Other Parts Discussed in Thread: TPS659039-Q1, DRA742, DRA752
HI,Experts
SDK:PROCESSOR_SDK_VISION_03_05_00_00
PMU is changed from tps659039-q1 (o9039a387izwsrq1) to o9039a385izwsrq1. The abnormal log will appear in Linux system and Insert TF Card,
Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
log:
root@dra7xx-evm:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA742
[ 0.000000] DRA752 ES2.0
[ 0.000000] powerdomain: ipu_pwrdm: waited too long to complete transition
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef628000 s14912 r8192 d21952 u45056
[ 0.462908] edma 43300000.edma: memcpy is disabled
[ 0.467776] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.472269] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.472458] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.472627] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.472787] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.473078] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.473267] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.476342] palmas 0-0058: IRQ missing: skipping irq request
[ 0.490727] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.562848] pcf857x: probe of 0-0020 failed with error -121
[ 0.563108] pcf857x: probe of 0-0021 failed with error -121
[ 0.563269] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.581442] omap_i2c 48072000.i2c: controller timed out
[ 1.601471] pcf857x: probe of 1-0026 failed with error -110
[ 1.601622] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.602002] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.602935] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.603147] media: Linux media interface: v0.10
[ 1.603199] Linux video capture interface: v2.00
[ 2.143322] NET: Registered protocol family 10
[ 2.154143] sit: IPv6 over IPv4 tunneling driver
[ 2.154696] NET: Registered protocol family 17
[ 2.154915] Key type dns_resolver registered
[ 2.155120] omap_voltage_late_init: Voltage driver support not added
[ 2.156451] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.156461] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.156513] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.173854] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48464000.mcasp mapping ok
[ 2.185807] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.185818] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.185871] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.187470] hctosys: unable to open rtc device (rtc0)
[ 2.199723] evm_1v8: disabling
[ 2.199738] aic_dvdd: disabling
[ 2.199965] ldousb: disabling
[ 2.200337] clk: Not disabling unused clocks
[ 2.200353] ALSA device list:
[ 2.200360] #0: DRA7xx-EVM
[ 2.201256] Waiting for root device PARTUUID=3309d28b-03...
[ 2.221159] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.221234] mmc0: new SDHC card at address 0001
[ 2.231727] mmcblk0: mmc0:0001 SD8GB 7.29 GiB
[ 2.239932] mmcblk0: p1 p2 p3 p4 < p5 p6 p7 p8 p9 >
[ 2.241780] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.241790] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.241844] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.282170] mmc1: MAN_BKOPS_EN bit is not set
[ 2.284712] mmc1: new DDR MMC card at address 0001
[ 2.285172] mmcblk1: mmc1:0001 8GUF4R 7.28 GiB
[ 2.295430] mmcblk1boot0: mmc1:0001 8GUF4R partition 1 31.9 MiB
[ 2.305678] mmcblk1boot1: mmc1:0001 8GUF4R partition 2 31.9 MiB
[ 2.307580] mmcblk1: p1 p2 p3 p4 < p5 p6 p7 p8 p9 >
[ 2.310116] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.310127] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.310177] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.669234] EXT4-fs (mmcblk0p3): recovery complete
[ 2.675734] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 2.675770] VFS: Mounted root (ext4 filesystem) on device 179:3.
[ 2.676644] devtmpfs: mounted
[ 2.676873] Freeing unused kernel memory: 336K
[ 2.676880] This architecture does not have kernel memory protection.
[ 3.131793] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[ 3.230252] EXT4-fs (mmcblk0p5): recovery complete
[ 3.234614] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.262615] EXT4-fs (mmcblk0p6): recovery complete
[ 3.262633] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.270254] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 3.302528] EXT4-fs (mmcblk0p9): recovery complete
[ 3.302547] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 3.339115] usbcore: registered new interface driver usbfs
[ 3.339176] usbcore: registered new interface driver hub
[ 3.339297] usbcore: registered new device driver usb
[ 3.430539] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.430553] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.430618] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 3.432280] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.432291] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.432342] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 3.457290] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.457302] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.457355] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 3.459586] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.459596] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.459643] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 3.524688] DMA: Module install successful, device major num = 243
[ 3.524698]
@dra7xx-evm:# [ 5335.603009] mmc0: host does not support reading read-only switch, assuming write-enable
[ 5335.605980] mmc0: new high speed SDHC card at address 0001
[ 5335.607082] mmcblk0: mmc0:0001 SD8GB 7.29 GiB
[ 5335.615420] mmcblk0: p1 p2 p3 p4 < p5 p6 p7 p8 p9 >
[ 5335.618288] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5335.619082] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5335.619914] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
