONFIG_RT2X00 is not setCONFIG_RTL8192CU=yCONFIG_RTLWIFI=yCONFIG_RTL8192C_COMMON=y# CONFIG_WL1251 is not set# CONFIG_WL12XX_MENU is not setCONFIG_WL12XX_PLATFORM_DATA=y# CONFIG_ZD1211RW is not set# CONFIG_MWIFIEX is not set
## Enable WiMAX (Networking options) to see the WiMAX drivers## CONFIG_WAN is not set# CONFIG_ISDN is not set# CONFIG_PHONE is not set
## Input device support#CONFIG_INPUT=y# CONFIG_INPUT_FF_MEMLESS is not setCONFIG_INPUT_POLLDEV=y# CONFIG_INPUT_SPARSEKMAP is not set
## Userland interfaces#CONFIG_INPUT_MOUSEDEV=yCONFIG_INPUT_MOUSEDEV_PSAUX=yCONFIG_INPUT_MOUSEDEV_SCREEN_X=1024CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768# CONFIG_INPUT_JOYDEV is not setCONFIG_INPUT_EVDEV=y# CONFIG_INPUT_EVBUG is not set
## Input Device Drivers#CONFIG_INPUT_KEYBOARD=y# CONFIG_KEYBOARD_ADP5588 is not set# CONFIG_KEYBOARD_ADP5589 is not set# CONFIG_KEYBOARD_ATKBD is not set# CONFIG_KEYBOARD_QT1070 is not set# CONFIG_KEYBOARD_QT2160 is not set# CONFIG_KEYBOARD_LKKBD is not setCONFIG_KEYBOARD_GPIO=y# CONFIG_KEYBOARD_TCA6416 is not setCONFIG_KEYBOARD_MATRIX=y# CONFIG_KEYBOARD_LM8323 is not set# CONFIG_KEYBOARD_MAX7359 is not set# CONFIG_KEYBOARD_MCS is not set# CONFIG_KEYBOARD_MPR121 is not set# CONFIG_KEYBOARD_NEWTON is not set# CONFIG_KEYBOARD_OPENCORES is not set# CONFIG_KEYBOARD_STOWAWAY is not set# CONFIG_KEYBOARD_SUNKBD is not set# CONFIG_KEYBOARD_TWL4030 is not set# CONFIG_KEYBOARD_XTKBD is not set# CONFIG_INPUT_MOUSE is not set# CONFIG_INPUT_JOYSTICK is not set# CONFIG_INPUT_TABLET is not set# CONFIG_INPUT_TOUCHSCREEN is not setCONFIG_INPUT_MISC=y# CONFIG_INPUT_AD714X is not set# CONFIG_INPUT_BMA150 is not set# CONFIG_INPUT_MMA8450 is not setCONFIG_INPUT_FXLS8471Q=y# CONFIG_INPUT_MPU3050 is not set# CONFIG_INPUT_ATI_REMOTE2 is not set# CONFIG_INPUT_KEYSPAN_REMOTE is not set# CONFIG_INPUT_KXTJ9 is not set# CONFIG_INPUT_POWERMATE is not set# CONFIG_INPUT_YEALINK is not set# CONFIG_INPUT_CM109 is not set# CONFIG_INPUT_TWL4030_PWRBUTTON is not set# CONFIG_INPUT_TWL4030_VIBRA is not set# CONFIG_INPUT_TWL6040_VIBRA is not set# CONFIG_INPUT_UINPUT is not set# CONFIG_INPUT_PCF8574 is not set# CONFIG_INPUT_PWM_BEEPER is not set# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set# CONFIG_INPUT_ADXL34X is not set# CONFIG_INPUT_CMA3000 is not set
## Hardware I/O ports#CONFIG_SERIO=y# CONFIG_SERIO_SERPORT is not set# CONFIG_SERIO_RAW is not set# CONFIG_SERIO_ALTERA_PS2 is not set# CONFIG_SERIO_PS2MULT is not set# CONFIG_GAMEPORT is not set
## Character devices#CONFIG_VT=yCONFIG_CONSOLE_TRANSLATIONS=yCONFIG_VT_CONSOLE=yCONFIG_VT_CONSOLE_SLEEP=yCONFIG_HW_CONSOLE=yCONFIG_VT_HW_CONSOLE_BINDING=yCONFIG_UNIX98_PTYS=y# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set# CONFIG_LEGACY_PTYS is not set# CONFIG_SERIAL_NONSTANDARD is not set# CONFIG_N_GSM is not set# CONFIG_TRACE_SINK is not setCONFIG_DEVKMEM=y
## Serial drivers## CONFIG_SERIAL_8250 is not set
## Non-8250 serial port support## CONFIG_SERIAL_MAX3100 is not set# CONFIG_SERIAL_MAX3107 is not setCONFIG_SERIAL_CORE=yCONFIG_SERIAL_CORE_CONSOLE=yCONFIG_SERIAL_OMAP=yCONFIG_SERIAL_OMAP_CONSOLE=y# CONFIG_SERIAL_TIMBERDALE is not set# CONFIG_SERIAL_ALTERA_JTAGUART is not set# CONFIG_SERIAL_ALTERA_UART is not set# CONFIG_SERIAL_IFX6X60 is not set# CONFIG_SERIAL_XILINX_PS_UART is not set# CONFIG_HVC_DCC is not set# CONFIG_IPMI_HANDLER is not set# CONFIG_HW_RANDOM is not set# CONFIG_R3964 is not set# CONFIG_RAW_DRIVER is not setCONFIG_detector=yCONFIG_vol_int=y# CONFIG_TCG_TPM is not set# CONFIG_RAMOOPS is not setCONFIG_I2C=yCONFIG_I2C_BOARDINFO=yCONFIG_I2C_COMPAT=yCONFIG_I2C_CHARDEV=y# CONFIG_I2C_MUX is not set# CONFIG_I2C_HELPER_AUTO is not setCONFIG_I2C_SMBUS=y
## I2C Algorithms#CONFIG_I2C_ALGOBIT=y# CONFIG_I2C_ALGOPCF is not set# CONFIG_I2C_ALGOPCA is not set
## I2C Hardware Bus support#
## I2C system bus drivers (mostly embedded / system-on-chip)## CONFIG_I2C_DESIGNWARE_PLATFORM is not set# CONFIG_I2C_GPIO is not set# CONFIG_I2C_OCORES is not setCONFIG_I2C_OMAP=y# CONFIG_I2C_PCA_PLATFORM is not set# CONFIG_I2C_PXA_PCI is not set# CONFIG_I2C_SIMTEC is not set# CONFIG_I2C_XILINX is not set
## External I2C/SMBus adapter drivers## CONFIG_I2C_DIOLAN_U2C is not set# CONFIG_I2C_PARPORT_LIGHT is not set# CONFIG_I2C_TAOS_EVM is not set# CONFIG_I2C_TINY_USB is not set
## Other I2C/SMBus bus drivers## CONFIG_I2C_STUB is not set# CONFIG_I2C_DEBUG_CORE is not set# CONFIG_I2C_DEBUG_ALGO is not set# CONFIG_I2C_DEBUG_BUS is not setCONFIG_SPI=yCONFIG_SPI_MASTER=y
## SPI Master Controller Drivers## CONFIG_SPI_ALTERA is not set# CONFIG_SPI_BITBANG is not set# CONFIG_SPI_GPIO is not set# CONFIG_SPI_OC_TINY is not setCONFIG_SPI_OMAP24XX=y# CONFIG_SPI_PXA2XX_PCI is not set# CONFIG_SPI_XILINX is not set# CONFIG_SPI_DESIGNWARE is not set
## SPI Protocol Masters#CONFIG_SPI_SPIDEV=y# CONFIG_SPI_TLE62X0 is not set
## PPS support## CONFIG_PPS is not set
## PPS generators support#
## PTP clock support#
## Enable Device Drivers -> PPS to see the PTP clock options.#CONFIG_ARCH_REQUIRE_GPIOLIB=yCONFIG_GPIOLIB=yCONFIG_GPIO_SYSFS=y
## Memory mapped GPIO drivers:## CONFIG_GPIO_GENERIC_PLATFORM is not set# CONFIG_GPIO_IT8761E is not set
## I2C GPIO expanders:## CONFIG_GPIO_MAX7300 is not set# CONFIG_GPIO_MAX732X is not set# CONFIG_GPIO_PCF857X is not set# CONFIG_GPIO_SX150X is not set# CONFIG_GPIO_TWL4030 is not set# CONFIG_GPIO_ADP5588 is not set
## PCI GPIO expanders:#
## SPI GPIO expanders:## CONFIG_GPIO_MAX7301 is not set# CONFIG_GPIO_MCP23S08 is not set# CONFIG_GPIO_MC33880 is not set# CONFIG_GPIO_74X164 is not set
## AC97 GPIO expanders:#
## MODULbus GPIO expanders:#CONFIG_GPIO_TPS65910=yCONFIG_GENERIC_PWM=yCONFIG_DAVINCI_EHRPWM=yCONFIG_ECAP_PWM=yCONFIG_W1=yCONFIG_W1_CON=y
## 1-wire Bus Masters## CONFIG_W1_MASTER_DS2490 is not setCONFIG_W1_MASTER_DS2482=y# CONFIG_W1_MASTER_DS1WM is not set# CONFIG_W1_MASTER_GPIO is not set# CONFIG_HDQ_MASTER_OMAP is not set
## 1-wire Slaves## CONFIG_W1_SLAVE_THERM is not set# CONFIG_W1_SLAVE_SMEM is not set# CONFIG_W1_SLAVE_DS2408 is not set# CONFIG_W1_SLAVE_DS2423 is not set# CONFIG_W1_SLAVE_DS2431 is not set# CONFIG_W1_SLAVE_DS2433 is not set# CONFIG_W1_SLAVE_DS2760 is not set# CONFIG_W1_SLAVE_DS2780 is not set# CONFIG_W1_SLAVE_BQ27000 is not set# CONFIG_POWER_SUPPLY is not setCONFIG_HWMON=y# CONFIG_HWMON_VID is not set# CONFIG_HWMON_DEBUG_CHIP is not set
## Native drivers## CONFIG_SENSORS_AD7314 is not set# CONFIG_SENSORS_AD7414 is not set# CONFIG_SENSORS_AD7418 is not set# CONFIG_SENSORS_ADCXX is not set# CONFIG_SENSORS_ADM1021 is not set# CONFIG_SENSORS_ADM1025 is not set# CONFIG_SENSORS_ADM1026 is not set# CONFIG_SENSORS_ADM1029 is not set# CONFIG_SENSORS_ADM1031 is not set# CONFIG_SENSORS_ADM9240 is not set# CONFIG_SENSORS_ADT7411 is not set# CONFIG_SENSORS_ADT7462 is not set# CONFIG_SENSORS_ADT7470 is not set# CONFIG_SENSORS_ADT7475 is not set# CONFIG_SENSORS_ASC7621 is not set# CONFIG_SENSORS_ATXP1 is not set# CONFIG_SENSORS_DS620 is not set# CONFIG_SENSORS_DS1621 is not set# CONFIG_SENSORS_F71805F is not set# CONFIG_SENSORS_F71882FG is not set# CONFIG_SENSORS_F75375S is not set# CONFIG_SENSORS_G760A is not set# CONFIG_SENSORS_GL518SM is not set# CONFIG_SENSORS_GL520SM is not set# CONFIG_SENSORS_GPIO_FAN is not set# CONFIG_SENSORS_IT87 is not set# CONFIG_SENSORS_JC42 is not set# CONFIG_SENSORS_LINEAGE is not set# CONFIG_SENSORS_LM63 is not set# CONFIG_SENSORS_LM70 is not set# CONFIG_SENSORS_LM73 is not set# CONFIG_SENSORS_LM75 is not set# CONFIG_SENSORS_LM77 is not set# CONFIG_SENSORS_LM78 is not set# CONFIG_SENSORS_LM80 is not set# CONFIG_SENSORS_LM83 is not set# CONFIG_SENSORS_LM85 is not set# CONFIG_SENSORS_LM87 is not set# CONFIG_SENSORS_LM90 is not set# CONFIG_SENSORS_LM92 is not set# CONFIG_SENSORS_LM93 is not set# CONFIG_SENSORS_LTC4151 is not set# CONFIG_SENSORS_LTC4215 is not set# CONFIG_SENSORS_LTC4245 is not set# CONFIG_SENSORS_LTC4261 is not set# CONFIG_SENSORS_LM95241 is not set# CONFIG_SENSORS_LM95245 is not set# CONFIG_SENSORS_MAX1111 is not set# CONFIG_SENSORS_MAX16065 is not set# CONFIG_SENSORS_MAX1619 is not set# CONFIG_SENSORS_MAX1668 is not set# CONFIG_SENSORS_MAX6639 is not set# CONFIG_SENSORS_MAX6642 is not set# CONFIG_SENSORS_MAX6650 is not set# CONFIG_SENSORS_NTC_THERMISTOR is not set# CONFIG_SENSORS_PC87360 is not set# CONFIG_SENSORS_PC87427 is not set# CONFIG_SENSORS_PCF8591 is not set# CONFIG_PMBUS is not set# CONFIG_SENSORS_SHT15 is not setCONFIG_SENSORS_SHT21=y# CONFIG_SENSORS_SMM665 is not set# CONFIG_SENSORS_DME1737 is not set# CONFIG_SENSORS_EMC1403 is not set# CONFIG_SENSORS_EMC2103 is not set# CONFIG_SENSORS_EMC6W201 is not set# CONFIG_SENSORS_SMSC47M1 is not set# CONFIG_SENSORS_SMSC47M192 is not set# CONFIG_SENSORS_SMSC47B397 is not set# CONFIG_SENSORS_SCH56XX_COMMON is not set# CONFIG_SENSORS_SCH5627 is not set# CONFIG_SENSORS_SCH5636 is not set# CONFIG_SENSORS_ADS1015 is not set# CONFIG_SENSORS_ADS7828 is not set# CONFIG_SENSORS_ADS7871 is not set# CONFIG_SENSORS_AMC6821 is not set# CONFIG_SENSORS_THMC50 is not set# CONFIG_SENSORS_TMP102 is not set# CONFIG_SENSORS_TMP401 is not set# CONFIG_SENSORS_TMP421 is not set# CONFIG_SENSORS_VT1211 is not set# CONFIG_SENSORS_W83781D is not set# CONFIG_SENSORS_W83791D is not set# CONFIG_SENSORS_W83792D is not set# CONFIG_SENSORS_W83793 is not set# CONFIG_SENSORS_W83795 is not set# CONFIG_SENSORS_W83L785TS is not set# CONFIG_SENSORS_W83L786NG is not set# CONFIG_SENSORS_W83627HF is not set# CONFIG_SENSORS_W83627EHF is not set# CONFIG_THERMAL is not setCONFIG_WATCHDOG=y# CONFIG_WATCHDOG_CORE is not set# CONFIG_WATCHDOG_NOWAYOUT is not set
## Watchdog Device Drivers## CONFIG_SOFT_WATCHDOG is not set# CONFIG_DW_WATCHDOG is not setCONFIG_OMAP_WATCHDOG=y# CONFIG_TWL4030_WATCHDOG is not set# CONFIG_MAX63XX_WATCHDOG is not set
## USB-based Watchdog Cards## CONFIG_USBPCWATCHDOG is not setCONFIG_SSB_POSSIBLE=y
## Sonics Silicon Backplane## CONFIG_SSB is not setCONFIG_BCMA_POSSIBLE=y
## Broadcom specific AMBA## CONFIG_BCMA is not set
## Multifunction device drivers#CONFIG_MFD_CORE=y# CONFIG_MFD_88PM860X is not set# CONFIG_MFD_SM501 is not set# CONFIG_MFD_ASIC3 is not set# CONFIG_HTC_EGPIO is not set# CONFIG_HTC_PASIC3 is not set# CONFIG_HTC_I2CPLD is not set# CONFIG_TPS6105X is not set# CONFIG_TPS65010 is not set# CONFIG_TPS6507X is not setCONFIG_MFD_TI_TSCADC=yCONFIG_MFD_TPS65217=y# CONFIG_MFD_TPS6586X is not setCONFIG_MFD_TPS65910=y# CONFIG_MFD_TPS65912_I2C is not set# CONFIG_MFD_TPS65912_SPI is not setCONFIG_TWL4030_CORE=y# CONFIG_TWL4030_MADC is not setCONFIG_TWL4030_POWER=y# CONFIG_MFD_TWL4030_AUDIO is not set# CONFIG_TWL6030_PWM is not set# CONFIG_TWL6040_CORE is not set# CONFIG_MFD_STMPE is not set# CONFIG_MFD_TC3589X is not set# CONFIG_MFD_TMIO is not set# CONFIG_MFD_T7L66XB is not set# CONFIG_MFD_TC6387XB is not set# CONFIG_MFD_TC6393XB is not set# CONFIG_PMIC_DA903X is not set# CONFIG_PMIC_ADP5520 is not set# CONFIG_MFD_MAX8925 is not set# CONFIG_MFD_MAX8997 is not set# CONFIG_MFD_MAX8998 is not set# CONFIG_MFD_WM8400 is not set# CONFIG_MFD_WM831X_I2C is not set# CONFIG_MFD_WM831X_SPI is not set# CONFIG_MFD_WM8350_I2C is not set# CONFIG_MFD_WM8994 is not set# CONFIG_MFD_PCF50633 is not set# CONFIG_MFD_MC13XXX is not set# CONFIG_ABX500_CORE is not set# CONFIG_EZX_PCAP is not set# CONFIG_MFD_WL1273_CORE is not setCONFIG_MFD_OMAP_USB_HOST=y# CONFIG_MFD_AAT2870_CORE is not setCONFIG_REGULATOR=y# CONFIG_REGULATOR_DEBUG is not setCONFIG_REGULATOR_DUMMY=yCONFIG_REGULATOR_FIXED_VOLTAGE=y# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set# CONFIG_REGULATOR_GPIO is not set# CONFIG_REGULATOR_BQ24022 is not set# CONFIG_REGULATOR_MAX1586 is not set# CONFIG_REGULATOR_MAX8649 is not set# CONFIG_REGULATOR_MAX8660 is not set# CONFIG_REGULATOR_MAX8952 is not set# CONFIG_REGULATOR_TWL4030 is not set# CONFIG_REGULATOR_LP3971 is not set# CONFIG_REGULATOR_LP3972 is not set# CONFIG_REGULATOR_TPS65023 is not set# CONFIG_REGULATOR_TPS6507X is not setCONFIG_REGULATOR_TPS65217=y# CONFIG_REGULATOR_ISL6271A is not set# CONFIG_REGULATOR_AD5398 is not set# CONFIG_REGULATOR_TPS6524X is not setCONFIG_REGULATOR_TPS65910=y# CONFIG_MEDIA_SUPPORT is not set
## Graphics support#CONFIG_DRM=y# CONFIG_VGASTATE is not set# CONFIG_VIDEO_OUTPUT_CONTROL is not setCONFIG_HDMI=yCONFIG_FB=y# CONFIG_FIRMWARE_EDID is not set# CONFIG_FB_DDC is not set# CONFIG_FB_BOOT_VESA_SUPPORT is not setCONFIG_FB_CFB_FILLRECT=yCONFIG_FB_CFB_COPYAREA=yCONFIG_FB_CFB_IMAGEBLIT=y# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set# CONFIG_FB_SYS_FILLRECT is not set# CONFIG_FB_SYS_COPYAREA is not set# CONFIG_FB_SYS_IMAGEBLIT is not set# CONFIG_FB_FOREIGN_ENDIAN is not set# CONFIG_FB_SYS_FOPS is not set# CONFIG_FB_WMT_GE_ROPS is not set# CONFIG_FB_SVGALIB is not set# CONFIG_FB_MACMODES is not set# CONFIG_FB_BACKLIGHT is not set# CONFIG_FB_MODE_HELPERS is not set# CONFIG_FB_TILEBLITTING is not set
## Frame buffer hardware drivers## CONFIG_FB_UVESA is not set# CONFIG_FB_S1D13XXX is not set# CONFIG_FB_TMIO is not set# CONFIG_FB_SMSCUFX is not set# CONFIG_FB_UDL is not setCONFIG_FB_DA8XX=yCONFIG_FB_DA8XX_CONSISTENT_DMA_SIZE=8# CONFIG_FB_VIRTUAL is not set# CONFIG_FB_METRONOME is not set# CONFIG_FB_BROADSHEET is not set# CONFIG_FB_OMAP is not set# CONFIG_OMAP2_DSS is not setCONFIG_BACKLIGHT_LCD_SUPPORT=yCONFIG_LCD_CLASS_DEVICE=y# CONFIG_LCD_L4F00242T03 is not set# CONFIG_LCD_LMS283GF05 is not set# CONFIG_LCD_LTV350QV is not set# CONFIG_LCD_TDO24M is not set# CONFIG_LCD_VGG2432A4 is not set# CONFIG_LCD_PLATFORM is not set# CONFIG_LCD_S6E63M0 is not set# CONFIG_LCD_LD9040 is not set# CONFIG_LCD_AMS369FG06 is not setCONFIG_BACKLIGHT_CLASS_DEVICE=y# CONFIG_BACKLIGHT_GENERIC is not setCONFIG_BACKLIGHT_PWM=y# CONFIG_BACKLIGHT_ADP8860 is not set# CONFIG_BACKLIGHT_ADP8870 is not setCONFIG_BACKLIGHT_TLC59108=y
## Display device support#CONFIG_DISPLAY_SUPPORT=y
## Display hardware drivers#
## NXP I2C encoder chips#CONFIG_DRM_I2C_NXP_TDA998X=m
## Console display driver support#CONFIG_DUMMY_CONSOLE=yCONFIG_FRAMEBUFFER_CONSOLE=y# CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set# CONFIG_FONTS is not setCONFIG_FONT_8x8=yCONFIG_FONT_8x16=yCONFIG_LOGO=yCONFIG_LOGO_LINUX_MONO=yCONFIG_LOGO_LINUX_VGA16=yCONFIG_LOGO_LINUX_CLUT224=y# CONFIG_SOUND is not setCONFIG_HID_SUPPORT=yCONFIG_HID=y# CONFIG_HIDRAW is not set
## USB Input Devices#CONFIG_USB_HID=y# CONFIG_HID_PID is not set# CONFIG_USB_HIDDEV is not set
## Special HID drivers#CONFIG_HID_A4TECH=y# CONFIG_HID_ACRUX is not setCONFIG_HID_APPLE=yCONFIG_HID_BELKIN=yCONFIG_HID_CHERRY=yCONFIG_HID_CHICONY=yCONFIG_HID_CYPRESS=y# CONFIG_HID_DRAGONRISE is not set# CONFIG_HID_EMS_FF is not set# CONFIG_HID_ELECOM is not setCONFIG_HID_EZKEY=y# CONFIG_HID_HOLTEK is not set# CONFIG_HID_KEYTOUCH is not setCONFIG_HID_KYE=y# CONFIG_HID_UCLOGIC is not set# CONFIG_HID_WALTOP is not set# CONFIG_HID_GYRATION is not set# CONFIG_HID_TWINHAN is not setCONFIG_HID_KENSINGTON=y# CONFIG_HID_LCPOWER is not setCONFIG_HID_LOGITECH=yCONFIG_HID_LOGITECH_DJ=m# CONFIG_LOGITECH_FF is not set# CONFIG_LOGIRUMBLEPAD2_FF is not set# CONFIG_LOGIG940_FF is not set# CONFIG_LOGIWHEELS_FF is not set# CONFIG_HID_MAGICMOUSE is not setCONFIG_HID_MICROSOFT=yCONFIG_HID_MONTEREY=y# CONFIG_HID_MULTITOUCH is not set# CONFIG_HID_NTRIG is not set# CONFIG_HID_ORTEK is not set# CONFIG_HID_PANTHERLORD is not set# CONFIG_HID_PETALYNX is not set# CONFIG_HID_PICOLCD is not set# CONFIG_HID_PRIMAX is not set# CONFIG_HID_QUANTA is not set# CONFIG_HID_ROCCAT is not set# CONFIG_HID_SAMSUNG is not set# CONFIG_HID_SONY is not set# CONFIG_HID_SPEEDLINK is not set# CONFIG_HID_SUNPLUS is not set# CONFIG_HID_GREENASIA is not set# CONFIG_HID_SMARTJOYPLUS is not set# CONFIG_HID_TOPSEED is not set# CONFIG_HID_THRUSTMASTER is not set# CONFIG_HID_WACOM is not set# CONFIG_HID_WIIMOTE is not set# CONFIG_HID_ZEROPLUS is not set# CONFIG_HID_ZYDACRON is not setCONFIG_USB_SUPPORT=yCONFIG_USB_COMMON=yCONFIG_USB_ARCH_HAS_HCD=yCONFIG_USB_ARCH_HAS_OHCI=yCONFIG_USB_ARCH_HAS_EHCI=y# CONFIG_USB_ARCH_HAS_XHCI is not setCONFIG_USB=y# CONFIG_USB_DEBUG is not setCONFIG_USB_ANNOUNCE_NEW_DEVICES=y
## Miscellaneous USB options#CONFIG_USB_DEVICEFS=yCONFIG_USB_DEVICE_CLASS=y# CONFIG_USB_DYNAMIC_MINORS is not setCONFIG_USB_SUSPEND=yCONFIG_USB_OTG=y# CONFIG_USB_OTG_WHITELIST is not set# CONFIG_USB_OTG_BLACKLIST_HUB is not set# CONFIG_USB_DWC3 is not set# CONFIG_USB_MON is not set# CONFIG_USB_WUSB is not set# CONFIG_USB_WUSB_CBAF is not set
## USB Host Controller Drivers## CONFIG_USB_C67X00_HCD is not setCONFIG_USB_EHCI_HCD=y# CONFIG_USB_EHCI_ROOT_HUB_TT is not setCONFIG_USB_EHCI_TT_NEWSCHED=yCONFIG_USB_EHCI_HCD_OMAP=y# CONFIG_USB_OXU210HP_HCD is not set# CONFIG_USB_ISP116X_HCD is not set# CONFIG_USB_ISP1760_HCD is not set# CONFIG_USB_ISP1362_HCD is not set# CONFIG_USB_OHCI_HCD is not set# CONFIG_USB_SL811_HCD is not set# CONFIG_USB_R8A66597_HCD is not set# CONFIG_USB_HWA_HCD is not setCONFIG_USB_MUSB_HDRC=y
## Platform Glue Layer## CONFIG_USB_MUSB_TUSB6010_GLUE is not set# CONFIG_USB_MUSB_OMAP2PLUS_GLUE is not set# CONFIG_USB_MUSB_AM35X_GLUE is not setCONFIG_USB_MUSB_TI81XX_GLUE=y# CONFIG_USB_MUSB_DAVINCI is not set# CONFIG_USB_MUSB_DA8XX is not set# CONFIG_USB_MUSB_TUSB6010 is not set# CONFIG_USB_MUSB_OMAP2PLUS is not set# CONFIG_USB_MUSB_AM35X is not setCONFIG_USB_MUSB_TI81XX=y# CONFIG_USB_MUSB_BLACKFIN is not set# CONFIG_USB_MUSB_UX500 is not setCONFIG_USB_TI_CPPI41_DMA_HW=y# CONFIG_MUSB_PIO_ONLY is not set# CONFIG_USB_INVENTRA_DMA is not set# CONFIG_USB_TI_CPPI_DMA is not setCONFIG_USB_TI_CPPI41_DMA=y# CONFIG_USB_TUSB_OMAP_DMA is not set# CONFIG_USB_UX500_DMA is not set# CONFIG_USB_RENESAS_USBHS is not set
## USB Device Class drivers## CONFIG_USB_ACM is not set# CONFIG_USB_PRINTER is not setCONFIG_USB_WDM=y# CONFIG_USB_TMC is not set
## NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may#
## also be needed; see USB_STORAGE Help for more info#CONFIG_USB_STORAGE=y# CONFIG_USB_STORAGE_DEBUG is not set# CONFIG_USB_STORAGE_REALTEK is not set# CONFIG_USB_STORAGE_DATAFAB is not set# CONFIG_USB_STORAGE_FREECOM is not set# CONFIG_USB_STORAGE_ISD200 is not set# CONFIG_USB_STORAGE_USBAT is not set# CONFIG_USB_STORAGE_SDDR09 is not set# CONFIG_USB_STORAGE_SDDR55 is not set# CONFIG_USB_STORAGE_JUMPSHOT is not set# CONFIG_USB_STORAGE_ALAUDA is not set# CONFIG_USB_STORAGE_ONETOUCH is not set# CONFIG_USB_STORAGE_KARMA is not set# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set# CONFIG_USB_STORAGE_ENE_UB6250 is not set# CONFIG_USB_UAS is not set# CONFIG_USB_LIBUSUAL is not set
## USB Imaging devices## CONFIG_USB_MDC800 is not set# CONFIG_USB_MICROTEK is not set
## USB port drivers#CONFIG_USB_SERIAL=y# CONFIG_USB_SERIAL_CONSOLE is not set# CONFIG_USB_EZUSB is not setCONFIG_USB_SERIAL_GENERIC=y# CONFIG_USB_SERIAL_AIRCABLE is not set# CONFIG_USB_SERIAL_ARK3116 is not set# CONFIG_USB_SERIAL_BELKIN is not set# CONFIG_USB_SERIAL_CH341 is not set# CONFIG_USB_SERIAL_WHITEHEAT is not set# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set# CONFIG_USB_SERIAL_CP210X is not set# CONFIG_USB_SERIAL_CYPRESS_M8 is not set# CONFIG_USB_SERIAL_EMPEG is not set# CONFIG_USB_SERIAL_FTDI_SIO is not set# CONFIG_USB_SERIAL_FUNSOFT is not set# CONFIG_USB_SERIAL_VISOR is not set# CONFIG_USB_SERIAL_IPAQ is not set# CONFIG_USB_SERIAL_IR is not set# CONFIG_USB_SERIAL_EDGEPORT is not set# CONFIG_USB_SERIAL_EDGEPORT_TI is not set# CONFIG_USB_SERIAL_GARMIN is not set# CONFIG_USB_SERIAL_IPW is not set# CONFIG_USB_SERIAL_IUU is not set# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set# CONFIG_USB_SERIAL_KEYSPAN is not set# CONFIG_USB_SERIAL_KLSI is not set# CONFIG_USB_SERIAL_KOBIL_SCT is not set# CONFIG_USB_SERIAL_MCT_U232 is not set# CONFIG_USB_SERIAL_MOS7720 is not set# CONFIG_USB_SERIAL_MOS7840 is not set# CONFIG_USB_SERIAL_MOTOROLA is not set# CONFIG_USB_SERIAL_NAVMAN is not set# CONFIG_USB_SERIAL_PL2303 is not set# CONFIG_USB_SERIAL_OTI6858 is not set# CONFIG_USB_SERIAL_QCAUX is not set# CONFIG_USB_SERIAL_QUALCOMM is not set# CONFIG_USB_SERIAL_SPCP8X5 is not set# CONFIG_USB_SERIAL_HP4X is not set# CONFIG_USB_SERIAL_SAFE is not set# CONFIG_USB_SERIAL_SIEMENS_MPI is not set# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set# CONFIG_USB_SERIAL_SYMBOL is not set# CONFIG_USB_SERIAL_TI is not set# CONFIG_USB_SERIAL_CYBERJACK is not set# CONFIG_USB_SERIAL_XIRCOM is not setCONFIG_USB_SERIAL_WWAN=yCONFIG_USB_SERIAL_OPTION=y# CONFIG_USB_SERIAL_OMNINET is not set# CONFIG_USB_SERIAL_OPTICON is not set# CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set# CONFIG_USB_SERIAL_ZIO is not set# CONFIG_USB_SERIAL_SSU100 is not set# CONFIG_USB_SERIAL_DEBUG is not set
## USB Miscellaneous drivers## CONFIG_USB_EMI62 is not set# CONFIG_USB_EMI26 is not set# CONFIG_USB_ADUTUX is not set# CONFIG_USB_SEVSEG is not set# CONFIG_USB_RIO500 is not set# CONFIG_USB_LEGOTOWER is not set# CONFIG_USB_LCD is not set# CONFIG_USB_LED is not set# CONFIG_USB_CYPRESS_CY7C63 is not set# CONFIG_USB_CYTHERM is not set# CONFIG_USB_IDMOUSE is not set# CONFIG_USB_FTDI_ELAN is not set# CONFIG_USB_APPLEDISPLAY is not set# CONFIG_USB_SISUSBVGA is not set# CONFIG_USB_LD is not set# CONFIG_USB_TRANCEVIBRATOR is not set# CONFIG_USB_IOWARRIOR is not set# CONFIG_USB_TEST is not set# CONFIG_USB_ISIGHTFW is not set# CONFIG_USB_YUREX is not setCONFIG_USB_GADGET=y# CONFIG_USB_GADGET_DEBUG_FILES is not set# CONFIG_USB_GADGET_DEBUG_FS is not setCONFIG_USB_GADGET_VBUS_DRAW=2CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2# CONFIG_USB_FUSB300 is not set# CONFIG_USB_OMAP is not set# CONFIG_USB_R8A66597 is not setCONFIG_USB_GADGET_MUSB_HDRC=y# CONFIG_USB_M66592 is not set# CONFIG_USB_NET2272 is not set# CONFIG_USB_DUMMY_HCD is not setCONFIG_USB_GADGET_DUALSPEED=y# CONFIG_USB_ZERO is not setCONFIG_USB_ETH=yCONFIG_USB_ETH_RNDIS=y# CONFIG_USB_ETH_EEM is not set# CONFIG_USB_G_NCM is not set# CONFIG_USB_GADGETFS is not set# CONFIG_USB_FUNCTIONFS is not set# CONFIG_USB_FILE_STORAGE is not set# CONFIG_USB_MASS_STORAGE is not set# CONFIG_USB_G_SERIAL is not set# CONFIG_USB_G_PRINTER is not set# CONFIG_USB_CDC_COMPOSITE is not set# CONFIG_USB_G_ACM_MS is not set# CONFIG_USB_G_MULTI is not set# CONFIG_USB_G_HID is not set# CONFIG_USB_G_DBGP is not set
## OTG and related infrastructure#CONFIG_USB_OTG_UTILS=y# CONFIG_USB_GPIO_VBUS is not set# CONFIG_USB_ULPI is not set# CONFIG_TWL6030_USB is not setCONFIG_NOP_USB_XCEIV=yCONFIG_MMC=y# CONFIG_MMC_DEBUG is not setCONFIG_MMC_UNSAFE_RESUME=y# CONFIG_MMC_CLKGATE is not set
## MMC/SD/SDIO Card Drivers#CONFIG_MMC_BLOCK=yCONFIG_MMC_BLOCK_MINORS=8CONFIG_MMC_BLOCK_BOUNCE=y# CONFIG_SDIO_UART is not set# CONFIG_MMC_TEST is not set
## MMC/SD/SDIO Host Controller Drivers## CONFIG_MMC_SDHCI is not set# CONFIG_MMC_SDHCI_PXAV3 is not set# CONFIG_MMC_SDHCI_PXAV2 is not set# CONFIG_MMC_OMAP is not setCONFIG_MMC_OMAP_HS=y# CONFIG_MMC_SPI is not set# CONFIG_MMC_DW is not set# CONFIG_MMC_VUB300 is not set# CONFIG_MMC_USHC is not set# CONFIG_MEMSTICK is not setCONFIG_NEW_LEDS=yCONFIG_LEDS_CLASS=y
## LED drivers## CONFIG_LEDS_LM3530 is not set# CONFIG_LEDS_PCA9532 is not setCONFIG_LEDS_GPIO=y# CONFIG_LEDS_LP3944 is not set# CONFIG_LEDS_LP5521 is not set# CONFIG_LEDS_LP5523 is not set# CONFIG_LEDS_PCA955X is not set# CONFIG_LEDS_DAC124S085 is not set# CONFIG_LEDS_PWM is not set# CONFIG_LEDS_REGULATOR is not set# CONFIG_LEDS_BD2802 is not set# CONFIG_LEDS_LT3593 is not set# CONFIG_LEDS_RENESAS_TPU is not setCONFIG_LEDS_TRIGGERS=y
## LED Triggers#CONFIG_LEDS_TRIGGER_TIMER=yCONFIG_LEDS_TRIGGER_HEARTBEAT=y# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set# CONFIG_LEDS_TRIGGER_GPIO is not set# CONFIG_LEDS_TRIGGER_DEFAULT_ON is not set
## iptables trigger is under Netfilter config (LED target)## CONFIG_ACCESSIBILITY is not setCONFIG_RTC_LIB=yCONFIG_RTC_CLASS=yCONFIG_RTC_HCTOSYS=yCONFIG_RTC_HCTOSYS_DEVICE="rtc0"# CONFIG_RTC_DEBUG is not set
## RTC interfaces#CONFIG_RTC_INTF_SYSFS=yCONFIG_RTC_INTF_PROC=yCONFIG_RTC_INTF_DEV=y# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set# CONFIG_RTC_DRV_TEST is not set
## I2C RTC drivers## CONFIG_RTC_DRV_DS1307 is not set# CONFIG_RTC_DRV_DS1374 is not set# CONFIG_RTC_DRV_DS1672 is not set# CONFIG_RTC_DRV_DS3232 is not set# CONFIG_RTC_DRV_MAX6900 is not set# CONFIG_RTC_DRV_RS5C372 is not set# CONFIG_RTC_DRV_ISL1208 is not set# CONFIG_RTC_DRV_ISL12022 is not set# CONFIG_RTC_DRV_X1205 is not set# CONFIG_RTC_DRV_PCF8563 is not set# CONFIG_RTC_DRV_PCF8583 is not set# CONFIG_RTC_DRV_M41T80 is not set# CONFIG_RTC_DRV_BQ32K is not set# CONFIG_RTC_DRV_TWL4030 is not set# CONFIG_RTC_DRV_S35390A is not set# CONFIG_RTC_DRV_FM3130 is not set# CONFIG_RTC_DRV_RX8581 is not set# CONFIG_RTC_DRV_RX8025 is not set# CONFIG_RTC_DRV_EM3027 is not set# CONFIG_RTC_DRV_RV3029C2 is not set
## SPI RTC drivers## CONFIG_RTC_DRV_M41T93 is not set# CONFIG_RTC_DRV_M41T94 is not set# CONFIG_RTC_DRV_DS1305 is not set# CONFIG_RTC_DRV_DS1390 is not set# CONFIG_RTC_DRV_MAX6902 is not set# CONFIG_RTC_DRV_R9701 is not set# CONFIG_RTC_DRV_RS5C348 is not set# CONFIG_RTC_DRV_DS3234 is not set# CONFIG_RTC_DRV_PCF2123 is not set
## Platform RTC drivers## CONFIG_RTC_DRV_CMOS is not set# CONFIG_RTC_DRV_DS1286 is not set# CONFIG_RTC_DRV_DS1511 is not set# CONFIG_RTC_DRV_DS1553 is not set# CONFIG_RTC_DRV_DS1742 is not set# CONFIG_RTC_DRV_STK17TA8 is not set# CONFIG_RTC_DRV_M48T86 is not set# CONFIG_RTC_DRV_M48T35 is not set# CONFIG_RTC_DRV_M48T59 is not set# CONFIG_RTC_DRV_MSM6242 is not set# CONFIG_RTC_DRV_BQ4802 is not set# CONFIG_RTC_DRV_RP5C01 is not set# CONFIG_RTC_DRV_V3020 is not set
## on-CPU RTC drivers#CONFIG_RTC_DRV_OMAP=y# CONFIG_DMADEVICES is not set# CONFIG_AUXDISPLAY is not set# CONFIG_UIO is not set
## Virtio drivers## CONFIG_VIRTIO_BALLOON is not set# CONFIG_VIRTIO_MMIO is not set# CONFIG_STAGING is not setCONFIG_CLKDEV_LOOKUP=y
## Hardware Spinlock drivers#CONFIG_CLKSRC_MMIO=y# CONFIG_IOMMU_SUPPORT is not set# CONFIG_VIRT_DRIVERS is not set# CONFIG_PM_DEVFREQ is not set
## File systems#CONFIG_EXT2_FS=y# CONFIG_EXT2_FS_XATTR is not set# CONFIG_EXT2_FS_XIP is not setCONFIG_EXT3_FS=yCONFIG_EXT3_DEFAULTS_TO_ORDERED=y# CONFIG_EXT3_FS_XATTR is not setCONFIG_EXT4_FS=yCONFIG_EXT4_FS_XATTR=yCONFIG_EXT4_FS_POSIX_ACL=yCONFIG_EXT4_FS_SECURITY=y# CONFIG_EXT4_DEBUG is not setCONFIG_JBD=y# CONFIG_JBD_DEBUG is not setCONFIG_JBD2=y# CONFIG_JBD2_DEBUG is not setCONFIG_FS_MBCACHE=y# CONFIG_REISERFS_FS is not set# CONFIG_JFS_FS is not set# CONFIG_XFS_FS is not set# CONFIG_GFS2_FS is not set# CONFIG_BTRFS_FS is not set# CONFIG_NILFS2_FS is not setCONFIG_FS_POSIX_ACL=yCONFIG_FILE_LOCKING=yCONFIG_FSNOTIFY=yCONFIG_DNOTIFY=yCONFIG_INOTIFY_USER=y# CONFIG_FANOTIFY is not setCONFIG_QUOTA=y# CONFIG_QUOTA_NETLINK_INTERFACE is not setCONFIG_PRINT_QUOTA_WARNING=y# CONFIG_QUOTA_DEBUG is not setCONFIG_QUOTA_TREE=y# CONFIG_QFMT_V1 is not setCONFIG_QFMT_V2=yCONFIG_QUOTACTL=y# CONFIG_AUTOFS4_FS is not set# CONFIG_FUSE_FS is not set
## Caches## CONFIG_FSCACHE is not set
## CD-ROM/DVD Filesystems## CONFIG_ISO9660_FS is not set# CONFIG_UDF_FS is not set
## DOS/FAT/NT Filesystems#CONFIG_FAT_FS=yCONFIG_MSDOS_FS=yCONFIG_VFAT_FS=yCONFIG_FAT_DEFAULT_CODEPAGE=437CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"# CONFIG_NTFS_FS is not set
## Pseudo filesystems#CONFIG_PROC_FS=yCONFIG_PROC_SYSCTL=yCONFIG_PROC_PAGE_MONITOR=yCONFIG_SYSFS=yCONFIG_TMPFS=y# CONFIG_TMPFS_POSIX_ACL is not set# CONFIG_TMPFS_XATTR is not set# CONFIG_HUGETLB_PAGE is not set# CONFIG_CONFIGFS_FS is not setCONFIG_MISC_FILESYSTEMS=y# CONFIG_ADFS_FS is not set# CONFIG_AFFS_FS is not set# CONFIG_ECRYPT_FS is not set# CONFIG_HFS_FS is not set# CONFIG_HFSPLUS_FS is not set# CONFIG_BEFS_FS is not set# CONFIG_BFS_FS is not set# CONFIG_EFS_FS is not set# CONFIG_JFFS2_FS is not setCONFIG_UBIFS_FS=y# CONFIG_UBIFS_FS_XATTR is not set# CONFIG_UBIFS_FS_ADVANCED_COMPR is not setCONFIG_UBIFS_FS_LZO=yCONFIG_UBIFS_FS_ZLIB=y# CONFIG_UBIFS_FS_DEBUG is not set# CONFIG_LOGFS is not setCONFIG_CRAMFS=y# CONFIG_SQUASHFS is not set# CONFIG_VXFS_FS is not set# CONFIG_MINIX_FS is not set# CONFIG_OMFS_FS is not set# CONFIG_HPFS_FS is not set# CONFIG_QNX4FS_FS is not set# CONFIG_ROMFS_FS is not set# CONFIG_PSTORE is not set# CONFIG_SYSV_FS is not set# CONFIG_UFS_FS is not setCONFIG_NETWORK_FILESYSTEMS=yCONFIG_NFS_FS=yCONFIG_NFS_V3=yCONFIG_NFS_V3_ACL=yCONFIG_NFS_V4=y# CONFIG_NFS_V4_1 is not setCONFIG_ROOT_NFS=y# CONFIG_NFS_USE_LEGACY_DNS is not setCONFIG_NFS_USE_KERNEL_DNS=y# CONFIG_NFS_USE_NEW_IDMAPPER is not set# CONFIG_NFSD is not setCONFIG_LOCKD=yCONFIG_LOCKD_V4=yCONFIG_NFS_ACL_SUPPORT=yCONFIG_NFS_COMMON=yCONFIG_SUNRPC=yCONFIG_SUNRPC_GSS=y# CONFIG_CEPH_FS is not set# CONFIG_CIFS is not set# CONFIG_NCP_FS is not set# CONFIG_CODA_FS is not set# CONFIG_AFS_FS is not set
## Partition Types#CONFIG_PARTITION_ADVANCED=y# CONFIG_ACORN_PARTITION is not set# CONFIG_OSF_PARTITION is not set# CONFIG_AMIGA_PARTITION is not set# CONFIG_ATARI_PARTITION is not set# CONFIG_MAC_PARTITION is not setCONFIG_MSDOS_PARTITION=y# CONFIG_BSD_DISKLABEL is not set# CONFIG_MINIX_SUBPARTITION is not set# CONFIG_SOLARIS_X86_PARTITION is not set# CONFIG_UNIXWARE_DISKLABEL is not set# CONFIG_LDM_PARTITION is not set# CONFIG_SGI_PARTITION is not set# CONFIG_ULTRIX_PARTITION is not set# CONFIG_SUN_PARTITION is not set# CONFIG_KARMA_PARTITION is not set# CONFIG_EFI_PARTITION is not set# CONFIG_SYSV68_PARTITION is not setCONFIG_NLS=yCONFIG_NLS_DEFAULT="iso8859-1"CONFIG_NLS_CODEPAGE_437=y# CONFIG_NLS_CODEPAGE_737 is not set# CONFIG_NLS_CODEPAGE_775 is not set# CONFIG_NLS_CODEPAGE_850 is not set# CONFIG_NLS_CODEPAGE_852 is not set# CONFIG_NLS_CODEPAGE_855 is not set# CONFIG_NLS_CODEPAGE_857 is not set# CONFIG_NLS_CODEPAGE_860 is not set# CONFIG_NLS_CODEPAGE_861 is not set# CONFIG_NLS_CODEPAGE_862 is not set# CONFIG_NLS_CODEPAGE_863 is not set# CONFIG_NLS_CODEPAGE_864 is not set# CONFIG_NLS_CODEPAGE_865 is not set# CONFIG_NLS_CODEPAGE_866 is not set# CONFIG_NLS_CODEPAGE_869 is not set# CONFIG_NLS_CODEPAGE_936 is not set# CONFIG_NLS_CODEPAGE_950 is not set# CONFIG_NLS_CODEPAGE_932 is not set# CONFIG_NLS_CODEPAGE_949 is not set# CONFIG_NLS_CODEPAGE_874 is not set# CONFIG_NLS_ISO8859_8 is not set# CONFIG_NLS_CODEPAGE_1250 is not set# CONFIG_NLS_CODEPAGE_1251 is not set# CONFIG_NLS_ASCII is not setCONFIG_NLS_ISO8859_1=y# CONFIG_NLS_ISO8859_2 is not set# CONFIG_NLS_ISO8859_3 is not set# CONFIG_NLS_ISO8859_4 is not set# CONFIG_NLS_ISO8859_5 is not set# CONFIG_NLS_ISO8859_6 is not set# CONFIG_NLS_ISO8859_7 is not set# CONFIG_NLS_ISO8859_9 is not set# CONFIG_NLS_ISO8859_13 is not set# CONFIG_NLS_ISO8859_14 is not set# CONFIG_NLS_ISO8859_15 is not set# CONFIG_NLS_KOI8_R is not set# CONFIG_NLS_KOI8_U is not set# CONFIG_NLS_UTF8 is not set
## Kernel hacking## CONFIG_PRINTK_TIME is not setCONFIG_DEFAULT_MESSAGE_LOGLEVEL=4CONFIG_ENABLE_WARN_DEPRECATED=yCONFIG_ENABLE_MUST_CHECK=yCONFIG_FRAME_WARN=1024CONFIG_MAGIC_SYSRQ=y# CONFIG_STRIP_ASM_SYMS is not set# CONFIG_UNUSED_SYMBOLS is not setCONFIG_DEBUG_FS=y# CONFIG_HEADERS_CHECK is not set# CONFIG_DEBUG_SECTION_MISMATCH is not set# CONFIG_DEBUG_KERNEL is not set# CONFIG_HARDLOCKUP_DETECTOR is not set# CONFIG_SPARSE_RCU_POINTER is not setCONFIG_DEBUG_BUGVERBOSE=yCONFIG_DEBUG_MEMORY_INIT=yCONFIG_FRAME_POINTER=y# CONFIG_LKDTM is not set# CONFIG_SYSCTL_SYSCALL_CHECK is not setCONFIG_HAVE_FUNCTION_TRACER=yCONFIG_HAVE_FUNCTION_GRAPH_TRACER=yCONFIG_HAVE_DYNAMIC_FTRACE=yCONFIG_HAVE_FTRACE_MCOUNT_RECORD=yCONFIG_HAVE_C_RECORDMCOUNT=yCONFIG_RING_BUFFER=yCONFIG_RING_BUFFER_ALLOW_SWAP=yCONFIG_TRACING_SUPPORT=y# CONFIG_FTRACE is not setCONFIG_DYNAMIC_DEBUG=y# CONFIG_DMA_API_DEBUG is not set# CONFIG_ATOMIC64_SELFTEST is not set# CONFIG_SAMPLES is not setCONFIG_HAVE_ARCH_KGDB=y# CONFIG_TEST_KSTRTOX is not set# CONFIG_STRICT_DEVMEM is not set# CONFIG_ARM_UNWIND is not set# CONFIG_DEBUG_USER is not setCONFIG_DEBUG_JTAG_ENABLE=y
## Security options#CONFIG_KEYS=y# CONFIG_ENCRYPTED_KEYS is not set# CONFIG_KEYS_DEBUG_PROC_KEYS is not set# CONFIG_SECURITY_DMESG_RESTRICT is not setCONFIG_SECURITY=y# CONFIG_SECURITYFS is not set# CONFIG_SECURITY_NETWORK is not set# CONFIG_SECURITY_PATH is not set# CONFIG_SECURITY_TOMOYO is not set# CONFIG_SECURITY_APPARMOR is not set# CONFIG_IMA is not set# CONFIG_EVM is not setCONFIG_DEFAULT_SECURITY_DAC=yCONFIG_DEFAULT_SECURITY=""CONFIG_CRYPTO=y
## Crypto core or helper#CONFIG_CRYPTO_ALGAPI=yCONFIG_CRYPTO_ALGAPI2=yCONFIG_CRYPTO_AEAD=yCONFIG_CRYPTO_AEAD2=yCONFIG_CRYPTO_BLKCIPHER=yCONFIG_CRYPTO_BLKCIPHER2=yCONFIG_CRYPTO_HASH=yCONFIG_CRYPTO_HASH2=yCONFIG_CRYPTO_RNG=yCONFIG_CRYPTO_RNG2=yCONFIG_CRYPTO_PCOMP2=yCONFIG_CRYPTO_MANAGER=yCONFIG_CRYPTO_MANAGER2=y# CONFIG_CRYPTO_USER is not set# CONFIG_CRYPTO_MANAGER_DISABLE_TESTS is not set# CONFIG_CRYPTO_GF128MUL is not set# CONFIG_CRYPTO_NULL is not setCONFIG_CRYPTO_WORKQUEUE=y# CONFIG_CRYPTO_CRYPTD is not set# CONFIG_CRYPTO_AUTHENC is not setCONFIG_CRYPTO_TEST=m
## Authenticated Encryption with Associated Data## CONFIG_CRYPTO_CCM is not set# CONFIG_CRYPTO_GCM is not setCONFIG_CRYPTO_SEQIV=y
## Block modes#CONFIG_CRYPTO_CBC=yCONFIG_CRYPTO_CTR=y# CONFIG_CRYPTO_CTS is not setCONFIG_CRYPTO_ECB=y# CONFIG_CRYPTO_LRW is not set# CONFIG_CRYPTO_PCBC is not set# CONFIG_CRYPTO_XTS is not set
## Hash modes#CONFIG_CRYPTO_HMAC=y# CONFIG_CRYPTO_XCBC is not set# CONFIG_CRYPTO_VMAC is not set
## Digest#CONFIG_CRYPTO_CRC32C=y# CONFIG_CRYPTO_GHASH is not set# CONFIG_CRYPTO_MD4 is not setCONFIG_CRYPTO_MD5=yCONFIG_CRYPTO_MICHAEL_MIC=y# CONFIG_CRYPTO_RMD128 is not set# CONFIG_CRYPTO_RMD160 is not set# CONFIG_CRYPTO_RMD256 is not set# CONFIG_CRYPTO_RMD320 is not setCONFIG_CRYPTO_SHA1=yCONFIG_CRYPTO_SHA256=y# CONFIG_CRYPTO_SHA512 is not set# CONFIG_CRYPTO_TGR192 is not set# CONFIG_CRYPTO_WP512 is not set
## Ciphers#CONFIG_CRYPTO_AES=y# CONFIG_CRYPTO_ANUBIS is not setCONFIG_CRYPTO_ARC4=y# CONFIG_CRYPTO_BLOWFISH is not set# CONFIG_CRYPTO_CAMELLIA is not set# CONFIG_CRYPTO_CAST5 is not set# CONFIG_CRYPTO_CAST6 is not setCONFIG_CRYPTO_DES=y# CONFIG_CRYPTO_FCRYPT is not set# CONFIG_CRYPTO_KHAZAD is not set# CONFIG_CRYPTO_SALSA20 is not set# CONFIG_CRYPTO_SEED is not set# CONFIG_CRYPTO_SERPENT is not set# CONFIG_CRYPTO_TEA is not set# CONFIG_CRYPTO_TWOFISH is not set
## Compression#CONFIG_CRYPTO_DEFLATE=y# CONFIG_CRYPTO_ZLIB is not setCONFIG_CRYPTO_LZO=y
## Random Number Generation## CONFIG_CRYPTO_ANSI_CPRNG is not set# CONFIG_CRYPTO_USER_API_HASH is not set# CONFIG_CRYPTO_USER_API_SKCIPHER is not setCONFIG_CRYPTO_HW=yCONFIG_CRYPTO_DEV_OMAP4_AES=yCONFIG_CRYPTO_DEV_OMAP4_SHAM=y
## OCF Configuration#CONFIG_OCF_OCF=y# CONFIG_OCF_RANDOMHARVEST is not setCONFIG_OCF_CRYPTODEV=yCONFIG_OCF_CRYPTOSOFT=y# CONFIG_OCF_OCFNULL is not set# CONFIG_OCF_BENCH is not set# CONFIG_BINARY_PRINTF is not set
## Library routines#CONFIG_BITREVERSE=yCONFIG_CRC_CCITT=yCONFIG_CRC16=yCONFIG_CRC_T10DIF=yCONFIG_CRC_ITU_T=yCONFIG_CRC32=yCONFIG_CRC7=yCONFIG_LIBCRC32C=y# CONFIG_CRC8 is not setCONFIG_ZLIB_INFLATE=yCONFIG_ZLIB_DEFLATE=yCONFIG_LZO_COMPRESS=yCONFIG_LZO_DECOMPRESS=yCONFIG_XZ_DEC=yCONFIG_XZ_DEC_X86=yCONFIG_XZ_DEC_POWERPC=yCONFIG_XZ_DEC_IA64=yCONFIG_XZ_DEC_ARM=yCONFIG_XZ_DEC_ARMTHUMB=yCONFIG_XZ_DEC_SPARC=yCONFIG_XZ_DEC_BCJ=y# CONFIG_XZ_DEC_TEST is not setCONFIG_DECOMPRESS_GZIP=yCONFIG_DECOMPRESS_BZIP2=yCONFIG_DECOMPRESS_LZMA=yCONFIG_DECOMPRESS_XZ=yCONFIG_DECOMPRESS_LZO=yCONFIG_GENERIC_ALLOCATOR=yCONFIG_HAS_IOMEM=yCONFIG_HAS_IOPORT=yCONFIG_HAS_DMA=yCONFIG_NLATTR=yCONFIG_AVERAGE=y# CONFIG_CORDIC is not set
