Other Parts Discussed in Thread: TIDEP-0097,
Dear TI Team,
please could you take a look into the customer question below.
- Part number used in TIDEP-0097 : MT41K512M16HA-125 AIT:A : SDRAM - DDR3L Memory IC 8Gb (512M x 16) Parallel 800MHz 13.5ns 96-FBGA (14x9)
- Alternate Part number used at customer project : MT41K512M16VRP-107 IT:P : DRAM Chip DDR3L SDRAM 8Gbit 512Mx16 1.35V 96-Pin TFBGA; DDR3 memory suggested by Distribution.
I ask you to clarify on our below mentioned questions;
- Does this alternate DDR3L MT41K512M16VRP-107 IT:P suitable to DRA718BJGCBDRQ1 with existing SDK support or we need to do some modifications on SW?
- If we need to do some modification in existing SDK TI SW, does TI supports for the same ?, and what types of modifications are required in SDK?, Need clarifications for the same.
- Does DRA718BJGCBDRQ1 support Twin Die DDR3L memory or not?
- Does DRA718BJGCBDRQ1 support 1.07ns@CL=13 (DDR3-1866) or not?
- Routing guidelines for the DDR3 signals in order to decrease the latency with the mentioned DDR3 memory Part No. MT41K512M16VRP-107 IT:P .
- is there any other guideline need to follow during PCB layout for smooth integration of new DDR3L memory?
Thanks and best regards
Jens
