Hello team,
Customer is having a reliability problem with the 2nd 1G port on the DM648 after boot.
Do we have any errata documents on the 1G ports for the DM648?
Do we have a newer version on the boot loader code for customer to review?
Sepeedah
Here is a file list of the main files:
KAILASH_ethernetboot.c
bethpr.c
btblpr.c
ethmain.c
rtx.c
common.c
Here is the header and footer of file KAILASH_ethernetboot.c:
* Copyright (c) Texas Instruments Inc 2002, 2003, 2004
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied.
/** @file KAILASH_ethernetboot.c
* @brief File contains dummy code for Ethernet-MAC boot option KAILASH_performEthernetBoot()
* Description
* - The @a KAILASH_performEthernetBoot() function definition & it's associated functions
* Modification 1
* - Created on: Jan 17, 2006
* - Reason: created the sources
* @author anonymous
// Revision History:
// 2007-Jan-03 - Removed BLOCK bit enable in UNICAST ALE entry for own
// MAC address, Removed second call to ethernetOpenDevice
// since this is already called from standard boot kernel
// 2007-Jan-07 - Added power domain to call to kailash_powerUp function
// 2007-Apr-13 - Updated SerDes TX/RX and added CFGPLL settings
// 2007-Apr-17 - Updated comments and SerDes RX configuration values
// 2007-May-4 - Modified code for ESS boot as standalone code for
// testing ESS-HPI boot workaround.
