Other Parts Discussed in Thread: TPS51200, DRA77P
We have built a PCB based on the DRA77P. We have made the power supply for the RAM based on the VAYU EVM PCB: the TPS77112 and the TPS51200. We have built a network of power good that controls the PORz. This network includes:
- PMIC O917A154TRGZTQ1 RESET_OUT,
- power good of the TPS57112,
- power good of the TPS51200DRCRG4 and
- power good of a regulator that feeds the VDDSHV2 to 1V8 (recently added after this post:
We are currently seeing a very strange behavior: when making an attempt to update the system (android) through USB3.0, the net of power good, which controls the PORZ, drops unexpectedly. From the SW side there is no trace as it is a HW reset. The problem has been solved after removing the power good of the TPS57112 and the TPS51200DRCRG4 from the general power good net. We have done this since we have seen that the VAYU EVM does not include the power good of the TPS57112 and the TPS51200DRCRG4 to the line that controls the PORZ.
The problem we have has been solved, however we do not understand why and we are not sure that it is a correct solution.
The questions:
- Who should control the PORz? Our criteria has been: release the PORz after all supplies reach valid operating levels.
- What is the relationship between the power good of the TPS57112 and the USB3.0? Is it possible that the TPS57112 drops the power good due to a high current requirement when trying to update the SW?
Greetings,
