Tool/software: TI-RTOS
Testing with a new (to us) SKAM437X starting with TI examples results in issues we have not been able to understand. We have started by building the TI furnished examples.
The "task_SK_AM437X_CortexA" example fails at the start of debugging with the "Device is held in reset....." error. The benchmark, clock, and hello examples all debug successfully. The onboard XDS100v2 debugger is used. All projects are downloaded from Resource Explorer Classic from the SK_AM437X . CortexA, GNU, Generic Examples and are not modified. Other examples also fail.
Many repeat over multiple days Tried power cycles, holding Power On button until debug start , always with same results. The projects which work, always work. The projects which fail, always fail.
Intended use of example project is the initial base from which to build a TI-RTOS project to support existing TI_Tiva system with Ethernet communications, computation, etc.
CCS 8.2.0.00007. SYS/BIOS 6.73.1.101 XDC 3.51.1.18_core.
Forum searches note similar issues, but I did not see a post where some CCS projects always work, and yet other CCS projects had the "Device Held in Reset" error. The fact that some example projects always work would seem to eliminate hardware issues.
Any assistance would, of course, be greatly appreciated.
Randy
